12-DPI深度安全命令参考
03-WAF命令
本章节下载: 03-WAF命令  (2.05 MB)
03-WAF命令
1 WAF
1.1 WAF配置命令
1.1.1 action(CC-defense policy rule view)
1.1.2 action(waf policy view)
1.1.3 action(waf signature view)
1.1.4 apply cc-defense policy
1.1.5 attack-category
1.1.6 cc-defense policy
1.1.7 cc-detection-item
1.1.8 description (WAF whitelist entry view)
1.1.9 description(CC-defense policy view)
1.1.10 description(waf policy view)
1.1.11 description(waf signature view)
1.1.12 destination-address(CC-defense policy rule view)
1.1.13 destination-address(waf signature rule view)
1.1.14 destination-port(CC-defense policy rule view)
1.1.15 destination-port(waf signature rule view)
1.1.16 detection-integer
1.1.17 detection-interval
1.1.18 detection-keyword
1.1.19 direction
1.1.20 display waf policy
1.1.21 display waf signature
1.1.22 display waf signature library
1.1.23 display waf signature pre-defined
1.1.24 display waf signature user-defined
1.1.25 entry enable
1.1.26 exception
1.1.27 hide-server-info ftp
1.1.28 hide-server-info http error-code
1.1.29 hide-server-info http header
1.1.30 http-method
1.1.31 logging enable
1.1.32 method
1.1.33 object-dir
1.1.34 protected-target
1.1.35 protected-url
1.1.36 reset waf tamper-proof baseline-file
1.1.37 rule copy
1.1.38 rule move
1.1.39 rule(CC-defense policy view)
1.1.40 rule(waf signature view)
1.1.41 rule-logic
1.1.42 semantic-analysis enable
1.1.43 severity-level(waf policy view)
1.1.44 severity-level(waf signature view)
1.1.45 signature override
1.1.46 signature override all
1.1.47 signature-id
1.1.48 source-address
1.1.49 source-address (WAF whitelist entry view)
1.1.50 source-port
1.1.51 tamper-proof auto-learn enable
1.1.52 tamper-proof enable
1.1.53 tamper-proof file-type enable
1.1.54 tamper-proof web-resources
1.1.55 trigger
1.1.56 update schedule
1.1.57 url
1.1.58 waf apply policy
1.1.59 waf enable
1.1.60 waf parameter-profile
1.1.61 waf policy
1.1.62 waf signature
1.1.63 waf signature auto-update
1.1.64 waf signature auto-update-now
1.1.65 waf signature rollback
1.1.66 waf signature update
1.1.67 waf tamper-proof cache-files enable
1.1.68 waf whitelist
1.1.69 waf whitelist activate
1.1.70 waf whitelist enable
1.1.71 xff-detection enable
1.1.72 yundi alias
1 WAF
1.1  WAF配置命令
action命令用来配置CC攻击防护的动作。
undo action命令用来恢复缺省情况。
action { block-source [ block-time ] | permit }
undo action
CC攻击防护策略规则的动作为允许。
CC攻击防护策略规则视图
context-admin
block-source:表示源阻断动作。该动作阻断检测为CC攻击行为的报文,并会将该报文的源IP地址加入IP黑名单。如果设备上同时开启了IP黑名单过滤功能,则在block-time指定的阻断时间内直接丢弃来自此IP地址的所有报文;否则,此IP黑名单不生效。有关IP黑名单过滤功能的详细介绍请参见“安全命令参考”中的“攻击检测与防范”。
block-time:表示阻断时间,取值范围为1~86400,单位为秒。如果未配置本参数,则表示使用缺省值,缺省为300秒。
permit:表示允许报文通过。
当设备检测出CC攻击时,执行本命令配置的动作。
# 在名称为news的CC攻击防护策略下,配置名称为test的防护规则动作为源阻断,阻断时间为350秒。
[Sysname] cc-defense policy news
[Sysname-cc-defense-policy-news] rule name test
[Sysname-cc-defense-policy-news-rule-test] action block-source 350
action命令用来配置筛选WAF特征的动作属性。
action { block-source | drop | permit | reset } *
undo action
未配置动作属性筛选条件。
WAF策略视图
context-admin
block-source:表示源阻断动作,该动作将阻断符合特征的报文,并将该报文的源IP地址加入IP黑名单。
drop:表示丢弃报文的动作。
permit:表示允许报文通过的动作。
reset:表示重置动作,该动作通过发送TCP的reset报文使TCP连接断开。
可通过配置动作分类属性筛选出具有该属性的特征,WAF策略将使用筛选出的特征与报文进行匹配。可多次执行本命令,配置多个动作。只要符合其中一个,具有该动作的特征将会被筛选出来。
特征库升级过程中,不能成功执行本命令以及undo命令。
# 在名称为test-policy的WAF策略中配置筛选WAF特征的动作属性为drop和reset。
[Sysname] waf policy test-policy
[Sysname-waf-policy-test-policy] action drop reset
·     display waf policy
action命令用来配置WAF自定义特征的动作。
action { block-source | drop | permit | reset } [ capture | logging ] *
undo action
WAF自定义特征的动作是permit。
WAF自定义特征视图
context-admin
block-source:表示阻断符合特征的报文,并会将该报文的源IP地址加入IP黑名单。
drop:表示丢弃报文。
permit:表示放行报文动作。
reset:表示通过发送TCP的reset报文使TCP连接断开。
capture:表示捕获符合特征的报文。
logging:表示记录日志。
本命令用来配置对匹配上WAF自定义特征的报文所执行的动作。
多次执行本命令,最后一次执行的命令生效。
# 配置WAF自定义特征的动作为permit。
[Sysname] waf signature user-defined name mysignature
[Sysname-waf-signature-mysignature] action permit
apply cc-defense policy命令用来在WAF策略中引用CC攻击防护策略。
undo apply cc-defense policy命令用来恢复缺省情况。
apply cc-defense policy policy-name
WAF策略未引用CC攻击防护策略。
WAF策略视图
context-admin
policy-name:表示CC攻击防护策略的名称,为1~31个字符的字符串,不区分大小写。
CC攻击防护策略仅在被WAF策略引用后生效。
# 在WAF策略master中引用CC攻击防护策略news。
[Sysname-cc-defense-policy-news] quit
[Sysname] waf policy master
[Sysname-waf-policy-master] apply cc-defense policy news
attack-category命令用来配置筛选WAF特征的攻击分类属性。
undo attack-category命令用来删除筛选WAF特征的攻击分类属性。
attack-category { category [ sub-category subcategory ] | all}
undo attack-category { category [ sub-category subcategory | all] }
未配置攻击分类属性筛选条件。
WAF策略视图
context-admin
category:表示设备中已有的攻击分类名称。不区分大小写,可通过输入“?”获取支持的攻击分类名称。
sub-category subcategory:表示设备中已有攻击分类中的子分类名称。若不指定本参数,则表示指定攻击分类中的所有子分类。不区分大小写,可通过输入“?”获取支持的子分类名称。
all:表示设备中已有的所有攻击分类。
可通过配置攻击分类属性筛选出具有该属性的特征,WAF策略将使用筛选出的特征与报文进行匹配。可多次执行本命令,配置多个攻击分类。只要符合其中一个,具有该攻击分类的特征将会被筛选出来。
# 在名称为test-policy的WAF策略中配置筛选WAF特征的攻击分类为Vulnerability攻击分类中的SQLInjection子分类。
[Sysname-waf-policy-test-policy] attack-category Vulnerability sub-category SQLInjection
cc-defense policy命令用来创建CC攻击防护策略,并进入CC攻击防护策略视图。如果指定的CC攻击防护策略已存在,则直接进入CC攻击防护策略视图。
undo cc-defense policy命令用来删除指定的CC攻击防护策略。
undo cc-defense policy policy-name
不存在CC攻击防护策略。
context-admin
policy-name:表示CC攻击防护策略的名称,为1~31个字符的字符串,不区分大小写,不可输入“-”。
# 创建一个名称为news的CC攻击防护策略。
·     apply cc-defense policy
cc-detection-item命令用来配置CC攻击检测项。
undo cc-detection-item命令用来恢复缺省情况。
cc-detection-item { request-concentration [ concentration-value ] [ request-number number ] | request-rate [ rate-value ] }
undo cc-detection-item { request-concentration | request-rate }
未配置CC攻击检测项,设备不对检查项进行检测。
CC攻击防护策略规则视图
context-admin
request-concentration concentration-value:表示请求集中度阈值的百分比数值,取值范围为1~100,缺省值为25。
request-number number:表示访问次数。取值范围为10~65535,缺省值为100。
request-rate rate-value:表示请求速率。rate-value表示请求速率的阈值,取值范围为1~65535,缺省值为150,单位为次/检测周期。
CC攻击防护策略规则的检测项包括请求速率和请求集中度。
·     请求速率:用于检测客户端是否过于频繁地访问某网站。
·     请求集中度:用于检测客户端是否主要针对某网站进行访问。
设备以检测周期为单位,对用户访问的网站进行统计,并对最常访问的URL检验是否超过检查项阈值,只要有一个检查项超过阈值,则认为客户端的访问为CC攻击。
检查项的计算方式分别为:
·     请求速率=用户最常访问的URL的访问次数/检测周期。
·     请求集中度=用户最常访问的URL的访问次数/所有URL的访问次数*100%。
其中,仅当达到配置的请求次数后,才计算请求集中度。
如果CC攻击防护策略下配置了防护路径,则URL为不同域名下的防护路径;如果CC攻击防护策略下未配置防护路径,则URL为用户访问的每个网站的URL。
多次执行本命令,配置同一个检查项时,最后一次执行的命令生效。
# 在CC攻击防护策略news下名称为test的规则中配置请求速率的阈值为10次/检测周期。
[Sysname-cc-defense-policy-news-rule-test] cc-detection-item request-rate 10
