H3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
09-SNMP Commands
09-SNMP Commands 90.58 KB
Chapter 1  SNMP Configuration Commands
1.1  SNMP Configuration Commands
1.1.1  display snmp-agent local-engineid
View
local-engineid: Local engine ID.
remote-engineid: Remote engine ID.
Use the display snmp-agent local-engineid command to view engine ID of current device.
SNMP engine is the core of SNMP entity. It performs the function of sending, receiving and authenticating SNMP message, extracting PDU, packet encapsulation and the communication with SNMP application, and so on.
# Display the engine ID of current device.
<H3C> display snmp-agent local-engineid
SNMP local EngineID: 800007DB00E0FC0000FF6877
The above displayed information “SNMP local engine ID” represents local SNMP engine ID.
1.1.2  display snmp-agent community
View
read: Displays read-only community information.
write: Displays read-write community information.
Use the display snmp-agent community command to view the currently configured community names.
# Display the currently configured community names.
<H3C> display snmp-agent community
Community name:public
       Group name:public
       Storage-type: nonVolatile
   Community name:private
       Group name:private
Table 1-1 display snmp-agent community command output description
community name
Community name
Group name
Group name
storage-type
Storage mode
1.1.3  display snmp-agent group
display snmp-agent group [ group-name ]
View
groupname: Group name.
Use the display snmp-agent group command to view group name, security mode, state of various views and storage modes.
# Display SNMP group name and safe mode.
<H3C> display snmp-agent group
       Group name: test
       Security model: v2c noAuthnoPriv
       Readview: ViewDefault
       Writeview: <no specified>
       Notifyview :<no specified>
The following table describes the output fields.
Table 1-2 display snmp-agent group command output description
groupname
SNMP Group name
Security model
The security mode adopted by SNMP
readview
Read-only MIB view name corresponding to that group
writeview
Writable MIB view corresponding to that group
notifyview
The name of the notify MIB view corresponding to that group
storage-type
Storage mode
1.1.4  display snmp-agent mib-view
display snmp-agent mib-view [ exclude | include | { viewname mib-view } ]
View
exclude: Displays the SNMP MIB view excluded.
Include: Displays the SNMP MIB view included.
viewname: Displays the SNMP MIB view according to the mib view name.
mib-view: Specifies the MIB view name.
Use the display snmp-agent mib-view command to view the MIB view configuration information of the switch.
# Display the information about the currently configured MIB view.
<H3C> display snmp-agent mib-view
View name:ViewDefault
       MIB Subtree:internet
       Subtree mask:
       View Type:included
       View status:active
       MIB Subtree:snmpUsmMIB
       Subtree mask:
       View Type:excluded
       View status:active
       MIB Subtree:snmpVacmMIB
       Subtree mask:
       View Type:excluded
       View status:active
Table 1-3 display snmp-agent mib-view command output description
View name
View name
MIB Subtree
MIB subtree
Subtree mask
Subtree mask
storage-type
Storage type
View Type
Permit or forbid access to an MIB object
View status
Indicate the line state in the table
  Caution:
If the SNMP Agent is disabled, "Snmp Agent disabled" will be displayed after you execute the above display commands.
1.1.5  display snmp-agent statistics
View
None
Use the display snmp-agent statistics command to view current state of SNMP communication.
This command provides a counter for SNMP operations.
# Display the current state of SNMP communication.
<H3C> display snmp-agent statistics
  0 Messages delivered to the SNMP entity
  0 Messages which were for an unsupported version
  0 Messages which used a SNMP community name not known
  0 Messages which represented an illegal operation for the community supplied
  0 ASN.1 or BER errors in the process of decoding
  9 Messages passed from the SNMP entity
  0 SNMP PDUs which had badValue error-status
  0 SNMP PDUs which had genErr error-status
  0 SNMP PDUs which had noSuchName error-status
  0 SNMP PDUs which had tooBig error-status (Maximum packet size 2000)
  9 MIB objects retrieved successfully
  0 MIB objects altered successfully
  0 GetRequest-PDU accepted and processed
  9 GetNextRequest-PDU accepted and processed
  0 GetBulkRequest-PDU accepted and processed
9 GetResponse-PDU accepted and processed
  0 SetRequest-PDU accepted and processed
  0 Trap PDUs accepted and processed
  0 Alternate Response Class PDUs droped silently
  0 Forwarded Confirmed Class PDUs droped silently
Table 1-4 display snmp-agent statistics command output description
9 Get-next PDUs accepted and processed
Total number of the input SNMP packets
Number of packets with version information error
0 GetResponse PDUs accepted and processed
Number of packets with community name error
0 Set-request PDU accepted and processed
Number of packets with authority error corresponding to the community name
Number of SNMP packets with encoding error
Number of SNMP data packets output
Number of SNMP packets with erroneous values
Number of SNMP packets with general error
Number or packets request for nonexistent MIB objects
Number of too long SNMP packets
Number of variables requested by NMS
Number of variables sent by NMS
Number of the received packets requested by get
Number of the received packets requested by get-next
Number of the received packets requested by getBulk
Number of the response packets sent
Number of the trap messages sent
Number of the response packets dropped
Number of the trap messages dropped
1.1.6  display snmp-agent sys-info
display snmp-agent sys-info [ contact | location | version ]*
View
None
Use the display snmp-agent sys-info command to view the character string sysContact (system contact), character string describing the system location and the version information about the running SNMP in the system.
