H3C S3600 Command Manual-Release 1602(V1.02)
HomeSupportSwitchesS3600 SeriesReference GuidesCommand ReferencesH3C S3600 Command Manual-Release 1602(V1.02)
45-Access Management Command
45-Access Management Command 31.25 KB
Access Management Configuration Commands
am enable
am enable
undo am enable
View
None
Use the am enable command to enable the access management function.
Use the undo am enable command to disable the function.
By default, Access management function is disabled.
Before enabling access management, you are recommended to cancel the static ARP configuration to ensure that the binding of IP address and Ethernet switch can take effect.
# Enable the access management function.
[Sysname] am enable
am ip-pool
am ip-pool address-list
undo am ip-pool { all | address-list }
View
Ethernet port view
all: Specifies all the IP addresses (or IP address pools).
address-list: IP address list. You need to provide this argument in the format of start-ip-address [ ip-address-number ]  & < 1-10 >, where start-ip-address is the start IP address of an IP address range in the address pool, ip-address-number specifies the number of the successive IP addresses following start-ip-address in the range, and & < 1-10 > means you can specify up to ten IP addresses/IP address ranges.
Use the am ip-pool command to configure the access management IP address pool on a port. For a port with the access management IP address pool configured, only the hosts with their IP addresses being in the access management pool can access external networks through the port.
Use the undo am ip-pool command to remove part of or all the IP addresses from the access management IP address pool of a port.
By default, the access management IP address pool is null.
Note that:
l          Before configuring the access management IP address pool of a port, you need to configure the interface IP address of the VLAN to which the port belongs, and the IP addresses in the access management IP address pool of a port must be in the same network segment as the interface IP address of the VLAN which the port belongs to.
l          If an access management address pool configured contains IP addresses that belong to the static ARP entries of other ports, the system prompts you to delete the corresponding static ARP entries to ensure the access management IP address pool can take effect.
# Configure the access management IP address pool on Ethernet 1/0/1 to allow hosts with their IP addresses being in the range 202.112.66.2 to 202.112.66.20 and 202.112.65.1 to access external networks through the port.
[Sysname-Ethernet1/0/1] am ip-pool 202.112.66.2 19 202.112.65.1
# Remove all the IP addresses from the access management IP address pool of port Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] undo am ip-pool all
am trap enable
am trap enable
undo am trap enable
View
None
Use the am trap enable command to enable the access management trap function.
Use the undo am trap enable command to disable the access management trap function.
By default, the access management trap function is disabled.
# Enable the access management trap.
[Sysname] am trap enable
display am
display am [ interface-list ]
View
interface-list: Port list. You need to provide this argument in the format of { interface-type interface-number [ to interface-type interface-number ] } &<1-10>, where interface-type is port type, interface-number is port number, and &<1-10> means that you can specify up to ten ports/port lists.
Use the display am command to display the current access management configuration, including the status (enabled/disabled), and the access management IP address pool configuration information.
If you do not specify the interface-list argument, this command displays the current access management configuration of all the ports.
# Display the access management configurations of Ethernet 1/0/1 and Ethernet 1/0/2.
<Sysname> display am Ethernet 1/0/1 Ethernet 1/0/2
Ethernet1/0/1
 Status       : enabled
 IP Pools     : 10.10.1.1(19) 10.10.1.30(1)
Ethernet1/0/2
 Status       : enabled
 IP Pools     : (NULL)
Table 1-1 Description on the fields of the display am command
Status
Access Management state of a port: enabled or disabled
IP Pools
Access management IP pools. NULL means the access management IP pool is not configured. Each IP address range is represented as X.X.X.X (number), among which “X.X.X.X” is the starting address and “number” indicates the number of successive IP addresses contained in the IP address range.
