04-二层技术-以太网交换命令参考
02-以太网链路聚合命令
本章节下载 02-以太网链路聚合命令  (619.23 KB)
02-以太网链路聚合命令
  录
1 以太网链路聚合
1.1 以太网链路聚合配置命令
1.1.1 display interface
1.1.2 display lacp system-id
1.1.3 display link-aggregation capability
1.1.4 display link-aggregation load-sharing mode
1.1.5 display link-aggregation load-sharing path
1.1.6 display link-aggregation member-port
1.1.7 display link-aggregation summary
1.1.8 display link-aggregation troubleshooting
1.1.9 display link-aggregation verbose
1.1.10 interface bridge-aggregation
1.1.11 interface route-aggregation
1.1.12 jumboframe enable
1.1.13 lacp default-selected-port disable
1.1.14 lacp edge-port
1.1.15 lacp mode
1.1.16 lacp period short
1.1.17 lacp select speed
1.1.18 lacp system-mac
1.1.19 lacp system-number
1.1.20 lacp system-priority
1.1.21 lacp transparent enable
1.1.22 link-aggregation auto-aggregation enable
1.1.23 link-aggregation bfd
1.1.24 link-aggregation bfd-compatible enable
1.1.25 link-aggregation capability
1.1.26 link-aggregation global load-sharing algorithm
1.1.27 link-aggregation global load-sharing mode
1.1.28 link-aggregation global load-sharing offset
1.1.29 link-aggregation global load-sharing seed
1.1.30 link-aggregation ignore speed
1.1.31 link-aggregation lacp isolate
1.1.32 link-aggregation lacp traffic-redirect-notification enable
1.1.33 link-aggregation load-sharing mode dynamic
1.1.34 link-aggregation management-port
1.1.35 link-aggregation management-subnet
1.1.36 link-aggregation management-vlan
1.1.37 link-aggregation mode
1.1.38 link-aggregation port-priority
1.1.39 link-aggregation primary-port
1.1.40 link-aggregation reversion delay
1.1.41 link-aggregation secondary-down
1.1.42 link-aggregation selected-port maximum
1.1.43 link-aggregation selected-port minimum
1.1.44 link-aggregation selected-port minimum percentage
1.1.45 link-aggregation switchover
1.1.46 mac-address
1.1.47 mtu
1.1.48 port lacp isolate enable
1.1.49 port lacp suppress unexpected-mac
1.1.50 port lacp system-mac
1.1.51 port lacp system-priority
1.1.52 port link-aggregation group
1.1.53 port s-mlag group
1.1.54 reset lacp statistics
1.1.55 sub-interface rate-statistic
1 以太网链路聚合
1.1  以太网链路聚合配置命令
display interface命令用来显示聚合接口的相关信息。
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
bridge-aggregation:显示二层聚合接口的相关信息。
route-aggregation:显示三层聚合接口的相关信息。
interface-number:表示聚合接口的编号,取值范围为已创建的聚合接口的编号。
brief:显示接口的概要信息。如果未指定该参数,将显示接口的详细信息。
如果未指定聚合接口的类型,将显示设备支持的所有接口的相关信息。
如果指定了聚合接口的类型而未指定聚合接口编号,将显示所有已创建的该类型聚合接口的相关信息。
# 显示二层聚合接口1的详细信息。
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 1000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Last 300 seconds input:  6900 packets/sec 885160 bytes/sec    0%
Last 300 seconds output:  3150 packets/sec 404430 bytes/sec    0%
Input (total):  5364747 packets, 686688416 bytes
         2682273 unicasts, 1341137 broadcasts, 1341337 multicasts, 0 pauses
Input (normal):  5364747 packets, 686688416 bytes
         - ignored, - parity errors
Output (total): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, - pauses
Output (normal): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, 0 pauses
         - lost carrier, - no carrier
# 显示三层聚合接口1的详细信息。
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Description: Route-Aggregation1 Interface
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
Input (total):  0 packets, 0 bytes
Input (normal):  0 packets, 0 bytes
         0 CRC, 0 frame, 0 overruns, 0 aborts
         0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
         0 lost carrier, 0 no carrier
# 显示二层聚合接口1的概要信息。
<Sysname> display interface bridge-aggregation 1 brief
Speed: (a) – auto
BAGG1                DOWN auto    A      A    1
# 显示三层聚合接口1的概要信息。
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1                UP   UP       --
表1-1 display interface命令显示信息描述表
Bridge-Aggregation1
二层聚合接口名
Route-Aggregation1
三层聚合接口名
Current state
接口的状态:
·     Administratively DOWN:表示该接口已被shutdown命令关闭,其管理状态为关闭
·     DOWN:表示该接口的管理状态为开启,但其物理状态为关闭(可能由于没有物理连线或线路故障)
·     UP:表示该接口的管理状态和物理状态均为开启
IPv4报文帧格式
IPv6报文帧格式
hardware address
接口的MAC地址
接口的描述信息
Bandwidth
接口的期望带宽值,当该参数的取值为0时,不显示该参数
接口的速率和双工模式均未知
接口的速率和双工模式都是通过自协商确定的
PVID
接口缺省VLAN的编号
Port link-type
接口的链路类型,取值可能为access、trunk或hybrid
Tagged VLANs
通过该接口后携带Tag的VLAN
Untagged VLANs
通过该接口后不再携带Tag的VLAN
最后一次使用reset counters interface命令清除接口统计信息的时间。如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never
Last 300 seconds input/output rate
接口在最近300秒接收/发送报文的平均速率
Input/Output (total)
接口接收/发送的全部报文的统计值
Input/Output (normal)
接口接收/发送的正常报文的统计值
Line protocol state
接口数据链路层协议状态:
·     UP
·     DOWN
接口的最大传输单元
接口未配置IP地址时,接口的网络协议配置参数:
·     Disabled:不能处理IP报文
·     Enabled:可以处理IP报文
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     Unnumbered:借用其他接口的IP地址
三层接口的概要信息
二层接口的概要信息
接口的物理连接状态:
·     ADM:表示该接口已被管理员通过shutdown命令关闭,在该接口下执行undo shutdown命令才能恢复其物理状态
·     Stby:表示该接口是一个处于Standby状态的备份接口
Speed: (a) - auto
如果某接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的
如果某接口的Speed属性值为“auto”,则表示该接口的速率是通过自动协商获取的,但协商还未开始
接口的双工模式:
·     (a)/A:表示双工模式都是通过自协商确定的
·     H:表示双工模式为半双工(暂不支持)
·     F:表示双工模式为全双工
接口的链路类型:
·     A:表示Access类型
·     H:表示Hybrid类型
·     T:表示Trunk类型
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
接口名称的缩写
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上是不通的
·     ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
Speed
接口的速率(单位为bps)
Duplex
接口的双工模式
接口的链路类型
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
Protocol
接口数据链路层协议状态,取值为:
·     UP:表示接口的数据链路层协议状态为开启
·     DOWN:表示接口的数据链路层协议状态为关闭
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
Primary IP
接口的主IP地址
Cause
接口物理连接状态为down的原因
display lacp system-id命令用来显示本端系统的设备ID。
使用lacp system-priority命令可以改变系统的LACP优先级,但通过该命令输入的是十进制的优先级数值。而当使用display lacp system-id命令显示时,系统会自动将其转换为十六进制的优先级数值。
# 显示本端系统的设备ID。
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
表1-2 display lacp system-id命令显示信息描述表
本端系统的设备ID(由系统的LACP优先级和系统的MAC地址共同构成):系统的LACP优先级为0x8000,系统的MAC地址为0000-FC00-6504
·     lacp system-priority
display link-aggregation capability命令用来显示设备的聚合能力。
# 显示设备的聚合能力。
<Sysname> display link-aggregation capability
Default link aggregation capability:
  Maximum groups: 1024
  Maximum Selected ports per group: 16
Current link aggregation capability:
Link aggregation capability at the next reboot:
Supported link aggregation capability list:
  1024*16        512*32         256*64         128*128        64*256
表1-3 display link-aggregation capability命令显示信息描述表
缺省情况下,设备支持的聚合能力
设备当前生效的聚合能力
下一次启动时生效的聚合能力
Maximum groups
设备支持创建的最大聚合组数
每个聚合组中最大选中的端口数
设备支持配置的聚合能力:支持创建的最大聚合组数*每个聚合组中最大选中端口数
·     link-aggregation capability
display link-aggregation load-sharing mode命令用来显示全局或聚合组内采用的聚合负载分担类型。
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
bridge-aggregation:显示二层聚合接口所对应聚合组内采用的聚合负载分担类型。
route-aggregation:显示三层聚合接口所对应聚合组内采用的聚合负载分担类型。
interface-number:聚合接口的编号。必须是当前已经创建的聚合接口编号。
如果未指定参数interface,则显示全局采用的聚合负载分担类型。
如果仅指定参数interface而未指定具体的聚合接口类型,则显示所有聚合接口所对应聚合组内采用的聚合负载分担类型。
只有在设备上创建了二层聚合接口、三层聚合接口之后,才能指定bridge-aggregationroute-aggregation参数。
# 显示全局采用的聚合负载分担类型(缺省情况)。
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing algorithm:
4 (default)
Link-aggregation load-sharing offset:
0 (default)
Link-aggregation load-sharing seed:
0x1 (default)
Link-aggregation load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# 显示全局采用的聚合负载分担类型(非缺省情况)。
5
3
0x10
destination-mac address  source-mac address
# 显示二层聚合接口1所对应聚合组内采用的聚合负载分担类型(缺省情况)。
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 1
The dynamic load sharing mode takes effect if it exists.
