08-System Volume
HomeSupportSwitchesH3C S7500E Switch SeriesReference GuidesCommand ReferencesH3C S7500E Series Ethernet Switches Command Manual(Release 6300 series V1.03)08-System Volume
04-File System Management Commands
04-File System Management Commands 224.26 KB
Throughout this document, a filename can be entered as either of the following:
l          A fully qualified filename with a path included to indicate a file under a specific path. The filename can be 1 to 135 characters in length, excluding the ending character.
l          A short filename with no path to indicate a file in the current working path. The filename can be 1 to 91 characters in length, excluding the ending character.
File System Configuration Commands
cd
cd directory
View
Default Level
3: Manage level
directory: Name of the target directory.
Use the cd command to change the current working directory.
# Change the current directory to Flash:.
<Sysname> cd flash:
# Return to the upper directory (Remember to enter a space after the keyword cd).
<Sysname> cd ..
# Return to the root directory.
<Sysname> cd /
After you change the current directory using the cd command, you can use the pwd command to view the path of the current working directory.
copy
copy fileurl-source fileurl-dest
View
Default Level
3: Manage level
fileurl-source: Name of the source file.
fileurl-dest: Name of the target file or folder.
Use the copy command to copy a file.
If you specify a target folder, the system will copy the file to the specified folder and use the name of the source file as the file name.
# Copy file testcfg.cfg under the current folder and save it as testbackup.cfg.
<Sysname> copy testcfg.cfg testbackup.cfg
Copy flash:/test.cfg to flash:/testbackup.cfg?[Y/N]:y
%Copy file flash:/test.cfg to flash:/testbackup.cfg...Done.
# Copy file 1.cfg under the folder test to folder testbackup, and save it as 1backup.cfg.
<Sysname> copy flash:/test/1.cfg cfa0:/testbackup/1backup.cfg
Copy flash:/test/1.cfg to flash:/testbackup/1backup.cfg?[Y/N]:y
%Copy file flash:/test/1.cfg to flash:/testbackup/1backup.cfg...Done.
delete
delete [ /unreserved ] file-url
View
Default Level
3: Manage level
/unreserved: Permanently deletes the specified file, and the deleted file can never be restored.
file-url: Name of the file to be deleted. Asterisks (*) are acceptable as wildcards. For example, to remove files with the extension of .txt in the current directory, you may use the delete *.txt command.
Use the delete command to move a specified file from a storage device to the recycle bin, where you can restore the file with the undelete command or permanently delete it with the reset recycle-bin command.
The dir /all command can display the files moved to the recycle bin. These files are enclosed in pairs of brackets.
This command supports the wildcard *.
If you delete two files in different directories but with the same filename, only the last one is retained in the recycle bin.
# Remove file tt.cfg from the root directory.
<Sysname> delete tt.cfg
Delete flash:/tt.cfg?[Y/N]:y
%Delete file flash:/tt.cfg...Done.
dir
dir [ /all ] [ file-url ]
View
Default Level
3: Manage level
/all: Displays all files (including those in the recycle bin).
file-url: Name of the file or directory to be displayed. Asterisks (*) are acceptable as wildcards. For example, to display files with the .txt extension under the current directory, you may use the dir *.txt command.
Use the dir command to display information about all visible files and folders in the current directory.
Use the dir /all command to display information about all files and folders in the current directory, including hidden files, hidden sub-folders and the files in the recycle bin that originally belong to the current directory. The names of these deleted files are enclosed in pairs of brackets [ ].
The dir file-url command displays information about a file or folder.
# Display information about all files and folders.
<Sysname> dir /all
Directory of flash:/
   0   -rw-   6985954  Apr 26 2005 21:06:29   mainup.app
   1   -rwh      1842  Apr 27 2005 04:37:17   private-data.txt
   2   -rw-      1518  Apr 26 2005 12:05:38   config.cfg
   3   -rw-      2045  May 04 2005 15:50:01   backcfg.cfg
   4   -rwh       428  Apr 27 2005 16:41:21   hostkey
   5   -rwh       572  Apr 27 2005 16:41:31   serverkey
   6   -rw-   2737556  Oct 12 2005 01:31:44   [old.app]
64389 KB total (54880 KB free)
[ ] indicates this file is in the recycle bin.
Table 1-1 dir command output description
Directory of
Current directory
d
Directory. The item is a file if d is not displayed.
r
The file or directory is readable.
w
The file or directory is writeable.
h
The file or directory is hidden.
The file is in the recycle bin.
execute
execute filename
View
Default Level
2: System level
filename: Name of a batch file with a .bat extension.
Use the execute command to execute the specified batch file.
Batch files are command line files. Executing a batch file is to execute a set of command lines in the file.
l          You should not include invisible characters in a batch file. If an invisible character is found during the execution, the batch process will abort and the commands that have been executed cannot be cancelled.
l          Not every command in a batch file is sure to be executed. For example, if a certain command is not correctly configured, the system omits this command and goes to the next one.
l          The configuration generated after a batch file is executed will not be backed up to the standby main board automatically.
l          Each configuration command in a batch file must be a standard configuration command, meaning that the valid configuration information can be displayed with the display current-configuration command after this command is configured successfully; otherwise, this command may not be executed correctly.
# Execute the batch file test.bat in the root directory.
[Sysname] execute test.bat
file prompt
file prompt { alert | quiet }
View
Default Level
3: Manage level
alert: Enables the system to warn you about operations that may bring undesirable results such as file corruption or data loss.
quiet: Disables the system from warning you about any operation.
Use the file prompt command to set a prompt mode for file operations.
By default, the prompt mode is alert.
Note that when the prompt mode is set to quiet, the system does not warn for any file operation. To prevent undesirable consequents resulting from misoperations, the alert mode is preferred.
# Set the file operation prompt mode to alert.
[Sysname] file prompt alert
fixdisk
fixdisk device
View
Default Level
3: Manage level
device: Storage device name.
Use the fixdisk command to restore the space of a storage device when it becomes unavailable because of some abnormal operation.
Note that, you can execute the fixdisk command for the storage device on the active main board (AMB), but you cannot execute the command for the storage device on the standby main board (SMB).
# Restore the space of the Flash.
<Sysname> fixdisk flash:
Fixdisk flash: may take some time to complete.
%Fixdisk flash: completed.
format
format device [ FAT16 | FAT32 ]
View
Default Level
3: Manage level
device: Name of a storage device (for example flash or cf).
FAT16: Formats a storage device using the FAT16 format. FAT16 does not support Tab matching but needs to be input completely if used, and is not applicable to a Flash card.
