H3C S3610[5510] Series Ethernet Switches Operation Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[5510] Series Ethernet Switches Operation Manual-Release 0001-(V1.02)
00-1Cover
00-1Cover 332 KB
 H3C S3610&S5510 Series Ethernet Switches
Operation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08163C-20070416-C-1.02
Product Version: Release 0001
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3610&S5510 Series Ethernet Switches documentation set includes the following:
Manual
H3C S3610&S5510 Series Ethernet Switches  Command Manual-Release 0001
It is used for assisting the users in using various commands. (See the electronic documentation for details)
H3C S3610 Series Ethernet Switches  Installation Manual
It provides information for the system installation. (See the electronic documentation for details)
H3C S5510 Series Ethernet Switches  Installation Manual
Organization
H3C S3610&S5510 Series Ethernet Switches Operation Manual Release 0001 is organized as follows:
Part
0 Product Overview
Introduces the system features, service features, and network application of the switches.
1 Login
Introduces the ways to log into an Ethernet switch.
2 VLAN
Introduces VLAN, Voice VLAN, GVRP fundamental and the related configuration.
3 IP Address and Performance
Introduces IP address and IP performance fundamental and the related configuration.
4 QinQ-BPDU Tunnel
Introduces QinQ, BPDU TUNNEL and the related configuration.
5 Port Correlation Configuration
Introduces basic port configuration, link aggregation, and port isolation configuration.
6 MAC Address Table Management
Introduces MAC address forwarding table and the related configuration.
7 MAC-IP-Port Binding
Introduces MAC address, IP address and port binding configuration.
8 MSTP
Introduces STP, BRDU tunnel and the related configurations.
9 Routing Overview
Introduces the basic routing information and the classification of routing protocols
10 IPv4 Routing
Introduces IPv4 routing related configurations, such as static routing, RIP, OSPF, IS-IS, BGP, and route policy.
11 IPv6 Routing
Introduces IPv6 routing related configurations, such as static routing, RIPng, OSPFv3, IS-ISv6, and BGP4+.
12 IPv6 Configuration
Introduces IPv6 basic configuration and application, IPv6 tunneling, and so on.
13 Multicast Protocol
Introduces the multicast protocol-related configurations.
14 802.1x-HABP-MAC Authentication
Introduces 802.1x, HABP and MAC related configurations.
15 AAA-RADIUS-HWTACACS
Introduces AAA, RADIUS, HWTACACS, and the related configurations.
16 ARP
Introduces ARP and the related configuration.
17 DHCP
Introduces DHCP and the related configuration.
18 ACL
Introduces IPv4&IPv6-based ACL and the related configuration.
19 QoS
Introduces QoS and the related configuration.
20 Port Mirroring
Introduces port mirroring and the related configuration.
21 Cluster Management
Introduces cluster and the related configuration.
22 UDP Helper
Introduces UDP Helper and the related configuration.
23 SNMP and RMON
Introduces the configuration to manage network devices through SNMP and RMON.
24 NTP
Introduces NTP and the related configuration.
25 DNS
Introduces DNS and the related configuration.
26 File System Management
Introduces basic configuration for file system management.
27 Information Center
Introduces the configuration to analyze and diagnose networks using the information center.
28 System Maintenance and Debugging
Introduces daily system maintenance and debugging.
29 NQA
Introduces NQA and the related configuration.
30 VRRP
Introduces VRRP and the related configuration.
31 SSH
Introduces SSH and the related configurations.
32 Appendix
Lists the acronyms used in this manual.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
