16-可靠性命令参考
10-BFD命令
本章节下载 10-BFD命令  (668.37 KB)
10-BFD命令
  录
1 BFD
1.1 BFD配置命令
1.1.1 bfd authentication-mode
1.1.2 bfd container reserve local-discriminator
1.1.3 bfd dampening
1.1.4 bfd demand enable
1.1.5 bfd detect-interface
1.1.6 bfd detect-interface first-fail-timer
1.1.7 bfd detect-interface special-processing
1.1.8 bfd detect-multiplier
1.1.9 bfd dynamic-udp-port enable
1.1.10 bfd echo enable
1.1.11 bfd echo-source-ip
1.1.12 bfd echo-source-ipv6
1.1.13 bfd init-fail-timer
1.1.14 bfd min-echo-receive-interval
1.1.15 bfd min-receive-interval
1.1.16 bfd min-transmit-interval
1.1.17 bfd multi-hop authentication-mode
1.1.18 bfd multi-hop destination-port
1.1.19 bfd multi-hop detect-multiplier
1.1.20 bfd multi-hop min-echo-receive-interval
1.1.21 bfd multi-hop min-receive-interval
1.1.22 bfd multi-hop min-transmit-interval
1.1.23 bfd session init-mode
1.1.24 bfd session-negotiation delay-upon-down
1.1.25 bfd static
1.1.26 bfd template
1.1.27 discriminator
1.1.28 display bfd session
1.1.29 first-fail-timer
1.1.30 hardware-resource bfd_enhance
1.1.31 process-interface-status
1.1.32 reset bfd session statistics
1.1.33 snmp-agent trap enable bfd
1.1.34 special-processing
1.2 SBFD配置命令
1.2.1 bfd detect-multiplier
1.2.2 bfd dynamic-udp-port enable
1.2.3 bfd min-transmit-interval
1.2.4 bfd multi-hop detect-multiplier
1.2.5 bfd multi-hop min-transmit-interval
1.2.6 bfd session-negotiation delay-upon-down
1.2.7 bfd template
1.2.8 display sbfd session initial
1.2.9 display sbfd session reflector
1.2.10 sbfd destination ipv4 remote-discriminator
1.2.11 sbfd destination ipv6 remote-discriminator
1.2.12 sbfd local-discriminator
1.2.13 sbfd source-ipv4
1.2.14 sbfd source-ipv6
1 BFD
1.1  BFD配置命令
bfd authentication-mode命令用来配置单跳BFD控制报文进行认证的方式。
undo bfd authentication-mode命令用来恢复缺省情况。
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
单跳BFD控制报文不进行认证。
BFD模板视图
静态BFD会话视图
hmac-md5:采用基于HMAC的MD5算法进行认证。
hmac-mmd5:采用基于HMAC的Meticulous MD5算法进行认证。
hmac-msha1:采用基于HMAC的Meticulous SHA1算法进行认证。
hmac-sha1:采用基于HMAC的SHA1算法进行认证。
m-md5:采用Meticulous MD5算法进行认证。
m-sha1:采用Meticulous SHA1算法进行认证。
md5:采用MD5算法进行认证。
sha1:采用SHA1算法进行认证。
simple采用简单认证。
key-id:认证字标识符,取值范围为1~255。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~16个字符的字符串,密文密钥为33~53个字符的字符串。
本命令主要为了提高BFD会话的安全性。
BFD版本0不支持本命令,配置不生效。
对于静态BFD会话,仅IPv4或IPv6控制报文方式单跳检测的静态BFD会话视图下支持配置本命令。
# 配置接口HundredGigE1/0/1对单跳BFD控制报文进行简单明文认证,认证字标识符为1,密钥为123456。
[Sysname-HundredGigE1/0/1] bfd authentication-mode simple 1 plain 123456
bfd container reserve local-discriminator命令用来配置本端预留给第三方容器的BFD会话本地标识符。
undo bfd container reserve local-discriminator命令用来取消本端预留给第三方容器的BFD会话本地标识符的配置。
仅R5212P01及以上版本支持本命令。
bfd container reserve local-discriminator discr-value1 [ to discr-value2 ]
未配置本端预留给第三方容器的BFD会话本地标识符。
discr-value1:指定预留给第三方容器的BFD会话本地标识符,取值范围为1048576~4026531840。
discr-value1 to discr-value2:指定预留给第三方容器的BFD会话本地标识符的范围。discr-value1discr-value2的取值范围均为1048576~4026531840。discr-value2的配置值必须大于或等于discr-value1的配置值。
应用场景
Comware V9支持用户在H3C物理设备上部署Guest Shell容器和Docker容器,以及基于Comware系统的RPM应用、基于Guest Shell容器的应用、基于Docker容器的应用。本命令用于解决部署在H3C物理设备上的第三方容器运行BFD时协议报文被丢弃的问题。关于容器的详细介绍,请参见“开放应用管理配置指导”中的“容器和开放型应用公共配置”。
工作机制
部署在H3C物理设备上的第三方容器运行BFD时,需要接收和发送BFD报文。当BFD报文的目的地址是H3C物理设备的地址时,这些报文会被Comware系统全部接管,无法发送给容器。
配置本命令后,H3C物理设备会为容器预留BFD会话标识符。当H3C物理设备收到的BFD报文中的Your Discriminator字段与预留的BFD会话标识符匹配,则Comware系统不会处理该报文,而是将其转交给内核,由内核转发给第三方容器。
注意事项
多次执行本命令,最后一次执行的命令生效。
本命令不能解决一个容器和另外一个容器之间BFD会话无法UP的问题。
当设备配置了bfd container reserved local-discriminator命令后,SRV6 BFD功能无法正常运行并处于非活动状态。
此命令主要为第三方容器预留,BFD本身并不会处理与此命令相关的报文。
如果容器协商的Discriminator数值超出设备配置值1048576~4026531840,需要在容器上删除会话并重新创建,直到协商的会话Discriminator值在1048576~4026531840范围内。
# 配置本端预留给第三方容器的BFD会话本地标识符范围为1048576~4026531840。
[Sysname] bfd container reserve local-discriminator 1048576 to 4026531840
1.1.3  bfd dampening
bfd dampening命令用来开启BFD会话震荡抑制功能。
undo bfd dampening命令用来关闭BFD会话震荡抑制功能。
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
不会对BFD会话的建立进行抑制。
maximum-interval:抑制BFD会话建立的最大时间间隔,取值范围为1~3600,单位为秒,缺省值为20秒。
initial-interval:第一次抑制BFD会话建立的时间间隔,取值范围为1~3600,单位为秒,缺省值为6秒。
secondary-interval:第二次抑制BFD会话建立的时间间隔,取值范围为1~3600,单位为秒,缺省值为10秒。
BFD检测到链路故障时,会拆除BFD会话,并通知上层协议邻居不可达。当上层协议重新建立邻居关系后,BFD会话重新up。当链路频繁发生故障并故障恢复时,将导致BFD会话震荡,引发设备不断执行上述操作,这会占用大量的系统资源并影响网络的稳定性。可配置本命令通过如下惩罚机制对BFD会话震荡进行抑制。BFD会话震荡的惩罚机制通过initial-intervalsecondary-intervalmaximum-interval参数来进行抑制:
·     在抑制时间间隔内,不允许建立BFD会话;在抑制时间间隔超时后,允许建立BFD会话。抑制时间最大不超过maximum-interval
·     BFD会话第二次down后,在initial-interval时间间隔内,不允许重新建立BFD会话。
·     BFD会话第三次down后,在secondary-interval时间间隔内,不允许重新建立BFD会话。
·     BFD会话第四次或更多次down后,按照如下规则抑制BFD会话的建立:
¡     secondary-interval×2n-3(n为BFD会话震荡的次数,初始值为4)小于或等于maximum-interval时,在secondary-interval×2n-3时间间隔内,不允许重新建立BFD会话。
¡     secondary-interval×2n-3(n为BFD会话震荡的次数,初始值为4)大于maximum-interval时,在maximum-interval时间间隔内,不允许重新建立BFD会话。
# 配置BFD会话震荡时,抑制BFD会话建立的最大时间间隔为12秒,第一次抑制BFD会话建立的时间间隔为4秒,第二次抑制BFD会话建立的时间间隔为8秒。
[Sysname] bfd dampening maximum 12 initial 4 secondary 8
bfd demand enable命令用来配置BFD会话为查询模式。
undo bfd demand enable命令用来恢复缺省情况。
bfd demand enable
BFD会话为异步模式。
在查询模式下,设备周期性发送BFD控制报文,但是对端(缺省为异步模式)会停止周期性发送BFD控制报文。如果通信双方都是查询模式,则双方都停止周期性发送BFD控制报文。当需要验证连接性的时候,设备会以协商的周期连续发送几个P比特位置1的BFD控制报文。如果在检测时间内没有收到返回的报文,就认为会话down;如果收到对方的回应F比特位置1的报文,就认为连通,停止发送报文,等待下一次触发查询。此模式下,建议用户通过bfd echo enable命令使能echo功能,设备将周期性发送echo报文来检测链路的连通性,如果在检测时间内未收到对端返回的echo报文,则认为会话down。
在异步模式下,设备周期性地发送BFD控制报文,如果在检测时间内对端没有收到BFD控制报文,则认为会话down。
BFD版本0不支持本命令,配置不生效。
# 在接口HundredGigE1/0/1上配置BFD会话为查询模式。
[Sysname-HundredGigE1/0/1] bfd demand enable
·     bfd echo enable
bfd detect-interface source-ip命令用来配置接口状态与BFD联动。
undo bfd detect-interface命令用来取消接口状态与BFD联动的配置。
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
接口状态不与BFD联动,即BFD检测到链路故障时,不会将接口链路层协议状态置为“DOWN(BFD)。
ip-address:BFD控制报文的源IP地址。
discriminator:指定BFD会话的标识符。如果未指定本参数,设备将通过自动协商的方式获取BFD会话标识符。
local local-value:指定BFD会话的本地标识符。local-value表示BFD会话的本地标识符,取值范围为1~32768。
remote remote-value:指定BFD会话的远端标识符。remote-value表示BFD会话的远端标识符,取值范围为1~4294967295。
template template-name:指定引用的BFD会话参数的模板名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则BFD会话使用接口视图下配置的单跳BFD会话参数。引用的BFD会话参数模板可以不存在,但要使引用BFD会话参数模板的配置生效,必须创建BFD模板。
配置接口状态与BFD联动后,系统将通过发送BFD控制报文来协商建立单跳检测的BFD会话,实现对链路的快速检测。当检测到链路故障时,将接口链路层协议状态置为“DOWN(BFD)”,从而帮助依赖接口链路层协议状态的应用快速收敛。系统发送的BFD控制报文中的源地址为用户手工指定的IP地址,目的地址固定为224.0.0.184。对于有IP地址的接口,建议将源地址指定为该接口的IP地址;如果接口没有IP地址,建议将源地址指定为0.0.0.0以外的单播地址。
仅支持三层以太网接口与BFD联动。
两端都必须配置本功能才能建立BFD会话。
当对端设备不支持通过自动协商的方式获取BFD会话的标识符时,必须指定discriminator参数,且两端都需要指定该参数,否则,BFD会话无法up。
指定BFD会话的标识符时,两端的BFD会话本地标识符和远端标识符必须匹配,即本端指定的本地标识符和远端标识符必须是对端设备上指定的远端标识符和本地标识符。例如,本端配置bfd detect-interface source-ip 20.1.1.1 discriminator local 6002 remote 6020时,对端要配置bfd detect-interface source-ip 20.1.1.2 discriminator local 6020 remote 6002,才能正确建立起BFD会话。
同一设备不同接口上的BFD会话的本地标识符不能相同。
回声功能对接口状态与BFD联动的会话无效。
如下两种方式均可检测接口数据链路层的连通性,但是不能同时用这两种方式检测同一个接口数据链路层的连通性。
·     配置bfd detect-interface source-ip命令检测接口数据链路层的连通性。
