11-ACL和QoS命令参考
02-QoS命令
本章节下载 02-QoS命令  (1.20 MB)
02-QoS命令
  录
1 QoS策略
1.1 定义类的命令
1.1.1 display traffic classifier
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 car
1.2.2 car percent
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 gts
1.2.6 gts percent
1.2.7 packet-rate
1.2.8 redirect
1.2.9 remark apn-id-ipv6 instance
1.2.10 remark dot1p
1.2.11 remark dscp
1.2.12 remark flow-id
1.2.13 remark ip-precedence
1.2.14 remark local-precedence
1.2.15 remark qos-local-id
1.2.16 remark service-class
1.2.17 remark tunnel-dscp
1.2.18 traffic behavior
1.2.19 traffic-policy
1.3 定义和应用QoS策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 control-plane management
1.3.4 display qos policy
1.3.5 display qos policy advpn
1.3.6 display qos policy control-plane
1.3.7 display qos policy control-plane management
1.3.8 display qos policy control-plane management pre-defined
1.3.9 display qos policy control-plane pre-defined
1.3.10 display qos policy global
1.3.11 display qos policy interface
1.3.12 display qos policy l2vpn-pw
1.3.13 display qos policy sdwan
1.3.14 display qos policy srv6-policy
1.3.15 display qos policy user-profile
1.3.16 qos apply policy (interface view, control plane view, control-plane management view, PW view)
1.3.17 qos apply policy (user profile view)
1.3.18 qos apply policy global
1.3.19 qos apply policy srv6-policy
1.3.20 qos apply user-profile downstream
1.3.21 qos policy
1.3.22 reset qos policy advpn
1.3.23 reset qos policy control-plane
1.3.24 reset qos policy control-plane management
1.3.25 reset qos policy global
1.3.26 reset qos policy srv6-policy
1.3.27 reset qos policy sdwan
1.4 接口流速统计配置命令
1.4.1 qos flow-interval
2 子接口切片
2.1 子接口切片配置命令
2.1.1 display mode channel-bandwidth interface
2.1.2 mode channel-bandwidth
3 优先级映射
3.1 优先级映射表配置命令
3.1.1 display qos map-table
3.1.2 import (priority map view)
3.1.3 qos map-table
3.2 端口优先级信任模式配置命令
3.2.1 display qos trust interface
3.2.2 qos trust
3.3 端口优先级配置命令
3.3.1 qos priority
4 流量监管、流量整形和限速
4.1 流量监管配置命令
4.1.1 display qos car interface
4.1.2 display qos carl
4.1.3 display qos tunnel-session
4.1.4 qos car (interface view)
4.1.5 qos car (user profile view)
4.1.6 qos car bandwidth-refresh-interval
4.1.7 qos car bandwidth-utilization-threshold
4.1.8 qos carl
4.1.9 qos overhead compensation-length
4.1.10 reset qos tunnel-session
4.2 流量整形配置命令
4.2.1 display qos gts interface
4.2.2 qos gts (interface view)
4.2.3 qos gts (user profile view)
4.3 限速配置命令
4.3.1 display qos lr
4.3.2 qos lr
4.3.3 qos lr outbound(user profile view)
4.3.4 qos overhead layer
4.3.5 qos bandwidth downstream
5 拥塞管理
5.1 拥塞管理公共配置命令
5.1.1 display qos queue interface
5.1.2 display qos queue l2vpn-pw
5.1.3 qos-queue enhanced
5.1.4 reset qos statistics l2vpn-pw
5.2 FIFO队列配置命令
5.2.1 display qos queue fifo
5.2.2 qos fifo queue-length
5.3 优先级队列配置命令
5.3.1 display qos pql
5.3.2 display qos queue pq interface
5.3.3 qos pq
5.3.4 qos pq(user profile view)
5.3.5 qos pql default-queue
5.3.6 qos pql inbound-interface
5.3.7 qos pql local-precedence
5.3.8 qos pql protocol
5.3.9 qos pql protocol mpls exp
5.3.10 qos pql queue
5.4 定制队列配置命令
5.4.1 display qos cql
5.4.2 display qos queue cq interface
5.4.3 qos cq
5.4.4 qos cql default-queue
5.4.5 qos cql inbound-interface
5.4.6 qos cql local-precedence
5.4.7 qos cql protocol
5.4.8 qos cql protocol mpls exp
5.4.9 qos cql queue
5.4.10 qos cql queue serving
5.5 加权公平队列配置命令
5.5.1 display qos queue wfq
5.5.2 qos wfq
5.6 实时传输协议队列的配置命令
5.6.1 display qos queue rtpq interface
5.6.2 qos rtpq
5.7 基于类的队列配置命令
5.7.1 display qos queue cbq
5.7.2 qos reserved-bandwidth
5.7.3 queue af
5.7.4 queue ef
5.7.5 queue sp
5.7.6 queue wfq
5.7.7 queue-length
5.7.8 wred
5.7.9 wred dscp
5.7.10 wred ip-precedence
5.7.11 wred weighting-constant
5.8 报文信息预提取命令
5.8.1 qos pre-classify
6 拥塞避免
6.1 WRED配置命令
6.1.1 display qos wred interface
6.1.2 qos wred dscp
6.1.3 qos wred enable
6.1.4 qos wred ip-precedence
6.1.5 qos wred weighting-constant
7 QPPB
7.1 QPPB配置命令
7.1.1 bgp-policy
1 QoS策略
1.1  定义类的命令
display traffic classifier命令用来显示类的配置信息。
(独立运行模式)
display traffic classifier { system-defined | user-defined } [ classifier-name ] [ slot slot-number ]
display traffic classifier { system-defined | user-defined } [ classifier-name ] [ chassis chassis-number slot slot-number ]
system-defined:系统定义类。
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定单板的流分类的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主用主控板的类的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流分类的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示全局主用主控板的类的配置信息。(IRF模式)
# 显示用户定义类的配置信息。
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
# 显示系统定义类default-class的配置信息。
<Sysname> display traffic classifier system-defined default-class
  System-defined classifier information:
   Classifier: default-class (ID 0)
     Operator: AND
     Rule(s) :
      If-match any
表1-1 display traffic classifier命令显示信息描述表
用户自定义类的信息
系统定义类的信息
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
1.1.2  if-match
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match [ not ] match-criteria
undo if-match [ not ] match-criteria
未定义匹配数据包的规则。
类视图
not:不匹配该规则。
表1-2 类的匹配规则取值
取值
acl [ ipv6 | mac ] { acl-number | name acl-name }[ mpls-inner | raw-vpn ]
定义匹配ACL的规则
·     acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999
·     acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
·     mpls-inner用来指定ACL规则匹配MPLS报文的内层报文信息,未配置mpls-inner则表示ACL规则匹配的是未经封装报文的信息或封装后的MPLS报文的外层报文头信息。此配置在QoS策略应用在Egress设备开启MPLS能力的接口入方向、MPLS TE出方向或者MPLS入方向时生效
·     raw-vpn指定该参数时,表示报文在该接口上先进行NAT地址转换再进行ACL匹配。未指定本参数时,设备先进行ACL匹配再执行NAT地址转换,此时不同私网用户的IP源地址可能转换为同一公网IP地址,导致流分类无法区分出不同的私网用户回程报文。仅限于在收到NAT回程报文的公网侧接口上配置nat outbound命令并调用ACL规则来匹配回程报文的场景。其他场景使用该参数时,可能导致错误,请谨慎使用。
ACL规则中未指定VPN实例时,表示该规则对非VPN报文有效,对VPN报文无效
app-group group-name
定义匹配应用组的规则,group-name为应用组的名称。建议引用已创建的应用组;引用未创建的应用组时,无法实现匹配报文的目的。有关创建应用组的详细介绍,请参见“安全配置指导”中的“APR”
application app-name
定义匹配应用名的规则,app-name为用户创建的应用名称
any
定义匹配所有数据包的规则
classifier classifier-name
定义匹配QoS类的规则,classifier-name为类名
control-plane protocol protocol-name&<1-8>
定义匹配控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示,&<1-8>表示前面的参数最多可以输入8次
control-plane protocol-group protocol-group-name
定义匹配控制平面协议组的规则,protocol-group-name取值为critical、important、management、monitor、normal、redirect
customer-dot1p dot1p-value&<1-8>
定义匹配内层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
customer-vlan-id vlan-id-list
定义匹配内层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
本参数支持情况与设备型号有关,请以设备实际情况为准
destination-mac mac-address
定义匹配目的MAC地址的规则,仅对以太网接口生效
dscp dscp-value&<1-8>
定义匹配DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如表1-5所示
inbound-interface interface-type interface-number
定义匹配入接口的规则,interface-type interface-number为接口类型和接口编号
在“and”模式的流分类中如果配置了本规则,然后将入接口所在单板或子卡拔出,会导致流分类失效,此时如果将单板或子卡恢复,则流分类会重新生效。但如果不恢复单板或子卡,请删除该流分类并按需重新配置。否则,即使再向该流分类中新增其他匹配规则,该流分类也不会生效
ip-precedence ip-precedence-value&<1-8>
定义匹配IP优先级的规则,ip-precedence-value&<1-8>为IP优先级的列表,IP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
local-precedence local-precedence-value&<1-8>
定义匹配本地优先级的规则,local-precedence-value&<1-8>为本地优先级的列表,本地优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
mpls-exp exp-value&<1-8>
定义匹配第一层MPLS EXP优先级的规则,exp-value&<1-8>为EXP的列表,EXP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
对于软转发产品,MPLS报文不支持匹配IP相关匹配规则
packet-length { min min-value | max max-value } *
定义匹配报文长度的规则,min-value为匹配报文最小长度的字节数,max-value为匹配报文最大长度的字节数
max-value必须大于等于min-value
定义匹配协议的规则,protocol-name取值为arp、ip、ipv6
qos-local-id local-id-value
定义匹配QoS本地ID值的规则,local-id-value为QoS本地ID,取值范围为1~4095
rtp payload-type { type-value&<0-16> | audio | video }*
定义匹配RTP负载类型的规则,type-value&<0-16>为RTP负载类型值的列表,RTP负载类型的取值范围为0~127,&<0-16>表示前面的参数最多可以输入16次。audio表示RTP负载类型为音频,对应RTP负载类型值包括,0~23和33,video表示RTP负载类型为视频,对应RTP负载类型值的范围为24~34
rtp start-port start-port-number end-port end-port-number
定义匹配RTP协议端口的规则。start-port-number为起始RTP端口号,取值范围为2000~65535;end-port-number为结束RTP端口号,取值范围为2000~65535
用于匹配落在指定RTP端口号范围内的RTP报文,即匹配所有在start-port-numberend-port-number之间的偶数UDP端口号的报文
sdwan-tte site-id site-id [ device-id device-id [ interface-id interface-id ] ]
定义匹配SDWAN网络TTE信息的规则
·     site-id site-id为设备的站点ID,取值范围为1~65535
·     device-id device-id为设备的ID,取值范围为1~255。未指定本参数时,表示匹配该站点中的所有设备
·     interface-id interface-id为SDWAN隧道接口的ID,取值范围为1~255。未指定本参数时,表示匹配该设备中的所有SDWAN隧道接口
关于SDWAN网络的详细介绍,请参见“SDWAN配置指导”中的“SDWAN”
second-mpls-exp exp-value&<1-8>
定义匹配第二层MPLS EXP优先级的规则,exp-value&<1-8>为EXP的列表,EXP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
service-dot1p dot1p-value&<1-8>
定义匹配外层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
service-vlan-id vlan-id-list
定义匹配外层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配
source-mac mac-address
定义匹配源MAC地址的规则,仅对以太网接口生效
tunnel-dscp dscp-value&<1-8>
定义匹配VXLAN报文外层IP头DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,VXLAN报文外层IP头DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如表1-5所示
vpn-instance vpn-name
定义匹配报文VPN实例的规则
vxlan { any | vxlan-id }
定义匹配VXLAN编号的规则,取值范围为0~16777215
表1-3 系统预定义匹配协议报文类型名称的列表
报文类型
arp
ARP协议
bgp
BGP协议
bgp4+
IPv6 BGP
default
其他协议
ftp
FTP协议
http
HTTP协议
https
HTTPS协议
icmp
ICMP协议
icmpv6
IPv6 ICMP协议
igmp
IGMP协议
isis
IS-IS协议
ldp
LDP协议
ldp6
IPv6 LDP协议
msdp
MSDP协议
ntp
NTP协议
ospf-multicast
OSPF组播
ospf-unicast
OSPF单播
ospf3-multicast
OSPFv3组播
ospf3-unicast
OSPFv3单播
pim-multicast
PIM组播
pim-unicast
PIM单播
pim6-multicast
IPv6 PIM组播
pim6-unicast
IPv6 PIM单播
radius
RADIUS协议
rip
RIP协议
ripng
RIPng协议
rsvp
RSVP协议
snmp
SNMP协议
ssh
SSH协议
tacacs
TACACS协议
telnet
TELNET协议
tftp
TFTP协议
vrrp
VRRP协议
vrrp6
IPv6 VRRP协议
一个类下可配置多条匹配命令,各个配置之间互相不覆盖。
在定义匹配规则(控制平面、DSCP、802.1p优先级、IP优先级、本地优先级、MPLS EXP优先级)时,请注意:
·     一条命令可以配置多个规则,如果指定了多个相同的规则,系统默认为一个;一条命令中多个不同的规则是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配的规则时,必须与该规则中定义的完全相同才会删除,顺序可以不同。
在定义匹配ACL的规则时,类中引用的ACL必须已经存在。
if-match中引用的ACL规则的动作为deny时,则跳出该if-match,继续进行后续规则的查找。
在定义匹配类的规则时,如果匹配类的规则之间既有逻辑与,又有逻辑或的关系,请使用以下方式配置。例如,需要定义classA,满足以下关系:规则1 & 规则2 | 规则3,可以这样定义:
·     traffic classifier classB operator and
¡     if-match规则1
¡     if-match规则2
·     traffic classifier classA operator or
¡     if-match规则3
¡     if-match classifier classB
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# 定义类class1的匹配规则为:匹配IP优先级值为1或6的报文。
[Sysname-classifier-class1] if-match ip-precedence 1 6
# 定义类class1的匹配规则为:匹配本地优先级值为1或6的报文。
[Sysname-classifier-class1] if-match local-precedence 1 6
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配RTP端口号在16384和32767之间的偶数UDP端口号的报文。
[Sysname-classifier-class1] if-match rtp start-port 16384 end-port 32767
# 定义类class1匹配QoS本地ID值为3的报文。
[Sysname-classifier-class1] if-match qos-local-id 3
# 匹配RTP负载类型值为1、8、音频或视频类型的报文。
[Sysname-behavior-class] if-match rtp payload-type 1 8 audio video
# 定义类class1匹配应用组multimedia。
[Sysname-classifier-class1] if-match app-group multimedia
# 定义类class1匹配应用名3link。
[Sysname-classifier-class1] if-match application 3link
# 在流分类class1中配置匹配上送控制平面的ARP协议报文。
[Sysname-classifier-class1] if-match control-plane protocol arp
# 在流分类class1中配置匹配上送控制平面的normal协议组报文。
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# 在流分类class1中配置匹配报文长度为100~200字节的报文。
[Sysname-classifier-class1] if-match packet-length min 100 max 200
# 在流分类class1中配置匹配外层IP头DSCP值为10的VXLAN报文。
[Sysname-classifier-class1] if-match tunnel-dscp 10
# 定义类class1的匹配规则为:匹配VXLAN编号为10的报文。
[Sysname-classifier-class1] if-match vxlan 10
# 定义类class1的匹配规则为:匹配内层报文特征符合ACL 3000的MPLS报文。
[Sysname-classifier-class1] if-match acl 3000 mpls-inner
traffic classifier命令用来创建一个类,并进入类视图。如果指定的类已经存在,则直接进入类视图。
undo traffic classifier命令用来删除一个类。
未配置类。
operator:指定各规则之间的逻辑运算符。缺省情况为and
# 定义一个名为class1的类。
·     display traffic classifier
1.2  定义流行为的命令
1.2.1  car
car命令用来配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
未配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,单位为kbps。取值范围与设备的型号有关,请以设备的实际情况为准。
cbs committee-burst-size:承诺突发尺寸,单位为byte。取值范围和缺省值与设备的型号有关,请以设备的实际情况为准。
ebs excess-burst-size:超出突发尺寸,单位为byte。取值范围和缺省值与设备的型号有关,请以设备的实际情况为准。
pir peak-information-rate:峰值速率,单位为kbps,pircir速率单位必须保持一致。取值范围与设备的型号有关,请以设备的实际情况为准。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63。
·     remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
·     remark-mpls-exp-pass new-exp:设置新的MPLS报文的EXP标志位的值,并允许数据包通过,取值范围为0~7。
·     remark-prec-pass new-precedence:设置新的IP优先级,并允许数据包通过,取值范围为0~7。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
如果未配置峰值速率,则表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 为流行为配置流量监管。报文正常流速为200kbps,承诺突发尺寸为51200bytes,速率大于200kbps时,报文DSCP值改为0并发送。
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
1.2.2  car percent
car cir percent命令用来采用百分比的方式在流行为内配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir percent cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ green action | red action | yellow action ] *
car cir percent cir-percent [ cbs cbs-time ] pir percent pir-percent [ ebs ebs-time ] [ green action | red action | yellow action ] *
undo car
未配置百分比形式的流量监管动作。
流行为视图
cir percent cir-percent:承诺信息速率百分比,取值范围为1~100。CIR的实际值是百分比值乘以接口带宽值。
cbs cbs-time:用指定的时间(单位为毫秒)来设置CBS,实际的CBS值是cbs-time乘以实际的cir值(cir值乘以接口带宽)。取值范围为50~2000,缺省值为500。
ebs ebs-time:用指定的时间(单位为毫秒)来设置EBS,实际的EBS值是ebs-time乘以实际的cir值(cir值乘以接口带宽)。取值范围为0~2000,不配置pir percent时,缺省值为0;配置pir percent时,缺省值为500。
pir percent pir-percent:以百分比的形式来指定峰值速率,取值范围为1~100。峰值速率不能比承诺信息速率小。
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63;用文字表示时,可以选取af11af12af13af21af22af23af31af32af33af41af42af43cs1cs2cs3cs4cs5cs6cs7defaultef
·     remark-lp-pass new-lp:设置新的报文的lp标志位的值,并允许数据包通过,取值范围为0~7。
接口上应用的QoS策略中使用CAR时,可以应用到接口报文的接收或者发送方向。
按百分比配置CAR的QoS策略只能应用到接口上。
