H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5303(V1.01)
36-DLDP Commands
36-DLDP Commands 47.76 KB
Chapter 1  DLDP Configuration Commands
1.1  DLDP Configuration Commands
1.1.1  display dldp
display dldp [ interface-type interface-number ]
View
interface-type interface-number: Port type and port number.
Use the display dldp command to display the DLDP configuration of a port.
If you do not provide the interface-type or interface-number arguments, this command displays the DLDP configuration of all the DLDP-enabled ports.
# Display the DLDP configuration of all the DLDP-enabled ports.
<Sysname> display dldp
 DLDP global status : enable
 DLDP interval : 5s
 DLDP work-mode : enhance
 DLDP authentication-mode : simple, password is 123
 DLDP unidirectional-shutdown : auto
 DLDP delaydown-timer : 2s
 The number of enabled ports is 2.
Interface GigabitEthernet1/1/1
 DLDP port state : advertisement
 DLDP link state : up
 The neighbor number of the port is 1.
    Neighbor mac address : 0000-0000-0100
    Neighbor port index : 21
    Neighbor state : two way
    Neighbor aged time : 13
Interface GigabitEthernet1/1/2
    Neighbor mac address : 0000-0000-1100
    Neighbor port index : 22
    Neighbor aged time : 12
# Display the DLDP configuration of GigabitEthernet1/1/1.
<Sysname> display dldp GigabitEthernet1/1/1
    Neighbor port index : 23
Table 1-1 Description on the fields of the display dldp command
DLDP global status
Global DLDP state (enable or disable)
DLDP interval
Interval for sending Advertisement packets (in seconds)
DLDP work-mode
DLDP mode (enhance or normal)
DLDP authentication mode (none, simple, or md5)
password
Password for DLDP authentication
Port shutdown mode (auto or manual)
Setting of the DelayDown timer
Number of the DLDP-enabled ports
Index of a DLDP-enabled port
DLDP port state
DLDP state on a port (initial, inactive, active, advertisement, probe, disable, or delaydown)
DLDP link state
Port state (up or down)
Number of the neighbors of a port
MAC address of a neighbor
Neighbor port index
Neighbor port index
Neighbor state
Neighbor state (unknown, one way, or two way)
Neighbor aged time
Neighbor aging time
1.1.2  display dldp statistics
display dldp statistics [ interface-type interface-number ]
View
Use the display dldp statistics command to display the statistics on the DLDP packets passing through a port.
If you do not provide the interface-type or interface-number argument, this command displays the statistics on the DLDP packets passing through all the DLDP-enabled ports.
# Display the statistics on the DLDP packets passing through all the DLDP-enabled ports.
<Sysname> display dldp statistics
 Packets sent : 6
 Packets received : 5
 Invalid packets received : 2
 Loop packets received : 0
 Authentication failed packets received : 0
 Valid packets received : 3
 Packets sent : 7
 Packets received : 7
 Invalid packets received : 3
 Valid packets received : 4
# Display the statistics on the DLDP packets passing through GigabitEthernet1/1/1.
<Sysname> display dldp statistics GigabitEthernet1/1/1
 Packets sent : 6
Table 1-2 Description on the fields of the display dldp statistics command
Port index
Packets sent
Total number of DLDP packets sent
Packets received
Total number of DLDP packets received
Number of the invalid packets received
Number of the loopback packets received
Number of the received packets that failed to pass the authentication
Number of the valid packets received
1.1.3  dldp authentication-mode
dldp authentication-mode { md5 md5-password | none | simple simple-password }
undo dldp authentication-mode
View
md5 md5-password: Specifies to perform MD5 authentication and sets the password. The md5-password argument is the password, a string of 1 to 16 characters or a 24-bit string. The former indicates a plain text password and the latter indicates a cipher text password. Note that this argument is case-sensitive.
None: Specifies not to perform authentication.
simple simple-password: Specifies to perform plain text authentication and sets the password. The simple-password argument is the password, a case-sensitive string of 1 to 16 characters.
Use the dldp authentication-mode command to configure DLDP authentication.
Use the undo dldp authentication-mode command to restore the default.
By default, DLDP authentication is not performed.
To enable DLDP to operate properly, make sure the DLDP authentication modes and the passwords of the both sides of a link are the same.
# Configure to perform plain text authentication, setting the password as abc (assuming that Device A and Device B are connected by the DLDP link).
l           Configuration on Device A
[DeviceA] dldp authentication-mode simple abc
l           Configuration on Device B
[DeviceB] dldp authentication-mode simple abc
1.1.4  dldp delaydown-timer
dldp delaydown-timer time
undo dldp delaydown-timer
View
Time: Setting of the DelayDown timer, in the range 1 to 5 (in seconds).
Use the dldp delaydown-timer command to set the DelayDown timer.
Use the undo dldp delaydown-timer command to restore the default.
By default, the setting of the DelayDown timer is 1 second.
Note that these two commands apply to all the DLDP-enabled ports.
# Set the DelayDown timer to 2 seconds.
[Sysname] dldp delaydown-timer 2
1.1.5  dldp enable
dldp enable
undo dldp enable
View
System view, Ethernet port view, port group view
None
Use the dldp enable command to enable DLDP.
Use the undo dldp enable command to disable DLDP.
