H3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
16-Information Center Commands
16-Information Center Commands 123.23 KB
Chapter 1  Information Center
1.1  Information Center Configuration Commands
1.1.1  display channel
display channel [ channel-number | channel-name ]
View
channel-number: Channel number, in the range 0 to 9, that is, the system has ten channels.
channel-name: Specifies the channel name. The name can be channel7, channel8, channel9, console, logbuffer, loghost, monitor, snmpagent, trapbuffer, logfile.
Use the display channel command to view the details about the information channel.
Without parameter, the display channel command shows the configurations of all the channels.
# Show details about the information channel 0.
<H3C> display channel 0
channel number:0, channel name:console
MODU_ID  NAME    ENABLE  LOG LEVEL   ENABLE  TRAP LEVEL  ENABLE  DEBUGGING LEVEL
0xffff0000   default Y   warning Y   debugging   Y   debugging
1.1.2  display info-center
display info-center
View
None
Use the display info-center command to view the configuration of system log and the information recorded in the memory buffer.
If the information in the current log/trap buffer is less than the size of buffer, display the actual log/trap information.
Related commands: info-center enable, info-center loghost, info-center logbuffer, info-center console channel, info-center monitor channel.
# Show the system log information.
<H3C> display info-center
Information Center:enabled
Log host:
Console:
Monitor:
         channel number:1, channel name:monitor
SNMP Agent:
         channel number:5, channel name:snmpagent
Log buffer:
         enabled, max buffer size:1024, current buffer size:256
         current messages:6, channel number:4, channel name:logbuffer
         dropped messages:0, overwrote messages:0
Trap buffer:
         current messages:0, channel number:3, channel name:trapbuffer
Log file :
        enabled,max file buffer size 32KB, current file buffer size 7KB,
        channel number : 6, channel name : logfile
        max log file number : 5, max length of each log file : 2MB
        log file directory : cf:/logfile
Information timestamp setting:
         log - date, trap - date, debug - boot
Table 1-1 display info-center command output description
Information Center:
The status of the information center
Log host:
The status of the log host, including its IP address, occupied channel number, channel name, language and the priority level of the log host.
Console:
The status of the console port, including the occupied channel name and channel number.
Monitor:
The status of the monitoring port, including the occupied channel number and channel name.
SNMP Agent:
The status of the SNMP agent, including the occupied channel number and channel name.
Log buffer:
The status of the log buffer, including enable status, maximum size, current size, number of current messages, channel name, channel number, number of dropped messages, number of the overwritten messages.
Trap buffer:
The status of the trap buffer, including enable status, maximum size, current size, number of current messages, channel name, channel number, number of dropped messages, number of the overwritten messages.
Log file
The status of the log file, including enable status, maximum file buffer size, channel number, channel name, maximum number of log files, maximum size of the log file, storage path of log files.
Information timestamp settings, including the timestamp type of log messages, trap messages and debugging messages.
1.1.3  display logbuffer
display logbuffer [ summary ] [size sizenum | [ reverse ] | level [ levelnum | emergencies | alerts | critical | errors | warnings | notifications | informational | debugging } ] * [ | { begin | include | exclude } text ]
View
size sizenum: Optional parameter. Number of log information you want to query.
levelnum: Optional parameter. Level of the log information you want to query.
summary: Optional parameter, displays the statistics of all logs levels in the log buffer.
reverse: Optional parameter, searches for the matching log information from the head of the log buffer.
emergencies, alerts, critical, debugging, errors, informational, notifications, warnings are the names of the eight log severity levels. You can type the values or names of the desired severity levels, which are equivalent, in commands. Table 1-2 gives the details.
Table 1-2 Severity levels defined in the information center
Severity
Value
emergencies
1
Information on system unavailability
alerts
2
Information requiring immediate reaction
critical
3
Critical information
errors
4
Error information
warnings
5
Warning information
notifications
6
Normal but important information
informational
7
Notification that should be recorded
debugging
8
Information generated during the debugging
size: Configures the size of buffer.
sizenum: Size of buffer (number of messages which can be kept); ranging from 1 to 1024. By default, the size of the buffer is 256.
|: Filters the configuration information to be output by regular expression.
begin: Optional parameter, displays all items beginning from the matching item.
exclude: Optional parameter, only displays the matching items.
include: Optional parameter, only displays the non-matching items..
text: Defines the regular expression.
