H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
10-IPv6 Commands
10-IPv6 Commands 217.95 KB
Table of Contents
Chapter 1 IPv6 Basics Configuration Commands. 1-1
1.1 IPv6 Basics Configuration Commands. 1-1
1.1.1 display dns ipv6 dynamic-host 1-1
1.1.2 display dns ipv6 server 1-2
1.1.3 display ipv6 fib. 1-3
1.1.4 display ipv6 fibcache. 1-4
1.1.5 display ipv6 host 1-4
1.1.6 display ipv6 interface. 1-5
1.1.7 display ipv6 neighbors. 1-7
1.1.8 display ipv6 neighbors count 1-9
1.1.9 display ipv6 pathmtu. 1-10
1.1.10 display ipv6 socket 1-11
1.1.11 display ipv6 statistics. 1-12
1.1.12 display tcp ipv6 statistics. 1-16
1.1.13 display tcp ipv6 status. 1-19
1.1.14 display udp ipv6 statistics. 1-20
1.1.15 dns server ipv6. 1-21
1.1.16 ipv6. 1-22
1.1.17 ipv6 address. 1-22
1.1.18 ipv6 address auto link-local 1-23
1.1.19 ipv6 address eui-64. 1-24
1.1.20 ipv6 address link-local 1-24
1.1.21 ipv6 fibcache. 1-25
1.1.22 ipv6 fib-loadbalance-type hash-based. 1-25
1.1.23 ipv6 host 1-26
1.1.24 ipv6 icmp-error 1-27
1.1.25 ipv6 icmpv6 multicast-echo-reply enable. 1-27
1.1.26 ipv6 nd autoconfig managed-address-flag. 1-28
1.1.27 ipv6 nd autoconfig other-flag. 1-29
1.1.28 ipv6 nd dad attempts. 1-29
1.1.29 ipv6 nd hop-limit 1-30
1.1.30 ipv6 nd ns retrans-timer 1-31
1.1.31 ipv6 nd nud reachable-time. 1-31
1.1.32 ipv6 nd ra halt 1-32
1.1.33 ipv6 nd ra interval 1-33
1.1.34 ipv6 nd ra prefix. 1-34
1.1.35 ipv6 nd ra router-lifetime. 1-35
1.1.36 ipv6 neighbor 1-35
1.1.37 ipv6 neighbors max-learning-num.. 1-36
1.1.38 ipv6 pathmtu. 1-37
1.1.39 ipv6 pathmtu age. 1-38
1.1.40 reset dns ipv6 dynamic-host 1-38
1.1.41 reset ipv6 fibcache. 1-39
1.1.42 reset ipv6 neighbors. 1-39
1.1.43 reset ipv6 pathmtu. 1-40
1.1.44 reset ipv6 statistics. 1-40
1.1.45 reset tcp ipv6 statistics. 1-41
1.1.46 reset udp ipv6 statistics. 1-41
1.1.47 tcp ipv6 timer fin-timeout 1-42
1.1.48 tcp ipv6 timer syn-timeout 1-42
1.1.49 tcp ipv6 window. 1-43
Chapter 2 Dual Stack Configuration Commands. 2-1
2.1 Dual Stack Configuration Commands. 2-1
2.1.1 display switch-mode. 2-1
2.1.2 ipv6. 2-1
2.1.3 ipv6 address. 2-2
2.1.4 ipv6 address auto link-local 2-3
2.1.5 ipv6 address eui-64. 2-3
2.1.6 ipv6 address link-local 2-4
2.1.7 switch-mode. 2-5
Chapter 3 Tunneling Configuration Commands. 3-1
3.1 Tunnel Configuration Commands. 3-1
3.1.1 aggregation-group. 3-1
3.1.2 destination. 3-2
3.1.3 display interface tunnel 3-3
3.1.4 display ipv6 interface tunnel 3-4
3.1.5 expediting enable. 3-6
3.1.6 expediting subnet 3-6
3.1.7 interface tunnel 3-7
3.1.8 mtu (tunnel interface view) 3-8
3.1.9 source. 3-9
3.1.10 tunnel-protocol 3-10
View
None
Use the display dns ipv6 dynamic-host command to display IPv6 dynamic domain name cache information.
# Display IPv6 dynamic domain name cache information.
<Sysname> display dns ipv6 dynamic-host
No   Host                IPv6 Address        TTL
1        aaa             2001::2         6
Table 1-1 Description on fields of the display dns ipv6 dynamic-host command
No
Sequence number
Host
Host name
IPv6 address
IPv6 address of the host
TTL
Time an entry can be cached in seconds
&  Note:
For a domain name displayed with the display dns ipv6 dynamic-host command, no more than 21 characters can be displayed. If the domain name exceeds the maximum length, the first 21 characters will be displayed.
display dns ipv6 server [ dynamic ]
View
dynamic: Displays the information of IPv6 DNS servers acquired dynamically through DHCP or other protocols.
Use the display dns ipv6 server command to display IPv6 DNS server information.
# Display IPv6 DNS server information.
<Sysname> display dns ipv6 server
 Type:
  D:Dynamic    S:Static
DNS Server  Type  IPv6 Address                                  (Interface Name)
     1        S      1::1
     2        S      FE80:1111:2222:3333:4444:5555:6666:7777  Vlan2
Table 1-2 Description on the fields of the display dns ipv6 server command
DNS Server
Sequence number of the DNS server, which is assigned automatically by the system, starting from 1.
Type of DNS server: S represents a statically configured DNS server, and D represents a DNS server obtained dynamically through DHCP.
IPv6 Address
IPv6 address of the DNS server
Interface Name
Name of the interface on the DNS server whose IP address is an IPv6 link-local address.
display ipv6 fib [ ipv6-address ]
View
ipv6-address: Destination IPv6 address whose IPv6 FIB entries are to be displayed.
Use the display ipv6 fib command to display IPv6 FIB entries. If no argument is specified, all IPv6 FIB entries will be displayed.
# Display all IPv6 FIB entries.
<Sysname> display ipv6 fib
FIB Table:
 Total number of Routes : 1
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
Destination: ::1                         PrefixLength    : 128
NextHop  :   ::1                         Flag            : HU
Label      : NULL                            Tunnel ID   : 0
TimeStamp      : Date- 12/5/2004, Time- 9:15:18
Interface    :  InLoopBack0
Table 1-3 Description on fields of the display ipv6 fib command
Total number of routes in the FIB
Destination
Destination address to which a packet is to be forwarded
PrefixLength
Prefix length of the destination address
NextHop
Next hop of the route to the destination
Flag
Route flag:
l      U — Usable route
l      G — Gateway route
l      H — Host route
l      B — Black hole route
l      D — Dynamic route
l      S — Static route
Label
Label
Tunnel ID
ID of a tunnel
TimeStamp
Generation time of a FIB entry
Outgoing interface that forwards packets
View
Parameter
None
Use the display ipv6 fibcache command to display the total number of routes in the FIB cache.
