08-System Volume
HomeSupportSwitchesH3C S7500E Switch SeriesReference GuidesCommand ReferencesH3C S7500E Series Ethernet Switches Command Manual(Release 6300 series V1.03)08-System Volume
07-MAC Address Table Management Commands
07-MAC Address Table Management Commands 52.68 KB
1  MAC Address Table Management Configuration Commands
display mac-address
display mac-address blackhole [ vlan vlan-id ] [ count ]
display mac-address [ mac-address [ vlan vlan-id ] | [ dynamic | static ] [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ]
View
Default Level
1: Monitor level
blackhole: Displays blackhole MAC address entries. These entries do not age but you can add or remove them. The packets whose destination MAC addresses match blackhole MAC address entries are dropped.
vlan vlan-id: Displays MAC address entries of the specified VLAN, where vlan-id is in the range 1 to 4094.
count: Displays the total number of MAC addresses in the MAC address table.
mac-address: Displays MAC address entries in a specified MAC address, in the format of H-H-H.
dynamic: Displays dynamic MAC address entries. Aging time is set for these entries.
static: Displays static MAC address entries. Similar to blackhole MAC address entries, these entries do not age but you can add or remove them.
interface interface-type interface-number: Displays MAC address learning status of the specified interface. interface-type interface-number specifies an interface by its type and number.
Use the display mac-address command to display information about the MAC address table.
Related commands: mac-address (system view), mac-address (Ethernet interface view), mac-address timer.
# Display the MAC address table entry for MAC address 00e0-fc01-0101.
<Sysname> display mac-address 00e0-fc01-0101
MAC ADDR       VLAN ID  STATE          PORT INDEX               AGING TIME(s)
00e0-fc01-0101 1        Config static Ethernet2/0/2           NOAGED
  ---  1 mac address(es) found  ---
Table 1-1 display mac-address command output description
MAC ADDR
MAC address
VLAN ID
ID of the VLAN to which the MAC address belongs
STATE
State of a MAC address, includes:
l      Config static: static entry configured by the user manually
l      Config dynamic: dynamic entry configured by the user manually
l      Learned: entry learned by the device
l      Blackhole: blackhole entry
PORT INDEX
Number of the port corresponding to the MAC address, that is, packets destined to this MAC address will be sent out from this port. (Displayed as N/A for a blackhole MAC address entry).
AGING TIME(s)
Aging time, which could be:
l      AGING, indicates that the entry is aging.
l      NOAGED, indicates that the entry does not age.
display mac-address aging-time
View
Default Level
1: Monitor level
None
Use the display mac-address aging-time command to display the aging time of dynamic entries in the MAC address table.
Related commands: mac-address (system view), mac-address (Ethernet interface view), mac-address timer, display mac-address.
# Display the aging time of dynamic entries in the MAC address table.
<Sysname> display mac-address aging-time
Mac address aging time: 300s
The above information indicates that the aging time of dynamic entries in the MAC address table is 300 seconds.
display mac-address mac-learning
display mac-address mac-learning [ interface-type interface-number ]
View
Default Level
1: Monitor level
interface-type interface-number: Specifies an interface by its type and number. Displays MAC address learning status of the specified interface.
Use the display mac-address mac-learning command to display MAC address learning status of the specified or all Ethernet ports.
# Display MAC address learning status of port GigabitEthernet 2/0/1.
<Sysname> display mac-address mac-learning gigabitethernet 2/0/1
Mac address learning status of the switch: enable
PortName                       Learning Status
GigabitEthernet2/0/1              enable
Table 1-2 display mac-address mac-learning command output description
Global MAC address learning status, enabled or disabled
PortName
Port name
Learning Status
MAC address learning status for a port, enabled or disabled
mac-address { dynamic | static } mac-address vlan vlan-id
undo mac-address { dynamic | static } mac-address vlan vlan-id
View
Ethernet interface view, Layer-2 aggregate interface view
Default Level
2: System level
dynamic: Dynamic MAC address entries. Aging time is set for these entries.
static: Static MAC address entries. They do not age but you can add or remove them.
mac-address: Specifies a MAC address in the format of H-H-H, where 0s at the beginning of each H (16-bit hexadecimal digit) can be omitted; for example, inputting “f-e2-1” indicates that the MAC address is “000f-00e2-0001”.
vlan vlan-id: Specifies an existing VLAN to which the Ethernet interface belongs, where vlan-id is the specified VLAN ID, in the range 1 to 4094.
Use the mac-address command to add or modify a MAC address entry on a specified Ethernet port.
Use the undo mac-address command to remove a MAC address entry on the Ethernet port.
Note that:
l          As your MAC address entries configuration cannot survive a reboot, save it after completing the configuration. The dynamic MAC address table entries however will be lost whether you save the configuration or not.
l          You cannot configure a static or dynamic MAC address entry on an aggregation port.
