23-WLAN命令参考
01-AP管理命令
本章节下载: 01-AP管理命令  (1.43 MB)
01-AP管理命令
1 AP管理
1.1 AP管理配置命令‌
1.1.1 ap (AP group view)
1.1.2 ap (vip-ap-group)
1.1.3 ap-mode fit
1.1.4 ap-model
1.1.5 ap-tag
1.1.6 bridge-aggregation
1.1.7 data-tunnel encryption
1.1.8 delete file
1.1.9 description (AP/Virtual-AP group view)
1.1.10 description (AP/Virtual-AP view)
1.1.11 discovery-response
1.1.12 display wlan ap
1.1.13 display wlan ap address
1.1.14 display wlan ap all feature capwap
1.1.15 display wlan ap ap-tag
1.1.16 display wlan ap connection-record
1.1.17 display wlan ap diagnostic-information
1.1.18 display wlan ap files
1.1.19 display wlan ap group
1.1.20 display wlan ap group-name
1.1.21 display wlan ap interface
1.1.22 display wlan ap online-time
1.1.23 display wlan ap reboot-log
1.1.24 display wlan ap reboot-record
1.1.25 display wlan ap region-code
1.1.26 display wlan ap running-configuration
1.1.27 display wlan ap statistics association-failure-record
1.1.28 display wlan ap statistics image-download
1.1.29 display wlan ap statistics switch-over-record
1.1.30 display wlan ap statistics online-record
1.1.31 display wlan ap statistics tunnel-down-record
1.1.32 display wlan ap total-online-duration
1.1.33 display wlan ap tunnel latency
1.1.34 display wlan ap-group
1.1.35 display wlan ap-model
1.1.36 display wlan license
1.1.37 display wlan modem statistics download-status
1.1.38 display wlan virtual-ap
1.1.39 display wlan virtual-ap-group
1.1.40 download file
1.1.41 echo-count
1.1.42 echo-interval
1.1.43 ethernet
1.1.44 firmware-upgrade
1.1.45 fragment-size
1.1.46 gigabitethernet
1.1.47 hybrid-remote-ap enable
1.1.48 if-match ip
1.1.49 if-match ipv6
1.1.50 keepalive-interval
1.1.51 led-mode
1.1.52 link-aggregation mode
1.1.53 mac-address (AP/Virtual-AP group view)
1.1.54 mac-address (AP/Virtual-AP view)
1.1.55 map-configuration
1.1.56 modem firmware-upgrade
1.1.57 poe port
1.1.58 port-isolate enable
1.1.59 port access vlan
1.1.60 port hybrid pvid
1.1.61 port hybrid vlan
1.1.62 port link-aggregation group
1.1.63 port link-type
1.1.64 port trunk permit vlan
1.1.65 port trunk pvid
1.1.66 power-level
1.1.67 priority
1.1.68 region-code (AP/AP group view)
1.1.69 region-code (Gobal configuration view)
1.1.70 region-code-ie
1.1.71 region-code-lock
1.1.72 remote-configuration
1.1.73 remote-configuration synchronize
1.1.74 report-interval
1.1.75 reset wlan ap
1.1.76 reset wlan ap connection-record
1.1.77 reset wlan ap reboot-log
1.1.78 reset wlan ap statistics association-failure-record
1.1.79 reset wlan ap statistics image-download
1.1.80 reset wlan ap statistics online-record
1.1.81 reset wlan ap statistics tunnel-down-record
1.1.82 reset wlan ap statistics switch-over-record
1.1.83 reset wlan tunnel latency ap
1.1.84 retransmit-count
1.1.85 retransmit-interval
1.1.86 serial-id (AP/Virtual-AP group view)
1.1.87 serial-id (AP/Virtual-AP view)
1.1.88 smartrate-ethernet
1.1.89 snmp-agent trap enable wlan ap
1.1.90 snmp-agent trap enable wlan capwap
1.1.91 statistics-interval
1.1.92 statistics-interval fast-report
1.1.93 ten-gigabitethernet
1.1.94 tunnel encryption enable
1.1.95 tunnel latency-detect
1.1.96 virtual-ap
1.1.97 vlan
1.1.98 wlan ap
1.1.99 wlan apdb
1.1.100 wlan apdb file
1.1.101 wlan ap-authentication
1.1.102 wlan ap-authentication acl
1.1.103 wlan ap-authentication enable
1.1.104 wlan ap-authentication import
1.1.105 wlan ap-authentication method
1.1.106 wlan ap-authentication permit-unauthenticated
1.1.107 wlan ap-fast-collect cloud enable
1.1.108 wlan ap-group
1.1.109 wlan ap-image-deploy
1.1.110 wlan ap-model modem-version
1.1.111 wlan auto-ap enable
1.1.112 wlan auto-ap fat-and-cloud enable
1.1.113 wlan auto-ap persistent
1.1.114 wlan auto-persistent enable
1.1.115 wlan capwap discovery-policy
1.1.116 wlan capwap encryption
1.1.117 wlan detect-anomaly enable
1.1.118 wlan execute modem-image-deploy
1.1.119 wlan global-configuration
1.1.120 wlan image-load filepath
1.1.121 wlan re-group
1.1.122 wlan rename-ap
1.1.123 wlan tcp mss
1.1.124 wlan timezone-sync enable
1.1.125 wlan trap ap-number threshold
1.1.126 wlan vip-ap-group
1.1.127 wlan virtual-5g-radio enable
1.1.128 wlan virtual-ap
1.1.129 wlan virtual-ap enable
1.1.130 wlan virtual-ap-group
1 AP管理
本特性的支持情况与设备型号有关,请以设备的实际情况为准。
系列
型号
F1000系列
F1000-AI-05-G、F1000-AI-03-G、F1000-AI-05-GS
不支持
F1000-AI-05-GWL
支持
1.1  AP管理配置命令‌
ap命令用来创建AP名称入组规则。
undo ap命令用来删除AP名称入组规则。
ap ap-name-list
undo ap ap-name-list
不存在AP名称入组规则。
AP组视图
虚拟AP组视图
ap-name-list:AP名称列表,表示方式为ap-name-list={ ap-name }&<1-10>。其中ap-name为AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写,&<1-10>表示前面的参数最多可以输入10个。
本命令不检查指定的AP是否存在。
AP将按照如下顺序匹配入组规则:AP名称入组规则-->AP序列号入组规则-->AP MAC地址入组规则-->IPv4网段入组规则或IPv6网段入组规则。若AP未匹配到入组规则,将被加入默认组。
若其它组已经存在该AP名称入组规则,在新组配置该AP名称入组规则,原AP组将删除该AP名称入组规则。
默认组视图下不能创建AP名称入组规则。
# 在AP组视图下创建一条AP名称入组规则。
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] ap ap1 ap2 ap3
# 在虚拟AP组视图下创建一条AP名称入组规则。
[Sysname] wlan virtual-ap-group group1
[Sysname-wlan-virtual-ap-group-group1] ap ap1 ap2 ap3
·     wlan ap-group
·     wlan virtual-ap-group
ap命令用来将指定AP添加到AP监控组。
undo ap命令用来从AP监控组中删除指定AP。
ap ap-name
undo ap ap-name
监控组中不存在任何AP。
监控组视图
ap-name:AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
AP加入监控组后,每隔一段时间会对AP上的客户端数量、射频流量、射频信道利用率、AP异常信息等数据进行采集并上报给AC。
AP加入监控组后不会对原有功能和业务造成影响。
监控组中最多添加32个AP。
# 将ap1添加到监控组中。
[Sysname] wlan vip-ap-group
[Sysname-wlan-vip-ap-group] ap ap1
·     report-interval
·     wlan vip-ap-group
1.1.3  ap-mode fit
本命令的支持情况与AP的型号有关,请以设备的实际情况为准。
ap-mode fit命令用来配置FAT AP或云AP的工作模式为FIT模式。
undo ap-mode fit命令用来恢复缺省情况。
ap-mode fit
undo ap-mode fit
AP视图:继承AP组配置。
AP组视图:FAT AP工作在FAT模式,云AP工作在Cloud模式。
AP视图
AP组视图
如果FAT AP或云AP自带FIT模式版本文件,则配置本命令后会直接重启进行模式切换。
如果FAT AP或云AP没有FIT模式版本文件,则配置本命令后,会先从AC上下载FIT模式版本文件,然后再重启进行模式切换。下载过程会持续几分钟到几十分钟不等。如果AC上也没有FIT模式版本文件,则不进行模式切换。
从AC上下载版本文件时,不允许在该AP或其上线的AC上进行操作,直到模式切换成功。
如果AP已经处于FIT模式,则配置本命令后不会产生任何影响。
配置AP模式切换命令后,如果AP已经下线,则需要在AC上保存配置,AP下次上线后会自动进行模式切换。
# 将名称为ap1的FAT AP切换为FIT模式。
[Sysname] wlan ap ap1
[Sysname-wlan-ap-ap1] ap-mode fit
Changing the working mode will reboot the AP. For the operation to succeed, make sure the corresponding AP image exists on the AC or AP. Continue? [Y/N]:
# 将名称为g1的ap组下所有AP切换为FIT模式。
[Sysname] wlan ap-group g1
[Sysname-wlan-ap-group-g1] ap-mode fit
1.1.4  ap-model
ap-model命令用来创建AP组下的AP型号,并进入AP型号视图。如果指定的AP型号已经存在,则直接进入AP型号视图。
undo ap-model命令用来删除组下AP型号视图及AP型号下的配置。
ap-model ap-model
undo ap-model ap-model
AP组下不存在AP型号。
AP组视图
虚拟AP组视图
ap-model:AP型号名。
# 在AP组视图下创建AP型号WA6320,并进入AP型号视图。
<System> system-view
[System] wlan ap-group group1
[System-wlan-ap-group-group1] ap-model WA6320
[System-wlan-ap-group-group1-ap-model-WA6320]
# 在虚拟AP组视图下创建AP型号WA6320,并进入AP型号视图。
[System] wlan virtual-ap-group group1
[System-wlan-virtual-ap-group-group1] ap-model WA6320
[System-wlan-virtual-ap-group-group1-ap-model-WA6320]
1.1.5  ap-tag
ap-tag命令用来配置AP标签。
undo ap-tag命令用来删除配置的AP标签。
ap-tag tag
undo ap-tag { all | tag }
AP视图:继承AP组配置。
AP组视图:未配置AP标签。
AP视图
AP组视图
tag:AP标签,目前取值只能为high-density和meeting。
all:删除配置的所有AP标签。
AP标签是AP参数属性的集合。根据每个应用场景的业务特征,设备中已经预定义了AP标签,用户可以根据自己的实际网络应用场景,为AP设备引用预定义的AP标签。引用标签后,AP可以继承AP标签中的AP参数,无需手工配置。
目前,设备预定义的AP标签包括:
·     meeting:会议室标签。此标签设置的参数属性为5GHz射频的频宽为80MHz。
·     high-density:高密标签。
·     vip:VIP标签,即监控组下的AP。在监控组视图下,通过命令ap ap-name添加指定AP到AP监控组。监控组可以使其中的AP对客户端数量、射频流量、射频信道利用率、AP异常信息等数据进行采集并上报给AC。
·     unstable:不稳定标签。具有不稳定标签的AP下线不会触发周边AP进行自动功率调整。该标签不支持用户配置。
如果AP视图和AP组视图下都配置了AP标签,AP视图下配置的优先级高于AP组视图下的配置。
# 为ap1配置高密标签和会议室标签。(AP视图)
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] ap-tag high-density meeting
# 为AP组group1中的AP配置高密标签。(AP组视图)
[Sysname-wlan-ap-group-group1] ap-tag high-density
·     display wlan ap ap-tag
·     wlan vip-ap-group
bridge-aggregation命令用来创建二层聚合接口,并进入二层聚合接口视图。如果指定的二层聚合接口已经存在,则直接进入该二层聚合接口视图。
undo bridge-aggregation命令用来删除二层聚合接口。
bridge-aggregation interface-number
undo bridge-aggregation interface-number
AP视图:继承AP组配置。
AP组ap-model视图:不存在二层聚合接口。
AP视图
AP组ap-model视图
interface-number:指定二层聚合接口的编号。不同型号的AP支持的取值范围不同,请以设备的实际情况为准。
创建二层聚合接口后,系统将自动生成同编号的二层聚合组,且该聚合组缺省工作在静态聚合模式下。
删除二层聚合接口的同时会删除其对应的二层聚合组,如果该聚合组内有成员端口,那么这些成员端口将自动从该聚合组中退出。
只有远程配置同步功能处于开启状态,且配置了remote-configuration synchronize命令,本配置才会被同步到AP上执行。
AP视图下配置的优先级高于AP组ap-model视图下的配置。
# 创建二层聚合接口1,并进入二层聚合接口1的视图。(AP视图)
[Sysname-wlan-ap-ap1] bridge-aggregation 1
[Sysname-wlan-ap-ap1-bridge-aggregation-1]
# 创建二层聚合接口1,并进入二层聚合接口1的视图。(AP组视图)
[Sysname-wlan-ap-group-1] ap-model WA6320
[Sysname-wlan-ap-group-1-ap-model-WA6320] bridge-aggregation 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-bridge-aggregation-1]
·     remote-configuration
·     remote-configuration synchronize
data-tunnel encryption enable命令用来开启CAPWAP数据隧道加密功能。
data-tunnel encryption disable命令用来关闭CAPWAP数据隧道加密功能。
undo data-tunnel encryption命令用来恢复缺省情况。
data-tunnel encryption { disable | enable }
AP视图:继承AP组配置。
AP组视图:CAPWAP数据隧道加密功能处于关闭状态。
虚拟AP视图:继承虚拟AP组配置。
虚拟AP组视图:CAPWAP数据隧道加密功能处于关闭状态。
AP视图
AP组视图
虚拟AP视图
虚拟AP组视图
开启了CAPWAP数据隧道加密功能,AP在收到AC回复的第一个数据隧道保活报文(keepalive报文)后,将与AC通过控制隧道交换包括密钥在内的加密信息,交换完成后对CAPWAP数据隧道报文进行加密传输(不加密Keepalive报文)。
开启该功能后,AP会重新关联到AC。
虚拟AP视图下配置的优先级高于虚拟AP组视图下的配置。
# 开启AP的CAPWAP数据隧道加密功能。(AP视图)
[Sysname-wlan-ap-ap1] data-tunnel encryption enable
This operation will reconnect the AP. Continue? [Y/N]
# 开启AP组的CAPWAP数据隧道加密功能。(AP组视图)
[Sysname-wlan-ap-group-group1] data-tunnel encryption enable
This operation will reconnect member APs that are not enabled with CAPWAP data tunnel encryption. Continue? [Y/N]
# 开启虚拟AP的CAPWAP数据隧道加密功能。(虚拟AP视图)
[Sysname] wlan virtual-ap ap1 model WA6320
[Sysname-wlan-virtual-ap-ap1] data-tunnel encryption enable
# 开启虚拟AP组的CAPWAP数据隧道加密功能。(虚拟AP组视图)
[Sysname-wlan-virtual-ap-group-group1] data-tunnel encryption enable
·     tunnel encryption
1.1.8  delete file
delete file命令用来删除AP上的文件。
delete file filename
AP视图
filename:要删除的文件名,为1~255个字符的字符串。
只有在AP和AC建立了CAPWAP隧道并且当前AC为主AC时,用户才能通过文件删除操作将AP上的文件删除。
# 删除AP上的文件startup.cfg。
[Sysname-wlan-ap-ap1] delete file startup.cfg
Do want to delete the flash:/startup.cfg file? [Y/N]
·     download file
·     display wlan ap files
description命令用来配置AP组的描述信息。
undo description命令用来恢复缺省情况。
未配置AP组的描述信息。
AP组视图
虚拟AP组视图
text:AP组的描述信息,为1~64个字符的字符串,区分大小写。
当存在多个AP组时,可以配置每个AP组的描述信息,以便区别各个AP组。
使用display wlan ap-group命令可以看到AP组配置的描述信息。
使用display wlan virtual-ap-group命令可以看到虚拟AP组配置的描述信息。
# 配置AP组group1的描述信息。
[Sysname-ap-group-group1] description L3-office
# 配置虚拟AP组group1的描述信息。
[Sysname-wlan-virtual-ap-group-group1] description L3-office
·     display wlan ap-group
·     display wlan virtual-ap-group
·     wlan ap-group
description命令用来配置AP的描述信息。
未配置AP的描述信息。
AP视图
虚拟AP视图
text:AP的描述信息,为1~64个字符的字符串,区分大小写。
# 配置名称为ap1的AP的描述信息为L3-office。
[Sysname-ap-ap1] description L3-office
# 配置名称为ap1的虚拟AP的描述信息为L3-office。
[Sysname-wlan-virtual-ap-ap1] description L3-office
discovery-response wait-time命令用来配置AP Discover interval定时器的超时时间。
undo discovery-response wait-time命令用来恢复缺省情况。
discovery-response wait-time seconds
AP视图:继承AP组配置。
AP组视图:AP Discover interval定时器的超时时间为2秒。
AP视图
AP组视图
seconds:指定AP Discover interval定时器超时时间,取值范围为2~20,单位为秒。
当AP收到Discover response报文时,会创建或刷新Discover interval定时器,当定时器超时后,AP会选择最优AC并向AC发送Join request报文。
当网络环境较差时,配置较长的Discover interval定时器超时时间,可以延长AP等待AC回复Discover response报文的时间。
# 配置AP Discover interval定时器的超时时间为3秒。(AP视图)
[Sysname] wlan ap ap3
[Sysname-wlan-ap-ap3] discovery-response wait-time 3
# 配置AP Discover interval定时器的超时时间为3秒。(AP组视图)
[Sysname-wlan-ap-group-group1] discovery-response wait-time 3
display wlan ap命令用来显示AP信息。
display wlan ap { all | apid ap-id | name ap-name } [ verbose [ filter { field }&<1-5> ] ]
all:显示所有AP的信息。
apid ap-id:显示指定AP的信息。ap-id表示AP的ID号,取值范围为1~65535。
name ap-name:显示指定AP的信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
verbose:显示AP的详细信息。
filter { field }&<1-5>:指定AP的详细显示信息的过滤字段,该参数的取值可通过在filter关键字后面输入?来获得。&<1-5>表示前面的参数最多可以输入5次。不指定该参数时,表示不对AP详细显示信息进行过滤,即显示AP的所有详细信息。
AP的详细显示信息字段丰富,如果仅关注部分字段,可以在执行本命令时,指定filter参数来仅显示这些字段的信息。
# 显示所有AP的信息。
<Sysname> display wlan ap all
Total number of APs: 3
Total number of connected APs: 3
Total number of connected manual APs: 3
Total number of connected auto APs: 0
Total number of connected common APs: 2
Total number of connected WTUs: 1
Total number of inside APs: 0
Maximum supported APs: 2048
Remaining APs: 2046
Total AP licenses: 128
Local AP licenses: 128
Server AP licenses: 0
Remaining local AP licenses: 127.75
Sync AP licenses: 0
                                 AP information
 State : I = Idle,       J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,     DC = DataCheck,  R  = Run   M = Master,  B = Backup
AP name  APID  State Model    Serial ID             Group name  Online time  Clients  Mode  IP address
ap1       1     I     WA6320  219801A28N819CE0002T    group1       100:12:47:10 1         Fit    1.1.1.70
ap2       2     R     WT1020   219801A0SS9156G00072    group2       100:12:47:10 3         Fat    1.1.1.71
ap3       3     R     WTU420H   219801A0SS9156G00169    group1       100:12:47:10 5         Fit    1.1.1.72
表1-1 display wlan ap all命令显示信息描述表
Total number of APs
AP的数量,包括普通AP,WT(Wireless Terminator,无线终结者)和WTU(Wireless Terminator Unit,无线终结单元)
处于连接状态的AP的总数量,包括普通AP,WT和WTU
处于连接状态的手工AP的总数量,包括普通AP,WT和WTU
处于连接状态的自动AP的总数量,包括普通AP,WT和WTU
处于连接状态的普通AP的总数量
处于连接状态的WTU总数量
处于连接状态的内部AP数量,内部AP为Anchor AP作为AC设备时自动创建的名称为本机MAC地址,序列号为本机序列号的手工AP
AC上最大AP容量,包括Fit AP和WTU,WT不计入AP容量
Remaining APs
剩余AP容量,即最大AP容量减去处于连接状态的Fit AP和WTU数量
Total AP licenses
AP License总数量,包括普通AP License数量,以及WTU License按照比例转换成普通AP License的数量,每个WTU License转换成0.25个普通AP License
Local AP licenses
AC本地License数量
Server AP licenses
AC从服务器申请的License数量
剩余本地AP License数量,不同的AP类型所占用的AP License数量不同,例如WA6320占用1个AP License,WT1020不占用AP License,WTU420H占用0.25个AP License
Sync AP licenses
共享的AP License数量
APID
AP的ID号,用于在AC上唯一标识一个AP
AP name
AP名称
AP当前状态:
·     I:空闲状态
·     J:CAPWAP连接建立状态
·     JA:CAPWAP连接确认阶段
·     IL:版本下载状态
·     C:初始化配置下载状态
·     DC:数据校验状态
·     R:CAPWAP隧道处于运行状态,表示AP与AC成功建立CAPWAP隧道
·     R/M:CAPWAP主隧道处于运行状态,表示AP与主AC成功建立主隧道
·     R/B:CAPWAP备隧道处于运行状态,表示AP与备AC成功建立备隧道
·     M:主用状态,表示当前AC为AP的主用AC
·     B:备用状态,表示当前AC为AP的备用AC
·     R/IL:在线下版本状态,表示当前处于运行状态的AP正在下载版本
Model
AP型号信息
Serial ID
AP序列号,如果未指定,则显示为Not configured
Group name
AP组名称
Online time
AP在线时长
Clients
终端个数
Mode
AP工作模式:
·     Fit:Fit AP
·     VAP:Virtual AP
·     Cloud:Cloud AP
·     Fat:Fat AP
IP address
AP的IP地址
# 显示ap1的详细信息。
<Sysname> display wlan ap name ap1 verbose
AP name                       : ap1
AP ID                         : 1
AP group name                 : default-group
State                         : Run
Backup type                   : Master
Ready-for-Switchover          : Not ready
Online time                   : 0 days 1 hours 25 minutes 12 seconds
System uptime                 : 0 days 2 hours 22 minutes 12 seconds
Model                         : WA6320
Region code                   : CN
Region code lock              : Disable
Serial ID                     : 219801A28N819CE0002T
MAC address                   : 0AFB-423B-893C
IP address                    : 192.168.1.50
UDP control port number       : 18313
UDP data port number          : N/A
H/W version                   : Ver.C
S/W version                   : E2321
Boot version                  : 1.01
Forwarding mode               : NSS
USB state                     : N/A
Power level                   : N/A
Power info                    : N/A
Description                   : wtp1
Priority                      : 4
Echo interval                 : 10 seconds
Echo count                    : 3 counts
Keepalive interval            : 10 seconds
Discovery-response wait-time  : 2 seconds
Statistics report interval    : 50 seconds
Fragment size (data)          : 1500
Fragment size (control)       : 1450
MAC type                      : Local MAC & Split MAC
Tunnel mode                   : Local Bridging & 802.3 Frame & Native Frame
CWPCAP data-tunnel status     : Down
Discovery type                : Static Configuration
Retransmission count          : 3
Retransmission interval       : 5 seconds
Firmware upgrade              : Enabled
Sent control packets          : 1
Received control packets      : 1
Echo requests                 : 147
Lost echo responses           : 0
Average echo delay            : 3
Last reboot reason            : User soft reboot
Last reboot reason (AP check) : The radio physical status was down
Last reboot reason (AC check) : The radio physical status was down
Latest IP address             : 10.1.0.2
Current AC IP                 : 192.168.1.1
Tunnel down reason            : Request wait timer expired
Connection count              : 1
Backup IPv4                   : Not configured
Backup IPv6                   : Not configured
Ctrl-tunnel encryption        : Disabled
Ctrl-tunnel encryption state  : Not encrypted
Data-tunnel encryption        : Disabled
Data-tunnel encryption state  : Not encrypted
LED mode                      : Normal
Remote configuration          : Enabled
AP type                       : Unknown
Radio 1:
    BSSID                     : 7848-59f6-3940
    State                     : Up
    Radio type                : 802.11ac
    Antenna type              : internal
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel bandwidth         : 20/40/80MHz
    Operating bandwidth       : 20/40/80MHz
    Secondary channel offset  : SCA
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    MIMO                      : Not Config
    Green-Energy-Management   : Disabled
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Not Supported
    STBC                      : Supported
    Operational VHT-MCS Set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS Set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel                   : 44(auto)
