18-安全命令参考
12-ARP攻击防御命令
本章节下载: 12-ARP攻击防御命令  (457.48 KB)
12-ARP攻击防御命令
1 ARP攻击防御
1.1 ARP防止IP报文攻击配置命令
1.1.1 arp resolving-route enable
1.1.2 arp resolving-route probe-count
1.1.3 arp resolving-route probe-interval
1.1.4 arp source-suppression enable
1.1.5 arp source-suppression limit
1.1.6 display arp source-suppression
1.2 ARP模块的告警功能配置命令
1.2.1 snmp-agent trap enable arp
1.3 源MAC地址固定的ARP攻击检测配置命令
1.3.1 arp source-mac
1.3.2 arp source-mac aging-time
1.3.3 arp source-mac exclude-mac
1.3.4 arp source-mac threshold
1.3.5 display arp source-mac
1.3.6 display arp source-mac statistics
1.3.7 reset arp source-mac statistics
1.4 ARP报文源MAC地址一致性检查配置命令
1.4.1 arp valid-check enable
1.4.2 display arp valid-check statistics
1.4.3 reset arp valid-check statistics
1.5 ARP主动确认配置命令
1.5.1 arp active-ack enable
1.6 授权ARP配置命令
1.6.1 arp authorized enable
1.7 ARP Detection配置命令
1.7.1 arp detection enable
1.7.2 arp detection log enable
1.7.3 arp detection port-match-ignore
1.7.4 arp detection rule
1.7.5 arp detection trust
1.7.6 arp detection validate
1.7.7 arp restricted-forwarding enable
1.7.8 display arp detection
1.7.9 display arp detection statistics attack-source
1.7.10 display arp detection statistics packet-drop
1.7.11 reset arp detection statistics attack-source
1.7.12 reset arp detection statistics packet-drop
1.8 ARP自动扫描、固化配置命令
1.8.1 arp fixup
1.8.2 arp scan
1.8.3 arp scan auto enable
1.8.4 arp scan auto send-rate
1.9 ARP的Keepalive表项扫描
1.9.1 arp scan keepalive aging-time
1.9.2 arp scan keepalive enable
1.9.3 arp scan keepalive send-rate
1.9.4 display arp scan keepalive entry
1.9.5 display arp scan keepalive statistics
1.9.6 reset arp scan keepalive statistics
1.10 ARP网关保护配置命令
1.10.1 arp filter source
1.11 ARP过滤保护配置命令
1.11.1 arp filter binding
1.12 配置ARP报文源IP地址检查功能配置命令
1.12.1 arp sender-ip-range
1 ARP攻击防御
1.1  ARP防止IP报文攻击配置命令
arp resolving-route enable命令用来开启ARP黑洞路由功能。
undo arp resolving-route enable命令用来关闭ARP黑洞路由功能。
ARP黑洞路由功能处于开启状态。
建议在网关设备上开启本功能。
# 开启ARP黑洞路由功能。
[Sysname] arp resolving-route enable
·     arp resolving-route probe-count
·     arp resolving-route probe-interval
arp resolving-route probe-count命令用来配置发送ARP请求报文的次数。
undo arp resolving-route probe-count命令用来恢复缺省情况。
arp resolving-route probe-count count
发送ARP请求报文的次数为3次。
count:发送ARP请求报文的次数,取值范围为1~25。
# 配置发送ARP请求报文的次数为5次。
[Sysname] arp resolving-route probe-count 5
·     arp resolving-route enable
arp resolving-route probe-interval命令用来配置发送ARP请求报文的时间间隔。
undo arp resolving-route probe-interval命令用来恢复缺省情况。
arp resolving-route probe-interval interval
发送ARP请求报文的时间间隔是1秒。
interval:发送ARP请求报文的时间间隔,取值范围为1~5,单位为秒。
# 配置发送ARP请求报文的时间间隔为3秒。
[Sysname] arp resolving-route probe-interval 3
arp source-suppression enable命令用来开启ARP源地址抑制功能。
undo arp source-suppression enable命令用来关闭ARP源地址抑制功能。
ARP源地址抑制功能处于关闭状态。
建议在网关设备上开启本功能。
# 开启ARP源地址抑制功能。
[Sysname] arp source-suppression enable
·     display arp source-suppression
arp source-suppression limit命令用来配置ARP源抑制的阈值。
undo arp source-suppression limit命令用来恢复缺省情况。
ARP源抑制的阈值为10。
limit-value:ARP源抑制的阈值,即设备在5秒间隔内可以处理的源IP相同,但目的IP地址不能解析的IP报文的最大数目,取值范围为2~1024。
如果网络中每5秒内从某IP地址向设备某接口发送目的IP地址不能解析的IP报文超过了设置的阈值,则设备将不再处理由此IP地址发出的IP报文直至该5秒结束,从而避免了恶意攻击所造成的危害。
# 配置ARP源抑制的阈值为100。
[Sysname] arp source-suppression limit 100
display arp source-suppression命令用来显示当前ARP源抑制的配置信息。
# 显示当前ARP源抑制的配置信息。
<Sysname> display arp source-suppression
 ARP source suppression is enabled
 Current suppression limit: 100
表1-1 display arp source-suppression显示信息描述表
ARP源抑制功能处于开启状态
设备在5秒时间间隔内可以接收到的源IP相同,但目的IP地址不能解析的IP报文的最大数目
1.2  ARP模块的告警功能配置命令
snmp-agent trap enable arp命令用来开启ARP模块的告警功能。
undo snmp-agent trap enable arp命令用来关闭ARP模块的告警功能。
snmp-agent trap enable arp [ active-ack | arp-miss | detection-drop | entry-check | entry-limit | gateway-check | local-conflict | mac-mismatch | packet-check | user-ip-conflict | user-move ] *
undo snmp-agent trap enable arp [ active-ack | arp-miss | detection-drop | entry-check | entry-limit | gateway-check | local-conflict | mac-mismatch | packet-check | user-ip-conflict | user-move ] *
ARP模块的告警功能处于关闭状态。
active-ack:开启触发ARP主动确认的告警功能。
arp-miss:开启ARP Miss消息和ARP报文发送限速的告警功能。
