- 08-IP Multicast Command Reference
- 01-IGMP Snooping Commands
- 02-PIM Snooping Commands
- 03-Multicast VLAN Commands
- 04-Multicast Routing and Forwarding Commands
- 05-IGMP Commands
- 06-PIM Commands
- 07-MSDP Commands
- 08-MBGP Commands
- 09-Multicast VPN Commands
- 10-MLD Snooping Commands
- 11-IPv6 PIM Snooping Commands
- 12-IPv6 Multicast VLAN Commands
- 13-IPv6 Multicast Routing and Forwarding Commands
- 14-MLD Commands
- 15-IPv6 PIM Commands
- 16-IPv6 MBGP Commands
| 05-IGMP Commands | 271.31 KB |
display igmp ssm-mapping group
display igmp ssm-mapping host interface
igmp last-member-query-interval
igmp timer other-querier-present
last-member-query-interval (IGMP view)
require-router-alert (IGMP view)
startup-query-count (IGMP view)
startup-query-interval (IGMP view)
timer other-querier-present (IGMP view)
NOTE: · The term router in this document refers to both routers and Layer 3 switches. · The switch operates in IRF or standalone (the default) mode. For more information about the IRF mode, see IRF Configuration Guide. |
display igmp group
display igmp [ all-instance | vpn-instance vpn-instance-name ] group [ group-address | interface interface-type interface-number ] [ static | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all-instance: Specifies all MPLS L3VPNs.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN, where vpn-instance-name is a case-sensitive string of 1 to 31 characters.
group-address: Multicast group address, in the range of 224.0.1.0 to 239.255.255.255. If you do not specify this argument, the command displays the IGMP group information of all multicast groups.
interface interface-type interface-number: Displays the IGMP group information about a particular interface. If you do not specify interface-type interface-number, this command displays the IGMP group information on all interfaces.
static: Displays the information of statically joined IGMP groups. If you do not specify this keyword, the command displays only dynamic group entries of IGMP groups.
verbose: Displays the detailed information of IGMP groups.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display igmp group command to display IGMP group information.
If neither all-instance nor vpn-instance is specified, this command displays the IGMP group information in the public network.
# Display the dynamic group entries of IGMP groups on all interfaces in the public network.
<Sysname> display igmp group
Total 3 IGMP Group(s).
Interface group report information of VPN-Instance: public net
Vlan-interface200(10.10.1.20):
Total 3 IGMP Groups reported
Group Address Last Reporter Uptime Expires
225.1.1.1 10.10.1.10 00:02:04 00:01:15
225.1.1.3 10.10.1.10 00:02:04 00:01:15
225.1.1.2 10.10.1.10 00:02:04 00:01:17
# Display the detailed information of the dynamic entries of IGMP group 225.1.1.1 in the public network.
<Sysname> display igmp group 225.1.1.1 verbose
Vlan-interface200 (10.10.1.20):
Group: 225.1.1.1
Uptime: 00:00:34
Expires: 00:00:40
Last reporter: 10.10.1.10
Last-member-query-counter: 0
Last-member-query-timer-expiry: off
Group mode: exclude
Version1-host-present-timer-expiry: off
Version2-host-present-timer-expiry: off
Table 1 Output description
Interface group report information of VPN-Instance: public net |
IGMP group information on a public network interface. |
Group |
Multicast group address. |
Uptime |
Length of time since the multicast group was reported. |
Expires |
Remaining time of the multicast group, where “off” means that the multicast group never times out. |
Last reporter |
Address of the last host that reported its membership for this multicast group. |
Last-member-query-counter |
Number of last-member queries sent. |
Last-member-query-timer-expiry |
Remaining time of the last member query timer, where “off” means that the timer never expires. |
Group mode |
Multicast source filtering modes: · include · exclude This field is displayed only when the device is running IGMPv3. |
Version1-host-present-timer-expiry |
Remaining time of the IGMPv1 host present timer, where “off” means that the timer never expires. |
Version2-host-present-timer-expiry |
Remaining time of the IGMPv2 host present timer, where “off” means that the timer never expires. This field is displayed only when the device is running IGMPv3. |
display igmp group port-info
Standalone mode:
display igmp group port-info [ vlan vlan-id ] [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display igmp group port-info [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-id: VLAN ID, in the range of 1 to 4094. If you do not specify a VLAN, this command displays the Layer 2 port information of IGMP groups in all VLANs.
slot slot-number: Displays the Layer 2 port information of IGMP groups on the card specified by its slot number. If no slot is specified, the command displays the Layer 2 port information of IGMP groups on the main board. (Standalone mode)
chassis chassis-number slot slot-number: Displays the Layer 2 port information of IGMP groups on a card on an IRF member device. The chassis-number argument refers to the ID of the IRF member device, and the slot-number argument refers to the number of the slot where the card resides. If this option is not specified, the Layer 2 port information of IGMP groups on all main boards in the IRF member device is displayed. To obtain the chassis number and slot number, you can use the display device command. (IRF mode)
verbose: Displays the detailed information about Layer 2 ports of IGMP groups.
Use the display igmp group port-info command to display Layer 2 port information of IGMP groups, including both dynamic and static Layer 2 port entries.
# Display detailed Layer 2 port information of IGMP groups.
<Sysname> display igmp group port-info slot 3 verbose
Total 1 IP Group(s).
Total 1 IP Source(s).
Total 1 MAC Group(s).
Port flags: D-Dynamic port, S-Static port, C-Copy port
Subvlan flags: R-Real VLAN, C-Copy VLAN
Vlan(id):4000.
Router port unit board: Mask(0x0)
Router port(s):total 0 port(s)..
IP group(s):the following ip group(s) match to one mac group.
IP group address:225.1.1.1
(0.0.0.0, 225.1.1.1):
Attribute: Host Port
Host port unit board: Mask(0x0)
Host port(s):total 1 port(s)..
GE3/0/23 (D) ( 00:01:28 )
MAC group(s):
MAC group address:0100-5e01-0101
Host port(s):total 1 port.
