H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
40-Appendix
40-Appendix 112.69 KB
Appendix A  Command Index
The command index includes all the commands in the Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
abr-summary
IPv4 Routing
3-1
abr-summary
IPv6 Routing
3-1
access-limit
AAA-RADIUS-HWTACACS
1-1
accounting
QoS
2-5
accounting default
AAA-RADIUS-HWTACACS
1-2
accounting lan-access
AAA-RADIUS-HWTACACS
1-3
accounting login
AAA-RADIUS-HWTACACS
1-4
accounting optional
AAA-RADIUS-HWTACACS
1-5
accounting-on enable
AAA-RADIUS-HWTACACS
1-29
accounting-on enable interval
AAA-RADIUS-HWTACACS
1-30
accounting-on enable send
AAA-RADIUS-HWTACACS
1-31
acl
Login
2-1
acl
ACL
1-4
acl copy
ACL
1-5
acl ipv6
ACL
1-22
acl ipv6 copy
ACL
1-24
acl ipv6 name
ACL
1-25
acl name
ACL
1-6
activation-key
Login
1-1
active region-configuration
MSTP
1-1
add-member
Cluster Management
1-17
administrator-address
Cluster Management
1-18
aggregate
IPv4 Routing
5-1
aggregation-group
IPv6
3-1
apply as-path
IPv4 Routing
6-1
apply comm-list delete
IPv4 Routing
6-2
apply community
IPv4 Routing
6-3
apply cost
IPv4 Routing
6-4
apply cost-type
IPv4 Routing
6-4
apply extcommunity
IPv4 Routing
6-5
apply ip-address next-hop
IPv4 Routing
6-23
apply ipv6 next-hop
IPv6 Routing
6-1
apply isis
IPv4 Routing
6-6
apply local-preference
IPv4 Routing
6-7
apply origin
IPv4 Routing
6-7
apply preference
IPv4 Routing
6-8
apply preferred-value
IPv4 Routing
6-9
apply tag
IPv4 Routing
6-10
area
IPv4 Routing
3-2
area
IPv6 Routing
3-2
area-authentication-mode
IPv4 Routing
4-1
arp check enable
ARP
1-1
arp max-learning-num
ARP
1-1
arp source-suppression enable
ARP
1-9
arp source-suppression limit
ARP
1-10
arp static
ARP
1-2
arp timer aging
ARP
1-3
asbr-summary
IPv4 Routing
3-3
ascii
File System Management
2-5
attribute
AAA-RADIUS-HWTACACS
1-6
attribute
PKI
1-1
authentication default
AAA-RADIUS-HWTACACS
1-7
authentication lan-access
AAA-RADIUS-HWTACACS
1-8
authentication login
AAA-RADIUS-HWTACACS
1-9
authentication-mode
Login
1-2
authentication-mode
IPv4 Routing
3-4
authorization command
AAA-RADIUS-HWTACACS
1-10
authorization default
AAA-RADIUS-HWTACACS
1-10
authorization lan-access
AAA-RADIUS-HWTACACS
1-12
authorization login
AAA-RADIUS-HWTACACS
1-13
auto cost enable
IPv4 Routing
4-2
auto-build
Cluster Management
1-19
auto-execute command
Login
1-3
auto-rp enable
Multicast Protocol
5-1
B
backup startup-configuration
1-11
balance
IPv4 Routing
5-3
balance
IPv6 Routing
5-1
bandwidth-reference
IPv4 Routing
3-5
bandwidth-reference
IPv4 Routing
4-3
bestroute as-path-neglect
IPv4 Routing
5-4
IPv6 Routing
5-2
bestroute compare-med
IPv4 Routing
5-4
IPv6 Routing
5-2
bestroute med-confederation
IPv4 Routing
5-5
IPv6 Routing
5-3
bfd authentication-mode
BFD-GR
1-1
bfd detect-multiplier
BFD-GR
1-2
bfd echo-source-ip
BFD-GR
1-3
bfd min-echo-receive-interval
BFD-GR
1-3
bfd min-receive-interval
BFD-GR
1-4
bfd min-transmit-interval
BFD-GR
1-5
bfd session init-mode
BFD-GR
1-5
bgp
IPv4 Routing
5-6
bims-server
DHCP
1-1
binary
2-5
black-list add-mac
Cluster Management
1-20
black-list delete-mac
Cluster Management
1-21
bootfile-name
DHCP
1-2
boot-loader
System Maintaining and Debugging
3-1
bootrom
3-2
bpdu-tunnel dot1q enable
QinQ-BPDU Tunneling
2-2
bpdu-tunnel dot1q stp
QinQ-BPDU Tunneling
2-1
bpdu-tunnel tunnel-dmac
QinQ-BPDU Tunneling
2-3
broadcast-suppression
Port Correlation Configuration
1-1
bsr-policy
Multicast Protocol
5-2
build
Cluster Management
1-21
burst-traffic
QoS
5-1
bye
2-6
bye
SSH
1-29
C
ca identifier
PKI
1-2
cache-sa-enable
Multicast Protocol
6-1
car
QoS
2-6
car name
QoS
6-3
c-bsr
Multicast Protocol
5-2
c-bsr admin-scope
Multicast Protocol
5-3
c-bsr global
Multicast Protocol
5-4
c-bsr group
Multicast Protocol
5-5
c-bsr hash-length
Multicast Protocol
5-6
c-bsr holdtime
Multicast Protocol
5-6
c-bsr interval
Multicast Protocol
5-7
c-bsr priority
Multicast Protocol
5-8
cd
1-1
cd
2-6
cd
SSH
1-29
cdup
2-7
cdup
SSH
1-30
certificate request entity
PKI
1-3
certificate request from
PKI
1-3
certificate request mode
PKI
1-4
certificate request polling
PKI
1-5
certificate request url
PKI
1-6
check region-configuration
MSTP
1-1
checkzero
IPv4 Routing
2-1
checkzero
IPv6 Routing
2-1
ciphersuite
SSL-HTTPS
1-1
circuit-cost
IPv4 Routing
4-4
classifier behavior
QoS
2-17
client-verify enable
SSL-HTTPS
1-2
clock datetime
1-1
clock summer-time one-off
1-2
clock summer-time repeating
1-3
clock timezone
1-4
close
2-7
close-mode wait
SSL-HTTPS
1-2
cluster
Cluster Management
1-22
cluster enable
Cluster Management
1-23
cluster switch-to
Cluster Management
1-24
command-privilege
1-5
common-name
PKI
1-6
compare-different-as-med
IPv4 Routing
5-7
IPv6 Routing
5-4
confederation id
IPv4 Routing
5-8
confederation nonstandard
IPv4 Routing
5-9
confederation peer-as
IPv4 Routing
5-9
control-vlan
RRPP
1-1
copy
1-2
cost-style
IPv4 Routing
4-5
count
NQA
1-1
country
PKI
1-7
crl check
PKI
1-8
crl update-period
PKI
1-8
crl url
PKI
1-9
c-rp
Multicast Protocol
5-9
c-rp advertisement-interval
Multicast Protocol
5-10
c-rp holdtime
Multicast Protocol
5-11
crp-policy
Multicast Protocol
5-11
cut connection
AAA-RADIUS-HWTACACS
1-14
D
dampening
IPv4 Routing
5-10
dampening
IPv6 Routing
5-5
databits
Login
1-4
datafill
NQA
1-2
data-flow-format
AAA-RADIUS-HWTACACS
1-32
data-flow-format
AAA-RADIUS-HWTACACS
1-59
datasize
NQA
1-2
debugging
2-7
default
IPv4 Routing
3-5
default cost
IPv4 Routing
2-2
default cost
IPv6 Routing
2-2
default cost
IPv6 Routing
3-2
default ipv4-unicast
IPv4 Routing
5-11
default local-preference
IPv4 Routing
5-12
IPv6 Routing
5-6
default med
IPv4 Routing
5-13
default med
IPv6 Routing
5-6
default-cost
IPv4 Routing
3-6
default-cost
IPv6 Routing
3-3
default-route imported
IPv4 Routing
5-14
IPv6 Routing
5-7
default-route originate
IPv4 Routing
2-2
default-route-advertise
IPv4 Routing
3-7
IPv4 Routing
4-6
delete
1-2
delete
2-8
delete
SSH
1-30
delete ipv6 static-routes all
IPv6 Routing
1-1
delete static-routes all
IPv4 Routing
1-1
delete-member
Cluster Management
1-25
description
VLAN
1-1
description
1-2
description
IPv4 Routing
3-8
description
NQA
1-3
description
MCE
1-1
description (for IPv4)
ACL
1-7
description (for IPv6)
ACL
1-25
destination
IPv6
3-2
destination-ip
NQA
1-4
destination-port
NQA
1-5
dhcp enable
DHCP
1-2
dhcp enable
DHCP
2-1
dhcp relay address-check
DHCP
2-2
dhcp relay information enable
DHCP
2-2
dhcp relay information format
DHCP
2-3
dhcp relay information strategy
DHCP
2-4
dhcp relay release
DHCP
2-5
dhcp relay security static
DHCP
2-5
dhcp relay security tracker
DHCP
2-6
dhcp relay server-detect
DHCP
2-7
dhcp relay server-group
DHCP
2-7
dhcp relay server-select
DHCP
2-8
dhcp select relay
DHCP
2-9
dhcp select server global-pool
DHCP
1-3
dhcp server detect
DHCP
1-4
dhcp server forbidden-ip
DHCP
1-4
dhcp server ip-pool
DHCP
1-5
dhcp server ping packets
DHCP
1-6
dhcp server ping timeout
DHCP
1-7
dhcp server relay information enable
DHCP
1-7
dhcp-snooping
DHCP
4-1
dhcp-snooping information enable
DHCP
4-2
dhcp-snooping information format
