H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
25-SNMP-RMON Commands
25-SNMP-RMON Commands 158.39 KB
Chapter 1  SNMP Configuration Commands
1.1  SNMP Configuration Commands
1.1.1  display snmp-agent local-engineid
View
None
Use the display snmp-agent local-engineid command to display the local SNMP agent engine ID.
SNMP engine ID identifies an SNMP entity uniquely within an SNMP domain. SNMP engine is an indispensable part of an SNMP entity. It provides the SNMP message allocation, message handling, authentication, and access control.
# Display the local SNMP agent engine ID.
<Sysname> display snmp-agent local-engineid
SNMP local EngineID: 800007DB7F0000013859
1.1.2  display snmp-agent community
View
read: Displays the information of communities with read-only access right.
write: Displays the information of communities with read and write access right.
Use the display snmp-agent community command to display community information for SNMPv1 or SNMPv2c.
# Display the information for all the current communities.
<Sysname> display snmp-agent community
   Community name: aa
       Group name: aa
       Acl:2001
       Storage-type: nonVolatile
   Community name: bb
       Group name: bb
Table 1-1 Descriptions on the fields of display snmp-agent community
Community name
Community name
Group name
SNMP group name
Acl
The number of the ACL in use
Storage-type
Storage type, which could be:
l      volatile: Information will be lost if the system is rebooted
l      nonVolatile: Information will not be lost if the system is rebooted
l      permanent: Modification permitted, but deletion forbidden
l      readOnly: Read only, that is, no modification, no deletion
l      other: Other storage types
1.1.3  display snmp-agent group
display snmp-agent group [ group-name ]
View
group-name: Specifies the SNMP group name, a string of 1 to 32 characters, case sensitive.
Use the display snmp-agent group command to display information for the SNMP agent group, including group name, security model, MIB view, storage type, and so on. Absence of the group-name parameter indicates that information for all groups will be displayed.
# Display the information of all SNMP agent groups.
<Sysname> display snmp-agent group
   Group name: aa
       Security model: v3 noAuthnoPriv
       Readview: ViewDefault
       Writeview: <no specified>
       Notifyview: <no specified>
Table 1-2 Descriptions on the fields of the display snmp-agent group command
Group name
SNMP group name
Security model
Security model of the SNMP group, which can be: authPriv (authentication with privacy), authNoPriv (authentication without privacy), or noAuthNoPriv (no authentication no privacy).
Readview
The read only MIB view associated with the SNMP group
Writeview
The writable MIB view associated with the SNMP group
Notifyview
The notify MIB view associated with the SNMP group, the view with entries that can generate Trap messages
Storage-type
Storage type, which includes: volatile, nonVolatile, permanent, readOnly, and other. For detailed information, refer to Table 1-1.
1.1.4  display snmp-agent mib-view
display snmp-agent mib-view [ exclude | include | viewname view-name ]
View
exclude: Specifies to display SNMP MIB views of the excluded type.
include: Specifies to display SNMP MIB views of the included type.
viewname view-name: Displays view with a specified name, where view-name is the name of the specified MIB view.
Use the display snmp-agent mib-view command to display SNMP MIB view information. Absence of the view-name parameter indicates that information for all MIB views will be displayed.
# Display the current SNMP MIB views.
<Sysname> display snmp-agent mib-view
   View name:ViewDefault
       MIB Subtree:iso
       Subtree mask:
       View Type:included
       View status:active
       MIB Subtree:snmpUsmMIB
       Subtree mask:
       View Type:excluded
       View status:active
       MIB Subtree:snmpVacmMIB
       Subtree mask:
       View Type:excluded
       View status:active
       MIB Subtree:snmpModules.18
       Subtree mask:
       View Type:excluded
       View status:active
Table 1-3 Descriptions on the fields of the display snmp-agent mib-view command
View name
MIB view name
MIB Subtree
MIB subtree corresponding to the MIB view
Subtree mask
MIB subtree mask
Storage-type
Storage type
View Type
View type, which can be included or excluded
Included indicates that all nodes of the MIB tree are included in current view.
Excluded indicates that not all nodes of the MIB tree are included in current view.
View status
The status of MIB view
1.1.5  display snmp-agent statistics
View
None
Use the display snmp-agent statistics command to display SNMP statistics.
# Display the statistics on the current SNMP.
<Sysname> display snmp-agent statistics
  0 Messages delivered to the SNMP entity
  0 Messages which were for an unsupported version
  0 Messages which used a SNMP community name not known
  0 Messages which represented an illegal operation for the community supplied
  0 ASN.1 or BER errors in the process of decoding
  0 Messages passed from the SNMP entity
  0 SNMP PDUs which had badValue error-status
  0 SNMP PDUs which had genErr error-status
  0 SNMP PDUs which had noSuchName error-status
  0 SNMP PDUs which had tooBig error-status (Maximum packet size 1500)
  0 MIB objects retrieved successfully
  0 MIB objects altered successfully
  0 GetRequest-PDU accepted and processed
  0 GetNextRequest-PDU accepted and processed
  0 GetBulkRequest-PDU accepted and processed
  0 GetResponse-PDU accepted and processed
  0 SetRequest-PDU accepted and processed
  0 Trap PDUs accepted and processed
  0 Alternate Response Class PDUs dropped silently
  0 Forwarded Confirmed Class PDUs dropped silently
Table 1-4 Descriptions on the fields of the display snmp-agent statistics command
Number of packets delivered to the SNMP agent
Number of packets from a device with an SNMP version that is not supported by the current SNMP agent
Number of packets that use an unknown community name
Number of packets with operations that breach the access right of a community
Number of packets with ASN.1 or BER errors in the process of decoding
Number of packets sent by an SNMP Agent
Number of SNMP PDUs with a badValue error
Number of SNMP PDUs with a genErr error
Number of PDUs with a noSuchName error
Number of PDUs with a tooBig error (the maximum packet size is 1,500 bytes)
Number of MIB objects that have been successfully retrieved
Number of MIB objects that have been successfully modified
Number of get requests that have been received and processed
Number of getNext requests that have been received and processed
Number of getBulk requests that have been received and processed
Number of get responses that have been received and processed
Number of set requests that have been received and processed
Number of Trap messages that have been received and processed
Number of dropped response packets
Number of forwarded packets that have been dropped
1.1.6  display snmp-agent sys-info
display snmp-agent sys-info [ contact | location | version ] *
View
contact: Displays the contact information of the current network administrator.
location: Displays the location information of the current device.
version: Displays the version of the current SNMP agent.