Table 2 Output description
Total 1 IP Group(s). |
Total number of IP multicast groups |
Total 1 IP Source(s). |
Total number of IP multicast sources |
Total 1 MAC Group(s). |
Total number of MAC multicast groups |
Port flags: D-Dynamic port, S-Static port, C-Copy port |
Port flags: D for a dynamic port, S for a static port, and C for a port copied from a (*, G) entry to an (S, G) entry |
Subvlan flags: R-Real VLAN, C-Copy VLAN |
Sub-VLAN flags: R for a real egress sub-VLAN under the current entry, and C for a sub-VLAN copied from a (*, G) entry to an (S, G) entry |
Router port(s) |
Number of router ports |
Router port unit board |
Mask indicating a board with a router port residing on it |
( 00:01:28 ) |
Remaining time of the aging timer for the dynamic member port or router port: · In standalone mode, to display the remaining life of a non-aggregation port that does not belong to the main board, you must specify the number of the slot where the corresponding card resides by using slot slot-number. This is not required for an aggregation port. · In IRF mode, to display the remaining life of a non-aggregation port that does not belong to the main board, you must specify the member ID of the IRF member device and the slot number of the card with chassis chassis-number slot slot-number. For an aggregation port, you do not need to do this. |
IP group address |
Address of the IP multicast group |
MAC group address |
Address of the MAC multicast group |
Attribute |
Attribute of the IP multicast group |
Host port unit board |
Mask indicating a board with a member port residing on it |
Host port(s) |
Number of member ports |
display igmp host interface
display igmp host interface interface-type interface-number group group-address [ source source-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Displays information about the hosts tracked by IGMP on the specified interface.
group group-address: Displays information about the hosts tracked by IGMP that are in the specified IGMP group. The value of group-address ranges from 224.0.1.0 to 239.255.255.255.
source source-address: Displays information about the hosts tracked by IGMP that are in the specified multicast source, where source-address is a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
Use the display igmp host interface command to display information about the hosts tracked by IGMP on the specified interface.
# Display information about the hosts tracked by IGMP in multicast group 224.1.1.1 on GigabitEthernet 3/0/1.
<Sysname> display igmp host interface GigabitEthernet 3/0/1 group 224.1.1.1
Host information of VPN-Instance: public net
GigabitEthernet3/0/1(192.168.1.1):
(0.0.0.0, 224.1.1.1)
Host Uptime Expires
1.1.1.1 00:02:20 00:00:40
2.2.2.2 00:02:21 00:00:39
Table 3 Output description
Host information of VPN-Instance: public net |
Information about the hosts tracked by IGMP on the public network interface. |
GigabitEthernet3/0/1(192.168.1.1) |
Interface and IP address. |
(0.0.0.0, 224.1.1.1) |
(S, G) entry, where 0.0.0.0 indicates all multicast sources. |
Host |
Host IP address. |
Uptime |
Host running duration. |
Expires |
Host expiration time, where timeout means that the host has expired. |
display igmp host port-info
Standalone mode:
display igmp host port-info vlan vlan-id group group-address [ source source-address ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display igmp host port-info vlan vlan-id group group-address [ source source-address ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays information about the hosts tracked by IGMP on the Layer 2 ports in the specified VLAN, where vlan-id is in the range of 1 to 4094.
group group-address: Displays information about the hosts tracked by IGMP that join in the specified IGMP group on the Layer 2 ports. The value of group-address ranges from 224.0.1.0 to 239.255.255.255.
source source-address: Displays information about the hosts tracked by IGMP that join in the specified multicast source on the Layer 2 ports, where source-address is a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
slot slot-number: Displays information about the hosts tracked by IGMP on the Layer 2 ports on the card specified by its slot number. If no slot is specified, the command displays the Layer 2 information of the IGMP hosts on the main board. (Standalone mode)
chassis chassis-number slot slot-number: Displays information about the hosts tracked by IGMP on the Layer 2 ports on a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device, and the slot-number argument represents the number of the slot that holds the card. If this option is not specified, this command displays information about the hosts tracked by IGMP on the Layer 2 ports on all main boards in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (IRF mode)
Use the display igmp host port-info command to display information about the hosts tracked by IGMP on the Layer 2 ports.
# Display information about the hosts tracked by IGMP that join in IGMP group 224.1.1.1 on the Layer 2 ports in VLAN 2.
<Sysname> display igmp host port-info vlan 2 group 224.1.1.1
VLAN(ID) : 2
Port : GigabitEthernet3/0/1
Host Uptime Expires
Port : GigabitEthernet3/0/2
Host Uptime Expires
3.3.3.3 00:02:20 00:00:40
Table 4 Output description
VLAN(ID) |
VLAN ID. |
Port |
Member port. |
Host |
Host IP address. |
Uptime |
Expires |
display igmp interface
display igmp [ all-instance | vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Specifies an interface to display the IGMP configuration and operation information about. If no interface is specified, this command displays the related information of all IGMP-enabled interfaces.
verbose: Displays the detailed IGMP configuration and operation information.
Use the display igmp interface command to display IGMP configuration and operation information of the specified interface or all IGMP-enabled interfaces.
If neither all-instance nor vpn-instance is specified, this command displays the information in the public network.
# Display the IGMP configuration and operation information on VLAN-interface 300 (downstream interface) in the public network.
<Sysname> display igmp interface Vlan-interface200 verbose
IGMP is enabled
Current IGMP version is 2
Value of query interval for IGMP(in seconds): 60
Value of other querier present interval for IGMP(in seconds): 125
Value of maximum query response time for IGMP(in seconds): 10
Value of last member query interval(in seconds): 1
Value of startup query interval(in seconds): 15
Value of startup query count: 2
General query timer expiry (hours:minutes:seconds): 00:00:54
Querier for IGMP: 10.10.1.20 (this router)
IGMP activity: 1 joins, 0 leaves
Multicast routing on this interface: enabled
Robustness: 2
Require-router-alert: disabled
Fast-leave: disabled
Ssm-mapping: disabled
Startup-query-timer-expiry: off
Other-querier-present-timer-expiry: off
Proxying interface: Vlan-interface300(20.10.1.20)
Total 1 IGMP Group reported
# Display the detailed IGMP configuration and operation information on VLAN-interface 300 (upstream interface) in the public network.