    Channel usage(%)          : 15
    Max power                 : -102 dBm
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Multicast             : Auto
        Supported             : 9, 18, 36, 48, 54 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Noise Floor               : 5 dBm
    Protection mode           : rts-cts
    MU-TxBF                   : Enabled
    SU-TxBF                   : Enabled
    Continuous mode           : N/A
    Radar-detect              : Disabled
    HT protection mode        : No protection
Radio 2:
    BSSID                     : 7848-59f6-3950
    State                     : Down
    Radio type                : 802.11n(2.4GHz)
    Channel bandwidth         : 20/40MHz
    Channel auto-switch       : Enabled
    MIMO                      : Not Config
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    STBC                      : Supported
                                10, 11, 12, 13, 14, 15, 16, 17,
                                18, 19, 20, 21, 22, 23, 24, 25,
                                26, 27, 28, 29, 30, 31
    Channel                   : 5(auto)
    Channel usage(%)          : 0
    Max power                 : 20 dBm
    Preamble type             : Short
    Operational rate:
        Mandatory             : 1, 2, 5.5, 11 Mbps
        Multicast             : Auto
        Supported             : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
    Distance                  : 1 km
    ANI                       : Enabled
    Noise Floor               : 0 dBm
# 根据过滤字段apid、hwver、conn-count、bootver、echo-count显示ap1的详细信息。
<Sysname> display wlan ap name ap1 verbose filter apid hwver conn-count bootver echo-count
                               Filtered information
apid = AP ID, hwver = H/W version, conn-count = Connection count, bootver = Boot version, echo-count = Echo count
AP name                        apid    hwver      conn-count   bootver    echo-count
ap1                            16      N/A        0            N/A        3
表1-2 display wlan ap name verbose命令显示信息描述表
AP name
AP名称
AP ID
AP的ID号,用于唯一标识一个AP
AP group name
AP组名称
AP当前状态:
·     Idle:空闲状态
·     Join:CAPWAP连接建立状态
·     JoinAck:CAPWAP连接确认状态
·     Image Download:版本下载状态
·     Config:初始化配置下载状态
·     Data Check:数据校验状态
·     Run:CAPWAP隧道处于运行状态,表示AP与AC成功建立CAPWAP隧道
Backup type
AP与AC间隧道类型:
·     Idle:未建立隧道
·     Master:主用隧道
·     Backup:备用隧道
AC侧为指定AP将备链路升级为主链路准备状态:
·     Ready:准备完成
·     Not ready:未准备完成
Online time
AP在线时长
System uptime
AP系统启动时长
Model
AP型号信息
Region code
区域码
Region code lock
区域码锁定功能:
·     Enabled:开启状态
·     Disabled:关闭状态
Serial ID
AP序列号。如果未指定序列号,显示为Not configured
MAC address
AP的MAC地址。如果未指定MAC地址,显示为Not configured
IP address
AP当前连接的IP地址
AP建立CAPWAP控制隧道的端口号
AP建立CAPWAP数据隧道的端口号
H/W version
AP当前硬件信息
S/W version
AP当前软件信息
CPE modem name
CPE模组型号
CPE modem version
CPE模组软件版本号
Boot version
AP当前引导程序版本
WT serial ID
WTU所连接的WT的序列号,仅在在线的WTU设备型号下显示
WT name
WTU所连接的WT的名称,仅在在线的WTU设备型号下显示
WT MAC address
WTU所连接的WT的MAC地址,仅在在线的WTU设备型号下显示
Forwarding mode
AP的转发模式:
·     DP:data-path模式,表示通过CPU转发
·     NSS:NSS硬件转发模式,表示通过NPU转发
USB state
USB的状态信息:
·     N/A:无
·     Enabled:开启状态
·     Disabled:关闭状态
Power level
供电等级:
·     N/A:未知供电等级
·     Low:低供电等级
·     Middle:中供电等级
·     High:高供电等级
(本字段的支持情况与AP设备的型号有关)
Power info
供电信息:
·     Power adapter:AP设备采用本地供电
·     PoE(port1+port2):AP设备采用PoE供电,port1、port2为AP上PoE+接口的供电状态,取值为:
¡     NA:未协商出供电模式
¡     802.3af:802.3af供电模式
¡     802.3at:802.3at供电模式
PoE status
PoE接口的供电状态:
·     Port number:PoE接口编号
·     Enabled:开启状态
·     Disabled:关闭状态
AP描述信息。如果未指定描述信息,显示为Not configured
Priority
AC配置的AP连接的优先级
Echo interval
AP的两次回声请求的时间间隔
Echo count
CAPWAP控制隧道保活报文的发送次数
Keepalive interval
CAPWAP数据隧道保活报文的发送时间间隔
AP等待Discovery response报文的时长
AP上报统计信息的时间间隔
CAPWAP数据报文分片的最大长度
CAPWAP控制报文分片的最大长度
MAC type
AP与AC连接的MAC模式类型:
·     Local MAC:AP侧数据帧支持802.3格式封装
·     Split MAC:AP侧数据帧支持802.11格式封装
·     Local & Split MAC:AP侧数据帧支持802.3与802.11格式封装
Tunnel mode
AP支持的隧道模式:
·     Local Bridging:AP侧支持用户数据本地桥接,不上送给AC
·     802.3 Frame:AP侧支持用户数据以802.3帧格式封装上传给AC
·     Native Frame:AP侧支持用户数据以802.11帧格式封装上传给AC
·     Local Bridging & 802.3 Frame:AP侧支持用户数据本地桥接、以802.3帧格式封装上传
·     802.3 Frame & Native Frame:AP侧支持用户数据以802.3或802.11帧格式封装上传
·     Local Bridging & Native Frame:AP侧支持用户数据本地桥接、以802.11帧格式封装上传
·     Local Bridging & 802.3 Frame & Native Frame:AP侧支持用户数据本地桥接、以802.3或802.11帧格式封装上传
CAPWAP数据隧道的运行状态:
·     Up:CAPWAP数据隧道处于运行状态
·     Down:CAPWAP数据隧道处于断开状态
Discovery type
AP的发现方式:
·     Static Configuration:AP使用静态配置的IPv4或IPv6地址发现AC
·     DHCP:AP使用DHCP选项发现AC
·     DNS:AP使用DHCP+DNS发现AC
·     Unknown:未知的发现方式
·     说明
·     双链路备份组网下,备AC的AP发现方式与主AC保持一致
AC重传请求报文的重传次数
AC重传请求报文的重传间隔
Firmware upgrade
AP的版本下载:
·     Enabled:开启AP的版本下载
·     Disabled:关闭AP的版本下载
AC在Run状态之后发送的控制报文的个数(包含Change State Event Response报文)
AC在Run状态之后接收的控制报文的个数(包含Change State Event Request报文)
Echo requests
AP在RUN状态下发送的echo请求报文数量
Lost echo responses
AP在Run状态下没有接收到的echo响应报文数量
Average echo delay
AP控制隧道保活报文的平均延时,单位为毫秒
Last reboot reason
AP上一次重启的原因:
·     Power on:AP设备上电重启
·     Hard reboot:硬重启,即使用reset按钮重启AP设备
·     Watchdog reboot:看门狗重启
·     Unknown reboot:未知原因重启
·     User soft reboot:通过命令行、SNMP、Web等管理手段重启设备
·     Kernel exception soft reboot:内核异常重启
·     Kernel deadloop soft reboot:内核死循环重启
·     Auto update soft reboot:版本自动升级
·     Unknown soft reboot:未知软件原因
·     Memory exhausted:内存耗尽
·     Other unknown soft reboot:其他原因
Last reboot reason(AP check)
AP上一次因AP校验失败重启的原因:
·     The radio state was incorrect:射频状态出错
·     The radio channel was incorrect:射频信道出错
·     The radio type was incorrect:射频类型出错
·     The radio bandwidth was incorrect:射频带宽出错
·     The radio rate was incorrect:射频速率出错
·     The radio dependence was incorrect:射频依赖条件出错
·     The radio physical status was down:射频物理口状态down
Last reboot reason(AC check)
AP上一次因AC校验失败重启的原因:
Latest IP address
AP最近一次使用的IP地址
Current AC IP
AP在线的当前AC的IP地址
Tunnel down reason
CAPWAP隧道关闭的原因:
·     N/A:无
·     Failed to create data check timer:创建数据定时器失败
·     Neighbor dead timer expired:邻居报告定时器超时
·     Wait request timer expired:等待请求消息定时器超时
·     Data check timer expired:数据检测定时器超时
·     Failed to process data channel keep-alive message:处理数据隧道保活报文失败
·     Failed to process request:请求报文处理失败
·     AP was reset by admin:用户AP重启
·     AP was reset by Web :Web网关管理重启AP
·     AP was reset from OASIS:云平台重启AP
·     WTU went offline because the WT was down:因无线终结者不在线,导致无线终结单元下线
·     Manual AP was deleted:手工AP被删除
·     Failed to come online:AP上线失败
·     Serial ID changed:AP的Serial ID改变
·     MAC address changed:AP的MAC地址改变
·     Exceeded AC max capability:AP数量超出AC能力集
·     Processed join request in Run state:在Run状态处理join request
·     Unauthenticated AP tunnel down:未认证AP下线
·     Failed to create AP context:创建AP上下文信息失败
·     Received failure result code in change state event request:CAPWAP状态机状态变迁时收到错误结果码
·     Failed to retransmit message:报文重传失败
·     Failed to download image file:下载AP镜像失败
·     Image file downloaded successfully:AP下载镜像成功重启系统
·     File operation timer expired:文件操作定时器超时
·     Failed to add tunnel:添加隧道失败
·     Received WTP tunnel down event from AP:AC收到AP的隧道down事件
·     Backup AC closed the backup tunnel:备份AC关闭备份隧道
·     Master and backup tunnel switchover:主备隧道切换
·     Failed to inherit configuration:继承配置失败
·     AP authentication failed:AP认证失败
·     Backup AP upgrade failed:备份隧道AP升级失败
·     Board is inactive:板非活跃状态
·     WT went offline:无线终结者已下线
·     Lack of AP license:无AP数量License
·     WAP went offline because the SPM was down:因SPM下线导致的WAP下线
·     SPM was down:SPM下线
·     Encryption status mismatch :加密运行状态和配置状态不一致
·     Associated local AC went down:Local AC下线导致AP下线
·     AP was reset due to inconsistent local and reported radio statistics :Radio数据统计信息上报数据不一致
·     AP was reset due to inconsistent AP state on APMGR and lib:APMGR和lib端AP状态不一致
·     AP was reset due to inconsistent BSS state on AC and AP:AC和AP上的BSS状态不一致
·     APs failed to request a license:备份隧道AP升级时扣除License失败
·     WT status is incorrect in master and backup switchover in dual link backup:备份隧道无线终结单元状态升级时依赖的无线终结者状态不是主隧道
·     Master and backup switchover is not allowed if AP software upgrade is enabled and APs were logged off:AP升级开关打开时不允许链路切换,强制AP下线
·     WTU creation timer timed out after a master and backup switchover in dual link backup:无线终结者备升主后,创建延迟检查无线终结者升级定时器超时
Connection count
AP和AC的连接次数,只有在以下情况下连接次数会清零:
·     AC重启
·     重新配置AP序列号
需要注意的是,使用reset wlan ap命令不会造成AP连接次数清零
Backup IPv4
备AC的IPv4地址。如果未指定,显示为Not configured
Backup IPv6
备AC的IPv6地址。如果未指定,显示为Not configured
CAPWAP控制隧道加密功能:
·     Enabled:开启状态
·     Disabled:关闭状态
CAPWAP控制隧道加密状态:
·     Encrypted:已加密
·     Not encrypted:未加密
CAPWAP数据隧道加密功能:
·     Enabled:开启状态
·     Disabled:关闭状态
CAPWAP数据隧道加密状态:
·     Encrypted:已加密
·     Not encrypted:未加密
LED mode
LED闪烁模式:
·     quiet:表示所有LED常灭
·     awake:表示所有LED每分钟闪烁一次
·     always-on:表示所有LED常亮
·     normal:Normal模式的LED闪烁情况与AP型号有关,请以设备的实际情况为准
远程配置同步功能:
·     Enabled:开启状态
·     Disabled:关闭状态
AP type
AP类型:
·     Unknown:未知AP类型,AP上线之前显示该内容
·     WTU:无线终结单元
·     Virtual AP:虚拟AP
·     Fat AP:Fat AP
·     Cloud AP:云AP
·     Normal AP:除上述AP以外的其它AP
Radio
射频
BSSID
Radio的MAC地址。N/A表示AP还未与AC建立CAPWAP隧道
Radio状态:
·     Up:Radio处于开启状态
·     Down:Radio处于关闭状态
Radio type
Radio类型:
·     2.4GHz:802.11b、802.11g、802.11n(2.4GHz)、802.11gac、802.11gax
·     5GHz:802.11a、802.11n(5GHz)、802.11ac、802.11ax
Antenna type
天线类型
Client dot11ax-only
只允许802.11ax客户端接入功能:
·     Enabled:只有802.11ax的无线客户端才能接入射频
·     Disabled:兼容802.11a/b/g/n/ac的无线客户端,同时还要接入802.11ax的无线客户端
Client dot11ac-only
只允许802.11ac和802.11ax客户端接入功能:
·     Enabled:只有802.11ac或802.11ax的无线客户端才能接入射频
·     Disabled:兼容802.11a/b/g/n的无线客户端,同时还要接入802.11ac或802.11ax的无线客户端
Client dot11n-only
只允许802.11n、802.11ac和802.11ax客户端接入功能:
·     Enabled:只有802.11n、802.11ac或802.11ax的无线客户端才能接入射频
·     Disabled:兼容802.11a/b/g的无线客户端,同时还要接入802.11n、802.11ac或802.11ax的无线客户端
Channel bandwidth
配置的带宽模式:
·     20MHz:工作带宽为20MHz
·     20/40MHz:工作带宽为20/40MHz
·     20/40/80MHz:工作带宽为20/40/80MHz
·     20/40/80/160MHz:工作带宽为20/40/80/160MHz
·     20/40/80/160/(80+80)MHz:工作带宽为20/40/80/160/(80+80)MHz
Operating  bandwidth
射频运行带宽
Channel auto-switch
当前带宽值,仅在开启20/40M带宽自动切换情况时显示,此值与beacon帧中的带宽保持一致
802.11n及802.11ac射频模式中的辅信道信息:
·     SCA:Second Channel Above,表示射频当前工作在40MHz带宽模式,并且辅信道高于主信道
·     SCB:Second Channel Below,表示射频当前工作在40MHz带宽模式,并且辅信道低于主信道
·     SCN:表示射频未工作在40MHz带宽模式
(仅对于运行带宽为20/40/80MHz时支持本字段)
Secondary channel center frequency
802.11ac射频模式且射频工作带宽为160/(80+80)MHz时,辅信道所在80M频宽的中心频点信息
(仅对于运行带宽为160/(80+80)MHz时支持本字段)
Short GI for 20MHz
射频工作带宽为20MHz时,对于Short GI的支持情况:
·     Not supported:射频不支持20MHz Short GI
·     Supported:射频支持20MHz Short GI
Short GI for 40MHz
射频工作带宽为40MHz时,对于Short GI的支持情况:
·     Not supported:射频不支持40MHz Short GI
·     Supported:射频支持40MHz Short GI
Short GI for 80MHz
射频工作带宽为80MHz时,对于Short GI的支持情况:
·     Not supported:射频不支持80MHz Short GI
·     Supported:射频支持80MHz Short GI
Short GI for 160MHz
射频工作带宽为160MHz时,对于Short GI的支持情况:
·     Not supported:射频不支持160MHz Short GI
·     Supported:射频支持160MHz Short GI
Short GI for 320MHz
射频工作带宽为320MHz时,对于Short GI的支持情况:
·     Not supported:射频不支持320MHz Short GI
·     Supported:射频支持320MHz Short GI
mimo
mimo功能:
·     1x1:射频工作在1条流收发模式
·     2x2:射频工作在2条流收发模式
·     3x3:射频工作在3条流收发模式
·     4x4:射频工作在4条流收发模式
·     5x5:射频工作在5条流收发模式
·     6x6:射频工作在6条流收发模式
·     7x7:射频工作在7条流收发模式
·     8x8:射频工作在8条流收发模式
·     Not configured:使用默认配置,即使用当前射频支持的最大流数
·     (PowerLow):若上面9种模式后有此显示,代表AP供电等级为低,射频只允许工作在1条流收发模式
AP绿色节能功能:
·     Disabled:AP绿色节能功能处于关闭状态
·     Enabled:AP绿色节能功能处于开启状态
A-MSDU
A-MSDU功能:
·     Disabled:A-MSDU功能处于关闭状态
·     Enabled:A-MSDU功能处于开启状态
A-MPDU
A-MPDU功能:
·     Disabled:A-MPDU功能处于关闭状态
·     Enabled:A-MPDU功能处于开启状态
LDPC
低密度奇偶校验码:
·     Supported:射频支持LDPC功能
·     Not Supported:射频不支持LDPC功能
STBC
空时块编码:
·     Supported:射频支持STBC功能
·     Not Supported:射频不支持STBC功能
Operational HE-MCS Set
HE-MCS集:
·     Supported:支持MCS索引
·     Mandatory:强制MCS索引
·     Multicast:组播MCS索引
Operational VHT MCS Set
VHT-MCS集:
·     Mandatory:基本VHT-MCS索引
·     Supported:支持VHT-MCS索引
·     Multicast:组播VHT-MCS索引
HT-MCS集:
·     Supported:支持MCS索引
·     Mandatory:强制MCS索引
·     Multicast:组播MCS索引
Operational EHT-MCS Set
EHT-MCS集:
·     Supported:支持MCS索引
·     Mandatory:强制MCS索引
·     Multicast:组播MCS索引
Channel
Radio信道:
·     Number <auto>:表示自动信道模式根据实际环境自动选择最优信道
·     Number:手动配置的2.4GHz或5GHz工作信道
·     Number <avoid radar>在手工信道上发现雷达信号时自动调整的规避信道
·     6G_Number:手动配置的6GHz工作信道
Channel usage (%)
信道利用率
Max power
Radio的最大传输功率
Preamble type
前导码类型:
·     Long:长和短前导码
·     Short:短前导码
Operational rate
操作速率:
·     Mandatory:强制速率
·     Supported:支持速率
·     Multicast:组播速率
·     Disabled:禁止速率
·     Not configured:未指定速率
Distance
Radio可覆盖的最远距离
ANI
ANI功能的状态:
·     Enabled:ANI功能处于开启状态
·     Disabled:ANI功能处于关闭状态
帧的分片门限值
Beacon interval
发送Beacon帧的时间间隔
启用protection机制所要求的帧的长度门限值
帧长超过RTS门限值的帧的最大重传次数
帧长不大于RTS门限值的帧的最大重传次数
Frame aging time in cache
帧可以在缓存中保存的最长时间
Noise Floor
噪声基底
Smart antenna
智能天线功能:
·     Enabled:智能天线处于开启状态
·     Disabled:智能天线处于关闭状态
Smart antenna policy
智能天线策略:
·     Auto:自适应策略
·     High availability:高可靠性策略
·     High throughput:高吞吐量策略
Protection mode
冲突避免方式:
·     cts-to-self:CTS-to-self方式
·     rts-cts:RTS/CTS方式
MU-TxBF
多用户TxBF功能:
·     Enabled:多用户TxBF功能处于开启状态
·     Disabled:多用户TxBF功能处于关闭状态
SU-TxBF
单用户TxBF功能:
·     Enabled:单用户TxBF功能处于开启状态
·     Disabled:单用户TxBF功能处于关闭状态
Continuous mode
常发模式所使用的速率、MCS索引值、NSS索引值和VHT-MCS索引值,N/A表示未配置常发模式
OFDMA random access RUs
是否支持HE 随机选址
·     Supported:不支持
·     Not Supported:不支持
DL-OFDMA
下行OFDMA功能:
·     Enabled:下行OFDMA功能处于开启状态
·     Disabled:下行OFDMA功能处于关闭状态
UL-OFDMA
上行OFDMA功能:
·     Enabled:上行OFDMA功能处于开启状态
·     Disabled:上行OFDMA功能处于关闭状态
UL-MU-MIMO
上行MU-MIMO功能:
·     Enabled:上行MU-MIMO功能处于开启状态
·     Disabled:上行MU-MIMO功能处于关闭状态
BSS-COLOR
BSS-COLOR功能:
·     Enabled:BSS-COLOR功能处于开启状态
·     Disabled:BSS-COLOR功能处于关闭状态
TWT negotiation
TWT协商功能状态:
·     Enabled:功能处于开启状态
·     Disabled:功能处于关闭状态
Radar-detect
雷达检测功能:
·     Enabled: 雷达检测功能处于开启状态
·     Disabled:雷达检测功能处于关闭状态
HT protection mode
802.11n保护模式:
·     No protection:此模式下,AP上关联的客户端以及周围环境中的无线设备都为802.11n模式,并且在AP上关联的客户端都是40MHz带宽的802.11n客户端;或者在AP上关联的客户端都是20MHz带宽的802.11n客户端
·     Non-member protection:此模式下,AP上关联的客户端都是802.11n客户端,但是周围环境中存在着非802.11n无线设备
·     20 MHz protection:此模式下,AP的射频带宽模式为40MHz,AP上关联的客户端以及周围环境中的无线设备都为802.11n模式,并且在该AP的射频上至少关联了一个20MHz带宽的802.11n客户端
·     Non-HT mixed:除以上三种模式之外的其它所有情况都属于此模式
Preamble puncturing
Preamble puncturing功能
·     N/A:不支持Preamble puncturing功能
·     Enable:Preamble puncturing功能处于开启状态
·     Disable:Preamble puncturing功能处于关闭状态
MRU
MRU功能
·     N/A:不支持MRU功能
·     Enable:MRU功能处于开启状态
·     Disable:MRU功能处于关闭状态
display wlan ap address命令用来显示AP地址信息。
display wlan ap { all | name ap-name } address
all:显示所有AP的地址信息。
name ap-name:显示指定AP的地址信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示所有AP的地址信息。
<Sysname> display wlan ap all address
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
AP name                          IP address                     MAC address
ap1                              1.1.1.5                        000b-6b8f-fc6a
表1-3 display wlan ap all address命令显示信息描述表
Total number of APs
AP name
AP名称
IP address
AP的IP地址,AP未上线时,该字段显示为N/A
MAC address
AP的MAC地址,AP未上线时,该字段显示为N/A
display wlan ap all feature capwap命令用来显示CAPWAP隧道的配置状态。
# 显示CAPWAP隧道的配置状态。
<Sysname> display wlan ap all feature capwap
AP name                       Upgrade   Encryption  Control-address   Switch-back
ap1                           Disabled Both        Enabled           Disabled
表1-4 display wlan ap all feature capwap命令显示信息描述表
AP name
AP的名称
Upgrade
AP版本升级的状态:
·     Enabled:开启
·     Disabled:关闭
Encryption
隧道加密开关状态:
·     Control:控制隧道加密功能开启
·     Data:数据隧道加密功能开启
·     Both:控制隧道和数据隧道加密功能均开启
·     Disabled:控制隧道和数据隧道加密功能均关闭
Control-address
二次发现AC功能的状态:
·     Enabled:开启
·     Disabled:关闭
Switch-back
分层AC的CAPWAP隧道回切功能状态:
·     Horizontal:水平回切
·     Vertical:垂直回切
·     Disabled:关闭
·     Both:水平回切和垂直回切均开启
display wlan ap ap-tag命令用来显示AP的标签。
display wlan ap { all | name ap-name } ap-tag { all | tag }
all:显示所有AP的标签。
name ap-name:显示指定AP的标签。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
all:显示AP的所有标签。
tag:显示AP的指定标签。
# 显示所有AP的所有标签。
<Sysname> display wlan ap all ap-tag all
AP name           Tag
ap1               vip, high-density, meeting
ap2               high-density
表1-5 display wlan ap ap-tag命令显示信息描述表
AP name
AP名称
Tag
·     AP标签,目前包括如下取值:
·     high-density:高密标签
·     meeting:会议室标签
·     unstable:不稳定标签
·     ap-tag
·     wlan vip-ap-group
display wlan ap connection-record命令用来显示AC上的AP连接记录。
display wlan ap { all | name ap-name } connection-record
all:显示所有AP的连接记录。
name ap-name:显示指定AP的连接记录,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示AC上所有AP的连接记录。
<Sysname> display wlan ap all connection-record
AP name                         IP address      State     Time
ap2                             192.168.100.27  Run       01-06 09:06:40
表1-6 display wlan ap connection-record命令显示信息描述表
AP name
AP名称
IP address
AP的IP地址
AP当前状态:
·     Discovery:AP发现AC阶段
·     Join:CAPWAP隧道处于连接建立状态
·     Offline:下线状态
Time
AP与AC最后一次建立CAPWAP隧道的时间
display wlan ap diagnostic-information命令用来在AC上保存AP的诊断信息。
display wlan ap name ap-name diagnostic-information
name ap-name:保存指定AP的诊断信息,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,区分大小写。
可以通过本命令使AP将诊断信息集中上报至AC,可以在AC的存储介质中取得诊断信息文件并手动解压查看或删除,无需登录每个AP进行查看。
执行本命令后,AP会在本地生成诊断信息,然后将诊断信息上报至AC本地存储介质的/apdiag/路径下,最后AP再将本地的诊断信息删除。
可以在AP上通过display diagnostic-information命令配置需要上报的诊断信息类型。关于display diagnostic-information的详细介绍请参考“设备管理配置指导”中的“设备基本配置”。
本功能仅对在线AP生效。
# 在AC上保存ap1的诊断信息。
<Sysname> display wlan ap name ap1 diagnostic-information
Diagnostic information is being output to flash:/apdiag/apdiag_ap1.tar.gz.