FAT32: Formats a storage device using the FAT32 format. FAT32 does not support Tab matching but needs to be input completely if used, and is not applicable to a Flash card.
Use the format command to format a storage device.
Formatting a storage device results in loss of all the files on the storage device and these files cannot be restored. In particular, if there is a startup configuration file on a storage device, formatting the storage device results in loss of the startup configuration file.
# Format the Flash.
<Sysname> format flash:
All data on flash: will be lost, proceed with format? [Y/N]:y
%Format flash: completed.
mkdir
mkdir directory
View
Default Level
3: Manage level
directory: Name of a folder.
Use the mkdir command to create a folder under a specified directory on the storage device.
Note that:
l          The name of the folder to be created must be unique under the specified directory. Otherwise, you will fail to create the folder under the directory.
l          To use this command to create a folder, the specified directory must exist. For instance, to create folder flash:/test/mytest, the test folder must exist. Otherwise, you will fail to create folder mytest.
# Create a folder named test.
<Sysname> mkdir test
%Created dir flash:/test
# Create folder test/subtest.
<Sysname> mkdir test/subtest
%Created dir flash:/test/subtest
more
more file-url
View
Default Level
3: Manage level
file-url: File name.
Use the more command to display the contents of the specified file.
So far, this command is valid only for text files.
# Display the contents of file test.txt.
<Sysname> more test.txt
Welcome to H3C.
# Display the contents of file testcfg.cfg.
<Sysname> more testcfg.cfg
 version 5.20, Beta 1201, Standard
 sysname Sysname
vlan 2
return
<Sysname>
mount
mount device
View
Default Level
3: Manage level
device: Name of a storage device.
Use the mount command to mount a hot swappable storage device, such as a CF card, etc (excluding Flash). This command is effective only when the device is in unmounted state.
By default, a storage device is in the mounted state, that is, you can use it without mounting it.
Note that:
l          Do not remove the storage device or swap the board when mounting or unmounting the device, or when you are processing files on the storage device. Otherwise, the file system could be damaged.
l          When a storage device is connected to a lower version system, the system may not be able to recognize the device automatically, and you need to use the mount command for the storage device to function normally.
l          Before removing a mounted storage device from the system, you should first unmount it to avoid damaging the device.
Related commands: umount.
# Mount a CF card of the AMB.
<Sysname> mount cf:
% Mount cf: successfully.
%Apr 23 01:50:00:628 2003 Sysname VFS/4/LOG:
cf: mounted into slot 4.
# Mount a CF card of the SMB (assume the SMB is in slot 5).
<Sysname> mount slot5#cf:
% Mount slot5#cf: successfully.
%Apr 23 01:50:00:628 2003 Sysname VFS/5/LOG:
cf: mounted into slot 5.
move
move fileurl-source fileurl-dest
View
Default Level
3: Manage level
Use the move command to move a file.
If you specify a target folder, the system will move the source file to the specified folder, with the file name unchanged.
# Move file flash:/test/sample.txt to flash:/, and save it as 1.txt.
<Sysname> move test/sample.txt 1.txt
Move flash:/test/sample.txt to flash:/1.txt?[Y/N]:y
% Moved file flash:/test/sample.txt to flash:/1.txt
# Move file b.cfg to the subfolder test2.
<Sysname> move b.cfg test2
Move flash:/b.cfg to flash:/test2/b.cfg?[Y/N]:y
%Moved file flash:/b.cfg to flash:/test2/b.cfg.
pwd
pwd
View
Default Level
3: Manage level
None
Use the pwd command to display the current path.
# Display the current path.
<Sysname> pwd
flash:
rename
rename fileurl-source fileurl-dest
View
Default Level
3: Manage level
fileurl-source: Name of the source file or folder.
Use the rename command to rename a file or folder.
The target file name must be unique under the current path.
# Rename file sample.txt as sample.bak.
<Sysname> rename sample.txt sample.bak
Rename flash:/sample.txt to flash:/sample.bak?[Y/N]:y
%Renamed file flash:/sample.txt to flash:/sample.bak
reset recycle-bin
reset recycle-bin [ /force ]
View
Default Level
3: Manage level
/force: Deletes all files in the recycle bin, including files that cannot be deleted by the command without the /force keyword.
Use the reset recycle-bin command to permanently delete the files in the recycle bin in the current directory.
If a file is corrupted, you may not be able to delete the file using the reset recycle-bin command. In this case, you can use the reset recycle-bin /force command, which can delete all the files in the recycle bin forcibly.
Unlike this command, the delete file-url command only moves a file to the recycle bin. To delete the file in the recycle bin, you need to execute the reset recycle-bin command in the original directory of the file.
# There are three files flash:/a.cfg, flash:/b.cfg, and flash:/test/c.cfg in the recycle bin. Permanently delete file flash:/a.cfg and flash:/b.cfg.
l          Display all the files in the recycle bin in directory flash:.
<Sysname> dir /all
   0     -rwh      3080  Apr 26 2000 16:41:43   private-data.txt
   1     -rw-      2416  Apr 26 2000 13:45:36   config.cfg
   2     -rw-   8036197  May 14 2000 10:13:18   main.app
   3     -rw-      2386  Apr 26 2000 13:30:30   back.cfg
   4     drw-         -  May 08 2000 09:49:25   test
   5     -rwh       716  Apr 24 2007 16:17:30   hostkey
   6     -rwh       572  Apr 24 2007 16:17:44   serverkey
   7     -rw-      2386  May 08 2000 11:14:20   [a.cfg]
   8     -rw-      3608  Dec 03 2007 17:29:30   [b.cfg]
64389 KB total (56514 KB free)
//The above information indicates that in directory flash:, there are two files a.cfg and b.cfg in the recycle bin.
l          Delete the files in directory flash: that are already in the recycle bin.
<Sysname> reset recycle-bin
Clear flash:/~/a.cfg ?[Y/N]:y
Clearing files from flash may take a long time. Please wait...
%Cleared file flash:/~/a.cfg.
Clear flash:/~/b.cfg ?[Y/N]:y
%Cleared file flash:/~/b.cfg...
l          In directory flash:, check whether all the files in the recycle bin are deleted.
<Sysname> dir /all
64389 KB total (56518 KB free)
// The above information indicates that file flash:/a.cfg and flash:/b.cfg are deleted permanently.
l          In directory flash:/test, see whether the file in the recycle bin is deleted or not.