承诺速率=CIR * bandwidth,峰值速率=PIR * bandwidth,最顶层策略的bandwidth取应用此策略的接口带宽,嵌套策略的bandwidth取所在流行为下的GTS速率值,如没有GTS,则取更上一层策略所在流行为的GTS速率,如没有取到,最终使用应用策略的接口带宽。
·     对于物理接口,bandwidth缺省值为物理接口实际的速率;
·     对于虚接口(如Tunnel接口、三层聚合接口、HDLC捆绑接口),由于其bandwidth缺省值为0kbps,所以需配置接口的期望带宽,避免流量不通。有关接口的期望带宽的详细介绍,请参见“接口管理命令参考”中的“以太网接口”。
# 为流行为配置流量监管。报文正常流速为带宽的20%,承诺突发尺寸为100ms。
[Sysname-behavior-database] car cir percent 20 cbs 100
display traffic behavior命令用来显示流行为的配置信息。
(独立运行模式)
display traffic behavior { system-defined | user-defined } [ behavior-name ] [ slot slot-number ]
display traffic behavior { system-defined | user-defined } [ behavior-name ] [ chassis chassis-number slot slot-number ]
system-defined:系统定义行为。
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定单板的流行为的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的流行为的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流行为的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的流行为的配置信息。(IRF模式)
# 显示用户定义行为的配置信息。
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Filter enable: Permit
      Marking:
        Remark mpls-exp 4
      Expedited Forwarding:
        Bandwidth 50 (kbps) CBS 1250 (Bytes)
# 显示系统定义行为的配置信息。
<Sysname> display traffic behavior system-defined
  System-defined behavior information:
    Behavior: be (ID 0)
      -none-
    Behavior: af (ID 1)
      Assured Forwarding:
        Bandwidth 20 (%)
        Discard Method: Tail
    Behavior: ef (ID 2)
        Bandwidth 20 (%) Cbs-ratio 25
    Behavior: be-flow-based (ID 3)
      Flow based Weighted Fair Queue:
        Max number of hashed queues: 256
        Discard Method: IP Precedence based WRED
        Exponential Weight: 9
        Pre  Low   High  Dis-prob
        0    10    30    10
        1    10    30    10
        2    10    30    10
        3    10    30    10
        4    10    30    10
        5    10    30    10
        6    10    30    10
        7    10    30    10
表1-4 display traffic behavior命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名称及其内容,内容可以有多种类型
Marking
标记相关信息
Remark dscp
重新标记报文的DSCP优先级值
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
EBS
超出突发尺寸,单位为byte
Green action
对绿色报文的动作
Red action
对红色报文的动作
Yellow action
对黄色报文的动作
General Traffic Shaping
流量整形的相关信息
Queue length
队列的最大长度
Redirecting
流量重定向相关信息
Mirroring
流量镜像相关信息
加速转发(EF队列)相关信息
Assured Forwarding
确保转发(AF队列)的相关信息
Bandwidth
队列的带宽
Discard Method
丢弃方式
Filter enable
流量过滤动作
none
表示未配置其他流行为
Redirect to SRv6-TE policy
重定向到SRv6 TE Policy
·     Endpoint:目的节点地址
·     Color:Color属性值
·     SID:尾节点的SRv6 SID
1.2.4  filter
filter命令用来配置流量过滤动作。
undo filter命令用来恢复缺省情况。
filter { deny | permit }
undo filter
未配置流量过滤动作。
流行为视图
deny:丢弃数据包。
permit:允许数据包通过。
# 为流行为配置丢弃数据包的过滤动作。
1.2.5  gts
gts命令用来采用绝对值的方式为流行为配置流量整形动作。
undo gts命令用来恢复缺省情况。
gts cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
gts cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
undo gts
未配置流量整形动作。
流行为视图
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~40000000。
cbs committed-burst-size:承诺突发尺寸,实际平均速率在承诺速率以内时的突发流量,单位为byte。取值范围为1000~1000000000,配置cir后,如果不指定cbs参数,缺省取值为62.5 × committed-information-rate。
ebs excess-burst-size:超出突发尺寸,单位为byte。取值范围为0~1000000000,配置pir后,如果不指定ebs参数,缺省取值为62.5 × peak-information-rate。
pir peak-information-rate:峰值速率。PIR必须大于等于CIR。取值范围为8~10000000。
queue-length queue-length:队列的最大长度,缺省值为50。取值范围为1~1024。
接口上应用的QoS策略中使用gts时,只能应用到接口的出方向。
接口上应用配置了gts的QoS策略将导致原有的qos gts命令失效。
如果未配置峰值速率,则表示所配置的是单速率流量整形,否则表示双速率流量整形。
# 为流行为配置GTS,正常流速为200kbps,承诺突发尺寸为51200bytes,速率大于200kbps时,将进入队列缓存,缓存队列长度为100。
[Sysname-behavior-database] gts cir 200 cbs 51200 ebs 0 queue-length 100
·     gts percent
1.2.6  gts percent
gts percent命令用来采用百分比的方式为流行为配置流量整形动作。
undo gts命令用来恢复缺省情况。
gts percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ queue-length queue-length ]
undo gts
未配置百分比形式的流量整形动作。
流行为视图
cir cir-percent:承诺信息速率百分比,取值范围为1~100。CIR的实际值是百分比值乘以接口带宽值。
cbs cbs-time:某段时间内的承诺突发尺寸,单位为ms,缺省值为500ms。CBS的实际值是CBS的配置时间值乘以实际的承诺信息速率(cir值乘以接口带宽)。取值范围为50~2000,配置cir后,如果不指定cbs参数,将该MQC应用在口后,cbs缺省值 = cir的实际值 × 62.5。
ebs ebs-time:某段时间内的超出突发尺寸,单位为ms,缺省值为0ms。EBS的实际值是EBS的配置时间值乘以实际的承诺信息速率(cir值乘以接口带宽)。取值范围为0~2000,缺省值为0。
# 配置使用流量整形,正常流量为50%的接口带宽,在第一时间可以有200ms×50%接口带宽的突发流量通过,以后速率小于等于50%的接口带宽时正常发送,速率大于50%的接口带宽时,将进入队列缓存。
[Sysname-behavior-database] gts percent cir 50 cbs 200
·     gts
1.2.7  packet-rate
packet-rate命令用来配置协议报文限速动作。
undo packet-rate命令用来恢复缺省情况。
packet-rate value
undo packet-rate
未配置协议报文限速动作。
流行为视图
value:协议报文速率,单位为包每秒(pps)。取值范围为1~1048575。
通过QoS策略配置协议报文限速后,可实现对上送CPU的协议报文的防攻击功能。
本命令支持情况与设备型号有关,请以设备实际情况为准。
# 为流行为copp配置CPU报文限速动作。
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
1.2.8  redirect
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来恢复缺省情况。
(独立运行模式)
redirect srv6-policy endpoint color [ { sid | vpnsid } sid ]
undo redirect srv6-policy
未配置流量重定向动作。
流行为视图
slot slot-number:重定向到指定的单板,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:重定向到指定成员设备上的指定单板,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
srv6-policy endpoint color [ { sid | vpnsid } sid ]:流量重定向到SRv6 TE Policy。endpoint表示SRv6 TE Policy的目的节点地址,格式为IPv6地址。color表示SRv6 TE Policy的Color属性值,取值范围为0~4294967295。sid表示指定尾节点的SRv6 SID。报文经SRv6 TE Policy转发后,再依据该SRv6 SID继续进行公网转发。vpnsid表示指定尾节点的SRv6 SID。报文经SRv6 TE Policy转发后,再依据该SRv6 SID继续进行私网转发。sid表示指定IPv6地址形式的SRv6 SID。在为报文封装的SRH中添加该SID,该SID位于SRv6 TE Policy的SID列表之后。报文经SRv6 TE Policy转发到尾节点后,尾节点再依据该SRv6 SID执行对应的转发动作。
将流量重定向到SRv6 TE Policy时,支持重定向到公网与私网,且不指定{ sid | vpnsid } sid时表示公网。
配置本命令中的sid时请注意,该值在报文中携带时并不区分公网与私网,目的节点接收报文后直接根据目的节点本地的Local SID转发表项进行转发。因此,可能出现本命令中配置的是流量重定向到公网(或私网),而实际上尾节点对流量进行了私网(或公网)转发的情况。所以在配置sid时请确保该值的正确性。
# 为流行为配置流量重定向动作,重定向到公网SRv6 TE Policy,目的节点地址为2::2,Color属性为2,公网SID为2::1。
[Sysname] traffic behavior 1
[Sysname-behavior-1] redirect srv6-policy 2::2 2 sid 2::1
·     classifier behavior
·     qos policy
·     traffic behavior
remark apn-id-ipv6 instance命令用来标记IPv6报文的APN ID值对应的APN ID实例。
undo remark apn-id-ipv6 instance命令用来恢复缺省情况。
remark apn-id-ipv6 instance instance-name
未配置标记IPv6报文的APN ID值对应的APN ID。
流行为视图
instance-name:APN ID实例名称。为1~31个字符的字符串,区分大小写。
应用场景
APN ID(Application-aware IPv6 Networking ID,应用感知型IPv6网络的标识)携带在IPv6的DOH(Destination Options Header,目的选项报文头)中,用于标识IPv6报文的应用信息。基于APN ID可以精细化地区分应用流量并为不同应用业务提供精准且差异化的网络服务。
一个APN ID实例对应了一个具体的APN ID。关于APN ID实例的详细介绍,请参见“应用感知型网络配置指导”中的“APN6”。
目前APN ID可以用于SRv6 TE Policy的引流。当业务流量被引入到SRv6 TE Policy组中转发时,设备可以根据IPv6报文的APN ID标识和Color的映射关系,将流量引入到指定Color对应的SRv6 TE Policy中转发,或者根据APN ID标识和SRv6 BE映射关系,采用SRv6 BE方式转发流量。
工作原理
通常在网络边缘设备或者隧道源节点上配置本命令,并将绑定了标记IPv6报文的APN ID值流行为的QoS策略应用到接口入方向。设备将为匹配到流分类的IPv6业务报文标记上APN ID值,设备在转发报文的过程中根据IPv6报文的APN ID值将不同应用的流量引入到指定的SRv6 TE Policy中转发或者采用SRv6 BE方式转发流量,从而实现基于应用的差异化流量控制。关于基于APN ID引流的详细介绍,请参见“Segment Routing配置指导”中的“SRv6 TE Policy”。
注意事项
如果报文中存在APN6封装且已携带APN ID信息,再执行remark apn-id-ipv6 instance命令,报文原本携带的APN ID不会被本命令配置的APN ID覆盖,报文原本携带的APN ID仍生效,只有报文未自带APN ID信息时,remark apn-id-ipv6 instance命令才会生效。
本功能仅在安装了FIP-260、FIP-380、FIP-660或SAP-XP4GE32单板的设备上支持。
# 标记IPv6报文的APN ID值对应的APN ID实例为aaa。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] remark apn-id-ipv6 instance aaa
·     apn-id instance(应用感知型网络命令参考/APN)
1.2.10  remark dot1p
remark dot1p命令用来配置重新标记报文的802.1p优先级。
undo remark dot1p命令用来恢复缺省情况。
remark dot1p dot1p-value
undo remark dot1p
未配置重新标记报文802.1p优先级。
流行为视图
dot1p-value:802.1p优先级,取值范围为0~7。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
1.2.11  remark dscp
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来恢复缺省情况。
remark dscp dscp-value
undo remark dscp
未配置重新标记报文DSCP值的动作。
流行为视图
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
# 重新标记报文的DSCP值为6。
remark flow-id命令用来重新标记报文的流ID。
undo remark flow-id命令用来恢复缺省情况。
remark flow-id flow-id
undo remark flow-id flow-id
未配置重新标记报文的流ID动作。
流行为视图
flow-id:流ID。取值范围为1~65535。
在RIR(Resilient Intelligent Route,智能选路)网络中,RIR服务器会对设备下发业务流量模板、NQA链路质量检测和QoS策略,为报文灵活选择转发链路:
·     设备根据业务流量模板、NQA链路质量检测结果,为报文选择合适的转发链路;
·     设备首先根据QoS参数中的五元组和DSCP识别报文,并对其标记流ID;再根据流ID及选路结果,指导报文转发。
有关RIR智能选路的详细介绍,请参见“三层技术-IP路由配置指导”中的“智能选路”。
# 在流行为behavior1中配置重新标记报文的流ID为10。
[Sysname-behavior-behavior1] remark flow-id 10
·     traffic behavior
remark ip-precedence命令用来重新标记报文的IP优先级。
undo remark ip-precedence命令用来恢复缺省情况。
remark ip-precedence ip-precedence-value
未配置重新标记报文IP优先级的动作。
流行为视图
ip-precedence-value:IP优先级,取值范围为0~7。
# 重新标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来恢复缺省情况。
remark local-precedence local-precedence-value
未配置重新标记报文本地优先级的动作。
流行为视图
local-precedence-value:本地优先级,取值范围为0~7。
# 重新标记报文的本地优先级值为2。
remark qos-local-id命令用来重新标记报文的QoS本地ID值。
undo remark qos-local-id命令用来恢复缺省情况。
remark qos-local-id local-id-value
未配置重新标记报文的QoS本地ID值的动作。
流行为视图
local-id-value:QoS本地ID值,取值范围为1~4095。
一般情况下,在QoS策略的入方向对报文的QoS本地ID值进行标记,在QoS策略的出方向根据标记的QoS本地ID值对报文进行分类以及指定相应的流行为,两者要结合使用。
# 重新标记报文的QoS本地ID值为2。
[Sysname-behavior-database] remark qos-local-id 2
remark service-class命令用来重新标记报文的MPLS TE隧道转发类的值。
undo remark service-class命令用来恢复缺省情况。
remark service-class service-class-value
未配置重新标记报文的MPLS TE隧道转发类的值。
流行为视图
service-class-value:报文的MPLS TE隧道转发类的值,参数的取值范围为0~127。
本命令仅用于CBTS组网中重新标记报文的MPLS TE隧道转发类的值,关于CBTS的详细介绍,请参见“MPLS配置指导”中的“MPLS TE配置”。
通过mpls te service-class命令可以配置MPLS TE隧道转发类的值,关于该命令的详细介绍,请参见“MPLS命令参考”中的“MPLS TE命令”。
如果流行为视图下配置了remark service-class命令,则指定该动作的QoS策略仅支持应用在接口上,且当QoS策略应用在接口入方向时,该动作才能生效。
# 重新标记报文MPLS TE隧道转发类的值为2。
[Sysname-behavior-data] remark service-class 2
remark tunnel-dscp命令用来重新标记隧道封装后报文外层IP头的DSCP值。
undo remark tunnel-dscp命令用来恢复缺省情况。
remark tunnel-dscp dscp-value
未配置重新标记报文外层IP头的DSCP值的动作。
流行为视图
dscp-value:隧道封装后报文外层IP头的DSCP值,取值范围为0~63,也可以是表1-6中对应的关键字。
表1-6 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
本命令对GRE、VXLAN、IPv4-IPv4、IPv6-IPv4、IPv6、MPLS-TE隧道封装后的报文生效。
如果流行为视图下配置了本命令,则指定该流行为的QoS策略仅支持应用在接口上。
# 重新标记隧道封装后报文外层IP头的DSCP值为2。
[Sysname-behavior-data] remark tunnel-dscp 2
traffic behavior命令用来创建一个流行为,并进入流行为视图。如果指定的流行为已经存在,则直接进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
不存在流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
同一个流行为下可以配置多个转发动作。通常情况下,匹配到流分类的报文将执行该流分类对应的流行为下所有转发动作。
# 定义一个名为behavior1的流行为。
·     display traffic behavior
traffic-policy命令用来在父策略流行为视图下应用一个子策略。
undo traffic-policy命令用来删除关联的子策略。
traffic-policy policy-name
undo traffic-policy
未配置应用子策略的动作。
流行为视图
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果QoS策略不存在,则自动创建该QoS策略。
通过在流行为视图下应用子策略,可以实现策略嵌套功能。即由traffic classifier命令定义的某一类流量,除了执行父策略中定义的行为外,还由子策略再次对该类流量进行分类,并执行子策略中定义的行为。
在配置策略嵌套功能时,请注意:
·     在父策略行为下应用子策略时,最多只能嵌套二层策略,并且不能嵌套自身。
·     一个流行为中至多只能嵌套一个子策略。
父策略和子策略中的内容需满足以下要求:
·     如果子策略中配置了CBQ,那么父策略中必须配置GTS,并且配置的父策略GTS带宽必须大于子策略CBQ带宽,否则配置失败。
·     如果父策略的GTS配置采用百分比形式,则子策略CBQ带宽配置不允许采用绝对值形式;如果父策略的GTS配置采用绝对值形式,则子策略CBQ带宽配置既可以采用百分比形式,也可以采用绝对值形式。
·     子策略中不允许配置GTS。
嵌套策略支持对IPv4、IPv6报文的处理。
如果嵌套策略已经应用在接口上,则不允许删除嵌套的子策略,必须先解除子策略和父策略的嵌套关系。
RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口不支持配置策略嵌套。
# 配置策略嵌套,在父策略下应用子策略child。
[Sysname-behavior-database] traffic-policy child
·     traffic behavior
1.3  定义和应用QoS策略的命令
classifier behavior命令用来为类指定流行为。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [ insert-before before-classifier-name ]
没有为类指定流行为。
QoS策略视图
insert-before before-classifier-name:表示将配置的类插入到QoS策略中已存在的指定类之前。before-classifier-name表示QoS策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到QoS策略最后。
QoS策略下每个类只能与一个流行为关联。
QoS策略下可以存在多个CB(Classifier-Behavior)对,应用QoS策略之后,报文按顺序逐个匹配QoS策略中CB对,如果匹配到某个CB对,则报文直接执行该CB对中指定流行为的所有转发动作,报文不再继续匹配其他CB对。
如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
如果undo命令指定的类为系统预定义类default-class,表示恢复default-class对应的流行为为系统预定义流行为be,而不是取消对应的流行为。
# 在QoS策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在QoS策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
·     qos policy
1.3.2  control-plane
control-plane命令用来进入控制平面视图。
(独立运行模式)
control-plane chassis chassis-number slot slot-number
slot slot-number:指定单板。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 进入指定slot上的控制平面视图。(独立运行模式)
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
control-plane management命令用来进入管理口控制平面视图。
# 进入管理口控制平面视图。
[Sysname] control-plane management
[Sysname-cp-management]
display qos policy命令用来显示QoS策略的配置信息。
(独立运行模式)
display qos policy { system-defined | user-defined } [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
display qos policy { system-defined | user-defined } [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
system-defined:系统定义QoS策略。
user-defined:用户定义QoS策略。
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:QoS策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定单板的QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的QoS策略的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的QoS策略的配置信息。(IRF模式)
# 显示用户定义QoS策略的配置信息。
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
     Behavior: 2
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
# 显示系统定义QoS策略的配置信息。
<Sysname> display qos policy system-defined
  System-defined QoS policy information:
  Policy: default (ID 0)
     Behavior: be
      -none-
   Classifier: ef (ID 1)
     Behavior: ef
   Classifier: af1 (ID 2)
     Behavior: af
      Assured Forwarding:
        Bandwidth 20 (%)
   Classifier: af2 (ID 3)
     Behavior: af
      Assured Forwarding:
        Bandwidth 20 (%)
   Classifier: af3 (ID 4)
     Behavior: af
      Assured Forwarding:
        Bandwidth 20 (%)
   Classifier: af4 (ID 5)
     Behavior: af
      Assured Forwarding:
        Bandwidth 20 (%)
表1-7 display qos policy命令显示信息描述表
用户自定义QoS策略的信息
系统定义QoS策略的信息
Policy
用户定义的QoS策略名或系统预定义的QoS策略名
其它显示信息解释请参见表1-1表1-4
display qos policy advpn命令用来显示Tunnel接口Hub-Spoke隧道应用QoS策略的配置信息和运行情况。
display qos policy advpn tunnel number [ ipv4-address | ipv6-address ] [ outbound ]
number:Tunnel接口编号,取值范围为0~20479
ipv4-address:隧道Spoke侧的IPv4私网地址。
ipv6-address:隧道Spoke侧的IPv6私网地址。
outbound:显示出方向Hub-Spoke隧道应用QoS策略的配置信息和运行情况。当前设备仅支持显示Hub-Spoke隧道接口出方向应用QoS策略的配置信息和运行情况。
