H3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
08-RMON Commands
08-RMON Commands 63.83 KB
Chapter 1  RMON Configuration Commands
1.1  RMON Configuration Commands
1.1.1  display rmon alarm
display rmon alarm [ alarm-table-entry ]
View
alarm-table-entry: Alarm table entry index.
Use the display rmon alarm command to view RMON alarm information.
Related commands: rmon alarm.
# Display the RMON alarm information.
<H3C> display rmon alarm
Alarm table 1 owned by monitor is VALID.
  Samples type          : delta
  Variable formula      : 1.3.6.1.2.1.16.1.1.1.3.1<etherStatsDropEvents.1>
  Description           : Ethernet5/1/1
  Sampling interval     : 10(sec)
  Rising threshold      : 10(linked with event 1)
  Falling threshold     : 2(linked with event 1)
  When startup enables  : risingOrFallingAlarm
  Latest value          : 0
Table 1-1 display rmon alarm command output description
Alarm table 1
Index 1 in alarm table
monitor
Owner
VALID
The alarm entry corresponding to this index is valid.
Samples type
Type of sampling
Variable formula
Variable parameters
Description information
Sampling interval
Time interval for sampling
Rising threshold is 1000
The rising threshold is 1000.
Falling threshold is 100
The falling threshold is 100.
startup
First triggering
When startup enables: risingOrFallingAlarm
Type of the first alarm. The startup may trigger rising threshold alarm, falling threshold alarm, or both.
Latest value
Last sample value
1.1.2  display rmon event
display rmon event [ event-table-entry ]
View
event-table-entry: Entry index of event table.
Use the display rmon event command to view RMON events.
The display includes event index in event table, owner of the event, description to the event, action caused by event (log or alarm information), and occurrence time of the latest event (counted on system initiate/boot time in centiseconds).
Related commands: rmon event.
# Show the RMON event.
<H3C> display rmon event
Event table 1 owned by null is VALID.
  Description: null.
  Will cause log-trap when triggered, last triggered at 0days 00h:02m:27s.
Table 1-2 display rmon event command output description
Event table 1
Index in event table
VALID
The entry corresponding to the index is valid
Event description
Cause log-trap when triggered,
When the event is triggered, it will cause the log-trap.
Last triggered at 0days 00h:02m:27s
The last triggered time is 00h:02m:27s
1.1.3  display rmon eventlog
display rmon eventlog [ event-number ]
View
event-number: Entry index of event table.
Use the display rmon eventlog command to view RMON event log.
The display includes event index in the event table, the status of the event, the time at which the event log is generated (this time starts from the system initialization or booting and counted in milliseconds), and event description.
# Show event log of RMON.
<H3C> display rmon eventlog 1
Generates eventLog 1.1 at 0days 00h:01m:39s.
Description: The 1.3.6.1.2.1.16.1.1.1.4.1 defined in alarm table 1,
less than(or =) 100 with alarm value 0. Alarm sample type is absolute.
Generates eventLog 1.2 at 0days 00h:02m:27s.
Description: The alarm formula defined in private alarm table 1,
Table 1-3 display rmon eventlog command output description
Event table 1
Index 1 in event table
VALID
Event description
The alarm sample value is less than or equal to 100
The type of alarm sampling is absolute
The eventlog corresponding to the index 1.2 is generated at 0days 00h:02m:27s.
1.1.4  display rmon history
display rmon history [ port-num ]
View
port-num: Ethernet port name.
Use the display rmon history command to view latest RMON history sampling information (including utility, error number and total packet number).
Related commands: rmon history.