DHCP
4-2
dhcp-snooping information strategy
DHCP
4-3
dhcp-snooping trust
DHCP
4-4
dir
1-3
dir
2-8
dir
SSH
1-31
disconnect
2-9
display acl
ACL
1-8
display acl ipv6
ACL
1-26
display arp
ARP
1-4
display arp ip-address
ARP
1-5
display arp source-suppression
ARP
1-10
display arp timer aging
ARP
1-6
display arp vpn-instance
ARP
1-6
display bfd interface
BFD-GR
1-6
display bfd paf
BFD-GR
1-8
display bfd session
BFD-GR
1-8
display bgp group
IPv4 Routing
5-15
display bgp ipv6 group
IPv6 Routing
5-8
display bgp ipv6 network
IPv6 Routing
5-9
display bgp ipv6 paths
IPv6 Routing
5-10
display bgp ipv6 peer
IPv6 Routing
5-11
display bgp ipv6 routing-table
IPv6 Routing
5-12
display bgp ipv6 routing-table as-path-acl
IPv6 Routing
5-15
display bgp ipv6 routing-table community
IPv6 Routing
5-15
display bgp ipv6 routing-table community-list
IPv6 Routing
5-16
display bgp ipv6 routing-table dampened
IPv6 Routing
5-17
display bgp ipv6 routing-table dampening parameter
IPv6 Routing
5-18
display bgp ipv6 routing-table different-origin-as
IPv6 Routing
5-19
display bgp ipv6 routing-table flap-info
IPv6 Routing
5-20
display bgp ipv6 routing-table peer
IPv6 Routing
5-21
display bgp ipv6 routing-table regular-expression
IPv6 Routing
5-22
display bgp ipv6 routing-table statistic
IPv6 Routing
5-23
display bgp network
IPv4 Routing
5-16
display bgp paths
IPv4 Routing
5-17
display bgp peer
IPv4 Routing
5-18
display bgp routing-table
IPv4 Routing
5-20
display bgp routing-table as-path-acl
IPv4 Routing
5-22
display bgp routing-table cidr
IPv4 Routing
5-23
display bgp routing-table community
IPv4 Routing
5-23
display bgp routing-table community-list
IPv4 Routing
5-24
display bgp routing-table dampened
IPv4 Routing
5-25
display bgp routing-table dampening parameter
IPv4 Routing
5-26
display bgp routing-table different-origin-as
IPv4 Routing
5-27
display bgp routing-table flap-info
IPv4 Routing
5-28
display bgp routing-table peer
IPv4 Routing
5-29
display bgp routing-table regular-expression
IPv4 Routing
5-30
display bgp routing-table statistic
IPv4 Routing
5-31
display bgp vpnv4 route-distinguisher routing-table
MCE
1-11
display bgp vpnv4 vpn-instance group
MCE
1-1
display bgp vpnv4 vpn-instance network
MCE
1-3
display bgp vpnv4 vpn-instance paths
MCE
1-4
display bgp vpnv4 vpn-instance peer
MCE
1-5
display bgp vpnv4 vpn-instance routing-table
MCE
1-8
display bgp vpnv4 vpn-instance routing-table label
MCE
1-10
display boot-loader
3-5
display bootp client
DHCP
5-1
display brief interface
1-3
display burst-traffic interface
QoS
5-2
display channel
Information Center
1-1
display clipboard
1-6
display clock
1-7
display cluster
Cluster Management
1-26
display cluster base-topology
Cluster Management
1-27
display cluster black-list
Cluster Management
1-29
display cluster candidates
Cluster Management
1-29
display cluster current-topology
Cluster Management
1-31
display cluster members
Cluster Management
1-33
display connection
AAA-RADIUS-HWTACACS
1-15
display cpu-usage
3-2
display current-configuration
1-8
display debugging
2-8
display debugging ospfv3
IPv6 Routing
3-4
display device
3-5
display device manuinfo
3-6
display dhcp client
DHCP
3-1
display dhcp relay
DHCP
2-10
display dhcp relay security
DHCP
2-10
display dhcp relay security statistics
DHCP
2-11
display dhcp relay security tracker
DHCP
2-12
display dhcp relay server-group
DHCP
2-13
display dhcp relay statistics
DHCP
2-13
display dhcp server conflict
DHCP
1-8
display dhcp server expired
DHCP
1-9
display dhcp server forbidden-ip
DHCP
1-10
display dhcp server free-ip
DHCP
1-10
display dhcp server ip-in-use
DHCP
1-11
display dhcp server statistics
DHCP
1-12
display dhcp server tree
DHCP
1-14
display dhcp-snooping
DHCP
4-5
display dhcp-snooping trust
DHCP
4-6
display diagnostic-information
1-10
display dldp
DLDP
1-1
display dldp statistics
DLDP
1-3
display dns domain
DNS
1-1
display dns dynamic-host
DNS
1-2
display dns ipv6 dynamic-host
IPv6
1-1
display dns ipv6 server
IPv6
1-2
display dns server
DNS
1-3
display domain
AAA-RADIUS-HWTACACS
1-16
display dot1x
802.1x-HABP-MAC Authentication
1-1
display fan
3-7
display fib
IP Addressing and Performance
2-1
display fib ip-address
2-3
display fib statistics
2-4
display fib vpn-instance
2-5
display flow-template interface
ACL
1-36
display flow-template user-defined
ACL
1-35
display ftp client configuration
2-10
display ftp-server
2-1
display ftp-user
2-1
display garp statistics
VLAN
3-1
display garp timer
VLAN
3-2
display gvrp local-vlan interface
VLAN
3-5
display gvrp state
VLAN
3-6
display gvrp statistics
VLAN
3-6
display gvrp status
VLAN
3-8
display gvrp vlan-operation interface
VLAN
3-8
display habp
3-1
display habp table
3-2
display habp traffic
3-2
display history-command
1-10
display hotkey
1-11
display hwtacacs
AAA-RADIUS-HWTACACS
1-60
display icmp statistics
2-6
display igmp group
Multicast Protocol
4-1
display igmp group port-info
Multicast Protocol
4-3
display igmp interface
Multicast Protocol
4-4
display igmp routing-table
Multicast Protocol
4-6
display igmp-snooping group
Multicast Protocol
1-1
display igmp-snooping statistics
Multicast Protocol
1-2
display info-center
Information Center
1-2
display interface
1-6
display interface tunnel
IPv6
3-3
display interface Vlan-interface
VLAN
1-2
display ip as-path
IPv4 Routing
6-10
display ip check source
IP Source Guard
1-3
display ip community-list
IPv4 Routing
6-11
display ip extcommunity-list
IPv4 Routing
6-12
display ip host
DNS
1-4
display ip https
SSL-HTTPS
2-1
display ip interface
1-1
display ip interface brief
1-3
display ip ip-prefix
IPv4 Routing
6-24
display ip ipv6-prefix
IPv6 Routing
6-2
display ip routing-table
Routing Overview
1-1
display ip routing-table acl
Routing Overview
1-5
display ip routing-table ip-address
Routing Overview
1-8
display ip routing-table ip-prefix
Routing Overview
1-10
display ip routing-table protocol
Routing Overview
1-12
display ip routing-table statistics
Routing Overview
1-13
display ip routing-table vpn-instance
MCE
1-12
display ip socket
2-7
display ip statistics
2-9
display ip vpn-instance
MCE
1-13
display ip-subnet-vlan interface
VLAN
1-21
display ip-subnet-vlan vlan
VLAN
1-22
display ipv6 fib
IPv6
1-3
display ipv6 fibcache
IPv6
1-4
display ipv6 host
IPv6
1-4
display ipv6 interface
IPv6
1-5
display ipv6 interface tunnel
IPv6
3-4
display ipv6 neighbors
IPv6
1-7
display ipv6 neighbors count
IPv6
1-9
display ipv6 pathmtu
IPv6
1-10
display ipv6 routing-table
Routing Overview
1-14
display ipv6 routing-table acl
Routing Overview
1-15
display ipv6 routing-table ipv6-address
Routing Overview
1-16
display ipv6 routing-table ipv6-address1 ipv6-address2
Routing Overview
1-18
display ipv6 routing-table ipv6-prefix
Routing Overview
1-19
display ipv6 routing-table protocol
Routing Overview
1-19
display ipv6 routing-table statistics
Routing Overview
1-20
display ipv6 routing-table verbose
Routing Overview
1-21
display ipv6 socket
IPv6
1-11
display ipv6 statistics
IPv6
1-12
display isis brief
IPv4 Routing
4-7
