- 08-System Volume
- 00-System Volume Organization
- 01-Login Commands
- 02-Basic System Configuration Commands
- 03-Device Management Commands
- 04-File System Management Commands
- 05-SNMP Commands
- 06-RMON Commands
- 07-MAC Address Table Management Commands
- 08-System Maintaining and Debugging Commands
- 09-Information Center Commands
- 10-PoE Commands
- 11-Track Commands
- 12-NQA Commands
- 13-NTP Commands
- 14-VRRP Commands
- 15-HA Commands
- 16-Hotfix Commands
| 12-NQA Commands | 145.92 KB |
Table of Contents
NQA Client Configuration Commands
description (any NQA test type view)
operation (FTP test type view)
operation (HTTP test type view)
vpn-instance (ICMP-echo test type view)
NQA Server Configuration Commands
data-fill
data-fill string
undo data-fill
View
ICMP-echo, UDP-echo, UDP-jitter test type view
Default Level
2: System level
string: String used to fill a probe packet, in the range 1 to 200. It is case sensitive.
Use the data-fill command to configure the string used to fill a probe packet.
Use the undo data-fill command to restore the default.
By default, the string used to fill a probe packet is the hexadecimal number 00010203040506070809.
l If the probe packet is smaller than the fill data, the system uses only the first part of the character string to encapsulate the packet.
l If the probe packet is larger than the fill data, the system fills the character string cyclically to encapsulate the packet until it is full.
For example, when the fill data is abcd and the size of a probe packet is 3 byte, abc is used to fill the packet. When the probe size is 6 byte, abcdab is used to fill the packet.
l In an ICMP-echo test, the configured character string is used to fill the data field in an ICMP echo message.
l In a UDP-echo test, because the first five bytes of a probe packet have some specific usage, the configured character string is used to fill the remaining bytes in the probe packet.
l In a UDP-jitter test, because the first 68 bytes of a probe packet have some specific usage, the configured character string is used to fill the remaining bytes in the probe packet.
# Configure the string used to fill an ICMP-echo probe packet as abcd.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] data-fill abcd
data-size
data-size size
undo data-size
View
Default Level
2: System level
size: Size of a probe packet in bytes, in the range 20 to 8100 for an ICMP-echo or a UDP-echo test and in the range 68 to 8100 for a UDP-jitter test.
Use the data-size command to configure the size of a probe packet sent.
Use the undo data-size command to restore the default.
By default, the size of a probe packet is 100 bytes.
l For an ICMP-echo test, the size of a packet sent in a probe is the length of the data field in an ICMP echo message.
l For a UDP-echo test and UDP-jitter test, the size of a packet sent in a probe is the length of the data field in a UDP packet.
# Configure the size of an ICMP-echo probe packet as 80 bytes.
[Sysname-nqa-admin-test-icmp-echo] data-size 80
View
Any NQA test type view
Default Level
2: System level
text: Descriptive string of a test group, in the range 1 to 200. It is case sensitive.
Use the description command to give a brief description of a test group, usually, the test type or test purpose of a test group.
Use the undo description command to remove the configured description information.
By default, no descriptive string is available for a test group.
# Configure the descriptive string for a test group as icmp-probe.
[Sysname-nqa-admin-test-icmp-echo] description icmp-probe
destination ip
destination ip ip-address
undo destination ip
View
DLSw, FTP, HTTP, ICMP-echo, SNMP, TCP, UDP-echo, UDP-jitter test type view
Default Level
2: System level
ip-address: Destination IP address of a test operation.
Use the destination ip command to configure a destination IP address for a test operation.
Use the undo destination ip command to remove the configured destination IP address.
By default, no destination IP address is configured for a test operation.
# Configure the destination IP address of an ICMP-echo test operation as 10.1.1.1.
[Sysname-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
destination port
destination port port-number
undo destination port
View
Default Level
2: System level
port-number: Destination port number of a test operation, in the range 1 to 65535.
Use the destination port command to configure a destination port number for a test operation.
Use the undo destination port command to remove the configured destination port number.