如果未指定隧道Spoke侧的私网地址,则显示Tunnel接口下所有Hub-Spoke隧道应用QoS策略的配置信息和运行情况。有关Hub-Spoke隧道的详细介绍,请参见“三层技术—IP业务配置指导”中的“ADVPN”。
有关Tunnel接口的配置命令,请参见“三层技术—IP业务命令参考”中的“隧道”。
# 显示Tunnel接口下Hub-Spoke隧道出方向应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy advpn tunnel 1 outbound
Session: Tunnel1 192.168.0.3
  Direction: Outbound
  Policy: finance
     Matched : 0 (Packets) 0 (Bytes)
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: finance
     Matched : 123713988 (Packets) 13608538380 (Bytes)
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: finance
        CIR 1500 (kbps), CBS 93750 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 14980239 (Packets) 1647826290 (Bytes)
        Yellow packets: 0 (Packets) 0 (Bytes)
        Red packets   : 108733781 (Packets) 11960715910 (Bytes)
Session: Tunnel1 192.168.0.4 (inactive)
  Direction: Outbound
  Policy: business
表1-8 display qos policy advpn命令显示信息描述表
Session
Hub-Spoke隧道信息,通过Tunnel接口和Spoke侧私网IPv4/IPv6地址可唯一标识一条Hub-Spoke隧道。其中Session: Tunnel1 192.168.0.4 (inactive)中的inactive表示Hub-Spoke隧道应用QoS策略失败或者应用的QoS策略不存在
Direction
QoS策略应用在Hub-Spoke隧道的方向
Matched
符合分类规则的数据包数目
其它显示信息解释请参见表1-1表1-4
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:显示指定单板的控制平面应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的控制平面应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 显示应用到slot 1控制平面的QoS策略信息。(独立运行模式)
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match control-plane protocol arp
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-9 display qos policy control-plane命令显示信息描述表
Direction
QoS策略应用的方向
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy control-plane management命令用于显示管理口控制平面应用的QoS策略信息。
# 显示对进入管理口控制平面的报文应用的QoS策略信息。
<Sysname> display qos policy control-plane management
Control plane management
  Direction: Inbound
  Policy: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: a
     Matched : 3 (Packets) 180 (Bytes)
     Operator: OR
     Rule(s) :
      If-match control-plane protocol rip
      If-match control-plane protocol-group critical
      If-match acl 3001
      If-match control-plane protocol bgp
      If-match control-plane protocol bgp4+
      If-match control-plane protocol ftp
      If-match control-plane protocol http https icmp icmp6 ripng snmp
     Behavior: a
        CIR 128 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 3 (Packets) 180 (Bytes)
表1-10 display qos policy control-plane management命令显示信息描述表
Direction
QoS策略应用的方向
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy control-plane management pre-defined命令用来显示系统预定义的管理口控制平面应用QoS策略的信息。
# 显示系统预定义的管理口控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane management pre-defined
Pre-defined policy information
  Protocol          Priority   Bandwidth (kbps)   Group
  Default           N/A        100000             N/A
  ARP               N/A        100000             normal
  BGP               N/A        100000             critical
  BGPv6             N/A        100000             critical
  DHCP              N/A        100000             critical
  DHCPv6            N/A        100000             critical
  HTTP              N/A        100000             management
  HTTPS             N/A        100000             management
  ICMP              N/A        100000             monitor
  ICMPv6            N/A        100000             monitor
  IGMP              N/A        100000             important
  IS-IS             N/A        100000             critical
  LDP               N/A        100000             critical
  LDPv6             N/A        100000             critical
  MSDP              N/A        100000             critical
  NTP               N/A        100000             important
  OSPF Multicast    N/A        100000             critical
  OSPF Unicast      N/A        100000             critical
  OSPFv3 Multicast  N/A        100000             critical
  OSPFv3 Unicast    N/A        100000             critical
  PIM Multicast     N/A        100000             critical
  PIM Unicast       N/A        100000             critical
  PIMv6 Multicast   N/A        100000             critical
  PIMv6 Unicast     N/A        100000             critical
  RADIUS            N/A        100000             management
  RIP               N/A        100000             critical
  RIPng             N/A        100000             critical
  RSVP              N/A        100000             critical
  SNMP              N/A        100000             management
  TACACS            N/A        100000             management
  VRRP              N/A        100000             important
  VRRPv6            N/A        100000             important
  SSH               N/A        100000             management
  TELNET            N/A        100000             management
  FTP               N/A        100000             management
  TFTP              N/A        100000             management
表1-11 display qos policy control-plane management pre-defined命令显示信息描述表
Pre-defined control plane policy management
预定义管理口控制平面策略内容
Protocol
系统预定义协议报文类型
Priority
优先级
Bandwidth
带宽
Group
协议组
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
任意视图‌
slot slot-number:显示指定单板的系统预定义的控制平面策略信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有在位单板的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的系统预定义的控制平面策略信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有成员设备上在位单板的系统预定义的控制平面应用QoS策略的信息。(IRF模式)
# 显示指定slot上的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
# 显示1号成员设备3号单板系统预定义的控制平面应用QoS策略的信息。(IRF模式)
<Sysname> display qos policy control-plane pre-defined chassis 1 slot 3
Pre-defined policy information chassis 1 slot 3
表1-12 display qos policy control-plane pre-defined命令显示信息描述表
预定义控制平面策略内容
Protocol
系统预定义协议报文类型
Priority
优先级
Bandwidth
带宽
Group
协议所属的协议组
其它显示信息解释请参见表1-3
display qos policy global命令用来显示基于全局应用QoS策略的配置信息和运行情况。
(独立运行模式)
display qos policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
inbound:显示入方向QoS策略的配置信息和运行情况。
outbound:显示出方向QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板的基于全局应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于全局应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于全局应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于全局应用QoS策略的信息。(IRF模式)
如果未指定显示方向,则同时显示出入两个方向QoS策略的配置信息和运行情况。
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-13 display qos policy global命令显示信息描述表
Direction
QoS策略应用的方向
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
(独立运行模式)
display qos policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
display qos policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口外所有接口上QoS策略的配置信息和运行情况。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
slot slot-number:显示指定单板上指定逻辑接口的QoS策略的配置信息和运行情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板逻辑接口的QoS策略的配置信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定逻辑接口的QoS策略的配置信息和运行情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板逻辑接口QoS策略的配置信息和运行情况。(IRF模式)
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的QoS策略的配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示对接口GigabitEthernet2/0/1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface gigabitethernet 2/0/1 inbound
Interface: GigabitEthernet2/0/1
  Direction: Inbound
  Policy: 1, Preorder 1
   Classifier: 1
     5-minute statistics:
      Forwarded: 0/0 (pps/bps)
      Dropped  : 0/0 (pps/bps)
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
# 显示所有接口上QoS策略的配置信息和运行情况。
<Sysname>display qos policy interface
Interface: GigabitEthernet5/0/1
  Direction: Inbound
  Policy: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: GigabitEthernet5/0/10
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: GigabitEthernet5/0/17
  Direction: Inbound
  Policy: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        CIR 200 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 0(Packets)
Interface: GigabitEthernet5/0/18
  Direction: Inbound
  Policy: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Green action  : pass
表1-14 display qos policy interface命令显示信息描述表
Direction
QoS策略应用的方向
Policy
Preorder
相同方向不同QoS策略的流行为执行顺序
策略的应用类型,与应用策略的命令对应。应用时没有指定类型时,显示信息中也没有此字段。可取值为:Extension:扩展型
Matched
符合分类规则的数据包数目
5-minute statistics
最近5分钟的流速统计信息
Forwarded
符合分类规则的成功转发报文在统计周期内的平均速率
Dropped
符合分类规则的丢弃报文在统计周期内的平均速率
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
重定向到SRv6 TE Policy
·     Forwarding ID:重定向到SRv6 TE Policy的转发表项索引
·     SID:尾节点的SRv6 SID
其它显示信息解释请参见表1-1表1-4表1-7
display qos policy l2vpn-pw命令用来显示L2VPN PW上QoS策略的配置信息和运行情况。
display qos policy l2vpn-pw [ peer ip-address pw-id pw-id ] [ outbound ]
peer ip-address pw-id pw-id:显示指定PW上的QoS策略的配置信息和运行情况。ip-address为PW远端PE的LSR ID。pw-id为PW的PW ID,取值范围为1~4294967295。如果未指定本参数,则显示所有PW上的QoS策略的配置信息和运行情况。
outbound:显示出方向QoS策略的配置信息和运行情况。指定与未指定本参数,命令执行结果相同。
# 显示远端PE地址为1.1.1.1、PW ID为1的PW发送报文方向上应用的QoS策略的配置信息和运行情况。
<Sysname> display qos policy l2vpn-pw peer 1.1.1.1 pw-id 1 outbound
L2VPN-PW: peer 1.1.1.1, pw-id 1
  Direction: Outbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-15 display qos policy l2vpn-pw命令显示信息描述表
L2VPN-PW
显示指定PW的信息,PW通过远端PE地址和PW ID唯一标识
Direction
QoS策略应用的方向
Matched
符合分类规则的数据包数目
5-minute statistics
最近5分钟的流速统计信息
Forwarded
Dropped
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy sdwan命令用来显示Tunnel接口SDWAN隧道应用QoS策略的配置信息和运行情况。
display qos policy sdwan tunnel number [ site-id site-id device-id device-id interface-id interface-id ] outbound
number:Tunnel接口编号,取值范围为0~20479。
site-id site-id:SDWAN网络中的站点ID,取值范围是1~65535。关于站点ID的详细信息,请参见“SDWAN配置指导”中的“SDWAN”。
device-id device-id:SDWAN网络中的设备的ID,取值范围为1~255。关于设备的ID的详细信息,请参见“SDWAN配置指导”中的“SDWAN”。
interface-id interface-id:SDWAN隧道接口的接口ID,取值范围为1~255。关于接口ID的详细信息,请参见“SDWAN配置指导”中的“SDWAN”。
如果未指定隧道Spoke侧的site-iddevice-idinterface-id组成的sdwan-tte地址,则显示Tunnel接口下所有SDWAN隧道应用QoS策略的配置信息和运行情况。关于SDWAN隧道的详细介绍,请参见“SDWAN配置指导”中的“SDWAN”。
# 显示Tunnel接口下SDWAN隧道出方向应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy sdwan tunnel 1 outbound
Session: Tunnel1 SiteID1/DevID1/IfID1
  Direction: Outbound
  Policy: finance
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: finance
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: finance
        Green action  : pass
表1-16 display qos policy sdwan命令显示信息描述表
Session
SDWAN隧道信息,通过Tunnel接口和sdwan-tte地址可唯一标识一条SDWAN隧道,其中sdwan-tte地址由以下内容组成:
·     SiteID表示SDWAN站点ID
·     DevID表示SDWAN设备ID
·     IfID表示SDWAN接口ID
Direction
QoS策略应用在SDWAN隧道的方向
Matched
符合分类规则的数据包数目
其它显示信息解释请参见表1-1表1-4
display qos policy srv6-policy命令用来显示指定SRv6 TE Policy绑定的QoS策略的配置信息和运行情况。
(独立运行模式)
display qos policy srv6-policy [ end-point ipv6 ipv6-address color color-value ] [ slot slot-number ] outbound
display qos policy srv6-policy [ end-point ipv6 ipv6-address color color-value ] [ chassis chassis-number slot slot-number ] outbound
end-point ipv6 ipv6-address:指定SRv6 TE Policy目的节点的IPv6地址。
color color-value:指定SRv6 TE Policy的Color属性,其中color-value的取值范围为0~4294967295。
outbound:显示从指定SRv6 TE Policy转发的出方向。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定所有单板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定所有单板。(IRF模式)
如果未指定end-point ipv6color参数,则显示所有SRv6 TE Policy绑定的QoS策略的配置信息和运行情况。
# 显示所有SRv6 TE Policy绑定的QoS策略的配置信息和运行情况。
<Sysname> display qos policy srv6-policy outbound
  Direction: Outbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-17 display qos policy srv6-policy命令显示信息描述表
Direction
QoS策略应用的方向,目前仅支持outbound方向
Preorder
相同方向不同QoS策略的流行为执行顺序
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy user-profile命令用来显示用户上线后User Profile下应用的QoS策略的信息和运行情况。
(独立运行模式)
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name profile-name:指定User Profile的名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线、连字符,且必须以英文字母开始,区分大小写。User Profile的名称必须全局唯一。如果未指定本参数,将显示所有User Profile下应用的QoS策略的信息和运行情况。
user-id user-id:表示在线用户的ID,为系统所分配,取值范围为十六进制数0~fffffffe。若未指定本参数,则显示所有用户在User Profile下应用的QoS策略的信息和运行情况。
slot slot-number:显示指定单板上指定用户在User Profile下应用的QoS策略的信息和运行情况,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的在线用户的QoS策略的信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上指定用户在User Profile下应用的QoS策略的信息和运行情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备所有单板上指定用户在User Profile下应用的QoS策略的信息和运行情况。(IRF模式)
# 显示指定全局用户(从聚合口等全局口上线的用户)在User Profile下应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc user-id 30000000 inbound
User-Profile: abc
  User ID: 0x30000000(global)
    Direction: Inbound
    Policy: p1
       Operator: AND
       Rule(s) :
        If-match any
       Behavior: be
        -none-
# 显示指定的非全局用户在User Profile下应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc user-id 30000001 inbound
User-Profile: abc
  slot 2:
    User ID: 0x30000001(local)
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
# 显示指定User Profile下所有用户的QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc inbound
User-Profile: abc
    Direction: Inbound
    Policy: p1
       Operator: AND
       Rule(s) :
        If-match any
       Behavior: be
        -none-
  slot 2:
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
  slot 3:
    User ID: 0x30000002(local)
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
# 显示指定单板上所有用户在User Profile abc下应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc slot 2
User-Profile: abc
    Direction: Inbound
    Policy: p1
       Operator: AND
       Rule(s) :
        If-match any
       Behavior: be
        -none-
    Direction: Inbound
    Policy: p1
       Operator: AND
       Rule(s) :
        If-match any
       Behavior: be
        -none-
#显示所有单板上指定用户在User Profile abc下应用QoS策略的配置信息和运行情况。
User-Profile: abc
  slot 2:
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
  slot 3:
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