# Display the character string sysContact.
<H3C> display snmp-agent sys-info contact
The contact person for this managed node:
           Hangzhou H3C Technologies Co.,Ltd.
The above information represents that the contact person for this machine is Hangzhou H3C Technologies Co.,Ltd.
# Display the character string describing the system location.
<H3C> display snmp-agent sys-info location
The physical location of this node:
 Hangzhou, China
The above information represents that the physical location of this machine is:  Hangzhou, China.
# Display the version information of running SNMP
<H3C> display snmp-agent sys-info version
SNMP version running in the system:
           SNMPv3
The above information represents that the SNMP version running in the system is: SNMPv3.
1.1.7  display snmp-agent usm-user
display snmp-agent usm-user [ engineid engineid | group groupname | username username ]*
View
engineid: Displays user information with specified engine ID.
username: Displays user information with specified user name.
groupname: Displays user information of specified group.
Use the display snmp-agent usm-user command to view information of all the SNMP usernames in the group username list.
SNMP user is the remote user executing SNMP administrative operation. You can use the snmp-agent usm-user command to specify the SNMP user.
# Display the information of all the current users.
<H3C> display snmp-agent usm-user
User name: NotifyV3
   Group name: NotifyGroup
       AuthenticationAuthencation Mode: sha
       Privacy Mode: des
       Engine ID: 800007DB00E0FC2095026877 active
   User name: publicV3
   Group name: groupV3
       AuthenticationAuthencation Mode: no
       Privacy Mode: no
       Acl:2000
Table 1-5 display snmp-agent usm-user command output description
User name
Character string identifying the SNMP user
Group name
Character string identifying the group the user belongs to
Authentication Mode
Authentication code
Privacy Mode
Personal code
Engine ID
Character string identifying the SNMP device
Acl
Character string identifying the access control list
1.1.8  enable snmp trap updown
undo enable snmp trap updown
View
Ethernet port view, VLAN interface view
None
Use the enable snmp trap updown command to enable current port or VLAN interface to transmit the link up and link down trap messages.
Use the undo enable snmp trap updown command to disable current port or VLAN interface from transmitting link up and link down trap messages.
The enable snmp trap command should be used in cooperation with the snmp-agent trap enable and the snmp-agent target-host commands. The snmp-agent target-host command is used to specify which hosts can receive the trap messages. To enable the transmitting of trap messages, you must execute the snmp-agent target-host command at least once.
# Enable port Ethernet 6/1/1 to transmit link up and link down trap messages with the community name public.
<H3C> system-view
[H3C-Ethernet6/1/1] snmp trap updown enable
[H3C] snmp-agent target-host trap address udp-domain 10.1.1.1 params securityname public
[H3C] interface ethernet6/1/1
[H3C-Ethernet6/1/1] enable snmp trap updown
1.1.9  snmp-agent community
snmp-agent community { read | write } community-name [ [ mib-view view-name ] [ acl acl-list ] ]
undo snmp-agent community community-name
View
read: Indicates that MIB object can only be read.
write: Indicates that MIB object can be read and written.
community-name: Community name character string.
view-name: MIB view name.
acl acl-list: sets access control list for specified community.
Use the snmp-agent community command to configure community access name and enable the access to SNMP.
Use the undo snmp-agent community command to cancel the settings of community access name.