detection-drop:开启ARP Detection丢包的告警功能。
entry-check:开启ARP表项被修改的告警功能。
entry-limit:开启ARP表项达到最大个数的告警功能。
gateway-check:开启ARP模块网关保护的告警功能。
local-conflict:开启ARP模块终端与本机IP地址冲突的告警功能。
mac-mismatch:开启ARP MAC地址不一致的告警功能。
packet-check:开启非法ARP报文检查的告警功能。
user-ip-conflict:开启ARP模块终端用户间IP地址冲突的告警功能。
user-move:开启ARP终端用户端口迁移的告警功能。
用户可根据业务需求开启指定功能的ARP模块的告警。
·     开启了触发ARP主动确认的告警功能后,如果设备由于主动确认功能而没有建立ARP表项,设备会将收到的ARP报文的发送端IP地址和收到ARP报文的接口信息作为告警信息发送到设备的SNMP模块。
·     开启了ARP Miss消息和ARP报文发送限速的告警功能后,如果设备每秒发送的ARP Miss消息或ARP报文的个数超过了设备定制的阈值,设备会将超速峰值作为告警信息发送到设备的SNMP模块。
·     开启了ARP Detection丢包的告警功能后,设备会将ARP Detection丢包的VLAN ID、Service ID、VSI、丢包类型等信息作为告警信息发送到设备的SNMP模块。
·     开启了ARP表项被修改的告警功能后,当设备检测到用户在设备上的ARP表项可能被刷新成攻击者的ARP表项时,设备会将ARP欺骗攻击报文的IP地址、MAC地址等信息作为告警信息发送到设备的SNMP模块。
·     开启了ARP表项达到最大个数的告警功能后,如果当前全局ARP表项的数量超过了告警阈值,设备会将当前ARP表项的数目作为告警信息发送到设备的SNMP模块。
·     当开启了ARP网关保护的告警功能后,当设备受到仿冒网关攻击时,设备会将因网关保护功能丢弃的ARP攻击报文的发送端IP地址、发送端MAC地址、收到ARP攻击报文的接口索引等作为告警信息发送到设备的SNMP模块。当同一发送端IP地址的ARP报文3分钟内再次触发告警,则认为此次告警恢复,同时发送告警恢复信息到设备的SNMP模块。
·     开启了ARP模块终端与本机冲突的告警功能后,设备会将冲突报文的发送端IP地址和MAC地址、目标IP地址和MAC地址等信息作为告警信息发送到设备的SNMP模块。
·     开启了ARP MAC地址不一致的告警功能后,当设备上配置的静态ARP表项的MAC地址和用户实际的MAC地址不一致时,设备会将该ARP表项的IP地址、VRF、MAC地址等信息作为告警信息发送到设备的SNMP模块。
·     非法ARP报文指报文中的硬件类型、协议类型、硬件地址长度、协议地址长度、操作类型或VLAN等信息存在非法值的ARP报文。比如当ARP报文的操作类型不是请求或响应时,操作类型为非法值,此ARP报文非法。当开启了非法ARP报文检查的告警功能后,设备将接收到的非法ARP报文的接口名、发送端MAC地址、发送端IP地址、用户VLAN ID、服务提供商VLAN ID作为告警信息发送出去,生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关特性。
·     开启了ARP模块终端用户间IP地址冲突的告警功能后,设备会将冲突报文的发送端IP地址和MAC地址、发生冲突的本地表项的MAC地址等信息作为告警信息发送到设备的SNMP模块。有关开启ARP记录终端用户间IP地址冲突功能请参见“三层技术-IP业务配置指导”中的“ARP”。
·     开启了ARP模块终端用户端口迁移的告警功能后,设备会将发生了端口迁移的用户的IP地址、MAC地址、迁移前后的端口名称等信息作为告警信息发送到设备的SNMP模块。有关开启ARP记录终端用户端口迁移功能请参见“三层技术-IP业务配置指导”中的“ARP”。
本命令如果不指定任何参数,则表示打开ARP模块的所有告警功能。
可以通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关特性。有关告警信息的详细描述,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启触发ARP主动确认的告警功能。
[Sysname] snmp-agent trap enable arp active-ack
arp source-mac命令用来开启源MAC地址固定的ARP攻击检测功能,并选择检查模式。
undo arp source-mac命令用来关闭源MAC地址固定的ARP攻击检测功能。
arp source-mac { filter | monitor }
undo arp source-mac [ filter | monitor ]
源MAC地址固定的ARP攻击检测功能处于关闭状态。
filter:配置检查方式为过滤模式。
monitor:配置检查方式为监控模式。
应用场景
设备处理大量源MAC地址固定的ARP报文会造成CPU繁忙,影响正常的业务处理。为了避免这种问题,可以在设备上开启源MAC地址固定的ARP攻击检测功能。
工作机制
本特性根据ARP报文的源MAC地址对上送CPU的ARP报文进行统计,在5秒内,如果收到同一源MAC地址(源MAC地址固定)的ARP报文超过一定的阈值,则认为存在攻击,系统会将此MAC地址添加到攻击检测表项中。
当开启了ARP日志信息功能(配置arp check log enable命令),且在该攻击检测表项老化之前,系统会根据设置的检查模式对源MAC地址存在于攻击检测表项中的ARP报文有如下处理:
·     如果设置的检查模式为过滤模式,则会打印日志信息并且将该源MAC地址发送的ARP报文过滤掉。
·     如果设置的检查模式为监控模式,则只打印日志信息,不会将该源MAC地址发送的ARP报文过滤掉。
关于ARP日志信息功能的详细描述,请参见“三层技术-IP业务配置指导”中的“ARP”。
根据ARP报文的源MAC地址对上送CPU的ARP报文进行统计时,设备支持如下两种统计方式:
·     基于三层接口(除VLAN接口外)的统计方式:每个接口单独进行报文统计计数。在固定时间(5秒)内,如果某接口收到同一源MAC地址(源MAC地址固定)的ARP报文超过一定的阈值,则认为存在攻击。
·     基于VLAN接口的统计方式:对VLAN接口所属slot上所有物理接口的报文进行统一计数。在固定时间(5秒)内,如果某slot收到同一源MAC地址(源MAC地址固定)的ARP报文超过一定的阈值,则认为存在攻击,表项记录第一次收到攻击报文的物理接口。
推荐配置
建议在网关设备上开启本功能。
注意事项
切换源MAC地址固定的ARP攻击检查模式时,如果从监控模式切换到过滤模式,则过滤模式立即生效;如果从过滤模式切换到监控模式,已生成的攻击检测表项在老化之前会继续按照过滤模式处理,新增的攻击检测表项会按照监控模式处理。
如果undo arp source-mac命令中未指定检查模式,则关闭任意检查模式的源MAC地址固定的ARP攻击检测功能。
# 开启源MAC地址固定的ARP攻击检测功能,并选择filter检查模式。
[Sysname] arp source-mac filter
arp source-mac aging-time命令用来配置源MAC地址固定的ARP攻击检测表项的老化时间。
undo arp source-mac aging-time命令用来恢复缺省情况。
arp source-mac aging-time time
源MAC地址固定的ARP攻击检测表项的老化时间为300秒。
time:源MAC地址固定的ARP攻击检测表项的老化时间,取值范围为60~6000,单位为秒。
# 配置源MAC地址固定的ARP攻击检测表项的老化时间为60秒。
[Sysname] arp source-mac aging-time 60
arp source-mac exclude-mac命令用来配置保护MAC地址。当配置了保护MAC地址之后,即使该ARP报文中的MAC地址存在攻击也不会被检测过滤。
undo arp source-mac exclude-mac命令用来取消配置的保护MAC地址。
arp source-mac exclude-mac mac-address&<1-10>
undo arp source-mac exclude-mac [ mac-address&<1-10> ]
未配置任何保护MAC地址。
mac-address&<1-10>:MAC地址列表。其中,mac-address表示配置的保护MAC地址,格式为H-H-H。&<1-10>表示每次最多可以配置的保护MAC地址个数。n的取值为10。
如果undo命令中未指定MAC地址,则取消所有已配置的保护MAC地址。
# 配置源MAC地址固定的ARP攻击检查的保护MAC地址为001e-1200-0213。
[Sysname] arp source-mac exclude-mac 001e-1200-0213
arp source-mac threshold命令用来配置源MAC地址固定的ARP报文攻击检测阈值,当在固定的时间(5秒)内收到源MAC地址固定的ARP报文超过该阈值则认为存在ARP报文攻击。
undo arp source-mac threshold命令用来恢复缺省情况。
arp source-mac threshold threshold-value
源MAC地址固定的ARP报文攻击检测阈值为30。