·     detection-interval
·     protected-url
description命令用来配置WAF白名单表项的描述信息。
undo description命令用来恢复缺省情况。
未配置WAF白名单表项的描述信息。
WAF白名单表项视图
context-admin
text:WAF白名单表项的描述信息,为1~255个字符的字符串,可以包含空格,不区分大小写。
通过合理编写描述信息,便于管理员快速理解和识别WAF白名单表项的作用,有利于后期维护。
# 配置编号为1的WAF白名单表项描述信息为News information。
[Sysname] waf whitelist 1
[Sysname-waf-whitelist-1] description News information
·     waf whitelist
description命令用来配置CC攻击防护策略的描述信息。
description text-string
未配置CC攻击防护策略的描述信息。
CC攻击防护策略视图
context-admin
text-string:CC攻击防护策略的描述信息,为1~255个字符的字符串,可以包含空格,不区分大小写。
通过合理编写描述信息,便于管理员快速理解和识别CC攻击防护策略的作用,有利于后期维护。
# 配置CC攻击防护策略news的描述信息为News information。
[Sysname-cc-defense-policy-news] description News information
description命令用来配置WAF策略的描述信息。
WAF策略描述信息不存在。
WAF策略视图
text:WAF策略的描述信息,为1~255个字符的字符串,不区分大小写。
通过合理编写描述信息,便于管理员快速理解WAF策略的作用,有利于后期维护。
# 配置WAF策略policy1的描述信息。
[Sysname] waf policy policy1
[Sysname-waf-policy-policy1] description protection
description命令用来配置WAF自定义特征的描述信息。
未配置WAF自定义特征的描述信息。
WAF自定义特征视图
context-admin
text:表示WAF自定义特征的描述信息,为1~127个字符的字符串,可以包含空格,区分大小写。
通过合理编写描述信息,便于管理员快速理解和识别WAF自定义特征的作用,有利于后期维护。
# 在WAF自定义特征mysignature中,配置描述信息为Http protocol check。
[Sysname-waf-signature-mysignature] description Http protocol check
destination-address命令用来配置作为CC攻击防护策略规则过滤条件的目的IP地址。
undo destination-address命令用来删除作为CC攻击防护策略规则过滤条件的目的IP地址。
destination-address { ipv4 ipv4-address | ipv6 ipv6-address }
undo destination-address { ipv4 ipv4-address | ipv6 ipv6-address }
不存在目的IP地址过滤条件。
CC攻击防护策略规则视图
context-admin
ipv4 ipv4-address:表示IPv4地址。
ipv6 ipv6-address:表示IPv6地址。
目的IP地址为受保护的网站服务器的IP地址。
多次执行本命令,可配置多个目的IP地址作为CC攻击防护策略规则的过滤条件。
# 在CC攻击防护策略news下名称为test的规则中配置作为过滤条件的目的IPv4地址为192.168.4.83。
[Sysname-cc-defense-policy-news-rule-test] destination-address ipv4 192.168.4.83
destination-address命令用来配置WAF自定义特征规则匹配的目的IP地址。
undo destination-address命令用来恢复缺省情况。
destination-address ip ip-address
未配置WAF自定义特征规则匹配的目的IP地址。
WAF自定义特征规则视图
context-admin
ip-address:表示WAF自定义特征规则匹配的目的IPv4地址。
# 在WAF自定义特征mysignature中,配置编号为1的关键字类型规则,配置自定义特征规则匹配的目的IP地址为10.1.1.1。
[Sysname-waf-signature-mysignature] rule 1 pattern-type keyword
[Sysname-waf-signature-mysignature-rule-1] destination-address ip 10.1.1.1
destination-port命令用来配置作为CC攻击防护策略规则过滤条件的目的端口。
undo destination-port命令用来删除作为CC攻击防护策略规则过滤条件的目的端口。
destination-port port-number
undo destination-port port-number
不存在目的端口过滤条件。
CC攻击防护策略规则视图
context-admin
port-number:表示CC攻击防护策略规则中的目的端口,取值范围为1~65535。
多次执行本命令,可配置多个目的端口作为CC攻击防护策略规则的过滤条件。
# 在CC攻击防护策略news下名称为test的规则中配置作为过滤条件的目的端口为8080。
[Sysname-cc-defense-policy-news-rule-test] destination-port 8080
destination-port命令用来配置WAF自定义特征规则匹配的目的端口。
undo destination-port命令用来恢复缺省情况。
destination-port start-port [ to end-port ]
未配置WAF自定义特征规则匹配的目的端口。
WAF自定义特征规则视图
context-admin
start-port:表示目的端口的起始端口号,取值范围为1~65535。
to end-port:指定结束目的端口号。end-port,表示目的端口的结束端口号,取值范围为1~65535。若不指定本参数,则表示仅匹配起始端口号。
本命令用于配置基于TCP协议的端口号。
# 在WAF自定义特征mysignature中,新建编号为1的关键字类型规则,配置自定义特征规则匹配的目的端口范围为1~3550。
[Sysname-waf-signature-mysignature-rule-1] destination-port 1 to 3550
detection-integer命令用来配置数值类型自定义特征规则的检查项。
undo detection-integer命令用来删除数值类型自定义特征规则的检查项。
detection-integer field field-name match-type { eq | gt | gt-eq | lt | lt-eq | nequ } number
未配置数值类型自定义特征规则的检查项。
WAF自定义特征规则视图
context-admin
field-name:表示待检测的协议字段。field-name表示待检测的协议字段名称,不区分大小写,需要通过输入“?”获取支持的协议字段。
match-type{ eq | gt | gt-eq | lt | lt-eq | nequ }:表示检查项和待检测数值的匹配方式。
·     eq:等于。
·     gt:大于。
·     gt-eq:大于等于。
·     lt:小于。
·     lt-eq:小于等于。
·     nequ:不等于。
number:表示检查项要比较的数值,取值范围为1~4294967295。
一条规则可以配多个检查项,检查项之间为逻辑与的关系,匹配顺序为配置顺序。配置检查项匹配的协议字段时,建议依据HTTP协议中各协议字段顺序进行配置,否则可能会影响设备的检测结果。
# 在WAF自定义特征mysignature中,新建编号为1的数值类型规则,配置编号为1的检查项的协议字段为http-uri、匹配方式为等于、检测内容为123456。
[Sysname-waf-signature-mysignature] rule 1 pattern-type integer
[Sysname-waf-signature-mysignature-rule-1] detection-integer field http-uri match-type eq 123456
trigger
detection-interval命令用来配置CC攻击检查项的检测周期。
undo detection-interval命令用来恢复缺省情况。
detection-interval interval
CC攻击检查项的检测周期为30秒。
CC攻击防护策略视图
context-admin
interval:表示CC攻击检查项的检测周期,取值范围为10~720,单位为秒。
检测周期是用于检测是否存在CC攻击行为的计时周期,从一条流的首个报文命中CC攻击防护规则时开始计时。
设备使用请求速率和请求集中度两个检查项判定是否存在CC攻击行为。在检测周期内,如果设备检测到检查项已超过阈值,则判定用户的访问为CC攻击,并执行CC攻击防护动作,包括允许、黑名单和记录日志;如果未超过阈值(即小于或等于阈值),则不认为遭受到CC攻击,放行报文。
# 配置CC攻击检查项的检测周期为10秒。
[Sysname-cc-defense-policy-news] detection-interval 10
·     detection
detection-keyword命令用来配置关键字类型自定义特征规则的检查项。
undo detection-keyword命令用来删除关键字类型自定义特征规则的检查项。
detection-keyword detection-id field field-name match-type { exclude | include } { hex hex-string | regex regex-pattern | text text-string } [ offset offset-value [ depth depth-value ] | relative-offset relative-offset-value [ relative-depth relative-depth-value ] ]
undo detection-keyword detection-id
未配置关键字类型自定义特征规则的检查项。
WAF自定义特征规则视图
context-admin
detection-id:表示检查项的ID,取值范围为1~10。
field field-name:表示待检测的协议字段。field-name表示协议字段名称,不区分大小写。需要通过输入“?”获取支持的协议字段。
match-type { exclude | include }:表示检查项和关键字的匹配方式。
·     include:包含。
·     exclude:不包含。
hex hex-string:表示用来匹配的十六进制字符内容,hex-string表示匹配内容,为8~254个字符的字符串,且必须输入偶数个字符,输入参数必须在两个竖杠“|”之间,仅支持输入“0-9、A-F、a-f”,区分大小写,例如|1234f5b6|。
regex regex-pattern:表示用来匹配的正则表达式,为3~255个字符的字符串,区分大小写,只能以字母、数字、下划线开头,不能以特殊符号开头,支持特殊字符配置,且必须包含连续的3个非通配符。
text text-string:表示用来匹配的文本内容,为3~255个字符的字符串,不区分大小写。
offset offset-value:表示检查项的偏移量,从协议字段起始位置开始偏移的长度。取值范围为1~65535,单位为字节。若不配置该参数,则表示从协议字段的起始位置开始对检查项进行检测。
depth depth-value:表示检查项的检测深度,从检查项的起始位置开始,检测的长度。取值范围为3~65535,单位为字节。若不配置该参数,则表示检查项对整个协议字段进行检测。
relative-offset relative-offset-value:表示当前检查项与上一个检查项之间的相对偏移量,取值范围为-32767~-1,1~32767,单位为字节。从上一个检查项的检测结束位置开始偏移。如果取值为正数,则表示向后偏移;如果取值为负数,则表示向前偏移。
relative-depth relative-depth-value:表示检查项的检测深度,从检测的起始位置开始检测的长度,取值范围为3~65535,单位为字节。
本命令仅在配置触发检查项之后才可配置。
检查项仅检测指定协议字段范围内的数据,可使用偏移量、检测深度和相对偏移量、相对检测深度两组参数中的任意一组精确定位检测的起始和终止位置。
# 在WAF自定义特征mysignature中,新建编号为1的关键字类型规则,配置编号为1的检查项的协议字段为http-uri、匹配类型为包含、检测内容为文本abc、偏移量为10字节、检测深度为50字节。
[Sysname-waf-signature-mysignature-rule-1] detection-keyword 1 field http-uri match-type include text abc offset 10 depth 50
·     trigger
1.1.19  direction
direction命令用来配置WAF自定义特征的检测方向。
undo direction命令用来恢复缺省情况。
direction { any | to-client | to-server }
undo direction
WAF自定义特征的检测方向是any。
WAF自定义特征视图
context-admin
any:表示发往服务器和客户端的两个方向。
to-client:表示发往客户端的方向。
to-server:表示发往服务器的方向。
不支持通过多次执行本命令修改自定义特征的检测方向,如需修改检测方向,请先执行undo direction命令。执行undo命令后,将删除该特征下的所有规则。
