H3C S3610[5510] Series Ethernet Switches Operation Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[5510] Series Ethernet Switches Operation Manual-Release 0001-(V1.02)
07-MAC-IP-Port Binding Operation
07-MAC-IP-Port Binding Operation 72 KB
Chapter 1  MAC-IP-Port Binding Configuration
1.1  MAC-IP-Port Binding Overview
MAC-IP-port binding allows a device to filter packets and thus enhance security. With MAC-IP-port binding configured, a port checks whether the source MAC and IP addresses of an inbound packet is identical to the configured MAC-to-IP binding on the port. If so, it forwards the packet; otherwise, it discards the packet.
1.2  Configuring MAC-IP-Port Binding
Follow these steps to configure MAC-IP-port binding:
To do…
Use the command…
Remarks
Enter system view
Configure MAC-IP-port binding
Bind a MAC-IP address pair to multiple ports
user-bind mac-addr mac-address ip-addr ip-address interface interface-list
Required
Use either approach.
Bind a MAC-IP address pair to  the current port
  Caution:
l      The port in an aggregation group does not support MAC-IP-Port binding configuration.
l      S3610&S5510 Series Ethernet Switches differentiate binding through “MAC address + IP address + port”. You can bind a MAC address with only one IP address and vice versa. However, you can bind a MAC-IP pair to multiple ports.
l      MAC-IP-port binding is on a per-port basis, that is, a port with MAC-IP-port binding enabled filters packets independently; it does not affect any other port.
l      The MAC address to be bound cannot be all 0s, all Fs, or a multicast address. The IP address can only be a Class A, Class B, or Class C address and can neither be 127.x.x.x nor 0.0.0.0.
1.3  Displaying and Maintaining MAC-IP-Port Binding
To do…
Use the command…
Remarks
Display the MAC-IP-port binding entries configured on all ports
display user-bind
Available in any view
Display the MAC-IP-port binding entries configured on all ports for a specified MAC address
display user-bind mac-addr mac-address
Display the MAC-IP-port binding entries configured on all ports for a specified IP address
display user-bind ip-addr ip-address
Display the MAC-IP-port binding entries configured on specified ports
display user-bind interface interface-list
1.4  MAC-IP-Port Binding Configuration Example
I. Network Requirements
As shown in Figure 1-1, switches LSA and LSB and data terminals DT1, DT2, and DT3 are on an Ethernet. DT1 and DT2 are connected to ports Ethernet 1/0/4 and Ethernet 1/0/5 of LSB respectively, DT3 is connected to port Ethernet 1/0/4 of LSA, while LSB is connected to port Ethernet 1/0/5 of LSA.
Detailed requirements are as follows:
l           On port Ethernet 1/0/4 of LSA, only IP packets with the source MAC address of 00-01-02-03-04-05 and the source IP address of 192.168.0.3 can pass.
l           On port Ethernet 1/0/5 of LSA, only IP packets with the source MAC address of 00-01-02-03-04-06 and the source IP address of 192.168.0.1 can pass.
l           On port Ethernet 1/0/4 of LSB, only IP packets with the source MAC address of 00-01-02-03-04-06 and the source IP address of 192.168.0.1 can pass.
l           On port Ethernet 1/0/5 of LSB, only IP packets with the source MAC address of 00-01-02-03-04-07 and the source IP address of 192.168.0.2 can pass.
II. Network Diagram
Figure 1-1 Network diagram for MAC-IP-port binding
III. Configuration Procedure
1)         Configure LSA
# Configure port Ethernet 1/0/4 of LSA to allow only IP packets with the source MAC address of 00-01-02-03-04-05 and the source IP address of 192.168.0.3 to pass.
[Sysname] interface ethernet 1/0/4
[Sysname-Ethernet1/0/4] user-bind mac-addr 0001-0203-0405 ip-addr 192.168.0.3
[Sysname-Ethernet1/0/4] quit
# Configure port Ethernet 1/0/5 of LSA to allow only IP packets with the source MAC address of 00-01-02-03-04-06 and the source IP address of 192.168.0.1 to pass.
[Sysname] interface ethernet 1/0/5
[Sysname-Ethernet1/0/5] user-bind mac-addr 0001-0203-0406 ip-addr 192.168.0.1
2)         Configure LSB
# Configure port Ethernet 1/0/4 of LSB to allow only IP packets with the source MAC address of 00-01-02-03-04-06 and the source IP address of 192.168.0.1 to pass.
[Sysname] user-bind mac-addr 0001-0203-0406 ip-addr 192.168.0.1 interface ethernet 1/0/4
# Configure port Ethernet1/0/5 of LSB to allow only IP packets with the source MAC address of 00-01-02-03-04-07 and the source IP address of 192.168.0.2 to pass.
[Sysname] user-bind mac-addr 0001-0203-0407 ip-addr 192.168.0.2 interface ethernet 1/0/5
