- 08-System Volume
- 00-System Volume Organization
- 01-Login Commands
- 02-Basic System Configuration Commands
- 03-Device Management Commands
- 04-File System Management Commands
- 05-SNMP Commands
- 06-RMON Commands
- 07-MAC Address Table Management Commands
- 08-System Maintaining and Debugging Commands
- 09-Information Center Commands
- 10-PoE Commands
- 11-Track Commands
- 12-NQA Commands
- 13-NTP Commands
- 14-VRRP Commands
- 15-HA Commands
- 16-Hotfix Commands
| 13-NTP Commands | 88.89 KB |
Table of Contents
ntp-service authentication enable
ntp-service authentication-keyid·
ntp-service in-interface disable·
ntp-service max-dynamic-sessions·
ntp-service reliable authentication-keyid·
NTP Configuration Commands
display ntp-service sessions
display ntp-service sessions [ verbose ]
View
Default Level
1: Monitor level
verbose: Displays the detailed information of all NTP sessions.
Use the display ntp-service sessions command to view the information of all NTP sessions. Without the verbose keyword, this command will display only the brief information of all NTP service sessions.
# View the brief information of NTP service sessions.
<Sysname> display ntp-service sessions
source reference stra reach poll now offset delay disper
[12345]1.1.1.1 127.127.1.0 3 377 64 178 0.0 40.1 22.8
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
Total associations : 1
Table 1-1 display ntp-service sessions command output description
source |
IP address of the clock source |
reference |
Reference clock ID of the clock source 1) If the reference clock is the local clock, the value of this field is related to the value of the stra field: l When the value of the stra field is 0 or 1, this field will be “LOCL”; l When the stra field has another value, this filed will be the IP address of the local clock. 2) If the reference clock is the clock of another device on the network, the value of this field will be the IP address of that device. |
stra |
Stratum level of the clock source |
reach |
Reachability count of the clock source. 0 indicates that the clock source in unreachable. |
poll |
Poll interval in seconds, namely, the maximum interval between successive NTP messages. |
now |
The length of time from when the last NTP message was received or when the local clock was last updated to the current time The time is in second by default. If the time length is greater than 2048 seconds, it is displayed in minute; if greater than 300 minutes, in hour; if greater than 96 hours, in day. |
offset |
The offset of the system clock relative to the reference clock, in milliseconds |
delay |
the roundtrip delay from the local device to the clock source, in milliseconds |
disper |
The maximum error of the system clock relative to the reference source. |
[12345] |
1: Clock source selected by the system, namely, the current reference source, with a system clock stratum level less than or equal to 15 2: Stratum level of the clock source is less than or equal to 15. 3: This clock source has passed the clock selection process. 4: This clock source is a candidate clock source. 5: This clock source was created by a configuration command. |
Total associations |
Total number of associations |
When a device is working in the NTP broadcast/multicast server mode, the display ntp-service sessions command executed on the device will not display the NTP session information corresponding to the broadcast/multicast server, but the sessions will be counted in the total number of associations.
display ntp-service status
View
Default Level
1: Monitor level
None
Use the display ntp-service status command to view the NTP service status information.
# View the NTP service status information.
<Sysname> display ntp-service status
Clock status: unsynchronized
Clock stratum: 16
Reference clock ID: none
Nominal frequency: 100.0000 Hz
Actual frequency: 100.0000 Hz
Clock precision: 2^17
Clock offset: 0.0000 ms
Root delay: 0.00 ms
Root dispersion: 0.00 ms
Peer dispersion: 0.00 ms
Reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
Table 1-2 display ntp-service status command output description
Clock status |
Status of the system clock |
Clock stratum |
Stratum level of the system clock |
Reference clock ID |
After the system clock is synchronized to a remote time server, this field indicates the address of the remote time server; after the system clock is synchronized to a local reference source, this field indicates the address of the local clock source: l When the local clock has a stratum level of 1, the value of this field is “LOCL”; l When the stratum of the local clock has another value, the value of this filed is the IP address of the local clock. |
Nominal frequency |
The nominal frequency of the local system hardware clock |
Actual frequency |
The actual frequency of the local system hardware clock |
Clock precision |
The precision of the system clock |
Clock offset |
The offset of the system clock relative to the reference source |
Root delay |
The roundtrip delay from the local device to the primary reference source |
Root dispersion |
The maximum error of the system clock relative to the primary reference source |
Peer dispersion |
The maximum error of the system clock relative to the reference source |
Reference time |
Reference timestamp |
display ntp-service trace
View
Default Level
1: Monitor level
None
Use the display ntp-service trace command view the brief information of each NTP server along the NTP server chain from the local device back to the primary reference source.
