H3C S3600 Command Manual-Release 1602(V1.02)
HomeSupportSwitchesS3600 SeriesReference GuidesCommand ReferencesH3C S3600 Command Manual-Release 1602(V1.02)
22-VRRP Command
22-VRRP Command 86.95 KB
VRRP Configuration Commands
l          Keywords in some commands are modified. See display vrrp, display vrrp statistics, reset vrrp statistics, vrrp vrid authentication-mode, and vrrp vrid track interface.
l          Keyword verbose is added to the display vrrp command to display the detailed information of the VRRP group(s). See display vrrp.
The S3600-EI series switches support the VRRP feature, but not the S3600-SI series.
display vrrp
display vrrp [ verbose ] [ interface vlan-interface vlan-id [ vrid virtual-router-id ] ]
View
verbose: Displays detailed state information of VRRP.
vlan-interface vlan-id: Displays VRRP state information of the specified VLAN interface. vlan-id is the VLAN interface ID.
vrid virtual-router-id: Displays state information of the specified VRRP group. virtual-router-id is the VRRP group ID, in the range 1 to 255.
Use the display vrrp command to display the brief VRRP state information. For details, refer to Table 1-1.
Use display vrrp verbose command to display the detailed VRRP state information. refer to Table 1-2 for details.
l          If you do not specify a VLAN interface or a VRRP group, the command will display the state information of all VRRP groups on the switch.
l          If you specify a VLAN interface only, the command will display the state information of all VRRP groups on the specified VLAN interface.
l          If you specify both a VLAN interface and a VRRP group, the command will display the state information of the specified VRRP group on the specified VLAN interface.
# Display the VRRP state information about all the VRRP groups on the switch.
<Sysname> display vrrp
 Run Method      : VIRTUAL-MAC
 Virtual Ip Ping : Disable
 The total number of the virtual routers:  1
  Interface     VRID  State       Run     Adver.  Auth  Virtual
                                  Pri     Time    Type  IP
  Vlan2         2     Initialize  100     1       NONE   173.160.0.1
Table 1-1 Description on the fields of the display vrrp command
Run Method
Current VRRP running method, including REAL-MAC and VIRTUAL-MAC
Virtual IP ping
Whether you can ping the virtual IP address of the VRRP group
Interface where the VRRP group resides
VRID
ID of the virtual router
Status of the current switch in the VRRP group, including Master, Backup and Initialize
Run Pri
Running priority
Adver. Timer
Interval for sending VRRP advertisements
Auth Type
Authentication type, including NONE, SIMPLE, and MD5
Virtual IP
Virtual IP address of the VRRP group
# Display detailed information about all VRRP groups on the switch.
<Sysname> display vrrp verbose
 Interface       : Vlan-interface1
 VRID            : 1                    Adver. Timer    : 1
 Admin Status    : UP                   State           : Master
 Config Pri      : 100                  Run Pri         : 100
 Preempt Mode    : YES                  Delay Time      : 0
 Auth Type       : NONE
 Virtual IP      : 192.168.0.133
 Virtual MAC     : 0000-5e00-0101
 Master IP       : 192.168.0.68
Table 1-2 Description on the fields of the display vrrp verbose command
Run Method
Virtual Ip Ping
VRID
VRRP group ID
Adver. Timer
Admin Status
Administrative state: UP or DOWN
Config Pri
Configured priority
Run Pri
Running priority
Preempt Mode
Preemptive mode
Delay Time
Preemption delay
Auth Type
Virtual IP
Virtual MAC
Virtual MAC address corresponding to the virtual IP address of the VRRP group. It is displayed only when the switch is in the state of master.
Master IP
Primary IP address of the master’s interface where the VRRP group is configured.
display vrrp statistics [ interface vlan-interface vlan-id [ vrid virtual-router-id ] ]
View
vlan-interface vlan-id: Specifies a VLAN interface by its VLAN ID. vlan-id is the ID of the VLAN interface.
vrid virtual-router-id: Specifies a VRRP group. virtual-router-id is the VRRP group ID, ranging from 1 to 255.
