20-GPON命令参考
01-GPON基础命令
本章节下载: 01-GPON基础命令  (791.87 KB)
01-GPON基础命令
1 GPON基础
1.1 GPON基本命令
1.1.1 activate onu
1.1.2 authentication-mode
1.1.3 bind onu-id
1.1.4 blacklist onu-id
1.1.5 dba bandwidth-assignment-mode
1.1.6 display dhcp-client
1.1.7 display interface
1.1.8 display onu
1.1.9 display onu sn
1.1.10 display packet-drop
1.1.11 display pon authentication-mode
1.1.12 display pon diagnostic dba
1.1.13 display pon diagnostic config
1.1.14 display pon diagnostic config-error
1.1.15 display pon diagnostic status
1.1.16 display pon fiber-backup group
1.1.17 display pon onu-event
1.1.18 display pon onu-loop-status
1.1.19 display pon onu-update
1.1.20 display pon optics-parameters
1.1.21 display pon version
1.1.22 display uni
1.1.23 display vendor-specific information
1.1.24 fiber-backup group
1.1.25 fiber-backup tcp
1.1.26 ip address
1.1.27 ipv6 address
1.1.28 management server
1.1.29 management-vlan
1.1.30 member
1.1.31 olt-mode
1.1.32 onu bind auto
1.1.33 onu bind batch
1.1.34 onu bind type
1.1.35 onu-distance
1.1.36 port fiber-backup group
1.1.37 port switch-over
1.1.38 preamble repeat count
1.1.39 shutdown management-vlan-interface
1.1.40 uplink interface
1.1.41 using onu
1.2 GPON配置模板命令
1.2.1 apply onu-config-profile
1.2.2 apply onu-service-profile
1.2.3 apply tcont
1.2.4 bind onu-line-profile
1.2.5 dba type1
1.2.6 dba type2
1.2.7 dba type3
1.2.8 dba type4
1.2.9 dba type5
1.2.10 display onu-config-profile
1.2.11 display onu-dba-profile
1.2.12 display onu-line-profile
1.2.13 display onu-service-profile
1.2.14 encryption enable
1.2.15 forward-error-correction
1.2.16 gpon compare-profile
1.2.17 gpon copy-profile
1.2.18 mapping-mode
1.2.19 onu config-profile
1.2.20 onu dba-profile
1.2.21 onu flow
1.2.22 onu line-profile
1.2.23 onu port-isolate enable
1.2.24 onu protocol enable
1.2.25 onu protocol loopback-detection action
1.2.26 onu service-profile
1.2.27 onu statistics enable
1.2.28 onu-mapping
1.2.29 subinterface
1.2.30 tcont
1.2.31 uni auto-negotiation
1.2.32 uni description
1.2.33 uni duplex
1.2.34 uni flow-control
1.2.35 uni port-isolate
1.2.36 uni shutdown
1.2.37 uni speed
1.2.38 uni statistics enable
1.2.39 uni vlan-mode
1 GPON基础
1.1  GPON基本命令
1.1.1  activate onu
activate onu命令用来激活GPON ONU设备。
undo activate onu命令用来取消ONU设备的激活状态。
activate onu
undo activate onu
ONU接口连接的ONU设备处于激活状态。
ONU接口视图
为了能正常使用GPON ONU设备,需要激活ONU设备。
# 激活Onu1/0/2:1接口连接的ONU设备。
[Sysname] interface onu 1/0/2:1
[Sysname-Onu1/0/2:1] activate onu
authentication-mode命令用来配置OLT认证模式。
undo authentication-mode命令用来删除指定的认证模式配置。
authentication-mode sn
undo authentication-mode sn
OLT基于ONU的序列号进行认证。
FTTH视图
OLT端口视图
sn:SN模式,表示OLT使用ONU的序列号进行认证。
本命令在接口视图下配置时只对该接口起作用,在FTTH视图下配置时对所有OLT端口生效。对一个OLT端口来说,优先采用该接口的配置,只有该接口未进行配置时,才采用FTTH的配置。
undo命令不指定参数时,表示恢复为缺省情况。undo命令指定参数时,表示删除指定的认证模式配置。
# 配置端口Olt1/0/1基于ONU的序列号进行认证。
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] authentication-mode sn
1.1.3  bind onu-id
bind onu-id命令用来将GPON ONU设备绑定到ONU接口,并应用ONU线路模板。
undo bind onu-id命令用来解除ONU接口和ONU设备的绑定。
bind onu-id sn serial-number
undo bind onu-id
ONU接口未绑定任何ONU设备。
ONU接口视图
sn:表示ONU使用其序列号进行绑定。
serial-number:表示ONU设备的序列号,为12个字符的字符串,区分大小写。
应用场景
GPON ONU设备绑定到ONU接口时,指定的(或缺省的)ONU接口命令将自动下发到该ONU接口。
注意事项
每个ONU接口只能绑定一台ONU。
使用undo bind onu-id命令解除ONU接口和ONU设备的绑定后,将导致该ONU设备下线。
绑定ONU设备后,可以通过bind onu-line-profile命令为绑定的ONU设备应用线路模板。
# 将指定序列号的GPON ONU设备绑定到Onu1/0/2:1接口。
[Sysname-Onu1/0/2:1] bind onu-id sn h3c-12345678
·     onu line-profile
blacklist onu-id命令用来添加ONU黑名单表项。
undo blacklist onu-id命令用来删除指定ONU的黑名单表项。
blacklist onu-id sn serial-number
undo blacklist onu-id sn serial-number
不存在ONU黑名单表项。
FTTH视图
serial-number:ONU设备的序列号,为12个字符的字符串,不区分大小写,不能包含字符“?”或十六进制数字0x0~0x20,且不能以字符“DEL”、“@”、“.”、“,”、“!”、“;”、“: ”、“`”、“"”开头或结尾。
通过配置ONU黑名单功能可以禁止指定特征的ONU设备注册到OLT。
配置ONU黑名单功能后,再上线的ONU都会被检测是否在黑名单中。
最多可以添加256台ONU设备到黑名单。
# 将指定序列号的ONU设备加入黑名单。
[Sysname] ftth
[Sysname-ftth] blacklist onu-id sn h2c-12345678
dba bandwidth-assignment-mode命令用来配置DBA带宽分配模式。
undo dba bandwidth-assignment-mode命令用来恢复缺省情况。
(独立运行模式)‌
dba bandwidth-assignment-mode slot slot-number min-delay
undo dba bandwidth-assignment-mode slot slot-number
dba bandwidth-assignment-mode chassis chassis-number slot slot-number min-delay
undo dba bandwidth-assignment-mode chassis chassis-number slot slot-number
DBA带宽分配模式为最小时延模式。
FTTH视图
slot slot-number:配置指定单板上的DBA带宽分配模式,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备指定单板上的DBA带宽分配模式,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
min-delay:最小时延模式。
工作机制
DBA(Dynamic Bandwidth Allocation)计算周期指的是OLT对ONU分配带宽的时间间隔。在PON网络中,带宽是在OLT和ONU之间共享的,因此DBA周期用于动态分配带宽以满足不同用户的需求。较短的DBA周期可以提高带宽分配的精度和效率,但也会增加网络的开销。
# 配置指定slot上的DBA带宽分配模式为最小时延模式。
[Sysname] ftth
[Sysname-ftth] dba bandwidth-assignment-mode slot 1 min-delay
display dhcp-client命令用来显示ONU作为DHCPv4客户端时的地址分配信息。
display dhcp-client
ONU接口视图
# 显示Onu1/0/1:1接口所连接的ONU作为DHCPv4客户端时的地址分配信息。(本命令的显示信息与ONU设备的型号有关,请以设备的实际情况为准。)
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] display dhcp-client
DHCP client statistic information :
  Current machine state : HALT
表1-1 display dhcp-client命令显示信息描述表
DHCP客户端统计信息
DHCP客户端状态机所处的状态
display interface命令用来显示OLT端口、ONU接口的相关信息。
display interface [ interface-type [ interface-number ] ] [ brief [ description | down ] ]
interface-type:指定接口类型,取值为Olt、Onu。如果不指定接口类型,将显示设备支持的所有接口的相关信息。
interface-number:表示接口的编号。如果指定接口类型,不指定interface-number参数,将显示所有该类型接口的相关信息。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过25个字符,不指定该参数时,只显示描述信息中的前25个字符,超出部分不显示。
# 显示Olt1/0/1端口的详细信息。
<Sysname> display interface Olt 1/0/1
Olt1/0/1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 00e0-fc00-511e
Description: Olt1/0/1 Interface
Maximum frame length: 1500
Port hardware type is 1000_BASE_PX_SFP
Flow-control is not enabled
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Known-unicast max-ratio: 100%
Current system time:2019-01-05 05:12:35
Last time when physical state changed to up:-
Last time when physical state changed to down:2019-01-04 00:54:04
 Last 300 seconds input: 0 packets/sec 0 bytes/sec 0%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec 0%
 Input (total):  0 packets, 0 bytes
          - unicasts, - broadcasts, - multicasts, 0 pauses
 Input (normal):  0 packets, 0 bytes
 Input:  0 input errors, 0 runts, 0 giants, - throttles
          0 CRC, - frame, - overruns, - aborts
          - ignored, - parity errors
 Output (total): 100000 packets, 12800000 bytes
 Output (normal): 100000 packets, 12800000 bytes
          - aborts, - deferred, - collisions, - late collisions
          - lost carrier, - no carrier
  XGSPON input (normal): 100000 packets, 12893588 bytes
  XGSPON input: 0 input errors, 0 runts, 0 giants, 0 CRC
  XGSPON output (normal): 100000 packets, 12845974 bytes
  XGSPON output: 0 output errors
# 显示Onu1/0/1:1接口的详细信息。
<Sysname> display interface Onu 1/0/1:1
Onu1/0/1:1
Current state: DOWN
Description: Onu1/0/1:1 Interface
Loopback is not set
Port hardware type is 1000M_SFF_NO_CONNECTOR
 Last 300 seconds input: - packets/sec - bytes/sec -%
 Last 300 seconds output: - packets/sec - bytes/sec -%
          - unicasts, 0 broadcasts, - multicasts, - pauses
 Input (normal):  - packets, - bytes
          - unicasts, - broadcasts, - multicasts, - pauses
 Input:  0 input errors, - runts, 0 giants, - throttles
          0 CRC, 0 frame, - overruns, - aborts
 Output (normal): - packets, - bytes
 Output: - output errors, - underruns, 0 buffer failures
# 显示所有OLT端口的概要信息。
<Sysname> display interface Olt brief
Speed: (a) - auto
Olt1/0/1             UP   --      --     H    1
Olt1/0/2             DOWN --      --     H    1
表1-2 display interface命令显示信息描述表
Current state
接口的物理状态,状态可能为:
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     UP:该端口的管理状态和物理状态均为开启
IPv4报文发送帧格式
hardware address
接口的MAC地址
接口的描述信息
接口允许通过的最大以太网帧长度
接口的硬件类型
未配置流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关
Broadcast max-
广播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Multicast max-
组播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Unicast max-
未知单播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
已知单播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
Current system time
当前系统时间,时间显示格式为YYYY/MM/DD HH:MM:SS
如果配置了时区,当前系统时间后面会追加显示时区的配置,格式为YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称
最近一次接口物理状态变为UP的时刻
如果配置了时区,该时间后面会追加显示时区的配置,格式为YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称
“-”表示接口物理状态没有发生过变化
最近一次接口物理状态变为DOWN的时刻
“-”表示接口物理状态没有发生过变化
端口在最近300秒接收和发送报文的平均速率,单位分别为数据包/秒和字节/秒,以及实际速率和接口带宽的百分比
如果值显示为“-”,则表示不支持该统计项
ONU接口暂不支持统计接口的平均速率
Input (total)
端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口接收的单播报文、广播报文、组播报文和PAUSE帧的数量
Input (normal)
端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口接收的正常单播报文、广播报文、组播报文和PAUSE帧的数量
Input
端口接收的异常报文统计值,包括:
·     input errors:接收错误的报文数量
·     runts:超小帧的数量
·     giants:超大帧的数量
·     throttles:长度为非整数字节的帧的数量
·     CRC:CRC校验错误且长度正常的帧的数量
·     frame:CRC校验错误且长度不是整字节数的帧的数量
·     overruns:因端口的接收速率超过接收队列的处理能力而丢弃的报文数量
·     aborts:非法报文总数,非法报文包括报文碎片(长度小于64字节且CRC校验错误的帧)、jabber帧(有效长度大于端口允许通过的最大报文长度,且CRC校验错误的帧)、符号错误帧等
·     ignored:因端口接收缓冲区不足等原因而丢弃的报文数量
·     parity errors:奇偶校验错误的帧的数量
Output (total)
端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口发送的单播报文、广播报文、组播报文和PAUSE帧的数量
Output (normal)
端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量
Output
端口发送的异常报文统计值,包括:
·     output errors:发送错误的报文数量
·     underruns:因端口的发送速率超过了发送队列的处理能力而丢弃的报文数量
·     buffer failures:因端口发送缓冲区不足而丢弃的报文数量
·     aborts:由于各种原因(如冲突)而发送失败的报文数量
·     deferred:延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文
·     collisions:冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文
·     late collisions:延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送
·     lost carrier:载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数器加一
·     no carrier:无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现,此计数器加一
XGSPON接口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
XGSPON接口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量
XGSPON input
XGSPON接口接收的异常报文统计值,包括:
·     runts:超小帧的数量
·     giants:超大帧的数量
XGSPON output
XGSPON接口发送错误的报文数量
二层接口的概要信息
接口名称
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上是不通的
·     ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
·     Stby:表示该接口是一个处于Standby状态的备份接口
Speed
接口的速率(单位为bps)
Duplex
接口的双工模式
接口的链路类型
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
PVID
接口所在的缺省VLAN ID
接口的描述信息
1.1.8  display onu
display onu命令用来显示ONU信息。
(独立运行模式)‌
display onu [ silent [ sn ] | status [ keep-time keep-time ] ] { interface interface-type interface-number | slot slot-number }
display onu [ silent [ sn ] | status [ keep-time keep-time ] ] { interface interface-type interface-number | chassis chassis-number slot slot-number }
silent:显示处于静默状态(未注册)的ONU的信息。指定本参数且不指定[ mac | loid ] 参数时,显示的ONU均是以MAC地址进行绑定的。
sn:显示以序列号进行绑定的ONU的信息。
status:显示ONU的状态信息。
keep-time keep-time:显示状态持续时间大于等于指定值的ONU。keep-time为Offline或者Up状态的持续时间,单位为分钟,取值范围为1~4294967295。如果未指定本参数,则显示所有ONU的状态信息。
interface interface-type interface-number:显示指定接口上的ONU信息。interface-type表示接口类型,取值为Olt、Onu;interface-number表示接口编号。
slot slot-number:显示指定单板上的ONU信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的ONU信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
# 显示指定slot上的ONU状态信息。
<Sysname> display onu status slot 1
---------------------------------- Olt1/0/1 ---------------------------------
SN             Port            Model          State    KeepTime   Description
3c8c-40cf-0f9e Onu1/0/1:1      ET254-G-S      Up       2625       Onu1/0/1:1 Interface
3c8c-40cf-0bf0 Onu1/0/1:2      ET254-G-S      Up       2625       Onu1/0/1:2 Interface
3c8c-40cf-04fd Onu1/0/1:3      ET254-G-S      Offline  239        Onu1/0/1:3 Interface
ONUs found: 128
  Up ONUs: 109
  Down ONUs: 8
  Offline ONUs: 11
表1-3 display onu status命令显示信息描述表
SN
ONU的序列号。仅显示绑定了ONU接口的ONU设备
Port
被绑定的ONU接口
Model
ONU设备型号。若ONU为Offline状态,则显示为N/A
ONU状态,取值包括:
·     若ONU未上电,但已和ONU接口绑定,则显示为Offline。此时Time表示ONU的离线时间
·     若ONU已上电,且已经和ONU接口绑定,则显示为Up。此时Time表示ONU的在线时间
·     若ONU已经绑定,但ONU接口的数据链路层协议状态为关闭,则显示为Down。此时KeepTime显示为N/A,但ONU仍视为在线,在线时间会继续累积
KeepTime
ONU Offline或者Up状态的持续时间,单位为分钟
ONU接口的描述信息
如果未使用description命令配置ONU接口描述信息,则该字段显示为“接口名 Interface”,例如:Onu1/0/1:1 Interface
ONUs found
找到的ONU总数,具体包括:
·     Up ONUs:在线ONU数量
·     Down ONUs:Down状态的ONU数量
·     Offline ONUs:离线ONU数量
# 显示指定slot上的ONU信息。
<Sysname> display onu slot 1
---------------------------------- Olt1/0/24 --------------------------------
SN           Distance      Port             Model          Sft/Epm    State     Aging
Version/LineProfile/Loid/Password
H3CT904094C9 <1000         Onu1/0/24:1      ET904-H        107/       Up        N/A
A/ys2//
H3CT000006F6 <1000         Onu1/0/24:2      EGT904-H-TW    111/       Up        N/A
V1.0.1/ys2//
表1-4 display onu命令显示信息描述表
SN
ONU设备的序列号
Distance
OLT与ONU之间的光纤长度,单位为米。如果光纤长度远小于1km,显示为<1000;如果ONU未注册成功,则显示为N/A
Port
被绑定的ONU接口。若未绑定,则显示为N/A
Model
ONU的型号。若ONU未注册成功,则显示为N/A
Sft/Epm
ONU的软件版本号和EEPROM(Electrically Erasable Programmable Read-Only Memory,电可擦可编程只读存储器)的版本号
若ONU未注册成功,则显示为N/A
ONU状态:
·     若ONU已上电,但未和ONU接口绑定,则显示为Silent;
·     若ONU未上电,但已和ONU接口绑定,则显示为Offline;
·     若ONU已上电,且已经和ONU接口绑定,则显示为Up;
·     若ONU已经绑定,但ONU接口被手工SHUTDOWN,则显示为Down
Aging
显示处于静默(Silent)状态的ONU的MAC地址老化时间。对于非静默状态的ONU,则显示为N/A
ONU硬件版本号/ONU线路模板的名称/ONU的LOID/ONU的密码
The port is down.