By default, no destination port number is configured for a test operation.
Note that you are not recommended to perform a UDP-jitter test on ports from 1 to 1023 (known ports). Otherwise, the NQA test will fail or the corresponding services of this port will be unavailable.
# Configure the destination port number of a test operation as 9000.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] destination port 9000
display nqa
display nqa { result | history } [ admin-name operation-tag ]
View
Default Level
2: System level
result: Displays the results of the last test.
history: Displays the history records of a test.
admin-name: Specifies the name of the administrator who creates NQA operations, a string of 1 to 32 characters. It is case-insensitive.
operation-tag: Specifies the test operation tag, a string of 1 to 32 characters. It is case-insensitive.
Use the display nqa command to display operation information of an NQA test or tests.
If neither of the test group arguments (admin-name and operation-tag) is specified, information of all test groups is displayed.
# Display the results of the last NQA test, in which the administrator name is administrator, and the operation tag is jitter.
<Sysname> display nqa result administrator jitter
NQA entry(admin administrator, tag jitter) test results:
Destination IP address: 192.168.0.81
Send operation times: 10 Receive response times: 0
Min/Max/Average round trip time: 0/0/0
Square-Sum of round trip time: 0
Last succeeded probe time: 0-00-00 00:00:00.0
Extend results:
Packet lost in test: 100%
Failures due to timeout: 10
Failures due to disconnect: 0
Failures due to no connection: 0
Failures due to sequence error: 0
Failures due to internal error: 0
Failures due to other errors: 0
UDP-jitter results:
RTT number: 0
SD max delay: 0 DS max delay: 0
Min positive SD: 0 Min positive DS: 0
Max positive SD: 0 Max positive DS: 0
Positive SD number: 0 Positive DS number: 0
Positive SD sum: 0 Positive DS sum: 0
Positive SD average: 0 Positive DS average: 0
Positive SD square sum: 0 Positive DS square sum: 0
Min negative SD: 0 Min negative DS: 0
Max negative SD: 0 Max negative DS: 0
Negative SD number: 0 Negative DS number: 0
Negative SD sum: 0 Negative DS sum: 0
Negative SD average: 0 Negative DS average: 0
Negative SD square sum: 0 Negative DS square sum: 0
SD lost packet(s): 0 DS lost packet(s): 0
Lost packet(s) for unknown reason: 10
Table 1-1 display nqa result command output description
Destination IP address |
IP address of the destination |
Send operation times |
Number of probe packets sent |
Receive response times |
Number of response packets received |
Min/Max/Average round trip time |
Minimum/maximum/average roundtrip time |
Square-Sum of round trip time |
Square sum of roundtrip time |
Last succeeded probe time |
Time of the last successful probe in a test |
Packet lost in test |
Average packet loss ratio |
Failures due to timeout |
Number of timeout occurrences in a test |
Failures due to disconnect |
Number of disconnections by the peer |
Failures due to no connection |
Number of failures to connect with the peer |
Failures due to sequence error |
Number of failures owing to out-of-sequence packets |
Failures due to internal error |
Number of failures owing to internal errors |
Failures due to other errors |
UDP-jitter results |
UDP-jitter test results, available only in UDP-jitter tests. |
RTT number |
SD max delay |
Maximum delay from the source to the destination |
DS max delay |
Maximum delay from the destination to the source |
Min positive SD |
Minimum positive jitter delay from the source to the destination |
Min positive DS |
Minimum positive jitter delay from the destination to the source |
Max positive SD |
Maximum positive jitter delay from the source to the destination |
Max positive DS |
Maximum positive jitter delay from the destination to the source |
Positive SD number |
Number of positive jitter delays from the source to the destination |
Positive DS number |
Number of positive jitter delays from the destination to the source |
Positive SD sum |
Sum of positive jitter delays from the source to the destination |
Positive DS sum |
Sum of positive jitter delays from the destination to the source |
Positive SD average |
Average of positive jitter delays from the source to the destination |
Positive DS average |
Average of positive jitter delays from the destination to the source |
Positive SD square sum |
Sum of the square of positive jitter delays from the source to the destination |
Positive DS square sum |
