09-三层技术-IP路由命令参考
04-OSPF命令
本章节下载: 04-OSPF命令  (1.30 MB)
04-OSPF命令
OSPF
1.1 OSPF配置命令
1.1.1 abr-summary
1.1.2 area
1.1.3 asbr-summary
1.1.4 authentication-mode
1.1.5 bandwidth-reference
1.1.6 capability default-exclusion
1.1.7 database-filter peer
1.1.8 default
1.1.9 default-cost
1.1.10 default-route-advertise
1.1.11 description
1.1.12 discard-route
1.1.13 display ospf
1.1.14 display ospf abr-asbr
1.1.15 display ospf abr-summary
1.1.16 display ospf asbr-summary
1.1.17 display ospf event-log
1.1.18 display ospf event-log hello
1.1.19 display ospf fast-reroute lfa-candidate
1.1.20 display ospf global-statistics
1.1.21 display ospf graceful-restart
1.1.22 display ospf hostname-table
1.1.23 display ospf interface
1.1.24 display ospf interface hello
1.1.25 display ospf lsdb
1.1.26 display ospf nexthop
1.1.27 display ospf non-stop-routing status
1.1.28 display ospf peer
1.1.29 display ospf peer statistics
1.1.30 display ospf request-queue
1.1.31 display ospf retrans-queue
1.1.32 display ospf routing
1.1.33 display ospf spf-tree
1.1.34 display ospf statistics
1.1.35 display ospf troubleshooting
1.1.36 display ospf vlink
1.1.37 display router id
1.1.38 distribute bgp-ls
1.1.39 dscp
1.1.40 enable link-local-signaling
1.1.41 enable out-of-band-resynchronization
1.1.42 event-log
1.1.43 fast-reroute
1.1.44 fast-reroute remote-lfa maximum-cost
1.1.45 fast-reroute remote-lfa prefix-list
1.1.46 fast-reroute remote-lfa tunnel ldp
1.1.47 fast-reroute tiebreaker
1.1.48 filter
1.1.49 filter-policy export
1.1.50 filter-policy import
1.1.51 graceful-restart
1.1.52 graceful-restart helper enable
1.1.53 graceful-restart helper strict-lsa-checking
1.1.54 graceful-restart interval
1.1.55 host-advertise
1.1.56 hostname
1.1.57 import-route
1.1.58 isolate enable
1.1.59 ispf enable
1.1.60 log-peer-change
1.1.61 lsa-arrival-interval
1.1.62 lsa-arrival-interval suppress-flapping
1.1.63 lsa-generation-interval
1.1.64 lsa-generation-interval suppress-flapping
1.1.65 lsdb-overflow-interval
1.1.66 lsdb-overflow-limit
1.1.67 maxage-lsa route-calculate-delay
1.1.68 maximum load-balancing
1.1.69 network
1.1.70 non-stop-routing
1.1.71 nssa
1.1.72 opaque-capability enable
1.1.73 ospf
1.1.74 ospf area
1.1.75 ospf authentication-mode
1.1.76 ospf bfd enable
1.1.77 ospf cost
1.1.78 ospf database-filter
1.1.79 ospf dr-priority
1.1.80 ospf fast-reroute lfa-backup
1.1.81 ospf fast-reroute remote-lfa disable
1.1.82 ospf link-quality adjust-cost
1.1.83 ospf lsu-flood-control
1.1.84 ospf mib-binding
1.1.85 ospf mtu-enable
1.1.86 ospf network-type
1.1.87 ospf packet-size
1.1.88 ospf peer hold-max-cost duration
1.1.89 ospf peer sub-address enable
1.1.90 ospf prefix-suppression
1.1.91 ospf primary-path-detect bfd
1.1.92 ospf timer dead
1.1.93 ospf timer hello
1.1.94 ospf timer poll
1.1.95 ospf timer retransmit
1.1.96 ospf track adjust-cost
1.1.97 ospf trans-delay
1.1.98 ospf troubleshooting max-number
1.1.99 ospf ttl-security
1.1.100 peer
1.1.101 pic
1.1.102 preference
1.1.103 prefix-priority
1.1.104 prefix-suppression
1.1.105 reset ospf event-log
1.1.106 reset ospf event-log hello
1.1.107 reset ospf process
1.1.108 reset ospf redistribution
1.1.109 reset ospf statistics
1.1.110 reset ospf troubleshooting
1.1.111 rfc1583 compatible
1.1.112 router id
1.1.113 shutdown process
1.1.114 silent-interface
1.1.115 snmp trap rate-limit
1.1.116 snmp-agent trap enable ospf
1.1.117 spf-schedule-interval
1.1.118 stub
1.1.119 stub-router
1.1.120 transmit-pacing
1.1.121 ttl-security
1.1.122 vlink-peer
OSPF
1.1  OSPF配置命令
1.1.1  abr-summary
abr-summary命令用来配置ABR路由聚合。
undo abr-summary命令用来取消ABR对指定网段的路由聚合。
abr-summary ip-address { mask-length | mask } [ advertise | not-advertise ] [ cost cost-value ]
undo abr-summary ip-address { mask-length | mask }
ABR不对路由进行聚合。
OSPF区域视图
ip-address:聚合路由的目的IP地址。
mask-length:聚合路由的网络掩码长度,取值范围为1~32。
mask:聚合路由的网络掩码,点分十进制形式。
advertise | not-advertise:是否发布这条聚合路由。缺省时发布聚合路由。
cost cost-value:聚合路由的开销值,取值范围为1~16777215,缺省值为所有被聚合的路由中最大的开销值。
本命令只适用于区域边界路由器(ABR),用来对某一个区域内的路由信息进行聚合。对于属于该聚合网段范围的路由,ABR向其它区域只发送一条聚合后的路由。一个区域可配置多条聚合网段,这样OSPF可对多个网段进行聚合。
当配置了undo abr-summary命令后,原来被聚合的路由又重新被发布。
# 将OSPF区域1中两个网段36.42.10.0/24和36.42.110.0/24的路由聚合成一条聚合路由36.42.0.0/16向其它区域发布。
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
1.1.2  area
area命令用来创建OSPF区域,并进入OSPF区域视图。
undo area命令用来删除指定的OSPF区域。
area area-id
undo area area-id
不存在OSPF区域。
OSPF视图
area-id:区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。
# 创建OSPF区域0并进入OSPF区域视图。
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0]
1.1.3  asbr-summary
asbr-summary命令用来配置ASBR路由聚合。
undo asbr-summary命令用来取消ASBR对指定网段的路由聚合。
asbr-summary ip-address { mask-length | mask } [ cost cost-value | not-advertise | nssa-only | tag tag ] *
undo asbr-summary ip-address { mask-length | mask }
ASBR不对路由进行聚合。
OSPF视图
mask:聚合路由的网络掩码,点分十进制格式。
cost cost-value:聚合路由的开销值,取值范围为1~16777214。如果未指定本参数,cost-value取所有被聚合的路由中最大的开销值作为聚合路由的开销值;如果是Type-7 LSA转化成的Type-5 LSA描述的路由匹配聚合、且是Type2外部路由,则cost-value取所有被聚合的路由中最大的开销值加1作为聚合路由的开销值。
not-advertise:不通告聚合路由。如果未指定本参数,将通告聚合路由。
nssa-only:设置Type-7 LSA的P比特位为不置位,即在对端路由器上不能转为Type-5 LSA。缺省时,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
tag tag:聚合路由的标识,可以通过路由策略控制聚合路由的发布,取值范围为0~4294967295,缺省值为1。
如果本地路由器是ASBR,对引入的聚合地址范围内的Type-5 LSA描述的路由进行聚合;当配置了NSSA区域时,对引入的聚合地址范围内的Type-7 LSA描述的路由进行聚合。
如果本地路由器同时是ASBR和ABR,并且是NSSA区域的转换路由器,将对由Type-7 LSA转化成的Type-5 LSA进行聚合处理;如果不是NSSA区域的转换路由器,则不进行聚合处理。
配置asbr-summary命令后,对处于聚合地址范围内的外部路由,本地路由器只向邻居路由器发布一条聚合后的路由;配置undo asbr-summary命令后,原来被聚合的外部路由将重新被发布。
# 配置OSPF对引入的路由进行聚合,聚合路由的标识为2,开销值为100。
[Sysname] ip route-static 10.2.1.0 24 null 0
[Sysname] ip route-static 10.2.2.0 24 null 0
[Sysname] ospf 100
[Sysname-ospf-100] import-route static
[Sysname-ospf-100] asbr-summary 10.2.0.0 255.255.0.0 tag 2 cost 100
authentication-mode命令用来配置OSPF区域所使用的验证模式。
undo authentication-mode命令用来取消OSPF区域所使用的验证模式。
Cryptographic验证模式:
authentication-mode { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 } [ key-id { cipher | plain } string ]
undo authentication-mode [ { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 } key-id ]
简单验证模式:
authentication-mode simple [ { cipher | plain } string ]
keychain验证模式:
authentication-mode keychain keychain-name
未配置区域验证模式。
OSPF区域视图
hmac-md5:HMAC-MD5验证模式。
hmac-sha-256:HMAC-SHA-256验证模式。
hmac-sm3:HMAC-SM3验证模式。
md5:MD5验证模式。
simple:简单验证模式。
key-id:验证字标识符,取值范围为0~255。如果未指定本参数,将使用空字符串对OSPF报文进行验证。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。简单验证模式下,明文密钥为1~8个字符的字符串;密文密钥为33~41个字符的字符串。HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式下,明文密钥为1~255个字符的字符串;HMAC-MD5/MD5验证模式下,密文密钥为33~53个字符的字符串;HMAC-SHA-256/HMAC-SM3验证模式下,密文密钥为33~373个字符的字符串。
keychain:使用keychain验证方式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
使用Cryptographic验证模式(包括HMAC-MD5、HMAC-SHA-256、HMAC-SM3和MD5验证模式)、简单验证模式或keychain验证模式时,一个区域中所有设备的验证模式必须一致,如果设置了密钥,需要保证密钥的一致性。
同一区域下重复执行本命令指定不同的验证模式时,新的验证模式会覆盖旧的验证模式。
使用Cryptographic验证模式时,同一区域下可配置多条HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证命令,但key-id是唯一的,同一key-id只能配置一个验证字。
修改OSPF区域的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字的步骤如下:
·     首先在该区域配置新的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字;此时若邻居设备尚未配置新的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字,便会触发HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证平滑迁移过程。在这个过程中,OSPF会发送分别携带各个HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字的多份报文,使得已配置新验证字的邻居设备、和尚未配置新验证字的邻居设备都能通过验证,保持邻居关系。
·     然后在各个邻居设备上也都配置相同的新HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字;当本设备上收到所有邻居的携带新验证字的报文后,便会退出HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证平滑迁移过程。
·     最后在本设备和所有邻居上都删除旧的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字;建议区域下不要保留多个HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字,每次HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字修改完毕后,应当及时删除旧的验证字,这样可以防止与持有旧验证字的系统继续通信、减少被攻击的可能,还可以减少验证迁移过程对系统、带宽的消耗。
简单验证模式下,如果未指定cipher和plain参数,对OSPF报文进行验证时,不使用密钥。
在OSPF区域使用keychain验证方式时,报文的收、发过程如下:
·     OSPF在发送报文前,会先从keychain获取当前的有效发送key,然后发送报文。如果当前不存在有效发送key,则不会发送报文。
·     OSPF在收到报文后,会根据报文携带的key的标识符从keychain中获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验,校验成功后再对报文进行下一步处理。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
对于keychain认证算法和key的标识符的范围,OSPF的支持情况如下:
·     OSPF支持MD5、SM3、HMAC-MD5、HMAC-SHA-256和HMAC-SM3认证算法。
·     OSPF仅支持标识符取值范围为0~255的key。
关于keychain命令的详细介绍,请参见“安全命令参考”中的“keychain”。
# 配置OSPF区域0使用MD5明文验证模式,验证字标识符为15,验证密钥为abc。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode md5 15 plain abc
# 配置OSPF区域0使用名称为abc的keychain进行验证。
[Sysname] keychain abc mode absolute
[Sysname-keychain-abc] key 1
[Sysname-keychain-abc-key-1] authentication-algorithm md5
[Sysname-keychain-abc-key-1] key-string plain hello12345
[Sysname-keychain-abc-key-1] send-lifetime utc 10:00:00 2023/03/02 to 11:00:00 2023/03/02
[Sysname-keychain-abc-key-1] accept-lifetime utc 10:00:00 2023/03/02 to 11:00:00 2023/03/02
[Sysname-keychain-abc-key-1] quit
[Sysname-keychain-abc] quit
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode keychain abc
·     ospf authentication-mode
bandwidth-reference命令用来配置计算链路开销时所依据的带宽参考值。
bandwidth-reference value
计算链路开销时所依据的带宽参考值为100Mbps。
OSPF视图
value:计算链路开销时所依据的带宽参考值,取值范围为1~4294967,单位为Mbps。
如果没有配置链路的开销值,OSPF根据链路带宽来计算开销值,接口开销=带宽参考值÷接口期望带宽(接口期望带宽通过命令bandwidth进行配置)。当计算出来的开销值大于65535时,开销取最大值65535;当计算出来的开销值小于1时,开销取最小值1。
# 配置链路的带宽参考值为1000Mbps。
[Sysname] ospf 100
[Sysname-ospf-100] bandwidth-reference 1000
·     bandwidth(接口管理命令参考/接口公共命令)
·     ospf cost
capability default-exclusion命令用来配置允许将区域下的接口从标准拓扑中分离。
undo capability default-exclusion命令用来恢复缺省情况。
OSPF区域下的接口自动加入标准拓扑base。
OSPF区域视图
缺省情况下,OSPF区域下的接口会自动加入标准拓扑。本命令允许区域下的接口从标准拓扑中分离出来。
需要在本设备和邻居设备上同时配置本命令,否则会影响邻居关系的建立。
# 允许OSPF区域1下的接口从标准拓扑中分离。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] capability default-exclusion
database-filter peer命令用来对发送给指定邻居的LSA进行过滤。
undo database-filter peer命令用来恢复缺省情况。
database-filter peer ip-address { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
undo database-filter peer ip-address
不对发送给指定邻居的LSA进行过滤。
OSPF视图
ip-address:接口的网络类型为P2MP的邻居的IP地址。
all:对发送给接口的网络类型为P2MP的邻居的所有LSA进行过滤(除了Grace LSA)。
ase:对发送给接口的网络类型为P2MP的邻居的Type-5 LSA进行过滤。
nssa:对发送给接口的网络类型为P2MP的邻居的Type-7 LSA进行过滤。
summary:对发送给接口的网络类型为P2MP的邻居的Type-3 LSA进行过滤。
acl ipv4-acl-number:指定的基本或高级IPv4 ACL编号,取值范围为2000~3999。
当两台路由器之间存在多条P2MP链路时,路由器上会存在多个接口的网络类型为P2MP的OSPF邻居。不愿让某个指定邻居收到的LSA,通过该功能可在本地将其过滤掉。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示OSPF不会对发送给指定邻居的LSA进行过滤。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则会拒绝所有发送给指定邻居的LSA通过过滤。
当配置的是高级ACL(3000~3999)时,其使用规则如下:
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard来过滤携带指定链路状态ID的LSA。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard来过滤携带指定链路状态ID和掩码的LSA。
其中,source用来过滤LSA的链路状态ID,destination用来过滤LSA的掩码。
如果在配置该命令前邻居路由器就已经收到了将要进行过滤的LSA,那么配置该命令后,这些LSA仍存在于邻居路由器的LSDB中。
# 配置对发送给接口的网络类型为P2MP的邻居的所有LSA进行过滤。
[Sysname] ospf 1
[Sysname-ospf-1] database-filter peer 121.20.20.121 all
# 配置编号为3000的高级ACL对发送给邻居121.20.20.121的Type-3 LSA进行过滤。
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000]rule 10 deny ip source 121.20.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 permit ip
[Sysname] ospf 1
[Sysname-ospf-1] database-filter peer 121.20.20.121 summary acl 3000
·     ospf database-filter
1.1.8  default
default命令用来配置引入外部路由时的缺省参数,包括OSPF引入外部路由的开销、类型和标记。
undo default命令用来取消引入外部路由时的缺省参数的配置。
default { cost cost-value | tag tag | type type } *
undo default { cost | tag | type } *
OSPF引入的外部路由的度量值为1,引入的外部路由的标记为1,引入的外部路由类型为2。
OSPF视图
cost cost-value:OSPF引入的外部路由的缺省度量值,cost-value的取值范围为0~16777214。
tag tag:外部路由的标记,tag的取值范围为0~4294967295。
type type:外部路由类型,type的取值范围为1~2。
# 配置外部路由开销、标记和类型的缺省值分别为10、100和2。
[Sysname] ospf 100
[Sysname-ospf-100] default cost 10 tag 100 type 2
·     import-route
1.1.9  default-cost
default-cost命令用来配置发送到Stub区域或NSSA区域的缺省路由的开销。
undo default-cost命令用来恢复缺省情况。
default-cost cost-value
undo default-cost
发送到Stub区域或NSSA区域的缺省路由的开销为1。
OSPF区域视图
cost-value:发送到Stub区域或NSSA区域的缺省路由的开销值,取值范围为0~16777214。
该命令只有在Stub区域的ABR或NSSA区域的ABR/ASBR上配置才能生效。
# 将区域1设置成Stub区域,配置发送到该Stub区域的缺省路由的开销为20。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
[Sysname-ospf-100-area-0.0.0.1] default-cost 20
·     nssa
·     stub
default-route-advertise命令用来将缺省路由引入到OSPF路由区域。
default-route-advertise [ [ always | permit-calculate-other ] | cost cost-value | route-policy route-policy-name | type type ] *
default-route-advertise [ summary cost cost-value ]
未引入缺省路由。
OSPF视图
always:如果当前路由器的路由表中没有缺省路由,使用此参数可产生一个描述缺省路由的Type-5 LSA发布出去。如果没有指定该关键字,仅当本地路由器的路由表中存在缺省路由时,才可以产生一个描述缺省路由的Type-5 LSA发布出去。
permit-calculate-other:当路由器产生并发布了一个描述缺省路由的Type-5 LSA时,指定此参数的路由器仍然会计算来自于其他路由器的缺省路由,未指定此参数的路由器不再计算来自其他路由器的缺省路由。当路由器没有产生一个描述缺省路由的Type-5 LSA时,无论是否指定此参数,路由器都会计算来自其他路由器的缺省路由。
cost cost-value:该缺省路由的度量值,取值范围为0~16777214,如果没有指定,缺省路由的度量值将取default cost命令配置的值。
route-policy route-policy-name:路由策略名,为1~63个字符的字符串,区分大小写。只有当前路由器的路由表中存在缺省路由,并且有路由匹配route-policy-name指定的路由策略,才可以产生一个描述缺省路由的Type-5 LSA发布出去,指定的路由策略会影响Type-5 LSA中的值。如果同时指定always参数,不论当前路由器的路由表中是否有缺省路由,只要有路由匹配指定的路由策略,就将产生一个描述缺省路由的Type-5 LSA发布出去,指定的路由策略会影响Type-5 LSA中的值。
type type:该Type-5 LSA的类型,取值范围为1~2,如果没有指定,Type-5 LSA的缺省类型将取default type命令配置的值。
summary:发布指定缺省路由的Type-3 LSA。在选用该参数时,必须首先使能VPN,否则路由不能发布。
使用import-route命令不能引入缺省路由,如果要引入缺省路由,必须使用该命令。当本地路由器的路由表中没有缺省路由时,要产生一个描述缺省路由的Type-5 LSA应使用always关键字。
default-route-advertise summary cost命令仅在VPN中应用,以Type-3 LSA引入缺省路由,PE路由器会将引入的缺省路由发布给CE路由器。
# 不管本地路由器的路由表中是否存在缺省路由,将产生的缺省路由引入到OSPF路由区域(本地路由器没有缺省路由)。
[Sysname] ospf 100
[Sysname-ospf-100] default-route-advertise always
·     default
·     import-route
1.1.11  description
description命令用来配置OSPF进程/OSPF区域的描述信息。
undo description命令用来恢复缺省情况。
未配置OSPF进程和区域的描述信息。
OSPF视图
OSPF区域视图
text:在OSPF视图下,该参数用来描述OSPF进程;在OSPF区域视图下,该参数用来描述OSPF区域,为1~80个字符的字符串,区分大小写。
本命令仅仅用于标识某OSPF进程/OSPF区域,并无特别的意义和用途。
# 配置OSPF进程100的描述信息为“abc”。
[Sysname] ospf 100
[Sysname-ospf-100] description abc
# 配置OSPF区域0的描述信息为“bone area”。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] description bone area
discard-route命令用来配置NULL0路由以及NULL0路由的优先级。
undo discard-route命令用来将NULL0路由的优先级恢复为255。
discard-route { external { preference | suppression } | internal { preference | suppression } } *
undo discard-route [ external | internal ] *
产生引入聚合NULL0路由和区域间聚合NULL0路由,且NULL0路由优先级为255。
OSPF视图
external:引入聚合NULL0路由。
preference:引入聚合NULL0路由的优先级,取值范围为1~255。
suppression:抑制产生引入聚合NULL0路由。
internal:区域间聚合NULL0路由。
preference:区域间聚合NULL0路由的优先级,取值范围为1~255。
suppression:抑制产生区域间聚合NULL0路由。
# 配置引入聚合路由的NULL0路由的优先级为100,区域间聚合NULL0路由的优先级为200。
[Sysname] ospf 100
[Sysname-ospf-100] discard-route external 100 internal 200
1.1.13  display ospf
display ospf命令用来显示OSPF的进程信息。
display ospf [ process-id ] [ verbose ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF的进程信息。
verbose:显示OSPF进程的详细信息。如果未指定本参数,将显示OSPF进程的概要信息。
# 显示OSPF的详细信息。
<Sysname> display ospf verbose
          OSPF Process 1 with Router ID 192.168.1.2
                  OSPF Protocol Information
 RouterID: 192.168.1.2      Router type:  NSSA
 Route tag: 0
 Ext-community type: Domain ID 0x105, Route Type 0x8000, Router ID 0x8001
 Domain ID: 0.0.0.0:23
 Opaque capable
 Isolation: Disabled
 Originating router-LSAs with maximum metric
    Condition: On startup while BGP is converging, State: Inactive
    Advertise stub links with maximum metric in router-LSAs
    Advertise summary-LSAs with metric 16711680
    Advertise external-LSAs with metric 16711680
 ISPF is enabled
 SPF-schedule-interval: 50 (in milliseconds)
 LSA generation interval: 5
 LSA arrival interval: 1000
 Route preference: 10
 ASE route preference: 150
 SPF computation count: 22
 RFC 1583 compatible
 Fast-reroute: lfa
 Fast-reroute: Remote-lfa Disabled
   Maximum-cost: 4294967295
 Node-Protecing Preference: 40
 Lowest-cost Preference: 20
 SRLG Preference: 10
 Microloop-avoidance: Enable
 Microloop-avoidance RIB-update-delay: 5000 ms
 Graceful restart interval: 120
 SNMP trap rate limit interval: 2  Count: 300
 This process is currently bound to MIB
 Area count: 1   NSSA area count: 1
 Normal areas with up interfaces: 0
 NSSA areas with up interfaces: 1
 Up interfaces: 1
 ExChange/Loading neighbors: 0
 Full neighbors:3
 Area0 full neighbors: 1
 Calculation trigger type: Full
 Current calculation type: SPF calculation
 Current calculation phase: Calculation area topology
 Process reset state: N/A
 Current reset type: N/A
 Next reset type: N/A
 Reset prepare message replied: -/-/-/-
 Reset process message replied: -/-/-/-
 Reset phase of module:
   M-N/A, P-N/A, L-N/A, C-N/A, R-N/A
 MPLS segment routing: Disabled
   Segment routing adjacency   : Disabled
   Configured SRGB             : 16000  16999
   Effective SRGB              : 16000  24000
   Segment routing local block : 15000  15999
   Segment routing tunnel count: 0
 Area: 0.0.0.1          (MPLS TE  not enabled)
 Authentication type: None    Area flag: NSSA
 SPF scheduled count: 5
 Up interfaces: 1
 Interface: 192.168.1.2 (Ten-GigabitEthernet0/0/6)
 Cost: 1       State: DR        Type: Broadcast    MTU: 1500
 Cost source: Default
 Priority: 1
 Designated router: 192.168.1.2
 Backup designated router: 192.168.1.1
 Timers: Hello 10 , Dead 40 , Poll  40 , Retransmit 5 , Transmit Delay 1
 FRR backup: Enabled
 FRR TI-LFA: Enabled
 FRR remote-lfa: Enabled
 Enabled by network configuration
 Packet size: 1000
表1-1 display ospf verbose命令显示信息描述表
OSPF进程号以及OSPF Router ID
RouterID
本路由器的Router ID
Router type
路由器类型,取值为:
·     ABR:表示区域边界路由器
·     ASBR:表示自治系统边界路由器
·     NSSA:表示支持NSSA区域
·     为空:表示非上面三种情况
Process state
OSPF进程的状态,显示为Admin-down表示通过shutdown process命令关闭了OSPF进程。如果未通过shutdown process命令关闭OSPF进程,则不显示该字段
Route tag
与外部路由相关联的标记
当前进程不支持多VPN实例
Ext-community type
OSPF扩展团体属性类型编码。其中:
·     Domain ID:表示domain ID属性编码
·     Route Type:表示route type属性编码
·     Router ID:表示router ID属性编码
Domain ID
OSPF域标识符(主标识符)
Opaque capable
使能OSPF的Opaque LSA发布接收能力
Isolation
是否开启Isolate功能:
·     Disabled:表示关闭
·     Enabled:表示开启
Router LSA中除Stublink外使用最大开销值发布
Condition
Stub路由器的状态:
·     Always:表示始终生效
·     On startup while BGP is converging:表示BGP收敛前生效
·     On startup while BGP is converging for XXX seconds:表示BGP收敛超时时间
·     On startup for XXX seconds:表示重启后生效时间
Stub路由器是否生效:
·     Active表示生效
·     Inactive表示不生效
Router LSA使用最大开销值发布
Summary LSA发布使用的开销值
外部LSA发布使用的开销值
Originating LSAs with metric xxx controlled by RBM
当前设备为HA中的备设备,HA通知OSPF调整开销值,有以下两种情况:
·     Originating LSAs with metric +n controlled by RBM:OSPF产生LSA时,需要在原始开销值的基础上叠加n
·     Originating LSAs with metric n controlled by RBM:OSPF产生LSA时,其开销值为n
仅在HA调整了OSPF的开销值时显示
有关HA的详细介绍,请参见“可靠性配置指导”中的“高可靠性”
ISPF is enabled
使能增量SPF计算功能
进行SPF计算的时间间隔,in milliseconds表示以固定的时间间隔进行SPF计算,单位为毫秒
LSA生成时间间隔
LSA重复到达的最小时间间隔
Transmit pacing
接口发送LSU报文的速率,其中:
·     Interval表示接口发送LSU报文的时间间隔
·     Count表示接口一次发送LSU报文的最大个数
引入外部路由的缺省参数值,其中:
·     Metric:表示度量值
·     Tag:表示路由标记
·     Type:表示路由类型
Route preference
OSPF协议对自治系统内部路由的优先级
OSPF协议对自治系统外部路由的优先级
OSPF进程的路由计算总数
RFC1583 compatible
兼容RFC 1583路由选择优先规则
Fast-reroute
快速重路由类型:
·     lfa:开启LFA功能
·     Remote-LFA Disabled:未开启Remote LFA功能
·     Remote-LFA Enabled:开启Remote LFA功能
·     TI-LFA:开启TI-LFA功能
Maximum-cost
Remote LFA到达指定PQ节点最大开销值
Node-Protecting Preference
节点保护优选方案的优先级
最小开销路径优选方案的优先级
SRLG preference
共享风险组保护优先级
Microloop-avoidance
是否开启正切防微环功能:
·     Disabled:正切防微环功能处于关闭状态
·     Enabled:正切防微环功能处于开启状态
GR重启间隔时间
TRAP发送间隔
Count
TRAP发送个数
当前进程绑定MIB
Area count
当前进程中的区域数
NSSA area count
当前进程中的NSSA区域数
有Up接口的外部能力区域个数
有Up接口的NSSA区域个数
Up interfaces
处于Up状态的接口计数
处于ExChange/Loading状态的邻居数
Full neighbors
处于Full状态的邻居数
骨干区域中处于Full状态的邻居数
触发路由计算的类型,具体如下:
·     Full:触发全部路由计算
·     Area topology change:区域拓扑改变触发路由计算
·     Intra router change:增量的区域内路由器路由变化
·     ASBR change:增量的ASBR路由变化
·     7to5 translator:7转5角色变化
·     Full IP prefix:触发全部IP前缀计算
·     Full intra AS:触发全部AS内部前缀计算
·     Inc intra AS:触发增量AS内部前缀计算
·     Full inter AS:触发全部AS外部前缀计算
·     Inc inter AS:触发增量AS外部前缀计算
·     N/A:未触发计算
当前路由计算的类型,具体如下:
·     SPF calculation:进行区域SPF计算
·     Intra router calculation:区域内路由器路由计算
·     ASBR calculation:区域间ASBR路由计算
·     Inc intra router:增量区域内路由器路由计算
·     Inc ASBR calculation:增量区域间ASBR路由计算
·     7to5 translator:7转5角色路由计算
·     Full intra AS:进行全部AS内部前缀计算
·     Inc intra AS:进行增量AS内部前缀计算
·     Full inter AS:进行全部AS外部前缀计算
·     Inc inter AS:进行增量AS外部前缀计算
·     Forward address:转发地址计算
·     N/A:未触发计算
当前路由计算调度运行到的阶段,具体如下:
·     Calculation area topology:计算区域拓扑
·     Calculation router:计算路由器路由
·     Calculation intra AS:计算AS内部路由
·     7to5 translator:计算7转5角色路由
·     Forward address:计算转发地址
·     Calculation inter AS:计算AS外部路由
·     Calculation end:计算收尾阶段
·     N/A:未触发计算
Process reset state
进程重启状态,具体如下:
·     N/A:进程未重启
·     Under reset:进程重启过程中
·     Under RIB smooth:进程正在同步RIB路由
Current reset type
当前进程重启类型,具体如下:
·     N/A:进程未重启
·     Normal:普通重启
·     GR quit:GR异常退出进行普通重启
·     Delete:删除OSPF进程
·     VPN delete:删除VPN
Next reset type
即将调度进程重启类型,具体如下:
·     N/A:进程未重启
·     Normal:普通重启
·     Delete:删除OSPF进程
·     VPN delete:删除VPN
响应准备重启消息的模块,具体如下:
·     P:表示邻居维护模块
·     L:表示LSDB同步模块
·     C:表示路由计算模块
·     R:表示路由引入模块
响应进程重启消息的模块,具体如下:
·     P:表示邻居维护模块
·     L:表示LSDB同步模块
·     C:表示路由计算模块
·     R:表示路由引入模块
各模块所处重启阶段。其中M代表主控制模块,其阶段有:
·     N/A:未重启
·     Delete area:删除区域
·     Delete process:删除进程
P代表邻居维护模块,其阶段有:
·     N/A:未重启
·     Delete neighbor:删除邻居
·     Delete interface:删除接口
·     Delete vlink:删除虚连接
·     Delete shamlink:删除伪连接
L代表LSDB同步模块,其阶段有:
·     N/A:未重启
·     Stop timer:停止计时器
·     Delete ASE:删除所有ASE LSA
·     Delete ASE maps:删除ASE LSA的map
·     Clear process data:清除进程数据
·     Delete area LSA:删除区域相关LSA及其map
·     Delete area interface:删除区域下接口
·     Delete process:删除进程相关资源
·     Restart:重启进程相关资源
C代表路由计算模块,其阶段有:
·     N/A:未重启
·     Delete topology:删除区域拓扑
·     Delete router:删除路由器路由
·     Delete intra AS:删除AS内部路由
·     Delete inter AS:删除AS外部路由
·     Delete forward address:删除转发地址列表
·     Delete advertise:删除发布源列表
R代表路由引入模块,其阶段有:
·     N/A:未重启
·     Delete ABR summary:删除ABR聚合路由
·     Delete ASBR summary:删除ASBR聚合路由
·     Delete import:删除引入路由
是否开启SR-MPLS功能:
·     Disabled:表示未开启
·     Enabled:表示开启
是否开启SR-MPLS邻居标签分配功能:
·     Disabled:表示未开启
·     Enabled:表示开启
Configured SRGB
OSPF进程下配置的SRGB的标签范围,仅在OSPF进程配置了SRGB时显示
Effective SRGB
当前生效的SRGB的标签范围
基于MPLS的SRLB的标签范围
SR隧道数目
Area
列举当前进程中各区域的信息。显示当前区域ID,IP地址格式
MPLS TE  not enabled
是否开启OSPF区域的MPLS TE能力
·     MPLS TE  not enabled:表示关闭
·     MPLS TE  enabled:表示开启
Authentication type
区域验证模式,取值为:
·     None:表示无验证
·     Simple:表示简单验证模式
