H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
18-ARP Commands
18-ARP Commands 65.04 KB
Chapter 1  ARP Configuration Commands
1.1  ARP Configuration Commands
1.1.1  arp check enable
arp check enable
undo arp check enable
View
None
Use the arp check enable command to enable ARP entry check. With this function enabled, the device cannot learn any ARP entry with a multicast MAC address. Configuring such a static ARP entry is not allowed either; otherwise, the system prompts error information.
Use the undo arp check enable command to disable the function. After the ARP entry check is disabled, the device can learn the ARP entry with a multicast MAC address, and you can also configure such a static ARP entry on the device.
By default, ARP entry check is enabled.
# Enable the ARP entry check function.
[Sysname] undo check enable
1.1.2  arp max-learning-num
arp max-learning-num number
undo arp max-learning-num
View
VLAN interface view
number: Maximum number of dynamic ARP entries that a VLAN interface can learn, in the range 1 to 2560.
Use the arp max-learning-num command to set the maximum number of dynamic ARP entries that a VLAN interface can learn.
Use the undo arp max-learning-num command to restore the default.
By default, a VLAN interface can learn up to 2,560 dynamic ARP entries.
# Specify VLAN-interface 40 to learn up to 500 dynamic ARP entries.
[Sysname] interface vlan-interface 40
[Sysname-Vlan-interface40]arp max-learning-num 500
1.1.3  arp static
arp static ip-address mac-address [ vlan-id interface-type interface-number ] [ vpn-instance vpn-instance-name ]
undo arp ip-address [ vpn-instance vpn-instance-name ]
View
ip-address: IP address in an ARP entry.
mac-address: MAC address in an ARP entry, in the format H-H-H.
vlan-id: ID of a VLAN to which a static ARP entry belongs to, in the range 1 to 4094.
interface-type interface-number: Port type and port number.
vpn-instance vpn-instance-name: Name of a VLAN instance, a case-insensitive string of 1 to 31 characters.
Use the arp static command to configure a static ARP entry in the ARP mapping table.
Use the undo arp command to remove an ARP entry.
Note that:
l           A static ARP entry is effective when the device works normally. However, when the VLAN or VLAN interface to which an ARP entry corresponds is deleted, the entry, if permanent, will be deleted, and if non-permanent and resolved, will become unresolved. A VLAN interface must be created for the VLAN.
l           The vlan-id argument is used to specify the corresponding VLAN of an ARP entry and must be the ID of an existing VLAN. In addition, the Ethernet port following the argument must belong to that VLAN.
Related commands: reset arp.
# Configure a static ARP entry, with the IP address being 202.38.10.2, the MAC address being 00e0-fc01-0000, and the outbound port being Ethernet 1/0/10 of VLAN 10.
[Sysname] arp static 202.38.10.2 00e0-fc01-0000 10 ethernet 1/0/10
1.1.4  arp timer aging
arp timer aging aging-time
undo arp timer aging
View
aging-time: Aging time for dynamic ARP entries in minutes. It ranges from 1 to 1,440 and defaults to 20.
Use the arp timer aging command to set aging time for dynamic ARP entries.
Use the undo arp timer aging command to restore the default.
Related commands: display arp timer aging.
# Set aging time for dynamic ARP entries to 10 minutes.
[Sysname] arp timer aging 10
1.1.5  display arp
display arp { { all | dynamic | static } | vlan vlan-id | interface interface-type interface-number } [ [ verbose ] [ | { begin | exclude | include } text ] | count ]
View
all: Displays all ARP entries.
dynamic: Displays dynamic ARP entries.
static: Displays static ARP entries.
vlan vlan-id: Displays the ARP entries of the specified VLAN. The VLAN ID ranges from 1 to 4,094.
interface interface-type interface-number: Displays the ARP entries of the port specified by the argument interface-type interface-number.
verbose: Displays detailed information about ARP entries.
|: Uses a regular expression to specify the ARP entries to be displayed.
begin: Displays ARP entries from the first one containing the specified string.
exclude: Displays the ARP entries that do not contain the specified string.
include: Displays the ARP entries containing the specified string.
text: A string for matching.
count: Displays the number of ARP entries.
