H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
09-MSTP Commands
09-MSTP Commands 200.6 KB
Table of Contents
Chapter 1 MSTP Configuration Commands. 1-1
1.1 MSTP Configuration Commands. 1-1
1.1.1 active region-configuration. 1-1
1.1.2 check region-configuration. 1-1
1.1.3 display stp. 1-3
1.1.4 display stp abnormal-port 1-5
1.1.5 display stp abnormal-port 1-6
1.1.6 display stp down-port 1-7
1.1.7 display stp history. 1-8
1.1.8 display stp region-configuration. 1-9
1.1.9 display stp root 1-10
1.1.10 display stp tc. 1-11
1.1.11 instance. 1-12
1.1.12 region-name. 1-13
1.1.13 reset stp. 1-13
1.1.14 revision-level 1-14
1.1.15 stp. 1-15
1.1.16 stp bpdu-protection. 1-16
1.1.17 stp bpdu-tagged. 1-17
1.1.18 stp bpdu-tagged cist-ignored. 1-17
1.1.19 stp bpdu-transparent-forwarding. 1-18
1.1.20 stp bpdu-transparent-forwarding vlan. 1-18
1.1.21 stp bridge-diameter 1-19
1.1.22 stp compliance. 1-20
1.1.23 stp config-digest-snooping. 1-21
1.1.24 stp cost 1-22
1.1.25 stp edged-port 1-23
1.1.26 stp ignored vlan. 1-24
1.1.27 stp loop-protection. 1-25
1.1.28 stp max-hops. 1-25
1.1.29 stp mcheck. 1-26
1.1.30 stp mode. 1-27
1.1.31 stp no-agreement-check. 1-28
1.1.32 stp pathcost-standard. 1-28
1.1.33 stp point-to-point 1-30
1.1.34 stp port-log. 1-31
1.1.35 stp port priority. 1-32
1.1.36 stp priority. 1-33
1.1.37 stp region-configuration. 1-34
1.1.38 stp root primary. 1-34
1.1.39 stp root secondary. 1-36
1.1.40 stp root-protection. 1-37
1.1.41 stp tc-protection. 1-38
1.1.42 stp tc-protection threshold. 1-38
1.1.43 stp timer forward-delay. 1-39
1.1.44 stp timer hello. 1-40
1.1.45 stp timer max-age. 1-41
1.1.46 stp timer-factor 1-42
1.1.47 stp transmit-limit 1-43
1.1.48 vlan-mapping modulo. 1-44
View
MST region view
None
Use the active region-configuration command to activate your MST region configuration.
When you carry out this command, MSTP will replace the currently running MST region–related parameters with the parameters you have just configured, and will perform spanning tree calculation again.
Related commands: instance, region-name, revision-level, vlan-mapping modulo, check region-configuration.
# Activate MST region configuration manually.
View
MST region view
None
Use the check region-configuration command to view all the configuration information of the MST region, including the region name, VLAN-to-instance mapping and revision level settings.
Be sure that your MST region configurations are correct, especially the VLAN-to-instance mapping table. MSTP-compliant devices are in the same MST region only when they have the same region name, the same VLAN-to-instance mapping table and the same MSTP revision level setting. A device will not be in a different region if it is different in any of these three settings. You can view all the MST region–related configuration information by using this command and determine the MST region the device is currently in, or check whether the MST region configuration is correct.
Related commands: instance, region-name, revision-level, vlan-mapping modulo, active region-configuration.
# View all the configuration information of the MST region.
[Sysname-mst-region] check region-configuration
Admin Configuration
   Format selector :0
   Region name     :00b010000001
   Revision level  :0
   Instance   Vlans Mapped
      0       1 to 9, 11 to 4094
     16       10
Table 1-1 Description on the fields of the check region-configuration command
Format selector
Configuration format selector of the MST region
Region name
MST region name
Revision level
Revision level of the MST region
VLAN-to-instance mappings in the MST region
1.1.3  display stp
display stp [ instance instance-id ] [ interface interface-list ] [ brief ]
View
instance instance-id: Displays the spanning tree information of a particular MST instance. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
interface interface-list: Displays the spanning tree information on one or multiple ports. You can provide up to 10 port lists, by each of which you can specify an individual port in the form of interface-type interface-number, or a port range in the form of interface-type start-interface-number to interface-type end-interface-number, where the end port number must be greater than the start port number.
brief: Displays brief information.
Use the display stp command to view the MSTP status information and statistics information.
Based on the MSTP status information and statistics information, you can analyze and maintain the network topology or check whether MSTP is working normally.
Note that:
l           If you do not specify any MST instance ID or port list, this command will display the MSTP information on all ports. The displayed information is sequenced by MST instance ID and by port name in each MST instance.
l           If you specify an MST instance ID, this command will display the MSTP information on all ports in that MST instance. The displayed information is sequenced by port name.
l           If you specify a port list, this command will display the MSTP information on the specified ports. The displayed information is sequenced by MST instance ID, and by port name in each MST instance.
l           If you specify both an MST instance ID and a port list, this command will display the MSTP information on the specified ports in the specified MST instance.
The MSTP status information includes:
l           CIST global parameters: Protocol work mode, device priority in the CIST instance (Priority), MAC address, hello time, max age, forward delay, maximum hops, common root of the CIST, external path cost from the device to the CIST common root, regional root, the internal path cost from the device to the regional root, CIST root port of the device, and status of the BPDU guard function (enabled or disabled).
l           CIST port parameters: Port status, role, priority, path cost, designated bridge, designated port, edge port/non-edge port, whether connecting to a point-to-point link, maximum transmission rate (transmit limit), status of the root guard function (enabled or disabled), BPDU format, boundary port/non-boundary port, hello time, max age, forward delay, message age, remaining hops, whether a port in an aggregation group, and whether rapid state transition enabled (designated ports).
l           MSTI global parameters: MSTI instance ID, bridge priority of the instance, regional root, internal path cost, MSTI root port, and master bridge.
l           MSTI port parameters: Port status, role, priority, path cost, designated bridge, designated port, remaining hops, whether a port in an aggregation group, and whether rapid state transition enabled (for designated ports).
