- 08-IP Multicast Command Reference
- 01-IGMP Snooping Commands
- 02-PIM Snooping Commands
- 03-Multicast VLAN Commands
- 04-Multicast Routing and Forwarding Commands
- 05-IGMP Commands
- 06-PIM Commands
- 07-MSDP Commands
- 08-MBGP Commands
- 09-Multicast VPN Commands
- 10-MLD Snooping Commands
- 11-IPv6 PIM Snooping Commands
- 12-IPv6 Multicast VLAN Commands
- 13-IPv6 Multicast Routing and Forwarding Commands
- 14-MLD Commands
- 15-IPv6 PIM Commands
- 16-IPv6 MBGP Commands
| 10-MLD Snooping Commands | 190.65 KB |
MLD snooping configuration commands
display mld-snooping statistics
entry-limit (MLD-snooping view)
fast-leave (MLD-snooping view)
group-policy (MLD-snooping view)
host-aging-time (MLD-snooping view)
host-tracking (MLD-snooping view)
last-listener-query-interval (MLD-snooping view)
max-response-time (MLD-snooping view)
mld-snooping general-query source-ip
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping router-aging-time
mld-snooping special-query source-ip
mld-snooping static-router-port
overflow-replace (MLD-snooping view)
report-aggregation (MLD-snooping view)
router-aging-time (MLD-snooping view)
NOTE: The switch operates in IRF or standalone (the default) mode. For more information about the IRF mode, see IRF Configuration Guide. |
display mld-snooping group
Standalone mode:
display mld-snooping group [ vlan vlan-id ] [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display mld-snooping group [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the MLD snooping group information in the specified VLAN, where vlan-id is in the range of 1 to 4094.
slot slot-number: Displays information about MLD snooping groups on the card specified by its slot number. If no slot is specified, the command displays the MLD snooping group information on the main board. (Standalone mode)
chassis chassis-number slot slot-number: Displays the information of MLD snooping groups on a card on an IRF member device. The chassis-number argument refers to the ID of the IRF member device, and the slot-number argument refers to the number of the slot where the card resides. If this option is not specified, the command displays the information of MLD snooping groups on all main boards in the IRF member device. To obtain the chassis number and slot number, you can use the display device command. (IRF mode)
verbose: Displays the detailed MLD snooping group information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display mld-snooping group command to display the MLD snooping group information, including both dynamic and static MLD snooping group entries. If you do not specify a VLAN, this command displays MLD snooping group information in all VLANs.
# Display detailed MLD snooping group information in VLAN 4000 on the card in slot 9 on IRF member device 1.
<Sysname> display mld-snooping group vlan 4000 chassis 1 slot 9 verbose
Total 1 IP Group(s).
Total 1 IP Source(s).
Total 1 MAC Group(s).
Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port
Subvlan flags: R-Real VLAN, C-Copy VLAN
Vlan(id):4000.
Router port unit board: Mask(0x0000000000000000)
Router port(s):total 0 port(s).
IP group(s):the following ip group(s) match to one mac group.
IP group address:FF1E::101
(::, FF1E::101):
Attribute: Host Port
Host port unit board: Mask(0x0000000000000000)
Host port(s):total 1 port(s).
GE1/9/0/48 (D) ( 00:03:35 )
MAC group(s):
MAC group address:3333-0000-0101
GE1/9/0/48
Table 1 Output description
Total 1 IP Group(s). |
Total 1 IP Source(s). |
Total number of IPv6 multicast sources. |
Total 1 MAC Group(s). |
Total number of MAC multicast groups. |
Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port |
Port flags: D—A dynamic port S—A static port C—A port copied from a (*, G) entry to an (S, G) entry P—A port that IPv6 PIM snooping adds |
Subvlan flags: R-Real VLAN, C-Copy VLAN |
Sub-VLAN flags: R for real egress sub-VLAN under the current entry, C for sub-VLAN copied from a (*, G) entry to an (S, G) entry. |
Router port unit board |
Mask indicating a board with a router port residing on it. |
Router port(s) |
Number of router ports. |
( 00:03:35 ) |
Remaining time of the aging timer for the dynamic member port or router port: · In standalone mode, to display the remaining life of a non-aggregation port that does not belong to the main board, you must specify the number of the slot where the corresponding card resides by using slot slot-number. This is not required for an aggregation port. · In IRF mode, to display the remaining life of a non-aggregation port that does not belong to the main board, you must specify the ID of the IRF member device and the slot number of the card with chassis chassis-number slot slot-number. For an aggregation port, you do not need to do this. |
IP group address |
Address of IPv6 multicast group. |
(::, FF1E::101) |
(S, G) entry, :: represents all the multicast sources. |
MAC group address |
Address of MAC multicast group. |
Attribute |
Attribute of IPv6 multicast group. |
Host port unit board |
Mask indicating a board with a member port residing on it. |
Host port(s) |
Number of member ports. |
display mld-snooping host
Standalone mode:
display mld-snooping host vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display mld-snooping host vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays information about the hosts tracked by MLD snooping in the specified VLAN, where vlan-id is in the range of 1 to 4094.