Saved successfully.
display wlan ap files命令用来显示AP上的文件及文件夹信息。
display wlan ap name ap-name files
name ap-name:指定AP的名称,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示ap1的文件及文件夹信息。
<Sysname> display wlan ap name ap1 files
Directory of flash:
   0   13638656  wa4300-system.bin
   1   2573312   wa4300-boot.bin
131072 KB total (114208 KB free)
表1-7 display wlan ap files命令显示信息描述表
Directory of
当前显示的AP目录
0   13638656  xx.xx
AP文件夹的信息:
·     0表示编号,由系统自动分配
·     13638656表示文件大小,单位为B。如果显示为“-”,则表示它是文件夹
·     xx.xx表示名称
·     download file
·     delete file
display wlan ap group命令用来显示AP所属的AP组。
display wlan ap { all | name ap-name } group
all:显示所有AP所属的AP组。
name ap-name:显示指定AP所属的AP组。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示所有AP所属的AP组。
<Sysname> display wlan ap all group
Remaining APs: 2046
Remaining local AP licenses: 126.75
Sync AP licenses: 0
                                 AP information
 State: I = Idle,       J= Join,       JA= JoinAck,    IL= ImageLoad
         C= Config,     DC= DataCheck,  R= Run   M= Master,  B= Backup
AP name                        APID  State Model           AP group name
ap1                            1     R     WA6320          default-group
ap2                            2     R     WT1020          default-group
ap3                            3     R     WTU420H         default-group
表1-8 display wlan ap all group命令显示信息描述表
Total number of APs
处于连接状态的普通AP的总数量
处于连接状态的WTU总数量
Remaining APs
Total AP licenses
local AP licenses
AC本地License数量
Server AP licenses
AC从服务器申请的License数量
Sync AP licenses
共享的AP License数量
APID
AP name
AP名称
AP当前状态:
·     I:空闲状态
·     J:CAPWAP连接建立状态
·     JA:CAPWAP连接确认阶段
·     IL:版本下载状态
·     C:初始化配置下载状态
·     DC:数据校验状态
Model
AP型号信息
AP group name
AP所属的AP组
display wlan ap group-name命令用来显示AP组内AP信息。
display wlan ap group-name ap-group-name
ap-group-name:AP组名称。
# 显示group1中所有AP的信息。
<Sysname> display wlan ap group-name group1
Total number of APs: 2
Total number of online APs: 1
                                 AP information
 Online time : Day:Hour:Minute:Second
ap3      3     R     WTU430H   219801A0SS9156G00169 group1       100:12:47:10 5         Fit    1.1.1.72
表1-9 表1-1 display wlan ap group-name命令显示信息描述表
Total number of APs
AP的数量,包括普通AP,虚拟AP,WT(Wireless Terminator,无线终结者)和WTU(Wireless Terminator Unit,无线终结单元)
上线AP的总数量,包括普通AP,WT和WTU
APID
AP name
AP名称
AP当前状态:
·     I:空闲状态
·     J:CAPWAP连接建立状态
·     JA:CAPWAP连接确认阶段
·     IL:版本下载状态
·     C:初始化配置下载状态
·     DC:数据校验状态
Model
AP型号信息
Serial ID
Group name
AP组名
Online time
AP在线时长
Clients
终端个数
Mode
AP模式
·     Fit:Fit AP
·     VAP:Virtual AP
·     Cloud:Cloud AP
·     Fat:Fat AP
IP address
AP的IP地址
display wlan ap interface命令用来显示在线AP的以太网接口的统计信息。
display wlan ap { all | name ap-name } interface [ verbose ]
all:显示所有在线AP的以太网接口的统计信息。
name ap-name:显示指定在线AP的以太网接口的统计信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
verbose:显示在线AP的以太网接口的详细统计信息。不指定该参数时,将显示接口的简要统计信息。
# 显示所有在线AP的以太网接口的简要统计信息。
<Sysname> display wlan ap all interface
AP name                           Interface            State Speed
ap1                               GE1/0/1              UP    1Gbps
ap2                               GE1/0/1              DOWN  Unknown
ap3                               GigabitEthernet1/0/1 DOWN  N/A
# 显示所有在线AP的以太网接口的详细统计信息。
<Sysname> display wlan ap all interface verbose
AP name: ap1
State  : UP
Speed  : 1 Gbps
Input  : 10 packets, 200 bytes
2 unicasts, 6 broadcasts, 2 multicasts, 0 drops
0 errors
Output : 10 packets, 200 bytes
4 unicasts, 4 broadcasts, 2 multicasts, 0 drops
0 errors
AP name: ap2
State  : DOWN
Speed  : Unknown
Input  : 0 packets, 0 bytes
0 unicasts, 0 broadcasts, 0 multicasts, 0 drops
0 errors
Output : 0 packets, 0 bytes
0 errors
AP name: ap3
State  : DOWN
Speed  : N/A
0 errors
0 errors
# 显示指定在线AP的以太网接口的简要统计信息。
<Sysname> display wlan ap name ap1 interface
# 显示指定在线AP的以太网接口的详细统计信息。
<Sysname> display wlan ap name ap1 interface verbose
AP name: ap1
State  : UP
Speed  : 1 Gbps
0 errors
0 errors
表1-10 display wlan ap interface命令显示信息描述表
AP name
AP的名称
接口名称,如果未获取到接口信息,则简要统计信息显示接口全称
接口物理连接状态,取值包括:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
Speed
接口的速率,如果显示为N/A,则表示未获取到接口速率,如果显示为Unknown,则表示接口速率未知
Input
接口接收报文的统计信息
Output
接口发送报文的统计信息
packets
接口接收或者发送的报文数量
bytes
接口接收或者发送的字节数
unicasts
接口接收或者发送的单播报文数量
broadcasts
接口接收或者发送的广播报文数量
multicasts
接口接收或者发送的组播报文数量
drops
接口丢弃的报文数量
errors
接口接收或者发送的错误报文数量
display wlan ap online-time命令用来显示AP的关联时长。
display wlan ap { all | name ap-name } online-time
all:显示所有AP的关联时长。
name ap-name:显示指定AP的关联时长。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示所有AP的关联时长。
<Sysname> display wlan ap all online-time
AP name            IP address               Time
ap1                1.1.1.2                  0 days 0 hours 2 minutes 6 seconds
ap2                1.1.1.1                  0 days 0 hours 5 minutes 6 seconds
ap3                1.1.1.6                  0 days 0 hours 2 minutes 1 seconds
表1-11 display wlan ap online-time命令显示信息描述表
AP name
AP名称
IP address
AP的IP地址
Time
AP从上线到当前查询时刻的关联时长
display wlan ap reboot-log命令用来显示指定AP的重启日志信息。
display wlan ap name ap-name reboot-log
name ap-name:指定重启的AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
如果AP曾发生过系统崩溃,那么可以使用该命令查看相关信息,注意指定的AP必须处于Run状态。
# 显示ap1的重启日志信息。
<Sysname> display wlan ap name ap1 reboot-log
Debugging information is not available on the AC.
Downloading debugging data from AP. Continue? [Y/N]:y
Downloading debugging data. Please wait...
Please enter the same command again to view the log messages.
--------------------- Reboot record 1 ---------------------
Recorded at           : 2018-07-20  03:29:43.324529
Occurred at           : 2018-07-20  03:29:43.324529
Reason                : 0x8
Thread                : devd (TID: 50)
Context               : thread context
Cpu                   : 0
Kernel module info    : module name (system) module address (0xd145a000)
                        module name (addon) module address (0xd00d5000)
Last 5 thread switches : WDRVFwdKthread (3:29:43.323999)-->
                         swapper (3:29:43.324011)-->
                         WDRVFwdKthread (3:29:43.324467)-->
                         swapper (3:29:43.324478)-->
                         devd (3:29:43.324502)-->
   略
·     reset wlan ap reboot-log
display wlan ap reboot-record命令用来显示AP的重启信息。
display wlan ap { all | name ap-name } reboot-record
all:显示所有AP的重启信息。
name ap-name:显示指定AP的重启信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
本命令只能显示当前在线AP的重启信息,若AP刚上线,则AC需要花费几分钟时间从AP获取重启信息。
AP掉线后,其重启信息会从AC上删除。
在双链路备份组网中,只支持从主AC上查看AP的重启信息。
# 显示ap1的重启信息。
<Sysname> display wlan ap name ap1 reboot-record
AP Name   : ap1
PowerOn BootTimes   : 70
Watchdog BootTimes  : 7
Software BootTimes   : 2939
Hardware BootTimes  : 0
MotherBoard BootTimes   : 0
Backup BootTimes  : 0
SlotOut BootTimes   : 0
Current Boot Type  : Poweron-boot
Current Running Time   : 240(s)
Running Time  : 90(d)7(h)
*** Boot History(Startup Time and Reason) ***
2021-09-10 20:46:36 Power on
2021-09-10 20:46:30 Power on
2021-09-10 20:46:51 Power on
2021-09-10 20:46:51 User soft reboot
2021-09-10 20:46:51 User soft reboot(Stayed in idle state for a long time)
# 显示所有AP的重启信息。
<Sysname> display wlan ap all reboot-record
Display AP reboot record total num: 2
Get AP Reboot info num: 2
AP Name   : ap1
Current Running Time   : 480(s)
AP Name   : ap2
PowerOn BootTimes   : 140
Watchdog BootTimes  : 6
Software BootTimes   : 2039
Running Time  : 70(d)5(h)
表1-12 display wlan ap reboot-record命令显示信息描述表
Number of Online APs Supporting Displaying Reboot Records
支持显示AP重启信息的在线AP总数
Number of APs from Which Reboot Records Have Been Obtained
已经获取重启信息的数量
AP Name
AP名称
PowerOn BootTimes
上电启动次数
Watchdog BootTimes
看门狗启动次数
Software BootTimes
软件启动次数
Hardware BootTimes
硬件启动次数
主板启动次数
Backup BootTimes
备用设备启动次数
Current Boot Type
当前启动类型,取值包括:
·     Unknown:未知
·     Poweron-boot:上电启动
·     Software-boot:软件启动
·     Watchdog-boot:看门狗启动
·     Hardware-boot:硬件启动
·     MotherBoard-boot:主板启动
·     ExtendWatchdog-boot:扩展看门狗启动
·     Backup-boot:备用设备启动
·     ExtendedModuleRemoved-boot:扩展模块移除启动
本次启动后运行的时间
Running Time
累计运行时间,格式为:天数(d)小时数(h)
Boot History
历史重启原因,包括主类和子类,子类在主类后面括号内显示
主类主要取值有:
·     Power on:上电启动
·     Hard reboot:复位键重启
·     Watchdog reboot:狗叫重启
·     User soft reboot:用户通过命令行、SNMP或者Web等方式重启设备
·     Kernel exception soft reboot:内核异常导致的重启
·     Kernel deadloop soft reboot:内核死循环导致的重启
·     DevHandShake soft reboot:设备管理握手失败导致的重启
·     Lic overTime soft reboot:License过期导致的重启
·     Slave switch soft reboot:主备倒换重启原主设备
·     IRF mergesoft reboot:IRF合并重启
·     Auto update soft reboot:版本自动升级重启
·     Memory-exhausted reboot:单板内存耗尽重启
·     -Crypto self-test failed reboot:算法库自检失败重启
子类主要取值有:
·     Reset by admin:用户手工ResetAP重启AP
·     Image was downloaded successfully:AP版本升级成功重启AP
·     Stayed in idle state for a long time:AP关联AC超时重启
·     WTU reboot because of offline WT:WT不在线,WTU重启
·     AP reset from Cloud:云端重启AP
·     Anomaly detected:业务探测异常重启
·     Inconsistent BSS states on AC and AP:AC侧检查BSS状态与AP侧不一致,AC主动重启AP
·     Inconsistent BSS states on AP and in drive:AP侧检查BSS状态与驱动侧不一致,AP自主重启
·     Inconsistent radio states on AC and AP:AC侧检查射频状态与AP侧不一致,AC主动重启AP
·     Inconsistent radio modes on AC and AP:AC侧检查射频类型与AP侧不一致,AC主动重启AP
·     Inconsistent radio rates on AC and AP:AC侧检查射频速率与AP侧不一致,AC主动重启AP
·     Inconsistent radio channels on AC and AP:AC侧检查射频信道与AP侧不一致,AC主动重启AP
·     Inconsistent radio bandwidth on AC and AP:AC侧检查射频带宽与AP侧不一致,AC主动重启AP
·     Inconsistent radio interface states on AC and AP:AC侧检查射频接口状态与AP侧不一致,AC主动重启AP
·     Inconsistent radio states on AP and in drive:AP侧检查射频状态与驱动侧不一致,AP自主重启
·     Inconsistent radio modes on AP and in drive:AP侧检查射频类型与驱动侧不一致,AP自主重启
·     Inconsistent radio channels on AP and in drive:AP侧检查射频信道与驱动侧不一致,AP自主重启
·     Inconsistent radio bandwidth on AP and in drive:AP侧检查射频带宽与驱动侧不一致,AP自主重启
·     Anchor AC detected another anchor AC with smaller MAC address and switched its role to AP:角色为AC的Anchor AP探测到比自己MAC小的另一台角色为AC的Anchor AP,本Anchor AP自主重启降级为AP角色
·     Anchor AC received a discovery response and switched its role to AP:角色为AC的Anchor AP收到discovery response报文,自主重启降级为AP角色
·     Anchor AP failed to detect other anchor ACs or ACs and switched its role to AC:Anchor AP未探测到其他AC或Anchor AC,Anchor AP自主重启晋升为AC角色
·     Anchor AC detected another anchor AC with higher priority and switched its role to AP:AC角色的Anchor AP探测到固化为AC角色的Anchor AP,自主重启降级
·     Configure the anchor device as an AC:配置Anchor AP的角色为AC,Anchor AP自主重启
·     Configure the anchor device as an AP:配置Anchor AP的角色为AP,Anchor AP自主重启
·     Manually configure the AP to act as a fit AP:手动配置AP工作在FIT AP模式,AP自主重启
·     Manually configure the AP to act as a fat AP:手动配置AP工作在FAT AP模式,AP自主重启
·     Manually configure the inside AP to act as a fat AP:配置内部AP工作在FAT AP模式,AP自主重启
·     Local AC image download:Local-AC下载完镜像文件后重启
·     Device role changed from common to local:设备角色由Common切换为Local后重启
·     Device role changed from local to common:设备角色由Local切换为Common后重启
·     Device role changed from common to central:设备角色由Common切换为Central后重启
·     Device role changed from central to common:设备角色由Central切换为Common后重启
·     WT version changed:WT版本切换,自主重启
·     Cannot process subslot insert event:子卡插入事件处理失败,WT主动重启WTU
·     Cannot send subslot insert event to next step for processing:子卡插入事件转场景消息处理失败,WT主动重启WTU
display wlan ap region-code命令用来显示AP的区域码信息。
display wlan ap { all | name ap-name } region-code
all:显示所有AP的区域码信息。
name ap-name:显示指定AP的区域码信息,ap-name为指定AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示所有AP的区域码信息。
<Sysname> display wlan ap all region-code
Region Code
AP name                         Region Code
ap1                             CN  CHINA
ap2                             CN  CHINA
ap3                             CN  CHINA
表1-13 display wlan ap region-code命令显示信息描述表
AP name
AP名称
Region Code
区域码,关于区域码对应的国家和地区,请参见表1-34
display wlan ap running-configuration命令用来显示指定AP或所有AP的运行配置。
display wlan ap { all | name ap-name } running-configuration [ verbose ]
all:显示所有AP的运行配置。
verbose:显示AP的详细运行配置。
# 显示所有AP的详细运行配置。
<Sysname> display wlan ap all running-configuration verbose
(i) -- Inherited from AP group
(ir) -- Inherited from AP group RF configuration
(g) -- Inherited from AP global-configuration
(wt)-- Inherited from WT
wlan ap ap1 model WA6320 id 5
  ap group name 1
  serial-id 219801A28N819CE00021
  region code 156
  echo interval 10 (i)
  retransmission count 3 (i)
  retransmission interval 5 (i)
  statistics interval 50 (i)
  fragment-size data 1500 (i)
  fragment-size control 1450 (i)
  tunnel-preempt disable (g)
  firmware-upgrade disable (g)
  priority 4 (i)
…略…
  radio 1
    radio type 802.11ac(5GHz) (i)
    radio disable (i)
    channel auto<64> (i)
    channel unlock (i)
    fragment-threshold 2346 (i)
    max-power 20 (i)
    power unlock (i)
    distance 1 kilometer (i)
    ANI Enabled (i)
    service time 5001 (i)
    idle time 100 (i)
    scan time 900 (i)
…略…
  radio 2
    radio type 802.11n(2.4GHz) (i)
    radio disable (i)
    channel auto<11> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
…略…
wlan ap ap2 model WA6320 id 6
  ap group name 2
  serial-id 219801A28N819CE0002T
  region code 156
  priority 4 (i)
…略…
  radio 1
    radio disable (i)
    channel auto<60> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
…略…
  radio 2
    radio disable (i)
    channel auto<13> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
…略…
表1-14 display wlan ap all running-configuration verbose命令显示信息描述表
表示继承AP组配置
表示继承AP组全局Radio视图下的配置
表示继承AP全局配置
(wt) -- Inherited from WT
表示继承WT
display wlan ap statistics association-failure-record命令用来显示AP上线失败原因。
# 显示AP上线失败原因。
<Sysname> display wlan ap statistics association-failure-record
MAC address    AP ID Last failed at   Reason
9a48-45ed-0300 12312 07-07/15:56:25   AP authentication failed
表1-15 display wlan ap association-failure-record命令显示信息描述表
MAC address
AP的MAC地址
AP ID
AP的ID,用于在AC上唯一标识一个AP
Last failed at
最近一次上线失败的时间,格式为date/hh:mm:ss
Reason
AP上线失败原因:
·     Failed to create data check timer:创建数据检测定时器失败
·     Memory is not enough:内存不足
·     The AP model doesn't exist:不支持AP类型