The display ntp-service trace command takes effect only if routes are available between the local device and all the devices on the NTP server chain; otherwise, this command will fail to display all the NTP servers on the NTP chain due to timeout.
# View the brief information of each NTP server from the local device back to the primary reference source.
<Sysname> display ntp-service trace
server 127.0.0.1,stratum 2, offset -0.013500, synch distance 0.03154
server 133.1.1.1,stratum 1, offset -0.506500, synch distance 0.03429
refid LOCL
The information above shows an NTP server chain for the server 127.0.0.1: The server 127.0.0.1 is synchronized to the server 133.1.1.1, and the server 133.1.1.1 is synchronized to the local clock source.
Table 1-3 display ntp-service trace command output description
server |
IP address of the NTP server |
stratum |
The stratum level of the corresponding system clock |
offset |
The clock offset relative to the upper-level clock |
synch distance |
The synchronization distance relative to the upper-level clock, in seconds, and calculated from dispersion and roundtrip delay values. |
refid |
Identifier of the primary reference source. When the stratum level of the primary reference clock is 0, it is displayed as LOCL; otherwise, it is displayed as the IP address of the primary reference clock. |
ntp-service access
ntp-service access { peer | query | server | synchronization } acl-number
undo ntp-service access { peer | query | server | synchronization }
View
Default Level
2: System level
peer: Specifies to permit full access.
query: Specifies to permit control query.
server: Specifies to permit server access and query.
synchronization: Specifies to permit server access only.
acl-number: Basic ACL number, in the range of 2000 to 2999
Use the ntp-service access command to configure the NTP service access-control right to the local device.
Use the undo ntp-service access command to remove the configured NTP service access-control right to the local device.
By default, the local NTP service access-control right is set to peer.
From the highest NTP service access-control right to the lowest one are peer, server, synchronization, and query. When a device receives an NTP request, it will perform an access-control right match and will use the first matched right.
l The ntp-service access command provides only a minimum degree of security protection. A more secure method is identity authentication.
l Before specifying an ACL number in the ntp-service access command, make sure you have already created and configured this ACL.
# Configure devices on the subnet 10.10.0.0/16 to have the full access right to the local device.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ntp-service access peer 2001
undo ntp-service authentication enable
View
Default Level
2: System level
None
Use the ntp-service authentication enable command to enable NTP authentication.
Use the undo ntp-service authentication enable command to disable NTP authentication.
By default, NTP authentication is disabled.
# Enable NTP authentication.
[Sysname] ntp-service authentication enable
ntp-service authentication-keyid keyid authentication-mode md5 value
undo ntp-service authentication-keyid keyid
View
Default Level
2: System level
keyid: Authentication key ID, in the range of 1 to 4294967295.
authentication-mode md5 value: Specifies to use the MD5 algorithm for key authentication, where value represents authentication key and is a string of 1 to 32 characters.
Use the ntp-service authentication-keyid command to set the NTP authentication key.
Use the undo ntp-service authentication-keyid command to remove the set NTP authentication key.
By default, no NTP authentication key is set.
l Presently the system supports only the MD5 algorithm for key authentication.
l You can set a maximum of 1,024 keys for each device.
l If an NTP authentication key is specified as a trusted key, the key automatically changes to untrusted after you delete the key. In this case, you do not need to execute the undo ntp-service reliable authentication-keyid command.
# Set an MD5 authentication key, with the key ID of 10 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 10 authentication-mode md5 BetterKey
ntp-service broadcast-client
undo ntp-service broadcast-client
View
Interface view
Default Level
2: System level
None
Use the ntp-service broadcast-client command to configure the device to work in the NTP broadcast client mode.
Use the undo ntp-service broadcast-client command to remove the configuration.