Sum of the square of positive jitter delays from the destination to the source |
Min negative SD |
Minimum absolute value of negative jitter delays from the source to the destination |
Min negative DS |
Minimum absolute value of negative jitter delays from the destination to the source |
Max negative SD |
Maximum absolute value of negative jitter delays from the source to the destination |
Max negative DS |
Maximum absolute value of negative jitter delays from the destination to the source |
Negative SD number |
Number of negative jitter delays from the source to the destination |
Negative DS number |
Number of negative jitter delays from the destination to the source |
Negative SD sum |
Sum of absolute values of negative jitter delays from the source to the destination |
Negative DS sum |
Sum of absolute values of negative jitter delays from the destination to the source |
Negative SD average |
Average absolute value of negative jitter delays from the source to the destination |
Negative DS average |
Average absolute value of negative jitter delays from the destination to the source |
Negative SD square sum |
Sum of the square of negative jitter delays from the source to the destination |
Negative DS square sum |
Sum of the square of negative jitter delays from the destination to the source |
SD lost packet(s) |
Number of lost packets from the source to the destination |
DS lost packet(s) |
Number of lost packets from the destination to the source |
Lost packet(s) for unknown reason |
Number of lost packets for unknown reasons |
# Display the history records of tests, in which the administrator name is administrator, and the operation tag is test.
<Sysname> display nqa history administrator test
NQA entry(admin administrator, tag test) history record(s):
Index Response Status Time
10 329 Succeeded 2007-04-29 20:54:26.5
9 344 Succeeded 2007-04-29 20:54:26.2
8 328 Succeeded 2007-04-29 20:54:25.8
7 328 Succeeded 2007-04-29 20:54:25.5
6 328 Succeeded 2007-04-29 20:54:25.1
5 328 Succeeded 2007-04-29 20:54:24.8
4 328 Succeeded 2007-04-29 20:54:24.5
3 328 Succeeded 2007-04-29 20:54:24.1
2 328 Succeeded 2007-04-29 20:54:23.8
1 328 Succeeded 2007-04-29 20:54:23.4
Table 1-2 display nqa history command output description
Index |
History record number |
Response |
Roundtrip delay of a test packet in the case of a successful test, timeout time in the case of timeout, or 0 in the case that a test cannot be completed (in milliseconds) |
Status |
Status value of test results, including: l Succeeded l Unknown error l Internal error l Timeout |
Time |
Time when the test is completed |
filename
filename filename
undo filename
View
FTP test type view
Default Level
2: System level
filename: Name of the file transferred between the FTP server and the FTP client, a string of 1 to 200 characters. It is case sensitive.
Use the filename command to specify a file to be transferred between the FTP server and the FTP client.
Use the undo filename command to restore the default.
By default, no file is specified.
# Specify the file to be transferred between the FTP server and the FTP client as config.txt.
[Sysname-nqa-admin-test] type ftp
[Sysname-nqa-admin-test-ftp] filename config.txt
frequency
frequency interval
undo frequency
View
Default Level
2: System level
interval: Interval between two consecutive tests, in milliseconds, in the range 0 to 604800000. If the interval is 0, it indicates that only one test is performed.
Use the frequency command to configure the interval between two consecutive tests for a test group.
Use the undo frequency command to restore the default.
By default, the interval between two consecutive tests for a test group is 0 milliseconds, that is, only one test is performed.
After you use the nqa schedule command to start an NQA test, one test is started at interval.
If the last test is not completed when the interval specified by the frequency command is reached, a new test is not started.
# Configure the interval between two consecutive tests as 1000 milliseconds.
[Sysname-nqa-admin-test-icmp-echo] frequency 1000
history-records
history-records number
undo history-records
View
Default Level
2: System level
number: Maximum number of history records that can be saved in a test group, in the range 0 to 50.
Use the history-records command to configure the maximum number of history records that can be saved in a test group.
Use the undo history-records command to restore the default.
By default, the maximum number of records that can be saved in a test group is 50.