·     Lack of AP license:缺少AP License
·     MAC address conflict:MAC地址冲突
·     Failed to add APLB:添加APLB失败
·     AP chose another AC:AP选择其它AC上线
·     Reached AC max capability:已经达到AC最大能力级
·     Received join request in Run state:run状态收到join request
·     APLB check failed:检查APLB失败
·     Rejected AP access in HA smooth:HA期间拒绝AP上线
·     Failed to create auto AP:创建自动AP失败
·     The AP information has already existed:AP信息已存在
·     Failed to download AP image file:下载AP版本文件失败
·     Timer for waiting change state event request expired:等待改变状态请求报文超时
·     Time for waiting image data request or configuration request expired:等待映像数据请求或配置状态请求超时
·     Received failure result code in change state event request:在改变状态请求报文中收到失败的结果码
·     AP configuration was not found:无AP相关配置
·     Inconsistent AP IDs:AP ID不一致
·     Failed to send query message:发送Query消息失败
·     Open image file timer expired:打开版本文件超时
display wlan ap statistics image-download命令用来显示AP下载版本的相关信息。
display wlan ap statistics image-download [ failed | in-progress | succeeded ]
failed:显示下载版本失败的AP列表。
in-progress:显示正在下载版本的AP列表。
succeeded:显示下载版本成功的AP列表。
未指定参数时,显示AP下载版本的简要信息。
# 显示AP下载版本的简要信息。
<Sysname> display wlan ap statistics image-download
Completed                                     : 50%
Time consumed                                 : xxd hh:mm:ss
Max. concurrent image downloads of online APs : 192
AP count:
 Succeeded : 152
 In-progress : 140
 Failed : 8
表1-16 display wlan ap statistics image-download命令显示信息描述表
Completed
版本下载完成AP占AP总数的百分比
Time consumed
截止到现在,本次在线升级用时
AP在线并发下载版本数
Total to download
本次需要在线升级的AP总数
Succeeded
升级成功的AP数量
In-progress
正在下载版本的AP数量
Failed
升级失败的AP数量
# 显示当前正在下载版本的AP列表。
<Sysname> display wlan ap statistics image-download in-progress
AP name                       Time consumed    Time left  Progress
ap6                           xxd 00:45:11     00:01:16   96%
ap7                           N/A              N/A        N/A
ap8                           xxd 00:14:05     00:06:15   80%
ap9                           xxd 01:16:09     00:00:04   99%
------More----
表1-17 display wlan ap statistics image-download downloading命令显示信息描述表
AP name
AP的名称
Time consumed
AP下载时长:
·     N/A:表示AP正在等待下载版本
·     hh:mm:ss:正在下载的AP到目前为止的下载用时
Time left
AP下载剩余时长:
·     N/A:表示AP正在等待下载版本
·     hh:mm:ss:预计剩余下载时长
Progress
AP下载进度:
·     N/A:表示AP正在等待下载版本
·     %:表示当前AP的下载进度
# 显示下载版本失败的AP列表。
<Sysname> display wlan ap statistics image-download failed
AP name                     Failure reason
ap1                         Tunnel down
ap2                         AP memory not enough
ap3                         Image file does not exist
ap5                         Others(0x40010001)
------More----
表1-18 display wlan ap statistics image-download failed命令显示信息描述表
AP name
AP的名称
Failure reason
AP下载失败的原因:
·     Tunnel down:AP下线
·     AP memory not enough:AP内存不足
·     Image file does not exist:文件不存在
·     Retransmission failed:AP版本重传失败
·     Time out:AP应答版本下载报文超时
·     Others(0x0):其他原因,括号中会附加其他情况下的错误码。
¡     0x40010001:下载失败,缺少AP版本
¡     0x622c0085:连接断开
# 显示下载版本成功的AP列表。
<Sysname> display wlan ap statistics image-download succeeded
AP name                     Version
ap1                         R5220
ap2                         R5220
ap3                         R5220
ap5                         R5220
------More----
表1-19 display wlan ap statistics image-download succeeded命令显示信息描述表
AP name
AP的名称
Version
版本号
display wlan ap statistics switch-over-record命令用来显示主备链路切换的详细信息。
# 查看主备链路切换的详细信息。
<Sysname> display wlan ap statistics switch-over-record
AP name     Switch-over at  Switch-over Reason  Switch-over result   Tunnel Down Reason
Ap2         01-10/15:51:27  VSRP                Success              No reason
表1-20 display wlan ap statistics switch-over-record命令显示信息描述表
AP name
AP名称
Switch-over at
主备链路切换的时间
Switch-over Reason
主备链路切换的原因:
·     VSRP:表示AC主动触发主备链路切换
·     CAPWAP:表示AP触发主备链路切换
·     HA:表示主板异常触发主备倒换
Switch-over result
主备链路切换的结果:
·     Success:表示主备链路切换成功
·     Operation failed:表示主备链路切换操作失败
·     The state is incorrect:表示当前状态不正确
·     The operation is not supported:表示不支持主备链路切换操作
·     The item is not ready to perform the operation.:表示执行的操作当前未准备好
Tunnel Down Reason
隧道断开原因:
·     No Reason:表示无原因
·     APs failed to request a license:表示AP上线时获取License失败
·     Backup AC closed the backup tunnel:表示当前主备链路切换未准备好,备AC关闭了CAPWAP隧道
·     WT status is incorrect in master and backup switchover in dual link backup:表示双链路主备切换时,WT状态不正确(当前环境不允许WTU上线),WTU下线
·     WTU creation timer timed out after a master and backup switchover in dual link backup:表示双链路主备倒换时,WT状态不正确(当前环境不允许WTU上线),WTU创建定时器,定时器超时后WTU下线
·     Master and backup switchover is not allowed if AP software upgrade is enabled and APs were logged off:表示AP升级开关打开时不允许进行主备链路切换
·     AP upgrade failed because obtaining AP model information failed:获取AP model失败,导致AP升级失败
·     AP upgrade failed because the maximum number of CAPWAP tunnel connections for AC has been reached:AC的capwap隧道连接数已达最大,导致AP升级失败
·     AP upgrade failed because AC has reached the maximum capacity for managing AP:当前AC能力集已达最大,导致AP升级失败
·     AP automatic upgrade failed because APID is already in use:当前APID已被使用,导致自动AP升级失败
·     AP upgrade failed because auto AP cannot be created during upgrade:升级期间无法创建自动AP,导致AP升级失败
display wlan ap statistics online-record命令用来显示AP在线数量的统计信息。
display wlan ap statistics online-record [ datetime date time [ count count ] ]
datetime date time:查看指定时间之后的AP的在线记录,格式为YYYY/MM/DD(年/月/日) HH:MM(小时:分钟),YYYY的取值范围为2000~2035,MM的取值范围为1~12,DD的取值范围与月份有关,HH取值范围为0~23,MM取值范围为0~59。若未指定本参数,则按时间逆序显示7日内的全部AP在线数量信息。
count count:查看指定时间之后指定条数的AP在线纪录,count取值范围为1~256。若未指定本参数,则默认显示10条。
统计信息以分钟为单位逐条显示。命令仅支持查询7日范围内的统计信息,若指定时间,则显示以指定时间开始指定条数的统计信息的统计信息。
# 显示11条2017/10/11 10:16之后产生的AP在线数量的统计信息。
<Sysname> display wlan ap statistics online-record datetime 2017/10/11 10:16 count 11
Time                  Manual AP    Auto AP    Virtual AP    Total   Total delta
2017-10-11 10:16:00   20           10         10            40      -2
2017-10-11 10:17:00   22           10         10            42      2
2017-10-11 10:18:00   16           10         10            36      -6
2017-10-11 10:19:00   16           10         10            36      0
2017-10-11 10:20:00   16           10         10            36      0
2017-10-11 10:21:00   16           10         10            36      0
2017-10-11 10:22:00   16           10         10            36      0
2017-10-11 10:23:00   16           10         10            36      0
2017-10-11 10:24:00   16           10         10            36      0
2017-10-11 10:25:00   16           10         10            36      0
2017-10-11 10:26:00   16           10         10            36      0
表1-21 display wlan ap statistics online-record命令显示信息描述表
Time
Manual AP
手工物理AP在线数量
Auto AP
自动物理AP在线数量
Virtual AP
虚拟AP在线数量
Total
AP总在线数量
Total delta
与上一分钟相比AP在线数量的变化
display wlan ap statistics tunnel-down-record命令用来显示AC与AP间CAPWAP隧道断开的原因。
# 显示当前状态显示AC与AP间CAPWAP隧道断开的原因。
<Sysname> display wlan ap statistics tunnel-down-record
AP name         AP ID  Tunnel down at  Tunnel down reason             Tunnel Down Count
9a48-45ed-0300  123    07-07/15:56:25  Processed join request in Run state   3
表1-22 display wlan ap tunnel-down-record命令显示信息描述表
AP name
AP名称
AP ID
Tunnel down at
CAPWAP隧道断开时间,格式为date/hh:mm:ss
Tunnel down reason
CAPWAP隧道关闭的原因:
·     AP was reset by admin:用户重启AP
·     AP was reset by Web:Web网络管理重启AP
·     Processed join request in Run state:在Run状态收到join request
·     Backup AP upgrade failed:备份ap升级失败
·     WT went offline:本体已下线
·     WAP went offline because the SPM was down:因SPM本体下线导致的SPM下线
·     Licenses for all APs remotely licensed by AP count were forcibly reclaimed:以AP数量进行远程授权时,强制回收所有远程授权AP的license
·     Receiving AP serial ID based licenses timed out:以AP序列号进行远程授权时,接受远程授权License超时
·     Request for AP serial ID based licenses was denied:以AP序列号进行远程授权时,License授权信息不通过
·     Failed to confirm for AP serial ID based licenses respond:以AP序列号进行远程授权时,核对License授权信息不通过
·     License for an AP remotely licensed by AP serial ID was forcibly reclaimed:强制回收以AP序列号进行远程授权的指定远程授权License
·     Licenses for all APs remotely licensed by AP serial ID were forcibly reclaimed:强制回收以AP序列号进行远程授权的全部远程授权License
·     License client configuration was disabled:设备不再作为远程授权客户端
·     Failed to synchronize information about AP serial ID based licenses:以AP序列号进行远程授权的License平滑失败
·     Request for AP serial ID based licenses was Timeout :以AP序列号进行远程授权时,申请授权超时
·     Request for recover AP serial ID based license was failed:恢复AP时以AP序列号进行远程授权失败
Tunnel down count
AP累计下线次数
display wlan ap total-online-duration命令用来显示AP的总计关联时长。
display wlan ap { all | name ap-name } total-online-duration
all:显示所有AP的信息。
# 显示全部AP的总计关联时长。
<Sysname> display wlan ap all total-online-duration
5098-b860-7f80           1.1.0.48        0 days 0 hours 3 minutes 9 seconds
5098-b860-8b60           1.1.0.6         0 days 0 hours 3 minutes 36 seconds
# 显示指定AP的总计关联时长。
<Sysname> display wlan ap name 5098-b860-8b60 total-online-duration
5098-b860-8b60           1.1.0.6         0 days 0 hours 6 minutes 52 seconds
表1-23 display wlan ap total-online-duration命令显示信息描述表
AP name
AP名称
IP address
AP的IP地址
Time
AP的总计关联时长
display wlan ap tunnel latency命令用来显示指定AP的隧道延迟信息。
display wlan ap name ap-name tunnel latency
name ap-name:指定AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
只有CAPWAP隧道延迟检测功能处于开启状态,才能够显示指定AP的控制隧道和数据隧道延迟的信息。
 # 显示ap1的隧道延迟信息。
<Sysname> display wlan ap name ap1 tunnel latency
AP name                              : ap1
Tunnel Latency                       : Enabled
Control Link Delay:
  Current Delay                      : 1ms
  Maximum Delay                      : 1ms
  Minimum Delay                      : 1ms
Data Link Delay:
  Current Delay                      : 1ms
  Maximum Delay                      : 1ms
  Minimum Delay                      : 1ms
表1-24 display wlan ap tunnel latency命令显示信息描述表
Tunnel Latency
隧道延迟检测功能的开启状态
Control Link Delay
控制隧道延时检测结果
Data Link Delay
数据隧道延时检测结果
Current Delay
最近一次的延时时间,单位为毫秒
Maximum Delay
最大的延时时间,单位为毫秒
Minimum Delay
最小的延时时间,单位为毫秒
·     reset wlan tunnel latency ap
·     tunnel latency-detect
display wlan ap-group命令用来显示AP组信息。
display wlan ap-group [ brief | name group-name ]
brief:所有AP组的概要信息。
name group-name:显示指定AP组的详细信息,group-name表示AP组的名称,为1~31个字符的字符串,不区分大小写。如果未指定本参数,显示所有AP组信息。
# 显示所有AP组的详细信息。
<Sysname> display wlan ap-group
Total number of AP groups: 2
Description         : Not configured
AP model            : Not configured
APs                 : Not configured
AP group name       : group1
Description         : abcd
AP model            : WA6320
AP grouping rules:
  AP name           : ap1, ap2
  IPv4 address      : Not configured
  IPv6 address      : Not configured
APs                 : ap1 (AP name)
# 显示指定AP组的详细信息。
<Sysname> display wlan ap-group group1
AP model            : WA6320
AP grouping rules:
  AP name           : ap1, ap2
APs                 : ap1 (AP name)
# 显示所有AP组的概要信息。
<Sysname> display wlan ap-group brief
Total number of AP groups: 4
AP group name                  Group ID  Member APs   Online APs
default-group                  1         1            0
group1                         2         2006         1986
group2                         3         10           10
group3                         4         4            4
表1-25 display wlan ap-group命令显示信息描述表
AP组的总数量
AP group name
AP组名
AP组描述信息
AP model
AP型号名
AP grouping rules
AP组入组规则
AP name
AP名称入组规则
Serial ID
AP序列号入组规则
MAC address
AP MAC地址入组规则
IPv4 address
IPv4网段入组规则
IPv6 address
IPv6网段入组规则
APs
AP组中的AP
Group ID
AP组的ID号,用于在AC上唯一标识一个AP组
Member APs
加入该AP组的AP的数量
Online APs
该AP组中在线AP的数量
·     wlan ap-group
display wlan ap-model命令用来显示AP型号的信息。
display wlan ap-model { all | name model-name }
all:显示所有AP型号的信息。
name model-name:显示指定AP型号的信息。
# 显示AP型号WA6320的信息。
<Sysname> display wlan ap-model name WA6320
AP model        : WA6320
Alias           : WA6320
Vendor name     : H3C
Vendor ID       : 25506
License weight  : 100
License type    : 1
Radio count     : 2
 Radio 1:
  Mode          : 802.11a, 802.11an, 802.11ac
  Default mode  : 802.11ac
  BSS count     : 16
 Radio 2:
  Mode          : 802.11b, 802.11g, 802.11gn
  Default mode  : 802.11gn
  BSS count     : 16
Version Support List :
 Hardware Version Ver.A:
  Software Version         : R2206P02
  Default Software Version : R2206P02
  Image Name               : wa4300.ipe
 Hardware Version Ver.B:
 Hardware Version Ver.C:
 Hardware Version Ver.D:
 Hardware Version Ver.E:
 Hardware Version Ver.F:
表1-26 display wlan ap-model命令显示信息描述表
AP model
AP 型号名
Alias
AP型号别名
Vendor name
厂商名
Vendor ID
厂商ID
License weight
占用单个AP license的权重,单位为%
License type
AP类型:
·     1:普通AP
·     2:WTU
·     3:WT
Radio count
射频个数
Mode
支持的射频模式
Default mode
默认的射频模式
BSS count
一个Radio可以创建的最大基本服务集个数
版本支持列表
Hardware Version
AP的硬件版本
Software Version
APDB保存的FIT AP当前的软件版本号,用于和AP上报的软件版本号进行比较
APDB中保存的FIT AP缺省的软件版本号
Image Name
AP镜像文件
display wlan license命令用来显示已安装的WLAN License数量。
# 显示已安装的WLAN License数量。
<Sysname> display wlan license
Installed common AP licenses : 64
Installed WTU licenses       : 0
Licenses obtained from license server     : 5
License server state                      : Valid
Licensing method                          : By AP serial ID
表1-27 display wlan license命令显示信息描述表
已安装的普通AP License数量
已安装的WTU License数量
已获取的AP远程license数量
远程License server状态,内容如下:
·     Valid:License server可用
·     Invalid:License server不可用
Licensing method
远程License server方案,指授权方式,内容如下:
·     Unknown:方式未知
·     By AP serial ID:以AP的SN码进行授权
·     By AP count:以AP的数量进行授权
本命令的支持情况与AP型号有关,请以设备的实际情况为准。
display wlan modem statistics download-status命令用来显示CPE下载Modem模组版本的相关信息。
<Sysname> display wlan modem statistics download-status
Completed                                      : 67%
Time consumed                                  : 30min 35s
Max. concurrent modem downloads of online CPEs : 128
CPE count:
Succeeded : 1
In-progress : 1
Failed : 1
Time                 CPE Name              Status
02-05 19:14:18       cpe1                  Succeed
00:00:30             cpe2                  Downloading (60%)