display isis graceful-restart status
IPv4 Routing
4-8
display isis interface
IPv4 Routing
4-10
display isis license
IPv4 Routing
4-12
display isis lsdb
IPv4 Routing
4-14
display isis mesh-group
IPv4 Routing
4-15
display isis name-table
IPv4 Routing
4-16
display isis peer
IPv4 Routing
4-17
display isis route
IPv4 Routing
4-19
display isis route ipv6
IPv6 Routing
4-1
display isis spf-log
IPv4 Routing
4-20
display isis statistics
IPv4 Routing
4-21
display lacp system-id
Link Aggregation
1-1
display link-aggregation interface
Link Aggregation
1-1
display link-aggregation service-type
Link Aggregation
1-3
display link-aggregation summary
Link Aggregation
1-4
display link-aggregation verbose
Link Aggregation
1-6
display local-proxy-arp
ARP
2-3
display local-user
AAA-RADIUS-HWTACACS
1-18
display logbuffer
Information Center
1-4
display logbuffer summary
Information Center
1-7
display loopback-detection
1-9
display mac-address
MAC Address Table Management
1-1
display mac-address aging-time
1-2
display mac-authentication
4-1
display memory
3-7
display mirroring-group
Port Mirroring
1-1
display mld-snooping group
Multicast Protocol
2-1
display mld-snooping statistics
Multicast Protocol
2-2
display msdp brief
Multicast Protocol
6-2
display msdp peer-status
Multicast Protocol
6-3
display msdp sa-cache
Multicast Protocol
6-5
display msdp sa-count
Multicast Protocol
6-7
display multicast boundary
Multicast Protocol
7-1
display multicast forwarding-table
Multicast Protocol
7-2
display multicast routing-table
Multicast Protocol
7-4
display multicast routing-table static
Multicast Protocol
7-6
display multicast rpf-info
Multicast Protocol
7-7
display multicast-vlan
Multicast Protocol
3-1
display ndp
Cluster Management
1-1
display nqa
NQA
1-5
display ntdp
Cluster Management
1-8
display ntdp device-list
Cluster Management
1-9
display ntdp single-device mac-address
Cluster Management
1-11
display ntp-service sessions
NTP
1-1
display ntp-service status
NTP
1-3
display ntp-service trace
NTP
1-4
display oam
OAM
1-1
display oam configuration
OAM
1-6
display oam critical-event
OAM
1-7
display oam link-event
OAM
1-8
display ospf abr-asbr
IPv4 Routing
3-9
display ospf asbr-summary
IPv4 Routing
3-10
display ospf brief
IPv4 Routing
3-11
display ospf cumulative
IPv4 Routing
3-14
display ospf error
IPv4 Routing
3-16
display ospf interface
IPv4 Routing
3-18
display ospf lsdb
IPv4 Routing
3-19
display ospf nexthop
IPv4 Routing
3-21
display ospf peer
IPv4 Routing
3-22
display ospf peer statistics
IPv4 Routing
3-24
display ospf request-queue
IPv4 Routing
3-26
display ospf retrans-queue
IPv4 Routing
3-27
display ospf routing
IPv4 Routing
3-28
display ospf vlink
IPv4 Routing
3-30
display ospfv3
IPv6 Routing
3-4
display ospfv3 interface
IPv6 Routing
3-6
display ospfv3 lsdb
IPv6 Routing
3-8
display ospfv3 lsdb statistic
IPv6 Routing
3-11
display ospfv3 next-hop
IPv6 Routing
3-12
display ospfv3 peer
IPv6 Routing
3-13
display ospfv3 peer statistic
IPv6 Routing
3-15
display ospfv3 request-list
IPv6 Routing
3-16
display ospfv3 retrans-list
IPv6 Routing
3-17
display ospfv3 routing
IPv6 Routing
3-19
display ospfv3 statistic
IPv6 Routing
3-20
display ospfv3 topology
IPv6 Routing
3-22
display ospfv3 vlink
IPv6 Routing
3-23
display pim bsr-info
Multicast Protocol
5-12
display pim claimed-route
Multicast Protocol
5-14
display pim control-message counters
Multicast Protocol
5-15
display pim grafts
Multicast Protocol
5-17
display pim interface
Multicast Protocol
5-18
display pim join-prune
Multicast Protocol
5-20
display pim neighbor
Multicast Protocol
5-21
display pim routing-table
Multicast Protocol
5-23
display pim rp-info
Multicast Protocol
5-26
display pki certificate
PKI
1-10
display pki certificate access-control-policy
PKI
1-11
display pki certificate attribute-group
PKI
1-12
display pki crl domain
PKI
1-13
display port
1-9
display port combo
1-10
display port-group manual
1-11
display port-isolate group
2-1
display power
3-8
display protocol-vlan interface
VLAN
1-15
display protocol-vlan vlan
VLAN
1-16
display proxy-arp
ARP
2-2
display public-key local
SSH
1-1
display public-key peer
SSH
1-2
display qos car interface
QoS
1-1
display qos car name
QoS
6-3
display qos gts interface
QoS
1-3
display qos map-table
QoS
4-1
display qos policy interface
QoS
2-18
display qos policy user-defined
QoS
2-17
display qos trust interface
QoS
4-4
display qos vlan-policy
QoS
7-1
display qos wred interface
QoS
5-2
display qos wrr interface
QoS
3-1
display radius scheme
AAA-RADIUS-HWTACACS
1-33
display radius statistics
AAA-RADIUS-HWTACACS
1-35
display reboot-type
3-9
display rip
IPv4 Routing
2-3
display rip database
IPv4 Routing
2-5
display rip interface
IPv4 Routing
2-6
display rip route
IPv4 Routing
2-7
display ripng
IPv6 Routing
2-2
display ripng database
IPv6 Routing
2-4
display ripng interface
IPv6 Routing
2-5
display ripng route
IPv6 Routing
2-6
display rmon alarm
SNMP-RMON
2-1
display rmon event
SNMP-RMON
2-2
display rmon eventlog
SNMP-RMON
2-3
display rmon history
SNMP-RMON
2-4
display rmon prialarm
SNMP-RMON
2-6
display rmon statistics
SNMP-RMON
2-7
display route-policy
IPv4 Routing
6-12
display rrpp brief
RRPP
1-1
display rrpp statistics
RRPP
1-3
display rrpp verbose
RRPP
1-6
display saved-configuration
1-12
display schedule reboot
3-9
display sftp client source
SSH
1-3
display snmp-agent community
SNMP-RMON
1-1
display snmp-agent group
SNMP-RMON
1-2
display snmp-agent local-engineid
SNMP-RMON
1-1
display snmp-agent mib-view
SNMP-RMON
1-3
display snmp-agent statistics
SNMP-RMON
1-5
display snmp-agent sys-info
SNMP-RMON
1-7
display snmp-agent trap-list
SNMP-RMON
1-8
display snmp-agent usm-user
SNMP-RMON
1-9
display ssh client source
SSH
1-4
display ssh server
SSH
1-5
display ssh server-info
SSH
1-6
display ssh user-information
SSH
1-7
display ssl client-policy
SSL-HTTPS
1-3
display ssl server-policy
SSL-HTTPS
1-4
display startup
1-15
display stop-accounting-buffer
AAA-RADIUS-HWTACACS
1-38
AAA-RADIUS-HWTACACS
1-62
display stp
MSTP
1-3
display stp abnormal-port
MSTP
1-5
MSTP
1-6
display stp down-port
MSTP
1-7
display stp history
MSTP
1-8
display stp region-configuration
MSTP
1-9
display stp root
MSTP
1-10
display stp tc
MSTP
1-11
display switch-mode
IPv6
2-1
display tcp ipv6 statistics
IPv6
1-16
display tcp ipv6 status
IPv6
1-19
display tcp statistics
2-11
display tcp status
2-14
display telnet client configuration
Login
1-5
display tftp client configuration
3-1
display this
1-12
display time-range
ACL
1-1
display traffic behavior
QoS
2-7
display traffic classifier
QoS
2-1
display transceiver alarm interface
3-10
display transceiver diagnosis interface
3-13
display transceiver interface
3-14
display transceiver manuinfo interface
3-16
display trapbuffer
Information Center
1-8
display udp ipv6 statistics
IPv6
1-20
display udp statistics
2-15
display udp-helper server
UDP Helper
1-1
display user-bind
IP Source Guard
1-1
display user-interface
Login
1-6
display users
Login
1-7
display version
1-13
display vlan