# Configure the device to work in the broadcast client mode and receive NTP broadcast messages on VLAN-interface 1.
[Sysname-Vlan-interface1] ntp-service broadcast-client
ntp-service broadcast-server
undo ntp-service broadcast-server
View
Interface view
Default Level
2: System level
authentication-keyid keyid: Specifies the key ID to be used for sending broadcast messages to broadcast clients, where keyid is in the range of 1 to 4294967295. This parameter is not meaningful if authentication is not required.
version number: Specifies the NTP version, where number is in the range of 1 to 3 and defaults to 3.
Use the ntp-service broadcast-server command to configure the device to work in the NTP broadcast server mode.
Use the undo ntp-service broadcast-server command to remove the configuration.
# Configure the device to work in the broadcast server mode and send NTP broadcast messages on VLAN-interface 1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service broadcast-server authentication-keyid 4 version 3
undo ntp-service in-interface disable
View
Interface view
Default Level
2: System level
None
Use the ntp-service in-interface disable command to disable an interface from receiving NTP messages.
Use the undo ntp-service in-interface disable command to restore the default.
By default, all interfaces are enabled to receive NTP messages.
# Disable VLAN-interface 1 from receiving NTP messages.
[Sysname-Vlan-interface1] ntp-service in-interface disable
undo ntp-service max-dynamic-sessions
View
Default Level
2: System level
number: Maximum number of dynamic NTP sessions that are allowed to be established, in the range of 0 to 100.
Use the ntp-service max-dynamic-sessions command to set the maximum number of dynamic NTP sessions that are allowed to be established locally.
Use the undo ntp-service max-dynamic-sessions command to restore the maximum number of dynamic NTP sessions to the system default.
By default, the number is 100.
# Set the maximum number of dynamic NTP sessions allowed to be established to 50.
[Sysname] ntp-service max-dynamic-sessions 50
ntp-service multicast-client
undo ntp-service multicast-client [ ip-address ]
View
Interface view
Default Level
2: System level
ip-address: Multicast IP address, defaulting to 224.0.1.1. The value range is 224.0.1.0 to 224.0.1.255.
Use the ntp-service multicast-client command to configure the device to work in the NTP multicast client mode.
Use the undo ntp-service multicast-client command to remove the configuration.
# Configure the device to work in the multicast client mode and receive NTP multicast messages on VLAN-interface 1, and set the multicast address to 224.0.1.1.
[Sysname-Vlan-interface1] ntp-service multicast-client 224.0.1.1
ntp-service multicast-server
undo ntp-service multicast-server [ ip-address ]
View
Interface view
Default Level
2: System level
ttl ttl-number: Specifies the TTL of NTP multicast messages, where ttl-number is in the range of 1 to 255 and defaults to 16.
Use the ntp-service multicast-server command to configure the device to work in the NTP multicast server mode.
Use the undo ntp-service multicast-server command to remove the configuration.
# Configure the device to work in the multicast server mode and send NTP multicast messages on VLAN-interface 1 to the multicast address 224.0.1.1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service multicast-server 224.0.1.1 version 3 authentication-keyid 4
ntp-service refclock-master
undo ntp-service refclock-master [ ip-address ]
View
Default Level
2: System level
ip-address: IP address of the local clock, which is 127.127.1.u, where u is the NTP process ID, in the range of 0 to 3. If you do not specify ip-address, it defaults to 127.127.1.0.
stratum: Stratum level of the local clock, in the range of 1 to 15 and defaulting to 8.
Use the ntp-service refclock-master command to configure the local clock as a reference source for other devices.
Use the undo ntp-service refclock-master command to remove the configuration.
The stratum level of a clock defines the clock precision. The value range is 1 to 16. The clock precision decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest precision, and a stratum 16 clock is not synchronized and cannot be used as a reference clock.
# Specify the local clock as the reference source, with the stratum level of 3.
[Sysname] ntp-service refclock-master 3
undo ntp-service reliable authentication-keyid keyid
View
Default Level
2: System level
keyid: Authentication key number, in the range of 1 to 4294967295.
Use the ntp-service reliable authentication-keyid command to specify that the created authentication key is a trusted key. When NTP authentication is enabled, a client can be synchronized only to a server that can provide a trusted authentication key.