Table 1-3 Special characters in the regular expression
Special characters
Restriction
_
Underscore, similar to a wildcard and can stand for these characters:
A space, the beginning of the input string, the end of the input string
If the first character in the regular expression is not a underscore, then there is no restriction on the number of the underscore (but it is restricted by the command length)
If the first character in the regular expression is an underscore, then there should be less than five consecutive underscores.
If the underscores in a command are discrete, on the first group of underscores are filtered for the output information, but not the subsequent underscores.
Left parenthesis, push flag in program
It is recommended not to use this character in the regular expression.
Use the display logbuffer command to view the attribute of logbuffer and the information recorded in logbuffer.
All log messages are saved in the log buffer. When the log buffer is full, the latest message will overlap the earliest one.
The displaying sequence of all log messages is from the newest message to the oldest one.
When you input size, if the size of current configured log messages is bigger than the logsize, the system will search for the messages on the following principles.
l           If you input reverse, the system will search for logsize matching messages from the oldest one( the head of the log buffer), then displays them from the newest message to the oldest one.
l           If you do not input inverse, the system will search for the logsize matching messages from the newest one( the end of the log buffer), then displays them from the newest message to the oldest one.
# Show the system logbuffer attribute and the log information in logbuffer.
<H3C> display logbuffer
Logging buffer configuration and contents:enabled
Allowed max buffer size : 1024
Actual buffer size : 512
Channel number : 4 , Channel name : logbuffer
Dropped messages : 0
Overwritten messages : 0
Current messages : 91
1.1.4  display logbuffer summary
display logbuffer summary [ level severity ]
View
level: Level of information severity.
severity: Information level, do not output information below this level. Information at different levels is as the following table:
Table 1-4 Severity levels defined in the information center
Severity
Value
emergencies
1
alerts
2
critical
3
errors
4
Error information
warnings
5
Warning information
notifications
6
informational
7
debugging
8
Information generated during debugging
Use the display logbuffer summary command to view the summary information recorded in logbuffer.
# Show the summary information recorded in logbuffer.
<H3C> display logbuffer summary
EMERG ALERT CRIT ERROR WARN NOTIF INFO DEBUG
0     0     0    0     94   0     1    0
1.1.5  display trapbuffer
display trapbuffer [ summary ] [ level [ levelnum | emergencies | alerts | critical | debugging | errors | informational | notifications | warnings ] ] [size sizenum]
View
summary: Number of statistical logs.
sizenum: Size of buffer (number of messages which can be kept), ranging from 1 to 1024. By default, the size of the buffer is 256.
levelnum: Information level value, ranging from 1 to 8.
Use the display trapbuffer command to view the attribute of trapbuffer and the information recorded in trapbuffer.
# Show the system trapbuffer attribute and the log information in trapbuffer.
<H3C> display trapbuffer
Trapping Buffer Configuration and contents:
enabled
allowed max buffer size : 1024
actual buffer size : 256
channel number : 3 , channel name : trapbuffer
dropped messages : 0
overwrote messages : 0
current messages : 6
#Dec 31 14:01:25 2004 H3C DEV/2/LOAD FINISHED:
 Trap 1.3.6.1.4.1.2011.2.23.1.12.1.20: frameIndex is 0, slotIndex 0.4
#Dec 31 14:01:33 2004 H3C DEV/2/BOARD STATE CHANGE TO NORMAL:
 Trap 1.3.6.1.4.1.2011.2.23.1.12.1.11: frameIndex is 0, slotIndex 0.2
#Dec 31 14:01:40 2004 H3C DEV/2/BOARD STATE CHANGE TO NORMAL:
1.1.6  info-center channel name
info-center channel channel-number name channel-name
undo info-center channel channel-number
View
channel-number: Channel number, ranging from 0 to 9, that is, system has ten channels.
channel-name: Specifies the channel name with a character string not exceeding 30 characters, excluding digit, "-", "/" or "\".
Use the info-center channel name command to rename a channel specified by the channel-number as channel-name.
Use the undo info-center channel command to restore the channel name.