·     配置bfd static session-name peer-ip default-ip interface interface-type interface-number source-ip ip-address命令检测接口数据链路层的连通性。
# 配置接口HundredGigE1/0/1的接口状态与BFD联动,并指定BFD会话的源地址为接口地址20.1.1.1。
[Sysname-HundredGigE1/0/1] bfd detect-interface source-ip 20.1.1.1
·     link-protocol(接口管理命令参考/WAN接口)
·     bfd static
bfd detect-interface first-fail-timer命令用来配置首次建立检测接口状态的BFD会话失败时,通知数据链路层BFD会话down的超时时间。
undo bfd detect-interface first-fail-timer命令用来恢复缺省情况。
bfd detect-interface first-fail-timer seconds
首次建立检测接口状态的BFD会话失败时,不会通知数据链路层BFD会话down。
seconds:首次建立检测接口状态的BFD会话失败时,通知数据链路层BFD会话down的超时时间,即在seconds时间后如果检测接口状态的BFD会话仍未建立成功,BFD会将此消息通知给数据链路层。取值范围为1~10000,单位为秒。
本端配置bfd detect-interface source-ip命令后,会尝试建立检测接口状态的BFD会话。如果对端未配置bfd detect-interface source-ip命令或两端BFD的认证配置不一致等原因,均会导致首次建立检测接口状态的BFD会话失败。如果需要关闭接口的数据链路层,快速定位首次建立检测接口状态的BFD会话失败的接口,可通过配置本命令来实现。
配置本命令后,如果接口首次建立检测接口状态的BFD会话失败,执行display bfd session命令显示该BFD会话的状态为down,执行display interface命令会显示该接口的Line protocol state为DOWN(BFD)。
# 配置首次建立检测接口状态的BFD会话失败时,通知数据链路层BFD会话down的超时时间为10秒。
[Sysname-HundredGigE1/0/1] bfd detect-interface first-fail-timer 10
·     bfd detect-interface source-ip
·     display interface(接口管理/以太网接口)
bfd detect-interface special-processing命令用来开启对检测接口状态的BFD会话进行特殊处理的功能。
undo bfd detect-interface special-processing命令用来关闭对检测接口状态的BFD会话进行特殊处理的功能。
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
undo bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
对检测接口状态的BFD会话进行特殊处理的功能处于关闭状态。
admin-down:本端收到会话状态为AdminDown的BFD报文时,将BFD会话down的消息通知给数据链路层。使用本参数,有利于快速发现BFD会话被手工关闭的接口。如果未配置本参数,本端收到会话状态为AdminDown的BFD报文,将BFD会话状态置为down,但是不会将BFD会话down的消息通知给数据链路层。
authentication-change:本端认证信息发生变化时,立即将BFD会话状态置为down。使用本参数,有利于快速发现认证信息不一致的接口。如果未配置本参数,本端认证信息发生变化时,会预留时间给用户修改本端或对端的认证参数,如果预留时间结束时,两端认证信息任未达成一致,本端会将BFD会话状态置为down。
session-up:本端BFD会话处于up状态时,不再检查收到的BFD报文中的认证信息。当设备上的BFD会话数量较多时,检查BFD报文中携带的认证信息会影响设备性能。配置本参数后,不再检查收到的报文中的认证信息,从而可以降低对设备性能的影响。如果未配置本参数,本端BFD会话处于状态up时,会检查收到的BFD报文中的认证信息,需要保证BFD会话两端认证信息的一致性,否则会导致BFD会话down。
如果未指定任何参数,将开启或关闭对检测接口状态的BFD会话进行所有特殊处理的功能。
# 在HundredGigE1/0/1接口下开启对检测接口状态的BFD会话进行特殊处理的功能,包括收到会话状态为AdminDown的BFD报文、本端认证信息发生变化以及BFD会话处于up状态时对收到的BFD报文中认证信息检查的特殊处理。
[Sysname-HundredGigE1/0/1] bfd detect-interface special-processing admin-down authentication-change session-up
bfd detect-multiplier命令用来配置控制报文方式或echo报文方式单跳检测的BFD检测时间倍数。
undo bfd detect-multiplier命令用来恢复缺省情况。
bfd detect-multiplier value
单跳BFD检测时间倍数为5。
BFD模板视图
静态BFD会话视图
value:单跳BFD检测时间倍数,取值范围为3~50。
检测时间倍数,即允许发送方发送BFD报文(包括echo报文和控制报文)的最大连续丢包数。
实际检测时间的计算方法遵循如下规则:
·     对于echo报文方式,本端实际检测时间=本端的检测时间倍数×本端实际发送echo报文的时间间隔。
·     对于控制报文方式单跳检测的异步模式,本端实际检测时间=对端的检测时间倍数×MAX(本端支持的接收BFD控制报文的最小时间间隔,对端支持的发送BFD控制报文的最小时间间隔)。
·     对于控制报文方式单跳检测的查询模式,本端实际检测时间=本端的检测时间倍数×MAX(本端支持的发送BFD控制报文的最小时间间隔,对端支持的接收BFD控制报文的最小时间间隔)。
对于静态BFD会话,仅如下类型的静态BFD会话视图下支持配置本命令:
·     IPv4控制报文方式单跳检测静态BFD会话
·     IPv4 echo报文方式单跳检测静态BFD会话
·     IPv6控制报文方式单跳检测静态BFD会话
·     IPv6 echo报文方式单跳检测静态BFD会话
# 配置接口HundredGigE1/0/1的控制报文方式单跳检测和echo报文方式的BFD检测时间倍数为6。
[Sysname-HundredGigE1/0/1] bfd detect-multiplier 6
bfd dynamic-udp-port enable命令用来开启动态修改BFD报文端口号功能。
undo bfd dynamic-udp-port enable命令用来关闭动态修改BFD报文端口号功能。
动态修改BFD报文端口号功能处于关闭状态。
应用场景
BFD检测两台设备间的链路连通性时,如果两台设备间存在多条可达路径(例如ECMP或聚合链路),设备在转发BFD报文时会根据UDP端口号作为报文特征来选择特定的转发路径。缺省情况下,对于同一个BFD会话,BFD报文的源端口号在会话开始时随机生成后保持不变,而目的端口号则根据会话类型确定,并在整个会话期间保持一致。
这种情况会导致设备始终使用同一条路径转发BFD报文。一旦该路径出现故障,BFD会话将变为Down状态。这意味着网络的冗余能力没有得到充分利用,对链路连通性检测的准确性和网络的稳定性构成了挑战。本功能用于解决上述问题。
工作机制
BFD检测两台设备间的链路连通性时,对于不同报文方式的会话,需要在不同的设备上配置本命令。具体如下:
·     对于控制报文方式的BFD会话,需要在这两台设备上同时配置本命令。
·     对于echo报文方式的BFD会话,仅需要在发送echo报文的设备上配置本命令。
配置本命令后,设备转发BFD报文时,会修改报文的端口号,使得设备能够选择不同的路径转发BFD报文,避免单链路故障导致BFD会话Down。修改端口号的机制如下:
·     对于BFD报文,设备修改报文的源端口号。
·     对于SBFD报文,Initiator端修改报文的源端口号,Reflector端修改报文的目的端口号。
注意事项
本功能为H3C私有实现,在与其他厂商设备对接的场景中,建议不要使用本功能,否则可能导致BFD会话震荡。
本命令仅对由硬件维护的BFD会话生效。配置本命令后,对于配置本命令前已创建的BFD会话以及配置本命令后新创建的BFD会话均生效。
本命令对BFD以及SBFD报文均生效。
# 开启动态修改BFD报文源端口号功能。
[Sysname] bfd dynamic-udp-port enable
bfd echo enable命令用来使能回声功能。
undo bfd echo enable命令用来关闭回声功能。
undo bfd echo [ receive | send ] enable
回声功能处于关闭状态。
静态BFD会话视图
receive:表示设备接收echo报文的能力。
send:表示设备发送echo报文的能力。
本功能在发送控制报文的BFD会话时使用。使能回声功能并且会话up后,设备周期性发送echo报文检测链路连通性,同时降低控制报文的接收速率。
使用bfd echo receive enable命令,表示使能回声功能后,只开启设备接收echo报文的能力;使用bfd echo send enable命令,表示使能回声功能后,只开启设备发送echo报文的能力。当不指定receivesend参数时,表示使能回声功能后,同时开启设备收、发echo报文的能力。
回声功能对使用IPv6链路本地地址建立的控制报文的BFD会话无效。
在同一接口下,同时配置bfd detect-interfacebfd echo enable命令,只有bfd detect-interface命令生效。
BFD版本0不支持本命令,配置不生效。
# 配置接口HundredGigE1/0/1使能回声功能。
[Sysname-HundredGigE1/0/1] bfd echo enable
bfd echo-source-ip命令用来配置echo报文的源IP地址。
undo bfd echo-source-ip命令用来删除echo报文的源IP地址。
bfd echo-source-ip ip-address
未配置echo报文的源IP地址。
ip-address:echo报文的源IP地址,点分十进制形式,取值范围为合法的单播IPv4地址。
对于echo报文方式的BFD会话,建议在创建BFD会话的一端配置本命令,且配置的源IP地址不属于该设备任何一个接口所在网段,以避免对端发送大量的ICMP重定向报文造成网络拥塞。
# 配置echo报文的源IP地址为8.8.8.8。
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6命令用来配置echo报文的源IPv6地址。
undo bfd echo-source-ipv6命令用来删除echo报文的源IPv6地址。
未配置echo报文的源IPv6地址。
ipv6-address:echo报文的源IPv6地址。
echo报文源IPv6地址仅支持全球单播地址。
对于echo报文方式的BFD会话,建议在创建BFD会话的一端配置本命令,且配置的源IPv6地址不属于该设备任何一个接口所在网段,以避免对端发送大量的ICMPv6重定向报文造成网络拥塞。
# 配置echo报文的源IPv6地址为80::2。
[Sysname] bfd echo-source-ipv6 80::2
bfd init-fail-timer命令用来配置BFD会话无法建立时,通知上层协议BFD会话down的超时时间。
undo bfd init-fail-timer命令用来恢复缺省情况。
bfd init-fail-timer seconds
BFD会话无法建立时,不会通知上层协议BFD会话down。
seconds:BFD会话无法建立时,通知上层协议BFD会话down的超时时间,即在seconds时间后将BFD会话down的消息通知给上层协议。取值范围为5~600,单位为秒。
配置本命令后,对于由于配置原因(比如对端设备没有使能BFD,或者两端的BFD认证配置不一致等)造成BFD会话无法进入up状态的情况,如果配置了本定时器,会导致上层协议作出错误的处理,所以,请谨慎使用本命令。
缺省情况下,控制报文工作方式的BFD会话无法建立时,不会通知上层协议BFD会话down。某些情况下,需要将BFD会话无法建立的消息通知给上层协议,以使上层协议作出正确的处理。比如在聚合链路中,由于链路故障等原因,BFD会话无法进入up状态,从而导致聚合模块无法及时将成员端口的选中状态修改为非选中状态,配置本命令可避免上述情况的发生。
对于echo报文方式的BFD会话,本命令不生效。
# 配置BFD会话无法建立时,通知上层协议BFD会话down的超时时间为10秒。
[Sysname] bfd init-fail-timer 10
bfd min-echo-receive-interval命令用来配置接收echo报文的最小时间间隔。
undo bfd min-echo-receive-interval命令用来恢复缺省情况。
接收echo报文的最小时间间隔为400毫秒。
BFD模板视图
静态BFD会话视图
interval:接收echo报文的最小时间间隔,单位为毫秒。取值可以为0或3~10000。
使用本命令,设备能够控制接收两个echo报文之间的时间间隔,即echo报文实际发送时间间隔。
对于控制报文方式的BFD会话,本端使能echo功能后,如果对端通过本命令将interval设置为0毫秒,那么本端设备与对端设备自动协商后,本端设备不再周期性发送echo报文。
# 配置接口HundredGigE1/0/1接收echo报文的最小时间间隔为500毫秒。
[Sysname-HundredGigE1/0/1] bfd min-echo-receive-interval 500
bfd min-receive-interval命令用来配置接收单跳BFD控制报文的最小时间间隔。
undo bfd min-receive-interval命令用来恢复缺省情况。
接收单跳BFD控制报文的最小时间间隔为400毫秒。
BFD模板视图
静态BFD会话视图
interval:接收单跳BFD控制报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
本命令主要为了防止对端发送控制报文的速度超过本地接收控制报文的速度。
对端的控制报文实际发送时间为对端发送控制报文的最小时间间隔和本地接收控制报文的最小时间间隔之间的较大值。
# 配置接口HundredGigE1/0/1接收单跳BFD控制报文的最小时间间隔为500毫秒。
[Sysname-HundredGigE1/0/1] bfd min-receive-interval 500
bfd min-transmit-interval命令用来配置发送单跳BFD控制报文的最小时间间隔。
undo bfd min-transmit-interval命令用来恢复缺省情况。
发送单跳BFD控制报文的最小时间间隔为400毫秒。
BFD模板视图
静态BFD会话视图
interval:发送单跳BFD控制报文的最小时间间隔,单位为毫秒。取值范围为10~10000。
本命令主要是为了保证发送BFD控制报文的速度不能超过设备发送报文的能力。