threshold-value:固定时间内源MAC地址固定的ARP报文攻击检测的阈值,单位为报文个数,取值范围为1~5000。
# 配置源MAC地址固定的ARP报文攻击检测阈值为30个。
[Sysname] arp source-mac threshold 30
display arp source-mac命令用来显示检测到的源MAC地址固定的ARP攻击检测表项。
display arp source-mac { interface interface-type interface-number [ slot slot-number ] | slot slot-number }
interface interface-type interface-number:显示指定接口检测到的源MAC地址固定的ARP攻击检测表项,interface-type interface-number表示指定接口的类型和编号。对于虚拟接口,还支持通过指定位置参数来显示指定位置上该虚拟接口对应的物理口检测到的源MAC地址固定的ARP攻击检测表项。
slot slot-number:显示指定单板检测到的源MAC地址固定的ARP攻击检测表项。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板检测到的源MAC地址固定的ARP攻击检测表项。
# 显示接口Ten-GigabitEthernet0/0/6检测到的源MAC地址固定的ARP攻击检测表项。
<Sysname> display arp source-mac interface ten-gigabitethernet 0/0/6
Source-MAC          VLAN ID  Interface                Aging-time
23f3-1122-3344      4094     XGE1/0/1                 10
表1-2 display arp source-mac命令显示信息描述表
Source-MAC
检测到攻击的源MAC地址
VLAN ID
检测到攻击的VLAN ID
攻击来源的接口
Aging-time
ARP防攻击策略表项老化剩余时间,单位为秒
display arp source-mac statistics命令用来显示ARP攻击检测功能丢弃的源MAC地址固定的ARP攻击报文计数统计信息。
display arp source-mac statistics slot slot-number
slot slot-number:指定单板。slot-number为单板所在的槽位号。
# 显示设备上ARP攻击检测功能丢弃的源MAC地址固定的ARP攻击报文计数统计信息。
<Sysname> display arp source-mac statistics
Dropped ARP packets:23321
表1-3 display arp source-mac statistics命令显示信息描述表
Dropped ARP packets
被丢弃的源MAC固定的ARP攻击报文数
·     arp source-mac
reset arp source-mac statistics命令用来清除源MAC地址固定的ARP攻击检测丢弃ARP攻击报文的计数统计信息。
reset arp source-mac statistics { all | [ slot slot-number ] }
all:清除所有的计数统计信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
如果未指定任何参数,则清除设备上所有源MAC地址固定的ARP攻击检测丢弃ARP攻击报文的计数统计信息。
# 清除设备上所有源MAC地址固定的ARP攻击检测丢弃ARP攻击报文的计数统计信息。
<Sysname> reset arp source-mac statistics
·     display arp source-mac statistics
arp valid-check enable命令用来开启ARP报文源MAC地址一致性检查功能。
undo arp valid-check enable命令用来关闭ARP报文源MAC地址一致性检查功能。
ARP报文源MAC地址一致性检查功能处于关闭状态。
ARP报文源MAC地址一致性检查功能主要应用于网关设备。
开启ARP报文源MAC地址一致性检查功能后,设备会对接收的ARP报文进行检查,如果以太网数据帧首部中的源MAC地址和ARP报文中的源MAC地址不同,则丢弃该报文。
# 开启ARP报文源MAC地址一致性检查功能。
[Sysname] arp valid-check enable
display arp valid-check statistics命令用来显示ARP报文源MAC地址一致性检查功能丢弃的ARP报文计数统计信息。
display arp valid-check statistics slot slot-number
# 显示设备上ARP报文源MAC地址一致性检查功能丢弃的ARP报文计数统计信息。
<Sysname> display arp valid-check statistics
Dropped ARP packets: 23321
表1-4 display arp valid-check statistics命令显示信息描述表
Dropped ARP packets
源MAC地址一致性检查不通过而丢弃的ARP报文数
·     arp valid-check enable
reset arp valid-check statistics命令用来清除ARP报文源MAC地址一致性检查功能丢弃的ARP报文计数统计信息。
reset arp valid-check statistics { all | slot slot-number }
all:清除所有的计数统计信息。
# 清除设备上ARP报文源MAC地址一致性检查功能丢弃的ARP报文计数统计信息。
<Sysname> reset arp valid-check statistics
·     display arp valid-check statistics
1.5  ARP主动确认配置命令
arp active-ack enable命令用来开启ARP主动确认功能。
undo arp active-ack enable命令用来关闭ARP主动确认功能。
arp active-ack [ strict ] enable
undo arp active-ack [ strict ] enable
ARP主动确认功能处于关闭状态。
strict:ARP主动确认功能的严格模式。
ARP的主动确认功能主要应用于网关设备,防止攻击者仿冒用户欺骗网关设备。
# 开启ARP主动确认功能。
[Sysname] arp active-ack enable
1.6  授权ARP配置命令
arp authorized enable命令用来开启接口下的授权ARP功能。
undo arp authorized enable命令用来关闭接口下的授权ARP功能。
接口下的授权ARP功能处于关闭状态。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
VSI虚接口视图
VLAN接口视图
# 开启Ten-GigabitEthernet0/0/6接口下授权ARP功能。
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] arp authorized enable
arp detection enable命令用来开启ARP Detection功能,即对ARP报文进行用户合法性检查。
undo arp detection enable命令用来关闭ARP Detection功能。
ARP Detection功能处于关闭状态,即不进行用户合法性检查。
二层以太网接口视图
VLAN视图
VSI视图
只要在二层以太网接口或二层以太网接口所在的VLAN上开启了ARP Detection功能,二层以太网网接口的ARP Detection功能就会被开启;只有将二层以太网接口和二层以太网接口所在的VLAN上的ARP Detection功能全部关闭后,接口上的ARP Detection功能才能被关闭。
在一个二层接口上同时配置arp detection enable命令和arp detection trust命令时,接口接收报文不会经过ARP Detection功能检查。
# 在二层以太网接口Ten-GigabitEthernet0/0/6上开启ARP Detection功能。
[Sysname-Ten-GigabitEthernet0/0/6] arp detection enable
# 在VLAN 2下开启ARP Detection功能。
[Sysname] vlan 2
[Sysname-vlan2] arp detection enable
# 在VSI vsi1下开启ARP Detection功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp detection enable
·     arp detection rule
·     display arp detection
arp detection log enable命令用来开启ARP Detection日志功能。
undo arp detection log enable命令用来关闭ARP Detection日志功能。
