H3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
12-Configuration File Management Commands
12-Configuration File Management Commands 42.25 KB
Chapter 1  Configuration File Management Commands
1.1.1  display current-configuration
display current-configuration [ controller | interface interface-type interface-number | configuration [ configuration ] ] [ | { begin | exclude | include } regular-expression ]
View
controller: Views the configuration information of controllers.
interface: Views the configuration information of interfaces.
interface-type: Type of the interface, including Aux, Ethernet, GigabitEthernet, NULL, VLAN-interface, M-Ethernet, and Loopback.
interface-number: Number of the interface.
configuration configuration: Views the pre-positive and post-positive configuration information. The value of configuration is the keyword of the configuration, such as:
l           system: Views the host name.
l           timerange: Views the configuration information of time range.
|: Filters the configuration information to be output by regular expression.
begin: Begins with the line that matches the regular expression.
exclude: Excludes lines that match the regular expression.
include: Includes lines that match the regular expression.
regular-expression: Defines the regular expression.
Table 1-1 Special characters in the regular expression
Special characters
Restriction
_
Underscore, similar to a wildcard and can stand for these characters:
A space, the beginning of the input string, the end of the input string
If the first character in the regular expression is not an underscore, then there is no restriction on the number of underscores (but it is restricted by the command length).
If the first character in the regular expression is an underscore, then there should be less than five consecutive underscores.
If the underscores in a command are discrete, the first group of underscores are filtered for the output information, but not the subsequent underscores.
Left parenthesis, push flag in program
It is recommended not to use this character in the regular expression.
Use the display current-configuration command to display the currently effective configuration parameters of the switch.
If some running configuration parameters are the same with the default operational parameters, they will not be displayed.
After finishing a set of configurations, you can use the display current-configuration command to view the currently effective parameters, verifying whether the configurations are correct. As for some configured parameters, if the corresponding functions have not taken effect, they will not be displayed.
When there is much configuration information, you can use the regular expression to filter the output information. For specific rules about the regular expression, refer to the corresponding operation manual.
&  Note:
If there is a large amount of information, it will take a long period to filter the output information using a regular expression.
Related commands: save, reset saved-configuration, display saved-configuration.
# View the running configuration parameters of the switch.
<H3C> display current-configuration
 sysname H3C
radius scheme system
 server-type nec
 primary authentication 127.0.0.1 1645
 primary accounting 127.0.0.1 1646
 user-name-format without-domain
domain system
 radius-scheme system
 access-limit disable
 state active
 idle-cut disable
 domain default enable system
 local-server nas-ip 127.0.0.1
 router id 2.2.2.2
 stp timer hello 500
vlan 1
vlan 2
interface Vlan-interface1
interface Vlan-interface2
interface Aux0/0
interface Aux0/0/1
interface M-Ethernet0/0/0
interface Ethernet4/1/1
interface Ethernet4/1/2
interface Ethernet4/1/3
interface Ethernet4/1/4
interface Ethernet4/1/5
interface Ethernet4/1/6
interface Ethernet4/1/7
interface NULL0
ospf
 area 0.0.0.0
  network 10.1.1.0 0.0.0.255
user-interface aux 0
user-interface vty 0 4
return
# View the line containing the string 10*.1, where ”*” indicates that the character 0 in the string before it can appear multiple times or does not appear.
<H3C> display current-configuration | include 10*.1
remote-ip 10.10.0.2
  peer 10.10.0.2
 ip address 10.10.0.1 255.255.255.0
 t1 1 unframed
 t1 1 unframed
interface Serial12/1/1/1:0
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface GigabitEthernet1/1/5
interface GigabitEthernet1/1/6
interface GigabitEthernet1/1/7
interface GigabitEthernet1/1/8
interface GigabitEthernet10/1/1
interface GigabitEthernet10/1/2
interface GigabitEthernet10/1/3
interface GigabitEthernet10/1/4
  network 10.10.0.0 0.0.0.255
# View configuration information beginning with user.
<H3C> display current-configuration | include ^user
user-interface con 0
user-interface vty 0 3
user-interface vty 4
# View the pre-positive and post-positive configuration information.
<H3C> display current-configuration configuration
 sysname H3C
 server-type nec
domain system
 state active
 idle-cut disable
 router id 2.2.2.2
 stp timer hello 500
ospf
 area 0.0.0.0
return
1.1.2  display saved-configuration
View
None
Use the display saved-configuration command to view the configuration files in the flash memory or CF card of a switch.