The system assigns a channel in each output direction by default. See the table below.
Table 1-5 Numbers and names of the channels for log output
Output direction
Channel number
Default channel name
Console
0
console
Monitor
1
monitor
Info-center loghost
2
loghost
Trap buffer
3
trapbuf
Logging buffer
4
logbuf
snmp
5
snmpagent
Log file
6
Logfile
Note that the channel name cannot be duplicated.
# Rename the channel 0 as execconsole.
<H3C> system-view
[H3C] info-center channel 0 name execconsole
1.1.7  info-center console channel
info-center console channel { channel-number | channel-name }
undo info-center console channel
View
channel-number: Channel number, in the range 0 to 9, that is, system has ten channels.
Use the info-center console channel command to configure the channel through which the log information is output to the console.
By default, Ethernet switches do not output log information to the console.
This command takes effect only after system logging is started.
Related commands: info-center enable, display info-center.
# Configure to output log information to the console through channel 0.
<H3C> system-view
[H3C] info-center console channel 0
1.1.8  info-center enable
info-center enable
undo info-center enable
View
None
Use the info-center enable command to enable the system log function.
Use the undo info-center enable command to disable system log function.
By default, system log function is enabled.
Only after the system log function is enabled can the system output the log information to the info-center loghost and console, and so on.
Related commands: info-center loghost, info-center logbuffer, info-center console channel, info-center monitor channel, display info-center, info-center enable.
# Enable the system log function.
<H3C> system-view
[H3C] info-center enable
1.1.9  info-center logbuffer
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ]*
undo info-center logbuffer [ channel | size ]
View
channel: Configures the channel to output information to buffer.
buffersize: Size of buffer (number of messages which can be kept).
Use the info-center logbuffer command to configure to output information to the memory buffer.
Use the undo info-center logbuffer command to cancel the information output to buffer.
By default, the switch outputs information to the memory buffer whose size is 512, that is, the memory buffer can hold 512 messages.
This command takes effect only after the system logging is enabled.
# Send log information to buffer and sets the size of buffer to 50.
<H3C> system-view
[H3C] info-center logbuffer size 50
1.1.10  info-center logfile
info-center logfile [ channel { channel-number | channel-name } | size logfile-size | directory directory | number logfile-num ]*
info-center logfile [ flush ]
undo info-center logfile [ channel | size | directory | number ]
View
channel: Specifies the channel whereby to output information to a log file.
channel-number: Channel number, in the range 0 to 9 (that is, the system has 10 channels).
channel-name: Channel name. The channel name range is: channel7, channel8, channel9, console, logbuffer, loghost, monitor, snmpagent, trapbuffer, and logfile.
size: Specifies the allowed size of each log file.
logfile-size: Allowed size of each log file, in the range 1 to 10 (Mbytes).
directory: Directory under which to save a log file.
directory: Directory under which to save a log file. Now, it is only the path of the compact flash (CF) card.
number: Specifies the allowed number of log files saved in the system.
logfile-num: Allowed number of log files saved in the system, in the range 1 to 5.
flush: Writes a log file from the buffer to the storage device.
Use the info-center logfile command to configure to output information to the logfile.
Use the undo info-center logfile command to cancel the information output to the logfile.
Use the undo info-center logfile channel command to restore the default channel whereby to output information to a log file.
Use the undo info-center logfile size command to restore the default size of a single log file.
Use the undo info-center logfile directory command to restore the default directory under which to save a log file.
Use the undo info-center logfile number command to restore the default allowed number of log files saved in the system.
By default, the Switch outputs information to a log file through Channel 6, the allowed size of each log file is 2 Mbytes, the system allows you to save a maximum of 5 log files, and log files are saved under cf:/logfile.
If no CF card is in position in the system, the system cannot output information to a log file, and the log file function cannot take effect.
# Send log information to logfile.
<H3C> system-view
[H3C] info-center logfile
# Save log files under cf:/test.
<H3C> system-view
[H3C] info-center logfile dirctory cf:/test
cf:/test does not exist.Do you want to create it?[Y/N]y
1.1.11  info-center loghost
info-center loghost { source interface-type interface-number | host-ip-addr [ channel { channel-number | channel-name } | facility local-number | language { chinese | english } ]*}
undo info-center loghost host-ip-addr
View
host-ip-addr: IP address of info-center loghost.
channel: Configures information channel of the info-center loghost.