When executed in system view, these two commands enables/disables DLDP globally; when executed in Ethernet port view, these two commands enables/disables DLDP on the current port; when executed in port group view, these two commands enables/disables DLDP on all the ports in the port group.
By default, DLDP is disabled globally or on a port.
&  Note:
l      These two commands are applicable to Layer 2 Ethernet ports, including optical ports and electrical ports.
l      DLDP can take effect only when it is enabled both globally and on a port.
# Enable DLDP globally.
[Sysname] dldp enable
# Enable DLDP on GigabitEthernet1/1/1.
[Sysname] interface GigabitEthernet 1/1/1
[Sysname- GigabitEthernet1/1/1] dldp enable
# Enable DLDP for all the ports in port group 1.
[Sysname] link-aggregation group 1 mode manual
[Sysname] interface GigabitEthernet1/1/2
[Sysname- GigabitEthernet1/1/2] port link-aggregation group 1
[Sysname- GigabitEthernet1/1/2] quit
[Sysname] interface GigabitEthernet1/1/3
[Sysname- GigabitEthernet1/1/3] port link-aggregation group 1
[Sysname- GigabitEthernet1/1/3] quit
[Sysname] port-group aggregation 1
[Sysname-port-group-aggregation-1] dldp enable
1.1.6  dldp interval
dldp interval time
undo dldp interval
View
time: Interval for sending Advertisement packets, in the range 1 to 100 (in seconds).
Use the dldp interval command to set the interval for sending Advertisement packets.
Use the undo dldp interval command to restore the default.
By default, the interval for sending Advertisement packets is 5 seconds.
Note that:
l           These two commands apply to all the DLDP-enabled ports.
l           Set the interval for sending Advertisement packets to a value not longer than one-third of the STP convergence time. If the interval is too long, STP loops may occur before unidirectional links are torn down; if the interval is too short, network traffic may increase in vain due to excessive Advertisement packets.
# Set the interval for sending Advertisement packets to 20 seconds.
[Sysname] dldp interval 20
1.1.7  dldp reset
dldp reset
View
None
Use the dldp reset command to reset DLDP state for ports shut down by DLDP to enable them to perform unidirectional link detect.
When executed in system view, this command applies to all the ports shut down by DLDP; when executed in Ethernet port view, this command applies to the current port; when executed in port group view, this command applies to all the ports in the port group shut down by DLDP.
Related commands: dldp enable, dldp unidirectional-shutdown.
# Reset DLDP state for all the ports shut down by DLDP.
[Sysname] dldp reset
# Reset DLDP state for GigabitEthernet 1/1/1 (assuming that GigabitEthernet 1/1/1 is shut down by DLDP).
[Sysname-GigabitEthernet1/1/1] dldp reset
# Reset DLDP state for all the ports in port group 1 shut down by DLDP.
[Sysname] interface GigabitEthernet 1/1/2
[Sysname-GigabitEthernet1/1/2] port link-aggregation group 1
[Sysname-GigabitEthernet1/1/2] quit
[Sysname] interface GigabitEthernet 1/1/3
[Sysname-GigabitEthernet1/1/3] port link-aggregation group 1
[Sysname-GigabitEthernet1/1/3] quit
[Sysname-port-group-aggregation-1] dldp reset
1.1.8  dldp unidirectional-shutdown
dldp unidirectional-shutdown { auto | manual }
undo dldp unidirectional-shutdown
View
auto: Sets the port shutdown mode as auto mode, where, when a unidirectional link is detected, the ports involved are shut down by DLDP.
manual: Sets the port shutdown mode as manual mode, where, when a unidirectional link is detected, DLDP prompts you to shut down the involved ports instead of doing so automatically.
Use the dldp unidirectional-shutdown command to set the port shutdown mode.
Use the undo dldp unidirectional-shutdown command to restore the default.
By default, the port shutdown mode is auto mode.
Related commands: dldp work-mode.
# Set the port shutdown mode as auto mode.
[Sysname] dldp unidirectional-shutdown auto
1.1.9  dldp work-mode
dldp work-mode { enhance | normal }
undo dldp work-mode
View
enhance: Specifies the enhanced DLDP mode. When a device operates in this mode and a neighbor entry it maintains expires, the device detects the neighbor before removing the neighbor entry.
normal: Specifies the normal DLDP mode. When a device operates in this mode and a neighbor entry it maintains expires, the device removes the neighbor entry directly.
Use the dldp work-mode command to set the DLDP mode.
Use the undo dldp work-mode command to restore the default DLDP mode.
By default, a device operates in normal DLDP mode.
Note that:
l           In normal DLDP mode, only fiber cross-connected unidirectional links can be detected.
l           In enhanced DLDP mode, two types of unidirectional links can be detected. One is fiber cross-connected links. The other refers to fiber pairs with one fiber not connected or disconnected.
# Configure the device to operate in enhanced DLDP mode.
[Sysname] dldp work-mode enhance
1.1.10  reset dldp statistics
reset dldp statistics [ interface-type interface-number ]
View
Use the reset dldp statistics command to clear the statistics on DLDP packets passing through a port.
If you do not provide the interface-type or interface-number argument, this command clears the statistics on the DLDP packets passing through all the DLDP-enabled ports.
# Clear the statistics on the DLDP packets passing through all the DLDP-enabled ports.
<Sysname> reset dldp statistics