·     Cryptographic:表示HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式
·     Keychain:表示keychain验证模式
Area flag
区域类型:
·     Normal:普通区域
·     Stub:Stub区域
·     StubNoSummary:完全Stub区域
·     NSSA:NSSA区域
·     NSSANoSummary:完全NSSA区域
Type-7 LSA转换为Type-5 LSA的转换者状态,取值为:
·     Enabled:表示通过命令指定Type-7 LSA转换为Type-5 LSA的转换者
·     Elected:表示通过选举指定Type-7 LSA转换为Type-5 LSA的转换者
·     Disabled:表示不是Type-7 LSA转换为Type-5 LSA的转换者
Type-7 LSA转换为Type-5 LSA转换稳定定时器超时时间间隔
SPF scheduled Count
OSPF区域的路由计算总数
区域内的接口信息
Cost
接口的开销值
接口状态
接口的网络类型
MTU
接口的MTU值
Cost source
接口当前的链路开销值来源,取值包括以下几种情况:
·     Default:缺省值
·     Manual:接口下配置的链路开销值
·     IGP_LDP:LDP IGP同步功能通告的链路开销值
·     Track:接口关联的Track项状态为Negative,调整接口的链路开销值
·     LOW:链路质量等级为LOW时接口开销的调整值
·     LinkUp:Hold-max-cost生效期间,向邻居通告的最大链路开销值
Priority
路由器优先级
Designated router
接口所属网段的DR
接口所属网段的BDR
Timers
OSPF定时器的值,其中:
·     Hello:表示接口发送Hello报文的时间间隔
·     Dead:表示邻居的失效时间
·     Poll:表示接口发送轮询Hello报文的时间间隔
·     Retransmit:表示定接口重传LSA时间间隔
Transmit Delay
接口对LSA的传输延迟时间
FRR backup
是否使能接口参与LFA(Loop Free Alternate)计算:
·     Enabled:使能
·     Disabled:关闭
FRR TI-LFA
是否使能接口参与TI-LFA(Topology IndependentLoop Free Alternate)计算:
·     Disabled:关闭
·     Enabled:开启
接口由网络配置使能到该区域
Simple authentication enabled
接口采用Simple验证模式
Keychain authentication: Enabled (xx), inherited
接口采用keychain验证模式,keychain名称为xx。inherited表示接口继承的是其所属区域下配置的keychain验证模式
No authentication is required
接口采用None验证模式,该模式下接口不会继承其所属区域下配置的验证模式
Cryptographic authentication: Enabled, inherited
接口采用HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式。inherited表示接口继承的是其所属区域下配置的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式
The last key is xx
最新的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证密钥为xx
The rollover is in progress, xx neighbor(s) left
正在进行HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证平滑迁移,尚未完成HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证平滑迁移的邻居个数为xx
Packet size
接口下配置的发送OSPF报文的最大长度
Prefix-SID type
表示前缀SID的类型:
·     Absolute:前缀SID绝对值
·     Index:前缀SID相对值
Value
前缀SID的取值
Process ID
配置前缀SID时实际指定的进程号
Prefix-SID validity
配置的Prefix SID是否为有效值:
·     Invalid:表示无效值,即前缀SID的值不在SRGB范围内或Loopback接口上使能的OSPF进程和配置前缀SID时实际指定的进程号不一致
·     Valid:表示有效值
display ospf abr-asbr命令用来显示到OSPF的区域边界路由器和自治系统边界路由器的路由信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程下到区域边界路由器和自治系统边界路由器的路由信息。
如果在Stub区域的路由器上执行此命令,不显示有关ASBR的信息。
# 显示到OSPF的区域边界路由器和自治系统边界路由器的路由概要信息。
<Sysname> display ospf abr-asbr
          OSPF Process 1 with Router ID 192.168.1.112
                  Routing Table to ABR and ASBR
                Topology base (MTID 0)
 Type    Destination     Area            Cost     Nexthop         RtType
 Inter   3.3.3.3         0.0.0.0         3124     10.1.1.2        ASBR
 Intra   2.2.2.2         0.0.0.0         1562     10.1.1.2        ABR
# 显示到OSPF的区域边界路由器和自治系统边界路由器的路由详细信息。
<Sysname> display ospf abr-asbr verbose
          OSPF Process 10 with Router ID 101.1.1.11
 Destination: 1.1.1.1             RtType     : ASBR
 Area       : 0.0.0.1             Type       : Intra
 Nexthop    : 150.0.1.12          BkNexthop  : 0.0.0.0
 Interface  : XGE0/0/6            BkInterface: N/A
 Cost       : 1000
 Remote-LFA Info:
    PQPrefix: 5.5.5.5                PQAdvID : 5.5.5.5
     LsIndex: 2
  LabelStack: {2301}
 TI-LFA backup info:
 PNodePrefix: 5.5.5.5             QNodeAdvID : 5.5.5.5
 BkInterface: XGE0/0/6            BkNexthop  : 1.4.0.4
     LsIndex: 5
  LabelStack: {16005}
表1-2 display ospf abr-asbr命令显示信息描述表
到ABR或ASBR的路由类型,取值为:
·     Intra表示区域内路由
·     Inter表示区域间路由
Topology
拓扑名称,显示为base表示标准拓扑,显示为其他表示子拓扑
MTID
拓扑ID,0表示标准拓扑,其他数值表示子拓扑
Destination
ABR或ASBR的路由器ID
Area
下一跳地址所在的区域ID
Cost
从本路由器到达ABR或ASBR的开销
MALsIndex
SR防微环标签栈索引
MALabelStack
SR防微环标签栈,从栈顶标签到栈底标签依次排列
Nexthop
下一跳地址
BkNexthop
备份下一跳地址
RtType
路由器类型,包括ABR和ASBR
路由出接口
BkInterface
路由备份出接口
Remote-LFA back Info
Remote LFA备份信息
PQPrefix
PQ节点前缀
PQAdvID
PQ节点通告路由器ID
TI-LFA backup Info
TI-LFA备份信息
PNodePrefix
P节点前缀
QNodeAdvID
Q节点通告路由器ID
LsIndex
标签索引
LabelStack
标签栈
display ospf abr-summary命令用来显示OSPF的ABR聚合信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的ABR聚合信息。
area area-id:显示指定区域的ABR聚合相关信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。如果未指定本参数,将显示所有区域的信息。
ip-address:指定的聚合路由的目的IP地址。
mask-length:网络掩码长度,取值范围为1~32。
mask:网络掩码,点分十进制格式。
verbose:显示ABR聚合的详细信息。如果未指定本参数,将显示ABR聚合的概要信息。
如果未指定IP地址和掩码,将显示所有的ABR聚合信息。
# 显示OSPF的ABR聚合信息。
<Sysname> display ospf abr-summary
                  ABR Summary Addresses
                         Area: 0.0.0.1
 Total summary address count: 1
 Net             Mask            Status        Count      Cost
 100.0.0.0       255.0.0.0       Advertise     1          (Not Configured)
表1-3 display ospf abr-summary命令显示信息描述表
Topology
MTID
Area
聚合路由所在的区域
聚合路由的路由数
Net
聚合路由的网络地址
Mask
聚合路由的网络掩码
Status
聚合路由的状态:
·     Advertise:已发布
·     Not-Advertise:未发布
Count
被聚合的路由数
Cost
聚合路由的开销
# 显示OSPF的ABR聚合详细信息。
<Sysname> display ospf abr-summary verbose
                         Area: 0.0.0.1
 Net         : 100.0.0.0
 Mask        : 255.0.0.0
 Status      : Advertise
 Cost        : (Not Configured)
 Routes count: 1
   Destination            NetMask                 Metric
   100.1.1.0              255.255.255.0           1000
表1-4 display ospf abr-summary verbose命令显示信息描述表
Topology
MTID
Destination
被聚合路由的网络地址
NetMask
被聚合路由的网络掩码
Metric
路由的开销值
display ospf asbr-summary命令用来显示OSPF的ASBR聚合信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的ASBR聚合信息。
mask:网络掩码,点分十进制格式。
如果未指定IP地址和掩码,将显示所有的ASBR聚合信息。
# 显示OSPF进程1的ASBR聚合信息。
<Sysname> display ospf 1 asbr-summary
                  Summary Addresses
                  Summary Address
 Net         : 30.1.0.0
 Mask        : 255.255.0.0
 Tag         : 20
 Status      : Advertise
 Cost        : 10 (Configured)
 Route count : 2
 Destination     Net mask        Proto      Process   Type     Metric
 30.1.2.0        255.255.255.0   OSPF       2         2        1
 30.1.1.0        255.255.255.0   OSPF       2         2        1
表1-5 display ospf asbr-summary命令显示信息描述表
Topology
MTID
聚合路由的路由数
Net
聚合路由的网络地址
Mask
聚合路由的网络掩码
Tag
聚合路由的标记字段
Status
聚合路由的发布状态
Cost
聚合路由的开销
Route count
被聚合的路由数
Destination
被聚合路由的网络地址
Net mask
被聚合路由的网络掩码
Proto
引入路由的协议类型
Process
引入路由的协议进程号
外部路由类型
Metric
路由的开销值
display ospf event-log命令用来显示OSPF的日志信息。
display ospf [ process-id ] event-log { lsa-flush | lsa-history [ verbose ] | peer [ neighbor-id ] [ slot slot-number ] | route | spf }
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的日志信息。
lsa-flush:显示LSA老化的日志信息。
lsa-history:显示生成和接收LSA的日志信息。
peer:显示邻居状态变化的日志信息。
neighbor-id:显示指定邻居状态变化的日志信息,neighbor-id表示邻居路由器的Router ID。如果未指定本参数,将显示所有OSPF邻居状态变化的日志信息。
slot slot-number:显示指定单板上OSPF邻居状态变化的日志信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主进程所在单板上OSPF邻居状态变化的日志信息。
route:路由的日志信息。
spf:路由计算的日志信息。
路由计算的日志信息是指更新到IP路由表的路由计数信息。
邻居的日志信息包括OSPF邻居状态倒退到DOWN,以及收到BadLSReq、SeqNumberMismatch和1-Way事件导致邻居状态倒退的信息。
# 显示OSPF的LSA 老化日志信息。
<Sysname> display ospf event-log lsa-flush
                  LSA Flush Log
 Date: 2019-09-22 Time: 14:47:33 Received MaxAge LSA from 10.1.1.1
 Type: 1   LS ID: 2.2.2.2         AdvRtr: 2.2.2.2           Seq#: 80000001
 Date: 2019-09-22 Time: 14:47:33 Flushed MaxAge LSA by the self
 Type: 1   LS ID: 1.1.1.1         AdvRtr: 1.1.1.1           Seq#: 80000001
 Date: 2019-09-22 Time: 14:47:33 Received MaxAge LSA from 10.1.2.2
表1-6 display ospf event-log lsa-flush命令显示信息描述表
Date &Time
收到MaxAge LSA的时间
Received MaxAge LSA from X.X.X.X
从源地址收到MaxAge LSA
由自己发起老化,洪泛MaxAge LSA
LSA类型
LS ID
LSA链路状态ID
AdvRtr
LSA发布路由器
Seq#
LSA序列号
# 显示OSPF进程1的LSA 日志信息。
<Sysname> display ospf event-log lsa-history
                  LSA Log
Date:2019-09-06 Time:10:47:44:007923 Area 0.0.0.2  LSAs received from interface XGE0/0/6 10.5.1.5
Type      LinkState ID     AdvRtr       Age  Length   Sequence
1         10.1.1.5         10.1.1.5     1    36       80000002
表1-7 display ospf event-log lsa-history命令显示信息描述表
Date & Time
生成或接收LSA的时间(精确到微秒)
LSAs received from interface XXX X.X.X.X
从IP地址为X.X.X.X的接口XXX收到LSA
Self-originated or self-aged LSAs
由自己生成的LSA,或者自己发起老化的LSA
LSA类型
LinkState ID
LSA链路状态ID
AdvRtr
LSA发布路由器
Age
LSA的老化时间
Length
LSA的长度
Sequence
LSA序列号
# 显示OSPF进程1的路由日志信息。
<Sysname> display ospf event-log route
                  Route Log
Date: 2019-09-22 Time: 14:47:33:070853 Modified 2.1.1.1/32,
Type:Stub
Interface: XGE0/0/7, Nexthop:10.5.1.1, Rely NbrID:0x13000004, Flag:0x01
表1-8 display ospf event-log route命令显示信息描述表
Date & Time
路由计算的时间(精确到微秒)
Added/Deleted/Modified
变化的路由条目(Add表示新增路由,Delete表示删除路由,Modified表示修改路由)
路由类型(Transit、Stub、Inter、Type1和Type2)
路由出接口
Nexthop
路由下一跳
Rely NbrID
迭代类型的Nbr ID(没有Rely字段表示非迭代类型Nbr)
Flag
路由属性标记
# 显示OSPF路由计算的日志信息。
<Sysname> display ospf event-log spf
          OSPF Process 1 with Router ID 1.1.1.2
                  SPF Log
Date       Time     Duration   Intra Inter External Reason
2019-09-27 15:28:26 0.95       1     1     10000    Intra-area LSA
2019-09-27 15:28:23 0.2        0     0     0        Area 0 full neighbor
2019-09-27 15:28:19 0          0     0     0        Intra-area LSA
2019-09-27 15:28:19 0          0     0     0        external LSA
2019-09-27 15:28:19 0.3        0     0     0        Intra-area LSA
2019-09-27 15:28:12 0          1     0     0        Intra-area LSA
2019-09-27 15:28:11 0          0     0     0        Routing policy
2019-09-27 15:28:11 0          0     0     0        Intra-area LSA
表1-9 display ospf event-log spf命令显示信息描述表
Topology
MTID
Date/Time
路由计算开始的时间
Duration
路由计算持续时间,单位为秒
Intra
区域内路由变化的个数
Inter
区域间路由变化的个数
External
外部路由变化的个数
Reason
路由计算的原因:
·     Intra-area LSA:区域内LSA变化
·     Inter-area LSA:区域间LSA变化
·     External LSA:外部LSA变化
·     Configuration:配置变化
·     Area 0 full neighbor:区域0FULL邻居个数变化
·     Area 0 up interface:区域0UP接口个数变化
·     LSDB overflow state:overflow状态变化
·     AS number:AS号变化
·     ABR summarization:ABR聚合变化
·     GR end:GR结束
·     Routing policy:路由策略变化
·     Intra-area tunnel:区域内隧道变化
·     Others:除上述原因之外的其他原因
# 显示OSPF邻居的日志信息。
<Sysname> display ospf 1 event-log peer
                  Neighbors Log
Date       Time     Local Address   Remote Address  Router ID       Reason
2019-12-31 12:35:45 197.168.1.1     197.168.1.2     2.2.2.2         IntPhyChange
2019-12-31 12:35:19 197.168.1.1     197.168.1.2     2.2.2.2         ConfNssaArea
2019-12-31 12:34:59 197.168.1.1     197.168.1.2     2.2.2.2         SilentInt
表1-10 display ospf event-log peer命令显示信息描述表
Date &Time
邻居状态变化的时间
Local Address
建立邻居关系的本端地址
Remote Address
建立邻居关系的对端地址
Router ID
邻居的Router ID
Reason
邻居状态变化的原因:
·     ResetConnect:内存不足断连接
·     IntChange:接口参数改变
·     VlinkChange:虚连接参数改变
·     ShamlinkChange:伪连接参数改变
·     ResetOspf:重启OSPF进程
·     UndoOspf:删除OSPF进程
·     UndoArea:删除OSPF区域
·     UndoNetwork:接口去使能
·     SilentInt:配置抑制接口
·     IntLogChange:接口逻辑属性变化
·     IntPhyChange:接口物理属性变化
·     IntVliChange:接口虚连接属性变化
·     VlinkDown:虚连接Down
·     ShamlinkDown:伪连接Down
·     DeadExpired:Dead Timer超时
·     ConfStubArea:配置Stub区域参数
·     ConfNssaArea:配置NSSA区域参数
·     AuthChange:认证类型变化
·     OpaqueChange:Opaque能力改变
·     Retrans:重传过多
·     LLSChange:LLS能力变化
·     OOBChange:OOB能力变化
·     GRChange:GR能力变化
·     BFDDown:BFD Down
·     BadLSReq:收到BadLSReq事件
·     SeqMismatch:收到SeqNumberMismatch事件
·     1-Way:收到1-Way事件
·     FilterLSA:对发送给指定邻居的LSA进行过滤的配置发生变化,或者该配置引用的ACL规则改变
·     LocalNoLSA:本地不存在请求的LSA
·     SameLSAReq:本地的请求列表中含有已收到的LSA
·     OldLSAReq:收到的LSA的老化时间比本地请求列表中LSA的老化时间大
·     DdTimerOut:定时器超时,收到DD报文
·     EAChange:External Attribute位发生变化
·     MTChange:Multi-Topology位发生变化
·     RecvNoDupPkt:在Loading、Full状态收到非重复的DD报文
·     EbitChange:E位发生变化
·     MSbitChange:主从位发生变化
·     IbitChange:I位发生变化
·     MSeqNumError:主路由器收到的从路由器的序列号与期望值不一致
·     SSeqNumError:从路由器收到的主路由器的序列号与期望值不一致
·     RecvOpqIntf:未使能Opaque LSA发布接收能力,但收到的DD报文中含有Type9 LSA
·     RecvOpqArea:未使能Opaque LSA发布接收能力,但收到的DD报文中含有Type10 LSA
·     RecvOpqAS:未使能Opaque LSA发布接收能力,但收到的DD报文中含有Type11 LSA
·     RecvNSSA:在非NSSA区域,收到的DD报文含有Type7 LSA
·     InvalidLSA:收到DD报文含有无效的LSA
·     RecvASE:在虚连接环境或Stub区域中,收到的DD报文含有Type5 LSA
·     shutdown:配置了shutdown process命令
·     reset ospf event-log
display ospf event-log hello命令用来显示OSPF接收或发送Hello报文的日志信息。
display ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent } [ neighbor-id ] [ slot slot-number ]
display ospf [ process-id ] event-log hello sent { abnormal | failed } [ neighbor-address ] [ slot slot-number ]
received:显示接收到的Hello报文的日志信息。
sent:显示发送Hello报文的日志信息。
abnormal:显示接收或发送异常Hello报文的日志信息。异常Hello报文指的是发送或接收到的Hello报文的时间间隔大于或等于1.5倍Hello定时器的报文。
dropped:显示丢弃接收到的Hello报文的日志信息。
failed:显示发送失败的Hello报文的日志信息。
neighbor-address:邻居的IP地址,显示指定邻居接收或发送Hello报文的日志信息。如果未指定本参数,将显示所有OSPF邻居接收或发送Hello报文的日志信息。
neighbor-id:邻居的Router ID,显示指定邻居接收或发送Hello报文的日志信息。如果未指定本参数,将显示所有OSPF邻居接收或发送Hello报文的日志信息。
slot slot-number:显示指定单板接收或发送Hello报文的日志信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主进程所在单板接收或发送Hello报文的日志信息。
# 显示发送Hello报文的日志信息。
<Sysname> display ospf event-log hello sent
         OSPF Process 1 with Router ID 5.5.5.5
                 Hello Log
Interface: XGE0/0/6
Neighbor address: 10.1.1.2, NbrID: 1.0.0.2
First 4 hello packets sent:
  2019-02-05 20:10:10:121, failed, errno: 132
  2019-02-05 20:10:30:121, succeeded
  2019-02-05 20:10:20:121, succeeded
  2019-02-05 20:10:40:121, succeeded
Last 4 hello packets sent before Full->Down at 2019-02-06 14:52:10:121
  2019-02-06 14:51:40:021, succeeded
  2019-02-06 14:51:50:021, succeeded
  2019-02-06 14:52:00:021, failed, errno: 132
  2019-02-06 14:52:10:010, failed, errno: 132
Interface: XGE0/0/6
Last 4 hello packets sent before Full->Init at 2019-02-06 11:16:20:171
  2019-02-06 11:15:20:121, succeeded
  2019-02-06 11:15:30:121, succeeded
  2019-02-06 11:15:40:121, succeeded
  2019-02-06 11:15:50:121, succeeded
表1-11 display ospf event-log hello sent命令显示信息描述表
发送Hello报文的接口
Neighbor address
邻居的IP地址
NbrID
邻居的路由器ID
最开始发送的4个Hello报文的时间,以及报文是否发送成功的信息
·     succeeded:发送成功
·     failed:发送失败
·     errno:错误码,表明了报文发送失败的原因。取值包括:
¡     4:EINTR,数据发送前被信号中断
¡     9:EBADF,输入文件描述符不是一个可用的文件描述符
¡     11:EAGAIN,非阻塞发送时,socket发现需要阻塞发送,比如基于流的socket发送缓冲区大小不够
¡     12:ENOMEM,内存不足
¡     32:EPIPE,socket发送被关闭,不能继续发送数据
¡     88:ENOTSOCK,输入文件描述符不是一个socket描述符
¡     90:EMSGSIZE,发送数据长度太长
¡     95:EOPNOTSUPP,协议不能支持flags指定的标志
¡     104:ECONNRESET,连接被对端关闭
¡     107:ENOTCONN,socket不是连接状态,且没有指定目的地址
¡     113:EHOSTUNREACH,可能是路由不可达、主机不可达等
¡     132:ENOBUFS,没有足够的缓冲区空间资源
邻居状态改变的时间,以及状态改变前发送的4个Hello报文的时间和报文是否发送成功的信息
·     succeeded:发送成功
·     failed:发送失败
¡     12:ENOMEM,内存不足
# 显示发送失败的Hello报文的日志信息。
<Sysname> display ospf event-log hello sent failed
                 Hello Log
Date: 2019-02-06 Time: 14:51:20:121 Interface: XGE0/0/6
Destination address: 224.0.0.5, sent failed, errno: 132
Date: 2019-02-06 Time: 11:20:20:116 Interface: XGE0/0/7
Destination address: 10.1.1.2, sent failed, errno: 132
表1-12 display ospf event-log hello sent failed命令显示信息描述表
Date
Hello报文发送失败的日期,单位为YYYY-MM-DD,其中YYYY为年,MM为月,DD为日
Time
Hello报文发送失败的时间,单位为hh:mm:ss:xxx,其中hh为小时,mm为分钟,ss为秒,xxx为毫秒
发送Hello报文的接口
Destination address
Hello报文的目的IP地址
sent failed
发送失败
errno
发送失败的错误码,取值包括:
·     4:EINTR,数据发送前被信号中断
·     9:EBADF,输入文件描述符不是一个可用的文件描述符
·     11:EAGAIN,非阻塞发送时,socket发现需要阻塞发送,比如基于流的socket发送缓冲区大小不够
·     12:ENOMEM,内存不足
·     32:EPIPE,socket发送被关闭,不能继续发送数据
·     88:ENOTSOCK,输入文件描述符不是一个socket描述符
·     90:EMSGSIZE,发送数据长度太长
·     95:EOPNOTSUPP,协议不能支持flags指定的标志
·     104:ECONNRESET,连接被对端关闭
·     107:ENOTCONN,socket不是连接状态,且没有指定目的地址
·     113:EHOSTUNREACH,可能是路由不可达、主机不可达等
·     132:ENOBUFS,没有足够的缓冲区空间资源
# 查看发送异常Hello报文的日志信息。
<Sysname> display ospf event-log hello sent abnormal
                 Hello Log
Date: 2019-02-06 Time: 11:21:12:121 Interface: XGE0/0/7
Destination address: 224.0.0.5, last one sent: 2019-02-06 11:20:51:916
Date: 2019-02-06 Time: 11:56:21:312 Interface: XGE0/0/7
Destination address: 10.1.1.2, last one sent: 2019-02-06 11:56:02:691
表1-13 display ospf event-log hello sent abnormal命令显示信息描述表
Date
发送异常Hello报文的日期,单位为YYYY-MM-DD,其中YYYY为年,MM为月,DD为日
Time
发送异常Hello报文的时间,单位为hh:mm:ss:xxx,其中hh为小时,mm为分钟,ss为秒,xxx为毫秒
发送异常Hello报文的接口
Destination address
异常Hello报文的目的IP地址
last one sent
发送异常Hello报文前,最后一次发送Hello报文的时间
# 显示接收Hello报文的日志信息。
<Sysname> display ospf event-log hello received
                 Hello Log
Interface: XGE0/0/6
First 4 hello packets received:
  2019-02-05 20:11:10:121
  2019-02-05 20:11:30:121
  2019-02-05 20:11:20:121
  2019-02-05 20:11:40:121
Last 4 hello packets received before Exchange->Down at 2019-02-06 14:52:10:121
  2019-02-06 14:51:10:121
  2019-02-06 14:51:30:121
  2019-02-06 14:51:20:121
  2019-02-06 14:51:40:121
Interface: XGE0/0/6
Neighbor address: 10.1.1.1, NbrID: 1.0.0.1
  2019-02-06 19:11:15:121
  2019-02-06 19:11:35:121
  2019-02-06 19:11:25:121
  2019-02-06 19:11:45:121
Last 4 hello packets received before Full->Init at 2019-02-06 21:16:20:171
  2019-02-06 21:15:45:121
  2019-02-06 21:15:55:121
  2019-02-06 21:16:05:121
  2019-02-06 21:16:15:121
表1-14 display ospf event-log hello received命令显示信息描述表
发送Hello报文的接口
Neighbor address
邻居的IP地址
NbrID
邻居的路由器ID
最开始接收的4个Hello报文的时间
邻居状态改变的时间,以及状态改变前接收的4个Hello报文的时间信息。其中,日期单位为YYYY-MM-DD,其中YYYY为年,MM为月,DD为日;时间单位为hh:mm:ss:xxx,其中hh为小时,mm为分钟,ss为秒,xxx为毫秒
# 显示丢弃接收到的Hello报文的日志信息。
<Sysname> display ospf event-log hello received dropped
                 Hello Log
Date: 2019-02-06 Time: 14:51:22:791 Interface: XGE0/0/6
Source address: 10.1.1.1, NbrID: 1.0.0.1, area: 0.0.0.1
Drop reason: Hello-time mismatch
Source address: 10.1.1.2, NbrID: 1.0.0.2, area: 0.0.0.1
Drop reason: NP-bit mismatch
                 Hello Log
Date: 2019-02-06 Time: 14:51:22:791 Interface: Vlan10
Date: 2019-02-06 Time: 14:51:20:121 Interface: Vlan10
表1-15 display ospf event-log hello received dropped命令显示信息描述表
Date
丢弃接收到的Hello报文的日期,单位为YYYY-MM-DD,其中YYYY为年,MM为月,DD为日
Time
丢弃接收到的Hello报文的时间,单位为hh:mm:ss:xxx,其中hh为小时,mm为分钟,ss为秒,xxx为毫秒
接收Hello报文的接口
Source address
接收到的Hello报文中的源IP地址
NbrID
邻居路由器的Router ID
area
邻居接口所在区域
Drop reason
丢弃Hello报文的原因:
·     Area under reset:正在进行区域重置
·     Router ID conflict:Router ID冲突
·     Area mismatch:区域ID不一致
·     Unknown virtual link:Hello报文来自未知的虚连接
·     Authentication failure:Hello报文认证检查失败
·     Peer address check failure:Hello报文的邻居地址检查失败
·     Not DR or BDR:Hello报文目的地址与接口DR/BDR状态不一致
·     Unknown unicast peer:Hello报文来自未知的单播邻居
·     Option mismatch:Hello报文Option字段不匹配
·     Subnet mask mismatch:Hello报文的网络掩码不匹配
·     Address mismatch:Hello报文的地址段不匹配
·     Hello timer mismatch:Hello报文的Hello定时器不匹配
·     Dead timer mismatch:Hello报文的Dead定时器不匹配
·     Peer change:Hello报文的源地址或Router ID发生变化
·     FilterLSA:对发送给指定邻居的LSA进行过滤的配置发生变化,或者该配置引用的ACL规则改变导致邻居关系断开
# 显示接收到异常的Hello报文的日志信息。
<Sysname> display ospf event-log hello received abnormal
                 Hello Log
Date: 2019-02-06 Time: 10:12:22:121 Interface: XGE0/0/6
Last one received: 2019-02-06 10:12:04:212
Last one received: 2019-02-06 14:51:05:113
                 Hello Log
Date: 2019-02-06 Time: 10:12:22:121 Interface: Vlan10
表1-16 display ospf event-log hello receiverd abnormal命令显示信息描述表
Date&Tme
收到异常Hello报文的日期,单位为YYYY-MM-DD,其中YYYY为年,MM为月,DD为日
Time
收到异常Hello报文的时间,单位为hh:mm:ss:xxx,其中hh为小时,mm为分钟,ss为秒,xxx为毫秒
收到异常Hello报文的接口
Source address
收到异常Hello报文的源IP地址
NbrID
邻居路由器的Router ID
area
邻居接口所在区域
Last one received
接收到异常的Hello报文前,最后一次收到Hello报文的时间
·     reset ospf event-log hello
display ospf fast-reroute lfa-candidate命令用来显示区域中FRR备份下一跳候选列表。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的备份下一跳候选列表。
area area-id:显示指定区域FRR备份下一跳候选列表。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。如果未指定本参数,将显示所有区域的信息。
# 显示OSPF的FRR备份下一跳候选列表。
<Sysname> display ospf 1 area 0 fast-reroute lfa-candidate
                  LFA Candidate List
 Area: 0.0.0.0
 Candidate nexthop count: 2
 NextHop          IntIP            Interface
 10.0.1.1         10.0.1.2         XGE0/0/7
 10.0.11.1        10.0.11.2        XGE0/0/8
表1-17 display ospf fast-reroute lfa-candidate命令显示信息描述表
Topology
MTID
Area
显示该区域的备份下一跳信息
备份下一跳个数
NextHop
备份下一跳地址
IntIP
出接口IP地址
出接口
display ospf global-statistics命令用来显示OSPF的全局统计信息。
display ospf global-statistics [ public | vpn-instance vpn-instance-name ]
public:显示公网下OSPF的全局统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例下OSPF的全局统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
如果不指定任何参数,将显示公网和VPN实例下OSPF的全局统计信息。
# 显示OSPF的全局统计信息。
<Sysname> display ospf global-statistics
  OSPF global statistics
   Instance count   : 1
   Process count    : 3
   Interface information
    Down            : 1
    Up              : 0
   Neighbor information
    Down            : 0
    Init            : 0
    Attempt         : 0
    2-Way           : 0
    ExStart         : 0
    Exchange        : 0
    Loading         : 0
    Full            : 0
   Packets sent     : 0
   Packets received : 0
   LSA count        : 0
   Route count      : 0
表1-18 display ospf global-statistics命令输出信息描述表
Instance count
公网和VPN实例下存在OSPF配置时,对公网和VPN实例总数的统计信息
Process count
进程数量
接口状态统计信息
Down
状态为Down的接口数目
Up
状态为Up的接口数目
邻居状态统计信息
Down
状态为Down的邻居路由器数目
Attempt
状态为Attempt的邻居路由器数目
Init
状态为Init的邻居路由器数目
2-Way
状态为2-Way的邻居路由器数目
ExStart
状态为ExStart的邻居路由器数目
Exchange
状态为Exchange的邻居路由器数目
Loading
状态为Loading的邻居路由器数目
Full
状态为Full的邻居路由器数目
Packets sent
发送协议报文的数目
Packets received
接收协议报文的数目
LSA count
链路状态数据库中所有LSA的数目
Route count
OSPF所有路由的数目
display ospf graceful-restart命令用来查看OSPF进程的GR状态信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的GR状态信息。
verbose:显示GR详细状态信息。如果未指定本参数,将显示OSPF进程的GR状态概要信息。
# 显示OSPF进程的GR详细状态信息。
<Sysname> display ospf graceful-restart verbose
              Graceful Restart information
Graceful Restart capability     : Enable(IETF)
Graceful Restart support        : Planned and unplanned,Partial
Helper capability                  : Enable(IETF)
Helper support                  : Planned and unplanned(IETF),Strict LSA check
Current GR state                : Normal
Graceful Restart period         : 40 seconds
Number of neighbors under Helper: 0
Number of restarting neighbors  : 0
Last exit reason:
  Restarter  : None
  Helper     : None
Area: 0.0.0.0
Authentication type: None Area flag: Normal
Area up Interface count: 2
Interface: 40.4.0.1 (Ten-GigabitEthernet0/0/7)
Restarter state: Normal  State: P-2-P     Type: PTP
Last exit reason:
  Restarter  : None
  Helper     : None
Neighbor count of this interface: 1
Number of neighbors under Helper:0
Neighbor        IP address      GR state     Last Helper exit reason
3.3.3.3         40.4.0.3        Normal       None
Virtual-link Neighbor-ID  -> 4.4.4.4, Neighbor-State: Full
Interface: 20.2.0.1 (Vlink)
Transit Area:0.0.0.1
Last exit reason:
  Restarter  : None