# Show the RMON history information.
<H3C> display rmon history ethernet 2/1/1
History control entry 1 owned by null is VALID
  Samples interface     : Ethernet2/1/1<ifEntry.642>
  Sampling interval     : 10(sec) with 10 buckets max
  Latest sampled values :
  Dropevents        :0         , octets               :0
  packets           :0         , broadcast packets    :0
  multicast packets :0         , CRC alignment errors :0
  undersize packets :0         , oversize packets     :0
  fragments         :0         , jabbers              :0
  collisions        :0         , utilization          :0
Table 1-4 display rmon history command output description
Samples interface
The sampled interface
Index number in history control table
VALID
Sampling interval
Sampling interval
buckets
Records in history control table
The latest sample information
dropevents
Dropping packet events
octets
Sent/Received octets in sampling time
packets
Packets sent/received in sampling time
broadcast packets
Number of broadcast packets
multicast packets
Number of multicast packets
Number of CRC error packets
undersized packets
Number of undersized packets
oversized packets
Number of oversized packets
fragments
Number of undersized and CRC error packets
jabbers
Number of oversized and CRC error packets
collisions
Number of collision packets
utilization
Utilization
1.1.5  display rmon prialarm
display rmon prialarm [ prialarm-table-entry ]
View
prialarm-table-entry: Entry index of extended RMON alarm table.
Use the display rmon prialarm command to view information about extended RMON alarm table.
Related commands: rmon prialarm.
# Display the information about extended RMON alarm table.
<H3C> display rmon prialarm
Prialarm table 1 owned by monitor is UNDERCREATION.
  Samples type          : changeratio
  Variable formula      : (.1.3.6.1.2.1.2.2.1.10.201326601+.1.3.6.1.2.1.2.2.1.16
.201326601)*8*100/.1.3.6.1.2.1.2.2.1.5.201326601
  Description           : ifUtilization.Ethernet5/1/1
  Rising threshold      : 50(linked with event 1)
  Falling threshold     : 5(linked with event 1)
  This entry will exist : forever.
  Latest value          : 0
Table 1-5 display rmon prialarm command output description
Prialarm table 1
Index of extended alarm entry.
owned by monitor
Creator of the extended alarm entry.
UNDERCREATION
Status of expansion alarms
Samples type
Type of sampling
Variable formula
Formula for expansion alarms
Sampling interval
Rising threshold. When sampling value rises from normal value to this threshold, rising threshold alarm will be triggered.
Falling threshold. When sampling value decreases from normal value to this threshold, falling threshold alarm will be triggered.
linked with event 1
Corresponding event index of ring and falling threshold alarm.
Kind of first alarm. It may trigger rising threshold alarm or falling threshold alarm or both.
This entry will exist forever
The lifespan of this alarm entry which can be forever or a specified period of time.
Latest value : 0
The value of the latest sampling.
1.1.6  display rmon statistics
display rmon statistics [ port-num ]
View
port-num: Ethernet port number.
Use the display rmon statistics command to view RMON statistics.
The displayed information includes collision, CRC (Cyclic Redundancy Check) and queue, undersized or oversized packet, timeout, fragment, broadcast, multicast, unicast, and bandwidth utility.
Related commands: rmon statistics.
# Show RMON statistics.
<H3C> display rmon statistics Ethernet 2/1/1
Statistics entry 1 owned by aaa is VALID.
  Interface : Ethernet2/1/1<ifIndex.872418178>
  etherStatsOctets         : 756       , etherStatsPkts          : 9
  etherStatsBroadcastPkts  : 9         , etherStatsMulticastPkts : 0
  etherStatsUndersizePkts  : 0         , etherStatsOversizePkts  : 0
  etherStatsFragments      : 0         , etherStatsJabbers       : 0
  etherStatsCRCAlignErrors : 0         , etherStatsCollisions    : 0
  etherStatsDropEvents (insufficient resources): 0
  Packets received according to length (etherStatsPktsXXXtoYYYOctets):
  64     : 0         ,  65-127  : 444       ,  128-255  : 0
  256-511: 0         ,  512-1023: 0         ,  1024-max : 0
1.1.7  rmon alarm
rmon alarm entry-number alarm-variable sampling-time { delta | absolute } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 [ owner text ]
undo rmon alarm entry-number
View
entry-number: Number of the entry to be added/deleted, ranging from 1 to 65535.
alarm-variable: Specifies the alarm variable with a character string, ranging from 1 to 256, in the OID dotted format, like 1.3.6.1.2.1.2.1.10.1 (or ifInOctets.1).
sampling-time: Specifies the sampling interval, ranging from 5 to 65535 (measured in seconds).
delta: Sampling type is delta.
absolute: Sampling type is absolute.
rising-threshold threshold-value1: Rising threshold, ranging from 0 to 2147483647.
event-entry1: Event number corresponding to the upper limit of threshold, ranging from 0 to 65535.
falling-threshold threshold-value2: Falling threshold, ranging from 0 to 2147483647.
event-entry2: Event number corresponding to the falling threshold, ranging from 0 to 65535.
owner text: Specifies the creator of the alarm. Length of the character string ranges from 1 to 127.
