H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
21-QoS Commands
21-QoS Commands 179.88 KB
Table of Contents
Chapter 1 TP and TS Configuration Commands. 1-1
1.1 TP Configuration Commands. 1-1
1.1.1 display qos car interface. 1-1
1.1.2 qos car 1-2
1.2 TS Configuration Commands. 1-3
1.2.1 display qos gts interface. 1-3
1.2.2 qos gts. 1-4
Chapter 2 QoS Policy Configuration Commands. 2-1
2.1 Commands for Defining Classes. 2-1
2.1.1 display traffic classifier 2-1
2.1.2 if-match. 2-2
2.1.3 traffic classifier 2-4
2.2 Traffic Behavior Configuration Commands. 2-5
2.2.1 accounting. 2-5
2.2.2 car 2-6
2.2.3 display traffic behavior 2-7
2.2.4 filter 2-8
2.2.5 nest 2-9
2.2.6 primap. 2-10
2.2.7 redirect 2-10
2.2.8 remark dot1p. 2-11
2.2.9 remark drop-precedence. 2-12
2.2.10 remark dscp. 2-13
2.2.11 remark ip-precedence. 2-14
2.2.12 remark local-precedence. 2-15
2.2.13 remark service-vlan-id. 2-15
2.2.14 traffic behavior 2-16
2.3 QoS Policy Configuration Commands. 2-17
2.3.1 classifier behavior 2-17
2.3.2 display qos policy user-defined. 2-17
2.3.3 display qos policy interface. 2-18
2.3.4 qos apply policy. 2-20
2.3.5 qos policy. 2-20
Chapter 3 Congestion Management Configuration Commands. 3-1
3.1 Congestion Management Configuration Commands. 3-1
3.1.1 display qos wrr interface. 3-1
3.1.2 qos wrr 3-2
Chapter 4 Priority Mapping Configuration Commands. 4-1
4.1 Priority Mapping Table Configuration Commands. 4-1
4.1.1 display qos map-table. 4-1
4.1.2 qos map-table. 4-2
4.1.3 import 4-3
4.2 Port Priority Configuration Commands. 4-3
4.2.1 qos priority. 4-3
4.3 Port Priority Trust Mode Configuration Commands. 4-4
4.3.1 display qos trust interface. 4-4
4.3.2 qos trust 4-5
Chapter 5 Congestion Avoidance Configuration Commands. 5-1
5.1 Congestion Avoidance Configuration Commands. 5-1
5.1.1 burst-traffic. 5-1
5.1.2 display burst-traffic interface. 5-2
5.1.3 display qos wred interface. 5-2
5.1.4 qos wred enable. 5-3
Chapter 6 Aggregation CAR Configuration Commands. 6-1
6.1 Aggregation CAR Configuration Commands. 6-1
6.1.1 qos car aggregative. 6-1
6.1.2 qos car 6-2
6.1.3 car name. 6-3
6.1.4 display qos car name. 6-3
6.1.5 reset qos car name. 6-4
Chapter 7 VLAN Policy Configuration Commands. 7-1
7.1 VLAN Policy Configuration Commands. 7-1
7.1.1 display qos vlan-policy. 7-1
7.1.2 qos vlan-policy. 7-2
7.1.3 reset qos vlan-policy. 7-3
Chapter 8 Traffic Mirroring Configuration Commands. 8-1
8.1 Traffic Mirroring Configuration Commands. 8-1
8.1.1 mirror-to cpu. 8-1
8.1.2 mirror-to interface. 8-1
display qos car interface [ interface-type interface-number ]
View
Parameter
interface-type: Port type.
interface-number: Port number.
Use the display qos car interface command to display the CAR (committed access rate) settings and statistics of a port.
If no ports are specified, this command displays the CAR setting and statistics of all the ports.
Example
# Display the CAR settings and statistics of Ethernet1/0/1 port.
<Sysname> display qos car interface Ethernet 1/0/1
Interface: Ethernet1/0/1
Direction: Inbound
  Rule(s): If-match acl 2001
  CIR 64 (kbps),  CBS 100000 (byte),  EBS 100000 (byte) ,  PIR 100000 (kbps)
  Red Action : discard
  Green : 0(Bytes)
Table 1-1 Description on the fields of the display qos car command
Port name, comprising of port type and port number
Direction
Direction of traffic policing (TP). As for S3610 and S5510 series Ethernet switches, TP is available to inbound packets only.
Rule(s)
Rules used for matching packets
CIR
Committed information rate (CIR), in kbps
CBS
Committed burst size (CBS), in bytes
EBS
Excess burst size (EBS), in bytes
PIR
Peak information rate (PIR), in kbps
Red Action
Action to be taken for packets when the traffic rate exceeds CIR
Green
Size of the packets (in bytes) when the traffic rate is lower than CIR
1.1.2  qos car
qos car inbound acl [ ipv6 ] acl-number cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ red action ]
undo qos car inbound acl [ ipv6 ] acl-number
View
Ethernet port view, port group view
Parameter
inbound: Limits the inbound traffic.
acl acl-number: Specifies an IPv4 ACL for  traffic rate limiting. The acl-number argument ranges from 2000 to 5999, among which:
l           A value in the range from 2000 to 2999 identifies a basic IPv4 ACL.
l           A value in the range from 3000 to 3999 identifies an advanced IPv4 ACL.
l           A value in the range from 4000 to 4999 identifies a Layer 2 ACL.
l           A value in the range from 5000 to 5999 identifies a user-defined ACL.
acl ipv6 acl-number: Specifies an IPv6 ACL for traffic rate limiting. The acl-number argument ranges from 2000 to 3999, among which:
l           A value in the range from 2000 to 2999 identifies a basic IPv6 ACL.
l           A value in the range from 3000 to 3999 identifies an advanced IPv6 ACL.
