H3C S3600 Command Manual-Release 1602(V1.02)
HomeSupportSwitchesS3600 SeriesReference GuidesCommand ReferencesH3C S3600 Command Manual-Release 1602(V1.02)
39-System Maintenance and Debugging Command
39-System Maintenance and Debugging Command 169.27 KB
Basic System Configuration and Debugging Commands
l          The configuration of real-time monitoring of the running status of the system is added. For the detailed configuration, refer to section system-monitor enable.
l          The configuration of loading hot patch is added. For the detailed configuration, refer to sections display patch-information, patch activate, patch delete, patch load, and patch run.
l          The configuration of identifying and diagnosing pluggable transceivers is added. For the detailed configuration, refer to sections display transceiver alarm interface, display transceiver diagnosis interface, display transceiver interface, and display transceiver manuinfo interface.
l          The language-mode command is deleted.
Basic System Configuration Commands
clock datetime
clock datetime HH:MM:SS { YYYY/MM/DD | MM/DD/YYYY }
View
HH:MM:SS: Current time, namely, hour:minute:second. HH ranges from 0 to 23, and MM and SS range from 0 to 59.
YYYY/MM/DD or MM/DD/YYYY: Current date, where YYYY represents year ranging from 2000 to 2099, MM represents month ranging from 1 to 12, and DD represents day ranging from 1 to 31.
Use the clock datetime command to set the current date and time of the Ethernet switch.
By default, it is 23:55:00 04/01/2000 when the system starts up.
In an implementation where exact absolute time is required, it is necessary to use this command to set the current date and time of the Ethernet switch.
After the setting, you can use the display clock command to check your configuration.
# Set the current date and time of the Ethernet switch to 0:0:0 2001/01/01.
<Sysname> clock datetime 0:0:0 2001/01/01
<Sysname> display clock
00:00:04 UTC Mon 01/01/2001
Time Zone : add 00:00:00
clock summer-time
clock summer-time zone-name { one-off | repeating } start-time start-date end-time end-date offset-time
undo clock summer-time
View
zone-name: Name of the summer time, a string of 1 to 32 characters.
one-off: Sets the summer time for only one year (the specified year).
repeating: Sets the summer time for every year starting from the specified year.
start-time: Start time of the summer time, in the form of HH:MM:SS.
start-date: Start date of the summer time, in the form of YYYY/MM/DD or MM/DD/YYYY.
end-time: End time of the summer time, in the form of HH:MM:SS.
end-date: end date of the summer time, in the form of YYYY/MM/DD or MM/DD/YYYY.
offset-time: Offset of the summer time relative to the standard time, in the form of HH:MM:SS.
Use the clock summer-time command to set the summer time, including the name, time range and time offset.
After the setting, you can use the display clock command to check the results.
# Set the summer time named abc1, which starts from 06:00:00 2005/08/01, ends until 06:00:00 2005/09/01, and is one hour ahead of the standard time.
<Sysname> clock summer-time abc1 one-off 06:00:00 08/01/2005 06:00:00 09/01/2005 01:00:00
00:02:36 UTC Mon 01/01/2001
Summer-Time : abc1 one-off 06:00:00 08/01/2005 06:00:00 09/01/2005  01:00:00
# Set the summer time named abc2, which starts from 06:00:00 08/01, ends until 06:00:00 09/01, and is one hour ahead of the standard time every year from 2005 on.
<Sysname> clock summer-time abc2 repeating 06:00:00 08/01/2005 06:00:00 09/01/2005 01:00:00
00:01:25 UTC Mon 01/01/2001
Summer-Time : abc2 repeating 06:00:00 08/01/2005 06:00:00 09/01/2005  01:00:00
clock timezone
clock timezone zone-name { add | minus } HH:MM:SS
undo clock timezone
View
zone-name: Name of the time zone, in length of 1 to 32 characters.
add: Specifies to add a time value based on the universal time coordinated (UTC) time to generate a later time.
minus: Specifies to subtract a time value based on the UTC time to generate an earlier time.
HH:MM:SS: Time to be added or subtracted from the UTC time, in the form of HH:MM:SS.
Use the clock timezone command to set the local time zone.
Use the undo clock timezone command to restore the local time zone to the default UTC time zone.
After the setting, you can use the display clock command to check the setting. The log information time and the debugging information time adopts the local time after the time zone and the summer time have been adjusted.
Related commands: clock summer-time, display clock.
# Set the local time zone named z5, which is five hours ahead of the UTC time.
<Sysname> clock timezone z5 add 05:00:00
05:03:17 z5 Mon 01/01/2001
Time Zone : z5 add 05:00:00
View
None
Use the quit command to return from current view to a lower level view.
The following lists the three levels of views available on a switch (from lower level to higher level):
l          User view
l          System view
l          VLAN view, Ethernet port view, and so on
If the current view is user view, this command is used to quit the system.
Related commands: return, system-view.
# Return from system view to user view.
[Sysname] quit
<Sysname>
# Return to system view from Ethernet port view.
[Sysname-Ethernet1/0/1] quit
[Sysname]
return
return
View
Views other than user view
None
Use the return command to return from current view to user view. The composite key <Ctrl+Z> has the same effect with the return command.
Related commands: quit.