OLT端口处于down状态
display onu sn命令用来显示指定序列号的合法ONU信息。
display onu sn serial-number
serial-number:表示ONU设备的序列号,为12个字符的字符串,区分大小写,不能包含字符“?”或十六进制数字0x0~0x20,且不能以字符“DEL”、“@”、“.”、“,”、“!”、“;”、“: ”、“`”、“"”开头或结尾。
# 显示指定序列号的合法ONU信息。
<Sysname> display onu sn h3c-12345678
SN           Distance       Port           Model/Version  Sft/Epm    State Aging        Password       ONU Line Profile
h3c-12345678 1200m          Onu1/0/1       BT/BV          S/E        Up   N/A          test           VOIP
关于各字段的解释,请参见“display onu”中的显示信息描述表。
display packet-drop命令用来显示接口丢弃的报文的信息。
(独立运行模式)‌
display packet-drop { interface [ interface-type [ interface-number ] ] | slot [ slot-number ] | summary }
display packet-drop { interface [ interface-type [ interface-number ] ] | chassis [ chassis-number [ slot slot-number ] ] | summary }
interface-type:显示指定类型接口丢弃的报文的信息。
interface-number:显示指定编号接口丢弃的报文的信息。
summary:将所有支持本命令的接口的丢弃报文统计信息累计后再显示。
slot [ slot-number ]:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示所有单板。(独立运行模式)
chassis [ chassis-number [ slot slot-number ] ]:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定chassis-number参数,则表示所有成员设备的所有单板。如果不指定slot参数,则表示所有成员设备。(IRF模式)‌
如果不指定接口类型和接口编号,显示所有支持本命令的接口的丢弃报文的信息。
如果仅指定接口类型,显示该类型所有支持本命令的接口的丢弃报文的信息。
# 显示Olt 1/4/0/5端口丢弃报文的信息。
<Sysname> display packet-drop interface Olt 1/4/0/5
Olt1/4/0/5:
  Packets dropped due to full GBP or insufficient bandwidth: 0
  Packets dropped due to Fast Filter Processor (FFP): 0
  Packets dropped due to STP non-forwarding state: 0
  Packets dropped due to insufficient data buffer. Input dropped: 0, Output dropped: 0
  Packets of ECN marked: 0
# 显示所有slot的丢弃报文统计信息。(独立运行模式)‌
<Sysname> display packet-drop slot
Slot            Total
0               210
1               210
2               210
# 显示所有chassis上所有slot的丢弃报文统计信息。(IRF模式)
<Sysname> display packet-drop chassis
Chassis         Slot            Total
1               0               210
2               0               210
                1               210
                2               210
表1-5 display packet-drop命令显示信息描述表
由于芯片缓存满或者带宽不够导致的丢包数
由于数据包被过滤所导致的丢包数
由于STP协议状态为discarding导致的丢包数
由于触发WRED(Weighted Random Early Detection,加权随机早期检测)队列门限导致ECN(Explicit Congestion Notification,显示拥塞通知)域被标记为11的报文数,有关WRED、ECN域的详细介绍请参见“ACL和QoS配置指导”中的“QoS”
Slot
Slot编号
Chassis
Chassis编号
Total
丢弃报文统计信息
display pon authentication-mode命令用来显示OLT的认证模式。
display pon authentication-mode [ interface interface-type interface-number ]
interface:显示指定接口的认证模式。如果不指定该参数,将显示FTTH认证模式和所有OLT端口的认证模式。
interface-type:指定接口类型,取值为Olt。
interface-number:指定接口编号。
# 显示FTTH认证模式和所有OLT的认证模式。
<Sysname> display pon authentication-mode
Ftth authentication mode:-
Interface              Authentication-mode
Olt1/0/1               sn
表1-6 display pon authentication-mode命令显示信息描述表
FTTH认证模式
·     未在FTTH视图下配置认证模式时,显示为“-”,此时采用缺省情况的FTTH认证模式
·     在FTTH视图下配置认证模式后,取值可能为:
¡     mac:表示所有OLT缺省基于ONU的MAC地址进行认证。
¡     loid:表示所有OLT缺省基于ONU的LOID进行认证。
¡     loid-password:表示所有OLT缺省基于ONU的LOID和LOID密码进行认证
¡     mac and loid:表示所有OLT缺省基于ONU的MAC地址或者LOID进行认证
¡     mac and loid-password:表示所有OLT缺省基于ONU的MAC地址或者LOID和LOID密码进行认证
¡     sn:表示所有OLT缺省基于ONU的序列号进行认证
¡     sn and password:表示所有OLT缺省基于ONU的序列号和密码进行认证
¡     password:表示所有OLT缺省基于ONU的密码进行认证
接口名称
Authentication mode
OLT认证模式
·     未在OLT端口视图下配置认证模式时,不显示该OLT端口,此时该OLT采用FTTH的认证模式
·     在OLT端口视图下配置认证模式后,取值可能为:
¡     mac:表示OLT基于ONU的MAC地址进行认证
¡     loid:表示OLT基于ONU的LOID进行认证
¡     loid-password:表示OLT基于ONU的LOID和LOID密码进行认证
¡     mac and loid:表示OLT基于ONU的MAC地址或者LOID进行认证
¡     mac and loid-password:表示OLT基于ONU的MAC地址或者LOID和LOID密码进行认证
¡     sn:表示OLT缺省基于ONU的序列号进行认证
¡     sn and password:表示OLT缺省基于ONU的序列号和密码进行认证
¡     password:表示OLT缺省基于ONU的密码进行认证
display pon diagnostic dba命令用来显示GPON的DBA诊断信息。
(独立运行模式)‌
display pon diagnostic dba slot slot-number
display pon diagnostic dba chassis chassis-number slot slot-number
slot slot-number:显示指定单板上的DBA诊断信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的DBA诊断信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
目前,DBA诊断信息仅包含带宽不足的ONU信息。
# 显示指定slot上GPON的DBA诊断信息。
<Sysname> display pon diagnostic dba slot 1
                 Total   Free    Fix     Assure
Olt1/0/1         8500000 2244000 256000  6000000
Olt1/0/4         8500000 8244000 256000  0
Olt1/0/23        8500000 8244000 256000  0
                 AllocId Fix     Assure  Max
Onu1/0/1:2       1026    0       3000000 0
Onu1/0/1:2       1027    0       2000000 0
Onu1/0/1:2       1028    0       1000000 0
Onu1/0/1:2       1029    0       0       200000
Onu1/0/1:2       1030    0       0       400000
Onu1/0/1:2       1031    0       0       600000
Onu1/0/1:2       1032    0       0       699968
Onu1/0/1:2       1033    0       0       800000
表1-7 display pon diagnostic dba命令显示信息描述表
Total
总带宽,单位kbps
Free
未分配的带宽,单位kbps
Fix
固定带宽,单位kbps
Assure
保证带宽,单位kbps
AllocId
分配标识符,区分同一ONU子接口下的不同T-CONT
Max
最大带宽,单位kbps
display pon diagnostic config命令用来显示ONU子接口的模板状态信息。
display pon diagnostic config interface interface-type interface-number
interface-type:指定接口类型,取值为Onu。
interface-number:指定ONU子接口编号。
# 显示指定ONU子接口的模板状态信息。
<Sysname> display pon diagnostic config interface onu 1/0/1:1.2
 Line Profile: line_profile_default
 Cfg  Profile: config_profile_default
 Mapping Mode: uni
 Upstream Fec: Default
 Encrypt: Enable
 SubInterface Number: 1
  SubInterface 1:
        Service Profile Name: service_profile_default
        Tcont Name: tcont_default
        Mapping info:
                Priority:
                Uni:all
                Vlan:
 Tcont Number: 1
  Tcont 1:
        Status: Enable
        Dba Name: dba_profile_default
表1-8 display pon diagnostic config命令显示信息描述表
Line Profile
ONU线路模板名称
Cfg  Profile
ONU配置模板名称
Mapping Mod
ONU子接口的ONU流量映射模式
Upstream Fec
ONU子接口上FEC功能的开启状态
·     Default:表示FEC功能开启
·     Disable:表示FEC功能关闭
Encrypt
ONU的下行流量加密功能
·     Enable:表示下行流量加密功能开启
·     Disable:表示下行流量加密功能关闭
SubInterface Number
ONU子接口数量
ONU子接口业务模板名称
Tcont Name
T-CONT名称
Mapping info
ONU子接口的流量映射信息
Tcont Number
T-CONT数量
Status
T-CONT状态
Tcont Name
T-CONT名称
Dba Name
ONU DBA模板名
display pon diagnostic config-error命令用来显示GPON配置下发失败信息。
(独立运行模式)‌
display pon diagnostic config-error { slot slot-number | interface interface-type interface-number }
display pon diagnostic config-error { chassis chassis-number slot slot-number | interface interface-type interface-number }
slot slot-number:显示指定单板上的GPON配置下发失败信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的GPON配置下发失败信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
interface-number:接口编号。
# 查询指定slot下模板配置下发失败情况。
<Sysname> display pon diagnostic config-error slot 1
Onu1/0/1:1
 Line Profile Name: line_profile_default  Cfg  Profile Name: config_profile_default
Onu1/0/1:2
 Line Profile Name: l1    Cfg  Profile Name: 1
Onu1/0/1:3
Onu1/0/4:1
 Line Profile Name: l2    Cfg  Profile Name: 1
表1-9 display pon diagnostic config-error命令显示信息描述表
Line Profile Name
ONU线路模板名称
Cfg  Profile Name
ONU配置模板名称
display pon diagnostic status命令用来显示ONU接口的链接状态。
display pon diagnostic status interface interface-type interface-number
# 显示指定ONU接口的链接状态。
<Sysname> display pon diagnostic status interface onu 1/0/1:1
 UpTime                : 2024-12-09 11:29:13
 DownTime              : 2024-12-09 11:29:11
 DownCause             : Change ONU distance triggers offline
表1-10 display pon diagnostic status命令显示信息描述表
UpTime
ONU接口上线时间
DownTime
ONU接口最后一次下线时间
DownCause
ONU接口最后一次下线原因
display pon fiber-backup group命令用来显示光纤备份组中的端口信息及其主备关系。
display pon fiber-backup group { group-number | all }
group-number:光纤备份组的编号,取值范围为1~240。
all:显示所有光纤备份组的信息。
# 显示所有光纤备份组的信息。其中含有Uplink interface字段的为跨设备光纤备份组。
<Sysname> display pon fiber-backup group all
Fiber backup group 1 information:
 Member         Role        State
 OLT1/0/1       Master      Active
 OLT1/0/2       Standby     Ready
Fiber backup group 2 information:
 Member         Role        State
 OLT1/0/3       Master      Other
 Uplink interface: GigabitEthernet1/0/20
表1-11 display pon fiber-backup group命令显示信息描述表
光纤备份组1的信息
Member
光纤备份组的成员端口(只能为OLT端口)
Role
OLT端口在备份组中的角色:
·     Master:主用端口。对于跨设备光纤备份组,表示命令行指定的主用端口
·     Standby:备用端口。对于跨设备光纤备份组,表示命令行指定的备用端口
OLT端口的状态:
·     Active:端口处于转发状态,为实际主用端口
·     Ready:端口处于备份状态
·     Other:其他情况,例如端口down
Uplink interface
跨设备光纤备份组的上行接口
·     对于跨设备光纤备份组,未配置该接口时,本字段显示为“-”
·     对于普通光纤备份组,本字段不显示
display pon onu-event命令用来显示ONU的注册和注销记录。
display pon onu-event interface interface-type interface-number
# 显示接口Onu1/0/1:1连接的ONU的注册和注销记录。
<Sysname> display pon onu-event interface onu 1/0/1:1
Date         Time       ONU Status    ONU Event
2015/06/24   14:41:18   Up            Registration
2015/06/24   14:41:59   Down          Deregistration
2015/06/24   14:42:02   Up            Registration
2015/06/24   14:42:49   Down          Deregistration
表1-12 display pon onu-event命令显示信息描述表
Date
ONU事件发生的日期
Time
ONU事件发生的时间
ONU Event
ONU事件:
·     Registration:注册
·     Deregistration:取消注册
·     Lob:发生丢包
·     Onu change Distance:ONU与OLT之间的距离发生变化
ONU Status
发生ONU事件时,ONU的状态:
·     Up:ONU状态为up
·     Down:ONU状态为down
display pon onu-loop-status命令用来显示ONU的UNI端口环路信息。
【命令】+
(独立运行模式)‌
display pon onu-loop-status { interface interface-type interface-number | slot slot-number }
display pon onu-loop-status { interface interface-type interface-number | chassis chassis-number slot slot-number }
interface interface-type interface-number:显示指定OLT端口或ONU接口连接的ONU的UNI端口环路信息。interface-type表示接口类型,取值为olt或onu;interface-number表示接口编号。接口类型为olt时,表示查看该OLT端口连接的所有ONU的UNI端口环路信息。
slot slot-number:显示指定单板上的所有OLT端口下的ONU的UNI端口环路信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的所有OLT端口下的ONU的UNI端口环路信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
通过本命令可以查看ONU的UNI端口最近上报的环路信息。
ONU设备上当UNI口存在环路且环路检测功能开启时,设备会自动检测并上报环路信息。可以通过本命令查看相关信息。
# 显示指定OLT端口下的所有ONU的UNI端口环路信息。
<Sysname> display pon onu-loop-status interface olt 1/0/1
ONU Interface  UNI      Date    Time
Onu1/0/1:1
                1    2024/09/27 18:13:55
                2    2024/09/27 18:13:55
                3    2024/09/27 18:13:55
表1-13 display pon onu-loop-status命令显示信息描述表
ONU Interface
ONU接口名称
UNI
UNI端口号
Date
UNI端口上报环路的日期
Time
UNI端口上报环路的时间
display pon onu-update命令用来显示ONU升级信息。
(独立运行模式)‌
display pon onu-update { interface interface-type interface-number | slot slot-number }
display pon onu-update { interface interface-type interface-number | chassis chassis-number slot slot-number }
interface interface-type interface-number:显示指定OLT端口或ONU接口连接的ONU的升级信息。interface-type表示接口类型,取值为olt或onu;interface-number表示接口编号。接口类型为olt时,表示查看该OLT端口连接的所有ONU的升级信息。
slot slot-number:显示指定单板上的所有OLT端口下的ONU升级信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的所有OLT端口下的ONU升级信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
# 显示指定slot上的ONU升级信息。
<Sysname> display pon onu-update slot 1
Port           Model            Version          Protocol   State
Onu1/0/1:3     ET924-H-POE      105              H3C        Not Configured
Onu1/0/1:4     ET924-H-POE      105              H3C        Not Configured
Onu1/0/1:5     ET916-H-A        107              H3C        Not Configured
Onu1/0/1:6     ET908-H-P        106              H3C        Not Configured
Onu1/0/1:7     ET904-H          203              H3C        Not Configured
ONUs found: 5
---------------------------------- Olt1/0/2 ---------------------------------
The port is down.