group ipv6-group-address: Displays information about the hosts tracked by MLD snooping that are in the specified IPv6 multicast group. The value of ipv6-group-address is in the range of FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where x and y represent any hexadecimal number ranging from 0 to F.
source ipv6-source-address: Displays information about the hosts tracked by MLD snooping that are in the specified IPv6 multicast source.
slot slot-number: Displays information about the hosts tracked by MLD snooping on the card specified by its slot number. If no slot is specified, the command displays the MLD snooping host information on the main board. (Standalone mode)
chassis chassis-number slot slot-number: Displays information about the hosts tracked by MLD snooping on a card in an IRF member device. The chassis-number argument refers to the ID of the IRF member device, and the slot-number argument refers to the number of the slot where the card resides. If this option is not specified, this command displays information about the MLD snooping tracked hosts on all main boards in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (IRF mode)
Use the display mld-snooping host command to display information about the hosts tracked by MLD snooping.
# Display information about the hosts tracked by MLD snooping in multicast group FF1E::101 in VLAN 2.
<Sysname> display mld-snooping host vlan 2 group ff1e::101
VLAN(ID) : 2
(::, FF1E::101)
Port : GigabitEthernet3/0/1
Host Uptime Expires
1::1 00:02:20 00:00:40
2::2 00:02:21 00:00:39
Port : GigabitEthernet3/0/2
Host Uptime Expires
3::3 00:02:20 00:00:40
Table 2 Output description
VLAN(ID) |
VLAN ID. |
(::, FF1E::101) |
(S, G) entry, where :: indicates all IPv6 multicast sources. |
Port |
Member port. |
Host |
Host IPv6 address. |
Uptime |
Host running duration. |
Expires |
Host expiration time, where timeout means that the host has expired. |
display mld-snooping statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display mld-snooping statistics command to display the statistics for MLD messages learned through MLD snooping.
# Display the statistics for all MLD messages learned through MLD snooping.
<Sysname> display mld-snooping statistics
Received MLD general queries:0.
Received MLDv1 specific queries:0.
Received MLDv1 reports:0.
Received MLD dones:0.
Sent MLDv1 specific queries:0.
Received MLDv2 reports:0.
Received MLDv2 reports with right and wrong records:0.
Received MLDv2 specific queries:0.
Received MLDv2 specific sg queries:0.
Sent MLDv2 specific queries:0.
Sent MLDv2 specific sg queries:0.
Received error MLD messages:0.
Table 3 Output description
general queries |
General query messages |
specific queries |
Multicast-address-specific query messages |
reports |
Report messages |
dones |
Done messages |
reports with right and wrong records |
Reports containing correct and incorrect records |
specific sg queries |
Multicast-address-and-source-specific queries |
error MLD messages |
Error MLD messages |
entry-limit limit
undo entry-limit
View
MLD-snooping view
Default level
2: System level
limit: Maximum number of entries in the MLD snooping forwarding table. The value ranges from 0 to 2000.
Use the entry-limit command to configure the maximum number of entries in the MLD snooping forwarding table globally.
Use the undo entry-limit command to restore the default.
By default, the upper limit is 2000.
Related commands: multicast-vlan ipv6 entry-limit.
