06-三层技术-IP业务命令参考
20-WAAS命令
本章节下载 20-WAAS命令  (675.21 KB)
20-WAAS命令
  录
1 WAAS
1.1 WAAS配置命令
1.1.1 class
1.1.2 display waas class
1.1.3 display waas fec peer-info
1.1.4 display waas policy
1.1.5 display waas session
1.1.6 display waas statistics dre
1.1.7 display waas statistics fec
1.1.8 display waas statistics load-balance
1.1.9 display waas statistics lz
1.1.10 display waas statistics packet-dup
1.1.11 display waas statistics tcp compress
1.1.12 display waas statistics udp compress
1.1.13 display waas status
1.1.14 display waas tfo auto-discovery blacklist
1.1.15 fec average-ratio
1.1.16 fec block-size
1.1.17 fec decode-timeout
1.1.18 fec encode-timeout
1.1.19 match tcp
1.1.20 match udp
1.1.21 optimize
1.1.22 packet-dup reorder timeout
1.1.23 packet-dup rir enable
1.1.24 passthrough
1.1.25 reset waas cache dre
1.1.26 reset waas statistics dre
1.1.27 reset waas statistics fec
1.1.28 reset waas statistics load-balance
1.1.29 reset waas statistics lz
1.1.30 reset waas statistics packet-dup
1.1.31 reset waas statistics tcp compress
1.1.32 reset waas statistics udp compress
1.1.33 reset waas tfo auto-discovery blacklist
1.1.34 waas apply policy
1.1.35 waas asymmetric
1.1.36 waas class
1.1.37 waas config remove-all
1.1.38 waas config restore-default
1.1.39 waas dre cache aging
1.1.40 waas dre offset-step
1.1.41 waas packet-dup sdwan static-path
1.1.42 waas policy
1.1.43 waas tcp
1.1.44 waas tcp acl
1.1.45 waas tcp destination
1.1.46 waas tfo auto-discovery blacklist enable
1.1.47 waas tfo auto-discovery blacklist hold-time
1.1.48 waas tfo base-congestion-window
1.1.49 waas tfo congestion-method
1.1.50 waas tfo connect-limit
1.1.51 waas tfo connect-wait
1.1.52 waas tfo keepalive
1.1.53 waas tfo optimize dre
1.1.54 waas tfo optimize lz
1.1.55 waas tfo receive-buffer
1.1.56 waas udp
1.1.57 waas udp acl
1.1.58 waas udp destination
1 WAAS
WAAS功能需要购买并正确安装License后才能使用,当License到期或被卸载后,所有已创建的WAAS策略都不允许使用。关于License的详细介绍,请参见“基础配置指导”中的“License管理”。
本特性仅在安装了RPE-X5/RPE-X5E主控板和FIP-260/FIP-380/FIP-660/FIP-680/SAP-XP4GE32业务板时支持。
1.1  WAAS配置命令
1.1.1  class
class命令用来配置WAAS策略引用的指定类,并进入WAAS策略类动作视图。
undo class命令用来取消WAAS策略对指定类的引用。
class class-name [ insert-before existing-class ]
undo class class-name
WAAS策略未引用任何类。
WAAS策略视图
class-name指定引用的类名称,为1~63个字符的字符串,不区分大小写,该类必须存在。
insert-before existing-class:表示插入到指定类之前,existing-class表示WAAS策略已引用的类名称。
WAAS策略支持引用预定义类。(预定义类参见表1-14
建议用户通过执行此命令进入预定义类动作视图,通过修改预定义类的方式完成配置。
通过本命令,可对WAAS策略已引用的多个类进行排序。
报文流量匹配类时,按照引用的类的排序进行匹配,匹配上任一个类,则按照相应动作处理报文流量。
如果WAAS策略未为引用的类配置任何动作,则该类不参与所属策略对报文流量的匹配。
# 配置WAAS策略引用预定义类AFS,并进入其动作视图。
[Sysname] waas policy waas_global
[Sysname-waaspolicy-waas_global] class AFS
[Sysname-waaspolicy-waas_global-AFS]
# 配置WAAS策略引用预定义类AOL,将其插入到AFS之前,并进入AOL动作视图。
[Sysname-waaspolicy-waas_global] class AOL insert-before AFS
[Sysname-waaspolicy-waas_global-AOL]
# WAAS策略已依次引用预定义类AFS、AOL,调整class顺序,将AOL插入到AFS之前,并进入AOL类动作视图。
·     display waas policy
·     waas class
·     waas policy
display waas class命令用来显示WAAS类的信息。
display waas class [ class-name ]
class-name:指定WAAS类的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有WAAS类的信息。
# 显示类class1的信息。
<Sysname> display waas class class1
WAAS class: class1
  match 1 tcp source ip-address 1.1.1.0 24 port 50000 60000
  match 6 tcp destination ip-address 2.2.2.2 port 1 1024
  match 11 tcp source ipv6-address 1001:: 96 port 50000 60000
  match 16 tcp destination ipv6-address 2002::2222 port 1 1024
表1-1 display waas class命令显示信息描述表
WAAS class
WAAS类的名称
match
WAAS类包含的匹配规则
·     match tcp
·     waas class
display waas fec peer-info命令用来显示对端FEC的信息。
(独立运行模式)
display waas fec peer-info { ipv4 | ipv6 } [ vpn-instance vpn-instance-name ] [ source-ip source-ip | source-port source-port | destination-ip destination-ip | destination-port destination-port ] * [ slot slot-number ]
display waas fec peer-info { ipv4 | ipv6 } [ vpn-instance vpn-instance-name ] [ source-ip source-ip | source-port source-port | destination-ip destination-ip | destination-port destination-port ] * [ chassis chassis-number slot slot-number ]
ipv4显示IPv4对端FEC的信息。
ipv6显示IPv6对端FEC的信息。
vpn-instance vpn-instance-name:显示指定VPN实例中的对端FEC信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网中对端FEC信息。
source-ip source-ip:显示指定源IP地址的对端FEC的信息,source-ip表示源IP地址。如果不指定本参数,将显示所有源地址的对端FEC的信息。
source-port source-port:显示指定源端口号的对端FEC的信息,source-port表示源端口号,取值范围为1~65535。如果不指定本参数,将显示所有源端口号的对端FEC的信息。
destination-ip destination-ip:显示指定目的IP地址的对端FEC的信息,destination-ip表示目的IP地址。如果不指定本参数,将显示所有目的IP地址的对端FEC的信息。
destination-port destination-port:显示指定目的端口号的对端FEC的信息,destination-port表示目的端口号,取值范围为1~65535。如果不指定本参数,将显示所有目的端口号的对端FEC的信息。
slot slot-number:显示指定单板的对端FEC的信息。slot-number为单板所在的槽位号。如果不指定本参数,则显示所有单板上的对端FEC的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的对端FEC的信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则显示所有单板上的对端FEC的信息。(IRF模式)
# 显示所有的IPv4对端FEC的信息。
<Sysname> display waas fec peer-info ipv4
Slot 0:
Slot 2:
Source IP/Port: 192.168.56.1/3230, Destination IP/Port: 192.168.157.100/3230
Protocol: UDP
Type: A-FEC
A-FEC info:
  Version: 1
  Interface              : GE2/0/1
  [1]Loss ratio (time)   : 5%  (2020/10/29 17:20:04.409)
  [2]Loss ratio (time)   : 5%  (2020/10/29 17:20:04.419)
  [3]Loss ratio (time)   : 5%  (2020/10/29 17:20:04.429)
  Sampling interval(ms)  : 10
  Average loss ratio     : 5%
  Receiving count        : 10
  Last receiving time(ms): 10
Source IP/Port: 192.168.57.1/3230, Destination IP/Port: 192.168.158.100/3230
Type: D-FEC
Source IP/Port: 192.168.58.1/3230, Destination IP/Port: 192.168.159.100/3230
Type: Unknown
# 显示私网vpn1 IPv6对端FEC的信息。
<Sysname> display waas fec peer-info ipv6 vpn-instance vpn1
Source IP/Port: 200::2/3030, Destination IP/Port:100::100/3030
Protocol: TCP
Type: A-FEC
A-FEC info:
  Version: 1
  Interface              : GE2/0/1
  Sampling interval(ms)  : 15
  Last receiving time(ms): 20
Source IP/Port: 201::2/3030, Destination IP/Port: 101::100/3030
Type: D-FEC
Source IP/Port: 202::2/3030, Destination IP/Port: 102::100/3030
Type: Unknown
表1-2 display waas fec ipv4 peer-info命令显示信息描述表
Slot 0
槽位号
FEC类型:
·     A-FEC:FEC类型为A-FEC
·     D-FEC:FEC类型为D-FEC
·     Unknown:FEC类型未知
Version
版本信息
探测对端信息的出接口
Source IP/Port
源IP/目的端口
Destination IP/Port
目的IP/目的端口
Protocol
协议类型,取值包括:
·     UDP:报文协议类型为UDP
·     TCP:报文协议类型为TCP
Loss ratio(time)
采样节点丢包率(采样时间)
Sampling interval (ms)
采样周期(单位:毫秒)
Average loss ratio
平均丢包率
Receiving count
接收采样报文的数量
距离上次接收时间(毫秒)
display waas policy命令用来显示WAAS策略的信息。
display waas policy [ policy-name ]
policy-name:指定WAAS策略的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有WAAS策略的信息。
# 显示指定WAAS策略po1的信息。
<Sysname> display waas policy po1
WAAS policy: po1
  class cl1
    optimize TFO DRE LZ
  class cl2
    optimize TFO DRE
  class cl3
    passthrough
  class cl4
    optimize TFO LZ
  class cl5
表1-3 display waas policy命令显示信息描述表
WAAS policy
WAAS策略的名称
class
WAAS策略引用的class名称
optimize
class配置的优化方式,取值包括:
·     TFO:表示流传输优化方式,仅支持TCP流传输优化。
·     DRE:表示消除冗余数据优化方式。
·     LZ:表示数据压缩优化方式。
passthrough
class直接旁路动作,不做任何优化处理
·     class
·     optimize
·     passthrough
·     waas policy
display waas session命令用来显示WAAS会话信息。
(独立运行模式)
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ] [ slot slot-number ]
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
ipv4:显示IPv4会话信息。
ipv6:显示IPv6会话信息。
client-ip client-ip:显示指定客户端地址的会话信息,client-ip表示客户端IP地址。
client-port client-port:显示指定客户端端口号的会话信息,client-port表示客户端端口号,取值范围为1~65535。
server-ip server-ip:显示指定服务器端地址的会话信息,server-ip表示服务器端IP地址。
server-port server-port:显示指定服务器端端口号的会话信息,server-port表示服务器端端口号,取值范围为1~65535。
peer-id peer-id:显示与指定对端设备相关的WAAS会话信息,peer-id表示对端设备的桥MAC地址,格式为H-H-H。
verbose:显示WAAS会话的详细信息。如果不指定本参数,则显示WAAS会话的简要信息。
slot slot-number:显示指定单板的会话信息。slot-number表示单板所在的槽位号。如果不指定本参数,将显示所有单板上的会话信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的会话信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示所有单板上的会话信息。(IRF模式)
显示所有满足指定条件的会话的信息。如果除IPv4或IPv6外没有指定任何参数,将显示与所有对端设备相关的IPv4或IPv6的会话信息。
# 显示IPv4会话的简要信息。
<Sysname> display waas session ipv4
Peer ID: 0021-90ad-0012
Start Time: Fri Mar 21 10:43:05 2014
Source IP/Port: 1.1.1.1/34572
Destination IP/Port: 2.2.2.2/80
Peer ID: 0011-10ad-0012
Start Time: Fri Mar 21 10:45:05 2014
Source IP/Port: 2.2.1.1/34572
Destination IP/Port: 3.2.2.3/80
Total 2 sessions found.