# Return from Ethernet port view to user view.
[Sysname-Ethernet1/0/1] return
<Sysname>
sysname
sysname sysname
undo sysname
View
sysname: System name of the Ethernet switch. It is a string of 1 to 30 characters. By default, it is H3C.
Use the sysname command to set the system name of an Ethernet switch. Use the undo sysname command to restore the default system name of the Ethernet switch.
Changing the system name will affect the CLI prompt. For example, if the system name of the switch is H3C, the prompt for user view is <H3C>.
# Set the system name of the Ethernet switch to LSW.
[Sysname] sysname LSW
[LSW]
View
None
Use the system-view command to enter system view from user view.
Related commands: quit, return.
# Enter system view from user view.
[Sysname]
System Status and Information Display Commands
display clock
display clock
View
None
Use the display clock command to display the current date, time, timezone and summertime of the system, so that you can adjust them if they are wrong.
The maximum date and time that can be displayed by this command is 23:59:59 9999/12/31.
Related commands: clock datetime, clock timezone, clock summer-time.
# Display the current date and time of the system.
18:36:31 beijing Sat 2002/02/02
Time Zone : beijing add 01:00:00
Summer-Time : bj one-off 01:00:00 2003/01/01 01:00:00 2003/08/08 01:00:00
Table 1-1 Description on the fields of the display clock command
Current date and time of the system
Time Zone
Configured time zone information
Summer-Time
Configured summer time information
display debugging
display debugging [ unit unit-id ] [ interface interface-type interface-number ] [ module-name ]
display debugging fabric [ by-module | interface interface-type interface-number [ module-name ] | module-name ]
View
unit-id: Unit ID of a switch.
interface-type: Interface type.
interface-number: Interface number.
module-name: Functional module name.
fabric: Specifies to display the enabled debugging of the switches in the Fabric.
by-module: Specifies to display fabric debugging by module.
Use the display debugging command to display enabled debugging on a specified device or the whole Fabric.
# Display enabled debugging on unit 1.
<Sysname> display debugging unit 1
IP icmp debugging is on
Rip packet debugging switch is on
Rip receive debugging switch is on
Rip send debugging switch is on
display version
display version
View
None
Use the display version command to display the version information about the switch system.
Specifically, you can use this command to check the software version and release time, the basic hardware configuration, and some other information about the switch.
# Display the version information of the system.
<Sysname> display version
H3C Comware Platform Software
Comware Software, Version 3.10, Test 1545
Copyright (c) 2004-2007 Hangzhou H3C Technologies Co., Ltd. All rights reserved.
S3600-52P-EI uptime is 0 week, 0 day, 23 hours, 15 minutes
S3600-52P-EI with 1 Processor
64M     bytes DRAM
16384K  bytes Flash Memory
Config Register points to FLASH
Hardware Version is REV.C
CPLD Version is CPLD 001
Bootrom Version is 510
[Subslot 0] 48 FE Hardware Version is REV.C
[Subslot 1] 4 GE  Hardware Version is REV.C
System Debugging Commands
debugging
debugging module-name [ debugging-option ]
undo debugging { all | module-name [ debugging-option ] }
View
module-name: Module name.
debugging-option: Debugging option.
all: Specifies to disable all debugging.
Use the debugging command to enable system debugging.
Use the undo debugging command to disable system debugging.
By default, all debugging is disabled.
Note that:
l          Enabled debugging will generate a great deal of debugging information and thus will affect the efficiency of the system. Therefore, it is recommended not to enable debugging for multiple functions at the same time. To disable all debugging at a time, you can use the undo debugging all command.
l          The specific debugging information can be displayed on a terminal only after you have configured the debugging, terminal debugging, and terminal monitor commands.
l          To display the enabled debugging types, use the display debugging command.
For information about the terminal monitor command, refer to Information Center Command.
# Enable packet debugging of the IP module.
<Sysname> debugging ip packet
IP packet debugging is on
display diagnostic-information
View
None
Use the display diagnostic-information command to display or save the running statistics of the system function modules. If you choose to save the statistics, the system will save the statistics to a file with the extension .diag in the Flash memory.
# Save the running statistics of the system function modules to the file default.diag.
 This operation may take a few minutes, continue?[Y/N]y
 Diagnostic-information is saved to Flash or displayed(Y=save N=display)?[Y/N]y
 Please input the file name(*.diag)[flash:/default.diag]:
 The file is already existing, overwrite it? [Y/N]y
% Output information to file: flash:/default.diag.
Please wait......
After saving the information, you can use the more default.diag command in user view to view the contents of the file (default.diag) with the Page Up and Page Down keys.
# Display the running statistics of the system function modules.
 Diagnostic-information is saved to Flash or displayed(Y=save N=display)?[Y/N]n
-------------------- display version --------------------
<Omitted>
terminal debugging
terminal debugging
undo terminal debugging
View
None
Use the terminal debugging command to enable terminal display for debugging information.
Use the undo terminal debugging command to disable terminal display for debugging information.
By default, terminal display for debugging information is disabled.