表1-14 display pon onu-update命令显示信息描述表
Port
绑定ONU设备的ONU接口
Model
ONU设备型号。若ONU未上电,则显示为N/A
Version
PCB版本号。若ONU未注册成功,则显示为N/A
Protocol
升级协议类型,取值包括:
·     H3C:H3C私有升级协议
·     CTC:CTC升级协议
ONU升级状态,取值包括:
·     Not configured:未配置升级ONU
·     Configured:已配置升级ONU,升级命令等待下发到对应的ONU
·     Updating(xx%):正在升级ONU,xx为当前进度的百分比
·     Active:升级文件的版本校验成功,正在重启ONU。如果ONU重启失败,则升级失败、版本回退
·     Update canceled:向ONU发送升级文件过程中,取消升级配置
·     Reconfigured:向ONU发送升级文件过程中,使用其他升级文件重新下发升级命令
·     Successful:ONU升级成功
·     Failed:ONU升级失败
·     Unsupported protocol:ONU不支持指定的升级协议
ONUs found
找到的ONU总数
The port is down.
OLT端口处于down状态
display pon optics-parameters命令用来显示OLT端口的光参数信息。
display pon optics-parameters interface interface-type interface-number
interface-number:OLT端口号。
# 显示Olt1/0/1端口的光参数信息。
<Sysname> display pon optics-parameters interface olt 1/0/1
Optical parameters:
 Temperature       :37.50 ℃
 Voltage           :3.27 V
 Bias              :1.74 mA
 Transmitter power :4.36 dBm
 Receiving power   :-15.00 dBm
表1-15 display pon optics-parameters命令显示信息描述表
Optical parameters
光参数信息
Temperature
温度
Voltage
电压
Bias
偏置电流
对于10G-PON单板上的OLT端口,该字段变为Bias(1G/10G),并同时显示1G-PON接口和10G-PON接口的偏置电流,例如24.36 mA/80.72 mA
Transmitter power
发射功率
对于10G-PON单板上的OLT端口,该字段变为Transmitter power(1G/10G),并同时显示1G-PON接口和10G-PON接口的发射功率,例如4.48 dBm/3.44 dBm
Receiving power
接收功率
对于10G-PON单板上的OLT端口,该字段变为Receiving power(1G/10G),并同时显示1G-PON接口和10G-PON接口的接收功率,例如-15.00 dBm/-5.00 dBm
display pon version命令用来显示OLT或ONU的版本信息。
display pon version interface interface-type interface-number
仅当接口的状态为up时,才能显示版本信息。
# 显示OLT的版本信息。
<Sysname> display pon version interface olt 1/0/1
Chip     : V1R1B1D008SP11, 20240716
Dba      : SoftWare, 20240815
Software : Mon Aug 19 07:45:13 UTC 2024
# 显示ONU的版本信息。
<Sysname> display pon version interface onu 1/0/1:1
 Model       : EGT904-H-TW
 HardWare    : V1.0.1
 Software    : 111
 Extend Model: EGT904-H-TW
表1-16 display pon version命令显示信息描述表
Olt
Chip
OLT的FPGA版本
Dba
软件DBA版本。Software表示为软件DBA
Software
软件DBA版本编译时间
Onu
Model
ONU型号
Hardware
ONU硬件版本号
Software
ONU软件版本号
Extend Model
ONU完整型号
1.1.22  display uni
display uni命令用来显示ONU上指定UNI端口的信息。
display uni uni-number
ONU接口视图
uni-number:UNI端口的编号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为32。
# 显示ONU的UNI端口1的信息。
[Sysname-Onu1/0/1:1] display uni 1
 UNI 1
 Description          :
 Port status          : Undo shutdown
 Flow control         : Closed
 Autonegotiation state: Enable
 Port isolation       : Disable
 MDI type             : Automdix
 Port policy :
   Inbound :
     CIR : 0
     Bucket depth : 0
     Extra burst size : 0
   Outbound :
     CIR : 0
     PIR : 0
 Vlan configuration :
   VLAN mode : Transparent
 Classification & marking :
 Multicast VLAN : None
 Multicast groups : 64
 Multicast VLAN untagging : Disable
 Multicast VLAN forwarding info:
  Multicast VLAN forwarding index:0
  VLAN ID:100
  Multicast MAC address:0100-5e00-0002
 Link state : DOWN
100Mbps-speed mode, Full-duplex mode
 Link speed type is autonegotiation, Link duplex type is autonegotiation
Input(total):  0 packets, 0 bytes
         0 broadcasts, 0 multicasts, 0 unicasts
 Input: 0 input errors, 0 runts, 0 giants,0 CRC,
         0 drop_events
Output(total): 0 packets, 0 bytes
 Output: 0 output errors, 0 runts, 0 giants, 0 CRC,
         0 drop_events
表1-17 display uni命令显示信息描述表
UNI
UNI端口号
显示UNI端口的描述信息。UNI端口未配置描述信息时为空
Port status
端口的管理状态:
·     Shutdown:表示该端口已经通过uni shutdown命令被关闭,即管理状态为关闭
·     Undo shutdown:表示该接口的管理状态为开启
Flow control
流量控制情况:
·     Open:表示流量控制功能开启
·     Closed:表示流量控制功能关闭
自协商功能状态:
·     Enable:表示自协商功能开启
·     Disable:表示自协商功能关闭
Port isolation
端口是否加入端口隔离组:
·     Enable:表示端口加入端口隔离组
·     Disable:表示端口不加入端口隔离组
MDI type
网线类型,取值为Automdix、Mdi或Mdix,与用户的配置有关
Port policy
UNI端口的上/下行流量监管参数:
·     Inbound:表示上行流量监管参数,包括CIR、Bucket depth和Extra burst size。相关配置命令为uni port-policy inbound
·     Outbound:表示下行流量监管参数,包括CIR和PIR。相关配置命令为uni port-policy outbound
Vlan configration
UNI端口的VLAN操作模式,包括:
·     Transparent:表示VLAN透传模式
·     Add-vlan-tag:表示VLAN标记模式
·     Translation:表示VLAN Translation模式
·     802.1q-in-802.1q:表示VLAN QinQ模式
·     Trunk:表示VLAN Trunk模式
·     Aggregation:表示VLAN N:1聚合模式
VLAN操作模式中可能出现的字段包括:
·     PVID:表示端口缺省VLAN ID
·     Priority:表示报文的802.1p优先级
·     Old VLAN:表示原始VLAN ID
·     New VLAN:表示转换后的VLAN ID
·     Trunk VLAN:表示端口允许通过的VLAN范围
相关配置命令为uni vlan-mode
流分类配置
Multicast VLAN
UNI端口加入的组播VLAN
Multicast groups
UNI端口支持的组播频道数目
是否开启了删除UNI端口下行组播流的VLAN Tag功能
UNI端口的未知组播报文透传功能的配置信息
VLAN ID
组播MAC地址对应的VLAN ID
透传的组播MAC地址
Link state
端口的链路层状态:
·     UP:表示数据链路层状态为开启
·     DOWN:表示数据链路层状态为关闭
Local autonegotiation ability
本地自协商能力
Autonegotiation advertisement ability
本地自协商通告能力
百兆全双工模式
端口速率处于双方自协商状态,端口双工状态为自协商状态
Input(total)
端口接收报文的统计值,包括:
·     报文、字节数
·     端口接收的广播报文、组播报文和单播报文的数量
Input
端口接收的错误帧、超小帧(runts)、超大帧(giants)、CRC校验错误的帧、分片报文(fragments)、有效长度大于指定最大长帧长度的帧(jabbers)、丢弃报文(discards)、丢弃事件(drop_events)、错误报文(errors)的数量
Packets of length(in octets)
端口接收的不同字节长度的报文数量
Output(total)
端口发送报文的统计值,包括:
·     报文、字节数
·     端口发送的广播报文、组播报文和单播报文的数量
Output
端口发送的错误帧、超小帧(runts)、超大帧(giants)、CRC校验错误的帧、分片报文(fragments)、有效长度大于指定最大长帧长度的帧(jabbers)、丢弃报文(discards)、丢弃事件(drop_events)、错误报文(errors)的数量
端口发送的不同字节长度的报文数量
Status change
端口的管理状态变更次数
display vendor-specific information命令用来显示ONU的详细信息。
ONU接口视图
# 显示Onu1/0/1:1接口对应ONU的详细信息。
[Sysname-Onu1/0/1:1] display vendor-specific information
 Serial number
     Vendor ID : H3CT
     ONU MAC address : 0000-0000-0000
     ONU model : EGT904-H-TW
     ONU hardware version : V1.0.1
     ONU software version : 212
     ONU extend model : EGT904-H-TW
 ONU capability :
     Gigabit ethernet interface :  Support
     Fast ethernet interface :  Not support
     VoIP service :  Support
     TDM ces service :  Not support
     Gigabit ethernet ports number :  4
     Fast ethernet ports number :  0
     POTS ports number :  1
     E1 ports number :  0
     Upstream queues number :  120
     Maximum queues per port upstream :  0
     Downstream queues number :  32
     Maximum queues per port downstream :  0
     Battery backup :  Not support
 ONU capability2 :
     ONU type :  SFU
     LLID number :  0
     Protection type :  Not support
     Slot number :  0
     PON number :  1
     Interface type number :  3
     VoIP ports number :  1
     GE ports number :  4
     FE ports number :  0
     WLAN ports number :  2
     CATV RF ports number :  0
 Onu-Type : 10G/10G
表1-18 display vendor-specific information命令显示信息描述表
Serial number
序列号
Vendor ID
ONU厂商ID
ONU MAC address
ONU 的MAC 地址
ONU model
ONU 类型
ONU 硬件版本
ONU 软件版本
ONU extend model
完整的ONU型号,CTC3.0标准时需要此字段
Firmware version
固件版本
Chipset information
芯片信息
·     Vendor ID:厂商ID
·     Chip model:芯片类型
·     Revision version:修订版本
·     Design date:设计日期
ONU capability
ONU能力信息
·     Gigabit ethernet interface:是否具有千兆以太网接口
·     Fast ethernet interface:是否具有百兆以太网接口
·     VoIP service:是否支持Voice over IP业务
·     TDM ces service:是否支持时分复用电路仿真(Circuit Emulation Service)业务
·     Gigabit ethernet ports number:千兆以太网端口数目
·     Fast ethernet ports number:百兆以太网端口数目
·     POTS ports number:POTS(Plain Old Telephone Service,传统电话业务)端口数量
·     E1 ports number:E1 端口数目
·     Upstream queues number:上行队列数目
·     Maximum queues per port upstream:每端口上行支持的最大队列数目
·     Downstream queues number:下行队列数目
·     Maximum queues per port downstream:每端口下行支持的最大队列数目
·     Battery backup:是否支持电池备份
ONU capability(CTC2.1)
ONU能力信息(CTC2.1标准)
·     ONU type:ONU设备形态,包括SFU(Single Family Unit,单个家庭用户单元)、HGU(Home Gateway Unit,家庭网关单元)、SBU(Single Business Unit,单个商业用户单元)、盒式MDU(Multi-Dwelling Unit,多住户单元)、插卡式MDU和MTU(Multi-Tenant Unit,多租户单元)
·     LLID number:ONU支持的LLID数量
·     Protection type:ONU支持的光链路保护类型,包括类型c和类型d
·     Slot number:插卡式ONU的业务槽位数量
·     PON number:ONU支持的上联PON口数量
·     Interface type number:ONU的接口类型数量
·     VoIP ports number:ONU的VoIP接口数量
·     GE ports number:ONU的千兆以太网接口数量
·     FE ports number:ONU的百兆以太网接口数量
·     WLAN ports number:ONU的WLAN接口数量
·     CATV RF ports number:ONU的CATV RF接口数量
ONU capability(CTC3.0)
ONU能力信息(CTC3.0标准)
·     IPV6 supported:是否支持IPv6感知
·     Power supply control:是否支持ONU电源控制,包括ONU Tx电源控制和ONU Rx电源控制
·     Service SLA:是否支持SLA(Service Level Agreement,服务等级协定)功能
Forward error correction ability
是否支持FEC 功能
IGMP-snooping fast-leave
是否支持指定UNI端口快速离开功能
Multicast control fast-leave
是否支持所有UNI端口快速离开功能
Forward error correction mode
是否开启FEC 功能
DBA-Report parameters
DBA Report 消息参数
·     Queue sets number:表示支持的队列集数量
·     Queue set:队列集编号
·     Queue x: State:x , Value:x:队列x的状态(State)及阈值(Value),当State为0 表示该队列关闭,为1 表示该队列开启
Multicast-fast-leave
是否开启了ONU下所有UNI端口快速离开功能
ONU-Isolate state