If the number of history records exceeds the maximum number, the earliest history record for a probe will be discarded.
# Configure the maximum number of history records that can be saved in a test group as 10.
[Sysname-nqa-admin-test-icmp-echo] history-records 10
http-version
http-version v1.0
undo http-version
View
HTTP test type view
Default Level
2: System level
v1.0: The HTTP version is 1.0 in an HTTP test.
Use the http-version command to configure the HTTP version used in an HTTP test.
Use the undo http-version command to restore the default.
By default, HTTP 1.0 is used in an HTTP test.
# Configure the HTTP version as 1.0 in an HTTP test.
[Sysname-nqa-admin-test] type http
[Sysname-nqa-admin-test-http] http-version v1.0
next-hop
next-hop ip-address
undo next-hop
View
Default Level
2: System level
ip-address: IP address of the next hop.
Use the next-hop command to configure the next hop IP address for an IP packet.
Use the undo next-hop command to remove the configured next hop IP address.
By default, no next hop IP address is configured.
# Configure the next hop IP address as 10.1.1.1.
[Sysname-nqa-admin-test-icmp-echo] next-hop 10.1.1.1
nqa
nqa entry admin-name operation-tag
undo nqa { all | entry admin-name operation-tag }
View
Default Level
2: System level
admin-name: Specifies the name of the administrator who creates the NQA test operation, a string of 1 to 32 characters, with “-” excluded. It is case-insensitive.
operation-tag: Specifies the tag of a test operation, a string of 1 to 32 characters, with “-” excluded. It is case-insensitive.
all: All NQA test groups.
Use the nqa command to create an NQA test group and enter NQA test group view.
Use the undo nqa command to remove the test group.
Note that if the test type has been configured for the test group, you will directly enter NQA test type view when you execute the nqa command.
# Create an NQA test group whose administrator name is admin and whose operation tag is test and enter NQA test group view.
nqa agent enable
nqa agent enable
undo nqa agent enable
View
Default Level
2: System level
None
Use the nqa agent enable command to enable the NQA client.
Use the undo nqa agent enable command to disable the NQA client and stop all the tests being performed.
By default, the NQA client is enabled.
Related commands: nqa server enable.
# Enable the NQA client.
[Sysname] nqa agent enable
nqa agent max-concurrent
nqa agent max-concurrent number
undo nqa agent max-concurrent
View
Default Level
2: System level
number: Maximum number of the tests that the NQA client can simultaneously perform, in the range 1 to 5. The default value is 2.
Use the nqa agent max-concurrent command to configure the maximum number of tests that the NQA client can simultaneously perform.
Use the undo nqa agent max-concurrent command to restore the default.
From the beginning to the end of a test, the NQA test is in the test status; from the end of a test to the beginning of the next test, the NQA test is in the waiting status.
# Configure the maximum number of the tests that the NQA client can simultaneously perform as 5.
[Sysname] nqa agent max-concurrent 5
nqa schedule
nqa schedule admin-name operation-tag start-time now lifetime forever
undo nqa schedule admin-name operation-tag
View
Default Level
2: System level
admin-name: Specifies the name of the administrator who creates the NQA test operation, a string of 1 to 32 characters. It is case-insensitive.
now: Specifies to start the test for a test group immediately.
forever: Specifies that the test is performed for a test group forever.
Use the nqa schedule command to configure the test start time and test period for a test group.
Use the undo nqa schedule command to stop the test for the test group.
Note that:
l It is not allowed to enter test group view or test type view after a test group is scheduled.
l At present, the configuration of the end time of an NQA test is not supported on the device, and you need to use the undo nqa schedule command to end an NQA test.
# Start a test for the test group with the administrator name admin and operation tag test.
[Sysname] nqa schedule admin test start-time now lifetime forever
operation { get | put }
undo operation
View
FTP test type view
Default Level
2: System level
get: Obtains a file from the FTP server.
put: Transfers a file to the FTP server.
Use the operation command to configure the FTP operation type.
Use the undo operation command to restore the default.