本地实际发送BFD控制报文的时间间隔,为本地配置的发送BFD控制报文的最小时间间隔和对端接收BFD控制报文的最小时间间隔的最大值。
# 配置接口HundredGigE1/0/1发送单跳BFD控制报文的最小时间间隔为500毫秒。
[Sysname-HundredGigE1/0/1] bfd min-transmit-interval 500
bfd multi-hop authentication-mode命令用来配置多跳BFD控制报文进行认证的方式。
undo bfd multi-hop authentication-mode命令用来恢复缺省情况。
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
多跳BFD控制报文不进行认证。
静态BFD会话视图
md5:采用MD5算法进行认证。
sha1:采用SHA1算法进行认证。
simple采用简单认证。
cipher:以密文方式设置密钥。
本命令主要为了提高BFD会话的安全性。
BFD版本0不支持本命令,配置不生效。
对于静态BFD会话,仅IPv4或IPv6控制报文方式多跳检测的静态BFD会话视图下支持配置本命令。
# 配置多跳BFD控制报文进行简单明文认证,认证字标识符为1,密钥为123456。
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
bfd multi-hop destination-port命令用来配置多跳BFD控制报文的目的端口号。
undo bfd multi-hop destination-port命令用来恢复缺省情况。
多跳BFD控制报文的目的端口号为4784。
port-number:多跳BFD控制报文的目的端口号,取值可以为3784或者4784。
IANA(Internet Assigned Numbers Authority,互联网编号分配委员会)将端口号4784分配给BFD,用于BFD控制报文多跳检测。缺省情况下,我司设备多跳BFD控制报文的目的端口号为4784。与多跳BFD控制报文目的端口号为3784的其他厂商设备互通时,建议两端使用相同的多跳BFD控制报文端口号,否则可能会导致BFD会话协商失败。
配置本命令后,只有此后新创建的控制报文方式的多跳BFD会话,才会使用本命令设置的端口块作为发送报文的目的端口号。对于配置本命令前已经Up的控制报文方式的多跳BFD会话,不会使用本命令设置的端口号作为发送报文的目的端口号。
# 配置多跳BFD控制报文的目的端口号为3784。
[Sysname] bfd multi-hop destination-port 3784
bfd multi-hop detect-multiplier命令用来配置控制报文方式或echo报文方式多跳检测的BFD检测时间倍数。
undo bfd multi-hop detect-multiplier命令用来恢复缺省情况。
控制报文多跳检测的BFD检测时间倍数为5。
静态BFD会话视图
value:BFD检测时间倍数,取值范围为3~50。
检测时间倍数,即接收方允许发送方发送BFD控制报文的最大连续丢包数。
实际检测时间的计算方法遵循如下规则:
·     对于控制报文方式的多跳检测异步模式,本端实际检测时间=对端的检测时间倍数×MAX(本端支持的接收BFD控制报文的最小时间间隔,对端支持的发送BFD控制报文的最小时间间隔)。
·     对于控制报文方式的多跳检测查询模式,本端实际检测时间=本端的检测时间倍数×MAX(本端支持的发送BFD控制报文的最小时间间隔,对端支持的接收BFD控制报文的最小时间间隔)。
·     IPv4控制报文方式多跳检测静态BFD会话
·     IPv4 echo报文方式多跳检测静态BFD会话
·     IPv6控制报文方式多跳检测静态BFD会话
·     IPv6 echo报文方式多跳检测静态BFD会话
# 配置控制报文多跳检测的BFD检测时间倍数为6。
[Sysname] bfd multi-hop detect-multiplier 6
bfd multi-hop min-echo-receive-interval命令用来配置接收多跳echo报文的最小时间间隔。
undo bfd multi-hop min-echo-receive-interval命令用来恢复缺省情况。
bfd multi-hop min-echo-receive-interval interval
接收多跳echo报文的最小时间间隔缺省为400毫秒。
静态BFD会话视图
interval:接收echo报文的最小时间间隔,单位为毫秒。取值范围为0或3~10000。
设备发送多跳echo报文的时间间隔与接收多跳echo报文的时间间隔相同。使用本命令,设备能够控制接收两个多跳echo报文之间的时间间隔,进而控制发送多跳echo报文的时间间隔。
对于静态BFD会话,仅IPv4或IPv6 echo报文方式多跳检测的静态BFD会话视图下支持配置本命令。
# 配置接收多跳echo报文的最小时间间隔为500毫秒。
[Sysname] bfd multi-hop min-echo-receive-interval 500
·     bfd static
bfd multi-hop min-receive-interval命令用来配置接收多跳BFD控制报文的最小时间间隔。
undo bfd multi-hop min-receive-interval命令用来恢复缺省情况。
接收多跳BFD控制报文的最小时间间隔为400毫秒。
静态BFD会话视图
interval:接收BFD控制报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
本命令主要为了防止对端设备发送报文的速度超出本地接收报文的能力(接收BFD控制报文的最小时间间隔),若超出,则对端设备将发送BFD控制报文的时间间隔动态调整为本地接收BFD控制报文的最小时间间隔。
# 配置接收多跳BFD控制报文的最小时间间隔为500毫秒。
[Sysname] bfd multi-hop min-receive-interval 500
bfd multi-hop min-transmit-interval命令用来配置发送多跳BFD控制报文的最小时间间隔。
undo bfd multi-hop min-transmit-interval命令用来恢复缺省情况。
发送多跳BFD控制报文的最小时间间隔为400毫秒。
静态BFD会话视图
interval:发送BFD控制报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
# 配置发送多跳BFD控制报文的最小时间间隔为500毫秒。
[Sysname] bfd multi-hop min-transmit-interval 500
bfd session init-mode命令用来配置BFD会话建立前的运行模式。
undo bfd session init-mode命令用来恢复缺省情况。
BFD会话建立前的运行模式为主动模式。
active:主动模式。在建立会话前不管是否收到对端发来的BFD控制报文,都会主动向会话的对端发送BFD控制报文。
passive:被动模式。在建立会话前不会主动向会话的对端发送BFD控制报文,只有等收到BFD控制报文后才会向对端发送BFD控制报文。
通信双方至少要有一方运行在主动模式才能成功建立起BFD会话。
BFD版本0不支持本命令,配置不生效。
# 配置BFD会话建立前的运行模式为被动模式。
[Sysname] bfd session init-mode passive
bfd session-negotiation delay-upon-down命令用来开启延迟DOWN状态的BFD会话进行协商的功能,并设置延迟会话协商的时间。
undo bfd session-negotiation delay-upon-down命令用来恢复缺省情况。
仅R5212及以上版本支持本命令。
bfd session-negotiation delay-upon-down interval
延迟DOWN状态的BFD会话进行协商的功能处于开启状态且延迟会话协商的时间为10秒。
interval:设置延迟DOWN状态的BFD会话进行协商的时间,取值范围为1~1200,单位为秒。
在上层应用使用BFD检测主用路径的场景中,主用路径DOWN后,触发上层协议进行主备路径切换。如果主路径故障恢复前,检测主用路径的BFD会话重新UP,将会触发备份路径切换到处于故障状态的主路径,会导致流量丢失。使用本功能可以解决上述问题。
开启本功能后,工作机制如下:
·     设备将对每一个从UP状态切换为DOWN状态的BFD会话启动一个定时器,在定时器超时前,对应的会话不会进行重协商。
·     任何新建立的BFD会话,设备都会启动定时器。在定时器超时前,不会重新进行会话协商。
# 开启延迟DOWN状态的BFD会话进行会话协商的功能,并设置延迟会话协商的时间为6秒。
[Sysname] bfd session-negotiation delay-upon-down 6
·     display bfd session
1.1.25  bfd static
bfd static命令用来创建静态BFD会话,并进入静态BFD会话视图。如果指定的BFD会话已经存在,则直接进入静态BFD会话视图。
undo bfd static命令用来删除静态BFD会话及静态BFD会话视图下的所有配置。
IPv4控制报文方式单跳检测:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address ]
IPv4控制报文方式多跳检测:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address [ track-interface interface-type interface-number ] ]
IPv4 echo报文方式单跳检测:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator auto ] ]
IPv4 echo报文方式多跳检测:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator auto ] ]
IPv6控制报文方式单跳检测:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address ]
IPv6控制报文方式多跳检测:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ track-interface interface-type interface-number ] ]
IPv6 echo报文方式单跳检测:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator auto ] ]
IPv6 echo报文方式多跳检测:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator auto ] ]
对端地址固定为组播地址224.0.0.184的IPv4控制报文方式单跳检测静态BFD会话:
bfd static session-name [ peer-ip default-ip interface interface-type interface-number source-ip ip-address ]
删除静态BFD会话:
undo bfd static session-name
不存在静态BFD会话。
系统视图。
session-name:静态BFD会话的名称,为1~64个字符的字符串,区分大小写。
peer-ip ipv4-address:静态BFD会话的对端IPv4地址,点分十进制形式,取值范围为合法的单播IPv4地址。对于控制报文方式的静态BFD,peer-ip地址和source-ip地址共同决定了静态BFD需要检测的路径。对于echo报文方式的静态BFD,peer-ip地址和destination-ip地址共同决定了静态BFD需要检测的路径。
peer-ipv6 ipv6-address:静态BFD会话的对端IPv6地址。对于控制报文方式的静态BFD,peer-ipv6地址和source-ipv6地址共同决定了静态BFD需要检测的路径。对于echo报文方式的静态BFD,peer-ipv6地址和destination-ipv6地址共同决定了静态BFD需要检测的路径。
default-ip:静态BFD会话的对端地址固定为组播地址224.0.0.184。
vpn-instance vpn-instance-name:指定静态BFD会话所属的VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,表示静态BFD会话属于公网实例。
interface interface-type interface-number:指定BFD会话所在的本地接口。interface-type interface-number表示接口类型和接口编号。指定本参数后,BFD将以该接口作为出接口发送报文。
destination-ip ipv4-address:指定echo报文的目的地址,点分十进制形式,取值范围为合法的单播IPv4地址。该地址为本端IPv4地址。
destination-ipv6 ipv6-address:指定echo报文的目的IPv6地址。该地址为本端IPv6地址。
source-ip ipv4-address:BFD报文的源IPv4地址,点分十进制形式,取值范围为合法的单播IPv4地址。
source-ipv6 ipv6-address:BFD报文的源IPv6地址。
one-arm-echo:指定静态BFD会话的方式为echo报文方式。
auto:采用自协商方式获取BFD会话的本地标识符。指定本参数后,设备自动为静态BFD会话分配本地标识符。
track-interface interface-type interface-number:指定静态BFD会话监视的接口,当接口故障时,静态BFD会话状态变为down。interface-type interface-number表示接口类型和接口编号。如果未指定本参数,静态BFD会话不会监视任何接口。
创建的静态BFD会话可以用来进行BFD单跳检测和多跳检测。
如果对端静态创建控制报文方式的静态BFD会话,那么本端必须通过本命令创建静态BFD会话,且两端的静态BFD会话的配置项必须匹配,例如,本端执行如下配置:
(1)     系统视图下配置bfd static abc peer-ip 20.1.1.1 source-ip 20.1.1.2。
(2)     静态BFD会话abc视图下配置discriminator local 513与discriminator remote 514。
对端需要执行如下配置才能建立静态BFD会话:
(1)     系统视图下配置bfd static bcd peer-ip 20.1.1.2 source-ip 20.1.1.1。
(2)     静态BFD会话bcd视图下配置discriminator local 514与discriminator remote 513。
创建和修改静态BFD会话时,需要注意:
·     首次创建静态BFD会话时,必须指定静态BFD会话的对端IPv4或IPv6地址。通过bfd static session-name命令只能进入已经存在的静态BFD会话视图。系统仅检查IP地址的形式,不检查其正确性。指定错误的目的IP地址或源IP地址均会导致静态BFD会话无法建立。