# 配置WAF自定义特征的检测方向为发往客户端的方向。
[Sysname-waf-signature-mysignature] direction to-client
display waf policy命令用来显示WAF策略信息。
display waf policy policy-name
context-admin
context-operator
policy-name:表示WAF策略名称,为1~63个字符的字符串,不区分大小写。
# 显示名称为aa的WAF策略信息。
<Sysname> display waf policy aa
Semantic-analysis status      : enabled
Tamper-proof information:
Tamper-proof status     :enabled
Auto-learn status       :enabled
Tamper-proof work-mode  :protect
FileType     Status:
XLS          enabled
HLP          enabled
PPT          enabled
DOC          enabled
PE           enabled
PDF          enabled
SWF          enabled
ZIP          enabled
GIF          enabled
JPEG         enabled
CSS          enabled
HTML         enabled
TXT          enabled
Total web-resources: 2
  Host: 1.1.1.1
  Method: get
  URI: /dm/26300981_1000.dac?type=10&pos=1
  Host: 2.2.2.2
  Method: get
  URI: //mp3/mix/34/33493.mp3
Total signatures              : 100
 Pre-defined signatures       : 10
 User-defined signatures      : 90
Flags:
  B: Block-source  D: Drop  P: Permit  Rs: Reset  Rd: Redirect  C: Capture  L: L
ogging
  Pre: pre-defined  User: user-defined
Type SigID    Target          SubTarget       Severity Direction Category
  SubCategory     Status  Action
Pre  23723     OperationSystem Any             High     Any       Vulnerability
  RemoteCodeExecu Enable  RsL
Pre  24728     OperationSystem Any             Critical Server    Malware
  Backdoor        Enable  DL
Pre  25066     OperationSystem Any             Critical Any       Malware
  Backdoor        Enable  DL
Pre  25067     OperationSystem Any             Critical Server    Malware
  Backdoor        Enable  RsL
Pre  25824     OperationSystem Any             Critical Server    Vulnerability
  Overflow        Enable  RsL
---- More ----
表1-1 display waf policy命令显示信息描述表
语义分析功能的启用状态,取值包括:
·     enabled:表示开启状态
·     disabled:表示关闭状态
Tamper-proof status
网页防篡改功能的启用状态,取值包括:
·     enabled:表示开启状态
·     disabled:表示关闭状态
Auto-learn status
网页防篡改网页自学习功能的启用状态,取值包括:
·     enabled:表示开启状态,设备处于学习状态
·     disabled:表示关闭状态,设备处于工作状态
Work-mode
网页防篡改功能的工作模式,取值包括:
·     monitor:监控模式
·     protect:保护模式
FileType
网页防篡改功能支持检测的文件类型
Status
网页防篡改功能是否开启对指定文件类型的检测功能,取值包括:
·     enabled:表示开启对指定文件类型进行检测
·     disabled:表示关闭对指定文件类型进行检测
Total web resource
网页防篡改功能检测的网页资源总数
Host
网页资源的主机名
Method
网页资源的请求方法
URI
网页资源的URI
Total signatures
WAF策略中的特征总数
预定义WAF特征数目
自定义WAF特征数目
Flags
标识符缩写,取值包括:
·     B: Block-source:表示源阻断动作
·     D: Drop:表示丢弃
·     P: Permit:表示允许
·     Rs: Reset:表示重置
·     C: Capture:表示捕获
·     L: Logging:表示记录日志
·     Pre: pre-defined:表示预定义特征
·     User: user-defined:表示自定义特征
WAF特征的类型,包括如下取值:
·     Pre:表示预定义特征
·     User:表示自定义特征
SigID
WAF特征编号
Target
攻击对象
SubTarget
攻击子对象
Severity
WAF特征的攻击严重程度属性,从低到高分为四级:Low、Medium、High、Critical
Category
WAF特征的攻击类别名称
SubCategory
WAF特征的子攻击类别名称
Status
WAF特征的状态,包括如下取值:
·     Enabled:表示此特征已生效
·     Disabled:表示此特征未生效
Action
对报文的处理动作,包括如下取值:
·     Block-source:表示阻断符合特征的报文,并会将该报文的源IP地址加入IP黑名单
·     Drop:表示丢弃符合特征的报文
·     Permit:表示允许符合特征的报文通过
·     Reset:表示发送TCP的reset报文或UDP的ICMP端口不可达报文使TCP或UDP连接断开
·     Redirect:表示重定向符合特征的报文
·     Capture:表示捕获符合特征的报文
·     Logging:表示对符合特征的报文生成日志
display waf signature命令用来显示WAF特征的简要信息。
display waf signature [ pre-defined | user-defined ] [ direction { any | to-client | to-server } ] [ category category-name | fidelity { high | low | medium } | severity { critical | high | low | medium } ] *
context-admin
context-operator
pre-defined:显示预定义WAF特征。
direction { any | to-client | to-server }:显示符合指定方向属性的WAF特征。如果未指定此参数,则显示所有方向上的WAF特征。
·     any:表示一个会话的两个方向。
·     to-server:表示一个会话的客户端到服务器的方向。
·     to-client:表示一个会话的服务器到客户端的方向。
category category-name:显示符合指定攻击类别属性的WAF特征,category-name是攻击类型的名称,可通过输入“?”获取支持的攻击类型名称。如果未指定此参数,则显示所有攻击类型的WAF特征。
fidelity { high | low | medium }:显示符合指定可信度属性的WAF特征。如果未指定此参数,则显示所有可信度的WAF特征。可信度是指此WAF特征识别攻击行为准确度,且从低到高分为如下三个级别:
·     low:可信度比较低。
·     medium:可信度中等。
·     high:可信度比较高。
severity { critical | high | low | medium }:显示符合指定严重级别属性的WAF特征。如果未指定此参数,则显示所有严重级别的WAF特征。严重级别是指匹配此WAF特征的网络攻击造成危害的严重程度,且从低到高分为四个级别:
·     low:攻击严重程度比较低。
·     medium:攻击严重程度中等。
·     high:攻击严重程度比较高。
·     critical:攻击严重程度非常高。
若不指定任何参数,则显示所有WAF特征。
# 显示可信度为中等的所有预定义WAF特征。
<Sysname> display waf signature pre-defined fidelity medium
Pre-defined  signatures total:88        failed:0
Flag:
  Pre: predefined   User: user-defined
Type SigID      Direction Severity Fidelity Category      Protocol SigName
Pre  3295       To-client Critical Medium   Vulnerability TCP
Pre  5379       To-client Critical Medium   Vulnerability TCP
Pre  6017       To-client Critical Medium   Vulnerability TCP
Pre  7453       To-server High     Medium   Other         TCP
Pre  10033      To-client High     Medium   Vulnerability TCP
Pre  23227      To-server Medium   Medium   Vulnerability TCP
Pre  23285      To-server Medium   Medium   Vulnerability TCP
Pre  23309      To-server Medium   Medium   Vulnerability TCP
Pre  23482      To-server High     Medium   Vulnerability TCP
Pre  23530      To-server High     Medium   Vulnerability TCP
Pre  23666      To-server High     Medium   Vulnerability TCP
Pre  23722      To-server Medium   Medium   Vulnerability TCP
Pre  23747      To-server Medium   Medium   Vulnerability TCP
Pre  24346      To-client Medium   Medium   Vulnerability TCP
Pre  25044      To-server High     Medium   Vulnerability TCP
Pre  25086      To-server High     Medium   Vulnerability TCP
Pre  25100      To-server High     Medium   Vulnerability TCP
---- More ----
# 显示攻击严重程度为比较高的所有WAF特征。
<Sysname> display waf signature severity high
Total signatures        :45        failed:0
 Pre-defined  signatures total:45        failed:0
 User-defined signatures total:0         failed:0
Flag:
Pre  23192      To-server High     High     Vulnerability TCP
Pre  23448      To-server High     High     Vulnerability TCP
Pre  23474      To-server High     Low      Vulnerability TCP
Pre  24485      To-server High     High     Vulnerability TCP
Pre  30781      To-server High     Medium   Vulnerability TCP
Pre  30807      To-server High     Medium   Vulnerability TCP
Pre  30851      To-server High     Medium   Vulnerability TCP
---- More ----
表1-2 display waf signature命令显示信息描述表
Total signatures
WAF特征总数
预定义WAF特征数目