The statistics information includes:
l           The number of TCN BPDUs, configuration BPDUs, RST BPDUs and MST BPDUs sent from each port
l           The number of TCN BPDUs, configuration BPDUs, RST BPDUs, MST BPDUs and wrong BPDUs received on each port
l           The number of BPDUs discarded on each port
Related commands: reset stp.
# View the MSTP status information and statistics information.
<Sysname> display stp instance 0 interface Ethernet 1/0/1 to Ethernet 1/0/4 GigabitEthernet 1/1/1 to GigabitEthernet 1/1/4 brief
  MSTID      Port                        Role  STP State     Protection
   0         Ethernet1/0/1               ALTE  DISCARDING    LOOP
   0         Ethernet1/0/2               DESI  FORWARDING    NONE
   0         Ethernet1/0/3               DESI  FORWARDING    NONE
   0         Ethernet1/0/4               DESI  FORWARDING    NONE
   0         GigabitEthernet1/1/1        DESI  FORWARDING    NONE
   0         GigabitEthernet1/1/2        DESI  FORWARDING    NONE
   0         GigabitEthernet1/1/3        DESI  FORWARDING    NONE
   0         GigabitEthernet1/1/4*       DESI  FORWARDING    NONE
  (*) means port in aggregation group
Table 1-2 Description on the fields of the display stp command
MSTID
MST instance ID in the MST region
Port
Port name, corresponding to each MST instance
Role
Port role
STP State
MSTP status on the port, including forwarding, discarding, and learning
Protection
Protection type on the port, including root guard, loop guard, and BPDU guard
* indicates a port in an aggregation group
View
None
Use the display stp abnormal-port command to view the information about abnormally blocked ports.
Any of the following reasons may cause a port to be abnormally blocked:
l           The root guard function is enabled on the port.
l           The loop guard function is enabled on the port.
l           The MSTP BPDU format compatibility protection function is enabled on the port.
# View information about abnormally blocked ports.
<Sysname> display stp abnormal-port
MSTID       Blocked Port                     Reason
  1         Ethernet1/0/1                    ROOT-Protected
  2         Ethernet1/0/2                    LOOP-Protected
  2          Ethernet1/0/3                      Formatcompatibility–Protected
Table 1-3 Description on the fields of the display stp abnormal-port command
MSTID
MST instance ID
Blocked Port
Name of blocked port, which corresponds to the related MST instance
Reason
Reason that caused abnormal blocking of the port.
l      ROOT-Protected: root guard enabled
l      LOOP-Protected: loop guard enabled
l      Formatcompatibility-Protected: MSTP BPDU format compatibility protection enabled
View
None
Table 1-4 Description on the fields of the display stp abnormal-port command
MSTID
MST instance ID
Blocked Port
Reason
View
None
Use the display stp down-port command to view the information about ports blocked by STP protection actions.
These actions include:
l           BPDU attack guard action
l           MSTP BPDU format compatibility protection action
# View the information about ports blocked by STP protection actions.
<Sysname> display stp down-port
Down Port                 Reason
Ethernet1/0/1             BPDU-Protected
Ethernet1/0/2             Formatfrequency-Protected
Table 1-5 Description on the fields of the display stp abnormal-port command
Down Port
Reason
Reason that caused the port to be blocked.
l      BPDU-Protected: BPDU attack guard enabled
l      Formatfrequency-Protected: MSTP BPDU format compatibility protection enabled
display stp [ instance instance-id ] history
View
instance instance-id: Displays the historic port role calculation information of a particular spanning tree instance. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
Use the display stp history command to view the historic port role calculation information of the specified spanning tree instance or all spanning tree instances.
Note that:
l           If you do not specify a spanning tree instance ID, this command will display the historic port role calculation information of all spanning tree instances. The displayed information is sequenced by instance ID, and in the timing of port role calculation in each instance.
l           If you specify a spanning tree instance ID, this command will display the historic port role calculation information of only this specified spanning instance, in the timing of port role calculation.
# View the historic port role calculation information of the card on slot 1 in MSTP instance 2.
<Sysname> display stp instance 2 history
-------------------  Instance 2   ---------------------
     Port Ethernet1/0/3
       Role change   : ROOT->DESI (Aged)
       Time          : 2006/08/08 00:22:56
       Port priority : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.1
     Port Ethernet1/0/4
       Role change   : ALTER->ROOT
       Port priority : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.2
Table 1-6 Description on the fields of the display stp history command
Port
Port name
Role change
A role change of the port (“Age” means that the change was caused by expiry of a configuration BPDU)
Time
Time of port role calculation
Port priority
Port priority
View
None
Use the display stp region-configuration command to view the currently effective configuration information of the MST region, including the region name, revision level, and user-configured VLAN-to-instance mappings.
Related commands: stp region-configuration.
# View the currently effective MST region configuration information.
<Sysname> display stp region-configuration
Oper Configuration
   Format selector :0
   Region name     :hello
   Revision level  :0
      0       21 to 4094
      1       1 to 10
      2       11 to 20
Table 1-7 Description on the fields of the display stp region-configuration command
Format selector
MSTP-defined format selector
Region name
MST region name
Revision level
display stp root
View
None
Use the display stp root command to view the root bridge information of all MSTP instances.