Use the display snmp-agent sys-info command to display the current SNMP system information.
If no keyword is specified, all SNMP agent system information will be displayed.
# Display the current SNMP agent system information.
<Sysname> display snmp-agent sys-info
   The contact person for this managed node:
           Hangzhou H3C Technologies Co., Ltd.
   The physical location of this node:
           Hangzhou, China
   SNMP version running in the system:
           SNMPv3
1.1.7  display snmp-agent trap-list
View
None
Use the display snmp-agent trap-list command to display the modules that can send the Trap messages and whether their Trap sending is enabled or not. If a module comprises of multiple sub-modules, then as long as one sub-module has the sending of Trap messages enabled, the whole module will be displayed as being enabled with the Trap sending.
Related commands: snmp-agent trap enable.
# Display the modules that can send the Trap messages and whether their Trap sending is enabled or not.
<Sysname> display snmp-agent trap-list
   bgp trap enable
   configuration trap enable
   flash trap enable
   fr trap enable
   isdn trap enable
   mpls trap enable
   ospf trap enable
   standard trap enable
   system trap enable
   voice trap enable
   vrrp trap enable
   Enable traps: 11; Disable traps: 0
In the above output, enable indicates that the module is enabled with the Trap sending whereas disable indicates the Trap sending is disabled. By default, Trap sending is enabled on all modules that can send Trap messages. Use the snmp-agent trap enable command to manually configure whether the Trap sending is enabled or not.
1.1.8  display snmp-agent usm-user
display snmp-agent usm-user [ engineid engineid | username user-name | group group-name ] *
View
engineid engineid: Displays SNMPv3 user information for a specified engine ID, where engineid indicates the SNMP engine ID.
username user-name: Displays SNMPv3 user information for a specified user name. It is case sensitive.
group group-name: Displays SNMPv3 user information for a specified SNMP group name. It is case sensitive.
Use the display snmp-agent usm-user command to display SNMPv3 user information.
 # Display SNMPv3 information for the user aa.
<Sysname> display snmp-agent usm-user username aa
   User name: aa
   Group name: mygroupv3
       Engine ID: 800007DB0000000000006877
       UserStatus: active
Table 1-5 Descriptions on the fields of the display snmp-agent usm-user command
User name
SNMP user name
Group name
SNMP group name
Engine ID
Engine ID for an SNMP entity
Storage-type
Storage type
UserStatus
SNMP user status
1.1.9  enable snmp trap updown
undo enable snmp trap updown
View
Interface view
None
Use the enable snmp trap updown command to enable the sending of Trap messages for interface state change (linkup/linkdown Trap messages).
Use the undo enable snmp trap updown command to disable the sending of linkup/linkdown SNMP Trap messages on an interface.
By default, the sending of linkup/linkdown SNMP Trap messages is enabled.
Note that:
To enable an interface to send SNMP Traps when its state changes, you need to enable the Link up/down Trap packet transmission function on an interface and globally. Use the enable snmp trap updown command to enable this function on an interface, and use the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command to enable this function globally.
Related commands: snmp-agent target-host, snmp-agent trap enable.
# Enable the sending of linkup/linkdown SNMP Trap messages on the port Ethernet 1/0/1 and use the community name public.
[Sysname] snmp-agent target-host trap address udp-domain 10.1.1.1 params securityname public
[Sysname-Ethernet1/0/1] enable snmp trap updown
1.1.10  snmp-agent
snmp-agent
undo snmp-agent
View
None
Use the snmp-agent command to enable SNMP agent.
Use the undo snmp-agent command to disable SNMP agent.
By default, SNMP agent is disabled.
# Disable the current SNMP agent.
[Sysname] undo snmp-agent
1.1.11  snmp-agent community
snmp-agent community { read | write } community-name [ acl acl-number | mib-view view-name ] *
undo snmp-agent community community-name
View
read: Indicates that the community has read only access right to the MIB objects, that is, the community can only inquire MIB information.
write: Indicates that the community has read and write access right to the MIB objects, that is, the community can configure MIB information.
community-name: Community name, a string of 1 to 32 characters.
acl acl-number: ACL for the community name, with acl-number indicating the ACL number, in the range 2,000 to 2,999.
mib-view view-name: Specifies the MIB view name associated with community-name, where view-name represents the MIB view name, a string of 1 to 32 characters. If no keyword is specified, the default view is ViewDefault (The view created by the system after SNMP agent is enabled).
Use the snmp-agent community command to configure a new SNMP community. Parameters to be configured include access right, community name, ACL, and accessible MIB views.
Use the undo snmp-agent community command to delete a specified community.
The community name configured with this command is only valid for the SNMP v1 and v2c agent.