arp detection log enable [ interval interval | number number  | threshold threshold-value ] *
ARP Detection日志功能处于关闭状态。
interval interval:ARP Detection日志信息输出周期,interval的取值范围为0、10~3600,单位为秒,缺省值为60。当interval取值为0时,表示立即输出日志信息。
number number:每个输出周期输出的ARP Detection日志最大数量,number的取值范围为1~128,缺省值为128。
threshold threshold-value:同一目的地址的ARP攻击报文数,threshold-value的取值范围为1~128,缺省值为1。
ARP Detection日志可以方便管理员定位问题和解决问题。设备生成的ARP Detection日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“设备管理配置指导”中的“信息中心”。
当设备输出大量ARP Detection日志信息时,会降低设备性能。这时用户可以关闭ARP Detection日志功能,使设备不再输出ARP Detection日志信息。
大量的日志信息不仅影响设备性能,还影响管理员查看日志和定位问题。用户可以设置每个输出周期输出的ARP Detection日志数量,超过指定的日志数量的日志信息不会被显示。用户还可以配置针对单个地址收到的攻击报文数的阈值,当设备收到某个地址对应的攻击报文时,开始计数,当收到的单个地址对应的攻击报文大于或等于阈值时,生成对应的ARP Detection日志。
对于单块单板或单个成员设备,设备最多同时输出128条ARP Detection日志信息。
# 开启ARP Detection日志功能。
[Sysname] arp detection log enable
arp detection port-match-ignore命令用来开启ARP Detection忽略端口匹配检查功能。
undo arp detection port-match-ignore命令用来关闭ARP Detection忽略端口匹配检查功能。
ARP Detection忽略端口匹配检查功能处于关闭状态。
开启ARP Detection忽略端口匹配检查功能后,ARP Detection在进行各类安全表项检查时,忽略ARP报文入端口和表项中的端口是否匹配的检查。
# 开启ARP Detection忽略端口匹配检查功能。
[Sysname] arp detection port-match-ignore
·     arp detection enable
arp detection rule命令用来配置用户合法性检查规则。
undo arp detection rule命令用来删除用户合法性检查规则。
arp detection rule rule-id { deny | permit } ip { ip-address [ mask ] | any } mac { mac-address [ mask ] | any } [ vlan vlan-id | vsi vsi-name ]
undo arp detection rule [ rule-id ]
未配置用户合法性检查规则。
rule-id:用户合法性规则编号,取值范围为0~511,数值越小表示该用户合法性规则优先级越高。
deny:丢弃指定范围内的ARP报文。
permit:转发指定范围内的ARP报文。
ip { ip-address [ mask ] | any }:指定报文的源IP地址范围。
·     ip-address:表示报文的源IP地址,为点分十进制形式。
·     mask:表示源IP地址的掩码,为点分十进制形式。如果未指定该参数,则ip-address表示主机地址。
·     any:表示任意源IP地址。
mac { mac-address [ mask ] | any }:指定报文的源MAC地址范围。
·     mac-address:表示报文的源MAC地址,格式为H-H-H。
·     mask:表示源MAC地址的掩码,格式为H-H-H。如果未指定该参数,则mac-address表示主机MAC地址。
·     any:表示任意源MAC地址。
vlan vlan-id:指定规则中匹配的VLAN,vlan-id的取值范围为1~4094。如果未指定该参数,则不对报文中的VLAN进行匹配检查。
vsi vsi-name:指定规则中匹配的VSI。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定该参数,则不对报文所属的VSI进行匹配检查。
只有配置了arp detection enable命令后,通过命令arp detection rule配置的规则才生效。
使用undo arp detection rule命令时,如果未指定rule-id,则会删除设备上所有已配置的用户合法性规则。
要使规则中匹配的VSI生效,需要执行l2vpn enable命令开启L2VPN功能。
# 配置用户合法性规则,规则编号为0,规则内容为转发源地址为10.1.1.1,掩码为255.255.0.0,源MAC地址为0001-0203-0405,掩码为ffff-ffff-0000的ARP报文。并在VLAN2中开启用户合法性检查功能。
[Sysname] arp detection rule 0 permit ip 10.1.1.1 255.255.0.0 mac 0001-0203-0405 ffff-ffff-0000
[Sysname] vlan 2
# 配置用户合法性规则,规则编号为1,规则内容为转发源地址为10.1.1.2、掩码为255.255.0.0、源MAC地址为0001-0203-0406、掩码为ffff-ffff-0000、所属VSI为vpna的ARP报文。并在VSI vpna下开启用户合法性检查功能。
[Sysname] arp detection rule 1 permit ip 10.1.1.2 255.255.0.0 mac 0001-0203-0406 ffff-ffff-0000 vsi vpna
[Sysname] vsi vpna
[Sysname-vsi-vpna] arp detection enable
arp detection trust命令用来配置接口为ARP信任接口或配置AC为ARP信任的AC。
undo arp detection trust命令用来恢复缺省情况。
arp detection trust
接口为ARP非信任接口,AC为ARP非信任AC。
二层以太网接口视图
二层聚合接口视图
# 配置二层以太网接口Ten-GigabitEthernet0/0/6为ARP信任接口。
[Sysname-Ten-GigabitEthernet0/0/6] arp detection trust
arp detection validate命令用来开启对ARP报文的目的MAC地址或源MAC地址、IP地址的有效性检查。
undo arp detection validate命令用来关闭对ARP报文的有效性检查。
undo arp detection validate [ dst-mac | ip | src-mac ] *
ARP报文有效性检查处于关闭状态。
dst-mac:检查ARP应答报文中的目的MAC地址,是否为全0或者全1,是否和以太网报文头中的目的MAC地址一致。全0、全1、不一致的报文都是无效的,无效的报文需要被丢弃。
ip:检查ARP报文源IP和目的IP地址,全1或者组播IP地址都是不合法的,需要丢弃。对于ARP应答报文,源IP和目的IP地址都进行检查;对于ARP请求报文,只检查源IP地址。
src-mac:检查ARP报文中的源MAC地址和以太网报文头中的源MAC地址是否一致,一致认为有效,否则丢弃。
开启有效性检查时可以指定某一种检查方式也可以配置成多种检查方式的组合。
关闭时可以指定关闭某一种或多种检查,在不指定检查方式时,表示关闭所有有效性检查。
# 开启对ARP报文的MAC地址和IP地址的有效性检查。
[Sysname] arp detection validate dst-mac ip src-mac
arp restricted-forwarding enable命令用来开启ARP报文强制转发功能。
undo arp restricted-forwarding enable命令用来关闭ARP报文强制转发功能。
ARP报文强制转发功能处于关闭状态。
VLAN视图
# 开启VLAN 2的ARP报文强制转发功能。
[Sysname] vlan 2
[Sysname-vlan2] arp restricted-forwarding enable
display arp detection命令用来显示配置了ARP Detection功能的VLAN和VSI。
# 显示所有配置了ARP Detection功能的VLAN和VSI。
<Sysname> display arp detection
 ARP detection is enabled in the following VLANs:
 1-2, 4-5
 ARP detection is enabled in the following VSIs:
 vpna
 vsi-0000-0000-0031