  Helper     : None
4.4.4.4         20.2.0.4        Normal       Reset neighbor
表1-19 display ospf graceful-restart命令显示信息描述表
OSPF进程是1,Router ID是1.1.1.1的GR状态信息
进程GR能力配置:
·     Enable(IETF):使能IETF GR能力
·     Enable(Nonstandard):使能非IETF GR能力
·     Disable:关闭了GR能力
进程GR支持模式(GR使能时才显示):
·     Planned and unplanned:支持计划和非计划GR
·     Planned only:只支持计划性GR
·     Partial:支持接口级GR
·     Global:不支持接口级GR,支持全局GR
Helper capability
进程Helper能力配置:
·     Enable(IETF):支持作为标准GR Helper的能力
·     Enable(Nonstandard):支持作为非标准GR Helper的能力
·     Enable(IETF and nonstandard):同时支持作为标准和非标准GR Helper的能力
·     Disable:不支持作为GR Helper的能力
Helper support
显示支持Helper的策略(Helper使能时才显示):
·     Strict LSA check:Helper端支持严格的LSA检查
·     Planned and unplanned:支持作为计划和非计划重启的Helper
·     Planned only:只支持作为计划GR的Helper
Current GR state
当前OSPF进程的GR状态:
·     Normal:普通状态
·     Under GR:进程正在GR
·     Under Helper:进程正在作为GR Helper
Graceful-restart period
GR周期
Number of neighbors under helper
处于Helper状态的邻居数量
Helper端显示的处于重启路由器的数量
Last exit reason
上次退出原因,其中:
·     Restarter:表示退出Restarter的原因
·     Helper:表示退出Helper的原因
Area
开始列举当前进程中各区域的信息。显示当前区域ID,IP地址格式
Authentication type
区域验证模式,取值为:
·     None:表示无验证
·     Simple:表示简单验证模式
·     Cryptographic:表示MD5/HMAC-MD5/HMAC-SHA-256验证模式
·     keychain:表示keychain验证模式
Area flag
区域类型:
·     Normal:普通区域
·     Stub:Stub区域
·     NSSA:NSSA区域
区域下UP的接口计数
区域内的接口信息
Restarter state
作为Restarter的状态
接口状态
接口的网络类型
接口下的邻居
Neighbor
邻居Router ID
IP address
邻居IP地址
GR state
邻居的GR状态:
·     Normal:普通状态
·     Under GR:进程正在GR
上一次作为该邻居Helper退出的原因
Vlink的邻居Router ID
Neighbor-State
Vlink和邻居的状态,包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
Vlink接口所属的出接口
display ospf hostname-table命令用来显示Router ID到主机名称的映射关系表。
display ospf [ process-id ] hostname-table
process-id:OSPF进程号,取值范围为1~65535,显示指定OSPF进程中Router ID到主机名称的映射关系表。如果未指定本参数,将显示所有OSPF进程中Router ID到主机名称的映射关系表。
# 显示所有OSPF进程中Router ID到主机名称的映射关系表。
<RouterA> display ospf hostname-table
         OSPF Process 1 with Router ID 192.168.56.21
                 Hostname Table Information
                         Area: 0.0.0.1
Router ID            Hostname
192.168.56.21        RouterA
表1-20 display ospf hostname-table命令输出信息描述表
Router ID
路由器ID
Hostname
主机名称
display ospf interface命令用来显示OSPF的接口信息。
display ospf [ process-id ] interface [ interface-type interface-number | verbose ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的接口信息。
interface-type interface-number:接口类型和编号。显示指定接口的OSPF详细信息。
verbose:显示所有接口的OSPF详细信息。
如果未指定接口或参数verbose,将显示所有接口的OSPF概要信息。
# 显示所有接口的OSPF概要信息。
<Sysname> display ospf interface
                  Interfaces
 Area: 0.0.0.0
 IP Address      Type         State    Cost  Pri   DR              BDR
 192.168.1.1     PTP          P-2-P    1562  1     0.0.0.0         0.0.0.0
 Area: 0.0.0.1
 172.16.0.1      Broadcast    DR       1     1     172.16.0.1      0.0.0.0
表1-21 display ospf interface命令显示信息描述表
Area
接口所属的区域ID
IP Address
接口IP地址(不管是否使能了流量工程)
接口的网络类型,取值为:
·     PTP表示网络类型为点对点
·     PTMP表示网络类型为点对多点
·     Broadcast表示网络类型为广播
·     NBMA表示网络类型为NBMA
根据OSPF接口状态机确定的当前接口状态,取值为:
·     Down表示在接口上没有发送和接收任何路由协议的报文
·     Loopback表示路由器到网络的接口处于环回状态,不能用于正常的数据传输
·     Waiting表示接口开始发送和接收Hello报文,并试图去识别网络上的DR和BDR
·     P-2-P表示接口将每隔HelloInterval的时间间隔发送Hello报文,并尝试和接口链路另一端相连的路由器建立邻接关系
·     DR表示路由器是所连网络的指定路由器
·     BDR表示路由器是所连网络的备份指定路由器
·     DROther表示路由器既不是所连网络的指定路由器,也不是所连网络的备份指定路由器
Cost
接口开销
Pri
路由器优先级
DR
接口所属网段的DR
BDR
接口所属网段的BDR
# 显示OSPF指定接口Ten-GigabitEthernet0/0/6的详细信息。
<Sysname> display ospf interface ten-gigabitethernet 0/0/6
                  Interfaces
 Area: 0.0.0.0
 Interface: 172.16.0.1 (Ten-GigabitEthernet0/0/6)
 Priority: 1
 Designated router: 172.16.0.1
 Backup designated router: 0.0.0.0
 Timers: Hello 10, Dead 40, Poll  40, Retransmit 5, Transmit Delay 1
 FRR backup: Enabled
 FRR TI-LFA: Enabled
 Primary path detection mode: BFD ctrl
 Enabled by interface configuration (including secondary IP addresses)
 BFD: echo
    The last key is 3.
    The rollover is in progress, 2 neighbor(s) left.
 LDP state: No-LDP
 LDP sync state: Achieved
 Link quality: GOOD, cost adjusted at low quality: 50
 Packet size: 1000
 MTID    Cost      Disabled    Topology name
 0       1         No          base
表1-22 display ospf interface verbose命令显示信息描述表
接口IP地址等信息
MTU
最大传输单元
Cost source
·     Default:缺省值
Timers
OSPF定时器的值,其中:
·     Dead:表示邻居的失效时间
·     Retransmit:表示接口重传LSA时间间隔
Transmit Delay
接口对LSA的传输延迟时间
FRR backup
·     Enabled:使能
·     Disabled:关闭
FRR TI-LFA
·     Disabled:关闭
·     Enabled:开启
FRR remote-LFA
是否使能路由Remote LFA计算功能
·     Disabled:关闭
·     Enabled:开启
主链路检测方式:
·     BFD ctrl:BFD控制报文检测方式
·     BFD echo:BFD echo报文检测方式
接口使能OSPF,包括接口从IP地址
BFD
接口使能OSPF的BFD功能:
·     ctrl:通过BFD控制报文方式实现BFD功能
·     echo:通过BFD echo报文方式实现BFD功能
Simple authentication: Enabled, inherited
接口采用Simple验证模式。inherited表示接口继承的是其所属区域下配置的simple验证模式
接口采用None验证模式
接口采用HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式。inherited表示接口继承的是其所属区域下配置的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式验证模式
The last key is xx
最新的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字标识符为xx
LDP state
LDP状态:
·     Init:表示处于初始化状态,LDP还没有上报状态
·     No-LDP:表示未配置LDP
·     Not ready:表示未建立LDP会话
·     Ready:表示已建立LDP会话
LDP sync state
LDP IGP同步状态:
·     Init:表示初始化
·     Achieved:表示已同步
·     Max cost:表示保持最大开销值
Link quality
接口的质量属性:
·     GOOD:链路质量优。误码率未达到高误码率门限或者误码率从大于等于高误码率门限回落到小于低误码率门限时,显示为GOOD
·     LOW:链路质量差。误码率达到高误码率门门限时,链路质量显示为LOW
该信息仅在接口配置了ospf link-quality adjust-cost命令时显示
当链路质量等级为LOW时接口开销值的调整值或最大值:
·     xx:表示调整值,即当链路质量等级为LOW时,接口的开销值=xx+接口原本的开销值
·     Maximum:表示调整为最大值,即当链路质量等级为LOW时,接口的开销值=Maximum
Packet size
接口下配置的发送OSPF报文的最大长度
Prefix-SID type
表示前缀SID的类型:
·     Absolute:前缀SID绝对值
·     Index:前缀SID相对值
Static adjacency SID
接口下配置的静态Adjacency SID
Nexthop
下一跳地址,0.0.0.0表示P2P类型
Adjacency-SID
Adjacency SID
Adjacency SID的类型:
·     Absolute:邻接SID绝对值
·     Index:邻接SID索引值
Result
向MPLS申请Adjacency SID的结果:
·     Succeeded:Adjacency SID申请成功
·     Conflicting:Adjacency SID冲突
·     Init:正在申请Adjacency SID或未开启邻接标签分配功能
Value
前缀SID的取值以及标志信息:
·     Explicit-null:表示上游邻居用显式空标签代替前缀SID
·     N-flag-clear:表示前缀SID为到达一组SR节点的SID
ProcessID
配置前缀SID时实际指定的进程号
Prefix-SID validity
·     Valid:表示有效值
MTID
Cost
‌指定拓扑下的接口路由开销
Disabled
‌OSPF是否通告指定拓扑下的接口所属拓扑的消息:
·     Yes:不通告
·     No:通告
Topology name
display ospf interface hello命令用来显示接口发送Hello报文的信息。
display ospf [ process-id ] interface [ interface-type interface-number ] hello
process-id:显示指定OSPF进程发送Hello报文的信息,process-id表示OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程发送Hello报文的信息。
interface-type interface-number:显示指定OSPF接口发送Hello报文的信息,interface-type interface-number表示接口类型和编号。如果未指定本参数,将显示所有OSPF接口发送Hello报文的信息。
本命令仅显示以组播形式发送Hello报文的信息。
# 显示OSPF接口发送Hello报文的信息。
<Sysname> display ospf interface hello
                  Interfaces
 Area: 0.0.0.0
   2019-02-05 11:05:10:121, succeeded
   2019-02-05 11:05:20:121, succeeded
   2019-02-05 11:05:30:121, succeeded
   2019-02-05 11:05:40:121, succeeded
 Last 4 hello packets sent:
   2019-02-06 11:15:10:121, succeeded
表1-23 display ospf interface hello命令显示信息描述表
Area
接口所在区域
接口IP地址
最先发送的4个Hello报文的时间,以及报文是否发送成功
·     succeeded:发送成功
·     failed:发送失败
执行本命令时,最近发送的4个Hello报文的时间,以及报文是否发送成功的信息
·     succeeded:发送成功
·     failed:发送失败
display ospf lsdb命令用来显示OSPF的链路状态数据库信息。
display ospf [ process-id ] lsdb [ brief | originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] lsdb { ase | opaque-as } [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb { ase | opaque-as } [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] [ area area-id ] lsdb { network | opaque-area | opaque-link } [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] [ area area-id ] lsdb { network | opaque-area | opaque-link } [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] [ area area-id ] lsdb { asbr | nssa | router | summary } [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] [ area area-id ] lsdb { asbr | nssa | router | summary } [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的链路状态数据库信息。
age:显示数据库中老化时间在指定范围内的LSA的信息。如果未指定本参数,则显示数据库中所有LSA的信息。
max-value max-age-value:指定LSA老化时间的最大值,取值范围为0~3600,单位为秒,缺省值为3600。
min-value min-age-value:指定LSA老化时间的最小值,取值范围为0~3600,单位为秒,缺省值为0。min-age-value的配置值不允许大于max-age-value。
area area-id:显示数据库中指定区域的LSA信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。如果未指定本参数,将显示所有区域的信息。
brief:显示数据库的概要信息。
asbr:显示数据库中Type-4 LSA(ASBR Summary LSA)的信息。
ase:显示数据库中Type-5 LSA(AS External LSA)的信息。
network:显示数据库中Type-2 LSA(Network LSA)的信息。
nssa:显示数据库中Type-7 LSA(NSSA External LSA)的信息。
opaque-area:显示数据库中Type-10 LSA (Opaque-area LSA)的信息。
opaque-as:显示数据库中Type-11 LSA (Opaque-AS LSA)的信息。
opaque-link:显示数据库中Type-9 LSA(Opaque-link LSA)的信息。
router:显示数据库中Type-1 LSA(Router LSA)的信息。
summary:显示数据库中Type-3 LSA(Network Summary LSA)的信息。
link-state-id:链路状态ID,IP地址格式。
originate-router advertising-router-id:发布LSA报文的路由器的Router ID。
self-originate:显示本地路由器自己产生的LSA的数据库信息。
hostname host-name:发布LSA报文的路由器的主机名。如果未指定本参数,则显示数据库中所有LSA的信息。
resolve-hostname:显示包含主机名的链路状态数据库信息。如果未指定本参数,显示的链路状态数据库信息中将不包含主机名。
min-age-value配置值不允许大于max-age-value。
# 显示OSPF的链路状态数据库信息。
<Sysname> display ospf lsdb
          OSPF Process 1 with Router ID 192.168.0.1
                  Link State Database
                          Area: 0.0.0.0
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Metric
 Router    192.168.0.2     192.168.0.2        474  36    80000004   0
 Router    192.168.0.1     192.168.0.1        21   36    80000009   0
 Network   192.168.0.1     192.168.0.1        321  32    80000003   0
 Sum-Net   192.168.1.0     192.168.0.1        321  28    80000002   1
 Sum-Net   192.168.2.0     192.168.0.2        474  28    80000002   1
                         Area: 0.0.0.1
 Router    192.168.0.1     192.168.0.1        21   36    80000005   0
 Sum-Net   192.168.2.0     192.168.0.1        321  28    80000002   2
 Sum-Net   192.168.0.0     192.168.0.1        321  28    80000002   1
                         Type 9 Opaque (Link-Local Scope) Database
 Flags: * -Vlink interface LSA
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Interfaces
*Opq-Link  3.0.0.0         7.2.2.1            8    14    80000001   10.1.1.2
*Opq-Link  3.0.0.0         7.2.2.2            8    14    80000001   20.1.1.2
# 显示OSPF的链路状态数据库信息,其中包含数据库中LSA的主机名信息。
<Sysname> display ospf lsdb resolve-hostname
                 Link State Database
                         Area: 0.0.0.0
 Router    1.1.1.1         1.1.1.1         1419 36    80000004  0
 Router    2.2.2.2         RouterB         1420 36    80000004  0
 Network   192.168.12.2    RouterB         1420 32    80000001  0
 Sum-Net   192.168.13.0    1.1.1.1         1456 28    80000001  1
                         Area: 0.0.0.1
 Router    3.3.3.3         3.3.3.3         1416 36    80000003  0
 Router    1.1.1.1         1.1.1.1         1415 36    80000003  0
 Network   192.168.13.2    3.3.3.3         1416 32    80000001  0
 Sum-Net   192.168.12.0    1.1.1.1         1456 28    80000001  1
                 Type 10 Opaque (Area-Local Scope) Database
 Type      LinkState ID    AdvRouter       Age  Len   Sequence  Area
 Opq-Area  4.0.0.0         RouterB         470  32    80000001  0.0.0.0
表1-24 display ospf lsdb命令显示信息描述表
Area
显示该区域的LSDB信息
LSA类型
LinkState ID
LSA链路状态ID
AdvRouter
LSA发布路由器或主机名
Age
LSA的老化时间
Len
LSA的长度
Sequence
LSA序列号
Metric
度量值
*Opq-Link
表示Vlink接口产生的Opaque LSA
Opq-Area
表示接收到的Type-10 LSA
# 显示OSPF的链路状态数据库的概要信息。
<Sysname> display ospf lsdb brief
                 LS Database Statistics
 Area ID         Router   Network  S-Net    S-ASBR   Type-7   | SubTotal
 0.0.0.0         2        1        0        0        0        | 3
 0.0.0.1         0        0        0        0        0        | 0
 Total           2        1        0        0        0        |
 Area ID         Opq-9    Opq-10                              | SubTotal
 0.0.0.0         0        9                                   | 9
 0.0.0.1         0        1                                   | 1
 Total           0        10                                  |
                 ASE      Opq-11                              | SubTotal
 Total           0        0                                   | 0
                                                              | Total
                                                              | 13
Area ID
区域ID
Router
Type-1 LSA的数目
Network
Type-2 LSA的数目
S-Net
Type-3 LSA的数目
S-ASBR
Type-4 LSA的数目
Type-7
Type-7 LSA的数目
Opq-9
Type-9 LSA的数目
Opq-10
Type-10 LSA的数目
ASE
Type-5 LSA的数目
Opq-11
Type-11 LSA的数目
SubTotal
部分类型的LSA总数
Total
同一类型的LSA总数,或者所有类型的LSA总数
# 显示进程号为1的OSPF进程的链路状态数据库中Type-2 LSA的信息。
<Sysname> display ospf 1 lsdb network
                  Link State Database
                          Area: 0.0.0.0
    Type      : Network
    LS ID     : 192.168.0.2
    Adv Rtr   : 192.168.2.1
    LS age    : 922
    Len       : 32
    Options   :  E
    Seq#      : 80000003
    Checksum  : 0x8d1b
    Net mask  : 255.255.255.0
       Attached router    192.168.1.1
       Attached router    192.168.2.1
                          Area: 0.0.0.1
    Type      : Network
    LS ID     : 192.168.1.2
    Adv Rtr   : 192.168.1.2
    LS age    : 782
    Len       : 32
    Options   :  NP
    Seq#      : 80000003
    Checksum  : 0x2a77
       Attached router    192.168.1.2
# 显示进程号为1的OSPF进程的链路状态数据库中Type-2 LSA的信息,其中包含发布路由器的主机名信息。
<Sysname> display ospf 1 lsdb network resolve-hostname
                 Link State Database
                         Area: 0.0.0.0
    Type      : Network
    LS ID     : 192.168.12.2
    Adv Rtr   : 2.2.2.2
    Hostname  : RouterB
    LS age    : 1552
    Len       : 32
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0xbdd0
       Attached router    1.1.1.1
       Attached router    2.2.2.2
                         Area: 0.0.0.1
    Type      : Network
    LS ID     : 192.168.13.2
    Adv Rtr   : 3.3.3.3
    LS age    : 1548
    Len       : 32
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0xc6be
       Attached router    3.3.3.3
表1-25 display ospf lsdb network命令显示信息描述表
LSA类型
LS ID
DR的IP地址
Adv Rtr
发布路由器
Hostname
LSA发布路由器主机名
LS age
LSA的老化时间
Len
LSA的长度
Options
LSA选项,各选项含义如下:
·     O:Opaque LSA发布接受能力
·     E:AS外部LSA的接受能力
·     EA:外部扩展属性LSA的接受和转发能力
·     DC:支持按需链路
·     N:是否支持NSSA外部LSA
·     P:非纯末稍区域中的ABR路由器将Type-7 LSA转换为Type-5 LSA的能力
Seq#
LSA序列号
Checksum
LSA校验和
Net mask
网络掩码
Attached router
与DR形成了完全邻接关系的路由器的Router ID,也包括DR自身的Router ID
# 显示进程号为1的OSPF进程的链路状态数据库中Type-9 LSA的信息。
<Sysname> display ospf 1 lsdb opaque-link
                 Link State Database
                         Area: 0.0.0.0
    Type      : Opq-Link
    LS ID     : 3.0.0.0
    Adv Rtr   : 1.1.1.1
    LS age    : 2
    Len       : 44
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0x31cf
      Opaque type: 3(Grace LSA)
      Opaque ID: 0
      IETF Graceful Restart Period: 120
      Restart Reason:    1 - software restart
      Neighbor Interface Address  : 192.168.12.1
# 显示进程号为1的OSPF进程的链路状态数据库中Type-10 LSA的信息。
<Sysname> display ospf 1 lsdb opaque-area
                 Link State Database
                         Area: 0.0.0.0
    Type      : Opq-Area
    LS ID     : 4.0.0.0
    Adv Rtr   : 1.1.1.1
    LS age    : 1311
    Len       : 52
    Options   : O E
    Seq#      : 8000015c
    Checksum  : 0x4323
      Opaque type: 4(Router information)
      Opaque ID: 0
      Router information TLV:
        Length      : 4
        Capabilities:
          All Capability Bits: 0x60000000
          Graceful restart helper capable
          Stub router capable
      Segment routing algorithm TLV:
        Length   : 1
        Algorithm: 0
      Segment routing range TLV:
        Length: 12
        Range : 1001
        SID sub-TLV:
          Length: 3
          Label : 16000
      SR Node Maximum SID Depths:
         MPLS MSD         : 13
    Type      : Opq-Area
    LS ID     : 1.0.0.2
    Adv Rtr   : 1.1.1.1
    LS age    : 1239
    Len       : 192
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0x9412
      Opaque type: 1(Traffic Engineering)
      Opaque ID: 2
      Link Type                : Broadcast
      Link ID                  : 12.1.1.2
      Local Interface Address  : 12.1.1.1
      TE Metric                : 1
      Maximum Bandwidth        : 0 bytes/sec
      Maximum Reservable BW    : 0 bytes/sec
      Administrative Group     : 0x0
      IGP Metric               : 1
      Number of SRLGs :  3
        SRLG [1]:10
        SRLG [2]:20
        SRLG [3]:30
      Unreserved Bandwidth for each TE Class:
        TE class  0 = 0 bytes/sec
        TE class  1 = 0 bytes/sec
        TE class  2 = 0 bytes/sec
        TE class  3 = 0 bytes/sec
        TE class  4 = 0 bytes/sec
        TE class  5 = 0 bytes/sec
        TE class  6 = 0 bytes/sec
        TE class  7 = 0 bytes/sec
      Bandwidth Constraint Model: Prestandard DS-TE RDM
      Bandwidth Constraints:
        BC [ 0] = 0 bytes/sec
        BC [ 1] = 0 bytes/sec
    Type      : Opq-Area
    LS ID     : 7.0.0.0
    Adv Rtr   : 1.1.1.1
    LS age    : 1311
    Len       : 44
    Options   : O E
    Seq#      : 8000012f
    Checksum  : 0xabcf
      Opaque type: 7(Extended prefix)
      Opaque ID: 0
         Extended prefix TLV:
           Length    : 20
           Route type: 1
           AF        : 0
           Flags     : N
           Prefix    : 23.1.1.1/32
           SID sub-TLV:
             Length    : 8
             Flags     : NP/-/E/-/-
             MTID      : 0
             Algorithm : 0
             SID index : 101
           LAN adj sub-TLV:
             Length : 11
             Flags (B/V/L/G/P): 0/1/1/0/0
             MTID   : 0
             Weight : 0
             Neighbor ID: 1.1.1.1
             Label  : 1279
# 显示进程号为1的OSPF进程的链路状态数据库中Type-11 LSA的信息。
<Sysname> display ospf 1 lsdb opaque-as
                 Link State Database
    Type      : Opq-AS
    LS ID     : 7.0.0.1
    Adv Rtr   : 3.3.3.3
    LS Age    : 78
    Len       : 44
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0xc164
      Opaque Type: 7(Extended prefix)
      Opaque ID: 1
          Length    : 20
          Route type: 5
          AF        : 0
          Flags     : -
          Prefix    : 5.5.5.5/32
          SID sub-TLV:
            Length    : 8
            Flags     : NP/-/-/-/-
            MTID      : 0
            Algorithm : 0
            SID index : 50
表1-26 display ospf lsdb opaque-area/opaque-as/opaque-link命令显示信息描述表
LSA类型:
·     Opq-Link:Type-9 LSA,仅在本地链路范围内泛洪
·     Opq-Area:Type-10 LSA,仅在区域内泛洪
·     Opq-AS:Type-11 LSA,可在一个自治系统内泛洪
LS ID
LSA的链路状态ID,由Opaque Type和Opaque ID合并而来。其中,高8位表示Opaque Type,低24位表示Opaque ID
Adv Rtr
发布路由器
Hostname
LSA发布路由器主机名
LS age
LSA的老化时间
Len
LSA的长度
Options
LSA选项,各选项含义如下:
·     E:AS外部LSA的接受能力
·     DC:支持按需链路
·     N:是否支持NSSA外部LSA
Seq#
LSA序列号
Checksum
LSA校验和
Opaque type
Opaque类型:
·     1(Traffic Engineering):用于MPLS TE的Opaque LSA
·     3(Grace LSA):用于GR(Graceful Restart,平滑重启)的Opaque LSA
·     4(Router information):用于通告路由能力的Opaque LSA
·     7(Extended prefix):用于通告SR的SID或MPLS Label的Opaque LSA
·     8(Extended link):用于通告链路扩展信息的Opaque LSA
Opaque ID
Opaque的ID值
GR重启间隔时间,单位为秒
Restart Reason
GR重启的原因:
·     0 - unknown:未知原因
·     1 - software restart:软件重启
·     2 - software reload/upgrade:软件重新加载(升级)
·     3 - switch to redundant control processor:主备倒换
本端建立邻居关系的接口的IP地址
Link Type
链路类型,取值包括:
·     Point to Point:点到点链路
·     Point to Multi Point:点到多点链路
·     Broadcast:广播链路
·     NBMA:非广播多点可达链路
Link ID
链路状态ID
Loacl Interface Address
本地接口的主IP地址
TE Metric
TE度量值
Maximum Bandwidth
链路的最大带宽
链路的最大可预留带宽
链路管理组属性
IGP Metric
IGP开销值
Number of SRLGs
共享风险链路组的个数
·     SRLG [n]:各个共享风险链路组的编号,n表示共享风险链路组的序号,例如,SRLG [1]表示第一个共享风险链路组
每个TE class的未预留带宽:
·     TE class 0-7:8个TE class各自的未预留带宽
宽约束模型,取值包括:
·     Prestandard DS-TE RDM
·     IETF DS-TE RDM
·     IETF DS-TE MAM
带宽约束:
·     BC:各个带宽约束值(Prestandard模式支持2个BC,IETF模式支持4个BC)
MPLS TE Router ID
本节点的LSR ID
路由能力TLV相关信息
·     Length:TLV长度,单位为字节
·     Capabilities:路由能力
¡     All Capability Bits:所有能力比特位,标明设备支持的特性
¡     Graceful restart helper capable:支持GR Restart Helper
¡     Stub router capable:支持Stub Router
¡     Traffic Engineering enabled area:OSPF区域的MPLS TE能力已开启
SR算法TLV
·     Algorithm:前缀关联的算法类型
SR标签范围TLV
·     Range标签范围
·     SID sub-TLV:前缀SID子TLV
¡     Length:TLV长度,单位为字节
¡     Label:最小标签值
SR-MPLS节点MSD(Maximum SID Depths,最大SID深度)TLV相关信息。MPLS MSD表示SR-MPLS能够封装到报文中的SID最大个数
Extended prefix TLV
扩展前缀TLV
·     Route type:前缀来源路由类型
¡     1:Intra-Area
¡     3:Inter-Area
¡     5:Autonnmous System (AS) External
¡     7:Not-So-Stubby Area (NSSA) External
·     AF:地址族
·     Flags:前缀SID标志信息
¡     A:A-Flag (Attach Flag)标志,如果置位,显示为“A”, 表示ABR产生的区域间前缀
¡     N:N-Flag (Node Flag)标志,如果置位,显示为“N”,表示前缀SID为到达某一台SR节点的SID
·     Prefix:前缀信息
·     Length:前缀SID子TLV的长度
·     Flags:前缀SID子TLV携带的标志信息
¡     NP:No-PHP标志,如果置位,显示为“NP”,倒数第二跳不允许弹出前缀SID
¡     E:显式空标志,如果置位,显示为“E”,该SID节点的上游邻居在转发报文前必须将该SID修改为显式空标签
¡     V:Value/Index标志,如果置位,显示为“V”,表明携带的前缀SID是一个绝对值
·     MTID:多拓扑ID,显示为0表示标准拓扑,显示为其他数值表示子拓扑
·     SID index:SID的相对值
LAN adj sub-TLV
用于在LAN网络中通告邻接类型SID(Adjacency SID)的子TLV
·     Length:子TLV长度,单位为字节
·     Flags:标志信息
¡     B:Backup标志,如果置位,表明Adjacency SID用于保护其他节点
¡     V:Value/Index标志,如果置位,显示为“V”,Adjacency SID携带标签值Value
¡     L:Local/Global标志,如果置位,表明Adjacency SID携带的Value/Index具有本地意义
¡     G:Group标志,如果置位,表明表示Adjacency SID代表一个Adjacency组
¡     P:Persistent标志,如果置位,表明该ADJ-SID永久有效
·     Weight:权重
·     Neighbor ID:邻居的Router ID
·     Label:标签值
SR Link Maximum SID Depths
SR-MPLS链路MSD(Maximum SID Depths,最大SID深度)TLV相关信息。MPLS MSD表示SR-MPLS能够封装到报文中的SID最大个数
1.1.26  display ospf nexthop
display ospf nexthop命令用来显示进程中的下一跳信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的下一跳信息。
# 显示OSPF路由下一跳信息。
<Sysname> display ospf nexthop
                  Neighbor Nexthop Information
 NbrID           Nexthop         Interface                RefCount   Status
 192.168.12.1    0.0.0.0         XGE0/0/7                 4          Valid
 192.168.12.2    192.168.12.2    XGE0/0/7                 3          Valid
 192.168.12.1    0.0.0.0         Loop100                  1          Valid
表1-27 display ospf nexthop命令显示信息描述表
NbrID
邻居路由器ID
Nexthop
下一跳地址
出接口
RefCount
该下一跳被引用次数
Status
该下一跳状态:
·     Valid:生效
·     Invalid:未生效
·     Valid-SR:下一跳类型为SR隧道,且该SR隧道已生效
·     Invalid-SR:下一跳类型为SR隧道,该SR隧道未生效
1.1.27  display ospf non-stop-routing status
display ospf non-stop-routing status命令用来显示OSPF的NSR阶段信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的NSR阶段信息。