# Configure a community with the name of comaccess that has read-only access right.
[Sysname] snmp-agent community read comaccess
# Delete the community comaccess.
[Sysname] undo snmp-agent community comaccess
1.1.12  snmp-agent group
The following syntax applies to SNMPv1 and SNMP v2c:
snmp-agent group { v1 | v2c } group-name [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
undo snmp-agent group { v1 | v2c } group-name
The following syntax applies to SNMPv3:
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
undo snmp-agent group v3 group-name [ authentication | privacy ]
View
v1: SNMPv1.
v2c: SNMPv2c.
v3: SNMPv3.
group-name: Group name, a string of 1 to 32 characters.
authentication: Specifies the security model of the SNMP group to be authentication only (without privacy).
privacy: Specifies the security model of the SNMP group to be authentication and privacy.
read-view read-view: Read view, a string of 1 to 32 characters.
write-view write-view: Write view, a string of 1 to 32 characters.
notify-view notify-view: Notify view, for sending Trap messages, a string of 1 to 32 characters.
acl acl-number: Specifies an ACL by its number, in the range 2000 to 2999.
Use the snmp-agent group command to configure a new SNMP group and specify its access right.
Use the undo snmp-agent group command to delete a specified SNMP group.
By default, SNMP groups configured by the snmp-agent group v3 command use a no-authentication-no-privacy security model.
Related commands: snmp-agent mib-view, snmp-agent usm-user.
# Create an SNMP group group1 on an SNMPv3 enabled device, no authentication, no privacy.
[Sysname] snmp-agent group v3 group1
1.1.13  snmp-agent local-engineid
undo snmp-agent local-engineid
View
engineid: Engine ID, an even number of hexadecimal characters, in the range 10 to 64. Its length must not be an odd number, and the all-zero and all-F strings are invalid.
Use the snmp-agent local-engineid command to configure a local engine ID for an SNMP entity.
Use the undo snmp-agent local-engineid command to restore the default local engine ID.
By default, the engine ID of a device is the combination of company ID and device ID. Device ID varies by product; it could be an IP address, a MAC address, or a self-defined string of hexadecimal numbers.
Notice that if the newly configured engine ID is not the same as the one used for creating the USM user, the user is invalid.
Related commands: snmp-agent usm-user.
# Configure the local engine ID as 123456789A.
[Sysname] snmp-agent local-engineid 123456789A
1.1.14  snmp-agent log
snmp-agent log { all | get-operation | set-operation }
undo snmp-agent log { all | get-operation | set-operation }
View
all: Enables logging of SNMP GET and SET operations.
get-operation: Enables logging of SNMP GET operation.
set-operation: Enables logging of SNMP SET operation.
Use the snmp-agent log command to enable SNMP logging.
Use the undo snmp-agent log command to restore the default.
By default, SNMP logging is disabled.
If a specified SNMP logging is enabled, when NMS performs a specified operation to SNMP Agent, the latter records the operation-related information and saves it to the information center.
# Enable logging of SNMP GET operation.
[Sysname] snmp-agent log get-operation
# Enable logging of SNMP SET operation.
[Sysname] snmp-agent log set-operation
1.1.15  snmp-agent mib-view
undo snmp-agent mib-view view-name
View
excluded: Indicates that not all nodes of the MIB tree are included in current view.
included: Indicates that all nodes of the MIB tree are included in current view.
view-name: View name, a string of 1 to 32 characters.
oid-tree: MIB subtree. It can only be an OID string, such as 1.4.5.3.1, or an object name string, such as “system”. OID is made up of a series of integers, which marks the position of the node in the MIB tree and uniquely identifies a MIB object.
mask mask-value: Mask for an object tree, in the range 1 to 32 hexadecimal digits. It must be an even digit.
Use the snmp-agent mib-view command to create or update MIB view information so that MIB objects can be specified.
Use the undo snmp-agent mib-view command to delete the current configuration.
By default, MIB view name is ViewDefault.
You can use the display snmp-agent mib-view command to view the access right of the default view. Also, you can use the undo snmp-agent mib-view command to remove the default view, after that, however, you cannot read or write all MIB nodes on Agent.
Related commands: snmp-agent group.
# Create a MIB view mibtest, which includes all objects of the subtree mib-2.
[Sysname] snmp-agent mib-view included mibtest 1.3.6.1
1.1.16  snmp-agent packet max-size
undo snmp-agent packet max-size
View
byte-count: Maximum number of bytes of an SNMP packet that can be received or sent by an agent, in the range 484 to 17,940. The default value is 1,500 bytes.
Use the snmp-agent packet max-size command to configure the maximum number of bytes in an SNMP packet that can be received or sent by an agent.
Use the undo snmp-agent packet max-size command to restore the default packet size.
# Configure the maximum number of bytes that can be received or sent by an SNMP agent as 1,042 bytes.
[Sysname] snmp-agent packet max-size 1042
1.1.17  snmp-agent sys-info
snmp-agent sys-info { contact sys-contact | location sys-location | version { all | { v1 | v2c | v3 }* } }
undo snmp-agent sys-info { contact | location | version { all | { v1 | v2c | v3 }* } }
View
contact sys-contact: A string of 1 to 200 characters that describes the contact information for system maintenance.
location sys-location: A string of 1 to 200 characters that describes the location of the device.
version: The SNMP version in use.
l           all: Specifies SNMPv1, SNMPv2c, and SNMPv3.
l           v1: SNMPv1.
l           v2c: SNMPv2c.
l           v3: SNMPv3.
Use the snmp-agent sys-info command to configure system information, including the contact information and the location, and enable the specified SNMP version.
Use the undo snmp-agent sys-info command to restore the default system information and disable the specified SNMP version..
By default, the location information is Hangzhou China, version is SNMPv3, and the contact is Hangzhou H3C Technologies Co., Ltd.
Related commands: display snmp-agent sys-info.