# 显示IPv4会话的详细信息。
<Sysname> display waas session ipv4 verbose
Peer ID: 0021-90ad0-01221
Start Time: Fri Mar 21 11:43:05 2014
LAN interface: GigabitEthernet2/0/1
WAN interface: GigabitEthernet2/0/2
Configured Policy: TFO DRE LZ
Negotiated Policy: TFO DRE LZ
LAN->WAN bytes: Original   104884      Optimized  88594
WAN->LAN bytes: Original   744588      Optimized  3355445
LZ section:
  Encode status:
    Bytes in: 0
    Bytes out: 0
    Bypass bytes: 400
    Space saved: 0%
    Average Latency: 0 usec
  Decode status:
    Bytes in: 329
    Bytes out: 393
    Bypass bytes: 63
    Space saved: 16%
    Average Latency: 2 usec
DRE section:
  Encode status:
    Bytes in: 0
    Bytes out: 0
    Bypass bytes: 314
    Space saved: 0%
    Average latency: 0 usec
  Decode status:
    Bytes in: 399
    Bytes out: 332
    Bypass bytes: 0
    Space saved: 0%
    Chunk miss: 0
    Collision: 0
    Average latency: 23 usec
LZ section:
  Encode status:
    Bytes in: 0
    Bytes out: 0
    Bypass bytes: 400
    Space saved: 0%
  Decode status:
    Bytes in: 329
    Bytes out: 393
    Bypass bytes: 63
    Space saved: 16%
DRE section:
  Encode status:
    Bytes in: 0
    Bytes out: 0
    Bypass bytes: 314
    Space saved: 0%
  Decode status:
    Bytes in: 399
    Bytes out: 332
    Bypass bytes: 0
    Space saved: 0%
    Chunk miss: 0
    Collision: 0
    Average latency 23 usec
表1-4 display waas session命令显示信息描述表
Peer ID
对端设备ID,即设备的桥MAC地址,用来唯一标识一台对端设备
Start time
WAAS会话建立时间
Source IP/Port
客户端IP地址/端口号
Destination IP/Port
服务器端IP地址/端口号
LAN interface
LAN侧接口
WAN interface
WAN侧接口
Configured Policy
本端设备配置的优化方式,取值包括:
·     DRE:表示消除冗余数据优化方式
·     LZ:表示数据压缩优化方式
Negotiated Policy
与对端设备协商后的优化动作,取值包括:
·     DRE:表示消除冗余数据优化方式
·     LZ:表示数据压缩优化方式
协商后的优化方式取两端WAAS设备配置优化方式的交集
LAN->WAN bytes
LAN侧接口到WAN侧接口的数据统计:
·     Original:表示原始字节数
·     Optimized:表示优化后的字节数
WAN->LAN bytes
WAN侧接口到LAN侧接口的数据统计:
·     Original:表示原始字节数
LZ section
LZ统计信息
DRE section
DRE统计信息
Encode status
压缩统计信息
Decode status
解压缩统计信息
Bytes in
输入字节数
Bytes out
输出字节数
Bypass bytes
未参与匹配的字节数
Space saved
压缩率,计算公式:
·     压缩:(1 - (Bytes out / Bytes in)) * 100
·     解压:(1 - (Bytes in/ Bytes out)) * 100
Average Latency
最后一次压缩或者解压的平均延迟时间,单位为微秒
Chunk miss
无法根据字典索引找到字典表项累计次数
Collision
解码后数据校验失败累计次数
Total sessions
当前建立的会话总数
display waas statistics dre命令用来显示DRE统计信息。
(独立运行模式)
display waas statistics dre [ peer peer-id ] [ slot slot-number ]
display waas statistics dre [ peer peer-id ] [ chassis chassis-number slot slot-number ]
peer peer-id:显示与指定对端设备相关的DRE统计信息,peer-id表示设备的MAC地址,形式为H-H-H。如果未指定本参数,则显示与所有对端设备相关的DRE的统计信息。
slot slot-number:显示指定单板上的DRE统计信息。slot-number表示单板所在的槽位号。如果不指定本参数,将显示所有单板上的DRE统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的DRE统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示所有单板上的DRE统计信息。(IRF模式)
# 显示设备上所有DRE的统计信息。
<Sysname> display waas statistics dre
Peer-ID: 0016-9d38-ca1d
Peer version: 1.0
Cache in storage: 19426304 bytes
Index number: 75884
Age: 00 weeks, 00 days, 00 hours, 00 minutes, 33 seconds
Total connections: 1
Active connections: 0
Encode Statistics
  Dre msgs: 2
  Bytes in: 392 bytes
  Bytes out: 424 bytes
  Bypass bytes: 0 bytes
  Bytes Matched: 0 bytes
  Space saved: -8%
Decode Statistics
  Dre msgs: 196407
  Bytes in: 29132703 bytes
  Bytes out: 42413368 bytes
  Space saved: 31%
Peer-ID: 0d38-9d38-ca1d
Peer version: 1.0
Cache in storage: 33554944 bytes
Index number: 131074
Age: 00 weeks, 00 days, 00 hours, 21 minutes, 31 seconds
Total connections: 2
Encode Statistics
  Dre msgs: 514872
  Bytes in: 111390296 bytes
  Bytes out: 60085884 bytes
  Bytes Matched: 56336640 bytes
  Space saved: 46%
Decode Statistics
  Dre msgs: 4
  Bytes in: 849 bytes
  Bytes out: 785 bytes
  Space saved: -8%
# 显示指定对端设备的DRE统计信息。
<Sysname> display waas statistics dre peer 0016-9d38-ca1d
Peer version: 1.0
Encode Statistics
  Dre msgs: 514872
  Space saved: 46%
Decode Statistics
  Dre msgs: 4
  Bytes in: 849 bytes
  Space saved: -8%
表1-5 display waas statistics dre命令显示信息描述表
Peer-ID
Peer version
对端设备的WAAS版本号
Cache in storage
元数据占用的空间大小,单位为字节
Index number
元数据块索引的个数
Age
peer节点存在时间
Total connections
DRE连接总数
Active connections
DRE活动连接数
Encode Statistics
压缩统计信息
Decode Statistics
解压缩统计信息
Dre msgs
数据块个数
Bytes in
输入字节数
Bytes out
输出字节数
Bypass bytes
未参与匹配的字节数
Bytes Matched
匹配上字典的字节数
Space saved
压缩率,计算公式:
Average latency
在多核处理中,最后一次压缩或者解压的平均延迟时间,单位为微秒
·     reset waas statistics dre
display waas statistics fec命令用来显示FEC的报文统计信息。
(独立运行模式)
display waas statistics fec [ slot slot-number ]
display waas statistics fec [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上的FEC统计信息。slot-number为单板所在的槽位号。如果不指定本参数,则显示所有成员设备累加的FEC统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的FEC统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则显示所有单板累加的FEC统计信息。(IRF模式)
# 显示设备上所有FEC的报文统计信息。
<Sysname> display waas statistics fec
Encoder:
  Received:
    Total packets                                                     : 661
  Sent:
    Original packets                                                  : 661
    Redundant packets                                                 : 375
    In-order original packets after timeout                           : 141
    Out-of-order original packets after timeout                       : 0
Decoder:
  Received:
    Original packets                                                  : 0
    Redundant packets                                                 : 0
    Original packets in different group                               : 0
    Redundant packets in different group from cached redundant packets: 0
    Redundant packets in different group from cached original packets : 0
    Redundant packets with sequence number less than cached ones      : 0
  Sent:
    Recovered packets                                                 : 0
    In-order original packets after timeout                           : 0
表1-6 display waas statistics fec命令显示信息描述表
Encoder
编码端的报文统计信息
Received
编码端接收的报文统计信息
Total packets
编码端接收的总报文数
Sent
编码端发送的报文统计信息
Original packets
编码端发送的原报文数
Redundant packets
编码端发送的冗余报文数
编码端超时后按顺序发送的原报文数
编码端超时后乱序发送的原报文数
Decoder
解码端的报文统计信息
Received
解码端接收的报文统计信息
Original packets
解码端接收到的原报文数
Redundant packets
解码端接收到的冗余报文数
解码端接收到的原报文与缓存报文不是同一组
解码端接收到的冗余报文与缓存冗余报文不是同一组
解码端接收到的冗余报文与缓存原报文不是同一组
解码端接收到的冗余报文序号小于缓存冗余报文的序号
Sent
解码端发送的报文统计信息
Original packets
解码端发送的原报文数
Recovered packets
解码端发送的恢复出来的报文数
解码端超时后按顺序发送的原报文数
·     reset waas statistics fec
display waas statistics load-balance命令用来显示SDWAM组网下负载分担的报文统计信息。
display waas statistics load-balance { ipv4 | ipv6 }
ipv4显示IPv4的报文统计信息。
ipv6显示IPv6的报文统计信息。
仅逐包模式下的负载分担报文支持通过本命令查看经过保序处理后的报文统计信息。