Source: Source address of the packet sent to the loghost.
interface-type interface-number: Type and number of interface sending log file.
facility: Configures the recording tool of info-center loghost.
local-number: Record tool of info-center loghost, ranging from local0 to local7.
language: Sets the logging language.
chinese, english: Language used in log file.
Use the info-center loghost command to configure the system to output information to the log host.
Use the undo info-center loghost command to cancel output to info-center loghost.
By default, Ethernet switches do not output information to info-center loghost.
# Configure to send log information to the UNIX workstation at 202.38.160.1.
<H3C> system-view
[H3C] info-center loghost 202.38.160.1
1.1.12  info-center loghost source
undo info-center loghost source
View
interface-type interface-number: Layer 3 interface on the switch.
Use the info-center loghost source command to specify source address of the packets sent to loghost as the address of the interface specified by the interface-name.
Use the undo info-center loghost source command to cancel the specified source address of the packets sent to loghost.
# Specify source address of the packets sent to loghost as the address of the VLAN interface 1.
<H3C> system-view
[H3C] info-center loghost source vlan-interface 1
1.1.13  info-center monitor channel
info-center monitor channel { channel-number | channel-name }
undo info-center monitor channel
View
channel-number: Channel number, ranging from 0 to 9, that is, the system has ten channels.
channel-name: Channel name. The name can be channel7, channel8, channel9, console, logbuffer, loghost, monitor, snmpagent, trapbuffer, logfile.
Use the info-center monitor channel command to configure the channel to output the log information to the user terminal.
Use the undo info-center monitor channel command to restore the channel to output the log information to the user terminal to default value.
By default, Ethernet switches do not output log information to user terminal.
# Configure channel 0 to output log information to user terminal.
<H3C> system-view
[H3C] info-center monitor channel 0
1.1.14  info-center snmp channel
info-center snmp channel { channel-number | channel-name }
undo info-center snmp channel
View
channel-number: Channel number, ranging from 0 to 9, that is, the system has ten channels. By default, channel 5 is used.
Use the info-center snmp channel command to configure new channel for transmitting the SNMP information.
Use the undo info-center snmp channel command to restore the default channel for transmitting the SNMP information.
The default channel for transmitting the SNMP information is channel 5.
# Configure channel 6 as the SNMP information channel.
<H3C> system-view
[H3C] info-center snmp channel 6
1.1.15  info-center source
info-center source { modu-name | default } channel { channel-number | channel-name } [ debug { level severity | state state }* | log { level severity | state state }* | trap { level severity | state state }* ]*
undo info-center source { modu-name | default | all } channel { channel-number | channel-name }
View
modu-name: Module name.
Table 1-6 gives the details.
Table 1-6 The module name field
Module name
8021X
802.1X module
ACL
Access Control List (ACL) module
ADBM
MAC address management module
ARP
Address Resolution Protocol (ARP) module
BGP
Border Gateway Protocol (BGP) module
CFM
Configuration file management module
CMD
Command module
DEV
Device management module
DHCP
Dynamic Host Configuration Protocol module
DIAGCLI
Diagnosis module
DRVMPLS
Multiprotocol Label Switching (MPLS) drive module
DRV_L2
Layer 2 drive module
DRV_L3
Layer 3 drive module
DRV_L3MC
Layer 3 multicast module
MPLS
MPLS (multiprotocol label switching) drive module
DRVPOS
POS drive module
DRVQACL
QACL drive module
ETH
Ethernet module
FTPS
FTP server module
HA
High availability module
HABP
HABP (Huawei authentication bypass protocol) module
HWCM
Huawei configuration management MIB module
IFNET
Interface management module
IGSP
IGMP snooping module
IP
Internet Protocol (IP) module
ISIS
Intermediate System-To-Intermediate System Intradomain Routing Protocol (IS-IS) module
L2INF
L2 interface management module
L2V
L2 VPN module
LACL
LAN switch ACL module
LDP
Label Distribution Protocol (LDP) module
LINKAGG
LINKAGG module
LQOS
LAN switch QoS module
LS
Local server module
LSPAGENT
Label Switched Path (LSP) agent module
LSPM
Label Switch Path Management (LSPM) module
MIX
Dual system management module
MODEM
Modem module
MPLSFW
MPLS forward module
MPM
Multicast port management module
MSDP
Multicast Source Discovery Protocol (MSDP) module
MSTP
MSTP (multiple spanning tree protocol) module
NAT
Network Address Translation (NAT) module
NTP
Network Time Protocol (NTP) module
OSPF
Open Shortest Path First (OSPF) module
PHY
Physical sublayer & physical layer module
PPP
PPP (point to point protocol) module
RDS
RADIUS module
RM
Routing management module
RMON
Remote monitor module
RSA
RSA (Revest, Shamir and Adleman) encryption module
RTPRO
Routing protocol module
SHELL
User interface module
SNMP
Simple Network Management Protocol (SNMP) module
SOCKET
Socket module
SYSMIB
System MIB module
TELNET
Telnet module
VFS
Virtual file system (VFS) module
VLAN
Virtual Local Area Network (VLAN) module
VRRP
Virtual Router Redundancy Protocol (VRRP) module
VTY
Virtual Type Terminal (VTY) module
default: All the modules.
