01-PPP命令
本章节下载: 01-PPP命令 (1.04 MB)
1.1.4 display interface virtual-access
1.1.5 display interface virtual-template
1.1.8 display ppp compression iphc
1.1.9 display ppp packet statistics
1.1.10 interface virtual-template
1.1.11 ip address ppp-negotiate
1.1.18 ppp access-user log enable
1.1.19 ppp account-statistics enable
1.1.22 ppp authentication-mode
1.1.25 ppp compression iphc enable
1.1.26 ppp compression iphc rtp-connections
1.1.27 ppp compression iphc tcp-connections
1.1.32 ppp ipcp remote-address match
1.1.36 ppp modify-authinfo restart
1.1.42 remote address dhcp client-identifier
1.1.43 reset counters interface virtual-access
1.1.45 reset ppp compression iphc
1.1.46 reset ppp packet statistics
1.2.1 display interface mp-group
1.2.7 ppp mp fast-forward enable
1.2.9 ppp mp lfi delay-per-frag
1.2.10 ppp mp load-sharing mode strict-round-robin
1.2.12 ppp mp lfi size-per-frag
1.2.18 ppp mp sort-buffer-size
1.2.19 ppp mp timer lost-fragment
1.2.21 ppp mp virtual-template
1.2.22 reset counters interface mp-group
2.1.1 display pppoe-server packet statistics
2.1.2 display pppoe-server session packet
2.1.3 display pppoe-server session summary
2.1.4 display pppoe-server throttled-mac
2.1.5 display pppoe-server va-pool
2.1.7 pppoe-server access-delay
2.1.8 pppoe-server access-line-id bas-info
2.1.9 pppoe-server access-line-id circuit-id parse-mode
2.1.10 pppoe-server access-line-id circuit-id trans-format
2.1.11 pppoe-server access-line-id content
2.1.12 pppoe-server access-line-id remote-id trans-format
2.1.13 pppoe-server access-line-id trust
2.1.15 pppoe-server session-limit
2.1.16 pppoe-server session-limit per-mac
2.1.17 pppoe-server session-limit per-vlan
2.1.18 pppoe-server session-limit total
2.1.19 pppoe-server tag ac-name
2.1.20 pppoe-server tag ppp-max-payload
2.1.21 pppoe-server tag service-name
2.1.22 pppoe-server throttle per-mac
2.1.23 pppoe-server virtual-template va-pool
2.1.25 reset pppoe-server packet statistics
2.2.2 display pppoe-client session packet
2.2.3 display pppoe-client session summary
2.2.6 reset pppoe-client session packet
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
虚拟模板接口视图
MP-group接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbps。
接口的期望带宽会影响链路开销值,具体介绍请参见“三层技术-IP路由配置指导”中的“OSPF”、“OSPFv3”和“IS-IS”。
# 配置虚拟模板接口10的期望带宽为1000kbps。
[Sysname] interface virtual-template 10
[Sysname-Virtual-Template10] bandwidth 1000
# 配置接口MP-group2/0/0的期望带宽为1000kbps。
[Sysname] interface mp-group 2/0/0
[Sysname-MP-group2/0/0] bandwidth 1000
default命令用来恢复接口的缺省配置。
default
虚拟模板接口视图
MP-group接口视图
# 将虚拟模板接口10恢复为缺省配置。
[Sysname-Virtual-Template10] default
# 将接口MP-group2/0/0恢复为缺省配置。
[Sysname-MP-group2/0/0] default
description命令用来设置接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“该接口的接口名 Interface”,比如:Virtual-Template1 Interface、MP-group2/0/0 Interface。
虚拟模板接口视图
MP-group接口视图
text:接口描述信息,为1~255个字符的字符串,区分大小写。
# 配置虚拟模板接口10的描述信息为“virtual-interface”。
[Sysname-Virtual-Template10] description virtual-interface
# 配置接口MP-group2/0/0的描述信息为“mpgroup-interface”。
[Sysname-MP-group2/0/0] description mpgroup-interface
display interface virtual-access命令用来显示VA(Virtual Access,虚拟访问)接口的相关信息。
display interface [ virtual-access [ interface-number ] ] [ brief [ description | down ] ]
virtual-access [ interface-number ]:显示指定VA接口的信息。interface-number表示VA接口的编号,取值范围为已创建的VA接口的编号。如果不指定virtual-access,则显示除VA接口外设备支持的所有接口的相关信息。如果指定virtual-access,不指定interface-number,则显示所有VA接口的相关信息。指定virtual-access,则需要确保系统已经创建了VA接口。
description:用来显示用户配置的接口的全部描述信息。VA接口的描述信息不可配置,此参数无用。
# 查看接口VA1的运行状态和相关信息。
<Sysname> display interface virtual-access 1
Virtual-Access1
Current state: UP
Line protocol state: UP
Description: Virtual-Access1 Interface
Bandwidth: 1920kbps
Hold timer: 10 seconds,retry times: 5
Internet address: 122.1.1.1/24 (primary)
Link layer protocol: PPP
LCP: opened, MP: opened, IPCP: opened
Physical: MP, baudrate: 1920000 bps
Main interface: Virtual-Template1
Last link flapping: Never
Input: 2 packets, 24 bytes, 0 drops
Output: 2 packets, 24 bytes, 0 drops
# 显示VA1接口的概要信息。
<Sysname> display interface virtual-access 1 brief
Protocol: (s) - spoofing
VA1 DOWN DOWN --
# 显示当前物理状态为down的VA接口的信息以及down的原因。
<Sysname> display interface virtual-access brief down
Interface Link Cause
VA1 DOWN Not connected
表1-1 display interface virtual-access命令显示信息描述表
Current state |
接口当前的物理状态和管理状态,可能的取值及含义如下: · DOWN:表示该接口的管理状态为开启,但物理状态为关闭 · UP:该接口的管理状态和物理状态均为开启 |
Line protocol state |
接口的链路层协议状态。其值由链路层经过参数协商决定,取值为: · UP:表示数据链路层协议状态为开启 · DOWN:表示数据链路层协议状态为关闭 |
接口的描述信息 |
Bandwidth |
接口的期望带宽 |
Maximum transmission unit |
接口的MTU |
Hold timer |
当前接口发送keepalive报文的周期 |
retry times |
在多少个keepalive周期内没有收到keepalive报文的应答就拆除链路 |
Internet protocol processing: Disabled |
接口当前不能处理IP报文 |
Internet address: ip-address/mask-length (Type) |
接口IP地址。Type表示地址获取方式,取值如下: · Primary:手动配置的主地址 · Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息 · DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP” · BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP” · PPP-negotiated:PPP协商过程中由Server端分配的IP地址,详细介绍请参见“二层技术-广域网接入配置指导”中的“PPP” · Unnumbered:借用其他接口的IP地址 · MAD:成员设备上配置的MAD IP地址,详细介绍请参见“虚拟化技术配置指导”中的“IRF” · MTunnel:组播隧道接口的IP地址(采用的是MD源接口的IP地址),关于MD源接口的详细介绍请参见“IP组播配置指导”中的“组播VPN” Type的取值情况与接口类型有关,请以实际情况为准 |
Link layer protocol: PPP |
链路层封装的协议 |
LCP: opened, MP: opened, IPCP: opened |
表示PPP连接建立成功 |
Physical |
接口的物理类型 |
baudrate |
接口的波特率 |
Main interface |
VA接口关联的模板 |
Output queue - Urgent queuing: Size/Length/Discards 0/100/0 Output queue - Protocol queuing: Size/Length/Discards 0/500/0 Output queue - FIFO queuing: Size/Length/Discards 0/75/0 |
接口输出队列的类型: · 紧急发送队列的报文统计 · 协议发送队列的报文统计 · 先入先出发送队列的报文统计 |
Last link flapping |
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过) |
Last clearing of counters: Never |
最后一次清除接口统计信息的时间(Never表示未清除过接口的统计信息) |
Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec |
当前接口最近300秒内输入(input)和输出(output)报文的平均速率 |
Input: 2 packets, 24 bytes, 0 drops |
接口输入的报文总数(分别以包和字节为单位进行了统计),输入报文中丢弃的报文数 |
Output: 2 packets, 24 bytes, 0 drops |
接口输出的报文总数(分别以包和字节为单位进行了统计),输出报文中丢弃的报文数 |
Brief information on interfaces in route mode |
三层接口的概要信息 |
Link: ADM - administratively down; Stby - standby |
· 如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态 · 如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口 |
Protocol: (s) - spoofing |
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性 |
接口名称缩写 |
Link |
接口物理连接状态,取值可能为: · UP:表示接口物理上是连通的 · DOWN:表示接口物理上不通 |
Protocol |
接口数据链路层协议状态,取值可能为: · UP:表示接口的数据链路层是连通的 · DOWN:表示接口的数据链路层不通 · UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性 |
Primary IP |
接口主IP地址。当显示“--”时,表示接口下还未配置IP地址 |
接口的描述信息 |
Cause |
接口物理连接状态为down的原因,取值为:Not connected:表示没有物理连接(可能没有插网线或者网线故障) |
· reset counters interface virtual-access
display interface virtual-template命令用来显示虚拟模板接口的相关信息。
display interface [ virtual-template [ interface-number ] ] [ brief [ description | down ] ]
virtual-template [ interface-number ]:显示指定虚拟模板接口的信息。interface-number表示虚拟模板接口的编号,取值范围为已创建的虚拟模板接口的编号。如果不指定virtual-template,则显示除VA接口外设备支持的所有接口的相关信息;如果指定virtual-template,不指定interface-number,则显示所有已创建的虚拟模板接口的相关信息。
# 查看虚拟模板接口1的运行状态和相关信息。
<Sysname> display interface virtual-template 1
Virtual-Template1
Current state: DOWN
Line protocol state: DOWN
Description: Virtual-Template1 Interface
Bandwidth: 100000kbps
Internet address: 192.168.1.200/24 (primary)
LCP: initial
Physical: None, baudrate: 100000000 bps
# 显示虚拟模板接口1的概要信息。
<Sysname> display interface virtual-template 1 brief
VT1 DOWN DOWN --
# 显示当前物理状态为down的虚拟模板接口的信息以及down的原因。
<Sysname> display interface Virtual-Template brief down
VT0 DOWN Not connected
VT12 DOWN Not connected
VT1023 DOWN Not connected
表1-2 display interface virtual-template命令显示信息描述表
Current state |
接口当前的物理状态。虚拟模板接口的状态只能为DOWN,表示物理状态为关闭 |
接口的链路层协议状态。虚拟模板接口的状态只能为DOWN,表示数据链路层协议状态为关闭 |
接口的描述信息 |
Bandwidth |
接口的期望带宽 |
接口的MTU |
Hold timer |
retry times |
接口当前不能处理IP报文 |
链路层封装的协议 |
LCP: initial |
LCP协议初始化完成 |
Physical |
接口的物理类型 |
baudrate |
接口的波特率 |
Output queue - Urgent queuing: Size/Length/Discards 0/100/0) Output queue - Protocol queuing: Size/Length/Discards 0/500/0) Output queue - FIFO queuing: Size/Length/Discards 0/75/0) |
Brief information on interfaces in route mode: |
三层接口的概要信息 |
· 如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态 · 如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口 |
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的 |
接口名称缩写 |
Link |
接口物理连接状态。虚拟模板接口的取值只能为DOWN,表示接口物理上不通 |
Protocol |
接口数据链路层协议状态。虚拟模板接口的取值只能为DOWN,表示接口的数据链路层不通 |
Primary IP |
接口主IP地址 |
用户通过description命令给接口配置的描述信息。使用display interface brief命令,不指定description参数时,该字段最多显示27个字符;指定description参数时,可显示配置的全部描述信息 |
Cause |
接口物理连接状态为down的原因,取值为Not connected时表示没有物理连接(可能没有插网线或者网线故障) |
display ip pool命令用来显示PPP地址池的信息。
display ip pool [ pool-name | group group-name ]
pool-name:显示指定PPP地址池的信息。pool-name表示PPP地址池的名称,为1~31个字符的字符串,区分大小写。
group group-name:显示指定组内的PPP地址池信息。group-name表示组的名称,为1~31个字符的字符串,区分大小写。
如果不指定任何参数,则显示所有PPP地址池的简要信息;如果指定PPP地址池的名称,将显示指定PPP地址池的详细信息。
# 显示所有PPP地址池的简要信息。
<Sysname> display ip pool
Group name: a
Pool name Start IP address End IP address Free In use
aaa1 1.1.1.1 1.1.1.5 5 0
aaa2 1.1.1.6 1.1.1.10 5 0
Group name: b
bbb 1.1.2.1 1.1.2.5 4 1
2.2.2.1 2.2.2.5 5 0
# 显示组a的PPP地址池的简要信息。
<Sysname> display ip pool group a
Group name: a
# 显示PPP地址池bbb的详细信息。
<Sysname> display ip pool bbb
Group name: b
2.2.2.1 2.2.2.5 5 0
In use IP addresses:
IP address Interface
1.1.2.1 POS2/1/0
# 显示PPP地址池bbb的详细信息。
Group name: b
2.2.2.1 2.2.2.5 5 0
1.1.2.1 Virtual-Template1
表1-3 display ip pool命令显示信息描述表
Group name |
组的名称 |
Pool name |
PPP地址池的名称 |
Start IP address |
IP地址范围的起始IP地址 |
End IP address |
IP地址范围的结束IP地址 |
Free |
空闲IP地址个数 |
In use |
已经分配出去的IP地址个数 |
In use IP addresses |
已经分配出去的IP地址信息 |
IP address |
已经分配出去的IP地址 |
本端设备上为对端接口申请分配该IP地址的接口 |
· ip pool
display ppp access-user命令用来显示PPP接入用户的信息。
display ppp access-user { domain domain-name | interface interface-type interface-number [ count ] | ip-address ipv4-address | ipv6-address ipv6-address | username user-name | user-type { lac | lns | pppoa | pppoe } [ count ] }
domain domain-name:显示通过指定ISP域上线的PPP接入用户的信息。domain-name表示ISP域的名称,为1~255个字符的字符串,区分大小写。
interface interface-type interface-number:显示通过指定接口上线的PPP接入用户的简要信息。interface-type interface-number表示用户接入接口的类型和接口编号。
ip-address ipv4-address:显示指定IPv4地址对应的PPP接入用户的详细信息。ipv4-address表示用户的IPv4地址。
ipv6-address ipv6-address:显示指定IPv6地址对应的PPP接入用户的详细信息。ipv6-address表示用户的IPv6地址。
username user-name:显示指定用户名的PPP接入用户的详细信息。user-name表示用户的名称,为1~80个字符的字符串,区分大小写。
user-type:显示指定类型的在线用户的简要信息。
lac:显示设备作为LAC的在线用户的简要信息。
lns:显示设备作为LNS的在线用户的简要信息。
pppoa:显示用户类型为PPPoA的在线用户的简要信息。
pppoe:显示用户类型为PPPoE的在线用户的简要信息。
count:显示指定条件的PPP接入用户总数。
PPP接入用户的简要信息包括:用户对应的VA接口简名、用户的用户名、MAC地址、IP地址/IPv6地址/IPv6前缀。
PPP接入用户的详细信息包括:用户对应的VA接口简名、用户User ID、用户的用户名、认证信息、用户上下行流量数、用户接入设备的时间等。
L2TP组网中,仅在远端系统的拨号用户通过PPPoE拨入LAC方式触发建立L2TP隧道的情况下,才支持在LAC端上通过本命令查看接入用户的信息。有关L2TP的相关介绍,请参见“二层技术-广域网接入配置指导”中的“L2TP”。
# 查看通过接口GigabitEthernet2/0/1上线的PPP接入用户的简要信息。
<Sysname> display ppp access-user interface gigabitethernet 2/0/1
Interface Username MAC address IP address IPv6 address IPv6 PDPrefix
VA0 user1@dm 0001-0101-9101 192.168.100.173 - -
VA1 user2@dm 0001-0101-9101 192.168.80.173 2000::1 -
# 查看通过接口GigabitEthernet2/0/1上线的PPP接入用户总数。
<Sysname> display ppp access-user interface gigabitethernet 2/0/1 count
Total users: 2
表1-4 display ppp access-user命令显示信息描述表(简要信息)
用户对应的VA接口简名 |
Username |
用户名(“-”表示用户不需要认证)。用户名过长时,一行只能显示8个字符,其余的字符会被换行显示 |
MAC address |
用户MAC地址(“-”表示用户为非PPPoE用户) |