# 显示OSPF的NSR阶段信息。
<Sysname> display ospf non-stop-routing status
                   OSPF Process 1 with Router ID 192.168.33.12
                          Non Stop Routing information
Non Stop Routing capability : Enabled
Upgrade phase : Normal
表1-28 display ospf non-stop-routing status命令显示信息描述表
是否使能NSR功能,其中:
·     Enabled:使能NSR
·     Disabled:不使能NSR
Upgrade phase
升级的各个阶段:
·     Prepare:升级准备阶段
·     Restore Smooth:升级数据平滑阶段
·     Preroute:路由计算预处理阶段
·     Calculating:路由计算阶段
·     Redisting:路由引入阶段
·     Original and age:LSA生成和老化阶段
·     Normal:普通状态
1.1.28  display ospf peer
display ospf peer命令用来显示OSPF中各区域邻居的信息。
display ospf [ process-id ] peer [ hello | verbose ] [ interface-type interface-number ] [ [ neighbor-id ] [ resolve-hostname ] | hostname host-name ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的各区域邻居的信息。
hello:显示发送给邻居路由器或从邻居路由器收到Hello报文的信息。以组播形式发送Hello报文的场景中,仅显示从邻居路由器接收Hello报文的信息。
verbose:显示OSPF各区域邻居的详细信息。如果未指定本参数,将显示OSPF进程各区域邻居的概要信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的OSPF邻居的信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的OSPF邻居的信息。
resolve-hostname:显示邻居路由器信息,且可以解析其中包含的主机名。如果未指定本参数,将无法解析邻居路由器信息中包含的主机名。
hostname host-name:邻居路由器的主机名,取值范围为1~255个字符的字符串,区分大小写。如果未指定本参数,将显示所有邻居路由器的OSPF邻居的信息。
# 显示发送给邻居路由器以及从邻居路由器收到Hello报文的详细信息。
<Sysname> display ospf peer hello
                  Neighbors
 Area 0.0.0.0 interface 1.1.1.1(Ten-GigabitEthernet0/0/6)'s neighbors
 Router ID: 1.1.1.2          Address: 1.1.1.2
   2019-02-06 09:12:10:121
   2019-02-06 09:12:20:121
   2019-02-06 09:12:30:121
   2019-02-06 09:12:40:121
 Last 4 hello packets received:
   2019-02-06 09:12:12:121, failed, errno:132
   2019-02-06 09:12:22:121, succeeded
   2019-02-06 09:12:32:121, succeeded
   2019-02-06 09:12:42:121, succeeded
   2019-02-06 11:15:12:121, succeeded
   2019-02-06 11:15:22:121, succeeded
   2019-02-06 11:15:32:121, failed, errno:132
   2019-02-06 11:15:42:121, failed, errno:132
表1-29 display ospf peer hello命令显示信息描述表
Router ID
邻居路由器的Router ID
Address
邻居接口的IP地址
最先收到邻居发送的4个Hello报文的时间
最近收到邻居发送的4个Hello报文的时间
最先发送给邻居的4个Hello报文的时间,以及报文是否发送成功的信息(以组播形式发送Hello报文的场景中,不显示该字段):
·     succeeded:发送成功
·     failed:发送失败
¡     12:ENOMEM,内存不足
执行本命令时,最近发送给邻居的4个Hello报文的时间,以及报文是否发送成功的信息(以组播形式发送Hello报文的场景中,不显示该字段):
·     succeeded:发送成功
·     failed:发送失败
¡     12:ENOMEM,内存不足
# 显示OSPF邻居详细信息。
<Sysname> display ospf peer verbose
                  Neighbors
 Router ID: 1.1.1.2          Address: 1.1.1.2          GR state: Normal
   DR: 1.1.1.2  BDR: 1.1.1.1  MTU: 0
   Dead timer due in 33  sec
   Neighbor is up for 02:03:35
   Authentication sequence: [ 0 ]
   BFD status: Disabled
 Last Neighbor Down Event:
 Router ID: 22.22.22.22
 Local Address: 11.11.11.11
 Remote Address: 22.22.22.22
 Time: Apr  9 03:18:19 2019
 Reason: Ospf_ifachange
# 显示邻居路由器的详细信息,并解析其中的主机名。
<Sysname> display ospf peer verbose resolve-hostname
 Area 0.0.0.1 interface 1.1.1.2(Ten-GigabitEthernet0/0/6)'s neighbors
 Router ID: 3.3.3.3          Address: 13.1.1.2          GR state: Normal
   Hostname: RouterA
   State: Full  Mode: Nbr is slave  Priority: 1
   DR: 13.1.1.2  BDR: 13.1.1.1  MTU: 0
   Options is 0x42 (-|O|-|-|-|-|E|-)
   Dead timer due in 31 sec
   Neighbor is up for 00:04:42
   Neighbor state change count: 5
 Router ID: 3.3.3.3
 Local Address: 13.1.1.1
 Remote Address: 13.1.1.2
 Time: Jun 15 16:13:29 2019
 Reason: Reset ospf command was performed
表1-30 display ospf peer verbose命令显示信息描述表
Area areaID interface IPAddress(InterfaceName)'s neighbors
显示接口在指定区域邻居信息,其中:
·     areaID:表示邻居所属的区域
·     IPAddress:表示接口IP地址
·     InterfaceName:表示接口名称
Router ID
邻居路由器ID
Address
邻居接口地址
GR state
GR状态,取值为:
·     Normal:普通状态
·     Restarter:正在作为GR Restarter
·     Complete:GR完成
·     Helper:正在作为GR Helper
Hostname
邻居路由器主机名
邻居状态,取值为:
·     Down表示邻居关系的初始状态
·     Init表示在邻居失效时间内收到来自邻居路由器的Hello报文,但该Hello数据包内没有包含自己的Router ID,双向通信还没有建立起来
·     Attempt该状态仅对NBMA网络上的邻居有效,表示最近没有从邻居收到信息,但仍需作出进一步的尝试,用以与邻居联系
·     2-Way表示双向通信已经建立,在从邻居路由器收到的Hello报文中看到了自己的Router ID
·     Exstart表示路由器和邻居建立主/从关系、确定初始DD报文的序列号,为交换DD报文做好准备
·     Exchange表示路由器向其邻居发送描述自己LSDB的DD报文
·     Loading表示路由器向邻居发送链路状态请求报文,请求最新的LSA
·     Full表示路由器与邻居路由器之间建立起完全邻接关系
Mode
路由器在数据库同步阶段,路由器与邻居协商的主从关系,取值为:
·     Nbr is master表示邻居路由器为主路由器
·     Nbr is slave表示邻居路由器为从路由器
Priority
邻居路由器优先级
DR
接口所属网段的DR
BDR
接口所属网段的BDR
MTU
接口MTU的值
Options
邻居的LSA选项,各选项含义如下:
·     E:AS外部LSA的接受能力
·     DC:支持按需链路
·     N:是否支持NSSA外部LSA
邻居将在33秒后被认为不可达
与邻居建立的时长02:03:35
验证序列号
邻居状态发生改变的次数
BFD status
BFD状态,各状态含义如下:
·     Disabled:未使能BFD
·     Enabled (Control mode):已使能BFD,并处于控制模式
·     Enabled (Echo mode):已使能BFD,并处于回应模式
Adjacency SID
邻接链路通告的SID
最后一次邻居down事件
Local Address
本端IP地址
Remote Address
对端IP地址
Time
邻居down的时间,格式为MM DD,hh:mm:ss YYYY,其中MM为月,DD为日,hh为小时,mm为分钟,ss为秒,YYYY为年
Reason
邻居down的原因,取值包括:
·     Ospf_resetconnect:内存不足,邻居关系断开
·     Ospf Interface Parameters Changed:OSPF接口参数的配置发生变化
·     VLINK Interface Parameters Changed:虚连接接口参数的配置发生变化
·     SHAMLINK Interface Parameters Changed:伪连接接口参数的配置发生变化
·     Reset ospf command was performed:执行了reset ospf process命令
·     Undo ospf command was performed:执行了undo ospf命令
·     Undo area command was performed:执行了undo area命令
·     Undo network:执行了undo network命令
·     Silent Interface:执行了silent interface命令
·     Ospf_iflchange:接口逻辑属性变化
·     Ospf_ifachange:接口物理属性变化
·     Ospf_ifvchange:接口vlink属性变化
·     Vlink down:虚连接接口down
·     Shamlink down:伪连接接口down
·     DeadInterval timer expired:Dead定时器超时
·     Configuring stub area:Stub区域配置变化
·     Configuring nssa area:NSSA区域配置变化
·     Area Authentication-mode changed:区域验证模式变化
·     Opaque-Capability changed:Opaque LSA发布接收能力的开启/关闭状态发生变化
·     Too many retransmissions:重传过多
·     Link-local-Signaling Capability changed:本地链路的信令能力的开启/关闭状态发生变化
·     Out-Of-Band Resynchronazition Capability changed:OSPF带外同步能力的开启/关闭状态发生变化
·     Graceful-Restart Capability changed:GR能力的配置发生变化
·     BFD session down:OSPF联动的BFD会话down
·     Database-filter or referenced ACL changed:指定接口对发送给邻居的LSA进行过滤的配置发生变化,或者该配置引用的ACL规则改变
# 显示OSPF邻居概要信息。
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 1.1.1.2         1.1.1.2         1   40         Full/DR           XGE0/0/6
 Sham link: 11.11.11.11 -> 22.22.22.22
 22.22.22.22     22.22.22.22     1   36         Full
# 显示OSPF邻居概要信息,并解析其中的主机名。
<Sysname> display ospf peer resolve-hostname
 Area: 0.0.0.0
 RouterA         1.1.1.2         1   34         Full/DR           XGE0/0/6
表1-31 display ospf peer命令显示信息描述表
Area
邻居所属的区域
Router ID
邻居路由器ID或邻居路由器主机名
Address
邻居接口IP地址
Pri
邻居路由器优先级
Dead-Time
OSPF的邻居失效时间
与邻居相连的接口
邻居状态(Down、Init、Attempt、2-Way、Exstart、Exchange、Loading、Full)
Sham link 11.11.11.11 -> 22.22.22.22
源地址为11.11.11.11、目的地址为22.22.22.22的伪连接
1.1.29  display ospf peer statistics
display ospf peer statistics命令用来显示本地路由器所有OSPF邻居的统计信息,即处于各种状态的邻居数目。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的邻居统计信息。
# 显示所有OSPF邻居的统计信息。
<Sysname> display ospf peer statistics
                    Neighbor Statistics
  Area ID         Down Attempt Init 2-Way ExStart Exchange Loading Full Total
  0.0.0.0         0    0       0    0     0       0        0       1    1
  0.0.0.2         0    0       0    0     0       0        0       1    1
  Total           0    0       0    0     0       0        0       2    2
  Sham links' neighbors (Total: 1):
    Down: 0, Init: 0, 2-Way: 0, ExStart: 0, Exchange: 0, Loading: 0, Full: 1
表1-32 display ospf peer statistics命令显示信息描述表
Area ID
区域ID,显示当前路由器位于该区域所有邻居路由器的状态统计信息
Down
同一个区域内状态为Down的邻居路由器数目
Attempt
同一个区域内状态为Attempt的邻居路由器数目
Init
同一个区域内状态为Init的邻居路由器数目
2-Way
同一个区域内状态为2-Way的邻居路由器数目
ExStart
同一个区域内状态为ExStart的邻居路由器数目
Exchange
同一个区域内状态为Exchange的邻居路由器数目
Loading
同一个区域内状态为Loading的邻居路由器数目
Full
同一个区域内状态为Full的邻居路由器数目
Total
处于各种状态(Down/Attempt/Init/2-Way/ExStart/Exchange/Loading/Full)邻居路由器的总和
sham-link邻居统计信息
1.1.30  display ospf request-queue
display ospf request-queue命令用来显示OSPF的请求列表信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的请求列表信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的请求列表信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的请求列表信息。
# 显示OSPF请求列表信息。
<Sysname> display ospf request-queue
          OSPF Process 100 with Router ID 192.168.1.59
                  Link State Request List
  The Router's Neighbor is Router ID 2.2.2.2         Address 10.1.1.2
  Interface 10.1.1.1         Area 0.0.0.0
  Request list:
       Type       LinkState ID      AdvRouter         Sequence   Age
       Router     2.2.2.2           1.1.1.1           80000004   1
       Network    192.168.0.1       1.1.1.1           80000003   1
       Sum-Net    192.168.1.0       1.1.1.1           80000002   2
表1-33 display ospf request-queue命令显示信息描述表
邻居路由器的Router ID
Address
邻居接口IP地址
本地接口IP地址
Area
区域ID
Request list
请求列表信息
LSA类型
LinkState ID
链路状态ID
AdvRouter
发布路由器的Router ID
Sequence
LSA的序列号
Age
LSA的老化时间
1.1.31  display ospf retrans-queue
display ospf retrans-queue命令用来显示OSPF的重传列表信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的重传列表信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的重传列表信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的重传列表信息。
# 显示OSPF重传列表信息。
<Sysname> display ospf retrans-queue
                  Link State Retransmission List
  The Router's Neighbor is Router ID 192.168.1.111   Address 111.1.1.1
  Interface 111.1.1.2        Area 0.0.0.1
  Retransmit list:
       Router     2.2.2.2           2.2.2.2           80000004   1
       Network    12.18.0.1         2.2.2.2           80000003   1
       Sum-Net    12.18.1.0         2.2.2.2           80000002   2
表1-34 display ospf retrans-queue命令显示信息描述表
邻居路由器ID
Address
邻居接口IP地址
本地接口IP地址
Area
区域ID
Retransmit list
重传列表信息
LSA类型
LinkState ID
链路状态ID
AdvRouter
发布路由器的Router ID
Sequence
LSA的序列号
Age
LSA的老化时间
1.1.32  display ospf routing
display ospf routing命令用来显示OSPF路由表的信息。
display ospf [ process-id ] routing [ ip-address { mask-length | mask } ] [ interface interface-type interface-number ] [ nexthop nexthop-address ] [ verbose ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的路由表信息。
ip-address:路由的目的IP地址。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
interface interface-type interface-number:显示指定出接口的路由信息。interface-type interface-number为接口类型和编号。如果未指定本参数,将显示所有接口的路由表信息。
nexthop nexthop-address:显示指定下一跳IP地址的路由信息。如果未指定本参数,将显示所有的OSPF路由表信息。
verbose:显示路由表详细信息。如果未指定本参数,将显示路由表的概要信息。
# 显示OSPF路由表的信息。
<Sysname> display ospf routing
                   Routing Table
 Routing for network
 192.168.1.0/24     1562     Stub    192.168.1.2     192.168.1.2     0.0.0.0
 172.16.0.0/16      1563     Inter   192.168.1.1     192.168.1.1     0.0.0.0
 Total nets: 2
 Intra area: 1  Inter area: 1  ASE: 0  NSSA: 0
表1-35 display ospf routing命令显示信息描述表
Topology
MTID
Destination
目的网络
Cost
到达目的地址的开销
NextHop
下一跳地址
AdvRouter
发布路由器
Area
区域ID
Total nets
区域内部、区域间、ASE和NSSA区域的路由总数
Intra area
区域内部路由总数
Inter area
区域间路由总数
ASE
OSPF区域外路由总数
NSSA
NSSA区域路由总数
# 显示OSPF路由表的详细信息。
<Sysname> display ospf routing verbose
          OSPF Process 2 with Router ID 192.168.1.112
                   Routing Table
 Routing for network
 Destination: 192.168.1.0/24
    Priority: Low                     Type: Stub
   AdvRouter: 192.168.1.2             Area: 0.0.0.0
  SubProtoID: 0x1               Preference: 10
     NextHop: 192.168.1.2        BkNextHop: N/A
      IfType: Broadcast           BkIfType: N/A
   Interface: XGE0/0/7         BkInterface: N/A
       NibID: 0x1300000c            Status: Normal
        Cost: 1562
      InLabel: 4294967295       Tunnel type: -
     OutLabel: 4294967295     OutLabel flag: -
   BkOutLabel: 4294967295   BkOutLabel flag: -
     LabelSrc: N/A               Delay Flag: -
 Destination: 172.16.0.0/16
    Priority: Low                     Type: Inter
   AdvRouter: 192.168.1.1             Area: 0.0.0.0
     NextHop: 192.168.1.1        BkNextHop: N/A
   Interface: XGE0/0/8         BkInterface: N/A
        Cost: 1563                 SpfCost: 65535
 Total nets: 2
 Intra area: 2  Inter area: 0  ASE: 0  NSSA: 0
表1-36 display ospf routing verbose命令显示信息描述表
Topology
MTID
Priority
前缀优先级,取值为:Critical、High、Medium和Low
AdvRouter
发布路由器
Area
区域ID
SubProtoID
子协议ID
Preference
OSPF路由优先级
NextHop
主下一跳IP地址
BkNextHop
备份下一跳IP地址
IfType
路由主下一跳网络类型
BkIfType
路由备份下一跳网络类型
路由出接口
BkInterface
路由备份出接口
NibID
路由下一跳信息的ID值
Status
路由状态,具体如下:
·     Local:该条路由在本地,未发送给路由管理模块
·     Invalid:路由下一跳无效
·     Stale:该路由下一跳较旧
·     Normal:正常可用状态
·     Delete:处于删除状态
·     Host-Adv:该条路由为主机路由
·     Rely:该条路由为迭代路由
Cost
到达目的地址的开销
SpfCost
SPF开销
InLabel
路由入标签。取值为4294967295表示无效的路由入标签
Tunnel type
隧道类型,目前取值只能为SR,表示SR隧道
OutLabel
路由出标签。取值为4294967295表示无效的路由出标签
OutLabel flag
出标签标志位
·     E:显式空标志,如果置位,显示为“E”,则该SID节点的上游邻居在转发报文前必须将该SID修改为显式空标签
·     I:隐式空标志,如果置位,显示为“I”,则该SID节点的上游邻居在转发报文前必须将该SID修改为隐式空标签(暂不支持)
·     N:普通标志
·     P:SR标签优先标志
BkOutLabel
路由备份出标签。取值为4294967295表示无效的路由备份出标签
BkOutLabel flag
备份出标签标志位
·     N:普通标志
·     P:SR标签优先标志
LabelSrc
标签来源:
·     SR:SR节点分配
·     SRMS:SR映射服务器发布
DelayFlag
正切防微环延迟标志位:
·     D:表示配置正切防微环功能后,路由处于延迟发送RIB的状态
·     -:未配置正切防微环功能或者达到正切防微环延迟时间时,路由处于正常发送RIB的状态
MALsIndex
SR防微环标签栈索引
MALabelStack
Remote LFA备份信息
PQPrefix
PQ节点前缀
PQAdvID
PQ节点通告路由器ID
LsIndex
标签栈索引
LabelStack
标签栈
TI-LFA backup info
TI-LFA备份信息
PNodePrefix
P节点前缀
QNodeAdvID
Q节点通告路由器ID
1.1.33  display ospf spf-tree
display ospf spf-tree命令用来显示OSPF区域的最短路径树信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程下区域的最短路径树信息。
area area-id:显示指定OSPF区域的最短路径树信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。如果未指定本参数,将显示所有区域的最短路径树信息。
verbose:显示OSPF区域的最短路径树的详细信息。如果未指定本参数,将显示OSPF区域的最短路径树的概要信息。
# 显示进程1下区域0的最短路径树信息。
<Sysname> display ospf 1 area 0 spf-tree
          OSPF Process 1 with Router ID 100.0.0.4
        Flags: S-Node is on SPF tree       R-Node is directly reachable
               I-Node or Link is init      D-Node or Link is to be deleted
               P-Neighbor is parent        A-Node is in candidate list
               C-Neighbor is child         T-Node is tunnel destination
               H-Nexthop changed           N-Link is a new path
               V-Link is involved          G-Link is in change list
                  Area: 0.0.0.0  Shortest Path Tree
 SpfNode         Type    Flag      SpfLink         Type   Cost  Flag
>192.168.119.130 Network S R
                                -->114.114.114.111 NET2RT 0     C
                                -->100.0.0.4       NET2RT 0     P
>114.114.114.111 Router  S
                                -->192.168.119.130 RT2NET 65535 P
>100.0.0.4       Router  S
                                -->192.168.119.130 RT2NET 10    C
表1-37 display ospf spf-tree命令显示信息描述表
Topology
MTID
SpfNode
SPF节点,若节点类型为路由器,则为路由器ID;若节点类型为网络,则为该网络DR接口IP地址。其中,Type为节点类型:
·     Network:表示网络节点
·     Router:表示路由器节点
Flag为节点标志:
·     I:节点处于初始化状态
·     A:节点在候选列表上
·     S:节点在SPF树上
·     R:该节点与根节点直连
·     D:该节点将被删除
·     T:该节点为隧道的终点‌
SpfLink
SPF链路,其值表示对端节点。其中,Cost为链路开销,Type为链路类型:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
Flag为链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     V:目的节点删除或者是新增节点时,链路的目的节点不在SPF树上或处于删除状态
·     N:新增链路,并且源节点和目的节点都在SPF树上
·     G:链路在区域变化列表中
# 显示进程1下区域0的最短路径树详细信息。
<Sysname> display ospf 1 area 0 spf-tree verbose
>LsId(192.168.119.130)
 AdvId    : 100.0.0.4       NodeType     : Network
 Mask     : 255.255.255.0   SPFLinkCnt   : 2
 Distance : 10
 VlinkData: 0.0.0.0         ParentLinkCnt: 1           NodeFlag: S R
 NextHop  : 1
   192.168.119.130    Interface: XGE0/0/7
 BkNextHop: 1
   0.0.0.0            Interface: XGE0/0/7
 -->LinkId(114.114.114.111)
    AdvId   : 100.0.0.4       LinkType   : NET2RT
    LsId    : 192.168.119.130 LinkCost   : 0           NextHopCnt: 1
    LinkData: 0.0.0.0         LinkNewCost: 0           LinkFlag  : C
 -->LinkId(100.0.0.4)
    LinkData: 0.0.0.0         LinkNewCost: 0           LinkFlag  : P
表1-38 display ospf spf-tree verbose命令显示信息描述表
Topology
MTID
LsId
链路状态ID
AdvId
通告路由器ID
NodeType
节点类型,其中:
·     Network:表示网络节点
·     Router:表示路由器节点
Mask
网络掩码,若为路由器节点掩码为0
SPFLinkCnt
SPF链路个数
Distance
表示到根节点的开销
VlinkData
Vlink报文的目的地址
ParentLinkCnt
父链路个数
NodeFlag
节点标志:
·     I:节点处于初始化状态
·     A:节点在候选列表上
·     S:节点在SPF树上
·     R:该节点与根节点直连
·     D:该节点将被删除
·     T:该节点为隧道的终点‌
NextHop
下一跳信息
出接口
BkNextHop
备份下一跳信息
MADuration
SR防微环持续时间,单位为毫秒
MALStack
BkNextHop
备份下一跳信息
Flag
标识下一跳的类型,SR表示为SR隧道,其他类型显示为“-”
Remote-LFA
Remote LFA备份信息
RLFAAdvId
Remote LFA备份下一跳邻居节点的Router ID
RLFAaInterface
Remote LFA备份下一跳出接口
RLFaNexthop
Remote LFA备份下一跳信息
PQNode AdvID
PQ节点的Router ID
PQNode prefix
PQ节点前缀
TI-LFA
TI-LFA信息
TiLfaAdvId
TI-LFA通告路由器ID
TiLfaInterface
TI-LFA接口
TiLfaNexthop
TI-LFA下一跳地址
PNode AdvID
P节点通告路由器ID
QNode AdvID
Q节点通告路由器ID
PNode prefix
P节点前缀
PNode SidIndex
P节点SID索引
Protect
保护类型:
·     Link:链路保护
·     Node:节点保护
Label stack
标签栈
LinkId
链路ID
LinkType
链路类型,其中:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
LinkCost
当前链路开销
NextHopCnt
下一跳个数
LinkData
链路数据
LinkNewCost
新的链路开销
LinkFlag
链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     G:链路在区域变化列表中
1.1.34  display ospf statistics
display ospf statistics命令用来显示OSPF的统计信息。
display ospf [ process-id ] statistics [ error | packet [ hello | interface-type interface-number ] ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的统计信息。
error:显示错误统计信息。如果未指定本参数,将显示OSPF进程的报文、LSA和路由的统计信息。
packet:显示OSPF的报文统计信息。
hello:显示接收和发送Hello报文的统计信息。如果未指定本参数,将显示接收和发送所有类型的OSPF协议报文的统计信息。
interface-type interface-number:接口类型和编号。显示指定接口的统计信息。如果未指定本参数,将显示所有接口的统计信息。
# 显示OSPF进程的统计信息。
<Sysname> display ospf statistics
                  Statistics
 I/O statistics
  Type                      Input     Output
  Hello                     61        122
  DB Description            2          3
  Link-State Req            1          1
  Link-State Update         3          3
  Link-State Ack            3          2
 LSAs originated by this router
  Router  : 4
  Network : 0
  Sum-Net : 0
  Sum-Asbr: 0
  External: 0
  NSSA    : 0
  Opq-Link: 0
  Opq-Area: 0
  Opq-As  : 0
 LSAs originated: 4  LSAs received: 7
 Routing table:
   Intra area: 2  Inter area: 3  ASE/NSSA: 0
表1-39 display ospf statistics命令显示信息描述表
I/O statistics
收发的报文和LSA的详细统计信息
OSPF报文类型
Input
接收报文数
Output
发送报文数
Hello
OSPF Hello报文
DB Description
OSPF数据库描述报文
Link-State Req
OSPF链路状态请求报文
Link-State Update
OSPF链路状态更新报文
Link-State Ack
OSPF链路状态确认报文
本路由器发布LSA的详细统计信息
Router
生成Type-1 LSA的数目
Network
生成Type-2 LSA的数目
Sum-Net
生成Type-3 LSA的数目
Sum-Asbr
生成Type-4 LSA的数目
External
生成Type-5 LSA的数目
NSSA
生成Type-7 LSA的数目
Opq-Link
生成Type-9 LSA的数目
Opq-Area
生成Type-10 LSA的数目
Opq-As
生成Type-11 LSA的数目
LSA originated
生成的LSA的总数
LSA received
接收的LSA的总数
Routing table
路由表信息
Intra area
区域内路由的数量
Inter area
区域间路由的数量
ASE/NSSA
自治系统外部/NSSA区域路由的数量
# 显示OSPF进程的错误统计信息。
<Sysname> display ospf statistics error
                  OSPF Packet Error Statistics
 0         : Router ID confusion         0         : Bad packet
 0         : Bad version                 0         : Bad checksum
 0         : Bad area ID                 0         : Drop on unnumbered link
 0         : Bad virtual link            0         : Bad authentication type
 0         : Bad authentication key      0         : Packet too small
 0         : Neighbor state low          0         : Transmit error
 0         : Interface down              0         : Unknown neighbor
 0         : HELLO: Netmask mismatch     0         : HELLO: Hello-time mismatch
 0         : HELLO: Dead-time mismatch   0         : HELLO: Ebit option mismatch
 0         : HELLO: Mbit option mismatch 0         : DD: MTU option mismatch
 0         : DD: Unknown LSA type        0         : DD: Ebit option mismatch
 0         : ACK: Bad ack                0         : ACK: Unknown LSA type
 0         : REQ: Empty request          0         : REQ: Bad request
 0         : UPD: LSA checksum bad       0         : UPD: Unknown LSA type
 0         : UPD: Less recent LSA
表1-40 display ospf statistics error命令显示信息描述表
Router ID confusion
含有重复路由器ID的OSPF报文数
Bad packet
非法的OSPF报文数
Bad version
错误版本号的OSPF报文数
Bad checksum
校验和出错的OSPF报文数
Bad area ID
非法的区域ID的OSPF报文数
在地址借用链路上丢弃的OSPF报文数
Bad virtual link
错误的虚链路的OSPF报文数
含有非法验证类型的OSPF报文数
含有错误验证码的OSPF报文数
Packet too small
报文长度太小的OSPF报文数
Neighbor state low
在低邻居状态收到的OSPF报文数
Transmit error
传输出错的OSPF报文数
Interface down
接口down的计数
Unknown neighbor
未知的邻居发来的OSPF报文数
网络掩码不匹配的Hello报文数
Hello定时器不匹配的Hello报文数
Dead定时器不匹配的Hello报文数
Option字段E位不匹配的Hello报文数
Option字段M位不匹配的Hello报文数
MTU不匹配的DD报文数
DD报文中描述未知类型LSA数目
Option字段E位不匹配的DD报文数
ACK: Bad ack
收到不匹配的ack数目
收到LSA类型未知的ack数目
REQ: Empty request
不含有任何请求信息的LSR报文数
REQ: Bad request
请求错误LSA的LSR报文数
LSU报文中LSA校验和出错的LSA数目
LSU报文中含有未知类型LSA数目
LSU报文中含有不是最新的LSA数目
# 显示OSPF进程和接口的报文统计信息。
<Sysname> display ospf statistics packet
                  Packet Statistics
 Waiting to send packet count: 0
         Hello      DD         LSR        LSU        ACK        Total
 Input : 489        6          2          44         40         581
 Output: 492        8          2          45         40         587
 Area: 0.0.0.1
 Interface: 20.1.1.1 (Ten-GigabitEthernet0/0/6)
 Input : 0          0          0          0          0
 Output: 0          0          0          0          0
 Interface: 100.1.1.1 (Ten-GigabitEthernet0/0/7)
 Input : 3          1          22         16         42
 Output: 2          1          19         20         42
表1-41 display ospf statistics packet命令显示信息描述表
等待发送报文数
Hello
Hello报文
DD
数据库描述报文
LSR
链路状态请求报文
LSU
链路状态更新报文
ACK
链路状态确认报文
Total
报文总数
Input
接收报文数
Output
发送报文数
Area
区域ID
接口地址和接口名
# 显示OSPF 接收和发送Hello报文的统计信息。
<Sysname> display ospf statistics packet hello
                  Hello statistics
   Total sent                             : 201
   Total sent failed                      : 0
   Sent after one and a half intervals    : 0
   Total received                         : 221
   Total received dropped                 : 0
   Received after one and a half intervals: 0
表1-42 display ospf peer hello命令显示信息描述表
Total sent
发送Hello报文的总数
Total sent failed
发送Hello报文失败的总数
发送Hello报文的时间间隔超过1.5倍Hello定时器的报文总数
Total received
接收Hello报文的总数
丢弃接收到的Hello报文总数
接收Hello报文的时间间隔超过1.5倍Hello定时器的报文总数
·     reset ospf statistics
1.1.35  display ospf troubleshooting
display ospf troubleshooting命令用来显示OSPF邻居关系断开的故障检测信息。
# 显示OSPF邻居关系断开的故障检测信息。
<Sysname> display ospf troubleshooting
                 OSPF troubleshooting Information
Total count: 3
Time                  Sequence  Description
2019-09-04 12:01:07   3         The state of OSPF 1 peer 12.1.1.2 changed to DOWN because OSPF interface parameters changed. Please check the interface parameters (Interface: XGE0/0/6, peer address: 12.1.1.2).