# View the root bridge information of all MSTP instances.
<Sysname> display stp root
MSTID   Root Bridge ID        ExtPathCost IntPathCost Root Port
   0    32768.000f-e200-2200  200         0           Ethernet1/0/1
Table 1-8 Description on the fields of the display stp root command
MSTID
MST instance ID
Root Bridge ID
Root bridge ID
ExtPathCost
External path cost
IntPathCost
Internal path cost
Root Port
Root port name (displayed only if a port of the current device is the root port of multiple instances)
display stp [ instance instance-id ] tc
View
instance instance-id: Displays the statistics of TC BPDUs (also known as TCN BPDUs) received and sent by all ports in a particular spanning tree instance. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
Use the display stp tc command to view the statistics of TC BPDUs received and sent.
Note that:
l           If you do not specify a spanning tree instance ID, this command will display the statistics of TC BPDUs received and sent by all ports in all spanning trees. The displayed information is sequenced by instance ID and by port name in each spanning tree instance.
l           If you specify a spanning tree instance ID, this command will display the statistics of TC BPDUs received and sent by all ports in the specified spanning tree instance, in port name order.
# View the statistics of TC BPDUs received and sent by all ports on the card on slot 1 in MSTP instance 0.
<Sysname> display stp instance 0 tc
MSTID      Port                       Receive      Send
   0        Ethernet1/0/1             6            4
   0        Ethernet1/0/2             0            2
Table 1-9 Description on the fields of the display stp tc command
MSTID
MSTP instance ID in the MST region
Port
Port name
Receive
Number of TC BPDUs received on each port
Send
Number of TC BPDUs received by each port
1.1.11  instance
instance instance-id vlan vlan-list
undo instance instance-id [ vlan vlan-list ]
View
MST region view
instance-id: MST instance ID. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
vlan vlan-list: Defines one or multiple VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The effective range of a VLAN ID is 1 to 4094.
Use the instance command to map the specified VLAN(s) to the specified MST instance.
Use the undo instance command to remap the specified VLAN(s) or all VLANs to the CIST (MST instance 0).
By default, all VLANs are mapped to the CIST.
Notice that:
l           If you specify no VLAN in the undo instance command, all VLANs mapped to the specified MST instance will be remapped to the CIST.
l           You cannot map the same VLAN to different MST instances. If you map a VLAN that has been mapped to an instance to a new instance, the old mapping will be automatically removed.
Related commands: region-name, revision-level, check region-configuration, vlan-mapping modulo, active region-configuration.
# Map VLAN 2 to MST instance 1.
[Sysname-mst-region] instance 1 vlan 2
1.1.12  region-name
region-name name
undo region-name
View
MST region view
name: MST region name, a string of 1 to 32 characters.
Use the region-name command to configure the MST region name of your device.
Use the undo region-name command to restore the default MST region name.
By default, the MST region name of a device is its MAC address.
The MST region name, the VLAN-to-instance mapping table and the MSTP revision level of a device jointly determine the MST region the device belongs to.
Related commands: instance, revision-level, check region-configuration, vlan-mapping modulo, active region-configuration.
# Set the MST region name of the device to “hello”.
[Sysname-mst-region] region-name hello
1.1.13  reset stp
reset stp [ interface interface-list ]
View
interface interface-list: Clears the spanning tree statistics information on one or multiple ports. You can provide up to 10 port lists, by each of which you can specify an individual port in the form of interface-type interface-number, or a port range in the form of interface-type start-interface-number to interface-type end-interface-number, where the end port number must be greater than the start port number.
Use the reset stp command to clear the MSTP statistics information.
The MSTP statistics information includes the numbers of TCN BPDUs, configuration BPDUs, RST BPDUs and MST BPDUs sent/received through the specified port(s) (STP BPDUs and TCN BPDUs are counted only for the CIST).
Note that this command clears the spanning tree-related statistics information on the specified port(s) if you specify the interface-list argument; otherwise, this command clears the spanning tree-related statistics on all ports.
Related commands: display stp.
# Clear the spanning tree-related statistics information on ports Ethernet 1/0/1 through Ethernet 1/0/3.
<Sysname> reset stp interface Ethernet 1/0/1 to Ethernet 1/0/3
revision-level level
undo revision-level
View
MST region view
level: MSTP revision level, in the range of 0 to 65535. The system default is 0.
Use the region-level command to configure the MSTP revision level of your device.
Use the undo region-level command to restore the default MSTP revision level.
The MSTP revision level, the MST region name and the VLAN-to-instance mapping table of a device jointly determine the MST region the device belongs to.
Related commands: instance, region-name, check region-configuration, vlan-mapping modulo, active region-configuration.
# Set the MSTP revision level of the MST region to 5.
[Sysname-mst-region] revision-level 5
1.1.15  stp
stp { enable | disable }
undo stp
View
System view, Ethernet interface view, port group view
enable: Enables the MSTP feature.
disable: Disables the MSTP feature.
Use the stp command to enable or disable the MSTP feature globally or on the port(s).
Use the undo stp command to restore the default MSTP status.
Whether a device is globally MSTP-enabled by default depends on the specific device model. By default, MSTP is enabled for all ports.
Note that:
l           To control MSTP flexibly, you can disable the MSTP feature for certain ports so that they will not take part in spanning tree calculation and thus to save the device’s CPU resources.
l           After you enable MSTP, the device determines whether to work in STP-compatible mode, in RSTP mode or in MSTP mode according to your MSTP work mode setting. After MSTP is disabled, the device becomes a transparent bridge.
l           After being enabled, MSTP dynamically maintains spanning tree status of the corresponding VLANs based on the received configuration BPDUs. After being disabled, it stops maintaining the spanning tree status.
l           Configured in system view, the setting is effective for the device globally; configured in Ethernet interface view, the setting is effective on the current port only; configured in port group view, the setting is effective on all ports in the port group.
Related commands: stp mode.
# Enable the MSTP feature globally.
[Sysname] stp enable
# Disable MSTP on port Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] stp disable
stp bpdu-protection
undo stp bpdu-protection
View
None
Use the stp bpdu-protection command to enable the BPDU guard function for the device.