Example
# Display information in the FIB cache.
<Sysname> display ipv6 fibcache
FIB Cache:
 Total number of Routes : 0
display ipv6 host
View
None
Use the display ipv6 host command to display the mappings between host names and IPv6 addresses in the static DNS database.
# Display the mappings between host names and IPv6 addresses in the static DNS database.
<Sysname> display ipv6 host
Host                 Age           Flags           IPv6Address
aaa                  0             static           2002::1
bbb                  0             static           2002::2
Table 1-4 Description on fields of the display ipv6 host command
Host
Host name
Age
Time for the entry to live. “0” is displayed in the case of static configuration.
Flags
Flag indicating the type of mapping between a host name and an IPv6 address. Static indicates a static mapping.
IPv6Address
IPv6 address of a host
display ipv6 interface [ brief ] [ interface-type [ interface-number ] ]
View
brief: Displays brief IPv6 information of an interface.
interface-type: Interface type.
interface-number: Interface number.
Use the display ipv6 interface command to display the IPv6 information of an interface for which an IPv6 address can be configured.
If interface-type interface-number is not specified, the IPv6 information of all interfaces for which IPv6 addresses can be configured is displayed; if only interface-type is specified, the IPv6 information of the interfaces of the specified type for which IPv6 addresses can be configured is displayed; if the interface-type interface-number is specified, the IPv6 information of the specified interface is displayed.
# Display the IPv6 information of VLAN-interface 2.
<Sysname> display ipv6 interface vlan-interface 2
Vlan-interface2 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::1234:56FF:FE65:4322
  Global unicast address(es):
    2001::1, subnet is 2001::/64
  Joined group address(es):
    FF02::1:FF00:1
    FF02::1:FF65:4322
    FF02::2
    FF02::1
  MTU is 1500 bytes
Table 1-5 Description on fields of the display ipv6 interface command
State of the interface
Network layer protocol state of the interface
IPv6 is enabled
IPv6 packet forwarding state of the interface (IPv6 packet forwarding is enabled in the example)
link-local address
Link-local address of the interface
Aggregatable global unicast address(es) of the interface(s)
Address(es) of multicast group(s) that the interface joins
MTU
Maximum transmission unit of the interface
Number of DAD attempts, with DAD enabled
ND reachable time
Neighbor reachable time
Interval for retransmitting a neighbor solicitation (NS) message
Hosts use stateless auto-configuration mode to acquire IPv6 addresses
# Display the brief IPv6 information of all interfaces for which IPv6 addresses can be configured.
<Sysname> display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface                            Physical        Protocol        IPv6 Address
Vlan-interface1                  down            down            Unassigned
Vlan-interface2                  up          up          2001::1
Vlan-interface100                    up          down            Unassigned
Table 1-6 Description on fields of display ipv6 interface brief
*down
The interface is down, that is, the interface is closed by using the shutdown command.
(s)
Spoofing attribute of the interface, that is, the network protocol state of the interface is up, but the link does not exist, or the link is established on demand, instead of being permanent.
Physical
Physical state of the interface
Protocol
Network protocol state of the interface
IPv6 Address
IPv6 address of the interface. Only the first of configured IPv6 addresses is displayed. (If no address is configured for the interface, “Unassigned” will be displayed.)
display ipv6 neighbors { ipv6-address | all | dynamic | interface interface-type interface-number | static | vlan vlan-id } [ | { begin | exclude | include } text ]
View
ipv6-address: IPv6 address whose neighbor information is to be displayed.
all: Displays information of all neighbors, including neighbors acquired dynamically and configured statically.
dynamic: Displays information of all neighbors acquired dynamically.
static: Displays information of all neighbors configured statically.
interface interface-type interface-number: Displays information of the neighbors of a specified interface.
vlan vlan-id: Displays information of the neighbors of a specified VLAN whose ID ranges from 1 to 4094.
|: Filters the output information.
begin: Displays the neighbor entries from the first one containing the specified character string.
include: Displays the neighbor entries containing the specified character string.
exclude: Displays the neighbor entries without the specified character string.
text: Character string.
Use the display ipv6 neighbors command to display neighbor information.
# Display all neighbor information.
<Sysname> display ipv6 neighbors all
                Type: S-Static    D-Dynamic
IPv6 Address             Link-layer     VID   Interface State    T   Age
FE80::200:5EFF:FE32:B800  0000-5e32-b800  N/A    Eth3/0/1    REACH   S   -
Table 1-7 Description on fields of the display ipv6 neighbors command
IPv6 Address
IPv6 address of a neighbor
Link-layer
Link layer address (MAC address of a neighbor)
VID
VLAN to which the interface connected with a neighbor belongs
Interface connected with a neighbor
State of a neighbor, including:
l      INCMP: The address is being resolved. The link layer address of the neighbor is unknown.
l      REACH: The neighbor is reachable.
l      STALE: The reachability of the neighbor is unknown. The device will not verify the reachability any longer unless data is sent to the neighbor.
l      DELAY: The reachability of the neighbor is unknown. The device sends an NS message after a delay.
l      PROBE: The reachability of the neighbor is unknown. The device sends an NS message to verify the reachability of the neighbor.
T
Type of neighbor information, including static configuration and dynamic acquisition.
Age
For a static entry, a hyphen “-“ is displayed. For a dynamic entry, the reachable time (in seconds) elapsed is displayed, and if it is never reachable, “#” is displayed (for a neighbor acquired dynamically).
display ipv6 neighbors { all | dynamic | interface interface-type interface-number | static | vlan vlan-id } count
View
all: Displays the total number of all neighbor entries, including neighbor entries acquired dynamically and configured statically.
dynamic: Displays the total number of all neighbor entries acquired dynamically.
static: Displays the total number of neighbor entries configured statically.
interface interface-type interface-number: Displays the total number of neighbor entries of a specified interface.
vlan vlan-id: Displays the total number of neighbor entries of a specified VLAN whose ID ranges from 1 to 4094.
Use the display ipv6 neighbors count command to display the total number of neighbor entries satisfying the specified condition.
# Display the total number of neighbor entries acquired dynamically.
<Sysname> display ipv6 neighbors dynamic count
Total dynamic entry(ies):  2
display ipv6 pathmtu { ipv6-address | all | dynamic | static }
View
ipv6-address: IPv6 address whose PMTU information is to be displayed.
all: Displays all PMTU information.
dynamic: Displays all dynamic PMTU information.
static: Displays all static PMTU information.
Use the display ipv6 pathmtu command to display the PMTU information of IPv6 addresses.
# Display all PMTU information.
<Sysname> display ipv6 pathmtu all
IPv6 Destination Address ZoneID  PathMTU     Age     Type
 fe80::12                    0       1300            40      Dynamic
 2222::3                 0       1280            -       Static
Table 1-8 Description on fields of the display ipv6 pathmtu command
ZoneID
ID of address zone, currently invalid
PathMTU
PMTU of an IPv6 address
Age
Time for a PMTU to live. For a static PMTU, a hyphen “-“ is displayed.
Indicates the PMTU is dynamically negotiated or statically configured.
