H3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-08 System Volume
19-ACSEI Server Commands
19-ACSEI Server Commands 37.44 KB
Chapter 1  ACSEI Server Configuration Commands
1.1  ACSEI Server Configuration Commands
1.1.1  acsei client close
acsei client close client-id
View
ACSEI server view
client-id: ID of the ACSEI client to be closed, in the range 1 to 12.
Use the acsei client close command to close the specified ACSEI client.
# Close ACSEI client 5.
<H3C> system-view
[H3C] acsei server
[H3C-acsei-server] acsei client close 5
1.1.2  acsei client reboot
acsei client reboot client-id
View
ACSEI server view
client-id: ID of the ACSEI client to be restarted, in the range 1 to 12.
Use the acsei client reboot command to restart the specified ACSEI client system.
# Restart ACSEI client 5.
<H3C> system-view
[H3C] acsei server
[H3C-acsei-server] acsei client reboot 5
1.1.3  acsei server
acsei server
View
None
Use the acsei server command to enter ACSEI server view.
# Enter ACSEI server view.
<H3C> system-view
[H3C] acsei server
[H3C-acsei-server]
1.1.4  acsei server enable
acsei server enable
undo acsei server enable
View
None
Use the acsei server enable command to enable ACSEI server.
Use the undo acsei server enable command to disable ACSEI server.
By default, ACSEI server is disabled.
# Enable ACSEI server.
<H3C> system-view
[H3C] acsei server enable
1.1.5  acsei timer clock-sync
acsei timer clock-sync minutes
undo acsei timer clock-sync
View
ACSEI server view
minutes: Time interval for clock synchronization from ACSEI server to ACSEI client. It ranges from 0 to 1440 (in minutes), where value 0 specifies to disable the clock synchronization from ACSEI server to ACSEI client.
Use the acsei timer clock-sync command to set the time interval for clock synchronization from ACSEI server to ACSEI client.
Use the undo acsei timer clock-sync command to restore the default.
By default, the time interval for clock sychronization is five minutes.
# Set the time interval for clock synchronization from ACSEI server to ACSEI client to 20 minutes.
<H3C> system-view
[H3C] acsei server
[H3C-acsei-server] acsei timer clock-sync 20
1.1.6  acsei timer monitor
acsei timer monitor seconds
undo acsei timer monitor
View
ACSEI server view
seconds: Time interval for ACSEI server to monitor ACSEI clients. It ranges from 0 to 10 (in seconds), where 0 specifies to disable ACSEI server from monitoring ACSEI client.
Use the acsei timer monitor command to set the time interval for ACSEI server to monitor ACSEI client.
Use the undo acsei timer monitor command to restore the default.
By default, the time interval for ACSEI server to monitor ACSEI client is 5 seconds.
# Set the time interval for ACSEI server to monitor ACSEI client to 6 seconds.
<H3C> system-view
[H3C] acsei server
[H3C-acsei-server] acsei timer monitor 6
1.1.7  debugging acsei server
debugging acsei server { error | packet | event | all }
undo debugging acsei server { error | packet | event | all }
View
error: ACSEI error debugging.
event: ACSEI event debugging.
packet: ACSEI packet debugging.
all: All ACSEI debugging.
Use the debugging acsei server command to enable ACSEI debugging.
Use the undo debugging acsei server command to disable ACSEI debugging.
By default, ACSEI debugging is disabled.
# Enable terminal monitor and all ACSEI debuggings.
<H3C> debugging acsei server all
1.1.8  display acsei client info
display acsei client info [ client-id ]
View
client-id: ID of an ACSEI client whose information is to be displayed, in the range 1 to 12.
Use the display acsei client info command to display the ACSEI client information. The client information is retrieved from the advertisement packet sent by the client, so that when there is no ACSEI client information, the command displays the information keywords only.
If executed without the client-id argument, the command displays information about all the ACSEI clients in order of registration time.
# Display information about all ACSEI clients.
<H3C> display acsei client info
Total Client Number: 1
 Client ID: 1
 Client Description: SecBlade LB
 Hardware: A.0
 System Software: COMWAREV500R002B53D001
 Application Software: V300R002B01D002
 CPU: RMI XLR732 1000MHz
 PCB Version: A.0
 CPLD Version: 1.0
 Bootrom Version: Basic BootRom Version:1.11,Extend BootRom Version:1.17
 CF card: 0M Bytes Compact Flash Storage Device
 Memory: 1024M Bytes DDR2 SDRAM Memory
 Harddisk:
Table 1-1 display acsei client info command output description
Client ID
Client Description
ACSEI client description
Hardware
Hardware version of the ACSEI client
System Software
System software name and version of the ACSEI client
Application name and version of the ACSEI client
CPU
CPU information of the ACSEI client
PCB Version
PCB version of the ACSEI client
CPLD Version
CPLD version of the ACSEI client
Bootrom Version
Boot ROM version of the ACSEI client
CF card
CF card information of the ACSEI client
Memory
Memory information of the ACSEI client
Harddisk
Harddisk information of the ACSEI client
&  Note:
The output information may vary with ACSEI clients. If an ACSEI client does not support a field, the field is null.
1.1.9  display acsei client summary
display acsei client summary [ client-id ]
View
client-id: ID of an ACSEI client whose summary is to be displayed, in the range 1 to 12.
Use the display acsei client summary command to display ACSEI client summary information. Summary information of multiple ACSEI clients is displayed in order of registration time.
If executed without the client-id argument, the command displays summary information about all the ACSEI clients.
# Display the summary of all ACSEI clients.
<H3C> display acsei client summary
 Client ID: 1
 Status: Open
 MAC Address: 000f-e200-0006
 Interface: GigabitEthernet2/1/1
 Last registered: 07/28/2008 10:51:23
Table 1-2 display acsei client summary command output description
Client ID
Status
ACSEI client status
MAC Address
MAC address of the ACSEI client
Interface carrying the ACSEI client
Last registered
The last registration time of the ACSEI client