Bridge-Aggregation1 load-sharing mode:
Dynamic:
  N/A
Static:
# 显示二层聚合接口1所对应聚合组内采用的聚合负载分担类型(非缺省情况)。
Dynamic:
  Eligible (flowlet gap time: 1000 us)
Static:
表1-4 display link-aggregation load-sharing mode命令显示信息描述表
全局采用的聚合负载分担HASH算法:
·     缺省情况下显示:algorithm-number (default)
·     非缺省情况下显示:用户配置后采用的聚合负载分担HASH算法
聚合负载分担计算结果的偏移量:
·     缺省情况下显示:offset-value (default)
·     非缺省情况下显示:用户配置后采用的聚合负载分担HASH Key偏移量
全局采用的聚合负载分担HASH SEED
·     缺省情况下显示:seed-number (default)
·     非缺省情况下显示:用户配置后采用的聚合负载HASH SEED
全局采用的聚合负载分担类型:
·     缺省情况下显示:二层报文、三层报文采用的聚合负载分担类型
·     非缺省情况下显示:用户配置后采用的聚合负载分担类型
二层聚合接口1所对应聚合组内采用的聚合负载分担类型:
·     缺省情况下显示:全局采用的聚合负载分担类型
Route-Aggregation1 load-sharing mode
三层聚合接口1所对应聚合组内采用的聚合负载分担类型:
二层报文缺省采用的聚合负载分担类型:按照目的MAC地址、源MAC地址进行负载分担。
三层报文缺省采用的聚合负载分担类型:按照目的MAC地址、源MAC地址、目的IP地址、源IP地址和IP协议进行负载分担。
用户配置后采用的聚合负载分担类型:按照源MAC地址和目的MAC地址进行负载分担
Dynamic
用户配置后采用的动态聚合负载分担模式:
·     Eligible:Eligible模式,flowlet gap time表示划分Flowlet的时间间隔,单位为微秒
·     Fixed:Fixed模式
·     Spray:Spray模式
·     N/A:未配置动态聚合负载分担模式
Static
用户配置后采用的静态聚合负载分担类型
display link-aggregation load-sharing path命令用来显示聚合组内采用的聚合负载分担的选路信息。
display link-aggregation load-sharing path interface { bridge-aggregation | route-aggregation } interface-number ingress-port interface-type interface-number [ route ] { { destination-ip ip-address | destination-ipv6 ipv6-address } | { source-ip ip-address | source-ipv6 ipv6-address } | destination-mac mac-address | destination-port port-id | ip-protocol protocol-id | mpls-label-number number | source-mac mac-address | source-port port-id | vlan vlan-id } *
bridge-aggregation:显示二层聚合接口相关信息。
route-aggregation:显示三层聚合接口相关信息。
interface-number:聚合接口的编号。取值范围为已创建的聚合接口的编号。
ingress-port interface-type interface-number:指定报文入接口。interface-type表示接口类型,只能指定物理接口。interface-number表示接口编号。
route:显示进行三层转发的报文的选路信息。不指定该参数时,显示进行二层转发的报文的选路信息。
destination-ip ip-address:显示指定目的IPv4地址的报文的选路信息。
destination-ipv6 ipv6-address:显示指定目的IPv6地址的报文的选路信息。
source-ip ip-address:显示指定源IPv4地址的报文的选路信息。
source-ipv6 ipv6-address:显示指定源IPv6地址的报文的选路信息。
destination-mac mac-address:显示指定目的MAC地址的报文的选路信息,mac-address的格式为H-H-H。
destination-port port-id:显示指定目的端口的报文的选路信息,port-id表示端口号,取值范围为1~65535。
ip-protocol protocol-id:显示指定IP协议类型的报文的选路信息。protocol-id表示协议号,取值范围为0~255。
mpls-label-number number:显示包含指定层数MPLS标签的报文的选路信息。number表示标签层数,取值范围为1~3。
source-mac mac-address:显示指定源MAC地址的报文的选路信息,mac-address的格式为H-H-H。
source-port port-id:显示指定源端口的报文的选路信息,port-id表示端口号,取值范围为1~65535。
vlan vlan-id:显示指定VLAN的报文的选路信息。vlan-id的取值范围为1~4094。
通过本命令可以显示聚合组内报文选择物理出接口时所使用的参数。
显示聚合组内指定特征报文的物理出接口时,本命令指定的参数不一定会被显示。例如通过本命令指定的参数为目的MAC地址和目的IP地址,但是通过目的MAC地址就可以找到报文的出接口,则在计算选路信息时实际使用的参数中不显示目的IP地址。
选择报文出接口时需要使用的参数,本命令没有指定,则取设备的缺省值。如果没有缺省值,则按照0处理。
本命令行的参数输入需要和display link-aggregation load-sharing mode命令显示的配置参数相匹配。如不匹配,则显示的聚合选路信息可能跟实际不一致。
# 显示特征为入接口HundredGigE1/0/1,目的MAC地址0000-fc00-0001,源MAC地址0000-fc00-0002,源IP地址10.100.0.2,目的IP地址10.100.0.1的报文指定出聚合接口Bridge-Aggregation 1时,进行二层转发选择的物理出端口信息。
<Sysname> display link-aggregation load-sharing path interface bridge-aggregation 1 ingress-port hundredgige 1/0/1 destination-mac 0000-fc00-0001 source-mac 0000-fc00-0002 source-ip 10.100.0.2 destination-ip 10.100.0.1
Load sharing mode: destination-mac, source-mac, source-ip, destination-ip
Unspecified parameters are set to 0.
Load-sharing parameters:
  Ingress port:HundredGigE1/0/1
  Destination MAC: 0000-fc00-0001
  Source MAC: 0000-fc00-0002
  Destination IP: 10.100.0.1
  Source IP: 10.100.0.2
Egress port: HundredGigE1/0/3
表1-5 display link-aggregation load-sharing path命令显示信息描述表
Load sharing mode:
聚合组采用的负载分担类型:
·     destination-mac:按照目的MAC地址负载分担
·     source-mac:按照源MAC地址负载分担
·     destination-ip:按照目的IP地址负载分担
·     source-ip:按照源IP地址负载分担
·     destination-port:按照目的端口负载分担
·     source-port:按照源端口负载分担
·     ip-protocol:按照IP协议类型负载分担
·     ingress-port:按照入端口负载分担
未指定的参数默认值为0
Load sharing parameters
计算选路信息时实际使用的参数
Ingress port
报文入接口
Destination MAC
报文目的MAC地址
Source MAC
报文源MAC地址
Destination IP
报文目的IP
Source IP
报文源IP
Destination port
报文目的端口
Source port
报文源端口
IP protocol
报文IP协议类型
MPLS labels
MPLS标签层数
VLAN
报文所属VLAN
Egress port
根据报文特征所选择的路径,如果找不到出端口显示“N/A”
display link-aggregation member-port命令用来显示成员端口上链路聚合的详细信息。
display link-aggregation member-port [ interface-list | auto ]
interface-list:成员端口列表,表示一个或多个成员端口。表示方式为interface-list = interface-type interface-number1 [ to interface-type interface-number2 ]。其中,interface-type为接口类型,interface-number1interface-number2为接口编号。interface-number2的值要大于等于interface-number1的值。
auto:显示所有自动聚合成员端口的链路聚合的详细信息。
由于静态聚合组无法获知对端信息,因此静态聚合组只显示本端的端口编号、端口优先级和操作Key的值。
# 显示静态聚合组内成员端口HundredGigE1/0/1上链路聚合的详细信息。
<Sysname> display link-aggregation member-port hundredgige 1/0/1
       G -- Defaulted, H -- Expired
HundredGigE1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# 显示动态聚合组内成员端口HundredGigE1/0/2上链路聚合的详细信息。
<Sysname> display link-aggregation member-port hundredgige 1/0/2
HundredGigE1/0/2:
Aggregate Interface: Bridge-Aggregation10
Local:
    Port Number: 2
    Oper-Key: 2
    Flag: {ACDEF}
Remote:
    Port Number: 26
    Oper-Key: 2
    Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
表1-6 display link-aggregation member-port命令显示信息描述表
Flags
LACP协议的状态标识,长度为1字节,该字节自低位至高位分别以英文字母A~H表示,某一位为1时打印出对应的英文字母,为0时不打印对应的英文字母。各标志位的含义如下:
·     A:LACP是否开启标志。1表示开启;0表示关闭
·     B:LACP长/短超时标志。1表示短超时;0表示长超时
·     C:发送端认为本成员端口所在链路是否可聚合。1表示是;0表示否
·     D:发送端认为本成员端口所在链路是否处于同步状态。1表示是;0表示否
·     E:发送端认为本成员端口所在链路是否处于收集状态。1表示是;0表示否
·     F:发送端认为本成员端口所在链路是否处于分发状态。1表示是;0表示否
·     G:发送端的接收状态机是否处于默认状态。1表示是;0表示否
·     H:发送端的接收状态机是否处于超时状态。1表示是;0表示否
Aggregate Interface
本成员端口所属的聚合接口
Preferred Aggregate Interface
半自动聚合优先选择加入的聚合口
Local
本端信息
Port Number
端口的编号
Port Priority
端口优先级
Oper-key
操作Key的值
Flag
LACP协议的状态标志值
Remote
对端信息
System ID
收到的LACP报文总数
Illegal
非法报文的总数
Sent LACP Packets
发出的LACP报文总数
display link-aggregation summary命令用来显示所有聚合组的摘要信息。
由于静态聚合组无法获知对端信息,因此静态聚合组的对端信息显示为None,并不代表对端系统的实际信息。