Note that:
l          To display the debugging information on the terminal, you need to configure both the terminal debugging and terminal monitor commands.
l          If you execute the undo terminal monitor command, you will disable the monitoring of the log, trap, and debugging information on the current terminal. Thereby, no log, trap, or debugging information will be displayed on the terminal.
l          The configuration of the terminal debugging command takes effect for the current connection only. If the terminal re-establishes a connection, the terminal display for debugging information is disabled.
Related commands: debugging.
# Enable terminal display for debugging information.
<Sysname> terminal debugging
% Current terminal debugging is on
Network Connectivity Test Commands
ping
ping [ -a ip-address ] [-c count ] [ -d ] [ -f ] [ -h ttl ] [ -i interface-type interface-number ] [ ip ] [ -n ] [ - p pattern ] [ -q ] [ -s packetsize ] [ -t timeout ] [ -tos tos ] [ -v ] string
View
-a ip-address: Specifies the source IP address to send ICMP ECHO-REQUEST packet. This IP address must be a local interface IP address.
-c count: Specifies how many times the ICMP ECHO-REQUEST packet will be sent. The count argument is the times, which ranges from 1 to 4,294,967,295 and defaults to 5.
-d: Specifies the socket to be in DEBUGGING mode. By default, the socket is in non-DEBUGGING mode.
-f: Specifies to discard a packet directly instead of fragmenting it if its length is greater than the maximum transmission unit (MTU) of the interface.
-h ttl: Specifies the Time To Live (TTL) value of the ICMP ECHO-REQUEST packets in the range 1 to 255. By default, the TTL value is 255.
-i interface-type interface-number: Specifies the ICMP echo request sending interface by its type and number. With the interface specified, the TTL of packets are set to 1 automatically to test the directly-connected device (the IP address of the device is in the same network segment with that of the interface).
ip: Specifies the device to support IPv4. By default, the device supports IPv4.
-n: Specifies to directly regard the host argument as an IP address without performing domain name resolution. By default, the host argument is first regarded as an IP address; if it is not an IP address, domain name resolution is performed.
-p pattern: Specifies the padding byte pattern of the ICMP ECHO-REQUEST packets. The pattern argument is a byte in hexadecimal. For example, -p ff fills a packet with all ffs. By default, the system fills a packet with 0x01, 0x02, and so on, until 0x09; then it repeats this procedure from 0x01 again.
-q: Specifies to display only the statistics without the details. By default, all the information including the details and statistics will be displayed.
-s packetsize: Specifies the size (in bytes) of each ICMP ECHO-REQUEST packet (excluding the IP and ICMP headers). The packetsize argument ranges from 20 to 32,000 and defaults to 56 bytes.
-t timeout: Specifies the timeout time (in milliseconds) before an ICMP ECHO-REPLY packet is received after an ICMP ECHO-REQUEST packet is sent. The timeout argument ranges from 0 to 65535 ms and defaults to 2,000 ms.
-tos tos: Specifies the ToS value of the ICMP ECHO-REQUEST packets in the range 0 to 255. By default, this value is 0.
-v: Specifies to display other ICMP packets received (that is, non-ECHO-REPLY packets). By default, other ICMP packets like non-ECHO-REPLY packets are not displayed.
string: Host name of the destination host, ranging from 1 to 30 characters.
The ping command also supports the ipv6 keyword. For details, refer to IPv6 Management Command.
Use the ping command to check the reachability of a host, and output the related statistics information.
The executing procedure of the ping command is as follows: First, the source host sends an ICMP ECHO-REQUEST packet to the destination host. If the connection to the destination network is normal, the destination host receives this packet and responds with an ICMP ECHO-REPLY packet.
You can use the ping command to check the network connectivity and the quality of a network line. This command can output the following information:
l          Response status of the destination to each ICMP ECHO-REQUEST packet, including the number of bytes, packet sequence number, TTL and response time of the response packet if the response packet is received within the timeout time. If no response packet is received within the timeout time, the message "Request time out" is displayed instead.
l          Final statistics, including the numbers of sent packets and received response packets, the irresponsive packet percentage, and the minimum, average and maximum values of response time.
You can set a relatively long timeout time if the network transmission speed is slow.
Related commands: tracert.
# Check the reachability of the host whose IP address is 202.38.160.244.
<Sysname> ping 202.38.160.244
ping 202.38.160.244 : 56 data bytes, press CTRL_C to break
Reply from 202.38.160.244 : bytes=56 sequence=1 ttl=255 time = 1ms
Reply from 202.38.160.244 : bytes=56 sequence=2 ttl=255 time = 2ms
Reply from 202.38.160.244 : bytes=56 sequence=3 ttl=255 time = 1ms
Reply from 202.38.160.244 : bytes=56 sequence=4 ttl=255 time = 3ms
Reply from 202.38.160.244 : bytes=56 sequence=5 ttl=255 time = 2ms
--202.38.160.244 ping statistics--
5 packet transmitted
5 packet received
0% packet loss
round-trip min/avg/max = 1/2/3 ms
The above output information indicates that the destination host is reachable. Each probe packet from the source device has got a reply, with the minimum/average/maximum packet roundtrip time being 1ms/2ms/3ms.
tracert
tracert [ -a source-ip ] [ -f first-ttl ] [ -m max-ttl ] [ -p port ] [ -q num-packet ] [ -w timeout ] string
View
-a source-ip: Specifies the source interface IP address used by this command.