# 显示负载分担的IPv4报文统计信息。
<Sysname> display waas statistics load-balance ipv4
Packet Order Preservation:
  In-order packets sent                                                     :200
  Out-of-order packets sent                                                 :19
  Out-of-order packets cached                                               :40
  Cached packets sent in order                                             :40
  Cache failed packets sent                                                 :0
  Cached packets sent on timeout                                            :0
  Out-of-order fragmented packets sent                                      :1
  Out-of-order fragmented packets cached                                    :3
  Cached fragmented packets sent in order                                   :3
  Cached fragmented packets sent on timeout                                 :3
表1-7 display waas statistics load-balance命令显示信息描述表
接收端保序处理时,报文统计信息
正常按序发送的报文数
乱序后直接发送的报文数
乱序后被缓存的报文数
缓存后按序发送的报文数
缓存失败直接发送的报文数
缓存超时后乱序发送的报文数
未经保序直接发送的分片首包报文数
乱序到被缓存的分片报文数
缓存后按序发送的分片报文数
缓存超时后乱序发送的分片报文
display waas statistics lz命令用来显示LZ统计信息。
(独立运行模式)
display waas statistics lz [ peer peer-id ] [ slot slot-number ]
display waas statistics lz [ peer peer-id ] [ chassis chassis-number slot slot-number ]
peer peer-id:显示与指定对端设备相关的LZ统计信息,peer-id表示设备的MAC地址,形式为H-H-H。如果未指定本参数,则显示与所有对端设备相关的LZ的统计信息。
slot slot-number:显示指定单板上的LZ统计信息。slot-number表示单板所在的槽位号。如果不指定本参数,将显示所有单板上的LZ统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的LZ统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示所有单板上的LZ统计信息。(IRF模式)
# 显示设备上所有LZ的统计信息。
<Sysname> display waas statistics lz
Peer version: 1.0
Encode Statistics
  Bytes in: 392 bytes
  Space saved: -8%
Decode Statistics
  Space saved: 31%
Peer version: 1.0
Encode Statistics
  Space saved: 46%
Decode Statistics
  Bytes in: 849 bytes
  Space saved: -8%
# 显示指定对端设备的LZ统计信息。
<Sysname> display waas statistics lz peer 0016-9d38-ca1d
Peer version: 1.0
Encode Statistics
  Space saved: 46%
Decode Statistics
  Bytes in: 849 bytes
  Space saved: -8%
表1-8 display waas statistics lz命令显示信息描述表
Peer-ID
Peer version
对端设备的WAAS版本号
Age
peer节点存在时间
Total connections
连接总数
Active connections
活动连接数
Encode Statistics
压缩统计信息
Decode Statistics
解压缩统计信息
Bytes in
输入字节数
Bytes out
输出字节数
Bypass bytes
未参与匹配的字节数
Space saved
压缩率,计算公式:
Average latency
display waas statistics packet-dup命令用来显示包复制的报文统计信息。
display waas statistics packet-dup { ipv4 | ipv6 }
ipv4显示IPv4包复制的报文统计信息。
ipv6显示IPv6包复制的报文统计信息。
# 显示IPv4包复制的报文统计信息。
<Sysname> display waas statistics packet-dup ipv4
Packet Duplication:
  Original packets                                                     : 522
  Duplicated packets                                                   : 522
  Non-duplicated packets due to fragmentation                          :0
  Packets exceeding MTU                                                : 0
Packet Redundancy:
  Passed packets                                                            :200
  Discarded packets                                                         :199
  Out-of-order fragmented packets sent                                      :10
  Out-of-order fragmented packets cached                                    :0
  Cached fragmented packets sent in order                                   :0
  Cached fragmented packets sent on timeout                                 :0
表1-9 display waas statistics packet-dup命令显示信息描述表
Packet Duplication
发送端复制处理时,报文统计信息
Original packets
原始报文数
Duplicated packets
复制报文数
由于报文分片,未复制的报文数
由于报文长度大于MTU,未复制的报文数
Packet Redundancy
接收端去冗余处理时,报文统计信息
Passed packets
保留的报文数
Discarded packets
丢弃的报文数
接收端保序处理时,报文统计信息
正常按序发送的报文数
乱序后直接发送的报文数
乱序后被缓存的报文数
缓存后按序发送的报文数
缓存失败直接发送的报文数
缓存超时后乱序发送的报文数
未经保序直接发送的分片首包报文数
乱序到被缓存的分片报文数
缓存后按序发送的分片报文数
·     reset waas statistics packet-dup
display waas statistics tcp compress命令用来查看TCP数据报文的压缩统计信息。
# 显示TCP日志报文的压缩统计信息。
<Sysname> display waas statistics tcp compress
Bytes in               : 42413368 bytes
Bytes out              : 29132703 bytes
Saved bandwidth ratio  : 31%
Compressed packet ratio: 100%
表1-10 display waas statistics tcp compress命令显示信息描述表
Bytes in
输入字节数
Bytes out
输出字节数
带宽节省百分比((输入字节数-输出字节数)/输入字节数)
包压缩率(压缩报文个数/总报文个数)
·     reset waas statistics tcp compress
display waas statistics udp compress命令用来查看UDP报文的压缩统计信息。
# 显示UDP报文的压缩统计信息。
<Sysname> display waas statistics udp compress
Compressed packet ratio       : 100%
表1-11 display waas statistics udp compress命令显示信息描述表
Bytes in
输入字节数
Bytes out
输出字节数
带宽节省百分比
包压缩率
·     reset waas statistics udp compress
display waas status命令用来显示WAAS全局状态。
display waas status
# 显示WAAS全局状态。
<Sysname> display waas status
WAAS version: 1.0
Local ID: 02e0-011a-0000
DRE status: Disabled
LZ status: Disabled
BlackList status: Disabled
Total active connections: 7889
Total data storage size: 1468006400 bytes
Total index number: 11513600
Blacklist hold-time:5 minutes
Max TFO connections: 10000
Offset step: Normal
Aging time: 0 minutes
Symmetrical Mode : Yes
Interfaces             Applied policy
GE2/0/1                waas_global
GE2/0/2                waas_default
GE2/0/3                waas_global
Total policy interfaces: 3
表1-12 display waas status命令显示信息描述表
WAAS version
WAAS版本号
Local ID
本端ID,即WAAS设备的桥MAC地址,用来唯一标识一台WAAS设备。
DRE status
是否开启WAAS数据冗余消除功能:
·     Enabled:表示已开启
·     Disabled:表示未开启
LZ status
是否开启WAAS数据压缩功能:
·     Enabled:表示已开启
·     Disabled:表示未开启
BlackList status
是否开启自动发现黑名单功能:
·     Enabled:表示已开启
·     Disabled:表示未开启
当前的WAAS活动连接数
所有元数据所占空间的大小,单位为字节。元数据即为字典索引对应的原始数据
Total index number
元数据对应的所有字典索引的个数
Blacklist hold-time
黑名单表项的老化时间,单位为分钟
Max TFO connections
TFO的最大并发连接数
Offset step
WAAS匹配偏移步进级别:
·     Fastest:最快
·     Faster:较快
·     Fast:一般
·     Normal:正常
Aging time
WAAS数据字典表项的老化时间,单位为分钟
Symmetrical Mode
是否是对称组网模式
Interfaces
已应用WAAS策略的接口列表
Applied policy
接口应用策略列表
应用WAAS策略的接口总数
display waas tfo auto-discovery blacklist命令用来显示黑名单信息。
(独立运行模式)
display waas tfo auto-discovery blacklist { ipv4 | ipv6 } [ slot slot-number ]
display waas tfo auto-discovery blacklist { ipv4 | ipv6 } [ chassis chassis-number slot slot-number ]
ipv4:显示IPv4黑名单信息。
ipv6:显示IPv6黑名单信息。
slot slot-number:显示指定单板的黑名单信息。slot-number表示单板所在的槽位号。如果不指定本参数,将显示所有单板上的黑名单信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的黑名单信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示所有单板上的黑名单信息。(IRF模式)
# 显示所有IPv4黑名单信息。
<Sysname> display waas tfo auto-discovery blacklist ipv4
Server IP address/Port           Insert Time
1.1.1.1/8080                     Fri Mar 21 10:43:05 2014
1.1.1.2/8080                     Fri Mar 21 10:43:06 2014
2.2.2.2/443                      Fri Mar 21 10:20:37 2014
Total 3 entries found.