By default, the FTP operation type is get.
# Configure the FTP operation type as put.
[Sysname-nqa-admin-test-ftp] operation put
operation { get | post }
undo operation
View
HTTP test type view
Default Level
2: System level
get: Obtains data from the HTTP server.
post: Transfers data to the HTTP server.
Use the operation command to configure the HTTP operation type.
By default, the HTTP operation type is get.
# Configure the HTTP operation type as post.
[Sysname-nqa-admin-test-http] operation post
operation interface
operation interface interface-type interface-number
undo operation interface
View
DHCP test type view
Default Level
2: System level
interface-type interface-number: Type and number of the interface that is performing a DHCP test.
Use the operation interface command to specify the interface to perform a DHCP test.
Use the undo operation interface command to restore the default.
By default, no interface is specified to perform a DHCP test.
Note that the specified interface must be up; otherwise, the test will fail.
# Specify the interface to perform a DHCP test as VLAN-interface 2.
[Sysname-nqa-admin-test] type dhcp
[Sysname-nqa-admin-test-dhcp] operation interface vlan-interface 2
password (FTP test type view)
password password
undo password
View
FTP test type view
Default Level
2: System level
password: Password used to log onto the FTP server, a string of 1 to 32 characters. It is case sensitive.
Use the password command to configure a password used to log onto the FTP server.
Use the undo password command to remove the configured password.
By default, no password is configured for logging onto the FTP server.
Related commands: username, operation.
# Configure the password used for logging onto the FTP server as ftpuser.
[Sysname-nqa-admin-test-ftp] password ftpuser
probe count
probe count times
undo probe count
View
Default Level
2: System level
times: Number of probes in an NQA test, in the range 1 to 15.
Use the probe count command to configure the number of probes in an NQA test.
Use the undo probe count command to restore the default.
By default, one probe is performed in an NQA test.
l For a TCP or DLSw test, one probe means one connection;
l For a UDP-jitter test, the number of packets sent in one probe depends on the probe packet-number command;
l For an FTP, HTTP or DHCP test, one probe means to carry out a corresponding function;
l For an ICMP-echo or UDP-echo test, one packet is sent in one probe;
l For an SNMP test, three packets are sent in a probe.
If the number of probes in a test is greater than 1, the system performs a second probe after it performs the first probe and receives a response packet. If the system does not receive a response packet, it waits for the test timer to expire before performing a second probe. The process is repeated until the specified probes are completed.
# Configure the number of probes in an ICMP-echo test as 10.
[Sysname] nqa entry admin-test
[Syaname-nqa-admin-test-icmp-echo] probe count 10
probe packet-interval
probe packet-interval packet-interval
undo probe packet-interval
View
Default Level
2: System level
packet-interval: Interval for packets sent in a probe in a UDP-jitter test, in milliseconds, in the range 10 to 1000.
Use the probe packet-interval command to configure the interval for sending packets in a probe in a UDP-jitter test.
Use the undo probe-interval command to restore the default.
By default, the interval is 20 milliseconds.
# Configure the interval for sending packets in a probe in a UDP-jitter test as 100 milliseconds.
[Sysname-nqa-admin-test] type udp-jitter
[Syaname-nqa-admin-test-udp-jitter] probe packet-interval 100
probe packet-number
probe packet-number packet-number
undo probe packet-number
View
Default Level
2: System level
packet-number: Number of packets sent in a UDP-jitter test, in the range 10 to 1000.
Use the probe packet-number command to configure the number of packets sent in a UDP-jitter probe.
Use the undo probe packet-number command to restore the default.
By default, the number of packets sent in a probe is 10.
# Configure the number of packets sent in a UDP-jitter probe as 100.
[Syaname-nqa-admin-test-udp-jitter] probe packet-number 100
probe packet-timeout
probe packet-timeout packet-timeout
undo probe packet-timeout
View
Default Level
2: System level
packet-timeout: Timeout time for waiting for responses in a UDP-jitter test, in the range 10 to 3600000 milliseconds.