IP address |
用户IP地址(“-”表示用户未分配到IP地址) |
IPv6 address |
用户IPv6地址(“-”表示用户未分配到IPv6地址) |
IPv6 PDPrefix |
用户IPv6前缀(“-”表示用户未分配到IPv6前缀) |
Total users |
PPP接入用户总数 |
# 查看IP地址为50.50.50.3的PPP接入用户的详细信息。
<Sysname> display ppp access-user ip-address 50.50.50.3
Basic:
Interface: VA0
User ID: 0x28000002
Username: user1@hrss
Domain: hrss
Access interface: RAGG2
Service-VLAN/Customer-VLAN: -/-
MAC address: 0000-0000-0001
IP address: 50.50.50.3
IPv6 address: -
IPv6 PD prefix: -
VPN instance: 123
Access type: PPPoE
Authentication type: CHAP
AAA:
Authentication state: Authenticated
Authorization state: Authorized
Realtime accounting switch: Open
Realtime accounting interval: 60s
Login time: 2013-1-19 2:42:3:358
Accounting start time: 2013-1-19 2:42:3:382
Online time(hh:mm:ss): 0:7:34
Accounting state: Accounting
Idle cut: 0 sec 0 byte
Session timeout: 12000 s
Time remained: 8000 s
Traffic quota: -
Traffic remained: -
Redirect WebURL: http://6.6.6.6
ACL&QoS:
User profile: profile123 (active)
User group profile: -
Inbound CAR: CIR 64000bps PIR 640000bps CBS 500bit
Outbound CAR: CIR 64000bps PIR 640000bps CBS 500bit
NAT:
Global IP address: 111.8.0.200
Port block: 28744-28748
Flow Statistic:
IPv4 uplink packets/bytes: 7/546
IPv4 downlink packets/bytes: 0/0
IPv6 uplink packets/bytes: 0/0
IPv6 downlink packets/bytes: 0/0
表1-5 display ppp access-user命令显示信息描述表(详细信息)
Basic |
基础信息 |
用户对应的VA接口简名 |
User ID |
用户ID |
Username |
用户名(“-”表示用户不需要认证) |
Domain |
认证使用的ISP域名(“-”表示未指定认证ISP域名) |
Access interface |
用户接入的接口名 |
Service-VLAN/Customer-VLAN |
服务提供商VLAN/用户VLAN(“-”表示没有VLAN信息) |
MAC address |
用户MAC地址 |
IP address |
用户的IP地址(“-”表示用户没有分配到IP地址) |
IPv6 address |
用户的IPv6地址(“-”表示用户没有分配到IPv6地址) |
IPv6 PD prefix |
用户的IPv6代理前缀(“-”表示用户没有分配到IPv6代理前缀) |
VPN instance |
用户所属VPN实例(“-”表示未绑定VPN实例) |
Access type |
用户的接入类型,目前支持PPPoE、PPPoA和L2TP |
Authentication type |
用户接入采用的认证类型,包括:PAP、CHAP、MSCHAP、MSCHAPv2 |
AAA |
AAA信息 |
Authentication state |
用户的认证状态,包括: · Idle:表示未认证 · Authenticating:表示正在认证中 · Authenticated:表示已认证 |
Authorization state |
用户的授权状态,包括: · Idle:表示未授权 · Authorizing:表示正在授权中 · Authorized:表示已授权 |
Realtime accounting switch |
实时计费开关,取值包括: · Open:表示开启 · Closed:表示关闭 |
Realtime accounting interval |
实时计费时间间隔,单位为秒(“-”表示未授权实时计费时间间隔) |
Login time |
用户接入时间 |
Accounting start time |
开始对用户计费的时间(“-”表示未对用户计费) |
Online time(hh:mm:ss) |
用户本次上线的在线时长 |
Accounting state |
用户的计费状态,包括: · Accounting:表示正在计费 · Stop:表示停止计费 |
Idle cut |
用户的闲置切断参数(在指定时间范围内流量没超过指定字节数,则认为该用户下线并强制将该用户下线) |
Session timeout |
用户的授权时间,单位为秒(“-”表示未对用户指定授权时间) |
Time remained |
用户的剩余时间,单位为秒(“-”表示未对用户指定授权时间) |
Traffic quota |
用户的授权流量配额,单位为字节(若未为用户授权流量配额,则显示“-”) |
Traffic remained |
用户的剩余流量,单位为字节(若未为用户授权流量配额,则显示“-”) |
Redirect WebURL |
用户的上线推送页面地址(“-”表示未对用户指定上线推送页面地址 |
ACL&QoS |
ACL和QoS信息 |
User profile |
授权User Profile名称(“-”表示未授权User Profile) 括号中的active表示授权User Profile下发成功,inactive表示授权User Profile下发失败 |
User group profile |
AAA授权的User Group Profile名称。若未授权User Group Profile,则显示为“-”。授权状态包括如下: · active:AAA授权User Group Profile成功 · inactive:AAA授权User Group Profile失败或者设备上不存在该User Group Profile · 授权结果未知 |
Inbound CAR |
授权的入方向CAR:CIR表示上行平均速率,单位为bps;PIR表示上行峰值速率,单位为bps;CBS表示上行突发尺寸,单位为bit |
Outbound CAR |
授权的出方向CAR:CIR表示下行平均速率,单位为bps;PIR表示下行峰值速率,单位为bps;CBS表示下行突发尺寸,单位为bit |
NAT |
NAT信息 |
Global IP address |
用户的公网IP地址(进行NAT444地址转换后显示此字段,关于NAT444地址转换的详细介绍请参见“三层技术-IP业务配置指导”中的“NAT”) |
Port block |
用户的端口块:起始端口-结束端口(进行NAT444地址转换后显示此字段) |
Flow Statistic |
流量统计信息 |
IPv4 uplink packets/bytes |
用户的IPv4上行计费流量的报文数和字节数 |
IPv4 downlink packets/bytes |
用户的IPv4下行计费流量的报文数和字节数 |
IPv6 uplink packets/bytes |
用户的IPv6上行计费流量的报文数和字节数 |
IPv6 downlink packets/bytes |
用户的IPv6下行计费流量的报文数和字节数 |
display ppp compression iphc命令用来显示IPHC压缩的统计信息。
display ppp compression iphc { rtp | tcp } [ interface interface-type interface-number ]
rtp:显示IPHC RTP头压缩的统计信息。
tcp:显示IPHC TCP头压缩的统计信息。
interface interface-type interface-number:显示指定接口的IPHC压缩的统计信息。如果不指定interface参数,则显示所有接口的IPHC压缩的统计信息。
当MP链路使用IPHC时,如果采用虚拟模板接口、Dialer接口,压缩在VA接口上进行,这时在VA接口下可以看到压缩信息;如果采用MP-group接口,压缩在MP-group接口上进行,在MP-group接口下可以看到压缩信息。
当普通PPP链路使用IPHC时,压缩在物理链路上进行,在物理接口下可以看到压缩信息。
# 显示IPHC RTP头压缩的统计信息。(独立运行模式)
<Sysname> display ppp compression iphc rtp
----------------------Slot1----------------------
Interface: Virtual-Access0
Received:
Compressed/Error/Total: 0/0/0 packets
Sent:
Compressed/Total: 0/0 packets
Sent/Saved/Total: 0/0/0 bytes
Packet-based compression ratio: 0%
Byte-based compression ratio: 0%
Connections:
Rx/Tx: 16/16
Five-Minute-Miss: 0 (Misses/5Mins)
Max-Miss: 0
----------------------Slot2----------------------
Received:
Compressed/Error/Total: 20/5/40 packets
Sent:
Compressed/Total: 34/40 packets
Sent/Saved/Total: 1131/1210/2341 bytes
Packet-based compression ratio: 85%
Byte-based compression ratio: 51%
Connections:
Rx/Tx: 16/16
Max-Miss: 0
# 显示IPHC TCP头压缩的统计信息。(独立运行模式)
<Sysname> display ppp compression iphc tcp
Received:
Sent:
Connections:
Rx/Tx: 16/16
Max-Miss: 0
Received:
Sent:
Connections:
Rx/Tx: 16/16
Max-Miss: 0
表1-6 display ppp compression iphc命令显示信息描述表
Received:: Compressed/Error/Total: |
收到报文的统计信息: · Compressed:被压缩的报文数 · Error:错误报文数 · Total:总的报文数 |
Sent:: Compressed/Total: Sent/Saved/Total: Packet-based compression ratio: Byte-based compression ratio: |
发送报文的统计信息: · Compressed:被压缩的报文数 · Total:总的报文数 · Sent:实际发送的字节数 · Saved:节省的字节数 · Total:在不压缩的情况下,需要发送的字节数 · Packet-based compression ratio:基于报文的压缩率,表示压缩的报文在总发送报文中的比率,即(Compressed÷Total)×100% · Byte-based compression ratio:基于字节的压缩率,表示压缩后带宽节省的百分比,即(Saved÷Total)×100% |
Connections: Rx/Tx: Five-Minute-Miss: Max-Miss: |
连接信息: · Rx:作为接收方,可解压缩的连接数 · Tx:作为发送方,可压缩的连接数 · Five-Minute-Miss:最后5分钟内,查找表项失败的次数(系统每5分钟统计一次查找表项失败的次数,本字段显示的是最新一次统计的结果) · Max-Miss:查找表项失败的最大次数(将每次统计的查找表项失败的次数进行比较,得到最大值在这个字段显示) |
· ppp compression iphc enable
· reset ppp compression iphc
display ppp packet statistics命令用来显示PPP的协商报文统计信息。
(独立运行模式)
display ppp packet statistics [ slot slot-number ]
display ppp packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的PPP的报文统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板的PPP的报文统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的PPP的报文统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板的PPP的报文统计信息。(IRF模式)
# 显示Slot1上的PPP协商报文统计信息。(独立运行模式)
<Sysname> display ppp packet statistics slot 1
PPP packet statistics in slot 1:
-------------------------------LCP------------------------------------
SEND_LCP_CON_REQ : 0 RECV_LCP_CON_REQ : 0
SEND_LCP_CON_NAK : 0 RECV_LCP_CON_NAK : 0
SEND_LCP_CON_REJ : 0 RECV_LCP_CON_REJ : 0
SEND_LCP_CON_ACK : 0 RECV_LCP_CON_ACK : 0
SEND_LCP_CODE_REJ : 0 RECV_LCP_CODE_REJ : 0
SEND_LCP_PROT_REJ : 0 RECV_LCP_PROT_REJ : 0
SEND_LCP_TERM_REQ : 0 RECV_LCP_TERM_REQ : 0
SEND_LCP_TERM_ACK : 0 RECV_LCP_TERM_ACK : 0
SEND_LCP_ECHO_REQ : 0 RECV_LCP_ECHO_REQ : 0
SEND_LCP_ECHO_REP : 0 RECV_LCP_ECHO_REP : 0
SEND_LCP_FAIL : 0
-------------------------------IPCP-----------------------------------
SEND_IPCP_CON_REQ : 0 RECV_IPCP_CON_REQ : 0
SEND_IPCP_CON_NAK : 0 RECV_IPCP_CON_NAK : 0
SEND_IPCP_CON_REJ : 0 RECV_IPCP_CON_REJ : 0
SEND_IPCP_CON_ACK : 0 RECV_IPCP_CON_ACK : 0
SEND_IPCP_CODE_REJ : 0 RECV_IPCP_CODE_REJ : 0
SEND_IPCP_PROT_REJ : 0 RECV_IPCP_PROT_REJ : 0
SEND_IPCP_TERM_REQ : 0 RECV_IPCP_TERM_REQ : 0
SEND_IPCP_TERM_ACK : 0 RECV_IPCP_TERM_ACK : 0
SEND_IPCP_FAIL : 0
-------------------------------IPV6CP---------------------------------
SEND_IPV6CP_CON_REQ : 0 RECV_IPV6CP_CON_REQ : 0
SEND_IPV6CP_CON_NAK : 0 RECV_IPV6CP_CON_NAK : 0
SEND_IPV6CP_CON_REJ : 0 RECV_IPV6CP_CON_REJ : 0
SEND_IPV6CP_CON_ACK : 0 RECV_IPV6CP_CON_ACK : 0
SEND_IPV6CP_CODE_REJ : 0 RECV_IPV6CP_CODE_REJ : 0
SEND_IPV6CP_PROT_REJ : 0 RECV_IPV6CP_PROT_REJ : 0
SEND_IPV6CP_TERM_REQ : 0 RECV_IPV6CP_TERM_REQ : 0
SEND_IPV6CP_TERM_ACK : 0 RECV_IPV6CP_TERM_ACK : 0
SEND_IPV6CP_FAIL : 0
-------------------------------OSICP---------------------------------
SEND_OSICP_CON_REQ : 0 RECV_OSICP_CON_REQ : 0
SEND_OSICP_CON_NAK : 0 RECV_OSICP_CON_NAK : 0
SEND_OSICP_CON_REJ : 0 RECV_OSICP_CON_REJ : 0
SEND_OSICP_CON_ACK : 0 RECV_OSICP_CON_ACK : 0
SEND_OSICP_CODE_REJ : 0 RECV_OSICP_CODE_REJ : 0
SEND_OSICP_PROT_REJ : 0 RECV_OSICP_PROT_REJ : 0
SEND_OSICP_TERM_REQ : 0 RECV_OSICP_TERM_REQ : 0
SEND_OSICP_TERM_ACK : 0 RECV_OSICP_TERM_ACK : 0
SEND_OSICP_FAIL : 0
-------------------------------MPLSCP---------------------------------
SEND_MPLSCP_CON_REQ : 0 RECV_MPLSCP_CON_REQ : 0
SEND_MPLSCP_CON_NAK : 0 RECV_MPLSCP_CON_NAK : 0
SEND_MPLSCP_CON_REJ : 0 RECV_MPLSCP_CON_REJ : 0
SEND_MPLSCP_CON_ACK : 0 RECV_MPLSCP_CON_ACK : 0
SEND_MPLSCP_CODE_REJ : 0 RECV_MPLSCP_CODE_REJ : 0
SEND_MPLSCP_PROT_REJ : 0 RECV_MPLSCP_PROT_REJ : 0
SEND_MPLSCP_TERM_REQ : 0 RECV_MPLSCP_TERM_REQ : 0
SEND_MPLSCP_TERM_ACK : 0 RECV_MPLSCP_TERM_ACK : 0
SEND_MPLSCP_FAIL : 0
--------------------------------AUTH ----------------------------------
SEND_PAP_AUTH_REQ : 0 RECV_PAP_AUTH_REQ : 0
SEND_PAP_AUTH_ACK : 0 RECV_PAP_AUTH_ACK : 0
SEND_PAP_AUTH_NAK : 0 RECV_PAP_AUTH_NAK : 0
SEND_CHAP_AUTH_CHALLENGE : 0 RECV_CHAP_AUTH_CHALLENGE : 0
SEND_CHAP_AUTH_RESPONSE : 0 RECV_CHAP_AUTH_RESPONSE : 0
SEND_CHAP_AUTH_ACK : 0 RECV_CHAP_AUTH_ACK : 0
SEND_CHAP_AUTH_NAK : 0 RECV_CHAP_AUTH_NAK : 0
SEND_PAP_AUTH_FAIL : 0 SEND_CHAP_AUTH_FAIL : 0
表1-7 display ppp packet statistics命令显示信息描述表
LCP |
LCP报文统计信息显示 |
SEND_LCP_CON_REQ |
发送的链路配置请求报文计数 |
RECV_LCP_CON_REQ |
接收的链路配置请求报文计数 |
SEND_LCP_CON_NAK |
发送的链路配置NAK报文计数 |
RECV_LCP_CON_NAK |
接收的链路配置NAK报文计数 |
SEND_LCP_CON_REJ |
发送的链路配置拒绝报文计数 |
RECV_LCP_CON_REJ |
接收的链路配置拒绝报文计数 |
SEND_LCP_CON_ACK |
发送的链路配置ACK报文计数 |
RECV_LCP_CON_ACK |
接收的链路配置ACK报文计数 |
SEND_LCP_CODE_REJ |
发送的链路配置解码错误报文计数 |
RECV_LCP_CODE_REJ |
接收的链路配置解码错误报文计数 |
SEND_LCP_PROT_REJ |
发送的链路配置协议码错误报文计数 |
RECV_LCP_PROT_REJ |
接收的链路配置协议码错误报文计数 |
SEND_LCP_TERM_REQ |
发送的链路终止请求报文计数 |
RECV_LCP_TERM_REQ |
接收的链路终止请求报文计数 |
SEND_LCP_TERM_ACK |
发送的链路终止ACK报文计数 |
RECV_LCP_TERM_ACK |
接收的链路终止ACK报文计数 |
SEND_LCP_ECHO_REQ |
发送的链路ECHO请求报文计数 |
RECV_LCP_ECHO_REQ |
接收的链路ECHO请求报文计数 |
SEND_LCP_ECHO_REP |
发送的链路ECHO应答报文计数 |
RECV_LCP_ECHO_REP |
接收的链路ECHO应答报文计数 |
SEND_LCP_FAIL |
发送的链路失败报文计数 |
IPCP |
IPCP报文统计信息显示 |
SEND_IPCP_CON_REQ |
发送的IP地址协商请求报文计数 |
RECV_IPCP_CON_REQ |
接收的IP地址协商请求报文计数 |
SEND_IPCP_CON_NAK |
发送的IP地址协商NAK报文计数 |
RECV_IPCP_CON_NAK |
接收的IP地址协商NAK报文计数 |
SEND_IPCP_CON_REJ |
发送的IP地址协商拒绝报文计数 |
RECV_IPCP_CON_REJ |
接收的IP地址协商拒绝报文计数 |
SEND_IPCP_CON_ACK |
发送的IP地址协商ACK报文计数 |
RECV_IPCP_CON_ACK |
接收的IP地址协商ACK报文计数 |
SEND_IPCP_CODE_REJ |
发送的IP地址协商解码错误报文计数 |
RECV_IPCP_CODE_REJ |
接收的IP地址协商解码错误报文计数 |
SEND_IPCP_PROT_REJ |
发送的IP地址协商协议码错误报文计数 |
RECV_IPCP_PROT_REJ |
接收的IP地址协商协议码错误报文计数 |
SEND_IPCP_TERM_REQ |
发送的IP地址协商终止请求报文计数 |
RECV_IPCP_TERM_REQ |
接收的IP地址协商终止请求报文计数 |
SEND_IPCP_TERM_ACK |
发送的IP地址协商终止ACK报文计数 |
RECV_IPCP_TERM_ACK |
接收的IP地址协商终止ACK报文计数 |
SEND_IPCP_FAIL |
发送的IP地址协商失败报文计数 |
IPV6CP |
IPV6CP报文统计信息显示 |
SEND_IPV6CP_CON_REQ |
发送的IPv6地址协商请求报文计数 |
RECV_IPV6CP_CON_REQ |
接收的IPv6地址协商请求报文计数 |
SEND_IPV6CP_CON_NAK |
发送的IPv6地址协商NAK报文计数 |
RECV_IPV6CP_CON_NAK |
接收的IPv6地址协商NAK报文计数 |
SEND_IPV6CP_CON_REJ |
发送的IPv6地址协商拒绝报文计数 |
RECV_IPV6CP_CON_REJ |
接收的IPv6地址协商拒绝报文计数 |
SEND_IPV6CP_CON_ACK |
发送的IPv6地址协商ACK报文计数 |
RECV_IPV6CP_CON_ACK |
接收的IPv6地址协商ACK报文计数 |
SEND_IPV6CP_CODE_REJ |
发送的IPv6地址协商解码错误报文计数 |
RECV_IPV6CP_CODE_REJ |
接收的IPv6地址协商解码错误报文计数 |
SEND_IPV6CP_PROT_REJ |
发送的IPv6地址协商协议码错误报文计数 |
RECV_IPV6CP_PROT_REJ |
接收的IPv6地址协商协议码错误报文计数 |
SEND_IPV6CP_TERM_REQ |
发送的IPv6地址协商终止请求报文计数 |
RECV_IPV6CP_TERM_REQ |
接收的IPv6地址协商终止请求报文计数 |
SEND_IPV6CP_TERM_ACK |
发送的IPv6地址协商终止ACK报文计数 |
RECV_IPV6CP_TERM_ACK |
接收的IPv6地址协商终止ACK报文计数 |
SEND_IPV6CP_FAIL |
发送的Ipv6地址协商失败报文计数 |
OSICP |