表1-13 display waas auto-discovery blacklist命令显示信息描述表
服务器IP地址/端口号
Insert Time
黑名单表项的生成时间
黑名单表项的总数
·     reset waas tfo auto-discovery blacklist
·     waas tfo auto-discovery blacklist enable
·     waas tfo auto-discovery blacklist hold-time
fec average-ratio命令用来配置FEC的平均抗丢包率。
undo fec average-ratio命令用来恢复缺省情况。
fec average-ratio ratio
FEC的平均抗丢包率为35%。
WAAS策略类动作视图
ratio:平均抗丢包率,取值范围为1~50,单位为百分比。
平均抗丢包率决定FEC一组编码块原始数据包产生冗余包的个数:平均抗丢包率越小,生成的冗余包个数越少,占用带宽越小;平均抗丢包率越大,生成的冗余包个数越多,占用带宽越大。用户需要根据网络的实际丢包率来配置此值,配置的抗丢包率大于实际丢包率。
冗余包个数=Round Up(原始数据包数×(平均抗丢包率÷(1—平均抗丢包率))。Round Up是向上取舍,无论取舍的是几都向上进1。
# 配置WAAS策略类AFS的FEC平均抗丢包率为30%。
[Sysname-waaspolicy-waas_global-AFS] fec average-ratio 30
·     fec block-size
fec block-size命令用来配置编码块包数。
undo fec block-size命令用来恢复缺省情况。
fec block-size block-size
undo fec block-size
编码块包数为20。
WAAS策略类动作视图
block-size:编码块包数,取值范围为1~150,单位为个。
FEC编码块包数和FEC编码超时时间共同决定FEC一组编码块的原始数据包个数,若包数先达到编码块包数,则以编码块包数为准;若编码超时时间先到,则以此时缓存的原始数据包个数为准。若此值配置较小,则冗余包会较少;若此值配置较大,则当网络中发生丢包时,解码侧恢复被丢报文产生的时延较大。请根据当前网络带宽配置此值。
# 配置WAAS策略类AFS的编码块包数为20。
[Sysname-waaspolicy-waas_global-AFS] fec block-size 20
·     fec average-ratio
fec decode-timeout命令用来配置解码超时时间。
undo fec decode-timeout命令用来恢复缺省情况。
fec decode-timeout milliseconds
解码超时时间为800毫秒。
WAAS策略类动作视图
milliseconds:解码超时时间,取值范围为30~1000,单位为毫秒。
在解码超时时间内,当缓存的原始数据包和冗余包之和大于等于该分组中原始数据包的个数,设备将缓存的数据包进行FEC解码处理,恢复丢失的数据包,再分别发送原始数据包和恢复的数据包,并丢弃冗余包。如果缓存时间达到解码超时时间,设备将不会进行FEC解码,而是直接发送接收到的原始数据包,丢弃冗余包。
# 配置WAAS策略类AFS的解码超时时间为500毫秒。
[Sysname-waaspolicy-waas_global-AFS] fec decode-timeout 500
·     fec block-size
·     fec encode-timeout
fec encode-timeout命令用来配置编码超时时间。
undo fec encode-timeout命令用来恢复缺省情况。
fec encode-timeout milliseconds
编码超时时间为500毫秒。
WAAS策略类动作视图
milliseconds:编码超时时间,取值范围为30~1000,单位为毫秒。
FEC编码块包数和FEC编码超时时间共同决定FEC一组编码块的原始数据包个数:若包数先达到编码块包数,则以编码块包数为准;若编码超时时间先到,则以此时缓存的原始数据包个数为准。
[Sysname-waaspolicy-waas_global-AFS] fec encode-timeout 60
·     fec block-size
1.1.19  match tcp
match tcp命令用来创建匹配流分类的规则。
undo match命令用来删除创建的匹配流分类规则。
match [ match-id ] tcp any [ ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name } | ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name } ] [ port { port-list | object-group port-object-group-name } ]
match [ match-id ] tcp { destination ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name } [ port { port-list | object-group port-object-group-name } ] | source ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name } [ port { port-list | object-group port-object-group-name } ] } *
match [ match-id ] tcp { destination ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name } [ port { port-list | object-group port-object-group-name } ] | source ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name } [ port { port-list | object-group port-object-group-name } ] } *
match [ match-id ] tcp { destination | source } port { object-group port-object-group-name | port-list }
undo match match-id
不存在匹配流分类的规则。
WAAS类视图
match-id:指定匹配流分类规则的编号,取值范围为1~65535,是match规则的唯一标识。如果指定编号的匹配规则不存在,则创建一条新的匹配规则;如果指定编号的匹配规则已存在,则对其进行修改。如果未指定本参数,系统将自动分配一个可用的最小编号。
tcp:匹配TCP报文流量。
any:指定匹配规则的源或目的地址、端口号。
destination:指定匹配规则的目的地址、目的端口号。
source:指定匹配规则的源地址、源端口号。
ip-address { ip-address [ mask-legnth | mask ] | object-group ip-object-group-name }:指定匹配规则引用的IP地址。其中:
·     ip-address:IPv4地址,为点分十进制格式。
·     mask-length:指定子网掩码长度,取值范围为0~32,缺省值为32。
·     mask:指定子网掩码,为点分十进制格式,缺省值为255.255.255.255。
·     object-group ip-object-group-name:指定匹配规则引用的IP地址对象组的名称,为1~63个字符的字符串,不区分大小写。
ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name }:指定匹配规则引用的IPv6地址。其中:
·     ipv6-address:指定匹配规则的IPv6地址。
·     prefix-length:指定前缀长度,取值范围为0~128,缺省值为128。
·     object-group ipv6-object-group-name:指定匹配规则引用的IPv6地址对象组的名称,为1~63个字符的字符串,不区分大小写。
port { port-list | object-group port-object-group-name }:指定匹配规则引用的端口。其中:
·     port-list:指定匹配规则的端口号列表。表示方式为port-list = { port-number [ to port-number ] } &<1-10>,其中port-number表示端口号,取值范围是1~65535,&<1-10>表示前面的参数最多可以输入10次。当使用to关键字指定端口号范围时,起始端口号必须小于或等于结束端口号。如果未指定本参数,则匹配所有端口号。
·     object-group port-object-group-name:指定匹配规则引用的端口对象组的名称,为1~63个字符的字符串,不区分大小写。
指定匹配类型为any时,如果指定IP地址、端口号,则表示匹配源IP地址、端口号,或匹配目的IP地址、端口号。
同时指定匹配类型为destinationsource时,必须指定IP地址信息。
不允许配置编号不同,但是内容完全相同的匹配规则。
WAAS类最多可创建256个匹配规则,按照匹配规则的创建顺序进行匹配,匹配上其中任意一条,则认为匹配上了该类。
# 创建类http_class的匹配规则:匹配源地址为192.168.0.1/16,源端口号为80和8000~8080的tcp流量。
[Sysname] waas class http_class
[Sysname-waasclass-http_class] match tcp source ip-address 192.168.0.1 16 port 80 8000 to 8080
# 创建类http_class的匹配规则:匹配所有TCP流量。
[Sysname-waasclass-http_class] match tcp any
# 创建类http_class的匹配规则:匹配源地址为10.0.3.1/24,目的地址为11.0.3.1/24的TCP流量。
[Sysname-waasclass-http_class] match tcp source ip-address 10.0.0.1 24 destination ip-address 11.0.3.1 24
#创建类http_class的匹配规则:匹配源地址引用对象组group1,目的地址引用对象组group2的TCP流量。
[Sysname-waasclass-http_class] match tcp source ip-address object-group group1 destination ip-address object-group group2
·     display waas class
·     waas class
1.1.20  match udp
match udp命令用来创建匹配UDP流分类的规则。
undo match命令用来删除指定的已创建的匹配UDP流分类规则。
match [ match-id ] udp any [ ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name } | ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name } ] [ port { port-list | object-group port-object-group-name } ]
match [ match-id ] udp { destination ip-address { ip-address [ mask-legnth | mask ] | object-group ip-object-group-name } [ port { port-list | object-group port-object-group-name } ] | source ip-address { ip-address [ mask-legnth | mask ] | object-group ip-object-group-name } [ port { port-list | object-group port-object-group-name } ] } *
match [ match-id ] udp { destination ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name } [ port { port-list | object-group port-object-group-name } ] | source ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name } [ port { port-list | object-group port-object-group-name } ] } *
match [ match-id ] udp { destination | source } port { port-list | object-group port-object-group-name  }
undo match match-id
不存在匹配UDP流分类的规则。
WAAS类视图