Use the display vrrp statistics command to display the VRRP statistics information of VRRP group(s). Refer to Table 1-3 for the displayed information.
l          If neither a VLAN interface nor a VRRP group is specified, the statistics information about all the VRRP groups on the switch is displayed.
l          If only a VLAN interface is specified, the statistics information about all the VRRP groups on the specified VLAN interface is displayed.
l          If both a VLAN interface and a VRRP group are specified, the statistics information about the specified VRRP group on the specified VLAN interface is displayed.
You can clear the VRRP statistics by using the reset vrrp statistics command.
Related commands: reset vrrp statistics
# Display the VRRP statistics information about all the VRRP groups.
<Sysname> display vrrp statistics
 VRID                   : 1
 CheckSum Errors        : 0          Version Errors                 : 0
 VRID Errors            : 0          Advertisement Interval Errors  : 0
 IP TTL Errors          : 0          Auth Failures                  : 0
 Invalid Auth Type      : 0          Auth Type Mismatch             : 0
 Packet Length Errors   : 0          Address List Errors            : 0
 Become Master          : 1          Priority Zero Pkts Rcvd        : 0
 Advertise Rcvd         : 0          Priority Zero Pkts Sent        : 0
 Invalid Type Pkts Rcvd : 0
Table 1-3 Description on the fields of the display vrrp statistics command
VRID
VRRP group ID
CheckSum Errors
Number of checksum errors
Version Errors
Number of version errors
VRID Errors
Number of virtual router ID errors
Number of errors of the interval for sending VRRP advertisements
IP TTL Errors
Number of TTL errors
Auth Failures
Number of authentication errors
Invalid Auth Type
Number of invalid authentication types
Auth Type Mismatch
Number of mismatched authentication types
Number of VRRP packet length errors
Address List Errors
Number of the virtual IP address list errors
Become Master
Number of the occasions where the current switch operates as the master
Number of the received VRRP advertisements with the priority of 0
Advertise Rcvd
Number of the sent advertisements with the priority of 0
Number of the packet type errors
reset vrrp statistics [ interface vlan-interface vlan-id [ vrid virtual-router-id ] ]
View
vlan-interface vlan-id: Specifies a VLAN interface by its ID. vlan-id is the ID of a VLAN interface.
Use the reset vrrp statistics command to clear the VRRP statistics information.
When you execute this command,
l          If neither a VLAN interface nor a VRRP group is specified, the statistics information about all the VRRP groups on the switch is cleared.
l          If only a VLAN interface is specified, the statistics information about all the VRRP groups on the specified VLAN interface is cleared.
l          If both a VLAN interface and a VRRP group are specified, the statistics information about the specified VRRP group on the specified VLAN interface is cleared.
You can view the current VRRP statistics by using the display vrrp statistics command.
Related commands: display vrrp statistics
# Clear the VRRP statistics information about all the interfaces on the switch.
<Sysname> reset vrrp statistics
vrrp method
vrrp method { real-mac | virtual-mac }
undo vrrp method
View
real-mac: Maps the real MAC address of the switch to the virtual IP address of the VRRP group.
virtual-mac: Maps the virtual MAC address of the VRRP group to the virtual IP address of the VRRP group.
Use the vrrp method command to configure the MAC-Virtual IP address mapping for VRRP groups. You can configure to map the real MAC address of the switch to the virtual IP address of a VRRP group or configure to map the virtual MAC address of a VRRP group to the virtual IP address of the VRRP group.
Use the undo vrrp method command to restore the default.
By default, the virtual MAC address of a VRRP group is mapped to the virtual IP address of the VRRP group.
Note that the mapping relationship between the MAC address and the virtual IP address must be configured before any VRRP group is created. If a VRRP group already exists on the switch, you are not allowed to modify the mapping relationship.
# Map the MAC address of a VLAN interface to the virtual IP address of the VRRP group.
[Sysname] vrrp method real-mac
vrrp ping-enable
vrrp ping-enable
undo vrrp ping-enable
View
None
Use the vrrp ping-enable command to enable a VRRP group to respond to ping packets destined for its virtual router IP address.
Use the undo vrrp ping-enable command to restore the default.
By default, a VRRP group does not respond to ping packets destined for its virtual router IP address.
