H3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
04-HA Commands
04-HA Commands 27.54 KB
Chapter 1  HA Configuration Commands
1.1  HA Configuration Commands
1.1.1  debugging ha
debugging ha { all | event | message | state }
undo debugging ha { all | event | message | state }
View
all: All HA debugging.
event: HA batch backup or smooth event debugging.
message: Debugging for messages received or sent by HA.
state: HA state machine state information debugging.
Use the debugging ha command to enable HA debugging.
Use the undo debugging ha command to disable HA debugging.
By default, HA debugging is disabled.
# Enable all the HA debugging.
<H3C> debugging ha all
1.1.2  display switchover state
display switchover state [ slot-id ]
View
slot-id: Slot number of master or slave board.
Use the display switchover state command to view the switchover state of master or slave board.
This command is used to display the switchover state of master or slave board according to the specified slot number. If slot-id is not specified, the status of SRPU will be displayed.
# Display the switchover state of master board.
<H3C> display switchover state
HA FSM State(master): Slave is absent.
1.1.3  display xbar
display xbar
View
None
Use the display xbar command to view the load mode of master and slave boards, which includes the configured system Xbar load mode and the active system Xbar load mode.
Note that the configured system Xbar load mode is not always the same as the active system Xbar load mode. Only when the slave board is in position or is started, can the system operate in the configured load mode.
# Display the load mode of the master/slave board.
<H3C> system-view
[H3C] display xbar
The configured system HA Xbar Load Mode is BALANCE
The active system HA Xbar Load Mode is SINGLE
1.1.4  slave restart
slave restart
View
None
Use the slave restart command to restart slave board.
When the slave system works abnormally, and needs to be reloaded, you can use this command to restart the slave board.
# Implement the restart of the slave system.
<H3C> slave restart
The slave will reset! Continue?[Y/N]:y
1.1.5  slave switchover
slave switchover
View
None
Use the slave switchover command to start the master-slave switchover manually.
In the environment in which the slave board is available and master in real-time backup state, the user can inform the slave board of a master-slave switchover by using a command if he expects the slave board to operate in place of the master board. After the switchover, the slave board will control the system and the original master board will be forced to reset.
# Enable master-slave switchover manually.
<H3C> slave switchover
Caution!!! Confirm the conversion of the Slave Fabric to the Master Fabric.
Continue?[Y/N]?y
Starting.....
RAM Line....OK
1.1.6  slave update configuration
View
None
Use the slave update configuration command to manually synchronize the configuration file on the master board to the slave board.
Related commands: slave auto-update config.
# Synchronize the configuration file on the master board to the slave board.
<H3C> slave update configuration
1.1.7  xbar
xbar [ load-balance | load-single ]
View
load-balance: Sets Xbar load balance mode.
load-single: Sets Xbar load single mode.
Use the xbar command to configure the load mode of the master/slave board.
By default, the master and slave boards are both in load single mode.
  Caution:
When a single SRPU is in position, the load-balance mode is not effective and the SRPU changes to the load-single mode automatically.
# Configure the system Xbar load mode.
<H3C> system-view
[H3C] xbar load-balance