# 显示所有聚合组的摘要信息。
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregatio
n, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG        AGG   Partner ID              Selected  Unselected  Individual  Share
Interface  Mode                          Ports     Ports       Ports       Type
RAGG10     S     None                    1         0           0           NonS
BAGG20     D     0x8000,00e0-fcff-ff01   2         0           0           Shar
表1-7 display link-aggregation summary命令显示信息描述表
聚合接口类型:
·     BAGG:表示二层聚合接口
·     RAGG:表示三层聚合接口
·     (暂不支持)BLAGG:表示引擎聚合接口
·     (暂不支持)SCH-B:表示S通道聚合接口
Aggregation Mode
聚合组类型:
·     S:表示静态聚合
·     D:表示动态聚合
Loadsharing Type
负载分担类型:
·     Shar:表示负载分担类型
·     NonS:表示非负载分担类型
Actor System ID
本端的设备ID(由系统的LACP优先级和系统的MAC地址共同构成)
AGG Interface
聚合接口的类型和编号
AGG Mode
聚合组的类型
Partner ID
对端的设备ID(由系统的LACP优先级和系统的MAC地址共同构成)
Selected Ports
处于选中状态的成员端口数量
Unselected Ports
处于非选中状态的成员端口数量
Individual Ports
处于独立状态的成员端口数量
Share Type
负载分担类型
display link-aggregation troubleshooting命令用来显示聚合组成员端口的选中状态及原因。
display link-aggregation troubleshooting [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
如果未指定聚合接口的类型,将显示设备支持的所有聚合接口的相关信息。
如果仅指定了聚合接口的类型,将显示所有已创建的该类型聚合接口的相关信息。
只有在设备上创建了二层或三层聚合接口之后,才能指定bridge-aggregationroute-aggregation参数。
# 显示所有聚合组的成员端口的选中状态及原因。
<Sysname> display link-aggregation troubleshooting
Aggregate Interface: Bridge-Aggregation2
 Member ports:
  HGE1/0/2
   Status: Selected
  HGE1/0/3
   Status: Unselected
   Reason: The physical or line protocol state of the port is down
   Advice: Check the connection
表1-8 display link-aggregation troubleshooting命令显示信息描述表
Aggregate interface
聚合接口名称
Member ports
聚合组成员端口信息
Status
端口状态:
·     Selected:处于选中状态
·     Unselected:处于非选中状态
Reason
成员端口未选中原因,具体内容请参见表1-9
Advice
解决建议,具体内容请参见表1-10
表1-9 成员端口未选中原因
The number of Selected ports had reached the upper limit
聚合组内选中端口数量已经到达上限
Hardware resources were not enough
硬件资源耗尽
The number of Selected ports was below the lower limit
聚合组内选中端口数量没有达到最小选中端口数
The link aggregation configuration of the port was incorrect
端口自身配置错误使端口未选中
The link aggregation configuration of its peer port was incorrect
对端端口配置错误导致本端端口未选中
The physical or line protocol state of the port was down
端口物理层或链路层处于DOWN状态
The port's hardware restriction prevented it from being Selected
端口硬件限制
The speed configuration of the port was different from that of the reference port
端口速率与参考端口不一致导致非选中
The duplex mode of the port was different from that of the reference port
端口双工模式与参考端口不一致导致非选中
The port and the aggregate interface had different attribute configurations
属性类配置与聚合接口配置不一致
The BFD session state of the port was down
端口的BFD会话DOWN
The member port has low link quality
成员端口链路质量低
The role of the aggregate interface is secondary in a smart trunk
聚合接口在S-Trunk组中为备用设备
It is the secondary member port in the aggregation group in 1+1 backup mode
接口为1:1主备模式聚合组的备份端口
No LACPDU was received by the reference port
参考端口未收到LACPDU
The reference port received its own LACPDUs
参考端口收到自己的LACPDU
The link of the port was not aggregatable
端口所在链路不可聚合
The link of the peer port was not aggregatable
对端端口所在链路不可聚合
The port's operational key was invalid
无效操作Key
Link-aggregation traffic redirection was triggered on the local port
本端触发聚合重定向功能
The port had not received LACPDUs
成员端口未收到LACPDU
The operational key of the peer port was different from that of the reference port
对端操作Key与参考端口不一致
The system MAC address of the peer port was different from that of the peer port for the reference port
对端系统MAC地址与参考端口的对端端口不一致
The peer port did not have the Synchronization flag
对端成员端口所在链路未处于同步状态
The operational key of the peer port was different than the other peer ports for the M-LAG group to which this aggregate interface belongs
同一M-LAG组中M-LAG接口的成员接口的对端操作key不一致
The system MAC address of the peer port was different than the other peer ports for the M-LAG group to which this aggregate interface belongs
同一M-LAG组中M-LAG接口的成员接口的对端系统MAC不一致
The system priority of the peer port was different than the other peer ports for the M-LAG group to which this aggregate interface belongs
同一M-LAG组中M-LAG接口的成员接口的对端系统优先级不一致
The speed of the port was different than the member ports of the peer M-LAG interface
端口的速率与对端M-LAG接口的成员端口速率不一致
Link-aggregation lacp isolate is configured
开启聚合流量隔离功能
表1-10 解决建议
Modify the aggregation group configuration
修改聚合组配置
Release resources
释放资源
Modify port configuration
修改端口配置
Modify peer port configuration
修改对端端口配置
检查端口之间的链路
Use another port
更换端口
Change the port rate to be the same as that of the reference port
修改端口速率与参考端口一致
Change the port duplex mode to be the same as that of the reference port
修改端口双工模式与参考端口一致
Change the port attribute configuration to be the same as that of the aggregate interface
修改端口属性类配置和聚合组一致
Check the link that conveys the BFD session
检查BFD会话所在链路,解决链路故障
Check for CRC errors
检查是否发生误码故障
Check whether the peer sends LACPDUs correctly
检查对端是否发送LACPDU
Check whether the device has a loop
检查设备是否存在环路
Make sure the card that hosts the port is installed
检查接口所在板已插入
Check whether the port sends LACPDUs correctly
检查本端是否发送LACPDU
Change the peer system MAC address to be the same as that of the reference port
修改对端系统MAC地址与参考端口一致
Check the LACPDUs sent by the peer
检查对端发送的LACPDU
Please check the aggregation state of member ports in a few minutes
等待一段时间再查看成员端口的选中状态
Make sure the peer aggregation member ports for a M-LAG group reside on the same device and belong to the same aggregation group
使对端成员口同一设备同一聚合组中
Check the configuration
检测聚合相关配置
N/A
无需处理
display link-aggregation verbose命令用来显示已有聚合接口所对应聚合组的详细信息。
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ all-configuration ]
bridge-aggregation:显示二层聚合接口所对应聚合组的详细信息。
route-aggregation:显示三层聚合接口所对应聚合组的详细信息。
all-configuration:显示聚合组中所有的成员端口。
实际未加入任何聚合组的自动聚合端口不会被显示。
# 二层聚合接口10所对应的聚合组是动态聚合组,显示该聚合组的详细信息。
<Sysname> display link-aggregation verbose bridge-aggregation 10
Port: A -- Auto port, M -- Management port, R -- Reference port