-f first-ttl: Specifies the initial TTL value of the packets to be sent, so as to only display the addresses of those gateways on the path whose hop counts are not smaller than the hop count specified by the first-ttl argument. For example, if the first-ttl argument is 3, the command displays the addresses of the gateways from the third hop. The first-ttl argument ranges from 1 to 255 and defaults to 1.
-m max-ttl: Specifies the maximum TTL value of the packets to be sent. After the command sends a packet with the maximum TTL, it will not send any more packets. With this argument, this command only displays the addresses of those gateways from the source address to hop according to the hop count specified by the argument. For example, if the max-ttl argument is 5, the command displays the addresses of the gateways from the source to the fifth hop. The max-ttl argument ranges from 1 to 255 and defaults to 30.
-p port: Specifies the destination port of the packets to be sent. The port argument ranges from 0 to 65535 and defaults to 33434. Generally, you need not change the argument.
-q num-packet: Specifies the number of packets to be sent each time. The num-packet  argument ranges from 0 to 65,535 and defaults to 3.
-w timeout: Specifies the timeout time to wait for ICMP error packets. The timeout argument ranges from 0 to 65,535 and defaults to 5,000 (in milliseconds).
string: Host name of the destination host, in the range of 1 to 20 characters.
The tracert command also supports the ipv6 keyword. For details, refer to IPv6 Management Command.
Use the tracert command to trace the gateways that the test packets pass through from the source device to the destination device. This command is mainly used to check the network connectivity and help locate the network faults.
The executing procedure of the tracert command is as follows: First, the source sends a packet with the TTL of 1, and the first hop device returns an ICMP error message indicating that it cannot forward this packet because of TTL timeout. Then, the source resends a packet with the TTL of 2, and the second hop device also returns an ICMP TTL timeout message. This procedure goes on and on until a packet gets to the destination or the maximum TTL is reached. During the procedure, the system records the source address of each ICMP TTL timeout message in order to offer the path that the packets pass through to the destination.
If you find that the network is faulty by using the ping command, you can use the tracert command to find the faulty nodes in the network.
The tracert command can output the IP addresses of all the gateways that the packets pass through to the destination. It outputs the string "***" if the response from a gateway times out.
# Trace the gateways that the packets pass through to the destination with IP address 18.26.0.115.
<Sysname> tracert 18.26.0.115
tracert to 18.26.0.115 (18.26.0.115), 30 hops max,40 bytes packet
1 128.3.112.1 (128.3.112.1) 0 ms 0 ms 0 ms
2 128.32.216.1 (128.32.216.1) 19 ms 19 ms 19 ms
3 128.32.206.1 (128.32.206.1) 39 ms 19 ms 19 ms
4 128.32.136.23 (128.32.136.23) 19 ms 39 ms 39 ms
5 128.32.168.22 (128.32.168.22) 20 ms 39 ms 39 ms
6 128.32.197.4 (128.32.197.4) 59 ms 119 ms 39 ms
7 131.119.2.5 (131.119.2.5) 59 ms 59 ms 39 ms
8 129.140.70.13 (129.140.70.13) 80 ms 79 ms 99 ms
9 129.140.71.6 (129.140.71.6) 139 ms 139 ms 159 ms
10 129.140.81.7 (129.140.81.7) 199 ms 180 ms 300 ms
11 129.140.72.17 (129.140.72.17) 300 ms 239 ms 239 ms
12 * * *
13 128.121.54.72 (128.121.54.72) 259 ms 499 ms 279 ms
14 * * *
15 * * *
16 * * *
17 * * *
18 18.26.0.115 (18.26.0.115) 339 ms 279 ms 279 ms
Device Management Commands
boot boot-loader
boot boot-loader [ backup-attribute ] { file-url [ fabric ] | device-name }
View
backup-attribute: Specifies the backup attribute for a file.
file-url: Path plus name of a host software file in the Flash, a string of 1 to 64 characters.
fabric: Specifies the file path in fabric mode.
device-name: File name, in the form of unit[NO.]>flash:, which is used to indicate that the specified file is stored in the Flash memory of a specified switch.
Use the boot boot-loader command to specify the host software that will be used when the switch starts up next time.
You can use this command to specify a .bin file in the Flash as the host software to be adopted at next startup.
# Specify the host software that will be used when the current switch starts up next time.
<Sysname> boot boot-loader S3600.BIN
The specified file will be booted next time on unit 1!
boot bootrom
boot bootrom { file-url | device-name }
View
file-ulr: Path plus name of a Boot ROM file (that is, a .btm file) in the Flash, a string of 1 to 64 characters.
device-name: File name, beginning with a device name in the form of unit[NO.]>flash, used to indicates that the specified file is stored in the Flash memory of a specified switch.
Use the boot bootrom command to update the Boot ROM. The updated Boot ROM is used at next startup.
# Update the Boot ROM of the switch using the file named S3600.btm.
<Sysname> boot bootrom S3600.btm
 This will update Bootrom on unit 1.  Continue? [Y/N] y
 Upgrading Bootrom, please wait...
 Upgrade Bootrom succeeded!
display boot-loader
display boot-loader [ unit unit-id ]
View
Use the display boot-loader command to display the host software (.bin file) that will be adopted when the switch starts up next time.