 vpnb
 vpnc-vsi-0000-0000-00aa
表1-5 display arp detection命令显示信息描述表
配置了ARP Detection功能的VLAN信息,如果不存在配置了ARP Detection功能的VLAN,则显示“ARP detection is not enabled in any VLANs.”
配置了ARP Detection功能的VSI信息,如果不存在配置了ARP Detection功能的VSI,则显示“ARP detection is not enabled in any VSIs.”
display arp detection statistics attack-source命令用来显示ARP Detection攻击源统计信息。
display arp detection statistics attack-source slot slot-number
slot slot-number:显示指定单板的ARP Detection攻击源统计信息。slot-number表示单板所在的槽位号。
执行本命令最多显示1024条信息。前1023条是有效的ARP Detection攻击源统计信息,第1024条是一条统计标识信息。当攻击源统计信息少于1024条时,不会显示统计标识信息。
当设备学习到第1024条表项时,会使用最新学习到的表项覆盖最老的表项,同时生成第1024条统计标识信息。第1024条表项中各字段的取值为:
·     Interface、VLAN、MAC address和IP address字段取值为空。
·     Number字段为被覆盖表项的Number字段的取值。
·     Time字段取值为生成第1024条表项的时间。
后续,设备再学习到新的表项,同样是使用最新学习到的表项覆盖最老的表项,并更新第1024条统计标识信息:
·     Number字段取值累加被覆盖表项的Number字段取值。
·     Time字段更新为更新本表项的时间。
# 显示Slot 1所有的ARP Detection攻击源统计信息。
<Sysname> display arp detection statistics attack-source slot 1
Interface              VLAN  MAC address    IP address      Number     Time
XGE0/0/6               1     0005-0001-0001 10.1.1.14       24         17:09:56
03-27-2017
表1-6 display arp detection attack statistics attack-source命令显示信息描述表
ARP Detection攻击报文的入接口
VLAN
ARP Detection攻击报文所属VLAN
MAC address
ARP Detection攻击报文中的源MAC地址
IP address
ARP Detection攻击报文中的源IP地址
Number
ARP Detection攻击报文被拦截的次数
Time
最近一次拦截该ARP Detection攻击报文的时间
display arp detection statistics packet-drop命令用来显示ARP Detection丢弃报文的统计信息。
display arp detection statistics packet-drop [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口的ARP Detection丢弃报文的统计信息。interface-type interface-number用来指定接口类型和编号。如果未指定本参数,则显示所有接口的ARP Detection丢弃报文的统计信息。
按接口显示用户合法性检查和报文有效性检查的统计情况,只显示ARP Detection功能报文的丢弃情况。
# 显示ARP Detection丢弃报文的统计信息。
<Sysname> display arp detection statistics packet-drop
State: U-Untrusted  T-Trusted
ARP packets dropped by ARP inspect checking:
Interface(State)            IP        Src-MAC   Dst-MAC   Inspect
XGE1/0/1(U)                 40        0         0         78
XGE1/0/2(U)                 0         0         0         0
XGE1/0/3(T)                 0         0         0         0
XGE1/0/4(U)                 0         0         30        0
表1-7 display arp detection statistics packet-drop命令显示信息描述表
接口状态:
·     U:ARP非信任接口
·     T:ARP信任接口
Interface(State)
ARP报文入接口,State表示该接口的信任状态
IP
ARP报文源和目的IP地址检查不通过丢弃的报文计数
Src-MAC
ARP报文源MAC地址检查不通过丢弃的报文计数
Dst-MAC
ARP报文目的MAC地址检查不通过丢弃的报文计数
Inspect
ARP报文结合用户合法性检查不通过丢弃的报文计数
·     reset arp detection statistics packet-drop
reset arp detection statistics attack-source命令用来清除ARP Detection攻击源统计信息。
reset arp detection statistics attack-source [ slot slot-number ]
slot slot-number:清除指定单板的ARP Detection攻击源统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,则清除所有单板上的ARP Detection攻击源统计信息。
# 清除所有的ARP Detection攻击源统计信息。
<Sysname> reset arp detection statistics attack-source
·     display arp detection statistics attack-source
reset arp detection statistics packet-drop命令用来清除ARP Detection的报文丢弃统计信息。
reset arp detection statistics packet-drop [ interface interface-type interface-number ]
interface interface-type interface-number:表示清除指定接口下的ARP Detection的报文丢弃统计信息。interface-type interface-number用来指定接口类型和编号。如果未指定本参数,则清除所有接口下的ARP Detection报文丢弃统计信息。
# 清除所有的ARP Detection的报文丢弃统计信息。
<Sysname> reset arp detection statistics packet-drop
·     display arp detection statistics packet-drop
1.8  ARP自动扫描、固化配置命令
1.8.1  arp fixup
arp fixup命令用来将设备上的动态ARP表项转化成静态ARP表项。
undo arp fixup命令用来将设备上有效静态ARP表项转化为动态ARP表项,将无效静态ARP表项删除。
arp fixup
undo arp fixup
本命令将当前的动态ARP表项转换为静态ARP表项,后续学习到的动态ARP表项可以通过再次执行arp fixup命令进行固化。
固化后的静态ARP表项与配置产生的静态ARP表项相同。
固化生成的静态ARP表项数量同样受到设备可以支持的静态ARP表项数目的限制,由于静态ARP表项数量的限制可能导致只有部分动态ARP表项被固化。
如果用户执行固化前有D个动态ARP表项,S个静态ARP表项,由于固化过程中存在动态ARP表项的老化或者新建动态ARP表项的情况,所以固化后的静态ARP表项可能为(D+S+M-N)个。其中,M为固化过程中新建的动态ARP表项个数,N为固化过程中老化的动态ARP表项个数。
通过固化生成的静态ARP表项,可以通过命令行undo arp ip-address [ vpn-instance-name ]逐条删除,也可以通过命令行reset arp all或reset arp static全部删除。
# 将设备上的动态ARP表项转化成静态ARP表项。
[Sysname] arp fixup
This command will convert existing dynamic ARP entries to static ARP entries. Continue? [Y/N]:Y
Fixup ARP. Please wait...