自定义WAF特征数目
Flags
标识符缩写,取值包括:
WAF特征的类型,包括如下取值:
·     Pre:表示预定义特征
·     User:表示自定义特征
SigID
WAF特征的编号
Direction
WAF特征的方向属性,包括如下取值:
·     any:表示一个会话的两个方向
·     To-server:一个会话的客户端到服务器方向
·     To-client:一个会话的服务器到客户端方向
Severity
WAF特征的攻击严重程度属性,严重程度从低到高分为四个级别:Low、Medium、High、Critical
Fidelity
WAF特征的可信度属性,可信度从低到高分为三个级别:Low、Medium、High
Category
WAF特征的攻击类别名称
Protocol
WAF特征的协议属性
SigName
WAF自定义特征的名称
display waf signature library命令用来显示WAF特征库信息。
context-admin
context-operator
# 显示WAF特征库信息。
<Sysname> display waf signature library
WAF signature library information:
Type     SigVersion         ReleaseTime               Size (bytes)
Current  1.02               Fri Sep 13 09:05:35 2014  71594
Factory  1.00               Fri Sep 11 09:05:35 2014  71394
表1-3 display waf signature information命令显示信息描述表
WAF特征库版本,包括如下取值:
·     Current:表示当前版本
·     Factory:表示出厂版本
SigVersion
WAF特征库版本号
ReleaseTime
WAF特征库发布时间
Size
WAF特征库文件大小,单位是Bytes
display waf signature pre-defined命令用来显示WAF预定义特征的详细信息。
display waf signature pre-defined signature-id
context-admin
context-operator
signature-id:指定WAF预定义特征的编号,取值范围为1~536870911。
# 显示编号为3295的预定义WAF特征的详细信息。
<Sysname> display waf signature pre-defined 3295
 Type        : Pre-defined
 Signature ID: 3295
 Status      : Enable
 Action      : Permit & Logging
 Protocol    : TCP
 Severity    : Critical
 Fidelity    : Medium
 Direction   : To-client
 Category    : Vulnerability
 Reference   :
 Description : WEB_SERVER_Possible_HTTP_503_XSS_Attempt_(Internal_Source)
表1-4 display waf signature pre-defined命令显示信息描述表
WAF特征的类型
Signature ID
WAF特征的编号
Status
WAF特征的状态,包括如下取值:
·     Enabled:表示此特征已生效
·     Disabled:表示此特未生效
Action
对报文的处理动作,包括如下取值:
·     Drop:表示丢弃符合特征的报文
Name
WAF特征的名称
Protocol
WAF特征的协议属性
Severity
Fidelity
Direction
WAF特征的方向属性,包括如下取值:
·     Any:表示一个会话的两个方向
Category
WAF特征的攻击类别名称
Reference
WAF特征的参考信息
WAF特征的描述信息
display waf signature user-defined命令用来显示WAF自定义特征的详细信息。
display waf signature user-defined signature-id
context-admin
signature-id:表示WAF自定义特征的ID,取值范围为536870928~1073741808。
# 显示ID为536870944的WAF自定义特征的详细信息。
<Sysname> display waf signature user-defined 536870944
Signature ID: 536870944
Signature name: mysignature
Status: Enabled
Action: Permit & Logging
Severity: High
Fidelity: Medium
Direction: To-server
Rulelogic: Or
Description: Http method check
Total rules: 2
Rule list:
  Rule ID: 1
  Match-type:  Keyword
  HTTP method: Get
  Source address ip: 10.1.1.1
  Source-address ipv6: 90::FE:1 111
  Source port: 1-35560
  Destination address ip: 20.1.1.1
  Destination-address ipv6: 70::FE:2 111
  Destination port: 1-35560
  trigger entry:
  Field: Http_Uri
  Value: abcksdhosihendsid
  Offset: 20
  Depth: 1000
  Detection entry list:
  Entry ID        Field               Match type   Content-type   Content
  1               http_cookie         include      text           sduhskdjs
  Rule ID: 2
---- More ----
display waf signature user-defined name my-signature
Signature ID
特征的编号
Signature name
特征的名字
Status
特征的状态,取值包括:
·     Enabled:表示生效状态
·     Disabled:表示失效状态
Action
报文与特征匹配成功后对该报文执行的动作,取值包括:
·     Permit:允许报文通过
·     Drop:丢弃报文
·     Reset:表示通过发送TCP的reset报文从而使TCP或UDP连接断开
·     Block-source:阻断报文
·     Logging:生成报文日志
·     Capture:捕获报文
Severity
特征的严重程度,从低到高分为四级:Low、Medium、High、Critical
Fidelity
Direction
特征匹配的方向,取值包括:
·     Any:双向
·     To-client:服务器到客户端的方向
·     To-server:客户端到服务器的方向
Rulelogic
特征下规则间的逻辑关系
特征的描述信息
Total rules
特征下的规则数量
Rule List
特征下的规则列表
Rule ID
特征下的规则编号
Match-type
特征匹配内容的类型,取值包括:
·     Keyword:关键字类型
·     Integer:数值类型
HTTP method
特征匹配的HTTP报文请求方法
Source address ip
特征匹配的源IP地址和掩码
Source-address ipv6
特征匹配的源IPv6地址和前缀
Source port
特征匹配的源端口范围
特征匹配的目的IP地址和掩码
特征匹配的目的IPv6地址和前缀
Destination port
特征规则匹配的目的端口范围
trigger entry
特征规则的触发检查项
特征规则触发检查项检测的协议字段
Value
特征规则触发检查项检测的内容
Offset
特征规则触发检查项的绝对偏移量
Depth
特征规则触发检查项的检测深度
特征规则的检查项列表
Entry ID
特征规则的检查项编号
特征规则检查项的协议字段
Match type
特征规则检查项的匹配方式,取值包括:
·     include:包含
·     exclude:不包含
Content-type
特征规则检查项检查内容的类型,取值包括:
·     hex:表示十六进制字符
·     regex:表示正则表达式
·     text:表示文本
Content
特征规则检查项的检查内容
1.1.25  entry enable
entry enable命令用来启用WAF白名单表项。
undo entry enable命令用来禁用WAF白名单表项。
entry enable
undo entry enable
WAF白名单表项处于启用状态。
WAF白名单表项视图
context-admin
创建WAF白名单表项后,该表项将自动启用。当某个WAF白名单表项暂时不需要用于匹配时,可配置undo entry enable命令禁用该白名单表项。
# 禁用编号为1的WAF白名单表项。
[Sysname-waf-whitelist-1] undo entry enable
·     waf whitelist
1.1.26  exception
exception命令用来配置CC攻击防护例外IP地址。
undo exception命令用来删除CC攻击防护例外IP地址。
exception { ipv4 ipv4-address | ipv6 ipv6-address }
undo exception { all | ipv4 ipv4-address | ipv6 ipv6-address }
未配置CC攻击防护例外IP地址。
CC攻击防护策略视图
context-admin
ipv4 ipv4-address:表示例外IPv4地址。
ipv6 ipv6-address:表示例外IPv6地址。
all:表示所有例外IP地址。
如果用户HTTP报文中的源IP地址与例外IP地址匹配成功,则直接允许此报文通过;如果匹配失败,则继续进行后续的CC攻击检测。
# 在名称为news的CC攻击防护策略中,配置IPv4例外地址为192.168.4.83。
[Sysname-cc-defense-policy-news] exception ipv4 192.168.4.83
hide-server-info ftp命令用来配置FTP协议报文服务器信息隐藏功能。
undo hide-server-info ftp命令用来恢复缺省情况。
未配置FTP协议报文服务器信息隐藏功能。
WAF策略视图
context-admin
配置本功能后,设备会对FTP协议报文应答信息中包含的服务器版本号和操作系统等信息进行隐藏,防止攻击者通过获取上述信息对服务器进行攻击。
本功能仅对返回码为220的FTP协议报文应答信息进行隐藏。
# 在名为test的WAF策略下配置FTP协议报文服务器信息隐藏功能。
[Sysname-waf-policy-test] hide-server-info ftp
hide-server-info http error-code命令用来配置HTTP错误响应状态码页面服务器信息隐藏功能。
undo hide-server-info http error-code命令用来取消配置HTTP错误响应状态码页面服务器信息隐藏功能。
hide-server-info http error-code { client-error | server-error } *
undo hide-server-info http error-code { client-error | server-error } *
未配置HTTP错误响应状态码页面服务器信息隐藏功能。
WAF策略视图
context-admin
client-error:表示对客户端错误响应状态码(即4XX)页面返回的服务器信息进行隐藏。
server-error:表示对服务器错误响应状态码(即5XX)页面返回的服务器信息进行隐藏。
浏览器向客户端返回的错误响应状态码(例如404)页面中可能包含服务器版本号、操作系统等信息,管理员可通过配置本功能,对指定的错误状态码页面内容进行隐藏,防止攻击者通过该页面获取服务器信息,进而对服务器进行攻击。
多次执行本命令,可对多个HTTP错误响应状态码页面的服务器信息进行隐藏。
# 在名为test的WAF策略下,配置设备对HTTP客户端错误响应状态码页面的服务器信息进行隐藏。
[Sysname-waf-policy-test] hide-server-info http client-error
hide-server-info http header命令用来配置HTTP报文首部字段服务器信息隐藏功能。
undo hide-server-info http header命令用来取消配置HTTP报文首部字段服务器信息隐藏功能。
hide-server-info http header header-name &<1-4>
undo hide-server-info http header header-name &<1-4>
未配置HTTP报文首部字段服务器信息隐藏功能。
WAF策略视图
context-admin
header-name:HTTP报文首部字段的名称,为1~63个字符的字符串,不区分大小写。可通过输入“?”获取支持的首部字段。&<1-4>表示前面的参数最多可以输入4次。
HTTP响应报文的部分首部字段中包含了服务器版本号等信息,管理员可以通过配置本功能对指定字段的内容进行隐藏,防止攻击者通过指定字段获取服务器信息,进而对服务器进行攻击。
多次执行本命令,可对多个HTTP报文首部字段的服务器信息进行隐藏。