Use the undo stp bpdu-protection command to disable the BPDU guard function for the device.
By default, the BPDU guard function is disabled.
# Enable the BPDU guard function for the device.
[Sysname] stp bpdu-protection
stp bpdu-tagged
undo stp bpdu-tagged
View
Port view
None
Use the stp bpdu-tagged command to enable the function of tagging BPDUs with the receiving port’s default VLAN on the port.
Use the undo stp bpdu-tagged command to disable the function of tagging BPDUs on the port.
By default, the function of tagging BPDUs is disabled on a port.
# Enable the function of tagging BPDUs on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] stp bpdu-tagged
undo stp bpdu-tagged cist-ignored
View
Port view
None
Use the stp bpdu-tagged cist-ignored command to enable the function of ignoring CIST information in tagged BPDUs on the port.
Use the undo stp bpdu-tagged cist-ignored command to disable the function of ignoring CIST information in tagged BPDUs on the port.
By default, the function of ignoring CIST information in tagged BPDUs is disabled on a port.
# Enable the function of ignoring CIST information in tagged BPDUs on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] stp bpdu-tagged cist-ignored
undo stp bpdu-transparent-forwarding
View
Port view
None
Use the stp bpdu-transparent-forwarding command to enable the function of transmitting BPDUs transparently on the port.
Use the undo stp bpdu-transparent-forwarding command to disable the function of transmitting BPDUs transparently on the port.
By default, the function of transmitting BPDUs transparently is disabled on a port.
# Enable the function of transmitting BPDUs transparently on Ethernet 1/0/1.
[Sysname] interface Ethernet1/0/1
[Sysname-Ethernet1/0/1] stp bpdu-transparent-forwarding
stp bpdu-transparent-forwarding vlan vlan-list
undo stp bpdu-transparent-forwarding vlan vlan-list
View
vlan-list: One or multiple VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of vlan-id to vlan-id, where the end VLAN ID must be greater than the starting VLAN ID. The effective range of a VLAN ID is 1 to 4094.
Use the stp bpdu-transparent-forwarding vlan command to enable the function of transmitting BPDUs transparently in the specified VLAN(s).
Use the undo stp bpdu-transparent-forwarding vlan command to disable the function of transmitting BPDUs transparently in the specified VLAN(s).
By default, the function of transmitting BPDUs transparently is disabled in a VLAN.
# Enable the function of transmitting BPDUs transparently in VLAN 10.
[Sysname] stp bpdu-transparent-forwarding vlan 10
stp bridge-diameter bridge-number
undo stp bridge-diameter
View
bridge-number: Specifies the switched network diameter, in the range of 2 to 7.
Use the stp bridge-diameter command to specify the network diameter, namely the maximum number of stations between any two terminal devices on the switched network.
Use the undo stp bridge-diameter command to restore the default network diameter setting.
By default, the network diameter of the switched network is 7.
An appropriate setting of hello time, forward delay and max age can speed up network convergence. The values of these timers are related to the network size. You can set these three timers indirectly by setting the network diameter. Based on the network diameter you configured, MSTP automatically sets an optimal hello time, forward delay, and max age for the device. With the network diameter set to 7 (the default), the three timer are also set to their defaults.
Note that this configuration is effective for the CIST and root bridge only, and not for MSTIs.
Related commands: stp timer forward-delay, stp timer hello, stp timer max-age.
# Set the network diameter of the switched network to 5.
[Sysname] stp bridge-diameter 5
stp compliance { auto | dot1s | legacy }
undo stp compliance
View
auto: Configures the port(s) to recognize the MSTP BPDU format automatically and accordingly determine the format of MSTP BPDUs to send.
dot1s: Configures the port(s) to receive and send only standard-format (802.1s-compliant) MSTP BPDUs.
legacy: Configures the port(s) to receive and send only compatible-format MSTP BPDUs.
Use the stp compliance command to configure the mode the port(s) will use to recognize and send MSTP BPDUs.
Use the undo stp compliance command to restore the system default.
The default mode is auto, namely all ports recognize the BPDU format automatically.
Note that:
l           Configured in Ethernet interface view, the setting is effective on the current port only; configured in port group view, the setting is effective on all ports in the port group.
l           If the mode is set to auto on a port, the port automatically recognizes and resolves the received compatible-format BPDUs or 802.1s-compliant BPDUs, and sends, when needed, compatible-format or 802.1s-compliant BPDUs.
l           If the mode is set to legacy or dot1s, on a port, the port can only receive and send BPDUs of the specified format. If the port is configured not to detect the packet format automatically while it works in the MSTP mode, and if it receives a packet in the format other than as configured, that port will become a designated port, and the port will remain in the discarding state to prevent the occurrence of a loop.
# Configure Ethernet 1/0/1 to receive and send only standard-format (802.1s) MSTP packets.
<Sysname>system-view
[Sysname-Ethernet1/0/1] stp compliance dot1s
# Restore the default mode for port Ethernet 1/0/1 to recognize and send MSTP BPDUs.
[Sysname-Ethernet1/0/1] undo stp compliance
undo stp config-digest-snooping
View
None
Use the stp config-digest-snooping command to enable Digest Snooping.
Use the undo stp config-digest-snooping command to disable Digest Snooping.
The feature is disabled by default.
Notice that:
l           You need to enable this feature both globally and on ports connected to other vendors’ devices to make it take effect. It is recommended to enable the feature on all associated ports first and then globally, making all configured ports take effect at the same time to minimize the impact, and disable the feature globally to disable it on all associated ports.
l           It is not recommended to enable Digest Snooping on the MST region edge port to avoid loops.