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ]
View
socktype socket-type: Displays the socket information of this type. The socket type is in the range of 1 to 3. The value “1” represents a TCP socket, “2” a UDP socket, and “3” a raw IP socket.
task-id: Displays the socket information of the task. The task ID is in the range 1 to 100.
socket-id: Displays the information of the socket. The socket ID is in the range 0 to 3072.
Use the display ipv6 socket command to display socket information.
# Display the information of all sockets.
<Sysname> display ipv6 socket
SOCK_STREAM:
Task = VTYD(14), socketid = 4, Proto = 6,
LA = ::->22, FA = ::->0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_REUSEPORT SO_SENDVPNID,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(14), socketid = 3, Proto = 6,
LA = ::->23, FA = ::->0,
SOCK_DGRAM:
SOCK_RAW:
Table 1-9 Description on fields of the display ipv6 socket command
SOCK_STREAM
TCP socket
SOCK_DGRAM
UDP socket
SOCK_RAW
Raw IP socket
Task ID of the created socket
socketid
ID assigned by the kernel to the created socket
Proto
Protocol ID
LA
Local address and local port number
FA
Remote address and remote port number
sndbuf
Size of the send buffer
rcvbuf
Size of the receive buffer
sb_cc
Number of bytes sent by the send buffer
rb_cc
Number of bytes received by the receive buffer
socket option
Socket option set by the application
socket state
State of the socket
View
None
Use the display ipv6 statistics command to display statistics of IPv6 packets and IPv6 ICMP packets.
# Display the statistics of IPv6 packets and IPv6 ICMP packets.
<Sysname> display ipv6 statistics
  IPv6 Protocol:
    Sent packets:
      Total:      0
        Local sent out:      0            forwarded:         0
        raw packets:     0                discarded:         0
        routing failed:      0            fragments:         0
        fragments failed:    0
    Received packets:
      Total:      0
        local host:          0            hopcount exceeded: 0
        format error:        0                option error:          0
        protocol error:      0            fragments:         0
        reassembled:     0                reassembly failed: 0
        reassembly timeout:  0
  ICMPv6 protocol:
    Sent packets:
      Total:      0
        unreached:           0               too big:                0
        hopcount exceeded:   0               reassembly timeout: 0
        parameter problem:   0
        echo request:        0               echo replied:       0
        neighbor solicit:    0               neighbor advert:        0
        router solicit:      0           router advert:      0
        redirected:          0
      Send failed:
        ratelimited:     0               other errors:       0
    Received packets:
      Total:      0
        checksum error:      0          too short:           0
        bad code:            0
        parameter problem:   0              unknown error type:  0
        echoed:          0              echo replied:        0
        redirected:          0          router renumbering:  0
        unknown info type:   0
      Deliver failed:
        bad length:          0          ratelimited:         0
Table 1-10 Description on fields of the display ipv6 statistics command
IPv6 Protocol:
Statistics of IPv6 packets
Sent packets:
 Total:      0
  fragments failed: 0
Statistics of sent IPv6 packets, including:
l      Total number of sent packets
l      Number of packets sent locally
l      Number of forwarded packets
l      Number of packets sent via raw socket
l      Number of discarded packets
l      Number of packets failing to be routed
l      Number of sent fragment packets
l      Number of fragments failing to be sent
Received packets:
 Total:     0
Statistics of received IPv6 packets, including
l      Total number of received packets
l      Number of packets received locally
l      Number of packets exceeding the hop limit
l      Number of packets in an incorrect format
l      Number of packets with incorrect options
l      Number of packets with incorrect protocol
l      Number of received fragment packets
l      Number of reassembled packets
l      Number of packets failing to be reassembled
l      Number of packets whose reassembly times out
ICMPv6 protocol:
Statistics of IPv6 ICMP packets
Sent packets:
 Total:     0
  router solicit:              0  router advert               0
  redirected:    0
 Send failed:
Statistics of sent IPv6 ICMP packets, including
l      Number of packets whose destination is unreachable
l      Number of too large packets
l      Number of packets whose fragmentation and reassembly times out
l      Number of packets with parameter errors
l      Number of request packets
l      Number of response packets
l      Number of neighbor solicitation packets
l      Number of neighbor advertisement packets
l      Number of router solicit packets
l      Number of router advertisement packets
l      Number of redirected packets
l      Number of packets failing to be sent because of rate limitation
l      Number of packets with other errors
Received packets:
 Total:      0
  bad code                    0
  redirected:                  0
  router renumbering      0
  Deliver failed:
Statistics of received IPv6 ICMP packets, including
l      Number of packets with checksum errors
l      Number of too small packets
l      Number of packets with error codes
l      Number of packets with unknown errors
l      Number of neighbor solicitation messages
l      Number of router solicitation packets
l      Number of packets  recounted by the router
l      Number of unknown type of packets
l      Number of packets with a incorrect size
l      Number of packets failing to be received because of rate limitation
View
None
Use the display tcp ipv6 statistics command to display IPv6 TCP connection statistics.
# Display the statistics of IPv6 TCP connections.
<Sysname> display tcp ipv6 statistics
Received packets:
     Total: 0
     packets in sequence: 0 (0 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 0 (0 bytes), partially duplicate packets: 0 (0 bytes)
     out-of-order packets: 0 (0 bytes)
     packets with data after window: 0 (0 bytes)
     packets after close: 0
     ACK packets: 0 (0 bytes)
     duplicate ACK packets: 0, too much ACK packets: 0
Sent packets:
     Total: 0
     urgent packets: 0
     control packets: 0 (including 0 RST)
     data packets: 0 (0 bytes) data packets retransmitted: 0 (0 bytes)
     ACK only packets: 0 (0 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Table 1-11 Description on fields of the display tcp ipv6 statistics command
Received packets:
  Total: 0
  checksum error:                 0
  offset error:                        0
  short error:                        0
Statistics of received packets, including
l      Number of packets received in sequence
l      Number of  window probe packets
l      Number of  window size update packets
l      Number of packets with offset errors
l      Number of packets whose total length is less than specified by the packet header
l      Number of duplicate packets
l      Number of partially duplicate packets
l      Number of out-of-order packets
l      Number of packets exceeding the size of the receiving window
l      Number of packets received after the connection is closed
l      Number of  ACK packets
l      Number of duplicate ACK packets
l      Number of excessive ACK packets
Sent packets:
     Total: 0
     urgent packets:               0
Statistics of sent packets, including
l      Total number of packets
l      Number of packets containing an urgent indicator
l      Number of  control packets
l      Number of window update packets
l      Number of data packets
l      Number of retransmitted packets
Number of packets whose retransmission times out
Number of connections dropped because of retransmission timeout
Keepalive timeout
Number of keepalive timeouts
keepalive probe
Number of keepalive probes
Keepalive timeout, so connections disconnected
Number of connections dropped because of keepalive response timeout
Number of initiated connections
Number of accepted connections
Number of established connections
Closed connections
Number of closed connections
dropped
Number of dropped connections (after SYN is received from the peer)
initiated dropped
Number of initiated but dropped connections (before SYN is received from the peer)
View
None
Use the display tcp ipv6 status command to display the IPv6 TCP connection status.