2019-09-04 11:54:19   2         The state of OSPF 1 peer 12.1.1.2 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: XGE0/0/6, peer address: 12.1.1.2; ping result: ping was not executed because of the disabled MTP; CPU usage: 29.0%; memory usage: 76.81%, memory state: normal).
2019-09-04 11:48:25   1         The state of OSPF 1 peer 12.1.1.2 changed to INIT because a 1-way hello packet was received. Please check the OSPF peer state on the remote end. (Interface: XGE0/0/6, peer address: 12.1.1.2).
表1-43 display ospf troubleshooting命令显示信息描述表
Total count
OSPF troubleshooting信息记录条数
Time
OSPF邻居断开时间。显示顺序为从新到旧
Sequence
OSPF邻居关系故障检测信息序号
OSPF邻居断开的故障检测信息:OSPF进程号、邻居ID、断开原因以及操作建议
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because OSPF interface parameters changed. Please check the interface parameters (Interface: XGE0/0/6, peer address: 10.1.1.1).:OSPF接口参数改变导致邻居关系断开。请检查接口参数
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the OSPF process was reset:重启OSPF进程导致邻居关系断开
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the OSPF process was deleted:删除OSPF进程导致邻居关系断开
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the OSPF area was deleted:删除OSPF区域导致邻居关系断开
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because OSPF was disabled (Interface: XGE0/0/6, peer address: 10.1.1.1).:关闭指定网段接口上的OSPF功能导致邻居关系断开。
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because OSPF packet receiving and sending are disabled (Interface: XGE0/0/6, peer address: 10.1.1.1).:接口禁止收发OSPF报文导致邻居关系断开
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the interface address was deleted or OSPF was disabled on interface. Please check the interface settings (Interface: XGE0/0/6, peer address: 10.1.1.1).:删除接口地址或者在接口上关闭OSPF导致邻居关系断开。请检查接口配置
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the interface went down or MTU changed. Please check the interface state and MTU settings (Interface: XGE0/0/6, peer address: 10.1.1.1).:接口down或者接口MTU改变导致邻居关系断开。请检查接口状态以及MTU
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the virtual link was deleted or the route it relies on was deleted. Please check the virtual link and the route it relies on (Interface: XGE0/0/6, peer address: 10.1.1.1).:虚连接删除或者其依赖的路由删除导致邻居关系断开。请检查虚连接配置以及其依赖的路由
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the virtual link interface went down or the virtual link settings were deleted. Please check the virtual link and the route it relies on (Interface: XGE0/0/6, peer address: 10.1.1.1).:虚连接接口down或者删除虚连接配置导致邻居关系断开。请检查虚连接配置以及其依赖的路由
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the sham link was deleted or the route it relies on was deleted. Please check the sham link and the route it relies on (Interface: XGE0/0/6, peer address: 10.1.1.1).:删除伪连接或者其依赖的路由删除导致邻居关系断开。请检查伪连接配置以及其依赖的路由
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: XGE0/0/6, peer address: 10.1.1.1; ping result: 5 packets in total, 5 packets timed out; CPU usage: 25.37%; memory usage: 36.49%, memory state: normal).:Dead定时器超时导致OSPF邻居关系断开。请检查与邻居的连接情况
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: XGE0/0/6, peer address: 10.1.1.1; ping result: ping was not executed because of the disabled MTP; CPU usage: 25.37%; memory usage: 36.49%, memory state: normal),:Dead定时器超时导致OSPF邻居关系断开。请检查与邻居的连接情况
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: XGE0/0/6, peer address: 10.1.1.1; ping result: waitting for the ping to execute; CPU usage: 25.37%; memory usage: 36.49%, memory state: normal).:Dead定时器超时导致OSPF邻居关系断开。请检查与邻居的连接情况
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the stub configuration changed in area 0.0.0.1.:Stub区域配置变化导致邻居关系断开
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the NSSA configuration changed in area 0.0.0.1.:NSSA区域配置变化导致邻居关系断开
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the Opaque LSA capability configuration changed.:Opaque LSA发布接收能力配置改变导致邻居关系断开
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the out-of-band resynchronization capability configuration changed.:OSPF带外同步能力配置改变导致邻居关系断开
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the BFD session went down. Please check the BFD session information.:BFD会话Down导致OSPF邻居关系断开。请检查BFD会话信息
·     The state of OSPF 1 peer 1.1.1.1 changed to INIT because a 1-way hello packet was received. Please check the OSPF peer state on the remote end. (Interface: XGE0/0/6, peer address: 10.1.1.1):接收到1-way的Hello报文导致邻居状态变为Init。请检查对端设备上的OSPF邻居状态
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because database-filter configuration changed or database-filter ACL configuration changed. Please check the OSPF database-filter and its ACL configuration (Interface: XGE0/0/6, peer address: 10.1.1.1).:对发送给指定邻居的LSA进行过滤的配置发生变化或者该配置引用的ACL规则改变导致邻居关系断开。请检查对发送给指定邻居的LSA进行过滤的配置及其引用的ACL
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a BadLSReq event was triggered upon the request for a nonexistent LSA. Please check the local OSPF LSDB and the OSPF request queue on the remote end (Interface: XGE0/0/6, peer address: 10.1.1.1, LSA type: 5, LSID: 91.1.1.0, AdvRouter: 5.5.5.5).:由于收到的LSR报文请求的是本地并不存在的LSA,触发了BadLSReq事件导致邻居状态变为Exstart。请检查本地OSPF LSDB以及对端设备的OSPF请求队列
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because the LSA requested and then learned is the same as that in local. Please check the OSPF request queue and the specified LSA on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1; LSA type: 5, LSID: 91.1.1.0, AdvRouter: 5.5.5.5).:本端向对端请求更新一条LSA,对端回复的LSA与本端LSDB中已有的LSA相同,导致邻居状态变为Exstart。请检查OSPF的请求列表信息,以及本地和对端设备的该LSA信息
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because the LSA requested and then learned is older than that in local. Please check the OSPF request queue and the specified LSA on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1; LSA type: 5, LSID: 91.1.1.0, AdvRouter: 5.5.5.5).:本端向对端请求更新一条LSA,对端回复的LSA比本端LSDB中已有的LSA旧,导致邻居状态变为Exstart。请检查对端设备的OSPF邻居状态,以及本地和对端设备的该LSA信息
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a non-retransmitted DD packet from the Loading or Full peer during the DD retransmit interval. Please check the OSPF peer state and LSDB on the remote end (Interface: XGE0/0/6, peer address: 10.1.1.1).:邻居状态到达Loading或Full,但在DD重传时间间隔内收到了非请求重传的DD报文,触发了SeqNumberMismatch事件导致邻居状态变为Exstart。请检查对端设备的OSPF邻居状态和LSDB
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the change of the OSPF peer’s capability to link-local signaling attribute. Please check the DD packets transmitted on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:接收到邻居发送的DD报文中的L位发生变化,触发了SeqNumberMismatch事件导致邻居状态变为Exstart。请检查两端交互的DD包情况
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the OSPF peer’s multi-topology attribute change. Please check the multi-topology capability configuration on the remote end (Interface: XGE0/0/6, peer address: 10.1.1.1).:邻居支持多拓扑属性发生变化,触发了SeqNumberMismatch事件导致邻居状态变为Exstart。请检对端设备的多拓扑配置
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a retransmitted DD packet from the Loading or Full peer after the DD retransmit interval expired. Please check the OSPF peer state and LSDB on the remote end (Interface: XGE0/0/6, peer address: 10.1.1.1).:邻居状态到达Loading或Full,在DD重传时间间隔超时后又收到了重传的DD报文,触发了SeqNumberMismatch事件导致邻居状态改为Exstart。请检查对端设备的OSPF邻居状态和LSDB
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the change of the OSPF peer’s capability to receive AS external LSA. Please check the area configuration (Interface: XGE0/0/6, peer address: 10.1.1.1).:接收到邻居发送的DD报文中的E位发生变化,触发了SeqNumberMismatch事件导致邻居状态改为Exstart。请检查区域配置
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the master-slave relationship change. Please check the DD packets transmitted on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:与邻居交互的主从关系发生改变,触发了SeqNumberMismatch事件导致邻居关系降为Exstart。请检查两端交互的DD包情况
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of an unexpected initial DD packet after DD transmission started. Please check the DD packets transmitted on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:开始通过DD报文交互DB摘要的时候,收到了初始DD包,触发了SeqNumberMismatch事件导致邻居关系降为Exstart。请检查两端交互的DD包情况
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet with a wrong sequence number from the slave. Please check the DD packets transmitted on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:Master收到Slave发送的序列号错误的DD报文,触发了SeqNumberMismatch事件导致邻居状态变为Exstart。请检查两端交互的DD包情况
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet with a wrong sequence number from the master. Please check the DD packets transmitted on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:Slave接收到Master发送的序列号错误的DD报文中,触发了SeqNumberMismatch事件导致邻居状态变为Exstart。请检查两端交互的DD包情况
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing local opaque LSA without enabling the opaque capability. Please check the specified LSA on the remote end and the opaque capability configuration on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:接收到的DD报文包含了Type-9 LSA,但本地未使能Opaque LSA发布接收能力,触发了SeqNumberMismatch事件导致邻居状态变为Exstart。请在对端上检查该LSA信息,并在两端设备上检查Opaque LSA发布接收能力的配置情况
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing area opaque LSA without enabling the opaque capability. Please check the specified LSA on the remote end and the opaque capability configuration on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:接收到的DD报文包含了Type-10 LSA,但本地未使能Opaque LSA发布接收能力,触发了SeqNumberMismatch事件导致邻居关系降为Exstart。请在对端上检查该LSA信息,并在两端设备上检查Opaque LSA发布接收能力的配置情况
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing AS opaque LSA without enabling the opaque capability. Please check the specified LSA on the remote end and the opaque capability configuration on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:接收到的DD报文包含了Type-11 LSA,但本地未使能Opaque LSA发布接收能力,触发了SeqNumberMismatch事件导致邻居状态变为Exstart。请在对端上检查该LSA信息,并在两端设备上检查Opaque LSA发布接收能力的配置情况
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing NSSA external LSA in a non-NSSA area. Please check the specified LSA on the remote end and the area configuration on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:在非NSSA区域收到了含有Type-7 LSA的DD报文,触发了SeqNumberMismatch事件导致邻居状态变为Exstart,请检查对端该LSA信息以及两端的区域配置信息
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing invalid LSA. Please check the specified LSA on the remote end (Interface: XGE0/0/6, peer address: 10.1.1.1).:接收到的DD报文中含有无效LSA,触发了SeqNumberMismatch事件导致邻居状态变为Exstart,请在对端上检查该LSA信息
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing AS external LSA in the stub area or on the virtual link. Please check the specified LSA on the remote end and the area configuration on both ends (Interface: XGE0/0/6, peer address: 10.1.1.1).:在Stub区域或虚连接上接收到了包含Type-5 LSA的DD报文,触发了SeqNumberMismatch事件导致邻居状态变为Exstart,请在对端检查该LSA信息并在两端设备上检查区域配置信息
·     reset ospf troubleshooting
1.1.36  display ospf vlink
display ospf vlink命令用来显示OSPF的虚连接信息。
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的虚连接信息。
# 显示OSPF的虚连接信息。
<Sysname> display ospf vlink
                  Virtual Links
 Virtual-link Neighbor-ID  -> 2.2.2.2, Neighbor-State: Full
 Interface: 10.1.2.1 (Ten-GigabitEthernet0/0/6)
 Cost: 1562  State: P-2-P  Type: Virtual
 Transit Area: 0.0.0.1
 Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
 Cryptographic authentication: Enabled, inherited
    The last key is 3.
 0       16777215  No          base
表1-44 display ospf vlink命令显示信息描述表
Virtual-link Neighbor-id
通过虚连接相连的邻居路由器的Router ID
Neighbor-State
邻居状态,包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
此虚连接的本端接口的IP地址和名称
Cost
接口的路由开销
接口状态
类型:虚连接
Transit Area
传输区域ID(如果当前接口为虚连接,则显示)
Timers
OSPF定时器,分别定义如下:
·     Hello:表示接口发送Hello报文的时间间隔,单位为秒
·     Dead:表示邻居的失效时间,单位为秒
·     Retransmit:表示接口重传LSA时间间隔,单位为秒
Transmit Delay
接口对LSA的传输延迟时间,单位为秒
Simple authentication enabled, inherited
采用Simple验证模式。inherited表示虚连接继承的是骨干区域下配置的Simple验证模式
Keychain authentication: Enabled (xx), inherited
采用keychain验证模式,keychain名称为xx。inherited表示虚连接继承的是骨干区域下配置的keychain验证模式
No authentication is required
采用None验证模式,该模式下虚连接不会继承其所属骨干区域下配置的验证模式
采用HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式。inherited表示虚连接继承的是骨干区域下配置的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式
The last key is xx
The rollover is in progress, xx neighbor(s) left
正在进行HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证平滑迁移,尚未完成HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证平滑迁移的邻居个数为xx
MTID
拓扑ID,0表示标准拓扑,其他数值表示子拓扑
Cost
‌指定拓扑下的接口路由开销
Disabled
‌OSPF是否通告指定拓扑下的虚连接所属拓扑的消息:
·     Yes:不通告
·     No:通告
Topology name
拓扑名称,显示为base表示标准拓扑,显示为其他表示子拓扑
1.1.37  display router id
display router id命令用来显示全局Router ID。
display router id [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示指定公网。
# 显示已配置的全局Router ID。
<Sysname> display router id
         Configured router ID is 1.1.1.1
1.1.38  distribute bgp-ls
distribute bgp-ls命令用来配置允许设备将OSPF链路状态信息发布到BGP。
undo distribute bgp-ls命令用来恢复缺省情况。
distribute bgp-ls [ instance-id id ] [ strict-link-checking ]
不允许设备将OSPF链路状态信息发布到BGP。
OSPF视图
instance-id id:实例ID,用于区分链路状态信息,取值范围为0~65535。如果未指定本参数,则表示实例0。
strict-link-checking:开启严格链路检查功能,即发布到BGP的链路信息中的本端地址与远端地址必须在同一网段。如果未指定本参数,则表示关闭严格链路检查功能,即发布到BGP的链路信息中的本端地址与远端地址可以不处于同一网段。本功能仅适用于P2P链路。
本功能允许设备将链路状态信息发布到BGP,由BGP向外发布,以满足需要知道链路状态信息的应用的需求。OSPF链路状态信息随链路状态的更新同步发布。
对于具有相同实例ID的不同OSPF进程,如果它们的链路状态信息相同,设备只会将OSPF进程号最小的链路状态信息发布到BGP。
如果要将不同OSPF进程的相同链路状态信息发布到BGP,需要为不同的进程指定不同的实例ID。
在包含等价链路的拓扑环境中,如果拓扑中每条链路的两端分别在各自的链路中处于同一网段,建议使用严格链路检查功能,以免等价链路震荡时将错误的链路信息发布到BGP。
严格链路检查功能和前缀抑制功能不能同时开启,使用本功能前,请确保前缀抑制功能处于关闭状态。
# 配置允许设备将OSPF进程1的链路状态信息发布到BGP。
[Sysname] ospf 1
[Sysname-ospf-1] distribute bgp-ls
1.1.39  dscp
dscp命令用来配置OSPF发送协议报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
OSPF发送协议报文的DSCP优先级为48。
OSPF视图
dscp-value:DSCP优先级,取值范围为0~63。
# 配置OSPF进程1发送协议报文的DSCP优先级为63。
[Sysname] ospf 1
[Sysname-ospf-1] dscp 63
1.1.40  enable link-local-signaling
enable link-local-signaling命令用来使能OSPF本地链路的信令能力。
undo enable link-local-signaling命令用来关闭OSPF本地链路的信令能力。
OSPF本地链路的信令能力处于关闭状态。
OSPF视图
# 使能OSPF进程1的本地链路的信令能力。
[Sysname] ospf 1
[Sysname-ospf-1] enable link-local-signaling
1.1.41  enable out-of-band-resynchronization
enable out-of-band-resynchronization命令用来使能OSPF带外同步能力。
undo enable out-of-band-resynchronization命令用来关闭OSPF带外同步能力。
OSPF带外同步能力处于关闭状态。
OSPF视图
在配置本命令之前,必须先使能OSPF本地链路的信令能力。
# 使能OSPF进程1的带外同步能力。
[Sysname] ospf 1
[Sysname-ospf-1] enable out-of-band-resynchronization
·     enable link-local-signaling
1.1.42  event-log
event-log命令用来配置OSPF的日志功能。
undo event-log命令用来取消OSPF日志功能的配置。
event-log { hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } | lsa-flush | peer | spf } size count
event-log lsa-history { asbr | ase | include-duplicate | link-state-id | network | nssa | opaque-area | opaque-as | opaque-link | originate-router advertising-router-id | router | size count | summary | verbose } *
undo event-log { hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } | lsa-flush | peer | spf } size
undo event-log lsa-history
记录接收Hello报文、接收异常Hello报文、丢弃接收到的Hello报文、发送Hello报文、发送异常Hello报文以及发送失败的Hello报文、LSA老化、邻居状态变化、路由计算的日志信息的最大个数均为100。
OSPF视图
hello:接收或发送Hello报文的日志信息个数。
received:接收Hello报文的日志信息个数。
sent:发送Hello报文的日志信息个数。
abnormal:发送或接收异常Hello报文的日志信息个数。异常Hello报文指的是发送或接收到的Hello报文的时间间隔大于或等于1.5倍Hello定时器的报文。
dropped:丢弃接收到的Hello报文的日志信息个数。
failed:发送失败的Hello报文的日志信息个数。
lsa-flush:LSA老化日志信息个数。
peer:邻居状态变化的日志信息个数。
spf:SPF日志信息个数。
size count:指定日志信息个数,取值范围为0~65535。
lsa-history:记录生成和接收LSA的日志信息。
# 配置OSPF进程100的路由计算日志信息个数为50。
[Sysname] ospf 100
[Sysname-ospf-100] event-log spf size 50
1.1.43  fast-reroute
fast-reroute命令用来配置OSPF快速重路由功能。
undo fast-reroute命令用来关闭OSPF快速重路由功能。
fast-reroute { lfa [ abr-only ] | route-policy route-policy-name }
undo fast-reroute
OSPF快速重路由功能处于关闭状态。
OSPF视图
lfa:表示通过LFA(Loop Free Alternate)算法选取备份下一跳信息。
abr-only:仅选取到ABR设备的路由作为备份下一跳。
route-policy route-policy-name:为通过策略的路由指定备份下一跳,route-policy-name为路由策略名,为1~63个字符的字符串,区分大小写。
OSPF快速重路由功能和前缀无关收敛功能同时配置时,OSPF快速重路由功能生效。
# 使能OSPF进程1的快速重路由功能,并使用LFA算法为非等价路由选取备份下一跳信息。
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute lfa
1.1.44  fast-reroute remote-lfa maximum-cost
fast-reroute remote-lfa maximum-cost命令用来配置Remote LFA源节点到指定PQ节点的最大开销值。
undo fast-reroute remote-lfa maximum-cost命令用来恢复缺省情况。
fast-reroute remote-lfa maximum-cost cost
Remote LFA源节点到指定PQ节点的最大开销值为4294967295。
OSPF视图
cost:源节点到指定PQ节点的开销值,取值范围为1~4294967295。
Remote LFA通过计算得到PQ节点集,集合中的每个节点到源节点的开销值不完全相同。配置本命令后,只有到源节点的开销值小于指定值的节点,才会加入到PQ节点集,以确保选择的备份路径开销不会过大。
# 配置OSPF进程1中源节点到指定PQ节点的最大开销值为200。
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute remote-lfa maximum-cost 200
1.1.45  fast-reroute remote-lfa prefix-list
fast-reroute remote-lfa prefix-list命令用来配置过滤Remote LFA PQ节点的地址前缀列表。
undo fast-reroute remote-lfa prefix-list命令用来恢复缺省情况。
fast-reroute remote-lfa prefix-list prefix-list-name
所有PQ节点都可以成为Remote LFA的备份下一跳。
OSPF视图
prefix-list-name:指定地址前缀列表名,唯一标识一个地址前缀列表。prefix-list-name为1~63个字符的字符串,区分大小写。
Remote LFA通过计算得到PQ节点集,但并不是集合中的所有节点都适合成为PQ节点。为了达到优化网络的目的,可以通过配置本命令,过滤掉不符合条件的节点,选取符合条件的PQ节点。
# 配置OSPF进程1过滤Remote LFA PQ节点的地址前缀列表为test1。
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute remote-lfa prefix-list 1
·     ip prefix-list(三层技术-IP路由命令参考/路由策略)
1.1.46  fast-reroute remote-lfa tunnel ldp
fast-reroute remote-lfa tunnel ldp命令用来开启OSPF的Remote LFA(Remote Loop-free Alternate)快速重路由功能。
undo fast-refroute remote-lfa tunnel ldp命令用来关闭OSPF的Remote LFA快速重路由功能。
undo fast-reroute remote-lfa tunnel ldp
OSPF的Remote LFA快速重路由功能处于关闭状态。
OSPF视图
开启Remote LFA快速重路由功能后,当某处链路或节点故障时,数据流量会快速切换到备份路径继续转发,从而最大程度上避免数据流量的丢失。
配置Remote LFA快速重路由功能前,需要执行以下配置:
·     mpls ldp
·     mpls ldp enable
·     fast-reroute lfa
# 开启OSPF进程1的Remote LFA快速重路由功能。
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute remote-lfa tunnel ldp
·     fast-reroute(三层技术-IP路由命令参考/OSPF)
·     mpls ldp(MPLS命令参考/LDP)
·     mpls ldp enable(MPLS命令参考/LDP)
1.1.47  fast-reroute tiebreaker
fast-reroute tiebreaker命令用来配置快速重路由备份路径优选方案的优先级。
undo fast-reroute tiebreaker命令用来恢复缺省情况。
fast-reroute tiebreaker { lowest-cost | node-protecting | srlg-disjoint } preference preference
undo fast-reroute tiebreaker { lowest-cost | node-protecting | srlg-disjoint }
最小开销路径优选方案的优先级是20,节点保护优选方案的优先级是40,共享风险组优选方案的优先级是10。
OSPF视图
lowest-cost:指定最小开销路径优选方案的优先级。
node-protecting:指定节点保护优选方案的优先级。
srlg-disjoint:指定SRLG(Shared Risk Link Group,共享风险链路组)优选方案的优先级。
preference preference:设置优选方案的优先级,取值范围为1~255,该数值越大表示优先级越高。
多次执行本命令:
·     可以分别配置最小开销路径优选方案、节点保护优选方案和SRLG优选方案的优先级。
·     对于同一优选方案,最后一次执行的命令生效。
当同一OSPF进程下配置多个优选方案时,会优先选择优先级较高的优选方案计算备份路径。如果该方案不能计算出备份路径,则再从其他优选方案中选择优先级较高的优选方案计算备份路径。具体工作机制如下:
(1)     通过SRLG方式计算备份路径时,如果不能算出备份路径,则再从节点保护方式和最小开销路径方式中选择优先级最高的方式计算备份路径,机制如下:
¡     选择节点保护方式计算备份路径时,如果仍不能计算备份路径,则再通过最小开销路径方式计算备份路径。
¡     选择最小开销路径方式计算备份路径时,如果仍不能计算出备份路径,则主链路故障后无法保证可靠性。
(2)     通过节点保护方式计算备份路径时,如果不能计算出备份路径,则再从SRLG方式和最小开销路径方式中选择优先级较高最高的方式计算备份路径,机制如下:
¡     选择SRLG保护方式计算备份路径时,如果仍不能计算备份路径,则再通过最小开销路径方式计算备份路径。
(3)     通过最小开销路径方式计算备份路径时,如果不能计算出备份路径,则不会再通过节点保护方式或者SRLG方式来计算备份路径,主链路故障后无法保证可靠性。
# 配置OSPF进程1快速重路由备份路径计算时节点保护优选方案的优先级为100。
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute tiebreaker node-protecting preference 100
·     fast-reroute
1.1.48  filter
filter命令用来配置对Type-3 LSA进行过滤。
undo filter命令用来取消对Type-3 LSA的过滤。
filter { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