# 显示所有User Profile的在线用户的QoS策略的配置信息和运行情况。
User-Profile: abc
  slot 3:
    User ID: 0x30000000(local)
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
User-Profile: a12
  slot 4:
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
       Classifier: a
        Operator: AND
        Rule(s) :
         If-match any
        Behavior: a
         Mirroring:
          Mirror to the interface: GigabitEthernet2/0/1
           Green action  : pass
表1-18 display qos policy user-profile命令显示信息描述表
User-Profile
User Profile名称
User ID
上线用户的ID
global
该用户从聚合口等全局口上线
local
该用户从物理口上线
镜像到接口
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte
EBS
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为byte
PIR
峰值信息速率
Direction
QoS策略应用的方向
Matched
符合分类规则的数据包数目
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
qos apply policy命令用来在接口、PW、控制平面或管理口控制平面上应用QoS策略。
undo qos apply policy命令用来取消接口、PW、控制平面或管理口控制平面上应用的QoS策略。
qos apply policy policy-name { inbound | outbound } [ preorder preorder-value ]
undo qos apply policy policy-name { inbound | outbound }
未应用QoS策略。
控制平面视图/管理口控制平面视图
交叉连接PW视图/VSI LDP PW视图/VSI静态PW视图
policy-name:策略名,为1~31个字符的字符串,区分大小写。
inbound:入方向应用QoS策略。设备不支持在PW入方向应用QoS策略。
outbound:出方向应用QoS策略。设备不支持在控制平面、控制平面管理口出方向应用QoS策略。
preorder preorder-value:指定接口相同方向不同QoS策略的流行为执行顺序。preorder-value取值只能为1。如果应用某QoS策略时未指定preorder,则设备优先执行已配置了preorder的QoS策略的流行为。在接口同一方向上,如果一份流量同时被多个QoS策略的类匹配,且QoS策略流行为的类型相同,优先执行已配置了preorder的QoS策略的流行为。
策略在接口或PW上应用的规则如下:
·     在应用策略时,如果策略中为确保转发和加速转发的类指定的带宽之和超过接口或PW允许的可用带宽,则在该接口或PW不可应用。如果对接口或PW修改了可用带宽,此时如果策略中为确保转发和加速转发的类指定的带宽之和超过接口或PW允许的可用带宽,则将策略删除。
·     入方向的策略与类关联的行为不允许有queue afqueue efqueue wfq配置,也不允许有GTS配置。
如果策略中与类关联的行为是重定向到Blade接口或Blade聚合接口时,需应用增强类型策略。
在控制平面和管理口控制平面上应用策略时,不支持配置了CBQ的策略。
仅在三层口和三层聚合口上应用策略时,支持preorder参数,而二层口和二层聚合口上不支持该参数。
基于控制平面应用QoS策略时,流分类中支持使用如下方法匹配上送控制平面的协议报文:
·     使用if-match control-plane protocol命令。
·     使用if-match control-plane protocol-group命令。
·     使用if-match acl命令,该方法可以更灵活的匹配上送控制平面的协议报文,需要注意的是if-match引用的ACL必须为高级ACL,且该ACL规则必须满足如下条件:
¡     规则中的protocol协议类型必须为TCP或UDP;
¡     规则中必须通过操作符eq指定一个源端口或指定一个目的端口。
例如,在流行为中,通过if-match引用配置rule permit tcp source-port eq 80规则的IPv4高级ACL,则该流行为可以匹配上送控制平面的TCP协议报文。
# 将QoS策略USER1应用到接口GigabitEthernet2/0/1的入方向上。
[Sysname-GigabitEthernet2/0/1] qos apply policy USER1 inbound
# 对进入3号槽控制平面的报文应用QoS策略aaa。
[Sysname-cp-slot3] qos apply policy aaa inbound
# 对进入管理口控制平面的报文应用QoS策略bbb。
[Sysname-cp-management] qos apply policy bbb inbound
# 在PW的出方向上应用QoS策略。
[Sysname] xconnect-group a
[Sysname-xcg-a] connection a
[Sysname-xcg-a-a] peer 1.1.1.1 pw-id 1
[Sysname-xcg-a-a-1.1.1.1-1] qos apply policy 1 outbound
qos apply policy命令用来在User Profile下应用策略。
undo qos apply policy命令用来取消User Profile下应用的策略。
未在User Profile下应用QoS策略。
User Profile视图
inbound:入方向应用QoS策略。
policy-name:策略名,为1~31个字符的字符串。
User Profile被删除将导致其下引用的QoS策略被删除。
# 对设备发送的上线用户user的流量应用策略test(该策略已经建立)。
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
undo qos apply policy policy-name global { inbound | outbound }
未在全局应用QoS策略。
inbound:入方向应用QoS策略。
全局应用的QoS策略对全部流量生效。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
qos apply policy srv6-policy命令用来配置指定的SRv6 TE Policy绑定QoS策略。
undo qos apply policy srv6-policy命令用来恢复缺省情况。
qos apply policy policy-name srv6-policy end-point ipv6 ipv6-address color color-value outbound
undo qos apply policy policy-name srv6-policy end-point ipv6 ipv6-address color color-value outbound
SRv6 TE Policy未绑定QoS策略。
outbound:指定SRv6 TE Policy转发的出方向的流量应用QoS策略。
在L3VPN over SRv6 TE Policy的场景中,常常需要在SRv6 TE Policy的头节点对属于不同VPN的原始报文进行QoS流分类,分类后的报文再根据业务需求执行相应的QoS流行为,例如对不同VPN的业务流量进行流量整形或限速。同时,对于属于同一VPN的原始报文又需要根据其报文的五元组等信息进行层次化和差异化的QoS调度。直接在SRv6 TE Policy头节点的转发出接口上通过traffic-policy命令应用嵌套QoS策略只能匹配到报文进行SRv6封装后的外层头部信息,而无法匹配原始报文头的信息。可以使用本功能来解决上述问题。
配置本功能后,设备会先对引流到指定SRv6 TE Policy的所有原始报文应用QoS策略,之后再根据SRv6 TE Policy的配置对原始报文进行SRv6的封装和转发。有关SRv6 TE Policy的详细介绍,请参见“Segment Routing配置指导”中的“SRv6 TE Policy”。
请在SRv6 TE Policy头节点上配置该功能,其它节点配置该功能不生效。
同一个SRv6 TE Policy只能绑定一个QoS策略。当一个SRv6 TE Policy绑定了某个QoS策略之后,如果要绑定新的QoS策略,则需要先执行undo qos apply policy srv6-policy命令解除绑定,再重新绑定新的QoS策略。
# 配置目的节点IPv6地址为1000::1、Color属性为10的SRv6 TE Policy绑定QoS策略aaa。
[Sysname] qos apply policy aaa srv6-policy end-point ipv6 1000::1 color 10 outbound
qos apply user-profile downstream命令用来配置需要在对端隧道出方向上应用的User Profile。
undo qos apply user-profile downstream命令用来恢复缺省情况。
qos apply user-profile profile-name downstream
undo qos apply user-profile profile-name downstream
未配置在对端隧道出方向上应用的User Profile。
Tunnel接口视图
profile-name:表示User Profile的名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线、连字符,且必须以英文字母或数字开始,但不能为纯数字,区分大小写。User Profile的名称必须全局唯一。
应用场景
本功能目前仅适用于SDWAN隧道。
在SDWAN场景的Hub-Spoke组网中存在大量Spoke设备,如果需要对Hub-Spoke间的每条SDWAN隧道配置限速等QoS策略,则每增加一个分支站点的Spoke设备,都需要在中心站点的Hub设备上手工配置并应用相应的QoS策略,大量配置命令重复且工作量较大。如果中心站点到各分支站点的SDWAN隧道的QoS策略相同,仅限速参数有差异,则可以通过在Spoke设备上配置本功能来简化Hub设备上的QoS策略配置。
关于本功能的详细介绍,请参见“SDWAN配置指导”中的“SDWAN”。
工作机制
在Spoke设备上配置本功能后,Hub-Spoke之间的数据通道建立过程中,Spoke设备上发布给对端Hub设备的BGP IPv4 Tnl-encap-ext路由将携带配置的User Profile名称,假设本功能指定的User Profile名称为A,A将随TTE信息一并由BGP发布给对端Hub设备。对端Hub设备将与A名称相同的本地User Profile应用到Hub到Spoke的SDWAN隧道出方向上。如果对端Hub设备上不存在名称为A的User Profile,或者名称为A的User Profile中无任何配置则对SDWAN隧道无影响。
注意事项
配置本功能前,请在Hub设备上创建需要应用的User Profile,并根据业务需求在User Profile下配置相应QoS策略、流量监管、流量整形、流量限速或优先队列。
上述应用到Hub到Spoke的SDWAN隧道出方向上的User Profile中如果存在某些QoS配置,且该QoS配置指定为入方向生效,则该QoS配置不生效。例如User Profile视图下配置了qos car命令且指定方向为inbound,则对于Hub到Spoke的SDWAN隧道,该User Profile视图下qos car命令不生效。
不建议基于SDWAN隧道粒度和Tunnel口粒度同时配置限速、流量监管、流量整形、队列调度等功能。如果在Hub-Spoke间的SDWAN隧道应用了User Profile,进行SDWAN隧道粒度的限速,同时在Hub的Tunnel接口上配置的流量限速LR或流量整形GTS等功能将不生效。
# 在Spoke设备上配置需要在对端隧道出方向上应用的User Profile名称为u1。
[Sysname] interface Tunnel 2 mode sdwan udp
[Sysname-Tunnel2] qos apply user-profile u1 downstream
1.3.21  qos policy
qos policy命令用来创建一个策略,并进入策略视图。如果指定的策略已经存在,则直接进入策略视图。
undo qos policy命令用来删除一个策略。
qos policy policy-name
undo qos policy policy-name
不存在策略。
如果QoS策略已经被应用,则不允许删除,需要先在应用的位置上取消对QoS策略的应用,然后再使用undo qos policy命令删除。
# 定义一个名为user1的QoS策略。
·     qos apply policy
reset qos policy advpn命令用来清除Tunnel接口Hub-Spoke隧道应用QoS策略的统计信息。
reset qos policy advpn tunnel number [ ipv4-address | ipv6-address ] [ outbound ]
Ipv4-address:隧道Spoke侧的IPv4私网地址。
outbound:清除出方向QoS策略的统计信息。如果未指定方向,则同时清除出入两个方向应用QoS策略的统计信息。
如果未指定隧道Spoke侧的私网地址,则清除Tunnel接口下所有Hub-Spoke隧道应用QoS策略的统计信息。有关Hub-Spoke隧道的详细介绍,请参见“三层技术—IP业务配置指导”中的“ADVPN配置”。
有关Tunnel接口的配置命令,请参见“三层技术—IP业务命令参考”中的“隧道命令”。
当前设备仅支持清除Hub-Spoke隧道接口出方向应用QoS策略的统计信息
# 清除Tunnel接口下指定Hub-Spoke隧道出方向应用QoS策略的统计信息。
<Sysname> reset qos policy advpn tunnel 1 192.168.0.3 outbound
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
(独立运行模式)
reset qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:清除指定单板的基于控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的基于控制平面应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 清除应用到指定slot上的控制平面的QoS策略统计信息。(独立运行模式)
<Sysname> reset qos policy control-plane slot 1
# 清除应用到1号成员设备3号板控制平面的QoS策略统计信息。(IRF模式)
<Sysname> reset qos policy control-plane chassis 1 slot 3
reset qos policy control-plane management命令用来清除管理口控制平面QoS策略的统计信息。
# 清除管理口控制平面QoS策略的统计信息。
<Sysname> reset qos policy control-plane management
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
inbound:清除入方向QoS策略的统计信息。
如果未指定清除方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
reset qos policy srv6-policy命令用来清除指定SRv6 TE Policy上绑定的QoS策略匹配的流量转发统计信息。
reset qos policy srv6-policy [ end-point ipv6 ipv6-address color color-value ] outbound
指定的SRv6 TE Policy上绑定了QoS策略后,将自动对符合QoS策略中流分类规则的流量进行统计,配置本命令后将清除上述流量转发的统计信息。
如果未指定end-point ipv6color参数,则清除所有SRv6 TE Policy绑定的QoS策略匹配的流量转发统计信息。
# 清除目的节点IPv6地址为1000::1、Color属性为10的SRv6 TE Policy上绑定的QoS策略的流量转发统计信息。
<Sysname> reset qos policy srv6-policy end-point ipv6 1000::1 color 10 outbound
reset qos policy sdwan命令用来清除Tunnel接口SDWAN隧道应用QoS策略的统计信息。
reset qos policy sdwan tunnel number [ site-id site-id device-id device-id interface-id interface-id ] outbound
如果未指定隧道site-iddevice-idinterface-id组成的sdwan-tte地址,则清除Tunnel接口下所有SDWAN隧道应用QoS策略的统计信息。
当前设备仅支持清除SDWAN隧道接口出方向应用QoS策略的统计信息
# 清除Tunnel接口下指定SDWAN隧道出方向应用QoS策略的统计信息。
<Sysname> reset qos policy sdwan tunnel 1 site-id 1 device-id 1 interface-id 1 outbound
1.4  接口流速统计配置命令
qos flow-interval命令用来配置接口流速统计时间。
undo qos flow-interval命令用来恢复缺省情况。
qos flow-interval interval
接口流速统计时间为5分钟。
interval:流速统计时间,单位为分钟。取值范围为1~10。
配置本命令后,设备将以设置的统计时间为周期,统计周期内经过QoS策略流分类后每类报文的发送和丢弃速率,并以t/5为刷新周期定期刷新统计速率。
子接口的流速统计时间采用主接口的统计时间。
# 配置接口GigabitEthernet2/0/1的流速统计时间为10分钟。
[Sysname-GigabitEthernet2/0/1] qos flow-interval 10
·     display qos policy interface
2 子接口切片
2.1  子接口切片配置命令
display mode channel-bandwidth interface命令用来显示子接口切片配置和运行信息。
(独立运行模式)
display mode channel-bandwidth interface [ interface-type { interface-number | interface-number.subnumber } ]
interface-type:指定接口类型。如果未指定本参数,将显示所有子接口切片的配置信息。
interface-number:指定接口编号。
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号,.subnumber为子接口编号。
# 显示子接口GigabitEthernet2/0/1.1的子接口切片配置信息。
<Sysname> display mode channel-bandwidth interface gigabitethernet 2/0/1.1
Subinterface : GE2/0/1.1                Channelized bandwidth : 100 kbps
  Passed   : 1000 (Packets) 1000 (Bytes)
  Discarded: 1000 (Packets) 1000 (Bytes)
  Delayed  : 1000 (Packets) 1000 (Bytes)
# 显示所有主接口的子接口切片配置信息。
  Interface : GE2/0/1                      Total bandwidth       : 1000000 kbps
    Total channelized bandwidth : 600 kbps
    Subinterface : GE2/0/1.2               Channelized bandwidth : 200 kbps
    Subinterface : GE2/0/1.3               Channelized bandwidth : 300 kbps
  Interface : GE2/0/2                      Total bandwidth       : 1000000 kbps
    Subinterface : GE2/0/2.1               Channelized bandwidth : 100 kbps
    Subinterface : GE2/0/2.2               Channelized bandwidth : 200 kbps
    Subinterface : GE2/0/2.3               Channelized bandwidth : 300 kbps
表2-1 display mode channel-bandwidth interface命令显示信息描述表
Subinterface
配置了子接口切片带宽的子接口
子接口切片的带宽值
Slot
聚合口所属的槽位号
子接口切片对应的主接口
Total bandwidth
主接口的总带宽值
所有成功生效的子接口切片带宽值之和
Passed
转发的数据包数目和字节数
Discarded
丢弃的数据包数目和字节数
Delayed
延迟发送的数据包数目和字节数
·     mode channel-bandwidth
mode channel-bandwidth命令用来配置子接口切片带宽。
undo mode channel-bandwidth命令用来恢复缺省情况。
mode channel-bandwidth bandwidth-value
子接口上未配置子接口切片带宽。
子接口视图
bandwidth-value:表示子接口切片带宽值,单位为kbps,取值范围与设备型号有关,请以设备实际情况为准。
缺省情况下,所有子接口共享主接口的带宽,不同子接口的业务流量之间存在竞争关系,因此无法保证个别子接口的关键业务流量。配置子接口切片功能后,该子接口将独占指定的带宽。
在网络分片场景中,可以在物理以太网接口或聚合接口的不同子接口上配置子接口切片带宽,保障该子接口的业务流量独享一定的带宽并独立进行QoS调度。
子接口切片带宽仅在出接口方向生效。在三层聚合子接口配置本命令之前,对应的三层聚合主接口需要执行bandwidth命令。
子接口配置的子接口切片带宽总和不能超过主接口实际物理带宽。主接口的总带宽减去子接口切片带宽总和少于1Mbps时,主接口仍会预留1Mbps带宽。
# 在子接口GigabitEthernet2/0/1.1上配置子接口切片带宽为100kbps。
[Sysname] interface gigabitethernet 2/0/1.1
[Sysname-GigabitEthernet2/0/1.1] mode channel-bandwidth 100
·     bandwidth(二层技术-以太网交换命令参考/以太网链路聚合)
·     display mode channel-bandwidth interface
3 优先级映射
本功能仅二层接口上支持。
仅安装了SAP-XP4GE32板卡的设备支持本功能。
3.1  优先级映射表配置命令
display qos map-table命令用来显示优先级映射表的配置情况。
display qos map-table [ dot1p-lp | dscp-lp | lp-dot1p ]
表3-1 优先级映射表
优先级映射
dot1p-lp
802.1p优先级到本地优先级映射表
dscp-lp
DSCP到本地优先级映射表
lp-dot1p
本地优先级到802.1p优先级映射表
如果未指定优先级映射表的类型,则同时显示所有优先级映射表的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表3-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名称
TYPE
映射表的类型
IMPORT
映射表的输入值
EXPORT
映射表的输出值
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
import-value-list:输入值列表。
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 配置802.1p优先级到本地优先级映射表的映射关系,与802.1p优先级4、5相对应的本地优先级为1。
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
·     display qos map-table
3.1.3  qos map-table
qos map-table { dot1p-lp | dscp-lp | lp-dot1p }
其它参数请参见表3-1
# 进入802.1p优先级到本地优先级映射表视图。
·     import
3.2  端口优先级信任模式配置命令
3.2.1  display qos trust interface
display qos trust interface命令用来显示端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示端口优先级信任模式信息。
<Sysname> display qos trust interface gigabitethernet 2/0/1
 Port priority information
  Port priority: 0
  Port priority trust type: none
表3-3 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
Port priority trust information
端口优先级信任信息
Port priority
端口优先级
端口优先级信任类型,取值为:
·     dot1p:802.1p优先级
·     dscp:DSCP优先级
·     none:不信任任何优先级
3.2.2  qos trust
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { dot1p | dscp | none }
undo qos trust
不信任报文中的任何优先级,信任端口优先级。
none:不信任报文中的任何优先级。
# 在接口GigabitEthernet2/0/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-GigabitEthernet2/0/1] qos trust dot1p
3.3  端口优先级配置命令
3.3.1  qos priority
qos priority命令用来配置端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority priority-value
undo qos priority
端口优先级为0。
priority-value:端口优先级值。取值范围为0~7。
# 配置接口GigabitEthernet2/0/1的端口优先级为2
[Sysname-GigabitEthernet2/0/1] qos priority 2
·     display qos trust interface
4 流量监管、流量整形和限速
4.1  流量监管配置命令
4.1.1  display qos car interface
display qos car interface命令用来显示接口的流量监管配置情况和统计信息。
display qos car interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口外所有接口的流量监管配置情况和统计信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的流量监管配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示接口GigabitEthernet2/0/1的流量监管配置情况和统计信息。
<Sysname> display qos car interface gigabitethernet 2/0/1
 Direction: inbound
  Rule: If-match any
   CIR 128 (kbps), CBS 5120 (Bytes), PIR 128 (kbps), EBS 512 (Bytes)
   Green action  : pass
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
# 显示接口GigabitEthernet2/0/2的流量监管配置情况和统计信息。
<Sysname> display qos car interface gigabitethernet 2/0/2
Interface: GigabitEthernet2/0/2
 Direction: inbound
  Rule: If-match any
   CIR 50 (%), CBS 600 (ms), EBS 0 (ms),PIR 50 (%)
   Green action  : pass
表4-1 display qos car interface命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Direction
流量监管应用的方向