Related commands: display mac-address.
# Add a static entry for MAC address 00e0-fc01-0101 on port GigabitEthernet 2/0/1 which belongs to VLAN 2.
[Sysname-GigabitEthernet2/0/1] mac-address static 00e0-fc01-0101 vlan 2
undo mac-address [ { dynamic | static } mac-address interface interface-type interface-number vlan vlan-id ]
undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id
undo mac-address [ dynamic | static ] mac-address interface interface-type interface-number vlan vlan-id
undo mac-address [ dynamic | static ] interface interface-type interface-number
View
Default Level
2: System level
blackhole: Blackhole MAC address entries. These entries do not age but you can add or remove them. The packets whose destination MAC addresses match blackhole MAC address entries are dropped.
static: Static MAC address entries. These entries do not age but you can add or remove them.
interface interface-type interface-number: Outbound interface, with interface-type interface-number representing the interface type and number.
Use the mac-address command to add or modify a MAC address entry.
Use the undo mac-address command to remove one or all MAC address entries.
Note that a static or blackhole entry will not be overwritten by a dynamic entry, but a dynamic entry can be overwritten by a static or blackhole entry.
As your MAC address entries configuration cannot survive a reboot, save it after completing the configuration. The dynamic entries however will be lost whether you save the configuration or not.
# Add a static entry for MAC address 00e0-fc01-0101. All frames destined to this MAC address are sent out of port GigabitEthernet 2/0/1 which belongs to VLAN 2.
[Sysname] mac-address static 00e0-fc01-0101 interface gigabitethernet 2/0/1 vlan 2
mac-address mac-learning disable
undo mac-address mac-learning disable
View
System view, Ethernet interface view, Layer-2 aggregate interface view, port group view
Default Level
2: System level
None
Use the mac-address mac-learning disable command to disable MAC address learning globally, on one or a group of Ethernet ports, or on a Layer-2 aggregate interface, depending on the view you entered.
Use the undo mac-address mac-learning disable command to enable MAC address learning globally, on one or a group of Ethernet ports, or on a VLAN, depending on the view you entered.
By default, MAC address learning is enabled globally and on all Ethernet ports.
Note that:
l          You may need to disable MAC address learning sometimes to prevent the MAC address table from being saturated, for example, when your device is being attacked by a great deal of packets with different source MAC addresses. This somewhat affects update of the MAC address table.
l          As disabling MAC address learning may result in broadcast storms, you need to enable broadcast storm suppression after you disable MAC address learning on a port.
Related commands: display mac-address mac-learning.
When MAC address learning is disabled, the learned MAC addresses remain valid until they age out.
# Disable global MAC address learning.
[Sysname] mac-address mac-learning disable
# Disable MAC address learning on port GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] mac-address mac-learning disable
mac-address max-mac-count
undo mac-address max-mac-count
View
Ethernet interface view, port group view
Default Level
2: System level
count: Maximum number of MAC addresses that can be learned on a port, in the range 0 to 4096. When the argument takes 0, the VLAN is not allowed to learn MAC addresses.
Use the mac-address max-mac-count command to configure the maximum number of MAC addresses that can be learned on an Ethernet port.
Use the undo mac-address max-mac-count command to remove the restriction on the maximum number of MAC addresses that can be learned on an Ethernet port.
By default, no maximum number of MAC addresses that can be learned on a port is configured.
If the command is executed in interface view, the configuration takes effect on the current interface; if the command is executed in port group view, the configuration takes effect on all ports belonging to the port group.
By using this command with the static MAC address function, you can disable an interface or a port group from learning MAC addresses, and only allow the packets with the specified destination address to pass, thus avoiding the access to the network from the illegal devices.
The Layer-2 aggregate interface and member interface not support this function.
# Set the maximum number of MAC addresses that can be learned on port GigabitEthernet 2/0/1 to 600. After this upper limit is reached, frames received with unknown destination MAC addresses on the port will not be forwarded.
[Sysname-GigabitEthernet2/0/1] mac-address max-mac-count 600
mac-address timer
undo mac-address timer aging
View
Default Level
2: System level
aging seconds: Sets an aging timer in seconds for dynamic MAC address entries,in the range 10 to 86400.
no-aging: Sets dynamic MAC address entries not to age.
Use the mac-address timer command to configure the aging timer for dynamic MAC address entries.
Use the undo mac-address timer command to restore the default.
By default the default aging timer is 300 seconds.
Set the aging timer appropriately: a long aging interval may cause the MAC address table to retain outdated entries and fail to accommodate the latest network changes; a short interval may result in removal of valid entries and hence unnecessary broadcasts which may affect device performance.
# Set the aging timer for dynamic MAC address entries to 500 seconds.