不对Type-3 LSA进行过滤。
OSPF区域视图
ipv4-acl-number:指定的基本或高级IPv4 ACL编号,对进出本区域的Type-3 LSA进行过滤,取值范围为2000~3999。
prefix-list-name:指定的地址前缀列表,对进出本区域的Type-3 LSA进行过滤,为1~63个字符的字符串,区分大小写。
route-policy-name:指定的路由策略,对进出本区域的Type-3 LSA进行过滤,为1~63个字符的字符串,区分大小写。
export:对ABR向其它区域发布的Type-3 LSA进行过滤。
import:对ABR向本区域发布的Type-3 LSA进行过滤。
此命令只在ABR路由器上有效,对区域内部路由器无效。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示ABR不会对Type-3 LSA进行过滤。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则会拒绝所有Type-3 LSA通过过滤。
当配置的是高级ACL(3000~3999)时,其使用规则如下:
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard来过滤携带指定链路状态ID的Type-3 LSA。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard来过滤携带指定链路状态ID和掩码的Type-3 LSA。
其中,source用来过滤Type-3 LSA的链路状态ID,destination用来过滤Type-3 LSA的掩码。
# 根据地址前缀列表my-prefix-list和编号为2000的基本ACL分别对进出OSPF区域1的Type-3 LSA进行过滤。
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] filter prefix-list my-prefix-list import
[Sysname-ospf-100-area-0.0.0.1] filter 2000 export
1.1.49  filter-policy export
filter-policy export命令用来配置OSPF对引入的路由信息进行过滤。
undo filter-policy export命令用来取消OSPF对引入的路由信息进行过滤。
filter-policy { ipv4-acl-number | prefix-list prefix-list-name } export [ bgp | direct | { isis | ospf | rip } [ process-id ] | static ]
undo filter-policy export [ bgp | direct | { isis | ospf | rip } [ process-id ] | static ]
OSPF不对引入的路由信息进行过滤。
OSPF视图
ipv4-acl-number:用于过滤路由信息目的地址的基本或高级IPv4 ACL编号,取值范围为2000~3999。
prefix-list-name:用于过滤路由信息目的地址的IP地址前缀列表的名称,为1~63个字符的字符串,区分大小写。
bgp:对引入的BGP路由进行过滤。
direct:对引入的直连路由进行过滤。
isis:对引入的IS-IS路由进行过滤。
ospf:对引入的OSPF路由进行过滤。
rip:对引入的RIP路由进行过滤。
process-id:路由协议进程号,取值范围为1~65535。
static:对引入的静态路由进行过滤。
如果没有指定任何参数,则表示OSPF对引入的所有路由信息进行过滤。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示OSPF不会对引入的路由信息进行过滤。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则会拒绝所有引入的路由信息通过过滤。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard来过滤指定目的地址的路由。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard来过滤指定目的地址和掩码的路由。
其中,source用来过滤路由目的地址,destination用来过滤路由掩码。
# 配置OSPF进程100使用编号为2000的基本ACL对引入的路由进行过滤。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 export
# 配置OSPF进程100使用编号为3000的高级ACL对引入的路由进行过滤,只允许113.0.0.0/16通过。
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 deny ip
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 export
·     import-route
1.1.50  filter-policy import
filter-policy import命令用来配置OSPF对通过接收到的LSA计算出来的路由信息进行过滤。
filter-policy { ipv4-acl-number [ gateway prefix-list-name ] | gateway prefix-list-name | prefix-list prefix-list-name [ gateway prefix-list-name ] | route-policy route-policy-name } import
OSPF不对通过接收到的LSA计算出来的路由信息进行过滤。
OSPF视图
gateway prefix-list-name:指定的地址前缀列表,基于要加入到路由表的路由信息的下一跳进行过滤。prefix-list-name为1~63个字符的字符串,区分大小写。
prefix-list prefix-list-name:指定的地址前缀列表,基于目的地址对接收的路由信息进行过滤。prefix-list-name为1~63个字符的字符串,区分大小写。
route-policy route-policy-name:指定路由策略名,基于路由策略对接收的路由信息进行过滤。route-policy-name为1~63个字符的字符串,区分大小写。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示OSPF不会对计算出来的路由信息进行过滤。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则会拒绝所有计算出来的路由信息通过过滤。
当配置的是高级ACL(3000~3999)或者指定的路由策略中配置的是高级ACL时,其使用规则如下:
# 使用编号为2000的基本ACL对接收的路由信息进行过滤。
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 import
# 使用编号为3000的高级ACL对接收的路由进行过滤,只允许113.0.0.0/16通过。
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 import
1.1.51  graceful-restart
graceful-restart命令用来使能OSPF协议的GR能力。
undo graceful-restart命令用来关闭OSPF协议的GR能力。
graceful-restart [ ietf | nonstandard ] [ global | planned-only ] *
OSPF协议的GR能力处于关闭状态。
OSPF视图
ietf:IETF标准GR能力选项。
nonstandard:非IETF标准GR能力选项。
global:全局GR,必须保证所有的GR Helper都存在,整个GR才会完成,如果有一个GR Helper失效(比如,接口down),则整个GR失败。如果未指定本参数,表示支持接口级GR,即只要有一个GR Helper存在,则整个GR会完成。
planned-only:表示只支持计划重启。如果未指定本参数,表示计划重启和非计划重启都支持。
GR包括计划重启和非计划重启:
·     计划重启指的是手动通过命令reset ospf process执行重启,或通过命令placement reoptimize触发进程的主备倒换,在进行重启或主备倒换前GR Restarter会先发送Grace-LSA。
·     非计划重启指的是由于设备故障等原因进行重启或主备倒换,在进行重启或主备倒换前GR Restarter不会事先发送Grace-LSA。
在使能OSPF协议的IETF标准GR能力前,需要先使能OSPF不透明链路状态发布接收能力(opaque-capability enable)。
在使能OSPF协议的非IETF标准的GR能力前,需要先使能OSPF本地链路的信令能力(enable link-local-signaling)和OSPF带外同步能力(enable out-of-band-resynchronization)。
如果在使能OSPF协议的GR能力时不指定可选参数nonstandard和ietf,则nonstandard为缺省配置。
OSPF GR特性与OSPF NSR特性互斥,即graceful-restart和non-stop-routing命令互斥,不能同时配置。
# 使能OSPF进程1的IETF标准GR能力。
[Sysname] ospf 1
[Sysname-ospf-1] opaque-capability enable
[Sysname-ospf-1] graceful-restart ietf
# 使能OSPF进程1的非IETF标准GR能力。
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart nonstandard
·     enable out-of-band-resynchronization
·     opaque-capability enable
1.1.52  graceful-restart helper enable
graceful-restart helper enable命令用来使能OSPF的GR Helper能力。
undo graceful-restart helper enable命令用来关闭OSPF的GR Helper能力。
OSPF的GR Helper能力处于开启状态。
OSPF视图
planned-only:表示只支持计划重启。如果未指定本参数,表示计划重启和非计划重启(即异常重启)都支持。
参数planned-only只有在IETF标准GR Helper的时候使用。
# 使能OSPF进程1的GR Helper能力。
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper enable
1.1.53  graceful-restart helper strict-lsa-checking
graceful-restart helper strict-lsa-checking命令用来使能GR Helper严格LSA检查能力。
undo graceful-restart helper strict-lsa-checking命令用来关闭GR Helper严格LSA检查能力。
OSPF协议的GR Helper严格LSA检查能力处于关闭状态。
OSPF视图
当检查到GR Helper设备的LSA发生变化时候,Helper设备退出GR Helper模式。
# 使能OSPF进程1的GR Helper严格LSA检查能力。
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper strict-lsa-checking
1.1.54  graceful-restart interval
graceful-restart interval命令用来配置OSPF协议的GR重启间隔时间。
OSPF协议的GR重启间隔时间为120秒。
OSPF视图
interval:指定OSPF协议的GR重启间隔时间(期望重启时间),取值范围为40~1800,单位为秒。
OSPF协议的GR重启间隔时间不能小于OSPF所有接口中邻居失效时间的最大值,否则可能会造成OSPF协议的GR重启失败。
# 配置OSPF进程1的GR重启间隔时间为100秒。
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart interval 100
·     ospf timer dead
1.1.55  host-advertise
host-advertise命令用来配置并发布一条主机路由。
undo host-advertise命令用来删除一条主机路由。
host-advertise ip-address cost-value
undo host-advertise ip-address
OSPF不发布主机路由。
OSPF区域视图
ip-address:主机IP地址。
cost-value:主机路由的开销值,取值范围为1~65535。
# 配置发布一条路由1.1.1.1,并设置其开销为100。
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0] host-advertise 1.1.1.1 100
1.1.56  hostname
hostname命令用来使能OSPF动态主机名映射功能。
undo hostname命令用来关闭OSPF动态主机名映射功能。
hostname [ host-name ]
undo hostname
OSPF动态主机名映射功能处于关闭状态。
OSPF视图
host-name:配置与当前OSPF进程的Router ID对应的主机名称,为1~255个字符的字符串,区分大小写。如果未指定本参数,当前OSPF进程的Router ID对应的主机名为设备名称。
OSPF使用Type-10 LSA或Type-11 LSA携带动态主机名属性信息,因此,使用该功能前,需要保证OSPF的Opaque LSA发布接收能力处于开启状态。
# 使能OSPF进程1的动态主机名映射功能,并配置Router ID映射后的主机名称为red。
[Sysname] ospf 1
[Sysname-ospf-1] hostname red
·     display ospf hostname-table
1.1.57  import-route
import-route命令用来配置引入外部路由信息。
undo import-route命令用来取消引入外部路由信息。
import-route bgp [ as-number ] [ allow-ibgp ] [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { direct | static } [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { isis | ospf | rip } [ process-id | all-processes ] [ allow-direct | [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
undo import-route { bgp | direct | { isis | ospf | rip } [ process-id | all-processes ] | static }
不引入外部路由信息。
OSPF视图
bgp:引入BGP协议的路由。
as-number:引入指定AS内的路由。as-number为AS号,取值范围为1~4294967295。如果没有指定本参数,则引入所有的IPv4 EBGP路由。建议配置时指定AS号,否则引入的IPv4 EBGP路由数量过多时,会引发设备内存资源紧张等问题。
direct:引入直连路由。
isis:引入IS-IS协议的路由。
ospf:引入OSPF协议的路由。
rip:引入RIP协议的路由。
process-id:路由协议进程号,取值范围为1~65535,缺省值为1。
static:引入静态路由。
all-processes:引入指定路由协议所有进程的路由。
allow-ibgp:允许引入IBGP路由。
allow-direct:在引入的路由中包含使能了该协议的接口网段路由。如果未指定本参数,在引入协议路由时不会包含使能了该协议的接口网段路由。当allow-direct与route-policy route-policy-name参数一起使用时,需要注意路由策略中配置的匹配规则不要与接口路由信息存在冲突,否则会导致allow-direct配置失效。例如,当配置allow-direct参数引入OSPF直连时,在路由策略中不要配置if-match route-type匹配条件,否则,allow-direct参数失效。
cost cost-value:路由开销值,取值范围为0~16777214,缺省值为1。
inherit-cost:指定引入外部路由时使用该路由的原有开销值。
nssa-only:设置Type-7 LSA的P比特位不置位,即在对端路由器上不能转为Type-5 LSA。如果未指定本参数,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
route-policy route-policy-name:配置只能引入符合指定路由策略的路由。route-policy-name为路由策略名称,为1~63个字符的字符串,区分大小写。
tag tag:外部LSA中的标记,取值范围为0~4294967295,缺省值为1。
type type:度量值类型,取值范围为1~2,缺省值为2。
外部路由是指到达自治系统外部的路由,有两类:
·     第一类外部路由(Type1 External):这类路由的可信程度较高,并且和OSPF自身路由的开销具有可比性,所以到第一类外部路由的开销等于本路由器到相应的ASBR的开销与ASBR到该路由目的地址的开销之和。
·     第二类外部路由(Type2 External):这类路由的可信度比较低,所以OSPF协议认为从ASBR到自治系统之外的开销远远大于在自治系统之内到达ASBR的开销。所以计算路由开销时将主要考虑前者,即到第二类外部路由的开销等于ASBR到该路由目的地址的开销。如果计算出开销值相等的两条路由,再考虑本路由器到相应的ASBR的开销。
该命令只能引入路由表中状态为active的路由,是否为active状态可以通过display ip routing-table protocol命令来查看。不能引入缺省路由。
在满足如下条件之一的OSPF进程中,配置import-route bgp命令表示只引入EBGP路由:
·     OSPF进程位于公网。
·     OSPF进程属于VPN实例,且该进程下通过vpn-instance-capability simple命令关闭了环路检测功能。这种情况下,如果又配置了import-route bgp allow-ibgp命令,会将IBGP路由也引入,容易引发路由环路,请慎用。
OSPF进程属于VPN实例,且该进程下未配置vpn-instance-capability simple命令时,配置import-route bgp命令(无需指定allow-ibgp参数)会同时引入EBGP和IBGP路由。
import-route nssa-only命令配置后,引入的路由只在NSSA区域产生Type-7 LSA,不会在非NSSA区域产生Type-5 LSA。
如果未指定cost和inherit-cost参数,则引入的外部路由的开销值为1。
undo import-route protocol all-processes命令只能取消import-route protocol all-processes命令的配置,不能取消import-route protocol process-id命令的配置。
# 指定引入的进程号为40的RIP路由为Type-2外部路由,路由标记为33,度量值为50。
[Sysname] ospf 100
[Sysname-ospf-100] import-route rip 40 type 2 tag 33 cost 50
·     default-route-advertise (OSPF view)
·     vpn-instance-capability simple(MPLS命令参考/MCE)
1.1.58  isolate enable
isolate enable命令用来开启OSPF协议的隔离功能。
undo isolate enable命令用来关闭OSPF协议的隔离功能。
isolate enable
undo isolate enable
OSPF协议的隔离功能处于关闭状态。
OSPF视图
Isolate是一种对网络设备进行软件或硬件维护的方式。Isolate使用网络中的冗余路径,平滑移除需要维护的设备。当完成设备维护后,该设备可以重新投入使用。
当用户需要对网络中某台设备的OSPF协议进行升级时,为了不对当前网络中通过该设备发布的OSPF路由指导转发的流量产生影响,可以使用OSPF isolate功能把该设备上的OSPF协议从当前网络中隔离出来,具体工作机制如下:
(1)     开启OSPF isolate功能后,OSPF将链路度量值调大,以便邻居重新进行路径优选。OSPF调整链路度量值的机制如下:
¡     发布的Type-1 LSA(Router LSA)中,OSPF将链路度量值调整为最大值65535。
¡     发布的Type-3 LSA(Network Summary LSA)、Type-5 LSA(AS External LSA)和Type-7 LSA(NSSA External LSA)中,OSPF将链路度量值调整为16711680。
(2)     邻居收到LSA完成路由计算后,将选择更优的路径转发流量,不再将流量发往OSPF isolate设备。此时,设备的OSPF协议完全从当前组网中隔离出来,可以对该设备上的OSPF协议进行升级处理。
(3)     对OSPF协议的维护结束后,使用undo isolate enable命令将链路度量值恢复为调整前的值,从而让该设备的OSPF协议重新加入网络。
单独配置isolate enable命令的效果与单独配置stub-router external-lsa 16711680 summary-lsa 16711680 include-stub命令的效果相同。
同时配置OSPF isolate功能和OSPF stub路由器功能时,需要注意:
·     OSPF isolate功能和OSPF stub路由器功能均生效时,发布的Type-3 LSA、Type-5 LSA、Type-7 LSA的链路度量值为Isolate功能和Stub路由器功能中该类LSA链路度量值的较大者。
·     如果stub-router命令中指定了on-startup参数,在Stub路由器功能未生效期间,仅Isolate功能会影响流量转发路径。
# 在OSPF进程100下,把设备的OSPF协议从当前网络中隔离出来。
[Sysname] ospf 100
[Sysname-ospf-100] isolate enable
·     stub-router
1.1.59  ispf enable
ispf enable命令用来使能增量SPF计算功能。
undo ispf enable命令用来关闭增量SPF计算功能。
ispf enable
undo ispf enable
增量SPF计算功能处于使能状态。
OSPF视图
使能增量SPF计算功能后,当网络的拓扑结构发生变化影响到最短路径树的结构时,只将受影响的部分节点进行修正,而不重建整棵最短路径树。
# 关闭OSPF进程100的增量SPF计算功能。
[Sysname] ospf 100
[Sysname-ospf-100] undo ispf enable
1.1.60  log-peer-change
log-peer-change命令用来打开邻居状态变化的输出开关。
undo log-peer-change命令用来关闭邻居状态变化的输出开关。
log-peer-change
邻居状态变化的输出开关处于打开状态。
OSPF视图
打开邻接状态输出开关后,OSPF邻居状态变化时会生成日志信息发送到设备的信息中心,通过设置信息中心的参数,最终决定日志信息的输出规则(即是否允许输出以及输出方向)。(有关信息中心参数的配置请参见“设备管理配置指导”中的“信息中心”。)
# 关闭OSPF进程100的邻居状态变化的输出开关。
[Sysname] ospf 100
[Sysname-ospf-100] undo log-peer-change
1.1.61  lsa-arrival-interval
lsa-arrival-interval命令用来配置OSPF LSA重复到达的最小时间间隔。
undo lsa-arrival-interval命令用来恢复缺省情况。
lsa-arrival-interval maximum-interval [ minimum-interval [ incremental-interval ] ]
OSPF LSA重复到达的最大时间间隔为1000毫秒,最小时间间隔为500毫秒,时间间隔惩罚增量为500毫秒。
OSPF视图
maximum-interval:OSPF LSA重复到达的最大时间间隔,取值范围为0~10000,单位为毫秒。
minimum-interval:OSPF LSA重复到达的最小时间间隔,取值范围为0~1000,单位为毫秒。
incremental-interval:OSPF LSA重复到达的时间间隔惩罚增量,取值范围为1~5000,单位为毫秒。
通过调节LSA重复到达的时间间隔,可以抑制网络频繁变化可能导致的带宽资源和路由器资源被过多占用的问题。在网络变化不频繁的情况下,将LSA重复到达的时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可以进行相应的惩罚,将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval。对于在LSA重复到达的时间间隔内收到的LSA类型、LS ID、生成路由器ID均相同的LSA,设备将直接丢弃。
在网络相对稳定且对路由收敛速度要求较高的组网环境中,可以将LSA重复到达的时间间隔配置为0,使得拓扑或者路由的变化可以立即被感知到,从而加快路由的收敛。
minimum-interval和incremental-interval配置值不允许大于maximum-interval配置值。
# 配置OSPF LSA重复到达的最大时间间隔为2000毫秒,最小时间间隔为100毫秒,惩罚增量为300毫秒。
[Sysname] ospf 1
[Sysname-ospf-1] lsa-arrival-interval 2000 100 300
·     lsa-generation-interval
1.1.62  lsa-arrival-interval suppress-flapping
lsa-arrival-interval suppress-flapping命令用来配置当路由震荡时抑制重复到达的OSPF LSA。
undo lsa-arrival-interval suppress-flapping命令用来恢复缺省情况。
lsa-arrival-interval suppress-flapping delay-interval [ threshold threshold-value ]
不会对重复到达的LSA进行抑制。
OSPF视图
delay-interval:对重复到达的OSPF LSA的抑制时间,取值范围为0~65535,单位为秒。
threshold threshold-value:进入抑制状态的阈值,即路由震荡threshold-value次后,OSPF将要对重复到达的LSA进行抑制,取值范围为3~100,单位为次,缺省值为5。
路由震荡时,如果在delay-interval的抑制时间内又收到一条LSA类型、LS ID、生成路由器ID均相同的LSA则直接丢弃,这样就可以抑制路由震荡可能导致的路由器资源过多占用。
# 配置路由震荡10次后,OSPF将要对重复到达的LSA进行抑制,抑制时间为5秒。
[Sysname] ospf 1
[Sysname-ospf-1] lsa-arrival-interval suppress-flapping 5 threshold 10
·     lsa-arrival-interval
1.1.63  lsa-generation-interval
lsa-generation-interval命令用来配置OSPF更新LSA的时间间隔。
undo lsa-generation-interval命令用来恢复缺省情况。
OSPF更新LSA的最大时间间隔为5秒,最小时间间隔为50毫秒,时间间隔惩罚增量为200毫秒。
OSPF视图
maximum-interval:OSPF更新LSA的最大时间间隔,取值范围为1~60,单位为秒。
minimum-interval:OSPF更新LSA的最小时间间隔,取值范围为10~60000,单位为毫秒。
incremental-interval:OSPF更新LSA的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
通过调节OSPF更新LSA的时间间隔,可以抑制网络频繁变化可能导致的带宽资源和路由器资源被过多占用的问题。在网络变化不频繁的情况下,将OSPF更新LSA的时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可以进行相应惩罚,将OSPF更新LSA的时间间隔按照配置的惩罚增量延长,最大不超过maximum-interval。
# 设置OSPF更新LSA的最大时间间隔为2秒,最小时间间隔为100毫秒,惩罚增量为100毫秒。
[Sysname] ospf 100
[Sysname-ospf-100] lsa-generation-interval 2 100 100
1.1.64  lsa-generation-interval suppress-flapping
lsa-generation-interval suppress-flapping命令用来配置当路由震荡时抑制OSPF更新LSA。
undo lsa-generation-interval suppress-flapping命令用来恢复缺省情况。
lsa-generation-interval suppress-flapping delay-interval [ threshold threshold-value ]
不会抑制OSPF更新LSA。
OSPF视图
delay-interval:OSPF更新LSA的抑制时间,取值范围为0~65535,单位为秒。
threshold threshold-value:进入抑制状态的阈值,即路由震荡threshold-value次后OSPF将抑制更新LSA,取值范围为3~100,单位为次,缺省值为5。
# 配置路由震荡10次后,OSPF将抑制更新LSA,抑制时间为3秒。
[Sysname] ospf 1
[Sysname-ospf-1] lsa-generation-interval suppress-flapping 3 threshold 10
1.1.65  lsdb-overflow-interval
lsdb-overflow-interval命令用来配置OSPF尝试退出overflow状态的定时器时间间隔。
undo lsdb-overflow-interval命令用来恢复缺省情况。
OSPF尝试退出overflow状态的定时器时间间隔是300秒。
OSPF视图
interval:OSPF尝试退出overflow状态的定时器时间间隔,取值范围为0~2147483647,单位为秒。
网络中出现过多LSA,会占用大量系统资源。当设置的LSDB中External LSA的最大数量达到上限时,LSDB会进入overflow状态,在overflow状态中,不再接收External LSA,同时删除自己生成的External LSA,对于已经收到的External LSA则不会删除。这样就可以减少LSA从而节省系统资源。
通过调整定时器间隔,可以调整OSPF退出overflow状态的时间。
配置为0秒表示不启动定时器,不退出overflow状态。
# 配置OSPF尝试退出overflow的定时器间隔为10秒。
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-interval 10
1.1.66  lsdb-overflow-limit
lsdb-overflow-limit命令用来配置OSPF的LSDB中External LSA的最大条目数。
undo lsdb-overflow-limit命令用来恢复缺省情况。
lsdb-overflow-limit number
不对LSDB中External LSA的最大条目数进行限制。
OSPF视图
number:LSDB中External LSA的最大条目数,取值范围为1~1000000。
# 设置LSDB中External LSA的最大条目数为400000。
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-limit 400000
1.1.67  maxage-lsa route-calculate-delay
maxage-lsa route-calculate-delay命令用来配置收到达到最大老化时间的Router LSA时,启动路由计算的延迟时间。
undo maxage-lsa route-calculate-delay命令用来恢复缺省情况。
maxage-lsa route-calculate-delay delay-interval
收到达到最大老化时间的Router LSA时启动路由计算的延迟时间为10秒。
OSPF视图
delay-interval:收到达到最大老化时间的Router LSA启动路由计算的延迟时间,取值范围为0~65535,单位为秒。
路由器收到达到最大老化时间的Router LSA时,表明此LSA已不能用于路由计算,即需要重新运行SPF算法。当路由震荡时,立即启动路由计算会加剧路由震荡。使用本功能可以延迟路由计算,有效抑制路由的频繁震荡。
# 配置OSPF收到达到最大老化时间的Router-LSA启动时,路由计算的延迟时间为20秒。
[Sysname] ospf 1
[Sysname-ospf-1] maxage-lsa route-calculate-delay 20
1.1.68  maximum load-balancing
maximum load-balancing命令用来配置OSPF支持的等价路由的最大条数。
maximum load-balancing number
OSPF支持的等价路由的最大条数与系统支持最大等价路由的条数相同。
OSPF视图
number:等价路由的最大条数,当number取值为1时,相当于不进行负载分担。取值范围为1~128
本命令中number参数的取值范围和max-ecmp-num命令相关。通过max-ecmp-num命令配置系统支持的最大等价路由条数为m,并重启设备后,number参数的取值范围将修改为1~m。
# 配置OSPF支持的等价路由的最大条数为2。
[Sysname] ospf 100
[Sysname-ospf-100] maximum load-balancing 2
1.1.69  network
network命令用来配置OSPF区域所包含的网段并在指定网段的接口上使能OSPF。
undo network命令用来删除区域所包含的网段并关闭指定网段接口上的OSPF功能。
undo network ip-address wildcard-mask
接口不属于任何区域且OSPF功能处于关闭状态。
OSPF区域视图
ip-address:接口所在的网段地址。
wildcard-mask:IP地址掩码的反码,相当于将IP地址的掩码取反(0变1,1变0)。其中,“1”表示忽略IP地址中对应的位,“0”表示必须保留此位。(例如:子网掩码255.0.0.0,该掩码的反码为0.255.255.255)。
该命令可以在一个区域内配置一个或多个接口。在接口上运行OSPF协议,此接口的主IP地址必须在network命令指定的网段范围之内。如果此接口只有从IP地址在network命令指定的网段范围之内,接口不运行OSPF协议。
# 指定运行OSPF协议的接口的主IP地址位于网段131.108.20.0/24,接口所在的OSPF区域ID为2。
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] network 131.108.20.0 0.0.0.255
·     ospf
1.1.70  non-stop-routing
non-stop-routing命令用来使能OSPF协议的NSR功能。
undo non-stop-routing命令用来关闭OSPF协议的NSR功能。
non-stop-routing
OSPF协议的NSR功能处于关闭状态。
OSPF视图
各个进程的NSR功能是相互独立的,只对本进程生效。如果存在多个OSPF进程,建议在各个进程下分别使能OSPF NSR功能。
OSPF NSR特性与OSPF GR特性互斥,即non-stop-routing和graceful-restart命令互斥,不能同时配置。
# 在OSPF进程100中使能NSR功能。
[Sysname] ospf 100
[Sysname-ospf-100] non-stop-routing
1.1.71  nssa
nssa命令用来配置一个区域为NSSA区域。
undo nssa命令用来恢复缺省情况。
nssa [ default-route-advertise [ cost cost-value | nssa-only | route-policy route-policy-name | type type ] * | no-import-route | no-summary | suppress-fa | [ [ [ translate-always ] [ translate-ignore-checking-backbone ] ] | translate-never ] | translator-stability-interval value ] *
undo nssa [ default-route-advertise [ cost | nssa-only | route-policy | type ] * | no-import-route | no-summary | suppress-fa | [ translate-always | translate-never ] | translator-stability-interval ] *
没有区域被配置为NSSA区域。
OSPF区域视图
default-route-advertise:该参数只用于NSSA区域的ABR或ASBR,配置后,对于ABR,不论本地是否存在缺省路由,都将生成一条Type-7 LSA向区域内发布缺省路由;对于ASBR,只有当本地存在缺省路由时,才产生Type-7 LSA向区域内发布缺省路由。
cost cost-value:该缺省路由的度量值,取值范围为0~16777214。如果未指定本参数,缺省路由的度量值将取default cost命令配置的值。
nssa-only:设置Type-7 LSA的P比特位不置位,即在对端路由器上不能转为Type-5 LSA。缺省时,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
route-policy route-policy-name:路由策略名,为1~63个字符的字符串,区分大小写。只有当前路由器的路由表中存在缺省路由,并且有路由匹配route-policy-name指定的路由策略,才可以产生一个描述缺省路由的Type-7 LSA发布出去,指定的路由策略会影响Type-7 LSA中的值。
type type:该Type-7 LSA的类型,取值范围为1~2,如果未指定本参数,Type-7 LSA的缺省类型将取default type命令配置的值。
no-import-route:该参数用于禁止将AS外部路由以Type-7 LSA的形式引入到NSSA区域中,这个参数通常只用在既是NSSA区域的ABR,也是OSPF自治系统的ASBR的路由器上,以保证所有外部路由信息能正确地进入OSPF路由域。
no-summary:该参数只用于NSSA区域的ABR,配置后,ABR只通过Type-3 LSA向区域内发布一条缺省路由,不再向区域内发布任何其它Type-3 LSA(这种区域又称为Totally NSSA区域)。
suppress-fa:指定当Type-7 LSA转换为Type-5 LSA时,生成的Type-5 LSA中的Forwarding Address不生效。
translate-always:指定ABR为NSSA区域的Type-7 LSA转换为Type-5 LSA的转换路由器。
translate-ignore-checking-backbone:选举NSSA区域的转换路由器时,不检查骨干区域是否存在FULL状态的邻居。
translate-never:指定ABR不能将NSSA区域的Type-7 LSA转换为Type-5 LSA。
translator-stability-interval value:当有新的设备成为NSSA区域的Type-7 LSA转换为Type-5 LSA的转换路由器后,原Type-7 LSA转换为Type-5 LSA的转换路由器保持转换能力的时间。value为保持时间,取值范围为0~900,单位为秒,缺省值为0,即不保持。
如果要将一个区域配置成NSSA区域,则该区域中的所有路由器都必须配置该命令。
当NSSA区域存在多个ABR时,如果在某个ABR上指定了translate-ignore-checking-backbone参数,则需要在NSSA区域的其他ABR上做相同的配置,否则可能会出现没有ABR被选举为NSSA区域的转换路由器,或者多个ABR被选举为NSSA区域的转换路由器的情况。
# 将区域1配置成NSSA区域。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] nssa
·     default-cost (OSPF area view)
1.1.72  opaque-capability enable
opaque-capability enable命令用来使能OSPF的Opaque LSA发布接收能力。
undo opaque-capability命令用来关闭OSPF的Opaque LSA发布接收能力。
OSPF视图
使能OSPF的Opaque LSA发布接收能力后,OSPF可以发布接收Type9的Opaque LSA,接收Type10和Type11的Opaque LSA。
使能OSPF的Opaque LSA发布接收能力后,如果存在如下配置,则无法关闭该功能。如需关闭OSPF的Opaque LSA发布接收能力,请删除相关配置:
·     使能OSPF动态主机名映射功能的配置
·     使能OSPF进程的IETF标准GR能力的配置
# 关闭OSPF的Opaque LSA发布接收能力。
[Sysname] ospf 100
[Sysname-ospf-100] undo opaque-capability
·     hostname
·     graceful-restart
1.1.73  ospf
ospf命令用来启动OSPF,并进入OSPF视图。
undo ospf命令用来关闭OSPF。
ospf [ process-id | router-id { auto-select | router-id } | vpn-instance vpn-instance-name ] *
undo ospf [ process-id ] [ router-id ]
系统没有运行OSPF。
process-id:OSPF进程号,取值范围为1~65535,缺省值为1。
router-id:指定OSPF进程的Router ID。如果未指定本参数,则使用全局Router ID。
auto-select:自动获取OSPF进程的Router ID。
router-id:手工指定的OSPF进程的Router ID,点分十进制形式,取值范围为0.0.0.1~255.255.255.255。
vpn-instance vpn-instance-name:指定OSPF进程所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示OSPF位于公网中。
通过指定不同的进程号,可以在一台路由器上运行多个OSPF进程。这种情况下,建议使用命令中的router-id为不同进程指定不同的Router ID。
必须先启动OSPF进程才能配置相关参数。
若指定了auto-select参数,OSPF进程将根据如下规则自动获取Router ID:
·     OSPF进程启动时,将选取第一个运行该进程的接口的主IPv4地址作为Router ID;
·     设备重启时,OSPF进程将会选取第一个运行本进程的接口主IPv4地址作为Router ID;
·     OSPF进程重启时,将从运行了本进程的所有接口的主IPv4地址中重新获取Router ID,具体规则如下:
¡     如果存在配置IP地址的Loopback接口,则选择Loopback接口地址中最大的作为Router ID。
¡     否则,从其他接口的IP地址中选择最大的作为Router ID(不考虑接口的up/down状态)。
对于undo ospf命令,如果不指定router-id参数,则表示关闭OSPF进程;如果指定了router-id参数,则表示将已生效的Router ID获取方式恢复为使用全局Router ID,进程重启后生效,进程重启前仍使用已获取的Router ID。
# 启动OSPF进程100并配置Router ID为10.10.10.1。
[Sysname] ospf 100 router-id 10.10.10.1
[Sysname-ospf-100]
1.1.74  ospf area
ospf area命令用来在接口上使能OSPF。
undo ospf area命令用来在接口上关闭OSPF。
undo ospf process-id area [ exclude-subip ]
接口上未使能OSPF。
area-id:区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。
exclude-subip:不包含从IP地址。如果未指定本参数,则会包含从IP地址。
接口配置优先,接口使能OSPF优于命令network的配置。
在接口上使能OSPF时,如果不存在进程和区域,则创建对应的进程和区域;在接口上关闭OSPF时,不删除已经创建的进程和区域。
# 配置接口Ten-GigabitEthernet0/0/7使能OSPF进程1,接口所在的OSPF区域ID为2,不包含从IP地址。
[Sysname] interface ten-gigabitethernet 0/0/7
[Sysname- Ten-GigabitEthernet0/0/7] ospf 1 area 2 exclude-subip
·     network
1.1.75  ospf authentication-mode
ospf authentication-mode命令用来设置接口对OSPF报文进行验证的验证模式及验证字。
undo ospf authentication-mode命令用来删除接口下指定的验证模式。
Cryptographic验证模式:
ospf authentication-mode { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 } [ key-id { cipher | plain } string ]
undo ospf authentication-mode { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 } [ key-id ]
简单验证模式:
ospf authentication-mode simple [ { cipher | plain } string ]
undo ospf authentication-mode simple
keychain验证模式:
ospf authentication-mode keychain keychain-name
undo ospf authentication-mode keychain
None验证模式:
ospf authentication-mode none
undo ospf authentication-mode none
接口不对OSPF报文进行验证。
hmac-md5:HMAC-MD5验证模式。
hmac-sha-256:HMAC-SHA-256验证模式。
hmac-sm3:HMAC-SM3验证模式。
md5:MD5验证模式。
simple:简单验证模式。
key-id:验证字标识符,取值范围为1~255。如果未指定本参数,将使用空字符串对OSPF报文进行验证。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。简单验证模式下,明文密钥为1~8个字符的字符串;密文密钥为33~41个字符的字符串。HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式下,明文密钥为1~255个字符的字符串;密文密钥为33~373个字符的字符串。
keychain:使用keychain验证方式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
none:None验证模式,表示不会对OSPF报文进行验证。
使用Cryptographic验证模式(包括HMAC-MD5、HMAC-SHA-256、HMAC-SM3和MD5验证模式)、简单验证模式或keychain验证模式时,不同设备上属于同一网段的接口的验证模式必须相同,如果设置了密钥,需要保证密钥的一致性。
同一接口下重复执行本命令指定不同的验证模式时,新的验证模式会覆盖旧的验证模式。
使用Cryptographic验证模式时,可配置多条HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证命令,但key-id是唯一的,同一key-id只能配置一个验证字。
修改接口的OSPF HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字的步骤如下:
·     首先在该接口配置新的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字;此时若邻居设备尚未配置新的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字,便会触发HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证平滑迁移过程。在这个过程中,OSPF会发送分别携带各个HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字的多份报文,使得已配置新验证字的邻居设备、和尚未配置新验证字的邻居设备都能通过验证,保持邻居关系。
·     然后在各个邻居设备上也都配置相同的新HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字;当设备上收到所有邻居的携带新验证字的报文后,便会退出HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证平滑迁移过程。
·     最后在本设备和所有邻居上都删除旧的HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字;建议接口下不要保留多个HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字,每次HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证字修改完毕后,应当及时删除旧的验证字,这样可以防止与持有旧验证字的系统继续通信、减少被攻击的可能,还可以减少验证迁移过程对系统、带宽的消耗。
在使能了OSPF的接口下使用keychain验证方式时,报文的收、发过程如下:
·     OSPF在发送报文前,会先从keychain获取当前的有效发送key,然后发送报文。如果当前不存在有效发送key,OSPF不会发送报文。
·     OSPF在收到报文后,会根据报文携带的key的标识符从keychain获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验,校验成功后再对报文进行下一步处理。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
对于keychain认证算法和key的标识符的范围,OSPF的支持情况如下:
·     OSPF支持HMAC-MD5、HMAC-SHA-256、HMAC-SM3、SM3、和MD5认证算法。
·     OSPF仅支持标识符取值范围为0~255的key。
关于keychain命令的详细介绍,请参见“安全命令参考”中的“keychain”。
简单验证模式下,如果未指定cipher和plain参数,对OSPF报文进行验证时,不使用密钥。
接口下未配置验证模式时,如果其所属区域下存在验证模式的配置,接口将会继承此配置。如果希望区域中的某些接口不对OSPF报文进行验证,可以使用None验证模式,使用该验证模式的接口将不会继承其所属区域下验证模式的配置。本设备使用None验证模式时,请保证邻居设备使用None验证模式或未配置任何验证模式。
# 配置接口Ten-GigabitEthernet0/0/6采用MD5明文验证模式,验证字标识符为15,验证密钥为123456。
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] ospf authentication-mode md5 15 plain 123456
# 配置接口Ten-GigabitEthernet0/0/6采用简单明文验证模式,验证密钥为123456。
[Sysname-Ten-GigabitEthernet0/0/6] ospf authentication-mode simple plain 123456
# 配置OSPF区域0使用名称为abc的keychain进行验证。
[Sysname] keychain abc mode absolute
[Sysname-keychain-abc] key 1
[Sysname-keychain-abc-key-1] authentication-algorithm md5
[Sysname-keychain-abc-key-1] key-string plain hello12345
[Sysname-keychain-abc-key-1] send-lifetime utc 10:00:00 2023/03/02 to 11:00:00 2023/03/02
[Sysname-keychain-abc-key-1] accept-lifetime utc 10:00:00 2023/03/02 to 11:00:00 2023/03/02
[Sysname-keychain-abc-key-1] quit
[Sysname-keychain-abc] quit
[Sysname-Ten-GigabitEthernet0/0/6] ospf authentication-mode keychain abc
·     authentication-mode
1.1.76  ospf bfd enable
ospf bfd enable命令用来使能OSPF的BFD功能。
undo ospf bfd enable命令用来关闭OSPF的BFD功能。
ospf bfd enable [ echo ]
OSPF的BFD功能处于关闭状态。
echo:通过BFD echo报文方式实现BFD功能。如果不指定本参数,表示通过BFD控制报文方式实现BFD功能。
OSPF周期性的向邻居发送Hello报文,如果在设定的时间内没有收到对方发送来的Hello报文,则本地路由器会认为对方路由器无效。这种故障检测所需时间比较长,较长的检测时间会导致数据丢失,无法满足高可靠性需求。
为了解决上述问题,配置OSPF与BFD(Bidirectional Forwarding Detection,双向转发检测)联动功能,可以快速检测链路的状态,提高链路状态变化时OSPF协议的收敛速度。
# 使能接口Ten-GigabitEthernet0/0/6的OSPF BFD功能。
[Sysname-Ten-GigabitEthernet0/0/6] ospf bfd enable
1.1.77  ospf cost
ospf cost命令用来配置接口运行OSPF协议所需的开销。
undo ospf cost命令用来恢复缺省情况。
ospf cost cost-value
undo ospf cost
接口按照当前的带宽自动计算接口运行OSPF协议所需的开销。对于Loopback接口,缺省值为0。
cost-value:接口运行OSPF协议所需的开销,Loopback接口的取值范围为0~65535,其他接口的取值范围为1~65535。
本命令可用来手动设置接口的开销值,否则OSPF会按照当前的带宽自动计算接口运行OSPF协议所需的开销。
# 指定接口Ten-GigabitEthernet0/0/6运行OSPF协议的开销为65。
[Sysname-Ten-GigabitEthernet0/0/6] ospf cost 65
·     bandwidth-reference
1.1.78  ospf database-filter
ospf database-filter命令用来对接口出方向的LSA进行过滤。
undo ospf database-filter命令用来恢复缺省情况。
ospf database-filter { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
不对接口出方向的LSA进行过滤。
all:对接口出方向的所有LSA(除了Grace LSA)进行过滤。
ase:对接口出方向的Type-5 LSA进行过滤。
nssa:对接口出方向的Type-7 LSA进行过滤。
summary:对接口出方向的Type-3 LSA进行过滤。
acl ipv4-acl-number:指定基本或高级IPv4 ACL编号用于过滤,ipv4-acl-number的取值范围为2000~3999。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示OSPF不会对接口出方向的LSA进行过滤。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则会拒绝所有接口出方向的LSA通过过滤。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard来过滤携带指定链路状态ID的LSA。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard来过滤携带指定链路状态ID和掩码的LSA。
其中,source用来过滤LSA的链路状态ID,destination用来过滤LSA的掩码。
如果在配置该命令前邻居路由器就已经收到了将要进行过滤的LSA,那么配置该命令后,这些LSA仍存在于邻居路由器的LSDB中。
# 配置在接口Ten-GigabitEthernet0/0/6上对出方向的所有LSA进行过滤。
[Sysname-Ten-GigabitEthernet0/0/6] ospf database-filter all
# 根据编号为2000、2100和2200的ACL分别对接口Ten-GigabitEthernet0/0/7出方向的Type-5、Type-7和Type-3 LSA进行过滤。
[Sysname-Ten-GigabitEthernet0/0/7] ospf database-filter ase acl 2000 nssa acl 2100 summary acl 2200
·     database-filter peer (OSPF view)
1.1.79  ospf dr-priority
ospf dr-priority命令用来设置接口的DR优先级。
undo ospf dr-priority命令用来恢复缺省情况。
ospf dr-priority priority
接口的DR优先级为1。
priority:接口的DR优先级,取值范围为0~255。
接口的DR优先级决定了该接口在选举DR/BDR时所具有的资格,数值越大,优先级越高。优先级高的在选举权发生冲突时被首先考虑。如果一台设备的优先级为0,则它不会被选举为DR或BDR。
# 设置接口Ten-GigabitEthernet0/0/6在选举DR时的优先级为8。
[Sysname-Ten-GigabitEthernet0/0/6] ospf dr-priority 8
1.1.80  ospf fast-reroute lfa-backup
ospf fast-reroute lfa-backup命令用来使能接口参与LFA(Loop Free Alternate)计算。
undo ospf fast-reroute lfa-backup命令用来禁止接口参与LFA计算。
接口参与LFA计算,能够被选为备份接口。
接口使能LFA计算,使其有资格成为备份接口。去使能此配置后,则接口不会被选为备份接口。
# 禁止接口Ten-GigabitEthernet0/0/6参与LFA计算。
[Sysname-Ten-GigabitEthernet0/0/6] undo ospf fast-reroute lfa-backup
1.1.81  ospf fast-reroute remote-lfa disable
ospf fast-reroute remote-lfa disable命令用来关闭接口的OSPF Remote LFA快速重路由功能。
undo ospf fast-reroute remote-lfa disable命令用来开启接口的OSPF Remote LFA快速重路由功能。
接口的OSPF Remote LFA功能处于开启状态。
在OSPF视图下开启Remote LFA快速重路由功能后,设备上所有接口都会参与Remote LFA计算。如果需要禁止某些接口的Remote LFA快速重路由功能,可以在接口下配置本命令。
# 关闭接口Ten-GigabitEthernet0/0/6的OSPF Remote LFA快速重路由功能。
[Sysname-Ten-GigabitEthernet0/0/6] ospf 1 area 0
[Sysname-Ten-GigabitEthernet0/0/6] ospf fast-reroute remote-lfa disable
1.1.82  ospf link-quality adjust-cost
ospf link-quality adjust-cost命令用来配置OSPF根据链路质量等级调整接口开销值。
undo ospf link-quality adjust-cost命令用来恢复缺省情况。
ospf link-quality adjust-cost { cost-offset | max }
OSPF不会根据链路质量等级调整接口开销值。
cost-offset:设置接口开销调整值的大小,取值范围为1~65534。指定本参数后,当链路的质量等级由GOOD变为LOW时,接口的开销值=接口原本的开销值+cost-offset。最大不超过接口开销的最大值65535。
max:将接口的开销调整为最大值65535。
误码是指通信设备接收到的信号与源信号之间存在比特差错。由于不可避免的线路老化、光路抖动等原因,误码是不能从根本上避免的,当误码积累到一定程度可能导致服务等级降低甚至停止等严重问题。为了尽可能减少误码对OSPF网络的影响,可在OSPF接口视图下配置本命令。
配置本命令后,OSPF将根据链路质量等级来调整接口开销值,具体机制如下:
·     链路的质量等级由GOOD变为LOW时,OSPF将接口开销值调大。
·     链路的质量等级由LOW变为GOOD时,OSPF将接口开销值恢复为调整前的值。
上述机制可以使OSPF选择误码率较小的链路转发流量,从而尽可能减少误码对OSPF网络的影响。
# 在接口Ten-GigabitEthernet0/0/6下配置OSPF根据链路质量等级调整接口开销值,并设置开销调整值为200。
[Sysname-Ten-GigabitEthernet0/0/6] ospf link-quality adjust-cost 200
1.1.83  ospf lsu-flood-control
ospf lsu-flood-control命令用来开启OSPF限制LSU发送速率功能。
undo ospf lsu-flood-control命令用来关闭OSPF限制LSU发送速率功能。
ospf lsu-flood-control [ interval count ]
OSPF不对LSU的发送速率进行限制。
interval:OSPF发送LSU的时间间隔,取值范围为10~1000,单位为毫秒,缺省值为30。
count:OSPF一次发送LSU的最大个数,取值范围为1~1000,缺省值为50。
在与邻居进行LSDB同步的过程中,当OSPF需要发送的LSU较多时(比如本地设备与数量较多的设备建立OSPF邻居关系),邻居设备会在短时间内收到大量的LSU。邻居设备忙于处理这些突发的大量报文时,有可能将维持邻居关系的Hello报文丢弃,从而导致邻居关系断开。邻居关系断开后,重新建立邻居关系的过程中,需要交互的LSU数量将会更大,上述情况会进一步恶化。
配置本命令后,在指定的时间间隔内,所有运行OSPF的接口发送LSU的最大个数不能超过限定值,即对整机发送LSU的速率进行限制,从而避免上述情况的发生。
调整OSPF对LSU的发送速率时,如果配置不当可能会造成路由异常等情况,请谨慎配置。通常情况下,建议使用缺省值。
# 开启OSPF限制LSU发送速率功能,配置OSPF发送LSU的时间间隔为40毫秒,一次最多发送60个LSU报文。
[Sysname] ospf lsu-flood-control 40 60
1.1.84  ospf mib-binding
ospf mib-binding命令用来配置OSPF进程绑定公有MIB。
undo ospf mib-binding命令用来恢复缺省情况。
ospf mib-binding process-id
MIB绑定在进程号最小的OSPF进程上。
该命令用来配置OSPF进程绑定MIB,用户可通过RFC4750-OSPF.MIB文件来读取被绑定的OSPF进程的相关信息。对于Comware的私有MIB,不管是否配置此命令,均可读取所有OSPF进程的相关信息。
如果指定的process-id不存在,配置OSPF进程绑定命令时将会提示OSPF进程不存在,无法完成配置。
如果配置了OSPF进程绑定MIB,若删除process-id对应的OSPF进程,则同时删除OSPF进程绑定MIB配置,MIB绑定到进程号最小的OSPF进程上。
# 配置OSPF进程100绑定MIB。
[Sysname] ospf mib-binding 100
1.1.85  ospf mtu-enable
ospf mtu-enable命令用来配置DD报文中MTU域的值为发送该报文接口的MTU值。
undo ospf mtu-enable命令用来恢复缺省情况。
ospf mtu-enable
接口发送的DD报文中MTU域的值为0。
通过Virtual-Template或Tunnel建立虚连接后,不同厂商的设备接口发送的DD报文中MTU域的缺省值可能不同,为了保证一致,应该将接口发送的DD报文中MTU域的值恢复为缺省值0。
当配置了该命令后,接收到DD报文时会检查报文中的MTU值是否大于接收接口的MTU值,如果大于则将报文丢弃。
# 指定接口Ten-GigabitEthernet0/0/6在发送DD报文时,填写MTU值域。
[Sysname-Ten-GigabitEthernet0/0/6] ospf mtu-enable
1.1.86  ospf network-type
ospf network-type命令用来配置OSPF接口的网络类型。
undo ospf network-type命令用来恢复为缺省情况。
ospf network-type { broadcast | nbma | p2mp [ unicast ] | p2p [ multicast | peer-address-check ] * }
当接口封装的链路层协议不同时,OSPF接口网络类型的缺省值也不同:
·     当接口封装的链路层协议是Ethernet、FDDI时,OSPF接口网络类型的缺省值为广播类型;
·     当接口封装的链路层协议是PPP、LAPB、HDLC或POS时,OSPF接口网络类型的缺省值为点对点。
broadcast:配置接口的网络类型为广播类型。
nbma:配置接口的网络类型为NBMA类型。
p2mp:配置接口的网络类型为点到多点类型。
unicast:P2MP类型支持单播发送报文,缺省情况下是组播方式发送报文。
p2p:配置接口的网络类型为点到点类型。
multicast:配置网络类型为P2P的接口以组播方式发送所有类型的协议报文。如果未指定本参数,网络类型为P2P的接口以单播方式发送DD报文,以组播方式发送其他类型的协议报文。
peer-address-check:配置建立邻接关系必须在同一网段的检查功能,即在接收Hello报文时,对端的IP地址与当前接口必须在同一网段。
如果在广播网络上有不支持组播地址的路由器,可以将接口的网络类型改为NBMA。
在NBMA网络中,如果任意两台路由器之间都有一条虚电路直接可达,或者说,这个网络是全连通的,那么可以把OSPF接口的网络类型配置为NBMA;否则,需要把OSPF接口的网络类型配置为点到多点,这样,两台不能直接可达的路由器之间可以通过一台与两者都直接可达的路由器来交换路由信息。
接口的网络类型为NBMA或P2MP(unicast)时,必须使用peer命令来配置邻接点。
如果一网段内只有两台路由器运行OSPF协议,也可以将接口的网络类型改为点到点。
接口的网络类型为P2MP(unicast)时,OSPF协议在该接口上发送的报文均为单播报文。
缺省情况下,网络类型为P2P的接口以单播方式发送DD报文。某些场景中,ARP学习不到邻居MAC地址,导致OSPF无法建立邻接关系。通过将接口类型指定为p2p multicast可以解决上述问题。
# 将接口Ten-GigabitEthernet0/0/6设置为NBMA类型。
[Sysname-Ten-GigabitEthernet0/0/6] ospf network-type nbma
·     ospf dr-priority
1.1.87  ospf packet-size
ospf packet-size命令用来配置接口发送OSPF报文的最大长度。
undo ospf packet-size命令用来恢复缺省情况。
ospf packet-size value
接口发送OSPF报文的最大长度为本接口的IP MTU值。
value:配置接口发送OSPF报文的最大长度,取值范围为500~10000,单位为字节。
接口取ospf packet-size配置值和本接口IP MTU中的较小值作为发送OSPF报文的最大长度。
本命令用于需要对接口发送OSPF报文的大小进行限制的场景。例如,通过隧道建立OSPF邻居时,为避免隧道口发送的OSPF报文分片,可用此命令在隧道口上设置OSPF报文的最大长度,保证OSPF报文的最大长度+封装报文头长度≤出接口的IP MTU。关于隧道接口的详细介绍请参见“接口管理配置指导”中的“隧道接口”。
# 配置接口Ten-GigabitEthernet0/0/6发送OSPF报文的最大长度为1000字节。
[Sysname-Ten-GigabitEthernet0/0/6] ospf packet-size 1000
1.1.88  ospf peer hold-max-cost duration
ospf peer hold-max-cost duration命令用来配置OSPF通告给邻居的链路开销值保持最大值的持续时间。
undo ospf peer hold-max-cost duration命令用来恢复缺省情况。
ospf peer hold-max-cost duration time
未配置OSPF通告给邻居的链路开销值保持最大值的持续时间。
time:OSPF通告给邻居的链路开销值保持最大值的持续时间,取值范围为100~1000000,单位为毫秒。
OSPF网络中,链路发生故障并从故障中恢复,或接口状态变化时,OSPF会重新建立邻接关系,路由会重新进行收敛。在路由重新收敛的过程中,由于各个节点的路由收敛速度不一致,可能会形成环路,造成流量丢失。为了在路由收敛过程中保持转发路径不变,可以配置本命令使OSPF在time时间内向邻居通告最大链路开销,time超时后OSPF向邻居通告的链路开销从最大值恢复为原始开销值,OSPF重新进行路由优选。
当OSPF邻居状态变为Full时,time开始计时。在此期间,OSPF向邻居通告的链路开销为65535。
# 在接口Ten-GigabitEthernet0/0/6上配置OSPF通告给邻居的链路开销值保持最大值的持续时间为1000毫秒。
[Sysname-Ten-GigabitEthernet0/0/6] ospf peer hold-max-cost duration 1000
·     display ospf interface verbose
1.1.89  ospf peer sub-address enable
ospf peer sub-address enable命令用来开启OSPF使用接口的从IP地址建立邻居关系的功能。
undo ospf peer sub-address enable命令用来关闭OSPF使用接口的从IP地址建立邻居关系的功能。
ospf peer sub-address enable ip-address
OSPF使用接口的从IP地址建立邻居关系的功能处于关闭状态。
ip-address:指定OSPF建立邻居关系使用的IP地址,点分十进制格式。
缺省情况下,OSPF只能使用接口的主IP地址建立邻居关系,如果希望OSPF使用接口的从IP地址建立邻居关系,则需要开启本功能。
在用户侧设备通过M-LAG双归接入OSPF网络的场景中,M-LAG设备作为网关进行三层转发。不同M-LAG设备上的网关接口(例如VLAN接口、VSI虚接口)具有相同的IP地址和MAC地址时,M-LAG设备与用户侧设备之间无法建立OSPF邻居关系。为了解决上述问题,需要为不同的M-LAG设备的网关接口配置不同的M-LAG虚拟IPv4地址,然后配置ospf peer sub-address enable ip-address命令,并将ip-address配置为网关接口的M-LAG虚拟IPv4地址。
使用特定的IP地址建立邻居关系时,需要注意:
·     配置ospf peer sub-address enable ip-address命令后,OSPF仅使用指定的IP地址建立邻居关系,不再使用接口的主IP地址建立邻居关系。
·     需要将ip-address指定为接口的M-LAG虚拟IPv4地址或者接口的从地址,否则该接口上无法建立OSPF邻居关系。
·     多次执行ospf peer sub-address enable ip-address命令,最后一次执行的命令生效。
OSPF接口的网络类型为P2P时,在该接口下配置ospf peer sub-address enable命令后,设备会自动检查本端和对端接口建立OSPF邻居关系的IP地址是否在同一网段。如果不在同一网段,则无法建立OSPF邻居关系。
# 在接口Ten-GigabitEthernet0/0/6下开启OSPF使用接口的从IP地址建立邻居关系的功能。
[Sysname-Ten-GigabitEthernet0/0/6] ospf peer sub-address enable 1.1.1.1
1.1.90  ospf prefix-suppression
ospf prefix-suppression命令用来抑制接口进行前缀发布。
undo ospf prefix-suppression命令用来恢复缺省情况。
不抑制接口进行前缀发布。
disable:不抑制接口进行前缀发布。
如果OSPF进程配置了抑制前缀发布,但某个接口不想进行抑制,此时可以配置本命令并指定disable参数。
接口配置不能抑制从地址对应的前缀。
具体内容请参见命令prefix-suppression中的使用指导。
# 抑制接口Ten-GigabitEthernet0/0/7进行前缀发布。
[Sysname-Ten-GigabitEthernet0/0/7] ospf prefix-suppression
·     prefix-suppression
1.1.91  ospf primary-path-detect bfd
ospf primary-path-detect bfd命令用来使能OSPF协议中主用链路的BFD检测功能。
undo ospf primary-path-detect bfd命令用来关闭OSPF协议中主用链路的BFD检测功能。
ospf primary-path-detect bfd { ctrl | echo }
OSPF协议中主用链路的BFD检测功能处于关闭状态。
ctrl:配置通过工作于控制报文方式的BFD会话对主用链路进行检测。
echo:配置通过工作于echo报文方式的BFD会话对主用链路进行检测。
配置本功能后,OSPF协议的快速重路由特性和PIC特性中的主用链路将使用BFD进行检测。
# 在接口Ten-GigabitEthernet0/0/6上配置OSPF协议快速重路由特性中主用链路使能BFD(Ctrl方式)检测功能。
[Sysname] ospf 1
[Sysname-ospf-1] quit
[Sysname-Ten-GigabitEthernet0/0/6] ospf primary-path-detect bfd ctrl
# 在接口Ten-GigabitEthernet0/0/7上配置OSPF协议PIC特性中主用链路使能BFD(Echo方式)检测功能。
[Sysname] ospf 1
[Sysname-ospf-1] pic additional-path-always
[Sysname-Ten-GigabitEthernet0/0/7] ospf primary-path-detect bfd echo
1.1.92  ospf timer dead
ospf timer dead命令用来设置OSPF的邻居失效时间。
undo ospf timer dead命令用来恢复缺省情况。
ospf timer dead seconds
P2P、Broadcast类型接口的OSPF邻居失效的时间为40秒;P2MP、NBMA类型接口的OSPF邻居失效的时间为120秒。
seconds:OSPF邻居失效的时间,取值范围为1~2147483647,单位为秒。
OSPF邻居的失效时间是指:在该时间间隔内,若未收到邻居的Hello报文,就认为该邻居已失效。dead seconds值至少应为hello seconds值的4倍,同一网段上的接口的dead seconds必须相同。
缺省情况下,邻居失效时间为发送Hello报文时间间隔的4倍。在配置Hello报文发送时间间隔并且不配置ospf timer dead命令的情况下,OSPF邻居失效时间为Hello报文发送时间间隔的4倍。即仅配置ospf timer hello命令的情况下,邻居失效时间会自动设置为发送Hello报文时间间隔的4倍。
如果使用ospf timer dead命令设置邻居失效时间,则邻居失效时间大于或等于发送Hello报文的时间间隔即可成功下发配置。对于成功下发的配置,邻居失效时间为用户实际配置的值。但是建议用户不要将邻居失效时间设置得过小,否则可能会引发邻居关系震荡。
# 配置接口Ten-GigabitEthernet0/0/6上的邻居失效时间为60秒。
[Sysname-Ten-GigabitEthernet0/0/6] ospf timer dead 60
·     ospf timer hello
1.1.93  ospf timer hello
ospf timer hello命令用来配置接口发送Hello报文的时间间隔。
undo ospf timer hello命令用来恢复缺省情况。
ospf timer hello seconds
P2P、Broadcast类型接口发送Hello报文的时间间隔为10秒;P2MP、NBMA类型接口发送Hello报文的时间间隔为30秒。
seconds的值越小,发现网络拓扑改变的速度越快,对系统资源的开销也就越大。同一网段上的接口的seconds必须相同。
# 配置接口Ten-GigabitEthernet0/0/6发送Hello报文的时间间隔为20秒。
[Sysname-Ten-GigabitEthernet0/0/6] ospf timer hello 20
·     ospf timer dead
1.1.94  ospf timer poll
ospf timer poll命令用来配置在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔。
undo ospf timer poll命令用来恢复缺省情况。
ospf timer poll seconds
在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔为120秒。
seconds:向状态为down的邻居路由器发送轮询Hello报文的时间间隔,取值范围为1~2147483647,单位为秒。
在NBMA的网络上,当邻居失效后,将按轮询时间间隔定期地发送Hello报文。用户可配置轮询时间间隔以指定该接口在与相邻路由器构成邻居关系之前发送Hello报文的时间间隔。
发送轮询Hello报文的时间间隔至少应为发送Hello报文时间间隔的4倍。
# 配置接口Ten-GigabitEthernet0/0/6上发送轮询Hello报文的时间间隔为130秒。
[Sysname-Ten-GigabitEthernet0/0/6] ospf timer poll 130
·     ospf timer hello
1.1.95  ospf timer retransmit
ospf timer retransmit命令用来配置接口重传LSA的时间间隔。
undo ospf timer retransmit命令用来恢复缺省情况。
ospf timer retransmit seconds
接口重传LSA的时间间隔为5秒。
seconds:接口重传LSA的时间间隔,取值范围为1~3600,单位为秒。
请合理配置接口重传LSA的时间间隔,避免引起不必要的重传。比如,对于低速链路,可以适当把这个时间间隔值设置大一点。
# 指定接口Ten-GigabitEthernet0/0/6与邻接路由器之间传送LSA的重传间隔为8秒。
[Sysname-Ten-GigabitEthernet0/0/6] ospf timer retransmit 8
1.1.96  ospf track adjust-cost
ospf track adjust-cost命令用来配置OSPF接口与Track项关联,并根据Track项的状态调整接口开销值。
undo ospf track adjust-cost命令用来取消OSPF接口与Track项的关联关系,并将接口的开销值恢复为原本的开销值。
ospf track track-entry-number adjust-cost { cost-offset | max }
未配置OSPF接口与Track项关联。
track-entry-number:指定Track项序号,取值范围为1~1024。
cost-offset:指定接口开销调整值的大小,取值范围为1~65534。指定本参数后,当接口关联的Track项的状态变为Negative时,接口的开销值=(接口原本的开销值+cost-offset),最大不会超过65535。
max:将接口的开销值调整为最大值65535。
配置本命令后,OSPF将根据接口状态调整接口开销值,以便邻居重新进行路径优选。使用本命令可以解决用户侧设备通过M-LAG双归接入OSPF网络的场景中,流量绕行peer-link链路的问题。该场景中,正常情况下两台M-LAG设备以负载分担方式转发来自网络侧的流量。当M-LAG系统中一台M-LAG设备的M-LAG接口故障时,网络侧无法感知,流量依然会发送给所有M-LAG设备。M-LAG接口故障的M-LAG设备收到网络侧的流量后,通过peer-link链路将流量发送给邻居M-LAG设备,由邻居M-LAG设备将流量转发到用户侧。为了避免M-LAG接口故障的M-LAG设备绕行peer-link链路转发去往用户侧的流量,请执行如下配置:
(1)     通过track interface命令创建与作为M-LAG接口的聚合接口链路状态关联的Track项。
(2)     通过ospf track adjust-cost命令将M-LAG设备的网关接口与Track项关联。
完成上述配置后,OSPF接口将通过关联的Track项的状态调整接口开销值,具体机制如下:
(1)     作为M-LAG接口的聚合接口故障时,Track项的状态变为Negative,OSPF将M-LAG设备网关接口的开销值调大,以便上游邻居优选其他去往用户侧的路径,不再将流量转发给M-LAG接口故障的M-LAG设备,从而避免流量绕行peer-link链路。
(2)     作为M-LAG接口的聚合接口故障恢复时,Track项的状态变为Positive,OSPF将M-LAG设备网关接口的开销值恢复为调整前的值,M-LAG设备正常转发流量。
多次执行本命令,最后一次执行的命令生效。
# 在接口Ten-GigabitEthernet0/0/6上配置OSPF与Track项1关联,并将接口的开销调整值设置为1000。
[Sysname-Ten-GigabitEthernet0/0/6] ospf track 1 adjust-cost 1000