VLAN
1-3
display voice vlan oui
VLAN
2-1
display voice vlan state
VLAN
2-2
display vrrp
VRRP
1-1
display vrrp ipv6
VRRP
1-14
display vrrp ipv6 statistics
VRRP
1-16
display vrrp statistics
VRRP
1-3
display web users
Login
1-9
dldp authentication-mode
DLDP
1-4
dldp delaydown-timer
DLDP
1-5
dldp enable
DLDP
1-6
dldp interval
DLDP
1-7
dldp reset
DLDP
1-8
dldp unidirectional-shutdown
DLDP
1-9
dldp work-mode
DLDP
1-9
dns domain
DNS
1-5
dns resolve
DNS
1-5
dns server
DNS
1-6
dns server ipv6
IPv6
1-21
dns-list
DHCP
1-15
domain
AAA-RADIUS-HWTACACS
1-19
domain default
AAA-RADIUS-HWTACACS
1-20
domain-authentication-mode
IPv4 Routing
4-23
domain-id
MCE
1-15
domain-name
DHCP
1-16
dot1x
1-4
dot1x authentication-method
1-6
dot1x free-ip
2-1
dot1x guest-vlan
1-7
dot1x handshake
1-8
dot1x max-user
1-9
dot1x multicast-trigger
1-10
dot1x port-control
1-11
dot1x port-method
1-12
dot1x quiet-period
1-13
dot1x retry
1-14
dot1x supp-proxy-check
1-14
dot1x timer
1-16
dot1x timer ead-timeout
2-2
dot1x url
2-2
duplex
1-13
E
ebgp-interface-sensitive
IPv4 Routing
5-31
enable link-local-signaling
IPv4 Routing
3-31
enable log
IPv4 Routing
3-31
enable out-of-band-resynchronization
IPv4 Routing
3-32
enable snmp trap updown
SNMP-RMON
1-10
encap-data-enable
Multicast Protocol
6-8
escape-key
Login
1-9
execute
1-4
exit
SSH
1-32
expediting enable
IPv6
3-6
expediting subnet
IPv6
3-6
expired
DHCP
1-17
export route-policy
MCE
1-15
F
fast-leave
Multicast Protocol
1-3
fast-leave
Multicast Protocol
2-3
fast-leave
Multicast Protocol
4-7
file prompt
1-5
filename
NQA
1-10
filter
IPv4 Routing
3-33
filter
QoS
2-8
filter-policy export
IPv4 Routing
2-10
IPv4 Routing
3-34
IPv4 Routing
4-24
IPv4 Routing
5-32
IPv6 Routing
2-7
IPv6 Routing
3-24
IPv6 Routing
5-23
MCE
1-16
filter-policy import
IPv4 Routing
2-11
IPv4 Routing
3-35
IPv4 Routing
4-25
IPv4 Routing
5-33
IPv6 Routing
2-8
IPv6 Routing
3-25
IPv6 Routing
5-24
MCE
1-17
fixdisk
1-5
flash-flood
IPv4 Routing
4-26
flow-control
Login
1-11
flow-control
1-13
flow-interval
1-14
flow-template
ACL
1-37
flow-template basic
ACL
1-38
flow-template extend
ACL
1-40
format
1-6
fqdn
PKI
1-15
free ftp user
2-2
free user-interface
Login
1-11
free web-users
Login
2-2
frequency
NQA
1-11
ftp
2-11
ftp client source
2-12
ftp ipv6
2-13
ftp server enable
2-3
ftp timeout
2-3
ftp update
2-4
ftp-operation
NQA
1-12
ftp-server
Cluster Management
1-35
G
garp timer
VLAN
3-2
garp timer leaveall
VLAN
3-4
gateway-list
DHCP
1-17
get
2-14
get
SSH
1-33
graceful-restart
IPv4 Routing
3-35
graceful-restart
IPv4 Routing
4-27
graceful-restart
IPv4 Routing
5-34
graceful-restart help
IPv4 Routing
3-36
graceful-restart interval
IPv4 Routing
3-37
IPv4 Routing
4-28
graceful-restart suppress-sa
IPv4 Routing
4-28
graceful-restart timer restart
IPv4 Routing
5-35
graceful-restart timer wait-for-rib
IPv4 Routing
5-35
gratuitous-arp-learning enable
ARP
1-8
gratuitous-arp-sending enable
ARP
1-8
group
IPv4 Routing
5-36
group
IPv6 Routing
5-25
group-member
1-15
group-policy
Multicast Protocol
1-4
group-policy
Multicast Protocol
2-4
gvrp
VLAN
3-9
gvrp registration
VLAN
3-10
H
habp enable
3-3
habp server vlan
3-4
habp timer
3-4
handshake timeout
SSL-HTTPS
1-5
header
1-14
hello-option dr-priority
Multicast Protocol
5-27
hello-option holdtime
Multicast Protocol
5-28
hello-option lan-delay
Multicast Protocol
5-28
hello-option neighbor-tracking
Multicast Protocol
5-29
hello-option override-interval
Multicast Protocol
5-30
help
SSH
1-33
history-command max-size
Login
1-12
history-records
NQA
1-12
holdtime
Cluster Management
1-36
holdtime assert
Multicast Protocol
5-30
holdtime join-prune
Multicast Protocol
5-31
host-advertise
IPv4 Routing
3-38
host-aging-time
Multicast Protocol
1-5
host-aging-time
Multicast Protocol
2-5
host-route
IPv4 Routing
2-11
hotkey
1-16
http-operation
NQA
1-13
http-string
NQA
1-14
hwtacacs nas-ip
AAA-RADIUS-HWTACACS
1-63
hwtacacs scheme
AAA-RADIUS-HWTACACS
1-64
I
idle-cut
AAA-RADIUS-HWTACACS
1-21
idle-timeout
Login
1-13
if-match
QoS
2-2
if-match acl
IPv4 Routing
6-25
if-match as-path
IPv4 Routing
6-13
if-match community
IPv4 Routing
6-14
if-match cost
IPv4 Routing
6-15
if-match extcommunity
IPv4 Routing
6-16
if-match interface
IPv4 Routing
6-16
if-match ip
IPv4 Routing
6-26
if-match ip-prefix
IPv4 Routing
6-26
if-match ipv6
IPv6 Routing
6-3
if-match route-type
IPv4 Routing
6-17
if-match tag
IPv4 Routing
6-18
igmp
Multicast Protocol
4-8
igmp enable
Multicast Protocol
4-9
igmp fast-leave
Multicast Protocol
4-9
igmp group-policy
Multicast Protocol
4-10
igmp last-member-query-interval
Multicast Protocol
4-11
igmp max-response-time
Multicast Protocol
4-12
igmp require-router-alert
Multicast Protocol
4-13
igmp robust-count
Multicast Protocol
4-14
igmp send-router-alert
Multicast Protocol
4-14
igmp static-group
Multicast Protocol
4-15
igmp timer other-querier-present
Multicast Protocol
4-16
igmp timer query
Multicast Protocol
4-17
igmp version
Multicast Protocol
4-18
igmp-snooping
Multicast Protocol
1-6
igmp-snooping drop-unknown
Multicast Protocol
1-7
igmp-snooping enable
Multicast Protocol
1-7
igmp-snooping fast-leave
Multicast Protocol
1-8
igmp-snooping general-query source-ip
Multicast Protocol
1-9
igmp-snooping group-limit
Multicast Protocol
1-10
igmp-snooping group-policy
Multicast Protocol
1-11
igmp-snooping host-aging-time
Multicast Protocol
1-12
igmp-snooping host-join
Multicast Protocol
1-13
igmp-snooping last-member-query-interval
Multicast Protocol
1-14
igmp-snooping max-response-time
Multicast Protocol
1-15
igmp-snooping overflow-replace
Multicast Protocol
1-16
igmp-snooping querier
Multicast Protocol
1-17
igmp-snooping query-interval
Multicast Protocol
1-17
igmp-snooping router-aging-time
Multicast Protocol
1-18
igmp-snooping special-query source-ip
Multicast Protocol
1-19
igmp-snooping static-group
Multicast Protocol
1-20
igmp-snooping static-router-port
Multicast Protocol
1-21
igmp-snooping version
Multicast Protocol
1-22
import
QoS
4-3
import route-policy
MCE
1-18
import-route
IPv4 Routing
2-12
import-route
IPv4 Routing
3-38
import-route
IPv4 Routing
4-29
import-route
IPv4 Routing
5-37
import-route
IPv6 Routing
2-9
import-route
IPv6 Routing
3-26
import-route
IPv6 Routing
5-26
import-route isis level-2 into level-1
IPv4 Routing
4-31
import-source
Multicast Protocol
6-9
info-center channel name
Information Center
1-9
info-center console channel
Information Center
1-10
info-center enable
Information Center
1-11
info-center logbuffer
Information Center
1-11
info-center loghost
Information Center
1-12
info-center loghost source
Information Center
1-13
info-center monitor channel
Information Center
1-14
info-center snmp channel
Information Center
1-15
info-center source
Information Center
1-16
info-center synchronous
Information Center
1-18
info-center timestamp
Information Center
1-19
info-center timestamp loghost
Information Center
1-20
info-center trapbuffer
Information Center
1-20
instance
MSTP
1-12
interface
1-15
interface tunnel
IPv6
3-7
VLAN
1-4
ip (PKI entity view)
PKI