<Sysname> cd test
<Sysname> dir /all
Directory of flash:/test/
   0     drw-         -  Dec 03 2007 18:19:09   subtest
   1     -rw-      2386  Dec 03 2007 18:43:41   [c.cfg]
// The above information indicates that file flash:/test/c.cfg in directory flash:/test is not deleted and is still in the recycle bin.
rmdir
rmdir directory
View
Default Level
3: Manage level
directory: Name of the folder.
Use the rmdir command to remove a folder.
l          The folder must be an empty one. If not, you need to delete all files and subfolders under it with the delete command.
l          After you execute the rmdir command successfully, the files in the recycle bin under the folder will be automatically deleted.
# Remove folder mydir.
<Sysname> rmdir mydir
Rmdir flash:/mydir?[Y/N]:y
%Removed directory flash:/mydir.
umount
umount device
View
Default Level
3: Manage level
Use the umount command to unmount a hot swappable storage device, such as a CF card, excluding Flash. This command is effective only when the storage device is in mounted state.
By default, a storage device is in the mounted state. You need to unmount it before removing it from the device.
Note that:
l          When mounting or unmounting a storage device, or performing file operations on it, do not unplug or switchover the storage device or the board where the storage device resides. Otherwise, the file system could be damaged.
Related commands: mount.
# Unmount a CF card of the AMB.
<Sysname> umount cf:
% Umount cf: successfully.
%Apr 23 01:49:20:929 2003 Sysname VFS/5/LOG:
cf: umounted from slot 0.
# Unmount a CF card of the SMB (assume the SMB is in slot 5).
<Sysname> umount slot5#cf:
% Umount slot5#cf: successfully.
cf: umounted from slot 5.
undelete
undelete file-url
View
Default Level
3: Manage level
file-url: Name of the file to be restored.
Use the undelete command to restore a file from the recycle bin.
If another file with the same name exists under the same path, the undelete operation will cause it to be overwritten and the system will prompt you whether to continue.
# Restore file a.cfg in directory flash: from the recycle bin.
<Sysname> undelete a.cfg
Undelete flash:/a.cfg?[Y/N]:y
%Undeleted file flash:/a.cfg.
# Restore file b.cfg in directory flash:/test from the recycle bin.
<Sysname> undel flash:/test/b.cfg
Undelete flash:/test/b.cfg?[Y/N]:y
%Undeleted file flash:/test/b.cfg.
Or, you can use the following steps to restore file flash:/test/b.cfg.
<Sysname> cd test
<Sysname> undelete b.cfg
Configuration File Management Commands
backup startup-configuration
backup startup-configuration to dest-addr [ dest-filename ]
View
Default Level
2: System level
dest-addr: IP address or name of a TFTP server. The address cannot be an IPv6 address.
dest-filename: Target filename used to save the startup configuration file for the next system startup on the server.
Use the backup startup-configuration command to backup the startup configuration file (used at the next system startup) using a filename you specify. If you do not specify this filename, the original filename is used. This command only backs up the startup configuration file of the AMB.
Presently, the device uses TFTP to back up configuration files.
# Back up the startup configuration file of the device to the TFTP server with IP address 2.2.2.2, using filename 192-168-1-26.cfg.
<Sysname> display startup
  Current startup saved-configuration file:          flash:/config.cfg
  Next startup saved-configuration file:             flash:/test.cfg
<Sysname> backup startup-configuration to 2.2.2.2 192-168-1-26.cfg
Backup next startup-configuration file to 2.2.2.2, please wait…
finished!
<Sysname>
After the above operation, the device backs up file test.cfg to TFTP server 2.2.2.2, where the file is saved as 192-168-1-26.cfg.
display saved-configuration
display saved-configuration [ by-linenum ]
View
Default Level
2: System level
by-linenum: Identifies each line of displayed information with a line number.
Use the display saved-configuration command to display the contents of the current configuration file saved on the storage medium of the device.
After the device is powered on, if you find that some configurations are not validated or incorrect, you may use this command to display the configuration used for the current startup. During device management and maintenance, you can also use this command to check whether important configurations are saved to the current configuration file.
If the device starts up without using the configuration file, meaning the displayed startup configuration file is NULL after you execute the display startup command, there will be no information displayed when you execute the display saved-configuration command; if you have saved the configuration to the configuration file after the device starts up, the information last saved in the configuration file is displayed.
Related commands: save, reset saved-configuration; display current-configuration in Basic Configuration Commands in the System Volume.
# Display the currently running configuration file saved on the storage medium of the device.
<Sysname> display saved-configuration
 version 5.20, Test 5310
 sysname Sysname
 domain default enable system
 telnet server enable
 multicast routing-enable
vlan 1
vlan 999
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
interface NULL0
  ---- More ----
The configurations are displayed in the order of global, port, and user interface. “  ---- More ----” means that all information on this screen has been displayed, and if you press the Space key, the next screen will be displayed.
# Display the contents of the currently running configuration file saved on the storage medium of the device with a number identifying each line.
<Sysname> display saved-configuration by-linenum
    1:  #
    2:   version 5.20, Test 5310
    3:  #
    4:   sysname Sysname
    5:  #
    6:   domain default enable system
    7:  #
    8:   telnet server enable
    9:  #
   10:   multicast routing-enable
   11:  #
   12:  vlan 1
   13:  #
   14:  vlan 999
   15:  #
   16:  domain system
   17:   access-limit disable
   18:   state active
   19:   idle-cut disable
   20:   self-service-url disable
   21:  #
   22:  interface NULL0
   23:  #
  ---- More ----
display startup
display startup
View
Default Level
1: Monitor level
None
Use the display startup command to display the configuration file used at the current system startup and the configuration file to be used at the next system startup.
Note that:
l          The SMB is started and runs based on the current configurations of the AMB; therefore the current startup configuration files displayed on the AMB and SMB are always the same.
l          After a switchover between the AMB and SMB, the new AMB does not restart using the configuration file but runs with the current configuration instead. Therefore, when you execute the display startup command, the startup configuration file used for the current startup of the new AMB is displayed as NULL and that of the new SMB is also NULL to keep consistent with the new AMB.
Related commands: startup saved-configuration.
# Display the startup configuration file used at the current system startup and the one to be used at the next system startup.
MainBoard:
  Current startup saved-configuration file:          flash:/testcfg.cfg
  Next startup saved-configuration file:             flash:/testcfg.cfg
  Bootrom-access enable state:                       enabled
Table 1-2 display startup command output description
Current Startup saved-configuration file
The configuration file used for the current startup
The configuration file used for the next startup
View
Default Level
2: System level
None
Use the reset saved-configuration command to delete the startup configuration file saved on the storage medium of the device.
Note that:
This command will permanently delete the configuration file from the device. Use it with caution.
