H3C S3600 Command Manual-Release 1602(V1.02)
HomeSupportSwitchesS3600 SeriesReference GuidesCommand ReferencesH3C S3600 Command Manual-Release 1602(V1.02)
14-Auto Detect Command
14-Auto Detect Command 57.6 KB
Auto Detect Configuration Commands
l          Refer to the Routing Protocol part of the manual for information about static routing.
l          Refer to the VRRP part of the manual for information about VRRP.
detect-group
detect-group group-number
undo detect-group group-number
View
group-number: Detected group number ranging from 1 to 25.
Use the detect-group command to create a detected group and enter detected group view.
Use the undo detect-group command to remove a detected group.
When a detected group is used by applications, the detected group cannot be deleted unless you delete the applications first.
# Create detected group 10.
[Sysname] detect-group 10
[Sysname-detect-group-10]
detect-list
detect-list list-number ip address ip-address [ nexthop ip-address ]
undo detect-list list-number
View
Detected group view
list-number: Sequence number of the IP address to be detected. This argument ranges from 1 to 10.
ip address ip-address: Specifies the destination IP address (in dotted decimal notation) to be detected.
nexthop ip-address: Specifies the next hop IP address for Auto Detect.
Use the detect-list command to add a detected object to a detected group and specify the detection sequence number of the detected object.
Use the undo detect-list command to remove a specified detected object.
When performing Auto Detect, a switch detects the configured detected objects in the order specified by their sequence numbers.
If you have configured multiple detected objects, you can use the option command to set the logical relationships between the detected objects.
Related commands: option.
# Add the detected object 202.13.1.55 to detected group 10, with the detection sequence number set to 1, and the next hop IP address set to 1.2.3.4.
[Sysname-detect-group-10] detect-list 1 ip address 202.13.1.55 nexthop 1.2.3.4
display detect-group
display detect-group [ group-number ]
View
Use the display detect-group command to display the configuration of the specified detected group or all detected groups.
# Display the configuration of detected group 1.
<Sysname> display detect-group 1
detect-group 1 :
 detect loop time(s) : 15
   ping wait time(s) : 2
  detect retry times : 2
    detect ip option : and
         group state : not detecting
 register module num : 0
     detect ip count : 1
detect-list  ip address       next hop
1            202.13.1.55      1.2.3.4
Table 1-1 Description on the fields of the display detect-group command
detect-group 1
Detected group number 1
detect loop time(s)
Detecting interval, in seconds.
ping wait time(s)
Timeout time of a ping operation, in seconds.
detect retry times
Number of retries of an auto detect operation.
detect ip option
The logic relationship between the detected objects in the detected group. It can be and or or.
group state
Current state of the detected group
register module num
Number of registered modules (that is, the number of the modules utilizing the detected group.)
detect ip count
Number of the IP addresses contained in a detected group
detect-list
Sequence number of an IP address contained in a detected group
ip address
next hop
Next hop IP address
ip route-static detect-group
ip route-static ip-address { mask | mask-length } { interface-type interface-number | next-hop } [ preference preference-value ] [ reject | blackhole ] detect-group group-number
undo ip route-static ip-address { mask | mask-length } [ interface-type interface-number | next-hop ] [ preference preference-value ]
View
ip-address: IP address in dotted decimal notation.
mask: Subnet mask.
mask-length: Length of the subnet mask, that is, the number of successive bits in the subnet mask whose values are 1.
interface-type interface-number: Interface type and interface number.
next-hop: Next hop IP address in dotted decimal notation.
preference-value: Priority of the route. This argument ranges from 1 to 255.
reject: Specifies the route to be unreachable. If you specify this keyword when executing this command, any packet destined for the specified IP address is discarded, and the system informs the source that the destination is unreachable.
blackhole: Specifies the route to be a blackhole route. If you specify this keyword when executing this command, all outbound interfaces of the static route are the NULL 0 interfaces regardless of the next hop. In addition, the system discards any packet transmitted along this route without informing the source.
Use the ip route-static detect-group command to configure a static route, whose validity depends on detecting results as follows:
l          The route is valid when the detecting result is reachable.
l          The route is invalid when the detecting result is unreachable.
Use the undo ip route-static command to remove an existing static route.
# Configure a static route to 192.168.1.5/24 with 192.168.0.2 as the next hop, and control the static route validity using the detecting result of detected group 10.
[Sysname] ip route-static 192.168.1.5 24 192.168.0.2 detect-group 10
After the configuration, if detected group 10 is reachable, the static route is valid; if detected group 10 is unreachable, the static route is invalid.
option
option [ and | or ]
undo option
View
Detected group view
and: Specifies the relationship between detected objects as logic AND, which means that the detecting result is reachable only when all the detected objects contained in the detected group are reachable.
or: Specifies the relationship between detected objects as logic OR, which means that the detecting result is reachable if one of the detected objects contained in the detected group is reachable.
