10-Segment Routing命令参考
01-SR-MPLS命令
本章节下载 01-SR-MPLS命令  (497.39 KB)
01-SR-MPLS命令
目
1 SR-MPLS
1.1 SR-MPLS配置命令
1.1.1 display bgp egress-engineering ipv4
1.1.2 display bgp egress-engineering peer-set
1.1.3 display bgp segment-routing label-range
1.1.4 display bgp segment-routing prefix-sid-map
1.1.5 display isis segment-routing adjacency
1.1.6 display isis segment-routing global-block
1.1.7 display isis segment-routing prefix-sid-map
1.1.8 display mpls static-sr-mpls
1.1.9 display mpls static-sr-mpls prefix
1.1.10 display ospf segment-routing global-block
1.1.11 display ospf segment-routing prefix-sid-map
1.1.12 display segment-routing label-block
1.1.13 display segment-routing mapping-server prefix-sid-map
1.1.14 egress-engineering peer-set
1.1.15 fast-reroute microloop-avoidance enable
1.1.16 fast-reroute microloop-avoidance rib-update-delay
1.1.17 fast-reroute ti-lfa
1.1.18 global-block
1.1.19 isis adjacency-sid
1.1.20 isis fast-reroute ti-lfa disable
1.1.21 isis prefix-sid
1.1.22 local-block
1.1.23 mapping-server prefix-sid-map
1.1.24 mpls te static-sr-mpls
1.1.25 ospf adjacency-sid
1.1.26 ospf fast-reroute ti-lfa disable
1.1.27 ospf prefix-sid
1.1.28 peer egress-engineering
1.1.29 peer peer-set
1.1.30 segment-routing
1.1.31 segment-routing adjacency enable
1.1.32 segment-routing global-block
1.1.33 segment-routing label-advertise
1.1.34 segment-routing mapping-server advertise-local
1.1.35 segment-routing mapping-server receive
1.1.36 segment-routing microloop-avoidance enable
1.1.37 segment-routing microloop-avoidance rib-update-delay
1.1.38 segment-routing mpls
1.1.39 segment-routing prefix-sid-map
1.1.40 segment-routing sr-prefer
1.1.41 static-sr-mpls adjacency
1.1.42 static-sr-mpls lsp
1.1.43 static-sr-mpls prefix
1 SR-MPLS
1.1  SR-MPLS配置命令
display bgp egress-engineering ipv4命令用来显示BGP-EPE信息。
display bgp [ instance instance-name ] egress-engineering ipv4 [ ipv4-address ] [ verbose ]
ipv4-address:显示指定对等体的BGP-EPE信息。ipv4-address为对等体的IPv4地址。指定的对等体必须已经创建。如果不指定本参数,则显示所有对等体的BGP-EPE信息。
verbose:显示BGP-EPE的详细信息。如果未指定本参数,则显示BGP-EPE的简要信息。
# 显示BGP-EPE的简要信息。
<Sysname> display bgp egress-engineering ipv4
BGP peering segment type: Set
  PeerSet          : 192.168.1.2
  Local AS number  : 1
  Remote AS number : 2
  Local router ID   : 1.1.1.3
  Remote router ID  : 1.1.1.4
  OriginNextHop    : 192.168.1.2
  RelyNextHop      : 192.168.1.2
  Interface        : GE2/0/1
  Label            : 24002
# 显示指定对等体的BGP-EPE的简要信息。
<Sysname> display bgp egress-engineering ipv4 192.168.1.5
BGP peering segment type: Node-Adjacency
  PeerNodeAdj       : 192.168.1.5
  Local AS number   : 1
  Remote router ID  : 1.1.1.5
  OriginalNextHop   : 192.168.1.5
  RelayNextHop      : 192.168.1.5
  Interface         : GE2/0/5
# 显示指定对等体的BGP-EPE的详细信息。
<Sysname> display bgp egress-engineering ipv4 1.1.1.1 verbose
BGP peering segment type : Node
  PeerAdj Num              : 2
  PeerNode                 : 1.1.1.1
  Local AS number          : 1
  Remote As number         : 2
  Local interface address  : 2.2.2.2
  Remote interface address : 1.1.1.1
  OriginalNextHop          : 1.1.1.1
  RelayNextHop             : 100.0.27.7
  RelayNextHop             : 100.0.28.7
  Label                    : 15000
  TunnelPolicy             : abc
  BGP peering segment type : Adjacency
    PeerAdj                  : 100.0.27.7
    Local AS number          : 1
    Local router ID          : 1.1.1.1
    Remote router ID         : 2.2.2.2
    OriginalNextHop          : 100.0.27.7
    Local interface address  : 100.0.27.2
    Remote interface address : 100.0.27.7
    Interface                : GE2/0/1
    Label                    : 24001
    TunnelPolicy             : abc
    PeerAdj                  : 100.0.28.7
    Local AS number          : 1
    OriginalNextHop          : 100.0.28.7
    Local interface address  : 100.0.28.2
    Remote interface address : 100.0.28.7
    Interface                : GE2/0/2
    Label                    : 24002
    TunnelPolicy             : abc
表1-1 display bgp egress-engineering ipv4命令显示信息描述表
指定对等体的BGP peering segments类型:
·     Node:表示节点类型
·     Adjacency:表示邻接类型
·     Set:表示Set类型
·     Node-Adjacency:表示节点类型和邻居类型
PeerAdj Num
对等体邻接数量
Local AS number
本地的AS号
Remote AS number
远端的AS号
Local router ID
本地的RouterID
Remote router ID
远端的RouterID
本地的接口地址
远端的接口地址
建立邻居的接口信息
OriginalNextHop
原始下一跳IP地址
RelayNextHop
迭代下一跳IP地址
Label
标签信息
TunnelPolicy
隧道策略信息
display bgp egress-engineering peer-set命令用来显示BGP-EPE Peer Set组的信息。
display bgp [ instance instance-name ] egress-engineering peer-set [ peer-set-name ]
peer-set-name:显示指定BGP-EPE Peer Set组的信息。peer-set-name为BGP-EPE Peer Set组名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则显示所有BGP-EPE Peer Set组的信息。
# 显示所有BGP-EPE Peer Set组的信息。
<Sysname> display bgp egress-engineering peer-set
  BGP egress peering segment peer-set: a
  PeerSet label : 2172
  Members: 0
  BGP egress peering segment peer-set: b
  PeerSet label : 5555
  Members: 1
         BGP PeerNodeAdj : 3.3.3.3
  BGP egress peering segment peer-set: c
  PeerSet label: 65001
  Label        : 65001
  Members: 2
         BGP PeerNode: 1.1.1.1
         BGP PeerAdj : 10.1.1.1
  PeerSet name: d
  PeerSet label: 65002
  Members: 2
         BGP PeerNode: 2.2.2.2
         BGP PeerAdj : 11.1.1.1