是否开启了ONU下所有UNI端口隔离功能
Onu-Type
ONU设备PON口上行/下行带宽
Multicast-mode
组播模式:IGSP(IGMP Snooping)或者multicast control
fiber-backup group命令用来创建光纤备份组,并进入光纤备份组视图。如果指定的光纤备份组已经存在,则直接进入光纤备份组视图。
undo fiber-backup group命令用来删除光纤备份组。
fiber-backup group group-number [ multidevice ]
undo fiber-backup group group-number
不存在光纤备份组。
FTTH视图
multidevice:创建跨设备光纤备份组。不指定本参数时,创建的是普通光纤备份组。
光纤备份组有以下两种形式:
·     普通光纤备份组:互为备份的两个OLT端口属于同一OLT设备。
·     跨设备光纤备份组:互为备份的两个OLT端口分别属于两台OLT设备。两台OLT设备之间通过TCP连接来同步数据。
# 创建普通光纤备份组1,并进入光纤备份组视图。
[Sysname] ftth
[Sysname-ftth] fiber-backup group 1
·     member
·     port fiber-backup group
fiber-backup tcp命令用来配置跨设备光纤备份组的TCP连接参数。
undo fiber-backup tcp命令用来恢复缺省情况。
fiber-backup tcp local-ip local-ip-address peer-ip peer-ip-address
未配置跨设备光纤备份组的TCP连接参数。
FTTH视图
local-ip local-ip-address:本端设备的IP地址。
peer-ip peer-ip-address:对端设备的IP地址。
跨设备光纤备份组所在的两台设备通过TCP连接来同步数据。
# 配置跨设备光纤备份组的TCP连接参数。
[Sysname] ftth
[Sysname-ftth] fiber-backup tcp local-ip 192.168.56.1 peer-ip 192.168.56.2
·     fiber-backup group
1.1.26  ip address
ip address命令用来配置ONU的管理VLAN的IPv4地址。
undo ip address命令用来将ONU的管理VLAN的IPv4地址恢复为缺省情况。
ip address { dhcp-alloc | ip-address { mask-length | mask } gateway gateway }
undo ip address
未配置ONU的管理VLAN接口的IPv4地址。
ONU接口视图
ONU配置模板视图
dhcp-alloc:通过DHCP功能自动获取IPv4地址。
ip-address:手工配置的接口IPv4地址,为点分十进制格式。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为1~31。
mask:接口IPv4地址相应的子网掩码,为点分十进制格式。
gateway gateway:网关IPv4地址。
ONU绑定了线路模板后,再配置管理VLAN的IPv4地址功能才能生效。
如果用management-vlan命令改变ONU的管理VLAN,原管理VLAN接口的IP地址将被清除。
ONU接口配置管理VLAN的IP地址时,设备不提示与其他接口配置的IP地址是否重复。当多个端口配置相同IP地址时,仅最先配置的IP地址有效。
在ONU配置模板视图下,仅支持dhcp-alloc参数。
# 配置ONU的IPv4地址为192.168.0.1/24,网关为192.168.0.99。
[Sysname-Onu1/0/1:1] ip address 192.168.0.1 24 gateway 192.168.0.99
·     management-vlan
1.1.27  ipv6 address
ipv6 address命令用来配置ONU的管理VLAN接口的IPv6地址。
undo ipv6 address命令用来删除ONU的管理VLAN接口的IPv6地址。
ipv6 address { dhcp-alloc | { ipv6-address prefix-length | ipv6-address/prefix-length } gateway gateway }
undo ipv6 address
未配置ONU的管理VLAN接口的IPv6地址。
ONU接口视图
dhcp-alloc:通过DHCP功能自动获取IPv6地址。
ipv6-address:ONU的管理VLAN接口的IPv6地址。
prefix-length:前缀长度,取值范围为1~128。
gateway gateway:网关的IPv6地址。
ONU绑定了线路模板后,再配置管理VLAN的IPv6地址功能才能生效。
# 开启ONU的管理VLAN接口,配置该接口的IPv6地址为2001::1,前缀长度为64,网关的IPv6地址为2001::99。
[Sysname-Onu1/0/1:1] undo shutdown management-vlan-interface
[Sysname-Onu1/0/1:1] ipv6 address 2001::1/64 gateway 2001::99
·     management-vlan
management server命令用来配置ONU的AD-Campus服务器连接参数。
undo management server命令用来删除ONU的AD-Campus服务器连接参数。
management server source-ip ip-address [ port port-number ] [ keepalive interval ] password { cipher | simple } string
未配置ONU的AD-Campus服务器连接参数。
FTTH视图
source-ip ip-address:服务器的IPv4地址。
port port-number:ONU与服务器建立连接时使用的TCP端口号,取值范围为1~65535。如果未指定本参数,表示未配置TCP端口号。
keepalive interval:ONU发送Keepalive报文的时间间隔,取值范围为1~600,单位为秒。缺省值为60秒。
password cipher:以密文方式设置密码。
password simple:以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~63个字符的字符串。密文密码为1~117个字符的字符串。
AD-Campus(应用驱动园区网)组网中,OLT为ONU提供上网服务。通过本命令,可在OLT上远程配置ONU的AD-Campus服务器连接参数,便于ONU与服务器建立连接。
# 配置ONU的AD-Campus服务器连接参数,其中IP地址为10.1.1.1,ONU发送Keepalive报文的时间间隔为100秒,建立连接时使用的TCP端口号为800,密码为12345678TESTplat&!。
[Sysname] ftth
[Sysname-ftth] management server source-ip 10.1.1.1 port 800 keepalive interval 100 password simple 12345678TESTplat&!
management-vlan命令用来配置ONU的管理VLAN。
undo management-vlan命令用来将ONU的管理VLAN恢复为缺省情况。
management-vlan vlan-id
管理VLAN为VLAN 1。
ONU接口视图
ONU配置模板视图
vlan-id :管理VLAN ID,取值范围为1~4094。
如果改变ONU的管理VLAN,原管理VLAN接口的IP地址将被清除。
# 设置ONU的管理VLAN为VLAN 10。
[Sysname-Onu1/0/1:1] management-vlan 10
·     shutdown management-vlan-interface
1.1.30  member
member命令用来向光纤备份组中添加OLT端口。
undo member命令用来将OLT端口从光纤备份组中删除。
member olt interface-number [ master | standby ]
undo member olt interface-number
光纤备份组中未添加OLT端口。
光纤备份组视图
olt interface-number:OLT端口的编号。
master:指定添加的OLT端口为跨设备光纤备份组的主用端口。
standby:指定添加的OLT端口为跨设备光纤备份组的备用端口。
在Type B组网中,建议先执行shutdown olt关闭目标端口, 待光纤连接、下游onu设备物理组网且olt口已加入备份组后,再通过undo shutdown olt 命令启用端口。
一个光纤备份组只能包含两个OLT端口。需要注意的是:
·     普通光纤备份组不支持指定master或standby参数。先加入普通光纤备份组的OLT端口为主用端口,后加入的为备用端口。
·     跨设备光纤备份组必须指定master或standby参数。请确保两台设备的跨设备光纤备份组ID相同,且其中一台设备上的该备份组包含一个主用端口,另一台设备的该备份组包含一个备用端口。
本命令和port fiber-backup group命令视图不同,执行效果相同。
在同一单板上,重启单板或者进行版本升级前,备份组配置和自动绑定配置不能同时存在,需要先删除此单板上的自动绑定配置,后将备份组中olt口下的onu设备进行绑定配置后再重新开启自动绑定功能。
# 将Olt1/0/1端口加入到普通光纤备份组1。
[Sysname] ftth
[Sysname-fiber-group1] member olt 1/0/1
1.1.31  olt-mode
olt-mode命令用来配置OLT工作模式。
undo olt-mode命令用来恢复缺省情况。
(独立运行模式)‌
olt-mode slot slot-number { 64-onu | 128-onu | 256-onu }
undo olt-mode slot slot-number
olt-mode chassis chassis-number slot slot-number { 64-onu | 128-onu | 256-onu }
undo olt-mode chassis chassis-number slot slot-number
OLT工作模式为64-ONU。
FTTH视图
slot slot-number:配置指定单板的OLT工作模式,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备指定单板的OLT工作模式,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
64-onu:64-ONU模式。该模式下指定slot的每个OLT端口支持创建的ONU接口数量上限为64。
128-onu:128-ONU模式。该模式下指定slot的每个OLT端口支持创建的ONU接口数量上限为128。
256-onu:256-ONU模式。该模式下指定slot的每个OLT端口支持创建的ONU接口数量上限为256。
切换slot的OLT工作模式后,需要重启该slot或者重启设备才能使OLT工作模式生效。
·     如果重启slot,则该slot上的OLT端口都恢复为缺省配置,这些OLT端口上创建的ONU接口也会被删除。
·     从128-ONU模式或256-ONU模式切换到64-ONU模式时,编号大于64的ONU接口会被删除。从256-ONU模式切换到128-ONU模式时,编号大于128的ONU接口会被删除。
# 配置指定slot的OLT工作模式为128-ONU。
[Sysname] ftth
[Sysname-ftth] olt-mode slot 1 128-onu
onu bind auto命令用来开启ONU自动绑定功能。
undo onu bind auto命令用来关闭ONU自动绑定功能。
(独立运行模式)‌
onu bind auto [ slot slot-number ] [ bind-type { mac | sn }* ]
undo onu bind auto [ slot slot-number ] [ bind-type { mac | sn}* ]
onu bind auto [ chassis chassis-number slot slot-number ] [ bind-type { mac | sn }* ]
undo onu bind auto [ chassis chassis-number slot slot-number ] [ bind-type { mac | sn }* ]
ONU自动绑定功能处于关闭状态。
FTTH视图
slot slot-number:开启指定单板上的ONU自动绑定功能,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU自动绑定功能。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备指定单板上的ONU自动绑定功能,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU自动绑定功能。(IRF模式)‌
bind-type:指定ONU绑定时使用的媒介。不指定本参数时,ONU使用其序列号或MAC地址进行绑定。
mac:表示ONU使用其MAC地址进行绑定。
sn:表示ONU使用其序列号进行绑定。
配置ONU自动绑定后,设备不仅会自动将未注册的ONU设备绑定到ONU接口上,而且对于后加入的ONU 设备也会进行自动绑定。
这种绑定方式适用于对OLT下面连接的ONU设备完全信任的情况。如果要解除某个ONU的绑定,需要先使用undo onu bind auto命令关闭ONU自动绑定功能。
多次执行带有bind-type参数的本命令时,ONU绑定时使用的媒介是多次配置的集合。
undo onu bind auto命令不指定bind-type参数时,表示关闭ONU的自动绑定功能。undo onu bind auto命令指定bind-type参数时,表示取消ONU使用指定媒介进行自动绑定。
# 开启指定slot上的ONU自动绑定功能。
[Sysname] ftth
[Sysname-ftth] onu bind auto slot 1
onu bind batch命令用来开启ONU批量绑定功能。
(独立运行模式)‌
onu bind batch [ slot slot-number ] [ bind-type sn ]
onu bind batch [ chassis chassis-number slot slot-number ] [ bind-type sn ]
ONU批量绑定功能处于关闭状态。
FTTH视图
slot slot-number:开启指定单板上的ONU批量绑定功能,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU批量绑定功能。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备指定单板上的ONU批量绑定功能,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU批量绑定功能。(IRF模式)‌
bind-type:指定ONU绑定时使用的媒介。不指定本参数时,ONU使用其序列号进行绑定。
sn:表示ONU使用其序列号进行绑定。
开启ONU批量绑定后,设备会自动将未注册的ONU设备绑定到ONU接口上,对于后加入的ONU不再进行绑定处理。
这种绑定方式适用于网络环境最初建立时,确定ONU 都是合法的,可以省去大量繁琐的绑定操作。而之后为了防止非法ONU 自动注册,对于新加入的ONU,可以再使用bind onu-id命令单独绑定。
# 开启指定slot上的ONU批量绑定功能。
[Sysname] ftth
[Sysname-ftth] onu bind batch slot 1
onu bind type命令用来按ONU类型指定批量应用的ONU线路模板。
undo onu bind type命令用来恢复缺省情况。
onu bind type onu-type [ onu-line-profile profile-name ]
undo onu bind type onu-type
批量应用的ONU线路模板为line_profile_default。
FTTH视图
OLT端口视图
onu-type:ONU类型,如ET704-A等,为1~31个字符的字符串,区分大小写。
onu-line-profile profile-name:指定ONU类型应用的ONU线路模板名称,为1~31个字符的字符串,区分大小写,仅支持数字、字母、下划线。未指定本参数时,批量应用缺省的ONU线路模板line_profile_default。
应用场景
开启ONU自动绑定(onu bind auto命令)或ONU批量绑定(onu bind batch命令)后,设备会自动将未注册的ONU设备绑定到ONU接口上:
·     对于本命令指定的ONU类型,ONU接口将会应用命令指定的ONU线路模板
·     对于未指定的ONU类型,ONU接口应用缺省的ONU线路模板line_profile_default
注意事项
在FTTH视图下最多支持为32种ONU类型指定批量应用的ONU线路模板。在OLT接口视图下最多支持为8种ONU类型指定批量应用的ONU线路模板。
在FTTH视图下配置本命令,对设备上的所有OLT端口生效;在OLT接口视图下配置本命令,仅对当前OLT接口生效。同时配置以上两种情况时,以OLT接口视图下的配置为准。
如果配置本命令时指定的线路模板不存在,则不为ONU应用线路模板,直到指定的线路模板被创建,后续上线的ONU才能应用该线路模板。
本命令仅对未应用ONU线路模板的ONU接口生效。
# 为类型为ET704-A-L的所有ONU指定批量应用的ONU线路模板line_profile_voip。之后开启指定slot上的ONU自动绑定功能。
[Sysname] ftth
[Sysname-ftth] onu bind type et704-a-l onu-line-profile line_profile_voip
# 在Olt1/0/1端口下,配置为类型为ET704-A-L的所有ONU指定批量应用的ONU线路模板line_profile_voip。
[Sysname] interface Olt 1/0/1
[Sysname-Olt1/0/1] onu bind type et704-a-l onu-line-profile line_profile_voip
1.1.35  onu-distance
onu-distance命令用来在OLT测距过程中设置OLT与ONU之间的最大和最小逻辑距离。
undo onu-distance命令用来恢复缺省情况。
onu-distance { max distance |  min distance } *
undo onu-distance
OLT与ONU之间的最大逻辑距离为20千米,最小逻辑距离为0千米。
OLT端口视图
max distance:OLT与ONU之间的最大距离,取值范围为0~60,单位为千米。