Rule
数据包的匹配规则,为If-match any表示匹配所有数据包
CIR
承诺信息速率,当采用绝对值形式输入时,单位为kbps;当采用百分比形式时,单位为%
CBS
承诺突发尺寸,当采用绝对值形式输入时,单位为byte;当采用百分比形式时,单位为ms,实际的CBS值是cbs-time 乘以实际的承诺信息速率(cir值乘以接口带宽)
EBS
超出突发尺寸,当采用绝对值形式输入时,单位为byte;当采用百分比形式时,单位为ms,实际的EBS值是ebs-time 乘以实际的承诺信息速率(cir值乘以接口带宽)
Max CIR
最大承诺信息速率,单位为kbps
·     Active:表示动态流量监管功能已生效
·     Inactive:表示动态流量监管功能未生效
PIR
峰值信息速率,当采用绝对值形式输入时,单位为kbps;当采用百分比形式时,单位为%
Green action
对绿色报文的动作
Yellow action
对黄色报文的动作
Red action
对红色报文的动作
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
·     bandwidth(接口管理命令参考/以太网接口)
·     qos car (interface view)
·     qos carl
·     qos car bandwidth-refresh-interval
·     qos car bandwidth-utilization-threshold
4.1.2  display qos carl
display qos carl命令用来显示CAR列表。
(独立运行模式)
display qos carl [ carl-index ] [ slot slot-number ]
display qos carl [ carl-index ] [ chassis chassis-number slot slot-number ]
carl-index:CAR列表的号码,取值范围为1~199。如果未指定本参数,将显示所有的CAR列表。
slot slot-number:显示指定单板的CAR列表信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的CAR列表的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CAR列表信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显全局主用主控板上的CAR列表的配置信息。(IRF模式)
# 显示CAR列表。
<Sysname> display qos carl
List  Rules
1     destination-ip-address range 1.1.1.1 to 1.1.1.2 per-address shared-bandwidth
2     destination-ip-address subnet 1.1.1.1 22 per-address shared-bandwidth
4     dscp 1 2 3 4 5 6 7 cs1
5     mac 0000-0000-0000
6     mpls-exp 0 1 2
9     precedence 0 1 2 3 4 5 6 7
10    source-ip-address range 1.1.1.1 to 1.1.1.2
11    source-ip-address subnet 1.1.1.1 31
表4-2 display qos carl命令显示信息描述表
List
CAR列表号码
Rules
数据包的匹配规则
4.1.3  display qos tunnel-session
display qos tunnel-session命令用来显示Tunnel接口上隧道的QoS配置信息和隧道报文统计信息。
display qos tunnel-session interface tunnel number [ identity identity ] [ inbound | outbound ]
display qos tunnel-session interface tunnel number [ sdwan-tte site-id site-id device-id device-id interface-id interface-id ] outbound
identity identity:IPsec P2MP Tunnel接口上隧道的识别字符串。如果未指定本参数,则显示指定Tunnel接口下所有隧道的QoS配置信息和隧道报文统计信息。关于IPsec P2MP隧道接口的详细信息,请参见“安全配置指导”中的“IPsec”。
inbound:显示Tunnel接口上隧道入方向的QoS配置信息和隧道报文统计信息。
outbound:显示Tunnel接口上隧道出方向的QoS配置信息和隧道报文统计信息。
sdwan-tte site-id site-id:SDWAN网络中的站点ID,取值范围是1~65535。关于站点ID的详细信息,请参见“SDWAN配置指导”中的“SDWAN”。
如果未指定inboundoutbound关键字,则同时显示Tunnel接口上隧道出入两个方向的QoS配置信息和隧道报文统计信息。
执行display qos tunnel-session interface tunnel number [ inbound | outbound ]命令可以显示所有隧道的QoS配置信息和隧道报文统计信息,然后再执行display qos tunnel-session interface tunnel number identity identity [ inbound | outbound ]命令,可以显示指定IPsec P2MP Tunnel接口下指定隧道的QoS配置信息和隧道报文统计信息。
执行display qos tunnel-session interface tunnel number [ sdwan-tte site-id site-id device-id device-id interface-id interface-id ] outbound命令,可以显示SDWAN Tunnel接口下指定隧道的QoS配置信息和报文统计信息。
# 显示IPsec P2MP Tunnel接口0识别信息为1的上所有隧道的QoS配置信息和隧道报文统计信息。
<Sysname> display qos tunnel-session interface tunnel 0 identity 1
Tunnel-session identity: Identity_1
  Direction: Inbound
  User Profile: a1
      Rule: If-match any
        CIR 3333 (kbps), CBS 208312 (Bytes), EBS 0 (Bytes)
      Rule: If-match acl 2000
        CIR 1000 (kbps), CBS 62500 (Bytes), EBS 0 (Bytes)
  Direction: Outbound
  User Profile: a1
    Overhead compensation length: 14
      Rule: If-match any
        CIR 4444 (kbps), CBS 277750 (Bytes), EBS 0 (Bytes)
      Rule: If-match acl 3000
Tunnel-session identity: Identity_2
  Direction: Inbound
  User Profile: a1
      Rule: If-match any
  Direction: Outbound
  User Profile: b1
# 显示SDWAN Tunnel接口0上站点ID为1,设备ID为2,接口ID为1的SDWAN隧道的QoS配置信息和隧道报文统计信息。
<Sysname> display qos tunnel-session interface tunnel 0 sdwan-tte site-id 1 device-id 2 interface-id 1 outbound
Tunnel-session identity: SiteID1/DevID2/IfID1
  Direction: Outbound
  User Profile: a1
    Rule: If-match any
  Line rate:
    CIR 2000 (kbps), CBS 20480 (Bytes), EBS 0 (Bytes)
    Active shaping: No
  Tunnel queue:
    Output queue - Urgent queuing: Size/Length/Discards 0/1024/0
    Output queue - Priority queuing: PQL 1 Size/Length/Discards
    Top:  0/20/0    Middle:  0/40/0    Normal:  0/60/0    Bottom:  0/80/0
表4-3 display qos tunnel-session命令显示信息描述表
Tunnel接口上隧道的识别字符串
指定为SDWAN隧道时,SDWAN隧道标识由以下内容组成:
·     SiteID表示SDWAN站点ID
·     DevID表示SDWAN设备ID
·     IfID表示SDWAN隧道的接口ID
Direction
QoS业务应用在隧道的方向:
·     Inbound:表示入方向
·     Outbound:表示出方向
User Profile
User Profile名称
CIR
承诺信息速率,单位为kbps
CBS
EBS
PIR
峰值信息速率
出方向限速时的报文补偿长度,单位为byte
Rule
数据包的匹配规则
·     If-match any:匹配所有数据包
·     If-match acl 2000:匹配命中该ACL中permit规则的数据包
Line rate
基于User Profile的流量限速统计信息
Passed
通过的数据包数目和字节数
Discarded
丢弃的数据包数目和字节数
Delayed
延迟发送的数据包数目和字节数
Active shaping
当前限速配置是否被激活,Yes表示激活,No表示未激活
Tunnel queue
基于SDWAN的隧道队列的报文统计
Output queue
出队列的详细信息
Urgent queuing
出队列中的紧急队列信息
Protocol queuing
出队列中的协议队列信息
Priority queuing
出队列中的优先级队列信息
Size
激活的队列中数据包的总大小
Length
每个队列的队列长度
Discards
丢弃的数据包数目
Top
高优先级队列
Middle
中优先级队列
Normal
普通优先级队列
Bottom
低优先级队列
·     reset qos tunnel-session
4.1.4  qos car (interface view)
qos car命令用来在接口上配置流量监管。
undo qos car命令用来取消接口上流量监管的配置。
(静态流量监管)
qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index }
(动态流量监管)
qos car { inbound | outbound } carl carl-index cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ max-cir max-committed-information-rate ] [ green action | red action | yellow action ] *
undo qos car { inbound | outbound } carl carl-index
未配置流量监管。
inbound:入方向流量监管。
outbound:出方向流量监管。
any:对所有的IP数据包进行流量监管。
acl [ ipv6 ] acl-number:对匹配ACL的数据包进行流量监管。acl-number为ACL编号,基本的ACL取值范围为2000~2999,高级的ACL取值范围为3000~3999。若未指定ipv6关键字,表示IPv4 ACL;否则表示IPv6 ACL。
carl carl-index:对匹配CAR列表的数据包进行限速。carl-index为承诺访问速率列表编号,取值范围为1~199。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~10000000。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,单位为byte。取值范围为512~128000000,配置cir后,如果不指定cbs参数,缺省取值为62.5 × committed-information-rate。
ebs excess-burst-size:过度突发尺寸,单位为byte。取值范围为0~128000000,配置pir后,如果不指定ebs参数,缺省取值为62.5 × peak-information-rate。
max-cir max-committed-information-rate:最大承诺信息速率,单位为kbps。如果未指定本参数,则表示未配置动态流量监管功能。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为64~1000000。
·     continue:继续由下一个CAR策略处理。
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dot1p-continue new-cos:设置新的802.1P报文的优先级值,并继续由下一个CAR策略处理,取值范围为0~7。
·     remark-dscp-continue new-dscp:设置报文新的DSCP值,并继续由下一个CAR策略处理,取值范围为0~63;用文字表示时,可以选取af11af12af13af21af22af23af31af32af33af41af42af43cs1cs2cs3cs4cs5cs6cs7defaultef
·     remark-mpls-exp-continue new-exp:设置新的MPLS报文的EXP标志位的值,并继续由下一个CAR策略处理,取值范围为0~7。
·     remark-prec-continue new-precedence:设置新的IP优先级,并继续由下一个CAR策略处理,取值范围为0~7。
在同一个接口上重复执行本命令可以配置多个CAR策略,策略的执行顺序与配置的先后顺序一致。
不配置峰值速率表示所配置的是单速率流量监管,否则表示双速率流量监管。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示不调用ACL对数据包进行流量监管。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则表示该规则仅对VPN报文有效;若规则未指定vpn-instance参数,则表示该规则仅对公网报文有效。
动态流量监管功能指的是设备能够动态调整流量的可用带宽,提高接口的带宽利用率。
当符合以下配置时,设备将启动接口上的动态流量监管功能:
·     配置了对网段内逐IP地址流量进行限速的CAR列表(通过qos carl命令创建CAR列表,并指定per-address参数)。
·     在接口同方向上仅应用了一个CAR策略(即引用上一步创建的CAR列表),且指定了最大承诺信息速率(配置qos car { inbound | outbound } carl命令并指定max-cir参数)。
接口流量可以分为两部分:不受流量监管限制的流量和受到流量监管限制的流量。当接口上启动动态流量监管功能后,将根据qos car bandwidth-refresh-interval命令配置的带宽刷新时间定时刷新每IP地址流的允许CIR值:
·     如果当前接口流量带宽未超过带宽最大使用门限值,且刷新后的允许CIR值小于最大CIR值(由qos car命令的max-cir参数指定),则增加允许CIR值。
·     如果当前接口流量带宽已达到带宽最大使用门限值,或刷新后的允许CIR值超过最大CIR值(由qos car命令的max-cir参数指定),则允许CIR值将不再增加。
·     如果接口下有新IP地址流加入,新IP地址流将使用与其他流相同的允许CIR值。
# 在接口GigabitEthernet2/0/1的出方向上对满足ANY规则的报文进行流量监管。报文正常流速为200kbps,在第一时间可以有大于正常流量的突发流量通过,以后速率小于等于200kbps时正常发送,大于200kbps时,报文优先级改为0并发送。
[Sysname-GigabitEthernet2/0/1] qos car outbound any cir 200 cbs 5120 ebs 0 green pass red remark-prec-pass 0
·     display qos car interface
·     qos carl
4.1.5  qos car (user profile view)
qos car命令用来在User Profile下配置流量监管。
undo qos car命令用来取消User Profile下流量监管的配置。
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound }  any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car { inbound | outbound } any
未配置流量监管。
User Profile视图
inbound:入方向流量监管。
outbound:出方向流量监管。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,单位为byte。取值范围为1000~1000000000,缺省值为62.5 × committed-information-rate。
ebs excess-burst-size:过度突发尺寸,单位为byte,取值范围为0~1000000000,缺省值为0byte。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为8~40000000。
数据流量符合承诺速率时,允许数据包通过;数据流量不符合承诺速率时,丢弃数据包。
在同一个User Profile下:仅支持配置一个指定any关键字的CAR策略,多次执行命令,仅最后一次执行的命令生效。
# 对上线用户user接收的报文进行流量监管。报文正常流速为200kbps,允许51200byte的突发流量通过,速率小于等于200kbps时正常发送,大于200kbps时,报文被丢弃。
[Sysname-user-profile-user] qos car outbound any cir 200 cbs 51200
4.1.6  qos car bandwidth-refresh-interval
qos car bandwidth-refresh-interval命令用来配置动态流量监管的带宽刷新时间。
undo qos car bandwidth-refresh-interval命令用来恢复缺省情况。
qos car bandwidth-refresh-interval interval
动态流量监管的带宽刷新时间为600秒。
interval:动态流量监管的带宽刷新时间,取值范围为5~600,单位为秒。
本配置仅在接口上的动态流量监管功能启用时,才能生效。关于动态流量监管功能的详细介绍,请参见qos car (interface view)命令。
接口流量可以分为两部分:不受流量监管限制的流量和受到流量监管限制的流量。当接口上启动动态流量监管功能后,将根据本命令配置的带宽刷新时间定时刷新每IP地址流的允许CIR值。
·     如果当前接口流量带宽已到达带宽最大使用门限值,或刷新后的允许CIR值超过最大CIR值(由qos car命令的max-cir参数指定),则允许CIR值将不再增加。
# 配置动态流量监管的带宽刷新时间为100秒。
[Sysname] qos car bandwidth-refresh-interval 100
·     qos carl
4.1.7  qos car bandwidth-utilization-threshold
qos car bandwidth-utilization-threshold命令用来在接口上设置流量的带宽最大使用率门限。
undo qos car bandwidth-utilization-threshold命令用来恢复缺省情况。
qos car bandwidth-utilization-threshold high-percent
流量的带宽最大使用率门限为80%。
high-percent:以百分比的形式设置流量的带宽最大使用率门限,取值范围为1~100。
如果接口下未配置bandwidth命令,则本命令中配置的百分比与接口实际带宽之积即为最大使用门限值;如果接口下配置了bandwidth命令,则本命令中配置的百分比与bandwidth命令配置的带宽值之积即为最大使用门限值。
# 在接口GigabitEthernet2/0/1上设置流量的带宽最大使用率门限为接口总带宽的70%。
[Sysname-GigabitEthernet2/0/1] qos car bandwidth-utilization-threshold 70
·     qos carl
4.1.8  qos carl
qos carl命令用来创建或修改CAR列表。
undo qos carl命令用来删除CAR列表。
qos carl carl-index { dscp dscp-list | mac mac-address | mpls-exp mpls-exp-value | precedence precedence-value | { destination-ip-address | source-ip-address } { object-group object-group-name | range start-ip-address to end-ip-address | subnet ip-address mask-length } [ per-address [ shared-bandwidth ] ] }
undo qos carl carl-index
未配置CAR列表。
carl-index:CAR列表号码,取值范围为1~199。
dscp dscp-list:DSCP取值列表。DSCP为区分服务编码点,用数字表示时,取值范围为0~63;用文字表示时,可以选取af11af12af13af21af22af23af31af32af33af41af42af43cs1cs2cs3cs4cs5cs6cs7defaultef。可以配置多个DSCP值,最多可指定8个;如果指定了多个相同的DSCP值,系统默认为一个;多个不同的DSCP值是或的关系,即只要有一个值匹配,就算匹配这条规则。
mac mac-address:16进制的MAC地址。
mpls-exp mpls-exp-value:MPLS EXP优先级,取值范围为0~7。可以配置多个MPLS EXP值,最多可指定8个;如果指定了多个相同的MPLS EXP值,系统默认为一个;多个不同的MPLS EXP值是或的关系,即只要有一个值匹配,就算匹配这条规则。
precedence precedence-value:优先级,取值范围为0~7。可以配置多个precedence值,最多可指定8个;如果指定了多个相同的precedence值,系统默认为一个;多个不同的precedence值是或的关系,即只要有一个值匹配,就算匹配这条规则。
destination-ip-address:基于目的IP地址的CAR列表。
source-ip-address:基于源IP地址的CAR列表。
range start-ip-address to end-ip-address:IP地址段起始地址和IP地址段终止地址。end-ip-address必须大于start-ip-addres
subnet ip-address mask-length:IP子网地址和IP子网地址掩码长度。取值范围为22~31。
object-group object-group-name:指定对象组。object-group-name表示对象组的名称,为1~63个字符的字符串,不区分大小写。指定的对象组必须是已经存在的IP地址对象组,否则创建或修改CAR列表的操作不生效。
per-address:表示对网段内逐IP地址流量进行限速,cir为各IP地址独享的限制带宽,不能被网段内其他IP流量共享。如果未指定本参数,将对整个网段的流量进行限速,cir为该网段内所有IP地址带宽之和,各个IP地址带宽按照流量大小的比例进行分配。
shared-bandwidth:表示网段内存在流量的IP地址均分配置的共享带宽,cir为该网段内所有IP地址的共享带宽,根据当前存在流量的IP地址数量,动态平均分配各IP地址占用的带宽。
可以选择基于优先级、基于MAC地址、基于MPLS EXP优先级、基于DSCP或基于IP网段建立CAR列表。
重复执行本命令时,如果carl-index取值不同,将创建多个CAR列表;如果carl-index取值相同,则表示修改指定CAR列表的参数。
指定单个IP地址限速请使用接口视图下qos car acl命令配置。
# 在接口GigabitEthernet2/0/1的出方向上应用CAR列表1。CAR列表1是对源地址属于子网1.1.1.0/24内每台主机限速512kbps,网段内各IP地址的流量不共享剩余带宽。
[Sysname] qos carl 1 source-ip-address subnet 1.1.1.0 24 per-address
[Sysname-GigabitEthernet2/0/1] qos car outbound carl 1 cir 512 cbs 5120 ebs 0 green pass red discard
# 在接口GigabitEthernet2/0/1的出方向上应用CAR列表2。CAR列表2是对源地址属于IP地址段1.1.2.100~1.1.2.199内所有主机限速5Mbps,网段内各IP地址的流量共享剩余带宽。
[Sysname] qos carl 2 source-ip-address range 1.1.2.100 to 1.1.2.199 per-address shared-bandwidth
[Sysname-GigabitEthernet2/0/1] qos car outbound carl 2 cir 5120 cbs 51200 ebs 51200 green pass red discard
# 在接口GigabitEthernet2/0/1的出方向上应用CAR列表3。CAR列表3对源地址属于IP地址对象组work-group内每台主机限速256kbps,IP地址对象组内各IP地址的流量不共享剩余带宽。
[Sysname] qos carl 3 source-ip-address object-group work-group per-address
[Sysname-GigabitEthernet2/0/1] qos car outbound carl 3 cir 256 cbs 6250 ebs 0 green pass red discard
·     display qos carl
·     qos car
4.1.9  qos overhead compensation-length
qos overhead compensation-length命令用来配置出方向QoS限速及统计时的报文补偿长度。
undo qos overhead compensation-length命令用来恢复缺省情况。
qos overhead compensation-length length
qos overhead compensation-length { dot1q | 802.3 | ppp | pppoe }
出方向QoS限速及统计时无报文补偿长度。
User Profile视图
隧道接口视图
length:出方向QoS限速及统计时的报文补偿长度,单位为字节。取值范围为1~256。
dot1q:按照802.1q协议的封装方式补偿报文长度,每包固定补偿42字节。其中数据链路层18字节,包含6字节目的MAC,6字节源MAC,4字节VLAN标签,2字节Type/Length字段;物理层24字节,包含8字节帧前导,12字节帧间隙,4字节FCS。通常应用在SDWAN隧道出接口为三层VLAN接口场景,为数据包补偿物理层、数据链路层(含VLAN)长度。
802.3:按照802.3协议的封装方式补偿报文长度,每包补偿38字节。其中数据链路层14字节,包含6字节目的MAC,6字节源MAC,2字节Type/Length字段;物理层24字节,包含8字节帧前导,12字节帧间隙,4字节FCS。通常应用在SDWAN隧道出接口为三层以太网接口场景,为数据包补偿物理层和数据链路层(不含VLAN)长度。
ppp:按PPP协议的封装方式补偿报文长度,每包固定补偿7字节。其中数据链路层4字节,包含1字节Address字段,1字节Control字段,2字节的Protocol;物理层3字节,包含1字节Flag,2字节FCS。
pppoe:按PPPoE协议的封装方式补偿报文长度,每包固定补偿48字节。其中数据链路层24字节,包含14字节以太帧头,6字节PPPoE帧头,4字节PPP帧头;物理层24字节,包含8字节帧前导,12字节帧间隙,4字节FCS。
工作机制
限速补偿是指在QoS限速过程中,在对报文进行测量时该报文可能已经被解封装(或还未被加封装)某层报文头,因此,测量结果未包含该层头长度,此时可以配置限速补偿长度,使限速功能更加准确。同时,限速补偿对于统计值也生效。
在如图4-1所示的隧道网络中,假设QoS限速功能配置在Device A上:
·     当限速配置在入方向时,设备收到隧道报文后进行解封装,在此过程中可以获取到链路层报文头长度,并将该长度传递给限速模块,所以无需手动配置补偿长度。
·     当限速配置在出方向时,因限速时还没有获知出方向的实际物理发送接口,所以限速模块无法获取到实际的链路层报文头长度,此时可通过本命令配置相应的补偿长度,保证限速的准确性。
图4-1 隧道限速方向示意图
应用场景
QoS限速及统计时的报文补偿长度存在两种使用场景:
·     基于User Profile配置报文补偿长度,并应用到SDWAN隧道。