# Display the host software that will be adopted when the switch starts up next time.
<Sysname> display boot-loader
 Unit 1:
   The current boot app is: s3600.bin
   The main boot app is:    s3600.bin
   The backup boot app is:  s3600backup.bin
Table 3-1 Description on the fields of the display boot-loader command
Boot file used for the current boot of the system
Main boot file to be used for the next boot of the system
Backup boot file to be used for the next boot of the system
display cpu
display cpu [ unit unit-id ]
View
Use the display cpu command to display the CPU usage.
# Display the CPU usage of this switch.
<Sysname> display cpu
Unit 1
Board 0 CPU busy status:
    12% in last 5 seconds
    12% in last 1 minute
    12% in last 5 minutes
Table 3-2 Description on the fields of the display cpu command
CPU busy status
CPU usage status.
The CPU usage in the last five seconds is 12%.
The CPU usage in the last one minute is 12%.
The CPU usage in the last five minutes is 12%.
display device
display device [ manuinfo [ unit unit-id ] | unit unit-id ]
View
manuinfo: Specifies to display the manufacture information of the specified switch.
Use the display device command to display the information, such as the module type and operating status, about each board (main board and sub-board) of a specified switch.
You can use this command to display the following information about each board, including slot number, sub-slot number, the number of ports, versions of PCB, FPGA, CPLD and Boot ROM software, address learning mode, interface board type, and so on.
# Display board information of this switch.
<Sysname> display device
Unit 1
SlotNo SubSNo PortNum PCBVer FPGAVer CPLDVer BootRomVer AddrLM Type       State
0       0       24       REV.C   NULL    001      510         IVL    MAIN     Normal
0       1       4        REV.C   NULL    001      NULL        IVL    4 GE     Normal
Table 3-3 Description on the fields of the display device command
SlotNo
Serial number of the slot
SubSNo
Serial number of the sub slot
PortNum
Number of ports
PCBVer
Version number of the PCB card
FPGAVer
Version number of the FPGA encapsulation
CPLDVer
Logical version number of the hardware CPLD
BootRomVer
Version number of the Boot ROM
AddrLM
MAC address learning mode
Card type
Running state
display fan
display fan [ unit unit-id [ fan-id ] ]
View
fan-id: ID number of a fan.
Use the display fan command to view the working states of fans in a switch.
# Display the working states of the fans.
<Sysname> display fan
Unit 1
 Fan  1 State: Normal
The above information indicates that the fan works normally.
display memory
display memory [ unit unit-id | limit ]
View
limit: Specifies to display the memory configuration information of the switch.
Use the display memory command to display the memory usage of a specified switch.
Currently, the limit keyword is available on S3600-EI series Ethernet switches only.
# Display the memory usage of this switch.
<Sysname> display memory
Unit 1
System Available Memory(bytes): 30045312
System Used Memory(bytes): 15698468
Used Rate: 52%
Table 3-4 Description on the fields of the display memory command
Available memory size of the system, in bytes
Used memory size of the system, in bytes
Used Rate
Percentage of the used memory
# Display the current memory configuration information of this switch.
<Sysname> display memory limit
Current memory limit configuration information:
  system memory safety: 5 (MBytes)
  system memory limit: 4 (MBytes)
  auto-establish enabled
Free Memory: 17067424 (Bytes)
The state information about connection:
  The times of disconnect: 0
  The times of reconnect: 0
  The current state: Normal
Table 3-5 Description on the fields of the display memory limit command.
Safety threshold of the system memory, in Mbytes. When the available memory is above the threshold, the system resumes the connection of the routing protocol.
system memory limit
Limit threshold of the system memory, in Mbytes. When the available memory drops below the threshold, the system cuts the connection of the routing protocol.
Automatically establish routing protocol connections when the system memory is above the safety threshold
Free Memory
Free memory of the system, in bytes
Information about the current routing protocol connection
Number of times that the system automatically disconnects the routing protocol connection
Number of times that the system automatically re-establishes the routing protocol connection
The current state
The current routing protocol connection status
View
None
Use the display patch-information command to display the state information about the patches loaded in the system, including patch version number, patch baseline version number, and patch state.
# Display the state information about the patches loaded in the system.
<Sysname> display patch-information
----------Patch information----------
  patch version          P001
  program version        1510
  patch  status          DEACTIVE
Table 3-6 Description on the fields of the display patch-information command
patch version
Patch version number
program version
Patch baseline version number
patch status
Patch state: IDLE, DEACTIVE, ACTIVE, RUNNING
display power
display power [ unit unit-id [ power-id ] ]
View
power-id: Power ID.
Use the display power command to display the working state of the power supply of the switch.
# Display the working state of the power supply.
<Sysname> display power
Unit 1
  power    1
  State    : Normal
  Type     : AC
The above information indicates that the power supply type is AC, and works normally.
display schedule reboot
View
None
Use the display schedule reboot command to display information about scheduled reboot.
Related commands: schedule reboot at, schedule reboot delay.
# Display the information about scheduled reboot.
<Sysname> display schedule reboot
System will reboot at 16:00:00 2002/11/1 (in 2 hours and 5 minutes).
View
interface-type interface-number: Interface type and interface number.