02-05 19:13:18       cpe3                  Failed(Image file does not exist)
表1-28 display wlan modem statistics download-status命令显示信息描述表
Completed
所有CPE获取Modem模组软件版本的进度
Time consumed
所有CPE获取Modem模组软件版本过程中已经消耗的时间
同时下载Modem软件版本的最大CPE数量
CPE count
进行Modem模组版本下载的CPE统计信息
Total to download
进行Modem模组版本下载的CPE总数
Succeeded
成功进行Modem模组版本下载的CPE数量
In-progress
正在进行Modem模组版本下载的CPE数量
Failed
Modem模组版本下载失败的CPE数量
Time
对于下载Modem模组版本成功和失败的CPE而言,代表完成下载的时刻;对于正在下载Modem模组版本的CPE而言,代表下载版本已经消耗的时间
CPE Name
进行Modem模组版本下载的CPE名称
Status
Modem模组版本下载状态:
·     Succeed:下载成功
·     Downloading:下载中以及进度
·     Failed:下载失败及理由
display wlan virtual-ap命令用来显示虚拟AP的信息。
display wlan virtual-ap { all | name ap-name }
all:显示所有虚拟AP的信息。
name ap-name:显示指定虚拟AP的信息。ap-name表示虚拟AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示所有虚拟AP的信息。
<Sysname> display wlan virtual-ap all
Total number of virtual-APs: 1
Total number of connected virtual-APs: 1
Total number of connected common virtual-APs: 1
Total number of connected virtual-WTUs: 0
Maximum supported APs: 48
Remaining APs: 47
                               AP information
ap1                        1     R     WA6320          210235A1BSC123000050
表1-29 display wlan virtual-ap all命令显示信息描述表
虚拟AP的数量
处于连接状态的虚拟AP的总数量,包括普通虚拟AP和虚拟WTU
处于连接状态的普通虚拟AP的总数量
处于连接状态的虚拟WTU总数量
AC上最大AP容量,包括物理Fit AP和WTU、虚拟Fit AP和WTU,物理以及虚拟WT不计入AP容量
Remaining APs
剩余AP容量,即最大AP容量减去处于连接状态的物理Fit AP和WTU、虚拟Fit AP和WTU
AP name
虚拟AP名称
APID
虚拟AP的ID号,用于在AC上唯一标识一个虚拟AP
虚拟AP当前状态:
·     I:空闲状态
·     J:CAPWAP连接建立状态
·     JA:CAPWAP连接确认阶段
·     IL:版本下载状态
·     C:初始化配置下载状态
·     DC:数据校验状态
·     R:CAPWAP隧道处于运行状态,表示虚拟AP与AC成功建立CAPWAP隧道
·     R/M:CAPWAP主隧道处于运行状态,表示虚拟AP与主AC成功建立主隧道
·     R/B:CAPWAP备隧道处于运行状态,表示虚拟AP与备AC成功建立备隧道
·     M:主用状态,表示当前AC为虚拟AP的主用AC
·     B:备用状态,表示当前AC为虚拟AP的备用AC
·     R/IL:在线下版本状态,表示当前处于运行状态的虚拟AP正在下载版本
Model
虚拟AP型号信息
Serial ID
虚拟AP序列号,如果未指定,则显示为Not configured
# 显示虚拟AP ap1的信息。
<Sysname> display wlan virtual-ap name ap1
                                   AP information
表1-30 display wlan virtual-ap name ap1命令显示信息描述表
AP name
虚拟AP名称
APID
虚拟AP当前状态:
·     I:空闲状态
·     J:CAPWAP连接建立状态
·     JA:CAPWAP连接确认阶段
·     IL:版本下载状态
·     C:初始化配置下载状态
·     DC:数据校验状态
Model
虚拟AP型号信息
Serial ID
·     wlan virtual-ap
1.1.39  display wlan virtual-ap-group
display wlan virtual-ap-group命令用来显示虚拟AP组的信息。
display wlan virtual-ap-group [ brief | name group-name ]
brief:所有虚拟AP组的概要信息。
name group-name:显示指定虚拟AP组的详细信息,group-name表示虚拟AP组的名称,为1~31个字符的字符串,不区分大小写。如果未指定本参数,显示所有虚拟AP组的详细信息。
# 显示所有虚拟AP组的详细信息。
<Sysname> display wlan virtual-ap-group
Total number of virtual AP groups: 2
AP group name                : default-virtualapgroup
Description                  : abcd
AP model                     : WA6320
AP grouping rules:
  AP name                    : ap1, ap2
  Serial ID                  : 219801A0CNC138011454
  IPV4 address               : Not configured
  IPV6 address               : Not configured
APs                          : ap1 (AP name)
# 显示指定虚拟AP组的详细信息。
<Sysname> display wlan virtual-ap-group name group1
Virtual-AP group information
AP model                     : WA6320
AP grouping rules:
  AP name                   : ap1, ap2
APs                         : ap1 (AP name)
# 显示所有虚拟AP组的概要信息。
<Sysname> display wlan virtual-ap-group brief
Total number of virtual AP groups: 4
default-virtualapgroup         1         1            0
group1                         2         2006         1986
group2                         3         10           10
group3                         4         4            4
表1-31 display wlan virtual-ap-group命令显示信息描述表
虚拟AP组的总数量
AP group name
虚拟AP组名
虚拟AP组的描述信息
AP model
虚拟AP型号名
AP grouping rules
虚拟AP组的入组规则
AP name
虚拟AP名称入组规则
Serial ID
虚拟AP序列号入组规则
MAC address
虚拟AP MAC地址入组规则
IPV4 address
IPv4网段入组规则
IPV6 address
IPv6网段入组规则
APs
虚拟AP组中的虚拟AP
Group ID
虚拟AP组的ID号,用于在AC上唯一标识一个虚拟AP组
Member APs
加入该虚拟AP组的虚拟AP的数量
Online APs
该虚拟AP组中在线虚拟AP的数量
1.1.40  download file
download file命令用来下发指定的文件到AP。
download file filename
AP视图
filename:文件名,为1~255个字符的字符串。
只有在AP和AC建立了CAPWAP隧道并且当前AC为主AC时,用户才能通过文件下载操作将AC上存储的文件下发给AP。
# 将版本文件main.ipe下发到ap1。
[Sysname-wlan–ap-ap1] download file main.ipe
1.1.41  echo-count
echo-count命令用来配置回声请求报文的最大发送次数。
undo echo-count命令用来恢复缺省情况。
echo-count count
undo echo-count
AP视图:继承AP组配置。
AP组视图:AP组内的AP发送回声请求报文的最大次数为3次。
AP视图
AP组视图
count:指定AP发送回声请求报文的最大次数,取值范围3~255。
AP和AC之间通过保活机制来检查控制隧道是否正常工作。AP周期性地向AC发送回声请求Echo request报文,若在保活时间内没有收到AC回复的Echo response报文,则AP断开控制隧道;若AC在保活时间内没有收到Echo request报文,则AC断开控制隧道。保活时间为Echo request报文的发送时间间隔乘以最大发送次数。
# 配置AP向AC发送回声请求报文的最大次数。(AP视图)
[Sysname] wlan ap ap3 model WA6320
[Sysname-wlan-ap-ap3] echo-count 5
# 配置AP向AC发送回声请求报文的最大次数。(AP组视图)
[Sysname-wlan-ap-group-group1] echo-count 5
1.1.42  echo-interval
echo-interval命令用来配置AP发送回声请求的时间间隔。
undo echo-interval命令用来恢复缺省情况。
echo-interval interval
undo echo-interval
AP视图:继承AP组配置。
AP组视图:AP发送回声请求的时间间隔为10秒。
虚拟AP视图:继承虚拟AP组配置
虚拟AP组视图:虚拟AP发送回声请求的时间间隔为10秒。
AP视图
AP组视图
虚拟AP视图
虚拟AP组视图
interval:指定AP发送回声请求的时间间隔,取值范围为0~4294967295,单位为秒。
保活时间为Echo request报文的发送时间间隔乘以最大发送次数,最大发送次数由echo-count count命令配置:
·     当发送时间间隔乘以最大发送次数小于120秒时,保活时间为120秒;
·     当发送时间间隔乘以最大发送次数大于120秒时,即为实际计算结果;
·     当发送时间间隔配置为0时,关闭CAPWAP控制隧道的保活机制,即AP不向AC发送回声请求报文。
关闭保活机制仅适用于特殊测试场合。在非测试场合中,为了保证控制隧道的正常运行,请勿将interval参数配置为0。
# 配置AP向AC发送的回声请求时间间隔为15秒。(AP视图)
[Sysname-wlan-ap-ap3] echo-interval 15
# 配置AP向AC发送的回声请求时间间隔为15秒。(AP组视图)
[Sysname-wlan-ap-group-group1] echo-interval 15
# 配置虚拟AP向AC发送的回声请求时间间隔为15秒。(虚拟AP视图)
[Sysname] wlan virtual-ap ap3 model WA6320
[Sysname-wlan-virtual-ap-ap3] echo-interval 15
# 配置虚拟AP向AC发送的回声请求时间间隔为15秒。(虚拟AP组视图)
[Sysname-wlan-virtual-ap-group-group1] echo-interval 15
1.1.43  ethernet
ethernet命令用来进入AP的Eth以太网接口视图。
ethernet interface-number
AP视图
AP组ap-model视图
interface-number:指定接口编号。
# 进入AP的Eth 1以太网接口视图。(AP视图)
[Sysname] wlan ap ap1 model SIC-AP220
[Sysname-wlan-ap-ap1] ethernet 1
[Sysname-wlan-ap-ap1-ethernet-1]
# 进入AP的Eth 1以太网接口视图。(AP组ap-model视图)
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] ap-model SIC-AP220
[Sysname-wlan-ap-group-group1-ap-model-SIC-AP220] ethernet 1
[Sysname-wlan-ap-group-group1-ap-model-SIC-AP220-ethernet-1]
1.1.44  firmware-upgrade
firmware-upgrade enable命令用来开启AP版本升级功能。
firmware-upgrade disable命令用来关闭AP版本升级功能。
undo firmware-upgrade命令用来恢复缺省情况。
firmware-upgrade { disable | enable }
AP视图:AP组有配置的情况下,继承AP组配置,AP组无配置的情况下,继承全局配置。
AP组视图:继承全局配置。
虚拟AP视图:虚拟AP组有配置的情况下,继承虚拟AP组配置,虚拟AP组无配置的情况下,继承全局配置。
虚拟AP组视图:继承全局配置。
全局配置视图:AP版本升级功能处于开启状态。
AP视图
AP组视图
虚拟AP视图
虚拟AP组视图
全局配置视图
建立CAPWAP隧道过程中,如果AP版本升级功能处于开启状态,AC会将AP的软件版本与AC上保存的该AP型号的软硬件版本对应关系进行比较。如果软件版本一致,则允许CAPWAP隧道建立;如果软件版本不一致,则将此情况告知AP。AP收到版本不一致的消息后,会向AC请求版本并进行版本升级后,再重新与AC建立CAPWAP隧道连接。
建立CAPWAP隧道过程中,如果关闭AP版本升级功能,则AC不对AP当前的软件版本进行比较,直接与AP建立CAPWAP隧道连接。
AP视图下的配置优先级高于AP组视图下的配置,AP组视图下的配置优先级高于全局配置视图下的配置。
虚拟AP视图下的配置优先级高于虚拟AP组视图下的配置,虚拟AP组视图下的配置优先级高于全局配置视图下的配置。
# 开启AP版本升级功能。(AP视图)
[Sysname-wlan-ap-ap3] firmware-upgrade enable
# 开启AP版本升级功能。(AP组视图)
[Sysname-wlan-ap-group-group1] firmware-upgrade enable
# 开启AP版本升级功能。(虚拟AP视图)
[Sysname-wlan-virtual-ap-ap3] firmware-upgrade enable
# 开启AP版本升级功能。(虚拟AP组视图)
[Sysname] wlan virtual-ap-group group1
[Sysname-wlan-virtual-ap-group-group1] firmware-upgrade enable
# 开启AP版本升级功能。(全局配置视图)
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] firmware-upgrade enable
·     wlan apdb
1.1.45  fragment-size
fragment-size命令用来配置CAPWAP控制报文或数据报文分片的最大长度。
undo fragment-size命令用来将指定的CAPWAP报文分片长度恢复为缺省情况。
fragment-size { control control-size | data data-size }
undo fragment-size { control | data }
AP视图:继承AP组配置。
AP组视图:CAPWAP控制报文分片的最大长度为1450字节,CAPWAP数据报文分片的最大长度为1500字节。
AP视图
AP组视图
control control-size:指定CAPWAP控制报文分片的最大长度,取值范围为1000~1450,单位为字节。
data data-size:指定CAPWAP数据报文分片的最大长度,取值范围为1000~1748,单位为字节。
当AC与AP跨越Internet建立连接时,由于传输路径上的设备可能对报文分片大小进行限制,超过分片门限的报文将被丢弃,因此,需要配置CAPWAP控制报文与数据报文分片长度,使其顺利通过中间设备。
修改CAPWAP报文分片长度后,新配置对已在线的AP立即生效。
AP视图下的配置优先级高于AP组视图下的配置。
# 配置CAPWAP数据报文最大长度为1500字节。(AP视图)
[Sysname-ap-ap1] fragment-size data 1500
# 配置CAPWAP数据报文最大长度为1500字节。(AP组视图)
[Sysname-wlan-ap-group-group1] fragment-size data 1500
1.1.46  gigabitethernet
gigabitethernet命令用来进入AP的GE以太网接口视图。
gigabitethernet interface-number
AP视图
AP组ap-model视图
# 进入AP的GE 1以太网接口视图。(AP视图)
[Sysname-wlan-ap-ap1] gigabitethernet 1
[Sysname-wlan-ap-ap1-gigabitethernet-1]
# 进入AP的GE 1以太网接口视图。(AP组ap-model视图)
[Sysname-wlan-ap-group-group1] ap-model WA6320
[Sysname-wlan-ap-group-group1-ap-model-WA6320] gigabitethernet 1
[Sysname-wlan-ap-group-group1-ap-model-WA6320-gigabitethernet-1]
1.1.47  hybrid-remote-ap enable
hybrid-remote-ap enable命令用来开启Remote AP功能。
hybrid-remote-ap disable命令用来关闭Remote AP功能。
undo hybrid-remote-ap命令用来恢复缺省情况。
hybrid-remote-ap { disable | enable }
AP视图:继承AP组配置。
AP组视图:Remote AP功能处于关闭状态。
AP视图
AP组视图
缺省情况下,当AP与AC之间的隧道断开后,AP将停止为客户端提供服务。Remote AP功能支持在AP与AC之间的隧道断开后,AP能够继续为客户端提供服务。
仅当客户端数据报文的转发位置在AP上时,Remote AP功能才会生效。
# 开启Remote AP功能。(AP视图)
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] hybrid-remote-ap enable
# 开启Remote AP功能。(AP组视图)
[Sysname-wlan-ap-group-group1] hybrid-remote-ap enable
1.1.48  if-match ip
if-match ip命令用来创建IPv4网段入组规则。
undo if-match ip命令用来删除指定的或所有IPv4网段入组规则。
if-match ip ip-address { mask-length | mask }
undo if-match ip [ ip-address { mask-length | mask } ]
不存在IPv4网段入组规则。
AP组视图
虚拟AP组视图
ip-address:IPv4地址,为点分十进制格式。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为1~31。
mask:子网掩码,为点分十进制格式。
如果AP使用IPv4地址接入AC,则上线时会与AP组的IPv4网段进行匹配。如果AP的IP地址在AP组的IP网段范围内,AP会加入该AP组。
AP将按照如下顺序匹配入组规则:AP名称入组规则-->AP序列号入组规则-->AP MAC地址入组规则-->IPv4网段入组规则或IPv6网段入组规则。若AP未匹配到入组规则,则将被加入默认组。
default-group视图下不能配置IPv4网段入组规则。
同一AP组(或者不同AP组)的IPv4网段入组规则不能重叠或相互包含。
同一AP组下最多能够配置32条IPv4网段入组规则。
可以在AP组内同时配置IPv4和IPv6网段入组规则。
对于undo if-match ip命令,不指定任何参数,则表示删除所有IPv4网段入组规则。
# 配置IPv4网段入组规则,在192.168.0.0/16网段的AP加入名为group1的AP组。(AP组视图)
[Sysname-wlan-ap-group-group1] if-match ip 192.168.0.0 16
# 配置IPv4网段入组规则,在192.168.0.0/16网段的AP加入名为group1的虚拟AP组。(虚拟AP组视图)
[Sysname-wlan-virtual-ap-group-group1] if-match ip 192.168.0.0 16
1.1.49  if-match ipv6
if-match ipv6命令用来创建IPv6网段入组规则。
undo if-match ipv6命令用来删除IPv6网段入组规则。
if-match ipv6 { ipv6-address prefix-length | ipv6-address/prefix-length }
undo if-match ipv6 [ ipv6-address prefix-length | ipv6-address/prefix-length ]
不存在IPv6网段入组规则。
AP组视图
虚拟AP组视图
ipv6-address:IPv6地址。
prefix-length:IPv6地址前缀长度,取值范围为1~128。
如果AP使用IPv6地址接入AC,则上线时会与AP组的IPv6网段进行匹配。如果AP的IPv6地址在AP组的IPv6网段范围内,AP会加入该AP组。
default-group视图下不能配置IPv6网段入组规则。
同一AP组(或者不同AP组)的IPv6网段匹配条件不能重叠或相互包含。
同一AP组下最多能够配置32条IPv6网段入组规则。
对于undo if-match ipv6命令,不指定任何参数,则表示删除所有IPv6网段入组规则。
# 配置IPv6网段入组规则,在2001:DB0::/28网段的AP加入名为group1的AP组。(AP组视图)
[Sysname-ap-group-group1] if-match ipv6 2001:DB8:: 28
# 配置IPv6网段入组规则,在2001:DB0::/28网段的AP加入名为group1的虚拟AP组。(虚拟AP组视图)
[Sysname-wlan-virtual-ap-group-group1] if-match ipv6 2001:DB8:: 28
1.1.50  keepalive-interval
keepalive-interval命令用来配置AP发送CAPWAP数据隧道keep alive报文的时间间隔。
undo keepalive-interval命令用来恢复缺省情况。
keepalive-interval interval
AP视图:继承AP组配置。
AP组视图:AP发送CAPWAP数据隧道keep alive报文的时间间隔为10秒。
AP视图
AP组视图
interval:AP发送CAPWAP数据隧道keep alive报文的时间间隔,取值范围为1~255,单位为秒。
# 配置AP向AC发送CAPWAP数据隧道keep alive报文时间间隔15秒。(AP视图)
[Sysname-wlan-ap-ap1] keepalive-interval 15
# 配置AP向AC发送CAPWAP数据隧道keep alive报文时间间隔15秒。(AP组视图)
[Sysname] wlan ap-group 1
[Sysname-ap-group-1] keepalive-interval 15
1.1.51  led-mode
led-mode命令用来配置AP的LED闪烁模式。
undo led-mode命令用来恢复缺省情况。
led-mode { always-on | awake | normal | quiet }
undo led-mode
AP视图:继承AP组配置。
AP组视图:LED闪烁模式为normal模式。
AP视图
AP组视图
always-on:指定LED闪烁模式为always-on模式,表示LED常亮。本参数的支持情况与AP设备的型号有关,请以设备的实际情况为准。
awake:指定LED闪烁模式为awake模式,表示LED每分钟闪烁一次。本参数的支持情况与AP设备的型号有关,请以设备的实际情况为准。
normal:指定LED闪烁模式为normal模式,normal模式的LED闪烁情况与AP型号有关,请以设备的实际情况为准。
quiet:指定LED闪烁模式为quiet模式,表示LED常灭。
在AP组视图下配置LED闪烁模式为awake模式或always-on模式时,仅对组内支持该模式的AP生效。
AP视图下配置的优先级高于AP组视图下的配置。
# 配置LED闪烁模式为normal。(AP视图)
[Sysname-wlan-ap-ap1] led-mode normal
# 配置LED闪烁模式为awake。(AP组视图)
[Sysname] wlan ap-group g1
[Sysname-wlan-ap-group-g1] led-mode awake
1.1.52  link-aggregation mode
本命令的支持情况与AP的型号有关,请以设备的实际情况为准。
link-aggregation mode命令用来配置聚合组的工作模式及LACP协议状态。
undo link-aggregation mode命令用来恢复缺省情况。
link-aggregation mode { dynamic | static }
AP的二层聚合接口视图:继承AP组的二层聚合接口配置。
AP组的二层聚合接口视图:聚合组工作在静态聚合模式下。
AP的二层聚合接口视图
AP组的二层聚合接口视图
dynamic:动态聚合模式,同时开启LACP协议。
static:静态聚合模式,同时关闭LACP协议。
当聚合组中存在成员端口时,如果修改聚合组的工作模式,则可能导致聚合组中选中端口变为非选中状态,影响流量转发,请用户根据实际情况修改聚合组的工作模式。
只有远程配置同步功能处于开启状态,且配置了remote-configuration synchronize命令,本配置才会被同步到AP上执行。
# 配置二层聚合接口1对应的聚合组工作在动态聚合模式下。(AP的二层聚合接口视图)
[Sysname-wlan-ap-ap1] bridge-aggregation 1
[Sysname-wlan-ap-ap1-bridge-aggregation-1] link-aggregation mode dynamic
# 配置二层聚合接口1对应的聚合组工作在动态聚合模式下。(AP组的二层聚合接口视图)
[Sysname-wlan-ap-group-1] ap-model WA6320
[Sysname-wlan-ap-group-1-ap-model-WA6320] bridge-aggregation 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-bridge-aggregation-1] link-aggregation mode dynamic
·     remote-configuration
·     remote-configuration synchronize
1.1.53  mac-address (AP/Virtual-AP group view)
mac-address命令用来创建一条AP MAC地址入组规则。
undo mac-address命令用来删除AP MAC地址入组规则。
mac-address mac-address
undo mac-address mac-address
不存在AP MAC地址入组规则。
AP组视图
虚拟AP组视图
mac-address:AP的MAC地址,形式为H-H-H。
若其它组已经存在该MAC地址入组规则,在新组配置该MAC地址入组规则,则原AP组将删除该MAC地址入组规则。
本命令不检查指定的AP是否存在。
同一AP组下可配置多条AP MAC地址入组规则。
默认组视图下不能创建AP MAC地址入组规则。
虚拟AP的MAC地址为所在物理AP的MAC地址。
# 在AP组视图下添加AP MAC地址入组规则0AC1-F9B2-B1C2。
[Sysname-wlan-ap-group-group1] mac-address 0AC1-F9B2-B1C2
# 在虚拟AP组group1下添加虚拟AP MAC地址入组规则0AC1-F9B2-B1C2。
[Sysname-wlan-virtual-ap-group-group1] mac-address 0AC1-F9B2-B1C2
·     wlan ap-group
·     wlan virtual-ap-group
1.1.54  mac-address (AP/Virtual-AP view)
mac-address命令用来配置AP的MAC地址。
undo mac-address用来恢复缺省情况。
undo mac-address
未配置AP的MAC地址。
AP视图
虚拟AP视图
如果AP已经与AC建立CAPWAP隧道连接,改变和删除MAC地址将触发CAPWAP隧道的拆除,AP将会重新发现AC并与AC建立CAPWAP隧道。
# 配置ap1的MAC地址为0001-0000-0000。
[Sysname-wlan-ap-ap1] mac-address 0001-0000-0000
# 配置虚拟ap1的MAC地址为0001-0000-0000。
[Sysname] wlan virtual-ap ap1 model WA6320
[Sysname-wlan-virtual-ap-ap1] mac-address 0001-0000-0000
1.1.55  map-configuration
map-configuration 命令用来指定AP的配置文件。
undo map-configuration命令用来恢复缺省状态。
map-configuration filename
未指定AP的配置文件。
AP视图
AP组ap-model视图
filename:文件名称,为1~63个字符的字符串,不可以包含“#”,不区分大小写。
# 指定AP的配置文件为downconfig.txt。
[Sysname-wlan-ap-ap1] map-configuration downconfig.txt