Related commands: save, display saved-configuration.
# Delete the currently running configuration file from the storage medium of the device.
<Sysname> reset saved-configuration
The saved configuration will be erased.
Are you sure? [Y/N]:y
Configuration in the device is being cleared.
Please wait .......
Configuration in the device is cleared.
restore startup-configuration
restore startup-configuration from src-addr src-filename
View
Default Level
2: System level
src-addr: IP address or name of a TFTP server. The address cannot be an IPv6 address.
src-filename: Filename of the configuration file to be downloaded from the specified server.
Use the restore startup-configuration command to download a configuration file from the specified TFTP server to the device and specify the configuration file as the startup configuration file to be used at the next startup of the device.
This command downloads the configuration file to the AMB and specifies the file as the configuration file to be used at the next startup of the AMB, and meanwhile copies the file to the SMB and specifies the file as the configuration file to be used at the next startup of the SMB.
If the file to be downloaded has the same filename as an existing file on the AMB or SMB, you will be prompted whether you want to overwrite the existing file or not. In addition, both the AMB and the SMB are assumed to use the storage devices of the same type when the device is checking the filename or backing up the configuration file to the SMB. When backing up the configuration file to the SMB, the device saves the file to the same directory on the SMB as on the AMB, that is, the root directory. If the AMB and SMB are of different types, for example, a Flash and a CF card respectively, the backup operation will fail.
# Download configuration file config.cfg from the TFTP server whose IP address is 2.2.2.2, and the configuration file is to be used at the next startup of the device.
<Sysname>restore startup-configuration from 2.2.2.2 config.cfg
Restore next startup-configuration file from 2.2.2.2. Please wait...finished!
Now restore next startup-configuration file from main to slave board. Please wait...finished!
save
save [ file-name | safely ]
View
Default Level
2: System level
file-name: File name, whose extension name must be .cfg.
safely: Sets the configuration saving mode to safe. If this argument is not specified, the configuration file is saved in fast mode.
Use the save file-name command to save the current configuration to the specified configuration file, but the system will not specify the file as the startup configuration file for the next system startup. If the file specified by file-name does not exist, the system will create the file and then save the configuration to the file.
Use the save [ safely ] command to save the current configuration to a configuration file and specify the file as the startup configuration file for the next system startup.
Note that:
If you use the save file-name command, even if the configuration file auto-save function is enabled, the SMB does not automatically save the current configuration to its own configuration file. If you do not specify the file-name argument, the SMB automatically saves the current configuration when the AMB executes the save  [ safely ] command.
Related commands: reset saved-configuration, display current-configuration, display saved-configuration.
# Save the current configuration file to the default directory.
<Sysname> save
The current configuration will be written to the device.
Please input the file name(*.cfg)[flash:/testcfg.cfg](To leave the
existing filename unchanged, press the enter key):
flash:/testcfg.cfg exists, overwrite?[Y/N]:y
Now saving current configuration to the device.
Saving configuration flash:/testcfg.cfg. Please wait...
Configuration is saved to flash successfully.
<Sysname>
slave auto-update config
undo slave auto-update config
View
Default Level
2: System level
None
Use the slave auto-update config command to enable the configuration file auto-save function. After the function is enabled, when you configure to save the current configuration on the AMB, the SMB automatically saves the current configuration to its configuration file.
Use the undo slave auto-update config command to disable the function.
By default, the configuration file auto-save function is enabled.
# Enable the configuration file auto-save function.
[Sysname] slave auto-update config
startup saved-configuration cfgfile
undo startup saved-configuration
View
Default Level
2: System level
cfgfile: Configuration file name.
Use the startup saved-configuration command to specify a startup configuration file (the configuration file to be used at the next system startup).
Use the undo startup saved-configuration command to configure the system to start up with the null configuration, that is, the factory configuration.
The specified file must be ended with a .cfg extension and saved in the root directory of the storage device.
Related commands: display startup.
# Specify a startup configuration file for the next system startup.
<Sysname> startup saved-configuration testcfg.cfg
Please wait ....... Done!
2  FTP Configuration Commands
FTP Server Configuration Commands
display ftp-server
display ftp-server
View
Default Level
3: Manage level
None
Use the display ftp-server command to display the FTP server configuration.
After configuring FTP server parameters, you may verify them with this command.
Related commands: ftp timeout, ftp update.
# Display the FTP server configuration.
<Sysname> display ftp-server
   FTP server is running
   Max user number:              1
   User count:                   1
   Timeout value(in minute):     30
   Put Method:                   fast
The output indicates that the FTP server is running, and supports only one concurrent login user; now one logged-in user is present; FTP connection idle time is 30 minutes, and put method is fast.
display ftp-user
display ftp-user
View
Default Level
3: Manage level
None
Use the display ftp-user command to display the detailed information of current FTP users.
# Display the detailed information of FTP users.
<Sysname> display ftp-user
  UserName             HostIP    Port    Idle              HomeDir
       ftp       192.168.1.54    1190       0               flash:
Table 2-1 display ftp-user command output description
UserName
Name of the currently logged-in user
HostIP
IP address of the currently logged-in user
Port
Port which the currently logged-in user is using
Idle
Duration time of the current FTP connection, in minutes
HomeDir
Authorized path of the present logged-in user
free ftp user
free ftp user username
View
Default Level
3: Manage level
username: Username.
Use the free ftp user command to manually release the FTP connection established with the specified username.
Note that if the user to be released is transmitting a file, the connection between the user and the FTP server is terminated after the file transmission.
# Manually release the FTP connection established with username ftpuser.
<Sysname> free ftp user ftpuser
Are you sure to free FTP user ftpuser? [Y/N]:y
<Sysname>
ftp server acl
ftp server acl acl-number
undo ftp server acl
View
Default Level
3: Manage level
acl-number: Basic access control list (ACL) number, in the range 2000 to 2999.
Use the ftp server acl command to use ACLs to restrict that which FTP clients are allowed to access the device.
Use the undo ftp server acl command to restore the default.
By default, no restriction is configured.
Associated with an ACL, the FTP server can deny the FTP requests of some FTP clients and only permit the access of clients allowed by the ACL rules. This configuration only filters the FTP connections to be established, and has no effect on the established FTP connections and operations. If you execute the command for multiple times, the last specified ACL takes effect.
# Associate the FTP service with ACL 2001 to allow only the client 1.1.1.1 to access the device through FTP.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule 0 permit source 1.1.1.1 0
[Sysname-acl-basic-2001] rule 1 deny source any
[Sysname-acl-basic-2001] quit
[Sysname] ftp server acl 2000
ftp server enable
ftp server enable
undo ftp server
View
Default Level
3: Manage level
None
Use the ftp server enable command to enable the FTP server.