在Spoke设备上执行qos apply user-profile downstream命令,则该命令指定的User Profile的名称可以通过BGP发布给SDWAN隧道的对端Hub设备。对端Hub设备自动将名称相同且已配置的本地User Profile应用到Hub到Spoke的SDWAN隧道出方向上,从而实现对SDWAN隧道的QoS业务配置。此时,基于User Profile配置的报文补偿长度仅对该SDWAN隧道应用的User Profile下配置的QoS业务有效。当本命令配置在User Profile中时,仅User Profile应用在出方向时,其中配置的限速补偿长度才生效。
·     基于SDWAN隧道接口直接配置报文补偿长度。
在SDWAN隧道接口下直接配置报文补偿长度则对该Tunnel接口下应用的QoS业务生效。
当本命令配置在隧道接口下时,仅QoS限速应用在出方向时,其中配置的限速补偿长度才对封装(加密)后的报文生效。
基于SDWAN的Tunnel接口配置报文补偿长度和基于User Profile配置报文补偿长度,应用到SDWAN隧道互相独立,互不影响。
# 在名为u1的User Profile中配置出方向QoS限速及统计时的报文补偿长度为14。
[Sysname] user-profile u1
[Sysname-user-profile-u1] qos overhead compensation-length 14
# 在名为u1的User Profile中配置隧道出方向QoS限速及统计时按dot1q预定义类型补偿。
[Sysname-user-profile-u1] qos overhead compensation-length dot1q
# 在Tunnel接口1下配置出方向QoS限速及统计时的报文补偿长度为14。
[Sysname] interface Tunnel 1
[Sysname-Tunnel1] qos overhead compensation-length 14
4.1.10  reset qos tunnel-session
reset qos tunnel-session命令用来清除Tunnel接口上隧道报文的QoS统计信息。
reset qos tunnel-session interface tunnel number [ identity identity ] [ inbound | outbound ]
reset qos tunnel-session interface tunnel number [ sdwan-tte site-id site-id device-id device-id interface-id interface-id ] outbound
identity identity:IPsec P2MP Tunnel接口上隧道的识别字符串。关于IPsec P2MP隧道接口的详细信息,请参见“安全配置指导”中的“IPsec”。
inbound:清除Tunnel接口上隧道入方向隧道报文的QoS统计信息。
outbound:清除Tunnel接口上隧道出方向隧道报文的QoS统计信息。
如果未指定inboundoutbound参数,则表示清除Tunnel接口上隧道入出方向隧道报文的QoS统计信息。
# 清除Tunnel接口0上隧道报文的QoS统计信息。
<Sysname> reset qos tunnel-session interface tunnel 0
·     display qos tunnel-session
4.2  流量整形配置命令
4.2.1  display qos gts interface
display qos gts interface命令用来显示接口的流量整形配置情况和统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口外所有接口的流量整形配置情况和统计信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的流量整形的配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示所有接口的流量整形配置情况。
 Rule: If-match acl 2001
  CIR 512 (kbps), CBS 51200 (Bytes), PIR 5120 (kbps), EBS 0 (Bytes)
  Queue Length: 100 (Packets)
  Queue Size: 70 (Packets)
  Passed   : 0 (Packets) 0 (Bytes)
  Discarded: 0 (Packets) 0 (Bytes)
  Delayed  : 0 (Packets) 0 (Bytes)
  CIR 64 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
表4-4 display qos gts命令显示信息描述表
Rule
匹配规则
CIR
CBS
EBS
PIR
峰值速率,当采用绝对值形式输入时,单位为kbps;当采用百分比形式时,单位为%
Queue Length
缓冲队列能够容纳的数据包的个数
Queue Size
当前缓冲区中数据包的数目
Passed
已经通过的数据包数目和字节数
Discarded
被丢弃的数据包数目和字节数
Delayed
被延迟发送的数据包数目和字节数
4.2.2  qos gts (interface view)
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
qos gts { any | acl [ ipv6 ] acl-number } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts { any | acl [ ipv6 ] acl-number } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
undo qos gts { any | acl [ ipv6 ] acl-number }
未配置流量整形。
any:对所有的数据包进行流量整形。
acl [ ipv6 ] acl-number:对匹配ACL的数据包进行流量整形。acl-number为ACL编号,基本的ACL取值范围为2000~2999,高级的ACL取值范围为3000~3999 。若未指定ipv6关键字,表示IPv4 ACL;否则表示IPv6 ACL。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~1000000。
cbs committed-burst-size:承诺突发尺寸,单位为byte。取值范围为1875~134217727,配置cir后,如果不指定cbs参数,缺省取值为62.5 × committed-information-rate。
ebs excess-burst-size:超出突发尺寸,在双令牌桶算法中超出承诺突发流量的部分,单位为byte。取值范围为0~134217727,配置pir后,如果不指定ebs参数,缺省取值为62.5 × peak-information-rate。
pir peak-information-rate:峰值速率,单位为kbps。PIR必须大于等于CIR。取值范围为8~1000000。
queue-length queue-length:缓存队列的最大长度。取值范围为1~1024。
不配置峰值速率表示所配置的是单速率流量整形,否则表示双速率流量整形。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示不调用ACL对数据包进行流量整形。
# 在接口GigabitEthernet2/0/1上对满足ACL规则2001的报文进行流量整形。正常流速为200kbps,突发流量为51200bytes,以后速率小于等于200kbps时正常发送,速率大于200kbps时,将进入缓存队列,缓存队列长度为100。
[Sysname-GigabitEthernet2/0/1] qos gts acl 2001 cir 200 cbs 51200 ebs 0 queue-length 100
4.2.3  qos gts (user profile view)
qos gts命令用来在User Profile下配置流量整形。
undo qos gts命令用来恢复缺省情况。
qos gts cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos gts cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos gts
未配置流量整形。
User Profile视图
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~40000000。
cbs committed-burst-size:承诺突发尺寸,单位为byte。取值范围为1000~1000000000。
ebs excess-burst-size:超出突发尺寸,单位为byte,缺省值为0byte。取值范围为0~1000000000。
pir peak-information-rate:峰值速率,单位为kbps。PIR必须大于等于CIR。取值范围8~10000000
# 对上线用户接收的报文进行流量整形。正常流速为200kbps,突发流量为51200bytes,以后速率小于等于200kbps时正常发送,速率大于200kbps时,将进入缓存队列。
[Sysname-user-profile-user] qos gts cir 200 cbs 51200
4.3  限速配置命令
4.3.1  display qos lr
display qos lr命令用来显示接口或PW上的限速配置情况和统计信息。
display qos lr { interface [ interface-type interface-number ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口外所有接口的限速配置情况和运行统计信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
peer ip-address pw-id pw-id:显示指定PW上的限速配置情况和运行统计信息。ip-address为PW远端PE的LSR ID。pw-id为PW的PW ID,取值范围为1~4294967295。如果未指定本参数,将显示所有PW上的限速配置情况和运行统计信息。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的限速的配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示所有接口的接口限速配置情况。
 Direction: outbound
  Active shaping: No
 Direction: Outbound
  CIR 64 (kbps), CBS 512 (Bytes), EBS 0 (Bytes)
  Active shaping: No
# 显示所有PW上的限速配置情况和统计信息。
<Sysname> display qos lr l2vpn-pw
L2VPN-PW: peer 1.2.3.4, pw-id 1
  Direction: Outbound
   CIR 1024 (kbps), CBS 64000 (Bytes), EBS 0 (Bytes)
   Active shaping: No
表4-5 display qos lr命令显示信息描述表
L2VPN-PW
Direction
接口限速应用的方向
CIR
CBS
EBS
Passed
已经通过的数据包数目和字节数
Discarded
被丢弃的数据包数目和字节数
Delayed
被延迟发送的数据包数目和字节数
Active shaping
4.3.2  qos lr
qos lr命令用来配置接口或PW限速。
undo qos lr命令用来取消接口或PW配置的限速。
qos lr { inbound | outbound } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
undo qos lr { inbound | outbound }
未配置限速。
inbound:入方向限速。本参数支持情况与设备型号有关,请以设备实际情况为准。
outbound:出方向限速。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围与设备的型号有关,请以设备的实际情况为准。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。取值范围和缺省值与设备的型号有关,请以设备的实际情况为准。
ebs excess-burst-size:超出突发尺寸,在双令牌桶算法中超出承诺突发流量的部分,单位为bytes。取值范围和缺省值与设备的型号有关,请以设备的实际情况为准。
# 对接口GigabitEthernet2/0/1上出方向的报文进行限速。正常流速为256kbps,突发流量为51200bytes,以后速率小于等于256kbps时正常发送,速率大于256kbps时,将进行限速。
[Sysname-GigabitEthernet2/0/1] qos lr outbound cir 256 cbs 51200
4.3.3  qos lr outbound(user profile view)
qos lr outbound命令用来配置基于User Profile的流量限速。
undo qos lr outbound命令用来恢复缺省情况。
qos lr outbound { cir commited-information-rate [ cbs commited-burst-size [ ebs excess-burst-size ] ] | peer-advertise-bandwidth }
未配置基于User Profile的流量限速。
User Profile视图
ebs excess-burst-size:超出突发尺寸,在双令牌桶算法中超出承诺突发流量的部分,单位为byte。取值范围为0~1000000000。
peer-advertise-bandwidth:使用对端隧道接口发布的承诺信息速率,该值在隧道对端接口下通过qos bandwidth downstream命令指定,在数据通道建立的过程中发布。
多次执行本命令,最后一次执行的命令生效。
# 配置基于User Profile a的流量限速,并使用对端站点隧道接口下配置的qos bandwidth downstream命令指定的限速值作为承诺信息速率。
[Sysname] user-profile a
[Sysname-user-profile-a] qos lr outbound peer-advertise-bandwidth
# 配置基于User Profile a的流量限速,指定承诺信息速率为1000kbps。
[Sysname-user-profile-a] qos lr outbound cir 1000
·     qos bandwidth downstream
4.3.4  qos overhead layer
qos overhead layer physical命令用来配置QoS限速时支持根据物理层报文计算报文长度。
undo qos overhead layer physical命令用来恢复缺省情况。
QoS限速时支持根据数据链路层帧计算报文长度。
在QoS限速场景中:
·     当设备处理的报文较小,且对限速精度要求较高时,建议开启本功能,此时设备将在报文限速时进行物理层补偿,长度为24字节。
·     当设备处理的报文较大时,建议关闭本功能,以节约设备运算资源。
本功能仅对三层以太网接口及三层以太网聚合接口的收发报文生效。
# 配置QoS限速时,根据物理层报文计算报文长度。
[Sysname] qos overhead layer physical
·     display qos lr
·     qos lr
·     qos lr percent
4.3.5  qos bandwidth downstream
qos bandwidth downstream命令用来配置需要在对端隧道出方向上应用的流量限速值。
undo qos bandwidth downstream命令用来恢复缺省情况。
qos bandwidth downstream bandwidth-value
未配置需要在对端隧道出方向上应用的流量限速值。
Tunnel接口视图
bandwidth-value表示隧道的流量限速值,单位为kbps,取值范围为8~10000000。
本功能目前仅适用于SDWAN隧道。关于本功能的详细配置介绍,请参见“SDWAN配置指导”中的“SDWAN”。
在SDWAN场景的Hub-Spoke组网中存在大量Spoke设备,如果需要对Hub-Spoke间的每条SDWAN隧道配置限速等QoS策略,则每增加一个分支站点的Spoke设备,都需要在中心站点的Hub设备上手工配置并应用相应的QoS策略,大量配置命令重复且工作量较大。如果中心站点到各分支站点的SDWAN隧道的QoS策略相同,仅限速参数有差异,则可以通过在Spoke设备上配置本功能来简化Hub设备上的QoS策略配置。详细配置生效的流程如下:
(1)     在Spoke设备执行qos apply user-profile downstream命令,使Hub设备到Spoke设备的SDWAN隧道上应用qos apply user-profile downstream命令指定的User Profile。
(2)     Spoke设备上配置本功能,使BGP IPv4 Tnl-encap-ext路由中携带配置的流量限速值。在Spoke设备和对端Hub设备的SDWAN数据通道建立过程中,流量限速值随TTE信息一并发布给Hub设备。
(3)     在对端Hub设备上的SDWAN隧道上应用的User Profile下执行qos lr outbound(user profile view)命令并指定peer-advertise-bandwidth参数,使对端Hub设备可以接受的Spoke设备上配置的SDWAN隧道的流量限速值。如果对端Hub设备未执行上述步骤,则本功能配置的流量限速值不生效。
# 在SDWAN Tunnel接口2上配置需要在对端隧道出方向上应用的流量限速值为1000kbps。
[Sysname-Tunnel2] qos bandwidth downstream 1000
·     qos apply user-profile downstream
·     qos lr outbound(user profile view)
5 拥塞管理
5.1  拥塞管理公共配置命令
5.1.1  display qos queue interface
display qos queue interface命令用来显示接口上队列配置情况和统计信息。
display qos queue interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口外所有接口的接口队列配置情况和运行统计信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的队列的配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示所有接口下的队列信息。
<Sysname> display qos queue interface
Output queue - Weighted Fair queuing: Size/Length/Discards 0/64/0
  Weight: IP Precedence
  Queues: Active/Max active/Total 0/0/128
表5-1 display qos queue interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列的相关信息
Queue ID
队列号
Group
分组号,说明队列属于哪一个分组
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算,N/A表示该队列采用SP调度算法
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算
5.1.2  display qos queue l2vpn-pw
display qos queue l2vpn-pw命令用来显示PW上队列配置情况和统计信息。
display qos queue l2vpn-pw [ peer ip-address pw-id pw-id ]
peer ip-address pw-id pw-id:显示指定PW上的队列配置情况和统计信息。ip-address为PW远端PE的LSR ID。pw-id为PW的PW ID,取值范围为1~4294967295。如果未指定本参数,将显示所有PW上的队列配置情况和统计信息。
# 显示PW下的所有队列。
<Sysname> display qos queue l2vpn-pw
L2VPN-PW: peer 2.2.2.2 pw-id 2
表5-2 display qos queue l2vpn-pw命令显示信息描述表
L2VPN-PW
Output queue
当前出队列的相关信息
Urgent queuing
紧急队列
Protocol queuing
协议队列
加权公平队列
Protocol queuing
协议队列
Size
激活的队列中数据包的总大小
Length
每个队列的队列长度
Discards
丢弃的数据包数目
Weight
权重类型,分为两类:IP Precedence和DSCP
Queues
WFQ队列的信息
Active
激活的WFQ队列数目
Max active
最大激活过的WFQ队列数目
Total
当前配置的WFQ队列总数
5.1.3  qos-queue enhanced
qos-queue enhanced命令用来开启QoS队列增强功能。
undo qos-queue enhanced命令用来关闭QoS队列增强功能。
(独立运行模式)
qos-queue enhanced slot slot-number
undo qos-queue enhanced slot slot-number
qos-queue enhanced chassis chassis-number slot slot-number
undo qos-queue enhanced chassis chassis-number slot slot-number
QoS队列增强未开启。
slot slot-number:开启指定单板上的QoS队列增强功能,slot-number表示槽位号。(独立运行模式)
chassis chassis-number slot slot-number:开启指定成员设备上指定单板上的QoS队列增强功能。chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号。(IRF模式)
本命令仅对RT-FIP-680单板生效,并且配置后仅对单板上的固定端口生效,对接口模块上的端口不生效。当开启QoS队列增强功能后,RT-FIP-680单板上的固定端口会切换成硬件芯片处理QoS队列调度,可以提升QoS队列调度的性能。
开启或关闭队列相关的QoS队列增强功能后需要重启单板才能生效。
[Sysname] qos-queue enhanced slot 5
Please reboot slot 5 to make the command take effect.
5.1.4  reset qos statistics l2vpn-pw
reset qos statistics l2vpn-pw命令用来清除PW下QoS的统计信息。
reset qos statistics l2vpn-pw [ peer ip-address pw-id pw-id ]
peer ip-address pw-id pw-id:清除指定PW上的QoS的统计信息。ip-address为PW远端PE的LSR ID。pw-id为PW的PW ID,取值范围为1~4294967295。如果未指定本参数,将清除所有PW上的QoS的统计信息。
# 清除QoS统计计数。
<Sysname> reset qos statistics l2vpn-pw peer 1.1.1.1 pw-id 1
5.2  FIFO队列配置命令
5.2.1  display qos queue fifo
display qos queue fifo命令用来显示接口或PW上先进先出队列配置情况和统计信息。
display qos queue fifo { interface [ interface-type interface-number ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口外所有接口的先进先出队列配置情况和统计信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
peer ip-address pw-id pw-id:显示指定PW上的先进先出队列配置情况和统计信息。ip-address为PW远端PE的LSR ID。pw-id为PW的PW ID,取值范围为1~4294967295。如果未指定本参数,将显示所有PW上的先进先出队列配置情况和统计信息。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的先进先出队列的配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示所有接口的先进先出队列配置情况和统计信息。
<Sysname> display qos queue fifo interface
# 显示所有PW下的先进先出队列配置情况和统计信息。
<Sysname> display qos queue fifo l2vpn-pw
表5-3 display qos queue fifo命令显示信息描述表
接口名,由接口类型和接口编号组成
L2VPN-PW
Output queue
当前出队列的相关信息
Urgent queuing
紧急队列
Protocol queuing
协议队列
FIFO queuing
先进先出队列
Size
激活的队列中数据包的总大小
Length
每个队列的队列长度
Discards
丢弃的数据包数目
5.2.2  qos fifo queue-length
qos fifo queue-length命令用来配置接口或PW先进先出队列的长度。
undo qos fifo queue-length命令用来恢复缺省情况。
qos fifo queue-length queue-length
先进先出队列的长度为75。
queue-length:队列的长度,即队列中所能容纳的数据包个数,取值范围为1~1024。
在子接口上配置FIFO队列时,需要开启接口限速功能以保证队列生效。
# 配置FIFO队列的长度为100。
[Sysname-GigabitEthernet2/0/1] qos fifo queue-length 100
·     display qos queue fifo interface
5.3  优先级队列配置命令
RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口不支持配置优先级队列。
5.3.1  display qos pql
display qos pql命令用来显示优先级队列列表的内容。
(独立运行模式)
display qos pql [ pql-index ] [ slot slot-number ]
display qos pql [ pql-index ] [ chassis chassis-number slot slot-number ]
pql-index:优先列表的组号,取值范围为1~16。
slot slot-number:显示指定单板的优先级队列列表的内容,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主用主控板的优先级队列列表的内容。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的优先级队列列表的内容,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示全局主用主控板的优先级队列列表的内容。(IRF模式)
# 显示优先列表。
<Sysname> display qos pql
Current PQL configuration:
List  Queue   Parameters
1     Top     Protocol ip less-than 1000
2     Normal  Length 80
2     Bottom  Length 40
3     Middle  Inbound-interface GigabitEthernet2/0/1
4     Top     Local-precedence  7
4     0       Protocol ip acl 3001
4     1       Protocol ipv6 acl 3001
4     2       Protocol ip
4     3       Protocol ipv6
表5-4 display qos pql命令显示信息描述表
当前优先级队列列表配置情况
List
优先列表的组号
Queue
PQ队列类型,取值包括:
·     0:表示八队列中编号为0的PQ队列
·     1:表示八队列中编号为1的PQ队列
·     2:表示八队列中编号为2的PQ队列
·     3:表示八队列中编号为3的PQ队列
·     Bottom:表示四队列中低优先队列或八队列中编号为4的PQ队列
·     Normal:表示四队列正常低优先队列或八队列中编号为5的PQ队列
·     Middle:表示四队列里中优先队列或八队列中编号为6的PQ队列
·     Top:表示四队列中高优先队列或八队列中编号为7的PQ队列
PQ队列的详细配置信息,包括:
·     PQ队列的分类规则
·     PQ队列的队列长度
5.3.2  display qos queue pq interface
display qos queue pq interface命令用来显示接口上优先级队列配置情况和统计信息。
display qos queue pq interface [ interface-type interface-number ]