Use the display transceiver alarm interface command to display the current alarm information of a single or all transceivers.
If no error occurs, None is displayed.
Table 3-7 shows the alarm information that may occur for the four types of transceivers.
Table 3-7 Description on the fields of display transceiver alarm interface
Remarks
GBIC/SFP
RX loss of signal
RX signal is lost.
RX power high
RX power is high.
RX power low
RX power is low.
TX fault
TX fault
TX bias high
TX bias current is high.
TX bias low
TX bias current is low.
TX power high
TX power is high.
TX power low
TX power is low.
Temp high
Temperature is high.
Temp low
Temperature is low.
Voltage high
Voltage is high.
Voltage low
Voltage is low.
Transceiver info I/O error
Transceiver information read and write error
Transceiver info checksum error
Transceiver information checksum error
Transceiver type and port configuration mismatch
Transceiver type does not match port configuration.
Transceiver type not supported by port hardware
Transceiver type is not supported on the port.
XFP
RX loss of signal
RX signal is lost.
RX not ready
RX is not ready
RX CDR loss of lock
RX clock cannot be recovered.
RX power high
RX power is high.
RX power low
RX power is low.
TX not ready
TX is not ready.
TX fault
TX fault
TX CDR loss of lock
TX clock cannot be recovered.
TX bias high
TX bias low
TX power high
TX power is high.
TX power low
TX power is low.
Module not ready
Module is not ready.
APD supply fault
APD (Avalanche Photo Diode) supply fault
TEC fault
TEC (Thermoelectric Cooler) fault
Wavelength unlocked
Wavelength of optical signal exceeds the manufacturer’s tolerance.
Temp high
Temp low
Temperature is low.
Voltage high
Voltage is high.
Voltage low
Voltage is low.
XENPAK
WIS local fault
WIS (WAN Interface Sublayer) local fault
Receive optical power fault
PMA/PMD receiver local fault
PMA/PMD (Physical Medium Attachment/Physical Medium Dependent) receiver local fault
PCS receive local fault
PCS (Physical Coding Sublayer) receiver local fault
PHY XS receive local fault
PHY XS (PHY Extended Sublayer) receive local fault
RX power high
RX power is high.
RX power low
RX power is low.
Laser bias current fault
Laser temperature fault
Laser output power fault
TX fault
TX fault
TX bias high
TX bias low
TX power high
TX power is high.
TX power low
TX power is low.
Temp high
Temp low
Temperature is low.
For pluggable transceivers supported by S3600 series Ethernet switches, refer to H3C S3600 Series Ethernet Switches  Installation Manual.
# Display the alarm information of the transceiver on interface GigabitEthernet 1/1/1.
<Sysname> display transceiver alarm interface gigabitethernet 1/1/1
GigabitEthernet1/1/1 transceiver current alarm information:
  TX fault
Table 3-8 Description on the fields of display transceiver alarm interface
Current alarm information of the transceiver
TX fault
TX fault
View
Use the display transceiver diagnosis interface command to display the currently measured value of digital diagnosis parameters of a single or all anti-spoofing transceivers customized by H3C.
# Display the currently measured value of digital diagnosis parameters of the anti-spoofing pluggable optical transceiver customized by H3C on interface GigabitEthernet 1/1/2.
<Sysname> display transceiver diagnosis interface gigabitethernet 1/1/2
GigabitEthernet1/1/2 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    36        3.31        6.13      -35.64         -5.19
Table 3-9 Description on the fields of display transceiver diagnosis interface
Digital diagnosis information of the transceiver carried by an interface
Temp.(°C)
Digital diagnosis parameter-temperature, in °C, with the precision to 1°C.
Voltage(V)
Digital diagnosis parameter-voltage, in V, with the precision to 0.01 V.
Bias(mA)
Digital diagnosis parameter-bias current, in mA, with the precision to 0.01 mA.
RX power(dBM)
Digital diagnosis parameter-RX power, in dBM, with the precision to 0.01 dBM.
TX power(dBM)
Digital diagnosis parameter-TX power, in dBM, with the precision to 0.01 dBM.
View
Use the display transceiver interface command to display main parameters of a single or all transceivers.
# Display main parameters of the pluggable transceiver on interface GigabitEthernet 1/1/3.
<Sysname> display transceiver interface gigabitethernet 1/1/3
GigabitEthernet1/1/3 transceiver information:
  Transceiver Type                    : 1000_BASE_LX_SFP
  Connector Type                      : LC
  Wavelength(nm)                      : 1310
  Transfer Distance(km)               : 10(9um)
  Digital Diagnostic Monitoring       : YES
  Vendor Name                         : H3C
  Ordering Name                       : SFP-GE-LX10-SM1310
Table 3-10 Description on the fields of the display transceiver interface command
Transceiver information of the interface
Transceiver Type
Transceiver type
Connector Type
Type of the connectors of the transceiver:
l      Optical connectors, including SC (SC connector, developed by NTT) and LC (LC connector, 1.25 mm/RJ45 optical connector developed by Lucent).
l      Other connectors, including RJ-45 and CX4.
Wavelength(nm)
l      Optical transceiver: central wavelength of the laser sent, in nm. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma.
l      Electrical transceiver: displayed as N/A.