# Display the IPv6 TCP connection status.
<Sysname> display tcp ipv6 status
TCP6CB       Local Address       Foreign Address      State
045d8074     ::->21                ::->0              Listening
Table 1-12 Description on fields of the display tcp ipv6 status command
TCP6CB
IPv6 address of the TCP control block (hexadecimal)
Local Address
Local IPv6 address and port number
Foreign Address
Remote IPv6 address and port number
IPv6 TCP connection status, including
l      Closed
l      Listening
l      Syn_Sent
l      Syn_Rcvd
l      Established
l      Close_Wait
l      Fin_Wait1
l      Closing
l      Last_Ack
l      Fin_Wait2
l      Time_Wait
View
None
Use the display udp ipv6 statistics command to display statistics of IPv6 UDP packets.
# Display statistics information of IPv6 UDP packets.
<Sysname> display udp ipv6 statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
Table 1-13 Description on fields of the display udp ipv6 statistics command
Total
Total number of received/sent packets
checksum error
Total number of packets with a checksum error
shorter than header
Total number of IPv6 UDP packets whose total length is less than specified by the packet header
Total number of packets whose data length exceeds that specified by the packet header
Total number of unicast packets without any socket received on a port
Total number of broadcast/multicast packets without any socket received on a port
Number of packets not handled because of the receive buffer being full
input packet missing pcb cache
Number of packets failing to match the PCB cache
dns server ipv6 ipv6-address [ interface-type interface-number ]
undo dns server ipv6 ipv6-address [ interface-type interface-number ]
View
ipv6-address: IPv6 address of a DNS server.
interface-type interface-number: Specifies an interface. When the IPv6 address of the DNS server is a link-local address, this argument must be specified.
Use the dns server ipv6 command to configure an IPv6 address for a DNS server.
Use the undo dns server ipv6 command to remove the configured DNS server.
By default, no DNS server is configured.
# Configure the IPv6 address 2002::1 for a DNS server.
[Sysname] dns server ipv6 2002::1
1.1.16  ipv6
ipv6
undo ipv6
View
None
Use the ipv6 command to enable the IPv6 packet forwarding function.
Use the undo ipv6 command to disable the IPv6 packet forwarding function.
By default, the IPv6 packet forwarding function is disabled.
# Enable the IPv6 packet forwarding function.
[Sysname] ipv6
1.1.17  ipv6 address
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
View
Interface view
ipv6-address: IPv6 address.
prefix-length: Prefix length of an IPv6 address, in the range 1 to 128.
Use the ipv6 address command to configure an IPv6 site-local address or aggregatable global unicast address for an interface.
Use the undo ipv6 address command to remove the IPv6 address from the interface.
By default, no site-local address or global unicast address is configured for an interface.
Note that except the link-local address automatically configured, all IPv6 addresses will be removed from the interface if you carry out the undo ipv6 address command without any parameter specified.
# Set the aggregatable global IPv6 unicast address of VLAN-interface 100 to 2001::1/64.
[Sysname-Vlan-interface100] ipv6 address 2001::1/64
undo ipv6 address auto link-local
View
Interface view
None
Use the ipv6 address auto link-local command to automatically generate a link-local address for an interface.
Use the undo ipv6 address auto link-local command to remove the automatically generated link-local address for an interface.
By default, a link-local address will automatically be generated after a site-local or global IPv6 unicast address is configured for an interface.
# Configure VLAN-interface 100 to automatically generate a link-local address.
[Sysname-Vlan-interface100] ipv6 address auto link-local
ipv6 address ipv6-address/prefix-length eui-64
undo ipv6 address ipv6-address/prefix-length eui-64
View
Interface view
ipv6-address/prefix-length: IPv6 address and IPv6 prefix. The ipv6-address and prefix-length arguments jointly specify the prefix of an IPv6 address in the EUI-64 format.
Use the ipv6 address eui-64 command to configure a site-local address or global unicast address in the EUI-64 format for an interface.
Use the undo ipv6 address eui-64 command to remove the configured site-local address or global unicast address in the EUI-64 format for an interface.
By default, no site-local or global unicast address in EUI-64 format is configured for an interface.
# Configure an IPv6 address in EUI-64 format for VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 eui-64
undo ipv6 address ipv6-address link-local
View
Interface view
ipv6-address: IPv6 link-local address. The first ten bits of an address must be 1111111010 (binary), that is, the first group of hexadecimals in the address must be FE80 to FEBF.
Use the ipv6 address link-local command to configure a link-local address manually for a specified interface. Use the undo ipv6 address link-local command to remove the configured link-local address for an interface.
# Configure a link-local address for VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address fe80::1 link-local
ipv6 fibcache
undo ipv6 fibcache
View
Parameter
None
Use the ipv6 fibcache command to enable the IPv6 FIB caching function.
Use the undo ipv6 fibcache command to disable the IPv6 FIB caching function.
By default, the IPv6 FIB caching function is disabled.
Note that the FIB caching function valid only for forwarded packets.
Example
# Enable the IPv6 FIB caching function.
[Sysname] ipv6 fibcache
undo ipv6 fib-loadbalance-type hash-based
View
Parameter
None
Use the ipv6 fib-loadbalance-type hash-based command to specify the load sharing mode based on the HASH algorithm for packet forwarding so that packets from the same source address can be forwarded from the same next-hop address.
Use the undo ipv6 fib-loadbalance-type hash-based command to restore the load sharing mode to the default load sharing based on polling.
By default, the load sharing based on polling is adopted, that is, each equivalent route is used in turn to forward packets.
Example
# Specify packets from the same source address to be forwarded out of the same next-hop address.
[Sysname] ipv6 fib-loadbalance-type hash-based
1.1.23  ipv6 host
ipv6 host hostname ipv6-address
undo ipv6 host hostname [ ipv6-address ]
View
hostname: Host name, a string of up to 20 characters. The character string can contain letters, numerals, “_”, “-“, or “.” and must contain at least one letter.
Use the ipv6 host command to configure the mappings between host names and IPv6 addresses.
Use the undo ipv6 host command to remove the mappings between host names and IPv6 addresses.
Each host name can correspond to only one IPv6 address.
# Configure the mapping between a host name and an IPv6 address.
[Sysname] ipv6 host aaa 2001::1
ipv6 icmp-error { bucket bucket-size | ratelimit interval } *
undo ipv6 icmp-error
View
bucket bucket-size: Number of tokens in a token bucket, in the range of 1 to 200.
ratelimit interval: Update period of the token bucket in milliseconds, in the range of 0 to 2,147,483,647. The update period “0” indicates that the number of ICMPv6 error packets sent is not restricted.
Use the ipv6 icmp-error command to configure the size and update period of the token bucket.
Use the undo ipv6 icmp-error command to restore the defaults.