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口和Dialer接口外所有接口上优先级队列配置情况和统计信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的优先级队列的配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示接口GigabitEthernet2/0/1的优先级队列配置情况和统计信息。
<Sysname> display qos queue pq interface gigabitethernet 2/0/1
3  :  0/80/0    2     :  0/80/0    1     :  0/100/0   0     :  0/100/0
表5-5 display qos queue pq interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
出队列信息
Urgent queuing
紧急队列
Protocol queuing
协议队列
Priority queuing
优先级队列,指明使用的优先级队列列表
Size
激活的队列中数据包的总大小
Length
每个队列的队列长度
Discards
丢弃的数据包数目
Top
四队列中的高优先级队列或八队列中队列编号为7的PQ队列
Middle
四队列中的中优先级队列或八队列中队列编号为6的PQ队列
Normal
四队列中的普通优先级队列或八队列中队列编号为5的PQ队列
Bottom
四队列中的低优先级队列或八队列中队列编号为4的PQ队列
3
八队列中队列编号为3的PQ队列
2
八队列中队列编号为2的PQ队列
1
八队列中队列编号为1的PQ队列
0
八队列中队列编号为0的PQ队列
5.3.3  qos pq
qos pq命令用来在接口上应用优先级队列调度机制。
undo qos pq命令用来恢复缺省情况。
qos pq pql pql-index
undo qos pq
接口的拥塞管理策略为FIFO。
在同一个接口视图下多次执行本命令,最后一次执行的命令生效。
可以为优先列表的组配置多条分类规则,在进行流分类时,数据流按照顺序进行匹配,如果匹配上某规则,则进入相应的队列,匹配结束;如果数据包不与任何规则匹配,则进入缺省队列。
若是Tunnel接口、子接口、三层聚合接口、HDLC捆绑接口,或是封装了PPPoE、PPPoA、PPPoEoA、PPPoFR、MPoFR(MpoFR中的FR接口不能开启帧中继流量整形功能)协议的VT、Dialer接口,则接口需要开启接口限速功能以保证队列生效。
# 将第12组的优先列表应用到GigabitEthernet2/0/1上。
[Sysname-GigabitEthernet2/0/1] qos pq pql 12
5.3.4  qos pq(user profile view)
qos pq命令用来配置基于User Profile应用优先队列。
undo qos pq
User Profile下未配置优先队列。
User Profile视图
pql-index:优先队列表的索引,取值范围为1~16。
PQ(priority queue,优先队列)可以根据网络协议(比如IP、IPX)、数据流入接口、报文长度、源地址/目的地址等灵活地为数据流指定优先次序。在队列调度时,PQ严格按照优先级从高到低的次序,优先发送较高优先级队列中的分组。
配置本功能可以将配置了优先队列表的User Profile应用到不同接口下,无需在每个接口下重复配置优先队列表。
在同一个User Profile下多次执行本命令,最后一次执行的命令生效。
可以为优先队列表的索引配置多条分类规则,在进行流分类时,数据流按照顺序进行匹配,如果匹配上某规则,则进入相应的队列,匹配结束;如果数据包不与任何规则匹配,则进入缺省队列。
# 配置基于User Profile a应用索引为12的优先队列表。
[Sysname-user-profile-a] qos pq pql 12
5.3.5  qos pql default-queue
qos pql default-queue命令用来为未匹配任何规则的数据包指定一个缺省队列。
undo qos pql default-queue命令用来恢复缺省情况。
四队列命令形式:
qos pql pql-index default-queue { bottom | middle | normal | top }
undo qos pql pql-index default-queue
八队列命令形式:
qos pql pql-index default-queue queue-number
为未匹配任何规则的数据包指定的缺省队列为normal
bottom:低优先队列。
middle:中优先队列。
normal:正常优先队列。
top:高优先队列。
queue-number:队列编号,取值范围为0~7,从队列0到队列7的调度优先级依次增加。
进行流分类的时候,如果数据包不与任何规则匹配,则进入缺省队列。
对于同一个pql-index,多次执行本命令,最后一次执行的命令生效。
对于支持八队列的产品,可以采用四队列命令形式或八队列命令形式配置为未匹配任何规则的数据包指定一个缺省PQ队列,队列编号为4~7的队列分别对应四队列形式中的bottom低优先队列、normal正常优先队列、middle中优先队列、top高优先队列。
# 将优先列表中第12组中无对应规则的包的缺省队列设定为bottom。
[Sysname] qos pql 12 default-queue bottom
5.3.6  qos pql inbound-interface
qos pql inbound-interface命令用来配置基于接口的分类规则。
undo qos pql inbound-interface命令用来删除相应的分类规则。
四队列命令形式:
qos pql pql-index inbound-interface interface-type interface-number queue { bottom | middle | normal | top }
undo qos pql pql-index inbound-interface interface-type interface-number
八队列命令形式:
qos pql pql-index inbound-interface interface-type interface-number queue queue-number
未配置任何分类规则。
bottom:低优先队列。
middle:中优先队列。
normal:正常优先队列。
top:高优先队列。
对于同一个pql-index,该命令可以重复使用,为来自不同接口的报文,建立不同的分类规则
对于支持八队列的产品,可以采用四队列命令形式或八队列命令形式配置基于接口的分类规则,队列编号为4~7的队列分别对应四队列形式中的bottom低优先队列、normal正常优先队列、middle中优先队列、top高优先队列。
# 配置组号为12的优先列表的分类规则,使得来自GigabitEthernet2/0/1的报文进入middle队列。
[Sysname] qos pql 12 inbound-interface gigabitethernet 2/0/1 queue middle
5.3.7  qos pql local-precedence
qos pql local-precedence命令用来配置基于本地优先级的分类规则。
undo qos pql local-precedence命令用来删除相应的规则。
四队列命令形式:
qos pql pql-index local-pecedence local-precedence-list queue { bottom | middle | normal | top }
undo qos pql pql-index local-precedence local-precedence-list
八队列命令形式:
qos pql pql-index local-pecedence local-precedence-list queue queue-number
未配置任何分类规则。
local-precedence-list:要匹配的本地优先级的列表,最多可以输入8个local-precedence,取值范围为0~7。
bottom:低优先队列。
middle:中优先队列。
normal:正常优先队列。
top:高优先队列。
对于同一个pql-index,该命令可以重复使用,为不同本地优先级的报文,建立不同的分类规则
对于支持八队列的产品,可以采用四队列命令形式或八队列命令形式配置基于本地优先级的分类规则,队列编号为4~7的队列分别对应四队列形式中的bottom低优先队列、normal正常优先队列、middle中优先队列、top高优先队列。
# 配置组号为12的优先列表的分类规则,使得本地优先级等于3的报文进入middle队列。
[Sysname] qos pql 12 local-precedence 3 queue middle
5.3.8  qos pql protocol
qos pql protocol命令用来配置基于协议的分类规则。
undo qos pql protocol命令用来删除相应的分类规则。
四队列命令形式:
qos pql pql-index protocol { ip | ipv6 } [ queue-key key-value ] queue { bottom | middle | normal | top }
undo qos pql pql-index protocol { ip | ipv6 } [ queue-key key-value ]
八队列命令形式:
qos pql pql-index protocol { ip | ipv6 } [ queue-key key-value ] queue queue-number
未配置任何分类规则。
bottom:低优先队列。
middle:中优先队列。
normal:正常优先队列。
top:高优先队列。
queue-key key-value:将IP或者IPv6报文分类进入队列。queue-keykey-value的取值见下表。当不输入queue-keykey-value时,表示所有IP或者IPv6报文进入队列。
表5-6 queue-key和key-value的取值
queue-key
key-value
acl
access-list-number(2000~3999)
符合某访问控制列表定义的IP或者IPv6报文进入队列
fragments
分片的IP或者IPv6报文进入队列
greater-than
长度值(0~65535)
长度大于某个计数值的IP或者IPv6报文进入队列
less-than
长度值(0~65535)
长度小于某个计数值的IP或者IPv6报文进入队列
tcp
端口号(0~65535)或端口名称
源或目的TCP端口号为指定的端口号的IP或者IPv6报文进入队列
udp
端口号(0~65535)或端口名称
源或目的UDP端口号为指定的端口号的IP或者IPv6报文进入队列
设备是以规则被配置的顺序来匹配数据包,如果发现数据包与某个规则匹配,便结束整个查找。
对于同一个pql-index,该命令可以重复使用,为IP数据包建立多种分类规则。
对于支持八队列的产品,可以采用四队列命令形式或八队列命令形式配置基于协议的分类规则的PQ队列,队列编号为4~7的队列分别对应四队列形式中的bottom低优先队列、normal正常优先队列、middle中优先队列、top高优先队列。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示不调用ACL对数据包进行过滤。
# 配置组号为5的优先列表的分类规则,使满足ACL为3100规则定义的IP报文进入top队列。
[Sysname] qos pql 5 protocol ip acl 3100 queue top
# 配置组号为6的优先列表的分类规则,使满足ACL为3100规则定义的IP报文进入队列编号为7的队列。
[Sysname] qos pql 6 protocol ip acl 3100 queue 7
5.3.9  qos pql protocol mpls exp
qos pql protocol mpls exp命令用来配置基于MPLS EXP优先级的分类规则。
undo qos pql protocol mpls exp命令用来删除相应的分类规则。
四队列命令形式:
qos pql pql-index protocol mpls exp exp-list queue { bottom | middle | normal | top }
undo qos pql pql-index protocol mpls exp exp-list
八队列命令形式:
qos pql pql-index protocol mpls exp exp-list queue queue-number
未配置任何分类规则。
exp-list:要匹配的MPLS EXP优先级的报文列表,最多可以输入8个expexp取值范围为0~7。
bottom:低优先队列。
middle:中优先队列。
normal:正常优先队列。
top:高优先队列。
对于同一个pql-index,该命令可以重复使用,为不同MPLS EXP优先级的报文建立不同的分类规则
对于支持八队列的产品,可以采用四队列命令形式或八队列命令形式配置基于MPLS EXP优先级的分类规则,队列编号为4~7的队列分别对应四队列形式中的bottom低优先队列、normal正常优先队列、middle中优先队列、top高优先队列。
# 配置组号为12的优先列表的分类规则,将MPLS EXP优先级为2、4的报文进入top队列。
[Sysname] qos pql 5 protocol mpls exp 2 4 queue top
5.3.10  qos pql queue
qos pql queue 命令用来设置各队列的长度。
undo qos pql queue命令用来恢复队列长度的缺省值。
四队列命令形式:
qos pql pql-index queue { bottom | middle | normal | top } queue-length queue-length
undo qos pql pql-index queue { bottom | middle | normal | top } queue-length
八队列命令形式:
qos pql pql-index queue queue-number queue-length queue-length
undo qos pql pql-index queue queue-number queue-length
高优先队列的缺省长度值为20,中优先队列的缺省长度值为40,正常优先队列的缺省长度值为60,低优先队列的缺省长度值为80。
编号为3的队列缺省长度值为80,编号为2的队列缺省长度值为80,编号为1的队列缺省长度值为100,编号为0的队列缺省长度值为100。
bottom:低优先队列。
middle:中优先队列。
normal:正常优先队列。
top:高优先队列。
queue-number:队列编号,取值范围为0~7,从队列0到队列7的调度优先级依次增加。queue-length queue-length:队列的长度,即队列中所能容纳的数据包个数,取值范围为1~1024。
如果队列的长度达到最大值时,后面收到的属于该队列的数据包将被丢弃。
对于支持八队列的产品,可以采用四队列命令形式或八队列命令形式各队列的长度,队列编号为4~7的队列分别对应四队列形式中的bottom低优先队列、normal正常优先队列、middle中优先队列、top高优先队列。
# 配置优先列表第5组top队列的长度为10。
[Sysname] qos pql 5 queue top queue-length 10
# 配置优先列表第6组队列编号为6的队列的长度为20。
[Sysname] qos pql 6 queue 6 queue-length 20
5.4  定制队列配置命令
RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口不支持配置定制队列。
5.4.1  display qos cql
display qos cql命令用来显示定制队列列表的内容。
(独立运行模式)
display qos cql [ cql-index ] [ slot slot-number ]
display qos cql [ cql-index ] [ chassis chassis-number slot slot-number ]
cql-index:优先列表的组号,取值范围为1~16。如果未指定本参数,则显示所有列表的内容。
slot slot-number:显示指定单板的定制列表的内容,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主用主控板的定制列表的内容。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的定制列表的内容,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示全局主用主控板的定制列表的内容。(IRF模式)
# 显示所有定制列表的内容。
<Sysname> display qos cql
Current CQL configuration:
2     3      Protocol ip fragments
3     6      Length 100
3     1      Inbound-interface GigabitEthernet2/0/1
4     5      Local-precedence 7
5.4.2  display qos queue cq interface
display qos queue cq interface命令用来显示接口上定制队列配置情况和统计信息。
display qos queue cq interface [ interface-type interface-number ]
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口和Dialer接口外所有接口上定制队列配置情况和统计信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的定制队列的配置情况和统计信息,Virtual-Template本身无QoS信息显示。
#显示接口GigabitEthernet2/0/1的定制队列配置情况和统计信息。
<Sysname>display qos queue cq interface gigabitethernet 2/0/1
Interface: GigabitEthernet2/0/1
Output queue - Custom queuing: CQL 1 Size/Length/Discards
 1:   0/  20/0          2:   0/  20/0          3:   0/  20/0
 4:   0/  20/0          5:   0/  20/0          6:   0/  20/0
 7:   0/  20/0          8:   0/  20/0          9:   0/  20/0
10:   0/  20/0         11:   0/  20/0         12:   0/  20/0
13:   0/  20/0         14:   0/  20/0         15:   0/  20/0
16:   0/  20/0
表5-7 display qos queue cq interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
出队列信息
Urgent queuing
紧急队列
Protocol queuing
协议队列
Custom queuing
定制队列,指明使用的定制队列列表
Size
激活的队列中数据包的总大小
Length
每个队列的队列长度
Discards
丢弃的数据包数目
5.4.3  qos cq
qos cq命令用来在接口上应用定制队列。
undo qos cq命令用来恢复缺省情况。
qos cq cql cql-index
undo qos cq
接口的拥塞管理策略为FIFO。
cql-index:定制列表的组号,取值范围为1~16。
对于同一个接口,多次执行本命令,最后一次执行的命令生效。
可以为定制列表的组配置多条分类规则,在进行流分类时,数据流按照顺序进行匹配,如果匹配上某规则,则进入相应的队列,匹配结束;如果数据包不与任何规则匹配,则进入缺省队列。
# 将第5组的定制列表应用到GigabitEthernet2/0/1上。
[Sysname-GigabitEthernet2/0/1] qos cq cql 5
5.4.4  qos cql default-queue
qos cql default-queue命令用来为未匹配任何规则的数据包指定一个缺省队列。
undo qos cql default-queue命令用来恢复缺省情况。
qos cql cql-index default-queue queue-id
undo qos cql cql-index default-queue
队列号为1。
queue-id:队列号,取值范围为1~16。
在进行流分类的时候,如果数据包不与任何规则匹配,则进入缺省队列。
# 指定定制列表第5组的缺省队列为2。
[Sysname] qos cql 5 default-queue 2
5.4.5  qos cql inbound-interface
qos cql inbound-interface命令用来建立基于接口的分类规则。
undo qos cql inbound-interface命令用来删除相应的分类规则。
qos cql cql-index inbound-interface interface-type interface-number queue queue-id
undo qos cql cql-index inbound-interface interface-type interface-number
未配置任何分类规则。
对于同一个cql-index,该命令可以重复使用,为来自不同接口的报文,建立不同的分类规则。
# 配置组号为5的定制列表的分类规则,将来自GigabitEthernet2/0/1的报文进入队列3。
[Sysname] qos cql 5 inbound-interface gigabitethernet 2/0/1 queue 3
5.4.6  qos cql local-precedence
qos cql local-precedence命令用来建立基于本地优先级的分类规则。
undo qos cql local-precedence命令用来删除相应的规则。
qos cql cql-index local-precedence local-precedence-list queue queue-id
undo qos cql cql-index local-precedence local-precedence-list
未配置任何分类规则。
queue-id:定制队列的队列号,取值范围为1~16。
对于同一个cql-index,该命令可以重复使用,为不同本地优先级的报文建立不同的分类规则。
# 配置组号为5的定制列表的分类规则,将本地优先级等于4的报文进入队列3。
[Sysname] qos cql 5 local-precedence 4 queue 3
5.4.7  qos cql protocol
qos cql protocol 命令用来配置基于协议的分类规则。
undo qos cql protocol命令用来删除相应的分类规则。
qos cql cql-index protocol { ip | ipv6 } [ queue-key key-value ] queue queue-id
undo qos cql cql-index protocol { ip | ipv6 } [ queue-key key-value ]
未配置任何分类规则。
queue-key key-value:将IP或者IPv6报文分类进入队列。queue-keykey-value的取值见表5-8。当不输入queue-keykey-value时,表示所有IP或者IPv6报文进入队列。
表5-8 queue-key和key-value的取值
queue-key
key-value
acl
符合某访问控制列表定义的IP或者IPv6报文就进入队列
fragments
只要是分片的IP或者IPv6报文就进入队列
greater-than
长度值(0~65535)
长度大于指定长度值的IP或者IPv6报文进入队列
less-than
长度值(0~65535)
长度小于指定长度值的IP或者IPv6报文进入队列
tcp
端口号(0~65535)或端口名称
udp
端口号(0~65535)或端口名称
系统是以规则被配置的顺序来匹配数据包,如果发现数据包与某个规则匹配,便结束整个查找。
对于同一个cql-index,该命令可以重复使用,为IP数据包建立多种分类规则。
引用ACL时,需要注意的是:
# 配置组号为5的定制列表的分类规则,将匹配访问控制列表3100的IP报文进入队列3。
[Sysname] qos cql 5 protocol ip acl 3100 queue 3
5.4.8  qos cql protocol mpls exp
qos cql protocol mpls exp命令用来配置基于MPLS EXP优先级的分类规则。
undo qos cql protocol mpls exp命令用来删除相应的分类规则
qos cql cql-index protocol mpls exp exp-list queue queue-id
undo qos cql cql-index protocol mpls exp exp-list
未配置任何分类规则。
对于同一个cql-index,该命令可以重复使用,为不同MPLS EXP优先级的报文建立不同的分类规则
# 配置组号为5的定制列表的分类规则,将MPLS EXP优先级为2、4的报文进入队列3。
[Sysname] qos cql 5 protocol mpls exp 2 4 queue 3
5.4.9  qos cql queue
qos cql queue 命令用来设置各队列的长度
undo qos cql queue命令用来恢复队列长度的缺省值。
qos cql cql-index queue queue-id queue-length queue-length
undo qos cql cql-index queue queue-id queue-length
队列长度值是20。
# 指定定制列表第5组队列4的长度为40。
[Sysname] qos cql 5 queue 4 queue-length 40
5.4.10  qos cql queue serving
qos cql queue serving命令用来设置各队列每次轮询所发送数据包的字节数。
undo qos cql queue serving命令用来恢复发送数据包数的缺省值。
qos cql cql-index queue queue-id serving byte-count
undo qos cql cql-index queue queue-id serving
发送数据包的字节数为1500。
byte-count:队列每次轮询所发送的数据包的字节数,取值范围为1~16777215。
# 指定定制列表第5组队列2每次轮询所发送数据包的字节数为1400。
[Sysname] qos cql 5 queue 2 serving 1400
5.5  加权公平队列配置命令
RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口不支持配置加权公平队列
5.5.1  display qos queue wfq
display qos queue wfq命令用来显示接口或PW上加权公平队列配置情况和统计信息。
display qos queue wfq { interface [ interface-type interface-number ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口和Dialer接口外所有接口的加权公平队列配置情况和统计信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
peer ip-address pw-id pw-id:显示指定PW上的加权公平队列配置情况和统计信息。ip-address为PW远端PE的LSR ID。pw-id为PW的PW ID,取值范围为1~4294967295。如果未指定本参数,将显示所有PW上的加权公平队列配置情况和统计信息。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的加权公平队列的配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示接口GigabitEthernet2/0/1的加权公平队列配置情况和统计信息。
<Sysname> display qos queue wfq interface gigabitethernet 2/0/1
# 显示所有PW下的加权公平队列配置情况和统计信息。
<Sysname> display qos queue wfq l2vpn-pw
L2VPN-PW: peer 1.1.1.1, pw-id 1
表5-9 表4-4 display qos queue wfq命令显示信息描述表
接口名,由接口类型和接口编号组成
L2VPN-PW
显示指定PW的信息,PW通过远端PE地址和PW ID唯一标识
Output queue
当前出队列的相关信息
Urgent queuing
紧急队列
Protocol queuing
协议队列
加权公平队列
Size
激活的队列中数据包的总大小
Length
每个队列的队列长度
Discards
丢弃的数据包数目
Weight
Queues
WFQ队列的信息
Active
激活的WFQ队列数目
Max active
最大激活过的WFQ队列数目
Total
当前配置的WFQ队列总数
5.5.2  qos wfq
qos wfq命令用来在接口或PW上应用加权公平队列或修改加权公平队列的参数。
undo qos wfq命令用来恢复缺省情况。
qos wfq [ dscp | precedence ] [ queue-number total-queue-number | queue-length max-queue-length ] *
undo qos wfq
接口或PW上使用的队列为FIFO。
交叉连接PW视图/VSI LDP PW视图/VSI静态PW视图
dscp:区分服务编码点权重类型。