OSICP报文统计信息显示 |
SEND_OSICP_CON_REQ |
发送的OSI地址协商请求报文计数 |
RECV_OSICP_CON_REQ |
接收的OSI地址协商请求报文计数 |
SEND_OSICP_CON_NAK |
发送的OSI地址协商NAK报文计数 |
RECV_OSICP_CON_NAK |
接收的OSI地址协商NAK报文计数 |
SEND_OSICP_CON_REJ |
发送的OSI地址协商拒绝报文计数 |
RECV_OSICP_CON_REJ |
接收的OSI地址协商拒绝报文计数 |
SEND_OSICP_CON_ACK |
发送的OSI地址协商ACK报文计数 |
RECV_OSICP_CON_ACK |
接收的OSI地址协商ACK报文计数 |
SEND_OSICP_CODE_REJ |
发送的OSI地址协商解码错误报文计数 |
RECV_OSICP_CODE_REJ |
接收的OSI地址协商解码错误报文计数 |
SEND_OSICP_PROT_REJ |
发送的OSI地址协商协议码错误报文计数 |
RECV_OSICP_PROT_REJ |
接收的OSI地址协商协议码错误报文计数 |
SEND_OSICP_TERM_REQ |
发送的OSI地址协商终止请求报文计数 |
RECV_OSICP_TERM_REQ |
接收的OSI地址协商终止请求报文计数 |
SEND_OSICP_TERM_ACK |
发送的OSI地址协商终止ACK报文计数 |
RECV_OSICP_TERM_ACK |
接收的OSI地址协商终止ACK报文计数 |
SEND_OSICP_FAIL |
发送的OSI地址协商失败报文计数 |
MPLSCP |
MPLSCP报文统计信息显示 |
SEND_MPLSCP_CON_REQ |
发送的MPLS地址协商请求报文计数 |
RECV_MPLSCP_CON_REQ |
接收的MPLS地址协商请求报文计数 |
SEND_MPLSCP_CON_NAK |
发送的MPLS地址协商NAK报文计数 |
RECV_MPLSCP_CON_NAK |
接收的MPLS地址协商NAK报文计数 |
SEND_MPLSCP_CON_REJ |
发送的MPLS地址协商拒绝报文计数 |
RECV_MPLSCP_CON_REJ |
接收的MPLS地址协商拒绝报文计数 |
SEND_MPLSCP_CON_ACK |
发送的MPLS地址协商ACK报文计数 |
RECV_MPLSCP_CON_ACK |
接收的MPLS地址协商ACK报文计数 |
SEND_MPLSCP_CODE_REJ |
发送的MPLS地址协商解码错误报文计数 |
RECV_MPLSCP_CODE_REJ |
接收的MPLS地址协商解码错误报文计数 |
SEND_MPLSCP_PROT_REJ |
发送的MPLS地址协商协议码错误报文计数 |
RECV_MPLSCP_PROT_REJ |
接收的MPLS地址协商协议码错误报文计数 |
SEND_MPLSCP_TERM_REQ |
发送的MPLS地址协商终止请求报文计数 |
RECV_MPLSCP_TERM_REQ |
接收的MPLS地址协商终止请求报文计数 |
SEND_MPLSCP_TERM_ACK |
发送的MPLS地址协商终止ACK报文计数 |
RECV_MPLSCP_TERM_ACK |
接收的MPLS地址协商终止ACK报文计数 |
SEND_MPLSCP_FAIL |
发送的MPLS地址协商失败报文计数 |
AUTH |
认证报文统计信息显示 |
SEND_PAP_AUTH_ REQ |
发送的PAP认证请求报文计数 |
RECV_PAP_AUTH_REQ |
接收的PAP认证请求报文计数 |
SEND_PAP_AUTH_ACK |
发送的PAP认证ACK报文计数 |
RECV_PAP_AUTH_ACK |
接收的PAP认证ACK报文计数 |
SEND_PAP_AUTH_NAK |
发送的PAP认证NAK报文计数 |
RECV_PAP_AUTH_NAK |
接收的PAP认证NAK报文计数 |
SEND_CHAP_AUTH_CHALLENGE |
发送的CHAP认证请求报文计数 |
RECV_CHAP_AUTH_CHALLENGE |
接收的CHAP认证请求报文计数 |
SEND_CHAP_AUTH_RESPONSE |
发送的CHAP认证回应报文计数 |
RECV_CHAP_AUTH_RESPONSE |
接收的CHAP认证回应报文计数 |
SEND_CHAP_AUTH_ACK |
发送的CHAP认证ACK报文计数 |
RECV_CHAP_AUTH_ACK |
接收的CHAP认证ACK报文计数 |
SEND_CHAP_AUTH_NAK |
发送的CHAP认证NAK报文计数 |
RECV_CHAP_AUTH_NAK |
接收的CHAP认证NAK报文计数 |
SEND_PAP_AUTH_FAIL |
发送的PAP认证失败报文计数 |
SEND_CHAP_AUTH_FAIL |
发送的CHAP认证失败报文计数 |
· reset ppp packet statistics
interface virtual-template命令用来创建虚拟模板接口并进入指定的虚拟模板接口视图。如果指定的虚拟模板接口已经存在,则直接进入虚拟模板接口视图。
undo interface virtual-template命令用来删除指定虚拟模板接口。
interface virtual-template number
undo interface virtual-template number
不存在虚拟模板接口。
number:虚拟模板接口的编号。取值范围为0~1023。
在删除虚拟模板接口前,请确定相关的虚拟访问接口都已经删除,而且该虚拟模板接口不再被使用。
通过configuration replace file命令用来执行配置回滚操作前,请确保已完成如下操作,否则可能导致interface virtual-template配置回滚失败。
· PPPoE用户已全部下线。
· 删除所有VA池。
VA接口被删除完成。
MIC-X-ET16L每个子卡最多支持16个Virtual-Access接口。
MIC-X-CLP4和MIC-X-CLP2每个子卡最多支持128个Virtual-Access接口。
MIC-X-CLP2、MIC-X-CLP4和MIC-X-ET16L接口卡上每个Virtual-Access接口最多支持绑定16个物理串口。
# 创建虚拟模板接口10。
ip address ppp-negotiate命令用来为接口配置IP地址可协商属性,使接口接受PPP协商产生的由Server端分配的IP地址。
undo ip address ppp-negotiate命令用来恢复缺省情况。
接口未配置IP地址可协商属性。
多次执行ip address ppp-negotiate命令和ip address命令,最后一次执行的命令生效。
# 为接口Serial2/1/0配置IP地址可协商属性。
[Sysname] interface serial 2/1/0
[Sysname-Serial2/1/0] ip address ppp-negotiate
# 为接口Virtual-Template1配置IP地址可协商属性。
[Sysname-Virtual-Template1] ip address ppp-negotiate
· ip address(三层技术-IP业务命令参考/IP地址)
· remote address
ip pool命令用来配置PPP地址池。
undo ip pool命令用来删除指定的PPP地址池或删除指定PPP地址池下的指定IP地址范围,该IP地址范围必须与配置的IP地址范围相同。
ip pool pool-name start-ip-address [ end-ip-address ] [ group group-name ]
undo ip pool pool-name [ start-ip-address [ end-ip-address ] ]
未配置PPP地址池。
pool-name:PPP地址池的名称,为1~31个字符的字符串,区分大小写。
start-ip-address [ end-ip-address ]:定义一个IP地址范围。start-ip-address为起始IP地址,end-ip-address为结束IP地址。一个起始IP地址和结束IP地址之间的地址为一个IP地址范围。如果不指定结束IP地址,则该IP地址范围中只有一个IP地址,即起始IP地址。
group group-name:指定PPP地址池所在的组。group-name表示组的名称,为1~31个字符的字符串,区分大小写。不指定本参数时,组名称为default。
系统支持多个地址空间,以此来实现对VPN的支持,每个地址空间可以对应一个VPN,不同地址空间中可以存在相同的IP地址。
系统用组来划分地址空间,每个组表示一个地址空间。设备上可以存在多个组。一个组下可以包含多个PPP地址池,一个PPP地址池下可以包含多个IP地址范围。
一个PPP地址池只能属于一个组。
一个PPP地址池下可以包含多个IP地址范围,一次只能配置一个IP地址范围,可以通过多次配置本命令来配置多个IP地址范围。
不同组内的IP地址范围可以重叠,同一个组内的IP地址范围不可以重叠。
一个IP地址范围中包含的IP地址数最多为65535。
一个PPP地址池中包含的IP地址数最多为65535。
对PPP地址池配置的修改不会影响到已经分配出去的IP地址的使用。比如,从PPP地址池a中分配出去一个IP地址1.1.1.1后,删除PPP地址池a,已经分配出去的IP地址1.1.1.1仍可以正常使用。
当通过PPP地址池给用户分配IP地址时,请确保PPP地址池中不包含该PPP地址池的网关地址。
# 配置PPP地址池aaa,IP地址范围为129.102.0.1到129.102.0.10,PPP地址池所在的组为a。
[Sysname] ip pool aaa 129.102.0.1 129.102.0.10 group a
· display ip pool
ip pool gateway命令用来配置PPP地址池的网关地址。
undo ip pool gateway命令用来删除指定PPP地址池的网关地址。
ip pool pool-name gateway ip-address [ vpn-instance vpn-instance-name ]
undo ip pool pool-name gateway
未指定PPP地址池的网关地址。
pool-name:PPP地址池的名称,为1~31个字符的字符串,区分大小写。该PPP地址池必须已经存在。
ip-address:PPP地址池的网关地址。
vpn-instance vpn-instance-name:网关地址所在的VPN实例。指定的VPN实例必须已经存在。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定本参数时,表示指定的是公网IP地址。
Server端的接口必须在配置IP地址后,才能开始进行IPCP协商,为Client端分配IP地址。在BRAS接入场景下,用户的IP地址都是Server端通过地址池分配的,大量用户可能是通过Server端的很多不同接口接入的,这样Server端上每个接入接口上都需要配置一个IP地址,会占用很多IP地址。
在这种情况下,用户可以为PPP地址池配置一个网关地址。配置网关地址后,在所有使用该PPP地址池为用户分配IP地址的接入接口上,当接入接口没有配置IP地址时,将使用该PPP地址池的网关地址进行IPCP协商。这样,就不用为每个接入接口单独配置IP地址了,大大节省了占用的IP地址数量。
当同时配置了PPP地址池的网关地址和接入接口的IP地址时,会使用接入接口的IP地址进行IPCP协商。
每个PPP地址池只能配置一个网关地址,不同PPP地址池配置的网关地址不能相同,即为不同PPP地址池配置网关地址时,ip-address和vpn-instance-name不能完全相同。
PPP地址池的网关地址可以配置为任意一个IP地址,只要不同PPP地址池的网关地址不冲突即可。
# 为PPP地址池aaa配置网关地址为1.1.1.1。
[Sysname] ip pool aaa gateway 1.1.1.1
· ip pool
link-protocol ppp命令用来配置接口封装的链路层协议为PPP。
link-protocol ppp
除以太网接口、VLAN接口、ATM接口外,其它接口封装的链路层协议均为PPP。
# 配置接口Serial2/1/0封装的链路层协议为PPP。
[Sysname-Serial2/1/0] link-protocol ppp
mtu命令用来设置接口的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
接口的MTU值为1500字节。
虚拟模板接口视图
MP-group接口视图
接口的MTU值影响IP协议报文在该接口上传输时的分片与重组。
需要注意的是,配置了mtu命令后需要执行命令shutdown和undo shutdown,这样该配置才能在接口上生效。
# 配置虚拟模板接口10的MTU值为1400字节。
[Sysname-Virtual-Template10] mtu 1400
# 配置接口MP-group2/0/0的MTU值为1200字节。
[Sysname-MP-group2/0/0] mtu 1200
nas-port-type命令用来配置虚拟模板接口的nas-port-type属性。
undo nas-port-type命令用来恢复缺省情况。
nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
undo nas-port-type
nas-port-type属性由PPP用户的业务类型和承载链路类型决定:
· 如果是PPPoE业务,当承载链路类型为三层虚拟以太网接口时,nas-port-type属性为xdsl,否则nas-port-type属性为ethernet;
· 如果是PPPoA业务,nas-port-type属性为xdsl;
· 如果是L2TP业务,nas-port-type属性为virtual。
虚拟模板接口视图
802.11:符合Wireless-IEEE 802.11标准的接口类型,对应的编码值为19。
adsl-cap:ADSL-CAP(Asymmetric DSL,Carrierless Amplitude Phase Modulation)接口类型,
对应的编码值为12。
adsl-dmt:ADSL-DMT(Asymmetric DSL,Discrete Multi-Tone)接口类型,对应的编码值为13。
async:Async接口类型,对应的编码值为0。
cable:Cable接口类型,对应的编码值为17。
ethernet:Ethernet接口类型,对应的编码值为15。
g.3-fax:G.3 Fax接口类型,对应的编码值为10。
hdlc:HDLC接口类型,对应的编码值为7。
idsl:IDSL(ISDN Digital Subscriber Line)接口类型,对应的编码值为14。
isdn-async-v110:ISDN Async V.110接口类型,对应的编码值为4。
isdn-async-v120:ISDN Async V.120接口类型,对应的编码值为3。
isdn-sync:ISDN Sync接口类型,对应的编码值为2。
piafs:符合PIAFS(PHS(Personal Handyphone System)Internet Access Forum Standard)标准的接口类型,对应的编码值为6。
sdsl:SDSL(Symmetric DSL)接口类型,对应的编码值为11。
sync:Sync接口类型,对应的编码值为1。
virtual:Virtual接口类型,对应的编码值为5。
wireless-other:Wireless-other接口类型,对应的编码值为18。
x.25:X.25接口类型,对应的编码值为8。
x.75:X.75接口类型,对应的编码值为9。
xdsl:XDSL(Digital Subscriber Line of unknown type)接口类型,对应的编码值为16。
本命令配置的nas-port-type属性主要应用于RADIUS认证计费时所携带的nas-port-type属性。
关于nas-port-type属性的详细介绍请参见RFC 2865。
本命令配置后仅对新接入的用户生效,对当前已经存在用户无影响。
# 配置虚拟模板接口1的nas-port-type属性为sync。
[Sysname-Virtual-Template1] nas-port-type sync
ppp accm命令用来配置ACCM字段的值。
undo ppp accm命令用来恢复缺省情况。
ppp accm hex-number
undo ppp accm
ACCM字段的值为十六进制数000a0000。
hex-number:ACCM字段的值,取值范围为十六进制数0~ffffffff。
ACCM协商选项只有在异步链路上才会生效。
# 在接口Serial2/1/0上配置ACCM字段的值为十六进制数01010101。
[Sysname-Serial2/1/0] ppp accm 01010101
ppp access-user log enable命令用来开启PPP接入用户日志信息功能。
undo ppp access-user log enable命令用来关闭PPP接入用户日志信息功能。
ppp access-user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
undo ppp access-user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
设备PPP接入用户日志信息功能处于关闭状态。
abnormal-logout:PPP用户异常下线的日志信息。
failed-login:PPP用户上线失败的日志信息。
normal-logout:PPP用户正常下线的日志信息。
successful-login:PPP用户上线成功的日志信息。
为了防止设备输出过多的PPP日志信息,一般情况下建议关闭此功能。
PPP接入用户日志是为了满足网络管理员维护的需要,对用户的上线、下线、上线失败的信息进行记录,包括用户名、IP地址、接口名称、两层VLAN、MAC地址、上线失败原因、下线原因等。设备生成的PPP日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
配置本命令时,如果未指定任何参数,将同时开启用户的上线成功、上线失败、正常下线和异常下线日志功能。需要注意的是,在多机备份环境下,用户接入接口down时不打印日志信息。关于多机备份的详细介绍请参见“可靠性配置指导”中的“多机备份”。
通过undo命令关闭日志功能时,如果未指定任何参数,将同时关闭用户的上线成功、上线失败、正常下线和异常下线日志功能。
# 开启PPP接入用户日志信息功能。
[Sysname] ppp access-user log enable
ppp account-statistics enable命令用来开启PPP计费统计功能。
undo ppp account-statistics enable命令用来关闭PPP计费统计功能。
ppp account-statistics enable [ acl { acl-number | name acl-name } ]
PPP计费统计功能处于关闭状态。
acl:对符合ACL的流量进行计费统计。如果不配置ACL,则对所有流量都进行计费统计。
acl-number:指定ACL的编号。acl-number表示ACL的编号,取值范围2000~2999表示IPv4基本ACL、IPv6基本ACL,取值范围3000~3999表示IPv4高级ACL、IPv6高级ACL。对于同一个ACL编号,如果同时存在对应的IPv4 ACL和IPv6 ACL,则会同时生效。
name acl-name:指定ACL的名称。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
引用ACL时,需要注意的是:
· 若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示PPP计费统计功能不生效。
· 在引用的ACL中,若某规则指定了vpn-instance参数,则表示该规则仅对VPN报文有效;若规则未指定vpn-instance参数,则表示该规则仅对公网报文有效。
# 在Serial2/1/0上开启PPP计费统计功能。
[Sysname-Serial2/1/0] ppp account-statistics enable
# 在Virtual-Template1上开启PPP计费统计功能。
[Sysname-Virtual-Template1] ppp account-statistics enable
ppp acfc local-request命令用来配置本地发送ACFC协商请求,即LCP协商时本地发送的协商请求携带ACFC协商选项。
undo ppp acfc local-request命令用来恢复缺省情况。
LCP协商时本地发送的协商请求未携带ACFC协商选项。
# 在接口Serial2/1/0上配置本地发送ACFC协商请求。
[Sysname-Serial2/1/0] ppp acfc local-request
# 在Virtual-Template1上配置本地发送ACFC协商请求。
[Sysname-Virtual-Template1] ppp acfc local-request
ppp acfc remote-reject命令用来拒绝对端的ACFC协商请求,即LCP协商时拒绝对端携带的ACFC协商选项。
undo ppp acfc remote-reject命令用来恢复缺省情况。
接受对端的ACFC协商请求,即LCP协商时接受对端携带的ACFC协商选项,并且发送的报文进行地址控制字段压缩。
# 在接口Serial2/1/0上配置拒绝对端的ACFC协商请求。
[Sysname-Serial2/1/0] ppp acfc remote-reject
# 在Virtual-Template1上配置拒绝对端的ACFC协商请求。
[Sysname-Virtual-Template1] ppp acfc remote-reject
ppp authentication-mode命令用来配置本地认证对端的认证方式。
undo ppp authentication-mode命令用来恢复缺省情况。
ppp authentication-mode { chap | ms-chap | ms-chap-v2 | pap } * [ [ call-in ] domain { isp-name | default enable isp-name } ]
PPP协议未进行认证。
chap:采用CHAP认证方式。
ms-chap:采用MSCHAP认证方式。
ms-chap-v2:采用MSCHAPv2认证方式。
pap:采用PAP认证方式。
call-in:表示只在远端用户呼入时才认证对方。当本端作为DDR呼叫的接收端时可以配置本参数。关于DDR的详细介绍请参见“二层技术-广域网接入配置指导”中的“DDR”。
domain isp-name:表示用户认证采用的ISP域名,为1~255个字符的字符串,不区分大小写。isp-name不能为字符串“d”、“de”、“def”、“defa”、“defau”、“defaul”、“default”。
default enable isp-name:表示用户认证采用的缺省ISP域名,为1~255个字符的字符串,不区分大小写。
PPP有以下几种认证方式:
· PAP为两次握手认证,口令为明文或者密文均可。
· CHAP为三次握手认证,口令为明文或者密文均可。
· MSCHAP为微软CHAP认证,是三次握手认证,口令为密文。
· MSCHAPv2为微软CHAP V2认证,是三次握手认证,口令为密文。
用户可以同时配置上面的多种认证方式。
上述任何一种认证方式,只是一种认证过程,最终能否通过认证,还需要AAA来作决定,AAA可以利用本地认证数据库认证或由AAA服务器进行认证。关于AAA认证的详细介绍请参见“安全配置指导”中的“AAA”。
需要注意的是,用户认证时支持通过多种方式获取ISP域,并按如下优先顺序选择第一个可用的ISP域进行认证:
· 使用本命令中通过domain isp-name指定的ISP域进行认证;
· 使用用户名中自带的domain信息作为ISP域进行认证;
· 使用本命令中通过domain default enable isp-name指定的接口缺省ISP域进行认证;
· 使用AAA模块选择的认证域进行认证,具体请参见“安全配置指导”中的“AAA”。
对于拨号接口的认证,建议在物理接口和Dialer接口上都配置。因为当物理接口接收到DDR呼叫请求时,首先进行PPP协商并认证拨入用户的合法性,然后再将呼叫转交给上层协议进行处理。
# 在接口Serial2/1/0上,采用PAP方法认证对端设备。
[Sysname-Serial2/1/0] ppp authentication-mode pap
# 在接口Serial2/1/0上,采用PAP、CHAP、MSCHAP三种方法认证对端设备。
[Sysname-Serial2/1/0] ppp authentication-mode pap chap ms-chap
# 在接口Virtual-Template1上,采用PAP方法认证对端设备。
[Sysname-Virtual-Template1] ppp authentication-mode pap
# 在接口Virtual-Template1上,采用PAP、CHAP两种方法认证对端设备。
[Sysname-Virtual-Template1] ppp authentication-mode pap chap
· domain default(安全命令参考/AAA)
· local-user(安全命令参考/AAA)
· ppp chap password
· ppp chap user
· ppp pap local-user
ppp chap password命令用来配置进行CHAP认证时采用的密码。