Transfer distance(xx)
Transfer distance, with xx representing km for single-mode transceivers and m for other transceivers. If the transceiver supports multiple transfer medium, every two values of the transfer distance are separated by a comma. The corresponding transfer medium is included in the bracket following the transfer distance value. The following are the transfer media:
l      9 um: 9/125 um single-mode fiber
l      50 um: 50/125 um multi-mode fiber
l      62.5 um: 62.5/125 um multi-mode fiber
l      TP: Twisted pair
l      CX4: CX4 cable
Whether the digital diagnosis function is supported, where:
l      YES: supported
l      NO: not supported
Vendor Name
Vendor name or vendor name specified of the transceiver:
l      The anti-spoofing transceiver customized by H3C: H3C is displayed.
l      Other transceivers: The original vendor name is displayed.
Ordering Name
Ordering name of the transceiver
View
Use the display transceiver manuinfo interface command to display part of the electrical label information of a single or all anti-spoofing pluggable transceivers customized by H3C.
# Display part of the electrical label information of the anti-spoofing pluggable transceiver customized by H3C on interface GigabitEthernet 1/1/4.
<Sysname> display transceiver manuinfo interface gigabitethernet 1/1/4
GigabitEthernet1/1/4 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2007-07-28
  Vendor Name          : H3C
Table 3-11 Description on the fields of display transceiver manuinfo interface
Manu. Serial Number
Serial number generated during debugging and testing
Manufacturing Date
Debugging and testing date.. The date takes the value of the system clock of the computer that performs debugging and testing.
Vendor Name
Vendor name specified, that is, H3C.
patch activate
patch activate
View
None
Use the patch activate command to place DEACTIVE patches into the ACTIVE state, replacing the original codes.
The active patches will become inactive after a system reboot. If you want to run these patches again, you need to use the command to activate and run these patches.
# Load patch file S3600_1510_P001.pat.
[Sysname] patch load S3600_1510_P001.pat
# Activate the patch that has been loaded into the device.
[Sysname] patch activate
patch delete
patch delete
View
None
Use the patch delete command to delete currently working patches. After this command is issued, the patches deleted and become IDLE.
After you execute the command, all patches are deleted. To prevent system problems that have been solved by the patches from happening again, you need to reload the patches and activate them.
# Delete patches.
[Sysname] patch delete
patch load
patch load filename
View
filename: Patch file name to be specified, a string of 1 to 142 characters.
Patch files are named in the format of [product name]_[baseline version number]_[patch version number].pat. An example is S3600_1510_P001.pat.
To ensure a successful patch loading, make sure that the baseline version of the patch file is consistent with the current software version of the device, and the extension of the batch file is .pat.
Use the patch load command to load the specified patch file in the flash memory into the system memory.
# Load a patch file named S3600_1510_P001.pat, with a version number of P001.
patch run
patch run
View
None
Use the patch run command to place ACTIVE patches to the RUNNING state.
This command is applicable to ACTIVE patches only. After a system reboot, running patches remain in the RUNNING state and keep working.
# Activate the loaded patch.
# Place ACTIVE patches into the RUNNING state.
[Sysname] patch run
reboot
reboot [ unit unit-id ]
View
Use the reboot command to restart a specified Ethernet switch.
Before rebooting, the system checks whether there is any configuration change. If yes, it prompts whether or not to proceed. This prevents the system from losing the configurations in case of shutting down the system without saving the configurations.
# Directly restart this switch without saving the current configuration.
<Sysname> reboot
Start to check configuration with next startup configuration file,
 please wait......
 This command will reboot the device. Current configuration will be lost in next startup if you continue.   Continue? [Y/N] y
 This will reboot device. Continue? [Y/N] y
<Sysname>
%Apr  2 00:06:01:148 2006 Sysname DEV/5/DEV_LOG:- 1 -
Switch is rebooting...
Starting......
schedule reboot at
schedule reboot at hh:mm [ mm/dd/yyyy | yyyy/mm/dd ]
undo schedule reboot
View
hh:mm: Reboot time, where hh (hour) ranges from 0 to 23, and mm (minute) ranges from 0 to 59.
mm/dd/yyyy and yyyy/mm/dd: Two formats used to specify the reboot date, where yyyy (year) ranges from 2,000 to 2,099, mm (month) ranges from 1 to 12, and the range of dd (day) depends on the specific month. You cannot set the date 30 days later than the system current date.
Use the schedule reboot at command to enable the scheduled reboot function on the current switch and set the reboot date and time.
Use the undo schedule reboot command to disable the scheduled reboot function.
By default, no scheduled reboot is set on the switch.
The switch timer can be set to a precision of one minute, that is, the switch will reboot within one minute after the specified reboot date and time.
Note that:
l          After you execute the schedule reboot at command with a specified future date, the switch will reboot at the specified time with at most one minute delay.
l          After you execute the schedule reboot at command without specifying a date, the switch will reboot at the specified time on the current day if the specified time is later than the current time, or reboot at the specified time on the next day if the specified time is earlier than the current time.
l          After you execute the command, the system will prompt you to confirm. Enter "Y" or "y" for your setting to take effect, and your setting will overwrite the previous one (if there is a setting already exists).
l          If you adjust the system time by the clock command after executing the schedule reboot at command, the configured schedule reboot at command will be invalid and the scheduled reboot will not happen.