By default, the size is 10 and the update period is 100 milliseconds. That is, at most 10 IPv6 ICMP error packets can be sent within these 100 milliseconds.
# Set the capacity of the token bucket to 50 and the update period to 100 milliseconds.
[Sysname] ipv6 icmp-error bucket 50 ratelimit 100
undo ipv6 icmpv6 multicast-echo-reply
View
None
Use the ipv6 icmpv6 multicast-echo-reply enable command to enable sending of multicast echo replies.
Use the undo ipv6 icmpv6 multicast-echo-reply command to disable sending of multicast echo replies.
By default, the device is disabled from sending multicast echo replies.
# Enable sending of multicast echo replies.
[Sysname] ipv6 icmpv6 multicast-echo-reply enable
undo ipv6 nd autoconfig managed-address-flag
View
Interface view
None
Use the ipv6 nd autoconfig managed-address-flag command to set the managed address configuration (M) flag to 1 so that the host can acquire an IPv6 address through stateful auto-configuration (for example, DHCP server).
Use the undo ipv6 nd autoconfig managed-address-flag command to restore the M flag to the default value “0” so that the host can acquire an IPv6 address through stateless auto-configuration.
By default, the M flag is set to “0”.
# Configure the host to acquire an IPv6 address through stateful auto-configuration.
[Sysname-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
undo ipv6 nd autoconfig other-flag
View
Interface view
None
Use the ipv6 nd autoconfig other-flag command to set the other stateful configuration flag (O) flag to 1 so that the host can acquire information other than IPv6 address through stateful auto-configuration (for example, DHCP server).
Use the undo ipv6 nd autoconfig other-flag command to remove the setting so that the host can acquire other information through stateless auto-configuration.
By default, the O flag is set to ”0”.
# Configure the host to acquire information other than IPv6 address through stateless auto-configuration.
[Sysname-Vlan-interface100] undo ipv6 nd autoconfig other-flag
ipv6 nd dad attempts value
undo ipv6 nd dad attempts
View
Interface view
value: Number of attempts to send a neighbor solicitation message for DAD, in the range of 0 to 600. The default value is “1”. When it is set to 0, the DAD is disabled.
Use the ipv6 nd dad attempts command to configure the number of attempts to send a neighbor solicitation message for DAD.
Use the undo ipv6 nd dad attempts command to restore the default.
By default, the number of attempts to send a neighbor solicitation message for DAD is 1.
# Set the number of attempts to send a neighbor solicitation message for DAD to 20.
[Sysname-Vlan-interface100] ipv6 nd dad attempts 20
ipv6 nd hop-limit value
undo ipv6 nd hop-limit
View
value: Number of hops, in the range of 0 to 255. When it is set to 0, the Cur Hop Limit field in RA messages sent by the device is 0. That is, the number of hops is determined by the host itself, but not specified by the device.
Use the ipv6 nd hop-limit command to configure the hop limit advertised by the device.
Use the undo ipv6 nd hop-limit command to restore the default hop limit.
By default, the hop limit advertised by the device is 64.
# Set the hop limit advertised by the device to 100.
[Sysname] ipv6 nd hop-limit 100
undo ipv6 nd ns retrans-timer
View
Interface view
value: Interval for sending NS messages in milliseconds, in the range of 1,000 to 4,294,967,295.
Use the ipv6 nd ns retrans-timer command to set the interval for sending NS messages. The local interface sends NS messages at intervals of this value. Furthermore, the Retrans Timer field in RA messages sent by the local interface is equal to this value.
Use the undo ipv6 nd ns retrans-timer command to restore the default interval.
By default, the local interface sends NS messages at intervals of 1,000 milliseconds and the Retrans Timer field in RA messages sent by the local interface is 0.
# Specify VLAN-interface 100 to send NS messages at intervals of 10,000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time value
undo ipv6 nd nud reachable-time
View
Interface view
value: Neighbor reachable time in milliseconds, in the range of 1 to 3,600,000.
Use the ipv6 nd nud reachable-time command to configure the neighbor reachable time on an interface. This time value serves as not only the neighbor reachable time on the local interface, but also the value of the Reachable Timer field in RA messages sent by the local interface.
Use the undo ipv6 nd nud reachable-time command to restore the default neighbor reachable time and to specify the value of the Reachable Timer field in RA messages as 0 so that the number of hops is determined by the host itself, but not specified by the device.
By default, the neighbor reachable time on the local interface is 30,000 milliseconds and the Reachable Timer field in RA messages is 0.
# Set the neighbor reachable time on VLAN-interface 100 to 10,000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd nud reachable-time 10000
ipv6 nd ra halt
undo ipv6 nd ra halt
View
Interface view
None
Use the ipv6 nd ra halt command to suppress RA messages.
Use the undo ipv6 nd ra halt command to disable the RA message suppression.
By default, RA messages are suppressed.
# Suppress RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra halt
ipv6 nd ra interval max-interval-value min-interval-value
undo ipv6 nd ra interval
View
Interface view
max-interval-value: Maximum interval for advertising RA messages in seconds, in the range of 4 to 1,800.
min-interval-value: Minimum interval for advertising RA messages in seconds, in the range of 3 to 1,350.
Use the ipv6 nd ra interval command to set the maximum and minimum interval for advertising RA messages. The device advertises RA messages at intervals of a random value between the maximum interval and the minimum interval.
Use the undo ipv6 nd ra interval command to restore the default.
By default, the maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Note the following:
l           The minimum interval should be three-fourths of the maximum interval or less.
l           The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
# Set the maximum interval for advertising RA messages to 1,000 seconds and the minimum interval to 700 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra interval 1000 700
ipv6 nd ra prefix { ipv6-address prefix-length | ipv6-address/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] *
undo ipv6 nd ra prefix ipv6-prefix
View
Interface view
ipv6-address: IPv6 address or IPv6 address prefix.
prefix-length: Prefix length of an IPv6 address.
ipv6-prefix: IPv6 address prefix.
valid-lifetime: Valid lifetime of a prefix in seconds, in the range of 0 to 4,294,967,295.
preferred-lifetime: Preferred lifetime of a prefix used for stateless auto-configuration in seconds, in the range of 0 to 4,294,967,295.
no-autoconfig: Specifies a prefix not to be used for stateless auto-configuration. If this keyword is not provided, the prefix is used for stateless auto-configuration.
off-link: Specifies the address with the prefix not to be directly reachable on the link. If this keyword is not provided, the address with the prefix is directly reachable on the link.
Use the ipv6 nd ra prefix command to configure the prefix information in RA messages.
Use the undo ipv6 nd ra prefix command to remove the prefix information from RA messages.
By default, no prefix information is configured in RA messages and the IPv6 address of the interface sending RA messages is used as the prefix information.
# Configure the prefix information for RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100/64 100 10
ipv6 nd ra router-lifetime value
undo ipv6 nd ra router-lifetime
View
Interface view
value: Router lifetime in seconds, in the range of 0 to 9,000. When it is set to 0, the device does not serve as the default router.