<Sysname> display igmp interface Vlan-interface 300 verbose
Vlan-interface300(20.10.1.20):
IGMP proxy is enabled
Current IGMP version is 3
Version1-querier-present-timer-expiry: off
Version2-querier-present-timer-expiry: off
Table 5 Output description
Vlan-interface200 (10.10.1.20) |
Interface and IP address |
Current IGMP version |
Version of IGMP that runs on the interface |
Value of query interval for IGMP(in seconds) |
IGMP general query interval, in seconds |
Value of other querier present interval for IGMP(in seconds) |
Other querier present interval, in seconds |
Value of maximum query response time for IGMP(in seconds) |
Maximum response time for IGMP general queries, in seconds |
Value of last member query interval(in seconds) |
IGMP last member query interval, in seconds |
Value of startup query interval(in seconds) |
IGMP startup query interval, in seconds |
Value of startup query count |
Number of IGMP general queries the device sends on startup |
General query timer expiry |
Remaining time of the IGMP general query timer, where “off” means that the timer never expires |
Querier for IGMP |
IP address of the IGMP querier |
IGMP activity |
Statistics of IGMP activities (joins and leaves) |
Multicast routing on this interface |
Whether the multicast routing and forwarding function is enabled |
Robustness |
Robustness variable of the IGMP querier |
Require-router-alert |
Dropping IGMP messages without Router-Alert (enabled/disabled) |
Fast-leave |
Fast-leave processing status (enabled/disabled) |
Ssm-mapping |
IGMP SSM mapping status (enabled/disabled) |
Startup-query-timer-expiry |
Remaining time of the startup query timer, where “off” means that the timer never expires |
Other-querier-present-timer-expiry |
Remaining time of the other querier present timer, where “off” means that the timer never expires |
Proxying interface |
IGMP proxy interface, where “none” means that no proxy interface exists |
Total 1 IGMP Group reported |
Total number of IGMP groups the interface has dynamically joined |
IGMP proxy is enabled |
IGMP proxying is enabled |
Version1-querier-present-timer-expiry |
Remaining time of the IGMPv1 querier present timer, where “off” means that the timer never expires |
Version2-querier-present-timer-expiry |
Remaining time of the IGMPv2 querier present timer, where “off” means that the timer never expires |
display igmp proxying group
display igmp [ all-instance | vpn-instance vpn-instance-name ] proxying group [ group-address ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Multicast group address, in the range of 224.0.1.0 to 239.255.255.255. With no multicast group address included, this command displays the information of all the IGMP proxying groups.
verbose: Displays the detailed IGMP proxying group information.
Use the display igmp proxying group command to display the IGMP proxying group information.
# Display the IGMP proxying group information in the public network.
<Sysname> display igmp proxying group
Proxying group record(s) information of VPN-Instance: public net
Total 1 IGMP-Proxying group record(s)
Group Address Member state Expires
225.1.1.1 Delay 00:01:15
# Display the detailed information of IGMP proxying group 225.1.1.1 in the public network.
<Sysname> display igmp proxying group 225.1.1.1 verbose
Group: 225.1.1.1
Group mode: include
Member state: Delay
Expires: 00:00:02
Source list (total 1 source(s))
Source: 1.1.1.1
Table 6 Output description
Proxying group record(s) information of VPN-Instance: public net |
IGMP proxying group information in the public network. |
Total 1 IGMP-Proxying group record(s) |
One IGMP proxying group is recorded. |
Group Address/Group |
Member state |
Host member states: · Delay · Idle |
Expires |
Group mode |
Multicast source filtering modes: · Include · Exclude |
Source list |
A list of sources joining the same multicast group in the IGMP proxying group. |
display igmp routing-table
display igmp [ all-instance | vpn-instance vpn-instance-name ] routing-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | flags { act | suc } ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
source-address: Multicast source address.
mask: Subnet mask of the multicast group address or multicast source address, 255.255.255.255 by default.
mask-length: Subnet mask length of the multicast group address or multicast source address. For a multicast source address, this argument has an effective value range of 0 to 32. For a multicast group address, this argument has an effective value range of 4 to 32. The system default is 32 in both cases.
flags: Specifies the route flag.
act: Displays the IGMP routes with the ACT flag.
suc: Displays the IGMP routes with the SUC flag.
Use the display igmp routing-table command to display the IGMP routing table information.
# Display IGMP routing table information in the public network.
<Sysname> display igmp routing-table
Routing table of VPN-Instance: public net
Total 2 entries
00001. (*, 225.1.1.1)
List of 1 downstream interface
Vlan-interface200(20.1.1.1),
Protocol: STATIC
00002. (1.1.1.1, 225.1.1.1), Flag: ACT
List of 1 downstream interface in include mode
Vlan-interface300 (30.1.1.1),
Protocol: IGMP
00003. (*, 239.255.255.250)
Vlan-interface200(20.20.20.20),
Protocol: IGMP
Table 7 Output description
Routing table of VPN-Instance: public net |
Public network IGMP routing table |
00001 |
Sequence number of this (*, G) entry |
(*, 225.1.1.1) |
A (*, G) entry of the IGMP routing table |
Flag |
IGMP route flags: · ACT: Indicates IGMP routing entries that have been used for forwarding data packets but have the multicast group address out of the SSM group range · SUC: Indicates IGMP routing entries that have been added to the forwarding table and have the multicast group address within the SSM group range |
List of 1 downstream interface |
Downstream interface list, namely, the interfaces to which multicast data for this group will be forwarded |
in include mode |
The downstream interface is in the include mode |
in exclude mode |
The downstream interface is in the exclude mode |
Downstream interface is none |
No downstream interfaces exist |
Protocol |
Protocol type |
display igmp [ all-instance | vpn-instance vpn-instance-name ] ssm-mapping group-address [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Specifies a multicast group by its IP address, in the range of 224.0.1.0 to 239.255.255.255.