表1-2 display bgp egress-engineering peer-set命令显示信息描述表
BGP-EPE Peer Set组名称
PeerSet label
BGP-EPE Peer Set组的生效标签
Label
BGP-EPE Peer Set组的指定标签
Members
加入BGP-EPE Peer Set组的对等体数量
BGP PeerNode
节点类型对等体的节点地址
BGP PeerAdj
邻接类型对等体的邻接地址
BGP PeerNodeAdj
节点邻接类型对等体的邻接地址
display bgp segment-routing label-range命令用来显示BGP SR的标签值范围。
display bgp [ instance instance-name ] segment-routing label-range
# 显示BGP SR标签值范围信息。
<Sysname> display bgp segment-routing label-range
 BGP peering segment labels:
    24001-69631
 Prefix labels:
    16000-24000
表1-3 display bgp segment-routing label-range命令显示信息描述表
BGP peering segments标签值
Prefix labels
BGP prefix segments标签值
display bgp segment-routing prefix-sid-map命令用来显示BGP SR前缀地址和SID的映射信息。
display bgp [ instance instance-name ] segment-routing prefix-sid-map [ ip-address mask-length | verbose ]
instance instance-name:显示指定BGP实例的信息。instance-name为BGP实例的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示default实例的信息。
ip-address mask-length:显示指定范围内的IP地址前缀和SID的映射信息。mask-length表示掩码长度,取值范围为1~32。如果未指定本参数,则显示所有前缀和SID的映射信息。
verbose:显示前缀和SID的详细映射信息。如果未指定本参数,则显示前缀和SID的简要映射信息。
# 显示前缀地址1.1.1.1和SID的映射信息。
<Sysname> display bgp segment-routing prefix-sid-map 1.1.1.1 32
Prefix              SID index
1.1.1.1/32          10
# 显示所有前缀地址和SID的简要映射信息。
Number of mappings: 2
Prefix              SID index   Range
1.1.1.1/32          10          100
2.2.2.2/32          256         520
# 显示所有前缀地址和SID的详细映射信息。
<Sysname> display bgp segment-routing prefix-sid-map verbose
Prefix: 1.1.1.1/32
  SID index     : 10
  Range         : 100
  Last prefix   : 1.1.1.100/32
  Last SID index: 109
Prefix: 2.2.2.2/32
  SID index     : 256
  Range         : 520
  Last prefix   : 2.2.4.9/32
  Last SID index: 775
表1-4 display bgp segment-routing prefix-sid-map命令显示信息描述表
Prefix
地址前缀
SID index
分配的SID的起始索引值
Range
连续分配SID的个数
Last prefix
最后一个地址前缀
Last SID index
为最后一个地址前缀分配的SID索引值
display isis segment-routing adjacency命令用来显示IS-IS SR的邻接段信息。
display isis segment-routing adjacency [ process-id ]
process-id:显示指定进程的IS-IS SR邻接段信息。process-id为IS-IS进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的IS-IS SR邻接段信息。
# 显示IS-IS 1的SR邻接段信息。
<Sysname> display isis segment-routing adjacency 1
               Segment routing adjacency path information for IS-IS(1)
SystemID            Interface       Nexthop         Label          Type
0000.0000.0011      GE2/0/1         10.123.110.21 24122          L1
0000.0000.0012      GE2/0/2         192.168.56.21 24121          L1
表1-5 display isis segment-routing adjacency命令显示信息描述表
SystemID
邻居的系统ID
建立邻居的接口信息
Nexthop
下一跳信息
Label
入标签信息
接口的链路邻接关系类型
display isis segment-routing global-block命令用来显示IS-IS SR的全局标签段信息。
display isis segment-routing global-block [ level-1 | level-2 ] [ process-id ]
level-1:显示Level-1标签段信息。
level-2:显示Level-2标签段信息。
process-id:显示指定IS-IS进程的SR全局标签段信息。process-id为IS-IS进程号,取值范围为1~65535。如果未指定本参数,将显示所有IS-IS进程的SR全局标签段信息。
如果不指定级别,将同时显示Level-1和level-2的标签段信息。
# 显示IS-IS 1的SR全局标签段信息。
<Sysname> display isis segment-routing global-block 1
             Segment routing global block information for IS-IS(1)
                          Level-1 SRGB
System ID                          Base                Range
0000.0000.0011                     16666               5557
0000.0000.0012                     18012               4001
表1-6 display isis segment-routing global-block命令显示信息描述表
System ID
邻居的系统ID
Base
SRGB标签段基值,即SRGB标签段中的最小标签值
Range
SRGB包含的标签数目
·     segment-routing global-block
display isis segment-routing prefix-sid-map命令用来显示IS-IS SR的SID标签映射信息。
display isis segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
active-policy:显示生效的SID标签映射信息。
backup-policy:显示未生效的SID标签映射信息。
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程号的标签映射信息。未指定本参数时,显示所有ISIS进程的SID标签映射信息。
verbose:显示指定类型的SID标签映射的详细信息。未指定本参数时,显示指定类型的SID标签映射的简要信息。
未指定active-policybackup-policy参数时,表示同时显示生效和未生效的SID标签映射信息。
# 显示生效的SID标签映射简要信息。
<Sysname> display isis segment-routing prefix-sid-map active-policy
         ISIS 1 - Active policy
Number of mappings: 5
Prefix               SID index    Range        Flags
2.2.2.2/32           10           10           -
3.3.3.3/32           300          1            -
8.8.8.8/32           600          20           -
11.11.11.11/32       100          10           -
12.12.12.1/32        44           3            -
# 显示生效的SID标签映射详细信息。
<Sysname> display isis segment-routing prefix-sid-map active-policy verbose
Prefix 1.1.1.1/32
    Source        : Local
    Router ID     : 1010.1020.1030
    Level         : Not set
    SID index     : 100
    Range         : 1
    Last prefix   : 1.1.1.1/32
    Last SID index: 100
    Flags         : -
Prefix 2.2.2.2/32
    Source        : Remote
    Router ID     : 1010.1020.1040
    Level         : L1
    SID index     : 200
    Range         : 1
    Last prefix   : 2.2.2.2/32
    Last SID index: 200
    Flags         : -
# 显示未生效的SID标签映射简要信息。
<Sysname> display isis segment-routing prefix-sid-map backup-policy
         ISIS 1 - Backup policy
Number of mappings: 4
2.2.2.2/32           200          30           -
8.8.8.8/32           600          20           -
2.2.2.2/32           10           10           -
# 显示所有SID标签映射简要信息。
         ISIS 1 – Both active policy and backup policy
Number of mappings: 9
2.2.2.2/32           10           10           -