Fixup is complete.
1.8.2  arp scan
arp scan命令用来开启ARP自动扫描功能。
arp scan [ start-ip-address to end-ip-address ]
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
VSI虚接口视图
VLAN接口视图
start-ip-address:ARP扫描区间的起始IP地址。起始IP地址必须小于等于终止IP地址。
end-ip-address:ARP扫描区间的终止IP地址。
扫描操作可能比较耗时,且会占用较大的设备资源和网络负载。可以通过<Ctrl_C>来终止扫描(在终止扫描时,对于已经收到的邻居应答,会建立该邻居的动态ARP表项)。
ARP自动扫描功能可以对接口下指定地址范围内的邻居进行扫描,对于已存在ARP表项的IP地址不进行扫描。
如果用户知道局域网内邻居分配的IP地址范围,指定了ARP扫描区间,则对该范围内的邻居进行扫描,减少扫描等待的时间。如果指定的扫描区间同时在接口下多个IP地址的网段内,则发送的ARP请求报文的源IP地址选择网段范围较小的接口IP地址。
如果用户不指定ARP扫描区间的起始IP地址和终止IP地址,则仅对接口下的主IP地址网段内的邻居进行扫描。其中,发送的ARP请求报文的源IP地址就是接口的主IP地址。
ARP扫描区间的起始IP地址和终止IP地址必须与接口的IP地址(主IP地址或手工配置的从IP地址)在同一网段。
# 对接口Ten-GigabitEthernet0/0/6下的主IP地址网段内的邻居进行扫描。
[Sysname-Ten-GigabitEthernet0/0/6] arp scan
# 对接口Ten-GigabitEthernet0/0/6下指定地址范围内的邻居进行扫描。
[Sysname-Ten-GigabitEthernet0/0/6] arp scan 1.1.1.1 to 1.1.1.20
arp scan auto enable命令用来在接口上开启ARP周期性自动扫描功能,并指定扫描范围。
undo arp scan auto enable命令用来在接口上关闭ARP周期性自动扫描功能或者取消指定IP地址网段的ARP扫描范围配置。
arp scan auto enable [ start-ip-address to end-ip-address [ source-addr source-ip-address ] ]
undo arp scan auto enable [ start-ip-address to end-ip-address ]
接口上的ARP周期性自动扫描功能处于关闭状态。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
VSI接口视图
VLAN接口视图
start-ip-address:ARP自动扫描区间的起始IP地址。起始IP地址必须小于等于终止IP地址。
to end-ip-address:ARP自动扫描区间的终止IP地址。起始IP地址和终止IP地址之间的地址个数不能超过65535。
source-addr source-ip-address:手动指定ARP请求报文的源地址。source-ip-address可以是任何合法的IP地址。若不指定该参数,则ARP请求报文的源地址为所在接口的IP地址。
应用场景
接口上开启了ARP周期自动扫描功能后,会定时向接口指定范围内的所有不存在ARP表项的IP地址发送ARP请求报文。通过在接口上开启本功能,解决了接口ARP表项无法及时刷新的问题。
工作机制
如果用户知道局域网内邻居分配的IP地址范围,指定了ARP扫描区间,则对该范围内的邻居进行扫描,减少扫描等待的时间。为了方便用户根据不同的IP地址网段指定扫描范围,支持通过本命令配置多个IP地址网段的扫描范围。系统中最多允许配置16个IP地址网段的扫描范围,且各扫描范围间的网段地址不能重叠。接口发送ARP请求报文时使用的源地址可自行指定,缺省为配置的接口IP地址:
·     如果用户指定了ARP扫描区间的起始IP地址和终止IP地址:
¡     如果用户未指定源source-addr参数,则接口将对ARP扫描区间和接口所在网段的交集进行扫描。如果接口上配置了多个网段的IP地址,且这些网段与ARP扫描区间都有交集,则设备发送ARP请求时会通过发送ARP请求的目的IP地址去匹配网段掩码较长的地址作为ARP请求报文的源IP地址;如果子网掩码长度相同,则选择接口主IP地址;若待扫描的IP地址全部在接口下同一个IP地址网段内,则选择此IP地址。
¡     如果用户指定了source-addr参数,则接口将对ARP扫描区间进行扫描,不判断与接口网段的交集。
·     如果用户不指定ARP扫描区间的起始IP地址和终止IP地址,则仅对接口下的主IP地址网段和从IP地址网段内的邻居进行扫描。其中,发送的ARP请求报文的源IP地址就是接口的主IP地址和从IP地址。
注意事项
接口上开启了ARP周期自动扫描功能后,会按照扫描速率向扫描区间的所有IP地址发送ARP请求报文,设备发送ARP报文的速率可在系统视图下通过arp scan auto send-rate命令设置。
如果接口下同时配置了本命令和arp scan命令,则两个功能可以同时生效。通常,仅建议在网络中用户频繁上下线的环境下开启本功能。
[Sysname-Ten-GigabitEthernet0/0/6] arp scan auto enable
·     arp scan auto send-rate
arp scan auto send-rate命令用来设置ARP周期自动扫描速率。
undo arp scan auto send-rate命令用来恢复缺省情况。
arp scan auto send-rate { ppm ppm | pps }
ARP周期自动扫描速率为每秒发送48个包。
ppm ppm:接口发送ARP报文的速率,单位为包每分钟。ppm的取值范围为10~600,且配置需要设置为10的整数倍。
pps:接口发送ARP报文的速率,单位为包每秒。pps的取值范围为10~1000,且需要设置为10的整数倍。
接口下开启了ARP周期自动扫描功能的情况下,为避免大量ARP报文的发送对设备性能造成影响,可通过本命令调整设备发送的ARP报文的速率。
当发送ARP报文的速率配置为较大值时,为避免影响设备性能,设备实际发送ARP报文的速率可能会小于该配置值。
# 配置ARP周期自动扫描速率为每秒发送10个包。
[Sysname] arp scan auto send-rate 10
·     arp scan auto enable
arp scan keepalive aging-time命令用来配置ARP的Keepalive表项的老化时间。
undo arp scan keepalive aging-time命令用来恢复缺省情况。
arp scan keepalive aging-time time
系统视图下,ARP的Keepalive表项的老化时间为60分钟。
接口视图下,ARP的Keepalive表项的老化时间采用系统视图下的配置。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
VSI虚接口视图
VLAN接口视图
time:ARP的Keepalive表项的老化时间,单位为分钟,取值范围为1~1440。
应用场景
在接口上通过arp scan keepalive enable命令开启ARP的Keepalive表项扫描功能后,用户上线时系统会建立对应的状态为在线的Keepalive表项。用户下线时,对应的Keepalive表项状态被置为离线,如果用户重新上线则状态会再次被置为在线。可以通过执行本命令配置ARP的Keepalive表项的老化时间,处于离线状态的Keepalive表项在老化时间内没有变为在线便会被删除。
工作机制