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps. The range of the committed-information-rate argument varies by port type as follows:
l           For fast Ethernet port: 4 to 100000
l           For GigabitEthernet port: 4 to 1000000
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The committed-burst-size argument ranges from 0 to 10,000,000, the default is 100,000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The excess-burst-size argument ranges from 0 to 10,000,000, the default is 100,000.
pir peak-information-rate: Specifies the peak information rate (PIR) in kbps. The range of the peak-information-rate argument varies by port type as follows:
red action: Specifies the action to be conducted when the traffic rate does not conforms to CIR.
l           discard: Drops the packets.
l           pass: Forwards the packets.
By default, packets not conforming to CIR are dropped.
Use the qos car command to apply a CAR policy to a port.
Use the undo qos car command to remove a CAR policy applied to a port.
You can execute the qos car command repeatedly to apply multiple CAR policies to a port. The policies applied to a port are invoked in the order they are applied.
Example
# Perform TP for inbound traffic matching ACL 2001 on Ethernet1/0/1 port. When the traffic rate is lower than 200 kbps, packets are forwarded normally; when the traffic rate exceeds 200 kbps, the extra packets are dropped.
[Sysname-Ethernet1/0/1] qos car inbound acl 2001 cir 200 red discard
View
Parameter
Use the display qos gts interface command to display the general TS configuration of a port.
If no port is specified, this command displays the general TS configuration of all the ports.
Example
# Display the general TS configuration of Ethernet 1/0/1 port.
<Sysname> display qos gts interface Ethernet 1/0/1
 Rule(s): If-match queue  0
 CIR 650 (kbps)
Table 1-2 Description on the fields of the display qos gts interface command
Rule(s)
Matching rules
l      any indicates that TS is performed for all the queues
l      queue indicates that TS is performed for the specific queue
CIR
Committed information rate (CIR) in kbps
1.2.2  qos gts
qos gts { any | queue queue-number } cir committed-information-rate
undo qos gts { any | queue queue-number }
View
Parameter
any: Performs traffic shaping (TS) for all the packets.
queue queue-number: Performs TS for packets in the queue identified by the queue-number argument, in the range of 0 to 7.
cir committed-information-rate: Specifies the committed information rate (CIR). The range of the committed-information-rate argument varies by port type as follows:
l           For fast Ethernet port: 650 to 100000
l           For GigabitEthernet port: 65 to 1000000
Note that the argument must be a multiple of 650.
Use the qos gts command to set TS parameters and enable TS for a specific type of traffic or all types of traffic.
Use the undo qos gts command to remove TS parameters for a specific type traffic or all types of traffic. .
By default, no TS parameters are configured for a port.
Example
#  Perform TS for all the packets on Ethernet1/0/1 port. Packets with the rate lower than 650 kbps are forwarded normally. Those with the rate exceeding 650 kbps are dropped.
[Sysname-Ethernet1/0/1] qos gts any cir 650
display traffic classifier user-defined [ classifier-name ]
View
classifier-name: Class name.
Use the display traffic classifier command to display the information about a class.
If no class name is provided, this command displays the information about all the user-defined classes.
# Display the information about all the user-defined classes.
  User Defined Classifier Information:
   Classifier: p
    Operator: AND
    Rule(s) : If-match acl 2001
Table 2-1 Description on the fields of the display traffic classifier user-defined command
The information about the user-defined classes is displayed.
Classifier
Class name and its contents, which could be of multiple types
Operator
Logical relationship among the classification rules
Rule
Classification rules
2.1.2  if-match
if-match match-criteria
undo if-match match-criteria
View
Class view
match-criteria: Matching rule to be defined. Table 2-2 describes the available forms of this argument.
Table 2-2 The forms of the match-criteria argument
acl access-list-number
Specifies an ACL to match packets. The access-list-number argument is in the range 2000 to 5999.
Note that, for a class with the relationship between the classification rules in it set to logical and, a packet matches the class if it matches a rule in the ACL.
acl ipv6 access-list-number
Specifies an IPv6 ACL to match IPv6 packets. The access-list-number argument is in the range 2000 to 3999.
any
Specifies to match all packets.
dscp dscp-list
Specifies to match packets by DSCP precedence. The dscp-list argument is a list of DSCP values. You can provide up to eight space-separated DSCP values for this argument. DSCP is in the range 0 to 63.
destination-mac mac-address
Specifies to match the packets with a specified destination MAC address.
dot1p 8021p
Specifies to match packets by 802.1p priority. The 8021p argument is a list of COS values. You can provide up to eight space-separated COS values for this argument. COS is in the range 0 to 7.
ip-precedence ip-precedence-list
Specifies to match packets by IP precedence. The ip-precedence-list argument is a list of IP precedence values. You can provide up to eight space-separated IP precedence values for this argument. IP precedence is in the range 0 to 7.
protocol protocol-name
Specifies to match the packets of a specified protocol. The protocol-name argument can be IP, IPv6 or Bittorrent.