# 指定AP组下AP的配置文件为downconfig.txt。
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] map-configuration downconfig.txt
1.1.56  modem firmware-upgrade
modem firmware-upgrade命令用来开启移动通信Modem模块版本自动升级功能。
undo modem firmware-upgrade命令用来恢复缺省情况。
modem firmware-upgrade { disable | enable }
AP组视图:继承全局组视图配置。
全局配置视图:模组版本自动升级功能处于关闭状态。
AP组视图
全局配置视图
开启模组版本自动升级功能后,AC会在CPE上线时立即检查CPE型号对应的Modem模块软件版本与AC配置中的是否一致,如果不一致,则将Modem模块的软件版本升级为AC存储介质中的软件版本。本功能处于开启状态下,CPE每次重启后都会执行上述模组版本升级操作。
在Modem模块版本升级期间,请不要对AC与CPE模组相连的接口进行shutdown操作。
AP组视图下的配置优先级高于全局组视图下的配置。
# 开启apgroup1组中CPE的移动通信Modem模块版本自动升级功能。
[Sysname-wlan-ap-group-apgroup1] modem firmware-upgrade enable
# 开启全局的移动通信Modem模块版本自动升级功能。
[Sysname-wlan-global-configuration] modem firmware-upgrade enable
1.1.57  poe port
poe port enable命令用来开启AP上PoE接口的远程供电功能。
poe port disable命令用来关闭AP上PoE接口的远程供电功能。
undo poe port命令用来恢复缺省情况。
poe port port-number1 [ to port-number2 ] { disable | enable }
undo poe port port-number1 [ to port-number2 ]
AP视图:继承AP组ap-model配置。
AP组ap-model视图:AP上PoE接口的远程供电功能处于关闭状态。
AP视图
AP组ap-model视图
port-number1:第一个PoE接口的编号,不同型号的AP支持的取值范围不同,请以设备的实际情况为准。
port-number2:最后一个PoE接口的编号,不同型号的AP支持的取值范围不同,请以设备的实际情况为准,该参数不能小于port-number1。
# 关闭WA5530X上PoE接口3的远程供电功能。(AP视图)
[Sysname] wlan ap ap1 model WA5530X
[Sysname-wlan-ap-ap1] poe port 3 disable
# 关闭WA5530X上PoE接口3的远程供电功能。(AP组ap-model视图)
[Sysname-wlan-ap-group-1] ap-model WA5530X
[Sysname-wlan-ap-group-1-ap-model-WA5530X] poe port 3 disable
1.1.58  port-isolate enable
port-isolate enable命令用来开启端口隔离功能。
port-isolate disable命令用来关闭端口隔离功能。
undo port-isolate命令用来恢复缺省情况。
port-isolate { enable | disable }
undo port-isolate
AP的以太网接口下的配置继承AP组以太网接口配置,AP组下以太网接口的端口隔离功能处于开启状态。
AP的Eth以太网接口视图
AP组的Eth以太网接口视图
AP的GE以太网接口视图
AP组的GE以太网接口视图
AP的2.5GE以太网接口视图
AP组的2.5GE以太网接口视图
AP的XGE以太网接口视图
AP组的XGE以太网接口视图
AP的二层聚合接口视图
AP组的二层聚合接口视图
以太网接口视图下的配置只对当前端口生效。
二层聚合接口视图下的配置对当前接口及其成员端口生效,若某成员端口配置失败,系统会跳过该端口继续配置其他成员端口,若二层聚合接口配置失败,则不会再配置成员端口。
AP的以太网接口视图下配置的优先级高于AP组的以太网接口视图下的配置。
# 开启AP端口GigabitEthernet 1的端口隔离功能。
[Sysname-wlan-ap-ap1-gigabitethernet-1] port-isolate enable
# 开启AP组端口GigabitEthernet 1的端口隔离功能。
[Sysname-wlan-ap-group-1-ap-model-WA6320] gigabitethernet 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port-isolate enable
1.1.59  port access vlan
port access vlan命令用来将AP上的Access端口加入到指定的AP VLAN中。
undo port access vlan命令用来恢复缺省情况。
port access vlan vlan-id
AP的以太网接口下的配置继承AP组以太网接口配置,AP组下所有的Access端口都属于VLAN 1。
AP的Eth以太网接口视图
AP组的Eth以太网接口视图
AP的GE以太网接口视图
AP组的GE以太网接口视图
AP的2.5GE以太网接口视图
AP组的2.5GE以太网接口视图
AP的XGE以太网接口视图
AP组的XGE以太网接口视图
AP的二层聚合接口视图
AP组的二层聚合接口视图
vlan-id:指定的VLAN编号,取值范围为1~4094。
在将Access端口加入到指定VLAN之前,该VLAN必须已经存在。
# 将AP的GigabitEthernet 1端口加入到VLAN 3中。
[Sysname-wlan-ap-ap1-gigabitethernet-1] port access vlan 3
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port access vlan 3
1.1.60  port hybrid pvid
port hybrid pvid命令用来配置AP上Hybrid端口的缺省VLAN。
undo port hybrid pvid命令用来配置AP上Hybrid端口的缺省VLAN为VLAN 1。
port hybrid pvid vlan vlan-id
AP的以太网接口下的配置继承AP组以太网接口配置,AP组下Hybrid端口的缺省VLAN为该端口在链路类型为Access时的所属VLAN。
AP的Eth以太网接口视图
AP组的Eth以太网接口视图
AP的GE以太网接口视图
AP组的GE以太网接口视图
AP的2.5GE以太网接口视图
AP组的2.5GE以太网接口视图
AP的XGE以太网接口视图
AP组的XGE以太网接口视图
AP的二层聚合接口视图
AP组的二层聚合接口视图
vlan-id:指定接口的缺省的VLAN ID,取值范围为1~4094。
对Hybrid端口,执行undo vlan命令删除端口的缺省VLAN后,端口的缺省VLAN配置不会改变,即可以使用已经不存在的VLAN作为缺省VLAN。
建议AP上Hybrid端口的缺省VLAN和AP相连的对端交换机的Hybrid端口的缺省VLAN保持一致。
配置缺省VLAN后,必须使用port hybrid vlan命令配置端口允许缺省VLAN的报文通过,该端口才能转发缺省VLAN的报文。
# 配置AP端口GigabitEthernet 1(Hybrid类型)的缺省VLAN为100。
[Sysname-wlan-ap-ap1-gigabitethernet-1] port link-type hybrid
[Sysname-wlan-ap-ap1-gigabitethernet-1] port hybrid pvid vlan 100
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port link-type hybrid
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port hybrid pvid vlan 100
·     port hybrid vlan
·     port link-type
1.1.61  port hybrid vlan
port hybrid vlan命令用来允许指定的VLAN通过当前Hybrid端口。
undo port hybrid vlan命令用来禁止指定的VLAN通过当前Hybrid端口。
undo port hybrid vlan vlan-id-list
AP的以太网接口下的配置继承AP组以太网接口配置,AP组下Hybrid端口只允许该端口在链路类型为Access时的所属VLAN的报文以Untagged方式通过。
AP的Eth以太网接口视图
AP组的Eth以太网接口视图
AP的GE以太网接口视图
AP组的GE以太网接口视图
AP的2.5GE以太网接口视图
AP组的2.5GE以太网接口视图
AP的XGE以太网接口视图
AP组的XGE以太网接口视图
AP的二层聚合接口视图
AP组的二层聚合接口视图
vlan-id-list:VLAN列表,Hybrid端口允许通过的VLAN范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。该VLAN必须是设备上已创建的VLAN。
untagged:该端口在转发指定的VLAN报文时将去掉VLAN Tag。
Hybrid端口允许多个VLAN通过。如果多次使用port hybrid vlan命令,那么Hybrid端口上允许通过的VLAN是这些vlan-id-list的合集。
# 配置AP端口GigabitEthernet 1为Hybrid端口,允许VLAN 2、4、50~VLAN 100通过,并且发送这些VLAN的报文时携带VLAN Tag。
[Sysname-wlan-ap-ap1-gigabitethernet-1] port hybrid vlan 2 4 50 to 100 tagged
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port hybrid vlan 2 4 50 to 100 tagged
·     port link-type
1.1.62  port link-aggregation group
port link-aggregation group命令用来将接口加入指定的聚合组。
undo port link-aggregation group命令用来将接口从已加入的聚合组中删除。
AP的以太网接口下的配置继承AP组以太网接口配置,AP组下以太网接口未加入任何聚合组。
AP的Eth以太网接口视图
AP组的Eth以太网接口视图
AP的GE以太网接口视图
AP组的GE以太网接口视图
AP的2.5GE以太网接口视图
AP组的2.5GE以太网接口视图
AP的XGE以太网接口视图
AP组的XGE以太网接口视图
group-id:指定聚合组所对应聚合接口的编号。不同型号的AP支持的取值范围不同,请以设备的实际情况为准。
二层以太网接口只能加入二层聚合组,一个接口只能加入一个聚合组。
接口加入聚合组后,接口下的配置会继承聚合组下的配置。
配置本命令之前请保证AP视图或AP组视图下已创建二层聚合接口,并且AP支持创建二层聚合接口。
# 将AP端口GigabitEthernet 1加入二层聚合组1中。
[Sysname-wlan-ap-ap1-gigabitethernet-1] port link-aggregation group 1
[Sysname-wlan-ap-group-1-ap-model-WA6320 gigabitethernet 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port link-aggregation group 1
1.1.63  port link-type
port link-type命令用来配置AP以太网端口的链路类型。
undo port link-type命令用来恢复缺省情况。
undo port link-type
AP的以太网接口下的配置继承AP组以太网接口配置,AP组下以太网接口的链路类型为Access类型。
AP的Eth以太网接口视图
AP组的Eth以太网接口视图
AP的GE以太网接口视图
AP组的GE以太网接口视图
AP的2.5GE以太网接口视图
AP组的2.5GE以太网接口视图
AP的XGE以太网接口视图
AP组的XGE以太网接口视图
AP的二层聚合接口视图
AP组的二层聚合接口视图
access:配置以太网端口的链路类型为Access类型。
hybrid:配置以太网端口的链路类型为Hybrid类型。
trunk:配置以太网端口的链路类型为Trunk类型。
# 配置AP端口GigabitEthernet 1的链路类型为Trunk类型。
[Sysname-wlan-ap-ap1-gigabitethernet-1] port link-type trunk
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port link-type trunk
1.1.64  port trunk permit vlan
port trunk permit vlan命令用来允许指定的VLAN通过当前Trunk端口。
undo port trunk permit vlan命令用来禁止指定的VLAN通过当前Trunk端口。
undo port trunk permit vlan { vlan-id-list | all }
AP的以太网接口下的配置继承AP组以太网接口配置,AP组下Trunk端口不允许任何VLAN的报文通过。
AP的Eth以太网接口视图
AP组的Eth以太网接口视图
AP的GE以太网接口视图
AP组的GE以太网接口视图
AP的2.5GE以太网接口视图
AP组的2.5GE以太网接口视图
AP的XGE以太网接口视图
AP组的XGE以太网接口视图
AP的二层聚合接口视图
AP组的二层聚合接口视图
vlan-id-list:VLAN列表,Trunk端口允许通过的VLAN范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
all:表示允许所有VLAN通过该Trunk端口。
Trunk端口可以允许多个VLAN通过。如果多次执行port trunk permit vlan命令,那么Trunk端口上允许通过的VLAN是这些vlan-id-list的集合。
Trunk端口发送出去的报文,只有缺省VLAN的报文不带VLAN Tag,其他VLAN的报文均会保留VLAN Tag。
建议用户谨慎使用port trunk permit vlan all命令,以防止未授权VLAN的用户通过该端口访问受限资源。
# 配置AP端口GigabitEthernet 1为Trunk端口,允许VLAN 2、4、50~100通过。
[Sysname-wlan-ap-ap1-gigabitethernet-1] port trunk permit vlan 2 4 50 to 100
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port trunk permit vlan 2 4 50 to 100
·     port link-type
1.1.65  port trunk pvid
port trunk pvid命令用来配置AP上Trunk端口的缺省VLAN。
undo port trunk pvid命令用来恢复缺省情况。
port trunk pvid vlan vlan-id
AP的以太网接口下的配置继承AP组以太网接口配置,AP组下Trunk端口的缺省VLAN为VLAN 1。
AP的Eth以太网接口视图
AP组的Eth以太网接口视图
AP的GE以太网接口视图
AP组的GE以太网接口视图
AP的2.5GE以太网接口视图
AP组的2.5GE以太网接口视图
AP的XGE以太网接口视图
AP组的XGE以太网接口视图
AP的二层聚合接口视图
AP组的二层聚合接口视图
vlan-id:指定接口的缺省VLAN ID,取值范围为1~4094。
对Trunk端口,执行undo vlan命令删除端口的缺省VLAN后,端口的缺省VLAN配置不会改变,即使用已经不存在的VLAN作为缺省VLAN。
本端设备Trunk端口的缺省VLAN ID和相连的对端设备的Trunk端口的缺省VLAN ID必须一致,否则报文将不能正确传输。
配置缺省VLAN后,必须使用port trunk permit vlan命令配置端口允许缺省VLAN的报文通过,该端口才能转发缺省VLAN的报文。
# 配置AP端口GigabitEthernet 1(Trunk类型)的缺省VLAN为VLAN 100,并允许VLAN 100通过。
[Sysname-wlan-ap-ap1-gigabitethernet-1] port trunk pvid vlan 100
[Sysname-wlan-ap-ap1-gigabitethernet-1] port trunk permit vlan 100
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port trunk pvid vlan 100
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port trunk permit vlan 100
·     port link-type
·     port trunk permit vlan
1.1.66  power-level
本命令的支持情况与AP设备的型号有关,请以设备的实际情况为准。
power-level命令用来配置AP的缺省供电等级。
undo power-level命令用来恢复缺省情况。
power-level default { high | low | middle }
undo power-level default
AP组ap-model视图:AP的缺省供电等级为中。
AP视图
AP组ap-model视图
high:缺省供电等级为高。
low:缺省供电等级为低。
middle:缺省供电等级为中。
AP的供电等级分为高、中、低。AP在启动后会自动进行供电模式检测,获取自身的供电等级。若AP无法获取到供电等级,在与AC关联之前,AP以低供电等级运行,在与AC关联之后,以配置的缺省供电等级运行。表1-32为AP的供电模式与供电等级对应关系。
表1-32 AP的供电模式与供电等级对应关系
供电模式
供电等级
电源适配器供电
多个PoE+供电
PoE与PoE+混合供电
高
单个PoE+供电
多个PoE供电
中
单个PoE供电
低
不同供电等级下,AP对于MIMO模式和USB接口的支持情况不同,如表1-33所示。
表1-33 MIMO模式和USB接口的支持情况
供电等级
MIMO模式
USB接口
高
1x1、2x2、3x3、4x4
允许开启
中
1x1、2x2、3x3、4x4
MIMO模式小于等于2x2时,允许开启
低
1x1
不允许开启
# 配置AP的缺省供电等级为高。(AP视图)
[Sysname] wlan ap ap1 model WA6330
[Sysname-wlan-ap-ap1] power-level default high
# 配置AP的缺省供电等级为高。(AP组ap-model视图)
[Sysname-wlan-ap-group-g1] ap-model WA6330
[Sysname-wlan-ap-group-g1-ap-model-WA6330] power-level default high
1.1.67  priority
priority命令用来配置AC上AP连接的优先级。
undo priority命令用来恢复缺省情况。
priority priority
undo priority
AP组视图:继承全局配置。
全局配置视图:AP连接的优先级为4。
AP视图
AP组视图
全局配置视图
priority:AP连接的优先级,取值范围为0~7。该数值越大,优先级越高。
建立CAPWAP隧道的过程中,AP会优先选择优先级高的AC建立隧道连接。
本命令配置的优先级,仅在AP建立CAPWAP隧道连接前生效。
AP视图下配置的优先级高于AP组视图下的配置,AP组视图下的配置优先级高于全局配置视图下的配置。
# 配置AP连接的优先级为7。(AP视图)
[Sysname-wlan-ap-ap3] priority 7
# 配置AP连接的优先级为7。(AP组视图)
[Sysname-wlan-ap-group-group1] priority 7
# 配置AP连接的优先级为7。(全局配置视图)
[Sysname-wlan-global-configuration] priority 7
1.1.68  region-code (AP/AP group view)
region-code命令用来配置区域码。
undo region-code命令用来恢复缺省情况。
region-code code
undo region-code
AP视图:AP组有配置的情况下,继承AP组配置;AP组无配置的情况下,继承全局配置。
AP组视图:继承全局配置。
AP视图
AP组视图
code:AP的区域码。区域码和区域的对应关系请参见表1-34。
表1-34 区域码对应的区域名
区域名
区域码
区域名
区域码
安道尔
AD
肯尼亚
KE
阿拉伯联合酋长国
AE
科威特
KW
阿尔巴尼亚
AL
哈萨克斯坦
KZ
亚美尼亚
AM
黎巴嫩
LB
澳大利亚
AU
列支郭士登
LI
阿根廷
AR
斯里兰卡
LK
奥地利
AT
立陶宛
LT
阿塞拜疆
AZ
卢森堡
LU
波斯尼亚和黑塞哥维那
BA
拉脱维亚
LV
比利时
BE
利比亚
LY
保加利亚
BG
摩洛哥
MA
巴林
BH
摩纳哥
MC
文莱
BN
摩尔多瓦
MD
玻利维亚
BO
马其顿王国
MK
巴西
BR
中国澳门
MO
巴哈马群岛
BS
马提尼克岛
MQ
白俄罗斯
BY
马耳他
MT
伯利兹
BZ
毛里求斯
MU
加拿大
CA
墨西哥
MX
瑞士
CH
马来群岛
MY
科特迪瓦
CI
纳米比亚
NA
智利
CL
尼日利亚
NG
中国
CN
尼加拉瓜
NI
哥伦比亚
CO
荷兰
NL
哥斯达黎加
CR
挪威
NO
塞尔维亚
RS
新西兰
NZ
塞浦路斯
CY
阿曼
OM
捷克斯洛伐克
CZ
巴拿马
PA
德国
DE
秘鲁
PE
丹麦
DK
波兰
PL
多米尼亚共和国
DO
菲律宾
PH
阿尔及利亚
DZ
巴基斯坦
PK
厄瓜多尔
EC
波多黎各
PR
爱沙尼亚
EE
葡萄牙
PT
埃及
EG
巴拉圭
PY
西班牙
ES
卡塔尔
QA
法罗群岛
FO
罗马尼亚
RO
芬兰
FI
俄罗斯
RU
法国
FR
沙特阿拉伯
SA
英国
GB
瑞典
SE
格鲁吉亚
GE
新加坡
SG
直布罗陀
GI
斯洛文尼亚
SI
格陵兰
GL
斯洛伐克
SK
瓜德罗普岛
GP
圣马力诺
SM
希腊
GR
萨尔瓦多
SV
危地马拉
GT
叙利亚共和国
SY
关岛
GU
泰国
TH
圭亚那
GY
突尼斯
TN
洪都拉斯
HN
土耳其
TR
中国香港
HK
特立尼达和多巴哥
TT
克罗地亚
HR
中国台湾
TW
匈牙利
HU
乌克兰
UA
冰岛
IS
美国
US
印度
IN
乌拉圭
UY
印度尼西亚
ID
乌兹别克斯坦
UZ
爱尔兰
IE
梵蒂网
VA
以色列
IL
委内瑞拉
VE
伊拉克
IQ
处女岛
VI
意大利
IT
越南
VN
牙买加
JM
也门
YE
约旦
JO
南非
ZA
日本
JP
津巴布韦
ZW
韩国
KR
不同国家或地区对射频有不同的管制要求,区域码决定了射频可以使用的工作频段、信道,以及合法的发射功率级别等。在配置WLAN设备时,必须正确地设置区域码,以确保不违反当地的管制规定。
AP视图下配置的优先级高于AP组视图下的配置,AP组视图下配置的优先级高于全局配置视图下的配置。
# 配置型号为WA6320的AP的区域码。(AP视图)
[Sysname-wlan-ap-ap1] region-code US
# 配置AP组group1的区域码。(AP组视图)
[Sysname-wlan-ap-group-group1] region-code US
·     region-code-lock
1.1.69  region-code (Gobal configuration view)
region-code code
中国设备区域码已配置为CN,日本设备区域码已配置为JP,其他国家或地区设备未配置区域码
全局配置视图
# 配置全局区域码。
[Sysname-wlan-global-configuration] region-code US
·     region-code-lock
1.1.70  region-code-ie
region-code-ie命令用来配置Beacon帧和Probe Response帧携带区域码功能。
undo region-code-ie命令用来恢复缺省情况。
region-code-ie { disable | enable { any | indoor | outdoor } }
undo region-code-ie
Beacon帧和Probe Response帧中携带区域码信息并且环境标记为通用。
无线服务模板视图
disable:Beacon帧和Probe Response帧中不携带区域码。
enable:Beacon帧和Probe Response帧中携带区域码。
any:Beacon帧和Probe Response帧中携带区域码并且环境标记为通用。
indoor:Beacon帧和Probe Response帧中携带区域码并且环境标记为室内。
outdoor:Beacon帧和Probe Response帧中携带区域码并且环境标记为室外。
环境标识主要用来标记AP是室内AP还是室外AP。
同一AP的不同Radio下需要绑定具有相同环境标记的无线服务模板。
# 在无线服务模板下,配置Beacon帧和Probe Response帧中携带区域码并且环境标识为室内。
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] region-code-ie enable indoor
·     region-code
1.1.71  region-code-lock
region-code-lock enable命令用来开启区域码锁定功能。
region-code-lock disable命令用来关闭区域码锁定功能。
undo region-code-lock命令用来恢复缺省情况。
region-code-lock { disable | enable }
AP组视图:继承全局配置。
全局配置视图:区域码锁定功能处于关闭状态。
AP视图
AP组视图
全局配置视图
区域码锁定功能是指锁定本级视图区域码,使其无法配置。
AP视图下没有配置区域码的情况下,即使开启区域码锁定功能,AP的运行区域码会被所属AP组或全局组区域码配置影响;AP组视图下没有配置区域码的情况下,即使开启区域码锁定功能,AP组的运行区域码也会被所属全局区域码配置影响。
# 开启型号为WA6320的AP的区域码锁定功能。(AP视图)
[Sysname-wlan-ap-ap1] region-code-lock enable
# 开启AP组group1的区域码锁定功能。(AP组视图)
[Sysname-wlan-ap-group-group1] region-code-lock enable
# 开启全局区域码锁定功能。(全局配置视图)
[Sysname-wlan-global-configuration] region-code-lock enable
·     region-code
1.1.72  remote-configuration
remote-configuration enable命令用来开启远程配置同步功能。
remote-configuration disable命令用来关闭远程配置同步功能。
undo remote-configuration命令用来恢复缺省情况。
remote-configuration { disable | enable }
undo remote-configuration enable
AP视图:继承AP组配置。
AP组视图:远程配置同步功能处于关闭状态。
AP视图
AP组视图
开启远程配置同步功能后,AC才会向AP下发AP视图或AP组视图下的VLAN相关配置。
# 开启远程配置同步功能。(AP视图)
[Sysname-wlan-ap-ap1] remote-configuration enable
# 开启远程配置同步功能。(AP组视图)
[Sysname-wlan-ap-group-group1] remote-configuration enable
1.1.73  remote-configuration synchronize
remote-configuration synchronize命令用来将AP或AP组视图下配置的VLAN、以太网链路聚合和端口隔离等命令同步到AP。
AP视图:继承AP组配置。
AP组视图:未将AP或AP组视图下配置的VLAN、以太网链路聚合和端口隔离相关命令同步到AP。
AP视图
AP组视图
配置本命令前请先开启远程配置同步功能。
AP新上线时,只要远程配置同步功能处于开启状态,便会主动向AC请求相关配置,不需要配置本命令。
本命令只对在线AP生效。配置本命令后,AC会将AP或AP组视图下的配置同步到在线的AP。
通常情况下,配置本命令后或在AP上线请求配置的时候,AP上所有的VLAN、以太网链路聚合及接口配置会被全部清除(为防止瞬间网络风暴,端口隔离命令不会清除),请谨慎使用。当AC上配置冲突时,AP上配置不会被全部清除,此时请检查配置是否存在问题。
请不要同时使用本命令和map-configuration命令,如果同时使用,请保证相关配置不冲突。
# 开启远程配置同步功能。(AP视图)
[Sysname-wlan-ap-ap1] remote-configuration synchronize
[Sysname-wlan-ap-group-group1] remote-configuration synchronize
1.1.74  report-interval
report-interval命令用来配置AP采集数据并上报AC的时间间隔。
undo report-interval命令用来恢复缺省情况。
report-interval interval
AP采集数据并上报AC的时间间隔为50秒。
监控组视图
interval:AP采集数据并上报AC的时间间隔,取值范围为10~120,单位为秒。
# 配置AP采集监控数据和上报数据的时间间隔为30秒。
[Sysname] wlan vip-ap-group
[Sysname-wlan-vip-ap-group] report-interval 30
·     ap (vip-ap-group)
·     wlan vip-ap-group
1.1.75  reset wlan ap
reset wlan ap命令用来重启AP。
reset wlan ap { all | ap-group group-name | model model-name | name ap-name | native }
all:重启连接到当前AC的所有AP。
ap-group group-name:重启指定AP组内的所有AP。group-name为AP组的名称,为1~31个字符的字符串,区分大小写。
model model-name:重启指定型号的AP。model-name为AP型号的名称。
name ap-name:重启指定名称的AP。ap-name为AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
native:重启与当前AC建立CAPWAP隧道连接的所有AP。