# Enable Digest Snooping globally.
[Sysname] stp config-digest-snooping
# Enable Digest Snooping on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] stp config-digest-snooping
1.1.24  stp cost
stp [ instance instance-id ] cost cost
undo stp [ instance instance-id ] cost
View
instance instance-id: Sets the path cost of the port(s) in a particular MST instance. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
cost: Path cost of the port, the effective range of which depends on the path cost calculation standard adopted.
Use the stp cost command to set the path cost of the port(s) in the specified MST instance or all MST instances.
Use the undo stp cost command to restore the system default.
By default, the device automatically calculates the path costs of ports in each MST instance based on the corresponding standard.
If you set instance-id to 0, you are setting the path cost of the port in the CIST. The path cost setting of a port can affect the role selection of the port. Setting different path costs for the same port in different MST instances allows different VLAN traffic flows to be forwarded along different physical links, thus to enable per-VLAN load balancing. When the path cost of a port is changed, MSTP will re-compute the role of the port and initiate a state transition.
If you do not provide instance instance-id, your configuration will take effect in the CIST instance only.
# Set the path cost of port Ethernet 1/0/3 in MST instance 2 to 200.
[Sysname] interface Ethernet 1/0/3
[Sysname-Ethernet1/0/3] stp instance 2 cost 200
stp edged-port { enable | disable }
undo stp edged-port
View
enable: Configures the current port to be an edge port.
disable: Configures the current port to be a non-edge port.
Use the stp edged-port enable command to configure the port(s) to be an edge port or edge ports.
Use the stp edged-port disable or undo stp edged-port enable command to configure the port(s) to be a non-edge port or non-edge ports.
All Ethernet ports are non-edge ports by default.
Note that:
l           If a port directly connects to a user terminal rather than another device or a shared LAN segment, this port is regarded as an edge port. When the network topology changes, an edge port will not cause a temporary loop. Therefore, configuring a port as an edge port can enable the port to transition to the forwarding state rapidly. We recommend that you configure an Ethernet port directly connecting to a user terminal as an edge port before to enable it to transition to the forwarding state rapidly.
l           Normally, configuration BPDUs from other devices cannot reach an edge port because it does not connect to any other device. Before the BPDU guard function is enabled, if a port receives a configuration BPDU, the port is working actually as a non-edge port even if you have configured it as an edge port.
# Configure Ethernet 1/0/1 as a non-edge port.
[Sysname-Ethernet1/0/1] stp edged-port disable
stp ignored vlan vlan-list
undo stp ignored vlan vlan-list
View
vlan vlan-list: Specifeis a VLAN list in the format of vlan-list = { vlan-id [ to vlan-id2 }&<1-10>, in which vlan-id represents the sub-VLAN ID and ranges from 1 to 4094. &<1-10> indicates you can specify up to 10 sub-VLAN IDs or sub-VLAN ID ranges.
Use the stp ignored vlan command to enable VLAN Ignore for the specified VLAN(s).
Use the undo stp ignored vlan command to disable VLAN Ignore for the specified VLAN(s).
# Enable VLAN Ignore for VLAN 2.
[Sysname] stp ignored vlan 2
# Enable VLAN Ignore for VLAN 1 through VLAN 10.
[Sysname] stp ignored vlan 1 to 10
stp loop-protection
undo stp loop-protection
View
None
Use the stp loop-protection command to enable the loop guard function on the port(s).
Use the undo stp loop-protection command to restore the system default.
By default, the loop guard function is disabled.
# Enable the loop guard function on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] stp loop-protection
1.1.28  stp max-hops
stp max-hops hops
undo stp max-hops
View
hops: Maximum hops, in the range of 1 to 40
Use the stp max-hops command to set the maximum hops of the MST region on the device.
Use the undo stp max-hops command to restore the maximum hops to the default setting.
By default, the maximum number of hops of an MST region is 20.
In the CIST and MST instances, the maximum hops setting configured on the regional root bridge determines the maximum network diameter supported by this MST region. After a configuration BPDU leaves the root bridge, its hop count is decremented by 1 whenever it passes a device. When its hop count reaches 0, it will be discarded by the device that has received it. As a result, devices beyond the maximum hop count are unable to take part in spanning tree calculation, and thereby the size of the MST region is limited.
When the current device becomes the root bridge of the CIST or an MSTI, the maximum hops setting configured on the device becomes the network diameter of that spanning tree and restricts the size of that spanning tree in the current MST region.
Devices other than the root bridge in an MST region use the maximum hops setting on the root bridge.
# Set the maximum hops of the MST region to 35.
[Sysname] stp max-hops 35
1.1.29  stp mcheck
stp mcheck
View
None
Use the stp mcheck command to carry out the mCheck operation globally or on the current port.
In a switched network, if a port on the device running MSTP (or RSTP) connects to a device running STP, this port will automatically migrate to the STP-compatible mode. However, if the device running STP is removed, this will not be able to migrate automatically to the MSTP (or RSTP) mode, but will remain working in the STP-compatible mode. In this case, you can perform an mCheck operation to force the port to migrate to the MSTP (or RSTP) mode.
Note that the stp mcheck command is meaningful only when the device works in the MSTP (or RSTP) mode, not in the STP-compatible mode.
# Carry out mCheck on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] stp mcheck
1.1.30  stp mode
stp mode { stp | rstp | mstp }
undo stp mode
View
stp: Configures the MSTP-compliant device to work in STP-compatible mode.
rstp: Configures MSTP-compliant device to work in RSTP mode.
mstp: Configures MSTP-compliant device to work in MSTP mode.
Use the stp mode command to configure the MSTP work mode of the device.
Use the undo stp mode command to restore the MSTP work mode to the default setting.
By default, an MSTP-compliant device works in MSTP mode.
Related commands: stp mcheck, stp.
# Configure the MSTP-compliant device to work in STP-compatible mode.
[Sysname] stp mode stp
undo stp no-agreement-check
View
None
Use the stp no-agreement-check command to enable No Agreement Check on the port(s).