·     track interface(可靠性命令参考/Track)
1.1.97  ospf trans-delay
ospf trans-delay命令用来配置接口对LSA的传输延迟时间。
undo ospf trans-delay命令用来恢复缺省情况。
ospf trans-delay seconds
接口对LSA的传输延迟时间为1秒。
LSA在本路由器的LSDB中会随时间老化(LSA的老化时间每秒钟加1),但在网络的传输过程中却不会,所以有必要在发送之前在LSA的老化时间上增加一定的延迟时间。此配置对低速率的网络尤其重要。
# 指定接口Ten-GigabitEthernet0/0/6上传送LSA的时延值为3秒。
[Sysname-Ten-GigabitEthernet0/0/6] ospf trans-delay 3
1.1.98  ospf troubleshooting max-number
ospf troubleshooting max-number命令用来配置OSPF记录邻居关系断开的故障检测信息的最大个数。
undo ospf troubleshooting max-number命令用来恢复缺省情况。
ospf troubleshooting max-number number
OSPF记录邻居关系断开的故障检测信息的最大个数为100。
number:OSPF记录邻居关系断开的故障检测信息的最大个数,取值范围为0~65535。取值为0表示OSPF不记录邻居关系断开的故障检测信息。
# 配置OSPF记录邻居关系断开的故障检测信息的最大个数为50。
[Sysname] ospf troubleshooting max-number 50
1.1.99  ospf ttl-security
ospf ttl-security命令用来开启接口的OSPF GTSM功能。
ospf ttl-security disable命令用来关闭接口的OSPF GTSM功能。
undo ospf ttl-security命令用来恢复缺省情况。
ospf ttl-security [ hops hop-count | disable ]
接口的OSPF GTSM功能与其所在区域OSPF GTSM功能的状态保持一致。
hops hop-count:指定接口收到OSPF报文并进行安全检测时,允许接收到的报文所经过的最大跳数。hop-count表示最大跳数,取值范围为1~254。对于OSPF普通邻居,缺省值为1;对于OSPF虚连接邻居,缺省值为255。
disable:关闭接口的GTSM功能。
开启OSPF报文的GTSM功能后,会对来自OSPF普通邻居和虚连接邻居的报文进行安全检测。当设备在接口上收到OSPF报文时,会判断报文的TTL是否在255-“hop-count”+1到255之间。如果在,就上送报文;否则直接丢弃报文。从而使设备能够避免受到CPU利用(CPU-utilization)类型的攻击(如CPU过载),增强系统的安全性。
执行本命令后,设备会将发送报文的初始TTL设置为255,这就要求本地设备和邻居设备上同时配置本特性,指定的hop-count值可以不同,只要能够通过安全检测即可。
如果接口上配置了OSPF GTSM功能,接口OSPF GTSM功能的状态以接口的配置为准,不受接口所在区域OSPF GTSM功能的影响。如果接口上未配置OSPF GTSM功能,接口OSPF GTSM功能的状态以区域的配置为准。
如果区域中配置了虚连接,建议用户只在区域视图下开启GTSM功能。当且仅当用户已经明确知道哪些接口是用来发送和接收虚连接的OSPF报文时,才在所有这些接口下开启OSPF的GTSM功能,否则可能会导致虚连接两端的路由器丢弃接收到的OSPF报文。
# 开启接口Ten-GigabitEthernet0/0/6的GTSM功能,并指定最大跳数为254。
[Sysname-Ten-GigabitEthernet0/0/6] ospf ttl-security hops 254
·     ttl-security
1.1.100  peer
peer命令用来配置NBMA网络或P2MP单播网络的邻居。
undo peer命令用来删除指定的NBMA网络或P2MP单播网络的邻居。
peer ip-address [ cost cost-value | dr-priority priority ]
undo peer ip-address
未配置邻居。
OSPF视图
ip-address:邻居的IP地址。
cost cost-value:邻居的开销值,取值范围为1~65535。
dr-priority priority:邻居的优先级,取值范围为0~255,缺省值为1。
NBMA网络或P2MP单播网络采用单播形式发送协议报文,必须手工指定邻居。
本命令设置的开销值仅用于P2MP链路上建立的邻居,如果没有配置开销值,去往该邻居的花费等于接口的开销值。
本命令设置的优先级仅用于表示路由器是否主动向该邻居发送Hello报文,并不用于实际的DR选举,ospf dr-priority命令设置的优先级用于实际的DR选举。
# 指定邻居的IP地址为1.1.1.1。
[Sysname] ospf 100
[Sysname-ospf-100] peer 1.1.1.1
·     ospf dr-priority
1.1.101  pic
pic命令用来使能前缀无关收敛功能。
undo pic命令用来关闭前缀无关收敛功能。
undo pic
前缀无关收敛功能处于使能状态。
OSPF视图
additional-path-always:支持从多个非直连发布源发布的同一前缀的路由中选择一条次优路由作为备份。
PIC(Prefix Independent Convergence,前缀无关收敛),即收敛时间与前缀数量无关,加快收敛速度。传统的路由计算快速收敛都与前缀数量相关,收敛时间与前缀数量成正比。OSPF只实现区域间路由以及外部路由的前缀无关收敛。
OSPF快速重路由功能和PIC同时配置时,OSPF快速重路由功能生效。
# 使能OSPF协议的PIC支持非直连次优路由做备份功能。
[Sysname] ospf 1
1.1.102  preference
preference命令用来配置OSPF协议的路由优先级。
undo preference命令用来取消OSPF协议的路由优先级的配置。
undo preference [ ase ]
对于自治系统内部路由,OSPF协议的路由优先级为10;对于自治系统外部路由,OSPF协议的路由优先级为150。
OSPF视图
ase:配置OSPF协议对自治系统外部路由的优先级。如果未指定该参数,则配置的是OSPF协议对自治系统内部路由的优先级。
preference:OSPF协议的路由优先级,取值范围为1~255。优先级的值越小,其实际的优先程度越高。
route-policy route-policy-name:应用路由策略,对特定的路由设置优先级。route-policy-name是路由策略名称,为1~63个字符的字符串,区分大小写。
由于路由器上可能同时运行多个动态路由协议,就存在各个路由协议之间路由信息共享和选择的问题,所以为每一种路由协议指定了一个缺省的优先级。在不同的路由协议发现去往同一目的地的多条路由时,优先级高的协议发现的路由将被选中以转发IP报文。
配置了route-policy参数后,如果route-policy中对某些匹配的路由优先级进行了修改,则这些匹配的路由取route-policy修改的优先级,其它路由的优先级均取preference命令所设的值。
# 配置OSPF协议对自治系统外部路由的优先级为200。
[Sysname] ospf 100
[Sysname-ospf-100] preference ase 200
# 配置OSPF协议对自治系统内部路由的优先级,匹配路由策略policy1的路由优先级为100,未匹配的路由优先级为150。
[Sysname] ip prefix-list test index 10 permit 100.1.1.0 24
[Sysname-route-policy-policy1-10] if-match ip address prefix-list test
[Sysname-route-policy-policy1-10] apply preference 100
[Sysname-route-policy-policy1-10] quit
[Sysname] ospf 100
[Sysname-ospf-100] preference route-policy policy1 150
1.1.103  prefix-priority
prefix-priority命令用来使能OSPF的前缀按优先级快速收敛功能。
undo prefix-priority命令用来关闭OSPF的前缀按优先级快速收敛功能。
OSPF的前缀按优先级快速收敛功能处于关闭状态。
OSPF视图
route-policy route-policy-name:应用路由策略,对特定的路由前缀设置优先级。route-policy-name是路由策略名称,为1~63个字符的字符串,区分大小写。
OSPF按照指定的收敛优先级依次计算区域内路由、区域间路由、自治系统外部路由。收敛优先级从高到低分为4个优先级Critical、High、Medium和Low。如果一条路由同时满足多个收敛优先级的匹配规则,那么优先选择拥有最高优先级的收敛规则作为该路由的收敛优先级。
通过配置OSPF路由的收敛优先级,允许用户配置特定路由的优先级,使这些路由能够比其他的路由优先收敛。
# 配置通过路由策略policy1修改特定路由前缀的优先级为Medium。
[Sysname-route-policy-policy1-10] apply prefix-priority medium
[Sysname] ospf 100
[Sysname-ospf-100] prefix-priority route-policy policy1
1.1.104  prefix-suppression
prefix-suppression命令用来抑制OSPF进程进行前缀发布。
undo prefix-suppression命令用来恢复缺省情况。
prefix-suppression
不抑制OSPF进程进行前缀发布。
OSPF视图
OSPF使能网段时会将接口上匹配该网段的所有网段路由与主机路由都通过LSA发布,但在某些情况下主机路由或网段路由是不希望被发布的。通过前缀抑制配置,可以减少LSA中携带不需要的前缀,即不发布某些网段路由和主机路由,从而提高网络安全性,加快路由收敛。
如果需要抑制前缀发布,建议整个OSPF网络都配置本命令。
全局配置不能抑制从地址、LoopBack接口以及处于抑制状态的接口对应的前缀。如果想对LoopBack接口或处于抑制状态的接口进行抑制,可以通过配置接口前缀抑制(ospf prefix-suppression命令)来实现。
当使能前缀抑制时,具体情况如下:
·     P2P或P2MP类型网络:Type-1 LSA中不发布接口的主地址,即Type-1 LSA中链路类型为3的Stub链路被抑制,不生成接口路由,但其他路由信息可以正常计算,不会影响流量转发。
·     广播类型或者NBMA网络:DR发布的Type-2 LSA的掩码字段会填成32位,即不生成网段路由,但其他路由信息可以正常计算,不会影响流量转发。另外,如果没有邻居,发布的Type-1 LSA中也不发布接口的主地址,即Type-1 LSA中链路类型为3的Stub链路被抑制。
# 抑制OSPF进程1的前缀发布。
[Sysname] ospf 1
[Sysname-ospf-1] prefix-suppression
·     ospf prefix-suppression
1.1.105  reset ospf event-log
reset ospf event-log命令用于清除OSPF的日志信息。
reset ospf [ process-id ] event-log [ lsa-flush | lsa-history | peer [ slot slot-number ] | route | spf ]
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,则清除所有OSPF进程的日志信息。
lsa-flush:清除LSA老化日志信息个数。
lsa-history:清除生成和接收LSA的日志信息。
peer:清除邻居状态变化的日志信息。
slot slot-number:清除指定单板上OSPF邻居状态变化的日志信息,slot-number表示单板所在的槽位号。如果未指定本参数,将清除主进程所在单板上OSPF邻居状态变化的日志信息。
spf:清除路由计算的日志信息。
如果未指定日志类型,则所有日志信息都被清除。
# 清除所有OSPF进程路由计算的日志信息。
<Sysname> reset ospf event-log spf
·     display ospf event-log
1.1.106  reset ospf event-log hello
reset ospf event-log hello命令用于清除OSPF接收或发送Hello报文的日志信息。
reset ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } [ slot slot-number ]
process-id:清除指定OSPF进程接收或发送Hello报文的日志信息,process-id表示OSPF进程号,取值范围为1~65535。如果未指定本参数,则清除所有OSPF进程的日志信息。
received:清除接收Hello报文的日志信息。
sent:清除发送Hello报文的日志信息。
abnormal:清除发送或者接收异常Hello报文的日志信息。异常Hello报文指的是发送或接收到的Hello报文的时间间隔大于或等于1.5倍Hello定时器的报文。
dropped:清除丢弃接收到的Hello报文的日志信息个数。
failed:清除发送失败的Hello报文的日志信息。
slot slot-number:清除指定单板接收或发送Hello报文的日志信息,slot-number表示单板所在的槽位号。如果未指定本参数,将清除主进程所在单板接收或发送Hello报文的日志信息。
# 清除所有OSPF进程发送Hello报文的日志信息。
<Sysname> reset ospf event-log hello sent
·     display ospf event-log hello
1.1.107  reset ospf process
reset ospf process命令用来重启OSPF进程。
process-id:OSPF进程号,取值范围为1~65535。如果不指定该参数,则重启所有的OSPF进程。
graceful-restart:以GR方式重启OSPF进程。
使用reset ospf process命令重启OSPF,可以获得如下结果:
·     可以立即清除无效的LSA,而不必等到LSA超时。
·     如果改变了Router ID,该命令的执行会导致新的Router ID生效。
·     方便重新选举DR、BDR。
·     重启前的OSPF配置不会丢失。
执行该命令后,系统提示用户确认是否重启OSPF协议。
# 重启所有OSPF进程。
<Sysname> reset ospf process
Reset OSPF process? [Y/N]:y
1.1.108  reset ospf redistribution
reset ospf redistribution命令用来重新向OSPF引入外部路由。
process-id:OSPF进程号,取值范围为1~65535。如果不指定本参数,则所有OSPF进程都将重新引入外部路由。
# 重新向OSPF引入外部路由。
<Sysname> reset ospf redistribution
1.1.109  reset ospf statistics
reset ospf statistics命令用来清除OSPF的统计信息。
process-id:OSPF进程号,取值范围为1~65535,清除指定OSPF进程的统计信息。
# 清除所有OSPF进程的统计信息。
<Sysname> reset ospf statistics
·     display ospf statistics
1.1.110  reset ospf troubleshooting
reset ospf troubleshooting命令用来清除OSPF邻居关系断开的故障检测信息。
# 清除OSPF邻居关系断开的故障检测信息。
<Sysname> reset ospf troubleshooting
·     display ospf troubleshooting
1.1.111  rfc1583 compatible
rfc1583 compatible命令用来开启兼容RFC 1583的路由选择优先规则的功能。
undo rfc1583 compatible命令用来关闭兼容RFC 1583的路由选择优先规则的功能。
rfc1583 compatible
兼容RFC 1583的路由选择优先规则的功能处于开启状态。
OSPF视图
当有多条路径可以到达同一个外部路由时,在选择最优路由的问题上,RFC 2328中定义的选路规则与RFC 1583的有所不同,进行此配置可以兼容RFC 1583中定义的规则。
具体的选路规则如下:
(1)     当RFC 2328兼容RFC 1583时,所有到达ASBR的路由优先级相同。当RFC 2328不兼容RFC 1583时,非骨干区的区域内路由优先级最高,区域间路由与骨干区区域内路由优先级相同,优选非骨干区的区域内路由,尽量减少骨干区的负担;
(2)     若存在多条优先级相同的路由时,按开销值优选,优选开销值小的路由;
(3)     若存在多条开销值相同路由时,按路由来源区域的区域ID选择,优选区域ID大的路由。
为了避免路由环路,同一路由域内的路由器建议统一配置相同规则。
# 关闭兼容RFC 1583的路由选择规则的功能。
[Sysname] ospf 100
[Sysname-ospf-100] undo rfc1583 compatible
1.1.112  router id
router id命令用来配置全局Router ID。
undo router id命令用来恢复缺省情况。
router id router-id
undo router id
未配置全局Router ID。
router-id:全局Router ID,点分十进制形式,取值范围为0.0.0.1~255.255.255.254。
一些动态路由协议要求使用Router ID,如果在启动这些路由协议时没有指定Router ID,则缺省使用全局路由器ID。
如果配置了全局路由器ID,则使用配置的值作为Router ID。如果没有配置全局路由器ID,则按照下面的规则进行选择:
(1)     如果存在配置IP地址的Loopback接口,则选择Loopback接口地址中最大的作为Router ID。
(2)     如果没有配置IP地址的Loopback接口,则从其他接口的IP地址中选择最大的作为Router ID(不考虑接口的up/down状态)。
存在主备的情况下,系统将备份命令行配置的Router ID或从接口地址中选择出来的Router ID。主备倒换后,系统将检查从地址中选出的Router ID的有效性,如果无效将重新进行选择。
当且仅当被选为Router ID的接口IP地址被删除或被修改时,才触发重新选择过程,其他情况不触发重新选择的过程。例如,以下情况不会触发Router ID重新选择的过程:
·     接口down。
·     已经选取了一个非Loopback接口地址后又配置了一个Loopback接口地址。
·     配置一个更大的接口地址。
Router ID改变之后,各协议需要通过手工执行reset命令才会获取新的Router ID。
# 配置全局Router ID为1.1.1.1。
[Sysname] router id 1.1.1.1
1.1.113  shutdown process
shutdown process命令用来关闭OSPF进程。
undo shutdown process命令用来开启OSPF进程。
shutdown process
OSPF进程处于开启状态。
OSPF视图
使用本功能或Isolate功能均可以对OSPF进程进行维护。
配置shutdown process命令后,相应的OSPF进程将执行如下操作:
·     向邻居发送1-way Hello报文。
邻居收到1-way Hello报文后,断开与发送该报文的设备的邻居关系。
·     停止收发OSPF协议报文,清除邻居信息、LSDB(包括自己产生的LSP和接收到的LSP)以及OSPF路由等信息。
当完成对网络设备的维护后,执行undo shutdown process命令,重新开启OSPF进程,以便OSPF重新建立邻居关系。
# 关闭进程号为100的OSPF进程。
[Sysname] ospf 100
[Sysname-ospf-100] shutdown process
·     isolate enable
1.1.114  silent-interface
silent-interface命令用来禁止接口收发OSPF报文。
undo silent-interface命令用来取消禁止接口收发OSPF报文的配置。
允许接口收发OSPF报文。
OSPF视图
interface-type interface-number:接口类型和接口号,禁止指定OSPF接口收发OSPF报文。
all:禁止所有OSPF接口收发OSPF报文。
如果要使OSPF路由信息不被某一网络中的路由器获得,可使用本命令禁止在此接口上收发OSPF报文。
# 禁止接口Ten-GigabitEthernet0/0/6收发OSPF报文。
[Sysname] ospf 100
[Sysname-ospf-100] silent-interface ten-gigabitethernet 0/0/6
1.1.115  snmp trap rate-limit
snmp trap rate-limit命令用来配置OSPF在指定时间间隔内允许输出的告警信息条数。
undo snmp trap rate-limit命令用来恢复缺省情况。
OSPF在10秒内允许输出7条告警信息。
OSPF视图
interval trap-interval:指定允许输出告警信息的时间间隔,取值范围为2~60,单位为秒。
count trap-number:在指定时间间隔内允许输出的告警信息条数,取值范围为0~300,为0时表示不输出告警信息。
# 配置OSPF在5秒内允许输出10条告警信息。
[Sysname] ospf 100
[Sysname-ospf-100] snmp trap rate-limit interval 5 count 10
1.1.116  snmp-agent trap enable ospf
snmp-agent trap enable ospf命令用来开启OSPF的告警功能。
undo snmp-agent trap enable ospf命令用来关闭OSPF的告警功能。
snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | dr-ip-address-conflict | grhelper-status-change | grrestarter-status-change | if-state-change | intra-area-router-id-conflict | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | sr-prefix-sid-conflict | sr-prefix-sid-conflict-clear | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
undo snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | dr-ip-address-conflict | grhelper-status-change | grrestarter-status-change | if-state-change | intra-area-router-id-conflict | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | sr-prefix-sid-conflict | sr-prefix-sid-conflict-clear | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
OSPF的告警功能处于开启状态。
authentication-failure:接口认证失败。
bad-packet:接收了错误报文。
config-error:接口配置错误。
dr-ip-address-conflict:区域内DR的IP地址冲突。
grhelper-status-change:邻居GR Helper状态变化。
grrestarter-status-change:GR Restarter状态变化。
if-state-change:接口状态变化。
intra-area-router-id-conflict:区域内Router ID冲突。
lsa-maxage:LSA的max age。
lsa-originate:本地生成LSA。
lsdb-approaching-overflow:LSDB接近溢出。
lsdb-overflow:LSDB溢出。
neighbor-state-change:邻居状态变化。
nssatranslator-status-change:NSSA转换路由器状态变化。
retransmit:接口接收和转发报文。
sr-prefix-sid-conflict:SR前缀SID冲突。
sr-prefix-sid-conflict-clear:SR前缀SID冲突清除。
virt-authentication-failure:虚接口认证失败。
virt-bad-packet:虚接口接收错误报文。
virt-config-error:虚接口配置错误。
virt-retransmit:虚接口接收和转发报文。
virtgrhelper-status-change:虚接口邻居GR Helper状态变化。
virtif-state-change:虚接口状态变化。
virtneighbor-state-change:虚接口邻居状态变化。
如果未指定任何参数,将开启OSPF所有类型的告警功能。
存在OSPF进程时,才允许开启OSPF告警功能。开启OSPF告警功能后,如果删掉所有的OSPF进程,则OSPF告警功能不生效。
# 关闭OSPF的告警功能。
[Sysname] undo snmp-agent trap enable ospf
1.1.117  spf-schedule-interval
spf-schedule-interval命令用来配置OSPF路由计算的时间间隔。
undo spf-schedule-interval命令用来恢复缺省情况。
spf-schedule-interval { maximum-interval [ minimum-interval [ incremental-interval [ conservative ] ] ] | millisecond interval }
OSPF路由计算的最大时间间隔为5秒,最小时间间隔为50毫秒,时间间隔惩罚增量为200毫秒。
OSPF视图
maximum-interval:OSPF路由计算的最大时间间隔,取值范围为1~60,单位为秒。
minimum-interval:OSPF路由计算的最小时间间隔,取值范围为10~60000,单位为毫秒。
incremental-interval:OSPF路由计算的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
conservative:路由震荡时,连续按照最大时间间隔进行路由计算。如果未指定本参数,连续三次按最大时间间隔进行路由计算后,将按照最小时间间隔进行路由计算。
millisecond interval:OSPF路由计算采用固定的时间间隔,取值范围为0~10000,单位为毫秒。
根据本地维护的LSDB,运行OSPF协议的路由器通过SPF算法计算出以自己为根的最短路径树,并根据这一最短路径树决定到目的网络的下一跳。通过调节SPF的计算间隔,可以抑制网络频繁变化可能导致的带宽资源和路由器资源被过多占用的问题。
执行spf-schedule-interval maximum-interval [ minimum-interval [ incremental-interval ] ]命令后,在网络变化不频繁时,设备会将连续路由计算的时间间隔缩小到minimum-interval,而在网络变化频繁时可以进行相应惩罚,将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval。
在某些特定的组网环境下(例如对路由收敛速度要求较高的环境),可以使用spf-schedule-interval millisecond interval命令来加快路由计算的频率,从而加速路由收敛。
# 设置OSPF路由计算最大时间间隔为10秒,最小时间间隔为500毫秒,惩罚增量为300毫秒。
[Sysname] ospf 100
[Sysname-ospf-100] spf-schedule-interval 10 500 300
1.1.118  stub
stub命令用来配置一个区域为Stub区域。
undo stub命令用来恢复缺省情况。
undo stub
没有区域被设置为Stub区域。
OSPF区域视图
default-route-advertise-always:该参数只用于Stub区域的ABR,配置后,ABR向Stub区域内发布缺省路由的Type-3 LSA时不检查骨干区域是否存在FULL状态的邻居。如果未指定本参数,ABR向Stub区域内发布缺省路由的Type-3 LSA时需要检查骨干区域是否存在FULL状态的邻居,如果不存在FULL状态的邻居,则ABR不会向Stub区域内发布缺省路由的Type-3 LSA。
no-summary:该参数只用于Stub区域的ABR,配置后,ABR只向Stub区域内发布一条缺省路由的Type-3 LSA,不生成任何其它Type-3 LSA(这种区域又称为Totally Stub区域)。
# 将OSPF区域1设置为Stub区域。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
1.1.119  stub-router
stub-router命令用来配置当前路由器为Stub路由器。
undo stub-router命令用来恢复缺省情况。
stub-router [ external-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } | summary-lsa [ max-metric-value ] ] *
undo stub-router
当前路由器没有被配置为Stub路由器。
OSPF视图
external-lsa max-metric-value:路由器发布的外部LSA链路度量值。max-metric-value表示链路度量值,取值范围为1~16777215,缺省值为16711680。
include-stub:路由器发布的Router-LSA中,链路类型为3的Stub链路度量值将设置为最大值65535。
on-startup seconds:在路由器重启期间,路由器作为Stub路由器。seconds表示超时时间,取值范围为5~86400,单位为秒。
wait-for-bgp seconds:在路由器重启后,等待BGP路由收敛期间,路由器作为Stub路由器。seconds表示超时时间,取值范围为5~86400,单位为秒,缺省值为600。
summary-lsa max-metric-value:路由器发布的3类LSA链路度量值。max-metric-value表示链路度量值,取值范围为1~16777215,缺省值为16711680。
通过将当前路由器配置为Stub路由器,在该路由器发布的Router-LSA中,当链路类型取值为3表示连接到Stub网络时,链路度量值不变;当链路类型为1、2、4分别表示通过P2P链路与另一路由器相连、连接到传送网络、虚连接时,链路度量值将设置为最大值65535。这样其邻居计算出这条路由的开销就会很大,如果邻居上有到这个目的地址开销更小的路由,则数据不会通过这个Stub路由器转发。
# 配置当前路由器为Stub路由器。
[Sysname] ospf 100
[Sysname-ospf-100] stub-router
1.1.120  transmit-pacing
transmit-pacing命令用来配置接口发送LSU报文的时间间隔和一次发送LSU报文的最大个数。
undo transmit-pacing命令用来恢复缺省情况。
接口发送LSU报文的时间间隔为20毫秒,一次最多发送3个LSU报文。
OSPF视图
interval interval:接口发送LSU报文的时间间隔,interval的取值范围为0~1000,单位为毫秒。当路由器上使能OSPF功能的接口数比较多时,建议增大该值,以控制路由器每秒钟发送LSU报文的总数。当OSPF LSDB规模较大或者路由更新比较频繁时,建议不要将interval配置为0,否则可能会影响网络稳定性。
count count:接口一次发送LSU报文的最大个数,count的取值范围为1~200。当路由器上使能OSPF功能的接口数比较多时,建议减小该值,以控制路由器每秒钟发送LSU报文的总数。
# 配置OSPF进程1的所有接口发送LSU报文的时间间隔为30毫秒,一次最多发送10个LSU报文。
[Sysname] ospf 1
[Sysname-ospf-1] transmit-pacing interval 30 count 10
1.1.121  ttl-security
ttl-security命令用来开启区域的OSPF GTSM功能。
undo ttl-security命令用来关闭区域的OSPF GTSM功能。
ttl-security [ hops hop-count ]
undo ttl-security
区域的OSPF GTSM功能处于关闭状态。
OSPF区域视图
hops hop-count:指定接口收到OSPF报文并进行安全检测时,允许接收的报文所经过的最大跳数。hop-count表示最大跳数,取值范围为1~254。对于OSPF普通邻居,缺省值为1;对于OSPF虚连接邻居,缺省值为255。
在OSPF区域视图下开启GTSM功能后,会对来自OSPF普通邻居和虚连接邻居的报文进行安全检测。当设备从某个接口上收到一个OSPF报文时,会判断报文的TTL是否在255-“hop-count”+1到255之间。如果在,就上送报文;否则直接丢弃报文。从而使设备能够避免受到CPU利用(CPU-utilization)类型的攻击(如CPU过载),增强系统的安全性。
如果区域中配置了虚连接,建议用户指定hops参数。配置时需要考虑虚连接发送的OSPF报文所经过的最大跳数。同时建议用户只在区域视图下开启GTSM功能,当且仅当用户已经明确知道了哪些接口是用来发送和接收虚连接的OSPF报文时,才在所有这些接口下开启OSPF的GTSM功能,否则可能会导致虚连接两端的路由器丢弃接收到的OSPF报文。
# 在OSPF区域视图下开启GTSM功能。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] ttl-security
·     ospf ttl-security
1.1.122  vlink-peer
vlink-peer命令用来创建并配置一条虚连接。
undo vlink-peer命令用来删除一条已有的虚连接。
vlink-peer router-id [ dead seconds | hello seconds | { authentication-none | { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 } [ key-id { cipher | plain } string ] | keychain keychain-name | simple [ { cipher | plain } string ] } | retransmit seconds | trans-delay seconds ] *
undo vlink-peer router-id [ dead | hello | { authentication-none | { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 } [ key-id ] | keychain } | retransmit | simple | trans-delay ] *
不存在虚链接。
OSPF区域视图
router-id:虚连接邻居的路由器ID。
dead seconds:失效时间间隔,取值范围为1~32768,单位为秒,缺省值为40。该值必须和与其建立虚连接路由器的dead seconds值相等,并至少为hello seconds值的4倍。
hello seconds:接口发送Hello报文的时间间隔,取值范围为1~8192,单位为秒,缺省值为10。该值必须和与其建立虚连接路由器上的hello seconds值相等。
authentication-none:None验证模式,表示不会对OSPF报文进行验证。
md5:MD5验证模式。
simple:简单验证模式。
key-id:MD5/HMAC-MD5验证字标识符,取值范围为1~255。如果未指定本参数,将使用空字符串对OSPF报文进行验证。
cipher:以密文方式设置密钥。
string:密钥字符串,区分大小写。简单验证模式下,明文密钥为1~8个字符的字符串;密文密钥为33~41个字符的字符串。MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证模式下,明文密钥为1~255个字符的字符串;MD5/HMAC-MD5验证模式下,密文密钥为33~53个字符的字符串;HMAC-SHA-256/HMAC-SM3验证模式下,密文密钥为33~373个字符的字符串。
retransmit seconds:接口重传LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为5。
trans-delay seconds:接口延迟发送LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为1。
根据RFC 2328的规定,OSPF的所有非骨干区域必须是和骨干区域保持连通的,可以使用vlink-peer命令建立逻辑上的连通性。
各参数取值规则如下:
·     hello值越小,发现网络变化的速度越快,消耗的网络资源也就越多。
·     不能将retransmit值设置的太小,否则将会引起不必要的重传。网络速度相对较慢的时候应把该值设的更大一些。
·     设置trans-delay值时必须考虑接口的发送延迟。
同一区域下重复执行本命令指定不同的验证模式时,新的验证模式会覆盖旧的验证模式。
使用HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5验证模式、简单验证模式或keychain验证模式时,同一虚连接的验证模式必须相同,如果设置了密钥,需要保证密钥的一致性。
虚连接未指定验证模式时,如果骨干区域下存在验证模式的配置,虚连接将会继承此配置。如果使用None验证模式,虚连接将不会继承骨干区域下验证模式的配置。本设备使用None验证模式时,请保证邻居设备使用None验证模式或未配置任何验证模式。
虚连接可指定使用MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证方式、简单验证方式或keychain验证方式,但不能同时指定;使用MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证方式时,可配置多条MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证命令,但key-id是唯一的,同一key-id只能配置一个验证字。
修改虚连接的OSPF MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证字的步骤如下:
·     首先为该虚连接配置新的MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证字;此时若邻居设备尚未配置新的MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证字,便会触发MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证平滑迁移过程。在这个过程中,OSPF会发送分别携带各个MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证字的多份报文,使得无论邻居设备上是否配置了新验证字都能验证通过,保持邻居关系。
·     然后在邻居设备上也都配置相同的新MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证字;当本设备上收到邻居的携带新验证字的报文后,便会退出MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证平滑迁移过程。
·     最后在本设备和邻居上都删除旧的MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证字;建议不要为虚连接保留多个MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证字,每次MD5/HMAC-MD5/HMAC-SHA-256/HMAC-SM3验证字修改完毕后,应当及时删除旧的验证字,这样可以防止与持有旧验证字的系统继续通信、减少被攻击的可能,还可以减少验证迁移过程对系统、带宽的消耗。
在OSPF虚连接使用keychain验证方式时,报文的收、发过程如下:
·     OSPF虚连接在发送报文前,会先从keychain获取当前的有效发送key,然后发送报文。如果当前不存在有效发送key,OSPF虚连接不会发送报文。
·     OSPF虚连接在收到报文后,会根据报文携带的key的标识符从keychain中获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验,校验成功后再对报文进行下一步处理。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
·     OSPF支持MD5、SM3、HMAC-MD5、HMAC-SHA-256和HMAC-SM3认证算法。
# 配置虚连接,对端路由器Router ID为1.1.1.1。
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.2] vlink-peer 1.1.1.1
·     display ospf vlink