# Configure community name as comaccess and permits read-only access by this community name.
<H3C> system-view
[H3C] snmp-agent community read comaccess
# Configure community name as mgr and permits read-write access.
[H3C] snmp-agent community write mgr
# Delete the community name comaccess.
[H3C] undo snmp-agent community comaccess
1.1.10  snmp-agent group
snmp-agent group { v1 | v2c } group-name [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-list ]
undo snmp-agent group { v1 | v2c } group-name
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [notify-view notify-view ] [ acl acl-list ]
undo snmp-agent group v3 group-name [ authentication | privacy ]
View
v1: SNMPv1 security mode.
v2c: SNMPv2c security mode.
v3: SNMPv3 security mode.
group-name: Group name, ranging from 1 to 32 bytes.
authentication: Configures to authenticate the packet without encryption.
privacy: Configures to authenticate and encrypt the packet.
read-view: Configures to allow read-only view settings.
read-view: Read-only view name, ranging from 1 to 32 bytes.
write-view: Configures to allow read-write view settings.
write-view: Name of read-write view, ranging from 1 to 32 bytes.
notify-view: Configures to allow notify view settings.
notify-view: Specifies the notify view name, ranging from 1 to 32 bytes.
acl Sets access control list for this group name.
acl-list: access control list
Use the snmp-agent group command to configure a new SNMP group, that is, to map SNMP user to SNMP view.
Use the undo snmp-agent group command to cancel a specified SNMP group.
By default, the SNMP group configured using the snmp-agent group v3 command is in none authentication mode.
Related commands: snmp-agent mib-view, snmp-agent usm-user.
# Create an SNMP group named test.
<H3C> system-view
[H3C] snmp-agent group v3 test.
1.1.11  snmp-agent local-engineid
undo snmp-agent local-engineid
View
engineid: Engine ID, an even number of hexadecimal characters, in the range 10 to 64. Its length must not be an odd number, and the all-zero and all-F strings are invalid.
Use the snmp-agent local-engineid command to configure a name for a local or remote SNMP engine on the switch.
Use the command to Using undo snmp-agent local-engineid command, you can restore the default setting of engine ID.
By default, the engine ID is corporation number + device information. Device information is determined according to different products. It can be IP address, MAC address or user defined text. However, you must use numbers in hexadecimal form.
# Configure the ID of a local or remote device as 1234512345.
<H3C> system-view
[H3C] snmp-agent local-engineid 1234512345
1.1.12  snmp-agent mib-view
snmp-agent mib-view { included | excluded } view-name oid-tree
undo snmp-agent mib-view view-name
View
included: Includes this MIB subtree.
excluded: Excludes this MIB subtree.
view-name: Specifies the view name, with a character string, ranging from 1 to 32 characters.
oid-tree: MIB object subtree. It can be a character string of the variable OID, or a variable name, ranging from 1 to 255 characters. By default, OID is 1.3.6.1.
Use the snmp-agent mib-view command to create or update the view information.
Use the undo snmp-agent mib-view command to cancel the view information
By default, the view name is ViewDefault. OID is 1.3.6.1.
This command supports the parameter input of both OID and node name.
Related commands: snmp-agent group.
# Create a view that consists of all the objects of MIB-II.
<H3C> system-view
[H3C] snmp-agent mib-view included mib2 1.3.6.1.2.1
1.1.13  snmp-agent packet max-size
undo snmp-agent packet max-size
View
byte-count: Specifies the size of SNMP packet (measured in bytes), ranging from 484 to 17940. By default, the size is 2000 bytes.
Use the snmp-agent packet max-size command to configure the size of SNMP packet that the Agent can send/receive.
Use the undo snmp-agent packet max-size command to restore the default size of SNMP packet.
The sizes of the SNMP packets received/sent by the Agent are different in different network environment.
# Set the size of SNMP packet to 1042 bytes.
<H3C> system-view
[H3C] snmp-agent packet max-size 1042
1.1.14  snmp-agent sys-info
snmp-agent sys-info { contact sysContact | location syslocation | version { { v1 | v2c | v3 } * | all } }
undo snmp-agent sys-info { { contact | location }* | version { { v1 | v2c | v3 } * | all } }
View
contact: The contact information for system maintenance.
sysContact: Characters describe the contact information for system maintenance.
location: Sets the geographical location of the device.
sysLocation: Geographical location of the device.
version: version of running SNMP.
v1: SNMPv1.
v2c: SNMPv2c.
v3: SNMPv3.
*: Indicates that you can select more than one item from the three options v1, v2c, and v3. Here, you must select at least one option, and you can select all the three options.
all: all SNMP version (includes SNMPv1, SNMPv2c, SNMPv3).
Use the snmp-agent sys-info command to configure system information such as geographical location of the device, contact information for system maintenance and version information of running SNMP.
Use the undo snmp-agent sys-info location command to restore the default value.