# Configure the MLD snooping forwarding table to contain at most 512 entries.
[Sysname] mld-snooping
[Sysname-mld-snooping] entry-limit 512
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
View
MLD-snooping view
Default level
2: System level
vlan vlan-list: Specifies one or multiple VLANs. You can provide up to 10 VLAN lists. For each list, you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The value range of a VLAN ID is 1 to 4094. If you do not specify any VLAN, the command applies to all VLANs. If you specify one or multiple VLANs, the command applies to the specified VLANs.
Use the fast-leave command to enable fast-leave processing globally. With this function enabled, when the switch receives an MLD done message on a port, it directly removes that port from the forwarding table entry for the specific group.
Use the undo fast-leave command to disable fast-leave processing globally.
By default, fast-leave processing is disabled.
This command also works on VLANs with MLD enabled on their VLAN interfaces.
Related commands: mld-snooping fast-leave.
# Enable fast-leave processing globally in VLAN 2.
[Sysname-mld-snooping] fast-leave vlan 2
group-policy acl6-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
View
MLD-snooping view
Default level
2: System level
Acl6-number: Basic or advanced IPv6 ACL number, in the range of 2000 to 3999. A host can join only the IPv6 multicast groups that match the permit statement in the specified ACL. The source address or address range specified in the advanced IPv6 ACL rule matches the IPv6 multicast source address or addresses specified in MLDv2 reports, rather than the source address in the IPv6 packets. The system assumes that an MLDv1 report or an MLDv2 IS_EX or TO_EX report that does not carry an IPv6 multicast source address carries an IPv6 multicast source address of 0::0.
vlan vlan-list: Specifies one or multiple VLANs. You can provide up to 10 VLAN lists. For each list, you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The value range of a VLAN ID is 1 to 4094. If you do not specify any VLAN, the command applies to all VLANs. If you specify one or multiple VLANs, the command applies to the specified VLANs only.
Use the group-policy command to configure a global IPv6 multicast group filter, namely, to control the IPv6 multicast groups a host can join.
Use the undo group-policy command to remove the configured global IPv6 multicast group filter.
By default, no IPv6 multicast group filter is configured globally. Namely, any host can join any valid IPv6 multicast group.
If the specified IPv6 ACL does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
You can configure different IPv6 ACL rules for each port in different VLANs. For a given VLAN, a newly configured IPv6 ACL rule will override the existing one.
Related commands: mld-snooping group-policy.
# Apply ACL 2000 as an IPv6 multicast group filter so that hosts in VLAN 2 can join FF03::101 only.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source ff03::101 16
[Sysname-acl6-basic-2000] quit
[Sysname-mld-snooping] group-policy 2000 vlan 2
host-aging-time interval
undo host-aging-time
View
MLD-snooping view
Default level
2: System level
interval: Dynamic member port aging time in seconds. The value ranges from 200 to 1000.
Use the host-aging-time command to configure the aging time of dynamic member ports globally.
Use the undo host-aging-time command to restore the default.
By default, the aging time of dynamic member ports is 260 seconds.
Related commands: mld-snooping host-aging-time.
# Set the aging time of dynamic member ports globally to 300 seconds.
[Sysname-mld-snooping] host-aging-time 300
host-tracking
undo host-tracking
View
MLD-snooping view
Default level
2: System level
None
Use the host-tracking command to enable the MLD snooping host tracking function globally.
Use the undo host-tracking command to disable the MLD snooping host tracking function globally.
By default, this function is disabled.
Related commands: display mld-snooping host and mld-snooping host-tracking.
# Enable the MLD snooping host tracking function globally.
[Sysname-mld-snooping] host-tracking
undo last-listener-query-interval
View
MLD-snooping view
Default level
2: System level
interval: MLD last listener query interval in seconds, namely, the length of time that the device waits between sending MLD multicast-address-specific queries. The value ranges from 1 to 5.
Use the last-listener-query-interval command to configure the MLD last listener query interval globally.
Use the undo last-listener-query-interval command to restore the default.
By default, the MLD last listener query interval is 1 second.
Related commands: mld-snooping last-listener-query-interval.
# Set the MLD last listener query interval to 3 seconds globally.
[Sysname-mld-snooping] last-listener-query-interval 3
max-response-time interval
undo max-response-time
View
MLD-snooping view
Default level
2: System level
interval: Maximum response time for MLD general queries in seconds. The value ranges from 1 to 25.