match-id:指定匹配流分类规则的编号,取值范围为1~65535,是匹配规则的唯一标识。如果指定编号的匹配规则不存在,则创建一条新的匹配规则;如果指定编号的匹配规则已存在,则对其进行修改。如果未指定本参数,系统将自动分配一个可用的最小编号。
udp:匹配UDP报文流量。
ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name }:指定匹配规则引用的IPv6地址,本参数仅支持在WAAS类视图下配置。其中:
·     ipv6-address:IPv6地址。
·     prefix-length:前缀长度,取值范围为0~128,缺省值为128。
指定匹配类型为any时,如果指定IP地址、端口号,则表示匹配源IP地址、端口号,或匹配目的IP地址、目的端口号。
# 创建WAAS类http_class的匹配规则:匹配源地址为192.168.0.1/16,源端口号为80和8000~8080的UDP流量。
[Sysname-waasclass-http_class] match udp source ip-address 192.168.0.1 16 port 80 8000 to 8080
# 创建WAAS类http_class的匹配规则:匹配所有UDP流量。
[Sysname-waasclass-http_class] match udp any
# 创建WAAS类http_class的匹配规则:匹配源地址为10.0.3.1/24,目的地址为11.0.3.1/24的UDP流量。
[Sysname-waasclass-http_class] match udp source ip-address 10.0.0.1 24 destination ip-address 11.0.3.1 24
#创建WAAS类http_class的匹配规则:匹配源地址引用对象组group1,目的地址引用对象组group2的UDP流量。
[Sysname-waasclass-http_class] match udp source ip-address object-group group1 destination ip-address object-group group2
·     waas class
1.1.21  optimize
optimize命令用来配置WAAS类的优化方式。
undo optimize命令用来恢复缺省情况。
optimize { fec | packet-dup | tfo [ dre | lz ] * }
undo optimize
未配置任何优化方式。
WAAS策略类动作视图
packet-dup:包复制优化方式。
tfo流传输优化方式,仅支持TCP流传输优化。
dre:消除冗余数据优化方式。
lz:数据压缩优化方式。
fec:前向冗余纠错优化方式。
该命令受优化控制功能状态的影响,如果用户配置了优化动作,而对应的优化控制功能处于关闭状态,则不能对匹配的报文流量进行相应的优化处理。
对于匹配了黑名单的流量,通过optimize命令配置优化动作后,不会对指定流量进行优化。
本命令与passthrough命令二者只能选其一,如果同时配置了这两条命令,则后配置的生效。
undo操作时,将所有优化方式恢复为缺省情况,即未配置任何优化方式。
# 配置WAAS策略类AFS的优化方式为TFO、DRE和LZ。
[Sysname-waaspolicy-waas_global-AFS] optimize tfo dre lz
# 配置WAAS策略类PKT的优化方式为packet-dup。
[Sysname-waaspolicy-waas_global] class PKT
[Sysname-waaspolicy-waas_global-PKT] optimize packet-dup
·     class
·     passthrough
·     waas policy
·     waas tfo optimize dre
·     waas tfo optimize lz
packet-dup reorder timeout命令用来配置包复制报文保序去重的超时时间。
undo packet-dup reorder timeout命令用来恢复缺省情况。
packet-dup reorder timeout timeout
包复制报文保序去重的超时时间为100ms。
WAAS策略类动作视图
timeout:保序去重的超时时间,单位ms,取值范围1~65535。
开启了包复制功能后,发送端会根据报文发送顺序对报文编排序号(例如1、2……n)并同时将报文复制一份到复制路径中传输。接收端收到报文后,会丢弃重复的报文并根据序号对报文重新排序,再进行转发。若出现较小序号的报文未接收到的情况,接收端会缓存已收到的报文,待较小序号的报文到达后再按照序号依次发送;如果接收端在报文保序去重的超时时间内未收到较小序号的报文,则接收端会直接发送缓存的数据包。
# 配置WAAS策略类AFS的包复制报文保序去重的超时时间。
[Sysname-waaspolicy-waas_global-AFS] packet-dup reorder timeout 100
packet-dup rir enable命令用来开启包复制路径智能选路功能。
undo packet-dup rir enable命令用来关闭包复制路径智能选路功能。
包复制路径智能选路功能处于关闭状态。
WAAS策略类动作视图
开启本功能后,设备在进行包复制时,会根据链路优先级、链路质量和链路带宽等因素,智能选择合适的路径作为复制报文的传输路径。
本功能需要在设备上开启智能选路功能才能生效,有关智能选路的相关介绍,请参见“三层技术-IP路由配置指导”中的“智能选路配置”。
设备支持智能选路和静态指定两种方式指定复制报文的传输路径,选路规则如下:
·     如果设备进行包复制时,发现同时存在智能选路的路径和静态指定路径,则优先使用智能选路方式确定的路径。
·     如果设备进行包复制时,发现既不存在智能选路的路径也不存在静态指定的路径,则选择路由表中与原始路径等价的转发路径中的第一条。
# 开启WAAS策略类AFS的包复制路径智能选路功能。
[Sysname-waaspolicy-waas_global-AFS] packet-dup rir enable
·     optimize
·     rir sdwan(三层技术-IP路由命令参考/智能选路命令)
1.1.24  passthrough
passthrough命令用来配置WAAS类的直接旁路动作。
undo passthrough命令用来恢复缺省情况。
passthrough
undo passthrough
未配置直接旁路动作。
WAAS策略类动作视图
直接旁路动作就是对匹配WAAS类的报文流量不进行任何优化处理,直接转发。
本命令与optimize命令二者只能选其一,如果同时配置了这两条命令,则后配置的生效。
# 配置WAAS策略类AFS的优化方式为直接旁路。
[Sysname-waaspolicy-waas_global-AFS] passthrough
·     class
·     optimize
·     waas policy
reset waas cache dre命令用来清除DRE的数据字典。
reset waas cache dre [ peer peer-id ]
peer peer-id:清除与指定对端设备相关的DRE数据字典,peer-id表示设备的桥MAC地址,形式为H-H-H。如果未指定本参数,则清除与所有对端设备相关的DRE的数据字典。
# 清除对端设备为0789-445d-effa的DRE数据字典。
<Sysname> reset waas cache dre peer 0789-445d-effa
·     display waas statistics dre
reset waas statistics dre命令用来清除DRE统计信息。
reset waas statistics dre [ peer peer-id ]
peer peer-id:清除指定与对端设备相关的DRE统计信息,peer-id表示对端设备的桥MAC地址,形式为H-H-H。如果未指定本参数,则清除与所有对端设备相关的DRE的统计信息。
# 清除设备上所有DRE的统计信息。
<Sysname> reset waas statistics dre
reset waas statistics fec命令用来清除FEC的报文统计信息。
# 清除设备上所有FEC的报文统计信息。
<Sysname> reset waas statistics fec
·     display waas statistics fec
reset waas statistics load-balance命令用来清除负载分担的报文统计信息。
reset waas statistics load-balance { ipv4 | ipv6 }
ipv4清除IPv4报文统计信息。
ipv6清除IPv6报文统计信息。
仅逐包模式下的负载分担报文支持通过本命令清除经过保序处理后的报文统计信息。
# 清除负载分担的IPv4报文统计信息。
<Sysname> reset waas statistics load-balance ipv4
·     display waas statistics load-balance
reset waas statistics lz命令用来清除LZ统计信息。
reset waas statistics lz [ peer peer-id ]
peer peer-id:清除指定与对端设备相关的LZ统计信息,peer-id表示对端设备的桥MAC地址,形式为H-H-H。如果未指定本参数,则清除与所有对端设备相关的LZ的统计信息。
# 清除设备上所有LZ的统计信息。
<Sysname> reset waas statistics lz
·     display waas statistics lz
reset waas statistics packet-dup命令用来清除包复制的报文统计信息。
reset waas statistics packet-dup { ipv4 | ipv6 }
ipv4清除IPv4包复制的报文统计信息。
ipv6清除IPv6包复制的报文统计信息。
# 清除IPv4包复制的报文统计信息。
<Sysname> reset waas statistics packet-dup ipv4
·     display waas statistics packet-dup
reset waas statistics tcp compress命令用来清除TCP数据报文压缩统计信息。
# 清除TCP数据报文压缩统计信息。
<Sysname> reset waas statistics tcp compress
·     display waas statistics tcp compress
reset waas statistics udp compress命令用来清除UDP报文压缩统计信息。
# 清除UDP报文压缩统计信息。
<Sysname> reset waas statistics udp compress
·     display waas statistics udp compress
reset waas tfo auto-discovery blacklist命令用来清除所有的黑名单表项。
# 清除所有的黑名单表项。
<Sysname> reset waas tfo auto-discovery blacklist
·     display waas tfo auto-discovery blacklist
waas apply policy命令用来在接口上应用WAAS策略。
undo waas apply policy命令用来恢复缺省情况。
waas apply policy [ policy-name ]
接口上未应用任何WAAS策略。
policy-name:指定WAAS策略的名称,为1~63个字符的字符串,不区分大小写,且该策略必须存在。如果不指定本参数,则在接口上应用预定义策略waas_default。
在同一台设备上连接广域网的接口上应用WAAS策略,连接局域网的接口上不应用WAAS策略。对从广域网侧发送或接收的报文流量会与广域网接口所引用的策略进行匹配。但如果指定流量经过设备的入接口和出接口都连接广域网,则不对报文进行优化。
为了保证流量的优化效果,当全局逻辑接口(如三层聚合接口、VLAN接口等)作为广域网侧的接口并跨板时,需要在逻辑接口视图下,使用service命令指定全局逻辑接口中的任意成员接口所在的单板或成员设备转发当前逻辑接口流量。
# 在接口GigabitEthernet2/0/1上应用WAAS策略global_policy。
[Sysname-GigabitEthernet2/0/1] waas apply policy global_policy
·     display waas status
·     waas policy
waas asymmetric命令用来配置WAAS工作在非对称组网模式。
undo waas asymmetric命令用来恢复缺省情况。
waas asymmetric
WAAS工作在对称组网模式。
若报文的收发均位于设备的同一个接口,则称为对称组网,否则为非对称组网。在非对称组网环境中需要配置WAAS非对称组网模式。
对于使用逻辑接口(包括聚合接口和隧道接口等)的组网,系统默认这类组网为非对称组网,必须配置本命令WAAS配置才能生效。
# 配置WAAS工作在非对称组网模式。
[Sysname] waas asymmetric
1.1.36  waas class
waas class命令用来创建WAAS类,并进入WAAS类视图。
undo waas class命令用来删除指定的WAAS类。