Use the undo ftp server command to disable the FTP server.
By default, the FTP server is disabled to prevent attacks.
# Disable the FTP server.
[Sysname] undo ftp server
% Close FTP server
ftp timeout
ftp timeout minute
undo ftp timeout
View
Default Level
3: Manage level
minute: Idle-timeout timer in minutes, in the range 1 to 35791. The default is 30 minutes.
Use the ftp timeout command to set the idle-timeout timer.
Use the undo ftp timeout command to restore the default.
After you log in to an FTP server, an FTP connection is established. When the connection is disrupted, the FTP server, if not notified, cannot realize that and thus maintains the connection. To address this problem, you can set an idle-timeout timer so that the FTP server can disconnect from the user if no information is received or/and transmitted before the timer expires.
# Set the idle-timeout timer to 36 minutes.
[Sysname] ftp timeout 36
ftp update
ftp update { fast | normal }
undo ftp update
View
Default Level
3: Manage level
fast: Fast update.
normal: Normal update.
Use the ftp update command to set the file update mode that the FTP server uses while receiving data.
Use the undo ftp update command to restore the default, namely, the normal mode.
# Set the FTP update mode to normal.
[Sysname] ftp update normal
FTP Client Configuration Commands
l          You must use the ftp command to enter FTP client view for configurations under this view. For details, refer to ftp.
l          The prompt information in this section is that in the network where the H3C S7500E series Ethernet switches act as the FTP server. If you use other devices as the FTP server, PC for example, the prompt information may be different.
ascii
ascii
View
FTP client view
Default Level
3: Manage level
None
Use the ascii command to set the file transfer mode to ASCII.
FTP provides two file transfer modes: ASCII and binary. To transfer text files, use the ASCII mode; to transfer program files, use the binary mode.
By default, the file transfer mode is ASCII.
# Set the file transfer mode to ASCII.
[ftp] ascii
200 Type set to A.
binary
binary
View
FTP client view
Default Level
3: Manage level
None
Use the binary command to set the file transfer mode to binary (also called flow mode).
By default, the transfer mode is ASCII mode.
# Set the file transfer mode to binary.
[ftp] binary
200 Type set to I.
bye
bye
View
FTP client view
Default Level
3: Manage level
None
Use the bye command to disconnect from the remote FTP server and return to user view. If no connection is established between the device and the remote FTP server, the command exits to the user view directly.
Related commands: close, disconnect, quit.
# Terminate the connection with the remote FTP server and return to user view.
[ftp] bye
221 Server closing.
cd
cd pathname
View
FTP client view
Default Level
3: Manage level
pathname: Path name.
Use the cd command to change the current working directory on the remote FTP server.
You can use this command to access another authorized directory on the FTP server.
# Change the working directory to the sub-directory logfile of the current directory.
[ftp] cd logfile
250 CWD command successful.
# Change the working directory to the sub-directory folder of the authorized directory.
[ftp] cd /folder
cdup
cdup
View
FTP client view
Default Level
3: Manage level
None
Use the cdup command to exit the current directory and enter the upper directory of the FTP server.
Execution of this command will not change the working directory if the current directory is already the authorized directory (that is, work-directory).
# Change the current working directory path to the upper directory.
[ftp] cdup
200 CDUP command successful.
close
close
View
FTP client view
Default Level
3: Manage level
None
Use the close command to terminate the connection to the FTP server, but remain in FTP client view.
This command is equal to the disconnect command.
# Terminate the connection to the FTP server and remain in FTP client view.
[ftp] close
221 Server closing.
[ftp]
debugging
debugging
undo debugging
View
FTP client view
Default Level
3: Manage level
None
Use the debugging command to enable FTP client debugging.
Use the undo debugging command to disable FTP client debugging.
By default, FTP client debugging is disabled.
# The device serves as the FTP client. Enable FTP client debugging and use the active mode to download file sample.file from the current directory of the FTP server.
<Sysname> terminal monitor
<Sysname> terminal debugging
<Sysname> ftp 192.168.1.46
Trying 192.168.1.46 ...
Press CTRL+K to abort
Connected to 192.168.1.46.
220 FTP service ready.
User(192.168.1.46:(none)):ftp
331 Password required for ftp.
Password:
230 User logged in.
[ftp]undo passive
[ftp] debugging
[ftp] get sample.file
---> PORT 192,168,1,44,4,21
200 Port command okay.
 The parsed reply is 200
---> RETR sample.file
150 Opening ASCII mode data connection for /sample.file.
 The parsed reply is 150
FTPC: File transfer started with the signal light turned on.
FTPC: File transfer completed with the signal light turned off.
.226 Transfer complete.
FTP: 3304 byte(s) received in 4.889 second(s), 675.00 byte(s)/sec.
[ftp]
Table 2-2 debugging command output description
---> PORT
Give an FTP order, with data port numbers being…
The parsed reply is
The received reply code, which is defined in RFC 959.
---> RETR
Download the file
File transfer starts, and the signal light is turned on.
File transfer is completed, and the signal light is turned off.
delete
delete remotefile
View
FTP client view
Default Level
3: Manage level
remotefile: File name.
Use the delete command to permanently delete a specified file on the remote FTP server, and the deleted file can never be restored.
To do this, you must be a user with the delete permission on the FTP server.
# Delete file temp.c.
[ftp] delete temp.c
250 DELE command successful.
dir
dir [ remotefile [ localfile ] ]
View
FTP client view
Default Level
3: Manage level
remotefile: Name of the file or directory on the remote FTP server.
localfile: Name of the local file to save the displayed information.
Use the dir command to view the detailed information of the files and subdirectories under the current directory on the remote FTP server.
Use the dir remotefile command to display the detailed information of the specified file or directory on the remote FTP server.
Use the dir remotefile localfile command to display the detailed information of the specified file or directory on the remote FTP server, and save the displayed information into a local file specified by the localfile argument.
The Is command can only display the names of files and directories, whereas the dir command can display other related information of the files and directories, such as the size, and the date they were created.
# View the information of the file ar-router.cfg, and save the result to aa.txt.
[ftp] dir ar-router.cfg aa.txt
227 Entering Passive Mode (192,168,1,50,17,158).
125 ASCII mode data connection already open, transfer starting for /ar-router.cfg.
....226 Transfer complete.
FTP: 67 byte(s) received in 4.600 second(s), 14.00 byte(s)/sec.