min distance:OLT与ONU之间的最小距离,取值范围为0~60,单位为千米。
应用场景
在ONU上线过程中,OLT需要测量ONU与OLT的光纤物理距离,并据此为ONU分配时序,以避免上行数据冲突。为了尽快获得测距结果,可以预先设置OLT与ONU之间的逻辑距离。
工作机制
最大逻辑距离定义了OLT和ONU之间可接受的最大距离,这个距离决定了OLT发送信号到接收ONU回复的最长等待时间。如果实际物理距离超过这个距离,OLT将认为ONU无法达到,因此无法建立连接。
最小逻辑距离定义了OLT和ONU之间可接受的最小距离,这个距离决定了OLT发送信号到接收ONU回复的最短等待时间。如果实际物理距离低于这个距离,OLT将认为ONU过于接近,可能会导致信号干扰,因此也无法建立连接。
最小逻辑距离越小,OLT越可能更快地收到ONU的回复消息,最大逻辑距离越大,OLT便可以与越远距离的ONU建立连接,因此,适当地调整这两个参数,可以尽快地精准测量出OLT与ONU之间的距离。
注意事项
请在具有一定PON网络部署知识的情况下再通过本命令修改测距时的逻辑距离,否则推荐使用缺省配置,以免配置错误的参数取值反而造成测距过程耗时变长。
最小逻辑距离应小于最大逻辑距离。
# 在接口Olt1/0/1中,在OLT测距过程中设置OLT与ONU之间的最大和最小逻辑距离分别为30千米和15千米。
[Sysname-Olt1/0/1] onu-distance max 30 min 15
port fiber-backup group命令用来将OLT端口加入光纤备份组。
undo port fiber-backup group命令用来恢复缺省情况。
port fiber-backup group group-number [ master | standby ]
OLT端口未加入任何光纤备份组。
OLT端口视图
group-number:光纤备份组的编号,取值范围为1~240。必须是已创建的光纤备份组。
通过TCP连接跨设备光纤备份组时,两台设备同时配置master或standby参数会导致配置冲突。
本命令和member命令视图不同,执行效果相同。
# 将Olt1/0/1端口加入普通光纤备份组1。
[Sysname] ftth
[Sysname-fiber-group1] quit
[Sysname-Olt1/0/1] port fiber-backup group 1
·     member
port switch-over命令用来手动切换光纤备份组内主备端口。
port switch-over
光纤备份组视图
仅当备用OLT端口处于Ready状态时,本命令才能成功执行。
执行该命令后,原主用OLT端口切换成备用端口,原备用OLT端口则切换成主用端口。
# 将光纤备份组1中的两个OLT端口手动进行主备切换。
[Sysname] ftth
[Sysname-fiber-group1] port switch-over
preamble repeat count命令用来设置ONU上行突发中前导码的重复次数。
undo preamble repeat count命令用来恢复缺省情况。
preamble repeat count repeat-number
本命令的缺省情况与设备的型号有关,请以设备的实际情况为准。
OLT端口视图
repeat-number:前导码的重复次数,取值范围为1~255。
在ONU上行突发报文中,前导码字段用于OLT的信号同步以及标识一个报文的开始。
重复前导码字段可以带来如下改变:
·     多个前导码为OLT提供更长的时间来进行信号同步,可以增强数据传输的稳定性。
·     多个前导码可以减少因前导码解析错误导致的丢包,从而提高数据传输的可靠性。
·     但多个前导码会导致上行突发报文变长,占用更多的带宽,从而降低数据传输效率。
·     前导码重复次数太小会降低数据传输的可靠性,甚至导致OLT不能信号同步而丢包、ONU不能注册等现象。
·     推荐使用缺省的前导码重复次数,如需修改,请在专业技术支持工程师的指导下配置。
·     在OLT端口视图下执行本命令后,对该端口下接入的所有ONU生效。
# 在接口Olt1/0/1下,设置ONU上行突发中前导码的重复次数为10次。
[Sysname-Olt1/0/1] preamble repeat count 10
shutdown management-vlan-interface命令用来关闭ONU的管理VLAN接口。
undo shutdown management-vlan-interface命令用来开启ONU的管理VLAN接口。
管理VLAN接口处于Shutdown状态。
ONU接口视图
ONU配置模板视图
开启ONU的管理VLAN接口后,必须配置该接口的IP地址。
当执行undo shutdown management-vlan-interface命令后,管理VLAN接口的状态与该VLAN内以太网端口(即UNI端口)状态有关:
·     当ONU的管理VLAN接口对应VLAN下的所有以太网端口状态为down时,则管理VLAN接口为关闭状态;
·     当ONU的管理VLAN接口对应VLAN下有一个或一个以上的以太网端口处于up状态,则管理VLAN接口处于打开状态。
# 开启ONU的管理VLAN接口。
uplink interface命令用来配置跨设备光纤备份组的上行接口。
undo uplink interface命令用来恢复缺省情况。
uplink interface interface-type interface-number
未配置跨设备光纤备份组的上行接口。
光纤备份组视图
interface-type:指定接口类型,只能为二层以太网接口/二层聚合接口。
仅跨设备光纤备份组支持配置本命令。
一个跨设备光纤备份组只能配置一个上行接口。同一接口可以作为不同跨设备光纤备份组的上行接口。
# 配置跨设备光纤备份组的上行接口为GigabitEthernet 1/0/20。
[Sysname] ftth
[Sysname-ftth] fiber-backup group 1 multidevice
[Sysname-fiber-group1] uplink interface gigabitethernet 1/0/20
1.1.41  using onu
using onu命令用来创建ONU接口。
undo using onu命令用来删除ONU接口。
using onu onu-number-list
undo using onu onu-number-list
未创建ONU接口。
OLT端口视图
onu-number-list:指定的ONU接口编号列表。表示方式为onu-number-list = { onu-number1 [ to onu-number2 ] }&<1-10>,onu-number2必须大于或等于onu-number1。onu-number1、onu-number2的取值范围与OLT工作模式有关。当OLT工作模式为64-ONU时,取值范围为1~64;当OLT工作模式为128-ONU时,取值范围为1~128;当OLT工作模式为256-ONU时,取值范围为1~256。&<1-10>表示前面的参数最多可以输入10次。
OLT端口下使用本命令创建的是ONU接口,接口名称为onu interface-number。
# 在Olt1/0/2端口上创建ONU接口1。
[Sysname] interface Olt 1/0/2
[Sysname-Olt1/0/2] using onu 1
1.2  GPON配置模板命令
本节主要介绍ONU配置模板、ONU DBA模板、ONU线路模板、ONU子接口业务模板相关的GPON基础命令。
apply onu-config-profile命令用来将ONU配置模板应用到ONU线路模板。
undo apply onu-config-profile命令用来恢复缺省情况。
apply onu-config-profile profile-name
当前ONU线路模板应用缺省的ONU配置模板config_profile_default。
ONU线路模板视图
profile-name:模板名称,为1~31个字符的字符串,区分大小写。
关于ONU配置模板的介绍,请参见onu config-profile命令。
多次执行本命令,最后一次执行的命令生效。
# 将指定ONU配置模板应用到ONU线路模板ET354。
[Sysname] onu line-profile ET354
[Sysname-onu-lineprofile-ET354] apply onu-config-profile config-ET354
·     onu config-profile
apply onu-service-profile命令用来将ONU子接口业务模板应用到ONU线路模板子接口。
undo apply onu-service-profile命令用来恢复缺省情况。
apply onu-service-profile profile-name
当前ONU线路模板子接口应用缺省的ONU子接口业务模板service_profile_default。
ONU线路模板子接口视图
关于ONU子接口业务模板的介绍,请参见onu service-profile命令。
# 将指定ONU子接口业务模板应用到ONU线路模板30的子接口2。
[Sysname] onu line-profile 30
[Sysname-onu-lineprofile-30] subinterface 2
[Sysname-onu-lineprofile-30-subinterface-2] apply onu-service-profile YY
·     onu service-profile
1.2.3  apply tcont
apply tcont命令用来将T-CONT应用到ONU线路模板子接口。
undo apply tcont命令用来恢复缺省情况。
apply tcont tcont-name
undo apply tcont
当前ONU线路模板子接口应用名为tcont_default的缺省T-CONT,该T-CONT使用ONU DBA模板dba_profile_default。
ONU线路模板子接口
tcont-name:T-CONT名称,必须是ONU线路模板中已创建的T-CONT。
关于T-CONT的介绍,请参见tcont命令。
# 在ONU线路模板30下配置名为voip的T-CONT,指定该T-CONT使用名为dba-voip的ONU DBA模板。进入ONU线路模板子接口2,将名为voip的T-CONT应用到该子接口。
[Sysname-onu-lineprofile-30] tcont voip onu-dba-profile dba-voip
[Sysname-onu-lineprofile-30-subinterface-2] apply tcont voip
·     tcont
bind onu-line-profile命令用来为ONU接口应用ONU线路模板。
undo bind onu-line-profile命令用来取消为ONU接口应用ONU线路模板。
bind onu-line-profile profile-name
ONU接口未应用ONU线路模板。
ONU接口视图
onu-line-profile profile-name:ONU线路模板的名称,为1~31个字符的字符串,区分大小写。必须指定已创建的模板。
多个ONU接口可以应用同一个ONU线路模板,为ONU接口应用ONU线路模板后,模板中存放的命令将下发到ONU接口,以节省配置工作量,实现自动化批量配置。
# 为ONU接口Onu1/0/1:1应用名为VOIP的ONU线路模板。
[Sysname-Onu1/0/1:1] bind onu-line-profile VOIP
·     onu line-profile
1.2.5  dba type1
dba type1命令用来配置第1类DBA(Dynamic Bandwidth Allocation,动态带宽分配),即固定带宽。
undo dba type命令用来恢复缺省情况。
dba type1 [ ratio ] fix fix-bandwidth
undo dba type
新建的ONU DBA模板中不存在带宽配置。
ONU DBA模板视图
ratio:表示以千分比形式配置带宽。不指定该参数时,配置的是带宽值。
fix fix-bandwidth:预留给ONU的固定带宽,取值范围为128~10000000,单位为kbps,配置后自动向下取整为64的整数倍。和ratio参数一起使用时,取值范围为1~1000,单位为ONU最大带宽的千分之一。
应用场景
固定带宽完全预留给特定ONU,即使该ONU没有上行业务流,这部分带宽也不能为其他ONU使用。固定带宽主要用于对业务质量要求很高的业务,如VoIP。
推荐配置
由于不同ONU设备的最大带宽可能不同,建议以千分比形式配置带宽。
注意事项
在同一DBA模板下多次执行dba type1、dba type2、dba type3、dba type4和dba type5命令时,以最后一次执行的命令为准。
# 配置第1类DBA:固定宽带为15Mbps。
[Sysname] onu dba-profile dba_15M
[Sysname-onu-dbaprofile-dba_15M] dba type1 fix 15000
1.2.6  dba type2
dba type2命令用来配置第2类DBA,即保证带宽。
dba type2 [ ratio ] assure assure-bandwidth
undo dba type
ONU DBA模板视图
assure assure-bandwidth:可分配给ONU的保证带宽,取值范围为128~10000000,单位为kbps,配置后自动向下取整为64的整数倍。和ratio参数一起使用时,取值范围为1~1000,单位为ONU最大带宽的千分之一。
应用场景
保证带宽指OLT分配给ONU使用的带宽,但如果该ONU的实际流量没有达到保证带宽,则DBA机制可将剩余带宽分配给其他ONU。
推荐配置
注意事项
# 配置第2类DBA:保证宽带为15Mbps。
[Sysname-onu-dbaprofile-dba_15M] dba type3 assure 15000
1.2.7  dba type3
dba type3命令用来配置第3类DBA,即保证带宽+最大带宽。
dba type3 [ ratio ] assure assure-bandwidth max max-bandwidth
undo dba type
ONU DBA模板视图
assure assure-bandwidth:可分配给ONU的保证带宽,取值范围为128~9999999,单位为kbps,取值不为64的整数倍时,实际生效值为向下取64‌的整数倍数。和ratio参数一起使用时,取值范围为1~999,单位为ONU最大带宽的千分之一。
max max-bandwidth:允许ONU使用的最大带宽,取值范围动态变化,最大值为10000000,最小值为assure-bandwidth实际生效值与64之和,单位为kbps,取值不为64的整数倍时,实际生效值为向下取64的整数倍数。和ratio参数一起使用时,取值范围动态变化,最大值为1000,最小值为assure-bandwidth加1,单位为ONU最大带宽的千分之一。
应用场景
使用第3类DBA的ONU,除了已分配的保证带宽之外,还能抢占一定带宽,但总带宽不超过最大带宽。
第3类DBA主要应用于VoIP、IPTV业务。
推荐配置
注意事项
最大带宽的实际生效值必须大于保证带宽的实际生效值。
# 配置第3类DBA:保证宽带为15Mbps,最大宽带为30Mbps。
[Sysname-onu-dbaprofile-dba_15M] dba type3 assure 15000 max 30000
1.2.8  dba type4
dba type4命令用来配置第4类DBA,即最大带宽。
dba type4 [ ratio ] max max-bandwidth [ priority priority | weight weight ] *
undo dba type
ONU DBA模板视图
max max-bandwidth:允许ONU使用的最大带宽,取值范围为128~10000000,单位为kbps,配置后自动向下取整为64的整数倍。和ratio参数一起使用时,取值范围为1~1000,单位为ONU最大带宽的千分之一。
priority priority:带宽分配优先级,取值范围为0~7。
weight weight:带宽分配权重,取值范围为1~10000。
应用场景
第4类DBA主要应用于普通上网业务。
推荐配置
注意事项
# 配置第4类DBA:最大宽带为30Mbps。
[Sysname-onu-dbaprofile-dba_15M] dba type4 max 30000
1.2.9  dba type5
dba type5命令用来配置第5类DBA,即固定带宽+保证带宽+最大带宽。
dba type5 [ ratio ] fix fix-bandwidth assure assure-bandwidth max max-bandwidth [ additional-bandwidth { non-assure | best-effort [ priority priority | weight weight ] * } ]
undo dba type
ONU DBA模板视图
fix fix-bandwidth:预留给ONU的固定带宽,取值范围为128~9999872,单位为kbps,取值不为64的整数倍时,实际生效值为向下取64的整数倍数。和ratio参数一起使用时,取值范围为1~999,单位为ONU最大带宽的千分之一。
assure assure-bandwidth:可分配给ONU的保证带宽,取值范围为动态变化,最小值为128,最大值为10000000与fix-bandwidth的实际生效值之差,单位为kbps,取值不为64的整数倍时,实际生效值为向下取64的整数倍数。和ratio参数一起使用时,取值范围动态变化,最小值为1,最大值为1000与fix-bandwidth之差,单位为ONU最大带宽的千分之一。
max max-bandwidth:允许ONU使用的最大带宽,取值范围动态变化,最大值为10000000,最小值为fix-bandwidth、assure-bandwidth的实际生效值之和加64,单位为kbps,取值不为64的整数倍时,实际生效值为向下取64的整数倍数。和ratio参数一起使用时,取值范围动态变化,最大值为1000,最小值为fix-bandwidth、assure-bandwidth之和,单位为ONU最大带宽的千分之一。
additional-bandwidth:最大带宽的附加带宽类型。未指定本参数时,缺省值为best-effort。
non-assure:按非保证方式分配最大带宽。当带宽分配需要按照fix和assure比例分配时,建议使用此参数。
best-effort:按尽力而为方式分配最大带宽。当带宽分配需要按照max的比例分配时,建议使用此参数。
应用场景
使用第5类DBA的ONU,除了拥有OLT为其预留的固定带宽,还能在需要时获得更大的保证带宽,另外还能抢占一定带宽,但总带宽不超过最大带宽。
推荐配置
注意事项
最大带宽的实际生效值必须大于固定带宽和保证带宽的实际生效值之和。
# 配置第5类DBA:固定带宽为128Mbps,保证带宽为128Mbps,最大带宽为500Mbps。
[Sysname] onu dba-profile dba_profile_1