The S3610 and S5510 series Ethernet switches do not support the Bittorrent protocol currently.
source-mac mac-address
Specifies to match the packets with a specified source MAC address.
customer-vlan-id vlan-id-list
Specifies to match the packets of specified VLANs of user networks. The vlan-id-list argument specifies a list of VLAN IDs, in the form of vlan-id to vlan-id or multiple discontinuous VLAN IDs (separated by space). You can specify up to eight VLAN IDs for this argument at a time. VLAN ID is in the range 1 to 4094.
service-vlan-id vlan-id-list
Specifies to match the packets of specified VLANs of the operator’s network. The vlan-id-list argument is a list of VLAN IDs, in the form of vlan-id to vlan-id or multiple discontinuous VLAN IDs (separated by space). You can specify up to eight VLAN IDs for this argument at a time. VLAN ID is in the range 1 to 4094.
Use the if-match command to define a rule to match a specific type of packets.
Use the undo if-match command to remove a matching rule.
# Define a rule for class1 to match the packets with their destination MAC addresses being 0050-ba27-bed3.
# Define a rule for class2 to match the packets with their source MAC addresses being 0050-ba27-bed2.
# Define a rule for class1 to match the advanced IPv4 ACL 3101.
# Define a rule for class1 to match the advanced IPv6 ACL 3101.
# Define a rule for class1 to match all the packets.
# Define a rule for class1 to match the packets with their DSCP precedence values being 1.
[Sysname-classifier-class1] if-match dscp 1
# Define a rule for class1 to match the packets with their IP precedence values being 1.
[Sysname-classifier-class1] if-match ip-precedence 1
# Define a rule for class1 to match IP packets.
# Define a rule for class1 to match the packets with their 802.1p priority values being 2.
[Sysname-classifier-class1] if-match dot1p 2
# Define a rule for class1 to match the packets of VLAN 1024 of the user networks.
[Sysname-classifier-class1] if-match customer-vlan-id 1024
# Define a rule for class1 to match the packets of VLAN 1000 of the operator’s network.
[Sysname-classifier-class1] if-match service-vlan-id 1000
View
and: Specifies the relationship among the rules in the class as logic AND. That is, a packet is matched only when it matches all the rules defined for the class.
or: Specifies the relationship among the rules in the class as logic OR. That is, a packet is matched if it matches a rule defined for the class.
classifier-name: Name of the class to be created.
Use the traffic classifier command to create a class. This command also leads you to class view.
Use the undo traffic classifier command to remove a class.
By default, a packet is matched only when it matches all the rules configured for the class.
# Create a class named class1.
2.2.1  accounting
accounting
undo accounting
View
Traffic behavior view
None
Use the accounting command to configure the traffic accounting action for a traffic behavior.
Use the undo accounting command to remove the traffic accounting action.
Related commands: qos policy, traffic behavior, classifier behavior.
Note that, the traffic accounting action and the aggregation CAR action cannot be configured at the same time in a traffic behavior. Otherwise, the policy cannot be successfully applied.
# Configure the traffic accounting action for a traffic behavior.
[Sysname-behavior-database] accounting
2.2.2  car
car { cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ red action ] | name global-car-name }
undo car
View
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps. The committed-information-rate argument ranges from 4 to 1,000,000.
ebs excess-burst-size: Specifies excess burst size (EBS) in bytes. The excess-burst-size argument ranges from 0 to 10,000,000, the default is 100,000.
pir peak-information-rate: Specifies the peak information rate (PIR) in kbps. The peak-information-rate argument ranges from 4 to 1,000,000.
name global-car-name: Specifies the name of the aggregation CAR.
Use the car command to configure TP action for a traffic behavior.
Use the undo car command to remove the TP action.
Note that:
l           If you configure the qos car command and a QoS policy configured with the car command for the same class of packets, the qos car command does not take effect.
l           If you execute the car command multiple times in traffic behavior view, the last configuration overrides the previous ones.
l           The traffic accounting action and the aggregation CAR action cannot be configured at the same time in a traffic behavior. Otherwise, the policy cannot be successfully applied.
# Configure TP action for a traffic behavior. When the traffic rate is lower than 200 kbps, packets are forwarded normally. When the traffic rate exceeds 200 kbps, the packets beyond 200 kbps are dropped.
[Sysname-behavior-database] car cir 200 red discard
display traffic behavior user-defined [ behavior-name ]
View
behavior-name: Name of a user defined traffic behavior.
Use the display traffic behavior command to display the information about a user defined traffic behavior.
If no behavior name is provided, this command displays the information about all the user-defined behaviors.