Use the ipv6 nd ra router-lifetime command to configure the router lifetime in RA messages.
Use the undo ipv6 nd ra router-lifetime command to restore the default configuration.
By default, the router lifetime in RA messages is 1,800 seconds.
Note that the router lifetime in RA messages should be greater than or equal to the advertising interval.
# Set the router lifetime in RA messages on VLAN-interface 100 to 1,000 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra router-lifetime 1000
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
undo ipv6 neighbor ipv6-address interface-type interface-number
View
ipv6-address: IPv6 address in a static neighbor entry.
mac-address: Link layer address in a static neighbor entry (48 bits long, in the format of H-H-H).
vlan-id: VLAN ID in a static neighbor entry, in the range of 1 to 4094.
port-type port-number: Type and number of  a Layer 2 port in a static neighbor entry.
interface interface-type interface-number: Type and number of a Layer 3 interface in a static neighbor entry.
Use the ipv6 neighbor command to configure a static neighbor entry.
Use the undo ipv6 neighbor command to remove a static neighbor entry.
Note that you can adopt the IPv6 address and link layer address of the Layer 3 VLAN interface or those of the VLAN port to configure a static neighbor entry.
l           If a static neighbor entry is configured by using the first method, the neighbor entry is in the INCMP state. After the device obtains the corresponding Layer 2 VLAN port information through resolution, the neighbor entry will go into the REACH state.
l           If a static neighbor entry is configured by using the second method, the corresponding VLAN interface must exist and the port specified by port-type port-number must belong to the VLAN specified by vlan-id. After a static neighbor entry is configured, the device will relate the VLAN interface with the IPv6 address to identify a static neighbor entry uniquely and the entry will be in the REACH state.
You only need to specify the corresponding VLAN interface before removing a static neighbor entry.
# Configure a static neighbor entry for layer 2 port Ethernet 1/0/2 of VLAN 100.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 100 ethernet 1/0/2
ipv6 neighbors max-learning-num number
undo ipv6 neighbors max-learning-num
View
Interface view
number: Maximum number of neighbors that can be dynamically learned by an interface, in the range 1 to 2560.
Use the ipv6 neighbors max-learning-num command to configure the maximum number of neighbors that can be dynamically learned on a specified interface.
Use the undo ipv6 neighbors max-learning-num command to restore the default.
# Set the maximum number of neighbors that can be dynamically learned on VLAN-interface 100 to 10.
[Sysname-Vlan-interface100] ipv6 neighbors max-learning-num 10
1.1.38  ipv6 pathmtu
ipv6 pathmtu ipv6-address [ value ]
undo ipv6 pathmtu ipv6-address
View
ipv6-address: Specified IPv6 address.
value: PMTU of a specified IPv6 address in bytes. The value range and the default value vary with devices. It ranges from 1280 to 10000.
Use the ipv6 pathmtu command to configure a static PMTU for a specified IPv6 address.
Use the undo ipv6 pathmtu command to remove the PMTU configuration for a specified IPv6 address.
By default, no static PMTU is configured.
# Configure a static PMTU for a specified IPv6 address.
[Sysname] ipv6 pathmtu fe80::12 1300
ipv6 pathmtu age age-time
undo ipv6 pathmtu age
View
age-time: Aging time for PMTU in minutes, in the range of 10 to 100.
Use the ipv6 pathmtu age command to configure the aging time for a dynamic PMTU.
Use the undo ipv6 pathmtu age command to restore the default.
By default, the aging time is 10 minutes.
Note that the aging time is invalid for a static PMTU.
Related commands: display ipv6 pathmtu.
# Set the aging time for a dynamic PMTU to 40 minutes.
[Sysname] ipv6 pathmtu age 40
View
None
Use the reset dns ipv6 dynamic-host command to clear IPv6 dynamic domain name cache information.
# Clear IPv6 dynamic domain name cache information.
<Sysname> reset dns ipv6 dynamic-host
reset ipv6 fibcache
View
Parameter
None
Use the reset ipv6 fibcache command to clear FIB cache entries.
Example
# Clear FIB cache entries.
<Sysname> reset ipv6 fibcache
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | static }
View
all: Clears the static and dynamic neighbor information on all interfaces.
dynamic: Clears the dynamic neighbor information on all interfaces.
interface interface-type interface-number: Clears dynamic neighbor information on a specified interface.
static: Clears the static neighbor information on all interfaces.
Use the reset ipv6 neighbors command to clear IPv6 neighbor information.
# Clear neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors all
reset ipv6 pathmtu { all | static | dynamic }
View
all: Clears all PMTUs.
static: Clears all static PMTUs.
dynamic: Clears all dynamic PMTUs.
Use the reset ipv6 pathmtu the command to clear the PMTU information.
# Clear all PMTUs.
<Sysname> reset ipv6 pathmtu all
View
None
Use the reset ipv6 statistics command to clear the statistics of IPv6 packets and ICMPv6 packets.
# Clear the statistics of IPv6 packets and ICMPv6 packets.
<Sysname> reset ipv6 statistics
View
None
Use the reset tcp ipv6 statistics command to clear the statistics of all IPv6 TCP connections.
# Clear the statistics of all IPv6 TCP connections.
<Sysname> reset tcp ipv6 statistics
View
None
Use the reset udp ipv6 statistics command to clear the statistics of all IPv6 UDP packets.
# Clear the statistics of all IPv6 UDP packets.
<Sysname> reset udp ipv6 statistics
tcp ipv6 timer fin-timeout wait-time
undo tcp ipv6 timer fin-timeout
View
wait-time: Length of the finwait timer for IPv6 TCP connections in seconds, in the range of 76 to 3,600.
Use the tcp ipv6 timer fin-timeout command to set the finwait timer for IPv6 TCP connections
Use the undo tcp ipv6 timer fin-timeout command to restore the default finwait timer length.
By default, the length of the finwait timer is 675 seconds.
# Set the finwait timer length of IPv6 TCP connections to 800 seconds.
[Sysname] tcp ipv6 timer fin-timeout 800
tcp ipv6 timer syn-timeout wait-time
undo tcp ipv6 timer syn-timeout
View
wait-time: Length of the synwait timer for IPv6 TCP connections in seconds, in the range of 2 to 600.
Use the tcp ipv6 timer syn-timeout command to set the synwait timer for IPv6 TCP connections
Use the undo tcp ipv6 timer syn-timeout command to restore the default synwait timer length.
By default, the length of the synwait timer of IPv6 TCP connections is 75 seconds.
# Set the synwait timer length of IPv6 TCP connections to 100 seconds.
[Sysname] tcp ipv6 timer syn-timeout 100
tcp ipv6 window size
undo tcp ipv6 window
View
size: Size of the IPv6 TCP sending/receiving buffer in KB (kilobyte), in the range of 1 to 32.
Use the tcp ipv6 window command to set the size of the IPv6 TCP sending/receiving buffer.
Use the undo tcp ipv6 window command to restore the default.
By default, the size of the IPv6 TCP sending/receiving buffer is 8 KB.