1-15
ip address
VLAN
1-5
ip address
1-4
ip address bootp-alloc
DHCP
5-2
ip address dhcp-alloc
DHCP
3-3
ip address unnumbered
1-5
ip as-path
IPv4 Routing
6-19
ip binding vpn-instance
MCE
1-19
ip check source
IP Source Guard
1-4
ip community-list
IPv4 Routing
6-20
IPv4 Routing
6-21
ip forward-broadcast (interface view)
2-16
ip forward-broadcast (system view)
2-17
ip host
DNS
1-7
ip http acl
Login
2-2
ip http enable
Login
1-14
ip https acl
SSL-HTTPS
2-2
ip https certificate access-control-policy
SSL-HTTPS
2-2
ip https enable
SSL-HTTPS
2-3
ip https ssl-server-policy
SSL-HTTPS
2-4
ip ip-prefix
IPv4 Routing
6-27
ip ipv6-prefix
IPv6 Routing
6-4
ip redirects enable
2-18
ip route-static
IPv4 Routing
1-2
ip route-static default-preference
IPv4 Routing
1-5
ip rpf-route-static
Multicast Protocol
7-9
ip ttl-expires enable
2-18
ip unreachables enable
2-19
ip vpn-instance
MCE
1-19
ip-pool
Cluster Management
1-37
ip-subnet-vlan
VLAN
1-22
ipv4-family vpn-instance
MCE
1-20
ipv6
IPv6
1-22
ipv6
IPv6
2-1
ipv6 address
IPv6
1-22
ipv6 address
IPv6
2-2
ipv6 address auto link-local
IPv6
1-23
IPv6
2-3
ipv6 address eui-64
IPv6
1-24
ipv6 address eui-64
IPv6
2-3
ipv6 address link-local
IPv6
1-24
IPv6
2-4
ipv6 default-route-advertise
IPv6 Routing
4-3
ipv6 enable
IPv6 Routing
4-4
ipv6 fibcache
IPv6
1-25
ipv6 fib-loadbalance-type hash-based
IPv6
1-25
ipv6 filter-policy export
IPv6 Routing
4-5
ipv6 filter-policy import
IPv6 Routing
4-6
ipv6 host
IPv6
1-26
ipv6 icmp-error
IPv6
1-27
IPv6
1-27
ipv6 import-route
IPv6 Routing
4-7
ipv6 import-route isisv6 level-2 into level-1
IPv6 Routing
4-8
ipv6 maximum load-balancing
IPv6 Routing
4-9
IPv6
1-28
ipv6 nd autoconfig other-flag
IPv6
1-29
ipv6 nd dad attempts
IPv6
1-29
ipv6 nd hop-limit
IPv6
1-30
ipv6 nd ns retrans-timer
IPv6
1-31
ipv6 nd nud reachable-time
IPv6
1-31
ipv6 nd ra halt
IPv6
1-32
ipv6 nd ra interval
IPv6
1-33
ipv6 nd ra prefix
IPv6
1-34
ipv6 nd ra router-lifetime
IPv6
1-35
ipv6 neighbor
IPv6
1-35
ipv6 neighbors max-learning-num
IPv6
1-36
ipv6 pathmtu
IPv6
1-37
ipv6 pathmtu age
IPv6
1-38
ipv6 preference
IPv6 Routing
4-10
ipv6 route-static
IPv6 Routing
1-2
ipv6 summary
IPv6 Routing
4-11
ipv6-family
IPv6 Routing
5-26
isis
IPv4 Routing
4-32
isis authentication-mode
IPv4 Routing
4-33
isis circuit-level
IPv4 Routing
4-34
isis circuit-type
IPv4 Routing
4-35
isis cost
IPv4 Routing
4-36
isis dis-name
IPv4 Routing
4-36
isis dis-priority
IPv4 Routing
4-37
isis enable
IPv4 Routing
4-38
isis ipv6 enable
IPv6 Routing
4-12
isis mesh-group
IPv4 Routing
4-39
isis silent
IPv4 Routing
4-40
isis small-hello
IPv4 Routing
4-41
isis timer csnp
IPv4 Routing
4-41
isis timer hello
IPv4 Routing
4-42
isis timer holding-multiplier
IPv4 Routing
4-43
isis timer lsp
IPv4 Routing
4-45
isis timer retransmit
IPv4 Routing
4-45
is-level
IPv4 Routing
4-46
is-name
IPv4 Routing
4-47
is-name map
IPv4 Routing
4-48
is-snmp-traps enable
IPv4 Routing
4-48
J
jitter-interval
NQA
1-16
jitter-packetnum
NQA
1-17
jp-pkt-size
Multicast Protocol
5-32
jp-queue-size
Multicast Protocol
5-32
jumboframe enable
1-16
K
key
AAA-RADIUS-HWTACACS
1-39
key
AAA-RADIUS-HWTACACS
1-64
L
lacp port-priority
Link Aggregation
1-8
lacp system-priority
Link Aggregation
1-8
last-listener-query-interval
Multicast Protocol
2-6
Multicast Protocol
1-22
Multicast Protocol
4-18
lcd
2-15
ldap-server
PKI
1-16
level
AAA-RADIUS-HWTACACS
1-22
link-aggregation group description
Link Aggregation
1-9
link-aggregation group mode
Link Aggregation
1-9
link-aggregation group service-type
Link Aggregation
1-10
locality
PKI
1-16
local-proxy-arp enable
ARP
2-1
local-user
AAA-RADIUS-HWTACACS
1-22
local-user password-display-mode
AAA-RADIUS-HWTACACS
1-23
lock
Login
1-14
logging-host
Cluster Management
1-38
log-peer-change
IPv4 Routing
3-40
log-peer-change
IPv4 Routing
4-49
log-peer-change
IPv4 Routing
5-38
log-peer-change
IPv6 Routing
3-27
loopback
1-16
loopback-detection control enable
1-17
loopback-detection enable
1-18
loopback-detection interval-time
1-19
loopback-detection per-vlan enable
1-20
ls
2-15
ls
SSH
1-34
lsa-arrival-interval
IPv4 Routing
3-41
lsa-generation-interval
IPv4 Routing
3-41
lsdb-overflow-limit
IPv4 Routing
3-42
lsp-fragments-extend
IPv4 Routing
4-50
lsp-length originate
IPv4 Routing
4-51
lsp-length receive
IPv4 Routing
4-51
M
mac-address (Ethernet port view)
1-3
mac-address (System view)
1-4
mac-address max-mac-count
1-5
mac-address timer
1-6
mac-authentication
4-3
mac-authentication domain
4-4
mac-authentication timer
4-5
mac-authentication user-name-format
4-6
mac-mirroring
QinQ-BPDU Tunneling
1-1
management-vlan
Cluster Management
1-39
IPv4 Routing
2-14
IPv4 Routing
3-43
IPv4 Routing
4-52
IPv6 Routing
2-10
IPv6 Routing
3-28
maximum-routes
IPv4 Routing
3-44
max-response-time
Multicast Protocol
1-23
max-response-time
Multicast Protocol
2-6
max-response-time
Multicast Protocol
4-19
mdi
1-21
mirroring-group
Port Mirroring
1-2
mirroring-group mirroring-port
Port Mirroring
1-3
mirroring-group monitor-port
Port Mirroring
1-4
mirroring-group reflector-port
Port Mirroring
1-5
mirroring-group remote-probe vlan
Port Mirroring
1-7
mirroring-port
Port Mirroring
1-8
mirror-to cpu
QoS
8-1
mirror-to interface
QoS
8-1
mkdir
1-7
mkdir
2-17
mkdir
SSH
1-35
mld-snooping
Multicast Protocol
2-7
mld-snooping drop-unknown
Multicast Protocol
2-8
mld-snooping enable
Multicast Protocol
2-8
mld-snooping fast-leave
Multicast Protocol
2-9
mld-snooping general-query source-ip
Multicast Protocol
2-10
mld-snooping group-limit
Multicast Protocol
2-11
mld-snooping group-policy
Multicast Protocol
2-12
mld-snooping host-aging-time
Multicast Protocol
2-13
mld-snooping host-join
Multicast Protocol
2-14
mld-snooping last-listener-query-interval
Multicast Protocol
2-15
mld-snooping max-response-time
Multicast Protocol
2-16
mld-snooping overflow-replace
Multicast Protocol
2-16
mld-snooping querier
Multicast Protocol
2-17
mld-snooping query-interval
Multicast Protocol
2-18
mld-snooping router-aging-time
Multicast Protocol
2-19
mld-snooping special-query source-ip
Multicast Protocol
2-19
mld-snooping static-group
Multicast Protocol
2-20
mld-snooping static-router-port
Multicast Protocol
2-22
mld-snooping version
Multicast Protocol
2-22
monitor-port
Port Mirroring
1-8
more
1-7
move
1-8
msdp
Multicast Protocol
6-10
mtracert
Multicast Protocol
7-10
mtu (tunnel interface view)
IPv6
3-8
multicast boundary
Multicast Protocol
7-12
multicast forwarding-table downstream-limit
Multicast Protocol
7-13
multicast forwarding-table route-limit
Multicast Protocol
7-14
multicast load-splitting
Multicast Protocol
7-15
multicast longest-match
Multicast Protocol
7-15
multicast routing-enable
Multicast Protocol
7-16
multicast-vlan enable
Multicast Protocol
3-1
multicast-vlan subvlan
Multicast Protocol
3-2
N
nas-ip
AAA-RADIUS-HWTACACS
1-40
nas-ip
AAA-RADIUS-HWTACACS
1-65
nbns-list
DHCP
1-18
ndp enable
Cluster Management
1-5
ndp timer aging
Cluster Management
1-6
ndp timer hello
Cluster Management
1-7
nest
QoS
2-9
netbios-type
DHCP
1-19
network
IPv4 Routing
2-14
network