Use the max-response-time command to configure the maximum response time for MLD general queries globally.
Use the undo max-response-time command to restore the default.
By default, the maximum response time for MLD general queries is 10 seconds.
Related commands: mld-snooping max-response-time and mld-snooping query-interval.
# Set the maximum response time for MLD general queries globally to 5 seconds.
[Sysname-mld-snooping] max-response-time 5
mld-snooping
mld-snooping
undo mld-snooping
View
Default level
2: System level
None
Use the mld-snooping command to enable MLD snooping globally and enter MLD-snooping view.
Use the undo mld-snooping command to disable MLD snooping globally.
By default, MLD snooping is disabled.
Related commands: mld-snooping enable.
# Enable MLD snooping globally and enter MLD-snooping view.
mld-snooping done source-ip
mld-snooping done source-ip { ipv6-address | current-interface }
undo mld-snooping done source-ip
View
VLAN view
Default level
2: System level
ipv6-address: Specifies a source IPv6 address for the MLD done messages sent by the MLD snooping proxy, which can be any legal IPv6 link-local address.
current-interface: Specifies the IPv6 link-local address of the current VLAN interface as the source address of MLD done messages sent by the MLD snooping proxy. If no IPv6 address has been assigned to the current interface, the default IPv6 address FE80::02FF:FFFF:FE00:0001 is used.
Use the mld-snooping done source-ip command to configure the source IPv6 address of the MLD done messages sent by the MLD snooping proxy.
Use the undo mld-snooping done source-ip command to restore the default.
By default, the source IPv6 address of the MLD done messages sent by the MLD snooping proxy is FE80::02FF:FFFF:FE00:0001.
Before you configure this command in a VLAN, enable MLD snooping for the VLAN.
The source IPv6 address configured in the mld-snooping done source-ip command also applies when the simulated host sends MLD done messages.
# Enable MLD snooping in VLAN 2 and configure the source IPv6 address of MLD done messages sent by the MLD snooping proxy in VLAN 2 to FE80:0:0:1::1.
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] mld-snooping done source-ip fe80:0:0:1::1
mld-snooping drop-unknown
undo mld-snooping drop-unknown
View
VLAN view
Default level
2: System level
None
Use the mld-snooping drop-unknown command to enable dropping unknown IPv6 multicast data in the current VLAN.
Use the undo mld-snooping drop-unknown command to disable dropping unknown IPv6 multicast data in the current VLAN.
By default, this function is disabled, unknown IPv6 multicast data is flooded in the VLAN.
This command takes effect only if MLD snooping is enabled for the VLAN.
# Enable MLD snooping and the function for dropping unknown IPv6 multicast data in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping drop-unknown
mld-snooping enable
mld-snooping enable
undo mld-snooping enable
View
VLAN view
Default level
2: System level
None
Use the mld-snooping enable command to enable MLD snooping in the current VLAN.
Use the undo mld-snooping enable command to disable MLD snooping in the current VLAN.
By default, MLD snooping is disabled in a VLAN.
MLD snooping must be enabled globally before it can be enabled in a VLAN
Related commands: mld-snooping.
# Enable MLD snooping in VLAN 2.
[Sysname] vlan 2
undo mld-snooping fast-leave [ vlan vlan-list ]
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
Default level
2: System level
Use the mld-snooping fast-leave command to enable fast-leave processing on the current port or group of ports. With this function enabled, when the switch receives an MLD done message on a port, it directly removes that port from the forwarding table entry for the specific group.
Use the undo mld-snooping fast-leave command to disable fast-leave processing on the current port or group of ports.
If you do not specify any VLAN when using this command in Layer 2 Ethernet interface view or Layer 2 aggregate interface view, the command will take effect for all VLANs the interface belongs to. If you specify one or multiple VLANs, the command will take effect for the specified VLANs that the interface belongs to.
If you do not specify any VLAN when using this command in port group view, the command will take effect on all the ports in this group. If you specify one or multiple VLANs, the command will take effect only on those ports in this group that belong to the specified VLANs.
Related commands: fast-leave.