By default, the contact information for system maintenance is " Hangzhou H3C Technologies Co., Ltd.", the system information about geographical location is " Hangzhou, China", and the version information is " SNMPv1, SNMPv2c, and SNMPv3".
Related commands: display snmp-agent sys-info.
# Set the system maintenance information to "Dial System Operator at beeper # 27345".
<H3C> system-view
[H3C] snmp-agent sys-info contact Dial System Operator at beeper # 27345
1.1.15  snmp-agent target-host
snmp-agent target-host trap address udp-domain host-addr [ udp-port udp-port-number ] params securityname securityname [ v1 | v2c | v3 [ authentication | privacy ] ]
undo snmp-agent target-host host-addr securityname securityname
View
address: Specifies the address of the host which receives SNMP messages.
host-addr: IP address of the host.
udp-port udp-port-number: Specifies the UDP port number of the host to receive the SNMP notification.
v1: Represent the version of SNMPv1.
v2c: Represent the version of SNMPv2c.
v3: Represent the version of SNMPv3.
securityname: Specifies the community name, in the range 1 to 32 bytes. It can be the community name of SNMPv1/v2c or the user name of SNMPv3.
Use the snmp-agent target-host command to configure destination of SNMP notification.
Use the undo snmp-agent target-host command to cancel the host that receives SNMP notification.
The snmp-agent target-host command and the snmp-agent trap enable command should be used at the same time. Use the snmp-agent trap enable command to enable the device to transmit trap messages. The snmp-agent trap enable command and snmp-agent target-host command should be used at the same time on the host to enable notify message sending.
&  Note:
If the version of SNMP message is v3, the packet authentication encryption mode specified by the command must be consistent with configuration for SNMP group to which the securityname belongs.
Related commands: snmp-agent trap enable, snmp-agent trap source, snmp-agent trap life, snmp-agent group, snmp-agent usm-user.
# Enable sending trap message to 10.1.1.1 with community name public.
<H3C> system-view
[H3C] snmp-agent trap enable
1.1.16  snmp-agent trap enable
snmp-agent trap enable [ bgp [ backwardtransition | established ]* | configuration | flash | ospf [ process-id ] [ ospf-trap-list ] | protect-switch | pw | ldp | lsp | mpls-oam | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
undo snmp-agent trap enable [ bgp [ backwardtransition | established ]* | configuration | flash | ospf [ process-id ] [ ospf-trap-list ] | protect-switch | pw | ldp | lsp | mpls-oam | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
View
standard [ authentication ] [ coldstart ] [ linkdown ] [ linkup ]: Enables the sending of standard trap messages.
authentication: Enables the sending of SNMP authentication trap messages.
coldstart: Enables the sending of SNMP cold start trap messages.
linkdown: Enables the sending of SNMP link down trap messages.
linkup: Enables the sending of SNMP link up trap messages.
warmstart: Enables the sending of SNMP hot start trap messages.
bgp [ backwardtransition ] [ established ] : Enables the sending of BGP trap messages.
ospf [ process-id ] [ ospf-trap-list ]: Enables the sending of OSPF trap messages.
pw: Enables the sending of trap messages about Martini VLL PW state.
mpls-oam: Enables the sending of trap messages about MPLS-OAM.
protect-switch: Enables the sending of trap messages about protect-switch state.
configuration: Enables the sending of configuration management trap messages.
flash: Enables the sending of FLASH trap messages.
system: Enables the sending of system management MIB trap messages.
vrrp [ authfailure | newmaster ]: Enables the sending of VRRP trap messages.
ldp: Enables the sending of LDP trap messages.
lsp: Enables the sending of LSP trap messages.
Use the snmp-agent trap enable command to enable the sending of trap messages.
Use the undo snmp-agent trap enable command to disable the sending of trap messages.
By default, trap message sending is disabled.
The snmp-agent trap enable command and snmp-agent target-host command should be used at the same time. The snmp-agent target-host command specifies which hosts can receive trap message. However, to send trap message, at least one snmp-agent target-host command should be configured.
&  Note:
After you enable the device to send trap messages of a specific event using the snmp-agent trap enable command, the corresponding trap alarms will be sent to the SNMP users when the event occurs.
# Enable the sending of the trap message of SNMP authentication failure to 10.1.1.1. The community name is public.
<H3C> system-view
[H3C] snmp-agent trap enable standard authentication
1.1.17  snmp-agent trap if-mib link extended
snmp-agent trap ifmib link extended
undo snmp-agent trap ifmib link extended
View
None
Use the snmp-agent trap ifmib link extended command to configure a link up/down trap to carry the interface type and interface number besides the parameters defined in the standard MIB when the trap is sent.