Use the rmon alarm command to add an entry to the alarm table.
Use the undo rmon alarm command to cancel an entry from this table.
In this way, the alarm event can be triggered in the abnormal situations and then decides to log and send trap to the NM station.
&  Note:
Before adding an alarm entry, you need first to define the event to be referenced in the alarm entry using the rmon event command.
The system takes these actions on the defined alarm entries:
l           Sampling the defined alarm variables at a specified time interval.
l           Comparing the sample values against the predefined threshold and take further actions (see Table 1-6).
Table 1-6 Handling alarm entries
Item
Handling
The sample value is greater than the upper limit threshold-value1.
Triggers the defined event event-entry1
The sample value is less than the lower limit threshold-value2.
Triggers the defined event event-entry2
# Create alarm group
l           Configure an event before configuring “alarm” and “prialarm”.
[H3C]rmon event 1 log  owner test-rmon
l           View configuration information.
[H3C]display rmon event 1
Event table 1 owned by test-rmon is VALID.
  Description: null.
  Will cause log when triggered, last triggered at 1days 01h:42m:09s.
l           Configure alarm group.
# Add the first line in the alarm table. Sample the nodes 1.3.6.1.2.1.16.1.1.1.4.1 every 10 seconds. Trigger event 1 when the sampling value exceeds the upper threshold 50, and trigger event 2 when the sampling value gets below the lower threshold 5. The owner is user1.
<H3C> system-view
[H3C]rmon alarm 1 1.3.6.1.2.1.16.1.1.1.4.1 10 absolute rising_threshold 50 1 falling_threshold 5 2 owner user1
# Delete the information of entry 15 from the alarm table.
<H3C> system-view
[H3C] undo rmon alarm 15
1.1.8  rmon event
rmon event event-entry [ description string ] { log | trap trap-community | log-trap log-trapcommunity | none } [ owner text ]
undo rmon event event-entry
View
event-entry: Number of the entry to be added/deleted, ranging from 1 to 65535.
description string: Event description. Length of the character string ranges from 1 to 127.
log-trap log-trapcommunity: Defines the event as log and trap event, and specifies the community name of the NMS which receives the messages triggered by the event.
log: Log event.
trap trap-community: Defines the event as trap event, and specifies the community name of the NMS which receives the messages triggered by the event.
none: Neither log nor trap event.
owner text: Creator for this entry. The length of the character string ranges from 1 to 127.
Use the rmon event command to add an entry to the event table.
Use the undo rmon event command to cancel an entry from this table.
RMON event management defines the event ID and the handling of the event.
You can handle the event in the following ways:
l           Keeping logs
l           Sending the trap messages to NMS
l           Keeping logs and sending the trap messages to NMS
# Add the entry 10 to the event table and marks it as log event.
<H3C> system-view
[H3C] rmon event 10 log
1.1.9  rmon history
rmon history entry-number buckets number interval sampling-interval [ owner text-string ]
undo rmon history entry-number
View
Ethernet port view
entry-number: Number of the entry to be added/deleted, ranging from 1 to 65,535.
buckets number: Capacity of the history table corresponding to the control line.
interval sampling-interval: Sampling interval, ranging from 5 to 3600 (measured in seconds).
owner text-string: Creator of this entry. Length of the character string ranges from 1 to 127.
Use the rmon history command to add an entry to the history control table.
Use the undo rmon history command to cancel an entry from history control table.
Perform this command to sample, set sample parameter (sample time interval) and storage amounts for a port. RMON will periodically perform data collection and save for query on this port. Sample information includes utility, error number and total packet number.
Related commands: display rmon history.
# Create a history control table entry with the index number of 15, capacity of 100 and sampling interval of 10 seconds. The owner is tester.