# 在名为test的WAF策略下,配置对HTTP报文首部中的via字段的服务器信息进行隐藏。
[Sysname-waf-policy-test] hide-server-info http header via
1.1.30  http-method
http-method命令用来配置WAF自定义特征规则匹配的HTTP报文请求方法。
undo http-method命令用来恢复缺省情况。
http-method method-name
undo http-method
未配置WAF自定义特征规则匹配的HTTP报文的请求方法。
WAF自定义特征规则视图
context-admin
method-name:HTTP报文的请求方法,不区分大小写。如:GET、POST等。需要通过输入“?”获取支持的请求方法。
# 在WAF自定义特征mysignature中,新建编号为1的关键字类型规则,配置自定义特征规则匹配的HTTP报文的请求方法为GET。
[Sysname-waf-signature-mysignature-rule-1] http-method get
logging enable命令用来开启日志记录功能。
undo logging enable命令用来关闭日志记录功能。
logging enable
undo logging enable
日志记录功能处于关闭。
CC攻击防护策略规则视图
context-admin
开启日志记录功能后,当设备检测出存在CC攻击时,将以快速日志方式输出CC攻击防护日志到日志主机。有关快速日志的详细介绍请参见“网络管理和监控命令参考”中的“快速日志输出”。
# 在CC攻击防护策略news下名称为test的规则中开启日志记录功能。
[Sysname-cc-defense-policy-news-rule-test] logging enable
1.1.32  method
method命令用来配置作为CC攻击防护策略规则过滤条件的请求方法。
undo method命令用来删除作为CC攻击防护策略规则过滤条件的请求方法。
method { connect | delete | get | head | options | post | put | trace } *
undo method { connect | delete | get | head | options | post | put | trace }
不存在请求方法过滤条件。
CC攻击防护策略规则视图
context-admin
connect:表示CONNECT请求方法,用于要求用隧道协议连接代理。
delete:表示DELETE请求方法,用于删除文件。
get:表示GET请求方法,用于获取资源。
head:表示HEAD请求方法,用于获得报文首部。
options:表示OPTIONS请求方法,用于询问支持的方法。
post:表示POST请求方法,用于传输实体的主体。
put:表示PUT请求方法,用于传输文件。
trace:表示TRACE请求方法,用于追踪路径。
多次执行本命令,可配置多个请求方法作为CC攻击防护策略规则的过滤条件。
# 在CC攻击防护策略news下名称为test的规则中配置作为过滤条件的请求方法为POST。
[Sysname-cc-defense-policy-news-rule-test] method post
1.1.33  object-dir
object-dir命令用来配置筛选WAF特征的方向属性。
undo object-dir命令用来恢复缺省情况。
object-dir { client | server } *
undo object-dir
未配置方向属性筛选条件。
WAF策略视图
context-admin
client:表示从服务器到客户端方向上的对象。
server:表示从客户端到服务器方向上的对象。
可通过配置方向属性筛选出具有该属性的特征,WAF策略将使用筛选出的特征与报文进行匹配。可同时配置多个方向,只要符合其中一个,具有该方向属性的特征将会被筛选出来。
# 在名称为test-policy的WAF策略中配置筛选WAF特征的方向属性为client。
[Sysname-waf-policy-test-policy] object-dir client
protected-target命令用来配置筛选WAF特征的保护对象属性。
undo protected-target命令用来删除筛选WAF特征的保护对象属性。
protected-target { target [ sub-target subtarget ] | all }
undo protected-target { target [ sub-target subtarget ] | all }
未配置保护对象属性筛选条件。
WAF策略视图
context-admin
target:表示保护对象分类名称。不区分大小写,可通过输入“?”获取支持的对象分类名称。
subtarget:表示保护对象分类中的子对象名称。若不指定本参数,则表示保护某对象分类中的所有子对象。不区分大小写,可通过输入“?”获取支持的子对象分类名称。
all:表示所有保护对象。
可通过配置保护对象属性筛选出具有该属性的特征,WAF策略将使用筛选出的特征与报文进行匹配。可多次执行本命令,配置多个保护对象。只要符合其中一个,具有该保护对象属性的特征将会被筛选出来。
# 在名称为test-policy的WAF策略中配置筛选WAF特征的保护对象为WebServer中WebLogic子对象。
[Sysname-waf-policy-test-policy] protected-target WebServer sub-target WebLogic
protected-url命令用来配置CC攻击防护策略规则防护的路径。
undo protected-url命令用来删除CC攻击防护策略规则防护的路径。
protected-url url
undo protected-url url
未配置CC攻击防护策略规则防护的路径。
CC攻击防护策略规则视图
context-admin
url:表示CC攻击防护策略规则防护的URL,取值范围为1~255个字符,不区分大小写,不包含域名以及请求参数部分,以“/”开头。例如/portal/release/ir/default.jsp。
本命令用来配置CC攻击防护的网站资源的路径。
多次执行本命令,可配置多个CC攻击防护策略规则防护的路径。
# 在CC攻击防护策略news下名称为test的规则中配置防护的路径为/portal/release/ir/default.jsp。
[Sysname-cc-defense-policy-news-rule-test] protected-url /portal/release/ir/default.jsp
reset waf tamper-proof baseline-file命令用来清除WAF策略下的防篡改基线文件。
reset waf tamper-proof baseline-file [ policy-name ]
context-admin
policy-name:表示WAF策略名称,为1~63个字符的字符串,不区分大小写。若未指定本参数,则清除所有WAF策略下的防篡改基线文件。
当管理员判定服务器的网页资源内容发生正常的变更时,可通过本命令清除基线文件,重新学习基线文件。
# 清除所有WAF策略下的防篡改基线文件。
<Sysname> reset waf tamper-proof
1.1.37  rule copy
rule copy命令用来复制CC攻击防护策略规则。
rule copy rule-name new-rule-name
CC攻击防护策略规图
context-admin
rule-name:表示被复制的规则的名称,为1~31个字符的字符串,不区分大小写。
new-rule-name:表示新规则的名称,为1~31个字符的字符串,不区分大小写。
在CC攻击防护策略中,如果需要创建的新规则的配置和已存在的规则非常相似,可通过复制此规则来生成新规则,再修改差异配置来实现,方便用户快速创建新规则。
# 在CC攻击防护策略news下,复制名称为test的规则为名称为testtmp的新规则。
[Sysname-cc-defense-policy-news] rule copy test testtmp
1.1.38  rule move
rule move命令用来移动CC攻击防护策略规则。
rule move rule-name1 { after | before } rule-name2
CC攻击防护策略视图
context-admin
rule-name1:指定待移动CC攻击防护策略规则名称,为1~31个字符的字符串,不区分大小写。
after:表示将待移动规则移动到目标规则之后。
before:表示将待移动规则移动到目标规则之前。
rule-name2:指定目标CC攻击防护策略规则的名称,为1~31个字符的字符串,不区分大小写。
CC攻击防护策略规则按照配置顺序进行匹配,可通过移动规则位置调整规则匹配的顺序。
# 在CC攻击防护策略news的匹配规则列表中,将名称为rule2的规则移动到名称为rule1的规则前面。
[Sysname-cc-defense-policy-news] rule move rule2 before rule1
rule命令用来创建CC攻击防护策略规则,并进入CC攻击防护策略规则视图。如果指定的CC攻击防护策略规则已经存在,则直接进入CC攻击防护策略规则视图。
undo rule命令用来删除指定的CC攻击防护策略规则。
rule name rule-name
undo rule name rule-name
不存在CC攻击防护策略规则。
CC攻击防护策略视图
context-admin
name rule-name:表示CC攻击防护策略规则的名称,rule-name表示规则名称,为1~31个字符的字符串,不区分大小写,不可输入“-”。
CC攻击防护策略规则下可以配置如下内容:
·     CC攻击检测的过滤条件,包括:目的IP地址、目的端口号和请求方法。
·     CC攻击防护策略规则防护的路径。
·     CC攻击检测的检查项阈值。
·     CC攻击防护策略规则的动作。
CC攻击防护策略规则的匹配顺序为配置顺序,当报文与一条规则匹配成功时,则结束匹配过程。
# 在名称为news的CC攻击防护策略中创建一条名称为test的CC攻击防护策略规则,并进入CC攻击防护策略规则视图。
rule命令用来创建WAF自定义特征规则,并进入WAF自定义特征规则视图。如果指定的WAF自定义特征规则已经存在,则直接进入WAF自定义特征规则视图。
undo rule命令用来删除WAF自定义特征规则。
rule rule-id pattern-type { integer | keyword }
undo rule { rule-id | all }
未配置WAF自定义特征规则。
WAF自定义特征视图
context-admin
rule-id:表示WAF自定义特征规则的ID,取值范围为1~8。
pattern-type:表示WAF自定义特征匹配内容的类型。
integer:表示数值类型。
keyword:表示关键字类型。
all:表示所有WAF自定义特征规则。
一个自定义特征下可以配置多条规则作为特征的匹配条件,规则间可以配置逻辑关系(即通过rule-logic命令配置)。
不支持通过多次执行本命令修改同一ID的自定义特征规则的匹配类型,如需修改匹配类型,请先执行undo rule命令。
# 在WAF自定义特征mysignature中,创建编号为1的自定义特征规则,并配置匹配内容的类型为字符串。
1.1.41  rule-logic
rule-logic命令用来配置WAF自定义特征下规则间的逻辑关系。
undo rule-logic命令用来恢复缺省情况。
rule-logic { and | or }
undo rule-logic
WAF自定义特征下规则间的逻辑关系为or。
WAF自定义特征视图
context-admin
and:表示逻辑与关系。
or:表示逻辑或关系。
如果规则间是逻辑与的关系,报文需要匹配该自定义特征的所有规则才结束匹配过程;如果规则间是逻辑或的关系,一旦报文与某条规则匹配成功就结束此匹配过程。
# 配置WAF自定义特征下规则间为逻辑与的关系。
[Sysname-waf-signature-mysignature] rule-logic and
semantic-analysis enable命令用来开启语义分析功能。
undo semantic-analysis enable命令用来关闭语义分析功能。
语义分析功能处于关闭状态。
WAF策略视图
context-admin
语义分析功能通过对报文中的SQL语法进行分析来检测SQL注入攻击行为。
开启本功能后,设备将同时使用特征匹配和语义分析功能对SQL注入攻击进行检测,可以提升该类攻击的识别率,但同时会对设备性能产生影响,请管理员根据实际情况配置。
当设备通过语义分析功能检测出攻击时,将对该报文执行WAF策略动作(通过signature override all命令配置);如果未配置WAF策略动作,则放行报文,并以快速输出方式发送WAF日志。
# 在名称为test的WAF策略中,开启语义分析功能。
[Sysname-waf-policy-test] semantic-analysis enable
·     signature override all
severity-level命令用来配置筛选WAF特征的严重级别属性。
undo severity-level命令用来恢复缺省情况。
severity-level { critical | high | low | medium } *
undo severity-level
未配置严重级别属性筛选条件。
WAF策略视图
context-admin
critical:表示严重级别最高。
high:表示严重级别高。
low:表示严重级别低。
medium:表示严重级别一般。
严重级别是指匹配此WAF特征的网络攻击造成危害的严重程度。可通过配置严重级别属性筛选出具有该属性的特征,WAF策略将使用筛选出的特征与报文进行匹配。可同时配置多个严重级别,只要符合其中一个,具有该严重级别属性的特征将会被筛选出来。
# 在名称为test-policy的WAF策略中配置筛选WAF特征的严重级别为critical和medium。
[Sysname-waf-policy-test-policy] severity-level critical medium