undo ppp chap password命令用来恢复缺省情况。
ppp chap password { cipher | simple } string
未配置进行CHAP认证时采用的密码。
cipher:表示以密文方式设置密码。
simple:表示以明文方式设置密码,该密码将以密文形式存储。
string:CHAP认证时采用的密码,区分大小写,以明文方式设置密码时为1~255个字符的字符串,以密文方式设置密码时为1~373个字符的字符串。
# 配置本地设备以CHAP方式被对端设备认证时,密码为sysname。
[Sysname-Serial2/1/0] ppp chap password simple sysname
[Sysname-Virtual-Template1] ppp chap password simple sysname
· ppp authentication-mode
ppp chap user命令用来配置采用CHAP认证时的用户名。
undo ppp chap user命令用来恢复缺省情况。
ppp chap user username
undo ppp chap user
CHAP认证的用户名为空。
username:CHAP认证用户名,为1~80个字符的字符串,区分大小写。该用户名是发送到对端设备进行CHAP认证时使用的用户名。
配置CHAP认证时,要将各自的username配置为对端的local-user,而且对应的password要一致。
# 配置接口Serial2/1/0进行CHAP认证时的用户名为Root。
[Sysname-Serial2/1/0] ppp chap user Root
# 配置接口Virtual-Template1进行CHAP认证时的用户名为Root。
[Sysname-Virtual-Template1] ppp chap user Root
ppp compression iphc enable命令用来开启IPHC压缩功能。
undo ppp compression iphc enable命令用来关闭IPHC压缩功能。
ppp compression iphc enable [ nonstandard ]
IPHC压缩功能处于关闭状态。
nonstandard:非标准的兼容的封装格式。不指定本参数时,则按照标准格式进行报文封装。与第三方设备互通时需要配置本参数。配置本参数后,仅支持RTP头压缩,不支持TCP头压缩。
IPHC压缩分为如下两种:
· RTP头压缩:对报文中的RTP/UDP/IP头进行压缩。
· TCP头压缩:对报文中的TCP/IP头进行压缩。
开启IPHC压缩功能后,上述两种压缩功能都将启动;关闭IPHC压缩功能后,上述两种压缩功能都将被禁止。
用户必须在链路的两端同时开启IPHC压缩功能,该功能才生效。
在虚拟模板接口、Dialer接口、ISDN接口上配置本功能时,配置不会立即生效,只有对此接口或者其绑定的物理接口进行shutdown/undo shutdown操作后,配置才能生效。
# 开启Serial2/1/0接口的IPHC压缩功能。
[Sysname-Serial2/1/0] ppp compression iphc enable
# 开启Virtual-Template1接口的IPHC压缩功能。
[Sysname-Virtual-Template1] ppp compression iphc enable
ppp compression iphc rtp-connections命令用来配置接口上允许进行RTP头压缩的最大连接数。
undo ppp compression iphc rtp-connections命令用来恢复缺省情况。
ppp compression iphc rtp-connections number
接口上允许进行RTP头压缩的最大连接数为16。
number:接口上允许进行RTP头压缩的最大连接数,取值范围为3~1000。当number≤256时,报文将被压缩成COMPRESSED_RTP_8格式,当number>256时,报文将被压缩成COMPRESSED_RTP_16格式。
RTP(Real-time Transport Protocol,实时传输协议)是面向连接的协议,一条链路上所能承载的RTP连接的数目是比较多的,但压缩算法压缩时需对每个连接维护一定的信息,从而占用一定的内存,因此可以用ppp compression iphc rtp-connections命令来配置RTP头压缩的最大连接数。例如最大连接数配置为3时,第4条RTP连接上的报文就不会被压缩了。
配置本功能后,需要对接口进行shutdown/undo shutdown操作后,配置才能生效。
只有在开启IPHC压缩功能后,才能配置本命令。在关闭IPHC压缩功能后,本配置将被清除。
# 配置Serial2/1/0接口上允许进行RTP头压缩的最大连接数为10。
[Sysname-Serial2/1/0] ppp compression iphc rtp-connections 10
# 配置Virtual-Template1接口上允许进行RTP头压缩的最大连接数为10。
[Sysname-Virtual-Template1] ppp compression iphc rtp-connections 10
ppp compression iphc tcp-connections命令用来配置接口上允许进行TCP头压缩的最大连接数。
undo ppp compression iphc tcp-connections命令用来恢复缺省情况。
ppp compression iphc tcp-connections number
接口上允许进行TCP头压缩的最大连接数为16。
number:接口上允许进行TCP头压缩的最大连接数,取值范围为3~256。
TCP是面向连接的协议,一条链路上所能承载的TCP连接的数目是比较多的,但压缩算法压缩时需对每个连接维护一定的信息,从而占用一定的内存,因此可以用ppp compression iphc tcp-connections命令来配置TCP头压缩的最大连接数。例如最大连接数配置为3时,第4条TCP连接上的报文就不会被压缩了。
只有在开启IPHC压缩功能,且不指定nonstandard参数时,才能配置本命令。在关闭IPHC压缩功能或者更改配置为nonstandard模式后,本配置将被清除。
# 配置Serial2/1/0接口上允许进行TCP头压缩的最大连接数为10。
[Sysname-Serial2/1/0] ppp compression iphc tcp-connections 10
# 配置Virtual-Template1接口上允许进行TCP头压缩的最大连接数为10。
[Sysname-Virtual-Template1] ppp compression iphc tcp-connections 10
ppp ip-pool route命令用来配置PPP地址池路由。
undo ppp ip-pool route命令用来删除PPP地址池路由。
ppp ip-pool route ip-address { mask-length | mask } [ vpn-instance vpn-instance-name ]
undo ppp ip-pool route ip-address { mask-length | mask } [ vpn-instance vpn-instance-name ]
未配置PPP地址池路由。
ip-address:PPP地址池路由的IP地址,为点分十进制格式。
mask-length:PPP地址池路由的子网掩码长度,即掩码中连续“1”的个数,取值范围为0~32。
mask:PPP地址池路由的IP地址相应的子网掩码,为点分十进制格式。
vpn-instance-name:MPLS L3VPN实例的名称,为1~31个字符的字符串,区分大小写。该VPN实例必须已经存在。如果未指定本参数,则表示PPP地址池路由位于公网中。
BRAS(Broadband Remote Access Server,宽带接入服务器)通过撤销和发布PPP地址池路由来实现对下行流量转发的控制。
BRAS设备配置PPP地址池路由以后,将生成一条黑洞静态路由,所有到该网段的流量均被丢弃,只有当合法用户上线以后,在BRAS设备上添加一条对应的主机路由,下行的用户流量才能被正确转发。动态路由协议通过引入静态路由把该路由发布到上游的核心路由器上,核心路由器上所有到该网段的流量都引到BRAS设备上。
图1-1 PPP地址池路由示意图
用户需要保证配置的PPP地址池路由网段覆盖PPP地址池网段范围。当存在多个PPP地址池网段时,可以配置多条对应的PPP地址池路由。
# 配置PPP添加的PPP地址池路由为2.2.2.2/24。
[Sysname] ppp ip-pool route 2.2.2.2 24
ppp ipcp dns命令用来配置设备为对端设备指定DNS服务器的IP地址。
undo ppp ipcp dns命令用来删除设备为对端设备指定DNS服务器的IP地址。
ppp ipcp dns primary-dns-address [ secondary-dns-address ]
undo ppp ipcp dns primary-dns-address [ secondary-dns-address ]
未指定对端设备DNS服务器的IP地址。
primary-dns-address:主DNS服务器的IP地址。
secondary-dns-address:从DNS服务器的IP地址。
当设备之间通过PPP协议相连时,通过协商,设备可以为对端设备指定DNS服务器的IP地址(但需要等待对端请求,不会主动给对端指定DNS的地址)。
如果主机与设备通过PPP协议相连时,用户可以在主机上使用命令winipcfg或ipconfig/all来查看设备为其提供的DNS服务器的IP地址。
# 配置设备为对端设备分配的主DNS服务器的IP地址为100.1.1.1,从DNS服务器的IP地址为100.1.1.2。
[Sysname-Serial2/1/0] ppp ipcp dns 100.1.1.1 100.1.1.2
[Sysname-Virtual-Template1] ppp ipcp dns 100.1.1.1 100.1.1.2
ppp ipcp dns admit-any命令用来配置设备可以被动地接收对端设备指定的DNS服务器的IP地址,即设备不发送DNS请求,也能接收对端设备分配的DNS服务器的IP地址。
undo ppp ipcp dns admit-any命令用来恢复缺省情况。
设备不会被动地接收对端设备指定的DNS服务器的IP地址。
当设备通过PPP协议与其它设备相连时,通过协商,设备可以被动地接收对端设备指定的DNS服务器地址,这样设备就可以使用对端设备指定的DNS服务器来解析域名。
正常情况下,Client端配置了ppp ipcp dns request,Server端才会为本端指定DNS服务器地址。但是有一些特殊的设备,Client端并未请求,Server端却要强制为Client端指定DNS服务器地址,从而导致协商不通过,为了适应这种情况,Client端可以配置ppp ipcp dns admit-any。
# 配置本地设备的Serial2/1/0接口可以被动地接收对端指定的DNS服务器地址。
[Sysname-Serial2/1/0] ppp ipcp dns admit-any
# 配置本地设备的Virtual-Template1接口可以被动地接收对端指定的DNS服务器地址。
[Sysname-Virtual-Template1] ppp ipcp dns admit-any
· ppp ipcp dns request
ppp ipcp dns request命令用来配置设备可以主动向对端请求DNS服务器地址。
undo ppp ipcp dns request命令用来恢复缺省情况。
禁止设备主动向对端请求DNS服务器地址。
当设备通过PPP协议与其它设备相连时(通常为设备拨号连接运营商的接入服务器),在进行IPCP协商时,设备可以主动请求对端设备为其指定DNS服务器地址,这样设备就可以使用对端设备指定的DNS来解析域名。
如果协商到有效的DNS服务器地址,将在接口显示信息中打印出来。
# 配置Serial2/1/0接口主动请求DNS服务器地址。
[Sysname-Serial2/1/0] ppp ipcp dns request
# 配置Virtual-Template1接口主动请求DNS服务器地址。
[Sysname-Virtual-Template1] ppp ipcp dns request
ppp ipcp remote-address match命令用来使能接口的IP网段检查功能。
undo ppp ipcp remote-address match命令用来关闭接口的IP网段检查功能。
接口的IP网段检查功能处于关闭状态。
使能接口的IP网段检查功能后,当IPCP协商时,本端会检查对端接口的IP地址与本端接口的IP地址是否在同一网段,如果不在同一网段,则IPCP协商失败。
# 在虚拟模板接口1上使能接口的IP网段检查功能。
[Sysname-Virtual-Template1] ppp ipcp remote-address match
ppp lcp delay命令用来配置LCP协商的延迟时间。
undo ppp lcp delay命令用来恢复缺省情况。
ppp lcp delay milliseconds
undo ppp lcp delay
接口物理层UP后,PPP立即进行LCP协商。
milliseconds:LCP协商的延迟时间,取值范围为1~10000,单位为毫秒。
在PPP链路两端设备对LCP协商报文的处理速度差异较大的情况下,为避免因一端无法及时处理对端发送的LCP协商报文而导致对端重传,可在对协商报文处理速度较快的设备上配置LCP协商的延迟时间。配置LCP协商的延迟时间后,当接口物理层UP时PPP将在延迟时间超时后才会主动进行LCP协商;如果在延迟时间内本端设备收到对端设备发送的LCP协商报文,则本端设备将不再等待延迟时间超时,而是直接进行LCP协商。
# 配置PPP链路初始化时LCP协商的延迟时间。
[Sysname-Virtual-Template1] ppp lcp delay 130
ppp lqm命令用来开启PPP链路质量监测功能。
undo ppp lqm命令用来关闭PPP链路质量监测功能。
ppp lqm close-percentage close-percentage [ resume-percentage resume-percentage ]
undo ppp lqm
PPP链路质量监测功能处于关闭状态。
close-percentage close-percentage:禁用链路质量百分比,取值范围为0~100。
resume-percentage resume-percentage:恢复链路质量百分比,取值范围为0~100。resume-percentage的值必须大于等于close-percentage的值。resume-percentage的缺省值等于close-percentage的值。
当在PPP链路两端同时开启链路质量监测功能时,两端设备的参数必须相等。一般来说,不建议在链路两端同时开启链路质量监测功能。
不建议在拨号线路上开启PPP链路质量监测功能。当在拨号线路上开启链路质量监测功能后,由于拨号线路的特点,一旦链路被禁用,DDR模块就会把拨号线路挂断,因此链路质量监测就不能正常的运行。只有当有数据需要传输时,DDR模块把拨号线路重新呼起,链路质量监测功能才能恢复正常。
# 在接口Serial2/1/0上开启PPP链路质量监测功能,禁用链路质量百分比为90%,恢复链路质量百分比为95%。
[Sysname-Serial2/1/0] ppp lqm close-percentage 90 resume-percentage 95
ppp lqm lcp-echo命令用来配置当链路质量检测功能检测到链路质量低时向对端发送LCP echo报文。
undo ppp lqm lcp-echo命令用来恢复缺省情况。
ppp lqm lcp-echo [ packet size ] [ interval interval ]
链路质量检测功能检测到链路质量低时不向对端发送LCP echo报文。
packet size:指定检测的报文大小,取值范围为128~1500,单位为字节。
interval interval:发送检测报文的时间间隔,取值范围为1~10,单位为秒。
当开启PPP链路质量监测功能时,可以通过配置ppp lqm lcp-echo命令,在监测到链路质量低的时候向PPP链路对端定期发送大字节LCP echo报文进行检测,从而避免由大字节报文丢失导致链路质量低下时的链路动荡。
# 在接口Serial2/1/0上每隔1秒发送一个1400字节的报文进行链路质量检测。
[Sysname-Serial2/1/0] ppp lqm lcp-echo packet 1400 interval 1
ppp modify-authinfo restart命令用来配置被认证方修改PPP认证的用户名或密码后触发PPP重新协商。
undo modify-authinfo restart命令用来恢复缺省情况。
ppp modify-authinfo restart [ delay delay-time ]
undo ppp modify-authinfo restart
被认证方修改PPP认证的用户名或密码后维持当前已协商建立的PPP连接。
delay delay-time:被认证方修改PPP认证的用户名或密码后,延迟一段时间再断开PPP连接。delay-time为延迟时间,取值范围为0~300,单位为秒。delay-time的缺省值为0秒,即立刻断开PPP连接,以触发PPP重新协商。
缺省情况下,被认证方修改PPP认证的用户名或密码后,会维持当前已协商建立的PPP连接。存在如下需求时,可以通过配置本功能,来让被认证方修改PPP认证的用户名或密码后,主动断开PPP连接,以便PPP重新进行协商:
· 实时性需求:当认证信息更改时,能够立即重新认证,确保连接的用户是使用最新的认证信息。
· 安全性需求:如果网络管理员发现有安全风险,例如密码泄露,修改密码后马上触发重新协商可以迅速切断未经授权用户的访问,防止潜在的安全威胁。
· 一致性需求:确保所有的用户都是根据最新的认证信息进行连接,这有助于维护用户数据库的一致性。
被认证方通过ppp chap password、ppp chap user或ppp pap local-user命令修改了用于认证的用户名或密码时,都会触发PPP连接断开。
开启触发PPP重新协商后,也有可能带来如下影响:
· 由于重新协商可能会中断当前的会话,可能会对正在进行的通信造成影响。
· 频繁的重新协商会引入额外的性能开销,增加系统的复杂性。
· 频繁的断开连接可能会影响接入用户的体验。
# 配置被认证方修改PPP认证的用户名或密码100秒后,断开PPP连接,以触发PPP重新协商。
[Sysname-Serial2/1/0] ppp modify-authinfo restart delay 100
· ppp chap password
· ppp chap user
ppp pap local-user命令用来配置本地设备被对端设备采用PAP方式认证时发送的用户名和密码。
undo ppp pap local-user命令用来恢复缺省情况。
ppp pap local-user username password { cipher | simple } string
被对端以PAP方式认证时,本地设备发送的用户名和密码均为空。
username:本地设备被对端设备采用PAP方式认证时发送的用户名,为1~80个字符的字符串,区分大小写。
cipher:表示以密文方式设置密码。
string:密码字符串,区分大小写。明文密码为1~255个字符的字符串,密文密码为1~373个字符的字符串。
当本地设备被对端以PAP方式认证时,本地设备发送的用户名和密码应与对端设备的用户名(通过命令local-user username配置)和密码(通过命令password { cipher | simple } string配置)一致。
# 配置本地设备被对端以PAP方式认证时发送的用户名为user1,密码为pass1。
[Sysname-Serial2/1/0] ppp pap local-user user1 password simple pass1
[Sysname-Virtual-Template1] ppp pap local-user user1 password simple pass1
· password(安全命令参考/AAA)
ppp pfc local-request命令用来配置本地发送PFC协商请求,即LCP协商时本地发送的协商请求携带PFC协商选项。
undo ppp pfc local-request命令用来恢复缺省情况。
LCP协商时本地发送的协商请求不携带PFC协商选项。
# 在接口Serial2/1/0上配置本地发送PFC协商请求。
[Sysname-Serial2/1/0] ppp pfc local-request
# 在Virtual-Template1上配置本地发送PFC协商请求。
[Sysname-Virtual-Template1] ppp pfc local-request
ppp pfc remote-reject命令用来拒绝对端的PFC协商请求,即LCP协商时拒绝对端携带的PFC协商选项。
undo ppp pfc remote-reject命令用来恢复缺省情况。
接受对端的PFC协商请求,即LCP协商时接受对端携带的PFC协商选项,并且发送的报文进行协议字段压缩。
# 在接口Serial2/1/0上配置拒绝对端的PFC协商请求。
[Sysname-Serial2/1/0] ppp pfc remote-reject
# 在Virtual-Template1上配置拒绝对端的PFC协商请求。
[Sysname-Virtual-Template1] ppp pfc remote-reject
ppp timer negotiate命令用来配置PPP协商超时时间。
undo ppp timer negotiate命令用来恢复缺省情况。
ppp timer negotiate seconds
PPP协商超时时间间隔为3秒。
seconds:协商超时时间间隔,取值范围为1~10,单位为秒。
在PPP协商过程中,如果在超时时间间隔内没有收到对端的应答报文,则PPP将会重发前一次发送的报文。
# 配置PPP协商超时时间间隔为5秒。
[Sysname-Serial2/1/0] ppp timer negotiate 5
# 配置PPP协商超时时间间隔为5秒。
[Sysname-Virtual-Template1] ppp timer negotiate 5
remote address命令用来配置为Client端分配IP地址。
undo remote address命令用来恢复缺省情况。
remote address { ip-address | pool pool-name }
undo remote address
接口不为Client端分配IP地址。
ip-address:为Client端分配的IP地址。
pool pool-name:为Client端分配IP地址使用的地址池,即将地址池pool-name中的一个IP地址分配给Client端。该地址池既可以是PPP地址池,也可以是DHCP地址池。pool-name表示地址池的名称,为1~31个字符的字符串,区分大小写。
当对端接口还未配置IP地址而本端接口已经有IP地址时,本端接口可以为对端接口分配IP地址。这时,需要在对端接口上配置ip address ppp-negotiate命令,使对端接口作为Client端,接受由PPP协商产生的、Server端分配的IP地址。
PPP可以使用两类地址池为对端接口分配IP地址:PPP地址池、DHCP地址池,优先采用PPP地址池。如果用户配置了名称相同的PPP地址池和DHCP地址池,并采用该名称的地址池来分配IP地址,则系统只会使用PPP地址池来分配IP地址。
本端接口配置了remote address命令后会强制为对端分配IP地址,如果对端接口没有配置ip address ppp-negotiate命令而是直接配置了IP地址,则对端接口不会接受本端分配的IP地址,则会导致IPCP协商失败。
Server端给Client端分配IP地址后,可以配置remote address/undo remote address命令,但是配置不能立即生效,已经为Client端分配的IP地址仍然可以正常使用,需要等到下一次IPCP协商时新的配置才生效。
建议在配置此应用时先配置remote address命令,然后再配置ip address命令,使得remote address命令的配置能够生效(因为配置ip address命令后,就开始进行IPCP协商。因此,如果在ip address命令后配置remote address命令,需要等到下次IPCP协商时,才能为Client端分配IP地址。所以建议先配置remote address命令,再配置ip address命令)。
# 接口Serial2/1/0为Client端分配的IP地址为10.0.0.1。
[Sysname-Serial2/1/0] remote address 10.0.0.1
# 接口Serial2/1/0使用地址池aaa为Client端分配IP地址。
[Sysname-Serial2/1/0] remote address pool aaa
# 接口Virtual-Template1为Client端分配的IP地址为10.0.0.1。
[Sysname-Virtual-Template1] remote address 10.0.0.1
# 接口Virtual-Template1使用地址池aaa为Client端分配IP地址。
[Sysname-Virtual-Template1] remote address pool aaa
· ip address ppp-negotiate
· ip pool
remote address dhcp client-identifier命令用来配置PPP用户作为DHCP客户端时使用的DHCP客户端ID。