·     对于控制报文方式的静态BFD会话,必须通过discriminator命令为静态BFD会话指定本地标识符和远端标识符。否则,静态BFD会话的配置不会生效。
·     如果使用echo报文方式的静态BFD会话进行检测,仅需在本端创建静态BFD会话。创建echo报文方式的静态BFD会话时,如果未指定source-ip/source-ipv6参数,将使用bfd echo-source-ip/bfd echo-source-ipv6命令配置的地址作为BFD报文IP头的源地址。如果用户既未指定source-ip/source-ipv6参数,也未配置bfd echo-source-ip/bfd echo-source-ipv6命令,BFD报文IP头中的源IPv4/IPv6地址为destination-ip/destination-ipv6参数指定的IPv4/IPv6地址。
建议用户创建echo报文方式的静态BFD会话时指定source-ip/source-ipv6参数,且配置的echo报文源地址不能属于该设备任何一个接口所在的网段。
·     使用控制报文方式的静态BFD会话进行单跳检测时,需要保证创建的静态BFD会话的peer-ip为对端静态BFD会话所在接口的IP地址,source-ip为本端静态BFD会话所在接口的IP地址,否则无法建立静态BFD会话。
·     不能通过重复执行本命令修改静态BFD会话。如需修改静态BFD会话,请先通过undo bfd static命令删除静态BFD会话,再执行bfd static命令。
·     不同的静态BFD会话的本地标识符不能相同。
BFD报文IP头中源IP地址和目的IP地址的获取方式与BFD会话的工作方式有关,具体如下:
·     对于控制报文方式的静态BFD,BFD报文IP头中的源IP地址为source-ip/source-ipv6,目的IP地址为peer-ip/peer-ipv6
·     对于echo报文方式的静态BFD,BFD报文IP头中的源IP地址为source-ip/source-ipv6,目的IP地址为destination-ip/destination-ipv6。如果用户既未指定source-ip/source-ipv6参数,也未配置bfd echo-source-ip/bfd echo-source-ipv6命令,BFD报文IP头中的源IPv4/IPv6地址为destination-ip/destination-ipv6参数指定的IPv4/IPv6地址。
·     配置bfd static session-name peer-ip default-ip interface interface-type interface-number source-ip ip-address命令检测接口数据链路层的连通性。对于配置了IP地址的接口,建议将source-ip指定为该接口的IP地址;如果接口未配置或无法配置IP地址,建议将source-ip指定为0.0.0.0以外的单播地址。只能使用一个静态BFD会话检测同一个接口数据链路层的连通性。
EVPN VPWS双归属组网中,当DF侧AC故障时,BDF无法快速感知该故障并切换为DF。通过在DF上配置静态BFD会话监测本地AC接口的状态(通过指定track-interface参数),并在BDF上配置evpn track bfd命令,可以实现:
(1)     DF侧AC故障时,DF上的静态BFD会话状态变为down,并将静态BFD会话状态通告给BDF。
(2)     BDF快速切换为DF,缩短DF的切换时间,减少丢包。
关于EVPN VPWS组网以及DF选举的详细介绍,请参见“EVPN配置指导”中的“EVPN VPWS”。
静态BFD会话支持监视的接口类型如下:
·     二层以太网接口
·     三层以太网接口及其子接口
·     二层聚合接口及二层聚合口的成员端口
·     三层聚合接口、三层聚合接口的子接口以及三层聚合口的成员端口
# 创建名称为abc的静态BFD会话,并进入静态BFD会话视图。对1.1.1.1和1.1.1.2之间的路径进行检测,并通过接口HundredGigE1/0/1发送BFD报文。其中,BFD报文的源IP地址为1.1.1.1,目的IP地址为1.1.1.2,本地标识符为1537,远端标识符为2048。
[Sysname] bfd static abc peer-ip 1.1.1.2 interface hundredgige 1/0/1 source-ip 1.1.1.1
[Sysname-bfd-static-session-abc] discriminator local 1537
[Sysname-bfd-static-session-abc] discriminator remote 2048
# 创建名称为abc的echo报文方式静态BFD会话,并进入静态BFD会话视图。对1.1.1.1和1.1.1.2之间的路径进行检测,并通过接口HundredGigE1/0/1发送BFD报文。其中,BFD报文的源IP地址为9.9.9.9,目的IP地址为本机地址1.1.1.2。
[Sysname] bfd static abc peer-ip 1.1.1.1 interface hundredgige 1/0/1 destination-ip 1.1.1.2 source-ip 9.9.9.9 one-arm-echo discriminator auto
·     bfd echo-source-ip
·     bfd echo-source-ipv6
·     discriminator
1.1.26  bfd template
bfd template命令用来创建BFD模板,并进入BFD模板视图。如果指定的BFD模板已经存在,则直接进入BFD模板视图。
undo bfd template命令用来删除BFD模板。
bfd template template-name
undo bfd template template-name
不存在BFD模板。
template-name:BFD模板名称,为1~63个字符的字符串,区分大小写。
# 创建BFD模板bfd1,并进入BFD模板视图。
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1]
discriminator命令用来指定静态BFD会话的本地标识符和远端标识符。
undo discriminator命令用来删除静态BFD会话的本地标识符和远端标识符。
discriminator { local local-value | remote remote-value }
undo discriminator { local local-value | remote remote-value }
未指定静态BFD会话的本地标识符和远端标识符。
静态BFD会话视图
local local-value:指定静态BFD会话的本地标识符。local-value表示静态BFD会话的本地标识符,取值范围为1~32768。
remote remote-value:指定静态BFD会话远端标识符。remote-value表示静态BFD会话的远端标识符,取值范围为1~4294967295。
本命令仅用于创建静态BFD会话时未指定静态BFD会话标识符的场景。
不能通过重复执行本命令修改静态BFD会话的本地标识符或远端标识符。如需修改,请先通过undo discriminator命令删掉相应的静态BFD会话的本地标识符或远端标识符,再执行discriminator命令为静态BFD会话配置新的本地标识符或远端标识符。
# 指定名称为abc的静态BFD会话的本地标识符为1537,远端标识符为2048。
·     bfd static
display bfd session命令用来显示BFD会话信息。
display bfd session [ discriminator local-value | discriminator local local-value | static name session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ peer-ip { ipv4-address | default-ip } [ vpn-instance vpn-instance-name ] ] [ interface interface-type interface-number ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ interface interface-type interface-number ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] lsp [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ fec-destination-ip ipv4-address  mask-length ] [ policy policy-name ] [ color color-value ] [ { end-point ipv4-address | end-point-ipv6 ipv6-address } ] [ nhlfe nid ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] te [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ interface interface-type interface-number ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] pw [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] srv6-policy [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ policy policy-name ] [ color color-value ] [ end-point ipv4-address | end-point-ipv6 ipv6-address ] [ nhlfe nid ]  [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ peer-ip { ipv4-address | default-ip } [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
discriminator local-value:显示指定本地标识符的BFD会话信息。local-value为本地标识符的值,取值范围为1~4294967295。如果未指定本参数,将显示所有BFD会话概要信息。
discriminator local local-value:显示指定本地标识符的BFD会话信息。local-value为本地标识符的值,取值范围为1~4294967295。如果未指定本参数,将显示所有BFD会话概要信息。
dynamic:显示动态BFD会话的信息。
static:显示静态BFD会话的信息。
name session-name:显示指定名称的静态BFD会话的详细信息,session-name表示静态BFD会话的名称,为1~15个字符的字符串,区分大小写。
control:显示控制报文方式的BFD会话信息。
echo:显示echo报文方式的BFD会话信息。
ip:显示检测IPv4链路的BFD会话信息。
ipv6:显示检测IPv6链路的BFD会话信息。
lsp:显示检测LSP链路的BFD会话信息。
peer-ip ipv4-address:显示指定对端IPv4地址的BFD会话信息,ipv4-address表示对端IPv4地址,为点分十进制形式。
peer-ipv6 ipv6-address:显示指定对端IPv6地址的BFD会话信息,ipv6-address表示对端IPv6地址。
pw:显示检测PW链路的BFD会话信息。
srv6-policy:显示检测SRv6 TE Policy的BFD会话信息。
te:显示检测TE隧道的BFD会话信息。
color color-value:显示检测SR TE Policy或者SRv6 TE Policy的BFD会话信息,且被检测的SR TE Policy或者SRv6 TE Policy的Color属性为指定的color-valuecolor-value表示SR-MPLS TE Policy或者SRv6 TE Policy的Color属性,取值范围为0~4294967295。
end-point ipv4-address:显示检测SR TE Policy的BFD会话信息,且被检测的SR TE Policy目的节点的IPv4地址为指定的ipv4-addressipv4-address表示目的节点的IPv4地址。
end-point-ipv6 ipv6-address:显示检测SRv6 TE Policy的BFD会话信息,且被检测的SRv6 TE Policy目的节点的IPv6地址为指定的ipv6-addressipv6-address表示目的节点的IPv6地址。
fec-destination-ip ipv4-address mask-length:显示检测IPv4 FEC的BFD会话信息,且被检测的IPv4 FEC的目的地址和掩码分别为指定的ipv4-addressmask-lengthipv4-address为FEC的目的IPv4地址;mask-length为FEC目的IPv4地址的掩码长度,取值范围为0~32。
interface interface-type interface-number:显示指定出接口的BFD会话信息。
nhlfe nid:显示检测指定索引号对应的转换发路径的BFD会话信息。nid为NHLFE(Next Hop Label Forwarding Entry,下一跳标签转发项)表项索引,取值范围为0~4294967295。
policy policy-name:显示检测指定SR TE Policy或者SRv6 TE Policy的BFD会话信息。policy-name为SR TE Policy或者SRv6 TE Policy的名称,为1~59个字符的字符串,区分大小写。
state:显示不同状态下的BFD会话信息。
admin-down:显示会话状态为AdminDown的BFD会话信息。
down:显示会话状态为Down的BFD会话信息。
init:显示会话状态为Init的BFD会话信息。
up:显示会话状态为Up的BFD会话信息。
discriminator remote remote-value:显示指定远端标识符的BFD会话信息。remote-value表示BFD会话的远端标识符的值,取值范围为1~4294967295。
default-ip:显示对端地址固定为组播地址224.0.0.184的BFD会话信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BFD会话信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则显示公网实例的BFD会话信息。
verbose:显示会话的详细信息。如果未指定本参数,将显示BFD会话概要信息。
如果未指定dynamicstatic参数,将显示所有动态BFD会话和静态BFD会话的信息。