[Sysname-onu-dbaprofile-dba_profile_1] dba type5 fix 128000 assure 128000 max 500000
display onu-config-profile命令用来显示ONU配置模板的信息。
display onu-config-profile [ profile-name profile-name ]
profile-name profile-name:显示指定模板的详细信息。profile-name表示模板名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有模板的概要信息。
# 显示所有ONU配置模板的概要信息。
<Sysname> display onu-config-profile
Profile name
  cfg-profile_1
# 显示名为cfg_profile_1的ONU配置模板的详细信息。
<Sysname> display onu-config-profile profile-name cfg_profile_1
Profile-name : cfg_profile_1
  ONU port-isolate : Disabled
  ONU multicast fast-leave : Disabled
  ONU protocol :
    DHCP-snooping : Disabled
    DHCP-snooping information : Disabled
    IGMP-snooping suppression leave : Enabled
    IGMP-snooping suppression report : Disabled
    IGMP-snooping timer host-aging-time : 260
    IGMP-snooping timer max-response-time : 1
    IGMP-snooping timer router-aging-time : 105
    Loopback-detection : Enabled
    PPPoE : Disabled
    STP : Disabled
  ONU statistics : Enabled
  Multicast mode IGMP-snooping :
    Multicast-control host-aging-time 260
  Service-sla mode : sp-wrr high-priority-boundary 3
  Service-sla queue :
    queue 1 sp fixed-bandwidth 0 guaranteed-bandwidth 0 best-effort-bandwidth 0
    queue 2 sp fixed-bandwidth 0 guaranteed-bandwidth 0 best-effort-bandwidth 0
    queue 3 sp fixed-bandwidth 256 guaranteed-bandwidth 256 best-effort-bandwidth 256
  UNI 1 config :
    Auto-negotiation : Enabled
    Classification-marking :
      index 2 queue 2 priority 3 vlan-id equal 100
      index 3 queue 5 priority 3 vlan-id equal 100
    Duplex : full
    Flow-control : Disabled
    Igmp-snooping fast-leave : Disabled
    MDIX-mode : automdix
    Multicast-group-number : 64
    Multicast-strip-tag : Disabled
    Port-isolation : Disabled
    Port-policy inbound : cir 64
    Shutdown : false
    Speed : auto
    Statistics : Enabled
    VLAN-mode : transparent  pvid 1
表1-19 display onu-config-profile命令显示信息描述表
Profile name
配置模板的名称
ONU port-isolate
所有UNI端口是否加入隔离组
所有UNI端口快速离开功能
ONU protocol
ONU协议相关配置:
·     DHCP-snooping:DHCP-Snooping协议
·     DHCP-snooping information:DHCP-Snooping Option 82协议
·     IGMP-snooping suppression leave:IGMP离开组报文
·     IGMP-snooping suppression report:IGMP成员关系报告报文
·     IGMP-snooping timer host-aging-time:动态成员端口的老化时间
·     IGMP-snooping timer max-response-time:IGMP普遍组查询的最大响应时间
·     IGMP-snooping timer router-aging-time:动态路由器端口老化时间
·     Loopback-detection:环路检测协议
·     PPPoE:PPPoE+协议
·     STP:快速生成树协议
ONU protocal loopback-detection action
ONU的环路检测处理模式
·     shutdown:当ONU检测到UNI端口出现环路时,自动关闭该端口。
·     none:当ONU检测到UNI端口出现环路时,不做任何处理。
ONU statistics
报文统计功能
Multicast mode
组播模式相关配置(IGMP Snooping或者multicast control)
Multicast-control host-aging-time表示组播组成员端口老化时间
Service-sla mode
上行流量队列调度模式
Service-sla queue
上行流量队列
UNI 1 config
配置模板下指定uni的配置信息
Auto-negotiation
UNI端口的自协商功能
UNI端口的描述信息
Duplex
UNI端口双工状态:
·     auto:端口处于自协商状态。
·     full:端口处于全双工状态。
·     half:端口处于半双工状态。
Flow-control
UNI端口的流量控制功能
MDIX-mode
UNI端口的MDIX(Media-dependent Interface-crossover)模式:
·     automdix:两端设备通过协商来决定引脚1和2是发送还是接收信号,引脚3和6是接收还是发送信号。
·     mdi:使用引脚1和2发送信号,使用引脚3和6接收信号。
·     mdix:使用引脚1和2接收信号,使用引脚3和6发送信号。
Port-isolation
UNI端口是否加入隔离组
QinQ
UNI端口QinQ信息:
·     svlan:外层VLAN
·     cvlan:内层VLAN
·     transparent-vlan:透传VLAN
Shutdown
UNI端口shutdown状态:
·     true:开启
·     false:关闭
Speed
UNI端口速率:
·     10:端口速率为10Mbps。
·     100:端口速率为100Mbps。
·     1000:端口速率为100Mbps。
·     auto:端口速率处于双方自协商状态。
Statistics
UNI端口的统计功能开关
VLAN-mode
UNI端口的VLAN操作模式:
·     VLAN透传模式:transparent
·     VLAN标记模式:tag
·     VLAN Translation模式:translation
·     VLAN QinQ模式:qinq
·     VLAN Trunk模式:trunk
·     VLAN N:1聚合模式:aggregation
display onu-dba-profile命令用来显示ONU DBA模板的信息。
display onu-dba-profile [ profile-name profile-name ]
# 显示所有ONU DBA模板的概要信息。
<Sysname> display onu-dba-profile
Profile name                     Type Assured  Max      Fix
dba_profile_default              3    8192     20480    6400
dba2                             1    8192     20480    6400
dba3                             5    8192     20480    6400
# 显示名为111的ONU DBA模板的详细信息。
<Sysname> display onu-dba-profile profile-name 111
Profile name :            111
  Type:                   5
  Fixed (kbps):           2048
  Assured (kbps):         2048
  Max (kbps):             10240
  Additional-bandwidth:   best-effort
  Best-effort-priority:   0
  Best-effort-weight:     10
表1-20 display onu-dba-profile命令显示信息描述表
Profile name
ONU DBA模板的名字
type
ONU DBA模板的类型:
·     1:固定带宽
·     2:保证带宽
·     3:保证带宽+最大带宽
·     4:最大带宽
·     5:固定带宽+保证带宽+最大带宽
Assured
保证带宽:
·     如果在ONU DBA模板中以绝对值形式配置带宽时,单位为kbps
·     如果在ONU DBA模板中以千分比形式配置带宽时,单位为千分之一
Max
最大带宽:
Fix
固定带宽:
Fixed
固定带宽:
附加带宽类型:
·     non-assure:非保证带宽分配
·     best-effort:尽力而为带宽分配
尽力而为带宽分配的优先级
Best-effort-weight
尽力而为带宽分配的权重
display onu-line-profile命令用来显示ONU线路模板的信息。
display onu-line-profile [ profile-name profile-name ]
# 显示所有ONU线路模板的概要信息。
<Sysname> display onu-line-profile
Profile name
  line-profile_1
# 显示名为line_profile_2的ONU线路模板的详细信息。
<Sysname> display onu-line-profile line_profile_2
Profile name : line_profile_2
  TCONT list :
    TCONT name                                                     DBA profile
    TCONT_1                                                        dba_1
    TCONT_voip                                                     dba_viop
  Config profile : config_voip
  Mapping mode : vlan
  ONU subinterface list :
    SubNo  TCONT name                                              Service profile
    1      TCONT_1                                                 bridge_1_voip
    3      TCONT_1                                                 bridge_1_voip
  Interface list :
    ONU3/1/0:1
    ONU3/1/0:2
表1-21 display onu-line-profile命令显示信息描述表
Profile name
ONU线路模板名称
TCONT list
T-CONT列表
TCONT name
T-CONT名称
DBA profile
ONU DBA模板名
Config profile
ONU配置模板名
Mapping mode
ONU子接口的ONU流量映射模式
ONU子接口列表
SubNo
ONU子接口编号
Service profile
ONU子接口业务模板名
Interface list
绑定该线路模板的onu接口列表
display onu-service-profile命令用来显示ONU子接口业务模板的信息。
display onu-service-profile [ profile-name profile-name ]
# 显示所有ONU子接口业务模板的概要信息。
<Sysname> display onu-service-profile
Profile name
  bridge_service_1
# 显示名为bridge_service_profile_2的ONU子接口业务模板的详细信息。
<Sysname> display onu-service-profile profile-name bridge_service_profile_2
Profile name : bridge_service_profile_2
  VLAN mapping
    Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
    10            N/A           120                      N/A
    200           100
  Port VLAN (hybrid)
    PVID  VLAN Passing
    100   Tagged:  1000, 1002, 1500, 1600-1611, 2000,
                   2555-2558, 3000, 4000
          Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
                   150-160, 200, 255, 286, 300-302
表1-22 display onu-service-profile命令显示信息描述表
Profile-name
业务模板的名字
Outer VLAN
原始外层VLAN:
·     对于1:1 VLAN映射、N:1 VLAN映射和1:2 VLAN映射,Outer VLAN表示原始VLAN
·     对于0:2 VLAN映射,Outer VLAN显示为N/A
Inner VLAN
原始内层VLAN:
·     对于1:1 VLAN映射、N:1 VLAN映射和1:2 VLAN映射,Inner VLAN显示为N/A
·     对于0:2 VLAN映射,Inner VLAN显示为N/A
转换后的外层VLAN:
·     对于1:1 VLAN映射、2:1 VLAN映射和N:1 VLAN映射,Translated Outer VLAN表示转换后VLAN
·     对于0:2 VLAN映射,Translated Outer VLAN表示添加的外层VLAN
转换后的内层VLAN:
·     对于1:1 VLAN映射、2:1 VLAN映射和N:1 VLAN映射,Translated Inner VLAN显示为N/A
·     对于0:2 VLAN映射,Translated Inner VLAN表示添加的内层VLAN
Nested VLAN
2:3 VLAN映射添加的最外层VLAN
PVID
使用该业务模板的端口缺省VLAN ID
VLAN Passing
表示使用该业务模板的端口实际通过的VLAN(该VLAN已经创建,并且接口允许其通过)
Tagged
表示哪些VLAN的报文通过使用该业务模板的端口时必须携带VLAN Tag
Untagged
表示哪些VLAN的报文通过使用该业务模板的端口时必须去掉VLAN Tag
encryption enable命令用来开启ONU的下行流量加密功能。
undo encryption enable命令用来关闭ONU的下行流量加密功能。
encryption enable
ONU的下行流量加密功能处于开启状态。
ONU线路模板视图
ONU的下行流量加密功能是指在光网络中,通过加密技术对从OLT到ONU的下行流量进行保护,保障用户的数据安全。
# 在ONU线路模板1中,开启ONU的下行流量加密功能。
[Sysname] onu line-profile 1
[Sysname-onu-lineprofile-1] encryption enable
forward-error-correction enable命令用来开启ONU的FEC功能。
undo forward-error-correction enable命令用来关闭ONU的FEC功能。
ONU的FEC功能处于开启状态。
ONU线路模板视图
FEC(Forward Error Correction,前向错误纠错)技术通过向数据流添加冗余信息来使接收方能够检测和纠正错误,从而提高数据传输的可靠性,减少数据重传的时间和成本。此外,FEC所需的计算能力和存储空间相对较小,对ONU设备的性能要求不高。
对于XGSPON或XGPON类型的ONU,下行方向的FEC功能强制开启不能关闭;上行方向的FEC功能在缺省情况下处于开启状态,但是可以被关闭。对于GPON类型的ONU,FEC功能在缺省情况下处于关闭状态,且可以控制开启/关闭状态。
# 在ONU线路模板1中,开启ONU的FEC功能。
[Sysname-onu-lineprofile-1] forward-error-correction enable
gpon compare-profile命令用来显示指定模板之间的配置差异。
gpon compare-profile { onu-config-profile | onu-dba-profile | onu-line-profile | onu-service-profile } source-profile-name profile-name destination-profile-name profile-name
onu-config-profile:表示模板类型为ONU线路模板。