Use the display igmp ssm-mapping command to display the configured IGMP SSM mappings for the specified multicast group.
Related commands: ssm-mapping.
# Display the IGMP SSM mappings for multicast group 232.1.1.1 in the public network.
<Sysname> display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
1.2.3.4
5.5.5.5
10.1.1.1
100.1.1.10
Table 8 Output description
Public network |
Group |
Multicast group address |
Source list |
List of multicast source addresses |
display igmp [ all-instance | vpn-instance vpn-instance-name ] ssm-mapping group [ group-address | interface interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Specifies a multicast group by its IP address, in the range of 224.0.1.0 to 239.255.255.255. If you do not specify any multicast group, the command displays the information of all multicast groups created based on the configured IGMP SSM mappings.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify any interface, the command displays the multicast group information created based on the configured IGMP SSM mappings on all the interfaces.
verbose: Displays the detailed multicast group information created based on the configured IGMP SSM mappings.
Use the display igmp ssm-mapping group command to display the multicast group information created based on the configured IGMP SSM mappings.
# Display the detailed information of multicast group 232.1.1.1 created based on the configured IGMP SSM mappings in the public network.
<Sysname> display igmp ssm-mapping group 232.1.1.1 verbose
Vlan-interface200(10.10.10.10):
Total 1 IGMP SSM-mapping Group reported
Group: 232.1.1.1
Uptime: 00:00:31
Expires: off
Last reporter: 1.1.1.1
Source list(Total 1 source):
Source: 1.1.1.1
Uptime: 00:00:31
Expires: 00:01:39
Table 9 Output description
Multicast group information created based on IGMP SSM mappings on a public network interface. |
Total 1 IGMP SSM-mapping Group reported |
One IGMP SSM mapping multicast group was reported. |
Group |
Uptime |
Expires |
Last reporter |
Source list(Total 1 source) |
Multicast source list (one multicast source). |
Source |
Multicast source address. |
display igmp ssm-mapping host interface interface-type interface-number group group-address source source-address [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Displays information about the hosts that join a multicast group based on the IGMP SSM mappings on the specified interface.
group group-address: Displays information about the hosts that join the specified multicast group based on the IGMP SSM mappings. The value of group-address ranges from 224.0.1.0 to 239.255.255.255.
source source-address: Displays information about the hosts that join the specified multicast source based on the IGMP SSM mappings, where source-address is a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
Use the display igmp ssm-mapping host interface command to display information about the hosts that join a multicast group based on the IGMP SSM mappings on an interface.
# Displays information about the hosts that join multicast source group (10.1.1.1, 224.1.1.1) based on the IGMP SSM mappings on GigabitEthernet 3/0/1.
<Sysname> display igmp ssm-mapping host interface GigabitEthernet 3/0/1 group 224.1.1.1 source 10.1.1.1
Host Uptime Expires
Table 10 Output description
Information about the hosts that join the group based on the IGMP SSM mappings on public network interface. |
(10.1.1.1, 224.1.1.1) |
(S, G) entry. |
Host |
Host IP address. |
Uptime |
Expires |
fast-leave (IGMP view)
fast-leave [ group-policy acl-number ]
undo fast-leave
View
Public network IGMP view, VPN instance IGMP view
Default level
2: System level
acl-number: Basic ACL number, in the range of 2000 to 2999. The fast-leave processing function takes effect only for the multicast groups that match the permit statement in the ACL. If you do not include this option in your command, this command takes effect for all multicast groups.
Use the fast-leave command to configure fast-leave processing globally.
Use the undo fast-leave command to disable fast-leave processing globally.
By default, fast-leave processing is disabled. Namely, the IGMP querier sends IGMP group-specific queries or IGMP group-and-source-specific queries after receiving an IGMP leave message from a host, instead of sending a leave notification directly to the upstream.
In IGMP view, this command takes effect on only Layer 3 interfaces except VLAN interfaces.
Related commands: igmp fast-leave and last-member-query-interval.
# Enable fast-leave processing globally in the public network.
[Sysname] igmp
[Sysname-igmp] fast-leave
# Enable fast-leave processing globally in VPN instance mvpn.
[Sysname] igmp vpn-instance mvpn
[Sysname-igmp-mvpn] fast-leave
host-tracking (IGMP view)
host-tracking
undo host-tracking
View
Default level
2: System level
None
Use the host-tracking command to enable the IGMP host tracking function globally.
Use the undo host-tracking command to disable the IGMP host tracking function globally.
By default, this function is disabled.
Related command: igmp host-tracking.
# Enable the IGMP host tracking function globally in the public network.
[Sysname] igmp
[Sysname-igmp] host-tracking
# Enable the IGMP host tracking function globally in VPN instance mvpn.
[Sysname-igmp-mvpn] host-tracking
igmp
igmp [ vpn-instance vpn-instance-name ]
undo igmp [ vpn-instance vpn-instance-name ]
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If this option is not specified, the command applies to the public network.
Use the igmp command to enter public network IGMP view or VPN instance IGMP view .
Use the undo igmp command to remove configurations in public network IGMP view or VPN instance IGMP view.
IP multicast routing must be enabled in the corresponding instance before this command can take effect.
Related commands: igmp enable and multicast routing-enable.
# Enable IP multicast routing in the public network and enter public network IGMP view.
[Sysname] multicast routing-enable
[Sysname] igmp
[Sysname-igmp]
# Enable IP multicast routing in VPN instance mvpn and enter IGMP view for VPN instance mvpn.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
[Sysname-vpn-instance-mvpn] quit
[Sysname-igmp-mvpn]
igmp enable
undo igmp enable
View
Interface view
Default level
2: System level
None
Use the igmp enable command to enable IGMP on the current interface.
Use the undo igmp enable command to disable IGMP on the current interface.
By default, IGMP is disabled on all interfaces.
IGMP must be enabled on an interface before any other IGMP feature configured on the interface can take effect.