Role: P -- Primary, S -- Secondary
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  HGE1/0/1            S        32768    61       2                      {ACDEF}
  HGE1/0/2            S        32768    62       2                      {ACDEF}
  HGE1/0/3            S        32768    63       2                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  HGE1/0/1(R)         32768    111      2        0x8000, 000f-e267-57ad {ACDEF}
  HGE1/0/2            32768    112      2        0x8000, 000f-e267-57ad {ACDEF}
  HGE1/0/3            32768    113      2        0x8000, 000f-e267-57ad {ACDEF}
# 二层聚合接口20所对应的聚合组是静态聚合组,显示该聚合组的详细信息。
<Sysname> display link-aggregation verbose bridge-aggregation 20
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
  Port             Status  Priority Oper-Key  Role
  HGE1/0/1(R)      S       32768    1         None
  HGE1/0/2         S       32768    1         None
  HGE1/0/3         S       32768    1         None
表1-11 display link-aggregation verbose命令显示信息描述表
Loadsharing Type
负载分担类型:
·     Shar:表示负载分担类型
·     NonS:表示非负载分担类型
Port Status
端口状态:
·     Selected:表示处于选中状态
·     Unselected:表示处于非选中状态
·     Individual:表示处于独立状态
Port
端口类型:
·     Auto port:表示为该端口为自动端口
·     (暂不支持)Management port:表示该端口为管理端口
·     Reference port:表示该端口为参考端口
Flags
LACP协议的状态标志,长度为1字节,该字节自低位至高位分别以字母A~H表示,取值为1的标志位显示为对应的字母,取值为0的标志为不显示。各标志位的含义如下:
Role
1:1主备模式聚合组的成员接口角色:
·     Primary:主接口
·     Secondary:备份接口
未配置聚合组工作在1:1主备模式时显示为None
Aggregate Interface
聚合接口的名称
Creation Mode
动态聚合组的创建方式:
·     Auto:表示自动创建
·     Manual:表示手工创建
Aggregation Mode
聚合组的工作模式:
·     Static:表示静态聚合
·     Dynamic:表示动态聚合
Management VLANs
管理VLAN,未指定时显示None
System ID
Local
本端信息:
·     Port:端口的类型和编号
·     Status:端口的选中/非选中/独立状态
·     Priority:端口优先级
·     Index:端口索引
·     Oper-Key:操作Key的值
·     Flag:LACP协议的状态标志值
静态聚合组只显示本端信息,显示信息中不包括Index和Flag字段
Remote
对端信息:
·     Actor:本端的端口类型和编号,当对端端口是参考端口时,参考端口会显示在对应的本端端口上
·     Priority:对端端口的端口优先级
·     Index:对端端口的端口索引
·     Oper-Key:对端端口的操作Key的值
·     System ID:对端的设备ID
·     Flag:对端的LACP协议的状态标志值
interface bridge-aggregation命令用来创建二层聚合接口,并进入二层聚合接口视图。如果指定的二层聚合接口已经存在,则直接进入该二层聚合接口视图。
undo interface bridge-aggregation命令用来删除二层聚合接口。
undo interface bridge-aggregation interface-number
不存在二层聚合接口。
interface-number:指定二层聚合接口的编号。对于Release 5212P01之前版本,取值范围为1~1024;对于Release 5212P01及以上版本,取值范围为1~4096。
创建二层聚合接口后,系统将自动生成同编号的二层聚合组,且该聚合组缺省工作在静态聚合模式下。
删除二层聚合接口的同时会删除其对应的二层聚合组,如果该聚合组内有成员端口,那么这些成员端口将自动从该聚合组中退出。
# 创建二层聚合接口1,并进入二层聚合接口1的视图。
[Sysname-Bridge-Aggregation1]
interface route-aggregation命令用来创建三层聚合接口/子接口,并进入三层聚合接口/子接口视图。如果指定的三层聚合接口/子接口已经存在,则直接进入该三层聚合接口/子接口视图。
undo interface route-aggregation命令用来删除三层聚合接口。
undo interface route-aggregation { interface-number | interface-number.subnumber }
不存在三层聚合接口/子接口。
interface-number:指定三层聚合接口的编号。对于Release 5212P01之前版本,取值范围为1~1024;对于Release 5212P01及以上版本,取值范围为1~4096。
interface-number.subnumber:指定三层聚合子接口。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
创建三层聚合接口后,系统将自动生成同编号的三层聚合组,且该聚合组缺省工作在静态聚合模式下。
删除三层聚合接口的同时会删除其对应的三层聚合组以及该接口下的所有聚合子接口,如果该聚合组内有成员端口,那么这些成员端口将自动从该聚合组中退出。
如果删除三层聚合子接口,则不会影响其主接口以及主接口对应的聚合组状态。
# 创建三层聚合接口1,并进入三层聚合接口1的视图。
[Sysname-Route-Aggregation1]
jumboframe enable命令用来允许超长帧通过。
undo jumboframe enable命令用来禁止超长帧通过。
undo jumboframe enable size命令用来恢复缺省情况。
jumboframe enable [ size ]
设备允许长度为9964字节的超长帧通过。
二层聚合接口视图
三层聚合接口视图
多次执行本命令,最后一次执行的命令生效。
# 允许超长帧通过二层聚合接口1。
<Sysname> System-view
[Sysname-Bridge-Aggregation1] jumboframe enable
lacp default-selected-port disable命令用来关闭聚合成员端口缺省选中功能。
undo lacp default-selected-port disable命令用来开启聚合成员端口缺省选中功能。
聚合成员端口缺省选中功能处于开启状态。
聚合成员端口缺省选中功能是指动态聚合组的成员端口处于up状态时,成员端口在经过LACP超时时间之后未收到LACPDU,则会在所有处于up状态的成员端口中选择一个作为选中端口。聚合组选择选中端口时比较各成员端口的端口ID,端口ID最小的作为选中端口。
关闭聚合成员端口缺省选中功能后,动态聚合组中处于up状态的成员端口未收到LACPDU时,处于非选中状态。
# 关闭聚合成员端口缺省选中功能。
[Sysname] lacp default-selected-port disable
lacp edge-port命令用来配置聚合接口为聚合边缘接口。
undo lacp edge-port命令用来恢复缺省情况。
lacp edge-port
undo lacp edge-port
聚合接口不是聚合边缘接口。
二层聚合接口视图
三层聚合接口视图
该命令主要用于在网络设备与服务器等终端设备相连的场景中。当网络设备配置了动态聚合模式,而终端设备未配置动态聚合模式时,网络设备的聚合成员端口都可以作为普通物理口转发报文,从而保证终端设备与网络设备间的多条链路可以相互备份,增加可靠性。
该配置仅在聚合接口对应的聚合组为动态聚合组时生效。
当聚合接口配置为聚合边缘接口后,聚合流量重定向功能将不能正常使用。
# 配置二层聚合接口1为聚合边缘接口。
[Sysname-Bridge-Aggregation1] lacp edge-port
1.1.15  lacp mode
lacp mode passive命令用来配置端口的LACP工作模式为PASSIVE。
undo lacp mode命令用来恢复缺省情况。
lacp mode passive
undo lacp mode
端口的LACP工作模式为ACTIVE。
二层以太网接口视图
三层以太网接口视图
执行本命令后,只有在当前端口为动态聚合组成员端口时,配置才生效。
如果动态聚合组内成员端口的LACP工作模式为PASSIVE,且对端的LACP工作模式也为PASSIVE时,两端将不能发送LACPDU。如果两端中任何一端的LACP工作模式为ACTIVE时,两端将可以发送LACPDU。
# 配置端口HundredGigE1/0/1的LACP工作模式为PASSIVE。
[Sysname-HundredGigE1/0/1] lacp mode passive
lacp period short命令用来配置端口的LACP超时时间为短超时,并配置短超时时间。
undo lacp period命令用来恢复缺省情况。
lacp period short [ timeout timeout ]
undo lacp period
端口的LACP超时时间为长超时(90秒)。
二层以太网接口视图
三层以太网接口视图
timeout timeout:指定端口的LACP短超时时间,timeout表示端口的LACP短超时时间,取值范围为3~90,单位为秒。若不指定本参数,则表示端口的LACP短超时时间为3秒。
功能简介
LACP超时时间是指成员端口等待接收LACPDU的超时时间,LACP超时时间分为短超时和长超时两种。缺省情况下,端口的LACP超时时间为长超时(90秒),即在LACP超时时间+3秒之后(即93秒之后),如果本端成员端口仍未收到来自对端的LACPDU,则认为对端成员端口已失效。
对于短超时时间,设备支持两种配置方式:
·     不指定timeout参数方式:在该方式下,短超时时间为固定值3秒,即在LACP超时时间+3秒之后(即6秒之后),如果本端成员端口仍未收到来自对端的LACPDU,则认为对端成员端口已失效。
·     指定timeout参数方式:在该方式下,短超时时间可以配置为3秒~90秒范围内的任意值,即在配置的LACP短超时时间之后,如果本端成员端口仍未收到来自对端的LACPDU,则认为对端成员端口已失效。
# 配置端口HundredGigE1/0/1的LACP超时时间为短超时(3秒)。
[Sysname-HundredGigE1/0/1] lacp period short
# 配置端口HundredGigE1/0/1的LACP超时时间为短超时,并配置短超时时间为30秒。
[Sysname-HundredGigE1/0/1] lacp period short timeout 30
lacp select speed命令用来配置动态聚合组内端口速率作为优先选择参考端口的条件。
undo lacp select speed命令用来恢复缺省情况。
lacp select speed
动态聚合组内以成员口的端口的端口ID作为优先选择参考端口的条件。
二层聚合接口视图
三层聚合接口视图
缺省情况下,聚合组可能会将速率小的端口选择为参考端口。通过配置本命令,用户可以选择速率高的端口作为参考端口。
配置该命令前,需要在聚合接口视图下先执行link-aggregation mode dynamic命令配置该聚合接口为动态聚合接口,该命令才生效。静态聚合组可以配置该命令,但不生效。
本命令会改变动态聚合口的参考端口的选择条件,可能会导致短暂的业务中断。建议在业务正常传输情况下,不要随便更改参考端口的选择条件,需要修改参考端口的选择条件时,可以先关闭聚合接口,待两端配置一致后再开启该聚合接口。
# 配置端口速率作为优先选择参考端口的条件。
[Sysname-Bridge-Aggregation1] lacp select speed