使用display bfd session discriminator local-value命令和display bfd session discriminator local local-value命令均可以显示指定本地标识符的BFD会话信息。通过display bfd session discriminator local-value命令显示指定本地标识符的BFD会话信息时,无需指定local参数,使用更便捷。
# 显示所有BFD会话的信息。
<Sysname> display bfd session
 Total Sessions: 4     Up Sessions: 4     Init Mode: Active
 IPv4 session working in control mode:
 LD/RD            SourceAddr      DestAddr        State Running Up for Holdtime
 513/513          1.1.1.1         1.1.1.2         Up    00:00:20       2297ms
   HGE1/0/1
 IPv6 session working in control mode:
       Local discr: 513                  Remote discr: 513
         Source IP: FE80::20C:29FF:FED4:7171
    Destination IP: FE80::20C:29FF:FE72:AC4D
     Session state: Up                      Interface: HGE1/0/2
         Hold time: 2142ms             Running Up for: 00:05:22
 IPv4 static session working in echo packet mode:
 LD               SourceAddr      DestAddr        State Running Up for Holdtime
 327             192.168.1.101   192.168.1.83    Up     00:00:20       2050ms
   HGE1/0/1
 MPLS LSP session working in control packet mode:
 LD/RD           SourceIP        DestinationIP   State   Holdtime    Interface
 32769/32769     2.2.2.9         127.0.0.1       Up      4990ms      N/A
 MPLS TE session working in echo mode:
 LD              SourceIP        DestinationIP   State   Holdtime    Interface
 32777           1.1.1.1         3.3.3.3         Up      4430ms      Tun0
表1-1 display bfd session命令显示信息描述表
Total sessions
所有BFD会话的数目
Up sessions
up的BFD会话的数目
Init mode
BFD运行模式:
·     Active:主动模式
·     Passive:被动模式
XX session working in yy mode
BFD会话类型及工作方式,有以下几种情况:
·     IPv4 session working in control mode:IPv4 BFD会话,工作方式为控制报文方式
·     IPv4 session working in echo mode:IPv4 BFD会话,工作方式为echo报文方式
·     IPv6 session working in control mode:IPv6 BFD会话,工作方式为控制报文方式
·     IPv6 session working in echo mode:IPv6 BFD会话,工作方式为echo报文方式
·     IPv4 static session working in control packet mode:IPv4静态BFD会话,工作方式为控制报文方式
·     IPv6 static session working in control packet  mode:IPv6静态BFD会话,工作方式为控制报文方式
·     MPLS LSP session working in control packet mode:检测LSP的BFD会话,工作方式为控制报文方式
·     MPLS LSP session working in echo mode:检测LSP的BFD会话,工作方式为echo报文方式
·     MPLS TE session working in control packet mode:检测MPLS TE隧道的BFD会话,工作方式为控制报文方式
·     MPLS TE session working in echo mode:检测MPLS TE隧道的BFD会话,工作方式为echo报文方式
·     IPv6 SR policy session working in echo mode:检测SRv6隧道的BFD会话,工作方式为echo报文方式
·     IPv4 SDWAN session working in control packet mode:检测IPv4 SDWAN隧道的BFD会话,工作方式为控制报文方式
·     IPv6 SDWAN session working in control packet mode:检测IPv6 SDWAN隧道的BFD会话,工作方式为控制报文方式
·     IPv6 SR policy session working in echo mode:检测SRv6 TE Policy的BFD会话,工作方式为echo报文方式
LD/RD
LD表示会话的本地标识符,RD表示会话的远端标识符
SourceAddr
会话的源IP地址
DestAddr
会话的目的IP地址
会话状态,包括Down、ADown、Init和Up
Holdtime
离会话检测时间超时的剩余时间。BFD会话处于down状态时,显示为0ms
会话所在的接口名
Local discr
IPv6类型的BFD会话的本地标识符
Remote discr
IPv6类型的BFD会话的远端标识符
Source IP
IPv6类型的BFD会话的源IP地址
Destination IP
IPv6类型的BFD会话的目的IP地址
Session state
IPv6类型的BFD会话状态,包括Down、ADown、Init和Up
Running Up for
会话持续Up的时间,格式为hh:mm:ss,其中hh为小时,mm为分钟,ss为秒
Hold time
IPv6类型的BFD会话离检测时间超时的剩余时间。BFD会话处于down状态时,显示为0ms
# 显示BFD会话的详细信息。
<Sysname> display bfd session verbose
       Local Discr: 513                  Remote Discr: 513
         Source IP: 1.1.1.1            Destination IP: 1.1.1.2
  Destination port: 3784                Session State: Up
         Interface: HundredGigE1/0/1
      Min Tx Inter: 500ms                Act Tx Inter: 500ms
      Min Rx Inter: 500ms                Detect Inter: 2500ms
          Rx Count: 42                       Tx Count: 43
      Connect Type: Direct             Running Up for: 00:00:20
         Hold Time: 2078ms                  Auth mode: None
       Detect Mode: Async                        Slot: 0
          Protocol: OSPF
           Version: 1
         Diag Info: No Diagnostic
        Hardware mode: Disable
         Interface: HundredGigE1/0/2
          Rx Count: 38                       Tx Count: 38
      Connect Type: Direct             Running Up for: 00:07:01
         Hold Time: 2211ms                  Auth Mode: None
          Protocol: OSPFv3
           Version: 1
      Session name: abc
       Local Discr: 310                  Remote Discr: 308
         Source IP: 12.1.1.1           Destination IP: 12.1.1.2
          Rx Count: 514                      Tx Count: 514
         Hold Time: 2120ms                  Auth Mode: None
          Protocol: STATIC_IPv4
           Version: 1
      Session name: bbbb
       Local Discr: 1700                 Remote Discr: 1700
      Connect Type: Direct             Running Up for: 00:12:01
          Protocol: STATIC_IPv6
           Version: 1
表1-2 display bfd session verbose命令显示信息描述表
Total Sessions
所有BFD会话的数目
Up Sessions
up的BFD会话的数目
Init Mode
BFD运行模式:
·     Active:主动模式
·     Passive:被动模式
·     IPv6 SR session working in echo mode:检测SRv6隧道的BFD会话,工作方式为echo报文方式
Session name
静态BFD会话名称。只有静态BFD会话才会显示该字段
Local Discr
会话的本地标识符
Remote Discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Destination port
BFD报文的目的端口号。常用的目的端口号包括:
·     控制报文单跳检测的目的端口号为3784
·     echo报文单跳或多跳检测的目的端口号均为3785
·     控制报文多跳检测的目的端口号为4784
·     链路聚合与BFD联动的控制报文的目的端口号为6784
对于非直连且通过IP路由转发协议报文的BFD会话,如果收到的报文的目的端口号与本端使用的端口号不同,本端将使用收到报文的目的端口号作为发送报文的目的端口号
Session State
会话所在的接口名
Min Tx Inter
最小发送时间间隔
Min Rx Inter
最小接收时间间隔
Act Tx Inter
实际发送间隔
Detect Inter
实际检测间隔
Rx Count
接收的报文数
Tx Count
发送的报文数
Hold Time
离会话检测时间超时的剩余时间
Auth mode
会话的认证模式
Connect Type
接口的连接类型:
·     Direct:直连
·     Indirect:非直连
Running up for
Detect Mode
检测模式:
·     Async:异步模式
·     Demand:查询模式
·     Async/Echo:开启了echo功能的异步模式
·     Demand/Echo:开启了echo功能的查询模式
Slot
BFD会话所在的slot编号
Protocol
协议名:
·     OSPF:OSPF与BFD联动的BFD会话
·     ISIS_BR_L1:IS-IS与BFD联动的BFD会话,其中IS-IS的网络类型为广播网络,路由器类型为Level-1
·     ISIS_BR_L2:IS-IS与BFD联动的BFD会话,其中IS-IS的网络类型为广播网络,路由器类型为Level-2
·     ISIS_P2P:IS-IS与BFD联动的BFD会话,其中IS-IS的网络类型为P2P
·     ISIS6_BR_L1:IPv6 IS-IS与BFD联动的BFD会话,其中IPv6 IS-IS的网络类型为广播网络,路由器类型为Level-1
·     ISIS6_BR_L2:IPv6 IS-IS与BFD联动的BFD会话,其中IPv6 IS-IS的网络类型为广播网络,路由器类型为Level-2
·     ISIS6_P2P:IPv6 IS-IS与BFD联动的BFD会话,其中IPv6 IS-IS的网络类型为P2P
·     BGP:BGP与BFD联动的BFD会话
·     MPLS_RSVP:RSVP与BFD联动的BFD会话
·     STATIC4:静态路由与BFD联动的BFD会话
·     TRACK:Track与BFD联动的BFD会话
·     RIP:RIP与BFD联动的BFD会话
·     IPFRR:FIB IP FRR与BFD联动的BFD会话
·     MAD:MAD与BFD联动的BFD会话
·     MPLS_LSPV:检测LSP的BFD会话
·     OSPFv3:OSPFv3与BFD联动的BFD会话
·     BGP4+:IPv6 BGP与BFD联动的BFD会话
·     PIM:PIM与BFD联动的BFD会话
·     PIM6:IPv6 PIM与BFD联动的BFD会话
·     STATIC6:IPv6静态路由与BFD联动的BFD会话
·     RIPNG:RIPng与BFD联动的BFD会话
·     Interface:检测接口状态类型的BFD会话
·     TUNNEL:检测隧道的BFD会话
·     VTEP:检测VTEP的BFD会话
·     LAGG:检测聚合链路的BFD会话
·     STATIC_IPv4:IPv4静态BFD会话
·     STATIC_IPv6:IPv6静态BFD会话
·     SDWAN:检测SDWAN隧道的BFD会话
Version
版本号
Diag Info
会话的诊断信息:
·     No Diagnostic:表示无诊断信息
·     Control Detection Time Expired:表示Ctrl会话本端检测时间超时,会话down
·     Echo Function Failed:表示Echo会话本端检测时间超时或echo报文的源IP地址被删除,会话down