This command is not supported in tunnel interface view.
Related commands: igmp and multicast routing-enable.
# Enable IP multicast routing in the public network, and then enable IGMP on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp enable
igmp fast-leave
igmp fast-leave [ group-policy acl-number ]
undo igmp fast-leave
View
Interface view
Default level
2: System level
Use the igmp fast-leave command to configure fast-leave processing on the current interface.
Use the undo igmp fast-leave command to disable fast-leave processing on the current interface.
The igmp fast-leave command cannot be used in VLAN-interface view. To enable fast-leave processing on a specific Layer 2 port, use the igmp-snooping fast-leave command or the fast-leave (IGMP-snooping view) command, because these two commands are effective on VLANs with IGMP enabled on their VLAN interfaces.
Related commands: fast-leave (IGMP view), fast-leave (IGMP-snooping view), igmp last-member-query-interval, and igmp-snooping fast-leave.
# Enable fast-leave processing on GigabitEthernet 3/0/1.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] port link-mode route
[Sysname-GigabitEthernet3/0/1] igmp fast-leave
igmp group-limit
igmp group-limit limit
undo igmp group-limit
View
Interface view
Default level
2: System level
limit: Maximum number of multicast groups that an interface can join. The value ranges from 1 to 1024.
Use the igmp group-limit command to configure the maximum number of multicast groups that an interface can join.
Use the undo igmp group-limit command to restore the default.
By default, the upper limit is 1024.
This command is effective only for dynamically joined multicast groups but not statically joined multicast groups.
If the configured limit value is smaller than the number of the existing multicast groups on the current interface, the system does not automatically remove the multicast groups in excess. To bring this configuration into effect in this case, you need to use the reset igmp group command to clear the IGMP group information manually.
You can also use the igmp-snooping group-limit command to limit the number of multicast groups that an interface can join. However, if you configure the limit both on a VLAN and on a VLAN interface of this VLAN by using these two commands, inconsistencies might exist between Layer 2 and Layer 3 table entries. Therefore, H3C recommends you to configure the limit only on the VLAN interface.
Related commands: igmp static-group, igmp-snooping group-limit, and reset igmp group.
# Allow VLAN-interface 100 to join up to 128 multicast groups.
[Sysname-Vlan-interface100] igmp group-limit 128
igmp group-policy
igmp group-policy acl-number [ version-number ]
undo igmp group-policy
View
Interface view
Default level
2: System level
acl-number: Basic or advanced ACL number, in the range of 2000 to 3999. A host can join only the multicast groups that match the permit statement in the ACL. The source address or address range specified in the advanced ACL rule matches the multicast source address or addresses specified in IGMPv3 reports, rather than the source address in the IP packets. The system assumes that an IGMPv1 or IGMPv2 report or an IGMPv3 IS_EX and TO_EX report that does not carry a multicast source address carries a multicast source address of 0.0.0.0.
version-number: IGMP version, in the range of 1 to 3. If you do not specify an IGMP version, the configured group filter will apply to IGMP reports of all versions.
Use the igmp group-policy command to configure a multicast group filter on the current interface to control the multicast groups that the hosts on the current interface can join.
Use the undo igmp group-policy command to remove the configured multicast group filter.
By default, no multicast group filter is configured. Namely, a host can join any valid multicast group.
You can also use the group-policy (IGMP-snooping view) command to control the multicast groups that hosts in a VLAN can join, achieving the same result as igmp group-policy. If you have configured a multicast group filter on a VLAN interface to control the multicast groups that the hosts on the interface can join, configure the same multicast group filter in the corresponding VLAN.
This command does not take effect on statically joined multicast groups.
Related commands: group-policy (IGMP-snooping view).
# Configure an ACL rule so that hosts on VLAN-interface 100 can join multicast group 225.1.1.1 only.
[Sysname] acl number 2005
[Sysname-acl-basic-2005] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2005] quit
[Sysname-Vlan-interface100] igmp group-policy 2005
igmp host-tracking
igmp host-tracking
undo igmp host-tracking
View
Interface view
Default level
2: System level
None
Use the igmp host-tracking command to enable the IGMP host tracking function on an interface.
Use the undo igmp host-tracking command to disable the IGMP host tracking function on an interface
Related commands: host-tracking.
# Enable the IGMP host tracking function on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp host-tracking
igmp last-member-query-interval interval
undo igmp last-member-query-interval
View
Interface view
Default level
2: System level
interval: IGMP last member query interval in seconds, in the range of 1 to 5.
Use the igmp last-member-query-interval command to configure the last-member query interval, namely, the length of time that the device waits between sending IGMP group-specific queries, on the current interface.
Use the undo igmp last-member-query-interval command to restore the default.
By default, the IGMP last member query interval is 1 second.
Related commands: display igmp interface, igmp robust-count, and last-member-query-interval.
# Set the IGMP last member query interval to 3 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp last-member-query-interval 3
igmp max-response-time
igmp max-response-time interval
undo igmp max-response-time
View
Interface view
Default level
2: System level
interval: Maximum response time in seconds for IGMP general queries, in the range of 1 to 25.
Use the igmp max-response-time command to configure the maximum response time for IGMP general queries on the current interface.
Use the undo igmp max-response-time command to restore the default.
By default, the maximum response time for IGMP general queries is 10 seconds.
Related commands: display igmp interface, igmp timer other-querier-present, and max-response-time.
# Set the maximum response time for IGMP general queries to 8 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp max-response-time 8
igmp proxying enable
undo igmp proxying enable
View
Interface view
Default level
2: System level
None
Use the igmp proxying enable command to enable IGMP proxying on an interface.
Use the undo igmp proxying enable command to disable IGMP proxying on the interface.
By default, IGMP proxying is disabled.
This command takes effect only after IP multicast routing is enabled on the corresponding instance.
If IGMP proxying is enabled on a loopback interface, the proxy device maintains only the IGMP routing table without adding the IGMP routes to the multicast routing table and forwarding table.
Related commands: multicast routing-enable.