&  Note:
Network maintenance engineers can use the system contact information to get in touch with the manufacturer in case of network failures. The system location information is a management variable under the system branch as defined in RFC1213-MIB, it identifies the location of the managed object.
# Configure the contact information as “Dial System Operator at beeper # 27345”.
[Sysname] snmp-agent sys-info contact Dial System Operator at beeper # 27345
1.1.18  snmp-agent target-host
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string [ v1 | v2c | v3 [ authentication | privacy ] ]
undo snmp-agent target-host { ip-address | ipv6 ipv6-address } securityname security-string [ vpn-instance vpn-instance-name ]
View
trap: Specifies the host to be the Trap host.
address: Specifies the IP address of the target host for the SNMP messages.
udp-domain: Indicates that the Trap message is transmitted using UDP.
ip-address: The IPv4 address of the Trap host.
ipv6 ipv6-address: Specifies that the target host that receives Trap messages uses the IPv6 address.
vpn-instance vpn-instance-name: Specifies the VPN where the host receiving Traps reside, where vpn-instance-name indicates the VPN instance name and is a string of 1 to 31 characters. It is case sensitive and is applicable only in a network supporting IPv4.
udp-port port-number: Specifies the number of the port that receives Trap messages.
params securityname security-string: Specifies authentication related parameters, which is SNMPv1 or SNMPv2c community name or an SNMPv3 user name, a string of 1 to 32 characters.
v1: SNMPv1.
v2c: SNMPv2c.
v3: SNMPv3.
authentication: Specifies the security model to be authentication without privacy.
privacy: Specifies the security model to be authentication with privacy.
Use the snmp-agent target-host command to configure the related settings for a Trap target host.
Use the undo snmp-agent target-host command to remove the current settings.
To enable the device to send Traps, you need to use the snmp-agent target-host command in combination with the snmp-agent trap enable and the enable snmp trap updown commands.
Related commands: enable snmp trap updown, snmp-agent trap enable, snmp-agent trap source, snmp-agent trap life.
# Enable the device to send SNMP Traps to 10.1.1.1, using the community name of public.
[Sysname] snmp-agent trap enable standard
# Enable the device to send SNMP Traps to the device which is in VPN 1 and has an IP address of 10.1.1.1, using the community name of public.
[Sysname] snmp-agent target-host trap address udp-domain 10.1.1.1 vpn-instance vpn1 params securityname public
1.1.19  snmp-agent trap enable
snmp-agent trap enable [ bfd | bgp | configuration | flash | ospf [ process-id ] [ ospf-trap-list ] | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
undo snmp-agent trap enable [ bgp | configuration | flash | ospf [ process-id ] [ ospf-trap-list ] | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
View
bfd: Enables the sending of BFD Trap messages.
bgp: Enables the sending of BGP Trap messages.
configuration: Enables the sending of configuration Trap messages.
flash: Enables the sending of FLASH Trap messages.
ospf [ process-id ] [ ospf-trap-list ]: Enables the sending of OSPF Trap messages. The parameter process-id is the process ID and spf-trap-list is the Trap packet list.
standard: Enables the sending of standard Trap messages.
l           authentication: Enables the sending of authentication failure Trap messages in the event of authentication failure.
l           coldstart: Sends coldstart Trap messages when the device restarts.
l           linkdown: Sends linkdown Trap messages when the port is in a linkdown status. It should be configured globally.
l           linkup: Sends linkup Trap messages when the port is in a linkup status. It should be configured globally.
l           warmstart: Sends warmstart Trap messages when the SNMP restarts.
system: Sends H3C-SYS-MAN-MIB (a private MIB) Trap messages.
vrrp [ authfailure | newmaster ]: Sends VRRP Trap messages.
l           authfailure: Sends authentication failure VRRP Trap messages.
l           newmaster: Enables the sending of VRRP newmaster Trap messages when the device becomes the Master.
Use the snmp-agent trap enable command to enable the device to send Trap messages globally.
Use the undo snmp-agent trap enable command to disable the device from sending Trap messages.
By default, the device is enabled to send all types of Trap messages.
Note that:
Related commands: snmp-agent target-host, enable snmp trap updown.
# Enable the device to send SNMP authentication failure packets to 10.1.1.1, using the community name of public.
[Sysname] snmp-agent trap enable standard authentication
1.1.20  snmp-agent trap if-mib link extended
undo snmp-agent trap if-mib link extended
View
None
Use the snmp-agent trap if-mib link extended command to extend the standard linkUp/linkDown Trap messages defined in RFC. The extended linkUp/linkDown Trap messages comprise the standard linkUp/linkDown Trap messages defined in RFC plus interface description and interface type.
Use the undo snmp-agent trap if-mib link extended command to restore the default.
By default, standard linkUp/linkDown Trap messages defined in RFC are used.
Note that after this command is configured, the device sends extended linkUp/linkDown Trap messages. If the extended messages are not supported on NMS, the device may not be able to resolute the messages.
# Extend standard linkUp/linkDown Trap messages defined in RFC.
[Sysname] snmp-agent trap if-mib link extended
1.1.21  snmp-agent trap life
snmp-agent trap life seconds
undo snmp-agent trap life
View
seconds: Time-out time, in the range 1 to 2,592,000 seconds.
Use the snmp-agent trap life command to configure the life time for Traps, which will be discarded when their life time expires.
Use the undo snmp-agent trap life command to restore the default life time for Trap messages.
By default, the life time for SNMP Traps is 120 seconds.
Related commands: snmp-agent trap enable, snmp-agent target-host.
# Configure the life time for Trap messages as 60 seconds.
[Sysname] snmp-agent trap life 60
1.1.22  snmp-agent trap queue-size
undo snmp-agent trap queue-size
View
size: The queue size for the Trap messages, in the range 1 to 1,000.