Related commands: reboot, display schedule reboot.
# Suppose the current time is 05:06, schedule a reboot so that the switch reboots at 22:00 on the current day.
<Sysname> schedule reboot at 22:00
Reboot system at 22:00 2000/04/02(in 16 hours and 53 minutes)
confirm?[Y/N]:y
<Sysname>
schedule reboot delay { hh:mm | mm }
View
hh:mm: Reboot waiting delay, where hh ranges from 0 to 720, and mm ranges from 0 to 59. The value of hh:mm can be up to 720:00.
mm: Reboot waiting delay, ranging from 0 to 43,200 minutes.
Use the schedule reboot delay command to enable the delay reboot function on the switch, and set the reboot delay time.
Use the undo schedule reboot command to disable the delay reboot function.
By default, the delay reboot function is disabled on the switch.
Note that:
l          The switch timer is precise to one minute. When the reboot time reaches, the switch will reboot in one minute at most.
l          You can set the reboot delay in two formats: the hour:minute format and the absolute minute format, and both must be less than or equal to 30 × 24 × 60 (that is, 30 days).
l          After you execute the command, the system will prompt you to confirm. Enter "Y" or "y" for your setting to take effect. Your setting will overwrite the previous one (if there is a setting already exists).
l          If you adjust the system time by the clock command after executing the schedule reboot delay command, the configured schedule reboot delay command will be invalid and the scheduled reboot will not happen.
Related commands: reboot, schedule reboot at, undo schedule reboot, display schedule reboot.
# Suppose the current time is 05:15, schedule a reboot so that the switch reboots after 70 minutes.
<Sysname> schedule reboot delay 70
Reboot system at 06:25 2000/04/02(in 1 hours and 10 minutes)
confirm?[Y/N]:y
<Sysname>
schedule reboot regularity
schedule reboot regularity at hh:mm period
undo schedule reboot regularity
View
hh:mm: Reboot time of the switch, in the hour:minute format, where hh ranges from 0 to 24, and mm ranges from 0 to 59.
period: Reboot period of the switch, in the format period = { daily | { monday | tuesday | wednesday | thursday | friday | saturday | sunday }* }. daily indicates the reboot period is one day, that is, the switch reboots at a specified time every day. { monday | tuesday | wednesday | thursday | friday | saturday | sunday }* indicates the week day when the switch reboots.
Use the schedule reboot regularity command to enable the periodical reboot of the switch and set the reboot time.
Use the undo schedule reboot regularity command to cancel the configured reboot period.
By default, the reboot period of the switch is not configured.
After you execute the command, the system will prompt you to confirm. Enter "Y" or "y" for your setting to take effect. Your setting will overwrite the previous one (if available).
If you adjust the system time by the clock command after executing the schedule reboot regularity command, the configured schedule reboot regularity command will be invalid.
# Schedule a reboot so that the switch reboots at 10:00 every Thursday.
[Sysname] schedule reboot regularity at 10:00 thursday
Schedule reboot regularity, are you sure?[Y/N]:y
[Sysname]
undo system-monitor enable
View
None
Use the system-monitor enable command to enable real-time monitoring of the running status of the system.
Use the undo system-monitor enable command to disable real-time monitoring of the running status of the system.
This function enables you to dynamically record the system running status, such as CPU, thus facilitating analysis and solution of the problems of the device.
By default, real-time monitoring of the running status of the system is enabled.
Enabling of this function consumes some amounts of CPU resources. Therefore, if your network has a high CPU usage requirement, you can disable this function to save your CPU resources.
# Disable real-time monitoring of the running status of the system.
[Sysname] undo system-monitor enable
update fabric
update fabric { file-url | device-name }
View
device-name: File name, in the form of unit[NO.]>flash:, which is used to indicate that the specified file is stored in the Flash of a specified switch.
Use the update fabric command to upgrade the host software of all devices in a Fabric.
# Use the file named s3600.bin in the Flash memory of Unit 2 to upgrade the host software of the devices in a Fabric.
<Sysname> update fabric unit2>flash:/s3600.bin
 This will update the Fabric. Continue? [Y/N] y
 The software is verifying ...
 The result of verification is :
 Unit ID   Free space(bytes)       Enough       Version comparison
    1          15281873              Y              Y
    2          15409873              Y              Y
 warning: the verification is completed, start the file transmission? [Y/N] y
 The fabric is being updated,  100%
 The s3600.bin is stored on unit 1 successfully!
 The s3600.bin is stored on unit 2 successfully!
 Do you want to set s3600.bin to be running agent next time to boot?[Y/N] y
 The s3600.bin is configured successfully!
xmodem get
xmodem get { file-url | device-name }
View
Use the xmodem get command to download files from the local device connected with the Console port of a switch through XModem. This command can be configured only when the device logging onto a switch through the Console port.
Note that, the communication parameter settings of the Console port of the switch and those of the serial port of the local device must be consistent and, the interface type of the Console port must be AUX.
# Download files through XModem.
<Sysname> xmodem get flash:/config.cfg
                **** WARNING ****
xmodem is a slow transfer protocol limited to the current speed settings of the auxiliary ports.
During the course of the download no exec input/output will be available!