Use the display arp command to display ARP entries in the ARP mapping table.
Related commands: arp static, reset arp.
# Display the detailed information of all ARP entries.
<Sysname> display arp all verbose
                Type: S-Static    D-Dynamic
IP Address       MAC Address     VLAN ID  Interface              Aging Type
Vpn-instance Name
20.1.1.1         00e0-fc00-0001  N/A      N/A                    N/A   S
test
193.1.1.70       00e0-fe50-6503  100      Eth1/0/1               14    D
[No Vrf]
192.168.0.115    000d-88f7-9f7d  1        Eth1/0/2               18    D
[No Vrf]
192.168.0.39     0012-a990-2241  1        Eth1/0/3               20    D
[No Vrf]
Table 1-1 Description on the fields of the display arp command
IP Address
MAC Address
VLAN ID
VLAN ID contained a static ARP entry
Outbound port in an ARP entry
Aging
Aging time for a dynamic ARP entry in minutes
ARP entry type: D stands for dynamic and S for static.
Vpn-instance Name
Name of VPN instance. [No Vrf] means no VPN instance is configured for the corresponding ARP.
# Display the number of all ARP entries
<Sysname> display arp all count
Total Entry(ies): 4
1.1.6  display arp ip-address
display arp ip-address [ verbose ] [ | { begin | exclude | include } text ]
View
ip-address: Displays the ARP entry for the specified IP address.
verbose: Displays the detailed information about ARP entries.
begin: Displays the ARP entries from the first one containing the specified string.
Include: Displays the ARP entries that contain the specified string.
text: A character string.
Use the display arp ip-address command to display the ARP entry for a specified IP address.
# Display the corresponding ARP entry for the IP address 20.1.1.1.
<Sysname> display arp 20.1.1.1
1.1.7  display arp timer aging
View
None
Use the display arp timer aging command to display the aging time for dynamic ARP entries.
Related commands: arp timer aging.
# Display the aging time for dynamic ARP entries.
[Sysname] display arp timer aging
Current ARP aging time is 10 minute(s)
1.1.8  display arp vpn-instance
display arp vpn-instance vpn-instance-name [ | { begin | exclude | include } text | count ]
View
vpn-instance-name: Name of VPN instance, a case-insensitive string of 1 to 31 characters. With this argument specified, the ARP entries for a specific VPN instance are displayed.
begin: Displays the ARP entries from the first one that contains the specified string.
include: Displays the ARP entries that contain the specified string.
Use the display arp vpn-instance command to display the ARP entries for a specified VPN instance.
Related commands: arp static and reset arp.
# Display ARP entries for the VPN instance named test.
<Sysname> display arp vpn-instance test
1.1.9  reset arp
reset arp { all | dynamic | static | interface interface-type interface-number }
View
all: Clears all ARP entries.
dynamic: Clears all dynamic ARP entries.
static: Clears all static ARP entries.
interface interface-type interface-number: Clears the ARP entries for the port specified by the argument interface-type interface-number.
Use the reset arp command to clear ARP entries from the ARP mapping table.
With interface interface-type interface-number specified, the command clears only dynamic ARP entries of the port.
Related commands: arp static, display arp.
# Clear all static ARP entries.
<Sysname> reset arp static
1.2  Gratuitous ARP Configuration Commands
1.2.1  gratuitous-arp-sending enable
undo gratuitous-arp-sending enable
View
None
Use the gratuitous-arp-sending enable command to enable a device to send gratuitous ARP packets when receiving ARP requests from another network segment.
Use the undo gratuitous-arp-sending enable command to restore the default.
By default, a device cannot send gratuitous ARP packets when receiving ARP requests from another network segment.