lacp system-mac命令用来配置LACP的系统MAC地址。
undo lacp system命令用来恢复缺省情况。
lacp system-mac mac-address
undo lacp system-mac
LACP的系统MAC地址为设备的桥MAC地址。
mac-address:LACP的系统MAC地址,格式为H-H-H,不支持组播MAC地址、全0的MAC地址和全F的MAC地址。
本命令配置的MAC地址会影响到LACP报文的MAC地址字段,LACP报文MAC地址字段可以通过display link-aggregation verbose命令查看。
LACP的系统MAC地址支持全局配置或在聚合组内配置两种方式:全局的配置对所有聚合组都有效,而聚合组内的配置只对当前聚合组有效。对于一个聚合组来说,优先采用该聚合组内的配置,只有该聚合组内未进行配置时,才采用全局的配置。
在开启S-MLAG功能的设备上,LACP的系统MAC地址需要配置一致。
在M-LAG组网环境中,需要保证同一M-LAG组中M-LAG接口的LACP系统MAC地址不同。
# 配置LACP的系统MAC地址为0001-0001-0001。
[Sysname] lacp system-mac 1-1-1
·     display link-aggregation verbose
lacp system-number命令用来配置LACP的系统编号。
undo lacp system-number命令用来恢复缺省情况。
lacp system-number number
未配置LACP的系统编号。
number:LACP的系统编号,取值范围为1~3。
如果聚合接口没有开启S-MLAG功能,本命令配置的系统编号不会影响到LACP报文的Index字段。LACP报文的Index字段可以通过display link-aggregation verbose命令查看。
在开启S-MLAG功能的设备上,不同设备上配置的LACP系统编号不能相同。
# 配置LACP的系统编号为1。
[Sysname] lacp system-number 1
lacp system-priority命令用来配置LACP的系统优先级。
undo lacp system-priority命令用来恢复缺省情况。
lacp system-priority priority
LACP的系统优先级为32768。
priority:LACP的系统优先级,取值范围为0~65535。该数值越小,优先级越高。
本命令配置的系统优先级会影响到LACP报文的系统优先级字段,LACP报文系统优先级字段可以通过display link-aggregation verbose命令查看。
LACP的系统优先级支持全局配置或在聚合组内配置两种方式:全局的配置对所有聚合组都有效,而聚合组内的配置只对当前聚合组有效。对于一个聚合组来说,优先采用该聚合组内的配置,只有该聚合组内未进行配置时,才采用全局的配置。
# 配置LACP的系统优先级为64。
[Sysname] lacp system-priority 64
·     link-aggregation port-priority
lacp transparent enable命令用来开启LACP报文透传功能。
undo lacp transparent enable命令用来关闭LACP报文透传功能。
LACP报文透传功能处于关闭状态。
二层以太网接口视图
三层以太网接口视图
在L2VPN组网环境中,需要在PE设备报文入端口和出端口开启LACP报文透传功能。
由于透传LACP报文会影响成员端口的选中,在PE设备的端口上配置本功能时,不要将该端口加入动态聚合组。当端口配置了LACP报文透传功能,同时将该端口加入动态聚合组时,则LACP报文透传功能优先生效。
二层以太网接口作为公网口时,必须配置本命令;三层以太网接口作为公网口时,无需配置本命令。
# 在接口HundredGigE1/0/1上开启LACP报文透传功能。
<Sysname> system
[Sysname-HundredGigE1/0/1] lacp transparent enable
link-aggregation auto-aggregation enable命令用来开启全自动聚合功能。
undo link-aggregation auto-aggregation enable命令用来关闭全自动聚合功能。
全自动聚合功能处于关闭状态。
开启LLDP功能和全自动聚合功能后,当本端端口收到对端发来的LLDP报文,根据报文信息,自动创建一个聚合组,同时将连接相同对端设备的端口加入该聚合组。若关闭LLDP功能或者关闭全自动聚合功能,端口将退出聚合组,但自动创建的聚合组不会被删除。
配置本命令后,开启了LLDP功能的三层以太网接口下可能无法创建子接口。
执行本命令后,对于自动加入聚合组的成员端口,建议不要修改其配置,以避免该成员端口退出聚合组。
请勿在M-LAG组网环境配置本命令,以保证M-LAG正常工作。
当端口自动加入聚合组时,如果端口下存在port link-aggregation group配置,则以端口下配置为准。
# 开启全自动聚合功能。
<Sysname> system
[Sysname] link-aggregation auto-aggregation enable
·     lldp enable(二层技术-以太网交换命令参考/LLDP)
·     lldp global enable(二层技术-以太网交换命令参考/LLDP)
·     port link-aggregation group
link-aggregation bfd命令用来开启链路聚合的BFD功能。
undo link-aggregation命令用来关闭链路聚合的BFD功能。
link-aggregation bfd { ipv4 | ipv6 } source { ipv4-address | ipv6-address } destination { ipv4-address | ipv6-address }
undo link-aggregation bfd [ ipv4 | ipv6 ]
链路聚合的BFD功能处于关闭状态。
二层聚合接口视图
三层聚合接口视图
ipv4:IPv4 BFD会话。
ipv6:IPv6 BFD会话。
source:BFD会话的源IP地址。
destination:BFD会话的目的IP地址。
ipv4-address:BFD会话的IPv4地址,不能为0.0.0.0。
ipv6-address:BFD会话的IPv6地址,不能为0::0。
聚合口两端的BFD会话源IP地址和目的IP地址必须成对配置,且源地址和目的地址为不同的单播地址。例如本端聚合接口配置link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2时,对端聚合接口要配置link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1后,才能正确建立起BFD会话。
在聚合接口下配置的BFD会话参数,会对该聚合组内所有选中链路的BFD会话生效,链路聚合的BFD会话仅支持控制报文方式和异步模式。关于BFD的介绍和基本功能配置,请参见“可靠性配置指导”中的“BFD”。
开启链路聚合的BFD功能后,不建议在该聚合接口上再开启其他应用与BFD联动。
开启链路聚合的BFD功能后,请配置聚合组中的成员端口数量不大于设备支持的BFD会话数量,否则可能导致聚合组内部分选中端口变为非选中状态。
当聚合链路两端最大选中端口数量不一致时,如果在链路两端都开启链路聚合的BFD功能,则可能会导致两端BFD会话数量不一致,但并不影响报文转发。
在同一聚合接口下,多次执行本命令:
·     可以分别配置IPv4 BFD会话和IPv6 BFD会话。
·     当配置的是同一会话时,最新的配置生效。
在聚合接口下同时配置IPv4 BFD会话和IPv6 BFD会话后,当IPv4 BFD会话和IPv6 BFD会话其中之一检测到链路故障时,聚合组成员端口的状态变为非选中状态。
# 开启二层聚合接口1下的链路聚合的BFD功能,并配置BFD会话的源地址为1.1.1.1,目的地址为2.2.2.2。
[Sysname-Bridge-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
link-aggregation bfd-compatible enable命令用来开启链路聚合与BFD联动的兼容功能。
undo link-aggregation bfd-compatible enable命令用来关闭链路聚合与BFD联动的兼容功能。
链路聚合与BFD联动的兼容功能处于关闭状态。
二层聚合接口视图
三层聚合接口视图
在与其他厂商设备互通的场景中,由于链路聚合与BFD联动功能实现方式不同,导致无法通过BFD快速检测链路故障。通过配置本命令,可以兼容其他厂商设备的链路聚合与BFD联动功能,使聚合链路两端可以通过BFD快速定位链路问题。
开启本功能后,聚合组所有成员端口都与对端建立BFD会话,且成员端口选中状态变化时,不会再拆除和重建BFD会话。
# 开启二层聚合接口1的链路聚合与BFD联动的兼容功能。
[Sysname-Bridge-Aggregation1] link-aggregation bfd-compatible enable
# 开启三层聚合接口1的链路聚合与BFD联动的兼容功能。
[Sysname-Route-Aggregation1] link-aggregation bfd-compatible enable
·     link-aggregation bfd
link-aggregation capability命令用来配置设备的聚合能力。
undo link-aggregation capability命令用来恢复缺省情况。
link-aggregation capability max-group max-group-number max-selected-port max-selected-port-number
设备支持创建的最大聚合组数为1024,每个聚合组中最大选中端口数为16。
max-group max-group-number:设备支持创建的最大聚合组数,取值范围为64、128、256、512、1024。
max-selected-port max-selected-port-number:每个聚合组中最大选中端口数,取值范围为16、32、64、128、256。
执行link-aggregation capability命令后,需要保存配置重启设备,配置才能生效。进行设备重启前请评估重启对网络造成的影响,做好相关准备工作。
如果当前的聚合组数大于所配置的max-group-number,则本命令配置失败。
配置link-aggregation capability命令后如果继续创建聚合组,且聚合组数超过了本命令配置的max-group-number,则会导致设备重启后部分聚合组配置丢失。
聚合组中的最大选中端口数为本命令及link-aggregation selected-port maximum命令配置值中的较小值。
建议用户在聚合链路两端的设备上配置相同的聚合能力,避免导致聚合功能无法正常使用。
多次执行本命令,最后一次执行的命令在重启后生效。
# 配置设备支持创建的最大聚合组数为1024,每个聚合组中最大选中端口数为16。
[Sysname] link-aggregation capability max-group 1024 max-selected-port 16
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Please save the configuration, and reboot the device.
·     display link-aggregation capability
link-aggregation global load-sharing algorithm命令用来配置全局采用的聚合负载分担HASH算法。
undo link-aggregation global load-sharing algorithm命令用来恢复缺省情况。
link-aggregation global load-sharing algorithm algorithm-number
全局采用的聚合负载分担HASH算法为4。
algorithm algorithm-number:基于报文逐流进行负载分担的算法切换。algorithm-number指定要进行算法切换的算法编号,取值范围为1~11。
本命令对聚合逐流负载分担类型无效。
在采用缺省负载分担类型进行负载分担情况下,尝试依次配置负载分担HASH算法,通过不同方式的CRC运算,选择相对适合的HASH算法实现链路流量均衡。
HASH算法和HASH SEED值可以单独配置,也可以同时配置。两者不同的配置组合对聚合负载分担影响效果也不一样。用户可以通过display counters命令查看各个成员端口流量情况,判断链路流量是否均衡。
# 配置聚合全局负载分担算法为1类型。
[Sysname] link-aggregation global load-sharing algorithm 1
·     display counters接口管理命令参考/接口公共命令
·     display link-aggregation load-sharing mode
·     link-aggregation global load-sharing mode