IPv4 Routing
3-44
network
IPv4 Routing
5-39
network
IPv6 Routing
5-27
network
DHCP
1-20
network-entity
IPv4 Routing
4-53
nm-interface vlan-interface
Cluster Management
1-39
nqa
NQA
1-14
nqa-agent enable
NQA
1-15
nqa-agent max-requests
NQA
1-16
nqa-server enable
NQA
1-29
nqa-server tcpconnect
NQA
1-30
nqa-server udpecho
NQA
1-31
nssa
IPv4 Routing
3-45
ntdp enable
Cluster Management
1-12
ntdp explore
Cluster Management
1-13
ntdp hop
Cluster Management
1-14
ntdp timer
Cluster Management
1-15
ntdp timer hop-delay
Cluster Management
1-15
ntdp timer port-delay
Cluster Management
1-16
ntp-service access
NTP
1-5
ntp-service authentication enable
NTP
1-6
ntp-service authentication-keyid
NTP
1-7
ntp-service broadcast-client
NTP
1-8
ntp-service broadcast-server
NTP
1-9
ntp-service in-interface disable
NTP
1-9
ntp-service max-dynamic-sessions
NTP
1-10
ntp-service multicast-client
NTP
1-11
ntp-service multicast-server
NTP
1-11
ntp-service reliable authentication-keyid
NTP
1-12
ntp-service source-interface
NTP
1-13
ntp-service unicast-peer
NTP
1-14
ntp-service unicast-server
NTP
1-15
O
oam enable
OAM
1-11
oam errored-frame period
OAM
1-11
oam errored-frame threshold
OAM
1-12
oam errored-frame-period period
OAM
1-13
oam errored-frame-period threshold
OAM
1-14
oam errored-frame-seconds period
OAM
1-15
oam errored-frame-seconds threshold
OAM
1-15
oam errored-symbol period
OAM
1-16
oam errored-symbol threshold
OAM
1-17
oam loopback
OAM
1-18
oam mode
OAM
1-19
opaque-capability enable
IPv4 Routing
3-46
open
2-17
open ipv6
2-18
option
DHCP
1-21
organization
PKI
1-17
organizational-unit
PKI
1-18
originating-rp
Multicast Protocol
6-10
ospf
IPv4 Routing
3-47
ospf authentication-mode
IPv4 Routing
3-47
ospf cost
IPv4 Routing
3-49
ospf dr-priority
IPv4 Routing
3-50
ospf mib-binding
IPv4 Routing
3-51
ospf mtu-enable
IPv4 Routing
3-51
ospf network-type
IPv4 Routing
3-52
ospf timer dead
IPv4 Routing
3-53
ospf timer hello
IPv4 Routing
3-54
ospf timer poll
IPv4 Routing
3-55
ospf timer retransmit
IPv4 Routing
3-55
ospf trans-delay
IPv4 Routing
3-56
ospfv3
IPv6 Routing
3-29
ospfv3 area
IPv6 Routing
3-29
ospfv3 cost
IPv6 Routing
3-30
ospfv3 dr-priority
IPv6 Routing
3-31
ospfv3 mtu-ignore
IPv6 Routing
3-31
ospfv3 timer dead
IPv6 Routing
3-32
ospfv3 timer hello
IPv6 Routing
3-33
ospfv3 timer retransmit
IPv6 Routing
3-34
ospfv3 trans-delay
IPv6 Routing
3-34
overflow-replace
Multicast Protocol
1-24
overflow-replace
Multicast Protocol
2-23
P
parity
Login
1-15
passive
2-19
password
AAA-RADIUS-HWTACACS
1-24
password
NQA
1-18
peer
IPv4 Routing
2-15
peer
IPv4 Routing
3-57
peer advertise-community
IPv4 Routing
5-40
IPv6 Routing
5-28
peer advertise-ext-community
IPv4 Routing
5-41
IPv6 Routing
5-29
peer allow-as-loop
IPv4 Routing
5-42
peer allow-as-loop
IPv6 Routing
5-29
peer allow-as-loop
MCE
1-21
peer as-number
IPv4 Routing
5-43
peer as-number
IPv6 Routing
5-30
peer as-path-acl
IPv4 Routing
5-43
peer as-path-acl
IPv6 Routing
5-31
peer capability-advertise conventional
IPv4 Routing
5-44
peer capability-advertise route-refresh
IPv4 Routing
5-45
IPv6 Routing
5-32
peer connect-interface
IPv4 Routing
5-46
IPv6 Routing
5-32
Multicast Protocol
6-11
peer default-route-advertise
IPv4 Routing
5-47
IPv6 Routing
5-33
peer description
IPv4 Routing
5-48
peer description
IPv6 Routing
5-34
peer description
Multicast Protocol
6-12
peer ebgp-max-hop
IPv4 Routing
5-49
peer ebgp-max-hop
IPv6 Routing
5-35
peer enable
IPv4 Routing
5-50
peer fake-as
IPv4 Routing
5-50
peer fake-as
IPv6 Routing
5-36
peer filter-policy
IPv4 Routing
5-51
peer filter-policy
IPv6 Routing
5-36
peer group
IPv4 Routing
5-52
peer group
IPv6 Routing
5-37
peer group
MCE
1-21
peer ignore
IPv4 Routing
5-53
peer ignore
IPv6 Routing
5-38
peer ip-prefix
IPv4 Routing
5-54
peer ipv6-prefix
IPv6 Routing
5-39
peer keep-all-routes
IPv4 Routing
5-55
IPv6 Routing
5-39
peer log-change
IPv4 Routing
5-56
peer log-change
IPv6 Routing
5-40
peer mesh-group
Multicast Protocol
6-12
peer minimum-ttl
Multicast Protocol
6-13
peer next-hop-local
IPv4 Routing
5-56
peer next-hop-local
IPv6 Routing
5-41
peer password
IPv4 Routing
5-57
peer preferred-value
IPv4 Routing
5-58
IPv6 Routing
5-41
peer public-as-only
IPv4 Routing
5-60
peer public-as-only
IPv6 Routing
5-42
peer reflect-client
IPv4 Routing
5-60
peer reflect-client
IPv6 Routing
5-43
peer request-sa-enable
Multicast Protocol
6-14
peer route-limit
IPv4 Routing
5-61
peer route-limit
IPv6 Routing
5-44
peer route-policy
IPv4 Routing
5-62
peer route-policy
IPv6 Routing
5-45
peer route-update-interval
IPv4 Routing
5-63
IPv6 Routing
5-46
peer sa-cache-maximum
Multicast Protocol
6-15
peer sa-policy
Multicast Protocol
6-15
peer sa-request-policy
Multicast Protocol
6-16
peer substitute-as
IPv4 Routing
5-64
peer substitute-as
IPv6 Routing
5-46
peer timer
IPv4 Routing
5-65
peer timer
IPv6 Routing
5-47
peer-public-key end
SSH
1-8
pim
Multicast Protocol
5-33
pim bsr-boundary
Multicast Protocol
5-34
pim dm
Multicast Protocol
5-35
pim hello-option dr-priority
Multicast Protocol
5-35
pim hello-option holdtime
Multicast Protocol
5-36
pim hello-option lan-delay
Multicast Protocol
5-37
pim hello-option neighbor-tracking
Multicast Protocol
5-37
pim hello-option override-interval
Multicast Protocol
5-38
pim holdtime assert
Multicast Protocol
5-39
pim holdtime join-prune
Multicast Protocol
5-39
pim require-genid
Multicast Protocol
5-40
pim sm
Multicast Protocol
5-41
pim state-refresh-capable
Multicast Protocol
5-41
pim timer graft-retry
Multicast Protocol
5-42
pim timer hello
Multicast Protocol
5-42
pim timer join-prune
Multicast Protocol
5-43
pim triggered-hello-delay
Multicast Protocol
5-44
ping
2-1
ping ipv6
2-3
PKI
1-18
PKI
1-19
pki delete-certificate
PKI
1-20
pki domain
PKI
1-20
pki entity
PKI
1-21
pki import-certificate
PKI
1-22
pki request-certificate domain
PKI
1-22
pki retrieval-certificate
PKI
1-23
pki retrieval-crl domain
PKI
1-24
pki validate-certificate
PKI
1-24
pki-domain
SSL-HTTPS
1-6
port
VLAN
1-8
port access vlan
VLAN
1-9
port hybrid ip-subnet-vlan vlan
VLAN
1-23
port hybrid protocol-vlan
VLAN
1-17
port hybrid pvid vlan
VLAN
1-10
port hybrid vlan
VLAN
1-11
port link-aggregation group
Link Aggregation
1-11
port link-type
VLAN
1-12
port trunk permit vlan
VLAN
1-13
port trunk pvid vlan
VLAN
1-14
port-group
1-21
port-group aggregation
Link Aggregation
1-12
port-isolate enable
2-2
port-isolate uplink-port
2-3
prefer-cipher
SSL-HTTPS
1-6
preference
IPv4 Routing
2-16
preference
IPv4 Routing
3-58
preference
IPv4 Routing
4-54
preference
IPv4 Routing
5-66
preference
IPv6 Routing
2-10
preference
IPv6 Routing
3-35
preference
IPv6 Routing
5-48
primap
QoS
2-10
primary accounting
AAA-RADIUS-HWTACACS
1-41
primary accounting
AAA-RADIUS-HWTACACS
1-66
primary authentication
AAA-RADIUS-HWTACACS
1-42
AAA-RADIUS-HWTACACS
1-67
primary authorization
AAA-RADIUS-HWTACACS
1-68
probe-failtimes
NQA
1-18
probe-interval
Multicast Protocol
5-44
protocol inbound
Login
1-16
protocol-vlan
VLAN
1-18
proxy-arp enable
ARP
2-1
public-key local create
SSH
1-10