ARP的Keepalive表项的老化时间可以在系统视图和接口视图下同时配置,优先使用接口视图下的配置,如果接口视图下为缺省配置则使用系统视图下的配置。
注意事项
如果配置的老化时间过短,可能会导致异常下线的设备来不及通过ARP请求报文恢复;如果配置的老化时间过长,会导致正常下线的设备对应的Keepalive表项长时间存在,即造成表项的冗余。
# 配置ARP的Keepalive表项的老化时间为10分钟。
[Sysname] arp scan keepalive aging-time 10
# 在Ten-GigabitEthernet0/0/6接口上配置ARP的Keepalive表项的老化时间为100分钟。
[Sysname-Ten-GigabitEthernet0/0/6] arp scan keepalive aging-time 100
·     arp scan keepalive enable
arp scan keepalive enable命令用来在接口上开启ARP的Keepalive表项扫描功能。
undo arp scan keepalive enable命令用来在接口上关闭ARP的Keepalive表项扫描功能。
接口上的ARP的Keepalive表项扫描功能处于关闭状态。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
VSI虚接口视图
VLAN接口视图
应用场景
在规模较大的组网环境中(比如园区网络),使用ARP周期性扫描功能后,如果指定的扫描范围过大,会导致需要较长的时间才能扫描到异常下线的主机。开启本功能后系统可以通过Keepalive表项快速定位异常下线的主机,并在老化时间内对异常下线主机的状态进行监测。
工作机制
用户上线后,系统会生成动态ARP表项和IP Source Guard绑定表项。开启本功能后,系统会根据这些表项建立状态为在线的Keepalive表项。用户下线后其ARP表项会被删除,对应的Keepalive表项的状态被置为离线。设备每隔一段时间会向处于离线状态的Keepalive表项对应的IP发送ARP请求报文,直到Keepalive表项的状态恢复成在线。对于某处于离线状态的Keepalive表项,设备发送ARP请求报文的间隔时间由已经向此Keepalive表项对应的IP地址发送的ARP请求报文的个数决定:个数小于等于50时间隔时间为30秒,个数大于50且小于等于100时间隔时间为45秒,个数大于100时间隔时间为60秒。
管理员可以通过display arp scan keepalive entry命令查看Keepalive表项。关于IP Source Guard的详细介绍,请参见“安全配置指导”中的“IP Source Guard”。
注意事项
可以通过arp scan keepalive aging-time命令配置Keepalive表项的老化时间,处于离线状态的Keepalive表项在老化时间内没有恢复为在线便会被删除。
# 在Ten-GigabitEthernet0/0/6接口上开启ARP扫描探测命令开关。
[Sysname-Ten-GigabitEthernet0/0/6] arp scan keepalive enable
·     arp scan keepalive aging-time
·     arp scan keepalive send-rate
·     display arp scan keepalive entry
arp scan keepalive send-rate命令用来设置ARP的Keepalive表项扫描速率。
undo arp scan keepalive send-rate命令用来恢复缺省情况。
arp scan keepalive send-rate pps
ARP的Keepalive表项扫描速率为每秒发送48个ARP请求报文。
pps:接口发送ARP报文的速率,取值范围为10~1000,单位为包每秒,为10的整数倍。
应用场景
接口下开启Keepalive表项扫描功能后,如果Keepalive表项的状态被置为离线,接口会按照指定的速率向离线表项对应的IP地址发送ARP请求报文。为避免接口发送的ARP请求报文对设备性能造成影响,可通过本命令调整接口发送ARP请求报文的速率。
工作机制
如果一个Keepalive表项的状态被置为离线,且此Keepalive表项没有在等待发送ARP请求报文的间隔时间结束,则此Keepalive表项是一个待扫描Keepalive表项。接口每秒会分别向不同的待扫描Keepalive表项对应的IP地址发送一个ARP请求报文。ARP的Keepalive表项扫描速率为每秒扫描的待扫描Keepalive表项的最大个数。如果待扫描Keepalive表项的个数小于扫描速率的值,则设备会在一秒内扫描所有的待扫描Keepalive表项;如果待扫描Keepalive表项的个数大于扫描速率的值,则设备在一秒内扫描的待扫描Keepalive表项的个数为扫描速率的值,且在下一秒继续扫描。
注意事项
# 配置设备每秒最多能够发送10个ARP请求报文。
[Sysname] arp scan keepalive send-rate 10
display arp scan keepalive entry命令用来显示ARP的Keepalive表项信息。
display arp scan keepalive entry [ interface interface-type interface-number ] [ count ]
interface interface-type interface-number:显示指定接口Keepalive表项信息。interface-type interface-number表示指定接口的类型和编号。不指定则显示所有接口类型。
count:指定该参数则只显示Keepalive表项数量。
<Sysname> display arp scan keepalive entry
Interface: XGE0/0/6
IPv4 address: 192.168.56.1        MAC address: 08-00-27-00-50-38
VLANID: 1                         SECVLANID: 1
Port interface: --                VPN instance: --
Scan status: 1                    Probe count: 10
Scan time: 08:01:01
表1-8 display arp scan keepalive entry 命令显示信息描述表
三层接口名称
IPv4 address
表项IPv4地址
MAC address
表项MAC地址
VLANID
Primary VLAN编号
SECVLANID
Secondary VLAN编号
Port interface
ARP报文的二层入接口
VPN instance
VPN实例
Scan status
扫描状态,“0”表示离线,“1”表示在线
Probe count
扫描计数
Scan time
Keepalive表项变为离线状态的时间
display arp scan keepalive statistics命令用来显示接口向离线状态的Keepalive表项发送的ARP请求报文个数。
display arp scan keepalive statistics [ slot slot-number [ cpu cpu-number ] ] [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口向离线状态的Keepalive表项发送的ARP请求报文的个数。interface-type 为指定的接口类型,interface-number为指定的接口编号。如果未指定本参数,则显示所有接口向离线状态的Keepalive表项发送的ARP请求报文的个数。