Use the undo snmp-agent trap if-mib link extended command to restore the default.
By default, a link up/down trap carries only the parameters defined in the standard MIB.
# Configure a link up/down trap to carry the interface type and interface number besides the parameters defined in the standard MIB when the trap is sent.
<H3C> system-view
[H3C] snmp-agent trap ifmib link extended
1.1.18  snmp-agent trap life
snmp-agent trap life seconds
undo snmp-agent trap life
View
seconds: Specifies the time for keeping trap messages, in the range 1 to 2,592,000 seconds; By default, the time for keeping trap messages is 120 seconds.
Use the snmp-agent trap life command to configure the timeout of trap messages.
Use the undo snmp-agent trap life command to restore the default value.
The set timeout of trap message is represented by seconds. If time exceeds seconds, this trap message will be discarded.
Related commands: snmp-agent trap enable, snmp-agent target-host .
# Configure the time for keeping trap messages as 60 seconds.
<H3C> system-view
[H3C] snmp-agent trap life 60
1.1.19  snmp-agent trap queue-size
snmp-agent trap queue-size length
undo snmp-agent trap queue-size
View
length: Length of queue, ranging from 1 to 1,000. By default, the length is 100.
Use the snmp-agent trap queue-size command to configure the information queue length of trap message sent to Destination Host.
Use the undo snmp-agent trap queue-size command to restore the default value.
Related commands: snmp-agent trap enable, snmp-agent target-host, snmp-agent trap life.
# Configure the queue length as 200.
<H3C> system-view
[H3C] snmp-agent trap queue-size 200
1.1.20  snmp-agent trap source
snmp-agent trap source interface vlan-id-type interface-number
undo snmp-agent trap source
View
interface-type: Specifies an interface by its type.
interface-number: Specifies an interface by its number.
Use the snmp-agent trap source command to configure the source address for sending trap.
Use the undo snmp-agent trap source command to cancel the source address for sending trap.
You can use this command to configure to track specific event by using the trap address.
# Configure the IP address of the VLAN interface 1 as the source address for transmitting the trap messages.
<H3C> system-view
[H3C] snmp-agent trap source vlan-interface 1
1.1.21  snmp-agent usm-user
snmp-agent usm-user { v1 | v2c } username groupname [ acl acl-list ]
undo snmp-agent usm-user { v1 | v2c } username groupname
snmp-agent usm-user v3 username groupname [ authentication-mode { md5 | sha } authpassstring [ privacy-mode { des56 privpassstring } ] ] [ acl acl-list ]
undo snmp-agent usm-user v3 username groupname { local | engineid engine-id }
View
v1: Configures to use v1 safe mode.
v2c: Configures to use v2c safe mode.
v3: Configures to use v3 safe mode.
username: Specifies the user name, ranging from 1 to 32 characters.
groupname: Specifies the group name corresponding to that user, a string of 1 to 32 characters.
authentication-mode: Specifies the safety level as authentication required.
md5: MD5 algorithm is adopted in authentication. MD5 authentication uses the 128-digit password. Computation speed of MD5 is faster than that of SHA
sha: SHA algorithm is adopted in authentication. SHA authentication uses the 160-digit password. Computation speed of SHA is slower than that of MD5, but with higher security.
authpasstring: Specifies the authentication password, a string of 1 to 64 characters.
privacy-mode: Specifies the safety level as encrypted.
des56: Specifies the authentication protocol as DES.
privpassword: Specifies the encryption password, a string of 1 to 64 characters.
acl acl-list: Sets access control list for this user based on USM name
engineid engine-id: SNMP engineID.
Use the snmp-agent usm-user command to add a new user to an SNMP group.
Use the undo snmp-agent usm-user command to cancel a user from SNMP group.
SNMP engineID (for authentication) is required when configuring remote user for an agent. This command will not be effective without engineID configured.
For SNMPv1 and SNMPv2c, this command will add a new community name. For SNMPv3, it will add a new user for an SNMP group.
# Add a user wang for test (an SNMP group), configures to authenticate with MD5 and sets authentication password as pass.
<H3C> system-view
[H3C] snmp-agent usm-user v3 wang test authentication-mode md5 pass
1.1.22  undo snmp-agent
undo snmp-agent
View
None
Use the undo snmp-agent command to disable all versions of SNMP running on the server.
Perform any command of snmp-agent will enable SNMP Agent.
# Disable the running SNMP agents of all SNMP versions.
<H3C> system-view