# Display the information about all the user defined traffic behaviors.
  User Defined Behavior Information:
    Behavior: test
      Marking:
        Remark dot1p COS 4
      Committed Access Rate:
        CIR 1000 (kbps) , CBS 100000 (byte), EBS 100000 (byte), PIR 1000 (kbps)
        Red Action: discard
Table 2-3 Description on the fields of the display traffic behavior user-defined command
The information about user defined traffic behaviors is displayed
Behavior
Name of a traffic behavior, which can be of multiple types
Marking
Information about priority marking
Information about traffic rate limit
CIR
Committed information rate in bytes
CBS
Committed burst size in bytes
EBS
Excessive burst size in bytes
PIR
Peak information rate in bytes
Red Action
Action conducted to packets not conforming to CIR
2.2.4  filter
filter { deny | permit }
undo filter
View
deny: Drops packets.
permit: Forwards packets.
Use the filter command to configure traffic filtering action for a traffic behavior.
Use the undo filter command to remove the traffic filtering action.
Note that the filter deny command cannot be configured with any other action at the same time in a traffic behavior. Otherwise, the policy cannot be successfully applied.
# Configure traffic filtering action for a traffic behavior.
2.2.5  nest
nest top-most vlan-id vlan-id
undo nest
View
vlan-id vlan-id: ID of the VLAN. The vlan-id argument is in the range 1 to 4094.
Use the nest command to configure the action of creating an external VLAN tag for a traffic behavior.
Use the undo nest command to remove the action of creating an external VLAN tag.
Note that, the nest command, the redirect next-hop command, and the remark service-vlan-id command cannot be configured at the same time in a traffic behavior. Otherwise, the policy cannot be successfully applied.
# Configure the action of creating an external VLAN tag for a traffic behavior.
[Sysname-behavior-database] nest top-most vlan-id 100
2.2.6  primap
primap pre-defined { dscp-lp | dscp-dp | dscp-dot1p | dscp-dscp }
undo primap pre-defined { dscp-lp | dscp-dp | dscp-dot1p | dscp-dscp }
View
Parameter
pre-defined: Specifies a pre-defined priority mapping table.
dscp-lp: Specifies the DSCP-to-local precedence mapping table.
dscp-dp: Specifies the DSCP-to-drop precedence mapping table.
dscp-dot1p: Specifies the DSCP-to-802.1p priority mapping table.
dscp-dscp: Specifies the DSCP-to-DSCP mapping table.
Use the primap command to configure the action of getting other precedence for packets by looking up a priority mapping table.
Use the primap command to remove the action.
Note that, the priority mapping action cannot be configured with any priority marking action except the DSCP precedence marking action at the same time in a traffic behavior. Otherwise, the policy cannot be successfully applied.
Related command: display qos map-table.
Example
# Define the DSCP-precedence-to-drop-precedence mapping action for the traffic behavior behavior1.
[Sysname-behavior-behavior1] primap pre-defined dscp-dp
2.2.7  redirect
redirect { cpu | interface interface-type interface-number | next-hop { ipv4-add [ ipv4-add ] | ipv6-add [ interface-type interface-number ] [ ipv6-add [ interface-type interface-number ] ] } }
undo redirect
View
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface identified by its type and number.
next-hop: Specifies the next hop to redirect the traffic to.
ipv4-add: IPv4 address of the next hop.
ipv6-add: IPv6 address of the next hop. The interface-type interface-number argument is a VLAN interface number. If the IPv6 address is a link-local address, you must specify a VLAN interface for the IPv6 address of the next hop; if the IPv6 address is not a link-local address, you need not specify a VLAN interface for the IPv6 address of the next hop.
Use the redirect command to configure traffic redirecting action for a traffic behavior.
Use the undo redirect command to remove the traffic redirecting action.
Note that, the redirect next-hop command, the remark service-vlan-id command, and the nest command cannot be configured at the same time in a traffic behavior. Otherwise, the policy cannot be successfully applied.
# Configure the redirecting action to redirect traffic to Ethernet1/0/1 port.
[Sysname-behavior-database] redirect interface Ethernet 1/0/1
2.2.8  remark dot1p
remark dot1p 8021p
undo remark dot1p
View
8021p: 802.1p priority to be set for packets, in the range 0 to 7.
Use the remark dot1p command to configure the action of setting 802.1p priority for a traffic behavior.
Use the undo remark dot1p command to remove the action of setting 802.1p priority.
# Configure the action to set 802.1p priority to 2 for a traffic behavior.
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence drop-precedence-value
undo remark drop-precedence
View
drop-precedence-value: Drop precedence to be set for packets, in the range 0 to 2.
Use the remark drop-precedence command to configure the action of setting drop precedence for a traffic behavior.
Use the undo remark drop-precedence command to remove the action of setting drop precedence.
# Configure the action to set drop precedence to 2 for a traffic behavior.
[Sysname-behavior-database] remark drop-precedence 2
2.2.10  remark dscp
remark dscp dscp-value
undo remark dscp
View
dscp-value: DSCP precedence to be set for packets, in the range of 0 to 63. This argument can also be the keywords listed in Table 2-4.
Table 2-4 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
Use the remark dscp command to configure the action of setting DSCP precedence for a traffic behavior.
Use the undo remark dscp command to remove the action of setting DSCP precedence.