log: Log information.
trap: Trap information.
all: Clears all the information filtering configuration on the channelnum channel except the default one.
debugging: Debugging information.
Table 1-7 gives detailed severity information:
Table 1-7 Severity levels defined in the information center
Severity
Value
emergencies
1
alerts
2
critical
3
errors
4
Error information
warnings
5
Warning information
notifications
6
informational
7
debugging
8
By default, the information level of each channel is as follows:
Table 1-8 Default information level of each channel
channel
Log information level
Trap information level
Debugging information level
Console
warning
debugging
debugging
Terminal
warning
debugging
debugging
Log host
informational
debugging
debugging
Trapbuffer
informational
warning
debugging
Logbuffer
warning
debugging
debugging
SNMPagent
debugging
warning
debugging
Logfile
warning
debugging
debugging
Channel7
debugging
debugging
debugging
Channel8
debugging
debugging
debugging
Channel9
debugging
debugging
debugging
By default, the information switch state of each channel is shown in Table 1-9:
Table 1-9 Default information switch state of each channel
Channel
Log information switch
Trap information switch
Debug information switch
Console
Enable
Disable
Enable
Terminal
Enable
Disable
Enable
Log host
Enable
Enable
Disable
Trapbuffer
Disable
Enable
Disable
Logbuffer
Enable
Disable
Disable
SNMPagent
Disable
Enable
Disable
Logfile
Enable
Disable
Disable
Channel7
Enable
Enable
Disable
Channel8
Enable
Enable
Disable
Channel9
Enable
Enable
Disable
&  Note:
If you only specify the level for one/two of the three types of information, the level(s) of the unspecified two/one return(s) to the default. For example, if you only define the level of the log information, then the levels of the trap and debugging information return to the defaults.
channel-number: Channel number to be set.
channel-name: Channel name to be set. The name can be channel7, channel8, channel9, console, logbuffer, loghost, monitor, snmpagent, trapbuffer, logfile.
state: Sets the state of the information.
state: Specifies the state as on or off.
Use the info-center source command to add/delete a record to the information channel.
Use the undo info-center source command to cancel the contents of the information channel.
Use this command to configure the information of log/trap/debugging type. For example, for the filter of IP module log output, you can configure to output the logs at a level higher than warnings to the log host and output those higher than informational to the log buffer. You can also configure to output the trap information on the IP module to a specified trap host, and so on.
The channels for filtering in all the directions are specified by this configuration command. All the information will be sent to the corresponding directions through the specified channels. You can configure the channels in the output direction, channel filter information, filtering and redirecting of all kinds of information.
At present, the system distributes an information channel in each output direction by default, shown as follows:
Table 1-10 Default information channel in each output direction
Output direction
Information channel name
Console
console
Monitor
monitor
Info-center loghost
loghost
Log buffer
logbuffer
Trap buffer
trapbuffer
snmp
snmpagent
Log file
logfile
In addition, each information channel has a default record with the module name “default” and module number as 0xffff0000. However, for different information channel, the default log, trap and debugging settings in the records may be different with one another. Use default configuration record if a module does not have any specific configuration record in the channel.