Use the undo stp no-agreement-check command to disable No Agreement Check on the port(s).
By default, No Agreement Check is disabled.
&  Note:
The No Agreement Check feature can take effect only on the root port.
# Enable No Agreement Check on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] stp no-agreement-check
stp pathcost-standard { dot1d-1998 | dot1t | legacy }
undo stp pathcost-standard
View
dot1d-1998: The device calculates the default path cost for ports based on IEEE 802.1D-1998.
dot1t: The device calculates the default path cost for ports based on IEEE 802.1t.
legacy: The device calculates the default path cost for ports based on the legacy standard.
Use the stp pathcost-standard command to specify a standard for the device to use when calculating the default path cost of the link connected with the device.
Use the undo stp pathcost-standard command to restore the system default.
By default, the device calculates the default path cost for ports based on the legacy standard.
Note that if you change the standard that the device uses in calculating the default path cost, the port path cost value set through the stp cost command will be out of effect.
Table 1-10 Link speed vs. path cost
Link speed
Duplex state
802.1D-1998
IEEE 802.1t
Legacy standard
0
65535
200,000,000
200,000
10 Mbps
Single Port
Aggregated Link 2 Ports
Aggregated Link 3 Ports
Aggregated Link 4 Ports
100
100
100
100
2,000,000
1,000,000
666,666
500,000
2,000
1,800
1,600
1,400
100 Mbps
Single Port
19
19
19
19
200,000
100,000
66,666
50,000
200
180
160
140
1000 Mbps
Single Port
4
4
4
4
20,000
10,000
6,666
5,000
20
18
16
14
10 Gbps
Single Port
2
2
2
2
2,000
1,000
666
500
2
1
1
1
In the calculation of the path cost value of an aggregated link, 802.1D-1998 does not take into account the number of ports in the aggregated link, while 802.1T takes the number of ports in the aggregated link into account. The calculation formula is: Path Cost = 200,000,000/link speed (in 100 kbps), where link speed is the sum of the link speed values of the non-blocked ports in the aggregated link.
# Configure the device to calculate the default path cost for ports based on IEEE 802.1D-1998.
[Sysname] stp pathcost-standard dot1d-1998
# Configure the device to calculate the default path cost for ports based on IEEE 802.1t.
[Sysname] stp pathcost-standard dot1t
stp point-to-point { auto | force-false | force-true }
undo stp point-to-point
View
auto: Specifies automatic detection of the link type.
force-false: Specifies the non-point-to-point link type.
force-true: Specifies the point-to-point link type.
Use the stp point-to-point command to specify whether the current port(s) connect(s) to a point-to-point link or point-to-point links.
Use the undo stp point-to-point command to restore the system default.
The default setting is auto; namely the MSTP-compliant device automatically detects whether an Ethernet port connects to a point-to-point link.
Note that:
l           When connecting to a non-point-to-point link, a port is incapable of rapid state transition.
l           If the current port is the master port of a link aggregation group or if it works in full duplex mode, the link to which the current port connects is a point-to-point link. We recommend that you use the default setting, namely let MSTP detect the link status automatically.
l           This setting is effective to the CIST and all MST instances. If a port is configured as connecting to a point-to-point link or a non-point-to-point link, the setting takes effect for the port in all MST instances. If the physical link to which the port connects is not a point-to-point link and you force it to be a point-to-point link by configuration, your configuration may incur a temporary loop.
# Configure port Ethernet 1/0/3 as connecting to a point-to-point link.
[Sysname-Ethernet1/0/3] stp point-to-point force-true
1.1.34  stp port-log
stp port-log { all | instance instance-id }
undo stp port-log { all | instance instance-id }
View
all: Enables output of port state transition information for all instances.
instance instance-id: Enables output of port state transition information for the specified instance. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
Use the stp port-log command to enable output of port state transition information for the specified instance or all instances.
Use the undo stp port-log command to disable output of port state transition information for the specified instance or all instances.
Whether this function is enabled by default depends on the specific device model.
&  Note:
The support for this command varies with device models.
# Enable output of port state transition information for instance 2.
[Sysname] stp port-log instance 2
%Aug 16 00:49:41:856 2006 Sysname MSTP/3/PDISC: Instance 2's Ethernet1/0/1 has been set to discarding state!
%Aug 16 00:49:41:856 2006 Sysname MSTP/3/PFWD: Instance 2's Ethernet1/0/2 has been set to forwarding state!
// The information mentioned above shows that in instance 2 the state of Ethernet 1/0/1 has changed to discarding and that of Ethernet 1/0/2 has changed to forwarding.
stp [ instance instance-id ] port priority priority
undo stp [ instance instance-id ] port priority
View
instance instance-id: Sets the priority of the current port(s) in a particular spanning tree instance. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
priority: Port priority, in the range of 0 to 240 at the step of 16 (0, 16, 32…, for example).
Use the stp port priority command to set the priority of the port(s).
Use the undo stp port priority command to restore the system default.
By default, the port priority is 128.
If you set instance-id to 0, you are setting the priority of the port in the CIST. The priority of a port can affect the role selection of the port in the specified MST instance.
Setting different priorities for the same port in different MST instances allows different VLAN traffic flows to be forwarded along different physical links, thus to enable per-VLAN load balancing.
When the priority of a port is changed, MSTP will re-compute the role of the port and initiate a state transition.
# Set the priority of port Ethernet 1/0/3 in MST instance 2 to 16.
[Sysname-Ethernet1/0/3] stp instance 2 port priority 16
1.1.36  stp priority
stp [ instance instance-id ] priority priority
undo stp [ instance instance-id ] priority
View
instance instance-id: Sets the priority of the device in a particular spanning tree instance. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
priority: Port priority, in the range of 0 to 61440 at the step of 4096, namely you can set up to 16 priority values, such as 0, 4096, 8192…, on the device.