在物理AP连接的AC上执行此命令后,将会重置AC与AP的CAPWAP隧道连接,并重启物理AP。
在虚拟AP连接的AC上执行此命令后,将会重置AC与虚拟AP的CAPWAP隧道连接,但不会导致虚拟AP所在的物理AP重启。
# 重启ap1。
<Sysname> reset wlan ap name ap1
Resetting the APs will terminate the CAPWAP tunnels with the AC. Continue? [Y/N]:
1.1.76  reset wlan ap connection-record
reset wlan ap connection-record命令用来清除AC上的AP连接记录。
reset wlan ap { all | name ap-name } connection-record
all:清除所有AP的连接记录。
# 清除AC上的所有AP连接记录。
<Sysname> reset wlan ap all connection-record
1.1.77  reset wlan ap reboot-log
reset wlan ap reboot-log命令用来清除指定AP或全部AP的重启日志信息。
reset wlan ap reboot-log { all | name ap-name }
all:清除所有AP的重启日志信息。
name ap-name:清除指定AP的重启日志信息,ap-name为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 清除ap1的重启日志信息。
<Sysname> reset wlan ap reboot-log name ap1
·     display wlan ap reboot-log
1.1.78  reset wlan ap statistics association-failure-record
reset wlan ap statistics association-failure-record命令用来清除AP上线失败原因。
# 清除AP的上线失败原因。
<Sysname> reset wlan ap statistics association-failure-record
1.1.79  reset wlan ap statistics image-download
reset wlan ap statistics image-download命令用来清除AP下载版本的相关信息。
reset wlan ap statistics image-download { all | failed | in-progress | succeeded }
all:清除所有下载版本的AP信息。
failed:清除下载版本失败的AP信息。
in-progress:清除正在下载版本的AP信息。
succeeded:清除下载版本成功的AP信息。
# 清除所有下载版本的AP信息。
<Sysname> reset wlan ap statistics image-download all
1.1.80  reset wlan ap statistics online-record
reset wlan ap statistics online-record命令用来清除AP在线数量的统计信息。
# 清除AP在线数量的统计信息。
<Sysname> reset wlan ap statistics online-record
1.1.81  reset wlan ap statistics tunnel-down-record
reset wlan ap statistics tunnel-down-record命令用来清除AC与AP间CAPWAP隧道断开原因统计。
# 清除AC与AP间CAPWAP隧道断开的原因统计。
<Sysname> reset wlan ap statistics tunnel-down-record
1.1.82  reset wlan ap statistics switch-over-record
reset wlan ap statistics switch-over-record命令用来清除主备链路切换的详细信息。
# 清除主备链路切换的详细信息。
<Sysname> reset wlan ap statistics switch-over-record
1.1.83  reset wlan tunnel latency ap
reset wlan tunnel latency ap命令用来清除AP的隧道延迟信息。
reset wlan tunnel latency ap { all | name ap-name }
all:清除所有AP的CAPWAP隧道延迟信息。
name ap-name:清除指定AP的CAPWAP隧道延迟信息,ap-name为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写
本命令仅对当前处于Run状态且与AC建立主隧道的AP生效。
# 清除ap1的隧道延迟信息。
<Sysname> reset wlan tunnel latency ap name ap1
·     display wlan ap tunnel latency
1.1.84  retransmit-count
retransmit-count命令用来配置AC发送给AP的请求报文重传次数。
undo retransmit-count命令用来恢复缺省情况。
retransmit-count value
AP视图:继承AP组配置。
AP组视图:请求报文重传次数为3次。
AP视图
AP组视图
value:请求报文重传次数,取值范围为2~5。
为了使AC的请求报文尽可能的发送到AP,提高报文的可靠传输能力,AC会对请求报文进行重传,重传次数为配置的请求报文重传次数。
AC发送给AP的请求报文包括Image Data Request报文、Configuration Update Request报文、Reset Request报文、Data Transfer Request报文、IEEE 802.11 WLAN Configuration Request报文和Station Configuration Request报文。
# 配置AC发往AP的请求报文重传次数为4。(AP视图)
[Sysname-wlan-ap-ap3] retransmit-count 4
# 配置AC发往AP的请求报文重传次数为4。(AP组视图)
[Sysname-wlan-ap-group-group1] retransmit-count 4
·     retransmit-interval
1.1.85  retransmit-interval
retransmit-interval命令用来配置请求报文重传的时间间隔。
undo retransmit-interval命令用来恢复缺省情况。
retransmit-interval interval
AP视图:继承AP组配置。
AP组视图:请求报文重传的时间间隔为5秒。
AP视图
AP组视图
interval:指定请求报文重传的时间间隔,取值范围为3~8,单位为秒。
为了使AC的请求报文尽可能的发送到AP,提高报文的可靠传输能力,AC会对请求报文进行重传,重传时间间隔为配置的请求报文重传时间。
# 配置AC发往AP的请求报文重传的时间间隔为6秒。(AP视图)
[Sysname-wlan-ap-ap3] retransmit-interval 6
# 配置AC发往AP的请求报文重传的时间间隔为6秒。(AP组视图)
[Sysname-wlan-ap-group-group1] retransmit-interval 6
·     retransmit-count
1.1.86  serial-id (AP/Virtual-AP group view)
serial-id命令用来创建AP序列号入组规则。
undo serial-id命令用来删除AP序列号入组规则。
serial-id serial-id
undo serial-id serial-id
不存在AP序列号入组规则。
AP组视图
虚拟AP组视图
serial-id:AP序列号,为1~63个字符的字符串,输入后的字母自动改为大写形式。
若其它组已经存在该序列号入组规则,在新组配置该序列号入组规则,则原AP组将删除该序列号入组规则。
本命令不检查指定的AP是否存在。
同一AP组下AP序列号可配置多个。配置后符合该序列号的AP可以入组。
默认组视图下不能创建AP序列号入组规则。
虚拟AP的序列号为所在物理AP的序列号。
# 在AP组视图下添加序列号入组规则serial-id 210235A1BSC123000037。
[Sysname-wlan-ap-group-group1] serial-id 210235A1BSC123000037
# 在虚拟AP组视图下添加序列号入组规则serial-id 210235A1BSC123000037。
[Sysname-wlan-virtual-ap-group-group1] serial-id 210235A1BSC123000037
·     wlan ap-group
1.1.87  serial-id (AP/Virtual-AP view)
serial-id命令用来配置AP的序列号。
undo serial-id命令用来恢复缺省情况。
serial-id serial-id
undo serial-id
未配置AP的序列号。
AP视图
虚拟AP视图
serial-id:指定AP的序列号,序列号为每个AP的唯一标识,为1~63个字符的字符串,不区分大小写。
如果AP已经与AC建立CAPWAP隧道连接,改变和删除序列号将触发CAPWAP隧道的拆除,AP将会重新发现AC并与AC建立CAPWAP隧道。
# 将ap1的序列号设置为219801A28N819CE0002T。
[Sysname-ap-ap1] serial-id 219801A28N819CE0002T
# 将名称为ap1的虚拟AP序列号设置为210235A1BSC123000050。
[Sysname-wlan-virtual-ap-ap1] serial-id 210235A1BSC123000050
1.1.88  smartrate-ethernet
smartrate-ethernet命令用来进入AP的2.5GE以太网接口视图。
smartrate-ethernet interface-number
AP视图
AP组ap-model视图
interface-number:指定接口编号,取值范围与AP型号有关,请以设备的实际情况为准。
# 进入AP的2.5GE 1以太网接口视图。(AP视图)
[Sysname-wlan-ap-ap1] smartrate-ethernet 1
[Sysname-wlan-ap-ap1-smartrate-ethernet-1]
# 进入AP的2.5GE 1以太网接口视图。(AP组ap-model视图)
[Sysname-wlan-ap-group-group1] ap-model WA6330
[Sysname-wlan-ap-group-group1-ap-model-WA6330] smartrate-ethernet 1
[Sysname-wlan-ap-group-group1-ap-model-WA6330-smartrate-ethernet-1]
1.1.89  snmp-agent trap enable wlan ap
snmp-agent trap enable wlan ap命令用来开启AP管理的告警功能。
undo snmp-agent trap enable wlan ap命令用来关闭AP管理的告警功能。
AP管理的告警功能处于关闭状态。
开启了AP管理模块的告警功能之后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。(有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。)
# 开启AP管理的告警功能。
[Sysname] snmp-agent trap enable wlan ap
1.1.90  snmp-agent trap enable wlan capwap
snmp-agent trap enable wlan capwap命令用来开启CAPWAP的告警功能。
undo snmp-agent trap enable wlan capwap命令关闭CAPWAP的告警功能。
CAPWAP的告警功能处于关闭状态。
开启了CAPWAP模块告警功能之后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。(有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。)
# 开启CAPWAP的告警功能。
[Sysname] snmp-agent trap enable wlan capwap
1.1.91  statistics-interval
statistics-interval命令用来配置AP向AC上报Radio统计信息的时间间隔。
undo statistics-interval命令用来恢复缺省情况。
statistics-interval interval
AP组视图:继承全局配置。
虚拟AP视图:虚拟AP组有配置的情况下,继承虚拟AP组配置;虚拟AP组无配置的情况下,继承全局配置。
虚拟AP组视图:继承全局配置。
全局配置视图:AP向AC上报Radio统计信息的时间间隔为50秒。
AP视图
AP组视图
虚拟AP视图
虚拟AP组视图
全局配置视图
interval:指定AP向AC上报Radio统计信息的时间间隔,取值范围为0~240,单位为秒。
为了对AP的运行情况进行有效监控,AP会周期性的向AC上报Radio统计信息。当时间间隔配置为0时,AP的Radio统计信息不上报AC。
虚拟AP视图下配置的优先级高于虚拟AP组视图下的配置,虚拟AP组视图下配置的优先级高于全局配置视图下的配置。
# 配置AP上报Radio统计信息的时间间隔为10秒。(AP视图)
[Sysname-wlan-ap-ap1] statistics-interval 10
# 配置AP上报Radio统计信息的时间间隔为10秒。(AP组视图)
[Sysname-wlan-ap-group-group1] statistics-interval 10
# 配置虚拟AP上报Radio统计信息的时间间隔为10秒。(虚拟AP视图)
[Sysname-wlan-virtual-ap-ap1] statistics-interval 10
# 配置虚拟AP上报Radio统计信息的时间间隔为10秒。(虚拟AP组视图)
[Sysname-wlan-virtual-ap-group-group1] statistics-interval 10
# 配置AP上报Radio统计信息的时间间隔为10秒。(全局配置视图)
[Sysname-wlan-global-configuration] statistics-interval 10
1.1.92  statistics-interval fast-report
statistics-interval fast-report命令用来配置AP向AC加速上报信息的时间间隔。
undo statistics-interval fast-report命令用来恢复缺省情况。
statistics-interval fast-report fast-report-interval
AP视图:继承AP组配置。
AP组视图:AP向AC加速上报信息的时间间隔为0秒。
虚拟AP视图:继承虚拟AP组配置。
虚拟AP组视图:AP向AC加速上报信息的时间间隔为0秒。
AP视图
AP组视图
虚拟AP视图
虚拟AP组视图
fast-report-interval:指定AP向AC上报信息的时间间隔,取值范围为0~120,单位为秒。
AP会周期性的向AC上报统计信息。时间间隔配置为0时,关闭AP向AC加速上报信息功能,即AP不向AC加速上信息。
目前加速上报信息仅包含信道利用率统计信息。
# 配置AP加速上报信息的时间间隔为10秒。(AP视图)
[Sysname-wlan-ap-ap1] statistics-interval fast-report 10
# 配置AP加速上报信息的时间间隔为10秒。(AP组视图)
[Sysname-wlan-ap-group-group1] statistics-interval fast-report 10
# 配置虚拟AP加速上报信息的时间间隔为10秒。(虚拟AP视图)
[Sysname-wlan-virtual-ap-ap1] statistics-interval fast-report 10
# 配置虚拟AP加速上报信息的时间间隔为10秒。(虚拟AP组视图)
[Sysname-wlan-virtual-ap-group-group1] statistics-interval fast-report 10
·     statistics-interval
1.1.93  ten-gigabitethernet
ten-gigabitethernet命令用来进入AP的XGE以太网接口视图。
ten-gigabitethernet interface-number
AP视图
AP组ap-model视图
# 进入AP的XGE 1以太网接口视图。(AP视图)
[Sysname-wlan-ap-ap1] ten-gigabitethernet 1
[Sysname-wlan-ap-ap1-ten-gigabitethernet-1]
# 进入AP的XGE 1以太网接口视图。(AP组ap-model视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320] ten-gigabitethernet 1
[Sysname-wlan-ap-group-group1-ap-model-WA6320-ten-gigabitethernet-1]
1.1.94  tunnel encryption enable
tunnel encryption enable命令用来开启CAPWAP控制隧道加密功能。
tunnel encryption disable命令用来关闭CAPWAP控制隧道加密功能。
undo tunnel encryption命令用来恢复缺省情况。
tunnel encryption { disable | enable }
AP视图:继承AP组配置。
AP组视图:CAPWAP控制隧道加密功能处于关闭状态。
虚拟AP视图:继承虚拟AP组配置。
虚拟AP组视图:CAPWAP控制隧道加密功能处于关闭状态。
AP视图
AP组视图
虚拟AP视图
虚拟AP组视图
disable:关闭CAPWAP隧道加密功能。
enable:开启CAPWAP隧道加密功能。
开启该功能后,AP会重新关联到AC。
开启CAPWAP控制隧道加密功能后,AC回复AP的Discovery Response报文中将携带加密标志位,AP接收到Discovery Response报文后将与该AC进行DTLS握手,然后完成CAPWAP隧道的建立。在AP与AC完成DTLS握手后交互的CAPWAP控制隧道报文将被加密传输。
虚拟AP视图下配置的优先级高于虚拟AP组视图下的配置。
# 开启AP的CAPWAP控制隧道加密功能。(AP视图)
[Sysname-wlan-ap-ap1] tunnel encryption enable
This operation will reconnect the AP. Continue? [Y/N]
# 开启AP组的CAPWAP控制隧道加密功能。(AP组视图)
[Sysname-wlan-ap-group-group1] tunnel encryption enable
This operation will reconnect member APs that are not enabled with CAPWAP control tunnel encryption. Continue? [Y/N]
# 开启虚拟AP的CAPWAP控制隧道加密功能。(虚拟AP视图)
[Sysname-wlan-virtual-ap-ap1] tunnel encryption enable
# 开启虚拟AP组的CAPWAP控制隧道加密功能。(虚拟AP组视图)
[Sysname-wlan-virtual-ap-group-group1] tunnel encryption enable
1.1.95  tunnel latency-detect
tunnel latency-detec命令用来配置CAPWAP隧道延迟检测功能。
tunnel latency-detect { start | stop }
未启动CAPWAP隧道延迟检测。
AP视图
start:启动CAPWAP隧道延迟检测。
stop:停止CAPWAP隧道延迟检测。
CAPWAP隧道延迟检测用于统计AP和AC之间的CAPWAP隧道延迟时间,便于及时了解CAPWAP隧道报文传输的延迟状况。
只有在AP和AC建立了CAPWAP隧道并且当前AC为主AC时,CAPWAP隧道延迟检测才会启动。
当AP下线,CAPWAP隧道延迟检测将自动停止。AP重新上线后,如果需要再次进行CAPWAP隧道延迟检测,则需要重新执行tunnel latency-detect start命令。
使用display wlan ap tunnel latency命令查看CAPWAP隧道延迟检测信息。
Inside AP不支持本功能。
# 启动CAPWAP隧道延迟检测。
[Sysname-wlan-ap-ap1] tunnel latency-detect start
1.1.96  virtual-ap
virtual-ap命令用来创建虚拟AP并配置虚拟AP连接的AC的IP地址。
undo virtual-ap命令用来删除虚拟AP。
virtual-ap ac-address { ip ipv4-address | ipv6 ipv6-address } [ management-vlan vlan ]
undo virtual-ap
未创建虚拟AP。
AP视图
AP组视图
ip ipv4-address:指定虚拟AP连接的AC的IPv4地址。
ipv6 ipv6-address:指定虚拟AP连接的AC的IPv6地址。
management-vlan vlan:指定虚拟AP上线时所使用的管理VLAN。若不指定本参数,则表示虚拟AP上线时使用的管理VLAN与物理AP相同。
本命令需要在物理AP连接的AC进行配置。
配置本命令前,需要确保当前AC已开启虚拟AP功能。
配置的虚拟AP连接的AC的IP地址不能和物理AP上线的AC的IP地址相同,但两者的IP地址类型需要保持一致,即都通过IPv4地址或者IPv6地址在AC上线。
通过设置虚拟AP上线时所使用的管理VLAN,可以实现物理AP和虚拟AP的管理VLAN隔离。
如果物理AP和虚拟AP使用相同的管理VLAN,则必须在AP的以太网接口上配置端口隔离功能。
配置虚拟AP上线时所使用的管理VLAN前需要将AP的以太网接口加入到相应的VLAN,并且该管理VLAN接口必须通过DHCP方式获取IP地址。
# 在ap1下创建虚拟AP,并配置虚拟AP连接的AC的IP地址为1.1.1.1。
[Sysname-wlan-ap-ap1] virtual-ap ac-address ip 1.1.1.1
·     port access vlan
·     vlan
·     wlan virtual-ap enable
1.1.97  vlan
vlan vlan-id命令用来创建AP的VLAN,并进入AP VLAN视图。如果指定的AP VLAN已存在,则直接进入该AP VLAN的视图。
vlan vlan-id1 to vlan-id2命令用来批量创建vlan-id1~vlan-id2之间的所有AP VLAN,保留VLAN除外。
undo vlan命令用来删除VLAN。
vlan { vlan-id1 [ to vlan-id2 ] }
undo vlan { vlan-id1 [ to vlan-id2 ] }
AP视图:继承AP组配置。
AP组视图:AP上只有一个缺省VLAN(VLAN 1)。
AP视图
AP组视图
vlan-id1:VLAN的编号,取值范围为1~4094。
vlan-id1 to vlan-id2:指定VLAN的编号范围。vlan-id1和vlan-id2为VLAN的编号,取值范围为1~4094。vlan-id2的值要大于或等于vlan-id1的值。
用户不能创建和删除缺省VLAN(VLAN 1)和保留VLAN。
AP视图优先级高于AP组视图。
# 创建VLAN 2,并进入该VLAN视图。(AP视图)
[Sysname-wlan-ap-ap1] vlan 2
[Sysname-wlan-ap-ap1-vlan2]
#创建VLAN 2,并进入该VLAN视图。(AP组视图)
[Sysname-wlan-ap-group-group1] vlan 2
[Sysname-wlan-ap-group-1-vlan2]
1.1.98  wlan ap
wlan ap命令用来创建手工AP,并进入AP视图。如果指定的AP已经存在,则直接进入AP视图。
undo wlan ap命令用来删除指定的AP。
wlan ap ap-name [ model model-name ]
undo wlan ap ap-name
不存在手工AP。
ap-name:AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
model model-name:AP的型号名称,在创建AP时,该参数必须配置。
执行undo wlan ap命令时,如果AP已经与AC建立了CAPWAP隧道连接,则会导致隧道连接断开。
# 创建ap1。
1.1.99  wlan apdb
wlan apdb命令用来配置指定AP型号的软硬件版本对应关系。
undo wlan apdb命令用来恢复缺省情况。
wlan apdb [ fatap | oasisap ] model-name hardware-version software-version
undo wlan apdb [ fatap | oasisap ] model-name hardware-version
FAT AP:未指定AP型号的软硬件版本对应关系。
云AP:未指定AP型号的软硬件版本对应关系。
FIT AP:AP型号的硬件版本所对应的软件版本为APDB脚本文件中存储的软件版本。
fatap:配置指定型号FAT AP的软硬件版本对应关系。
oasisap:配置指定型号云AP的软硬件版本对应关系。
model-name:AP型号名称。
hardware-version:AP硬件版本。
software-version:AP软件版本,为1~31个字符的字符串,不区分大小写。
AP版本升级功能处于开启状态时,配置AP型号的软硬件版本对应关系后,AC将比较AP的软件版本与配置的软硬件版本关系是否一致。如果一致,则不进行升级,如果不一致,则进行软件版本升级。
·     对于云AP和FAT AP,只有准备对其进行版本升级时,才需要配置本命令。用户需要将待升级的AP版本保存到AC的apimge路径下,并且保证该软件版本的版本号同本命令指定的版本号一致。
·     对于FIT AP,只有期望AP使用的软件版本与APDB中存储的该AP型号对应的软件版本不一致时才需要配置本命令。本命令通常用于向AP下发临时版本,建议用户不要自行配置,以免导致AP无法与AC建立CAPWAP隧道。
若未指定fatap和oasisap,则表示配置FIT AP型号的软硬件版本对应关系。
# 配置FIT AP型号为WA6320的硬件版本Ver.C对应的软件版本为E2108。
[Sysname] wlan apdb WA6320 Ver.C E2108
# 配置云AP型号为WA6330的硬件版本Ver.A对应的软件版本为R1106。
[Sysname] wlan apdb oasisap WA6330 Ver.A R1106
# 配置FAT AP型号为WA5530的硬件版本Ver.A对应的软件版本为R2101。
[Sysname] wlan apdb fatap WA5530 Ver.A R2101
·     firmware-upgrade
1.1.100  wlan apdb file
wlan apdb file命令用来加载APDB用户脚本文件。
undo wlan apdb file命令用来卸载APDB用户脚本文件。
wlan apdb file user.apdb
undo wlan apdb file
未加载APDB用户脚本文件。
user.apdb:指定需要加载的APDB用户脚本文件名,为1~63个字符的字符串,区分大小写。apdb为文件后缀。
用户脚本只能加载一个,多次加载用户脚本,最后一次加载的脚本生效。
加载APDB脚本文件时,需要保证脚本文件的合法性,不合法的脚本文件会导致加载失败。
在云集群组网中,请在各成员设备上均加载相同的APDB用户脚本,防止主备倒换后找不到APDB脚本。
当出现以下情况时,加载用户脚本文件的操作将会失败:
·     用户脚本中的AP型号与系统脚本中AP型号重复。
·     若AC上已加载的脚本中某个AP型号已经被配置为手工AP或者已经存在上线的自动AP,则不允许重新加载脚本文件,需要将对应的AP型号删除后才能重新加载。
·     若已加载的脚本中的某个AP型号已经被加入AP组,则不允许重新加载脚本文件,需要将对应的AP型号从AP组删除后才能重新加载。
·     若已加载的脚本中的某个AP型号已经进行了软件版本配置,则不允许重新加载脚本文件,需要使用wlan apdb命令将对应的软件版本还原到初始版本后才能重新加载。关于wlan apdb命令的详细介绍,请参见“WLAN命令参考”中的“AP管理”。
当出现以下情况时,需要重新加载用户脚本文件:
·     在文件系统中将用户脚本文件进行重命名,需要重新加载脚本文件,否则当AC重启后将丢失对应该用户脚本文件的AP型号配置。
·     在文件系统中将用户脚本文件进行替换,需要重新加载新脚本文件,如果新脚本中不包含被替换脚本中的AP型号信息,当AC重启后将丢失对应被替换脚本文件的AP型号配置。
·     在文件系统中将用户脚本文件进行删除,需要重新加载新脚本文件,否则当AC重启后将丢失该用户脚本文件的AP型号配置。
# 加载名为user.apdb的用户脚本。
[Sysname] wlan apdb file user.apdb
·     wlan apdb
1.1.101  wlan ap-authentication
wlan ap-authentication命令用来对处于未认证状态的自动AP进行手工认证。
wlan ap-authentication { accept | reject } ap-unauthenticated { all | name ap-name }
未配置对处于未认证状态的自动AP进行手工认证。
accept:允许自动AP的状态从“未认证”转变为“已认证”,并生成对应的WLAN ACL permit规则,已认证状态的AP可以提供无线服务。
reject:拒绝处于未认证状态的自动AP接入AC,并生成对应的WLAN ACL deny规则。配置该参数后,强制已经上线的未认证自动AP下线。
all:所有处于未认证状态的自动AP。
name ap-name:处于未认证状态的自动AP名称,为1~64个字符的字符串,区分大小写。
处于未认证状态的自动AP是否可以接入AC由命令wlan ap-authentication permit-unauthenticated决定。如果允许其接入AC,此时的自动AP将无法提供无线服务(Radio接口处于关闭状态),管理员可以通过执行本命令来手工改变这类自动AP的认证状态。
在执行本命令前,需要使用acl wlan ap命令创建WLAN AP类型的ACL,并使用wlan ap-authentication acl命令指定ACL编号,本命令生成的ACL规则会加入到该ACL编号下。
# 对处于未认证状态的自动AP进行手工认证,并在ACL 200中生成相应的规则。
[Sysname] acl wlan ap 200