# Enable fast-leave processing on GigabitEthernet 3/0/1 in VLAN 2.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] mld-snooping fast-leave vlan 2
mld-snooping general-query source-ip { ipv6-address | current-interface }
undo mld-snooping general-query source-ip
View
VLAN view
Default level
2: System level
ipv6-address: Specifies the source IPv6 address of MLD general queries, which can be any legal IPv6 link-local address.
current-interface: Sets the source IPv6 link-local address of MLD general queries to the IPv6 address of the current VLAN interface. If the current VLAN interface does not have an IPv6 address, the default IPv6 address FE80::02FF:FFFF:FE00:0001 will be used as the source IPv6 address of MLD general queries.
Use the mld-snooping general-query source-ip command to configure the source IPv6 address of MLD general queries.
Use the undo mld-snooping general-query source-ip command to restore the default.
By default, the source IPv6 address of MLD general queries is FE80::02FF:FFFF:FE00:0001.
# In VLAN 2, enable MLD snooping and specify FE80:0:0:1::1 as the source IPv6 address of MLD general queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping general-query source-ip fe80:0:0:1::1
mld-snooping group-limit
undo mld-snooping group-limit [ vlan vlan-list ]
View
Default level
2: System level
limit: Maximum number of IPv6 multicast groups that a port can join. The value ranges from 1 to 1024.
Use the mld-snooping group-limit command to configure the maximum number of IPv6 multicast groups that a port can join.
Use the undo mld-snooping group-limit command to restore the default.
By default, the upper limit is 1024.
For a switch that supports both MLD snooping and MLD, you can also use the mld group-limit command to limit the number of IPv6 multicast groups that an interface can join. However, if you configure the limit both on a VLAN and on a VLAN interface of this VLAN by using these two commands, inconsistencies might exist between Layer 2 and Layer 3 table entries. Therefore, H3C recommends you to configure the limit only on the VLAN interface.
Related commands: mld group-limit.
# Configure to allow GigabitEthernet 3/0/1 in VLAN 2 to join up to 10 IPv6 multicast groups.
[Sysname-GigabitEthernet3/0/1] mld-snooping group-limit 10 vlan 2
mld-snooping group-policy acl6-number [ vlan vlan-list ]
undo mld-snooping group-policy [ vlan vlan-list ]
View
Default level
2: System level
acl6-number: Basic or advanced IPv6 ACL number, in the range of 2000 to 3999. A host can join only the IPv6 multicast groups that match the permit statement in the specified ACL. The IPv6 source address or address range specified in the advanced IPv6 ACL rule is the IPv6 multicast source address or addresses specified in MLDv2 reports, rather than the source address in the IPv6 packets. The system assumes that an MLDv1 report or an MLDv2 IS_EX or TO_EX report that does not carry an IPv6 multicast source address carries an IPv6 multicast source address of 0::0.
Use the mld-snooping group-policy command to configure an IPv6 multicast group filter on the current port or ports, namely, to control the multicast groups that the port or ports can join.
Use the undo mld-snooping group-policy command to remove the configured IPv6 multicast group filter on the current port or ports.
By default, no IPv6 multicast group filter is configured on a port. Namely, a host can join any valid IPv6 multicast group.
If the specified ACL does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
Related commands: group-policy.
# Apply ACL 2000 as an IPv6 multicast group filter so that hosts on GigabitEthernet 3/0/1 in VLAN 2 can join FF03::101 only.
[Sysname-GigabitEthernet3/0/1] mld-snooping group-policy 2000 vlan 2
mld-snooping host-aging-time interval
undo mld-snooping host-aging-time
View
VLAN view
Default level
2: System level
interval: Dynamic member port aging time, in seconds. The value ranges from 200 to 1000.
Use the mld-snooping host-aging-time command to configure the aging time of dynamic member ports in the current VLAN.
Use the undo mld-snooping host-aging-time command to restore the default.
By default, the dynamic member port aging time is 260 seconds.
Related commands: host-aging-time and mld-snooping enable.
# Enable MLD snooping and set the aging time of dynamic member ports to 300 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-aging-time 300
mld-snooping host-join
undo mld-snooping host-join ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
View
Default level
2: System level
ipv6-group-address: Address of IPv6 multicast group which the simulated host will join. The value ranges from FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal number between 0 and F, inclusive.
ipv6-source-address: Address of the IPv6 multicast source that the simulated host will join.
vlan vlan-id: Specifies a VLAN that comprises the port or ports, where vlan-id is in the range of 1 to 4094.