If the switch works abnormally after being powered on, execute the display saved-configuration command to view the startup configuration of the switch.
Related commands: save, reset saved-configuration, display current-configuration.
# Display configuration files in flash memory or CF card of the switch.
<H3C> display saved-configuration
 sysname H3C
local-user abc password simple abc
 tcp window 8
interface Aux7/1/1
 link-protocol ppp
interface Ethernet2/1/1
interface Ethernet2/1/2
interface Ethernet2/1/3
 ip address 10.110.101.17 255.255.255.0
interface NULL0
ospf 1
 ip route-static 10.12.0.0 255.255.0.0 Ethernet 12/1/0
 authentication-mode none
return
From top down are the global configurations, port configurations, and user interface configurations.
1.1.3  display this
display this
View
None
Use the display this command to display the running configuration of the current view.
After finishing a set of configurations, you can use the display this command to view the currently effective parameters, verifying whether the configurations are correct.
Some effective parameters are not displayed if they are the same with the default ones. As for some configured parameters, if the corresponding functions have not taken effect, they will not be displayed. For example, if X.25 is encapsulated at the data link layer on an interface, you can configure PPP parameter on the interface, but cannot view the configuration information when executing the display this command.
Associated configuration of the interface is displayed when you execute the command in different interface views; related configuration of the protocol view is displayed when you execute this command in different protocol views; and all the configuration of the protocol view is displayed when you execute this command in protocol sub-views.
Related commands: save, reset saved-configuration, display current-configuration, display saved-configuration.
# Display the running configuration parameters in the current view.
<H3C> display this
1.1.4  display startup
display startup
View
None
Use the display startup command to display the related system software and configuration filenames used for the current and the next startups.
This command is used to display the following information: the user-configured filename of the system software for the current startup, the filename of the system software actually used for the current startup, the filename of the system software configured for the next startup, the configuration filename used for the current startup, the configuration filename configured for the next startup.
Related commands: startup saved-configuration.
# Display the filenames related to the current and the next startup.
<H3C> display startup
MainBoard:
  Startup saved-configuration file:          flash:/9500.cfg
  Next startup saved-configuration file:     flash:/9500.cfg
1.1.5  reset saved-configuration
View
None
Use the reset saved-configuration command to erase configuration files from the flash memory of the switch.
Perform this command with caution. It is suggested to consult technical support personnel first.
Generally, this command is used in the following situations:
l           After upgrade of software, configuration files in flash memory may not match the new version software. Perform the reset saved-configuration command to erase the old configuration files.
l           If a used switch is applied to the new circumstance and the original configuration files cannot meet the new requirements, the switch should be configured again. Erase the original configuration files for reconfiguration.
If the configuration files do not exist in the flash memory when the switch is powered on and initialized, default values will be used for initialization.
Related commands: save, display current-configuration, display saved-configuration.
# Erase the configuration files from the flash memory of the switch.
<H3C> reset saved-configuration
The saved configuration will be erased.
Are you sure?[Y/N]
1.1.6  save
save [ file-name ]
View
file-name: Name of the configuration file with the extension .cfg. It is a character string of 5 to 56 characters.
Use the save command to save the current configuration files to Flash memory.
After finishing a group of configurations, you should get the current configuration files stored in the flash memory.
Even if the problems like reboot and power-off occur during saving, the configuration can still be saved to Flash.
Related commands: reset saved-configuration, display current-configuration, display saved-configuration.
# Get the current configuration files stored in the flash memory.
<H3C> save
The configuration will be written to flash:/config.cfg
Are you sure?[Y/N]y
Now saving current configuration to the device.
Saving configuration flash:/config.cfg. Please wait..
Configuration is saved successfully.
1.1.7  startup saved-configuration
startup saved-configuration cfgfile
View
cfgfile: Name of the configuration file. It is a string with a length of 5 to 56 characters.
Use the startup saved-configuration command to configure the configuration file used for starting up the system for the next time.
The configuration file must have “.cfg” as its extension name and must be saved under the root directory of the Flash.
Related commands: display startup.
# Configure the configuration file for the next startup
<H3C> startup saved-configuration config.cfg