# View the content of aa.txt.
[ftp] quit
<Sysname> more aa.txt
-rwxrwxrwx   1 noone    nogroup      3077 Jun 20 15:34 ar-router.cfg
disconnect
disconnect
View
FTP client view
Default Level
3: Manage level
None
Use the disconnect command to disconnect from the remote FTP server but remain in FTP client view.
This command is equal to the close command.
# Disconnect from the remote FTP server but remain in FTP client view.
[ftp] disconnect
221 Server closing.
display ftp client configuration
View
Default Level
1: Monitor level
None
Use the display ftp client configuration command to display the configuration information of the FTP client.
Currently this command displays the configured source IP address or source interface of the FTP client.
Related commands: ftp client source.
# Display the current configuration information of the FTP client.
<Sysname> display ftp client configuration
The source IP address is 192.168.0.123
ftp
ftp [ server-address [ service-port ] [ source { interface interface-type interface-number | ip source-ip-address } ] ]
View
Default Level
3: Manage level
server-address: IP address or host name of a remote FTP server.
service-port: TCP port number of the remote FTP server, in the range 0 to 65535. The default value is 21.
interface interface-type interface-number: Specifies the source interface by its type and number. The primary IP address configured on this interface is the source address of the transmitted packets. If no primary IP address is configured on the source interface, the connection fails.
ip source-ip-address: The source IP address of the current FTP client. This source address must be the one that has been configured on the device.
Use the ftp command to log in to the remote FTP server and enter FTP client view.
Note that:
l          This command applies to IPv4 networks.
l          If you use this command without specifying any parameters, you will simply enter the FTP client view without logging in to the FTP server.
l          If you specify the parameters, you will be prompted to enter the username and password for accessing the FTP server.
l          The priority of the source address specified with this command is higher than that with the ftp client source command. If you specify the source address with the ftp client source command first and then with the ftp command, the source address specified with the ftp command is used to communicate with the FTP server.
# Log in from the current device Sysname1 to the device Sysname2 with the IP address of 192.168.0.211. The source IP address of the packets sent is 192.168.0.212.
<Sysname> ftp 192.168.0.211 source ip 192.168.0.212
Trying 192.168.0.211 ...
Connected to 192.168.0.211.
220 FTP Server ready.
User(192.168.0.211:(none)):abc
331 Password required for abc
Password:
230 Login OK
[ftp]
ftp client source
undo ftp client source
View
Default Level
2: System level
interface interface-type interface-number: Source interface for the FTP connection, including interface type and interface number. The primary IP address configured on the source interface is the source IP address of the packets sent by FTP. If no primary IP address is configured on the source interface, the connection fails.
ip source-ip-address: Source IP address of the FTP connection. It must be an IP address that has been configured on the device.
Use the ftp client source command to configure the source address of the transmitted FTP packets from the FTP client.
Use the undo ftp client source command to restore the default.
By default, a device uses the IP address of the interface determined by the matched route as the source IP address to communicate with an FTP server.
Note that:
l          The source address can be specified as the source interface and the source IP address. If you use the ftp client source command to specify the source interface and then the source IP address, the newly specified source IP address overwrites the configured source interface and vice versa.
l          If the source address is specified with the ftp client source command and then with the ftp command, the source address specified with the latter one is used to communicate with the FTP server.
l          The source address specified with the ftp client source command is valid for all FTP connections and the source address specified with the ftp command is valid only for the current FTP connection.
Related commands: display ftp client configuration.
# Specify the source IP address of the FTP client as 2.2.2.2.
[Sysname] ftp client source ip 2.2.2.2
# Specify the source interface of the FTP client as Vlan-interface 1.
[Sysname] ftp client source interface Vlan-interface 1
ftp ipv6
ftp ipv6 [ server-address [ service-port ] [ source ipv6 source-ipv6-address ] [ -i interface-type interface-number ] ]
View
Default Level
3: Manage level
server-address: IP address or host name of the remote FTP server.
service-port: TCP port number of the FTP server, in the range 0 to 65535. The default value is 21.
source ipv6 source-ipv6-address: Specifies a source IPv6 address for transmitted FTP packets. This address must be an IPv6 address that has been configured on the device.
-i interface-type interface-number: Specifies the type and number of the egress interface. This parameter can be used only in case that the FTP server address is a link local address and the specified egress interface must have a link local address (For the configuration of link local addresses, see IPv6 Basics in the IP Services Volume).
Use the ftp ipv6 command to log in to the FTP server and enter FTP client view.
Note that:
l          This command applies to IPv6 networks.
l          If you use this command without specifying any parameters, you will simply enter the FTP client view without logging in to an FTP server.
l          If you specify the parameters, you will be asked to enter the username and password for accessing the FTP server.
# Log in to the FTP server with IPv6 address 3000::200.
<Sysname> ftp ipv6 3000::200
Trying 3000::200 ...
Connected to 3000::200.
220 Welcome!
User(3000::200:(none)): MY_NAME
331 Please specify the password.
Password:
230 Login successful.
[ftp]
get
get remotefile [ localfile ]
View
FTP client view
Default Level
3: Manage level
remotefile: File name on the remote FTP server.
localfile: Local file name.
Use the get command to download a file from a remote FTP server and save it.
If no local file name is specified, the local file uses the name of the source file on the FTP server by default.
# Download file testcfg.cfg and save it as aa.cfg.
[ftp]get testcfg.cfg aa.cfg
227 Entering Passive Mode (192,168,1,50,17,163).
125 ASCII mode data connection already open, transfer starting for /testcfg.cfg.
.....226 Transfer complete.
FTP: 5190 byte(s) received in 7.754 second(s), 669.00 byte(s)/sec.
lcd
lcd
View
FTP client view
Default Level
3: Manage level
None
Use the lcd command to display the local working directory of the FTP client.
# Display the local working directory.
[ftp] lcd
FTP: Local directory now flash:/temp
ls
ls [ remotefile [ localfile ] ]
View
FTP client view
Default Level
3: Manage level
remotefile: Filename or directory on the remote FTP server.
localfile: Name of a local file used to save the displayed information.
Use the ls command to view the information of all the files and subdirectories under the current directory of the remote FTP server. The file names and subdirectory names are displayed.
Use the ls remotefile command to view the information of a specified file or subdirectory.
Use the ls remotefile localfile command to view the information of a specified file or subdirectory, and save the result to a local file specified by the localfile argument.
The Is command can only display the names of files and directories, whereas the dir command can display other related information of the files and directories, such as the size, and the date they are created.