# Configure the action to set DSCP precedence to 6 for a traffic behavior.
remark ip-precedence ip-precedence-value
undo remark ip-precedence
View
ip-precedence-value: IP precedence to be set for packets, in the range of 0 to 7.
Use the remark ip-precedence command to configure the action of setting IP precedence for a traffic behavior.
Use the undo remark ip-precedence command to remove the action of setting IP precedence.
# Configure the action to set IP precedence to 6 for a traffic behavior.
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence local-precedence
undo remark local-precedence
View
local-precedence: Local precedence to be set for packets, in the range of 0 to 7.
Use the remark local-precedence command to configure the action of setting local precedence for a traffic behavior.
Use the undo remark local-precedence command to remove the action of remarking local precedence.
# Configure the action to set local precedence to 2 for a traffic behavior.
remark service-vlan-id vlan-id-value
undo remark service-vlan-id
View
vlan-id-value: VLAN ID to be set for packets, in the range of 1 to 4094.
Use the remark service-vlan-id command to configure the action of setting the service provider network VLAN ID for a traffic behavior.
Use the undo remark service-vlan-id command to remove the action of setting the service provider network VLAN ID.
Note that, the remark service-vlan-id command, the redirect next-hop command, and the nest command cannot be configured at the same time in a traffic behavior. Otherwise, the policy cannot be successfully applied.
# Configure the action of setting the service provider network VLAN ID to 2 for a traffic behavior.
[Sysname-behavior-database] remark service-vlan-id 2
View
behavior-name: Name of the traffic behavior to be created.
Use the traffic behavior command to create a traffic behavior. This command also leads you to traffic behavior view.
Use the undo traffic classifier command to remove a traffic behavior.
Related commands: qos policy, qos apply policy, classifier behavior.
# Define a traffic behavior named behavior1.
classifier classifier-name behavior behavior-name
View
Policy view
classifier-name: Name of an existing class.
behavior–name: Name of an existing traffic behavior.
Use the classifier behavior command to associate a traffic behavior with a class.
Use the undo classifier command to remove a class from a policy.
Note that each class can be associated with only one traffic behavior.
Related commands: qos policy.
# Associate the behavior named test with the class named database in the policy user1.
[Sysname] qos policy user1
display qos policy user-defined [ policy-name [ classifier classifier-name ] ]
View
policy-name: Policy name. If it is not provided, the configuration of all the user defined policies is displayed.
classifier-name: Name of a class in the policy. If it is not provided, all the classes in the policy are specified.
Use the display qos policy command to display the configuration of a specified policy, including the configuration of the classes and the associated traffic behaviors in the policy.
# Display the configuration of all the user specified policies.
  User Defined QoS Policy Information:
  Policy: test
   Classifier: test
     Behavior: test
      Marking:
        Remark dot1p COS 4
        CIR 1000 (kbps), CBS 100000 (byte), EBS 100000 (byte), PIR 1000 (kbps)
        Red Action: discard
      Filter enable : permit
      Redirect enable:
        Redirect type: next-hop
        Redirect destination: 1:1::1 2:2::2
Table 2-5 Description on the fields of the display qos policy command
Policy
Policy name
Classifier
Class name and the corresponding configuration information
Behavior
Traffic behavior name and the corresponding configuration information
display qos policy interface [ interface-type interface-number ] [ inbound ]
View
inbound: Specifies the inbound direction.
Use the display qos policy interface command to display the configuration and statistics information about the policy applied on a port.
If no interface is provided, the configuration and statistics information about the policies applied on all the ports is displayed.
# Display the configuration and statistics information about the policy applied on Ethernet1/0/1 port.
<Sysname> display qos policy interface Ethernet 1/0/1
  Direction: Inbound
  Policy: test1
   Classifier: test1 (Failed)
     Operator: AND
     Rule(s) : If-match acl 2000
     Behavior: test1
      Filter Enable: deny
Table 2-6 Description on the fields of the display qos policy interface command
Direction
Direction of the port where the policy is applied (For S3610 and S5510 series Ethernet switches, a QoS policy can only be used in the inbound direction of a port.)
Policy
Name of the policy applied to the port
Classifier
Name of the class in the policy and its configuration
Failed indicates that the policy is not successfully applied
Operator
Logical relationship among the classification rules in a class
Rule(s)
Classification rules in the class
Behavior
Name of the behavior in the policy and its configuration
qos apply policy policy-name  inbound
undo qos apply policy inbound
View
policy-name: Specifies the policy name.
Use the qos apply policy command to apply a policy on a port or a port group.
Use the undo qos apply policy command to remove the policy applied on a port or a port group.
# Apply the policy named test in the inbound direction of Ethernet1/0/1 port.
[Sysname-Ethernet1/0/1] qos apply policy test inbound
2.3.5  qos policy
qos policy policy-name
undo qos policy policy-name
View
policy-name: Name of the policy to be created.
Use the qos policy command to create a policy. This command also leads you to policy view.
Use the undo qos policy command to remove a policy.
To remove a policy that is currently applied on a port, you need to disable it on the port first.
Related commands: classifier behavior, qos apply policy.
# Create a policy named user1.
display qos wrr interface [ interface-type interface-number ]
View
Parameter
Use the display qos wrr interface command to display the weighted round robin (WRR) queue information about a port.