[Sysname-acl-ap-200] quit
[Sysname] wlan ap-authentication acl 200
[Sysname] wlan ap-authentication accept ap-unauthenticated all
·     acl wlan ap
·     wlan ap-authentication
·     permit-unauthenticated
1.1.102  wlan ap-authentication acl
wlan ap-authentication acl命令用来配置认证自动AP使用的ACL。
undo wlan ap-authentication acl命令用来恢复缺省情况。
wlan ap-authentication acl { acl-number | name acl-name }
未配置自动AP进行认证使用的ACL。
acl-number:WLAN AP类型的ACL编号,取值范围为200~299。
name acl-name:WLAN AP类型的ACL名称。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
配置该命令前,需要使用acl wlan ap命令创建WLAN AP类型的ACL,然后通过wlan ap-authentication import命令生成ACL规则或者通过rule命令手工配置ACL规则。手工配置ACL规则时,需要根据wlan ap-authentication method配置的认证方式,来决定ACL规则中使用的是MAC地址还是序列号。
如果未认证状态的自动AP匹配上ACL permit规则,允许AP上线,如果匹配上ACL deny规则或者未匹配上任何规则,则不允许AP上线。
如果配置的ACL中没有任何规则,则AC在对自动AP进行认证时,所有自动AP均会因为没有匹配上任何ACL规则,而被置为“未认证”状态。
如果多次配置了该命令,以最后一次配置为准。
# 配置并使用ACL 200对自动AP进行认证,该ACL的规则为允许序列号为210235A42QB095000766的自动AP接入AC。
[Sysname-acl-ap-200] rule 0 permit serial-id 210235A42QB095000766
·     acl wlan ap
·     rule
·     wlan ap-authentication import
·     wlan ap-authentication method
1.1.103  wlan ap-authentication enable
wlan ap-authentication enable命令用来开启自动AP认证功能。
undo wlan ap-authentication enable命令用来关闭自动AP认证功能。
自动AP认证功能处于关闭状态。
开启该功能后,AC会对自动AP进行认证,当认证成功时允许AP接入AC,认证失败时拒绝AP接入AC。
自动AP认证功能仅对自动AP生效,手工AP和已固化的自动AP不生效。
开启自动AP认证功能开启后,AC不会对已经上线的自动AP进行认证,仅对新上线的自动AP进行认证。
# 开启自动AP认证功能。
[Sysname] wlan ap-authentication enable
1.1.104  wlan ap-authentication import
wlan ap-authentication import命令用来导入自动AP认证文件,并生成相应的ACL规则。
wlan ap-authentication import file-name
file-name:自动AP认证文件的文件名,为1~32个字符的字符串,不区分大小写,文件名的后缀必须为“.txt”。
AP认证文件中只能包含AP的MAC地址或只能包含AP序列号,不允许两种格式同时存在,其中MAC地址格式为HH-HH-HH-HH-HH-HH,多个MAC地址或序列号之间使用英文逗号分隔。使用本命令导入到指定的ACL中后,将生成一组permit类型的规则。
在执行本命令前,必须完成以下配置:
·     使用wlan ap-authentication acl命令指定ACL,根据文件生成ACL规则才能添加到该编号的ACL中。
·     使用wlan ap-authentication method命令指定认证模式。文件根据此认证模式来生成ACL规则。所要导入文件的格式需要与此认证模式一致。
# 导入AP认证文件office.txt,并在ACL 200中生成ACL规则。
[Sysname] acl number 200
[Sysname] wlan ap-authentication import office.txt
·     wlan ap-authentication acl
1.1.105  wlan ap-authentication method
wlan ap-authentication method命令用来配置自动AP认证方式。
undo wlan ap-authentication method命令用来恢复缺省情况。
wlan ap-authentication method { mac-address | serial-id }
使用MAC地址对自动AP进行认证。
mac-address:使用MAC地址对自动AP进行认证。
serial-id:使用AP序列号对自动AP进行认证。
# 配置使用AP序列号对自动AP进行认证。
[Sysname] wlan ap-authentication method serial-id
1.1.106  wlan ap-authentication permit-unauthenticated
wlan ap-authentication permit-unauthenticated命令用来配置允许未认证状态的自动AP接入AC,但不允许其提供无线服务。
undo wlan ap-authentication permit-unauthenticated命令用来配置禁止未认证的自动AP接入AC。
配置本地认证后,自动AP在找不到可匹配的ACL规则的情况下,会出现“未认证AP”状态。如果开启远程认证,可以使用认证服务器对自动AP进行远程认证,远程认证的结果只有两个状态:认证成功或是认证失败。如果没有开启远程认证,则处于未认证状态的自动AP是否可以接入AC由wlan ap-authentication permit-unauthenticated命令决定。
# 配置禁止未认证的自动AP接入AC。
[Sysname] undo wlan ap-authentication permit-unauthenticated
1.1.107  wlan ap-fast-collect cloud enable
wlan ap-fast-collect cloud enable命令用来开启AP数据采集并上报云平台功能。
undo wlan ap-fast-collect cloud enable命令用来恢复缺省情况。
wlan ap-fast-collect cloud enable [ timer interval ]
AP数据采集并上报云平台功能处于关闭状态。
timer interval:数据采集的时间间隔,取值范围为500~4000,单位为毫秒,缺省值为1000。
开启本功能后,AP会定期收集数据并上报给设备,设备将AP收集的数据上报至云平台,以图形界面的方式展示。本功能通常用于轨道交通场景中收集轨旁Fit AP的数据。
# 开启AP数据采集并上报云平台功能。
[Sysname] wlan ap-fast-collect cloud enable
1.1.108  wlan ap-group
wlan ap-group命令用来创建AP组,并进入AP组视图。如果指定的AP组已经存在,则直接进入AP组视图。
undo wlan ap-group命令用来删除指定的AP组。
wlan ap-group group-name
undo wlan ap-group group-name
存在默认组,名称为default-group。
group-name:AP组的名称,为1~31个字符的字符串,不区分大小写。
默认组default-group不能被删除。
# 创建一个名为group1的AP组。
·     display wlan ap-group
1.1.109  wlan ap-image-deploy
wlan ap-image-deploy命令用来配置AC给AP在线下发版本。
wlan ap-image-deploy { all | ap-group group-name | name ap-name }
all:配置AC给所有AP在线下发版本。
ap-group group-name:配置AC给指定AP组内的所有AP在线下发版本。group-name为AP组的名称,为1~31个字符的字符串,不区分大小写,且该AP组必须已经存在。
name ap-name:配置AC给指定名称的AP在线下发版本。ap-name为AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写,且该AP必须已经存在。
CAPWAP隧道建立成功后,AC将不再向AP下发版本。开启本功能后,在CAPWAP隧道建立成功后,AC会将版本下发到AP,AP获取到版本后,需要通过手动重启才能使新版本生效。
可以先使用wlan image-load filepath命令配置AC需要下发的AP版本在AC上的存放路径。
# 配置AC在线向AP下发版本。
[Sysname] wlan ap-image-deploy all
·     wlan image-load filepath
1.1.110  wlan ap-model modem-version
wlan ap-model modem-version命令用来配置CPE型号的Modem模块软件版本号。
undo wlan ap-model命令用来恢复缺省情况。
wlan ap-model ap-model-name modem-version modem-version-name
undo wlan ap-model ap-model-name
用户需要将待升级的版本保存到AC的根目录下,并且保证该软件版本的版本号同本配置指定的版本号一致。
# 配置CPE5100对应的Modem模块软件版本号为R13A04M4G。
[Sysname] wlan ap-model CPE5100 modem-version R13A04M4G
1.1.111  wlan auto-ap enable
wlan auto-ap enable命令用来开启自动AP功能。
undo wlan auto-ap enable命令用来关闭自动AP功能。
wlan auto-ap enable
自动AP功能处于关闭状态。
在无线网络中部署的AP数量较多时,使用自动AP功能可以减少管理员的配置工作量,并可以简化配置,避免多次配置AP序列号,同时降低了配置出错的概率。
自动AP不能单独配置,需要固化为手工AP或者通过AP Group进行配置。
# 开启自动AP功能。
[Sysname] wlan auto-ap enable
1.1.112  wlan auto-ap fat-and-cloud enable
wlan auto-ap fat-and-cloud enable命令用来开启FAT AP和云AP在AC上自动上线功能。
undo wlan auto-ap fat-and-cloud enable命令用来关闭FAT AP和云AP在AC上自动上线功能。
FAT AP和云AP在AC上自动上线功能处于开启状态。
当用户希望FAT AP或云AP在AC上线,以便通过AC集中管理该AP时,需要开启FAT AP和云AP在AC上自动上线功能。开启本功能后,支持上线的FAT AP或云AP与本AC建立CAPWAP隧道,而后完成上线。
本功能当前仅用于AP版本升级以及变更AP运行模式。请勿在该FAT AP或该Cloud AP的AP视图、AP组视图下,进行除AP版本升级、运行模式变更的其它配置。
网络中存在多个AC时,为防止云AP和FAT AP随机选择AC上线,应仅在需要上线的AC上开启本功能,而在其它AC上关闭本功能。
开启本功能前,必须先通过wlan auto-ap enable命令开启自动AP功能。
# 开启FAT AP和云AP在AC上自动上线功能。
[Sysname] wlan auto-ap fat-and-cloud enable
·     wlan auto-ap enable
1.1.113  wlan auto-ap persistent
wlan auto-ap persistent命令用来将自动AP固化为手工AP。
wlan auto-ap persistent { all | name auto-ap-name [ new-ap-name ] }
all:将所有自动AP固化为手工AP,AP名称保持不变。
name auto-ap-name:自动AP的名称。
new-ap-name:固化为手工AP以后的AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。如果未指定本参数,则表示将名称为auto-ap-name的自动AP固化为手工AP,且其名称保持不变。
使用自动AP固化功能后,可以对固化后的手工AP进行配置。
# 将自动AP转换为固化AP,转换后的固化AP的名称为ap2。
[Sysname] wlan auto-ap persistent name 0001-ab12-cd36 ap2
1.1.114  wlan auto-persistent enable
wlan auto-persistent enable命令用来开启自动固化功能。
undo wlan auto-persistent enable命令用来关闭自动固化功能。
自动固化功能处于关闭状态。
该命令仅对配置本命令后上线的自动AP生效,对于已上线的自动AP,只能使用wlan auto-ap persistent命令将自动AP固化为手工AP。
# 开启自动固化功能。
[Sysname] wlan auto-persistent enable
1.1.115  wlan capwap discovery-policy
wlan capwap discovery-policy unicast命令用来开启单播发现策略功能。
undo wlan capwap discovery-policy命令用来关闭单播发现策略功能。
单播发现策略功能处于关闭状态。
AP可以通过单播、组播及广播三种方式发现AC并建立CAPWAP或LWAPP隧道。开启了单播发现策略功能后,AC只对发送单播Discovery request报文的AP进行响应,不对发送组播、广播Discovery request报文的AP进行响应,即只允许单播发现的AP与AC建立CAPWAP或LWAPP隧道连接。
# 开启单播发现策略功能。
[Sysname] wlan capwap discovery-policy unicast
1.1.116  wlan capwap encryption
wlan capwap encryption命令用来配置CAPWAP控制隧道加密使用的证书文件。
undo wlan capwap encryption命令用来恢复缺省情况。
wlan capwap encryption certificate cer-name key key-name ca ca-name
CAPWAP控制隧道加密使用的证书为系统自带的证书文件。
certificate cer-name:支持.pem,.cer格式证书。cer-name为证书的名称,形如cer-name.pem。该文件保存在设备任一文件系统的目录下即可。
key key-name:支持.pem,.cer格式密钥文件。key-name为密钥文件的名称,形如key-name.pem。该文件保存在设备任一文件系统的目录下即可。
ca ca-name:支持.pem,.cer格式根证书。ca-name为证书的名称,形如ca-name.pem。该文件保存在设备任一文件系统的目录下即可。
配置本功能前,需要通过FTP/TFTP将AC的证书上传至AC。
执行本命令后,在AP重新上线时,使用设置的新证书文件进行认证。
# 系统视图下设置使用的加密认证证书。
[Sysname] wlan capwap encryption certificate server.cer key server.key ca cacert.cer
·     tunnel encryption
1.1.117  wlan detect-anomaly enable
wlan detect-anomaly enable命令用来开启重启业务异常AC功能。
undo wlan detect-anomaly enable命令用来关闭重启业务异常AC功能。
重启业务异常AC功能处于开启状态。
关闭本功能后,设备在发生业务异常时无法通过自动重启立即恢复,只能通过手动重启设备进行恢复。因此,如无特殊需要,请不要关闭本功能。
该配置只有在云集群组网环境中的主用设备上,并且AP上线数曾经超过50才能生效。
开启该功能后,主用设备会检测自身的业务状态,当其上连接的AP数变为0时,主用设备会创建定时器,超时时间为10分钟:
·     如果在定时器达到10分钟时,连接的AP数一直为0,主用设备会进行重启;
·     如果在定时器达到10分钟时,连接的AP数不为0,定时器会被删除;
·     如果在定时器达到10分钟前,连接的AP数重新变为0时,定时器被刷新,重新计时。
# 开启重启业务异常AC功能。
[Sysname] wlan detect-anomaly enable
1.1.118  wlan execute modem-image-deploy
wlan execute modem-image-deploy命令用来手动为在线CPE下发Modem模块软件版本。
wlan execute modem-image-deploy { name ap-name | ap-group group-name | all }
all:AC给所有在线的CPE下发Modem模块版本。
ap-group group-name:AC给指定AP组内的所有在线CPE下发Modem模块版本。group-name为AP组的名称,为1~31个字符的字符串,不区分大小写,且该AP组必须已经存在。
name ap-name:AC给指定名称的CPE下发Modem模块版本。ap-name为CPE的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写,且该CPE必须已经存在。
# 为所有在线的CPE下发Modem模块软件版本。
[Sysname] wlan execute modem-image-deploy all
1.1.119  wlan global-configuration
wlan global-configuration命令用来进入全局配置视图。
AP的生效配置取决于AP、AP组及全局配置中优先级最高的配置,优先级从高到低为AP视图配置、AP组视图配置、全局视图配置。若优先级高的配置不存在,则AP使用优先级低的配置。若都不存在AP的配置,则使用优先级最低的视图下的缺省值。
# 进入全局配置视图。
1.1.120  wlan image-load filepath
wlan image-load filepath命令用来配置AC向AP下发版本时,优先获取AP镜像文件的位置。
undo wlan image-load filepath命令用来恢复缺省情况。
wlan image-load filepath { local | ram }
AC优先获取内存中的AP镜像文件下发给AP。
local:指定AC优先获取本地文件夹中的AP镜像文件,若本地文件夹中没有AP镜像文件,再从内存中获取,若AC内存中也没有AP镜像文件,则获取AP镜像文件失败。
ram:指定AC优先获取内存中的AP镜像文件,若内存中没有AP镜像文件,再从本地文件夹中获取,若本地文件夹中也没有AP镜像文件,则获取AP镜像文件失败。
AC内存中的AP镜像文件来自于AC镜像文件,AC设备启动后会将AP镜像文件读取到内存中。
只有存放在文件系统根路径下的AP镜像文件,才能被AC从本地文件夹中获取并下发给AP。
仅在以下两种情况下,才需要将AP镜像文件放至本地文件夹,并将AC优先获取AP镜像文件的位置指定为本地文件夹。
·     AC镜像文件中缺少所需的AP镜像文件。
·     通过修改AP软硬件版本关系来指定AP上线时使用的软件版本。
本命令仅在以CF卡或Flash为缺省文件系统的AC设备上生效。
仅能将格式为.ipe的AP镜像文件下发给AP。
# 指定优先从AC本地文件夹中获取AP镜像文件下发给AP。
[Sysname] wlan image-load filepath local
1.1.121  wlan re-group
wlan re-group命令用来将一个或者一组AP规则迁移到指定AP组。
wlan re-group { ap ap-name | ap-group source-group-name | mac-address mac-address | serial-id serial-id } group-name
ap ap-name:将指定的AP名称入组规则迁移到目的AP组。
ap-group source-group-name:将指定的AP组的入组规则迁移到目的AP组。source-group-name不能是默认组。
mac-address mac-address:将指定的MAC地址入组规则迁移到目的AP组。
serial-id serial-id:将指定的序列号地址入组规则迁移到目的AP组。
group-name:目的AP组名称,不能是默认组。
# 创建AP组group1与group2,在group1下配置三个AP名称规则ap1、ap2、ap3,并将ap1移至group2。
[Sysname-wlan-ap-group-group1] ap ap1 ap2 ap3
[Sysname-wlan-ap-group-group1] quit
[Sysname] wlan ap-group group2
[Sysname-wlan-ap-group-group2] quit
[Sysname] wlan re-group ap ap1 group2
1.1.122  wlan rename-ap
wlan rename-ap命令用来重命名指定的手工AP。
wlan rename-ap ap-name new-ap-name
ap-name:AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。ap-name不能为自动AP的名称。
new-ap-name:重命名后的AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。new-ap-name不能和已有的AP名称相同。
# 重命名手工ap1的名称为ap1-office。
[Sysname] wlan rename-ap ap1 ap1-office
1.1.123  wlan tcp mss
wlan tcp mss命令用来配置CAPWAP隧道的TCP最大报文段长度。
undo wlan tcp mss命令用来恢复缺省情况。
wlan tcp mss value
undo wlan tcp mss
CAPWAP隧道的TCP最大报文段长度为1460字节。
value:CAPWAP隧道的TCP最大报文段长度,取值范围为128~2048,单位为字节。
MSS(Max Segment Size,TCP最大报文段长度)表示TCP连接的对端发往本端的最大TCP报文段的长度,目前作为TCP连接建立时的一个选项来协商:当一个TCP连接建立时,连接的双方要将MSS作为SYN报文的一个选项通告给对端,对端会记录下这个MSS值,后续在发送TCP报文时,会限制TCP报文的大小不超过该MSS值。当对端发送的TCP报文的长度小于等于本端的TCP最大报文段长度时,TCP报文不需要分段;否则,对端需要对TCP报文按照最大报文段长度进行分段处理后再发给本端。
配置本命令后,当通过CAPWAP封装发送SYN报文时,会将SYN报文中携带的TCP最大报文段长度设置为指定值。
【配置举例】
# 配置CAPWAP隧道的TCP最大报文段长度为2000字节。
[Sysname] wlan tcp mss 2000
1.1.124  wlan timezone-sync enable
wlan timezone-sync enable命令用来开启时区同步的功能。
undo wlan timezone-sync enable命令用来恢复缺省情况。
时区同步功能为开启状态。
# 开启时区同步的功能。
<Syname> system-view
[Sysname] wlan timezone-sync enable
1.1.125  wlan trap ap-number threshold
wlan trap ap-number threshold命令用来配置上线AP数量的告警阈值。
undo wlan trap ap-number threshold命令用来恢复缺省情况。
wlan trap ap-number threshold percent
上线AP数量告警阈值为100,AC设备不会发送Trap告警消息。
percent:AP上线数量告警阈值,取值范围为30~100,单位为百分比。
开启AP管理的告警功能且配置了本命令后,当已上线AP数量占已授权可管理AP总数的百分比超过配置的阈值时,AC设备将向SNMP模块发送overload Trap告警信息(超过阈值后,每上线一个AP就会发送一条overload Trap告警消息);当上线AP数量降低到阈值时,AC设备将向SNMP模块发送一次recover Trap告警信息。
配置阈值为100时,由于上线AP数量无法超过已授权可管理AP总数,因而AC设备不会发送overload Trap告警信息。
# 配置上线AP数量的告警阈值为50,即上线AP数量超过50%,则AC向SNMP模块发送Trap告警消息。
[Sysname] wlan trap ap-number threshold 50
·     snmp-agent trap enable wlan ap
1.1.126  wlan vip-ap-group
wlan vip-ap-group命令用来创建AP监控组,并进入监控组视图。
undo wlan vip-ap-group命令用来删除AP监控组。
wlan vip-ap-group
不存在AP监控组。
监控组可以使其中的AP对客户端数量、射频流量、射频信道利用率、AP异常信息等数据进行采集并上报给AC。
# 创建AP监控组,并进入监控组视图。
·     ap (vip-ap-group)
·     report-interval
1.1.127  wlan virtual-5g-radio enable
wlan virtual-5g-radio enable命令用来开启虚拟5GHz频段射频功能。
undo wlan virtual-5g-radio enable命令用来恢复缺省情况。
wlan virtual-5g-radio enable { all | ap-model ap-model }
undo wlan virtual-5g-radio enable { all | ap-model ap-model }
虚拟5GHz频段射频功能处于关闭状态,即不会为AP虚拟出新的射频。
all:指定所有AP型号。
ap-model ap-model:AP型号名称。
开启本功能后,AP的5GHz频段射频将虚拟出另外一个新的5GHz频段射频,虚拟出的射频编号为2。原有的一个5GHz频段射频支持八条流,现有两个5GHz频段射频每个最多支持四条流。
开启本功能前,需要先关闭自动AP功能、删除指定型号的手工AP、删除AP组下指定型号的AP。开启本功能后,需要重新配置AP上线,并在上线过程中自动重启来完成切换。
# 为型号为WA6628X的AP开启虚拟5GHz频段射频功能。
[Sysname] wlan virtual-5g-radio enable ap-model wa6628x
1.1.128  wlan virtual-ap
wlan virtual-ap命令用来创建手工虚拟AP,并进入虚拟AP视图。如果指定的虚拟AP已经存在,则直接进入虚拟AP视图。
undo wlan virtual-ap命令用来删除指定的虚拟AP。
wlan virtual-ap ap-name [ model model-name ]
undo wlan virtual-ap ap-name
不存在手工虚拟AP。
ap-name:虚拟AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
model model-name:虚拟AP的型号名称,在创建虚拟AP时,该参数必须配置。
执行undo wlan virtual-ap命令时,如果虚拟AP已经与AC建立了CAPWAP隧道连接,则会导致隧道连接断开。
本命令需要在虚拟AP连接的AC进行配置。
不能通过配置本命令修改已经存在的虚拟AP对应的型号名称,如果需要修改,请删除已经存在的虚拟AP并重新配置该AP名称对应的型号名称。
# 创建名称为ap1的虚拟AP,并进入虚拟AP视图。
1.1.129  wlan virtual-ap enable
wlan virtual-ap enable命令用来开启虚拟AP功能。
undo wlan virtual-ap enable命令用来关闭虚拟AP功能。
虚拟AP功能处于关闭状态。
虚拟AP是在物理AP上虚拟化出的一个AP,它与物理AP在逻辑上相互隔离,为不同用户提供无线接入服务。用户可以将其无线网络中的多台物理AP虚拟化出多台虚拟AP,使用一台AC对物理AP进行管理,使用其它AC对虚拟AP进行管理,实现多套相互隔离的无线网络环境,降低用户部署无线网络的成本。
开启本功能前,需要确保所有AP Radio视图和AP组Radio视图下已绑定的无线服务模板被分配的WLAN ID不能为WLAN ID取值范围的后一半,否则需要首先解绑当前WLAN ID对应的无线服务模板,才能成功开启本功能。无线服务模板被分配的WLAN ID可以通过Probe视图下的命令display system internal wlan bss list ap ap-id radio radio-id查看,WLAN ID取值从1开始,最大值为开启本功能前Radio下可创建的BSS个数。
开启本功能后,一个Radio下可以创建的最大BSS个数会减半。
关闭本功能前,需要确保所有AP和AP组视图下没有创建虚拟AP,否则需要首先删除已创建的虚拟AP,才能成功关闭本功能。
虚拟AP不支持自动选择信道,只支持手工指定工作信道,且物理AP以及虚拟AP所连接AC的射频工作信道配置必须保持一致。
# 开启虚拟AP功能。
[Sysname] wlan virtual-ap enable
·     virtual-ap
·     wlan virtual-ap
1.1.130  wlan virtual-ap-group
wlan virtual-ap-group命令用来创建虚拟AP组,并进入虚拟AP组视图。如果指定的虚拟AP组已经存在,则直接进入虚拟AP组视图。
undo wlan virtual-ap-group命令用来删除指定的虚拟AP组。
wlan virtual-ap-group group-name
undo wlan virtual-ap-group group-name
存在缺省虚拟AP组,名称为default-vitualapgroup。
group-name:虚拟AP组的名称,为1~31个字符的字符串,不区分大小写。
缺省虚拟AP组default-virtualapgroup不能被删除。
通过配置AP入组规则将AP加入到AP组中,如果AP视图下没有配置,可以将AP组视图下的配置下发到当前AP组中的所有AP,降低逐个AP进行配置的工作量。
# 创建一个名为group1的虚拟AP组,并进入虚拟AP组视图。
·     display wlan virtual-ap-group
