- 08-System Volume
- 00-System Volume Organization
- 01-Login Commands
- 02-Basic System Configuration Commands
- 03-Device Management Commands
- 04-File System Management Commands
- 05-SNMP Commands
- 06-RMON Commands
- 07-MAC Address Table Management Commands
- 08-System Maintaining and Debugging Commands
- 09-Information Center Commands
- 10-PoE Commands
- 11-Track Commands
- 12-NQA Commands
- 13-NTP Commands
- 14-VRRP Commands
- 15-HA Commands
- 16-Hotfix Commands
| 00-System Volume Organization | 56.76 KB |
Manual Version
20091105-C-1.03
Product Version
Release 6300 series
Organization
The System Volume is organized as follows:
Features |
Login |
Upon logging into a device, you can configure user interface properties and manage the system conveniently. This document introduces the commands for: l
Logging In Through the l Logging In Through Telnet/SSH l Logging In Using Modem l Specifying Source for Telnet Packets l Controlling Login Users |
Basic System Configuration |
Basic system configuration involves the configuration of device name, system clock, welcome message, and user privilege levels. This document introduces the commands for: l Configuring the device name, the system clock and a Banner l Configuring CLI Hotkeys l Configuring User Privilege Levels and Command Levels l Multiple-screen output configuring |
Device Management |
Through the device management function, you can view the current condition of your device and configure running parameters. This document introduces the commands for: l Rebooting a device l Configuring the scheduled automatic execution function l Specifying a file for the next device boot l Upgrading Boot ROM l Configuring a detection interval l Configuring temperature alarm thresholds for a board l Clearing the 16-bit interface indexes not used in the current system l Configuring the system load sharing function l Enabling Active/Standby Mode for Service Ports on SRPUs l Configuring the traffic forwarding mode of SRPUs l Configuring the working mode of EA LPUs l Enabling the port down function globally l Enabling expansion memory data recovery function on a board l Identifying and diagnosing pluggable transceivers |
File System Management |
A major function of the file system is to manage storage devices, mainly including creating the file system, creating, deleting, modifying and renaming a file or a directory and opening a file. This document introduces the commands for: l File system management l Configuration File Management l FTP configuration l TFTP configuration |
SNMP |
Simple network management protocol (SNMP) offers a framework to monitor network devices through TCP/IP protocol suite. This document introduces the commands for: l Basic SNMP function configuration l SNMP log configuration l Trap configuration |
RMON |
RMON provides an efficient means of monitoring subnets and allows SNMP to monitor remote network devices in a more proactive and effective way. This document introduces the commands for RMON configuration (event group, history group, alarm group, private alarm group) |
MAC Address Table Management |
A switch maintains a MAC address table for fast forwarding packets. This document introduces the commands for: l How a MAC Address Table Entry is Generated l Configuring MAC Address Entries l Disabling MAC Address Learning l Configuring the Aging Timer for Dynamic MAC Address Entries |
System Maintaining and Debugging |
For the majority of protocols and features supported, the system provides corresponding debugging information to help users diagnose errors. This document introduces the commands for maintenance and debugging configuration |
Information Center |
As the system information hub, Information Center classifies and manages all types of system information. This document introduces the commands for: l Setting to Output System Information to the Console l Setting to Output System Information to a Monitor Terminal l Setting to Output System Information to a Log Host l Setting to Output System Information to the Trap Buffer l Setting to Output System Information to the Log Buffer l Setting to Output System Information to the SNMP Module l Setting to Save System Information to a Log File l Configuring Synchronous Information Output |
PoE |
The Power over Ethernet (PoE) feature enables the power sourcing equipment (PSE) to feed powered devices (PDs) from Ethernet ports through twisted pair cables. This document introduces the commands for: l Configuring PoE power supply l Configuring the PSE l Configuring the PoE interface l Configuring PoE power management l Configuring the PoE monitoring function l Online upgrading the PSE processing software l Enabling the PSE to detect nonstandard PDs |
Track |
The track module is used to implement collaboration between different modules through established collaboration objects. The detection modules trigger the application modules to perform certain operations through the track module. This document introduces the commands for: l Configuring Collaboration Between the Track Module and the Detection Modules l Configuring Collaboration Between the Track Module and the Application Modules |
NQA |
NQA analyzes network performance, services and service quality by sending test packets to provide you with network performance and service quality parameters. This document introduces the commands for: l Configuring an NQA Test Group l Configuring the Collaboration Function l Configuring Optional Parameters Common to an NQA Test Group |
NTP |
Network Time Protocol (NTP) is the TCP/IP that advertises the accurate time throughout the network. This document introduces the commands for: l Configuring the Operation Modes of NTP l Configuring the Local Clock as a Reference Source l Configuring Optional Parameters of NTP l Configuring Access-Control Rights l Configuring NTP Authentication |
VRRP |
Virtual Router Redundancy Protocol (VRRP) combines a group of switches (including a master and multiple backups) on a LAN into a virtual router called VRRP group. VRRP streamlines host configuration while providing high reliability. This document introduces the commands for: l IPv4-Based VRRP configuration l IPv6-Based VRRP configuration |
HA |
High Availability (HA) is to achieve a high availability of the system. Devices supporting HA are typically equipped with two SRPUs to provide active-standby backup. This document introduces the commands for: l Restarting the SMB l Manually Configuring Switchover Between the AMB and SMB |
Hotfix |
Hotfix is a fast, cost-effective method to fix software defects of the device without interrupting the running services. This document introduces the commands for hotfix operations (including loading, activating, running, deactivating, and deleting patch files) |