# Set the size of the IPv6 TCP sending/receiving buffer to 4 KB.
[Sysname] tcp ipv6 window 4
display switch-mode
View
Parameter
None
Use the display switch-mode command to display the information about the current system operating mode, the system operating mode after the device reboots the next time, and related system information
Example
# Display the information about the current system operating mode, the system operating mode after the device reboots the next time, and related system information.
<Sysname> display switch-mode
2.1.2  ipv6
ipv6
undo ipv6
View
None
By default, the function is disabled.
[Sysname] ipv6
2.1.3  ipv6 address
View
Interface view
ipv6-address: IPv6 address for the interface.
prefix-length: Length of the prefix in bits, in the range of 1 to 128.
Use the ipv6 address command to configure a site-local address or global unicast address for an interface.
Use the undo ipv6 address command to remove the configuration.
By default, neither site-local addresses nor global unicast addresses are configured.
Note that:
l           Up to eight global unicast addresses and site-local addresses can be configured on an interface in total.
l           The undo ipv6 address command without parameters removes all IPv6 addresses manually configured, except link-local addresses automatically configured on the interface.
# Specify the global unicast address of the interface VLAN-interface 100 as 2001::1/64.
View
Interface view
None
Use the ipv6 address auto link-local command to enable the device to automatically generate a link-local address for an interface.
Use the undo ipv6 address auto link-local command to remove the automatically generated link-local address.
By default, a link-local address will automatically be generated when an IPv6 site-local address or IPv6 global unicast address is configured for an interface.
# Enable the interface VLAN-interface 100 to generate a link-local address automatically.
View
Ethernet interface view
ipv6-address/prefix-length: IPv6 address and prefix length. They together specify the prefix length of an IPv6 address in the EUI-64 format. The prefix length of an EUI-64 address ranges from 1 to 64.
Use the ipv6 address eui-64 command to configure a site-local address or global unicast address in the EUI-64 format on an interface.
Use the undo ipv6 address eui-64 command to delete the site-local address or global unicast address in the EUI-64 format on an interface.
By default, no site-local or global unicast address in the EUI-64 format is configured for an interface.
# Configure the interface VLAN-interface 100 to generate an IPv6 address in the EUI-64 format.
View
Interface view
ipv6-address: IPv6 link-local address. The high-order ten bits of an IPv6 link-local address must be 1111111010 (binary), that is to say, the first group of the IPv6 link-local address must range from FE80 to FEBF (hexadecimal).
Use the ipv6 address link-local command to configure manually a link-local address for an interface.
Use the undo ipv6 address link-local command to remove the link-local address of an interface.
By default, a link-local address will automatically be generated when an IPv6 site-local address or global unicast address is configured for an interface.
# Configure a link-local address on the interface VLAN-interface 100.
2.1.7  switch-mode
switch-mode { default | dual-ipv4-ipv6 | mce }
View
Parameter
default: Configures the device to support only IPv4.
dual-ipv4-ipv6: Configures the device to support IPv4/IPv6 dual-stack. When operating in this mode, a device supports both IPv4 and IPv6 packet forwarding.
mce: Configure the device to support MCE mode.
Use the switch-mode command to configure the protocol stack mode supported. Be default, a device supports only IPv4 protocol stack.
&  Note:
l      The configuration performed by this command takes effect only after the device is restarted.
l      Before enabling dual-stack, you need to configure the device to operate in the IPv4/IPv6 dual-stack mode by using the switch-mode dual-ipv4-ipv6 command. Otherwise, IPv6 packets cannot be forwarded on the device even if dual-stack is enabled.
l      For details about MCE mode, refer to MCE Configuration in this manual.
Example
# Configure the device to operate in IPv4/IPv6 dual-stack mode.
[Sysname] switch-mode dual-ipv4-ipv6
aggregation-group aggregation-group-id
undo aggregation-group
View
Tunnel interface view
aggregation-group-id: Link aggregation group ID. The value ranges from 1 to 26.
Use the aggregation-group command to reference a link aggregation group.
Use the undo aggregation-group command to remove the link aggregation group referenced by the tunnel.
By default, a tunnel does not reference any link aggregation group.
Before specifying a link aggregation group for a tunnel in tunnel interface view, you have configured the manual link aggregation group and set the service type of the link aggregation group to tunnel in system view.
Make sure the ports in the manual link aggregation group are not up, and STP is disabled.
One tunnel interface can reference only one link aggregation group.
Related commands: link-aggregation group in Link Aggregation Commands.
# Create link aggregation group 1, and set the configuration mode to manual and the service type to tunnel.
[Sysname] link-aggregation group 1 mode manual
[Sysname] link-aggregation group 1 service-type tunnel
# Add a layer 2 Ethernet interface to link aggregation group 1.
[Sysname-Ethernet1/0/1] stp disable
[Sysname-Ethernet1/0/1] port link-aggregation group 1
[Sysname-Ethernet1/0/1] quit
# Configure the tunnel to reference link aggregation group 1 in tunnel interface view.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] aggregation-group 1
3.1.2  destination
destination ip-address
undo destination
View
Parameter
ip-address: Destination IPv4 address to be specified for the tunnel interface.
Use the command destination to specify the destination address of the tunnel interface.
Use the undo destination command to remove the configured destination IP address.
By default, no destination address is configured for the tunnel interface.
Note that:
l           The destination address of a tunnel interface is the address of the peer interface receiving packets and is usually the source address of the peer tunnel interface.
l           Two or more tunnel interfaces using the same encapsulation protocol must have different source addresses and destination addresses.
Related command: interface Tunnel and source.
Example
# Set VLAN1 (193.101.1.1) of Sysname1 to the source interface and destination interface of a tunnel between two devices, respectively.
<Sysname1> system-view
[Sysname1] interface Tunnel 0
[Sysname1-Tunnel0] source 193.101.1.1
[Sysname1-Tunnel0] destination 192.100.1.1
# Set VLAN1 (192.100.1.1) of Sysname2 to the source interface and destination interface of a tunnel between two devices, respectively.
<Sysname2> system-view
[Sysname2] interface Tunnel 1
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
display interface tunnel [ number ]
View
number: Tunnel interface number. If the number argument is not specified, the information of all tunnel interfaces will be displayed.
Use the display interface tunnel command to display related information of a specified tunnel interface, such as source address, destination address, and encapsulation mode.
Related commands: interface tunnel, source, destination, tunnel-protocol.
# Display the information of the interface Tunnel 0.
<Sysname> display interface Tunnel0
Tunnel0 current state: UP
The Maximum Transmit Unit is 64000
Internet Address is 10.1.2.1/24 Primary
Encapsulation is TUNNEL, aggregation ID not set
Tunnel source 192.13.2.1, destination 192.13.2.2
Tunnel protocol/transport ipv6/IP
    Last 300 seconds input:  0 bytes/sec, 0 packets/sec
    Last 300 seconds output:  0 bytes/sec, 0 packets/sec
    361 packets input,  9953388 bytes
    0 input error
    361 packets output,  30324 bytes
    0 output error
Table 3-1 Description on fields of the display interface tunnel command
The physical layer protocol state of the tunnel interface.