# View the information of all files and subdirectories under the current directory of the FTP server.
[ftp] ls
227 Entering Passive Mode (192,168,1,50,17,165).
125 ASCII mode data connection already open, transfer starting for /*.
ar-router.cfg
logfile
mainar.app
arbasicbtm.app
ftp
test
bb.cfg
testcfg.cfg
FTP: 87 byte(s) received in 0.132 second(s) 659.00 byte(s)/sec.
# View the information of directory logfile, and save the result to file aa.txt.
[ftp] ls logfile aa.txt
227 Entering Passive Mode (192,168,1,46,4,3).
125 ASCII mode data connection already open, transfer starting for /logfile/*.
FTP: 20 byte(s) received in 3.962 second(s), 5.00 byte(s)/sec.
# View the content of file aa.txt.
[ftp] quit
logfile.log
mkdir
mkdir directory
View
FTP client view
Default Level
3: Manage level
directory: Directory name.
Use the mkdir command to create a subdirectory under the current directory on the remote FTP server.
To do this, you must be a user with the permission on the FTP server.
# Create subdirectory mytest on the current directory of the remote FTP server.
[ftp] mkdir mytest
257 "/mytest" new directory created.
open
open server-address [ service-port ]
View
FTP client view
Default Level
3: Manage level
service-port: Port number of the remote FTP server, in the range 0 to 65535, with the default value of 21.
Use the open command to log in to the IPv4 FTP server under FTP client view.
At login, you will be asked to enter the username and password for accessing the FTP server. If your input is correct, the login succeeds; otherwise, it fails.
Related commands: close.
# In FTP client view, log in to the FTP server with the IP address of 192.168.1.50.
<Sysname> ftp
[ftp] open 192.168.1.50
Trying 192.168.1.50 ...
Connected to 192.168.1.50.
User(192.168.1.50:(none)):aa
331 Password required for aa.
Password:
230 User logged in.
[ftp]
open ipv6
open ipv6 server-address [ service-port ] [ -i interface-type interface-number ]
View
FTP client view
Default Level
3: Manage level
service-port: Port number of the remote FTP server, in the range 0 to 65535. The default value is 21.
-i interface-type interface-number: Specifies the egress interface by its type and number. This parameter can be used only in case that the FTP server address is a link local address and the specified egress interface must have a link local address (For the configuration of link local addresses, see IPv6 Basics in the IP Services Volume).
Use the open ipv6 command to log in to the IPv6 FTP server in FTP client view.
# Log in to the FTP server (with IPv6 address 3000::200) in FTP client view.
<Sysname> ftp
[ftp] open ipv6 3000::200
220 Welcome!
Password:
passive
passive
undo passive
View
FTP client view
Default Level
3: Manage level
None
Use the passive command to set the data transmission mode to passive.
Use the undo passive command to set the data transmission mode to active.
The default transmission mode is passive.
Data transmission modes fall into the passive mode and the active mode. The active mode means that the data connection request is initiated by a server. The passive mode means that the data connection request is initiated by a client. This command is mainly used in conjunction with a firewall to restrict the FTP session connection between private and public network users.
# Set the data transmission mode to passive.
[ftp] passive
FTP: passive is on
put
put localfile [ remotefile ]
View
FTP client view
Default Level
3: Manage level
remotefile: Name of the file to be saved on the remote FTP server.
Use the put command to upload a file to the remote FTP server.
If no name is assigned to the file to be saved on the FTP server, the name of the source file is used by default.
# Upload source file cc.txt to the remote FTP server and save it as dd.txt.
[ftp] put cc.txt dd.txt
227 Entering Passive Mode (192,168,1,50,17,169).
125 ASCII mode data connection already open, transfer starting for /dd.txt.
FTP: 9 byte(s) sent in 0.112 second(s), 80.00 byte(s)/sec.
pwd
pwd
View
FTP client view
Default Level
3: Manage level
None
Use the pwd command to display the current working directory on the remote FTP server.
# Display the current working directory on the remote FTP server.
[ftp] pwd
257 "/temp" is current directory.
View
FTP client view
Default Level
3: Manage level
None
Use the quit command to disconnect from the remote FTP server and exit to user view.
# Disconnect from the remote FTP server and exit to user view.
[ftp] quit
221 Server closing.
<Sysname>
remotehelp
remotehelp [ protocol-command ]
View
FTP client view
Default Level
3: Manage level
protocol-command: FTP command.
Use the remotehelp command to display the help information of FTP-related commands supported by the remote FTP server.
If no argument is specified, FTP-related commands supported by the remote FTP server are displayed.
# Display FTP commands supported by the remote FTP server.
[ftp] remotehelp
214-Here is a list of available ftp commands
    Those with '*' are not yet implemented.
   USER   PASS   ACCT*  CWD    CDUP   SMNT*  QUIT   REIN*
   PORT   PASV   TYPE   STRU*  MODE*  RETR   STOR   STOU*
   APPE*  ALLO*  REST*  RNFR*  RNTO*  ABOR*  DELE   RMD
   MKD    PWD    LIST   NLST   SITE*  SYST   STAT*  HELP
   NOOP*  XCUP   XCWD   XMKD   XPWD   XRMD
214 Direct comments to H3C company.
# Display the help information for the user command.
[ftp] remotehelp user
214 Syntax: USER <sp> <username>.
[ftp]
Table 2-3 remotehelp command output description
The following is an available FTP command list.
Those commands with “*” are not yet implemented.
USER
Username
PASS
Password
CWD
CDUP
Change to parent directory
SMNT*
File structure setting
QUIT
Quit
REIN*
Re-initialization
PORT
Port number
PASV
Passive mode
TYPE
Request type
STRU*
File structure
MODE*
Transmission mode
RETR
Download a file
STOR
Upload a file
STOU*
Store unique
APPE*
Appended file
ALLO*
Allocation space
REST*
Restart
RNFR*
Rename the source
RNTO*
Rename the destination
ABOR*
Abort the transmission
DELE
Delete a file
RMD
Delete a folder
MKD
Create a folder
PWD
Print working directory
LIST
List files
NLST
List file description
SITE*
Locate a parameter
SYST
Display system parameters
STAT*
HELP
Help
NOOP*
No operation
XCUP
Extension command, the same meaning as CUP
XCWD
Extension command, the same meaning as CWD
XMKD
Extension command, the same meaning as MKD
XPWD
Extension command, the same meaning as PWD
XRMD
Extension command, the same meaning as RMD
Syntax of the user command: user (keyword) + space + username
rmdir
rmdir directory
View
FTP client view
Default Level
3: Manage level
directory: Directory name on the remote FTP server.
Use the rmdir command to remove a specified directory from the FTP server.