·     Neighbor Signaled Session Down:表示对端通知本端BFD会话down
·     Administratively Down:表示本端系统阻止BFD会话的建立
Hardware mode
硬件处理BFD报文模式:
·     Enabled:硬件处理BFD报文模式处于开启状态
·     Disabled:硬件处理BFD报文模式处于关闭状态,此时由软件处理BFD报文
first-fail-timer命令用来配置首次建立检测设备间数据链路层连通性的静态BFD会话失败时,通知数据链路层BFD会话down的超时时间。
undo first-fail-timer命令用来恢复缺省情况。
首次建立检测设备间数据链路层连通性的静态BFD会话失败时,不会通知数据链路层BFD会话down。
静态BFD会话视图
seconds:首次建立检测设备间数据链路层连通性的静态BFD会话失败时,通知数据链路层BFD会话down的超时时间,取值范围为1~10000,单位为秒。
配置本命令后,在seconds时间内,检测设备间数据链路层连通性的静态BFD会话未能成功建立时,BFD会将此消息通知给数据链路层,并将接口的数据链路层协议状态置为“DOWN(BFD)”。此时,执行display bfd session命令显示该静态BFD会话的状态为Down,执行display interface命令会显示与该静态BFD会话联动的接口的Line protocol state为DOWN(BFD)。
本命令仅用于接口状态与静态BFD会话(通过bfd static命令创建)联动的场景中,即只有将接口状态与该静态BFD会话关联后(配置process-interface-status命令),本命令才会生效。
本端配置设备间数据链路层连通性的静态BFD会话后,如果对端未配置检测设备间数据链路层连通性的静态BFD会话或两端BFD的认证配置不一致等原因,均会导致首次建立检测数据链路层连通性的BFD会话失败。
# 配置首次建立检测设备间数据链路层连通性的静态BFD会话abc失败时,通知数据链路层BFD会话down的超时时间为100秒。
[Sysname] bfd static abc peer-ip default-ip interface hundredgige 1/0/1 source-ip 10.1.1.1 discriminator local 1 remote 1
[Sysname-bfd-static-session-1] first-fail-timer 100
·     bfd static
·     processing-interface-status
hardware-resource bfd_enhance命令用来配置BFD优化功能。
hardware-resource bfd_enhance { enable | disable }
BFD优化功能处于开启状态。
enable:开启BFD优化功能。
disable:关闭BFD优化功能。
# 将设备的BFD优化功能关闭。
[Sysname] hardware-resource bfd_enhance disable
Do you want to change the specified hardware resource working mode? [Y/N]: y
The hardware resource working mode is changed.
process-interface-status命令用来配置接口状态与静态BFD会话联动。
undo process-interface-status命令用来恢复缺省情况。
接口状态不与静态会话联动,即静态BFD会话状态的改变不会影响接口数据链路层协议状态。
静态BFD会话视图
通过对端地址固定为组播地址224.0.0.184的静态BFD会话检测到数据链路发生故障时,若开启了本功能,则BFD检测到故障且会话进入Down状态时,将建立数据链路的接口链路层协议状态置为DOWN(BFD)。可通过display interface命令查看接口的Line protocol state状态信息。
# 配置接口HundredGigE1/0/1的状态与静态BFD会话abc联动。
[Sysname-bfd-static-session-abc] process-interface-status
·     bfd static
·     display interface
reset bfd session statistics命令用来清除所有BFD会话的统计信息。
# 清除所有BFD会话的统计信息。
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd命令用来开启BFD的告警功能。
undo snmp-agent trap enable bfd命令用来关闭BFD的告警功能。
BFD的告警功能处于开启状态。
开启BFD模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。(有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。)
# 关闭BFD的告警功能。
[Sysname] undo snmp-agent trap enable bfd
special-processing命令用来开启对检测数据链路层连通性的静态BFD会话进行特殊处理的功能。
undo special-processing命令用来关闭对检测数据链路层连通性的静态BFD会话进行特殊处理的功能。
undo special-processing [ admin-down | authentication-change | session-up ] *
对检测数据链路层连通性的静态BFD会话进行特殊处理的功能处于关闭状态。
静态BFD会话视图
admin-down:本端收到会话状态为AdminDown的BFD报文时,将静态BFD会话down的消息通知给数据链路层。使用本参数,有利于快速发现BFD会话被手工关闭的建立数据链路的接口。如果未配置本参数,本端收到会话状态为AdminDown的BFD报文,将静态BFD会话状态置为down,但是不会将BFD会话down的消息通知给数据链路层。
authentication-change:本端认证信息发生变化时,立即将静态BFD会话状态置为down。使用本参数,有利于快速发现认证信息不一致的建立数据链路的接口。如果未配置本参数,本端认证信息发生变化时,会预留时间给用户修改本端或对端的认证参数,如果预留时间结束时,两端认证信息仍未达成一致,本端会将静态BFD会话状态置为down。
session-up:本端静态BFD会话处于up状态时,不再检查收到的BFD报文中的认证信息。当设备上的BFD会话数量较多时,检查BFD报文中携带的认证信息会影响设备性能。配置本参数后,不再检查收到的报文中的认证信息,从而可以降低对设备性能的影响。如果未配置本参数,本端静态BFD会话处于状态up时,会检查收到的BFD报文中的认证信息,需要保证静态BFD会话两端认证信息的一致性,否则会导致静态BFD会话down。
如果未指定任何参数,将开启或关闭对检测数据链路层连通性的静态BFD会话进行所有特殊处理的功能。
# 开启对检测数据链路层连通性的静态BFD会话abc进行特殊处理的功能,其中建立数据链路的本端接口为HundredGigE1/0/1。对静态BFD会话abc进行的特殊处理包括收到会话状态为AdminDown的BFD报文、本端认证信息发生变化以及BFD会话处于up状态时对收到的BFD报文中认证信息检查的特殊处理。
[Sysname-bfd-static-session-1] special-processing
·     bfd static
·     process-interface-status
1.2  SBFD配置命令
bfd detect-multiplier命令用来配置SBFD检测时间倍数。
SBFD检测时间倍数为5。
BFD模板视图
value:SBFD检测时间倍数,取值范围为3~50。
检测时间倍数,即允许Initiator发送SBFD报文的最大连续丢包数。
实际检测时间为Initiator的检测时间倍数和发送SBFD报文的最小时间间隔的乘积。
# 在BFD模板abc中,配置SBFD检测时间倍数为6。
[Sysname] bfd template abc
[Sysname-bfd-template-abc] bfd detect-multiplier 6
·     bfd min-transmit-interval
bfd dynamic-udp-port enable命令用来开启动态修改SBFD报文端口号功能。
undo bfd dynamic-udp-port enable命令用来关闭动态修改SBFD报文端口号功能。
动态修改SBFD报文端口号功能处于关闭状态。
应用场景
SBFD检测两台设备间的链路连通性时,如果两台设备间存在多条可达路径(例如ECMP或聚合链路),设备在转发SBFD报文时会根据UDP端口号作为报文特征来选择特定的转发路径。缺省情况下,对于同一个SBFD会话,SBFD报文的源端口号在会话开始时随机生成后保持不变,而目的端口号则根据会话类型确定,并在整个会话期间保持一致。
这种情况会导致设备始终使用同一条路径转发SBFD报文。一旦该路径出现故障,SBFD会话将变为Down状态。这意味着网络的冗余能力没有得到充分利用,对链路连通性检测的准确性和网络的稳定性构成了挑战。本功能用于解决上述问题。
工作机制
SBFD检测两台设备间的链路连通性时,对于不同报文方式的会话,需要在不同的设备上配置本命令。具体如下:
·     对于控制报文方式的SBFD会话,需要在这两台设备上同时配置本命令。
·     对于echo报文方式的SBFD会话,仅需要在发送echo报文的设备上配置本命令。
配置本命令后,Initiator端转发SBFD报文时修改报文的源端口号,Reflector端转发SBFD报文时修改报文的目的端口号,使得设备能够选择不同的路径转发SBFD报文,避免单链路故障导致SBFD会话Down。
注意事项
本功能为H3C私有实现,在与其他厂商设备对接的场景中,建议不要使用本功能,否则可能导致SBFD会话震荡。
本命令仅对由硬件维护的SBFD会话生效。配置本命令后,对于配置本命令前已创建的SBFD会话以及配置本命令后新创建的SBFD会话均生效。
# 开启动态修改SBFD报文源端口号功能。
bfd min-transmit-interval命令用来配置发送SBFD报文的最小时间间隔。
发送SBFD报文的最小时间间隔为400毫秒。
BFD模板视图
interval:发送SBFD报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
本命令主要是为了保证发送SBFD控制报文的速度不能超过设备发送报文的能力。
Initiator实际发送SBFD报文的时间间隔即为本地配置的发送SBFD报文的最小时间间隔。
# 在BFD模板abc中,配置发送SBFD报文的最小时间间隔为500毫秒。
[Sysname-bfd-template-abc] bfd min-transmit-interval 500
·     bfd detect-multiplier
bfd multi-hop detect-multiplier命令用来配置SBFD检测时间倍数。
SBFD检测时间倍数为5。
# 配置SBFD检测时间倍数为6。
bfd multi-hop min-transmit-interval命令用来配置发送SBFD控制报文的最小时间间隔。
发送SBFD控制报文的最小时间间隔为400毫秒。
interval:发送SBFD控制报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
# 配置发送SBFD控制报文的最小时间间隔为500毫秒。
bfd session-negotiation delay-upon-down命令用来开启延迟DOWN状态的SBFD会话进行协商的功能,并设置延迟会话协商的时间。
仅R5212及以上版本支持本命令。
延迟DOWN状态的SBFD会话进行协商的功能处于开启状态且延迟会话协商的时间为10秒。
interval:设置延迟DOWN状态的SBFD会话进行协商的时间,取值范围为1~1200,单位为秒。
在上层应用使用SBFD检测主用路径的场景中,主用路径DOWN后,触发上层协议进行主备路径切换。如果主路径故障恢复前,检测主用路径的SBFD会话重新UP,将会触发备份路径切换到处于故障状态的主路径,会导致流量丢失。使用本功能可以解决上述问题。
开启本功能后,工作机制如下:
·     设备将对每一个从UP状态切换为DOWN状态的SBFD会话启动一个定时器,在定时器超时前,对应的会话不会进行重协商。
·     任何新建立的SBFD会话,设备都会启动定时器。在定时器超时前,不会重新进行会话协商。
# 开启延迟DOWN状态的SBFD会话进行会话协商的功能,并设置延迟会话协商的时间为6秒。
·     display sbfd session
1.2.7  bfd template
不存在BFD模板。
display sbfd sessioninitiator命令用来显示Initiator端的SBFD会话信息。
display sbfd session initiator [ discriminator value | verbose ]
display sbfd session initiator lsp [ state { admin-down | down | up } ] [ peer-ip ipv4-address ] [ fec-destination-ip ipv4-address mask-length ] [ discriminator remote remote-value ] [ verbose ]
display sbfd session initiator te [ state { admin-down | down |  up } ] [ peer-ip ipv4-address ] [ interface interface-type interface-number ] [ discriminator remote remote-value ] [ verbose ]
display sbfd session initiator sr-policy [ state { admin-down | down |  up } ] [ peer-ip ipv4-address ] [ policy policy-name ] [ color color-value ] [ { end-point ipv4-address | end-point-ipv6 ipv6-address } ] [ nhlfe nid ] [ discriminator remote remote-value ] [ verbose ]
display sbfd session initiator srv6-policy [ state { admin-down | down | up } ] [ peer-ipv6 ipv6-address ] [ policy policy-name ] [ color color-value ] [ { end-point ipv4-address | end-point-ipv6 ipv6-address } ] [ nhlfe nid ] [ discriminator remote remote-value ] [ verbose ]