Note that this command must be configured before any VRRP group is created. If a VRRP group already exists on the switch, you are not allowed to execute the command.
# Enable a VRRP group to respond to ping packets destined for its virtual router IP address.
[Sysname] vrrp ping-enable
vrrp vlan-interface vrid track
vrrp vlan-interface vlan-id vrid virtual-router-id track [ reduced value-reduced ]
undo vrrp vlan-interface vlan-id vrid virtual-router-id track
View
Ethernet port view
virtual-router-id: VRRP group ID, ranging from 1 to 255.
vlan-id: VLAN ID.
value-reduced: Value by which the priority of a switch is to decrease. This argument ranges from 1 to 255, and defaults to 10.
Use the vrrp vlan-interface vrid track command to enable the port tracking function of a VRRP group on a physical port.
Use the undo vrrp vlan-interface vrid track command to disable the port tracking function.
After the port tracking function of a VRRP group is enabled on a port, this function will track the link status of the port. If a fault occurs on the port, the function decreases the priority of the switch where the port resides by a specified value.
Usually, this function is used to track the status of the uplink port of the master in a VRRP group. Thereby, when the uplink port of the master fails, the master’s priority will decrease by a specified value, so as to trigger a new master election in the VRRP group.
l          If an IP address owner exists in a VRRP group, the port tracking function configured on the IP address owner cannot take effect.
l          The port to be tracked can be in the VLAN whose VLAN interface has the VRRP group configured.
l          Up to eight ports can be tracked simultaneously.
# Configure that the priority of the switch decreases by 50 if its Ethernet 1/0/1 port fails.
[Sysname] vlan 2
[Sysname-vlan2] port Ethernet1/0/1
[Sysname-vlan2] quit
[Sysname-Ethernet1/0/1] vrrp vlan-interface 2 vrid 1 track reduced 50
vrrp vrid virtual-router-id authentication-mode authentication-type authentication-key
undo vrrp vrid virtual-router-id authentication-mode
View
VLAN interface view
authentication-type: Authentication type, which can be:
l          simple: Indicates to perform simple text authentication.
l          md5: Indicates to perform the authentication by using MD5 algorithm.
authentication-key: Authentication key, which can be:
l          When the authentication type is simple, the authentication key is in plain text and can contain one to eight characters.
l          When the authentication type is md5, the authentication key can be a string of one to eight characters in plain text, such as 1234567, or a 24-character MD5 encrypted string, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
Use the vrrp vrid authentication-mode command to specify the authentication type and the authentication key for a VRRP group to receive and send VRRP packets.
Use the undo vrrp vrid authentication-mode command to restore the default.
By default, no VRRP authentication is configured.
Note that:
l          The authentication key is case sensitive.
l          Before configuring VRRP authentication on a VLAN interface, you need to create a VRRP group and configure the virtual IP address of it on the VLAN interface.
l          This command sets the authentication type and authentication key for all the VRRP groups on an interface. This is determined by the protocol, which defines that all the VRRP groups on an interface share the same authentication type and authentication key. Besides, all the members joining the same VRRP group should also share the same authentication type and authentication key.
# Set the authentication type of VRRP group 1 on VLAN-interface 2 to simple and the authentication key for it to aabbcc.
[Sysname] interface Vlan-interface 2
[Sysname-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
[Sysname-Vlan-interface2] vrrp vrid 1 authentication-mode simple aabbcc
vrrp vrid preempt-mode
vrrp vrid virtual-router-id preempt-mode [ timer delay delay-value ]
undo vrrp vrid virtual-router-id preempt-mode
View
VLAN interface view
delay-value: Preemption delay period (in seconds), ranging from 0 to 255.
Use the vrrp vrid preempt-mode command to configure a switch to operate in the preemptive mode and set the preemption delay period.
Use the undo vrrp vrid preempt-mode command to cancel the configuration, that is, configure the switch to work in the non-preemptive mode.
By default, switches in a VRRP group operate in the preemptive mode, with the preemption delay period set to 0 seconds.
If you want a switch with high priority to preempt the master, configure the switch to operate in the preemptive mode. You can also set the delay period for preemption as needed.