# Disable a device from sending gratuitous ARP packets.
[Sysname] undo gratuitous-arp-sending enable
1.2.2  gratuitous-arp-learning enable
undo gratuitous-arp-learning enable
View
None
Use the gratuitous-arp-learning enable command to enable the gratuitous ARP packet learning function.
Use the undo gratuitous-arp-learning enable command to disable the function.
By default, the function is disabled.
# Enable the gratuitous ARP packet learning function.
[Sysname] gratuitous-arp-learning enable
1.3  ARP Source Suppression Configuration Commands
1.3.1  arp source-suppression enable
undo arp source-suppression enable
View
None
Use the arp source-suppression enable command to enable the ARP source suppression function.
Use the undo arp source-suppression enable command to disable the function.
By default, the ARP source suppression function is disabled.
Related commands: display arp source-suppression.
# Enable the ARP source suppression function.
[Sysname] arp source-suppression enable
1.3.2  arp source-suppression limit
undo arp source-suppression limit
View
limit-value: Specifies the maximum number of packets with the same source IP address but unresolvable destination IP addresses that a port can receive in five seconds. It ranges from 2 to 1,024.
Use the arp source-suppression limit command to set the maximum number of packets with the same source IP address but unresolvable destination IP addresses that a port can receive in five seconds.
Use the undo arp source-suppression limit command to restore the default value, which is 10.
# Set to 100 the maximum number of packets with the same source address but unresolvable destination IP addresses that a port can receive in five seconds.
[Sysname] arp source-suppression limit 100
1.3.3  display arp source-suppression
View
None
Use the display arp source-suppression command to display information about the current ARP source suppression configuration.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
ARP source suppression is enabled
 Current suppression limit: 100
 Current cache length: 16
Table 1-2 Description on fields of display arp source-suppression
The ARP source suppression function is enabled
Maximum number of packets with the same  source IP address but unresolvable IP addresses that the device can receive in five seconds
Size of cache used to record source suppression information
Chapter 2  Proxy ARP Configuration Commands
2.1  Proxy ARP Configuration Commands
2.1.1  proxy-arp enable
proxy-arp enable
undo proxy-arp enable
View
VLAN interface view
None
Use the proxy-arp enable command to enable proxy ARP.
Use the undo proxy-arp enable command to disable proxy ARP.
By default, proxy ARP is disabled.
Related commands: display proxy-arp.
# Enable proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] proxy-arp enable
2.1.2  local-proxy-arp enable
undo local-proxy-arp enable
View
VLAN interface view
None
Use the local-proxy-arp enable command to enable local proxy ARP.
Use the undo local-proxy-arp enable command to disable local proxy ARP.
By default, local proxy ARP is disabled.
Related commands: display local-proxy-arp.
# Enable local proxy ARP on VLAN-interface 2.
[Sysname] interface Vlan-interface 2
[Sysname-Vlan-interface2] local-proxy-arp enable
2.1.3  display proxy-arp
display proxy-arp [ interface Vlan-interface vlan-id ]
View
interface Vlan-interface vlan-id: Displays the proxy ARP status of the VLAN interface specified by the argument vlan-id.
Use the display proxy-arp command to display the proxy ARP status.
Related commands: proxy-arp enable.
# Display the proxy ARP status on VLAN-interface 1.
<Sysname> display proxy-arp interface vlan-interface 1
Interface Vlan-interface1
 Proxy ARP status: disabled
2.1.4  display local-proxy-arp
display local-proxy-arp [ interface Vlan-interface vlan-id ]
View
interface vlan-interface vlan-id: Displays the local proxy ARP status of the VLAN interface specified by the argument vlan-id.
Use the display local-proxy-arp command to display the status of the local proxy ARP.
Related commands: local-proxy-arp enable.
# Display the status of the local proxy ARP on VLAN-interface 2.
<Sysname> display local-proxy-arp interface vlan-interface 2
Interface Vlan-interface2
 Local Proxy ARP status: enabled