2.2.2.2/32           10           10           -
2.2.2.2/32           200          30           -
3.3.3.3/32           300          1            -
8.8.8.8/32           600          20           -
8.8.8.8/32           600          20           -
表1-7 display isis segment-routing prefix-sid-map命令显示信息描述表
ISIS 1 – Active policy
IS-IS进程1下生效的SID标签映射信息
ISIS 1 – Backup policy
IS-IS进程1下未生效的SID标签映射信息
IS-IS进程1下所有SID标签映射信息
Prefix
地址前缀信息
SID index
分配的SID的索引的起始值
Range
指定要连续分配SID的个数
Flags
映射标志位,取值为:
·     A:Attached,表示当前被映射前缀是本地直连
·     -:表示未设置映射标志位
Source
SID映射关系来源,取值为:
·     Local:本端配置的SID映射关系
·     Remote:对端配置的SID映射关系
Router ID
路由发布者ID
Level
路由发布者Level,取值为:
·     L1:Level-1的IS-IS路由
·     L2:Level-2的IS-IS路由
·     Not set:表示路由通过本地发布
Last prefix
最后一个地址前缀
Last SID index
为最后一个地址前缀分配的SID
display mpls static-sr-mpls命令用来显示静态SRLSP信息或静态配置的邻接段信息。
display mpls static-sr-mpls { lsp [ lsp-name ] | adjacency [ adjacency-path-name ] }
lsp lsp-name:显示指定静态SRLSP的信息。lsp-name表示静态SRLSP的名称,为1~15个字符的字符串,区分大小写。如果不指定该参数,则显示所有静态SRLSP信息。
adjacency adjacency-path-name:显示指定邻接路径的信息。adjacency-path-name表示邻接路径的名称,为1~15个字符的字符串,区分大小写。如果不指定该参数,则显示所有邻接路径信息。
# 显示所有基于MPLS的静态SRLSP信息。
<Sysname> display mpls static-sr-mpls lsp lsp1
Type           : LSP
In-Label       : -
Out-Label      : 60,70,80
Out-Interface  : -
Nexthop        : -
State          : Up
表1-8 display mpls static-sr-mpls命令显示信息描述表
Name
静态SRLSP或邻接路径的名称
静态Segment Routing信息类型,取值包括:
·     LSP:表示静态SRLSP信息
·     Adjacency:表示邻接路径信息
In-Label
入标签值
Out-Label
出标签值
Out-Interface
出接口
Nexthop
下一跳
静态SRLSP或邻接路径的状态,取值包括:
·     Down:表示不可用
·     Up:表示可用
·     static-sr-mpls adjacency
·     static-sr-mpls lsp
display mpls static-sr-mpls prefix命令用来显示静态配置的前缀段信息。
display mpls static-sr-mpls prefix [ path lsp-name | destination ip-address [ mask | mask-length ] ]
path lsp-name:显示指定静态SRLSP的前缀段信息。lsp-name表示静态SRLSP的名称,为1~15个字符的字符串,区分大小写。
destination ip-address [ mask | mask-length ]:显示指定目的地址的前缀段信息。ip-address为指定目的IP地址,mask为目的IP地址掩码,mask-length为目的IP地址掩码长度,取值范围为0~32。
如果不指定任何参数,则显示所有静态配置的前缀段信息。
# 显示所有静态配置的前缀段的信息。
<Sysname> display mpls static-sr-mpls prefix
Prefix Name    : prefixname
Destination    : 2.2.2.2/32
In-Label       : 1024
Active         : Yes(1)
Out-Interface  : GE2/0/1
Nexthop        : 10.0.0.2
Out-Label      : 600000
Status         : up
Out-Interface  : GE2/0/2
Nexthop        : 11.0.0.2
Out-Label      : 600002
Status         : down(No Route)
Out-Interface  : GE2/0/3
Nexthop        : 12.0.0.2
Out-Label      : 600001
Status         : down(No Mpls)
表1-9 display mpls static-sr-mpls prefix命令显示信息描述表
Prefix Name
前缀路径的名称
Destination
目的地址
In-Label
入标签值
Active
前缀路径的状态,取值包括:
·     Yes(count):表示前缀路径激活,count表示激活的出方向数量
·     No:表示前缀路径未激活
Out-Interface
出接口
Nexthop
下一跳
Out-Label
出标签值
Status
出方向状态,取值包括:
·     Down:表示该出方向未激活(No Route表示没有路由,No Mpls表示出接口没有使能MPLS)
·     Up:表示该出方向激活
·     Duplicate:表示出方向冲突
·     static-sr-mpls prefix
display ospf segment-routing global-block命令用来显示OSPF SR的全局标签段信息。
display ospf [ process-id ] [ area area-id ] segment-routing global-block
process-id:显示指定OSPF进程的SR全局标签段信息,process-id为OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的全局标签段信息。
area area-id:显示指定区域的全局标签段信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。如果未指定本参数,将显示所有区域的全局标签段信息。
# 显示所有OSPF进程的全局标签段信息。
<Sysname> display ospf segment-routing global-block
             Segment Routing Global Block
                     Area: 0.0.0.0
 Router ID       Min SID         Max SID         Total
 1.1.1.1         16000           24000           8001
 2.2.2.2         18000           18999           1000
 3.3.3.3         16000           24000           8001
 4.4.4.4         17000           17999           1000
 5.5.5.5         16000           16999           1000
表1-10 display ospf segment-routing global-block命令显示信息描述表
Router ID
本地及邻居的Router ID
Min SID
Max SID
SRGB标签段中的最大标签值
Total
SRGB包含的标签数目
display ospf segment-routing prefix-sid-map命令用来显示OSPF SR的SID标签映射信息。
display ospf segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
process-id:显示指定OSPF进程号的标签映射信息,取值范围为1~65535。未指定本参数时,显示所有SID标签映射信息。
verbose:显示SID标签映射的详细信息。未指定本参数时,显示SID标签映射的简要信息。
未指定active-policybackup-policy参数时,表示显示所有SID标签映射信息。
# 显示生效的SID标签映射简要信息。
<Sysname> display ospf segment-routing prefix-sid-map active-policy
              OSPF 1 - Active policy
Flags: IA - Inter-Area, L – Local, R - Remote
1.1.1.11/32          10           10           L/-
1.1.1.22/32          20           20           R/-
# 显示生效的SID标签映射详细信息。
<Sysname> display ospf segment-routing prefix-sid-map active-policy verbose
Prefix 1.1.1.11
    Source        : Local
    Router ID     : 10.1.1.1
    Area ID       : Not set
    LS ID         : Not set
    SID index     : 10
    Range         : 10
    Last prefix   : 1.1.1.20
    Last SID index: 19
    Flags         : -
Prefix 1.1.1.22
    Source        : Remote
    Router ID     : 10.2.1.1
    Area ID       : 0.0.0.1
    LS ID         : 7.0.0.0
    SID index     : 20
    Range         : 20
    Last prefix   : 1.1.1.41
    Last SID index: 39
    Flags         : -
<Sysname> display ospf segment-routing prefix-sid-map backup-policy
              OSPF 1 - Backup policy
Number of mappings: 1
1.1.1.33/32          30           30           R/IA
# 显示所有SID标签映射简要信息。
   OSPF 1 - Both active policy and backup policy