If no ports are specified, this command displays the WRR information about all the ports.
Related command: qos wrr.
Example
# Display the WRR information about Ethernet1/0/1 port.
<Sysname> display qos wrr interface Ethernet 1/0/1
Output queue:   Weighted round robin queue
Queue ID    Group    Weight
   0         sp       N/A
   1         sp       N/A
   2         1        10
   3         1        30
   4         1        70
   5         2        20
   6         2        50
   7         2        100
Table 3-1 Description on the fields of the display qos wrr interface command
Output queue
Type of the current output queues
Queue ID
Queue number
Group
ID of the group which a queue belongs to
Weight
Queue weight
N/A indicates that the queue adopts the SP queue scheduling algorithm
3.1.2  qos wrr
qos wrr queue-id group { group-id weight queue-weight | sp }
undo qos wrr
View
Parameter
queue-id: Output queue ID, in the range of 0 to 7.
group group-id: Specifies a WRR priority group. The group-id argument can be 1 or 2. The WRR priority groups are scheduled by priority.
weight queue-weight: Specifies weight for the queue. The queue-weight argument is in the range 8 to 100.
sp: Specifies the SP queue scheduling algorithm.
Use the qos wrr command to configure the WRR or SP + WRR queue scheduling algorithm for a port or port group.
Use the undo qos wrr command to restore the default.
By default, all the output queues of a port are scheduled using the strict priority (SP) algorithm.
A port on an S3610 and S5510 switch supports eight output queues. Different queues can adopt different queue scheduling algorithms. As required, you can configure part of the queues on a port to adopt the SP queue scheduling algorithm and part of the queues to adopt the WRR queue scheduling algorithm. The SP+WRR queue scheduling algorithm is implemented by adding queues on a port to SP scheduling queues and WRR queue scheduling queues respectively. For example, queue 0 and queue 1 are in the SP queue scheduling group, and queue 2, queue 3, and queue 4 are in the WRR queue scheduling group 1, queue 5, queue 6, and queue 7 are in WRR queue scheduling group 2. Round robin is performed in WRR group 2 firstly. If no packet is to be sent in WRR group 2, round robin is performed in WRR group 1. At last, packets in the SP queue scheduling group are processed.
  Caution:
With WRR or SP + WRR queue scheduling algorithm adopted, the queues assigned to the same queue scheduling group must be with consecutive queue numbers.
Example
# Enable the SP+WRR queue scheduling algorithm on Ethernet1/0/1. Add queue 0 and queue 1 to the SP queue scheduling group; add queue 2, queue 3, and queue 4 to WRR queue scheduling group 1, with the weight being 20, 70, and 100 respectively; add queue 5, queue 6, and queue 7 to WRR queue scheduling group 2, with the weight being 10, 50, and 80 respectively.
[Sysname-Ethernet1/0/1] qos wrr 0 group sp
[Sysname-Ethernet1/0/1] qos wrr 1 group sp
[Sysname-Ethernet1/0/1] qos wrr 2 group 1 weight 20
[Sysname-Ethernet1/0/1] qos wrr 3 group 1 weight 70
[Sysname-Ethernet1/0/1] qos wrr 4 group 1 weight 100
[Sysname-Ethernet1/0/1] qos wrr 5 group 2 weight 10
[Sysname-Ethernet1/0/1] qos wrr 6 group 2 weight 50
[Sysname-Ethernet1/0/1] qos wrr 7 group 2 weight 80
display qos map-table [ dot1p-lp | dot1p-dp | dscp-lp | dscp-dp | dscp-dot1p | dscp-dscp ]
View
dot1p-lp: Specifies the 802.1p priority-to-local precedence mapping table.
dot1p-dp: Specifies the 802.1p priority-to-drop precedence mapping table.
Use the display qos map-table command to display the configuration of a priority mapping table.
If the type of the priority mapping table is not specified, the configuration of all the priority mapping tables is displayed.
Related commands: qos map-table.
# Display the configuration of the 802.1p priority-to-drop precedence mapping table.
<Sysname> display qos map-table dot1p-dp
MAP-TABLE NAME: dot1p-dp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    2
   2    :    2
   3    :    1
   4    :    1
   5    :    1
   6    :    0
   7    :    0
Table 4-1 Description on the fields of the display qos map-table command
MAP-TABLE NAME
Name of the mapping table
TYPE
Type of the mapping table
IMPORT
Input entries of the mapping table
EXPORT
Output entries of the mapping table
4.1.2  qos map-table
qos map-table { dot1p-lp | dot1p-dp | dscp-lp | dscp-dp | dscp-dot1p | dscp-dscp }
View
dscp-dot1p: Specifies the DSCP-to-802.1p-priority mapping table.
Use the qos map-table command to enter specific priority mapping table view.
Related commands: display qos map-table.
# Enter 802.1p priority-to-drop precedence mapping table view.
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp]
4.1.3  import
View
Priority mapping table view
import-value-list: List of input parameters.
export-value: Output parameter in the mapping table.
all: Removes all the parameters in the priority mapping table.
Use the import command to configure entries for a priority mapping table, that is, to define one or more mapping rules.
Use the undo import command to restore specific entries of a priority mapping table to the default.