Use the snmp-agent trap queue-size command to configure the size of the Trap queue.
Use the undo snmp-agent trap queue-size command to restore the default queue size.
By default, up to 100 Trap messages can be stored in the Trap queue.
Related commands: snmp-agent trap enable, snmp-agent target-host, snmp-agent trap life.
# Configure the size of the Trap queue as 200.
[Sysname] snmp-agent trap queue-size 200
1.1.23  snmp-agent trap source
snmp-agent trap source interface-type { interface-number | interface-number.subnumber }
undo snmp-agent trap source
View
interface-type { interface-number | interface-number.subnumber }: Specifies the interface type and interface number. The parameter interface-number represents the main interface number. The parameter subnumber represents the subinterface number and ranges from 1 to 4,094.
Use the snmp-agent trap source command to specify the source IP address contained in the Trap message.
Use the undo snmp-agent trap source command to restore the default.
By default, SNMP chooses the IP address of an interface to be the source IP address of the Trap message.
Use this command to trace a specific event by the source IP address of a Trap message.
Note: Before you can configure the IP address of a particular interface as the source IP address of the Trap message, ensure that the interface already exists and that it has a legal IP address. Otherwise, it is likely that the configurations will either fail or be invalid.
# Configure the IP address for the port Ethernet 1/0/1 as the source address for Trap messages.
[Sysname] snmp-agent trap source ethernet 1/0/1
1.1.24  snmp-agent usm-user
The following syntax applies to SNMPv1 and SNMPv2c:
snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number ]
undo snmp-agent usm-user { v1 | v2c } user-name group-name
snmp-agent usm-user v3 user-name group-name [ authentication-mode { md5 | sha } auth-password  [ privacy-mode { aes128 | des56 } priv-password ] ] [ acl acl-number ]
undo snmp-agent usm-user v3 user-name group-name { local | engineid engineid-string }
View
v1: SNMPv1.
v2c: SNMPv2c.
v3: SNMPv3.
user-name: User name, a string of 1 to 32 characters. It is case sensitive.
group-name: Group name, a string of 1 to 32 characters. It is case sensitive.
acl acl-number: Basic ACL, in the range 2,000 to 2,999.
authentication-mode: Specifies that the security mode is authentication.
l           md5: Specifies the authentication protocol to be HMAC-MD5-96.
l           sha: Specifies the authentication protocol to be HMAC-SHA-96.
auth-password: Authentication password, a string of 1 to 64 characters.
privacy: Specifies that the security mode is privacy.
l           aes128: Specifies the privacy protocol to be advanced encryption standard (AES).
l           des56: Specifies the privacy protocol to be data encryption standard (DES).
priv-password: The privacy password, a string of 1 to 64 characters.
local: Represents a local SNMP entity user.
engineid engineid-string: The engine ID string, an even number of hexadecimal characters, in the range 10 to 64. Its length must not be an odd number, and the all-zero and all-F strings are invalid.
Use the snmp-agent usm-user command to add a user to an SNMP group.
Use the undo snmp-agent usm-user command to delete a user from an SNMP group.
Note that the validity of a user depends on the engine ID of the SNMP agent. If the engine ID used for creating the user is not identical to the current engine ID, the user is invalid.
For SNMPv1 and SNMPv2c, this command means adding of a new SNMP group. For SNMPv3, this command adds a new user to an SNMP group.
Related commands: snmp-agent group, snmp-agent community, snmp-agent local-engineid.
# Add a user John to the SNMP group Johngroup. Configure the security model as authentication, the authentication protocol as HMAC-MD5-96, and the authentication password as hello.
[Sysname] snmp-agent group v3 Johngroup
[Sysname] snmp-agent usm-user v3 John Johngroup authentication-mode md5 hello
Chapter 2  RMON Configuration Commands
2.1  RMON Configuration Commands
2.1.1  display rmon alarm
display rmon alarm [ entry-number ]
View
entry-number: Index of an RMON alarm entry, in the range 1 to 65535. If no entry is specified, the configuration of all alarm entries is displayed.
Use the display rmon alarm command to display the configuration of the specified or all RMON alarm entries.
Related commands: rmon alarm.
# Display the configuration of all RMON alarm table entries.
<Sysname> display rmon alarm
Alarm table 1 owned by user1 is VALID.
  Samples type          : absolute
  Variable formula      : 1.3.6.1.2.1.16.1.1.1.4.1<etherStatsOctets.1>
  Sampling interval     : 10(sec)
  Rising threshold      : 50(linked with event 1)
  Falling threshold     : 5(linked with event 2)
  When startup enables  : risingOrFallingAlarm
    Latest value          : 0
Table 2-1 Description on the fields of the display rmon alarm command
Alarm table
Alarm entry index, 1 in this example
owned by
Owner of the entry, user1 in this example
VALID
Status of the entry identified by the index (VALID means the entry is valid, and UNDERCREATION means invalid. You can use the display rmon command to view the invalid entry and with the display current-configuration and display this commands you cannot view the corresponding rmon commands.)
Samples type
The sampling type (absolute in this example)
Variable formula
Formula for the sampling value
Sampling interval
Sampling interval
Rising threshold
Alarm rising threshold (When the sampling value is bigger than or equal to this threshold, a rising alarm is triggered.)
Falling threshold
Alarm falling threshold (When the sampling value is smaller than or equal to this threshold, a falling alarm is triggered.)
How an alarm can be triggered
Latest value
The last sampled value
2.1.2  display rmon event
display rmon event [ entry-number ]
View
entry-number: Index of an RMON event entry, in the range 1 to 65535. If no entry is specified, the configuration of all event entries is displayed.