# Enable IP multicast routing in the public network and enable IGMP proxying on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp proxying enable
igmp proxying forwarding
undo igmp proxying forwarding
View
Interface view
Default level
2: System level
None
Use the igmp proxying forwarding command to enable a non-querier downstream interface to forward multicast traffic.
Use the undo igmp proxying forwarding command to disable the forwarding capability of a non-querier downstream interface.
By default, a non-querier downstream interface does not forward multicast traffic.
# Enable the multicast forwarding capability on VLAN-interface 100, a non-querier downstream interface on the IGMP proxy device.
[Sysname-Vlan-interface100] igmp proxying forwarding
igmp require-router-alert
undo igmp require-router-alert
View
Interface view
Default level
2: System level
None
Use the igmp require-router-alert command to configure the interface to discard IGMP messages that do not carry the Router-Alert option.
Use the undo igmp require-router-alert command to restore the default.
By default, the device does not check the Router-Alert option. Namely, it passes all the IGMP messages that it receives to the upper layer protocol for processing.
Related commands: igmp send-router-alert and require-router-alert.
# Configure VLAN-interface 100 to discard IGMP messages that do not carry the Router-Alert option.
[Sysname-Vlan-interface100] igmp require-router-alert
igmp robust-count
igmp robust-count robust-value
undo igmp robust-count
View
Interface view
Default level
2: System level
robust-value: IGMP querier’s robustness variable, in the range of 2 to 5.
Use the igmp robust-count command to configure the IGMP querier’s robustness variable on the current interface.
Use the undo igmp robust-count command to restore the default.
By default, the IGMP querier’s robustness variable is 2.
The IGMP querier’s robustness variable defines the maximum number of attempts for transmitting IGMP general queries, group-specific queries or group-and-source-specific queries in case of packet loss due to network problems. A greater value of the robustness variable makes the IGMP querier “more robust”, but results in a longer multicast group timeout time.
The IGMP querier’s robustness variable determines the following values:
· The default number of general queries the IGMPv1/v2/v3 querier sends on startup
· The number of IGMP group-specific queries the IGMPv2 querier sends after receiving an IGMP leave message.
· The number of IGMP group-and-source-specific queries that the IGMPv3 querier sends after receiving an IGMP report that tells relation changes between IPv6 multicast groups and IPv6 multicast sources.
Related commands: display igmp interface, igmp last-member-query-interval, igmp startup-query-count, igmp timer other-querier-present, igmp timer query, and robust-count.
# Set the IGMP querier’s robustness variable to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp robust-count 3
undo igmp send-router-alert
View
Interface view
Default level
2: System level
None
Use the igmp send-router-alert command on the current interface to enable insertion of the Router-Alert option in IGMP messages to be sent.
Use the undo igmp send-router-alert command on the current interface to disable insertion of the Router-Alert option in IGMP messages to be sent.
By default, IGMP messages are sent with the Router-Alert option.
Related commands: igmp require-router-alert and send-router-alert.
# Disable insertion of the Router-Alert option into IGMP messages that leave VLAN-interface 100.
[Sysname-Vlan-interface100] undo igmp send-router-alert
igmp ssm-mapping enable
undo igmp ssm-mapping enable
View
Interface view
Default level
2: System level
None
Use the igmp ssm-mapping enable command to enable the IGMP SSM mapping feature on the current interface.
Use the undo igmp ssm-mapping enable command to disable the IGMP SSM mapping feature on the current interface.
By default, the IGMP SSM mapping feature is disabled on all interfaces.
# Enable the IGMP SSM mapping feature on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp ssm-mapping enable
igmp startup-query-count value
undo igmp startup-query-count
View
Interface view
Default level
2: System level
value: Startup query count, namely, the number of queries the IGMP querier sends on startup, in the range of 2 to 5.
Use the igmp startup-query-count command to configure the startup query count on the current interface.
Use the undo igmp startup-query-count command to restore the default.
By default, the startup query count is set to the IGMP querier’s robustness variable.
Related commands: igmp robust-count and startup-query-count.
# Set the startup query count to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp startup-query-count 3
igmp startup-query-interval
igmp startup-query-interval interval
undo igmp startup-query-interval
View
Interface view
Default level
2: System level
interval: Startup query interval in seconds, namely, the interval between general queries that the IGMP querier sends on startup, in the range of 1 to 18000.
Use the igmp startup-query-interval command to configure the startup query interval on the current interface.
Use the undo igmp startup-query-interval command to restore the default.
By default, the startup query interval is 1/4 of the IGMP general query interval.
Related commands: igmp timer query and startup-query-interval.
# Set the startup query interval to 5 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp startup-query-interval 5
igmp static-group
igmp static-group group-address [ source source-address ]
undo igmp static-group { all | group-address [ source source-address ] }
View
Interface view
Default level
2: System level
all: Specifies to remove all static multicast groups that the current interface has joined.
Use the igmp static-group command to configure the current interface to be a statically connected member of the specified multicast group or multicast source and group.
Use the undo igmp static-group command to restore the default.
By default, an interface is not a static member of any multicast group or multicast source and group.
If the specified multicast address is in the SSM multicast address range, you must specify a multicast source address at the same time. Otherwise, IGMP routing table entries cannot be established. No such a restriction exists if the specified multicast group address is not in the SSM multicast address range.
If you want to configure a VLAN interface as a static member of a multicast group or multicast source and group, configure the igmp static-group command on the VLAN interface, and configure the igmp-snooping static-group command on the member ports of the corresponding VLAN.
Related commands: igmp-snooping static-group.
# Configure VLAN-interface 100 to be a statically connected member of multicast group 224.1.1.1.
[Sysname-Vlan-interface100] igmp static-group 224.1.1.1
# Configure VLAN-interface 100 to be a statically connected member of multicast source and group (192.168.1.1, 232.1.1.1).
[Sysname-Vlan-interface100] igmp static-group 232.1.1.1 source 192.168.1.1
igmp timer other-querier-present interval
undo igmp timer other-querier-present
View
Interface view
Default level
2: System level
interval: IGMP other querier present interval in seconds, in the range of 60 to 300.