·     waf policy
severity命令用来配置WAF自定义特征的严重级别。
undo severity命令用来恢复缺省情况。
undo severity-level
WAF自定义特征的严重级别为low。
WAF自定义特征视图
context-admin
critical:表示自定义特征的严重级别为严重。
high:表示自定义特征的严重级别为高。
low:表示自定义特征的严重级别为低。
medium:表示自定义特征的严重级别为中。
# 在WAF自定义特征mysignature中,配置严重级别为low。
[Sysname-waf-signature-mysignature] severity low
signature override命令用来修改WAF策略中指定特征的动作和状态。
undo signature override命令用来恢复WAF策略中指定特征的动作和状态。
signature override { pre-defined | user-defined } signature-id { disable | enable } [ { block-source | drop | permit | redirect | reset } | capture | logging ] *
undo signature override { pre-defined | user-defined } signature-id
预定义WAF特征使用系统预定义的状态和动作,自定义WAF特征使用自定义的状态和动作。
WAF策略视图
context-admin
signature-id:WAF特征的编号。预定义WAF特征编号的取值范围为1~536870911;自定义WAF特征编号的取值范围为536870928~1073741808。
disable:表示禁用此WAF特征。在某些网络环境中,如果一些WAF特征暂时不会被用到,而且又不想将其从WAF策略中删除时,可以使用disable参数来禁用这些规则。
enable:表示启用此WAF特征。
block-source:表示源阻断,该动作阻断符合特征的报文,并会将该报文的源IP地址加入IP黑名单。如果设备上同时开启了IP黑名单过滤功能,则一定时间内(由block-period命令指定)来自此IP地址的所有报文将被直接丢弃;否则,此IP黑名单不生效。有关IP黑名单过滤功能的详细介绍请参见“安全命令参考”中的“攻击检测与防范”,有关block-period命令的详细介绍请参见“DPI深度安全”中的“应用层检测引擎”。
drop:表示丢弃报文。
permit:表示允许报文通过。
redirect:表示把符合特征的报文重定向到指定的Web页面上。
capture:表示捕获报文。
logging:表示生成报文日志。
本命令用于修改WAF特征的动作和状态,名称为default的缺省WAF策略中特征的动作和状态不能被修改。
在同一个WAF策略视图中对同一WAF特征多次执行本命令,最后一次执行的命令生效。
# 在名称为test-policy的WAF策略中配置编号为2的预定义WAF特征的状态为开启,动作为丢弃和捕获报文,并生成日志信息。
[Sysname-waf-policy-test-policy] signature override pre-defined 2 enable drop capture logging
·     blacklist enable (security zone view)(安全命令参考/攻击检测与防范)
signature override all命令用来配置WAF策略动作。
undo signature override all命令用来恢复缺省情况。
signature override all { { block-source | drop | permit | redirect | reset } | capture | logging } *
未配置WAF策略动作。
WAF策略视图
context-admin
block-source:表示源阻断,该动作用于阻断报文,并将该报文的源IP地址加入IP黑名单。如果设备上同时开启了IP黑名单过滤功能,则一定时间内(由block-period命令指定)来自此IP地址的所有报文将被直接丢弃;否则,此IP黑名单不生效。有关IP黑名单过滤功能的详细介绍请参见“安全命令参考”中的“攻击检测与防范”,有关block-period命令的详细介绍请参见“DPI深度安全”中的“应用层检测引擎”。
drop:表示丢弃报文。
permit:表示允许报文通过。
redirect:表示把报文重定向到指定的Web页面上。
capture:表示捕获报文。
logging:表示生成报文日志。
当设备检测到攻击报文时,将对报文进行如下处理:
·     当设备仅通过特征匹配方式检测出攻击时,如果配置了WAF策略动作,则将根据该动作对报文进行处理。否则,设备将根据特征属性中的动作对报文进行处理。如果特征配置了例外动作(通过signature override命令配置),则无论是否配置了WAF策略动作,设备都优先根据例外动作对报文进行处理。
·     当设备仅通过语义分析方式检测出攻击时(该方式仅支持检测SQL注入攻击),如果配置了WAF策略动作,则将根据该动作对攻击报文进行处理。否则,设备将放行攻击报文,并以快速输出方式发送日志。
·     当设备通过特征匹配和语义分析功能同时检测出攻击时,则执行两种检测方式下严重级别最高的动作。其中,只要一种检测方式下开启了日志记录功能,设备就会记录日志。
# 在名称为test-policy的WAF策略中配置WAF策略动作为丢弃,并生成日志信息和捕获报文。
[Sysname-waf-policy-test-policy] signature override all drop logging capture
1.1.47  signature-id
signature-id命令用来向WAF白名单表项中添加特征ID。
undo signature-id命令用来删除WAF白名单表项中的特征ID。
signature-id [ serial-number ] sig-id
undo signature-id [ serial-number ]
WAF白名单表项中不存在特征ID。
WAF白名单表项视图
context-admin
serial-number:表示WAF白名单表项中特征ID的序号,取值范围为1~10。若不指定本参数,系统将从1开始,按照步长为1自动分配一个大于现有最大编号的最小编号。在删除特征ID时,用户仅需要指定特征ID的序号即可,方便用户配置。
sig-id:表示WAF特征ID,取值范围为1~4294967295。其中,4294967295为语义分析功能检测出的攻击所共用的特征ID。
当发现WAF日志存在误报的情况时,可以通过本配置将日志中提取到的WAF特征ID加入指定编号的WAF白名单。设备对匹配白名单的报文放行,可以减少误报。
当白名单表项中同时存在特征ID、URL和源IP地址中的两者或以上时,只有报文同时匹配上所有配置项才认为匹配成功。
当管理员希望将通过语义分析功能识别出的WAF攻击的信息添加到白名单中时,需要先将源IP地址或URL添加到白名单表项中,再添加特征ID(4294967295)。否则配置将下发失败。
执行undo signature-id命令时,若不指定任何参数,则表示删除所有特征ID。
# 在编号为1的WAF白名单表项中,添加特征ID 936。
[Sysname-waf-whitelist-1] signature-id 936
·     source-address (WAF whitelist entry view)
·     url
source-address命令用来配置WAF自定义特征规则匹配的源IP地址。
undo source-address命令用来恢复缺省情况。
source-address ip ip-address
undo source-address
未配置WAF自定义特征规则匹配的源IP地址。
WAF自定义特征规则视图
context-admin
ip-address:表示自定义特征匹配的源IPv4地址。
# 在WAF自定义特征mysignature中,新建编号为1的关键字类型规则,配置自定义特征规则匹配的源IP地址为10.1.1.1。
[Sysname-waf-signature-mysignature-rule-1] source-address ip 10.1.1.1
source-address命令用来向WAF白名单表项中添加源IP地址。
source-address { ip ipv4-address | ipv6 ipv6-address }
undo source-address
WAF白名单表项中不存在源IP地址。
WAF白名单表项视图
context-admin
ip ipv4-address:表示IPv4地址。
当发现WAF日志存在误报的情况时,可以将日志中提取到的源IP地址加入WAF白名单。设备对匹配白名单的报文放行,可以减少误报。
当白名单表项中同时存在特征ID、URL和源IP地址中的两者或以上时,需要同时匹配才认为匹配成功。
# 向编号为1的WAF白名单表项中添加源IP地址为192.168.0.1。
[Sysname-waf-whitelist-1] source-address ip 192.168.0.1
·     signature-id
·     url
1.1.50  source-port
source-port命令用来配置WAF自定义特征规则匹配的源端口。
undo source-port命令用来恢复缺省情况。
source-port start-port [ to end-port ]
undo source-port
未配置WAF自定义特征匹配的源端口。
WAF自定义特征规则视图
context-admin
start-port:表示源端口的起始端口号,取值范围为1~65535。
to end-port:指定结束源端口号。end-port表示源端口的结束端口号,取值范围为1~65535。若不指定该参数,则表示仅匹配起始端口号。
本命令用于配置TCP协议的端口号。
# 在WAF自定义特征mysignature中,新建编号为1的关键字类型规则,配置自定义特征规则匹配的源端口范围为1~3550。
[Sysname-waf-signature-mysignature-rule-1] source-port 1 to 3550
tamper-proof auto-learn enable命令用来开启网页自学习功能。
undo tamper-proof auto-learn enable命令用来关闭网页自学习功能。
网页自学习功能处于开启状态。
WAF策略视图
context-admin
本功能用于对客户端访问的静态网页资源进行学习,并在完成学习后将该网页文件保存为基线文件,以便后续进行防篡改功能检测时,与待检测文件进行对比,判断待检测文件是否被恶意篡改。
其中,设备仅对如下资源进行学习。
·     满足学习条件的资源:当客户端请求访问的URL中请求方法为“GET”且资源文件的类型为防篡改支持检测的文件类型时,防篡改会进行自动学习。
·     管理员手动添加的静态网页资源路径下的资源:当网页资源不符合上述学习条件时,管理员可以根据实际需要,手动添加资源的路径(通过tamper-proof web-resources命令配置),防篡改会对该路径下的网页资源进行学习。
管理员可以通过查看Web页面中的“自学习URL列表”,判断设备是否已完成学习。如果已完成,则需要手动关闭网页自学习功能,使网页防篡改功能切换到工作状态。
# 在名为p1的WAF策略中开启网页自学习功能。
<Sysname> sysname
[Sysname] waf policy p1
[Sysname-waf-policy-p1] tamper-proof auto-learn enable
·     tamper-proof web-resources
tamper-proof enable命令用来开启网页防篡改功能。
undo tamper-proof enable命令用来关闭网页防篡改功能。
tamper-proof enable
网页防篡改功能处于关闭状态。
WAF策略视图
context-admin
开启本功能后,设备可对客户端访问的网页资源进行检测,判断内容是否被篡改,同时支持对篡改后的页面进行恢复,避免客户端因访问篡改后的网页(例如钓鱼网站等)而遭到攻击。
本功能需要与网页自学习功能配合使用,即通过tamper-proof auto-learn enable命令配置。
# 在名为p1的WAF策略中,开启网页防篡改功能。
<Sysname> sysname
[Sysname-waf-policy-p1] tamper-proof enable
·     tamper-proof auto-learn enable
tamper-proof file-type enable命令用来开启网页防篡改功能对指定类型的文件进行检测。
undo tamper-proof file-type enable命令用来关闭网页防篡改功能对指定类型文件进行检测。
tamper-proof file-type file-type enable
undo tamper-proof file-type file-type enable
网页防篡改功能支持对XLS、HLP、PPT、DOC、PE、PDF、SWF、ZIP、GIF、JPEG、CSS、HTML、TXT类型文件进行检测。
WAF策略视图
context-admin
file-type:表示网页防篡改功能检测的文件类型。可通过输入“?”获取支持的文件类型。
防篡改检测过程中会占用一定的内存、降低设备的转发性能,当组网环境中不需要对某种类型文件进行防篡改检测时,可执行undo命令,关闭对该类型文件的防篡改检测。减少对内存的占用,提升设备转发性能。
多次执行本命令,可以配置多个防篡改功能检测的文件类型。
各文件类型支持的扩展名包括如下取值:
·     XLS:支持扩展名为xl和xla。
·     HLP:支持扩展名为hlp和chm。
·     PPT:支持扩展名为ppt、ppz、pps、pot和pptx。
·     DOC:支持扩展名为doc和dot。
·     PE:支持扩展名为bin、exe、com和dll。