Use the display rmon event command to display the configuration of the specified or all RMON event entries.
Displayed information includes event index, event owner, event description, action triggered by the event (such as sending log or trap messages), and last time the event occurred (the elapsed time since system initialization/startup) in seconds.
Related commands: rmon event.
# Display the configuration of RMON event table.
<Sysname> display rmon event
Event table 1 owned by user1 is VALID.
  Description: null.
  Will cause log-trap when triggered, last triggered at 0days 00h:02m:27s.
Table 2-2 Description on the fields of the display rmon event command
Event table
Event entry number
owned by
Owner of the entry
VALID
Description for the event
The event will trigger logging and trapping.
last triggered at
Last time the event was triggered
2.1.3  display rmon eventlog
display rmon eventlog [ entry-number ]
View
entry-number: Index of an event entry, in the range 1 to 65535. If no entry number is specified, the log information for all event entries is displayed.
Use the display rmon eventlog command to display log information for the specified or all event entries.
If you use the rmon event command to specify that the action of an entry includes logging, then when this event is triggered, the event log is retained in the RMON log list. You can use the display rmon eventlog command to display detailed log information including event index, current event state, time the event was logged (the elapsed time in seconds since system initialization/startup), and event description.
# Display the RMON log information for event entry 1.
<Sysname> display rmon eventlog 1
Generates eventLog 1.1 at 0days 00h:01m:39s.
Description: The 1.3.6.1.2.1.16.1.1.1.4.1 defined in alarm table 1,
less than(or =) 100 with alarm value 0. Alarm sample type is absolute.
Generates eventLog 1.2 at 0days 00h:02m:27s.
Description: The alarm formula defined in private alarm table 1,
Table 2-3 Description on the fields of the display rmon eventlog command
Event table
Event index
owned by
Owner of the entry
VALID
Generates eventLog at
Time the log was created
Log description
2.1.4  display rmon history
display rmon history [ interface-type interface-number ]
View
interface-type interface-number: Port type and port number.
Use the display rmon history command to display RMON history control entry and last history sampling information, including bandwidth utilization, number of bad packets, and total packet number.
Related commands: rmon history.
# Display RMON history entry information of port Ethernet 1/0/1.
<Sysname> display rmon history ethernet 1/0/1
History control entry 1 owned by user1 is VALID
  Samples interface     : Ethernet1/0/1<ifEntry.642>
  Sampling interval     : 10(sec) with 10 buckets max
  Latest sampled values :
  Dropevents        :0         , octets               :0
  packets           :0         , broadcast packets    :0
  multicast packets :0         , CRC alignment errors :0
  undersize packets :0         , oversize packets     :0
  fragments         :0         , jabbers              :0
  collisions        :0         , utilization          :0
Table 2-4 Description on the fields of the display rmon history command
Index of the history control entry for the interface, 1 in this example
owned by
Owner of the entry
VALID
Samples Interface
The sampled interface
Sampling interval
Sampling interval
buckets max
History table size for the entry, if the specified value of the buckets argument exceeds the history table size supported by the device the latter is displayed.
The latest sampled values
Dropevents
Dropped packets during the sampling period
octets
Number of octets received during the sampling period
packets
Number of packets received during the sampling period
broadcastpackets
Number of broadcasts received during the sampling period
multicastpackets
Number of multicasts received during the sampling period
Number of packets received with CRC alignment errors during the sampling period
undersize packets
Number of undersize packets received during the sampling period
oversize packets
Number of oversize packets received during the sampling period
fragments
Number of fragments received during the sampling period
jabbers
Number of jabbers received during the sampling period
collisions
Number of colliding packets received during the sampling period
utilization
Bandwidth utilization during the sampling period
2.1.5  display rmon prialarm
display rmon prialarm [ entry-number ]
View
entry-number: Private alarm entry index, in the range 1 to 65535. If no entry is specified, the configuration of all private alarm entries is displayed.
Use the display rmon prialarm command to display the configuration of the specified or all private alarm entries.
Related commands: rmon prialarm.
# Display the configuration of all private alarm entries.
<Sysname> display rmon prialarm
Prialarm table 5 owned by user1 is UNDERCREATION.
  Samples type          : changeratio
  Variable formula      : ((.1.3.6.1.2.1.16.1.1.1.5.1-.1.3.6.1.2.1.16.1.1.1.6.1)*100/.1.3.6.1.2.1.16.1.1.1.5.1)
  Description           : ifUtilization.Ethernet1/0/1
  Rising threshold      : 892340484(linked with event 1)
  Falling threshold     : 889783312(linked with event 2)
  This entry will exist : forever
  Latest value          : 0
Table 2-5 Description on the fields of the display rmon prialarm command
Prialarm table
Index of the prialarm table
owned by
VALID
Samples type
Samples type
Variable formula
Variable formula
Sampling interval
Sampling interval
Rising threshold
Alarm rising threshold. An alarm event is triggered when the sampled value is greater than or equal to this threshold.
Falling threshold
Alarm falling threshold. An alarm event is triggered when the sampled value is less than or equal to this threshold.
linked with event
Event index associated with the prialarm
How can an alarm be triggered
The lifetime of the entry, which can be forever or span the specified period
Latest value
2.1.6  display rmon statistics
display rmon statistics [ interface-type interface-number ]
View
Use the display rmon statistics command to display RMON statistics.
Related commands: rmon statistics.
# Display RMON statistics on Ethernet port Ethernet 1/0/1.
<Sysname> display rmon statistics Ethernet 1/0/1
Statistics entry 1 owned by null is VALID.