# Configure the 802.1p priority-to-drop precedence mapping table to map 802.1p priority 4 and 5 to drop precedence 1.
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
4.2.1  qos priority
qos priority priority-value
undo qos priority
View
priority-value: Port priority to be configured. This argument is in the range 0 to 7.
Use the qos priority command to set the port priority for a port.
Use the undo qos priority command to restore the default port priority.
By default, the port priority is 0.
# Set the port priority of Ethernet1/0/1 port to 2.
[Sysname-Ethernet1/0/1] qos priority 2
View
Use the display qos trust interface command to display the port priority trust mode of a port.
If no port is specified, this command displays the port priority trust modes of all the ports.
# Display the port priority trust mode of Ethernet1/0/1 port.
<Sysname> display qos trust interface Ethernet 1/0/1
Port priority information
Port priority :0
Port priority trust type : dot1p
Table 4-2 Description on the fields of the display qos trust interface command
Port priority
Port priority
Port priority trust mode
l      dot1p indicates that the 802.1p priority of the received packets is trusted
l      untrust indicates that the port priority is trusted
4.3.2  qos trust
qos trust dot1p
undo qos trust
View
dot1p: Specifies to trust 802.1p priority carried in the packet and adopt this priority for priority mapping.
Use the qos trust command to configure the port priority trust mode.
Use the undo qos trust command to restore the default port priority trust mode.
By default, The priory mode set on the port is trusted.
# Specify to trust 802.1p priority carried in the packets on Ethernet1/0/1 port.
[Sysname-Ethernet1/0/1] qos trust dot1p
5.1.1  burst-traffic
burst-traffic { queue queue-id length queue-length }&<1-8>
undo burst-traffic [ queue queue-id ]&<1-8>
View
queue queue-id: Specifies a queue ID, in the range 0 to 7.
length queue-length: Specifies the queue length, in the range of 1 to 256.
Use the burst-traffic command to set the queue length on the port or port group to adjust the capability of processing burst traffic.
Use the undo burst-traffic command to restore the default.
By default, the default queue length on a port varies by port type as follows:
l           For fast Ethernet port, the length of queue 0 is 4, and the length of the other queues is 1.
l           For GigabitEthernet port, the queue length is 6.
Although increasing queue length improves the ability to process burst traffic, it reduces the ability of congestion avoidance.
Related commands: display burst-traffic interface.
# Set the length of queue 1 and queue 3 to 8 and 32 on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] burst-traffic queue 1 length 8 queue 3 length 32
display burst-traffic interface [ interface-type interface-number ]
View
interface-type interface-number: Port type and port number.
Use the display burst-traffic interface command to display the queue length configuration of a port.
If no port is specified, this command displays the queue length configuration of all the ports.
# Display the queue length configuration information of Ethernet 1/0/1.
<Sysname> display burst-traffic interface Ethernet 1/0/1
Interface e1/0/1
 Queue 0: 4      Queue 1: 8      Queue 2: 1
 Queue 3: 32     Queue 4: 1      Queue 5: 1
 Queue 6: 1      Queue 7: 1
View
Parameter
Use the display qos wred interface command to display the configuration about WRED on the specified ports.
If no port is specified when this command is executed, the configuration about WRED on all the ports is displayed.
Example
# Display the configuration information about WRED on Ethernet1/0/1.
<Sysname> display qos wred interface Ethernet 1/0/1
 Current WRED configuration:
 WRED: Enable
qos wred enable
undo qos wred enable
View
Parameter
None
Use the qos wred enable command to enable the WRED function on the port or port group.
Use the undo qos wred enable command to restore the packet drop mode to the default tail drop mode and disable the WRED function.
By default, the tail drop mode is adopted on the port.
Related command: display qos wred interface.
Example
# Enable the WRED function on Ethernet1/0/1.
[Sysname-Ethernet1/0/1] qos wred enable
qos car global-car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ red action ]
undo qos car global-car-name
View
Parameter
global-car-name: Name of an aggregation CAR.
aggregative: Indicates that CAR is aggregated globally. Only aggregation CAR is supported currently.
Use the qos car aggregative command to configure an aggregation CAR.
Use the undo qos car command to cancel the aggregation CAR configuration.
An aggregation CAR does not take effect until it is applied to a port or referenced in a policy.
Example
# Specify the aggregation CAR to adopt the following CAR parameters: CIR is 100, and red packets are dropped.
[Sysname] qos car test aggregative cir 100 red discard
6.1.2  qos car
qos car inbound acl [ ipv6 ] acl-number name global-car-name
View
Parameter
inbound: Specifies to limit the rate of the packets received on the port.
name global-car-name: Specifies the name of an aggregation CAR.
Use the qos car name command to apply the aggregation CAR on the port.
Use the undo qos car command to remove the aggregation CAR from the port.
This command can be executed repeatedly on a port to apply multiple aggregation CAR policies to the port. CAR actions are performed on the packets according to the sequence that they are configured.
Example
# Apply the aggregation CAR named aggcar-1 to the packets matching IPv4 ACL 2001 on Ethernet1/0/1.
[Sysname-Ethernet1/0/1] qos car inbound acl 2001 name aggcar-1
6.1.3  car name
car name global-car-name
undo car
View
Parameter
Use the car name command to configure the aggregation CAR action for the traffic behavior.