Use the mld-snooping host-join command to enable simulated joining on a port, namely, to configure the current port as member host for the specified IPv6 multicast group or source and group.
Use the undo mld-snooping host-join command to remove the current port or ports as simulated member host or hosts for the specified IPv6 multicast group or source and group.
By default, no ports are configured as static member ports for any IPv6 multicast group or source and group.
The version of MLD on the simulated host is consistent with the version of MLD snooping running on the VLAN.
This command also works on VLANs with MLD enabled on their VLAN interfaces. The version of MLD on the simulated host is consistent with the version of MLD running on the VLAN interfaces.
The source-ip ipv6-source-address option in the command is meaningful only for MLDv2 snooping. If MLDv1 snooping is running, the source-ip ipv6-source-address option does not take effect although you can include source-ip ipv6-source-address in the command.
In Layer 2 Ethernet interface view or Layer 2 aggregate interface view, this feature takes effect only if the interface belongs to the specified VLAN. In port group view, this feature takes effect only on those ports in this port group that belong to the specified VLAN.
# Configure GigabitEthernet 3/0/1 in VLAN 2 to join (2002::22, FF3E::101) as a simulated host.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping version 2
[Sysname-vlan2] quit
[Sysname-GigabitEthernet3/0/1] mld-snooping host-join ff3e::101 source-ip 2002::22 vlan 2
undo mld-snooping host-tracking
View
VLAN view
Default level
2: System level
None
Use the mld-snooping host-tracking command to enable the MLD snooping host tracking function in a VLAN.
Use the undo mld-snooping host-tracking command to disable the MLD snooping host tracking function in a VLAN.
Before you configure this command, enable MLD snooping for the VLAN first.
Related commands: display mld-snooping host, host-tracking, and mld-snooping enable.
# Enable MLD snooping and the MLD snooping host tracking function for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-tracking
undo mld-snooping last-listener-query-interval
View
VLAN view
Default level
2: System level
Use the mld-snooping last-listener-query-interval command to configure the MLD last-listener query interval in the VLAN.
Use the undo mld-snooping last-listener-query-interval command to restore the default.
Related commands: last-listener-query-interval and mld-snooping enable.
# Enable MLD snooping and set the MLD last-listener query interval to 3 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping last-listener-query-interval 3
mld-snooping max-response-time interval
undo mld-snooping max-response-time
View
VLAN view
Default level
2: System level
Use the mld-snooping max-response-time command to configure the maximum response time for MLD general queries in the VLAN.
Use the undo mld-snooping max-response-time command to restore the default.
Related commands: max-response-time, mld-snooping enable, and mld-snooping query-interval.
# Enable MLD snooping and set the maximum response time for MLD general queries to 5 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping max-response-time 5
mld-snooping overflow-replace
undo mld-snooping overflow-replace [ vlan vlan-list ]
View
Default level
2: System level
Use the mld-snooping overflow-replace command to enable the IPv6 multicast group replacement function on the current port or ports.
Use the undo mld-snooping overflow-replace command to disable the IPv6 multicast group replacement function on the current port or ports.
By default, the IPv6 multicast group replacement function is disabled.
Related commands: overflow-replace.
# Enable the IPv6 multicast group replacement function on GigabitEthernet 3/0/1 in VLAN 2.
[Sysname-GigabitEthernet3/0/1] mld-snooping overflow-replace vlan 2
mld-snooping proxying enable
undo mld-snooping proxying enable
View
VLAN view
Default level
2: System level
None
Use the mld-snooping proxying enable command to enable the MLD snooping proxying function in a VLAN.
Use the undo mld-snooping proxying enable command to disable the MLD snooping proxying function in a VLAN.
By default, MLD snooping proxying is disabled in all VLANs.
# Enable MLD snooping and then MLD snooping proxying in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping proxying enable
mld-snooping querier
undo mld-snooping querier
View
VLAN view
Default level
2: System level
None
Use the mld-snooping querier command to enable the MLD snooping querier function.
Use the undo mld-snooping querier command to disable the MLD snooping querier function.
By default, the MLD snooping querier function is disabled.
This command takes effect only if MLD snooping is enabled for the VLAN, and it does not take effect in a sub-VLAN of an IPv6 multicast VLAN.