Number of mappings: 3
表1-11 display ospf segment-routing prefix-sid-map命令显示信息描述表
OSPF 1 – Active policy
OSPF进程1下生效的SID标签映射信息
OSPF 1 – Backup policy
OSPF进程1下未生效的SID标签映射信息
OSPF 1 – Both active policy and backup policy
OSPF进程1下所有SID标签映射信息
Prefix
地址前缀信息
SID index
分配的SID索引的起始值
Range
指定要连续分配SID的个数
Flags
映射标志位,取值为:
·     IA:Inter-Area,区域渗透标记,表示当前被映射前缀非本区域产生
·     L:本端映射
·     R:远端映射
·     -:表示未设置映射标志位
Source
SID映射关系来源,取值为:
Router ID
路由发布者ID
Area ID
区域ID,本端映射显示为Not set
LS ID
链路状态ID,本端映射显示为Not set
Last prefix
最后一个地址前缀
Last SID index
为最后一个地址前缀分配的SID
display segment-routing label-block命令用来显示SR标签段的信息。
display segment-routing label–block [ protocol { isis | ospf } ]
protocol:显示指定协议的SR标签段信息。如果未指定本参数,则显示所有协议的SR标签段信息。
isis:显示IS-IS协议的SR标签段信息。
ospf:显示OSPF协议的SR标签段信息。
# 显示所有协议的SR标签段的信息。
<Sysname> display segment-routing label-block
Default label block:
  SRLB: 15000-15999
  SRGB: 16000-55999
Configurate label block:
  SRLB: 200000-210000
  SRGB: 16000-17000
Type      Protocol    Process-ID   Label range     State
SRLB      Global      -            200000-210000   Active
SRGB      Global      -            16000-17000     Active
表1-12 display segment-routing label-block命令显示信息描述表
Default Label Block
缺省的标签段
Configurate Label Block
用户配置的标签段
SRLB
分段路由本地标签段
SRGB
分段路由全局标签段
标签类型:
·     SRGB
·     SRLB
Protocol
使用SRGB或SRLB的协议类型:
·     ISIS
·     OSPF
·     Global:协议进程下未配置标签范围时使用全局SRLB或SRGB标签范围
Process-ID
进程ID,使用Global的SRLB或SRGB标签范围时,显示为“-”
Label range
标签范围
标签段是否生效:
·     Active:表示标签段生效,可以使用该标签段
·     Inactive:表示标签段未生效,不可以使用该标签段
display segment-routing mapping-server prefix-sid-map命令用来显示前缀地址和SID的映射关系。
display segment-routing mapping-server prefix-sid-map [ ip-address mask-length | verbose ]
ip-address:指定IP地址前缀,点分十进制格式。未指定本参数时,显示所有配置的前缀地址和SID的映射关系。
mask-length:掩码长度,取值范围1~32。
verbose:显示所有配置的前缀地址和SID的详细映射信息。未指定本参数时,显示所有配置的前缀地址和SID的映射关系。
# 显示前缀地址1.1.1.1和SID的映射关系。
<Sysname> display segment-routing mapping-server prefix-sid-map 1.1.1.1 32
                    SRMS mappings
Prefix              SID index       Flags
1.1.1.1/32          10              A
# 显示所有配置的前缀地址和SID的映射关系。
                    SRMS mappings
1.1.1.1/32          10          100         A
2.2.2.2/32          256         520         -
# 显示所有配置的前缀地址和SID的详细映射关系。
<Sysname> display segment-routing mapping-server prefix-sid-map verbose
                    SRMS mappings
Prefix 1.1.1.1/32
  SID index     : 10
  Range         : 100
  Last prefix   : 1.1.1.100/24
  Last SID index: 109
  Flags         : A
Prefix 2.2.2.2/32
  SID index     : 256
  Range         : 520
  Last prefix   : 2.2.4.9/24
  Last SID index: 775
  Flags         : -
表1-13  display segment-routing mapping-server prefix-sid-map命令显示信息描述表
Prefix
地址前缀信息
SID index
分配的SID的起始索引值
Range
指定要连续分配SID的个数
Flags
映射标志位,取值为:
·     A:Attached,表示当前被映射前缀是否是本地直连
·     -:表示未设置映射标志位
Last Prefix
最后一个地址前缀
Last SID index
为最后一个地址前缀分配的SID
egress-engineering peer-set命令用来创建BGP-EPE Peer Set组。
undo egress-engineering peer-set命令用来删除BGP-EPE Peer Set组。
egress-engineering peer-set peer-set-name [ label label-value ]
undo egress-engineering peer-set peer-set-name
不存在BGP-EPE Peer Set组。
BGP实例视图
peer-set-name:指定BGP-EPE Peer Set组名称,为1~63个字符的字符串,区分大小写。
label label-value:配置BGP-EPE Peer Set组的静态SID。label-value为静态SID值,取值范围为16~1048575。如果未指定本参数,则设备会为BGP-EPE Peer Set组自动分配SID。
BGP-EPE用来为域间路径分配BGP Peer SID。Peer SID通过BGP LS扩展传递给网络控制器。控制器通过对IGP SID和BGP Peer SID进行合理编排,实现跨域最优路径转发。
PeerSet SID即手工规划的邻居组,可以将一组BGP邻居规划为一个Set,基于该组分配SID。通过PeerSet SID转发时可以对应多个出接口。
用户可以执行display mpls label命令,查看SID使用状态。如果配置的BGP-EPE SID已经被其他协议使用,则该SID不可用。此后如果该SID的使用状态变为Idle时,则先删除BGP-EPE的配置,再重新配置BGP-EPE,该SID才可以被使用。
# 创建BGP-EPE Peer Set组bgpepe,并指定静态SID 5555。
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering peer-set bgpepe label 5555
·     display mpls label(MPLS命令参考/MPLS基础)
·     peer egress-engineering
·     peer peer-set
fast-reroute microloop-avoidance enable命令用来开启FRR正切防微环功能。
undo fast-reroute microloop-avoidance enable命令用来关闭FRR正切防微环功能。
IS-IS IPv4单播地址族视图:
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
OSPF视图:
FRR正切防微环功能处于关闭状态。
IS-IS IPv4单播地址族视图
OSPF视图
level-1:开启Level-1区域的FRR正切防微环功能。
level-2:开启Level-2区域的FRR正切防微环功能。
应用了TI-LFA快速重路由功能的组网环境中,若某节点或者链路发生故障,流量会切换到TI-LFA计算的备份路径。但是,如果此时备份路径上的设备还没有完成收敛,则会在源节点(故障节点或者链路的前一节点)和备份路径上的设备之间形成环路,直到备份路径上的设备完成收敛。
为了解决上述问题,节点或者链路故障以后,首先流量切换到TI-LFA计算的备份路径,然后源节点延迟一段时间收敛(延迟时间可通过fast-reroute microloop-avoidance rib-update-delay命令配置),等待备份路径上的设备收敛完成以后,源节点开始收敛。
未指定level-1level-2参数时,表示开启或关闭所有Level区域的FRR正切防微环功能。
本命令仅在源节点配置。
# 开启IS-IS进程1的FRR正切防微环功能。
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] fast-reroute microloop-avoidance enable
# 开启OSPF进程1的FRR正切防微环功能。
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute microloop-avoidance enable
·     fast-reroute microloop-avoidance rib-update-delay
fast-reroute microloop-avoidance rib-update-delay命令用来配置FRR正切防微环延迟时间。
undo fast-reroute microloop-avoidance rib-update-delay命令用来恢复缺省情况。
IS-IS IPv4单播地址族视图:
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance rib-update-delay [ level-1 | level-2 ]
OSPF视图:
FRR正切防微环延迟时间为5000毫秒。
IS-IS IPv4单播地址族视图
OSPF视图
delay-time:FRR正切防微环的延迟时间,取值范围为1~60000,单位为毫秒。
level-1:配置Level-1区域的FRR正切防微环的延迟时间。
level-2:配置Level-2区域的FRR正切防微环的延迟时间。
未指定level-1level-2参数时,表示配置所有Level区域的FRR正切防微环的延迟时间。
本命令仅在源节点配置。