Use the stp priority command to set the priority of the device.
Use the undo stp priority command to restore the default device priority.
By default, the device priority is 32768.
The device priority is involved in spanning tree calculation. The device priority is set on a per-instance basis. An MSTP-compliant device can have different priorities in different MST instances.
# Set the device priority in MST instance 1 to 4096.
[Sysname] stp instance 1 priority 4096
undo stp region-configuration
View
None
Use the stp region-configuration command to enter MST region view.
Use the undo stp region-configuration command to restore the default MST region configurations.
By default, the default settings are used for all the three MST region parameters. Namely, the device’s MST region name is the device’s MAC address, all VLANs are mapped to the CIST, and the MSTP revision level is 0.
After you enter MST region view, you can configure the parameters related to the MST region, including the region name, VLAN-to-instance mapping and revision level.
# Enter MST region view.
stp [ instance instance-id ] root primary [ bridge-diameter bridge-number ] [ hello-time centi-seconds ]
undo stp [ instance instance-id ] root
View
instance instance-id: Configures the device as the root bridge in a particular spanning tree instance. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
bridge-number: Network diameter of the spanning tree, in the range of 2 to 7 and defaulting to 7.
centi-seconds: Hello time (in centiseconds) of the spanning tree, in the range of 100 to 1,000.
Use the stp root primary command to configure the current device as the root bridge.
Use the undo stp root command to restore the system default.
By default, a device is not a root bridge.
Note that:
l           If you do not provide instance instance-id, your configuration will take effect in the CIST instance only.
l           There is only one root bridge in effect in a spanning tree instance. If two or more devices have been designated to be root bridges of the same spanning tree instance, MSTP will select the device with the lowest MAC address as the root bridge.
l           You can specify a root bridge for each MST instance without caring about the device priority. After specifying the current device as the root bridge or a secondary root bridge, you cannot change the priority of the device.
l           When configuring a root bridge, you can use this command to specify the network diameter of the switched network, so that the MSTP-compliant device automatically calculates the three timers (hello time, forward delay and max age). As the calculated hello time value is not the optimal value, you can specify a hello time value by providing hello-time centi-seconds in the command, which will override the hello time value calculated by the device based on the network diameter. Generally, we recommend that you use the values of the other two timers calculated by the device based on the specified network diameter.
l           The configured network diameter and hello time settings are effective only for MST instance 0, namely the CIST. If you configure these two timers for any other instance, your configuration can succeed, but they will not actually work.
# Define the current device as the root bridge of MST instance 0 and set the network diameter to 4 and the hello time of the device to 500 centiseconds.
[Sysname] stp instance 0 root primary bridge-diameter 4 hello-time 500
stp [ instance instance-id ] root secondary [ bridge-diameter bridge-number ] [ hello-time centi-seconds ]
View
instance instance-id: Configures the device as a secondary root bridge in a particular spanning tree instance. The effective range of instance-id is 0 to 15, with 0 representing the common internal spanning tree (CIST).
Use the stp root secondary command to configure the device as a secondary root bridge.
By default, a device is not a secondary root bridge.
Note that:
l           You can configure one or more secondary root bridges for each MST instance. When the root bridge of an instance fails or is shut down, the secondary root bridge can take over the role of the instance of the specified MST instance. If you specify more than one secondary root bridge, the secondary root bridge with the lowest MAC address will become the root bridge.
l           When configuring a secondary root bridge, you can specify the network diameter of the switched network and the hello time for the secondary root bridge, so that the MSTP-compliant device automatically calculates the other two timers (forward delay and max age) of the root bridge.
l           If you set instance-id to 0, you are specifying the current device as the secondary root bridge of the CIST.
l           Upon specifying the current device as the root bridge or a secondary root bridge, you cannot change the priority of the device.
# Define the current device as the secondary root bridge of MST instance 0 and set the network diameter to 5 and the hello time of the device to 300 centiseconds.
[Sysname] stp instance 0 root secondary bridge-diameter 5 hello-time 300
stp root-protection
undo stp root-protection
View
None
Use the stp root-protection command to enable the root guard function on the port(s).
Use the undo stp root-protection command to disable the root guard function on the port(s).
By default, the root guard function is disabled.
# Enable the root guard function for port Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] stp root-protection
stp tc-protection enable
stp tc-protection disable
View
None
Use the stp tc-protection enable command to enable the TC-BPDU attack guard function for the device.
Use the stp tc-protection disable command to disable the TC-BPDU attack guard function for the device.
By default, the TC-BPDU attack guard function is enabled.
# Enable the TC-BPDU attack guard function for the device.
[Sysname] stp tc-protection enable
stp tc-protection threshold number
undo stp tc-protection threshold
View
number: Maximum number of times the device deletes forwarding address entries within a certain period of time immediately after it receives TC-BPDUs, in the range of 1 to 255.
Use the stp tc-protection threshold command to configure the maximum number of times the device deletes forwarding address entries within 10 seconds immediately after it receives TC-BPDUs.
Use the undo stp tc-protection threshold command to restore the system default.
By default, the device deletes forwarding address entries a maximum of six times within a certain period of time immediately after it receives TC-BPDUs.
# Set the maximum number of times the device deletes forwarding address entries within a certain period of time immediately after it receives TC-BPDUs to 10.
[Sysname] stp tc-protection threshold 10
stp timer forward-delay centi-seconds
undo stp timer forward-delay
View
centi-seconds: Forward delay in centiseconds, in the range of 400 to 3,000.
Use the stp timer forward-delay command to set the forward delay timer of the device.
Use the undo stp timer forward-delay command to restore the system default.
By default, the forward delay timer is set to 1,500 centiseconds.