Use the option command to specify the way to generate detecting results.
Use the undo option command to restore the default way to generate detecting results.
By default, the relationship between the detected objects is and.
When a detecting operation is being carried out, the switch detects each detected object contained in the detected group in turn by their sequence number.
l          If you specify the and keyword, the switch returns reachable as the detecting result only if all the detected objects in the detected group are detected reachable.
l          If you specify the or keyword, the switch returns reachable as the detecting result only if one of the detected objects in the detected group is detected reachable and the remaining detected objects will not be detected any more.
# Specify the relationship between the three detected objects in detected group 10 as or.
[Sysname-detect-group-10] detect-list 2 ip address 202.13.1.56 nexthop 1.2.3.4
[Sysname-detect-group-10] detect-list 3 ip address 202.13.1.57 nexthop 1.2.3.4
[Sysname-detect-group-10] option or
After the configuration, if one of the three detected objects is reachable, the system will consider detected group 10 reachable.
retry
retry retry-times
undo retry
View
Detected group view
retry-times: Maximum retry times during a detect operation. This argument ranges from 0 to 10 and defaults to 2.
Use the retry command to set the maximum retry times during a detect operation. Use the undo retry command to restore the default times.
By default, the maximum retry times during a detect operation is two.
# Specify the maximum number of retires to 3 for detected group 10.
[Sysname-detect-group-10] retry 3
standby detect-group
standby detect-group group-number
undo standby detect-group
View
VLAN interface view
Use the standby detect-group command to configure the interface backup function by using the auto detect function.
Use the undo standby detect-group command to disable the interface backup function.
After you configure the standby detect-group command, whether the backup interface is enabled depends on the auto detecting results:
l          The primary interface keeps in use when the detected group is reachable.
l          The backup interface is enabled when the detected group is unreachable.
l          The backup interface is disabled and the primary interface is re-enabled when the link between the primary interface and the destination resumes, that is, the detected group is reachable again.
# Specify to enable VLAN-interface 2 (the backup interface) when the detected group 10 is unreachable.
[Sysname-Vlan-interface2] standby detect-group 10
After the configuration, if detected group 10 is reachable, the backup interface VLAN-interface 2 will be in the disabled state, and if detected group 10 is unreachable, VLAN-interface 2 will be enabled.
timer loop
timer loop interval
undo timer loop
View
Detected group view
seconds: Detecting interval. This argument ranges form 1 to 86,400 (in seconds) and defaults to 15.
Use the timer loop command to set the detecting interval, that is, the frequency to perform auto detect operations.
Use the undo timer loop command to restore the default.
By default, auto detect operations are performed on all detected groups every 15 seconds.
# Set the detecting interval to 60 seconds for detected group 10.
[Sysname-detect-group-10] timer loop 60
timer wait
timer wait seconds
undo timer wait
View
Detected group view
seconds: Timeout waiting for an ICMP reply. This argument ranges from 1 to 30 (in seconds) and defaults to 2.
Use the timer wait command to set a timeout waiting for an ICMP reply.
Use the undo timer wait command to restore the default.
By default, timeout waiting for an ICMP reply in an auto detect operation is 2 seconds.
# Set a timeout of 3 seconds waiting for an ICMP reply in detected group 10.
[Sysname-detect-group-10] timer wait 3
vrrp vrid track detect-group
vrrp vrid virtual-router-id track detect-group group-number [ reduced value-reduced ]
undo vrrp vrid virtual-router-id track detect-group [ group-number ]
View
VLAN interface view
virtual-router-id: Virtual router ID ranging from 1 to 255.
value-reduced: Value by which the priority is to be reduced. This argument ranges from 1 to 255 and defaults to 10.
Use the vrrp vrid track detect-group command to specify an auto detected group for a VRRP group.
Use the undo vrrp vrid track detect-group command to cancel the configuration.
You can enable Auto Detect on the master switch in a VRRP group, use the Auto Detect function to detect the links from the master to other networks, and use the detection results (reachable/unreachable) to control the priority of the master, so as to realize the automatic master-backup switchover:
l          The master keeps as master when the detected group is reachable.
l          The priority of the master decreases and thus becomes a backup when the detected group is unreachable.
Currently, auto detect in VRRP is only supported in S3600-EI series Ethernet switches.
# Specify to decrease the priority of the master switch in VRRP group 1 by 20 when the detected group 10 is unreachable.
[Sysname-Vlan-interface1] vrrp vrid 1 track detect-group 10 reduced 20
After this configuration, if detected group 10 is reachable, the master keeps as master, and if detected group 10 is unreachable, the master decreases its priority by 20 and becomes a backup.