# 配置IS-IS进程1中Level-1区域的FRR正切防微环的延迟时间为6000毫秒。
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute microloop-avoidance rib-update-delay 6000 level-1
# 配置OSPF进程1中FRR正切防微环的延迟收敛时间为6000毫秒。
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute microloop-avoidance rib-update-delay 6000
fast-reroute ti-lfa命令用来开启TI-LFA(Topology-Independent Loop-free Alternate,拓扑无关无环备份)快速重路由功能。
undo fast-refroute ti-lfa命令用来关闭TI-LFA快速重路由功能。
IS-IS IPv4单播地址族视图:
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
undo fast-reroute ti-lfa [ level-1 | level-2 ]
OSPF视图:
TI-LFA快速重路由功能处于关闭状态。
IS-IS IPv4单播地址族视图
OSPF视图
per-prefix:仅当路由由多源发布时,指定本参数可以为每条路由的每个发布源计算备份信息。如果未指定本参数,则设备为每条路由计算备份信息。
route-policy route-policy-name:指定仅为通过路由策略的前缀开启TI-LFA快速重路由功能。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
host:为主机路由开启TI-LFA快速重路由功能。
level-1:开启Level-1区域的TI-LFA快速重路由功能。
level-2:开启Level-2区域的TI-LFA快速重路由功能。
TI-LFA快速重路由功能为Segment Routing隧道提供链路及节点的保护。当某处链路或节点故障时,数据流量会快速切换到备份路径继续转发,从而最大程度上避免数据流量的丢失。
配置TI-LFA快速重路由功能前,需要在IS-IS IPv4单播地址族视图或OSPF视图下执行以下命令:
·     segment-routing mpls
·     fast-reroute lfa,只有开启了LFA快速重路由功能,TI-LFA快速重路由功能才能生效,否则配置不生效。
未指定route-policy route-policy-namehost参数时,设备为所有路由计算备份信息。
只有开启了相应Level的LFA快速重路由功能,TI-LFA快速重路由功能才能在指定Level生效,否则配置不生效。
未指定level-1level-2参数时,表示开启或关闭所有Level区域的TI-LFA快速重路由功能。
# 开启IS-IS进程1的快速重路由功能,并为所有路由通过TI-LFA算法选取备份下一跳信息。
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute ti-lfa
# 开启OSPF进程1的TI-LFA快速重路由功能,并为所有路由通过TI-LFA算法计算备份下一跳信息。
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute ti-lfa
·     fast-reroute(三层技术-IP路由命令参考/IS-IS)
·     route-policy(三层技术-IP路由命令参考/路由策略)
1.1.18  global-block
global-block命令用来配置基于MPLS的SRGB的标签范围。
undo global-block命令用来恢复缺省情况。
global-block minimum-value maximum-value
undo global-block
基于MPLS的SRGB的最小标签值为16000 ,最大标签值为24000。
Segment Routing视图
minimum-value:SRGB中的最小标签值,取值范围为15000~1048574。
maximum-value:SRGB中的最大标签值,取值范围为10242~1048575。
Segment Routing视图下配置的SRGB用于Prefix Segment和BGP Prefix SID。当IS-IS视图和OSPF视图下未配置SRGB时,也会使用Segment Routing视图配置的SRGB。
配置SRGB的范围时,若已配置前缀SID,需确保配置的SRGB标签范围包含已配置的前缀SID值,否则SRGB配置失败。
# 配置SRGB标签范围为200000~220000。
[Sysname] segment-routing
[Sysname-segment-routing] global-block 200000 220000
isis adjacency-sid命令用来配置IS-IS Adjacency SID。
undo isis adjacency-sid命令用来恢复缺省情况。
isis adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
undo isis adjacency-sid { absolute absolute-value | index index-value }
未配置ISIS Adjacency SID。
absolute absolute-value:指定Adjacency SID绝对值,取值范围为15000~1048575。
index index-value:指定Adjacency SID索引值,取值为0~1033575。
nexthop nexthop-address:指定下一跳IP地址。在广播网类型接口下配置Adjacency SID时,必须指定本参数;在P2P类型接口下配置Adjacency SID时,不能指定本参数。
开启IGP邻接标签分配功能,设备为IGP邻接链路随机分配Adjacency SID,如果IGP邻接失效(例如链路震荡),为同一邻接链路分配的SID可能与之前的值不同,从而导致Adjacency SID在网络中不断变化和抖动。为了确保分配给邻接链路的SID能够唯一,可以配置本命令为邻接链路分配指定Adjacency SID。
配置Adjacency SID索引值时,不同的配置方式,为邻接链路分配的Adjacency SID分别为:
·     绝对值方式:Adjacency SID=absolute-value
·     索引值方式:Adjacency SID=SRLB基值+index-value
配置本命令前,需要配置以下功能:
·     在接口上使能IS-IS功能后。
·     配置segment-routing mpls命令和segment-routing adjacency enable
多次执行本命令时,不同网络类型接口生效情况不同:
·     在P2P类型接口下,多次执行本命令,最后一次执行的命令生效。
·     在广播网类型接口下,多次执行本命令,可以为不同的下一跳指定IS-IS Adjacency SID。对于同一下一跳IP地址,多次执行本命令,最后一次执行的命令生效。
用户可根据实际情况,通过isis circuit-type p2p命令修改接口的网络类型。配置Adjacency SID后,不能修改接口的网络类型,必须先删除配置的Adjacency SID,再修改接口网络类型。
开启IGP邻接标签分配功能后,如果IS-IS接口上配置了本命令,则接口将优先使用本命令配置的Adjacency SID。
用户可以执行display mpls label命令,查看SID使用状态。如果配置的Adjacency SID已经被其他协议使用,则该Adjacency SID不可用。此后如果该Adjacency SID的使用状态变为Idle时,则先删除Adjacency SID的配置,再重新配置Adjacency SID,该Adjacency SID才可以被使用。
# 配置接口GigabitEthernet2/0/1上的Adjacency SID绝对值为20000,下一跳地址为1.1.1.1。
[Sysname-GigabitEthernet2/0/1] isis enable 1
[Sysname-GigabitEthernet2/0/1] isis adjacency-sid absolute 20000 nexthop 1.1.1.1
·     isis circuit-type p2p(三层技术-IP路由命令参考/IS-IS)
·     isis enable(三层技术-IP路由命令参考/IS-IS)
·     segment-routing adjacency enable
isis fast-reroute ti-lfa disable命令用来禁止接口参与TI-LFA计算。
undo isis fast-reroute ti-lfa disable命令用来允许接口参与TI-LFA计算。
isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
undo isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
允许接口参与TI-LFA计算。
level-1:禁止Level-1接口参与TI-LFA计算。
level-2:禁止Level-2接口参与TI-LFA计算。
接口下配置本命令表示禁止当前接口(主下一跳出接口)参与TI-LFA计算。
未指定level-1level-2参数时,表示禁止或允许所有Level区域接口参与TI-LFA计算。
# 禁止接口GigabitEthernet2/0/1参与TI-LFA计算。
[Sysname-GigabitEthernet2/0/1] isis fast-reroute ti-lfa disable
·     fast-reroute ti-lfa
isis prefix-sid命令用来配置IS-IS前缀SID。
undo isis prefix-sid命令用来恢复缺省情况。
isis prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
未配置IS-IS前缀SID。
LoopBack接口视图
absolute absolute-value:配置前缀SID绝对值。absolute-value表示前缀SID绝对值,取值范围为15000~1048575。
index index-value:配置前缀SID相对值。index-value表示前缀SID相对值,取值范围为0~1033575。
n-flag-clear:将前缀SID的Node-SID标志位置为0,表示前缀SID为到达一组SR节点的SID。如果不指定本参数,则Node-SID标志位置为1,表示前缀SID为到达某一台SR节点的SID。
explicit-null:将前缀SID的Explicit-null标志位置为1,表示上游邻居用显式空标签代替前缀SID。如果不指定本参数,标志位置为0,表示上游邻居继续按照前缀SID进行转发。关于显式空标签的内容请参见“MPLS配置指导”中的“MPLS基础”。
no-php:倒数第二跳不弹出,表示将前缀SID里的P-flag标志位置为1。如果不指定本参数,则前缀SID里的P-flag标志位置为0,表示上游邻居继续按照前缀SID倒数第二跳弹出进行转发。
配置IS-IS前缀SID时,必须按照以下规则执行:
·     当配置前缀SID绝对值时,绝对值的取值即为前缀SID的值,该值必须在SRGB的范围内。
·     当配置前缀SID相对值时,相对值加上SRGB最小值的大小即为前缀SID的值,前缀SID的值必须在SRGB的范围内。
在Anycast使用场景中,需要使用同一个前缀SID标识一组SR节点时,需要通过指定n-flag-clear参数将Node-SID标志位置为0。
当配置IS-IS SR前缀SID时,必须在LoopBack接口上使能IS-IS进程。