For S3600 series, you can enable the preemptive mode for switches in a VRRP group:
l          In a VRRP group where the preemptive mode is not enabled, once a switch in the VRRP group becomes the master, other switches, even if they are with a higher priority later, do not preempt the master as long as the master is not down.
l          In a VRRP group where switches are enabled with the preemptive mode, a backup sends out VRRP advertisements to trigger a new master election if it finds its priority is higher than that of the current master, and finally becomes the new master. The former master becomes a backup accordingly.
You can also set the preemptive delay for the switches in a VRRP group. Setting a preemption delay period aims at:
l          In an unstable network, backups in a VRRP group possibly cannot receive VRRP advertisements from the master in time due to network congestions. This causes the master of the VRRP group to be determined frequently. In this case, the backup considers itself as the master and sends out VRRP advertisements to elect the master. This causes the master of the VRRP group to be determined frequently.
l          With the configuration of preemption delay, if a backup does not receive VRRP advertisements from the master in time, it waits for a while before switching to a new master. The backup does not send VRRP advertisements if it receives VRRP advertisements from the master during the specified delay period.
# Configure the switch to operate in the preemptive mode.
[Sysname-Vlan-interface2] vrrp vrid 1 preempt-mode
# Set the preemption delay period.
[Sysname-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5
# Configure the switch to operate in non-preemptive mode.
[Sysname-Vlan-interface2] undo vrrp vrid 1 preempt-mode
vrrp vrid priority
vrrp vrid virtual-router-id priority priority
undo vrrp vrid virtual-router-id priority
View
VLAN interface view
priority: Switch priority to be set. This argument ranges from 1 to 254.
Use the vrrp vrid priority command to set the priority of a switch in a VRRP group.
Use the undo vrrp vrid priority command to restore the default priority.
By default, the priority of a switch in a VRRP group is 100.
Switch priority determines the possibility for the switch to become a master. A switch with higher priority is more likely to become a master. Switch priority ranges from 0 to 255 (a larger number indicates a higher switch priority) and defaults to 100. Note that only 1 through 254 are available to users. Switch priority 0 and 255 are reserved for special uses and IP address owner respectively. If a switch is an IP address owner, its priority is always 255 and not configurable. So if an IP address owner exists in a VRRP group, the switch (the IP address owner) is the master of the VRRP group as along as it can work properly.
# Set the priority to 120 on VLAN-interface 2 for the switch in the VRRP group.
[Sysname-Vlan-interface2] vrrp vrid 1 priority 120
vrrp vrid timer advertise
undo vrrp vrid virtual-router-id timer advertise
View
VLAN interface view
adver-interval: Interval (in seconds) at which the master of a VRRP group sends VRRP advertisement packets, in seconds. This argument ranges from 1 to 255 and defaults to 1.
Use the vrrp vrid timer advertise command to set the interval for the master of a VRRP group to send VRRP advertisements.
Use the undo vrrp vrid timer advertise command to restore to the default interval.
By default, the interval for the master in a VRRP group to send VRRP advertisements is 1 second.
The master of a VRRP group will send VRRP advertisements at a specified interval to inform backups of the VRRP group that it works normally. If backups receive no VRRP advertisement packet after waiting for a period three times of the advertisement interval, they send VRRP advertisements to other members of the VRRP group to elect a new master.
Note that configuration error occurs if switches of the same VRRP group are configured with different adver-interval values.
# Set the interval for the master to send VRRP advertisements to 15 seconds.
[Sysname-Vlan-interface2] vrrp vrid 1 timer advertise 15
vrrp vrid virtual-router-id track interface vlan-interface vlan-id [ reduced value-reduced ]
undo vrrp vrid virtual-router-id track interface vlan-interface vlan-id
View
VLAN interface view
vlan-id: A VLAN interface ID to be tracked.
value-reduced: Value by which the priority decreases. This argument ranges from 1 to 255 and defaults to 10.
Use the vrrp vrid track interface command to set a VLAN interface to be tracked.
Use the undo vrrp vrid track interface command to disable a VLAN interface from being tracked.