public-key local destroy
SSH
1-11
public-key local export rsa
SSH
1-11
public-key peer
SSH
1-13
public-key peer import sshkey
SSH
1-13
public-key-code begin
SSH
1-8
public-key-code end
SSH
1-9
put
2-19
put
SSH
1-35
pwd
1-8
pwd
2-20
pwd
SSH
1-36
Q
qinq enable
QinQ-BPDU Tunneling
1-3
qinq ethernet-type
QinQ-BPDU Tunneling
1-4
qinq vid
QinQ-BPDU Tunneling
1-6
qos apply policy
QoS
2-20
qos car
QoS
1-2
qos car
QoS
6-2
qos car aggregative
QoS
6-1
qos gts
QoS
1-4
qos map-table
QoS
4-2
qos policy
QoS
2-20
qos priority
QoS
4-3
qos trust
QoS
4-5
qos vlan-policy
QoS
7-2
qos wred enable
QoS
5-3
qos wrr
QoS
3-2
2-20
1-18
SSH
1-36
R
radius client
AAA-RADIUS-HWTACACS
1-43
radius nas-ip
AAA-RADIUS-HWTACACS
1-44
radius scheme
AAA-RADIUS-HWTACACS
1-45
radius trap
AAA-RADIUS-HWTACACS
1-46
raw-vlan-id inbound
QinQ-BPDU Tunneling
1-2
reboot
3-17
reboot member
Cluster Management
1-40
redirect
QoS
2-10
reflect between-clients
IPv4 Routing
5-67
IPv6 Routing
5-49
reflector cluster-id
IPv4 Routing
5-67
IPv6 Routing
5-50
refresh bgp
IPv4 Routing
5-68
refresh bgp ipv6
IPv6 Routing
5-50
refresh bgp vpn-instance
MCE
1-22
region-name
MSTP
1-13
register-policy
Multicast Protocol
5-45
register-suppression-timeout
Multicast Protocol
5-46
register-whole-checksum
Multicast Protocol
5-46
remark dot1p
QoS
2-11
remark drop-precedence
QoS
2-12
remark dscp
QoS
2-13
remark ip-precedence
QoS
2-14
remark local-precedence
QoS
2-15
remark service-vlan-id
QoS
2-15
remotehelp
2-21
remove
SSH
1-37
rename
1-9
rename
SSH
1-37
report-aggregation
Multicast Protocol
1-25
report-aggregation
Multicast Protocol
2-24
Multicast Protocol
4-20
reset acl counter
ACL
1-9
reset acl ipv6 counter
ACL
1-27
reset arp
ARP
1-7
reset bfd session statistics
BFD-GR
1-10
reset bgp
IPv4 Routing
5-69
reset bgp dampening
IPv4 Routing
5-70
reset bgp flap-info
IPv4 Routing
5-70
reset bgp ipv4 all
IPv4 Routing
5-71
reset bgp ipv6
IPv6 Routing
5-51
reset bgp ipv6 dampening
IPv6 Routing
5-52
reset bgp ipv6 flap-info
IPv6 Routing
5-52
reset bgp vpn-instance
MCE
1-23
reset bgp vpn-instance dampening
MCE
1-23
reset bgp vpn-instance flap-info
MCE
1-24
reset counters interface
1-22
reset dhcp relay statistics
DHCP
2-15
reset dhcp server conflict
DHCP
1-21
reset dhcp server ip-in-use
DHCP
1-22
reset dhcp server statistics
DHCP
1-23
reset dhcp-snooping
DHCP
4-7
reset dldp statistics
DLDP
1-10
reset dns dynamic-host
DNS
1-7
reset dns ipv6 dynamic-host
IPv6
1-38
reset dot1x statistics
1-17
reset garp statistics
VLAN
3-5
reset hwtacacs statistics
AAA-RADIUS-HWTACACS
1-69
reset igmp group
Multicast Protocol
4-20
reset igmp-snooping group
Multicast Protocol
1-25
reset igmp-snooping statistics
Multicast Protocol
1-26
reset ip ip-prefix
IPv4 Routing
6-29
reset ip ipv6-prefix
IPv6 Routing
6-5
reset ip routing-table statistics protocol
Routing Overview
1-22
reset ip statistics
2-19
reset ipv6 fibcache
IPv6
1-39
reset ipv6 neighbors
IPv6
1-39
reset ipv6 pathmtu
IPv6
1-40
reset ipv6 routing-table statistics
Routing Overview
1-23
reset ipv6 statistics
IPv6
1-40
reset isis all
IPv4 Routing
4-54
reset isis peer
IPv4 Routing
4-55
reset lacp statistics
Link Aggregation
1-12
reset logbuffer
Information Center
1-21
reset mac-authentication statistics
4-7
reset mld-snooping group
Multicast Protocol
2-25
reset mld-snooping statistics
Multicast Protocol
2-25
reset msdp peer
Multicast Protocol
6-17
reset msdp sa-cache
Multicast Protocol
6-18
reset msdp statistics
Multicast Protocol
6-18
reset multicast forwarding-table
Multicast Protocol
7-17
reset multicast routing-table
Multicast Protocol
7-18
reset ndp statistics
Cluster Management
1-7
reset oam
OAM
1-19
reset ospf counters
IPv4 Routing
3-59
reset ospf process
IPv4 Routing
3-59
reset ospf redistribution
IPv4 Routing
3-60
reset pim control-message counters
Multicast Protocol
5-47
reset qos car name
QoS
6-4
reset qos vlan-policy
QoS
7-3
reset radius statistics
AAA-RADIUS-HWTACACS
1-46
reset recycle-bin
1-10
reset rip statistics
IPv4 Routing
2-16
reset rrpp statistics
RRPP
1-9
reset saved-configuration
1-15
reset stop-accounting-buffer
AAA-RADIUS-HWTACACS
1-47
AAA-RADIUS-HWTACACS
1-69
reset stp
MSTP
1-13
reset tcp ipv6 statistics
IPv6
1-41
reset tcp statistics
2-20
reset trapbuffer
Information Center
1-22
reset udp ipv6 statistics
IPv6
1-41
reset udp statistics
2-20
reset udp-helper packet
UDP Helper
1-1
reset unused porttag
3-18
reset vrrp ipv6 statistics
VRRP
1-18
reset vrrp statistics
VRRP
1-5
restore startup-configuration
1-16
retry
AAA-RADIUS-HWTACACS
1-48
retry realtime-accounting
AAA-RADIUS-HWTACACS
1-49
retry stop-accounting
AAA-RADIUS-HWTACACS
1-50
AAA-RADIUS-HWTACACS
1-70
return
1-18
revision-level
MSTP
1-14
rfc1583 compatible
IPv4 Routing
3-60
ring
RRPP
1-9
ring enable
RRPP
1-12
rip
IPv4 Routing
2-17
rip authentication-mode
IPv4 Routing
2-18
rip input
IPv4 Routing
2-19
rip metricin
IPv4 Routing
2-20
rip metricout
IPv4 Routing
2-20
rip mib-binding
IPv4 Routing
2-21
rip output
IPv4 Routing
2-22
rip poison-reverse
IPv4 Routing
2-22
rip split-horizon
IPv4 Routing
2-23
rip summary-address
IPv4 Routing
2-24
rip version
IPv4 Routing
2-24
ripng
IPv6 Routing
2-11
ripng default-route
IPv6 Routing
2-12
ripng enable
IPv6 Routing
2-13
ripng metricin
IPv6 Routing
2-13
ripng metricout
IPv6 Routing
2-14
ripng poison-reverse
IPv6 Routing
2-15
ripng split-horizon
IPv6 Routing
2-15
ripng summary-address
IPv6 Routing
2-16
rmdir
1-10
rmdir
2-23
rmdir
SSH
1-38
rmon alarm
SNMP-RMON
2-9
rmon event
SNMP-RMON
2-11
rmon history
SNMP-RMON
2-13
rmon prialarm
SNMP-RMON
2-14
rmon statistics
SNMP-RMON
2-16
robust-count
Multicast Protocol
4-21
root-certificate fingerprint
PKI
1-25
route-distinguisher
MCE
1-25
route-policy
IPv4 Routing
6-22
router-aging-time
Multicast Protocol
1-27
router-aging-time
Multicast Protocol
2-26
router-id
IPv4 Routing
5-71
router-id
IPv6 Routing
3-36
router-id
IPv6 Routing
5-53
routing-table limit
MCE
1-26
rrpp domain
RRPP
1-13
rrpp enable
RRPP
1-13
rule (access control policy view)
PKI
1-26
rule (advanced IPv4 ACL view)
ACL
1-12
rule (advanced IPv6 ACL view)
ACL
1-29
rule (basic IPv4 ACL view)
ACL
1-10
rule (basic IPv6 ACL view)
ACL
1-28
rule (Ethernet frame header ACL view)
ACL
1-17
rule (user-defined ACL view)
ACL
1-18
rule comment (for IPv4)
ACL
1-20
rule comment (for IPv6)
ACL
1-33
S
save
1-17
schedule reboot at
3-18
schedule reboot delay
3-20
screen-length
Login
1-17
secondary accounting
AAA-RADIUS-HWTACACS
1-51
AAA-RADIUS-HWTACACS
1-70
secondary authentication
AAA-RADIUS-HWTACACS
1-51
AAA-RADIUS-HWTACACS
1-71
secondary authorization
AAA-RADIUS-HWTACACS
1-72
security-policy-server
AAA-RADIUS-HWTACACS
1-52
self-service-url
AAA-RADIUS-HWTACACS
1-25
send
Login
1-18
sendpacket passroute
NQA
1-20
send-router-alert
Multicast Protocol
4-22
send-trap
NQA
1-19
server-type
AAA-RADIUS-HWTACACS
1-53
service-type
Login
1-19
service-type
AAA-RADIUS-HWTACACS
1-26
service-type ftp
AAA-RADIUS-HWTACACS
1-27
session
SSL-HTTPS
1-7
set authentication password
Login
1-20
set-overload
IPv4 Routing
4-56
sftp
SSH
1-14