waas class class-name
undo waas class class-name
不存在WAAS类。
如果指定的类不存在,创建该类并进入其视图,否则直接进入其视图。如果创建的class未配置任何match规则,则该类不参与所属策略对报文流量的匹配。
建议用户通过本命令进入WAAS预定义类视图,修改预定义类配置。(预定义类参见表1-14
# 创建WAAS类waas_global,并进入其视图。
[Sysname] waas class waas_global
[Sysname-waasclass-waas_global]
·     class
waas config remove-all命令用来删除WAAS所有配置。
通过本命令删除WAAS特性的所有配置数据和运行数据,并使WAAS进程退出。
# 删除WAAS所有配置。
[Sysname] waas config remove-all
The command will clear all the WAAS configuration. Continue? [Y/N]:y
waas config restore-default命令用来创建WAAS的预定义策略配置。
应用场景
设备缺省未定制WAAS预定义配置时,WAAS进程启动后,配置本命令可以在设备中创建预定义配置,设备中会自动生成预定义类和WAAS预定义策略waas_default。(预定义类参见表1-14
WAAS预定义配置可以手动修改。当用户在预定义类视图或WAAS预定义策略视图下对预定义配置进行修改后,可以配置本命令将WAAS预定义配置还原成缺省状态。
注意事项
配置本命令前,需要先配置WAAS相关命令启动WAAS进程,例如waas class命令,否则配置失败。
配置本命令时,需保证所有接口未应用任何策略,否则恢复失败。
# 还原或创建WAAS预定义配置。
[Sysname] waas config restore-default
The command will restore or add the predefined WAAS policy. Continue? [Y/N]:y
·     waas class
waas dre cache aging命令用来配置WAAS数据字典表项的老化时间。
undo waas dre cache aging命令用来恢复缺省情况。
waas dre cache aging minutes
WAAS数据字典表项不老化,表项达到最大数量后,后续创建的新表项会覆盖最早创建的表项。
minutes:表项的老化时间,取值范围为10~60,单位为分钟。
配置了老化时间之后,设备会循环遍历所有的WAAS数据字典表项,超过老化时间的表项将会被删除。WAAS数据字典表项数量到达最大后,不再新建表项。
设备遍历一次WAAS数据字典表项的时间与当前设备上表项数量有关,请以设备的实际情况为准。
使能WAAS功能的两端,应配置相同的空闲老化时间。
# 配置WAAS表项老化时间为10分钟。
[Sysname] waas dre cache aging 10
waas dre offset-step命令用来配置WAAS匹配偏移步进级别。
undo waas dre offset-step命令用来恢复缺省情况。
waas dre offset-step { general | fast | fastest | normal }
WAAS匹配偏移步进为normal级别。
general:WAAS DRE匹配过程中一般偏移步进级别。
fast:WAAS DRE匹配过程中较快偏移步进级别。
fastest:WAAS DRE匹配过程中最快偏移步进级别。
normal:WAAS DRE匹配过程中正常偏移步进级别。
本命令配置的步进级别由高到低为:fastestfastgeneralnormal,配置的WAAS匹配偏移步进级别越高,匹配精度就越低。请根据链路的传输速率配置WAAS匹配偏移步进级别,建议在高速链路上配置高级别偏移步进,提高WAAS匹配的效率;在低速链路上配置低级别偏移步进,确保WAAS匹配的精度。
# 配置WAAS匹配偏移步进级别为fast。
[Sysname] waas dre offset-step fast
waas packet-dup sdwan static-path命令用来配置SDWAN组网下静态包复制路径。
undo waas packet-dup sdwan static-path命令用来删除SDWAN组网下静态包复制路径。
waas packet-dup sdwan static-path { destination-ip dest-ipv4-address { dest-mask-length | dest-mask } | destination-ipv6 dest-ipv6-address dest-prefix-length } [ vpn-instance vpn-instance-name ] interface interface-type interface-number peer-site-id peer-site-id peer-device-id peer-device-id peer-interface-id peer-interface-id [ priority priority ]
undo waas packet-dup sdwan static-path [ { destination-ip dest-ipv4-address { dest-mask-length | dest-mask } | destination-ipv6 dest-ipv6-address dest-prefix-length } [ vpn-instance vpn-instance-name ] [ interface interface-type interface-number ] [ peer-site-id peer-site-id peer-device-id peer-device-id peer-interface-id peer-interface-id ] [ priority priority ] ]
不存在静态包复制路径。
destination-ip dest-ip-address:指定匹配静态路径的报文目的IPv4地址,dest-ip-address表示目的IPv4地址,为点分十进制格式。
dest-mask-length:目的IPv4地址的掩码长度,取值范围0~32。
dest-mask:目的IPv4地址的掩码,点分十进制格式。
destination-ipv6 dest-ipv6-address:指定匹配静态路径的报文目的IPv6地址,dest-ipv6-address表示目的IPv6地址。
dest-prefix-length:目的IPv6地址的前缀长度,取值范围为1~128。
vpn-instance vpn-instance-name:指定静态路径目的端所属的VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示静态路径目的端未配置VPN实例。
interface interface-type interface-number:指定本端的SDWAN隧道接口,interface-type表示接口类型,interface-number表示接口编号。仅支持指定Tunnel类型的接口。
peer-site-id peer-site-id:指定对端设备的站点ID。peer-site-id表示对端设备建立SDWAN隧道时配置的站点ID,取值范围为1~65535。
peer-device-id peer-device-id:指定对端设备的设备ID。peer-device-id表示对端设备建立SDWAN隧道时配置的设备ID,取值范围1~255。
peer-interface-id peer-interface-id:指定对端的SDWAN隧道接口ID,peer-interface-id表示对端建立SDWAN隧道时配置的SDWAN隧道接口ID,取值范围为1~255。
priority priority:指定静态路径的优先级,缺省为60。priority表示静态路径的优先级,取值范围为1~255,数值越大,优先级越高。
设备在SDWAN组网下进行WAAS包复制时,通过本命令可以为复制的数据包静态指定一条SDWAN隧道作为的转发路径。指定的SDWAN隧道必须已经存在,设备上SDWAN隧道可以通过display sdwan tte connection命令查看。
若同一条SDWAN隧道被多次配置为复制路径,则最后一次配置生效。若同一个目的地址配置了多条静态路径,有且仅一条静态路径会被选择为复制路径(由设备内部算法决定)。
设备支持同时静态指定和智能选路两种方式指定复制报文的传输路径,选路规则如下:
·     如果设备进行WAAS包复制时,发现同时存在静态指定的路径和智能选路的路径,则优先使用智能选路方式确定的路径。
·     如果设备进行WAAS包复制时,发现既不存在静态指定的路径也不存在智能选路的路径,则选择路由表中与原始路径等价的转发路径中的第一条。
配置undo waas packet-dup sdwan static-path命令时,如果不指定任何参数,则表示删除所有静态包复制路径。
本功能仅SDWAN组网支持。
# 配置SDWAN组网下静态WAAS包复制路径。
[Sysname] waas packet-dup sdwan static-path destination-ip 200.1.1.0 24 vpn-instance vpn-1 local tunnel 1 peer-site-id 2 peer-device-id 3 peer-interface-id 5 priority 50
·     display sdwan tte connection(SDWAN命令参考/SDWAN命令)
1.1.42  waas policy
waas policy命令用来创建WAAS策略,并进入WAAS策略视图。如果指定的WAAS策略已经存在,则直接进入WAAS策略视图。
undo waas policy命令用来删除指定的WAAS策略。
waas policy policy-name
undo waas policy policy-name
不存在WAAS策略。
删除指定策略时,如果该策略应用于接口,则应先取消策略在接口上的应用再删除,否则删除失败。
建议用户通过此命令进入预定义策略的视图,采用修改预定义策略的方式完成策略配置。预定义名称为waas_default,默认引用所有的预定义类。
表1-14 预定义策略
预定义类
优化方式
源端口号
目的端口号
AFS
LZ+TFO+DRE
7000-7009
Altiris-CarbonCopy
Pass-through
1680
Amanda
TFO
10080
AOL
Pass-through
5190-5193
Apple-AFP
LZ+TFO+DRE
548
Apple-iChat
Pass-through
5297、5298
Apple-NetAssistant
Pass-through
3283
AppSocket
LZ+TFO+DRE
9100
BackupExpress
TFO
6123
Basic-TCP-services
Pass-through
1-19
BFTP
LZ+TFO+DRE
152
BGP
LZ+TFO+DRE
179
BitTorrent
Pass-through
6881–6889, 6969
BMC-Patrol
Pass-through
6161、6162、6767、6768, 8160、8161、10128
Borland-Interbase
LZ+TFO+DRE
3050
CIFS
LZ+TFO+DRE
139、445
CIFS-non-wafs
LZ+TFO+DRE
139、445
Cisco-CallManager
Pass-through
2443、2748
Cisco-NetFlow
Pass-through
7544、7545
Citrix-ICA
LZ+TFO+DRE
1494、2598
Clearcase
LZ+TFO+DRE
371
CommVault
TFO
8400-8403
Connected-DataProtector
TFO
16384
ControlIT
TFO
799
CU-SeeMe
Pass-through
7640、7642、7648、7649
CVS
LZ+TFO+DRE
2401
Danware-NetOp
TFO
6502
DNS
Pass-through
53
Documentum
LZ+TFO+DRE
1489
Double-Take
LZ+TFO+DRE
1100、1105
eDonkey
Pass-through
4661、4662
EMC-Celerra-Replicator
LZ+TFO+DRE
8888
EMC-SRDFA-IP
LZ+TFO+DRE
1748
ezMeeting
Pass-through
10101-10103、26260-26261
FCIP
LZ+TFO+DRE
3225
Filenet
LZ+TFO+DRE
32768-32774
FTP
Pass-through
21
FTP-Data
LZ+TFO+DRE
20
FTPS
TFO
990
FTPS-Data
Pass-through
989
GnomeMeeting
Pass-through
30000-30010
Gnutella
Pass-through
6346–6349、6355、5634
Grouper
Pass-through
8038
HotLine
Pass-through
5500–5503
HP-OpenMail
LZ+TFO+DRE
5729、5755、5757、5766, 5767、5768
HP-OpenView
Pass-through