Use the igmp timer other-querier-present command to configure the IGMP other querier present interval on the current interface.
Use the undo igmp timer other-querier-present command to restore the default.
By default, the IGMP other querier present interval is [ IGMP general query interval ] × [ IGMP querier’s robustness variable ] + [ maximum response time for IGMP general queries ] /2.
Related commands: display igmp interface, igmp max-response-time, igmp robust-count, igmp timer query, and timer other-querier-present.
# Set the IGMP other querier present interval to 200 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp timer other-querier-present 200
igmp timer query
igmp timer query interval
undo igmp timer query
View
Interface view
Default level
2: System level
interval: IGMP general query interval in seconds, namely, the interval between IGMP general queries, in the range of 1 to 18,000.
Use the igmp timer query command to configure the IGMP general query interval on the current interface.
Use the undo igmp timer query command to restore the default.
By default, the IGMP general query interval is 60 seconds.
Related commands: display igmp interface, igmp timer other-querier-present, and timer query.
# Set the IGMP general query interval to 125 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp timer query 125
igmp version
igmp version version-number
undo igmp version
View
Interface view
Default level
2: System level
Use the igmp version command to configure the IGMP version on the current interface.
Use the undo igmp version command to restore the default IGMP version.
The default IGMP version is version 2.
Related commands: version.
# Set the IGMP version to IGMPv1 on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp version 1
undo last-member-query-interval
View
Default level
2: System level
interval: Last-member query interval in seconds, in the range of 1 to 5.
Use the last-member-query-interval command to configure the global IGMP last-member query interval.
Use the undo last-member-query-interval command to restore the default.
By default, the IGMP last-member query interval is 1 second.
Related commands: display igmp interface, igmp last-member-query-interval, and robust-count.
# Set the global IGMP last-member interval to 3 seconds in the public network.
[Sysname] igmp
[Sysname-igmp] last-member-query-interval 3
# Set the global IGMP last-member interval to 3 seconds in VPN instance mvpn.
[Sysname-igmp-mvpn] last-member-query-interval 3
max-response-time (IGMP view)
undo max-response-time
View
Default level
2: System level
interval: Maximum response time for IGMP general queries in seconds, in the range of 1 to 25.
Use the max-response-time command to configure the maximum response time for IGMP general queries globally.
Use the undo max-response-time command to restore the default.
Related commands: display igmp interface, igmp max-response-time, and timer other-querier-present.
# Set the maximum response time for IGMP general queries to 8 seconds globally in the public network.
[Sysname] igmp
[Sysname-igmp] max-response-time 8
# Set the maximum response time for IGMP general queries to 8 seconds globally in VPN instance mvpn.
[Sysname-igmp-mvpn] max-response-time 8
undo require-router-alert
View
Default level
2: System level
None
Use the require-router-alert command to configure globally the router to discard IGMP messages that do not carry the Router-Alert option.
Use the undo require-router-alert command to restore the default.
By default, the device does not check the Router-Alert option. Namely, it passes all the IGMP messages that it received to the upper layer protocol for processing.
# Configure the router to discard IGMP messages that do not carry the Router-Alert option globally in the public network.
[Sysname] igmp
[Sysname-igmp] require-router-alert
[Sysname-igmp-mvpn] require-router-alert
reset igmp group
reset igmp [ all-instance | vpn-instance vpn-instance-name ] group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
View
Default level
2: System level
all: The first all specifies all interfaces, and the second all specifies all IGMP groups.
group-address: Multicast group address, in the range of 224.0.0.0 to 239.255.255.255.
mask-length: Subnet mask length of the multicast group address or multicast source address. For a multicast group address, this argument has an effective value range of 4 to 32. For a multicast source address, this argument has an effective value range of 0 to 32. The system default is 32 in both cases.
Use the reset igmp group command to remove the dynamic group entries of a specified IGMP group or all IGMP groups.
If neither all-instance nor vpn-instance is specified, this command removes the dynamic IGMP group entries on the public network.
This command cannot remove static IGMP group entries.
Related commands: display igmp group.
# Remove dynamic group entries of IGMP groups on all interfaces in the public network.
<Sysname> reset igmp group all
# Remove dynamic group entries of IGMP groups on VLAN-interface 100 in the public network.
<Sysname> reset igmp group interface vlan-interface 100 all
# Remove the dynamic IGMP group entry of IGMP group 225.0.0.1 on VLAN-interface 100 in the public network.
<Sysname> reset igmp group interface vlan-interface 100 225.0.0.1
reset igmp group port-info
reset igmp group port-info { all | group-address } [ vlan vlan-id ]
View
Default level
2: System level
all: Specifies all the IGMP groups.
group-address: Specifies an IGMP group. The value range of group-address is 224.0.1.0 to 239.255.255.255.
vlan-id: Specifies a VLAN. The value range of vlan-id is 1 to 4094.
Use the reset igmp group port-info command to remove dynamic Layer 2 port entries of a specified IGMP group or all IGMP groups.
Layer 2 ports for IGMP groups include member ports and router ports.
This command cannot remove static Layer 2 port entries of IGMP groups.
Related commands: display igmp group port-info.
# Remove dynamic Layer 2 port entries of all IGMP groups in all VLANs.
<Sysname> reset igmp group port-info all
# Remove dynamic Layer 2 port entries of all IGMP groups in VLAN 100.
<Sysname> reset igmp group port-info all vlan 100
# Remove dynamic Layer 2 port entries of multicast group 225.0.0.1 in VLAN 100.
<Sysname> reset igmp group port-info 225.0.0.1 vlan 100
reset igmp ssm-mapping group
reset igmp [ all-instance | vpn-instance vpn-instance-name ] ssm-mapping group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
View
Default level
2: System level
all: The first all specifies to clear multicast group information created based on the configured IGMP SSM mappings on all interfaces, and the second all specifies to clear all multicast group information created based on the configured IGMP SSM mappings.
group-address: Specifies a multicast group by its IP address, in the range of 224.0.0.0 to 239.255.255.255.
source-address: Specifies a multicast source by its IP address.
mask-length: Subnet mask length of the multicast group address or multicast source address. For a multicast group address, this argument has an effective value range of 4 to 32. For a multicast source address, this argument has an effective value range of 0 to 32. For both cases, the default value is 32.