sftp client ipv6 source
SSH
1-15
sftp client source
SSH
1-16
sftp ipv6
SSH
1-16
sftp server enable
SSH
1-17
sftp server idle-timeout
SSH
1-18
shell
Login
1-21
shutdown
VLAN
1-6
shutdown
1-23
shutdown
Multicast Protocol
6-19
shutdown-interval
3-22
silent-interface
IPv4 Routing
2-25
silent-interface
IPv4 Routing
3-61
silent-interface
IPv6 Routing
3-37
snmp-agent
SNMP-RMON
1-11
Login
2-3
SNMP-RMON
1-11
snmp-agent group
Login
2-4
snmp-agent group
SNMP-RMON
1-12
SNMP-RMON
1-13
snmp-agent log
SNMP-RMON
1-14
snmp-agent mib-view
SNMP-RMON
1-15
snmp-agent packet max-size
SNMP-RMON
1-16
snmp-agent sys-info
SNMP-RMON
1-16
snmp-agent target-host
SNMP-RMON
1-18
snmp-agent trap enable
SNMP-RMON
1-19
snmp-agent trap enable bfd
BFD-GR
1-11
snmp-agent trap enable ospf
IPv4 Routing
3-62
snmp-agent trap if-mib link extended
SNMP-RMON
1-21
snmp-agent trap life
SNMP-RMON
1-21
snmp-agent trap queue-size
SNMP-RMON
1-22
snmp-agent trap source
SNMP-RMON
1-23
snmp-agent usm-user
Login
2-5
snmp-agent usm-user
SNMP-RMON
1-23
snmp-host
Cluster Management
1-41
source
IPv6
3-9
source-interface
NQA
1-21
source-ip
NQA
1-22
source-lifetime
Multicast Protocol
5-48
source-policy
Multicast Protocol
5-48
source-port
NQA
1-23
speed
Login
1-22
speed
1-24
spf timers
IPv6 Routing
3-38
spf-schedule-interval
IPv4 Routing
3-63
spf-slice-size
IPv4 Routing
4-57
spt-switch-threshold
Multicast Protocol
5-49
ssh client authentication server
SSH
1-19
ssh client first-time enable
SSH
1-19
ssh client ipv6 source
SSH
1-20
ssh client source
SSH
1-21
ssh server authentication-retries
SSH
1-21
ssh server authentication-timeout
SSH
1-22
ssh server compatible-ssh1x enable
SSH
1-23
ssh server enable
SSH
1-23
ssh server rekey-interval
SSH
1-24
ssh user
SSH
1-25
ssh2
SSH
1-26
ssh2 ipv6
SSH
1-28
ssl client-policy
SSL-HTTPS
1-8
ssl server-policy
SSL-HTTPS
1-9
ssm-policy
Multicast Protocol
5-50
startup saved-configuration
1-18
state
AAA-RADIUS-HWTACACS
1-28
state
AAA-RADIUS-HWTACACS
1-54
state
PKI
1-26
state-refresh-interval
Multicast Protocol
5-51
state-refresh-rate-limit
Multicast Protocol
5-52
state-refresh-ttl
Multicast Protocol
5-52
static-bind client-identifier
DHCP
1-23
static-bind ip-address
DHCP
1-24
static-bind mac-address
DHCP
1-25
static-rp
Multicast Protocol
5-53
static-rpf-peer
Multicast Protocol
6-19
step (for IPv4)
ACL
1-21
step (for IPv6)
ACL
1-34
stop-accounting-buffer enable
AAA-RADIUS-HWTACACS
1-55
AAA-RADIUS-HWTACACS
1-73
stopbits
Login
1-23
stp
MSTP
1-15
stp bpdu-protection
MSTP
1-16
stp bpdu-tagged
MSTP
1-17
stp bpdu-tagged cist-ignored
MSTP
1-17
stp bpdu-transparent-forwarding
MSTP
1-18
stp bpdu-transparent-forwarding vlan
MSTP
1-18
stp bridge-diameter
MSTP
1-19
stp compliance
MSTP
1-20
stp config-digest-snooping
MSTP
1-21
stp cost
MSTP
1-22
stp edged-port
MSTP
1-23
stp ignored vlan
MSTP
1-24
stp loop-protection
MSTP
1-25
stp max-hops
MSTP
1-25
stp mcheck
MSTP
1-26
stp mode
MSTP
1-27
stp no-agreement-check
MSTP
1-28
stp pathcost-standard
MSTP
1-28
stp point-to-point
MSTP
1-30
stp port priority
MSTP
1-32
stp port-log
MSTP
1-31
stp priority
MSTP
1-33
MSTP
1-34
stp root primary
MSTP
1-34
stp root secondary
MSTP
1-36
stp root-protection
MSTP
1-37
stp tc-protection
MSTP
1-38
stp tc-protection threshold
MSTP
1-38
stp timer forward-delay
MSTP
1-39
stp timer hello
MSTP
1-40
stp timer max-age
MSTP
1-41
stp timer-factor
MSTP
1-42
stp transmit-limit
MSTP
1-43
stub
IPv4 Routing
3-64
stub
IPv6 Routing
3-38
stub-router
IPv4 Routing
3-65
summary
IPv4 Routing
2-26
summary
IPv4 Routing
4-58
summary automatic
IPv4 Routing
5-72
super
1-19
super password
1-20
switch-mode
IPv6
2-5
switch-mode mce
MCE
1-26
synchronization
IPv4 Routing
5-73
synchronization
IPv6 Routing
5-54
sysname
1-21
1-22
T
tcp anti-naptha enable
2-21
tcp ipv6 timer fin-timeout
IPv6
1-42
tcp ipv6 timer syn-timeout
IPv6
1-42
tcp ipv6 window
IPv6
1-43
tcp state
2-22
tcp syn-cookie enable
2-23
tcp timer check-state
2-23
tcp timer fin-timeout
2-24
tcp timer syn-timeout
2-25
tcp window
2-25
telnet
Login
1-24
telnet client source
Login
1-26
telnet ipv6
Login
1-25
telnet server enable
Login
1-26
terminal debugging
Information Center
1-22
terminal logging
Information Center
1-23
terminal monitor
Information Center
1-23
terminal trapping
Information Center
1-24
terminal type
Login
1-27
test-enable
NQA
1-24
test-failtimes
NQA
1-25
test-type
NQA
1-23
tftp
3-2
tftp client source
3-4
tftp ipv6
3-5
tftp-server
Cluster Management
1-42
tftp-server acl
3-1
tftp-server domain-name
DHCP
1-26
tftp-server ip-address
DHCP
1-27
timeout
NQA
1-26
timer
IPv4 Routing
5-74
timer
IPv6 Routing
5-55
timer
Cluster Management
1-42
timer
RRPP
1-14
timer hello
Multicast Protocol
5-54
timer isp-generation
IPv4 Routing
4-59
timer join-prune
Multicast Protocol
5-55
timer lsp-max-age
IPv4 Routing
4-60
timer lsp-refresh
IPv4 Routing
4-61
Multicast Protocol
4-23
timer query
Multicast Protocol
4-24
timer quiet
AAA-RADIUS-HWTACACS
1-56
timer quiet
AAA-RADIUS-HWTACACS
1-74
timer realtime-accounting
AAA-RADIUS-HWTACACS
1-56
AAA-RADIUS-HWTACACS
1-75
timer response-timeout
AAA-RADIUS-HWTACACS
1-57
AAA-RADIUS-HWTACACS
1-76
timer retry
Multicast Protocol
6-21
timer spf
IPv4 Routing
4-62
time-range
ACL
1-2
timers
IPv4 Routing
2-27
timers
IPv6 Routing
2-17
topology accept
Cluster Management
1-43
topology restore-from
Cluster Management
1-44
topology save-to
Cluster Management
1-45
tos
NQA
1-26
tracert
2-4
tracert ipv6
2-6
traffic behavior
QoS
2-16
traffic classifier
QoS
2-4
ttl
NQA
1-27
tunnel-protocol
IPv6
3-10
U
udp-helper enable
UDP Helper
1-2
udp-helper port
UDP Helper
1-3
udp-helper server
UDP Helper
1-4
undelete
1-11
user
2-24
user privilege level
Login
1-28
user-bind
IP Source Guard
1-2
user-interface
Login
1-28
username
NQA
1-28
user-name-format
AAA-RADIUS-HWTACACS
1-58
user-name-format
AAA-RADIUS-HWTACACS
1-76
V
validate-source-address
IPv4 Routing
2-28
verbose
2-25
version
IPv4 Routing
2-29
version
Multicast Protocol
4-24
version
SSL-HTTPS
1-9
virtual-cable-test
1-24
virtual-system
IPv4 Routing
4-63
vlan
VLAN
1-7
vlan-check disable
VLAN
1-15
vlan-mapping modulo
MSTP
1-44
vlink-peer
IPv4 Routing
3-65
vlink-peer
IPv6 Routing
3-39
voice vlan
VLAN
2-3
voice vlan aging
VLAN
2-4
voice vlan enable
VLAN
2-4
voice vlan mac-address
VLAN
2-5
voice vlan mode auto
VLAN
2-7
voice vlan security enable
VLAN
2-8
voice-config
DHCP
1-27
vpninstance
NQA
1-28
vpn-instance-capability simple
MCE
1-27
vpn-target
MCE
1-28
vrrp ipv6 method
VRRP
1-19
vrrp ipv6 ping-enable
VRRP
1-20
vrrp ipv6 vrid authentication-mode
VRRP
1-19
vrrp ipv6 vrid preempt-mode
VRRP
1-21
vrrp ipv6 vrid priority
VRRP
1-22
vrrp ipv6 vrid timer advertise
VRRP
1-23
vrrp ipv6 vrid track
VRRP
1-24
vrrp ipv6 vrid virtual-ip
VRRP
1-25
vrrp method
VRRP
1-7
vrrp ping-enable
VRRP
1-8
vrrp un-check ttl
VRRP
1-8
vrrp vrid authentication-mode
VRRP
1-6
vrrp vrid preempt-mode
VRRP
1-9
vrrp vrid priority
VRRP
1-10
vrrp vrid timer advertise
VRRP
1-11
vrrp vrid track
VRRP
1-12
vrrp vrid virtual-ip
VRRP
1-13
W
work-directory
AAA-RADIUS-HWTACACS
1-29
X
Y
Z