display sbfd session initiator ipv6 [ state { admin-down | down | up } ] [ peer-ipv6 ipv6-address ] [ discriminator remote remote-value ] [ verbose ]
discriminator value:显示指定本地标识符的SBFD会话的详细信息。value为本地标识符的值,取值范围为1~4294967295。
ipv6:显示检测IPv6链路的SBFD会话。
lsp:显示检测LSP链路的SBFD会话信息。
sr-policy:显示检测SR TE Policy的SBFD会话。
srv6-policy:显示检测SRv6 TE Policy的SBFD会话。
te:显示检测TE隧道的SBFD会话信息。
color color-value:显示检测SR TE Policy或者SRv6 TE Policy的SBFD会话信息,且被检测的SR TE Policy或者SRv6 TE Policy的Color属性为指定的color-valuecolor-value表示SR-MPLS TE Policy或者SRv6 TE Policy的Color属性,取值范围为0~4294967295。
end-point ipv4-address:显示检测SR TE Policy的SBFD会话信息,且被检测的SR TE Policy目的节点的IPv4地址为指定的ipv4-addressipv4-address表示目的节点的IPv4地址。
end-point-ipv6 ipv6-address:显示检测SRv6 TE Policy的SBFD会话信息,且被检测的SRv6 TE Policy目的节点的IPv6地址为指定的ipv6-addressipv6-address表示目的节点的IPv6地址。
fec-destination-ip ipv4-address mask-length:显示检测IPv4 FEC的SBFD会话信息,且被检测的IPv4 FEC的目的地址和掩码分别为指定的ipv4-addressmask-lengthipv4-address为FEC的目的IPv4地址;mask-length为FEC目的IPv4地址的掩码长度,取值范围为0~32。
peer-ip ipv4-address:显示指定对端IPv4地址的SBFD会话信息,ipv4-address表示对端IPv4地址,为点分十进制形式。
peer-ipv6 ipv6-address:显示指定对端IPv6地址的SBFD会话信息,ipv6-address表示对端IPv6地址。
state:显示不同状态下的SBFD会话信息。
admin-down:显示会话状态为AdminDown的SBFD会话信息。
down:显示会话状态为Down的SBFD会话信息。
up:显示会话状态为Up的SBFD会话信息。
discriminator remote remote-value:显示指定远端标识符的SBFD会话信息。remote-value表示SBFD会话的远端标识符的值,取值范围为1~4294967295。
verbose:显示SBFD会话的详细信息。如果未指定本参数,将显示SBFD会话的概要信息。
如果未指定任何参数,将显示Initiator端或Reflector端的所有SBFD会话的概要信息。
# 显示所有Initiator SBFD会话的概要信息。
<Sysname> display sbfd session intiator
 Total Session Num: 2     Up Session Num: 2
 SBFD session (MPLS LSP):
          Local Discr: 1                          Remote Discr: 1000001
            Source IP: 1.1.1.1
       Destination IP: 127.0.0.1
        Session State: Up                            Hold Time: 2184ms
       Running Up for: 00:00:10
 SBFD Session (SRv6 TE policy):
          Local Discr: 34818                      Remote Discr: 16777000
            Source IP: 1::1
       Destination IP: 2::2
        Session State: Up                            Hold Time: 2180ms
       Running Up for: 00:03:35
表1-3 display sbfd session intiator命令显示信息描述表
Total Session Num
所有SBFD会话的数目
Up Session Num
up的SBFD会话的数目
SBFD session (xxx)
SBFD检测的路径类型,xxx表示路径类型:
·     MPLS LSP:MPLS LSP类型的路径
·     SRv6 TE policy:SRv6 TE Policy类型的路径
·     IPv6:IPv6链路
Local Discr
会话的本地标识符
Remote Discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Session State
SBFD会话状态,包括Up和Down
Hold Time
离会话检测时间超时的剩余时间,单位为毫秒。SBFD会话处于down状态时,显示为0ms
Running up for
# 显示Initiator端本地标识符为2的SBFD会话的详细信息。
<Sysname> display sbfd session intiator discriminator 2
          Local Discr: 2                          Remote Discr: 1000002
            Source IP: 1.1.1.2                  Destination IP: 127.0.0.2
        Session State: Up                            Hold Time: 4130ms
         Min Tx Inter: 500ms                      Act Tx Inter: 1000ms
         Detect Inter: 5000ms                   Running Up for: 00:01:30
             Rx Count: 100                            Tx Count: 100
                 Slot: 0                                   NID: 22020097
             Protocol: MPLS_LSPV
        Template Name: abc
                  FEC: TE Tunnel, 1.1.1.1/4.4.4.9/1/34246
        Hardware mode: Disabled
表1-4 display sbfd session intiator discriminator命令显示信息描述表
Local Discr
会话的本地标识符
Remote Discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Session State
会话状态,包括Up和Down
Hold Time
Min Tx Inter
当前最小发送时间间隔,单位为毫秒
Act Tx Inter
实际的发送间隔,单位为毫秒
Detect Inter
检测时间间隔,单位为毫秒
Running Up for
Rx Count
接收的报文数
Tx Count
发送的报文数
Slot
SBFD会话所在的slot编号
Color
NID
SID列表的转发表项索引,存在且非0时才会显示该字段
Protocol
协议名称
Diag Info
会话的诊断信息
·     Control Detection Time Expired:表示本端SBFD会话检测时间超时,会话down
·     Neighbor Signaled Session Down:表示对端通知本端SBFD会话down
·     Concatenated Path Down:表示与会话关联的附加路径故障,会话down
Template Name
关联的BFD模板名称。如果未关联BFD模板,则不显示该字段
FEC
转发等价类,包括以下形式:
·     LSP 目的IP地址/掩码/下一跳IP地址
·     NIL_FEC 目的IP地址/掩码/下一跳IP地址
·     IGP-PREFIX 目的IP地址/掩码/协议类型/下一跳IP地址。协议类型的取值包括:
¡     1:表示OSPF协议
¡     2:表示IS-IS协议
·     IGP-ADJ 下一跳IP地址
·     TE Tunnel, 源地址/目的地址/TunnelID/LSPID
·     PW FEC-128, 目的地址/PWID
·     EVPN PW, 目的地址/服务ID/VSI索引/链路ID
·     LSP-IPV6, 目的IPv6地址/掩码(Flex-Algo的算法标识符)/下一跳IPv6地址
·     IGP-IPV6-PREFIX, 目的IPv6地址/掩码(Flex-Algo的算法标识符)/下一跳IPv6地址
Hardware mode
硬件处理BFD报文模式:
·     Disable:硬件处理BFD报文模式处于关闭状态,此时由软件处理BFD报文
# 显示Initiator端所有SBFD会话的详细信息。
<Sysname> display sbfd session intiator verbose
            Source IP: 1.1.1.1                  Destination IP: 127.0.0.1
             Protocol: MPLS_LSPV
        Template Name: abc
            Source IP: 1::1
                Color: 10                                  NID: 2150629377
        Session State: Up                            Hold Time: 2460ms
         Detect Inter: 2500ms                   Running Up for: 00:03:41
             Rx Count: 510                            Tx Count: 510
                 Slot: 1
             Protocol: SRV6PLY
表1-5 display sbfd session intiator verbose命令显示信息描述表
Total Session Num
所有BFD会话的数目
Up Session Num
Up的BFD会话的数目
SBFD session (xxx)
·     IPv6:IPv6链路
Local Discr
会话的本地标识符
Remote Discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Session State
会话状态,包括Up和Down
Hold Time
Min Tx Inter
当前最小发送时间间隔
Act Tx Inter
实际的发送间隔
Detect Inter
检测时间间隔
Running Up for
Rx Count
接收的报文数
Tx Count
发送的报文数
Slot
SBFD会话所在的slot编号
Color
NID
Protocol
协议名称
Diag Info
会话的诊断信息
Template name
关联的BFD模板名称。关联的BFD模板名称。如果未关联BFD模板,则不显示该字段
FEC
转发等价类,包括以下形式:
¡     1:表示OSPF协议
¡     2:表示IS-IS协议
·     IGP-ADJ 下一跳IP地址
Hardware mode
硬件处理BFD报文模式:
# 显示Reflector端所有SBFD会话的概要信息。
<Sysname> display sbfd session reflector
 Local discriminator 1000001 on slot 0
 Configured mode: Explicit value
  Total Session Num: 1
        Local Discr: 1000001                  Remote Discr:1
          Source IP: 2.2.2.1
     Destination IP: 1.1.1.1
          Hold Time: 2200ms
           VRF Name: vpn1
表1-6 display sbfd session reflector命令显示信息描述表
Local discriminator xx on slot yy
在slot yy上本地标识符为xx的SBFD会话信息
Configured mode
标识符的配置形式:
·     IP Address:表示配置IPv4地址形式的Reflector端标识符
·     Explicit Value:表示配置整数形式的Reflector端标识符
Total Session Num
标识符所在slot上的会话数目
Local Discr
会话的本地标识符
Remote Discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Hold Time
离会话检测时间超时的剩余时间。SBFD会话处于down状态时,显示为0ms
VRF Name
收到SBFD会话报文的接口关联的VPN实例的名称。如果接口没有关联VPN实例,该字段显示为“-”
# 显示Reflector端本地标识符为1000001的SBFD会话的详细信息。
<Sysname> display sbfd session reflector discriminator 1000001
 Configured mode: IP Address
       Local Discr: 1000001              Remote Discr: 1
         Source IP: 2.2.2.1            Destination IP: 1.1.1.1
      Min Tx Inter: 500ms                Min Rx Inter: 10ms
      Detect Multi: 5                  Running Up for: 00:02:30
     Max Rx Period: 498ms               Max Tx Period: 1280us
         Hold Time: 2200ms
          VRF Name: vpn1
      Local Discr: 1000001              Remote Discr: 2