·     link-aggregation global load-sharing seed
link-aggregation global load-sharing mode命令用来配置全局采用的聚合负载分担类型。
undo link-aggregation global load-sharing mode命令用来恢复缺省情况。
link-aggregation global [ ipv6 ] load-sharing mode { destination-ip | destination-mac | destination-port | flow-label | ingress-port | ip-protocol | source-ip | source-mac | source-port } * }
二层报文按照目的MAC地址、源MAC地址进行负载分担。
三层报文按照目的MAC地址、源MAC地址、目的IP地址、源IP地址和IP协议进行负载分担。
ipv6:表示配置的聚合负载分担类型仅对聚合组内的IPv6报文生效。
仅R5220及以上版本支持ipv6参数。
destination-ip:表示按报文的目的IP地址进行聚合负载分担。
destination-mac:表示按报文的目的MAC地址进行聚合负载分担。
destination-port:表示按报文的目的服务端口进行聚合负载分担。
flow-label:表示按报文所属的流标签进行聚合负载分担。
ingress-port:表示按报文的入端口进行聚合负载分担。
ip-protocol:表示按报文的IP协议类型进行聚合负载分担。
source-ip:表示按报文的源IP地址进行聚合负载分担。
source-mac:表示按报文的源MAC地址进行聚合负载分担。
source-port:表示按报文的源服务端口进行聚合负载分担。
工作机制
若仅指定ipv6参数,则配置的全局聚合负载分担类型仅适用于IPv6报文。
在不指定ipv6参数的情况下,配置的全局聚合负载分担类型对所有报文生效。
多次配置本命令,IPv6报文优先使用ipv6参数指定的聚合负载分担类型处理,其他报文则采用link-aggregation global load-sharing mode命令指定的聚合负载分担类型进行处理。
注意事项
多次配置link-aggregation global ipv6 load-sharing mode命令,则最后一次执行的命令生效。
多次配置link-aggregation global load-sharing mode命令(不带ipv6参数),则最后一次执行的命令生效。
多次配置link-aggregation global load-sharing mode命令,则最后一次执行的命令生效。
对于设备不支持的聚合负载分担类型,系统将提示用户不支持。
目前,在系统视图下进行全局聚合负载分担类型配置,设备支持任意组合。
ip load-sharing mode命令与link-aggregation load-sharing mode命令互斥,后下发的命令生效。有关ip load-sharing mode命令的详细介绍,请参见“三层技术-IP路由”中的“IP路由基础”。
开启对称负载分担功能后,聚合负载分担时也采用对称负载分担方式。有关对称负载分担的详细介绍,请参见“三层技术-IP路由配置指导”中的“IP路由基础”。
配置destination-ip参数后,相当于同时配置destination-ipsource-ip,反之亦同。此时聚合组可以根据目的IP地址和源IP地址负载分担。
配置destination-mac参数后,相当于同时配置destination-macsource-mac,反之亦同。此时聚合组可以根据目的MAC地址和源MAC地址负载分担。
配置destination-port参数后,相当于同时配置destination-portsource-port,反之亦同。此时聚合组可以根据目的服务端口和源服务端口负载分担。
# 配置全局按照报文目的MAC地址进行聚合负载分担。
[Sysname] link-aggregation global load-sharing mode destination-mac
·     link-aggregation load-sharing mode
link-aggregation global load-sharing offset命令用来配置聚合负载分担计算结果的偏移量。
undo link-aggregation global load-sharing offset命令用来恢复缺省情况。
link-aggregation global load-sharing offset offset-value
聚合负载分担计算结果的偏移量为0。
offset-value:聚合负载分担计算结果的偏移量。对于R5220之前的版本,取值范围为0~15;对于R5220及以上版本,取值范围为0~255。
当聚合链路上负载分担不均匀时,用户可以通过本命令配置聚合负载分担计算结果的偏移量,调整流量的出端口,以均衡聚合链路上各物理链路的流量。
建议在专业人士的指导下配置本命令,避免由于配置不合理导致链路上流量失衡。
# 配置聚合负载分担计算结果的偏移量为2。
<Sysname> system
[Sysname] link-aggregation global load-sharing offset 2
link-aggregation global load-sharing seed命令用来配置全局采用的聚合负载分担HASH SEED。
undo link-aggregation global load-sharing seed命令用来恢复缺省情况。
link-aggregation global load-sharing seed seed-number
全局采用的聚合负载分担HASH SEED为0x1。
seed seed-number:全局采用的聚合流量负载分担算法HASH SEED。seed-number指定参与负载分担计算的HASH SEED值,取值范围为0~FFFF。
本命令对对聚合逐流负载分担类型无效。
在采用缺省负载分担类型进行负载分担情况下,多次尝试配置负载分担的HASH SEED,通过增加一个负载分担参数参与HASH运算,实现链路流量的均衡。
# 配置聚合全局负载分担算法为HASH SEED为1023。
[Sysname] link-aggregation global load-sharing seed 3FF
·     display counters(接口管理命令参考/接口公共命令)
·     link-aggregation global load-sharing algorithm
link-aggregation ignore speed命令用来配置聚合组选择选中端口时忽略端口速率。
undo link-aggregation ignore speed命令用来恢复缺省情况。
聚合组选择选中端口时计算端口速率。
二层聚合接口视图
三层聚合接口视图
通过配置本命令,同一聚合组中的选中端口的端口速率可以不同。
如果聚合组两端本命令配置不一致,动态聚合组可以通过LACP协议协商状态,使链路两端端口状态一致;静态聚合组无法协商状态,为了防止报文丢失,所以要求静态聚合组两端本命令配置一致。
配置本命令后,如果聚合组中选中端口速率不同,聚合组中流量负载分担时,速率较小的选中端口可能存在丢包现象,请按需配置本功能。
开启和关闭本功能后,操作Key会发生变化,导致聚合接口震荡,请按需配置本功能。
# 配置二层聚合组1选择选中端口时忽略端口速率。
[Sysname-Bridge-Aggregation1] link-aggregation ignore speed
link-aggregation lacp isolate命令用来开启聚合流量隔离功能。
undo link-aggregation lacp isolate命令用来关闭聚合流量隔离功能。
link-aggregation lacp isolate [ bagg | ragg ]
undo link-aggregation lacp isolate [ bagg | ragg ]
聚合流量隔离功能处于关闭状态。
bagg:开启二层聚合接口的流量隔离功能。
ragg:开启三层聚合接口的流量隔离功能。
配置本功能后,就表示设备上聚合接口流量被隔离,即该设备所有M-LAG接口的成员端口都处在非选中状态,对端设备与之相应聚合组的成员端口也处在非选中状态。为了避免流量丢弃,所有从当前设备M-LAG接口转发的流量会切换到另一台M-LAG设备上同一M-LAG组的M-LAG接口上转发。
本命令仅对动态聚合接口生效,对于静态聚合接口和M-LAG组网中的peer-link接口不生效。
配置本命令后,如果本端设备处于M-LAG MAD DOWN状态,则不能通过执行undo link-aggregation lacp isolate命令恢复流量从本端M-LAG接口转发。
如果未指定任何参数,则表示开启或关闭所有聚合接口的流量隔离功能。
# 开启聚合流量隔离功能。
[Sysname] link-aggregation lacp isolate
link-aggregation lacp traffic-redirect-notification enable命令用来开启聚合流量重定向功能。
undo link-aggregation lacp traffic-redirect-notification enable命令用来关闭聚合流量重定向功能。
聚合流量重定向功能处于关闭状态。
二层聚合接口视图
三层聚合接口视图
在开启了聚合流量重定向功能后,当手工关闭聚合组内某选中端口或重启聚合组内某选中端口所在的slot时,系统可以将该端口上的流量重定向到其他选中端口上,从而实现聚合链路上流量的不中断。聚合流量重定向过程中,对于聚合组中新选中的端口,流量不会重定向到该端口上。其中,已知单播报文可以实现零丢包,非已知单播报文不保证不丢包。
只有动态聚合组支持聚合流量重定向功能。
必须在聚合链路两端都开启聚合流量重定向功能才能实现聚合链路上流量的不中断。
如果同时开启聚合流量重定向功能和生成树功能,在重启slot时会出现少量的丢包,因此不建议同时开启上述两个功能。
建议优先选择开启聚合接口的聚合流量重定向功能。开启全局的聚合流量重定向功能时,如果有连接其它厂商设备的聚合接口,可能影响该聚合组的正常通信。
# 开启聚合流量重定向功能。
[Sysname] link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode dynamic命令用来配置聚合接口的动态负载分担模式。
undo link-aggregation load-sharing mode dynamic命令用来恢复缺省情况。
link-aggregation load-sharing mode dynamic { eligible [ flowlet-gap-time flowlet-gap-time ] | fixed | spray }
聚合组内采用的静态的聚合负载分担类型。
二层聚合接口视图
三层聚合接口视图
eligible:指定链路聚合的动态负载分担模式为Eligible模式。该模式下,设备根据五元组,将收到的报文划分为Flow,同一Flow中转发时间间隔小于等于flowlet-gap-time的报文组成一个Flowlet。同一Flowlet中的数据包选取相同的成员链路进行转发,新Flowlet选取当前负载分担链路中带宽利用率最小的成员链路进行转发。
flowlet-gap-time flowlet-gap-time:划分Flowlet的时间间隔。设备按照flowlet-gap-time对Flow进行分割,同一Flow中转发时间间隔小于等于flowlet-gap-time的报文组成一个Flowlet。flowlet-gap-time取值范围为1~2000。flowlet-gap-time单位为微秒,缺省值为1000。
fixed:指定链路聚合的动态负载分担模式为Fixed模式。该模式下,同一Flow使用同一个成员链路转发,新的Flow使用当前负载分担链路中带宽利用率最小的成员链路进行转发。
spray:指定链路聚合的动态负载分担模式为Spray模式。该模式下,基于数据包选取当前负载分担链路中带宽利用率最小的成员链路进行转发。属于同一Flow的数据包可能选择不同的成员链路转发,接收流量的设备上可能出现报文乱序问题。因此,该模式下需要保证接收流量的设备上支持报文乱序重组功能。
同一聚合接口下,同时配置了静态聚合负载分担和动态聚合负载分担时,动态聚合负载分担生效。
# 配置二层聚合接口1的动态负载分担模式为Eligible模式,Flowlet时间间隔为2000微秒。
[Syaname] interface bridge-aggregation 1
[Syaname-Bridge-Aggregation1] link-aggregation load-sharing mode dynamic eligible flowlet-gap-time 2000
link-aggregation management-port命令用来配置聚合管理端口。
undo link-aggregation management-port命令用来恢复缺省情况。
未配置聚合管理口。
二层以太网接口视图
同一个聚合组中,可以在多个成员端口上配置link-aggregation management-port命令,但只会选择端口号最小的端口作为管理端口。