undo remote address dhcp client-identifier命令用来恢复缺省情况。
remote address dhcp client-identifier { callingnum | username }
未配置PPP用户作为DHCP客户端时使用的DHCP客户端ID。
callingnum:使用主叫号码作为DHCP客户端ID。其中,主叫号码通过L2TP协商报文中的calling number AVP携带,由用户MAC地址和用户所属VLAN组成。例如,某用户MAC地址是000f-e235-dc71,用户所属的外层和内层VLAN分别是VLAN 1和VLAN 2,则主叫号码为000f-e235-dc71-00010002。
username:使用PPP用户名作为DHCP客户端ID。
缺省情况下,PPP客户端通过DHCP申请IP地址时随机选择DHCP客户端ID,此时DHCP服务器无法根据客户端ID为特定的客户端分配特定的IP地址。如需根据客户端ID为特定的客户端分配特定的IP地址,需要通过本命令配置使用主叫号码或用户名作为客户端ID。
需要注意的是,当使用PPP用户名作为DHCP客户端ID时,请确保各个上线用户分别使用不同的PPP用户名上线。
# 配置PPP用户作为DHCP客户端时使用用户名作为DHCP客户端ID。
[Sysname-Serial2/1/0] remote address dhcp client-identifier username
[Sysname-Virtual-Template1] remote address dhcp client-identifier username
reset counters interface virtual-access命令用来清除VA接口的统计信息。
reset counters interface [ virtual-access [ interface-number ] ]
virtual-access [ interface-number ]:清除VA接口的统计信息。interface-number表示VA接口的编号。取值范围为已创建的VA接口的编号。如果不指定virtual-access和interface-number,则清除除VA接口外所有接口的统计信息;如果指定virtual-access而不指定interface-number,则清除所有VA接口的统计信息;如果同时指定virtual-access和interface-number,则清除指定VA接口的统计信息。
在某些情况下,需要统计一定时间内某接口的流量,这就需要在统计开始前清除该接口的原有的统计信息,重新进行统计。
# 清除VA接口10的统计信息。
<Sysname> reset counters interface virtual-access 10
· display interface virtual-access
reset ppp access-user命令用来强制PPP用户下线。
reset ppp access-user { ip-address ipv4-address [ vpn-instance ipv4-vpn-instance-name ] | ipv6-address ipv6-address [ vpn-instance ipv6-vpn-instance-name ] | username user-name }
ip-address ipv4-address:表示指定IPv4地址的PPP用户。ipv4-address表示用户的IPv4地址。
ipv6-address ipv6-address:表示指定IPv6地址的PPP用户。ipv6-address表示用户的IPv6地址。
vpn-instance ipv4-vpn-instance-name:表示指定PPP用户所属的VPN实例。ipv4-vpn-instance-name表示MPLS L3VPN的IPv4 VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示该用户属于公网。
vpn-instance ipv6-vpn-instance-name:表示指定PPP用户所属的VPN实例。ipv6-vpn-instance-name表示MPLS L3VPN的IPv6 VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示该用户属于公网。
username user-name:表示指定用户名的PPP用户。user-name表示用户的名称,为1~80个字符的字符串,区分大小写。
本命令仅对当前在线的PPPoE、L2TP等BRAS用户生效。用户被强制下线后,重新连接即可再次上线。
# 强制IP地址为192.168.100.2的PPP用户下线。
<Sysname> reset ppp access-user ip-address 192.168.100.2
· display ppp access-user
reset ppp compression iphc命令用来清除IPHC压缩的统计信息。
reset ppp compression iphc [ rtp | tcp ] [ interface interface-type interface-number ]
rtp:清除IPHC RTP头压缩的统计信息。
tcp:清除IPHC TCP头压缩的统计信息。
interface interface-type interface-number:清除指定接口的IPHC压缩的统计信息。不指定本参数时,将清除所有接口的IPHC压缩的统计信息。
不指定rtp和tcp参数时,将同时清除RTP头压缩和TCP头压缩的统计信息。
# 清除所有接口的IPHC压缩的统计信息。
<Sysname> reset ppp compression iphc
· display ppp compression iphc
reset ppp packet statistics命令用来清除PPP的协商报文统计信息。
(独立运行模式)
reset ppp packet statistics [ slot slot-number ]
reset ppp packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number:清除指定单板的PPP的报文统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,将清除所有单板的PPP报文统计信息。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的PPP的报文统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除所有成员设备上所有单板的PPP报文统计信息。(IRF模式)
# 清除接口板Slot2上的PPP的协商报文统计信息。(独立运行模式)
<Sysname> reset ppp packet statistics slot 2
# 清除成员设备1的接口板Slot2上的PPP的协商报文统计信息。(IRF模式)
<Sysname> reset ppp packet statistics chassis 1 slot 2
· display ppp packet statistics
service命令用来配置处理接口流量的主用slot。
undo service命令用来恢复缺省情况。
(独立运行模式)
service slot slot-number
undo service slot
service chassis chassis-number slot slot-number
undo service chassis
未配置处理接口流量的主用slot。
虚拟模板接口视图
slot slot-number:指定单板所在的槽位号。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
当要求同一个VA接口的流量在同一个slot上处理时,可以配置用于转发当前接口流量的slot。
为提高当前接口处理流量的可靠性,可以通过service命令和service standby命令为接口分别指定一个主用slot和一个备用slot进行流量处理。为避免不必要的流量切换,建议配置主用slot后,再配置备用slot。如果先配置备用slot再配置主用slot,流量将会从备用slot切换到主用slot。
如果同时配置了主用slot和备用slot,流量处理的机制如下:
· 当主用slot不可用时,流量由备用slot处理。之后,即使主用slot恢复可用,流量也继续由备用slot处理;仅当备用slot不可用时,流量才切换到主用slot。
· 当主用slot和备用slot均不可用时,流量由接收报文的slot处理;之后,主用slot和备用slot谁先恢复可用,流量就由谁处理。
如果接口上未配置主用slot和备用slot,则流量在接收报文的slot上处理。
# 指定2号槽位单板作为转发虚拟模板接口10下VA接口的流量的主用单板。(独立运行模式)
[Sysname-Virtual-Template10] service slot 2
# 指定2号成员设备的2号单板作为转发虚拟模板接口10下VA接口的流量的主用单板。(IRF模式)
[Sysname-Virtual-Template10] service chassis 2 slot 2
· service standby
service standby命令用来配置处理接口流量的备用slot。
undo service standby命令用来恢复缺省情况。
(独立运行模式)
service standby slot slot-number
undo service standby slot
service standby chassis chassis-number slot slot-number
undo service standby chassis
未配置处理接口流量的备用slot。
虚拟模板接口视图
# 指定2号槽位单板作为转发虚拟模板接口10下VA接口的流量的主用单板,同时指定3号槽位单板为备用单板。(独立运行模式)
[Sysname-Virtual-Template10] service standby slot 3
# 指定2号成员设备的2号槽位单板作为转发虚拟模板接口10下VA接口的流量主用单板,同时指定2号成员设备的3号槽位单板为备用单板。(IRF模式)
[Sysname-Virtual-Template10] service standby chassis 2 slot 3
· service
timer-hold命令用来配置接口发送keepalive报文的周期。
undo timer-hold命令用来恢复缺省情况。
timer-hold seconds
undo timer-hold
接口发送keepalive报文的周期为10秒。
seconds:接口发送keepalive报文的周期,取值范围为0~32767,单位为秒。取值为0表示不主动发送keepalive报文;当本端收到对端主动发送过来的keepalive报文时,可以对该keepalive报文进行应答。
在速率非常低的链路上,参数seconds不能配置过小。因为在低速链路上,大报文可能会需要很长的时间才能传送完毕,这样就会延迟keepalive报文的发送与接收。而接口如果在retries个(可以通过timer-hold retry命令修改该个数)keepalive周期内没有收到keepalive报文的应答,它就会认为链路发生故障。如果keepalive报文被延迟的时间超过接口的这个限制,链路就会被认为发生故障而被关闭。
# 配置接口Serial2/1/0发送keepalive报文的周期为20秒。
[Sysname-Serial2/1/0] timer-hold 20
# 配置接口Virtual-Template1发送keepalive报文的周期为20秒。
[Sysname-Virtual-Template1] timer-hold 20
· timer-hold retry
timer-hold retry命令用来配置接口在多少个keepalive周期内没有收到keepalive报文的应答就拆除链路。
undo timer-hold retry命令用来恢复缺省情况。
timer-hold retry retries
接口在5个keepalive周期内没有收到keepalive报文的应答就拆除链路。
retries:接口在多少个keepalive周期内没有收到keepalive报文的应答就拆除链路,取值范围为1~255。
在速率非常低的链路上,参数retries不能配置过小。因为在低速链路上,大报文可能会需要很长的时间才能传送完毕,这样就会延迟keepalive报文的发送与接收。而接口如果在retries个keepalive周期内没有收到keepalive报文的应答,它就会认为链路发生故障。如果keepalive报文被延迟的时间超过接口的这个限制,链路就会被认为发生故障而被关闭。
# 配置接口Serial2/1/0在10个keepalive周期内没有收到keepalive报文的应答就拆除链路。
[Sysname-Serial2/1/0] timer-hold retry 10
# 配置接口Virtual-Template1在10个keepalive周期内没有收到keepalive报文的应答就拆除链路。
[Sysname-Virtual-Template1] timer-hold retry 10
· timer-hold
MIC-X-SP4、MIC-X-SP8、MIC-SP4L和MIC-SP8L不支持MP特性。
display interface mp-group命令用来显示MP-group接口的相关信息。
display interface [ mp-group [ interface-number ] ] [ brief [ description | down ] ]
mp-group [ interface-number ]:显示指定MP-group接口的信息。interface-number表示MP-group接口的编号,取值范围为已创建的MP-group接口的编号。如果不指定mp-group,则显示除VA接口外设备支持的所有接口的相关信息;如果指定mp-group,不指定interface-number,则显示所有已创建的MP-group接口的相关信息。
# 查看接口MP-group2/0/0的运行状态和相关信息。
<Sysname> display interface mp-group 2/0/0
MP-group2/0/0
Current state: UP
Description: MP-group2/0/0 Interface
Bandwidth: 2048kbps
Physical: MP, baudrate: 2048000 bps
Last 300 seconds input rate: 0 bytes/sec, 0 packets/sec
Last 300 seconds output rate: 0 bytes/sec, 0 packets/sec
# 显示接口MP-group2/0/0的概要信息。
<Sysname> display interface mp-group 2/0/0 brief
MP2/0/0 DOWN DOWN --
# 显示当前物理状态为down的MP-group接口的信息以及down的原因。
<Sysname> display interface mp-group brief down
MP2/0/0 ADM Administratively
MP2/0/1 DOWN Not connected
表1-8 display interface mp-group命令显示信息描述表
Current state |
接口的物理状态,状态可能为: · Administratively DOWN:表示该接口已经通过shutdown命令被关闭,即管理状态为关闭 · DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障) · UP:该端口的管理状态和物理状态均为开启 |
接口的描述信息 |
Bandwidth |
接口的期望带宽。本字段仅在接口处于UP状态时才显示 |
接口的MTU |
Hold timer |
retry times |
接口当前不能处理IP报文 |
链路层封装的协议 |
LCP: opened, MP: opened |
LCP(链路控制协议)初始化完成 |
Physical |
接口的物理类型 |
baudrate |
接口的波特率。本字段仅在接口处于UP状态时才显示 |
Last 300 seconds input rate: 0 bytes/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 packets/sec |
Input: 0 packets, 0 bytes, 0 drops |
Output: 0 packets, 0 bytes, 0 drops |
三层模式下(route)的接口的概要信息,即三层接口的概要信息 |
接口名称缩写 |
Link |
接口物理连接状态,取值可能为: · UP:表示接口物理上是连通的 · DOWN:表示接口物理上不通 · ADM:表示接口被手工关闭了,需要执行undo shutdown命令才能打开接口 · Stby:表示该接口是一个备份接口 |
Protocol |
Primary IP |
接口的描述信息 |
Cause |
接口物理连接状态为down的原因,取值为: · Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态 · Not connected:表示没有物理连接(可能没有插网线或者网线故障) |
· reset counters interface mp-group
display ppp mp命令用来显示MP的相关信息。
display ppp mp [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口的MP信息。如果不指定本参数,将显示所有接口的MP信息。
# 显示MP的相关信息(通过MP-group配置的MP)。
<Sysname> display ppp mp
Template: MP-group2/0/0
max-bind: 20, fragment: enabled, min-fragment: 128
Master link: MP-group2/0/0, Active members: 2, Bundle Multilink
Peer's endPoint descriptor: MP-group2/0/0
Sequence format: short (rcv)/long (sent)
Bundle Up Time: 2012/11/05 07:29:33:612
0 lost fragments, 0 reordered, 0 unassigned, 0 interleaved
Sequence: 0 (rcv)/0 (sent)
Active member channels: 2 members
Serial2/1/0:15 Up-Time: 2012/11/05 07:29:33:613
Serial2/1/0:16 Up-Time: 2012/11/05 07:30:10:945
Inactive member channels: 2 members
Serial2/1/0:17
Serial2/1/0:18
Template: MP-group2/0/0 |
MP接口为MP-group2/0/0 |
max-bind |
MP最大捆绑链路数 |
fragment |
是否使能MP报文分片功能: · enabled表示使能 · disabled表示未使能 |
min-fragment |
MP报文分片的最小长度 |
Master link |
主通道 |
Active members |
绑定的生效通道数目 |
Bundle Multilink |
多链路捆绑 |
Peer's endPoint descriptor |
MP通道对端终端标识符 |
Sequence format: short (rcv)/long (sent) |
MP序号格式,收方向短序,发方向长序 |
Bundle Up Time |
MP通道Up的时间 |
lost fragments |
丢弃分片数 |
reordered |
重组报文数 |
unassigned |
等待重组分片数 |
interleaved |
交叉存取分片数(LFI是将MP报文分成小片穿插到其他报文中传输,交叉存取分片数指的是穿插到其他报文中传输的分片个数) |
Sequence: 0 (rcv)/0 (sent) |
接收序列号/发送序列号 |
Active member channels |
生效的子通道 |
Up-Time |
子通道Up的时间 |
Inactive member channels |
不生效的子通道 |
interface mp-group命令用来创建MP-group接口并进入指定的MP-group接口视图。如果指定的MP-group接口已经存在,则直接进入MP-group接口视图。
undo interface mp-group命令用来删除指定的MP-group接口。
interface mp-group mp-number
undo interface mp-group mp-number
未配置MP-group接口。
该命令与ppp mp mp-group命令配合使用,可以先创建MP-group接口,也可以先配置接口加入MP-group。
MIC-X-ET16L每个子卡最多支持16个MP-group接口。
MIC-X-CLP4和MIC-X-CLP2每个子卡最多支持128个MP-group接口。
MIC-X-CLP2、MIC-X-CLP4和MIC-X-ET16L接口卡上每个MP接口最多支持绑定16个物理串口。
# 创建接口MP-group2/0/0。
ppp mp命令用来配置封装PPP的接口工作在MP方式。
undo ppp mp命令用来恢复缺省情况。
ppp mp
undo ppp mp
封装PPP的接口工作在普通PPP方式下。
为了增加带宽,可以将多个PPP链路捆绑使用,形成一个逻辑MP接口使用。
# 配置接口Serial2/1/0工作在MP方式下。
[Sysname-Serial2/1/0] ppp mp
# 配置接口VT1工作在MP方式下。
[Sysname] interface virtual-template1
[Sysname-Virtual-Template1] ppp mp
ppp mp binding-mode命令用来配置MP捆绑的条件。
undo ppp mp binding-mode命令用来恢复缺省情况。
ppp mp binding-mode { authentication | both | descriptor }
同时根据PPP的认证用户名和终端标识符进行MP捆绑。
虚拟模板接口视图
Dialer接口视图
authentication:根据PPP的认证用户名进行MP捆绑。
both:同时根据PPP的认证用户名和终端标识符进行MP捆绑。
descriptor:根据PPP的终端标识符进行MP捆绑。
用户名是指PPP链路进行PAP、CHAP、MSCHAP或MSCHAPv2认证时所接收到的对端用户名;终端标识符是用来唯一标识一台设备的标志,是指进行LCP协商时所接收到的对端终端标识符。系统可以根据接口接收到的用户名或终端标识符找到指定的虚拟模板接口,从而利用模板上的配置,创建相应的MP捆绑。
当只选择descriptor的绑定模式时,MP捆绑时无法区分不同的用户,如果不同用户需要绑定到不同的捆绑组下时,应该选用both的绑定模式。
当只选择authentication的绑定模式时,无法区分各个对端设备,因此MP捆绑有多个对端设备时,应该选用both的绑定模式。
# 仅根据PPP认证的用户名进行MP捆绑。
[Sysname-Virtual-Template1] ppp mp binding-mode authentication
ppp mp endpoint命令用来配置当前接口在MP应用时,LCP协商的Endpoint选项内容。
undo ppp mp endpoint命令用来恢复缺省情况。
ppp mp endpoint endpoint
接口发送报文中携带的Endpoint选项内容为设备名称。
endpoint:终端标识符(Endpoint选项内容),为1~20个字符的字符串,区分大小写。
在MP的LCP协商过程会协商Endpoint选项(终端标识符)值:
· 在通过虚拟模板接口配置MP时,会根据Endpoint选项值来进行MP捆绑。缺省情况下,接口发送报文中携带的Endpoint选项内容为设备名称。如果网络中存在相同的设备名称,导致无法区分MP捆绑时,用户可以修改接口发送报文中携带的Endpoint选项的内容。
· 在通过MP-group接口配置MP时,不需要根据Endpoint选项值进行MP捆绑。当使用ppp mp mp-group命令将接口加入指定MP-group后,接口发送报文中携带的Endpoint选项内容缺省为MP-group的接口名称,如果用户配置了Endpoint选项内容,则携带用户配置的值。
由于Endpoint选项内容最长为20字节,如果内容超过20个字节,则截取前20个字节作为Endpoint选项内容。
# 配置Serial2/1/0接口发送报文中的Endpoint选项内容。
[Sysname-Serial2/1/0] ppp mp endpoint 123456
# 配置接口VT1发送报文中的Endpoint选项内容。
[Sysname-Virtual-Template1] ppp mp endpoint 123456
ppp mp fast-forward enable命令用来开启MP报文快转功能。
undo ppp mp fast-forward enable命令用来关闭MP报文快转功能。
MP报文快转功能处于关闭状态。
虚拟模板接口视图
Dialer接口视图
MP-group接口视图
开启接口的MP报文快转功能后,从当前接口发送的报文中会携带MP序号和分片标记,但每个报文都是以一个整片发送出去,提高了报文的转发效率。