·     PDF:支持扩展名为pdf。
·     SWF:支持扩展名为swf和cab。
·     ZIP:支持扩展名为zip。
·     GIF:支持扩展名为gif。
·     JPEG:支持扩展名为jpeg、jpg和jpe。
·     CSS:支持扩展名为css。
·     HTML:支持扩展名为html和htm。
·     TXT:支持扩展名为txt。
# 在名为p1的WAF策略中,取消网页防篡改功能对DOC类型文件进行检测。
<Sysname> sysname
[Sysname-waf-policy-p1] undo tamper-proof file-type doc enable
tamper-proof web-resources命令用来添加网页防篡改功能学习的静态网页资源路径。
undo tamper-proof web-resources命令用来删除网页防篡改功能学习的静态网页资源路径。
tamper-proof web-resources host method uri
undo tamper-proof web-resources host method uri
WAF策略视图
context-admin
host:表示服务器主机名或IP地址。取值范围为3~224个字符,区分大小写,只能包含字母、数字、下划线“_”、连接符“-”、冒号“:”、左方括号“[”、右方括号“]”、和点号“.”。
method:表示请求方法,可通过输入“?”获取支持的请求方法。
uri:表示URI,取值范围为3~245个字符,区分大小写,以“/”开头。
当某些静态网页资源不符合网页防篡改自动学习的条件时,即该资源的文件类型不属于网页防篡改支持检测的文件类型,或者客户端请求报文中的请求方法非“Get”,可通过本命令手动添加该资源路径,设备将会对路径下的网页资源进行学习。
# 在名为p1的WAF策略中,添加网页防篡改功能学习的静态网页资源路径host为66.66.66.1:250,请求方法为get,URI为/dm/26300981_1000.dac?type=10&pos=1&uid=445059629。
<Sysname> sysname
[Sysname-waf-policy-p1] tamper-proof web-resources 66.66.66.1:250 get /dm/26300981_1000.dac?type=10&pos=1&uid=445059629
1.1.55  trigger
trigger命令用来配置WAF自定义特征规则的触发检查项。
undo trigger命令用来恢复缺省情况。
trigger field field-name include { hex hex-string | text text-string } [ offset offset-value ] [ depth depth-value ]
undo trigger
未配置WAF自定义特征规则的触发检查项。
WAF自定义特征规则视图
context-admin
field-name:表示协议字段名称,不区分大小写。需要通过输入“?”获取支持的协议字段。
include:表示触发检查项与检测内容的匹配方式是包含。
hex hex-string:表示触发检查项匹配的十六进制字符内容,hex-string表示匹配内容,为8~254个字符的字符串,且必须输入偶数个字符,输入参数必须在两个竖杠“|”之间,仅支持输入“0-9、A-F、a-f”,区分大小写,例如|1234f5b6|。
text text-string:表示触发检查项匹配的字符串内容,text-string表示匹配内容,为3~255个字符的字符串,不区分大小写。
offset offset-value:表示触发检查项的偏移量,从协议字段的起始位置开始偏移的长度。取值范围为1~65535,单位为字节。若不配置该参数,则表示触发检查项从协议字段的起始位置开始检测。
depth depth-value:表示触发检查项的检测深度,从触发检查项检测的起始位置开始,检测的长度。取值范围为3~65535,单位为字节。若不配置该参数,则表示触发检查项检测整个协议字段。
只有自定义特征规则的匹配类型为关键字的情况下才需要配置触发检查项,触发检查项是同一规则下检查项的触发条件。如果一条规则的触发检查项匹配失败,则该规则匹配失败,不会再对该规则下的检查项进行检测。
对于关键字类型的自定义特征规则,在配置检查项之前,必须先配置触发检查项。
删除触发检查项后,将一并删除所有的检查项。
# 在WAF自定义特征mysignature中,新建编号为1的关键字类型规则,配置触发检查项的协议检测字段为http-uri、匹配内容为字符串abc、偏移量为10、检测深度为50。
[Sysname-waf-signature-mysignature-rule-1] trigger field http-uri include text abc offset 10 depth 50
update schedule命令用来配置定期自动在线升级WAF特征库的时间。
undo update schedule命令用来恢复缺省情况。
设备在每天01:00:00至03:00:00之间自动在线升级WAF特征库。
自动升级配置视图
context-admin
daily:表示自动升级周期为每天。
weekly:表示以一周为周期,在指定的一天进行自动升级。
fri:表示星期五。
mon:表示星期一。
sat:表示星期六。
sun:表示星期日。
thu:表示星期四。
tue:表示星期二。
wed:表示星期三。
start-time time:指定自动升级开始时间,time的格式为hh:mm:ss,取值范围为00:00:00~23:59:59。
tingle minutes:指定抖动时间,即实际自动升级开始时间的偏差范围,取值范围为0~120,单位为分钟。在start-time指定时间的前后各偏移抖动时间的一半作为自动升级的时间范围,例如,指定自动升级的开始时间为01:00:00,抖动时间为60分钟,则自动升级的时间范围为00:30:00至01:30:00。
# 配置WAF特征库的定期自动在线升级时间为每周一20:30:00,抖动时间为10分钟。
[Sysname] waf signature auto-update
[Sysname-waf-sig-autoupdate] update schedule weekly mon start-time 20:30:00 tingle 10
·     waf signature auto-update
·     waf signature auto-update-now
1.1.57  url
url命令用来向WAF白名单表项中添加URL。
undo url命令用来恢复缺省情况。
url match-type { accurate | substring } url-text
undo url
WAF白名单表项不存在URL。
WAF白名单表项视图
context-admin
match-type:表示URL的匹配方式。
accurate:表示精确匹配,即报文中URL必须和配置的URL完全一致才能匹配成功。
substring:表示模糊匹配,即报文中携带的URL只要包含配置的URL即可匹配成功。
url-text:表示WAF攻击报文中携带的URL,为3~460个字符的字符串,不区分大小写。
当发现WAF日志存在误报的情况时,可以将日志中提取到的URL加入指定的WAF白名单。设备对匹配白名单的报文放行,可以减少误报。
配置本命令后,需要执行waf whitelist activate命令使WAF白名单表项生效。
# 在编号为1的WAF白名单表项中,添加URL为example.com,匹配方式为精确匹配。
[Sysname-waf-whitelist-1] url match-type accurate example.com
·     signature-id
·     waf whitelist activate
waf apply policy命令用来在DPI应用profile中引用WAF策略。
undo waf apply policy命令用来删除引用的WAF策略。
waf apply policy policy-name mode { alert | protect }
DPI应用profile中未引用WAF策略。
DPI应用profile视图
context-admin
policy-name:指定WAF策略名称,为1~63个字符的字符串,不区分大小写。
mode:表示WAF策略的模式。
alert:告警模式,表示报文匹配上该WAF策略中的特征后,仅可以生成日志或捕获报文,但其他动作均不能生效。
protect:保护模式,表示报文匹配上该WAF策略中的特征后,设备按照特征的动作对该报文进行处理。
WAF策略仅在被DPI应用profile引用后生效。一个DPI应用profile视图下只能引用一个WAF策略。
# 在名称为sec的DPI应用profile下引用WAF策略waf1,且配置WAF策略为保护模式。
[Sysname] app-profile sec
[Sysname-app-profile-sec] waf apply policy waf1 mode protect
·     app-profile(DPI深度安全命令参考/应用层检测引擎)
·     waf policy
1.1.59  waf enable
waf enable命令用来启用WAF策略。
undo waf enable命令用来禁用WAF策略。
waf enable
undo waf enable
WAF策略处于启用状态。
WAF策略视图
如果在某些组网环境中某条WAF策略暂时不会被用到,则可以使用undo waf enable禁用此策略。禁用WAF策略后,此策略将不能对流量进行匹配。
# 禁用WAF策略wpolicy。
[Sysname] waf policy wpolicy
[Sysname-waf-policy-wpolicy] undo waf enable
waf { block-source | capture | email | logging | redirect } parameter-profile命令用来配置WAF策略动作引用应用层检测引擎动作参数profile。
undo waf { block-source | capture | email | logging | redirect } parameter-profile命令用来取消配置WAF策略动作引用应用层检测引擎动作参数profile。
waf { block-source | capture | email | logging | redirect } parameter-profile parameter-name
WAF策略动作未引用应用层检测引擎动作参数profile。
context-admin
block-source:表示设置WAF源阻断动作的参数。
capture:表示设置WAF捕获动作的参数。
email:表示设置WAF邮件动作的参数。
logging:表示设置WAF日志动作的参数。
redirect:表示设置WAF重定向动作的参数。
parameter-profile parameter-name:指定WAF策略动作引用的应用层检测引擎动作参数profile。parameter-name表示动作参数profile的名称,为1~63个字符的字符串,不区分大小写。
每类WAF策略动作的具体执行参数由应用层检测引擎动作参数profile来定义,可通过引用各动作参数proflle为WAF策略动作提供执行参数。有关应用层检测引擎动作参数proflle的具体配置请参见“DPI深度安全命令参考”中的“应用层检测引擎”。
如果WAF策略动作没有引用应用层检测引擎动作参数profile,或者引用的动作参数profile不存在,则使用系统中各动作参数的缺省值。
# 创建名称为waf1的应用层检测引擎源阻断动作参数profile,配置其阻断源IP地址的时长为1111秒。
[Sysname] inspect block-source parameter-profile waf1
[Sysname-inspect-block-source-waf1] block-period 1111
[Sysname-inspect-block-source-waf1] quit
# 配置WAF源阻断动作引用名称为waf1的应用层检测引擎源阻断动作参数profile。
[Sysname] waf block-source parameter-profile waf1
·     inspect block-source parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·     inspect capture parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·     inspect email parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·     inspect logging parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·     inspect redirect parameter-profile(DPI深度安全命令参考/应用层检测引擎)
1.1.61  waf policy
waf policy命令用来创建WAF策略,并进入WAF策略视图。如果指定的策略已经存在,则直接进入WAF策略视图。
undo waf policy命令用来删除指定的WAF策略。
undo waf policy policy-name
存在WAF策略,名称为default。
context-admin
policy-name:表示WAF策略的名称,为1~63个字符的字符串,不区分大小写,创建策略时策略名称不能为default且不能包含“protected-website”字符串。
WAF策略下可以配置特征过滤条件、匹配特征后执行的动作、防护的网站以及引用CC攻击防护策略。
名称为default的策略不可以被删除。
WAF策略需要在app-profile中引用才生效,有关app-profile的详细介绍,请参见“DPI深度安全命令参考”中的“应用层检测引擎”。