The VLAN interface tracking function extends the use of the backup function. With this function enabled on a switch, the backup function can take effect not only when the VLAN interface where a VRRP group resides fails, but also when some other VLAN interfaces on the switch fail. You can utilize the VLAN interface tracking function by specifying monitored VLAN interfaces.
When the tracked VLAN interface on the master of a VRRP group is down, the priority of the master decreases by the value set by the value-reduced argument, allowing a switch with the highest priority in the VRRP group becomes the master.
l          If an IP address owner exists in a VRRP group, do not configure the interface tracking function on the IP address owner. If configured, the function cannot take effect.
l          A VRRP group can track up to eight VLAN interfaces simultaneously.
# On VLAN-interface 2, configure to track VLAN-interface 1 and configure the priority of the master of VRRP group 1 (on VLAN-interface 2) to decrease by 50 when VLAN-interface 1 goes down.
[Sysname-Vlan-interface2] vrrp vrid 1 track interface vlan-interface 1 reduced 50
vrrp vrid track detect-group
vrrp vrid virtual-router-id track detect-group group-number [ reduced value-reduced ]
undo vrrp vrid virtual-router-id track detect-group group-number
View
VLAN interface view
virtual-router-id: Virtual VRRP group ID, ranging from 1 to 255.
group-number: Detected group number, ranging from 1 to 25.
Use the vrrp vrid track detect-group command to enable the auto detect function when employing VRRP.
Use the undo vrrp vrid track detect-group command to disable the auto detect implementation in VRRP.
The auto detect result of the detected group can control the priority of a switch in a VRRP group. In this way, the automatic switching between the master and the backup is implemented.
l          Decrease the priority of a switch in a VRRP group when the result of the detected group is unreachable.
l          Restore the priority of the switch in the VRRP group when the result of the detected group is reachable.
l          If an IP address owner exists in a VRRP group, the auto detect function configured on the IP address owner cannot take effect.
l          A detected group can be used to detect up to eight Layer 3 interfaces.
l          Currently, auto detect in VRRP is only supported in S3600-EI series switches.
# Create detected group 10 and specify to detect the IP address of 202.12.1.55.
[Sysname] detect-group 10
[Sysname-detect-group-10] detect-list 1 ip address 202.12.1.55
# Specify to decrease the priority of the master of VRRP group 1 by 20 when detected group 10 is unreachable.
[Sysname- Vlan-interface2] vrrp vrid 1 track detect-group 10 reduced 20
vrrp vrid virtual-ip
vrrp vrid virtual-router-id virtual-ip virtual-address
undo vrrp vrid virtual-router-id [ virtual-ip virtual-address ]
View
VLAN interface view
virtual-address: Virtual IP address to be configured.
Use the vrrp vrid virtual-ip command to create a VRRP group and configure the virtual IP address for the VRRP group, or add a virtual IP address to the virtual IP address list of an existing VRRP group. You can add up to 16 virtual IP addresses for a VRRP group.
Use the undo vrrp vrid virtual-ip command to remove an existing VRRP group, or remove a virtual IP address from the virtual IP address list of an existing VRRP group. A VRRP group is removed if all its virtual IP addresses are removed.
By default, no VRRP group is created.
Note that:
l          A virtual IP address cannot be an all-zero address (0.0.0.0), a broadcast address (255.255.255.255), a loopback interface, a non-A/B/C class address, or an illegal IP address, such as 0.0.0.1.
l          Virtual IP addresses of a VRRP group must be in the same network segment with the IP address of the interface where the VRRP group is configured. Otherwise, the VRRP group cannot work normally.
It is not recommended to perform VRRP group-related configurations on the VLAN interface of a remote-probe VLAN. Otherwise, packet mirroring may be affected.
# Create a VRRP group.
[Sysname-Vlan-interface2] vrrp vrid 1 virtual-ip 10.10.10.10
# Add a virtual IP address to an existing VRRP group.
[Sysname-Vlan-interface2] vrrp vrid 1 virtual-ip 10.10.10.11
# Remove a virtual IP address from a VRRP group.
[Sysname-Vlan-interface2] undo vrrp vrid 1 virtual-ip 10.10.10.10
# Remove a VRRP group.