         Source IP: 2.2.2.2            Destination IP: 1.1.1.2
      Min Tx Inter: 1000ms               Min Rx Inter: 3790ms
      Detect Multi: 5                  Running Up for: 00:10:59
          Rx Count: 123                      Tx Count: 122
     Max Rx Period: 980ms               Max Tx Period: 580us
         Hold Time: 2500ms
          VRF Name: vpn2
表1-7 display sbfd session reflector discriminator命令显示信息描述表
本地标识符为xx的在slot yy上的SBFD会话信息
Configured mode
标识符的配置形式:
·     IP address:表示配置IPv4地址形式的Reflector端标识符
Total Session Num
标识符所在板上的会话数目
Local Discr
会话的本地标识符
Remote Discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Hold Time
Min Tx Inter
收到报文中的最小发送时间间隔
Min Rx Inter
最小接收间隔
Detect Multi
接收到的报文中携带的检测倍数
Running Up for
Rx Count
接收的报文数
Tx Count
发送的报文数
Max Rx Period
最大收包时间间隔,单位为毫秒
Max Tx Period
收到报文后回复应答报文的最大时间间隔,单位为微秒
Hold Time
VRF Name
Hardware mode
硬件处理BFD报文模式:
·     sbfd local-discriminator
display sbfd session reflector命令用来显示Reflector端的SBFD会话信息。
display sbfd session reflector [ discriminator value | verbose ]
如果未指定任何参数,将显示Reflector端所有SBFD会话的概要信息。
          Source IP: 2.2.2.1
          Hold Time: 2200ms
           VRF Name: vpn1
表1-8 display sbfd session reflector命令显示信息描述表
Configured mode
标识符的配置形式:
Total Session Num
标识符所在slot上的会话数目
Local Discr
会话的本地标识符
Remote Discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Hold Time
VRF Name
         Hold Time: 2200ms
          VRF Name: vpn1
         Hold Time: 2500ms
          VRF Name: vpn2
表1-9 display sbfd session reflector discriminator verbose命令显示信息描述表
Configured mode
标识符的配置形式:
Total Session Num
标识符所在板上的会话数目
Local Discr
会话的本地标识符
Remote Discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Hold Time
Min Tx Inter
收到报文中的最小发送时间间隔
Min Rx Inter
最小接收间隔
Detect Multi
接收到的报文中携带的检测倍数
Running Up for
Rx Count
接收的报文数
Tx Count
发送的报文数
Max Rx Period
最大收包时间间隔,单位为毫秒
Max Tx Period
Hold Time
VRF Name
sbfd destination ipv4 remote-discriminator命令用来在Initiator端配置被检测路径的目的IPv4地址和远端标识符的映射关系。
undo sbfd destination ipv4命令用来取消Initiator端被检测路径的目的IPv4地址和远端标识符的映射关系的配置。
sbfd destination ipv4 destination-ipv4-address remote-discriminator { ipv4-address | integer-value }
undo sbfd destination ipv4 destination-ipv4-address
未配置Initiator端被检测路径的目的IPv4地址和远端标识符的映射关系。
destination-ipv4-address:被检测路径的目的IPv4地址,需要为有效的单播地址。
ipv4-address:IPv4地址形式的远端标识符,需要为有效的单播地址。
integer-value:整数形式的远端标识符,取值范围为1~4294967295。
使用SBFD检测LSP、MPLS TE隧道或SR-MPLS TE Policy时,如果希望控制建立SBFD会话使用的远端标识符,可以使用本命令配置被检测路径的目的IPv4地址和远端标识符的映射关系。
Initiator端按照下面的顺序选取SBFD会话的远端标识符:
(1)     使用SBFD进行路径连通性检测的配置中指定的SBFD会话的远端标识符。例如,使用mpls sbfd命令检测LSP的连通性的配置中指定的SBFD会话的远端标识符。
(2)     本命令配置的远端标识符。
(3)     被检测路径的目的IPv4地址。例如,使用SBFD检测SR-MPLS TE Policy时,将End-point地址作为SBFD会话的远端标识符。
多次执行本命令,可以在Initiator端配置多个被检测路径的目的IPv4地址和远端标识符的映射关系。
配置映射关系或者取消映射关系的配置时,如果SBFD会话处于UP状态,可能会导致会话震荡。
# 在Initiator端配置使用SBFD检测到达目的地址22.22.2.2/32的LSP的连通性,并使用1.1.1.1作为SBFD会话的远端标识符。
[Sysname] mpls bfd enable
[Sysname] mpls sbfd 22.22.2.2 32
[Sysname] sbfd destination ipv4 22.22.2.2 remote-discriminator 1.1.1.1
·     mpls sbfd(MPLS命令参考/MPLS OAM)
·     sbfd(Segment Routing命令参考/SR-MPLS TE Policy)
·     sr-policy sbfd enable(Segment Routing命令参考/SR-MPLS TE Policy)
sbfd destination ipv6 remote-discriminator命令用来在Initiator端配置被检测路径的目的IPv6地址和远端标识符的映射关系。
undo sbfd destination ipv6命令用来取消Initiator端被检测路径的目的IPv6地址和远端标识符的映射关系的配置。
sbfd destination ipv6 destination-ipv6-address remote-discriminator { ipv4-address | integer-value }
undo sbfd destination ipv6 destination-ipv6-address
未配置Initiator端被检测路径的目的IPv6地址和远端标识符的映射关系。
destination-ipv6-address:被检测路径的目的IPv6地址,需要为有效的全球单播地址。
integer-value:整数形式的远端标识符。取值范围为1~4294967295。
使用SBFD检测SRv6 TE Policy时,如果希望控制建立SBFD会话使用的远端标识符,可以使用本命令配置被检测路径的目的IPv6地址和远端标识符的映射关系。
(1)     使用SBFD检测SRv6 TE Policy连通性的配置中指定的SBFD会话的远端标识符。
(2)     本命令配置的远端标识符。
使用SBFD检测SRv6 TE Policy时,如果未配置SBFD会话的远端标识符,则无法建立SBFD会话。
在公网IP over SRv6 BE场景、IP L3VPN over SRv6 BE场景或EVPN L3VPN over SRv6 BE场景中,对端CE双归属接入到两个PE设备时,在本端PE设备上开启FRR功能后,本端PE上将形成主备两条路径。主路径发生故障时,为了使流量快速切换到备份路径进行转发,可以在本端PE设备配置SBFD检测对端PE设备通过BGP发布的SRv6 Locator网段的连通性,以便快速发现主路径故障,并引导流量快速切换至备份路径。为保证此功能正常生效,请在本端PE设备上执行sbfd destination ipv6 remote-discriminator命令配置被检测SRv6 Locator网段和远端标识符的映射关系,并在主路径对端PE设备上执行sbfd local-discriminator命令设置Reflector端的本地标识符,并保证本端PE设备的远端标识符和对端PE设备上的本地标识符一致。
多次执行本命令,可以在Initiator端配置多个被检测路径的目的IPv6地址和远端标识符的映射关系。
# 在Initiator端全局开启SRv6 TE Policy的SBFD功能,并使用1.1.1.1作为SBFD会话的远端标识符。
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] srv6-policy sbfd
[Sysname-srv6-te] quit
[Sysname-segment-routing-ipv6] quit
[Sysname] sbfd destination ipv6 10::1 remote-discriminator 1.1.1.1
·     locator-sbfd enable(Segment Routing命令参考/SRv6)
·     sbfd(Segment Routing命令参考/SRv6 TE Policy)
·     srv6-policy sbfd(Segment Routing命令参考/SRv6 TE Policy)
sbfd local-discriminator命令用来在SBFD会话的Reflector端配置本地标识符。
undo sbfd local-discriminator命令用来取消SBFD会话的Reflector端本地标识符的配置。
sbfd local-discriminator { ipv4-address | integer-value }
undo sbfd local-discriminator { ipv4-address | integer-value }
未配置SBFD会话的Reflector端的本地标识符。
ipv4-address:在SBFD会话的Reflector端配置IPv4地址形式的本地标识符,需要为有效的单播地址。
integer-value:在SBFD会话的Reflector端配置整数形式的本地标识符,取值范围为1000001~4294967295。
在BFD会话中,会话的两端都需要维护BFD状态信息,通过周期性地发送BFD报文来检测网络设备间的双向转发路径的可达性。SBFD对链路进行单向检测,其检测速度比BFD更快速,适用于仅一端需要进行链路状态检测的情况,如使用静态SRLSP建立MPLS TE隧道的场景。
SBFD使用Initiator和Reflector来实现对链路的检测:
·     Initiator通过周期性发送SBFD控制报文来检测网络节点到远端实体的链路是否可达。由Initiator发起SBFD会话并维护BFD会话的状态信息。
·     Reflector监听到达本地实体的SBFD控制报文,并发送SBFD控制报文类型的响应报文给Initiator。
Initiator发送的SBFD控制报文中携带的远端标识符必须为本命令指定的标识符,否则Reflector不会发送响应报文给Initiator。
多次执行本命令,可以配置多个SBFD Reflector端标识符。
一个节点可以同时作为不同SBFD会话的Initiator和Reflector。
# 在SBFD会话的Reflector端配置本地标识符为1.1.1.1。
[Sysname] sbfd local-discriminator 1.1.1.1
# 在SBFD会话的Reflector端配置本地标识符为1000001。
[Sysname] sbfd local-discriminator 1000001
·     mpls bfd(MPLS命令参考/MPLS OAM)
sbfd source-ipv4命令用来配置Initiator发送SBFD报文使用的源IPv4地址。
undo sbfd source-ipv4命令用来恢复缺省情况。
sbfd source-ipv4 ipv4-address
未配置Initiator发送SBFD报文使用的源IPv4地址。
·     ipv4-address:SBFD报文的源IPv4地址,点分十进制形式,取值范围为合法的单播IPv4地址,且不能是环回地址。
SRv6 TE Policy的尾节点位于纯IPv4网络中,使用SBFD检测此SRv6 TE Policy时,需要保证SBFD报文的封装模式为Encaps方式,同时需要在Initiator配置SBFD报文使用的源IPv4地址。
支持通过如下两种方式配置SBFD报文使用的源IPv4地址:
·     SRv6 TE Policy视图下通过source-address ipv4命令配置SBFD报文使用的源IPv4地址。
·     系统视图下通过sbfd source-ipv4命令配置SBFD报文使用的源IPv4地址,并确保Reflector上存在到达通过本命令配置的IPv4地址的路由。
设备按照如下优先顺序选取报文源地址:
(1)     source-address ipv4命令配置的报文源地址。
(2)     sbfd source-ipv4命令配置的报文源地址。
# 配置Initiator发送SBFD报文使用的源IPv4地址为1.1.1.1。
[Sysname] sbfd source-ipv4 1.1.1.1
·     source-address ipv4(Segment Routing命令参考/SRv6 TE Policy)
sbfd source-ipv6命令用来配置Initiator发送SBFD报文使用的源IPv6地址。
undo sbfd source-ipv6命令用来恢复缺省情况。
sbfd source-ipv6 ipv6-address
未配置Initiator发送SBFD报文使用的源IPv6地址。
ipv6-address:SBFD报文的源IPv6地址,必须是单播地址。
使用SBFD检测SRv6 TE Policy或者SRv6 BE中转发路径的可达性时,需要在Initiator配置本命令,并确保Reflector上存在到达通过本命令配置的IPv6地址的路由。
# 配置Initiator发送SBFD报文使用的源IPv6地址为80::2。
[Sysname] sbfd source-ipv6 80::2