  Interface : Ethernet1/0/1<ifIndex.1>
  etherStatsOctets         : 0         , etherStatsPkts          : 0
  etherStatsBroadcastPkts  : 0         , etherStatsMulticastPkts : 0
  etherStatsUndersizePkts  : 0         , etherStatsOversizePkts  : 0
  etherStatsFragments      : 0         , etherStatsJabbers       : 0
  etherStatsCRCAlignErrors : 0         , etherStatsCollisions    : 0
  etherStatsDropEvents (insufficient resources): 0
  Packets received according to length:
  64     : 0         ,  65-127  : 0         ,  128-255  : 0
  256-511: 0         ,  512-1023: 0         ,  1024-1518: 0
Table 2-6 Description on the fields of the display rmon statistics command
Statistics entry
Statistics table entry index
VALID
Interface on which statistics are gathered
etherStatsOctets
Number of octets received by the interface during the statistical period
etherStatsPkts
Number of packets received by the interface during the statistical period
Number of broadcast packets received by the interface during the statistical period
Number of multicast packets received by the interface during the statistical period
Number of undersize packets received by the interface during the statistical period
Number of oversize packets received by the interface during the statistical period
etherStatsFragments
Number of undersize packets with CRC errors received by the interface during the statistical period
etherStatsJabbers
Number of oversize packets with CRC errors received by the interface during the statistical period
Number of packets with CRC errors received on the interface during the statistical period
Number of collisions received on the interface during the statistical period
Total number of drop events received on the interface during the statistical period
Statistics of packets received according to length during the statistical period
2.1.7  rmon alarm
rmon alarm entry-number alarm-variable sampling-interval { absolute | delta } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 [ owner text ]
undo rmon alarm entry-number
View
entry-number: Alarm entry index, in the range 1 to 65535.
alarm-variable: Alarm variable, a string of 1 to 256 characters. It can be in dotted object identifier (OID) format, such as 1.3.6.1.2.1.2.1.10.1 or a node name (such as ifInOctets.1). Only variables that can be parsed into INTEGER (INTEGER, Counter, Gauge, or Time Ticks) in the ASN.1 can be used for the alarm-variable argument.
sampling-interval: Sampling interval, in the range 5 to 65,535 seconds.
absolute: Sets the sampling type to absolute.
delta: Sets the sampling type to delta.
rising-threshold threshold-value1 event-entry1: Sets the rising threshold, where threshold-value1 represents the rising threshold, in the range –2,147,483,648 to +2,147,483,647, and event-entry 1 represents the index of the event triggered when the rising threshold is reached. It ranges from 0 to 65,535, with 0 meaning no corresponding event is triggered and no event action is taken when an alarm is triggered.
falling-threshold threshold-value2 event-entry2: Sets the falling threshold, where threshold-value2 represents the falling threshold, in the range –2,147,483,648 to +2,147,483,647 and event-entry2 represents the index of the event triggered when the falling threshold is reached. It ranges from 1 to 65,535.
owner text: Owner of the entry, a string of 1 to 127 characters. It is case sensitive and space is supported.
Use the rmon alarm command to create an entry in the RMON alarm table.
Use the undo rmon alarm command to remove a specified entry from the RMON alarm table.
This command defines alarms. The generation and notification of an alarm however, is controlled by the event entry associated with it.
The following is how the system handles alarm entries:
1)         Samples the alarm variables at the specified interval.
2)         Compares the sampled values with the predefined threshold and does the following:
l           If the rising threshold is reached, triggers the event specified by the event-entry1 argument.
l           If the falling threshold is reached, triggers the event specified by the event-entry2 argument.
&  Note:
l      Before creating an alarm entry, define the events to be referenced in the event table with the rmon event command.
l      When you create an entry, if the values of the specified alarm variable (alarm-variable), sampling interval (sampling-interval), sampling type (absolute or delta), rising threshold (threshold-value1) and falling threshold (threshold-value2) are identical to those of the existing alarm entry, the system considers their configurations the same and the creation fails.
l      You can create up to 60 alarm entries.
l      The rising alarm and falling alarm are alternate.
# Add entry 1 in the alarm table and sample the node 1.3.6.1.2.1.16.1.1.1.4.1 at a sampling interval of 10 seconds in absolute sampling type. Generate event 1 when the sampled value is greater than or equal to the rising threshold of 50, and event 2 when the sampled value is lower than or equal to the falling threshold of 5. Set the owner of the entry to be user1.
[Sysname] rmon event 1 log
[Sysname] rmon event 2 none
[Sysname-Ethernet1/0/1] rmon statistics 1
[Sysname-Ethernet1/0/1] quit
[Sysname] rmon alarm 1 1.3.6.1.2.1.16.1.1.1.4.1 10 absolute rising_threshold 50 1 falling_threshold 5 2 owner user1
# Remove the alarm table entry with the index of 15.
[Sysname] undo rmon alarm 15
2.1.8  rmon event
rmon event entry-number [ description string ] { log | log-trap log-trapcommunity | none | trap trap-community } [ owner text ]
undo rmon event entry-number
View
entry-number: Event entry index, in the range 1 to 65,535.
description string: Event description, a string of 1 to 127 characters.
log: Logs the event when it occurs.
log-trap log-trapcommunity: Log and trap events. The system performs both logging and trap sending when the event occurs. log-trapcommunity indicates the community name of the network management station that receives trap messages, a string of 1 to 127 characters.
none: Performs no action when the event occurs.
trap trap-community: Trap event. The system sends a trap with the community name being trap-community when the event occurs. trap-community represents network management station community to which traps are sent, a string of 1 to 127 characters.
Use the rmon event command to create an entry in the RMON event table.
Use the undo rmon event command to remove a specified entry from the RMON event table.