Use the reset igmp ssm-mapping group command to clear multicast group information created based on the configured IGMP SSM mappings.
If neither all-instance nor vpn-instance is specified, this command will clear the information in the public network.
Related commands: display igmp ssm-mapping group.
# Clear all multicast group information created based on the configured IGMP SSM mappings on all interfaces in the public network.
<Sysname> reset igmp ssm-mapping group all
robust-count (IGMP view)
undo robust-count
View
Default level
2: System level
Use the robust-count command to configure the IGMP querier’s robustness variable globally.
Use the undo robust-count command to restore the default.
· The default number of general queries that the IGMPv1/v2/v3 querier sends on startup
· The number of IGMP group-specific queries that the IGMPv2 querier sends after receiving an IGMP leave message.
Related commands: display igmp interface, igmp robust-count, last-member-query-interval, startup-query-count, timer other-querier-present, and timer query.
# Set the IGMP querier’s robustness variable to 3 globally in the public network.
[Sysname] igmp
[Sysname-igmp] robust-count 3
# Set the IGMP querier’s robustness variable to 3 globally in VPN instance mvpn.
[Sysname-igmp-mvpn] robust-count 3
send-router-alert (IGMP view)
send-router-alert
undo send-router-alert
View
Default level
2: System level
None
Use the send-router-alert command to globally enable insertion of the Router-Alert option into IGMP messages to be sent.
Use the undo send-router-alert command to globally disable insertion of the Router-Alert option into IGMP messages to be sent.
By default, an IGMP message carries the Router-Alert option.
# Globally disable the insertion of the Router-Alert option in IGMP messages to be sent in the public network.
[Sysname] igmp
[Sysname-igmp] undo send-router-alert
# Globally disable the insertion of the Router-Alert option in IGMP messages to be sent in VPN instance mvpn.
[Sysname-igmp-mvpn] undo send-router-alert
ssm-mapping (IGMP view)
ssm-mapping group-address { mask | mask-length } source-address
undo ssm-mapping { group-address { mask | mask-length } source-address | all }
View
Default level
2: System level
mask: Subnet mask of the multicast group address.
mask-length: Subnet mask length of the multicast group address, in the range of 4 to 32.
all: Removes all IGMP SSM mappings.
Use the ssm-mapping command to configure an IGMP SSM mapping.
Use the undo ssm-mapping command to remove one or all IGMP SSM mappings.
By default, no IGMP SSM mappings are configured.
Related commands: display igmp ssm-mapping and igmp ssm-mapping enable.
# Configure an IGMP SSM mapping in the public network for multicast groups in the range of 225.1.1.0/24 and multicast source 125.1.1.1.
[Sysname] igmp
[Sysname-igmp] ssm-mapping 225.1.1.0 24 125.1.1.1
# Configure an IGMP SSM mapping in VPN instance mvpn for multicast groups in the range of 225.1.1.0/24 and multicast source 125.1.1.1.
[Sysname-igmp-mvpn] ssm-mapping 225.1.1.0 24 125.1.1.1
undo startup-query-count
View
Default level
2: System level
value: Startup query count, namely, the number of queries that the IGMP querier sends on startup, in the range of 2 to 5.
Use the startup-query-count command to configure the startup query count globally.
Use the undo startup-query-count command to restore the default.
Related commands: igmp startup-query-count and robust-count.
# Set the startup query count to 3 globally in the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-count 3
# Set the startup query count to 3 globally in VPN instance mvpn.
[Sysname-igmp-mvpn] startup-query-count 3
undo startup-query-interval
View
Default level
2: System level
Use the startup-query-interval command to configure the startup query interval globally.
Use the undo startup-query-interval command to restore the default.
By default, the startup query interval is 1/4 of the “IGMP general query interval”.
Related commands: igmp-startup-query-interval and timer query.
# Set the startup query interval to 5 seconds globally in the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-interval 5
# Set the startup query interval to 5 seconds globally in VPN instance mvpn.
[Sysname-igmp-mvpn] startup-query-interval 5
undo timer other-querier-present
View
Default level
2: System level
interval: IGMP other querier present interval, in the range of 60 to 300.
Use the timer other-querier-present command to configure the IGMP other querier present interval globally.
Use the undo timer other-querier-present command to restore the default.
Related commands: display igmp interface, igmp timer other-querier-present, max-response-time, robust-count, and timer query.
# Set the IGMP other querier present interval to 200 seconds globally in the public network.
[Sysname] igmp
[Sysname-igmp] timer other-querier-present 200
# Set the IGMP other querier present interval to 200 seconds globally in VPN instance mvpn.
[Sysname-igmp-mvpn] timer other-querier-present 200
timer query (IGMP view)
undo timer query
View
Default level
2: System level
interval: IGMP general query interval in seconds, namely, interval between IGMP general queries, in the range of 1 to 18,000.
Use the timer query command to configure the IGMP general query interval globally.
Use the undo timer query command to restore the default.
By default, IGMP general query interval is 60 seconds.
Related commands: display igmp interface, igmp timer query, and timer other-querier-present.
# Set the IGMP general query interval to 125 seconds globally in the public network.
[Sysname] igmp
[Sysname-igmp] timer query 125
# Set the IGMP general query interval to 125 seconds globally in VPN instance mvpn.
[Sysname-igmp-mvpn] timer query 125
version (IGMP view)
undo version
View
Default level
2: System level
Use the version command to configure the IGMP version globally.
Use the undo version command to restore the default.
Related commands: igmp version.
# Set the global IGMP version to IGMPv1 in the public network.
[Sysname] igmp
[Sysname-igmp] version 1
# Set the global IGMP version to IGMPv1 in VPN instance mvpn.
[Sysname-igmp-mvpn] version 1