Use the probe packet-timeout command to configure the timeout time for waiting for responses in a UDP-jitter test.
Use the undo probe packet-timeout command to restore the default.
By default, the timeout time in a UDP-jitter test is 3000 milliseconds.
# Configure the timeout time for waiting for responses in a UDP-jitter test as 100 milliseconds.
[Syaname-nqa-admin-test-udp-jitter] probe packet-timeout 100
probe timeout
probe timeout timeout
undo probe timeout
View
DHCP, DLSw, FTP, HTTP, ICMP-echo, SNMP, TCP, UDP-echo test type view
Default Level
2: System level
timeout: Timeout time in a probe except UDP-jitter probe, in milliseconds. For an FTP or HTTP probe, the value range is 10 to 86400000; for a DHCP, DLSw, ICMP-echo, SNMP, TCP or UDP-echo probe, the value range is 10 to 3600000.
Use the probe timeout command to configure the timeout time in a probe.
Use the undo probe timeout command to restore the default.
By default, the timeout time is 3000 milliseconds.
After an NQA probe begins, if the NQA probe is not finished within the time specified in the probe timeout command, then the probe times out.
# Configure the timeout time in a DHCP probe as 10000 milliseconds.
[Syaname-nqa-admin-test-dhcp] probe timeout 10000
reaction
reaction item-num checked-element probe-fail threshold-type consecutive occurrences [ action-type { none | trigger-only } ]
undo reaction item-num
View
Default Level
2: System level
item-num: Number of the reaction entry, in the range 1 to 10.
checked-element: Type of the monitored element in collaboration. At present, the type of the monitored element can be probe failure only.
probe-fail: The type of the monitored element is probe failure.
threshold-type consecutive: Threshold type is consecutive probe failures.
occurrences: Number of consecutive probe failures, in the range 1 to 16.
action-type: Triggered action type, defaulting to none.
none: No actions.
trigger-only: Triggers collaboration between other modules only.
Use the reaction command to establish a collaboration entry to monitor the probe results of the current test group. If the number of consecutive probe failures reaches the threshold, collaboration with other modules is triggered.
Use the undo reaction command to remove the collaboration entry.
By default, no collaboration entries are configured.
Note that you cannot modify the content of a collaboration object using the reaction command after the collaboration object is created.
Related commands: track in the Track Commands in the System Volume.
# Create collaboration object 1. If the number of consecutive probe failures reaches 3, collaboration with other modules is triggered.
[Sysname-nqa-admin-test] type tcp
[Sysname-nqa-admin-test-tcp] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
reaction trap
reaction trap { probe-failure consecutive-probe-failures | test-complete | test-failure cumulate-probe-failures }
undo reaction trap { probe-failure | test-complete | test-failure }
View
Default Level
2: System level
probe-failure consecutive-probe-failures: Specifies to send a trap indicating a probe failure to the network management server after consecutive probe failures in an NQA test. consecutive-probe-failures is the number of consecutive probe failures in a test, in the range 1 to 15.
test-complete: Specifies to send a trap to indicate that the test is completed.
test-failure cumulate-probe-failures: Specifies to send a trap indicating a probe failure to the network management server if the total number of probe failures in an NQA test is larger than or equal to cumulate-probe-failures. For one test, the trap is sent only when the test is completed. cumulate-probe-failures is the total number of consecutive probe failures in a test, in the range 1 to 15.
Use the reaction trap command to configure to send traps to network management server under specified conditions.
Use the undo reaction trap command to restore the default.
By default, no traps are sent to the network management server.
# Configure to send a trap indicating a probe failure after five consecutive probe failures in an ICMP-echo test.
[Sysname-nqa-admin-test-icmp-echo] reaction trap probe-failure 5
route-option bypass-route
undo route-option bypass-route
View
Default Level
2: System level
None
Use the route-option bypass-route command to enable the routing table bypass function to test the direct connectivity to the direct destination.
Use the undo route-option bypass-route command to disable the routing table bypass function.
By default, the routing table bypass function is disabled.
Note that after this function is enabled, the routing table is not searched, and the packet is directly sent to the destination in a directly connected network.