The link layer protocol state of the tunnel interface.
Descriptive information of a tunnel interface
Tunnel0 Interface
Maximum transmission unit (MTU) in a tunnel
The encapsulation protocol is tunnel.
Aggregation ID
Link aggregation group ID referenced by a tunnel. If the device supports link aggregation groups, the link aggregation group ID configured in tunnel interface view is displayed. If device does not support, “aggregation ID not set” is displayed.
Tunnel source
Tunnel source address
Destination
Tunnel destination address
Tunnel protocol and transport protocol.
Checksumming of GRE packets disabled
Disables the GRE packet checksum function.
Number of bytes and packets input per second in the last five minutes.
Number of bytes and packets output per second in the last five minutes.
packets input
Total number of input packets.
input error
Number of error packets among all input packets.
packets output
Total number of output packets.
output error
Number of error packets in all output packets
display ipv6 interface tunnel number
View
Use the display ipv6 interface tunnel command to display related IPv6 information of a specified tunnel interface, including link state, IPv6 protocol state, and IPv6 address.
<Sysname> display ipv6 interface Tunnel0
Tunnel0 current state :UP
IPv6 is enabled, link-local address is FE80::101:101
    2002:101:101::1, subnet is 2002::/16
    FF02::1:FF01:101
    FF02::1:FF00:1
    FF02::2
    FF02::1
  MTU is 1500 bytes
Table 3-2 Description on fields of the display interface tunnel command
The physical layer of the tunnel interface is reachable.
The link layer of the tunnel interface is reachable.
IPv6 is enabled
Enables IPv6 on a tunnel interface
link-local address
Link-local address of a tunnel interface
Aggregatable global unicast address of a tunnel interface.
Multicast group to which a tunnel interface is added.
MTU is 1500 bytes
Size of the MTU in a tunnel. The MTU in this example is 1,500 bytes.
ND reachable time
Interval for retransmitting a neighbor discovery message.
Hosts use the stateless auto-configuration mode to acquire IPv6 addresses.
expediting enable
undo expediting enable
View
Parameter
None
Use the expediting enable command to enable the expedite termination function.
Use the expediting enable command to disable the expedite termination function.
By default, the expedite termination function is disabled.
Example
# Enable the expedite termination function
[Sysname] interface Tunnel 0
[Sysname-Tunnel0] expediting enable
expediting subnet ip-address mask
undo expediting subnet
View
Parameter
ip-address: Address of the expedite termination subnet of a tunnel
mask: Mask of the expedite termination subnet of a tunnel
Use the expediting subnet command to set an IP address and mask for the expedite termination subnet.
Use the undo expediting subnet command to remove the configuration.
By default, no expedite termination subnet is configured for a tunnel.
Note that:
l           You must enable the expedite termination before configuring an expedite termination subnet in tunnel interface view.
l           The expediting subnet is not applicable to a manual tunnel (for example, IPv6 manually configured tunnel). After the expedite termination function is enabled, the system will automatically consider the destination address of a tunnel as the address of the expedite termination subnet, and the subnet mask as 255.255.255.255.
l           For automatic tunnels (for example, automatic IPv4-compatible IPv6 tunnel, automatic 6to4 tunnel, and ISATAP tunnel), you must carry out the expediting subnet command to designate an IP address and subnet for the expedite termination subnet after carrying out the expediting enable command.
Example
# Configure an expedite termination subnet for an automatic 6to4 tunnel: First enable the expedite termination, and then set the address of the expedite termination subnet to 1.1.1.2 and the subnet mask to 255.255.255.0.
[Sysname] interface Tunnel 1
[Sysname-Tunnel1] tunnel-protocol ipv6-ipv4 6to4
[Sysname-Tunnel1] expediting enable
The expediting subnet needs to be configured, or else the expediting is not available.
[Sysname-Tunnel1] expediting subnet 1.1.1.2 255.255.255.0
undo interface tunnel number
View
number: Tunnel interface number, in the range of 0 to 1023. The number of tunnels that can be created is restricted to the total number of interfaces and the memory.
Use the interface tunnel command to create a tunnel interface and enter tunnel interface view.
Use the undo interface tunnel command to remove a specified tunnel interface.
By default, there is no tunnel interface on the device.
Carry out the interface tunnel command to enter interface view of a specified tunnel. If the tunnel interface is not created, you must create it before entering tunnel interface view.
A tunnel interface number has only local significance, and therefore, the same interface number or different interface numbers can be set at both ends of a tunnel.
Related commands: display interface tunnel, source, destination, tunnel-protocol.
# Create the interface Tunnel 3.
[Sysname] interface Tunnel3
[Sysname- Tunnel3]
mtu mtu-size
undo mtu
View
mtu-size: Tunnel interface MTU in bytes, in the range of 100 to 64,000.
Use the mtu command to configure the tunnel interface MTU.
Use the undo mtu command to restore the default tunnel interface MTU.
# Set the tunnel interface MTU to 10,000 bytes.
[Sysname] interface tunnel 3
[Sysname-Tunnel3] mtu 10000
3.1.9  source
source { ip-address | interface-type interface-number }
undo source
View
ip-address: Tunnel source IPv4 address.
interface-type interface-number: Specifies an interface. The interface types include Vlan-interface and loopback.
Use the source command to specify the source address for the tunnel interface.
Use the undo source command to remove the configured tunnel source address.
By default, no tunnel source address is configured.
Note that:
l           The tunnel source address is the address of the interface sending packets and is usually the destination address of the peer tunnel interface.
Related commands: interface tunnel, destination.
# Set the tunnel source address to VLAN-interface 10 on the interface Tunnel 5.
[Sysname] interface tunnel 5
[Sysname-Tunnel5] source 192.100.1.1
Or
[Sysname-Tunnel5] source Vlan-interface 10
tunnel-protocol ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ]
undo tunnel-protocol
View
ipv6-ipv4: Sets the tunnel to an IPv6 over IPv4 manual tunnel.
ipv6-ipv4 6to4: Sets the tunnel to IPv6 over IPv4 6to4 tunnel.
ipv6-ipv4 auto-tunnel: Sets the tunnel to an automatic IPv4 compatible IPv6 tunnel.
ipv6-ipv4 isatap: Sets the tunnel to an IPv6 over IPv4 ISATAP tunnel.
Use the tunnel-protocol command to configure the tunnel type.
Use the undo tunnel-protocol to restore the tunnel type to the default.
Note that:
l           A proper tunnel type can be selected for packet encapsulation according to the network topology and application. The same tunnel type must be configured at both ends of the tunnel. Otherwise, packet delivery will fail.
l           Only one automatic tunnel can be configured at the same tunnel source.
# Specify the tunnel type as IPv6 over IPv4 manual tunnel for a tunnel interface.
[Sysname] interface tunnel 2
[Sysname-Tunnel2] tunnel-protocol ipv6-ipv4