当接口上配置ppp mp fast-forward enable命令后,该接口上的ppp mp fragment disable命令或undo ppp mp fragment disable命令功能不再生效。
# 开启接口MP-group2/0/0的MP报文快转功能。
[Sysname] interface mp-group 2/0/0
[Sysname-MP-group2/0/0] ppp mp fast-forward enable
· ppp mp fragment disable
ppp mp fragment disable命令用来关闭MP报文分片功能。
undo ppp mp fragment disable命令用来开启MP报文分片功能。
MP报文分片功能处于开启状态。
虚拟模板接口视图
Dialer接口视图
MP-group接口视图
配置ppp mp fragment disable命令关闭MP报文分片功能后,发送的报文中仍然带有MP序号和分片标记,只不过每个报文都是以一个整片发送出去。当对端设备不支持分片重组功能时,需要在本端配置ppp mp fragment disable命令,以和对端进行互通。
配置ppp mp fragment disable命令后,接口的ppp mp lfi enable、ppp mp min-fragment命令不再起作用。
# 关闭接口MP-group2/0/0的MP报文分片功能。
[Sysname-MP-group2/0/0] ppp mp fragment disable
· ppp mp lfi enable
· ppp mp min-fragment
ppp mp lfi delay-per-frag命令用来配置传输一个LFI分片的最大时延。
undo ppp mp lfi delay-per-frag命令用来恢复缺省情况。
ppp mp lfi delay-per-frag time
· MIC-X-CLP2、MIC-X-CLP4和MIC-X-ET1接口卡不支持本命令。
HIM-CL1P和HIM-CL2P接口卡在配置为硬件捆绑模式时,不支持本命令。
传输一个LFI分片的最大时延为10ms。
虚拟模板接口视图
Dialer接口视图
MP-group接口视图
time:LFI分片的最大时延值,取值范围为1~1000,单位为毫秒。
当没有配置传输LFI分片的最大字节数,而配置了传输LFI分片的最大时延时,最大分片大小=(接口的期望带宽×最大时延)÷8。
# 把接口MP-group2/0/0的LFI分片的最大时延配置为20ms。
[Sysname-MP-group2/0/0] ppp mp lfi delay-per-frag 20
· ppp mp lfi enable
· ppp mp lfi size-per-frag
ppp mp load-sharing mode strict-round-robin命令用来配置MP在报文发送时使用严格负载分担模式。
undo ppp mp load-sharing mode strict-round-robin命令用来恢复缺省情况。
MP使用智能负载分担模式
MP-group接口视图
设备工作在智能负载分担模式下,在报文发送时,系统会选择最近使用过的空闲的MP成员接口来发送报文分片;而工作在严格负载分担模式下,系统会按照MP成员接口加入MP-group接口的顺序来依次选择成员接口发送报文分片。
# 配置接口MP-group2/0/0的MP报文发送使用严格负载分担模式。
[Sysname-MP-group2/0/0] ppp mp load-sharing mode strict-round-robin
ppp mp lfi enable命令用来在接口上开启LFI(Link Fragmentation and Interleaving,链路分片与交叉)功能。
undo ppp mp lfi enable命令用来在接口上关闭LFI功能。
ppp mp lfi enable
LFI功能处于关闭状态。
虚拟模板接口视图
Dialer接口视图
MP-group接口视图
开启LFI功能后,LFI功能对MP报文的最大分片大小首先由LFI的最大字节数(通过ppp mp lfi size-per-frag命令配置)决定,如果没有配置LFI的最大字节数,则由LFI的最大时延(通过ppp mp lfi delay-per-frag命令配置)决定,最大分片大小=(接口的期望带宽×最大时延)÷8。
关闭LFI功能会同时删除用户配置的LFI分片的最大时延或LFI分片的最大字节数。
# 在接口MP-group2/0/0上开启LFI功能。
[Sysname-MP-group2/0/0] ppp mp lfi enable
· ppp mp lfi delay-per-frag
ppp mp lfi size-per-frag命令用来配置LFI分片的最大字节数。
undo ppp mp lfi size-per-frag命令用来恢复缺省情况。
ppp mp lfi size-per-frag size
LFI分片的大小由ppp mp lfi delay-per-frag的配置来决定,最大分片大小=(接口的期望带宽×最大时延)÷8。
虚拟模板接口视图
Dialer接口视图
MP-group接口视图
开启LFI功能后,配置了LFI分片的最大字节数,则最大分片大小为本命令配置的值。
# 把接口MP-group2/0/0的LFI分片的最大字节数配置为80字节。
[Sysname-MP-group2/0/0] ppp mp lfi size-per-frag 80
· ppp mp lfi enable
ppp mp max-bind命令用来配置MP最大捆绑链路数。
undo ppp mp max-bind命令用来恢复缺省情况。
ppp mp max-bind max-bind-num
MP最大捆绑链路数为16。
虚拟模板接口视图
Dialer接口视图
MP-group接口视图
max-bind-num:表示可以被捆绑的最大链路数,取值范围为1~128。
一般情况下用户不必配置此参数,当需要配置此参数时请在技术工程师的指导下进行。配置该参数可能影响PPP的性能。如果确实需要使用大于16个的PPP通道进行捆绑,可以改变max-bind-num参数。
如果MP捆绑链路失败,那么很可能是由于用户想要捆绑的链路数大于最大捆绑链路数。
本命令配置后立即生效。如果修改后的MP最大捆绑链路数小于实际已经加入MP捆绑的链路数,那么已经加入MP捆绑的链路不会因此而退出捆绑。
# 配置MP的最大捆绑链路数为12。
[Sysname-MP-group2/0/0] ppp mp max-bind 12
ppp mp min-bind命令用来配置MP最少需要呼起的PPP通道数。
undo ppp mp min-bind命令用来恢复缺省情况。
ppp mp min-bind min-bind-num
最小捆绑链路数为0,即MP拨号将依赖流量检测。
Dialer接口视图
min-bind-num:最小捆绑链路数,取值范围为0~128。
在拨号使用中,有时需要能够同时使用多条通道来承载业务,因此需要一次报文触发能够呼起多条通道以保证最小需要的带宽。此时可以使用该命令来配置最小捆绑链路数。
当配置的最小捆绑链路数不为0时,MP拨号将不依赖流量检测,但对于已经呼叫建立的链路会因为没有流量后空闲超时而主动拆除。
ppp mp min-bind命令配置的最小捆绑链路数应该小于等于ppp mp max-bind命令配置的最大捆绑链路数。
# 配置MP最小捆绑链路数为4。
[Sysname] interface dialer 0
[Sysname-Dialer0] ppp mp min-bind 4
· ppp mp max-bind
ppp mp min-fragment命令用来配置对MP报文进行分片的最小报文长度。
undo ppp mp min-fragment命令用来恢复缺省情况。
ppp mp min-fragment size
MP报文进行分片的最小报文长度为128字节。
虚拟模板接口视图
Dialer接口视图
MP-group接口视图
如果采用硬件芯片实现MP捆绑功能(如CPOS硬件芯片),则最小分片大小的配置需要参考具体芯片规格(如部分硬件芯片约定只能按128、256、512等字节分片),此时要求ppp mp min-fragment命令的配置参数符合芯片要求。如果不符合,则MP捆绑无法产生,子通道LCP链路会拆断。
MIC-X-ET16L、MIC-X-CLP4和MIC-X-CLP2接口卡的最小分片取值只能是128、256或512字节。
# 配置对MP报文进行分片的最小报文长度为500字节。
[Sysname-MP-group2/0/0] ppp mp min-fragment 500
ppp mp mp-group命令用来将当前接口加入指定的MP-group,使接口工作在MP方式。
ppp mp mp-group mp-number
undo ppp mp
接口工作在普通PPP方式。
mp-number:MP-group接口的编号。
本命令与interface mp-group命令配合使用,可以先创建MP-group接口然后再将指定接口加入到该MP-group中,也可以先配置接口加入MP-group然后再创建该MP-group接口。
# 将接口Serial2/1/0加入MP-group2/0/0。
[Sysname-Serial2/1/0] ppp mp mp-group 2/0/0
· interface mp-group
ppp mp short-sequence命令用来触发MP短序协商,协商成功后本端接收方向将使用短序。
undo ppp mp short-sequence命令用来恢复缺省情况。
不触发短序协商,使用长序。
配置该命令只能使接收方向更改为短序方式,如果发送方向想使用短序方式,则需要在对端配置该命令。
MP捆绑组使用的长短序方式由第一条加入该捆绑组中的子通道决定,后续加入捆绑组的子通道配置不能更改MP捆绑组的长短序方式。
如果想使用MP短序协商,对于普通MP,建议在所有的MP子通道下配置该命令。对于拨号MP,建议在Dialer接口和ISDN的D信道下均配置该命令。配置该命令会导致PPP重协商。
# 配置接口Serial2/1/0为MP短序协商。
[Sysname-Serial2/1/0] ppp mp short-sequence
# 配置接口VT1为MP短序协商。
[Sysname-Virtual-Template1] ppp mp short-sequence
ppp mp sort-buffer-size命令用来配置MP排序窗口的大小系数。
undo ppp mp sort-buffer-size命令用来恢复缺省情况。
ppp mp sort-buffer-size size
MP排序窗口大小系数为1。
虚拟模板接口视图
Dialer接口视图
MP-group接口视图
MP排序窗口大小=MP当前加入的子通道个数×size。其中,MP当前加入的子通道个数可以通过display ppp mp命令查询。如果计算出来的MP排序窗口大小为20,则表示可对20个报文进行排序。
在MP情况下,接收端收到的报文很可能乱序。因此需要对接收到的报文进行排序。窗口越大排序结果越好,但会增大报文的延迟。对于语音报文,应避免出现延时过大的问题。
# 配置MP排序窗口的大小系数为。
[Sysname-MP-group2/0/0] ppp mp sort-buffer-size 64
ppp mp timer lost-fragment命令用来配置MP等待期望分片报文的时间。
undo ppp mp timer lost-fragment命令用来恢复缺省情况。
ppp mp timer lost-fragment seconds
MP等待期望分片报文的时间为30秒。
虚拟模板接口视图
Dialer接口视图
MP-group接口视图
seconds:表示MP等待期望分片报文的时间,取值范围为1~255,单位为秒。
MP报文被分片发送后,接收端会将这些分片重新组装成一个报文。当接收端收到分片报文后,会先将这些分片报文放到缓冲区中,待收到该报文的所有分片后,再将分片组装起来。用户可以配置MP等待期望分片报文的时间。当接收端收到某报文的第一个分片后,就开启等待期望分片报文的定时器,当这个定时器超时后,系统查看是否收到了该报文的所有分片,如果已经收到了所有分片,则将分片报文组装起来;如果收到的分片不完整,则认为分片报文丢失,将已经收到的该报文的所有分片都丢弃,以空出缓冲区。
# 配置MP等待期望分片报文的时间为20秒。
[Sysname-MP-group2/0/0] ppp mp timer lost-fragment 20
ppp mp user命令用来配置根据用户名进行MP捆绑。
undo ppp mp user命令用来删除根据用户名进行MP捆绑。
ppp mp user username bind virtual-template number
undo ppp mp user username
不根据用户名进行MP捆绑。
username:用户名,为1~80个字符的字符串,区分大小写。
bind virtual-template number:绑定的虚拟模板接口。number用来指定虚拟模板接口号,取值范围为0~1023。
在PPP建立连接的过程中,当PPP认证通过后,如果该用户名指定的虚拟模板接口存在,则将按照虚拟模板接口的参数进行MP捆绑,并创建一个VA口进行数据传输。
在虚拟模板接口上可以配置的工作参数包括:
· 本地IP地址和为PPP对端分配的IP地址(或地址池)
· ppp mp相关命令
# 指定用户名user1对应的虚拟模板接口为1,并配置该虚拟模板接口的IP地址是202.38.60.1/24。
[Sysname] ppp mp user user1 bind virtual-template 1
[Sysname] interface virtual-template 1
[Sysname-Virtual-Template1] ip address 202.38.60.1 255.255.255.0
· ppp mp
ppp mp virtual-template命令用来将当前接口加入指定的虚拟模板接口,使接口工作在MP方式。
ppp mp virtual-template number
undo ppp mp
接口工作在普通PPP方式下。
number:接口所要绑定的虚拟模板接口号。取值范围为0~1023。
本命令实现了在接口上指定要绑定的虚拟模板接口号,将该接口绑定到指定的虚拟模板接口上。配置该命令的接口进行MP绑定时,可以不用配置PAP、CHAP、MSCHAP或MSCHAPv2认证。
两个或多个配置了相同虚拟模板接口号的接口直接绑定在一起。另外,在接口上该命令与ppp mp命令互斥,即同一个接口只能配置这两条命令中的一条。
# 配置封装PPP的接口Serial2/1/0工作在MP方式下,绑定的虚拟模板接口为Virtual-Template1。
[Sysname-Serial2/1/0] ppp mp virtual-template 1
· ppp mp
reset counters interface mp-group命令用来清除MP-group接口的统计信息。
reset counters interface [ mp-group [ interface-number ] ]
mp-group [ interface-number ]:清除MP-group接口的统计信息。interface-number表示MP-group接口的编号,取值范围为已创建的MP-group接口的编号。如果不指定mp-group和interface-number,则清除除VA接口外所有接口的统计信息;如果指定mp-group而不指定interface-number,则清除所有MP-group接口的统计信息;如果同时指定mp-group和interface-number,则清除指定MP-group接口的统计信息。
# 清除接口MP-group2/0/0的统计信息。
<Sysname> reset counters interface mp-group 2/0/0
· display interface mp-group
shutdown命令用来关闭接口。
undo shutdown命令用来打开接口。
shutdown
接口处于打开状态。
MP-group接口视图
执行本命令关闭接口会导致基于当前接口的MP功能不可用。建议您在执行该命令前,完全了解其对网络产生的影响。
# 关闭接口MP-group2/0/0。
display pppoe-server packet statistics命令用来显示PPPoE的协商报文统计信息。
(独立运行模式)
display pppoe-server packet statistics [ slot slot-number ]
display pppoe-server packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的PPPoE Server的报文统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板的PPPoE Server报文统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的PPPoE Server的报文统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备上所有单板的PPPoE Server报文统计信息。(IRF模式)
# 显示接口板Slot2上PPPoE Server协商报文统计信息。(独立运行模式)
<Sysname> display pppoe-server packet statistics slot 2
PPPoE Server packet statistics in slot 2:
RECV_PADI_PKT : 10 DISCARD_PADI_PKT : 0
SEND_PADO_PKT : 10
RECV_PADR_PKT : 10 DISCARD_PADR_PKT : 0
SEND_PADS_PKT : 10
RECV_PADT_PKT : 9 DISCARD_PADT_PKT : 0
SEND_PADT_PKT : 9
# 显示成员设备1的接口板Slot2上PPPoE Server协商报文统计信息。(IRF模式)
<Sysname> display pppoe-server packet statistics chassis 1 slot 2
PPPoE Server packet statistics in chassis 1 slot 2:
RECV_PADI_PKT : 834826 DISCARD_PADI_PKT : 1277
SEND_PADO_PKT : 833471
RECV_PADR_PKT : 833357 DISCARD_PADR_PKT : 0
SEND_PADS_PKT : 833357
RECV_PADT_PKT : 833253 DISCARD_PADT_PKT : 0
SEND_PADT_PKT : 295671
表2-1 display pppoe-server packet statistics命令显示信息描述表
RECV_PADI_PKT |
收到的PADI报文计数 |
DISCARD_PADI_PKT |
丢弃收到的PADI报文计数 |
SEND_PADO_PKT |
发送的PADO报文计数 |
RECV_PADR_PKT |
收到的PADR报文计数 |
DISCARD_PADR_PKT |
丢弃收到的PADR报文计数 |
SEND_PADS_PKT |
发送的PADS报文计数 |
RECV_PADT_PKT |
收到的PADT报文计数 |
DISCARD_PADT_PKT |
丢弃收到的PADT报文计数 |
SEND_PADT_PKT |
发送的PADT报文计数 |
· reset pppoe-server packet statistics
display pppoe-server session packet命令用来显示PPPoE会话的数据报文统计信息。
(独立运行模式)
display pppoe-server session packet { slot slot-number | interface interface-type interface-number }
display pppoe-server session packet { chassis chassis-number slot slot-number | interface interface-type interface-number }
interface interface-type interface-number:显示指定接口的PPPoE会话的数据报文统计信息。interface-type interface-number用来指定接口的类型和编号。
slot slot-number:显示指定单板的PPPoE会话的数据报文统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的PPPoE会话的数据报文统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 查看GigabitEthernet2/0/1接口的PPPoE会话的数据报文统计信息。
<Sysname> display pppoe-server session packet interface gigabitethernet 2/0/1
Total PPPoE sessions: 2
Ethernet interface: GE2/0/1 Session ID: 1
InPackets: 37 OutPackets: 38
InBytes: 390 OutBytes: 406
InDrops: 0 OutDrops: 0
Ethernet interface: GE2/0/1 Session ID: 2
InPackets: 67 OutPackets: 48
InBytes: 490 OutBytes: 806
InDrops: 1 OutDrops: 2
表2-2 display pppoe-server session packet命令显示信息描述表
Ethernet interface |
PPPoE会话绑定的接口 |
Session ID |
PPPoE会话的编号 |
InPackets |
接收报文数 |
OutPackets |
发送报文数 |
InBytes |
接收字节数 |
OutBytes |
发送字节数 |
InDrops |
接收非法并丢弃的报文数 |
OutDrops |
发送非法并丢弃的报文数 |
display pppoe-server session summary命令用来显示PPPoE会话的摘要信息。
(独立运行模式)
display pppoe-server session summary { slot slot-number | interface interface-type interface-number }
display pppoe-server session summary { chassis chassis-number slot slot-number | interface interface-type interface-number }
interface interface-type interface-number:显示指定接口的PPPoE会话的摘要信息。interface-type interface-number用来指定接口的类型和编号。
slot slot-number:显示指定单板的PPPoE会话的摘要信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的PPPoE会话的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
通过物理接口上线的PPPoE会话信息只在物理接口所在单板显示,通过逻辑接口上线的全局PPPoE会话信息将在所有单板显示。
# 查看GigabitEthernet2/0/1接口的PPPoE会话的摘要信息。
<Sysname> display pppoe-server session summary interface gigabitethernet 2/0/1
PPP interface: VA1 State: PADR_RCVD
Remote MAC: 00e0-1500-7100 Local MAC: 00e0-1400-7300
Service VLAN: N/A Customer VLAN: N/A
PPP interface: VA2 State: OPEN
Remote MAC:00e0-1600-7200 Local MAC: 00e0-1400-7400
Service VLAN: 2 Customer VLAN: 155
# 配置指定Slot上的PPPoE会话的摘要信息。(独立运行模式)
<Sysname> display pppoe-server session summary slot 2
Total PPPoE sessions on slot 2: 2
Local PPPoE sessions on slot 2: 1
Ethernet interface: GE2/0/2 Session ID: 1
PPP interface: VA1 State: OPEN
Remote MAC: 0000-0000-0005 Local MAC: 0000-5e00-0101
Ethernet interface: RAGG1 Session ID: 1
PPP interface: VA0 State: OPEN
Remote MAC: 0050-56c0-0005 Local MAC: 0000-5e00-0102
表2-3 display pppoe-server session summary命令显示信息描述表
Total PPPoE sessions |
上线PPPoE会话总数(物理接口上线的PPPoE会话和全局PPPoE会话总数) |
Local PPPoE sessions |