# 创建名称为test-policy的WAF策略,并进入该WAF策略视图。
waf signature命令用来创建WAF自定义特征,并进入WAF自定义特征视图。如果指定的WAF自定义特征已经存在,则直接进入WAF自定义特征视图。
undo waf signature命令用来删除WAF自定义特征。
waf signature user-defined name signature-name
undo waf signature user-defined { all | name signature-name }
不存在WAF自定义特征。
context-admin
signature-name:表示WAF自定义特征的名称,取值范围为1~63个字符的字符串,不区分大小写。
all:表示所有WAF自定义特征。
多次执行本命令,可配置多个WAF自定义特征。
删除WAF自定义特征后,将删除该特征下的所有配置。
# 创建名称为mysignature的WAF自定义特征。
·     display waf signature user-defined
waf signature auto-update命令用来开启定期自动在线升级WAF特征库功能,并进入自动升级配置视图。
undo waf signature auto-update命令用来关闭定期自动在线升级WAF特征库功能。
定期自动在线升级WAF特征库功能处于关闭状态。
context-admin
如果设备可以访问官方网站上的特征库服务专区,可以采用定期自动在线升级方式来对设备上的WAF特征库进行升级。
# 开启定期自动在线升级WAF特征库功能,并进入自动升级配置视图。
·     update schedule
waf signature auto-update-now命令用来立即自动在线升级WAF特征库。
context-admin
执行此命令后,将立即自动升级设备上的WAF特征库,且会备份当前的WAF特征库文件。此命令的生效与否,与是否开启了定期自动升级WAF特征库功能无关。
当管理员发现官方网站上的特征库服务专区中的WAF特征库有更新时,可以选择立即自动在线升级方式来及时升级WAF特征库版本。
# 立即自动在线升级WAF特征库版本。
[Sysname] waf signature auto-update-now
waf signature rollback命令用来回滚WAF特征库。
waf signature rollback factory
context-admin
factory:表示WAF特征库的出厂版本。
如果管理员发现设备当前WAF特征库版本在检测和防御网络攻击时,误报率较高或出现异常情况,则可以对当前WAF特征库版本进行回滚。目前支持将设备中的WAF过滤特征库版本回滚到出厂版本。
# 配置WAF特征库回滚到出厂版本。
[Sysname] waf signature rollback factory
waf signature update命令用来手动离线升级WAF特征库。
waf signature update file-path [ vpn-instance vpn-instance-name ] [ source { ip | ipv6 } { ip-address | interface interface-type interface-number } ]
context-admin
file-path:指定特征库文件的路径,为1~255个字符的字符串。
vpn-instance vpn-instance-name:表示TFTP、FTP服务器所属的VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则表示TFTP、FTP服务器位于公网中。
source:指定手动离线升级特征库时发送给TFTP、FTP服务器的请求报文的源IP地址。如果不指定该参数,则表示使用系统根据路由表项查找到的出接口的地址。
ip ip-address:指定手动离线升级特征库时发送给TFTP、FTP服务器的请求报文的源IPv4地址。
ipv6 ip-address:指定手动离线升级特征库时发送给TFTP、FTP服务器的请求报文的源IPv6地址。
interface interface-type interface-number:指定该接口的主IPv4地址或接口上最小的IPv6地址为源IP地址。
如果设备不能访问官方网站上的特征库服务专区,管理员可以采用如下几种方式手动离线升级WAF特征库版本。
·     本地升级:使用本地保存的特征库文件升级系统上的WAF特征库版本。
·     FTP/TFTP升级:通过FTP或TFTP方式下载远程服务器上保存的特征库文件,并升级系统上的WAF特征库版本。
使用本地升级方式离线升级特征库版本时,特征库文件只能存储在当前主用设备上,否则设备升级特征库会失败。‌
参数file-path的取值与手动离线升级的操作方式有关。本地升级时参数file-path取值请参见表1-5;FTP/TFTP升级时参数file-path取值请参见表1-6。
表1-5 本地升级时参数file-path取值说明表
升级场景
参数file-path取值
特征库文件的存储位置与当前工作路径一致
filename
可以执行pwd命令查看当前工作路径
有关pwd命令的详细介绍请参见“基础配置命令参考”中的“文件系统管理”
特征库文件的存储位置与当前工作路径不一致,且在相同存储介质上
filename
需要先执行cd命令将工作路径切换至特征库文件所在目录下
有关cd命令的详细介绍请参见“基础配置命令参考”中的“文件系统管理”
特征库文件的存储位置与当前工作路径不在相同存储介质上
path/ filename
需要先执行cd命令将工作路径切换至特征库文件所在存储介质的根目录下,再指定特征库文件的相对路径
表1-6 FTP/TFTP升级时参数file-path取值说明表
升级场景
参数file-path取值
特征库文件存储在开启FTP服务的远程服务器上
ftp://username:password@server/filename
username为登录FTP服务器的用户名,password为登录FTP服务器的密码,server为FTP服务器的IP地址或主机名
当FTP的用户名和密码中使用了“:”、“@”和“/”三种特殊字符时,需要将这三种特殊字符替换为其对应的转义字符。“:”、“@”和“/”三种特殊字符对应的转义字符分别为“%3A或%3a”、“%40”和“%2F或%2f”
特征库文件存储在开启TFTP服务的远程服务器上
tftp://server/filename
server为TFTP服务器的IP地址或主机名
当采用FTP/TFTP方式升级特征库时,如果指定的是服务器的主机名,则需要确保设备能通过静态或动态域名解析方式获得FTP/TFTP服务器的IP地址,并与之路由可达。否则设备升级特征库会失败。有关域名解析功能的详细配置请参见“三层技术-IP业务配置指导”中的“域名解析”。
如果管理员希望手动离线升级特征库时发送给TFTP、FTP服务器的请求报文的源IP地址是一个特定的地址时,可配置source参数。例如,当组网环境中设备发出的报文需要经过NAT地址转换后才能访问TFTP、FTP服务器时,则需要管理员通过source参数指定一个符合NAT地址转换规则的源IP地址(其中,如果设备需要经过一台独立的NAT设备进行地址转换时,本命令指定的IP地址必须可以与NAT设备三层路由可达),使设备发出的报文可以进行NAT地址转换等处理,正常访问TFTP、FTP服务器。
当同时配置了source和vpn-instance参数时,需要保证source中指定的源IP地址或接口所属VPN实例与vpn-instance中配置的VPN实例相同。
# 配置手动离线升级WAF特征库,且采用TFTP方式,WAF特征库文件的远程路径为tftp://192.168.0.10/waf-1.0.2-en.dat。
[Sysname] waf signature update tftp://192.168.0.10/waf-1.0.2-en.dat
# 配置手动离线升级WAF特征库,且采用FTP方式,WAF特征库文件的远程路径为ftp://192.168.0.10/waf-1.0.2-en.dat,用户名为user:123,密码为user@abc/123。
[Sysname] waf signature update ftp://user%3A123:user%40abc%[email protected]/waf-1.0.2-en.dat
# 配置手动离线升级WAF特征库,且采用本地方式,WAF特征库文件的本地路径为cfa0:/waf-1.0.23-en.dat,且当前工作路径为cfa0:。
[Sysname] waf signature update waf-1.0.23-en.dat
# 配置手动离线升级WAF特征库,且采用本地方式,WAF特征库文件的本地路径为cfa0:/dpi/waf-1.0.23-en.dat,且当前工作路径为cfa0:。
<Sysname> cd dpi
# 配置手动离线升级WAF特征库,且采用本地方式,WAF特征库文件的本地路径为cfb0:/dpi/waf-1.0.23-en.dat,当前工作路径为cfa0:。
<Sysname> cd cfb0:/
[Sysname] waf signature update dpi/waf-1.0.23-en.dat
waf tamper-proof cache-files enable命令用来开启篡改文件缓存功能。
undo waf tamper-proof cache-files enable命令用来关闭篡改文件缓存功能。
篡改文件缓存功能处于开启状态。
context-admin
context-operator
当设备检测到服务器返回给客户端的网页资源文件是篡改文件时,会将其缓存到存储介质(硬盘或U盘)中。管理员可到Web界面的防篡改日志页面中下载篡改文件,用于分析。
缓存文件的过程会占用存储介质的存储空间,并影响设备转发性能。当存储介质的存储空间不足、设备的转发性能降低或者用户不关心篡改文件时,可执行undo命令,关闭篡改文件缓存功能。
本功能仅在设备安装了存储介质(硬盘或U盘)时生效。
# 关闭篡改文件缓存功能。
[Sysname] undo waf tamper-proof cache-files enable
waf whitelist命令用来创建并进入WAF白名单表项视图。如果指定的WAF白名单表项视图已存在,则直接进入WAF白名单表项视图。
undo waf whitelist命令用来删除指定的WAF白名单表项。
waf whitelist entry-id
undo waf whitelist entry-id
context-admin
entry-id:表示WAF白名单ID,取值范围为1~2048。
当管理员发现WAF日志存在误报的情况时,可在指定的WAF白名单表项视图下,将日志中提取到的WAF特征ID、源IP地址或URL加入WAF白名单。设备对匹配白名单的报文放行,可以减少误报。
# 创建并进入编号为1的WAF白名单表项视图。
waf whitelist activate命令用来激活WAF白名单配置。
创建、修改和删除含有URL的WAF白名单后,系统会自动激活白名单配置使其生效。
context-admin
缺省情况下,当创建、修改和删除含有URL的WAF白名单后,系统将在10秒后自动激活白名单配置使其生效,如果希望对白名单立即进行激活,可执行本命令手工激活。
# 激活WAF白名单配置。
[Sysname] waf whitelist activate
·     url
waf whitelist enable命令用来开启WAF白名单功能。
undo waf whitelist enable命令用来关闭WAF白名单功能。
WAF白名单功能处于开启状态。
context-admin
当管理员发现WAF日志存在误报的情况时,可通过开启白名单功能,将日志中获取到的特征ID、URL和源IP地址加入白名单。设备将放行匹配白名单的报文,从而降低误报率。
# 关闭WAF白名单功能。
[Sysname] undo waf whitelist enable
xff-detection enable命令用来开启X-Forwarded-For字段检测功能。
undo xff-detection enable命令用来恢复缺省情况。
undo x-forwarded-for enable
X-Forwarded-For字段检测功能处于关闭状态。
CC攻击防护策略规则视图
context-admin
本功能适用于客户端使用代理方式访问服务器的场景。
设备需要对客户端的源IP地址进行检测,当客户端使用代理方式访问服务器时,源IP地址将会发生改变,设备无法获取真正的源IP地址。开启X-forward-For字段检测功能后,设备将从客户端HTTP请求报文头的X-forward-for字段获取真正的源IP地址,避免上述问题。
# 在名称为news的CC攻击防护策略下,配置名称为test的防护规则中开启X-Forwarded-For字段检测功能。
[Sysname-cc-defense-policy-news-rule-test] xff-detection enable
1.1.72  yundi alias
yundi alias命令用来配置电信云堤网络中WAF策略的别名及所属的租户。
undo yundi alias tenant命令用来恢复缺省情况。
yundi alias alias-name tenant tenant-id
在电信云堤网络中未配置WAF策略的别名及所属的租户。
WAF策略视图
alias-name:表示WAF策略的别名,为1~63个字符的字符串,不区分大小写。
tenant tenant-id:表示WAF策略所属的租户,tenant-id为租户ID,取值范围为1~63个字符的字符串,不区分大小写。
在电信云堤网络中WAF策略的别名及所属的租户是WAF策略的属性信息,一个WAF策略只能属于一个租户,一个租户可以有多个WAF策略,但WAF策略间不能具有相同的别名。别名和租户ID通常由控制器下发,因此不建议在设备上手工设置本功能。
多次执行本命令,最后一次执行的命令行生效。
# 配置名为wafpolicy的WAF策略的别名为policy1,所属的租户为abc。
[Sysname] waf policy wafpolicy
[Sysname-waf-policy-wafpolicy] yundi alias policy1 tenant abc