slot slot-number:显示指定单板向离线状态的Keepalive表项发送的ARP请求报文的个数。slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板向离线状态的Keepalive表项发送的ARP请求报文的个数。
通过本命令可以分别查看最近5秒、1分钟、5分钟接口向离线状态的Keepalive表项源MAC地址对应的终端发送的ARP请求报文的个数。如果接口向离线状态的Keepalive表项源MAC地址对应的终端发送的ARP请求报文的个数多,则代表处于离线状态的Keepalive表项较多或某些处于离线状态的Keepalive表项长时间没有恢复为在线状态,反之亦然。用户可以通过display arp scan keepalive entry命令查看处于离线状态的Keepalive表项的个数,从而对情况进行判断。如果是处于离线状态的Keepalive表项较多,可能是由于设置了过长的表项老化时间,也可能是网络中存在大量异常下线的情况,这时需要网络管理员检查配置及网络情况;如果是某些处于离线状态的Keepalive表项长时间没有恢复为在线状态,可能是由于ARP请求报文无法解决异常下线问题,这时需要网络管理员根据离线状态表项定位问题。
# 显示Slot1上接口向离线状态的Keepalive表项发送的ARP请求报文的个数。
<Sysname> display arp scan keepalive statistics slot 1
Scanning statistics for slot 1:
     Total ARP requests: 1000 packets
     Start time for statistics: 12:20:30
Interface                     5 secs   1 min    5 mins
Ten-GigabitEthernet0/0/6            123      200       230
Ten-GigabitEthernet0/0/7            0        0         0
Ten-GigabitEthernet0/0/8            0        0         0
Ten-GigabitEthernet0/0/9            0        0         0
Ten-GigabitEthernet0/0/10            0        0         0
Ten-GigabitEthernet0/0/11            0        0         0
表1-9 display arp scan keepalive statistics命令显示信息描述表
Total ARP requests
向离线状态的Keepalive表项发送的ARP请求报文的总数
设备开始对向离线状态的Keepalive表项发送的ARP请求报文的个数进行计数的时间
接口名
5 secs
接口最近5秒内向离线状态的Keepalive表项发送的ARP请求报文的个数
1 min
接口最近1分钟内向离线状态的Keepalive表项发送的ARP请求报文的个数
5 mins
接口最近5分钟内向离线状态的Keepalive表项发送的ARP请求报文的个数
·     reset arp scan keepalive statistics
reset arp scan keepalive statistics命令用来清除接口向离线状态的Keepalive表项发送的ARP请求报文的计数信息。
reset arp scan keepalive statistics [ slot slot-number ]
slot slot-number:表示清除指定单板向离线状态的Keepalive表项发送的ARP请求报文的计数信息。slot-number表示单板的槽位号。如果未指定本参数,则清除所有单板向离线状态的Keepalive表项发送的ARP请求报文的计数信息。
通过本命令可以重新统计接口向离线状态的Keepalive表项发送的ARP请求报文的计数信息。即执行display arp scan keepalive statistics命令显示的是执行本命令后接口向离线状态的Keepalive表项发送的ARP请求报文的个数,且开始计数的时间为执行本命令后设备第一次向离线状态的Keepalive表项发送的ARP请求报文的时间。
# 清除Slot1向离线状态的Keepalive表项发送的ARP请求报文的计数信息。
<Sysname> reset arp scan keepalive statistics slot 1
·     display arp scan keepalive statistics
1.10  ARP网关保护配置命令
arp filter source命令用来开启ARP网关保护功能,配置受保护的网关IP地址。
undo arp filter source命令用来关闭ARP网关保护功能,并删除已配置的受保护网关IP地址。
arp filter source ip-address
undo arp filter source ip-address
ARP网关保护功能处于关闭状态。
二层以太网接口视图
二层聚合接口视图
ip-address:受保护的网关IP地址。
每个接口最多支持配置8个受保护的网关IP地址。
不能在同一接口下同时配置命令arp filter source和arp filter binding。
# 在Ten-GigabitEthernet0/0/6下开启ARP网关保护功能,受保护的网关IP地址为1.1.1.1。
[Sysname-Ten-GigabitEthernet0/0/6] arp filter source 1.1.1.1
1.11  ARP过滤保护配置命令
arp filter binding命令用来开启ARP过滤保护功能并配置ARP过滤保护表项。
undo arp filter binding命令用来删除ARP过滤保护表项。
undo arp filter binding ip-address
ARP过滤保护功能处于关闭状态。
二层以太网接口视图
二层聚合接口视图
ip-address:允许通过的ARP报文的源IP地址。
mac-address:允许通过的ARP报文的源MAC地址。
ARP过滤保护表项可以限制只有特定源IP地址和源MAC地址的ARP报文才允许通过。
每个接口最多支持配置8组允许通过的ARP报文的源IP地址和源MAC地址。
# 在Ten-GigabitEthernet0/0/6下开启ARP过滤保护功能,允许源IP地址为1.1.1.1、源MAC地址为0e10-0213-1023的ARP报文通过。
[Sysname-Ten-GigabitEthernet0/0/6] arp filter binding 1.1.1.1 0e10-0213-1023
arp sender-ip-range命令用来配置可接受的ARP报文中sender IP的地址范围。
undo arp sender-ip-range命令用来恢复缺省情况。
arp sender-ip-range start-ip-address end-ip-address
未限制ARP报文中sender IP的地址范围。
VLAN视图
start-ip-address:起始IP地址。
end-ip-address:终止IP地址,必须大于等于起始IP地址。
如果设备收到的VLAN内ARP报文的sender IP不在指定地址范围内,则将该ARP报文丢弃。
多次执行本命令,最后一次执行的命令生效。
# 在VLAN 2内配置可接受的ARP报文中sender IP的地址范围为1.1.1.1~1.1.1.20。
[Sysname] vlan 2
[Sysname–vlan2] arp sender-ip-range 1.1.1.1 1.1.1.20