通过物理接口上线的PPPoE会话总数 (当命令行中指定了接口时,不显示本字段) |
PPPoE会话绑定的接口 |
Session ID |
PPPoE会话的编号 |
PPP interface |
PPPoE会话的VA接口号 |
State |
PPPoE会话的状态,取值如下: · PADR_RCVD:表示PPPoE会话正在创建中,处于会话协商阶段 · OPEN:表示PPPoE处于会话阶段 |
Remote MAC |
对端MAC地址 |
Local MAC |
本端MAC地址 |
Service VLAN |
服务提供商VLAN(N/A表示没有此信息) |
Customer VLAN |
用户VLAN(N/A表示没有此信息) |
display pppoe-server throttled-mac命令用来显示被扼制的PPPoE用户信息。
(独立运行模式)
display pppoe-server throttled-mac { slot slot-number | interface interface-type interface-number }
display pppoe-server throttled-mac { chassis chassis-number slot slot-number | interface interface-type interface-number }
interface interface-type interface-number:显示指定接口下的被扼制的用户信息。interface-type interface-number用来指定接口的类型和编号。
slot slot-number:显示指定单板的被扼制的用户信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的被扼制的用户信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 查看GigabitEthernet2/0/1接口的被扼制的用户信息。
<Sysname> display pppoe-server throttled-mac interface gigabitethernet 2/0/1
Total 3 client MACs:
Interface Remote MAC Start time Remaining time(s)
GE2/0/1 00e0-1500-4100 2010-12-01,12:10:30 55
GE2/0/1 00e0-1500-4000 2010-12-01,12:10:40 65
GE2/0/1 00e0-1500-3300 2010-12-01,12:10:50 75
表2-4 display pppoe-server throttled-mac命令显示信息描述表
被扼制的用户的上线接口 |
Remote MAC |
用户的MAC地址 |
Start time |
开始扼制的时间 |
Remaining time(s) |
剩余扼制时间,单位为秒 |
· pppoe-server throttle per-mac
display pppoe-server va-pool命令用来显示VA池信息。
# 显示VA池信息。(独立运行模式)
<Sysname> display pppoe-server va-pool
Location VT interface Size Unused/State
Virtual-Template1 1000 900
0/cpu1 Virtual-Template2 1000 1000
表2-5 display pppoe-server va-pool命令显示信息描述表
Location |
VA池所在的成员设备、单板和CPU(显示“-”时表示全局VA池;不支持按CPU显示的设备则显示“*”,例如2/0/*) |
VT interface |
使用VA池的虚拟模板 |
Size |
用户申请的VA池容量 |
Unused/State |
用户可以使用的VA池容量/VA池当前的状态(Creating表示正在创建VA池;Destroying表示正在删除VA池) |
· pppoe-server virtual-template va-pool
ppp lcp echo mru verify命令用来开启PPPoE应用的MRU检测功能。
undo ppp lcp echo mru verify命令用来关闭PPPoE应用的MRU检测功能。
ppp lcp echo mru verify [ minimum value ]
PPPoE应用的MRU检测功能处于关闭状态。
虚拟模板接口视图
minimum value:指定用来进行监测的最小MRU,取值范围为64~1500。
PPPoE应用为了支持大于1492的MTU,在PPPoE协商中增加PPP-Max-Payload选项,标识当前PPPoE会话所能支持的最大MTU。如果此MTU大于1492,则PPP在LCP协商中将会使用此最大值作为MRU的上限进行协商,协商完成后上报MTU。
有时为避免协商的MRU大于接口的实际收发能力,需要开启MRU检测功能。开启本功能后,对于PPPoE Server应用,如果在LCP协商完成后,LCP协商到的MRU大于1492,则开始进行如下检测处理:
(1) 设备向对端发送MRU大小的Echo-Request报文,如果能够收到Echo-Reply报文,则按照此MRU大小上报MTU;
(2) 如果不能收到Echo-Reply报文,则进行第二次检测;
(3) 如果指定了进行监测的最小MRU,则第二次检测使用指定的最小MRU进行;否则第二次检测仍将使用第一次检测时的MRU大小进行。
(4) 如果两次检测都没有通过,则断开PPP链路。
开启本功能时,网络层NCP协商将会延后启动,只有当检测通过之后再启动NCP协商。
# 在虚拟模板接口10上开启PPPoE应用的MRU检测功能,MRU最小值为1200。
[Sysname] interface virtual-template 10
[Sysname-Virtual-Template10] ppp lcp echo mru verify minimum 1200
pppoe-server access-delay命令用来配置用户接入响应延迟时间。
undo pppoe-server access-delay命令用来恢复缺省情况。
pppoe-server access-delay delay-time
对用户接入响应不延迟。
三层以太网接口视图/三层以太网子接口视图
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
delay-time:用户接入响应延迟时间,取值范围为10~25500,单位为毫秒。
本命令用来配置PPPoE Server对接入用户进行响应的延迟时间,系统按照配置的时间延迟响应从此接口上线用户的首个报文。
# 在接口GigabitEthernet2/0/1上配置用户接入响应延迟时间为100毫秒。
[Sysname-GigabitEthernet2/0/1] pppoe-server access-delay 100
pppoe-server access-line-id bas-info命令用来配置在NAS-PORT-ID属性中自动插入BAS信息。
undo pppoe-server access-line-id bas-info命令用来恢复缺省情况。
pppoe-server access-line-id bas-info [ cn-163 ]
在NAS-PORT-ID属性中不自动插入BAS信息。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
cn-163:插入中国电信163格式的BAS信息。不指定本参数时,插入中国电信格式的BAS信息。
BAS信息的格式分为两种:中国电信格式和中国电信163格式。
· 中国电信格式的BAS信息格式:{atm|eth|trunk} NAS_slot/NAS_subslot/NAS_port:XPI.XCI,表示BRAS设备上的用户接入端口信息,包括BRAS上用户接入端口的VLAN、VPI/VCI等信息(当使用ATM/DSL时,XPI.XCI表示VPI/VCI信息;当使用Ethernet/DSL时,XPI.XCI表示VLAN信息)。例如:eth 2/0/1:4096.2345,其含义为:BRAS设备上的用户接入端口为:上行接口类型为以太网接口,接口所在槽号为1、子槽号为0、端口号为1,外层VLAN ID为4096(4096表示无效VLAN),内层VLAN ID为2345。
· 中国电信163格式的BAS信息格式如表2-6所示。其中,NAS_slot/NAS_subslot/NAS_port表示BAS设备上PPPoE用户接入的接口编号信息,vpi、vci表示VPI、VCI信息,vlanid、vlanid2表示VLAN信息,其中vlanid表示内层VLAN,vlanid2表示外层VLAN,主接口的vlanid总为0。
表2-6 中国电信163格式的BAS信息格式
接口类型 |
BAS信息格式 |
ATM接口 |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vpi=XPI;vci=XCI; |
主接口或没有携带双层VLAN信息的接口 |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=VLAN id; |
携带双层VLAN信息的接口 |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=VLAN id;vlanid2=VLAN id2; |
本命令用来配置是否在NAS-PORT-ID属性中自动插入BAS信息:
· 如果配置为不自动插入BAS信息,则BAS设备上传给RADIUS服务器的NAS-PORT-ID属性由命令pppoe-server access-line-id content决定。
· 如果配置为自动插入BAS信息,则BAS设备最终上传给RADIUS服务器的NAS-PORT-ID属性内容将由本命令决定:
¡ 如果插入中国电信163格式的BAS信息,则将相应的BAS信息插入到解析时新构造的circuit-id前面,并将此“BAS信息+circuit-id”内容作为NAS-PORT-ID属性上传给RADIUS服务器。
¡ 如果插入中国电信格式的BAS信息,则将相应的BAS信息和原circuit-id信息里的DSLAM上的用户接入信息拼装成中国电信格式的circuit-id,并将此中国电信格式的circuit-id内容作为NAS-PORT-ID属性上传给RADIUS服务器。
需要注意的是,当在NAS-PORT-ID属性中插入BAS信息时,若NAS-PORT-ID属性中还包含remote-id,会导致RADIUS服务器无法正确解析。所以,用户需要通过配置保证,在BAS设备信任接收到的报文中的接入线路ID的内容的情况下插入BAS信息时,上传给RADIUS服务器的NAS-PORT-ID属性的内容中仅包含circuit-id,不能包含remote-id。
# 在接口GigabitEthernet2/0/1上配置在NAS-PORT-ID属性中自动插入BAS信息。
[Sysname-GigabitEthernet2/0/1] pppoe-server access-line-id bas-info
· pppoe-server access-line-id circuit-id parse-mode
· pppoe-server access-line-id content
· pppoe-server access-line-id trust
pppoe-server access-line-id circuit-id parse-mode命令用来配置接入线路ID中circuit-id的解析格式。
undo pppoe-server access-line-id circuit-id parse-mode命令用来恢复缺省情况。
pppoe-server access-line-id circuit-id parse-mode { cn-telecom | tr-101 }
接入线路ID中circuit-id的解析格式为TR-101格式。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
cn-telecom:中国电信格式。
tr-101:TR-101格式。
circuit-id的格式分为两种:TR-101格式和中国电信格式。本命令用来设置设备采用哪种格式来解析circuit-id。
(1) TR-101格式
TR-101格式如下:
· 当使用ATM/DSL时,格式为:Access-Node-Identifier atm frame/slot/subslot/port:vpi.vci。
· 当使用Ethernet/DSL时,格式为:Access-Node-Identifier eth frame/slot/subslot/port[:vlan-id]。
表示DSLAM上的用户接入信息,其中,Access-Node-Identifier表示接入节点标识符(即DSLAM设备标识符),后半部分的信息表示DSLAM上用户接入的接口信息(其中,frame表示机框号)。
(2) 中国电信格式
中国电信格式如下:AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port[:ANI_XPI.ANI_XCI]。表示DSLAM上的用户接入信息,包括DSLAM设备标识符、用户接入接口等信息。
例如:guangzhou001/1/31/63/31/127,其含义为接入节点DSLAM的标识为guangzhou001,DSLAM的机架号为1,用户接入接口所在机框号为31,槽号为63,子槽号为31,端口号为127。
# 配置接口GigabitEthernet2/0/1采用中国电信格式来解析接入线路ID中circuit-id。
[Sysname-GigabitEthernet2/0/1] pppoe-server access-line-id circuit-id parse-mode cn-telecom
· pppoe-server access-line-id circuit-id trans-format
pppoe-server access-line-id circuit-id trans-format命令用来配置接入线路ID中circuit-id的传输格式。
undo pppoe-server access-line-id circuit-id trans-format命令用来恢复缺省情况。
pppoe-server access-line-id circuit-id trans-format { ascii | hex }
接入线路ID中circuit-id的传输格式为字符串格式。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
ascii:字符串格式。
hex:十六进制格式。
circuit-id可以选择使用字符串或者十六进制的格式进行传输。
比如circuit-id的内容为00010002,则使用不同格式传输时,其报文内容如下(前两个字节为TYPE和Length的值):
· 字符串格式:01 08 30 30 30 31 30 30 30 32
· 十六进制格式:01 04 00 01 00 02
# 配置接口GigabitEthernet2/0/1使用十六进制格式传输circuit-id。
[Sysname-GigabitEthernet2/0/1] pppoe-server access-line-id circuit-id trans-format hex
pppoe-server access-line-id content命令用来设置上传给RADIUS服务器的NAS-PORT-ID属性中包含的内容。
undo pppoe-server access-line-id content命令用来恢复缺省情况。
pppoe-server access-line-id content { all [ separator ] | circuit-id | remote-id }
上传给RADIUS服务器的NAS-PORT-ID属性中仅包含circuit-id。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
all:上传circuit-id和remote-id。
separator:分隔符,长度为一个字符,缺省情况下为空格。circuit-id与remote-id通过该分隔符连接在一起后上传。
circuit-id:仅上传circuit-id。
remote-id:仅上传remote-id。
在含有DSLAM的组网中,DSLAM通过接入线路ID(access-line-id)把用户的物理位置信息传送给BAS设备(PPPoE Server功能部署在BAS设备上),接入线路ID的内容包括circuit-id和remote-id两部分(circuit-id的介绍请参见pppoe-server access-line-id circuit-id parse-mode命令,remote-id的介绍请参见pppoe-server access-line-id remote-id trans-format命令)。BAS设备采用一定的规则解析接入线路ID后,把解析后的内容通过RADIUS的NAS-PORT-ID属性发送给RADIUS服务器,RADIUS服务器通过收到的NAS-PORT-ID属性和数据库中已配置好的物理位置信息比较,验证用户的物理位置信息是否正确。
分隔符可以是所有可见字符,但如果用户配置的分隔符是可能出现在circuit-id和remote-id两个字符串中的字符,则会使最终RADIUS服务器解析的结果不可预知,所以需要选择合适的分隔符。
在没有配置pppoe-server access-line-id bas-info命令的情况下,上传给RADIUS服务器的NAS-PORT-ID属性中包含的内容由本命令的配置决定。在配置了pppoe-server access-line-id bas-info命令的情况下,上传给RADIUS服务器的NAS-PORT-ID属性中包含的内容请参见pppoe-server access-line-id bas-info命令的介绍。
# 配置接口GigabitEthernet2/0/1仅上传circuit-id给RADIUS服务器。
[Sysname-GigabitEthernet2/0/1] pppoe-server access-line-id content circuit-id
· pppoe-server access-line-id bas-info
· pppoe-server access-line-id remote-id trans-format
pppoe-server access-line-id remote-id trans-format命令用来配置接入线路ID中remote-id的传输格式。
undo pppoe-server access-line-id remote-id trans-format命令用来恢复缺省情况。
pppoe-server access-line-id remote-id trans-format { ascii | hex }
接入线路ID中remote-id的传输格式为字符串格式。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
ascii:字符串格式,指的是用字符形式传送remote-id信息。
hex:十六进制格式,指的是用十六进制数字传送remote-id信息。
remote-id为PPPoE中继设备(比如DSLAM)的系统MAC地址。remote-id可以选择使用字符串或者十六进制的格式进行传输。
# 配置接口GigabitEthernet2/0/1上使用十六进制格式传输remote-id。
[Sysname-GigabitEthernet2/0/1] pppoe-server access-line-id remote-id trans-format hex
pppoe-server access-line-id trust命令用来配置设备信任接收到的报文中的接入线路ID的内容。
undo pppoe-server access-line-id trust命令用来恢复缺省情况。
设备不信任接收到的报文中的接入线路ID的内容。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
本命令用来配置设备是否信任接收到的报文中的接入线路ID的内容:
· 当设置为信任模式时,BAS设备会解析收到报文中携带的circuit-id和remote-id的信息,并根据解析出来的信息构造新的circuit-id和remote-id。
· 当设置为不信任模式时,BAS设备将不再解析报文中携带的circuit-id和remote-id的信息,新构造的circuit-id和remote-id的内容均为空。
需要注意的是,当设置为信任模式时,如果解析PADR报文中的circuit-id或remote-id失败,则丢弃此PADR报文,不回应PADS。
# 在接口GigabitEthernet2/0/1上配置信任接收到的报文中的接入线路ID的内容。
[Sysname-GigabitEthernet2/0/1] pppoe-server access-line-id trust
pppoe-server bind命令用来在接口上启用PPPoE Server协议,将该接口与虚拟模板接口绑定。
undo pppoe-server bind命令用来在相应接口关闭PPPoEServer协议。
pppoe-server bind virtual-template number
接口上的PPPoE Server协议处于关闭状态。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
virtual-template number:指定虚拟模板接口。number表示虚拟模板接口号。取值范围为0~1023。
接口上启用PPPoE Server协议时,可以绑定不存在的虚拟模板。
如果接口上已经启用PPPoE Server绑定了虚拟模板接口,则不能直接使用该命令绑定新的虚拟模板接口,需要先关闭PPPoE Server协议后,再重新启用PPPoE Server时绑定新的虚拟模板接口。
如果在接口上同时启用PPPoE Client与PPPoE Server功能,则PPPoE Client功能不生效。
# 在接口GigabitEthernet2/0/1上启用PPPoE Server协议,将接口GigabitEthernet2/0/1与虚拟模板接口Virtual-Template1绑定。
[Sysname-GigabitEthernet2/0/1] pppoe-server bind virtual-template 1
pppoe-server session-limit命令用来配置接口上所能创建PPPoE会话的最大数目。
undo pppoe-server session-limit命令用来恢复缺省情况。
pppoe-server session-limit number
不限制接口上所能创建PPPoE会话的数目。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
number:接口上所能创建PPPoE会话的最大数目,取值范围为1~65534。
系统创建会话时,需同时满足如下限制,若其中任何一项不满足,则无法创建会话:
· 接口下每个用户所能创建PPPoE会话的最大数目限制
· 接口下每个VLAN所能创建PPPoE会话的最大数目限制
· 接口上所能创建PPPoE会话的最大数目限制
· 单板所能创建PPPoE会话的最大数目限制
本命令配置后仅对新创建的PPPoE会话有效,对已经创建的PPPoE会话无效,即不会导致已经上线的用户下线。
# 配置接口GigabitEthernet2/0/1上所能创建PPPoE会话的最大数目为50。
[Sysname-GigabitEthernet2/0/1] pppoe-server session-limit 50
· pppoe-server session-limit per-mac
· pppoe-server session-limit per-vlan
· pppoe-server session-limit total
pppoe-server session-limit per-mac命令用来配置在接口上每个用户所能创建PPPoE会话的最大数目。
undo pppoe-server session-limit per-mac命令用来恢复缺省情况。
pppoe-server session-limit per-mac number
每个用户可创建100个PPPoE会话。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
number:每个用户所能创建PPPoE会话的最大数目,取值范围为1~65534。
每个用户通过MAC地址进行标识。
# 配置在接口GigabitEthernet2/0/1下,每个用户所能创建PPPoE会话的最大数目为50。
[Sysname-GigabitEthernet2/0/1] pppoe-server session-limit per-mac 50
pppoe-server session-limit per-vlan命令用来配置在接口上每个VLAN所能创建PPPoE会话的最大数目。
undo pppoe-server session-limit per-vlan命令用来恢复缺省情况。
pppoe-server session-limit per-vlan number
不限制每个VLAN所能创建PPPoE会话的数目。
三层以太网子接口视图
三层聚合子接口视图
L3VE子接口视图
number:每个VLAN所能创建PPPoE会话的最大数目,取值范围为1~65534。
# 配置在子接口GigabitEthernet2/0/1.1下,每个VLAN所能创建PPPoE会话的最大数目为50。
[Sysname] interface gigabitethernet 2/0/1.1