# 配置接口LoopBack1前缀SID的相对值为20。
[Sysname] interface loopback 1
[Sysname-LoopBack1] isis enable 1
[Sysname-LoopBack1] isis prefix-sid index 20
1.1.22  local-block
local-block命令用来配置SRLB标签范围。
undo local-block命令用来恢复缺省情况。
local-block minimum-value maximum-value
undo local-block
基于MPLS的SRGB的最小标签值为15000,最大标签值为15999。
Segment Routing视图
minimum-value:SRLB中的最小标签值,取值范围为15000~1048574。
maximum-value:SRLB中的最大标签值,取值范围为15001~1048575。
SRLB(Segment Routing Local Block,分段路由本地标签段)是专门用于SR-MPLS邻接类型SID(Adjacency SID)的本地标签范围。
配置本命令前需要通过display mpls label命令查看MPLS标签的使用状态,确保指定标签范围内的标签全部处于空闲状态,否则配置本命令后,需要保存配置并重启设备,本命令才能生效。
# 配置SRLB标签范围为200000~220000。
[Sysname-segment-routing] local-block 200000 220000
mapping-server prefix-sid-map命令用来配置前缀和SID的映射关系。
undo mapping-server prefix-sid-map命令用来取消前缀和SID的映射关系配置。
mapping-server prefix-sid-map ip-address mask-length start-value [ range range-value ] [ attached ]
undo mapping-server prefix-sid-map ip-address mask-length
不存在前缀和SID的映射关系。
Segment Routing视图
start-value:SID起始索引值,取值范围为0~1033574。单条配置前缀时,此数值为被映射前缀的SID索引值。批量配置前缀时,此数值为被映射前缀的起始SID索引值。
range range-value:指定要连续分配SID的个数,取值范围为1~1033575。
attached:标识当前被映射前缀是否是本地直连。
前缀地址必须符合规范且不与本地已配置的映射关系冲突。
批量配置前缀地址和SID映射关系时,请合理规划前缀和SID的映射个数,避免没有足够的IP地址和SID映射。
如果配置的range-value大于65535,则无法通过IS-IS和OSPF协议发布前缀和SID的映射关系。
# 配置前缀地址1.1.1.1/32和SID索引值100的映射关系。
[Sysname-segment-routing] mapping-server prefix-sid-map 1.1.1.1 32 100
# 批量前缀地址和SID索引值的映射关系:10.1.1.1/32分配的SID索引值为200,10.1.1.2/32分配的SID索引值为201。
[Sysname-segment-routing] mapping-server prefix-sid-map 10.1.1.1 32 200 range 2
mpls te static-sr-mpls命令用来配置隧道引用的静态SRLSP。
undo mpls te static-sr-mpls命令用来取消配置隧道引用指定的静态SRLSP。
mpls te static-sr-mpls lsp-name [ backup ]
undo mpls te static-sr-mpls lsp-name
隧道未引用任何静态SRLSP。
Tunnel接口视图
lsp-name:引用的静态SRLSP的名称,为1~15个字符的字符串,区分大小写。所引用的静态SRLSP,必须已经通过static-sr-mpls lsp命令创建。
backup:配置隧道引用的备用静态SRLSP。如果未指定本参数则配置隧道引用的主用静态SRLSP。
只有在Tunnel接口视图下配置了mpls te signaling static命令,本命令才会生效。
只有当主用和备用SRLSP均采用Adjacency方式建立时,才允许通过指定backup参数配置隧道引用备用SRLSP。
本命令需要在SRLSP的头节点上执行。
如果同时配置了mpls te static-sr-mplsmpls te static-cr-lsp命令,则mpls te static-cr-lsp命令生效,只有执行undo mpls te static-cr-lsp命令后,mpls te static-sr-mpls命令才会生效。
# 配置隧道Tunnel0引用名称为static-sr-3的静态SRLSP。
[Sysname] interface tunnel 0 mode mpls-te
[Sysname-Tunnel0] mpls te static-sr-mpls static-sr-3
·     display mpls te tunnel-interface(MPLS命令参考/MPLS TE)
·     mpls te signaling(MPLS命令参考/MPLS TE)
·     mpls te static-cr-lsp(MPLS命令参考/MPLS TE)
ospf adjacency-sid命令用来配置OSPF Adjacency SID。
undo ospf adjacency-sid命令用来恢复默认情况。
ospf adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
undo ospf adjacency-sid { absolute absolute-value | index index-value }
未配置OSPF Adjacency SID。
index index-value:指定Adjacency SID索引值,取值范围为0~1033575。
nexthop nexthop-address:指定下一跳IP地址。在非P2P类型接口下配置Adjacency SID时,必须指定本参数;在P2P类型接口下配置Adjacency SID时,不能指定本参数。
配置segment-routing mpls命令和segment-routing adjacency enable命令后,本命令才会生效。
·     在广播网类型接口下,多次执行本命令,可以为不同的下一跳指定OSPF Adjacency SID。对于同一下一跳IP地址,多次执行本命令,最后一次执行的命令生效。
用户可根据实际情况,通过ospf network-type命令修改接口的网络类型。
开启IGP邻接标签分配功能后,如果OSPF接口上配置了本命令,则接口将优先使用本命令配置的Adjacency SID。
[Sysname-GigabitEthernet2/0/1] ospf adjacency-sid absolute 20000 nexthop 1.1.1.1
·     ospf network-type(三层技术-IP路由命令参考/OSPF)
ospf fast-reroute ti-lfa disable命令用来禁止开启OSPF的接口参与TI-LFA计算。
undo ospf fast-reroute ti-lfa disable命令用来允许开启OSPF的接口参与TI-LFA计算。
源节点设备上路由的主下一跳接口可能不在TI-LFA计算出的备份路径上,需要禁止其参与计算。
[Sysname-GigabitEthernet2/0/1] ospf fast-reroute ti-lfa disable
·     fast-reroute ti-lfa (OSPF view)
ospf prefix-sid命令用来配置OSPF前缀SID。
undo ospf prefix-sid命令用来恢复缺省情况。
ospf process-id prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
undo ospf process-id prefix-sid
未配置OSPF前缀SID。
LoopBack接口视图
process-id:OSPF进程号,取值范围为1~65535。
explicit-null:将前缀SID的explicit-null标志位置为1,表示上游邻居用显式空标签代替前缀SID。如果不指定本参数,标志位置为0,表示上游邻居继续按照前缀SID进行转发。(关于显式空标签的内容请参见“MPLS配置指导”中的“MPLS基础”。)
no-php:将前缀SID里的P-flag标志位置为1,表示倒数第二跳不弹出。如果不指定本参数,则前缀SID里的P-flag标志位置为0,表示上游邻居继续按照前缀SID倒数第二跳弹出进行转发。
配置OSPF前缀SID时,必须按照以下规则执行:
当配置OSPF SR前缀SID时,必须保证LoopBack接口上使能的OSPF进程和前缀SID关联的进程一致,否则配置不会生效。
[Sysname-LoopBack1] ospf 1 prefix-sid index 20
peer egress-engineering命令用来在设备上开启BGP-EPE功能,并为指定对等体/对等体组分配标签。
undo peer egress-engineering命令用来恢复缺省情况。
peer { group-name | ipv4-address [ mask-length ] } egress-engineering [ adjacency | node-adjacency | set ] [ label label-value | route-policy policy-name ]
undo peer { group-name | ipv4-address [ mask-length ] } egress-engineering
BGP-EPE功能处于关闭状态。
BGP实例视图
ipv4-address:对等体的IPv4地址。指定的对等体必须已经创建。
adjacency:为指定对等体/对等体组分配邻接类型的SID。不指定adjacencyset参数时,设备将为邻居分配的SID为节点类型。
node-adjacency:为指定对等体/对等体组同时分配节点类型和邻接类型的SID。
set:为指定对等体/对等体组分配Set类型的SID。不指定adjacencyset参数时,设备将为邻居分配的SID为节点类型。
label label-value:为指定对等体/对等体组配置静态SID。lable-value为静态SID值,取值范围为16~1048575。
route-policy route-policy-name:为指定对等体/对等体组应用路由策略,通过路由策略为邻居分配标签值。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。若未指定本参数,将自动为邻居分配标签。
配置BGP-EPE功能时,需要注意:
·     缺省情况下,BGP peering SID为节点类型。
·     如果开启BGP-EPE功能时未指定路由策略,将自动为BGP邻居分配标签。
通过BGP-EPE功能为指定对等体/对等体组应用路由策略时需要注意:
·     路由策略中只能通过配置apply label-value命令来分配标签值,不支持apply label-index命令分配标签索引值。
·     为BGP对等体/对等体组分配PeerNode SID、PeerAdj SID和PeerNode-Adj SID时,不同的BGP对等体/对等体组不能应用路由策略分配相同的标签。
·     为BGP对等体/对等体组分配PeerSet SID时,不同的BGP对等体/对等体组可以应用路由策略分配相同的标签。