# Enable the routing table bypass function.
[Sysname-nqa-admin-test-icmp-echo] route-option bypass-route
source interface
source interface interface-type interface-number
undo source interface
View
Default Level
2: System level
interface-type interface-number: Interface type and the interface number of the source interface of a probe packet.
Use the source interface command to specify the IP address of an interface as the source IP address of ICMP-echo probe requests.
Use the undo source interface command to remove the IP address of an interface as the source IP address of ICMP-echo probe requests.
By default, no interface address is specified as the source IP address of ICMP test request packets.
Note that:
l If you use the source ip command to configure the source IP address of ICMP probe requests, the source interface command is invalid.
l The interface specified by the source interface command must be up; otherwise, the probe fails.
Related commands: source ip.
# Specify the IP address of interface VLAN-interface 2 as the source IP address of ICMP-echo probe requests.
[Sysname-nqa-admin-test-icmp-echo] source interface vlan-interface 2
source ip
source ip ip-address
undo source ip
View
Default Level
2: System level
ip-address: Source IP address of a test operation.
Use the source ip command to configure the source IP address of ICMP probe requests in a test operation.
Use the undo source ip command to remove the configured source address. That is, the IP address of the interface sending a probe request serves as the source IP address of the probe request.
By default, no source IP address is specified.
Note that:
l For an ICMP-echo test, if no source IP address is specified, but the source interface is specified, the IP address of the source interface is taken as the source IP address of ICMP probe requests.
l The source IP address specified by the source ip command must be the IP address of an interface on the device, and the interface must be up; otherwise, the test fails.
Related commands: source interface.
# Configure the source IP address of an ICMP-echo probe request as 10.1.1.1.
[Sysname-nqa-admin-test-icmp-echo] source ip 10.1.1.1
source port
source port port-number
undo source port
View
SNMP, UDP-echo, UDP-jitter test type view
Default Level
2: System level
port-number: Source port number for a test operation, in the range 1 to 50000.
Use the source port command to configure the source port of ICMP probe requests in a test operation.
Use the undo source port command to remove the configured port number.
By default, no source port number is specified.
# Configure the source port number of a probe request as 8000.
[Sysname-nqa-admin-test-udp-echo] source port 8000
tos
tos value
undo tos
View
Default Level
2: System level
value: Value of the ToS field in the IP header in an NQA probe packet, in the range 0 to 255.
Use the tos command to configure the value of the ToS field in the IP header in an NQA probe packet.
Use the undo tos command to restore the default.
By default, the ToS field in the IP header of an NQA probe packet is 0.
# Configure the ToS field in a IP packet header in an NQA probe packet as 1.
[Sysname-nqa-admin-test-icmp-echo] tos 1
ttl
ttl value
undo ttl
View
Default Level
2: System level
value: Maximum number of hops a probe packet traverses in the network, in the range 1 to 255.
Use the ttl command to configure the maximum number of hops a probe packet traverses in the network.
Use the undo ttl command to restore the default.
By default, the maximum number of hops that a probe packet can traverse in a network is 20.
Note that after you configure the route-option bypass-route command, the maximum number of hops a probe packet traverses in the network is 1, and the ttl command does not take effect.
# Configure the maximum number of hops that a probe request can traverse in a network as 16.
[Sysname-nqa-admin-test-icmp-echo] ttl 16
type
type { dhcp | dlsw | ftp | http | icmp-echo | snmp | tcp | udp-echo | udp-jitter }
View
NQA test group view
Default Level
2: System level
dhcp: DHCP test.
dlsw: DLSw test.
ftp: FTP test.
http: HTTP test.
icmp-echo: ICMP-echo test.
snmp: SNMP test.
tcp: TCP test.
udp-echo: UDP-echo test.
udp-jitter: UDP-jitter test.
Use the type command to configure the test type of the current test group and enter test type view.
By default, no test type is configured.
# Configure the test type of a test group as FTP.
url
url url
undo url
View
HTTP test type view
Default Level
2: System level
url: Website an HTTP test visits, a string of 1 to 185 characters. It is case sensitive.