7426–7431、7501、7510
HP-Radia
LZ+TFO+DRE
3460、3461、3464、3466
HTTP
LZ+TFO+DRE
80、3128、8000、8001、8080
HTTPS
TFO
443
HTTPS
TFO
443
IBM-DB2
LZ+TFO+DRE
523
IBM-NetView
Pass-through
729–731
IBM-Tivoli
LZ+TFO+DRE
94、627、1580、1581、1965
IBM-TSM
TFO+LZ+DRE
1500-1502
iFCP
LZ+TFO+DRE
3420
Intel-Proshare
Pass-through
5713-5717
Internet-Mail
LZ+TFO+DRE
25、110、143、220
Internet-Mail-secure
TFO
465、993、995
InterSystems-Cache
LZ+TFO+DRE
1972
IPP
LZ+TFO+DRE
631
IRC
Pass-through
531、6660-6669
iSCSI
LZ+TFO+DRE
3260
iSNS
Pass-through
3205
Jabber
Pass-through
5222、5269
Kazaa
Pass-through
1214
Kerberos
Pass-through
88、464、543、544、749、754、888、2053
L2TP
TFO
1701
LANDesk
LZ+TFO+DRE
9535、9593–9595
Laplink-Host
TFO
1547
Laplink-PCSync
TFO
8444
Laplink-PCSync-secure
TFO
8443
Laplink-ShareDirect
Pass-through
2705
LDAP
LZ+TFO+DRE
389、8404
LDAP-Global-Catalog
LZ+TFO+DRE
3268
LDAP-Global-Catalog-Secure
Pass-through
3269
LDAP-secure
Pass-through
636
Legato-NetWorker
TFO
7937、7938、, 7939
Legato-RepliStor
TFO
7144、7145
Liquid-Audio
LZ+TFO+DRE
18888
Lotus-Notes
LZ+TFO+DRE
1352
Lotus-Sametime-Connect
Pass-through
1533
MDaemon
LZ+TFO+DRE
3000、3001
MS-Chat
Pass-through
6665、6667
MS-Content-Replication-Service
TFO
560、507
MS-Message-Queuing
LZ+TFO+DRE
1801、2101、2103、2105
MS-NetMeeting
Pass-through
522、1503、1731
MS-NetShow
LZ+TFO+DRE
1755
MSN-Messenger
Pass-through
1863、6891-6900
MS-SQL
LZ+TFO+DRE
1433
MS-Terminal-Services
TFO
3389
MySQL
LZ+TFO+DRE
3306
Napster
Pass-through
6666、6677、6700、6688, 7777、8875
Netapp-SnapMirror
LZ+TFO+DRE
10565–10569
NetIQ
Pass-through
2220、2735、10113–10116
Netopia-netOctopus
Pass-through
1917、1921
Netopia-Timbuktu
TFO
407、1417–1420
NFS
LZ+TFO+DRE
2049
NNTP
LZ+TFO+DRE
119
NNTP-secure
TFO
563
Novell-Groupwise
LZ+TFO+DRE
1099、1677、2800、3800, 7100、7101、7180、7181、7205、9850
Novell-NetWare
LZ+TFO+DRE
524
Novell-ZenWorks
LZ+TFO+DRE
517、1761–1763、2037, 2544、8039
NTP
Pass-through
123
OpenVPN
TFO
1194
Oracle
LZ+TFO+DRE
66、1521、1525
Other-Secure
Pass-through
261、44,、684、695、994、2252、2478、2479、2482、2484、2679、2762、2998、3077、3078、3183、3191、3220、3410、3424、3471、3496,3509、3529、3539、3660、3661、3747、3864、3885、3896、3897、3995、4031、5007、5989、5990、7674、9802、12109
PCAnywhere
TFO
73、5631、5632、65301
PCMail-Server
LZ+TFO+DRE
158
PDMWorks
LZ+TFO+DRE
30000、40000
Pervasive-SQL
LZ+TFO+DRE
1583
PostgreSQL
LZ+TFO+DRE
5432
PPTP
TFO
1723
ProjectWise-FileTransfer
LZ+TFO+DRE
5800
QMTP
LZ+TFO+DRE
209
Qnext
Pass-through
44、5555
RAdmin
TFO
4899
Remote-Anything
TFO
3999、4000
Remote-Replication-Agent
TFO
5678
Rsync
TFO
873
RTSP
LZ+TFO+DRE
554、8554
SAP
LZ+TFO+DRE
3200-3219、3221-3224、3226-3267、3270-3282、3284-3305、3307-3388、3390-3399、3600-3659、3662-3699
SASL
Pass-through
3659
Scalable-SQL
LZ+TFO+DRE
3352
Service-Location
Pass-through
427
Siebel
LZ+TFO+DRE
2320、2321、8448
Simple-FTP
LZ+TFO+DRE
115
SIP-secure
Pass-through
5061
SOAP
LZ+TFO+DRE
7627
SoulSeek
Pass-through
2234、5534
SQL-Service
LZ+TFO+DRE
156
SSH
TFO
22
SSL-Shell
Pass-through
614
Sun-RPC
Pass-through
111
SUN-Xprint
LZ+TFO+DRE
8100
Sybase-SQL
LZ+TFO+DRE
1498、2439、2638、3968
Symantec-AntiVirus
LZ+TFO+DRE
2847、2848、2967、2968, 38037, 38292
TACACS
Pass-through
49
Telnet
Pass-through
23、107、513
Telnets
Pass-through
992
TFTPS
TFO
3713
UniSQL
LZ+TFO+DRE
1978、1979
Unix-Printing
LZ+TFO+DRE
170, 515
Unix-Remote-Execution
Pass-through
512、514
VDOLive
LZ+TFO+DRE
7000
Veritas-BackupExec
TFO
1125、3527、6101、6102、6106
Veritas-NetBackup
TFO
13720、13721、13782、13785
VMware-VMConsole
TFO
902
VNC
TFO
5801–5809、6900–6909
VocalTec
Pass-through
1490、6670、22555、25793
VoIP-Control
Pass-through
1300、1718-1720, 2000-2002,2428, 5060,11000-11999
WAAS-FlowMonitor
TFO
7878
WASTE
Pass-through
1337
WBEM
Pass-through
5987、5988
WinMX
Pass-through
6699
WINS
Pass-through
42、137、1512
X400
LZ+TFO+DRE
102
XWindows
TFO
6000–6063
Yahoo-Messenger
Pass-through
5000、5001、5050、5100
# 进入WAAS预定义策略视图。
[Sysname] waas policy waas_default
[Sysname-waaspolicy-waas_default]
1.1.43  waas tcp
waas tcp命令用来开启TCP数据报文的LZ压缩或解压缩功能。
undo waas tcp命令用来关闭TCP数据报文的LZ压缩或解压缩功能。
waas tcp { compress [ max max-number ] | decompress }
undo waas tcp
TCP数据报文的LZ压缩和解压缩功能处于关闭状态。
compress:开启TCP数据报文的LZ压缩功能。
max max-number:设置压缩的TCP数据报文的个数,取值范围为2~20,缺省值为5,即每收到5个报文进行一次压缩。
decompress:开启TCP数据报文的LZ解压缩功能。
本命令只对waas tcp destination命令指定的目的地址和目的端口的TCP数据报文进行LZ压缩或解压缩处理。
请在上游设备开启TCP数据报文的压缩功能,下游设备开启TCP数据报文的解压缩功能,报文在上游设备进行LZ压缩后转发到下游设备,下游设备对报文进行LZ解压缩,还原成原始报文继续转发。
设备不能同时开启LZ压缩功能和解压缩功能,即对于一对源/目地址,只能对单向流量进行LZ压缩处理。
# 开启TCP数据报文LZ压缩功能,并设置报文的最大压缩个数为8。
[Sysname] waas tcp compress max 8
·     waas tcp destination
1.1.44  waas tcp acl
waas tcp acl命令用来配置TCP数据报文的ACL匹配规则。
undo waas tcp acl命令用来恢复缺省情况。
waas tcp acl { acl-number | name acl-name }
undo waas tcp acl
未配置TCP数据报文的ACL匹配规则。
acl-number:访问控制列表号,取值范围为2000~3999。其中:
·     基本ACL,acl-number取值范围为2000~2999;
·     高级ACL,acl-number取值范围为3000~3999。
name acl-name:指定ACL的名称。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。只有指定基本ACL或高级ACL的acl-name才生效。
开启TCP数据报文LZ压缩或解压缩功能之后,只有与本命令配置的ACL规则相匹配的TCP报文会被LZ压缩或解压缩。
配置TCP数据报文的ACL匹配规则后,waas tcp destination命令配置的目的地址和目的端口号均不生效。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则TCP数据报文LZ压缩或解压缩功能对所有报文均不会生效。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则表示该规则仅对VPN报文有效;若规则未指定vpn-instance参数,则表示该规则仅对公网报文有效。
# 配置满足ACL 2001的TCP数据报文被匹配。
[Sysname] waas tcp acl 2001
·     waas tcp
waas tcp destination命令用来配置需要进行LZ压缩或解压缩的TCP数据报文的目的地址和目的端口号。
undo waas tcp destination命令用来删除已经配置的需要LZ压缩或解压缩的TCP数据报文的目的地址和目的端口号。
waas tcp destination { ip-address port port-number | object-group ip-object-group-name port object-group port-object-group-name }
undo waas tcp destination { ip-address port port-number | object-group }
未配置需要进行LZ压缩或解压缩的TCP数据报文的目的地址和目的端口号。
ip-address:需要进行LZ压缩或解压缩的TCP数据报文的目的IP地址。
port port-number:需要进行LZ压缩或解压缩的TCP数据报文的目的端口,port-number表示目的端口号,取值范围为1~65535。
port object-group port-object-group-name:需要进行LZ压缩或解压缩的TCP数据报文的目的端口。port-object-group-name:指定匹配规则引用的端口对象组的名称,为1~63个字符的字符串,不区分大小写。
开启TCP数据报文的LZ压缩或解压缩功能之后,只有与本命令配置的目的IP地址和目的端口相同的报文会被LZ压缩或解压缩。
重复执行本命令,可以指定多个需要进行LZ压缩或解压缩的TCP数据报文的目的地址和目的端口号。
优先匹配对象组。