In order to prevent temporary loops, a port must go through an intermediate state, the learning state, before it transitions from the discarding state to the forwarding state, and must wait a certain period of time before it transitions from one state to another to keep synchronized with the remote device during state transition. The forward delay timer set on the root bridge determines the time interval of state transition.
If the current device is the root bridge, the state transition interval of the device depends on the set forward delay value; for a secondary root bridge, its state transition interval is determined by the forward delay timer set on the root bridge.
The setting of the hello time, forward delay and max age timers must meet the following formulae:
l           2 × (forward delay – 1 second) ¦ max age
l           Max age ¦ 2 × (hello Time + 1 second)
MSTP can work effectively on the entire network only when the above-mentioned conditions are met; otherwise, network instability will frequently occur. We recommend that you specify the network diameter of the switched network in the stp root primary command and let MSTP automatically calculate an optimal setting of these three timers.
Related commands: stp timer hello, stp timer max-age, stp bridge-diameter.
# Set the forward delay timer of the device to 2,000 centiseconds.
[Sysname] stp timer forward-delay 2000
stp timer hello centi-seconds
undo stp timer hello
View
centi-seconds: Hello time (in centiseconds), in the range of 100 to 1,000.
Use the stp timer hello command to set the hello time of the device.
Use the undo stp timer hello command to restore the system default.
By default, the hello time is set to 200 centiseconds.
Hello time is the time interval at which MSTP-compliant devices send configuration BPDUs to maintain spanning tree stability. If a device fails to receive configuration BPDUs within the set period of time, a new spanning tree calculation process will be triggered due to timeout. The root bridge sends configuration BPDUs at the interval of the hello time set on the device, while secondary root bridges use the hello time set on the root bridge.
l           Max age ¦ 2 × (hello time + 1 second)
Related commands: stp timer forward-delay, stp timer max-age, stp bridge-diameter.
# Set the hello time of the device to 400 centiseconds.
[Sysname] stp timer hello 400
stp timer max-age centi-seconds
undo stp timer max-age
View
centi-seconds: Max age (in centiseconds), in the range of 600 to 4,000.
Use the stp timer max-age command to set the max age timer of the device.
Use the undo stp timer max-age command to restore the system default.
By default, the max age is set to 2,000 centiseconds.
MSTP can detect link faults and automatically restore the forwarding state of the redundant link. In the CIST, the device determines whether a configuration BPDU received on a port has expired based on the max age timer. If a port receives a configuration BPDU that has expired, that MST instance needs to be re-computed.
The max age timer is not meaningful for MSTIs. If the current device is the root bridge of the CIST, it determines whether a configuration BPDU has expired based on the configured max age timer; if the current device is not the root bridge of the CIST, it uses the max age timer set on the CIST root bridge.
MSTP can work effectively on the entire network only when the above-mentioned conditions are met; otherwise, network instability will frequently occur. We recommend that you specify the network diameter in the stp root primary command and let MSTP automatically calculate an optimal setting of these three timers.
Related commands: stp timer forward-delay, stp timer hello, stp bridge-diameter.
# Set the max age timer of the device to 1,000 centiseconds.
[Sysname] stp timer max-age 1000
stp timer-factor number
undo stp timer-factor
View
number: Timeout factor, in the range of 1 to 20.
Use the stp timer-factor command to configure the timeout time of the device by setting the timeout factor. Timeout time = timeout factor × 3 × hello time.
Use the undo stp timer-factor command to restore the default timeout factor.
By default, the timeout factor of the device is set to 3.
After the network topology is stabilized, each non-root-bridge device forwards configuration BPDUs to the surrounding devices at the interval of hello time to check whether any link is faulty. Typically, if a device does not receive a BPDU from the upstream device within nine times the hello time, it will assume that the upstream device has failed and start a new spanning tree calculation process.
In a very stable network, this kind of spanning tree calculation may occur because the upstream device is busy. In this case, you can avoid such unwanted spanning tree calculation by lengthening the timeout time (by setting the timeout factor to 4 or more). We recommend that you set the timeout factor to 5, or 6, or 7 for a stable network.
# Set the timeout factor of the device to 7.
[Sysname] stp timer-factor 7
stp transmit-limit packet-number
undo stp transmit-limit
View
packet-number: Maximum number of MSTP packets that the port can send within each hello time, namely the maximum transmission rate of the port, in the range of 1 to 255.
Use the stp transmit-limit command to set the maximum transmission rate of the port(s).
Use the undo stp transmit-limit command to restore the system default.
By default, the maximum transmission rate of all ports of the device is 10.
A larger maximum transmission rate value represents more MSTP packets that the port will send within each hello time, but this means that more device resources will be used. An appropriate maximum transmission rate setting can prevent MSTP from using an excessive bandwidth resource during network topology instability.
# Set the maximum transmission rate of port Ethernet 1/0/1 to 5.
[Sysname-Ethernet1/0/1] stp transmit-limit 5
vlan-mapping modulo modulo
View
MST region view
modulo: Modulo value, in the range of 1 to 15.
Use the vlan-mapping modulo command to map VLANs in the current MST region to MST instances according to the specified modulo value.
By default, all VLANs are mapped to the CIST (instance 0).
&  Note:
By using the vlan-mapping modulo command, you can quickly specify a VLAN for each MST instance. This command maps each VLAN to the MST instance whose ID is (VLAN ID–1) %modulo + 1, where (VLAN ID-1) %modulo is the modulo operation for (VLAN ID–1). If the modulo value is 15, for example, then VLAN 1 will be mapped to MSTI 1, VLAN 2 to MSTI 2, VLAN 15 to MSTI 15, VLAN 16 to MSTI 1, and so on.
Related commands: region-name, revision-level, check region-configuration, active region-configuration.
# Map VLANs to MSTIs as per modulo 8.
[Sysname-mst-region] vlan-mapping modulo 8