precedence:IP优先级权重类型,缺省权重类型。
queue-length max-queue-length:队列的最大长度,即每个队列中可容纳的数据包的最大个数,超出后数据包将被丢弃,取值范围为1~1024,缺省值为64。
queue-number total-queue-number:队列的总数目,可取的值为:16、32、64、128、256、512、1024、2048、4096,缺省值为256。
对于Tunnel接口、子接口、三层聚合接口、HDLC捆绑接口,或是封装了PPPoE、PPPoA、PPPoEoA、PPPoFR、MPoFR(MpoFR中的FR接口不能开启帧中继流量整形功能)协议的VT、Dialer接口,则接口上需要开启接口限速功能以保证队列功能生效。
# 在接口GigabitEthernet2/0/1上应用WFQ,并设置队列长度为100,总队列个数设置为512个。
[Sysname-GigabitEthernet2/0/1] qos wfq queue-length 100 queue-number 512
·     display qos queue wfq interface
5.6  实时传输协议队列的配置命令
RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口不支持配置实时传输协议队列
5.6.1  display qos queue rtpq interface
display qos queue rtpq interface命令用来显示接口上IP RTP Priority的队列信息。
display qos queue rtpq interface [ interface-type interface-number ]
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口和Dialer接口外所有接口上当前IP RTP Priority的队列信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的QoS RTP队列的信息,Virtual-Template本身无QoS信息显示。
# 显示IP RTP Priority的队列信息。
<Sysname> display qos queue rtpq interface
Output queue - RTP queuing: Size/Max/Outputs/Discards 0/0/0/0
表5-10 display qos queue rtpq interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前的输出队列
Size
队列中数据包数目
Max
队列中数据包的历史最大数目
Outputs
发送出去的数据包数目
Discards
丢弃的数据包数目
5.6.2  qos rtpq
qos rtpq命令用来开启接口RTP队列,为某个UDP目的端口范围的RTP报文保留一个实时业务。
undo qos rtpq命令用来恢复缺省情况。
qos rtpq start-port first-rtp-port-number end-port last-rtp-port-number bandwidth bandwidth [ cbs committee-burst-size ]
undo qos rtpq
接口上没有启动RTP队列。
start-port first-rtp-port-number:指定发起RTP报文的第一个UDP目的端口号,取值范围为2000~65535。
end-port last-rtp-port-number:指定发起RTP报文的最后一个UDP目的端口号,取值范围为2000~65535。
bandwidth bandwidth:RTP队列所占用的带宽,取值范围为8~1000000,单位为kbps。
cbs committee-burst-size:指定承诺突发尺寸,取值范围为1500~2000000,单位为字节。配置bandwidth后,如果不指定cbs参数,则缺省值为25 × bandwidth
若是Tunnel接口、子接口、三层聚合接口、HDLC捆绑接口,或是封装了PPPoE、PPPoA、PPPoEoA、PPPoFR、MPoFR协议的VT、Dialer接口,则接口需要开启接口限速功能以保证RTP队列功能生效。
该命令主要应用于对时延敏感的应用,如实时语音传输。qos rtpq命令为语音业务提供最优先服务。
在配置bandwidth参数时,配置值通常应大于此实时业务所需的带宽总量,以预防突发流量的冲击。
# 在接口GigabitEthernet2/0/1上启动RTP队列,发起RTP报文的第一个UDP目的端口号为16384,发起RTP报文的最后一个UDP目的端口号为32767,RTP报文占用64kbps的带宽,如果输出接口拥塞,进入RTP队列。
[Sysname-GigabitEthernet2/0/1] qos rtpq start-port 16384 end-port 32767 bandwidth 64
5.7  基于类的队列配置命令
5.7.1  display qos queue cbq
display qos queue cbq命令用来显示接口或PW上基于类的队列配置信息和运行情况。
display qos queue cbq { interface [ interface-type interface-number ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口外所有接口的基于类的队列配置信息和运行情况。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
peer ip-address pw-id pw-id:显示指定PW上的加权公平队列配置情况和统计信息。ip-address为PW远端PE的LSR ID。pw-id为PW的PW ID,取值范围为1~4294967295。如果未指定本参数,将显示所有PW上的基于类的队列配置情况和统计信息。
如果指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的基于类的队列的配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示所有接口的基于类的队列配置信息和运行情况。
<Sysname> display qos queue cbq interface
Output queue - Class Based Queuing: Size/Discards 0/0
Queue Size: EF/AF/BE 0/0/0
  BE Queues: Active/Max active/Total 0/0/256
  AF Queues: Allocated 1
  Bandwidth(kbps): Available/Max reserve 74992/75000
# 显示所有PW下的基于类的队列配置情况和统计信息。
<Sysname> display qos queue cbq l2vpn-pw
表5-11 display qos queue cbq命令显示信息描述表
接口名,由接口类型和接口编号组成
L2VPN-PW
Output queue
当前出队列的相关信息
Urgent queuing
紧急队列
Protocol queuing
协议队列
Class Based Queuing
基于类的队列
Size
激活的队列中数据包的总大小
Length
每个队列的队列长度
Discards
丢弃的数据包数目
EF
加速转发队列
AF
保证转发队列
BE
尽力转发队列
Active
BE队列当前处于激活状态的队列数
Max active
BE队列最大处于激活状态队列数
Total
BE队列总数
Bandwidth(kbps)
带宽
Available
CBQ当前可用带宽
Max reserve
CBQ最大预留带宽
5.7.2  qos reserved-bandwidth
qos reserved-bandwidth命令用来设置最大预留带宽占可用带宽的百分比。
undo qos reserved-bandwidth命令用来恢复缺省情况。
qos reserved-bandwidth pct percent
最大预留带宽占可用带宽的百分比为80。
percent:预留带宽占可用带宽的百分比,取值范围为1~100。
为队列分配带宽时,考虑到部分带宽用于控制协议报文、二层帧头等,通常配置的最大预留带宽不大于可用带宽的80%。
建议慎重使用该命令修改最大预留带宽。如果配置的最大预留带宽过大,发送的报文加上链路层的帧头有可能大于接口最大可用带宽,导致接口无法满足需求,建议使用缺省最大预留带宽。
接口最大可用带宽通过命令bandwidth进行配置,具体情况请参见接口分册命令参考中的介绍。
# 配置GigabitEthernet2/0/1接口的最大预留带宽占可用带宽的百分比为70。
[Sysname-GigabitEthernet2/0/1] qos reserved-bandwidth pct 70
5.7.3  queue af
queue af命令用来配置类采用AF队列,并配置类可确保的最小带宽。
undo queue af命令用来恢复缺省情况。
queue af bandwidth { bandwidth | pct percentage | remaining-pct remaining-percentage }
undo queue af
未配置类采用AF队列。
流行为视图
bandwidth:带宽,单位kbps。取值范围为8~10000000。
pct percentage:可用带宽的百分比,取值范围为1~100。
remaining-pct remaining-percentage:剩余带宽的百分比,取值范围为1~100。
在将类与queue af所属行为关联时,必须满足以下条件:
·     同一个策略下为AF队列和EF队列指定的带宽之和必须不大于该策略所应用接口的可用带宽;
·     同一个策略下为AF队列和EF队列指定的带宽百分比之和必须不大于100;
·     同一个策略下AF队列和EF队列的带宽的配置必须都采用相同的值的类型,比如都采用绝对值形式,或者都采用百分比形式。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
# 为行为database配置采用AF队列,并且确保最小带宽为200kbps。
[Sysname-behavior-database] queue af bandwidth 200
·     display qos queue cbq interface
·     traffic behavior
5.7.4  queue ef
queue ef命令用来配置类采用EF队列,并配置最大带宽。
undo queue ef命令用来恢复缺省情况。
queue ef bandwidth { bandwidth [ cbs burst ] | pct percentage [ cbs-ratio ratio ] }
undo queue ef
未配置类采用EF队列。
流行为视图
cbs burst:指定承诺突发尺寸,单位为字节,取值范围为32~1000000000,缺省值为bandwidth×25。
cbs-ratio ratio:允许的突发因子,取值范围为25~500,缺省值是25。
该命令在同一个流行为视图下不能与queue afqueue-length同时使用。
在策略下,缺省类default-class不能与queue ef所属behavior关联。
当将类与queue ef所属行为关联时,必须满足以下条件:
·     同一个策略下为AF队列和EF队列指定的带宽之和必须不大于该策略所应用接口的可用带宽。
·     同一个策略下为AF队列和EF队列指定的带宽百分比之和必须不大于100。
·     对于设置百分比形式queue ef bandwidth pct percentage [ cbs-ratio ratio ],CBS = 接口可用带宽×percentage×ratio÷100。
·     对于设置绝对值形式queue ef bandwidth bandwidth [ cbs burst ],CBS = burst,若不指定burst,则CBS = bandwidth×25。
# 配置报文进入EF队列,最大带宽为200kbps,承诺突发尺寸为5000bytes。
[Sysname-behavior-database] queue ef bandwidth 200 cbs 5000
·     traffic behavior
5.7.5  queue sp
queue sp命令用来配置类采用SP队列。
undo queue sp用来恢复缺省情况。
queue sp
undo queue sp
未配置类采用SP队列。
流行为视图
配置了该命令的行为不能与缺省类关联使用。
队列长度为固定值,取值为500。
在同一流行为视图下queue sp不能与queue efqueue-length命令同时使用。
在同一流行为视图下queue sp不能与queue afqueue-length命令同时使用。
RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口不支持配置SP队列。
# 配置报文进入SP队列。
[Sysname-behavior-database] queue sp
·     traffic behavior
5.7.6  queue wfq
queue wfq命令用来为缺省类配置采用公平队列。
undo queue wfq命令用来恢复缺省情况。
queue wfq [ queue-number total-queue-number ]
undo queue wfq
没有为缺省类配置采用公平队列。
流行为视图
queue-number total-queue-number:公平队列的数目,可取的值为16、32、64、128、256、512、1024、2048、4096,即2的幂数,缺省值为256。
配置了该命令的行为仅可以与缺省类关联使用。
该命令可以搭配queue-length命令或wred命令使用。
# 为缺省类配置使用WFQ,队列数为16。
[Sysname] traffic behavior test
[Sysname-behavior-test] queue wfq queue-number 16
[Sysname] qos policy user1
[Sysname-qospolicy-user1] classifier default-class behavior test
·     traffic behavior
5.7.7  queue-length
queue-length命令用来配置最大队列长度,丢弃方式为尾部丢弃。
undo queue-length命令用来恢复缺省情况。
undo queue-length
丢弃方式为尾部丢弃方式,队列长度为64。
流行为视图
queue-length:队列长度,即队列中所能容纳的数据包个数。取值范围为1~1024。
本命令必须在配置了queue afqueue wfq后使用。
配置queue-length后,若执行undo queue afundo queue wfq命令,则queue-length也同时被取消。
RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口不支持配置队列最大长度。
# 配置尾部丢弃,队列长度最大为16。
[Sysname-behavior-database] queue-length 16
·     queue af
·     queue wfq
5.7.8  wred
wred命令用来配置丢弃方式为加权随机早期检测。
undo wred命令用来恢复缺省情况。
wred [ dscp | ip-precedence ]
undo wred
未配置WRED动作。
流行为视图
dscp:表明在为一个包计算丢弃概率时使用的是DSCP值。
ip-precedence:表明在为一个包计算丢弃概率时使用的是IP优先级值。缺省情况下使用的是ip-precedence
对于RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口必须在配置了queue wfq后使用本命令。
如果流行为中同时配置了wredqueue-length命令,则后配置的命令生效。
执行undo wred命令时将删除WRED相关的其他配置。
# 配置采用加权早期检测方式,丢弃概率以IP优先级计算。
[Sysname-behavior-database] queue wfq
[Sysname-behavior-database] wred
·     queue af
·     queue wfq
5.7.9  wred dscp
wred dscp命令用来设置WRED各DSCP的下限、上限和丢弃概率的分母。
undo wred dscp命令用来取消WRED中某个DSCP的丢弃参数配置。
wred dscp dscp-value low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo wred dscp dscp-value
WRED中所有DSCP的下限缺省值为10,上限缺省值为30。
流行为视图
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
low-limit low-limit:WRED下限,单位为报文个数,取值范围为1~1024。
high-limit high-limit:WRED上限,单位为报文个数,取值范围为1~1024。
discard-probability discard-prob:丢弃概率的分母,取值范围为1~255,缺省值为10。
进行本命令配置以前,必须已用wred dscp命令开启了基于DSCP的WRED丢弃方式。
执行undo wred命令将会同时取消wred dscp命令的配置。
取消queue afqueue wfq配置,WRED丢弃参数的配置同时被取消。
# 设置DSCP为3的报文的队列下限为20,上限为40,丢弃概率的分母为15。
[Sysname-behavior-database] wred dscp
[Sysname-behavior-database] wred dscp 3 low-limit 20 high-limit 40 discard-probability 15
·     queue af
·     queue wfq
·     wred
5.7.10  wred ip-precedence
wred ip-precedence命令用来设置WRED各IP优先级的下限、上限和丢弃概率的分母。
undo wred ip-precedence命令用来取消WRED中某个IP优先级的丢弃参数配置。
wred ip-precedence precedence low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo wred ip-precedence precedence
WRED中所有IP优先级的下限缺省值为10,上限缺省值为30。
流行为视图
precedence:IP优先级,取值范围为0~7。
进行本命令配置以前,必须已用wred命令开启了基于IP优先级的WRED丢弃方式。
执行undo wred命令将会同时取消wred ip-precedence命令的配置。
# 设置优先级为3的报文的队列下限为20,上限为40,丢弃概率的分母为15。
[Sysname-behaviro-database] wred ip-precedence
[Sysname-behavior-database] wred ip-precedence 3 low-limit 20 high-limit 40 discard-probability 15
·     queue af
·     queue wfq
·     wred
5.7.11  wred weighting-constant
wred weighting-constant命令用来设置WRED计算平均队列长度的指数。
undo wred weighting-constant命令用来恢复缺省情况。
wred weighting-constant exponent
WRED计算平均队列长度的指数为9。
流行为视图
exponent:指数,取值范围为1~16。
进行本命令配置之前,需先配置queue afqueue wfq命令,并已使用wred命令开启了WRED丢弃方式。
执行undo wred命令将会同时取消wred weighting-constant命令的配置。
RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口不支持配置设置WRED计算平均队列长度的指数。
# 配置计算平均队列长度的指数为6。
[Sysname-behavior-database] wred weighting-constant 6
·     queue af
·     queue wfq
·     wred
5.8  报文信息预提取命令
5.8.1  qos pre-classify
qos pre-classify命令用来开启报文信息预提取功能。
undo qos pre-classify命令用来关闭报文信息预提取功能。
qos pre-classify
报文信息预提取功能处于关闭状态。
Tunnel接口视图
# 在Tunnel接口上开启报文信息预提取功能。
[Sysname] interface tunnel 1
[Sysname-Tunnel1] qos pre-classify
6 拥塞避免
RT-FIP-680单板上的POS端口和开启QoS队列增强功能后的RT-FIP-680单板固定端口不支持配置拥塞避免。
6.1  WRED配置命令
6.1.1  display qos wred interface
display qos wred interface命令用来显示接口上WRED配置情况和统计信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示除VA(Virtual Access,虚拟访问)接口外所有接口的WRED配置情况和统计信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
如指定接口为Virtual-Template接口,将显示继承该Virtual-Template接口的所有Virtual-Access接口下的WRED配置情况和统计信息,Virtual-Template本身无QoS信息显示。
# 显示所有接口的WRED配置情况和统计信息。
<Sysname> display qos wred interface
Interface: GigabitEthernet2/0/4
 Current WRED configuration:
 Exponent: 9 (1/512)
 Pre  Low   High  Dis-prob Random-discard  Tail-discard
0    10    30    10       0               0
1    10    30    10       0               0
2    10    30    10       0               0
3    10    30    10       0               0
4    10    30    10       0               0
5    10    30    10       0               0
6    10    30    10       0               0
7    10    30    10       0               0
表6-1 display qos wred interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Exponent
计算平均队列长度的指数
Pre
报文的IP优先级
Low
队列下限
High
队列上限
Dis-prob
计算丢弃概率时的分母
Random-discard
随机丢弃的报文的数目
Tail-discard
尾丢弃报文的数目
当前WRED的配置情况
6.1.2  qos wred dscp
qos wred dscp命令用来设置各DSCP优先级的下限、上限和丢弃概率的分母。
undo qos wred dscp命令用来恢复缺省情况。
qos wred dscp dscp-value low-limit low-limit high-limit high-limit discard-probability discard-prob
undo qos wred dscp dscp-value
下限缺省值为10,上限缺省值为30,丢弃概率的分母缺省值为10。
discard-probability discard-prob:丢弃概率的分母,取值范围为1~255。
必须先使用qos wred dscp enable在接口上应用基于DSCP的WRED后,才可以进行本配置。
阈值限制的是平均队列长度。
# 在接口上设置DSCP优先级为63的报文的队列下限为20,上限为40,丢弃概率的分母为15。
[Sysname-GigabitEthernet2/0/1] qos wred dscp enable
[Sysname-GigabitEthernet2/0/1] qos wred dscp 63 low-limit 20 high-limit 40 discard-probability 15
·     display qos wred interface
·     qos wred enable
6.1.3  qos wred enable
qos wred enable命令用来在接口上开启WRED。
undo qos wred enable命令用来恢复缺省情况。
qos wred [ dscp | ip-precedence ] enable
undo qos wred [ dscp | ip-precedence ] enable
队列丢弃方法为尾丢弃。
dscp:表明计算丢弃概率时使用的是DSCP值。
ip-precedence:表明计算丢弃概率时使用的是IP优先级值。缺省情况下使用的是ip-precedence
必须先在接口上配置qos wfq命令,才能配置本命令。
# 在GigabitEthernet2/0/1接口上开启WRED,丢弃概率以IP优先级计算。
[Sysname-GigabitEthernet2/0/1] qos wred ip-precedence enable
·     qos wred enable
6.1.4  qos wred ip-precedence
qos wred ip-precedence命令用来设置IP优先级的下限、上限和丢弃概率的分母。
undo qos wred ip-precedence命令用来恢复缺省情况。
qos wred ip-precedence ip-precedence low-limit low-limit high-limit high-limit discard-probability discard-prob
undo qos wred ip-precedence ip-precedence
ip-precedence ip-precedence:IP优先级,取值范围为0~7。
必须先使用qos wred enable在接口上应用基于IP优先级的WRED后,才可以进行本配置。
阈值限制的是平均队列长度。
# 在接口上设置IP优先级为3的报文的队列下限为20,上限为40,丢弃概率的分母为15。
[Sysname-GigabitEthernet2/0/1] qos wred ip-precedence 3 low-limit 20 high-limit 40 discard-probability 15
·     qos wred enable
6.1.5  qos wred weighting-constant
qos wred weighting-constant命令用来设置WRED计算平均队列长度的指数。
undo qos wred weighting-constant命令用来恢复缺省情况。
qos wred weighting-constant exponent
WRED计算平均队列长度的指数为9。
weighting-constant exponent:计算平均队列长度的指数,取值范围为1~16。
必须先使用qos wred enable在接口上应用WRED后,才可以配置WRED的参数。
# 在GigabitEthernet2/0/1接口上配置计算平均队列长度的指数为6。
[Sysname-GigabitEthernet2/0/1] qos wred enable
[Sysname-GigabitEthernet2/0/1] qos wred weighting-constant 6
·     qos wred enable
7 QPPB
7.1  QPPB配置命令
7.1.1  bgp-policy
bgp-policy命令用来配置QPPB功能,即通过BGP传播路由策略中设置的apply ip-precedenceapply qos-local-id信息。
undo bgp-policy命令用来恢复缺省情况。
bgp-policy { destination | source } { ip-prec-map | ip-qos-map } *
undo bgp-policy { destination | source } [ ip-prec-map | ip-qos-map ] *
未配置QPPB功能。
destination:使用目的IP查找路由。
source:使用源IP查找路由。如果指定本参数,则以源IP为目的进行反向查找。
ip-prec-map:设置IP优先级。
ip-qos-map:设置QoS本地ID。
本配置只对接口接收的报文生效。
在MPLS L3VPN网络中,PE公网接口入方向QoS业务在本配置之前进行;其他网络环境中QoS业务在本配置之后进行。
如果存在两条bgp-policy命令,分别指定sourcedestination,后者的设置操作会覆盖前者。
# 在接口GigabitEthernet2/0/1上根据源IP查找路由获得IP优先级和QoS本地ID。
[Sysname-GigabitEthernet2/0/1] bgp-policy source ip-prec-map ip-qos-map
·     apply ip-precedence (三层技术-IP路由命令参考/路由策略)
·     apply qos-local-id (三层技术-IP路由命令参考/路由策略)
·     route-policy (三层技术-IP路由命令参考/路由策略)