# 配置对目的地址为172.16.105.50,目的端口为8000的TCP数据报文进行LZ压缩。
[Sysname] waas tcp destination 172.16.105.50 port 8000
# 配置对匹配源地址引用对象组group1,目的地址引用对象组group2的TCP数据报文进行LZ压缩。
[Sysname] waas tcp destination ip-address object-group group1 port object-group group2
·     waas tcp
waas tfo auto-discovery blacklist enable命令用来开启自动发现黑名单功能。
undo waas tfo auto-discovery blacklist enable命令用来关闭自动发现黑名单功能。
自动发现黑名单功能处于关闭状态。
当本端设备配置了WAAS策略并应用于接口时,如果本端设备不能通过此接口与对端设备建立优化的TCP连接,那么系统自动将请求的服务器接口的IP地址和端口号加入黑名单,对匹配黑名单的流量不做任何优化。
在建立TCP连接的三次握手过程中,本端发送携带特定TCP选项的请求报文后,如果发生下列情况,则认为连接建立失败:
·     在指定时间内未作出有效应答。
·     对端设备关闭了TCP连接。
# 开启WAAS自动发现黑名单功能。
[Sysname] waas tfo auto-discovery blacklist enable
waas tfo auto-discovery blacklist hold-time命令用来配置黑名单表项的老化时间。
undo waas tfo auto-discovery blacklist hold-time命令用来恢复缺省情况。
waas tfo auto-discovery blacklist hold-time minutes
黑名单表项的老化时间为5分钟。
minutes:指定黑名单表项的老化时间,取值范围为1~10080,单位为分钟。
黑名单表项具有一定的生存时间,超出老化时间,黑名单表项被系统自动删除,当有新连接接入时,设备通过发现黑名单功能构建新的黑名单表项。
# 配置WAAS黑名单表项的老化时间为30分钟。
[Sysname] waas tfo auto-discovery blacklist hold-time 30
waas tfo base-congestion-window命令用来配置超时重传时慢启动的初始拥塞窗口大小。
undo waas tfo base-congestion-window命令用来恢复缺省情况。
waas tfo base-congestion-window segments
初始拥塞窗口为2。
segments超时重传时慢启动的初始拥塞窗口大小,取值范围为1~10,单位为TCP分段。
拥塞窗口的大小取决于网络的拥塞程度和发送速度,并且动态的在变化。设置合理的慢启动初始拥塞窗口,当拥塞发生后,能够较快的恢复到网络最大传输能力。
# 配置超时重传时慢启动的初始拥塞窗口为3。
[Sysname] waas tfo base-congestion-window 3
waas tfo congestion-method命令用来配置WAAS在WAN侧链路所使用的TCP拥塞控制算法。
undo waas tfo congestion-method命令用来恢复缺省情况。
waas tfo congestion-method { bbrv1 | bbrv2 | bic | reno }
WAAS在WAN侧链路所使用的TCP拥塞控制算法为BIC算法。
bbrv1:WAAS在WAN侧链路所使用的TCP拥塞控制算法为BBRv1算法。
bbrv2:WAAS在WAN侧链路所使用的TCP拥塞控制算法为BBRv2算法。
bic:WAAS在WAN侧链路所使用的TCP拥塞控制算法为BIC算法。
reno:WAAS在WAN侧链路所使用的TCP拥塞控制算法为Reno算法。
不同TCP拥塞控制算法的特点如下:
·     Reno:推荐用于低延时、低带宽的场景,因为在高延时、高带宽的场景中,传输速度往往要经过很长时间才能达到最大,会降低带宽的利用率。Reno将收到ACK作为拥塞窗口增长的依据,是一种早期的TCP拥塞控制算法。
·     BIC:推荐用于高带宽、低丢包率的场景。BIC将丢包作为拥塞信号,优点是只要没有出现丢包,就不会主动降低发送速度,可以最大程度的利用网络剩余带宽,提高吞吐量;缺点是传输时延较高,而且会将传输错误丢包认为是拥塞丢包,从而减小拥塞窗口,降低发送速率。
·     BBR:推荐用于高带宽、高时延、存在一定丢包率的场景。BBR不将丢包作为拥塞信号,所以在丢包率较高的场景下,BBR可以有效降低传输时延,并保证较高的吞吐量。BBRv2降低了抢占性,提高了不同算法共存时的公平性。
# 配置WAAS在WAN侧链路所使用的TCP拥塞控制算法为Reno算法。
[Sysname] waas tfo congestion-method reno
waas tfo connect-limit命令用来配置TFO的最大并发连接数。
undo waas tfo connect-limit命令用来恢复缺省情况。
waas tfo connect-limit limit
TFO的最大并发连接数为10000条。
limit:TFO的最大并发连接数,取值范围为1000~4294967295,单位为条。
当TFO的连接数超过配置的值后,后续流量不再进行WAAS优化处理。因为TCP流进行WAAS优化需要消耗内存资源,需要根据内存情况配置TFO的最大并发连接数。
使能WAAS功能的两端,应配置相同的最大连接数。
# 配置TFO的最大并发连接数为20000条。
[Sysname] waas tfo connect-limit 20000
waas tfo connect-wait命令用来配置TFO建立TCP代理连接的最大等待时间。
undo waas tfo connect-wait命令用来恢复缺省情况。
waas tfo connect-wait seconds
未配置TFO建立TCP代理连接的最大等待时间。
seconds:TFO建立TCP代理连接的最大等待时间,取值范围为1~75,单位为秒。
应用场景
缺省情况下,TCP客户端和服务器建立TCP连接过程中,若对端未作出有效应答,客户端或服务器会在最大等待时间75s超时后,宣布建立TCP连接失败,WAAS设备作为TCP代理无法干预TCP连接的最大等待时间。配置本功能后,WAAS设备作为TCP代理可以通过配置较小的TCP代理最大等待时间,来缩短客户端和服务器等待时间。
工作机制
(1)     本端设备作为TFO优化的TCP代理,在与对端设备建立TFO优化的TCP连接时,如果在TCP代理连接的最大等待时间内未收到对端的有效应答,则停止建立连接。
(2)     本端设备停止建立TCP连接后,若设备上配置了waas tfo auto-discovery blacklist enable命令(自动发现黑名单功能),会将本端设备用于建立TCP连接的IP地址和端口加入到黑名单。
# 配置TFO建立TCP代理连接的最大等待时间为2秒。
[Sysname] waas tfo connect-wait 2
waas tfo keepalive命令用来开启TFO的保活功能。
undo waas tfo keepalive命令用来关闭TFO的保活功能。
waas tfo keepalive
TFO的保活功能处于开启状态。
开启TFO的保活功能后,系统启动保活定时器。保活定时器的超时时间为2小时,定时器超时后如果通信双方仍没有数据传输,则向对端设备发送保活报文,使连接不断开。
# 关闭TFO的保活功能。
[Sysname] undo waas tfo keepalive
waas tfo optimize dre命令用来开启WAAS消除数据冗余功能。
undo waas tfo optimize dre命令用来关闭WAAS消除数据冗余功能。
WAAS消除数据冗余功能处于开启状态。
只有WAAS消除数据冗余功能处于开启状态时,WAAS策略下所配置的消除数据冗余优化方式才会生效。
# 关闭WAAS消除数据冗余功能。
[Sysname] undo waas tfo optimize dre
waas tfo optimize lz命令用来开启WAAS数据压缩功能。
undo waas tfo optimize lz命令用来关闭WAAS数据压缩功能。
WAAS数据压缩功能处于开启状态。
只有WAAS数据压缩功能处于开启状态时,WAAS策略下所配置的数据压缩优化方式才会生效。
# 关闭WAAS数据压缩功能。
[Sysname] undo waas tfo optimize lz
waas tfo receive-buffer命令用来配置TFO的接收缓冲区大小。
undo waas tfo receive-buffer命令用来恢复缺省情况。
waas tfo receive-buffer buffer-size
TFO的接收缓冲区为64KB。
buffer-sizeTFO的接收缓冲区大小,取值范围为32~16384,单位为KB。
用户可以通过调整接收缓冲区的大小来影响线路的吞吐量。
# 调整TFO的接收缓冲区为1024KB。
[Sysname] waas tfo receive-buffer 1024
1.1.56  waas udp
waas udp命令用来开启UDP报文LZ压缩或解压缩功能。
undo waas udp命令用来关闭UDP报文LZ压缩或解压缩功能。
waas udp { compress [ max max-number ] | decompress }
undo waas udp
UDP报文LZ压缩和解压缩功能处于关闭状态。
compress:开启UDP报文LZ压缩功能。
max max-number:设置UDP报文最大压缩个数,取值范围为2~20,缺省值为5,即每收到5个报文进行一次压缩。
decompress:开启UDP报文LZ解压缩功能。
本命令只对waas udp destination命令指定的目的地址和目的端口的UDP报文进行LZ压缩或解压缩处理。
请在上游设备开启UDP报文LZ压缩功能,下游设备开启UDP报文LZ解压缩功能,报文在上游设备进行LZ压缩后转发到下游设备,下游设备对报文进行LZ解压缩,还原成原始报文继续转发。
# 开启UDP报文LZ压缩功能,并设置报文的最大压缩个数为10。
[Sysname] waas udp compress max 10
·     waas udp destination
1.1.57  waas udp acl
waas udp acl命令用来配置UDP数据报文的ACL匹配规则。
undo waas udp acl命令用来恢复缺省情况。
waas udp acl { acl-number | name acl-name }
undo waas udp acl
未配置UDP数据报文的ACL匹配规则。
开启UDP数据报文LZ压缩或解压缩功能之后,只有与本命令配置的ACL规则相匹配的UDP数据报文会被LZ压缩或解压缩。
配置UDP数据报文的ACL匹配规则后,waas udp destination命令配置的目的地址和目的端口号均不生效。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则UDP数据报文LZ压缩或解压缩功能对所有报文均不会生效。
# 配置满足ACL 2001的UDP数据报文被匹配。
[Sysname] waas udp acl 2001
·     waas udp
waas udp destination命令用来配置需要进行LZ压缩或解压缩的UDP报文的目的地址和目的端口号。
undo waas udp destination命令用来删除已经配置的需要LZ压缩或解压缩的UDP报文的目的地址和目的端口号。
waas udp destination { ip-address port port-number | object-group ip-object-group-name port object-group port-object-group-name }
undo waas udp destination { ip-address  port port-number | object-group }
未配置需要进行LZ压缩或解压缩的UDP报文目的地址和目的端口号。
ip-address:需要进行LZ压缩或解压缩UDP报文的目的IP地址。
port port-number:需要进行LZ压缩或解压缩UDP报文的目的端口,port-number表示目的端口号,取值范围为1~65535。
port object-group port-object-group-name:需要进行LZ压缩或解压缩的UDP数据报文的目的端口。port-object-group-name:指定匹配规则引用的端口对象组的名称,为1~63个字符的字符串,不区分大小写。
开启UDP报文LZ压缩或解压缩功能之后,只有与本命令配置的目的IP地址和目的端口相同的报文会被LZ压缩或解压缩。
重复执行本命令,可以指定多个需要进行LZ压缩或解压缩的UDP报文的目的地址和目的端口号。
优先匹配对象组。
# 配置对目的地址为172.16.105.48,目的端口为5000的UDP报文进行LZ压缩。
[Sysname] waas udp destination 172.16.105.48 port 5000
# 配置对匹配源地址引用对象组group1,目的地址引用对象组group2的UDP数据报文进行LZ压缩。
[Sysname] waas udp destination ip-address object-group group1 port object-group group2
·     waas udp