When an event is triggered by its associated alarm in the alarm table, the event group allows you to log it, send a trap, do both, or do neither at all. This helps control the generation and notification of events.
&  Note:
l      When you create an entry, if the values of the specified event description (description string), event type (log, trap, logtrap or none), and community name (trap-community or log-trapcommunity) are identical to those of the existing event entry, the system considers their configurations the same and the creation fails.
# Create event 10 in the RMON event table.
[Sysname] rmon event 10 log owner user1
2.1.9  rmon history
rmon history entry-number buckets number interval sampling-interval [ owner text ]
undo rmon history entry-number
View
Ethernet port view
entry-number: History control entry index, in the range 1 to 65535.
buckets number: History table size for the entry, in the range 1 to 65,535. The number varies by device.
interval sampling-interval: Sampling interval, in the range 5 to 3600 seconds.
owner text-string: Owner of the entry, a string of 1 to 127 characters. It is case sensitive and space is supported.
Use the rmon history command to create an entry in the RMON history control table.
Use the undo rmon history command to remove a specified entry from the RMON history control table.
This command enables RMON to periodically sample and save for an interface data such as bandwidth utilization, errors, total number of packets for later retrieval.
When you create an entry in the history table, if the specified history table size exceeds that supported by the device, the entry will be created. However, the validated value of the history table size corresponding with the entry is that supported by the device.
&  Note:
l      When you create an entry, if the value of the specified sampling interval (interval sampling-interval) is identical to that of the existing history entry, the system considers their configurations the same and the creation fails.
l      You can create up to 100 alarm entries.
Related commands: display rmon history.
# Create RMON history control entry 1 for interface Ethernet 1/0.
[Sysname-Ethernet1/0/1] rmon history 1 buckets 10 interval 5 owner user1
# Remove history control entry 15.
[Sysname-Ethernet1/0/1] undo rmon history 15
2.1.10  rmon prialarm
rmon prialarm entry-number prialarm-formula prialarm-des sampling-interval { absolute | changeratio | delta } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 entrytype { forever | cycle cycle-period } [ owner text ]
undo rmon prialarm entry-number
View
entry-number: Index of a private alarm entry, in the range 1 to 65535.
prialarm-formula: Private alarm variable formula, a string of 1 to 256 characters. The variables in the formula must be represented in OID format that starts with a point “.”, the formula (.1.3.6.1.2.1.2.1.10.1)*8 for example. You may perform the basic operations of addition, subtraction, multiplication, and division on these variables. The operations should yield a long integer. To prevent errors, make sure that the result of each calculating step falls into the value range for long integers.
prialarm-des: Private alarm entry description, a string of 1 to 127 characters.
sampling-interval: Sampling interval, in the range 10 to 65,535 seconds.
absolute | changeratio | delta : Sets the sampling type to absolute, delta, or change ratio.
forever: Indicates that the lifetime of the private alarm entry is infinite.
cycle cycle-period: Sets the lifetime period of the private alarm entry, in the range 0 to 2,147,483,647 seconds.
Use the rmon prialarm command to create an entry in the private alarm table of RMON.
Use the undo rmon prialarm command to remove a private alarm entry from the private alarm table of RMON.
The following is how the system handles private alarm entries:
1)         Samples the private alarm variables in the private alarm formula at the specified sampling interval.
2)         Performs calculation on the sampled values with the formula.
3)         Compares the calculation result with the predefined thresholds and does the following:
&  Note:
l      When you create an entry, if the values of the specified alarm variable formula (prialarm-formula), sampling type (absolute changeratio or delta), rising threshold (threshold-value1) and falling threshold (threshold-value2) are identical to those of the existing alarm entry, the system considers their configurations the same and the creation fails.
l      You can create up to 50 pri-alarm entries.
# Create entry 5 in the private alarm table. Calculate the private alarm variables with the (1.3.6.1.2.1.16.1.1.1.6.1*100/.1.3.6.1.2.1.16.1.1.1.5.1) formula and sample the corresponding variables at intervals of 10 seconds to get the percentage of broadcasts received on Ethernet 1/0 in the total packets. When this ratio reaches or is bigger than the rising threshold of 50, trigger event 1; when this ratio reaches or drops under the falling threshold, trigger event 2. Set the lifetime of the entry to forever and owner to user 1.
[Sysname] rmon prialarm 5 (1.3.6.1.2.1.16.1.1.1.6.1*100/.1.3.6.1.2.1.16.1.1.1.5.1)
packet Ethernet1/0/1 10 absolute rising_threshold 50 1 falling_threshold 5 2 entrytype forever owner user1
# Remove private alarm entry 10.
[Sysname] undo rmon prialarm 10
2.1.11  rmon statistics
rmon statistics entry-number [ owner text ]
undo rmon statistics entry-number
View
Ethernet port view
entry-number: Index of statistics entry, in the range 1 to 65535.
Use the rmon statistics command to create an entry in the RMON statistics table.
Use the undo rmon statistics command to remove a specified entry from the RMON statistics table.
The RMON statistics group collects information on how a monitored port is being used and records errors. Statistics include number of collisions, CRC alignment errors, number of undersize or oversize packets, number of broadcasts, number of multicasts, number of bytes received, number of packets received.
To display information for the RMON statistics table, use the display rmon statistics command.
&  Note:
l      Only one statistics entry can be created on one port.
l      You can create up to 100 statistics entries.
# Create an entry in the RMON statistics table for port Ethernet 1/0/1. The index of the entry is 20.
[Sysname-Ethernet1/0/1] rmon statistics 20 owner user1
# Delete the entry (entry 20) of Ethernet 2/0/1 from the RMON statistics table.
[Sysname] interface Ethernet 2/0/1
[Sysname-Ethernet2/0/1] undo rmon statistics 20