Use the undo ntp-service reliable authentication-keyid command to remove the configuration.
No authentication key is configured to be trusted by default.
# Enable NTP authentication, specify to use MD5 encryption algorithm, with the key ID of 37 and key value of BetterKey, and specify that this key is a trusted key.
[Sysname] ntp-service authentication-keyid 37 authentication-mode md5 BetterKey
[Sysname] ntp-service reliable authentication-keyid 37
ntp-service source-interface
ntp-service source-interface interface-type interface-number
undo ntp-service source-interface
View
Default Level
2: System level
interface-type interface-number: Specifies an interface by its interface type and interface number.
Use the ntp-service source-interface command to specify an interface for sending NTP messages.
Use the undo ntp-service source-interface command to remove the configured interface for sending NTP messages.
If you do not wish the IP address of a certain interface on the local device to become the destination address of response messages, you can use this command to specify a particular interface for sending all NTP messages, so that the source address in all NTP messages is the primary IP address of this interface.
# Specify that all NTP messages are to be sent out from VLAN-interface 1.
[Sysname] ntp-service source-interface vlan-interface 1
ntp-service unicast-peer
ntp-service unicast-peer [ vpn-instance vpn-instance-name ] { ip-address | peer-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-peer [ vpn-instance vpn-instance-name ] { ip-address | peer-name }
View
Default Level
2: System level
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, where vpn-instance-name is a string of 1 to 31 characters.
ip-address: IP address of the symmetric-passive peer. It must be a host address, rather than a broadcast address, a multicast address or the IP address of the local clock.
peer-name: Host name of the symmetric-passive peer, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the peer, where keyid is in the range of 1 to 4294967295.
priority: Specifies the peer designated by ip-address or peer-name as the first choice under the same condition.
source-interface interface-type interface-number: Specifies an interface for sending NTP messages. In an NTP message the local device sends to its peer, the source IP address is the primary IP address of this interface. interface-type interface-number represents the interface type and number.
Use the ntp-service unicast-peer command to designate a symmetric-passive peer for the device.
Use the undo ntp-service unicast-peer command to remove the symmetric-passive peer designated for the device.
No symmetric-passive peer is designated for the device by default.
l To synchronize the PE to a PE or CE in a VPN, you need to provide vpn-instance vpn-instance-name in your command.
l If you include vpn-instance vpn-instance-name in the undo ntp-service unicast-peer command, the command will remove the symmetric-passive peer with the IP address of ip-address in the specified VPN; if you do not include vpn-instance vpn-instance-name in this command, the command will remove the symmetric-passive peer with the IP address of ip-address in the public network.
# Designate the device with the IP address of 10.1.1.1 as the symmetric-passive peer of the device, and configure the device to run NTP version 3, and send NTP messages through VLAN-interface 1.
[Sysname] ntp-service unicast-peer 10.1.1.1 version 3 source-interface vlan-interface 1
ntp-service unicast-server
ntp-service unicast-server [ vpn-instance vpn-instance-name ] { ip-address | server-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-server [ vpn-instance vpn-instance-name ] { ip-address | server-name }
View
Default Level
2: System level
ip-address: IP address of the NTP server. It must be a host address, rather than a broadcast address, a multicast address or the IP address of the local clock.
server-name: Host name of the NTP server, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the NTP server, where keyid is in the range of 1 to 4294967295.
priority: Specifies this NTP server as the first choice under the same condition.
source-interface interface-type interface-number: Specifies an interface for sending NTP messages. In an NTP message the local device sends to the NTP server, the source IP address is the primary IP address of this interface. interface-type interface-number represents the interface type and number.
Use the ntp-service unicast-server command to designate an NTP server for the device.
Use the undo ntp-service unicast-server command to remove an NTP server designated for the device.
No NTP server is designated for the device by default.
l If you include vpn-instance vpn-instance-name in the undo ntp-service unicast-server command, the command will remove the NTP server with the IP address of ip-address in the specified VPN; if you do not include vpn-instance vpn-instance-name in this command, the command will remove the NTP server with the IP address of ip-address in the public network.
# Designate NTP server 10.1.1.1 for the device, and configure the device to run NTP version 3.
[Sysname] ntp-service unicast-server 10.1.1.1 version 3