Use the undo car command to remove the aggregation CAR action for the traffic behavior.
Example
# Configure the aggregation CAR named aggcar-1 for the traffic behavior named be1.
display qos car name global-car-name
View
Parameter
Use the display qos car name command to display the configuration information and statistics information about the specified aggregation CAR.
Example
# Display the configuration information of the aggregation CAR named aggcar-1.
<Sysname> display qos car name aggcar-1
  Mode: aggregative
  CIR 100(kbps)  CBS: 100000(byte)  EBS: 100000(byte)
  Red Action: discard
  Green packet 0(Bytes)
Table 6-1 Description on the fields of the display qos car name command
Name
Name of the aggregation CAR action
Mode
Type of the aggregation CAR action
CIR
CBS
EBS
Red Action
reset qos car name [ global-car-name ]
View
Parameter
Use the reset qos car name command to clear the statistics information about the specified aggregation CAR.
If the global-car-name argument is not specified, this command will clear the statistics information about all aggregation CAR policies.
Example
# Clear the statistics information about the aggregation CAR named aggcar-1.
<Sysname> reset qos car name aggcar-1
display qos vlan-policy { name policy-name | vlan [ vlan-id ] }
View
name policy-name: Specifies to display the information about the VLAN policy with the specified name.
vlan vlan-id: Specifies to display the information about the VLAN policy applied to the specified VLAN.
Use the display qos vlan-policy name command to display the information about VLAN policies.
If the vlan-id argument is not specified, the information about all the VLAN policies will be displayed.
# Display the information about the VLAN policy named test.
<Sysname> display qos vlan-policy name test
  Policy test
    Vlan 300: inbound
Table 7-1 Description on the fields of the display qos vlan-policy command
Policy
Name of the VLAN policy
Vlan 300
ID of the VLAN where the VLAN policy is applied
inbound
VLAN policy is applied in the inbound direction of the VLAN.
# Display the information about the VLAN policy applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
  Vlan 2
  Direction: Inbound
  Policy: 1
   Classifier: 2
     Operator: AND
     Behavior: 2
      Accounting Enable
        0 (Packets)
        CIR 128 (kbps), CBS 8000 (byte), EBS 0 (byte)
        Red Action: discard
        Green : 0(Bytes)
Table 7-2 Description on the fields of the display qos vlan-policy command
Vlan 2
Inbound
Classifier
Behavior
qos vlan-policy policy-name vlan vlan-id-list inbound
undo qos vlan-policy vlan vlan-id-list inbound
View
vlan-id-list: List of VLAN IDs, presented in the form of vlan-id to vlan-id or discontinuous VLAN IDs. Up to eight VLAN IDs can be specified at a time.
inbound: Specifies to apply the VLAN policy in the inbound direction of the VLAN.
Use the qos vlan-policy command to apply the VLAN policy to the specific VLAN(s).
Use the undo qos vlan-policy command to remove the VLAN policy from the specific VLAN(s).
&  Note:
The QoS policy applied to a port overrides the QoS policy applied to the VLAN the port belongs to.
# Apply the VLAN policy named test in the inbound direction of VLAN 200, VLAN 300, VLAN 400, VLAN 500, VLAN 600, VLAN 700, VLAN 800, and VLAN 900.
[Sysname] qos vlan-policy test vlan 200 300 400 500 600 700 800 900 inbound
reset qos vlan-policy [ vlan vlan-id ]
View
vlan-id: VLAN ID, in the range 1 to 4,094.
Use the reset qos vlan-policy command to clear the statistics information about VLAN policies.
# Clear the statistics information about the VLAN policy applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
8.1.1  mirror-to cpu
mirror-to cpu
undo mirror-to cpu
View
cpu: Mirrors traffic to the CPU.
Use the mirror-to cpu command to configure the action of mirroring traffic to the CPU for the traffic behavior.
Use the undo mirror-to cpu command to remove the action.
By default, the action of mirroring traffic to the CPU is not configured for a traffic behavior.
In a traffic behavior, the action of mirroring traffic to an interface, and the action of mirroring traffic to the CPU are mutually exclusive. Therefore, you can configure only one of them for a traffic behavior.
# Configure the action of mirroring traffic to the CPU for the traffic behavior 1.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to interface interface-type interface-number
undo mirror-to interface interface interface-type interface-number
View
interface interface-type interface-number: Port type and port number of the destination port for the traffic mirroring action.
Use the mirror-to interface command to configure the action of mirroring traffic to the specified port for a traffic behavior.
Use the undo mirror-to interface command to remove the traffic mirroring action.
  Caution:
l      A member port in a port aggregation group cannot function as the destination port for traffic mirroring.
l      If the destination port for traffic mirroring is not the same port as the destination port of the local port mirroring group, you cannot configure the two ports at the same time. For the detailed information about local port mirroring groups, refer to the Port Mirroring module in this manual.
# Configure traffic behavior 1 and define the action of mirroring traffic to Ethernet1/0/2 in the traffic behavior.
[Sysname-behavior-1] mirror-to interface Ethernet 1/0/2