[Sysname-GigabitEthernet2/0/1.1] pppoe-server session-limit per-vlan 50
· pppoe-server sessions limit
· pppoe-server sessions limit per-mac
· pppoe-server sessions limit total
pppoe-server session-limit total命令用来配置系统所能创建PPPoE会话的最大数目。
undo pppoe-server session-limit total命令用来恢复缺省情况。
(独立运行模式)
pppoe-server session-limit slot slot-number total number
undo pppoe-server session-limit slot slot-number total
pppoe-server session-limit chassis chassis-number slot slot-number total number
undo pppoe-server session-limit chassis chassis-number slot slot-number total
不限制单板所能创建PPPoE会话的数目。
number:系统所能创建PPPoE会话的最大数目,取值范围为1~65534。
slot slot-number total number:指定单板所能创建PPPoE会话的最大数目。slot-number表示单板所在的槽位号,number的取值范围为1~65534。(独立运行模式)
chassis chassis-number slot slot-number total number:指定成员设备上指定单板所能创建PPPoE会话的最大数目。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,number的取值范围为1~65534。(IRF模式)
# 配置指定slot上所能创建PPPoE会话的最大数目为3000。(独立运行模式)
[Sysname] pppoe-server session-limit slot 2 total 3000
# 配置指定成员设备指定slot上的所能创建PPPoE会话的最大数目为3000。(IRF模式)
[Sysname] pppoe-server session-limit chassis 1 slot 2 total 3000
pppoe-server tag ac-name命令用来配置PPPoE Server的AC Name(Access Concentrator Name,接入集中器名称)。
undo pppoe-server tag ac-name命令用来恢复缺省情况。
pppoe-server tag ac-name name
PPPoE Server的AC Name为设备名称。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
name:AC Name,为1~64个字符的字符串,区分大小写。
本命令用来配置PPPoE Server的AC Name,PADO报文中会携带AC Name,PPPoE Client可以根据AC Name来选择PPPoE Server(H3C实现的PPPoE Client暂不支持该功能)。
需要注意的是,系统不支持全部空格的AC Name。
# 在接口GigabitEthernet2/0/1上配置PPPoE Server的AC Name为pppoes。
[Sysname-GigabitEthernet2/0/1] pppoe-server tag ac-name pppoes
pppoe-server tag ppp-max-payload命令用来配置设备支持PPP最大负载TAG,并指定最大负载的范围。
undo pppoe-server tag ppp-max-payload命令用来恢复缺省情况。
pppoe-server tag ppp-max-payload [ minimum min-number maximum max-number ]
不支持PPP最大负载TAG。PPPoE Server不支持此TAG,此时如果收到的PADI和PADR报文中包含此TAG,则直接忽略,不在回应的PADO和PADS报文中携带此TAG。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
minimum min-number:最大负载的最小值,取值范围为64~4470,单位为字节,缺省值为1492。
maximum max-number:最大负载的最大值,取值范围为64~4470,单位为字节,缺省值为1500。max-number值要大于等于min-number 值。
PPP最大负载TAG主要提供对PPP的载荷超过1492的大报文支持,最大程度上减少报文的分片。PPP最大负载TAG包含在PPPoE Client端发送的PADI和PADR报文里。如果PPPoE Client端发送的此TAG值处于本命令配置的范围内,则PPPoE Server将此TAG原样拷贝至回复的PADO和PADS报文中;否则就认为报文的请求无效,不向PPPoE Client端回复PADO或PADS报文。
需要注意的是,jumboframe enable命令可以改变接口支持的超长帧的大小,jumboframe enable命令配置的超长帧的最大长度应大于pppoe-server tag ppp-max-payload命令配置的最大负载的最大值。
# 使能对PPP最大负载TAG的支持,并指定最大负载的范围为1494~1508字节。
[Sysname-GigabitEthernet2/0/1] pppoe-server tag ppp-max-payload minimum 1494 maximum 1508
· jumboframe enable(接口管理命令参考/以太网接口)
pppoe-server tag service-name命令用来配置PPPoE Server的Service Name。
undo pppoe-server tag service-name命令用来恢复缺省情况。
pppoe-server tag service-name name
PPPoE Server的Service Name为空。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
name:Service Name,为1~64个字符的字符串,区分大小写。
当组网环境中存在两个或者两个以上PPPoE Server提供不同的服务时,PPPoE Client可以根据自身的Service Name选择不同的服务器来建立连接,这时PPPoE Server将根据本机上的Service Name来进行匹配处理。
当PPPoE Server收到客户端的PADI/PADR报文时,需要检查报文中的Service Name TAG字段并和本机上配置的Service Name进行匹配,具体处理过程有以下两步:
(1) PPPoE Server将收到PADI报文中的Service-Name TAG字段与本地配置的Service Name进行匹配,且匹配规则如下:
· 如果PPPoE Server端配置了Service Name,则需要进行精确匹配,只有二者相同,服务器端才会接受并回应PADO报文;如果不相同或者此TAG字段内容为空,则不接受。
· 如果PPPoE Server端没有配置Service Name,则不论此TAG字段内容是否为空,服务器端都将接受并回应PADO报文。
(2) PPPoE Server将收到PADR报文中的Service-Name TAG字段与本地配置的Service Name进行匹配,且匹配规则如下:
· 如果PPPoE Server端配置了Service Name,则需要进行精确匹配,只有二者相同,服务器端才会接受并回应PADS报文和创建Session;如果不相同或者此TAG字段内容为空,则不能创建Session。
· 如果PPPoE Server端没有配置Service Name,则不论此TAG字段内容是否为空,服务器端都将接受并回应PADS报文和创建Session。
# 在接口GigabitEthernet2/0/1上配置PPPoE Server的Service Name为pppoes。
[Sysname-GigabitEthernet2/0/1] pppoe-server tag service-name pppoes
pppoe-server throttle per-mac命令用来配置接口允许每个用户创建会话的速度。
undo pppoe-server throttle per-mac命令用来恢复缺省情况。
pppoe-server throttle per-mac session-requests session-request-period blocking-period
不限制会话建立的速度。
VEth接口视图
VLAN接口视图
三层聚合接口视图/三层聚合子接口视图
L3VE接口视图/L3VE子接口视图
session-requests:在监视时间段内允许每个用户的会话数目,取值范围为1~100000。
session-request-period:监视时间,取值范围为1~3600,单位为秒。
blocking-period:扼制时间,取值范围为0~3600,单位为秒。
设备可以通过此命令来限制特定接口下每个用户(每个用户通过MAC地址进行标识)创建会话的速度。如果用户建立会话的速度达到门限值,即在监视时间段内该用户的会话请求数目超过本命令配置的允许数目,则扼制该用户的会话请求,即在监视时间段内该用户的超出允许数目的请求都会被丢弃,并输出对应的Log信息。如果扼制时间配置为0,表示不扼制会话请求,但仍然会输出Log信息。
系统使用监控表和扼制表来共同控制用户创建会话的速度:
监视表:监视各用户在监视时间周期内创建的会话数。监视表的规格为8K。当监视表达到规格时,对新用户的会话请求不进行监视和扼制,正常建立会话。监视表项的老化时间为配置的session-request-period值,老化后对用户重新监视。
扼制表:当某用户建立会话的速度超过门限值时,会将该用户的信息加入扼制表,扼制该用户的会话请求。扼制表规格为8K。当扼制表达到规格时,对新用户的会话请求只进行监视和发送Log信息,但不触发扼制。扼制表项的老化时间为配置的blocking-period值,老化后对用户重新监视。
修改本命令的配置后,系统将删除已记录的监视表和扼制表,重新开始监视每个用户的会话请求。
# 配置接口允许每个用户创建会话的速度。
[Sysname-GigabitEthernet2/0/1] pppoe-server throttle per-mac 100 100 5
· display pppoe-server throttled-mac
pppoe-server virtual-template va-pool命令用来配置VA池。
undo pppoe-server virtual-template va-pool命令用来删除VA池。
(独立运行模式)
pppoe-server virtual-template template-number [ slot slot-number ] va-pool va-volume
undo pppoe-server virtual-template template-number [ slot slot-number ] va-pool
pppoe-server virtual-template template-number [ chassis chassis-number slot slot-number ] va-pool va-volume
undo pppoe-server virtual-template template-number [ chassis chassis-number slot slot-number ] va-pool
未配置VA池。
virtual-template template-number:指定需要使用VA池的虚拟模板接口。该接口必须已经存在。
va-pool va-volume:指定需要创建的VA池的大小,取值范围为1~65534。
slot slot-number:在指定单板上创建局部VA池。slot-number表示单板所在的槽位号。如果不指定本参数,则表示创建全局VA池。(独立运行模式)
chassis chassis-number slot slot-number:在指定成员设备的指定单板上创建局部VA池。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示创建全局VA池。(IRF模式)
PPPoE在建立连接时需要创建VA接口(VA接口用于PPPoE与PPP之间的报文传递),在用户下线后需要删除VA接口。由于创建/删除VA接口需要一定的时间,所以如果有大量用户上线/下线时,PPPoE的连接建立、连接拆除性能会受到影响。
使用VA池对PPPoE的连接建立、连接拆除性能有显著提高。VA池是在建立连接前事先创建的VA接口的集合。创建VA池后,当需要创建VA接口时,直接从VA池中获取一个VA接口,加快了PPPoE连接的建立速度。当用户下线后,直接把VA接口放入VA池中,不需要删除VA接口,加快了PPPoE连接的拆除速度。当VA池中的VA接口耗光后,仍需在建立PPPoE连接时再创建VA接口,在用户下线后删除VA接口。
每个虚拟模板接口只能关联一个全局VA池,在每个单板上只能关联一个局部VA池。通过某单板上的以太网接口上线的用户,只能使用上线以太网接口绑定的虚拟模板接口在该单板上关联的VA池。如果想要修改使用的VA池的大小,只能先删除原来的配置,然后重新配置VA池。
创建/删除VA池需要花费一定的时间,请用户耐心等待。在VA池创建/删除过程中(还没创建/删除完成)允许用户上线/下线,但正在创建/删除的VA池不生效。
系统可能由于资源不足不能创建用户指定容量的VA池,用户可以通过display pppoe-server va-pool命令查看实际可用的VA池的容量以及VA池的状态。
VA池会占用较多的系统内存,请用户根据实际情况创建合适大小的VA池。
删除VA池时,如果已有在线用户使用该VA池中的VA接口,不会导致这些用户下线。
# 为虚拟模板2创建容量为1000的VA池。
[Sysname] pppoe-server virtual-template 2 va-pool 1000
· display pppoe-server va-pool
reset pppoe-server命令用来在PPPoE Server端清除PPPoE会话。
reset pppoe-server { all | interface interface-type interface-number | virtual-template number }
all:清除全部PPPoE会话。
interface interface-type interface-number:清除指定接口的PPPoE会话。interface-type interface-number用来指定接口的类型和编号。
virtual-template number:清除指定虚拟模板接口的PPPoE会话。
# 在PPPoE Server端清除Virtual-template1上的PPPoE会话。
<Sysname> reset pppoe-server virtual-template 1
reset pppoe-server packet statistics命令用来清除PPPoE的协商报文统计信息。
(独立运行模式)
reset pppoe-server packet statistics [ slot slot-number ]
reset pppoe-server packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number:清除指定单板的PPPoE Server的报文统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,将清除所有单板的PPPoE Server报文统计信息。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的PPPoE Server的报文统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除所有成员设备上所有单板的PPPoE Server报文统计信息。(IRF模式)
# 清除接口板Slot2上的PPPoE Server的协商报文统计信息。(独立运行模式)
<Sysname> reset pppoe-server packet statistics slot 2
# 清除成员设备1的接口板Slot2上的PPPoE Server的协商报文统计信息。(IRF模式)
<Sysname> reset pppoe-server packet statistics chassis 1 slot 2
· display pppoe-server packet statistics
dialer diagnose命令用来配置DDR应用工作在诊断模式。
undo dialer diagnose命令用来恢复缺省情况。
dialer diagnose [ interval interval ]
DDR应用工作在非诊断模式。
Dialer接口视图
interval:诊断时间间隔,取值范围为5~65535,单位为秒,缺省值为120。
只有当Dialer接口用于PPPoE Client时,此配置才生效。
在PPPoE Client工作在诊断模式时,设备会在配置完成后立即发起PPPoE Client呼叫,建立链接,链接建立后隔interval时间,设备会自动断开该链接,并启动自动拨号定时器,等待自动拨号定时器超时再重新发起PPPoE Client呼叫建立链接。通过定期建立、删除呼叫,可以监控PPPoE Client链路是否处于正常工作状态。
当工作在诊断模式时,dialer timer idle命令配置的Idle定时器失效。
# 设置接口Dialer1工作在诊断模式,诊断时间间隔为300秒。
[Sysname] interface dialer 1
[Sysname-Dialer1] dialer diagnose interval 300
· dialer timer autodial(二层技术-广域网接入命令参考/DDR)
· dialer timer idle(二层技术-广域网接入命令参考/DDR)
display pppoe-client session packet命令用来显示PPPoE会话的协议报文统计信息。
display pppoe-client session packet [ dial-bundle-number number ]
dial-bundle-number number:显示指定PPPoE会话的协议报文统计信息。取值范围为0~1023。如果不指定PPPoE会话,则显示所有PPPoE会话的协议报文统计信息。
PPPoE会话的数据报文统计信息可以通过display interface virtual-access命令查看指定Virtual Access接口的详细信息获得。
# 显示所有PPPoE会话的协议报文统计信息。
<Sysname> display pppoe-client session packet
Bundle: 1 Interface: GE2/0/1
InPackets: 19 OutPackets: 19
InBytes: 816 OutBytes: 816
Bundle: 2 Interface: GE2/0/1
InPackets: 18 OutPackets: 18
InBytes: 730 OutBytes: 730
表2-7 display pppoe-client session packet命令显示信息描述表
Bundle |
PPPoE会话所属的Dialer bundle |
PPPoE会话对应的以太网接口,即在该以太网接口上建立PPPoE会话 |
InPackets |
接收报文数 |
OutPackets |
发送报文数 |
InBytes |
接收字节数 |
OutBytes |
发送字节数 |
InDrops |
接收非法并丢弃的报文数 |
OutDrops |
发送非法并丢弃的报文数 |
· reset pppoe-client session packet
display pppoe-client session summary命令用来显示PPPoE会话的概要信息。
display pppoe-client session summary [ dial-bundle-number number ]
dial-bundle-number number:显示指定PPPoE会话的概要信息。取值范围为0~1023。如果不指定PPPoE会话,则显示所有PPPoE会话的概要信息。
# 显示所有PPPoE会话的概要信息。
<Sysname> display pppoe-client session summary
Bundle ID Interface VA RemoteMAC LocalMAC State
1 1 GE2/0/1 VA0 00e0-1400-4300 00e0-1500-4100 SESSION
2 1 GE2/0/2 VA1 00e0-1500-4300 00e0-1600-4100 SESSION
表2-8 display pppoe-client session summary命令显示信息描述表
Bundle |
ID |
Session ID,PPPoE会话的编号 |
PPPoE会话所属的以太网接口 |
VA |
PPPoE会话创建的Virtual Access接口 |
RemoteMAC |
PPPoE会话所属的对端以太网接口的MAC地址 |
LocalMAC |
PPPoE会话所属的本端以太网接口的MAC地址 |
State |
PPPoE会话所处的状态: · IDLE:初始化状态 · PADI SENT:已发送PADI报文、等待PADO报文状态 · PADR SENT:已发送PADR报文、等待PADS报文状态 · SESSION:会话协商成功 |
pppoe-client命令用来建立一个PPPoE会话,并且指定该会话所对应的Dialer bundle。
undo pppoe-client命令用来删除一个PPPoE会话。
pppoe-client dial-bundle-number number [ no-hostuniq ]
undo pppoe-client dial-bundle-number number
接口下未配置PPPoE会话。
VEth接口视图
VLAN接口视图
三层聚合口视图/三层聚合子接口视图
dial-bundle-number number:与PPPoE会话相对应的Dialer bundle编号,取值范围为0~1023。参数number可以用来唯一标识一个PPPoE会话,也可以把它作为PPPoE会话的编号。
no-hostuniq:在PPPoE Client发起的呼叫中不携带Host-Uniq字段。缺省情况下,呼叫中携带Host-Uniq字段。Host-Uniq字段用来唯一标识一个PPPoE Client。当接口下配置了多个PPPoE会话时,为了区分不同PPPoE会话的报文,可以配置在PPPoE Client呼叫报文中携带Host-Uniq字段。PPPoE Server收到携带Host-Uniq字段的报文后,必须在应答报文中携带Host-Uniq字段,内容和请求报文中的Host-Uniq字段相同。设备收到PPPoE Server的应答报文后,根据Host-Uniq字段的值可以唯一确定应答报文所属的PPPoE Client。
# 在三层以太网接口GigabitEthernet2/0/1上建立一个PPPoE会话。
[Sysname-GigabitEthernet2/0/1] pppoe-client dial-bundle-number 1
# 在VLAN接口1上建立一个PPPoE会话。
[Sysname-Vlan-interface1] pppoe-client dial-bundle-number 1
# 在VSI虚接口1上建立一个PPPoE会话。
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] pppoe-client dial-bundle-number 1
reset pppoe-client命令用来复位PPPoE会话。
reset pppoe-client { all | dial-bundle-number number }
all:复位所有的PPPoE会话。
dial-bundle-number number:复位与指定Dialer bundle相对应的PPPoE会话。取值范围为0~1023。
当PPPoE会话工作在永久在线模式时,如果使用reset pppoe-client命令复位PPPoE会话,设备会在自动拨号定时器超时后自动重新建立PPPoE会话。
当PPPoE会话工作在按需拨号模式时,如果使用reset pppoe-client命令复位PPPoE会话,设备会在有数据需要传送时,才重新建立PPPoE会话。
# 复位所有的PPPoE会话。
<Sysname> reset pppoe-client all
reset pppoe-client session packet命令用来清除PPPoE会话的协议报文统计信息。
reset pppoe-client session packet [ dial-bundle-number number ]
dial-bundle-number number:清除指定PPPoE会话的协议报文统计信息。取值范围为0~1023。如果不指定PPPoE会话,则清除所有PPPoE会话的协议报文统计信息。
# 清除所有的PPPoE会话的协议报文统计信息。
<Sysname> reset pppoe-client session packet
· display pppoe-client session packet