Related commands: mld-snooping enable and subvlan.
# Enable MLD snooping and the MLD snooping querier function in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier
undo mld-snooping query-interval
View
VLAN view
Default level
2: System level
interval: MLD query interval in seconds, namely, the length of time that the device waits between sending MLD general queries. The value ranges from 2 to 300.
Use the mld-snooping query-interval command to configure the MLD query interval.
Use the undo mld-snooping query-interval command to restore the default.
By default, the MLD query interval is 125 seconds.
Related commands: max-response-time, mld-snooping enable, mld-snooping max-response-time, and mld-snooping querier.
# Enable MLD snooping and set the MLD query interval to 20 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping query-interval 20
mld-snooping report source-ip
mld-snooping report source-ip { ipv6-address | current-interface }
undo mld-snooping report source-ip
View
VLAN view
Default level
2: System level
ipv6-address: Specifies a source IPv6 address for the MLD reports sent by the MLD snooping proxy, which can be any legal IPv6 link-local address.
current-interface: Specifies the IPv6 link-local address of the current VLAN interface as the source address of MLD reports sent by the MLD snooping proxy. If no IPv6 address has been assigned to the current interface, the default IPv6 address FE80::02FF:FFFF:FE00:0001 is used.
Use the mld-snooping report source-ip command to configure the source IPv6 address of the MLD reports sent by the MLD snooping proxy.
Use the undo mld-snooping report source-ip command to restore the default.
By default, the source IPv6 address of the MLD reports sent by the MLD snooping proxy is FE80::02FF:FFFF:FE00:0001.
The source IPv6 address configured in the mld-snooping report source-ip command also applies when the simulated host sends MLD reports.
# Enable MLD snooping in VLAN 2 and configure the source IPv6 address of MLD reports sent by the MLD snooping proxy in VLAN 2 to FE80:0:0:1::1.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping report source-ip fe80:0:0:1::1
mld-snooping router-aging-time interval
undo mld-snooping router-aging-time
View
VLAN view
Default level
2: System level
interval: Dynamic router port aging time, in seconds. The value ranges from 1 to 1000.
Use the mld-snooping router-aging-time command to configure the aging time of dynamic router ports in the current VLAN.
Use the undo mld-snooping router-aging-time command to restore the default.
By default, the dynamic router port aging time is 260 seconds.
Related commands: mld-snooping enable and router-aging-time.
# Enable MLD snooping and set the aging time of dynamic router ports to 100 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping router-aging-time 100
mld-snooping router-port-deny
undo mld-snooping router-port-deny [ vlan vlan-list ]
View
Default level
2: System level
Use the mld-snooping router-port-deny command to disable a port from becoming a dynamic router port.
Use the undo mld-snooping router-port-deny command to restore the default.
By default, a port can become a dynamic router port.
# Disable GigabitEthernet 3/0/1 from becoming a dynamic router port in VLAN 2.
[Sysname-GigabitEthernet3/0/1] mld-snooping router-port-deny vlan 2
mld-snooping special-query source-ip { ipv6-address | current-interface }
undo mld-snooping special-query source-ip
View
VLAN view
Default level
2: System level
ipv6-address: Specifies an IPv6 link-local address as the source IPv6 address of MLD multicast-address-specific queries.
current-interface: Specifies the source IPv6 link-local address of the VLAN interface of the current VLAN as the source IPv6 address of MLD multicast-address-specific queries. If the current VLAN interface does not have an IPv6 address, the default IPv6 address FE80::02FF:FFFF:FE00:0001 will be used as the source IPv6 address of MLD multicast-address-specific queries.
Use the mld-snooping special-query source-ip command to configure the source IPv6 address of MLD multicast-address-specific queries.
Use the undo mld-snooping special-query source-ip command to restore the default.
By default, the source IPv6 address of MLD multicast-address-specific queries is FE80::02FF:FFFF:FE00:0001.
# In VLAN 2, enable MLD snooping and specify FE80:0:0:1::1 as the source IPv6 address of MLD multicast-address-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping special-query source-ip fe80:0:0:1::1
mld-snooping static-group
undo mld-snooping static-group ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
View
Default level
2: System level
ipv6-group-address: Address of an IPv6 multicast group that the port or ports will join as static member port or ports. The value ranges from FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal number between 0 and F, inclusive.
ipv6-source-address: Address of the IPv6 multicast source that the port or ports will join as static member port or ports.
vlan vlan-id: Specifies the VLAN that comprises the Ethernet port or ports, where vlan-id is in the range of 1 to 4094.