onu-dba-profile:表示模板类型为ONU DBA模板。
onu-line-profile:表示模板类型为ONU线路模板。
onu-service-profile:表示模板类型为ONU子接口业务模板。
source-profile-name profile-name:指定要比较的源模板名称。profile-name表示模板名称,为1~31个字符的字符串,区分大小写,仅支持数字、字母、下划线。
destination-profile-name profile-name:指定要比较的目标模板名称。profile-name表示模板名称,为1~31个字符的字符串,区分大小写,仅支持数字、字母、下划线。
# 显示指定2个线路模板之间的配置差异。
[Sysname] gpon compare-profile onu-line-profile source-profile-name l1 destination-profile-name l3
Differences:
--- Source profile
+++ Destination profile
@@ -1,12 +1,13 @@
-onu line-profile l1
+onu line-profile l3
  apply onu-config-profile config_profile_default
+ tcont t1 onu-dba-profile dba_profile_default
  tcont tcont_default onu-dba-profile dba_profile_default
  subinterface 1
   apply tcont tcont_default
   apply onu-service-profile service_profile_default
- subinterface 2
-  apply tcont tcont_default
+ subinterface 3
+  apply tcont t1
gpon copy-profile命令用来快速新增GPON配置模板,并从源模板复制配置到这些模板。
gpon copy-profile { onu-config-profile | onu-dba-profile | onu-line-profile | onu-service-profile } source-profile-name profile-name { destination-profile-name profile-name } &<1-15>
onu-config-profile:表示模板类型为ONU配置模板。
source-profile-name profile-name:指定复制配置的源模板名称。profile-name表示模板名称,为1~31个字符的字符串,区分大小写,仅支持数字、字母、下划线。
destination-profile-name profile-name:指定粘贴配置的目标模板名称。profile-name表示模板名称,为1~31个字符的字符串,区分大小写,仅支持数字、字母、下划线。
&<1-15>:表示目标模板最多可以输入15个。
源模板类型和目标模板类型必须相同。源模板必须存在,目标模板不能与现有的同名。
# 快速增加ONU DBA模板a、b,将缺省ONU DBA模板dba_profile_default中的配置复制到这些模板。
[Sysname] gpon copy-profile onu-dba-profile source-profile-name dba_profile_default destination-profile-name a destination-profile-name b
Create new profile successfully
Dba profile name:
  a
  b
Total:2
1.2.18  mapping-mode
mapping-mode命令用来配置ONU的流量映射方式。
undo mapping-mode命令用来恢复缺省情况。
mapping-mode { priority | uni | vlan }
undo mapping-mode
ONU的流量映射方式为UNI端口号映射。
ONU线路模板视图
priority:802.1p优先级映射方式。
vlan:VLAN映射方式。
uni:UNI端口号映射方式。
应用场景
ONU设备的来自用户侧的流量,需要按一定规则映射到ONU子接口,才能上行到OLT。
注意事项
mapping-mode命令仅定义了ONU线路模板的子接口可用的流量映射方式。具体映射配置需要到ONU线路模板子接口下使用onu-mapping命令。
# 配置ONU线路模板30的ONU的流量映射方式为VLAN。
[Sysname-onu-lineprofile-30] mapping-mode vlan
·     onu-mapping
onu config-profile命令用来创建ONU配置模板,并进入ONU配置模板视图。如果指定的ONU配置模板已存在,则直接进入其视图。
undo onu config-profile命令用来删除ONU配置模板。
onu config-profile profile-name
undo onu config-profile profile-name
存在缺省的ONU配置模板config_profile_default。
应用场景
ONU配置模板主要用于集中存放ONU的UNI端口配置命令,通过apply onu-config-profile命令可以将这些命令应用到ONU线路模板。
工作机制
ONU配置模板含有如下命令。对于缺省模板config_profile_default,这些命令均使用缺省值。
·     GPON组播命令
·     onu protocol loopback-detection action
·     service-sla mode(GPON命令参考/GPON QoS)
·     service-sla queue(GPON命令参考/GPON QoS)
·     uni auto-negotiation
·     uni classification-marking(GPON命令参考/GPON QoS)
·     uni description
·     uni duplex
·     uni flow-control
·     uni port-isolate
·     uni port-policy inbound(GPON命令参考/GPON QoS)
·     uni port-policy outbound(GPON命令参考/GPON QoS)
·     uni speed
·     uni statistics enable
·     uni vlan-mode
注意事项
ONU配置模板被应用到ONU线路模板后,如果要删除该ONU配置模板,必须先在ONU线路模板视图下使用undo apply onu-config-profile命令恢复缺省情况。
最多支持同时存在1024个配置模板。
# 创建名ONU配置模板1,并进入其视图。
[Sysname] onu config-profile 1
[Sysname-onu-cfgprofile-1]
·     apply onu-config-profile
1.2.20  onu dba-profile
onu dba-profile命令用来创建ONU DBA模板,并进入ONU DBA模板视图。如果指定的ONU DBA模板已存在,则直接进入其视图。
undo onu dba-profile命令用来删除ONU DBA模板。
onu dba-profile profile-name
undo onu dba-profile profile-name
存在缺省的ONU DBA模板dba_profile_default。
应用场景
ONU DBA模板用于集中存放ONU子接口的dba type系列命令,通过apply tcont命令可以将T-CONT对应ONU DBA模板的命令应用到ONU线路模板子接口。
工作机制
ONU DBA模板支持如下命令。
·     dba type1
·     dba type2
·     dba type3
·     dba type4
·     dba type5
缺省模板dba_profile_default中存在预配置dba type4 ratio max 1000。新建ONU DBA模板则不存在配置。
注意事项
ONU DBA模板被T-CONT使用后,如果要删除该ONU DBA模板,必须先在ONU线路模板视图下使用undo tcont命令删除相关T-CONT。
最多支持同时存在512个DBA模板。
# 创建名为dba_15M的ONU DBA模板,并进入其视图。
[Sysname-onu-dba-profile-dba_15M]
·     apply tcont
·     tcont
1.2.21  onu flow
onu flow命令用来配置ONU组播/广播报文的多VLAN转发。
undo onu flow命令用来取消ONU组播/广播报文的多VLAN转发配置。
onu flow flow-id vlan vlan-id { destination-ip ipv4-address { mask-length | mask } | destination-mac mac-address } [ udp-port port-number ] forward-vlan vlan-list
undo onu flow flow-id
未配置ONU组播/广播报文的多VLAN转发。
flow-id:流匹配规则的ID号,取值范围为1~1000。ID越小,流匹配的优先级越高。
vlan vlan-id:组播或广播报文所属的VLAN。vlan-id表示VLAN的编号,取值范围为1~4094。
destination-ip ipv4-address:组播或广播报文的目的IPv4地址,为点分十进制格式。其中组播IP地址取值范围为224.0.0.0~239.255.255.255,广播IP地址为255.255.255.255。
mask:IPv4地址的掩码,为点分十进制格式。
destination-mac mac-address:组播或广播报文的目的MAC地址,格式为H-H-H。其中组播MAC地址取值范围为0100-5E00-0000~0100-5EFF-FFFF,广播MAC地址为FFFF-FFFF-FFFF。
udp-port port-number:组播或广播报文的UDP端口号,取值范围为1~65535。如果未指定本参数,则匹配组播或广播报文时不关注UDP端口号。
forward-vlan vlan-list:转发VLAN的列表。vlan-list表示多个VLAN的编号,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>。其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
应用场景
使用本命令可以实现灵活的二层跨VLAN转发。当OLT设备从指定VLAN中收到来自ONU的、目的MAC地址/目的IP地址为指定地址、目的端口为指定端口号的报文时,设备会将这样的报文直接在指定目标VLAN中转发。
注意事项
最多支持1000条流匹配规则。
本命令不支持在M-LAG组网中配置。
本命令不支持组播IPv6报文匹配。
多次执行本命令,且指定的flow-id相同时,最后一次执行的命令生效。
# 配置ID为1的流匹配规则:将VLAN 1、目的IP地址为255.1.1.1/16网段的组播报文转发至VLAN 10~20。
[Sysname] onu flow 1 vlan 1 destination-ip 255.1.1.1 16 forward-vlan 10 to 20
1.2.22  onu line-profile
onu line-profile命令用来创建ONU线路模板,并进入ONU线路模板视图。如果指定的ONU线路模板已存在,则直接进入其视图。
undo onu line-profile命令用来删除ONU线路模板。
onu line-profile profile-name
undo onu line-profile profile-name
存在缺省的ONU线路模板line_profile_default。
应用场景
ONU线路模板用于集中存放GPON ONU的配置命令,通过bind onu-id命令将ONU设备绑定到ONU接口时可以应用该模板,将模板中存放的命令下发到ONU接口。
一个ONU线路模板可以应用到多个ONU接口,节省配置工作量。
工作机制
ONU线路模板含有如下命令。对于缺省模板line_profile_default,这些命令均使用缺省值。
·     encryption enable
·     forward-error-correction enable
·     mapping-mode
·     subinterface
·     tcont
注意事项
ONU线路模板被应用到ONU接口后,如果要删除该ONU线路模板,必须先使用undo bind onu-id命令解除相关ONU接口和ONU设备的绑定。
最多支持同时存在1024个线路模板。
# 创建名为ET354的ONU线路模板,并进入其视图。
·     bind onu-id
1.2.23  onu port-isolate enable
onu port-isolate enable命令用来将ONU下的所有UNI端口加入隔离组。
undo onu port-isolate enable命令用来将ONU下的所有UNI端口从隔离组中删除。
ONU下的UNI端口未加入隔离组。
ONU配置模板视图
一台ONU只支持一个隔离组。隔离组内端口数不受限制。
本命令和uni port-isolate命令互斥,不能同时配置。
# 在ONU配置模板1中,将ONU下的所有UNI端口加入隔离组。
[Sysname-onu-cfgprofile-1] onu port-isolate enable
·     uni port-isolate
1.2.24  onu protocol enable
onu protocol enable命令用来开启ONU的业务特性。
undo onu protocol enable命令用来关闭指定的业务特性。
onu protocol { loopback-detection } enable
undo onu protocol { loopback-detection } enable
环路检测处于开启状态。
ONU配置模板视图
loopback-detection:环路检测协议。
# 在ONU配置模板1中,开启ONU的环路检测功能。
[Sysname-onu-cfgprofile-1] onu protocol loopback-detection enable
1.2.25  onu protocol loopback-detection action
onu protocol loopback-detection action命令用来配置ONU的环路检测处理模式。
undo onu protocol loopback-detection action命令用来恢复缺省情况。
onu protocol loopback-detection action { none | shutdown }
ONU的环路检测处理模式为shutdown。
ONU配置模板视图
none:当ONU检测到UNI端口出现环路时,不对该端口进行任何处理。
# 在ONU配置模板1中,配置ONU的环路检测处理模式为shutdown。
[Sysname-onu-cfgprofile-1] onu protocol loopback-detection action shutdown
1.2.26  onu service-profile
onu service-profile命令用来创建ONU子接口业务模板,并进入ONU子接口业务模板视图。如果指定的ONU子接口业务模板已存在,则直接进入其视图。
undo onu service-profile命令用来删除ONU子接口业务模板。
onu service-profile profile-name [ realtime ]
undo onu service-profile profile-name
存在缺省的ONU子接口业务模板service_profile_default。
realtime:创建实时下发配置的业务模板,在此类型的业务在模板中执行的配置,会实时下发给该模板应用到的所有ONU子接口。未指定本参数时,如果业务模板已经被应用,则模板中下发的配置无法修改,如果想要修改,只能先取消应用线路模板后重新应用线路模板。
应用场景
ONU子接口业务模板用于集中存放ONU子接口的VLAN等二层技术配置命令,通过apply onu-service-profile命令可以将这些命令应用到ONU线路模板子接口。
工作机制
ONU子接口业务模板支持如下命令。对于缺省模板service_profile_default,这些命令均使用缺省值(端口的链路类型为Access,属于VLAN 1)。
·     port access vlan(二层技术-以太网交换命令参考/VLAN)
·     port hybrid pvid(二层技术-以太网交换命令参考/VLAN)
·     port hybrid vlan(二层技术-以太网交换命令参考/VLAN)
·     port link-type(二层技术-以太网交换命令参考/VLAN)
·     port trunk permit vlan(二层技术-以太网交换命令参考/VLAN)
·     port trunk pvid(二层技术-以太网交换命令参考/VLAN)
·     vlan mapping(二层技术-以太网交换命令参考/VLAN映射)
注意事项
ONU子接口业务模板被应用到ONU线路模板子接口后,如果要删除该ONU子接口业务模板,必须先在ONU线路模板子接口视图下使用undo apply onu-service-profile命令恢复缺省情况。
最多支持同时存在1024个业务模板。
指定了realtime参数时:
·     修改业务模板的配置后,该配置会实时下发给该业务模板所有应用到的ONU子接口,在应用的子接口较多时,此同步下发操作可能占用较长时间,在此过程中不允许执行以下操作:
¡     创建或删除线路模板子接口。
¡     删除正在下发配置的业务模板。
¡     删除正在下发配置的业务模板应用到的线路模板和ONU接口。
¡     修改其他实时下发配置的业务模板的配置。
·     修改业务模板的配置后,如果该配置实时下发到某个ONU子接口时失败,则在遍历所有应用的ONU子接口下发配置完成后,系统会打印出下发失败的ONU子接口列表(最多打印100个接口名称)。
# 创建名为YY的ONU子接口业务模板,并进入其视图。
[Sysname] onu service-profile YY
[Sysname-onu-srvprofile-YY]
# 进入实时下发配置的业务模板视图,并修改其配置。
[Sysname] onu service-profile YY realtime
Configuration under this view may take a long time. Continue?[Y/N]:Y
[Sysname-onu-srvprofile-YY+] vlan mapping 1 translated-vlan 101
·     apply onu-service-profile