·     仅当为BGP对等体/对等体组分配PeerAdj SID时,可支持策略中配置if-match interface作为过滤条件。
如果未指定adjacencynode-adjacencyset参数,则设备为邻居分配的SID类型为节点类型。
# 开启BGP-EPE功能,并为对等体1.1.1.1分配节点类型的标签。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 egress-engineering
peer peer-set命令用来将对等体/对等体组加入BGP-EPE Peer Set组。
undo peer peer-set命令用来将对等体/对等体组从BGP-EPE Peer Set组中删除。
peer { group-name | ipv4-address [ mask-length ] } peer-set peer-set-name
undo peer { group-name | ipv4-address [ mask-length ] } peer-set
对等体/对等体组未加入BGP-EPE Peer Set组。
BGP实例视图
peer-set-name:BGP对等体加入的BGP Peer Set组的名称,为1~63个字符的字符串,区分大小写。
配置本命令前,对等体/对等体必须开启BGP-EPE功能。
通过peer egress-engineering set命令为指定对等体/对等体组分配Set类型的SID后,该对等体/对等体组不能再加入到BGP-EPE Peer Set组;反之亦然。
# 将对等体10.1.1.1加入到名为abc的BGP-EPE Peer Set组。
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.1.1 peer-set abc
·     egress-engineering peer-set
segment-routing命令用来开启Segment Routing功能,并进入Segment Routing视图。
undo segment-routing命令用来关闭Segment Routing功能。
segment-routing
Segment Routing功能处于关闭状态。
SRMS(Segment Routing Mapping Server,段路由映射服务器)是能够在IGP中通告前缀和Prefix SID映射关系的实体。通过部署SRMS,可以为不支持SR-MPLS的设备分配SID,完成SR-MPLS和LDP网络的互通。配置SRMS相关功能前,需要执行本命令。
# 开启Segment Routing功能,并进入Segment Routing视图。
segment-routing adjacency enable命令用来开启邻接标签分配功能。
undo segment-routing adjacency enable命令用来关闭邻接标签分配功能。
基于MPLS的SR邻接标签分配功能处于关闭状态。
IS-IS IPv4单播地址族视图
OSPF视图
开启邻接标签分配功能时,需确保SR-MPLS处于开启状态,否则该功能不会生效。
# 在IS-IS进程1的IPv4单播地址族下开启SR-MPLS邻接标签分配功能。
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing adjacency enable
# 开启OSPF进程1下SR-MPLS邻接标签分配功能。
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing adjacency enable
segment-routing global-block命令用来配置基于MPLS的SRGB的标签范围。
undo segment-routing global-block命令用来恢复缺省情况。
segment-routing global-block minimum-value maximum-value
基于MPLS的SRGB的最小标签值为16000,最大标签值为24000。
IS-IS视图
OSPF视图
maximum-value:SRGB中的最大标签值,取值范围为15001~1048575。
配置SRGB(Segment Routing Global Block,分段路由全局标签段)的范围时,若已配置前缀SID,需确保配置的SRGB标签范围包含已配置的前缀SID值,否则配置的前缀SID不生效。
如果配置的SRGB范围存在如下情况,则配置不会立即生效,需要重启设备后才能生效:
·     SRGB的范围内有其它协议已经分配的标签,例如SRGB范围内的标签已经被LDP协议使用。
·     SRGB的范围与其它协议的标签范围冲突,例如OSPF进程1下的SRGB和IS-IS进程1下的SRGB存在重叠部分。
# 配置IS-IS进程1下基于MPLS的SRGB的标签范围为17000~22000。
[Sysname] isis 1
[Sysname-isis-1] segment-routing global-block 17000 22000
# 配置OSPF进程1下基于MPLS的SRGB的标签范围为17000~22000。
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing global-block 17000 22000
·     global-block
segment-routing label-advertise命令用来配置设备在SR-MPLS组网中作为Egress节点时为倒数第二跳分配的标签类型。
undo segment-routing label-advertise命令恢复缺省情况。
segment-routing label-advertise { explicit-null | non-null }
设备在SR-MPLS组网中作为Egress节点时为倒数第二跳分配隐式空标签,标签值为3。
BGP IPv4单播地址族视图
explicit-null:指定设备在SR-MPLS组网中作为Egress节点时为倒数第二跳分配显式空标签,标签值为0。
non-null:指定设备在SR-MPLS组网中作为Egress节点时为倒数第二跳分配非空标签。
在SR-MPLS组网中,请根据实际情况选择Egress节点为倒数第二跳分配的标签类型:
·     如果倒数第二跳节点支持PHP(Penultimate Hop Popping,倒数第二跳弹出)功能,则建议采用隐式空标签;
·     如果在简化Egress节点转发处理的同时,希望Egress节点能够根据标签中的TC等信息决定QoS策略,则建议采用显式空标签;
·     通常情况下不建议使用非空标签。非空标签只适用于一些比较特殊的场景,比如Egress节点上部署了OAM,只有根据标签才能对应到OAM功能实体的情况。当使用非空标签时,Egress节点根据BGP IPv4单播路由中的前缀SID信息为倒数第二跳分配SID。
执行本令修改Egress分配的标签类型后,已经通过BGP IPv4单播路由建立的SRLSP会被拆除,并根据新的标签类型重新建立。
配置本命令前,需要先配置segment-routing mpls命令开启SR-MPLS功能。
# 在BGP IPv4单播地址族下配置设备在SR-MPLS组网中作为Egress节点时为倒数第二跳分配显示空标签。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] segment-routing label-advertise explicit-null
segment-routing mapping-server advertise-local命令用来开启通告本地SID标签映射消息功能。
undo segment-routing mapping-server advertise-local命令用来关闭通告本地SID标签映射消息功能。
通告本地SID标签映射消息处于关闭状态。
IS-IS IPv4单播地址族视图
OSPF视图
在SR to LDP组网环境中,需要在SRMS上配置本命令,以便设备向邻居通告指定前缀和SID的映射关系。
# 开启IS-IS通告本地SID标签映射消息功能。
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing mapping-server advertise-local
# 开启OSPF通告本地SID标签映射消息功能。
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing mapping-server advertise-local
·     mapping-server prefix-sid-map
segment-routing mapping-server receive命令用来开启接收远端SID标签映射消息功能。
undo segment-routing mapping-server receive命令用来关闭接收远端SID标签映射消息功能。
接收远端SID标签映射消息功能处于开启状态。
IS-IS IPv4单播地址族视图
OSPF视图
在SR to LDP组网环境中,需要在SRMC上配置本命令,以便使SR域内设备具备识别远端设备通告的指定前缀和SID的映射关系的能力。
# 关闭IS-IS接收远端SID标签映射消息功能。
[Sysname] isis 1
[Sysname-isis-1-ipv4] undo segment-routing mapping-server receive
# 关闭OSPF接收远端SID标签映射消息功能。
[Sysname] ospf 1
[Sysname-ospf-1] undo segment-routing mapping-server receive
·     mapping-server prefix-sid-map advertise-local
segment-routing microloop-avoidance enable命令用来开启SR防微环功能。
undo segment-routing microloop-avoidance enable命令用来关闭SR防微环功能。
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
undo segment-routing microloop-avoidance enable [ level-1 | level-2 ]
SR防微环功能处于关闭状态。
IS-IS IPv4单播地址族视图
level-1:开启Level-1区域的SR防微环功能。
level-2:开启Level-2区域的SR防微环功能。
在网络故障或故障恢复期间,路由都会重新收敛,由于网络节点之间转发状态短暂不一致,各个设备收敛速度不同,可能存在转发微环现象。配置SR的防微环功能后,在IGP收敛期间,设备会按照指定路径转发流量,转发过程不依赖于各设备的路由收敛,可以避免环路产生。
如果同时配置本命令和fast-reroute microloop-avoidance enable命令,则本命令生效。
未指定level-1level-2参数时,表示开启或关闭所有Level区域的SR防微环功能。
# 开启IS-IS进程1的SR防微环功能。
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing microloop-avoidance enable
·     fast-reroute microloop-avoidance enable
·     segment-routing microloop-avoidance rib-update-delay
segment-routing microloop-avoidance rib-update-delay命令用来配置SR防微环延迟时间。
undo segment-routing microloop-avoidance rib-update-delay命令用来恢复缺省情况。