Use the url command to configure the website an HTTP test visits.
Use the undo url command to remove the configured website an HTTP test visits.
Note that the character string of the configured URL cannot contain spaces.
# Configure the website that an HTTP test visits as /index.htm.
[Sysname-nqa-admin-test-http] url /index.htm
username (FTP test type view)
username username
undo username
View
FTP test type view
Default Level
2: System level
username: Username used to log onto the FTP server, a string of 1 to 32 characters. It is case sensitive.
Use the username command to configure a username used to log onto the FTP server.
Use the undo username command to remove the configured username.
By default, no username is configured for logging onto the FTP server.
Related commands: password, operation.
# Configure the login username as administrator.
[Sysname-nqa-admin-test-ftp] username administrator
vpn-instance instance
undo vpn-instance
View
Default Level
2: System level
instance: VPN instance name, a string of 1 to 31 characters. It is case sensitive.
Use the vpn-instance command to specify a VPN instance.
Use the undo vpn-instance command to restore the default.
By default, no VPN instance is specified.
After you specify a VPN instance, NQA will test the connectivity of the specified VPN tunnel.
# Specify the VPN instance vpn1.
[Sysname-nqa-admin-test-icmp-echo] vpn-instance vpn1
You only need to configure the NQA server for UDP-jitter, TCP, and UDP-echo tests.
display nqa server status
View
Default Level
2: System level
None
Use the display nqa server status command to display NQA server status.
# Display NQA server status.
<Sysname> display nqa server status
nqa server is: enabled
tcp-connect:
IP Address Port Status
2.2.2.2 2000 active
udp-echo:
3.3.3.3 3000 inactive
Table 1-3 display nqa server status command output description
tcp-connect |
NQA server status in the NQA TCP test |
udp-echo |
NQA server status in the NQA UDP test |
IP Address |
IP address specified for the TCP/UDP listening service on the NQA server |
Port |
Port number of the TCP/UDP listening service on the NQA server |
Status |
Listening service status: active: Listening service is ready; inactive: Listening service is not ready. |
nqa server enable
nqa server enable
undo nqa server enable
View
Default Level
2: System level
None
Use the nqa server enable command to enable the NQA server.
Use the undo nqa server enable command to disable the NQA server.
By default, the NQA server is disabled.
Related commands: nqa server tcp-connect, nqa server udp-echo.
# Enable the NQA server.
[Sysname] nqa server enable
nqa server tcp-connect ip-address port-number
undo nqa server tcp-connect ip-address port-number
View
Default Level
2: System level
ip-address: IP address specified for the TCP listening service on the NQA server.
port-number: Port number specified for the TCP listening service on the NQA server, in the range 1 to 50000.-
Use the nqa-server tcp-connect command to create a TCP listening service on the NQA server.
Use the undo nqa-server tcp-connect command to remove the TCP listening service created.
Note that:
l You need to configure the command on the NQA server for TCP tests only.
l The IP address and port number must be consistent with those on the NQA client and must be different from those for an existing listening service.
l The IP address must be that of an interface on the NQA server. Otherwise, the configuration will be invalid.
# Create a TCP listening service by using the IP address 169.254.10.2 and port 9000.
[Sysname] nqa server tcp-connect 169.254.10.2 9000
nqa server udp-echo
nqa server udp-echo ip-address port-number
undo nqa server udp-echo ip-address port-number
View
Default Level
2: System level
ip-address: IP address specified for the UDP listening service on the NQA server.
port-number: Port number specified for the UDP listening service on the NQA server, in the range 1 to 50000.
Use the nqa-server udp-echo command to create a UDP listening service on the NQA server.
Use the undo nqa-server udp-echo command to remove the UDP listening service created.
Note that:
l You need to configure the command on the NQA server for UDP-jitter and UDP-echo tests only.
l The IP address and port number must be consistent with those configured on the NQA client and must be different from those of an existing listening service.
# Create a UDP listening service by using the IP address 169.254.10.2 and port 9000.