1.2.27  onu statistics enable
onu statistics enable命令用来开启ONU的统计功能。
undo onu statistics enable命令用来关闭ONU的统计功能。
ONU的统计功能处于开启状态。
ONU配置模板视图
# 在ONU配置模板1中,开启ONU的统计功能。
[Sysname-onu-cfgprofile-1] onu statistics enable
1.2.28  onu-mapping
onu-mapping命令用来配置ONU子接口的流量映射。
undo onu-mapping命令用来恢复缺省情况。
onu-mapping { [ uni [ all | { uni-number [ to uni-number ] }&<1-32> ] ] [vlan [ untag | { vlan-id [ to vlan-id ] }&<1-12> ] ] [ priority [ all | { priority [ to priority ] }&<1-8> ] ] }
undo onu-mapping
允许所有UNI端口的流量映射到子接口。
ONU线路模板子接口视图
uni all:将所有UNI端口的流量映射到子接口。
uni { uni-number [ to uni-number ] }&<1-32>:将指定UNI端口的流量映射到子接口。其中,uni-number为UNI端口号,取值范围为1~32,uni-number to uni-number表示一个UNI端口号范围,&<1-32>表示前面的参数最多可以输入32次。
priority all:将所有报文优先级的流量映射到子接口。
priority priority [ to priority ] }&<1-8>:将指定报文优先级的流量映射到子接口。其中,priority为报文优先级,取值范围为0~7,取值越大,优先级越高;priority to priority表示一个优先级范围,&<1-8>表示前面的参数最多可以输入8次。
vlan untag:将不携带VLAN Tag的流量映射到子接口。
vlan vlan-id [ to vlan-id ] }&<1-12>:将携带指定VLAN Tag的流量映射到子接口。其中,vlan-id为VLAN ID,取值范围为1~4094,vlan-id to vlan-id表示一个VLAN范围,&<1-12>表示前面的参数最多可以输入12次,且一个子接口最多支持12个VLAN ID。
应用场景
注意事项
ONU线路模板子接口上onu-mapping命令配置的流量映射方式,需要和ONU线路模板下的mapping-mode命令保持一致。
onu-mapping命令具有如下限制:
·     多次执行本命令时,最后一次执行的命令生效。
·     不同子接口不能存在配置重叠。
·     处于mapping-mode uni模式时,onu-mapping uni all为子接口1下的缺省配置,其他子接口无缺省配置,此时其他子接口不能配置onu-mapping uni命令。处于其他mapping-mode模式时,所有子接口无onu-mapping命令的缺省配置。
# 配置ONU线路模板30的ONU的流量映射方式为VLAN,然后在子接口1中配置来自VLAN 1的报文映射到该子接口。
[Sysname-onu-lineprofile-30] subinterface 1
[Sysname-onu-lineprofile-30-subinterface-1] onu-mapping vlan 1
·     mapping-mode
1.2.29  subinterface
subinterface命令用来创建ONU线路模板子接口,并进入ONU线路模板子接口视图。如果指定的ONU线路模板子接口已存在,则直接进入其视图。
undo subinterface命令用来删除ONU线路模板子接口。
subinterface subnumber
undo subinterface subnumber
ONU线路模板中已创建缺省子接口subinterface 1。
ONU线路模板视图
subnumber:子接口编号,取值范围为1~8。一个ONU线路模板最多支持配置8个子接口。
应用场景
ONU线路模板的子接口用来规划ONU子接口的配置,当ONU接口应用ONU线路模板时,会生成该模板指定子接口编号的ONU子接口和相关配置。
ONU子接口是标识OLT和ONU之间业务流的虚拟接口。通过不同的ONU子接口,可以为同一ONU配置不同的业务。
工作机制
ONU线路模板子接口含有如下命令。对于缺省子接口subinterface 1,这些命令均使用缺省值。
·     apply tcont
·     onu-mapping
# 为ONU线路模板30创建子接口2,并进入其视图。
完成上述配置后,将ONU绑定到Onu1/0/1:1接口且应用该ONU线路模板,可以生成子接口编号为2的ONU子接口Onu1/0/1:1.2。
[Sysname-onu-lineprofile-30-subinterface-2] quit
[Sysname-onu-lineprofile-30] quit
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] bind onu-id sn h3c-12345678
[Sysname-Onu1/0/1:1] bind onu-line-profile 30
[Sysname-Onu1/0/1:1] quit
[Sysname] interface onu 1/0/1:1.2
[Sysname-Onu1/0/1:1.2]
·     apply tcont
·     onu-mapping
1.2.30  tcont
tcont命令用来创建T-CONT,并指定该T-CONT使用的ONU DBA模板。
undo tcont命令用来删除T-CONT。
tcont tcont-name [ onu-dba-profile profile-name ]
undo tcont tcont-name
ONU线路模板已创建名为tcont_default的缺省T-CONT,该T-CONT使用ONU DBA模板dba_profile_default。
ONU线路模板视图
tcont-name:T-CONT名称,为1~31个字符的字符串,区分大小写。
onu-dba-profile profile-name:T-CONT使用的ONU DBA模板名称,必须是已创建的ONU DBA模板。未指定本参数时,T-CONT使用缺省的ONU DBA模板dba_profile_default。
应用场景
T-CONT(Transmission Container,传输容器)是GPON网络上行方向承载业务的载体,所有ONU子接口的业务流量都需要映射到T-CONT中,再由OLT通过DBA(Dynamic Bandwidth Allocation,动态带宽分配)调度上行。
创建T-CONT后,通过apply tcont命令可以将T-CONT应用到ONU线路模板子接口,使子接口的流量映射到该T-CONT。
注意事项
T-CONT被应用到ONU线路模板子接口后,如果要删除该T-CONT,必须先在ONU线路模板子接口视图下使用undo apply tcont命令恢复缺省情况。
ONU线路模板支持配置的T-CONT数量上限为8。
# 在ONU线路模板30下配置名为voip的T-CONT,并指定该T-CONT使用名为dba-voip的ONU DBA模板。
·     apply tcont
1.2.31  uni auto-negotiation
uni auto-negotiation命令用来开启UNI端口的自协商功能。
undo uni auto-negotiation命令用来关闭UNI端口的自协商功能。
uni uni-number auto-negotiation
undo uni uni-number auto-negotiation
UNI端口的自协商功能处于开启状态。
ONU配置模板视图
uni-number :UNI端口号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为32。
本命令与双工状态(uni duplex)、MDIX模式(uni mdix-mode)和速率(uni speed)配置命令互斥,不能同时配置。
# 在ONU配置模板1中,开启UNI 1的自协商功能。
[Sysname-onu-cfgprofile-1] uni 1 auto-negotiation
1.2.32  uni description
uni description命令用来设置UNI端口的描述信息。
undo uni description命令用来恢复缺省情况。
uni uni-number description text
undo uni uni-number description
UNI端口无描述信息。
ONU配置模板视图
uni-number:UNI端口号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为32。
text:UNI端口的描述字符串,长度为1~40个字符。
# 在ONU配置模板1中,将UNI端口1描述为Test。
[Sysname-onu-cfgprofile-1] uni 1 description Test
1.2.33  uni duplex
uni duplex命令用来设置UNI端口双工状态。
undo uni duplex命令用来将端口的双工状态恢复为缺省值。
uni uni-number duplex { auto | full | half }
undo uni uni-number duplex
UNI端口处于全双工状态。
ONU配置模板视图
auto:端口处于自协商状态。
full:端口处于全双工状态。
half:端口处于半双工状态。
在配置该命令前,需要配置undo uni uni-number auto-negotiation命令。
# 在ONU配置模板1中,设置UNI端口1为自协商状态。
[Sysname-onu-cfgprofile-1] uni 1 duplex auto
1.2.34  uni flow-control
uni flow-control命令用来开启UNI端口的流量控制功能。
undo uni flow-control命令用来关闭UNI端口的流量控制功能。
uni uni-number flow-control
undo uni uni-number flow-control
UNI端口的流量控制功能处于关闭状态。
ONU配置模板视图
# 在ONU配置模板1中,开启UNI端口1的流量控制功能。
[Sysname-onu-cfgprofile-1] uni 1 flow-control
1.2.35  uni port-isolate
uni port-isolate命令用来将UNI端口加入隔离组。
undo uni port-isolate命令用来将UNI端口从隔离组中删除。
uni uni-number port-isolate
undo uni uni-number port-isolate
ONU下的UNI端口未加入隔离组。
ONU配置模板视图
本命令和onu port-isolate enable命令互斥,不能同时配置。
# 在ONU配置模板1中,将ONU下的UNI端口1和UNI端口2加入隔离组。
[Sysname-onu-cfgprofile-1] uni 1 port-isolate
[Sysname-onu-cfgprofile-1] uni 2 port-isolate
1.2.36  uni shutdown
uni shutdown命令用来关闭UNI端口。
undo uni shutdown命令用来打开UNI端口。
uni uni-number shutdown
undo uni uni-number shutdown
UNI端口处于开启状态。
ONU接口视图
uni-number :UNI 端口号,取值范围1~当前ONU的UNI端口数,且支持最大的UNI端口数为32。
# 关闭UNI端口1。
[Sysname] interface Onu 1/0/1:1
[Sysname-Onu1/0/1:1] uni 1 shutdown
1.2.37  uni speed
uni speed命令用来设置UNI端口速率。
undo uni speed命令用来恢复端口的速率为缺省值。
uni uni-number speed { 10 | 100 | 1000 | auto }
undo uni uni-number speed
UNI端口速率为100Mbps。
ONU配置模板视图
10:端口速率为10Mbps。
100:端口速率为100Mbps。
1000:端口速率为100Mbps。
auto:端口速率处于双方自协商状态。
# 在ONU配置模板1中,设置UNI端口1速率为10Mbps。
[Sysname-onu-cfgprofile-1] uni 1 speed 10
1.2.38  uni statistics enable
uni statistics enable命令用来开启ONU上指定UNI端口的统计功能。
undo uni statistics enable命令用来关闭ONU上指定UNI端口的统计功能。
uni uni-number statistics enable
undo uni uni-number statistics enable
UNI端口的统计功能处于开启状态。
ONU配置模板视图
# 在ONU配置模板1中,开启UNI端口1的统计功能。
[Sysname-onu-cfgprofile-1] uni 1 statistics enable
1.2.39  uni vlan-mode
uni vlan-mode命令用来配置UNI端口的VLAN操作模式为VLAN透传模式、VLAN标记模式、VLAN Translation模式、VLAN Trunk模式或VLAN N:1聚合模式。
undo uni vlan-mode命令用来恢复缺省情况。
undo uni uni-number vlan-mode
VLAN透传模式:
uni uni-number vlan-mode transparent
VLAN标记模式:
uni uni-number vlan-mode tag pvid pvid [ priority priority ]
VLAN Translation模式:
uni uni-number vlan-mode translation pvid pvid [ priority priority ] { original-vlan-id to translated-vlan-id } &<1-15>
VLAN Trunk模式:
uni uni-number vlan-mode trunk pvid pvid [ priority priority ] trunk-vlan-list
VLAN N:1聚合模式:
uni uni-number vlan-mode aggregation pvid pvid [ priority priority ] { vlan-id1 to vlan-id2 aggregated-vlan aggregated-vlan }&<1-15>
UNI端口的VLAN操作模式为VLAN透传模式。
ONU配置模板视图
ONU接口视图
pvid pvid:端口缺省VLAN ID,取值范围为1~4094。在VLAN标记模式/Translation模式/Trunk模式/N:1聚合模式下,仅当端口接收到不带VLAN Tag的报文时,才会为该报文添加本端口PVID的Tag。
priority priority:报文的802.1p优先级,有效取值范围为0~7。在VLAN标记模式/Translation模式/Trunk模式/N:1聚合模式下,仅当端口接收到不带VLAN Tag的报文时,对添加的本端口PVID Tag的802.1p优先级进行设置。
{ original-vlan-id to translated-vlan-id } &<1-15>:original-vlan-id表示原始VLAN ID,translated-vlan-id表示转换后的VLAN ID,取值范围均为1~4094。&<1-15>表示前面的参数最多可以重复输入15次。
trunk-vlan-list:表示端口允许通过的VLAN范围。具体表示方式为trunk-vlan-list = { vlan-id1 to vlan-id2 }&<1-15>,vlan-id1表示起始VLAN ID,vlan-id2表示结束VLAN ID,取值范围均为1~4094,vlan-id2的值要大于等于vlan-id1的值;&<1-15>表示前面的参数最多可以重复输入15次。不同VLAN范围之间不允许有交集。
{ vlan-id1 to vlan-id2 aggregated-vlan aggregated-vlan }&<1-15>:表示将指定范围的VLAN ID转换成指定的VLAN ID。vlan-id1 to vlan-id2表示原始VLAN范围,vlan-id2的值要大于等于vlan-id1的值;aggregated-vlan为转换后的VLAN ID;&<1-15>表示前面的参数最多可以重复输入15次。参数涉及的VLAN ID取值范围都为1~4094。不同VLAN范围之间不允许有交集。
当OLT下的所有ONU接口的链路类型为Access时,UNI端口操作模式只能为透明传输模式,这样才能保证ONU接口和用户PC接收的是不带Tag的报文。
# 在ONU配置模板1中,配置UNI端口1的VLAN操作模式为VLAN 透传模式。
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode transparent
# 配置UNI端口1的VLAN操作模式为VLAN 标记模式,给进入本端口的不带Tag报文打上VLAN 100的Tag,并设置报文802.1p优先级为3。
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode tag pvid 100 priority 3
# 配置UNI端口1的VLAN操作模式为VLAN Translation模式,缺省VLAN ID为100,对于进入本端口不带VLAN tag的报文,为报文添加端口缺省VLAN的Tag,并设置报文的802.1p优先级为3,对于进入本端口VLAN ID为2的报文,将其VLAN ID替换成5。
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode translation pvid 100 priority 3 2 to 5
# 配置UNI端口1的VLAN操作模式为VLAN Trunk模式,PVID为1,报文的802.1p优先级为3,同时允许VLAN 2~VLAN 5的报文通过。
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode trunk pvid 1 priority 3 2 to 5
# 配置UNI端口1的VLAN操作模式为N:1聚合模式,PVID为1,报文的802.1p优先级为3,对于进入本端口的VLAN 2~VLAN 5的报文,将其VLAN ID替换成100。
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode aggregation pvid 1 priority 3 2 to 5 aggregate 100