<H3C> system-view
[H3C] interface Ethernet 2/1/1
[H3C-Ethernet2/1/1] rmon history 15 buckets 100 interval 10 owner tester
1.1.10  rmon prialarm
rmon prialarm entry-number prialarm-formula prialarm-des sampling-timer { delta | absolute | changeratio } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 entrytype { forever | cycle cycle-period } [ owner text ]
undo rmon prialarm entry-number
View
entry-number: Specifies the entry number, ranging from 1 to 65535.
prialarm-formula: Variables in the formula must be represented by OID, for example, (1.3.6.1.2.1.2.1.10.1)*8. The operation results are in long integers. Every operation result must be within the range of the long integer; otherwise, errors may be prompted.
prialarm-des : Specifies the alarm description with a length ranging from 1 to 256;
sampling-timer: Sets the sampling interval, ranging from 10 to 65535 and measured in seconds.
delta | absolute | changeratio: Specifies the sampling type as delta ratio, absolute ratio or change ratio.
threshold-value1: Rising threshold value, specified with a number greater than 0.
event-entry1: Corresponding event number to the upper limit threshold value, ranging from 0 to 65535.
threshold-value2: Falling threshold value, specified with a number greater than 0.
forever | cycle cycle-period: Specifies the type of the alarm instance line.
cycle-period specifies the functional cycle of the instance.
owner text: Creator of this entry. Length of the character string ranges from 1 to 127.
Use the rmon prialarm command to add an entry to the extended RMON alarm table.
Use the undo rmon prialarm command to cancel an entry from the extended RMON alarm table.
The number of instances can be created in the table depends on the hardware resource of the product.
&  Note:
Before adding an extended alarm entry, you need first to define the event to be referenced in the extended alarm entry using the rmon event command.
You can define up to 50 prialarm entries.
The system takes these actions on the extended alarm entries you defined:
l           Sampling the alarm variables in the defined extended alarm formula at a specified time interval.
l           Calculating the sample value using the defined extended alarm formula.
l           Comparing the sample values against the predefined threshold and take further actions (see Table 1-7).
Table 1-7 Handling extended alarm entries
Item
Handling
The calculated sample value is greater than the upper limit threshold-value1.
The calculated sample value is less than the lower limit threshold-value2.
# Add an extended alarm entry in the fifth line of the extended alarm table. Perform operation on the corresponding variant by means of the formula ((.1.3.6.1.4.1.43.45.1.6.1.2.1.1.2.1-.1.3.6.1.4.1.43.45.1.6.1.2.1.1.3.1)*100/.1.3.6.1.4.1.43.45.1.6.1.2.1.1.2.1) to get the port utilization of Gigabit Ethernet interface 1/1/1. Monitor the operation results at the sampling interval of 10 seconds. When the variation rate exceeds the upper threshold 50, trigger event 1; when the variation rate gets below the lower threshold 2, trigger event 2. Set the alarm instance sampling type to “forever”, and set the owner of the extended alarm table to “user1”.
<H3C> system-view
[H3C] rmon prialarm 5 ((.1.3.6.1.4.1.43.45.1.6.1.2.1.1.2.1-.1.3.6.1.4.1.43.45.1.6.1.2.1.1.3.1)*100/.1.3.6.1.4.1.43.45.1.6.1.2.1.1.2.1) ifUtilization.GigabitEthernet1/1/1 10 changeratio rising_threshold 50 1 falling_threshold 5 2 entrytype forever owner user1
# Delete line 10 from the extended RMON alarm table.
<H3C> system-view
[H3C] undo rmon prialarm 10
1.1.11  rmon statistics
rmon statistics entry-number [ owner text-string ]
undo rmon statistics entry-number
View
Ethernet port view
Use the rmon statistics command to add an entry to the statistic table.
Use the undo rmon statistics command to cancel an entry from statistic table.
RMON statistic management concerns the statistics and monitoring of the usage and error on a port. Statistics includes collision, undersized or oversized packet, timeout, fragment, broadcast, multicast, unicast, and bandwidth utility.
Related commands: display rmon statistics.
# Add statistics of Ethernet 2/1/1 to the entry 20.
<H3C> system-view
[H3C]interface Ethernet 2/1/1
[H3C-Ethernet2/1/1] rmon statistic 20