# 配置二层以太网接口HundredGigE1/0/1为聚合管理端口。
[Sysname-HundredGigE1/0/1] link-aggregation management-port
link-aggregation management-subnet命令用来配置聚合管理网段。
undo link-aggregation management-subnet命令用来删除指定的管理网段。
link-aggregation management-subnet ip-address { mask | mask-length }
undo link-aggregation management-subnet ip-address { mask | mask-length }
未配置聚合管理网段。
ip-address:IP地址,为点分十进制格式。
mask:IP地址相应的子网掩码,为点分十进制格式。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为1~32。
配置本功能后,当聚合接口收到该网段的ARP报文时,仅在收到该报文的成员端口上建立对应的ARP表项,聚合接口不建立ARP表项。此时,经过聚合接口的访问该网段的流量会通过指定的接口转发,不再进行负载分担。
配置聚合管理网段后,当通过聚合接口发送ARP报文到管理网段时,该报文会在聚合组中所有成员端口上转发。
当聚合接口收到管理网段的ARP报文时,设备会根据报文IP地址查看当前ARP表项:
·     如果存在对应的ARP表项,设备会在接收该报文的聚合成员端口上创建ARP表项。所有匹配该表项的报文都通过该成员端口转发。
·     如果存在对应ARP表项,但该表项对应不同的接口,设备会在所有端口发送ARP请求报文,重新学习建立对应的ARP表项。
设备最多允许存在20条管理网段。
当配置本命令后,请不要在设备上配置以下功能:
·     M-LAG。有关M-LAG的详细介绍,请参见“二层技术-以太网交换配置指导”中的“M-LAG”。
·     ARP Snooping。有关ARP Snooping的详细介绍,请参见“三层技术-IP业务配置指导”中的“ARP Snooping”。
# 配置聚合管理网段的IP地址为22.1.1.1,掩码为255.0.0.0。
[Sysname] link-aggregation management-subnet 22.1.1.1 255.0.0.0
link-aggregation management-vlan命令用来配置聚合管理VLAN。
undo link-aggregation management-vlan命令用来删除聚合管理VLAN。
link-aggregation management-vlan vlan-id-list
undo link-aggregation management-vlan vlan-id-list
未配置聚合管理VLAN。
vlan-id-list:聚合管理VLAN列表。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
聚合组中最多允许存在64个管理VLAN。如果多次使用link-aggregation management-vlan命令,那么聚合组中允许存在的管理VLAN是这些vlan-id-list的合集。
VLAN 1不能被配置为聚合管理VLAN。
# 配置聚合管理VLAN为VLAN 2和VLAN 3。
[Sysname] link-aggregation management-vlan 2 3
link-aggregation mode命令用来配置聚合组的工作模式。
undo link-aggregation mode命令用来恢复缺省情况。
link-aggregation mode { dynamic | static [ backup ] }
聚合组工作在静态聚合模式下。
二层聚合接口视图
三层聚合接口视图
dynamic:配置聚合组工作在动态聚合模式,同时开启LACP协议。
static:配置聚合组工作在静态聚合模式。
backup:配置静态聚合组工作在1:1主备模式。如果未指定本参数,则聚合组工作在非1:1主备模式。仅三层聚合接口可以指定本参数。
当聚合组中存在成员端口时,如果修改聚合组的工作模式,则可能导致聚合组中选中端口变为非选中状态,影响流量转发,请用户根据实际情况修改聚合组的工作模式。
配置聚合组工作在1:1主备模式时,聚合组的成员端口不能大于两个,且最大最小选中端口个数配置将失效。
# 配置二层聚合接口1对应的聚合组工作在动态聚合模式下。
link-aggregation port-priority命令用来配置端口优先级。
undo link-aggregation port-priority命令用来恢复缺省情况。
端口优先级为32768。
二层以太网接口视图
三层以太网接口视图
priority:端口优先级,取值范围为0~65535。该数值越小,优先级越高。
# 配置二层以太网接口HundredGigE1/0/1的端口优先级为64。
[Sysname-HundredGigE1/0/1] link-aggregation port-priority 64
# 配置三层以太网接口HundredGigE1/0/2的端口优先级为64。
[Sysname] interface hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] link-aggregation port-priority 64
link-aggregation primary-port命令用来配置成员接口为工作在1:1主备模式的聚合组的主接口。
undo link-aggregation primary-port命令用来恢复缺省情况。
成员接口非工作在1:1主备模式的聚合组的主接口。
三层以太网接口视图
配置聚合组工作在1:1主备模式后,仅主接口处于选中状态,可以转发流量,而备份接口处于非选中状态,不能转发流量。为保证业务可靠通信,建议通过本命令指定主接口。指定主接口后,主接口将具有回切功能,即主接口故障恢复后,可以立即切换为选中状态并转发流量。
当未通过本命令指定主接口时:
·     如果成员接口同时加入聚合组,则聚合组内的参考端口作为主接口转发流量。
·     如果成员接口依次加入聚合组,则聚合组内先选中的端口作为主接口转发流量。
当接口未加入聚合组或者聚合组未工作在1:1主备模式时,不能在接口下配置本命令。
聚合组工作在1:1主备模式下时,该聚合组只能有一个主接口。
# 将三层以太网接口HundredGigE1/0/1配置为工作在1:1主备模式的聚合组的主接口。
[Sysname-HundredGigE1/0/1] port link-aggregation group 1
[Sysname-HundredGigE1/0/1] link-aggregation primary-port
link-aggregation reversion delay命令用来配置工作于1:1主备模式聚合组的主接口延时回切功能,并配置延时回切时间。
undo link-aggregation reversion delay命令用来恢复缺省情况。
link-aggregation reversion delay time-value
工作于1:1主备模式聚合组的主接口延时回切功能处于关闭状态,即主接口故障恢复时可以立即转发流量。
三层聚合接口视图
time-value:延时回切的时间,单位为秒,取值范围为1~65535。
工作于1:1主备模式聚合组的主接口由于故障而处于备用状态,当主接口故障恢复时需要回切到转发状态。缺省情况下,主接口故障恢复后可以立即切换为选中状态并转发流量。为了避免链路震荡引起主接口频繁切换,可以通过本命令配置主接口延时回切时间。
配置聚合组工作在1:1主备模式且使用link-aggregation primary-port命令指定主接口后,本命令才能生效。
# 开启工作于:1主备模式三层聚合组1的主接口延时回切功能,并配置延时回切时间为5秒。
[Sysname-Route-Aggregation1] link-aggregation reversion delay 5
·     link-aggregation mode
·     link-aggregation primary-port
link-aggregation secondary-down命令用来配置工作于1:1主备模式聚合组的备份接口处于DOWN状态。
undo link-aggregation secondary-down命令用来恢复缺省情况。
工作于1:1主备模式聚合组的备份接口处于非选中状态。
三层聚合接口视图
配置聚合组工作在1:1主备模式后,如果对端设备无法感知本端的主备接口时,流量可能发送到本端备份接口,由于本端备份接口处于非选中状态,流量无法转发,导致丢包。为避免这种情况,可以配置本命令,仅使两端设备转发流量的接口保持UP状态,避免丢包。
配置聚合组工作在1:1主备模式后,本命令才能生效。
# 配置1:1主备模式的三层聚合组1的备份接口处于DOWN状态。
[Sysname-Route-Aggregation1] link-aggregation secondary-down
link-aggregation selected-port maximum命令用来配置聚合组中的最大选中端口数。
undo link-aggregation selected-port maximum命令用来恢复缺省情况。
link-aggregation selected-port maximum max-number [ lacp-sync ]
聚合组中的最大选中端口数仅受设备硬件能力的限制
二层聚合接口视图
三层聚合接口视图
max-number:聚合组中的最大选中端口数,取值范围为1~256。
lacp-sync:配置动态聚合组使用LACPDU同步最大选中端口数,使两端聚合组最大选中端口数一致。未指定本参数时,不同步最大选中端口数。
执行本命令可能导致聚合组内部分成员端口变为非选中状态。
对于静态聚合组,本端和对端配置的聚合组中的最大选中端口数必须一致。对于动态聚合组,不指定lacp-sync参数时,本端和对端配置的聚合组中的最大选中端口数必须一致;指定lacp-sync参数时,本端和对端聚合组中的最大选中端口数以配置值最小的一端为准。
同一聚合组内,最大选中端口数配置值不能小于最小选中端口数配置值。
当配置了聚合组中的最大选中端口数之后,最大选中端口数将同时受配置值和设备硬件能力的限制,即取二者的较小值作为限制值。
用户借此可实现两端口间的冗余备份:在一个聚合组中只添加两个成员端口,并配置该聚合组中的最大选中端口数为1,这样这两个成员端口在同一时刻就只能有一个成为选中端口,而另一个将作为备份端口。
# 配置二层聚合接口1对应的聚合组中的最大选中端口数为5。
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
·     link-aggregation selected-port minimum
link-aggregation selected-port minimum命令用来配置聚合组中的最小选中端口数。
undo link-aggregation selected-port minimum命令用来恢复缺省情况。
聚合组中的最小选中端口数不受限制。
二层聚合接口视图
三层聚合接口视图
min-number:聚合组中的最小选中端口数取值范围为1~256。
执行本命令可能导致聚合组内所有成员端口都变为非选中状态。
本端和对端配置的聚合组中的最小选中端口数必须一致。
同一聚合组内,最小选中端口数配置值不能大于最大选中端口数配置值。
# 配置二层聚合接口1对应的聚合组中的最小选中端口数为3。
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
·     link-aggregation selected-port maximum
link-aggregation selected-port minimum percentage命令用来配置聚合组中最小选中端口数的百分比。
undo link-aggregation selected-port minimum percentage命令用来恢复缺省情况。
link-aggregation selected-port minimum percentage number
未配置聚合组中最小选中端口数的百分比。
二层聚合接口视图
三层聚合接口视图
number:聚合组中最小选中端口数占所有成员端口的百分比,取值范围为1~100。
缺省情况下,聚合组中最小选中端口数不受限制。聚合组两端需要配置相同的百分比。
聚合组中的最小选中端口数为配置本命令后计算的值(该聚合组所有成员端口×最小选中端口数的百分比)及link-aggregation selected-port minimum命令配置值中的较大值。
用户配置聚合组中最小选中端口数的百分比后,当有端口加入或者退出该聚合组时,可能会引起最小选中端口数的改变,导致聚合接口震荡。
# 配置二层聚合接口1的最小选中端口数的百分比为50。
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum percentage 50
# 配置三层聚合接口1的最小选中端口数的百分比为50。
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum percentage 50
link-aggregation switchover命令用来切换工作于1:1主备模式聚合组的主备接口。