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo segment-routing microloop-avoidance rib-update-delay [ level-1 | level-2 ]
SR防微环延迟时间为5000毫秒。
IS-IS IPv4单播地址族视图
delay-time:SR防微环延迟时间,取值范围为1~60000,单位为毫秒。
level-1:配置Level-1区域的SR防微环延迟时间。
level-2:配置Level-2区域的SR防微环延迟时间。
为了保证IGP收敛有足够的时间,可以配置SR防微环延迟时间,在此期间设备按照指定路径转发流量。在网络故障恢复IGP完成收敛后,流量再通过IGP计算的路径转发。
未指定level-1level-2参数时,表示配置所有Level区域的SR防微环的延迟时间。
# 配置IS-IS进程1的SR防微环延迟时间为6000毫秒。
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing microloop-avoidance rib-update-delay 6000
·     segment-routing microloop-avoidance enable
segment-routing mpls命令用来开启基于MPLS的SR功能。
undo segment-routing mpls命令用来关闭基于MPLS的SR功能。
基于MPLS的SR功能处于关闭状态。
IS-IS IPv4单播地址族视图
OSPF视图
BGP IPv4单播地址族视图
开启IGP支持SR-MPLS功能前,需进行以下配置,否则SR-MPLS功能不会生效:
·     当IGP协议为IS-IS时,需确保IS-IS开销值的类型为wide、compatible或wide-compatible。关于IS-IS开销值类型的配置请参见“三层技术-IP路由配置指导”中的“IS-IS”。
·     当IGP协议为OSPF时,需使能OSPF的Opaque LSA发布接收能力。关于OSPF使能Opaque LSA发布接收能力的配置请参见“三层技术-IP路由配置指导”中的“OSPF”。
# 在IS-IS进程1的IPv4单播地址族下开启SR-MPLS功能。
[Sysname] isis 1
[Sysname-isis-1] cost-style wide
[Sysname-isis-1-ipv4] segment-routing mpls
# 开启OSPF进程1下SR-MPLS功能。
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing mpls
# 在BGP IPv4单播地址族下开启SR-MPLS功能。
[Sysname] bgp 100
[Sysname-bgp-default] address family ipv4 unicast
[Sysname-bgp-default-ipv4] segment-routing mpls
·     cost-style(三层技术-IP路由命令参考/IS-IS)
·     opaque-capability enable(三层技术-IP路由命令参考/OSPF)
segment-routing prefix-sid-map命令用来开启前缀和SID的映射功能。
undo segment-routing prefix-sid-map命令用来关闭前缀和SID的映射功能。
前缀和SID的映射功能处于关闭状态。
BGP IPv4单播地址族视图
在SRMS上配置本命令后,当从邻居收到BGP IPv4单播路由时,会根据mapping-server prefix-sid-map命令配置的映射关系,为前缀地址分配SID。
如果BGP路由携带SID,同时又存在前缀和SID的映射关系,则优先使用前缀和SID的映射关系。
# 在BGP IPv4单播地址族下开启前缀和SID的映射功能。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing prefix-sid-map
segment-routing sr-prefer命令用来配置优先使用SRLSP转发流量。
undo segment-routing sr-prefer命令用来恢复缺省情况。
segment-routing sr-prefer [ prefix-list prefix-list-name ]
设备优先使用LDP LSP转发流量。
IS-IS IPv4单播地址族视图
OSPF进程视图
prefix-list prefix-list-name:指定IP地址前缀列表。prefix-list-name为IP地址前缀列表名称,为1~63个字符的字符串,区分大小写。只有通过IP地址前缀列表过滤的前缀才会优先使用SRLSP转发流量;未通过过滤的前缀优先使用LDP LSP转发流量。如果不指定本参数,则表示所有的IP地址前缀均优先使用SRLSP转发流量。
当到达同一目的网络同时存在SRLSP和LDP LSP两种标签转发路径时,通过配置本命令,可以指定转发到达该目的网络的流量时优先使用的路径,以便更好地规划和控制流量转发路径。
配置本命令时,请开启SR-MPLS功能,并确保SRLSP路径标签为前缀SID。
# 配置所有流量均优先使用SRLSP转发。
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing sr-prefer
# 配置通过IP地址前缀列表8过滤的前缀优先使用SRLSP转发流量。
[Sysname] ip prefix-list 8 permit 4.4.4.4 32
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing sr-prefer prefix-list 8
·     ip prefix-list(三层技术-IP路由命令参考/路由策略)
static-sr-mpls adjacency命令用来配置静态Adjacency Segment。
undo static-sr-mpls adjacency命令用来删除静态Adjacency Segment。
static-sr-mpls adjacency adjacency-path-name in-label label-value { nexthop ip-address | outgoing-interface interface-type interface-number }
undo static-sr-mpls adjacency adjacency-path-name
不存在静态Adjacency Segment。
adjacency-path-name:静态Adjacency Segment的名称,为1~15个字符的字符串,区分大小写。
in-label label-value:指定入标签值,取值范围为16~10240。
nexthop ip-address:指定下一跳IP地址。
outgoing-interface interface-type interface-number:指定出接口的接口类型和接口编号。指定的接口必须为点到点连接类型的接口。
本命令需要在静态SRLSP的所有节点上执行。
如果指定下一跳IP地址,设备上必须存在到达该地址的路由且路由出接口上必须使能MPLS能力;如果指定出接口,该出接口必须处于UP状态并且能够接收到直连路由,且必须使能MPLS能力。
如果所指定的入标签与已经存在的静态LSP/静态PW/静态CRLSP的入标签相同,则会导致标签冲突,所配置的邻接路径不可用。即使修改静态LSP/静态PW/静态CRLSP的入标签,该邻接路径仍不可用,需要手工删除该邻接路径并重新配置。
# 配置名为adj1的邻接路径,指定入标签值为100,下一跳IP地址为12.2.1.2。
[Sysname] static-sr-mpls adjacency adj1 in-label 100 nexthop 12.2.1.2
·     display static-sr-mpls
static-sr-mpls lsp命令用来配置用于MPLS TE隧道的静态SRLSP。
undo static-sr-mpls lsp命令用来删除用于MPLS TE隧道的静态SRLSP。
static-sr-mpls lsp lsp-name out-label out-label-value&<1-n>
undo static-sr-mpls lsp lsp-name
不存在用于MPLS TE隧道的静态SRLSP。
lsp-name:静态SRLSP的名称,为1~15个字符的字符串,区分大小写。
out-label out-label-value&<1-n>:指定出标签值列表,配置顺序为从外到内各层标签依次配置,&<1-n>表示前面的参数最多可以输入n次。out-label-value的取值范围为0、3、16~1048575。n的取值为15。
本命令需要在静态SRLSP的头节点上执行。
命令中的出标签值列表代表报文所经过路径上的标签信息,最外层的标签必须为源节点出链路标签或者源节点为目标前缀分配的前缀标签。
# 配置名为lsp1的静态SRLSP,出标签值列表为100、200。
[Sysname] static-sr-mpls lsp lsp1 out-label 100 200
static-sr-mpls prefix命令用来配置静态Prefix Segment。
undo static-sr-mpls prefix命令用来删除静态Prefix Segment。
static-sr-mpls prefix prefix-path-name destination ip-address { mask | mask-length } in-label in-label-value [ { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value ]
undo static-sr-mpls prefix prefix-path-name [ destination ip-address { mask | mask-length } in-label in-label-value [ nexthop ip-address | outgoing-interface interface-type interface-number ] ]
不存在静态Prefix Segment。
prefix-path-name:静态Prefix Segment的名称,为1~15个字符的字符串,区分大小写。
destination ip-address:指定目的IP地址。
mask:目的IP地址掩码。
mask-length:目的IP地址掩码长度,取值范围为0~32。
in-label label-value:指定入标签值,取值范围为16000~24000。
out-label out-label-value:指定出标签值,取值范围为0,3,16~1048575。
指定的下一跳或出接口必须与路由表中最优路由(非BGP路由)的下一跳或出接口保持一致,同一台设备上,如果最优路由有多个下一跳或者出接口,那么就能配置多个到该目的地址的前缀路径用于负载分担,但是需要注意的是到达同一目的地址前缀路径的名称、入标签值需要保持一致。
执行undo static-sr-mpls prefix命令时,如果只配置了prefix-path-name参数,则将所有同名的前缀路径配置全部删除。如果携带了所有的关键字,则将匹配下一跳或出接口的配置删除。
# 配置名为prefix1的前缀路径,目的地址为2.2.2.2,指定入标签值为16000,出标签值为16001,下一跳IP地址为10.0.0.2。
[Sysname] static-sr-mpls prefix prefix1 destination 2.2.2.2 32 in-label 16000 nexthop 10.0.0.2 out-label 16001
·     display mpls static-sr-mpls prefix