# Set to enable the log information of VLAN module in SNMP channel and allow the output of the information with a level higher than emergencies.
<H3C> system-view
[H3C] info-center source vlan channel snmp log level emergencies
1.1.16  info-center timestamp
info-center timestamp { log | trap | debugging } { boot | date | none }
undo info-center timestamp { log | trap | debugging }
View
boot: Time elapsing after system starts. Format: xxxxxx.yyyyyy, xxxxxx is the high 32 bits of the elapsed time (in milliseconds) after system starts, and yyyyyy is the low 32 bits.
date: Current system date and time. It shows as yyyy/mm/dd-hh:mm:ss in Chinese environment and mm dd hh:mm:ss yyyy in Western language environment.
none: No timestamp format.
Use the info-center timestamp command to configure the timestamp output format in debugging/trap information.
Use the undo info-center timestamp command to disable the output of timestamp field.
By default, date stamp is used.
# Configure the debugging information timestamp format as boot.
<H3C> system-view
[H3C] info-center timestamp debugging boot
1.1.17  info-center trapbuffer
info-center trapbuffer [ size buffersize | channel { channel-number | channel-name } ]*
undo info-center trapbuffer [ channel | size ]
View
size: Configures the size of the trap buffer.
buffersize: Size of trap buffer (numbers of messages).
channel: Configures the channel to output information to trap buffer.
channel-name: Channel name which can be the channel7, channel8, channel9, console, logbuffer, loghost, monitor, snmpagent, trapbuffer, logfile
Use the info-center trapbuffer command to output information to the trap buffer.
Use the undo info-center trapbuffer command to cancel output information to trap buffer.
By default, output information is transmitted to trap buffer and size of trap buffer is 256, that is, the trap buffer can hold 256 messages.
The information can be output to the trap buffer by configuring the size of the buffer.
# Send information to the trap buffer and sets the size of the buffer to 30.
<H3C> system-view
[H3C] info-center trapbuffer size 30
1.1.18  reset logbuffer
reset logbuffer
View
None
Use the reset logbuffer command to reset information in log buffer.
# Clear information in log buffer.
<H3C> reset logbuffer
1.1.19  reset trapbuffer
reset trapbuffer
View
None
Use the reset trapbuffer command to reset information in trap buffer.
# Clear information in trap buffer.
<H3C> reset trapbuffer
1.1.20  terminal debugging
terminal debugging
undo terminal debugging
View
None
Use the terminal debugging command to configure to display the debugging information on the terminal.
Use the undo terminal debugging command to configure not to display the debugging information on the terminal.
By default, the terminal display function of debugging information is disabled.
Related commands: debugging.
# Enable the terminal display debugging.
<H3C> terminal debugging
1.1.21  terminal logging
terminal logging
undo terminal logging
View
None
Use the terminal logging command to enable terminal log information display.
Use the undo terminal logging command to disable terminal log information display.
By default, the log information display is enabled on the console and disabled on the terminal.
# Disable the terminal display function of log information.
<H3C> undo terminal logging
1.1.22  terminal monitor
terminal monitor
undo terminal monitor
View
None
Use the terminal monitor command to enable the terminal display functions.
Use the undo terminal monitor command to disable the terminal display functions.
By default, the system enables the functions of debugging/log/trap information on the console and disables them on the terminal.
This command only takes effect on the current terminal where the commands are input. The debugging/log/trap information can be output to the current terminal, beginning in user view. When the terminal monitor is shut down, no debugging/log/trap information will be displayed in local terminal, which is equals to having performed undo terminal debugging, undo terminal logging, undo terminal trapping commands. When the terminal monitor is enabled, you can use terminal debugging / undo terminal debugging, terminal logging / terminal logging and terminal trapping / undo terminal trapping respectively to enable or disable the corresponding functions.
# Disable the terminal monitor.
<H3C> undo terminal monitor
1.1.23  terminal trapping
terminal trapping
View
None
Use the terminal trapping command to enable terminal display function of trap information.
Use the undo terminal trapping command to disable this function.
By default, this function is enabled.
# Enable the terminal display function of trap information.
<H3C> terminal trapping