三层聚合接口视图
当工作于1:1主备模式聚合组未配置主接口时,用户可以根据1:1主备模式聚合组对端设备转发流量的接口,随时切换主备接口。
配置本命令后,如果备份接口因为link-aggregation secondary-down命令而处于DOWN状态,则设备会将备份接口置为UP状态,使备份接口可以切换为主接口转发流量。
聚合组切换主备接口时,可能导致丢包,请谨慎配置本命令。
执行本命令前需要满足以下条件,否则无法切换:
·     工作于1:1主备模式聚合组未配置主接口。
·     工作于1:1主备模式聚合组中存在一个选中端口和一个非选中端口。
·     备份接口可以变为选中状态。
# 切换工作于1:1主备模式聚合组1的主备接口。
[Sysname-Route-Aggregation1] link-aggregation switchover
This operation will change the current link status. Continue? [Y/N]:
1.1.46  mac-address
mac-address命令用来配置聚合接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
未配置聚合接口的MAC地址。
三层聚合接口视图
三层聚合子接口视图
mac-address:MAC地址,形式为H-H-H。
同一设备上所有聚合接口的MAC地址都相同,不同设备上聚合接口的MAC地址不同。
配置MAC地址时,需满足以下条件:
·     MAC地址高36位取值必须和MAC基地址相同。
·     MAC地址必须大于等于MAC基地址的值加上160。
有关MAC基地址的详细介绍,请参见“二层技术-以太网交换配置指导”中的“MAC地址表”。
# 配置三层聚合接口1的MAC地址为0001-0001-0002。
[Sysname-Route-Aggregation1] mac-address 1-1-2
1.1.47  mtu
mtu命令用来配置三层聚合接口/子接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
三层聚合接口/子接口的MTU值为1500字节。
三层聚合接口视图
三层聚合子接口视图
# 配置三层聚合接口1的MTU值为1430字节。
[Sysname-Route-Aggregation1] mtu 1430
·     display interface
port lacp isolate enable命令用来开启聚合成员端口的流量隔离功能。
undo port lacp isolate enable命令用来关闭聚合成员端口的流量隔离功能。
仅R5220及以上版本支持本命令。
聚合成员端口的流量隔离功能处于关闭状态。
二层以太网接口视图
三层以太网接口视图
工作机制
开启聚合成员端口流量隔离功能后,表示该动态聚合成员接口流量被隔离,即该动态聚合成员接口处非选中状态,对端设备与之相应聚合组的成员端口也处于非选中状态。
聚合成员接口流量隔离功能支持两种配置方式:
·     在系统视图下,执行link-aggregation lacp isolate命令来开启全局聚合流量隔离功能,对所有动态聚合接口生效;
·     在以太网接口视图下,执行port lacp isolate enable命令来开启聚合成员端口流量隔离功能,仅对当前接口生效。
对于一个接口来说,优先采用该接口下的配置;如果该接口下未进行配置时,则采用全局配置。
注意事项
开启本功能后,如果本端设备处于M-LAG MAD DOWN状态,则不能通过执行undo port lacp isolate enable命令恢复流量从本端M-LAG接口转发。
本功能仅对动态聚合接口生效,对于静态聚合接口和M-LAG组网中的peer-link接口不生效。
# 开启接口GigabitEthernet1/0/1的流量隔离功能。
[Sysname-GigabitEthernet1/0/1] port lacp isolate enable
·     link-aggregation lacp isolate
port lacp suppress unexpected-mac命令用来开启非法MAC报文丢弃功能。
undo port lacp suppress unexpected-mac命令用来关闭非法MAC报文丢弃功能。
仅R5220及以上版本支持本命令。
非法MAC报文丢弃功能处于关闭状态。
二层聚合接口视图
三层聚合接口视图
应用场景
当聚合接口未开启非法MAC报文丢弃功能时,如果发现聚合接口收到LACP报文中携带的源MAC地址与参考端口的MAC地址不一致时,会触发重新协商过程,可能导致已选中端口发生震荡,影响网络的稳定性。
工作机制
聚合接口开启非法MAC报文丢弃功能后,系统会在聚合接口收到LACP报文时进行MAC地址一致性检查。若发现携带的源MAC地址与参考端口的MAC地址不一致时,认为该报文为非法MAC报文,会自动将其丢弃,从而避免重新协商导致端口状态震荡。
注意事项
请在设备扩容场景时使用,避免已选中成员口发生震荡。
本命令不适用于M-LAG分裂后独立运行场景。
本命令仅对动态聚合接口生效。
# 开启二层聚合接口1的非法MAC报文丢弃功能。
[Sysname-Bridge-Aggregation1] port lacp suppress unexpected-mac
# 开启三层聚合接口1的非法MAC报文丢弃功能。
[Sysname-Route-Aggregation1] port lacp suppress unexpected-mac
·     link-aggragation mode dynamic
port lacp system-mac命令用来配置LACP的系统MAC地址。
undo port lacp system命令用来恢复缺省情况。
port lacp system-mac mac-address
undo port lacp system-mac
二层聚合接口视图
三层聚合接口视图
mac-address:LACP的系统MAC地址,格式为H-H-H,不支持组播与广播MAC地址、全0的MAC
# 配置聚合组1的LACP系统MAC地址为0002-0002-0002。
[Sysname-Bridge-Aggregation1] port lacp system-mac 2-2-2
·     lacp system-mac
port lacp system-priority命令用来配置LACP的系统优先级。
undo port lacp system-priority命令用来恢复缺省情况。
port lacp system-priority priority
LACP的系统优先级为32768。
二层聚合接口视图
三层聚合接口视图
LACP的系统优先级支持全局配置或在聚合组内配置两种方式:全局的配置对所有聚合组都有效,而聚合组内的配置只对当前聚合组有效。对于一个聚合组来说,优先采用该聚合组内的配置,只有该聚合组内未进行配置或配置为缺省值时,才采用全局的配置。
在开启S-MLAG功能的设备上,LACP的系统优先级需要配置一致。
# 配置聚合组1的LACP系统优先级为32。
[Sysname-Bridge-Aggregation1] port lacp system-priority 32
port link-aggregation group命令用来将接口加入指定的聚合组。
undo port link-aggregation group命令用来将接口从已加入的聚合组中删除。
port link-aggregation group { group-id [ force ] | auto [ group-id ] }
以太网接口未加入任何聚合组。
二层以太网接口视图
三层以太网接口视图
三层以太网子接口视图
group-id:指定聚合组所对应聚合接口的编号。对于Release 5212P01之前版本,取值范围为1~1024;对于Release 5212P01及以上版本,取值范围为1~4096。
force:表示接口加入聚合组时同步该聚合组的属性类配置。不指定该参数时,表示接口加入聚合组时不同步该聚合组的属性类配置。仅二层以太网接口支持指定本参数。
auto:开启端口的半自动聚合功能。
二层以太网接口只能加入二层聚合组,三层以太网接口/子接口只能加入三层聚合组。
一个接口只能加入一个聚合组。
接口加入聚合组前,如果接口上的属性类配置和聚合接口不同,则该接口不能加入聚合组。
接口加入聚合组后,不能修改接口的属性类配置。
指定force参数后,通过display current-configuration命令显示设备生效的配置中和配置文件中不会保存force参数。
缺省情况下,以太网接口不能和以太网子接口加入同一个聚合组。加入聚合组的以太网接口不能再创建子接口;已创建子接口的以太网接口不能加入聚合组。
成员端口为以太网子接口的聚合组对应的聚合接口不能再创建聚合子接口;以太网子接口不能加入已创建聚合子接口的聚合组。
仅指定auto参数时,表示根据对端发来的LACP报文决定加入哪个动态聚合组;如果未找到能够加入的聚合组,则创建一个符合条件的动态聚合组,并加入该聚合组中。
指定autogroup-id时,表示优先查看该聚合组参考端口所含的对端信息和收到的LACP报文中的对端信息是否一致:
·     如果相同则加入该聚合组。
·     如果不同,则再选择其他动态聚合组;如果未找到能够加入的动态聚合组,则创建一个符合条件的动态聚合组,并加入该聚合组中。
group-id必须是已经存在的动态聚合组。
当配置半自动聚合后,建议用户不要修改自动创建的聚合组及其成员端口的配置,避免影响半自动聚合功能。
仅二层以太网接口和三层以太网接口支持指定auto参数。指定auto参数后,二层以太网接口和三层以太网接口只能加入动态聚合组。
以太网冗余接口的成员接口和冗余组节点的成员接口不能再加入聚合组。有关以太网冗余接口和冗余组节点的详细介绍,请参见“可靠性配置指导”中的“冗余备份”。
当聚合成员组中首次加入配置MACsec的端口或配置MACsec的端口全部退出聚合成员组时,聚合组可能发生震荡。有关MACsec的详细介绍,请参见“安全配置指导”中的“MACsec”。
# 将二层以太网接口HundredGigE1/0/1加入二层聚合组1中。
# 将三层以太网接口HundredGigE1/0/2加入三层聚合组2中。
[Sysname-HundredGigE1/0/2] port link-aggregation group 2
port s-mlag group命令用来配置聚合接口加入S-MLAG组。
undo port s-mlag group命令用来恢复缺省情况。
port s-mlag group group-id
聚合接口未加入S-MLAG组。
二层聚合接口视图
group-id:指定S-MLAG组编号,取值范围为1~1024。
仅工作在动态聚合模式下的二层聚合接口可以加入S-MLAG组。
同一设备上不同聚合接口不能加入同一S-MLAG组。
配置聚合接口加入S-MLAG组后,该聚合接口不能再配置为M-LAG接口或peer-link接口。有关M-LAG接口和peer-link接口的详细介绍,请参见“二层技术-以太网交换配置指导”中的“M-LAG”。
# 配置二层聚合接口1加入S-MLAG组1。
[Sysname-Bridge-Aggregation1] port s-mlag group 1
reset lacp statistics命令用来清除成员端口上的LACP统计信息。
interface interface-list:表示清除指定成员端口上的LACP统计信息。interface-list为成员端口列表,表示一个或多个成员端口。表示方式为interface-list = interface-type interface-number1 [ to interface-type interface-number2 ]。其中,interface-type为接口类型,interface-number1interface-number2为接口编号。interface-number2的值要大于等于interface-number1的值。若未指定本参数,则清除所有成员端口上的LACP统计信息。
# 清除所有成员端口上的LACP统计信息。
<Sysname> reset lacp statistics
·     display link-aggregation member-port
sub-interface rate-statistic命令用来开启三层聚合子接口的速率统计功能。
undo sub-interface rate-statistic命令用来关闭三层聚合子接口的速率统计功能。
三层聚合子接口的速率统计功能处于关闭状态。
三层聚合接口视图
开启本功能后可能需要耗费大量系统资源,请谨慎使用。
开启本功能后,需要等待两个统计周期,才能显示三层聚合子接口的速率统计信息。统计周期可以通过flow-interval命令进行设置。
# 开启三层聚合接口1的子接口速率统计功能。
[Sysname-Route-Aggregation1] sub-interface rate-statistic
This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]:y
The configuration will take effect after 2 flow intervals.
·     flow-interval(接口管理命令参考/以太网接口)