Note that only authorized users are allowed to use this command.
Note that:
l          The directory to be deleted must be empty, meaning you should delete all files and subdirectories under the directory before you delete a directory. For the deletion of files, refer to the delete command.
l          After you execute the rmdir command successfully, the files in the remote recycle bin under the directory will be automatically deleted.
# Delete the temp1 directory from the authorized directory on the FTP server.
[ftp] rmdir /temp1
200 RMD command successful.
user
user username [ password ]
View
FTP client view
Default Level
3: Manage level
username: Login username.
password: Login password.
Use the user command to relog in to the currently accessed FTP server with another username.
Before using this command, you must configure the corresponding username and password on the FTP server; otherwise, your login fails and the FTP connection is closed.
# User ftp1 has logged in to the FTP server. Use username ftp2 to log in to the current FTP server. (Suppose username ftp2 and password 123123123123 have been configured on the FTP server).
[ftp] user ftp2
331 Password required for ftp2.
Password:
230 User logged in.
[ftp]
verbose
verbose
undo verbose
View
FTP client view
Default Level
3: Manage level
None
Use the verbose command to enable the verbose function to display detailed prompt information.
Use the undo verbose command to disable the verbose function.
By default, the verbose function is enabled.
# Enable the verbose function.
[ftp] verbose
FTP: verbose is on
3  TFTP Configuration Commands
TFTP Client Configuration Commands
display tftp client configuration
View
Default Level
1: Monitor level
None
Use the display tftp client configuration command to display the configuration information of the TFTP client.
Related commands: tftp client source.
# Display the current configuration information of the TFTP client.
<Sysname> display tftp client configuration
Currently this command displays the configured source IP address or source interface of the TFTP client.
tftp-server acl
tftp-server [ ipv6 ] acl acl-number
undo tftp-server [ ipv6 ] acl
View
Default Level
3: Manage level
ipv6: References an IPv6 ACL. If it is not specified, an IPv4 ACL is referenced.
acl-number: Number of a basic ACL, in the range 2000 to 2999.
Use the tftp-server acl command to use ACLs to restrict access to the TFTP server
Use the undo tftp-server acl command to restore the default.
You can reference an ACL control TFTP server access.
For more information about ACL, refer to ACL Configuration in the Security Volume.
# Reference ACL 2000 to control IPv4 TFTP server access.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 1.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname] tftp-server acl 2000
# Reference IPv6 ACL 2001 to control Ipv6 TFTP server access.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source 2030:5060::9050/64
[Sysname-acl6-basic-2001] quit
[Sysname] tftp-server ipv6 acl 2001
tftp
tftp server-address { get | put | sget } source-filename [ destination-filename ] [ source { interface interface-type interface-number | ip source-ip-address } ]
View
Default Level
3: Manage level
server-address: IP address or host name of a TFTP server.
source-filename: Source file name.
destination-filename: Destination file name.
get: Downloads a file in normal mode.
put: Uploads a file.
sget: Downloads a file in secure mode.
source: Configures parameters for source address binding.
l          interface interface-type interface-number: Specifies the source interface by its type and number. The primary IP address configured on the source interface is the source IP address of the packets sent by TFTP. If no primary IP address is configured on the source interface, the transmission fails.
l          ip source-ip-address: Specifies the source IP address for the current TFTP client to transmit packets. This source address must be an IP address that has been configured on the device.
Use the tftp command to upload files from the local device to a TFTP server or download files from the TFTP server to the local device.
l          If no destination file name is specified, the saved file uses the source file name.
l          The priority of the source address specified with this command is higher than that specified with the tftp client source command. If you use the tftp client source command to specify the source address first and then with the tftp command, the latter one is adopted.
# Download the config.cfg file from the TFTP server with the IP address of 192.168.0.98 and save it as config.bak. Specify the source IP address to be 192.168.0.92.
<Sysname> tftp 192.168.0.98 get config.cfg config.bak source ip 192.168.0.92
  File will be transferred in binary mode
  Downloading file from remote TFTP server, please wait....
  TFTP:      372800 bytes received in 1 second(s)
  File downloaded successfully.
# Upload the config.cfg file from the local device to the default path of the TFTP server with the IP address of 192.168.0.98 and save it as config.bak. Specify the source IP interface to be Vlan-interface 1.
<Sysname> tftp 192.168.0.98 put config.cfg config.bak source interface Vlan-interface 1
  Sending file to remote TFTP server. Please wait...
  TFTP:        345600 bytes sent in 1 second(s).
  File uploaded successfully.
tftp client source
undo tftp client source
View
Default Level
2: System level
ip source-ip-address: The source IP address of TFTP connections. It must be an IP address that has been configured on the device.
Use the tftp client source command to configure the source address of the TFTP packets from the TFTP client.
Use the undo telnet client source command to restore the default.
By default, a device uses the IP address of the interface determined by the matched route as the source IP address to communicate with a TFTP server.
Note that:
l          The source address can be specified as the source interface and the source IP; if you use the tftp client source command to specify the source interface and then the source IP, the newly specified source IP overwrites the configured source interface and vice versa.
l          If the source address is specified with the tftp client source command and then with the tftp command, the source address specified with the latter one is used to communicate with the TFTP server.
l          The source address specified with the tftp client source command is valid for all tftp connections and the source address specified with the tftp command is valid for the current tftp command.
Related commands: display tftp client configuration.
# Specify the source IP address of the TFTP client as 2.2.2.2.
[Sysname] tftp client source ip 2.2.2.2
# Specify the source interface of the TFTP client as Vlan-interface 1.
[Sysname] tftp client source interface Vlan-interface 1
tftp ipv6
tftp ipv6 tftp-ipv6-server [ -i interface-type interface-number ] { get | put } source-file [ destination-file ]
View
Default Level
3: Manage level
tftp-ipv6-server: IPv6 address or host name (a string of 1 to 46 characters) of a TFTP server.
-i interface-type interface-number: Specifies the egress interface by its type and number. This parameter can be used only in case that the TFTP server address is a link local address and the specified egress interface must have a link local address (For the configuration of link local address, see IPv6 Basics in the IP Services Volume).
get: Downloads a file.
source-filename: Source filename.
destination-filename: Destination filename. If not specified, this filename is the same as the source filename.
Use the tftp ipv6 command to download a specified file from a TFTP server or upload a specified local file to a TFTP server.
# Download filetoget.txt from the TFTP server.
<Sysname> tftp ipv6 fe80::250:daff:fe91:e058 -i Vlan-interface 1 get filetoget.txt
  TFTP:      411100 bytes received in 2 second(s)