Use the mld-snooping static-group command to configure the static IPv6 (*, G) or (S, G) joining function, namely, to configure the port or port group as static IPv6 multicast group or source-group member(s).
Use the undo mld-snooping static-group command to restore the default.
By default, no ports are static member ports.
# Configure GigabitEthernet 3/0/1 in VLAN 2 to be a static member port for (2002::22, FF3E::101).
[Sysname] vlan 2
[Sysname-GigabitEthernet3/0/1] mld-snooping static-group ff3e::101 source-ip 2002::22 vlan 2
undo mld-snooping static-router-port vlan vlan-id
View
Default level
2: System level
vlan vlan-id: Specifies a VLAN in which one or more static router ports will be configured, where vlan-id is in the range of 1 to 4094.
Use the mld-snooping static-router-port command to configure the current port or ports as static router port or ports.
Use the undo mld-snooping static-router-port command to restore the default.
By default, no ports are static router ports.
This command does not take effect in a sub-VLAN of an IPv6 multicast VLAN.
Related commands: subvlan.
# Enable the static router port function on GigabitEthernet 3/0/1 in VLAN 2.
[Sysname-GigabitEthernet3/0/1] mld-snooping static-router-port vlan 2
undo mld-snooping version
View
VLAN view
Default level
2: System level
version-number: MLD snooping version, in the range of 1 to 2.
Use the mld-snooping version command to configure the MLD snooping version.
Use the undo mld-snooping version command to restore the default.
By default, the MLD version is 1.
This command can take effect only if MLD snooping is enabled for the VLAN, and it does not take effect in a sub-VLAN of an IPv6 multicast VLAN.
# Enable MLD snooping in VLAN 2, and set the MLD snooping version to version 2.
[Sysname] vlan 2
undo overflow-replace [ vlan vlan-list ]
View
MLD-snooping view
Default level
2: System level
Use the overflow-replace command to enable the IPv6 multicast group replacement function globally.
Use the undo overflow-replace command to disable the IPv6 multicast group replacement function globally.
By default, the IPv6 multicast group replacement function is disabled globally.
Related commands: mld-snooping overflow-replace.
# Enable the IPv6 multicast group replacement function globally in VLAN 2.
[Sysname-mld-snooping] overflow-replace vlan 2
report-aggregation
undo report-aggregation
View
MLD-snooping view
Default level
2: System level
None
Use the report-aggregation command to enable MLD report suppression.
Use the undo report-aggregation command to disable MLD report suppression.
By default, MLD report suppression is enabled.
# Disable MLD report suppression.
[Sysname-mld-snooping] undo report-aggregation
reset mld-snooping group
reset mld-snooping group { ipv6-group-address | all } [ vlan vlan-id ]
View
Default level
2: System level
ipv6-group-address: Specifies an IPv6 multicast group. The value range of ipv6-group-address is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal number between 0 and F, inclusive.
all: Specifies all IPv6 multicast groups.
vlan vlan-id: Specifies a VLAN. The value range of vlan-id is 1 to 4094.
Use the reset mld-snooping group command to remove the dynamic group entries of a specified MLD snooping group or all MLD snooping groups.
This command cannot remove the static group entries of MLD snooping groups.
# Remove the dynamic group entries of all MLD snooping groups.
<Sysname> reset mld-snooping group all
reset mld-snooping statistics
View
Default level
2: System level
None
Use the reset mld-snooping statistics command to clear the statistics for MLD messages learned through MLD snooping.
# Clear the statistics for all MLD messages learned through MLD snooping.
<Sysname> reset mld-snooping statistics
undo router-aging-time
View
MLD-snooping view
Default level
2: System level
Use the router-aging-time command to configure the aging time of dynamic router ports globally.
Use the undo router-aging-time command to restore the default.
Related commands: mld-snooping router-aging-time.
# Set the aging time of dynamic router ports globally to 100 seconds.
[Sysname-mld-snooping] router-aging-time 100
