03-硬件资源管理命令
本章节下载: 03-硬件资源管理命令 (700.67 KB)
1.1.5 display cpu-usage configuration
1.1.6 display cpu-usage history
1.1.9 display device manuinfo fan
1.1.10 display device manuinfo power
1.1.14 display hardware-resource acl-hash
1.1.15 display hardware-resource mdb
1.1.16 display hardware-resource bfd_enhance
1.1.17 display hardware-resource opttask-delay
1.1.18 display hardware-resource port-speed
1.1.19 display hardware-resource smartman
1.1.20 display hardware-resource telemetry-stream
1.1.23 display memory-threshold
1.1.24 display memory-threshold dma
1.1.26 display resource-monitor
1.1.27 display transceiver alarm
1.1.28 display transceiver diagnosis
1.1.29 display transceiver interface
1.1.30 display transceiver itu-channel
1.1.31 display transceiver manuinfo
1.1.32 hardware-failure-detection
1.1.34 hardware-resource acl-hash
1.1.36 hardware-resource opttask-delay
1.1.37 hardware-resource port-speed
1.1.38 hardware-resource smartman
1.1.39 hardware-resource telemetry-stream
1.1.45 monitor chipblock reset
1.1.46 monitor cpu-usage enable
1.1.47 monitor cpu-usage interval
1.1.48 monitor cpu-usage threshold
1.1.49 monitor resend cpu-usage
1.1.50 monitor resend cpu-usage core-interval
1.1.51 monitor resend memory-threshold dma
1.1.52 parity-error consistency-check log enable
1.1.53 parity-error consistency-check threshold
1.1.54 parity-error monitor log enable
1.1.55 parity-error monitor period
1.1.56 parity-error monitor threshold
1.1.57 parity-error unrecoverable log enable
1.1.58 parity-error unrecoverable period
1.1.59 parity-error unrecoverable reboot
1.1.60 parity-error unrecoverable threshold
1.1.61 power-exception-monitor
1.1.62 power-supply surplus-power enable
1.1.63 resource-monitor minor resend enable
1.1.64 resource-monitor output
1.1.65 resource-monitor resource
1.1.68 transceiver monitor enable
1.1.69 transceiver monitor interval
display alarm命令用来显示设备硬件的告警信息。
display alarm [ slot slot-number ]
slot slot-number:指定设备编号,取值只能为1。
# 显示设备硬件的告警信息。
<Sysname> display alarm
Slot CPU Level Info
1 0 ERROR faulty
表1-1 display alarm命令显示信息描述表
Slot |
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上 |
CPU |
告警CPU的编号 |
Level |
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO |
Info |
告警的详细信息。取值为: · faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态) · Fan n is absent:风扇n当前不在位 · Power n is absent:电源n当前不在位 · Power n is faulty:电源n处于异常状态 · The temperature of sensor n exceeds the lower limit:传感器n的温度低于低温门限 · The temperature of sensor n exceeds the upper limit:传感器n的温度高于高温门限 |
display alarm active命令用来显示设备当前仍未恢复的告警信息。
当设备运行异常时,使用display alarm命令可以查看到相应的告警信息。对于过去发生的、已经恢复的告警可以使用display alarm history命令查看;对于过去发生的、当前仍未恢复的告警可以使用display alarm active命令查看。
# 显示设备当前仍未恢复的告警信息。
<Sysname>display alarm active
Seq Level Time Info
24 MINOR 2020-01-11 12:40:00 CPU usage is in minor alarm state on slot 1 cpu 0.
23 MINOR 2020-01-11 12:30:00 Memory usage is in minor alarm state on slot 1 cpu 0.
22 WARNING 2020-01-11 12:30:00 Interface GigabitEthernet2/0/2 changed to DOWN state.
表1-2 display alarm active命令显示信息描述表
Seq |
告警序列号,告警发生时分配。 |
Level |
告警的级别,级别由高到低依次为CRITICAL、MAJOR、MINOR、WARNING |
Time |
告警产生的时间 |
Info |
告警的详细信息,涉及接口、CPU以及内存等运行异常,主要取值包括: · Memory usage is in minor alarm state on slot xx cpu xx:槽位xx上CPU xx的剩余内存低于一级告警门限 · Memory usage is in severe alarm state on slot xx cpu xx:槽位xx上CPU xx的剩余内存低于二级告警门限 · Memory usage is in critical alarm state on slot xx cpu xx:槽位xx上CPU xx的剩余内存低于三级告警门限 · CPU usage is in minor alarm state on slot xx cpu xx:槽位xx上CPU xx的使用率高于一级告警门限 · CPU usage is in critical alarm state on slot xx cpu xx:槽位xx上CPU xx的使用率高于二级告警门限 · Interface interface-name changed to DOWN state:接口Interface-name变为down状态 |
display alarm history命令用来显示设备告警历史信息。
display alarm history [ verbose ]
verbose:显示告警项的详细信息。不指定该参数时,显示概要信息。
# 显示设备告警历史信息。
<Sysname> display alarm history
Seq Time Info
23 2020-01-11 12:40:00 CPU usage severe alarm cleared on slot 1 cpu 0.
22 2020-01-11 12:30:00 Memory usage severe alarm cleared on slot 1 cpu 0.
21 2020-01-11 12:30:00 Physical state of GigabitEthernet2/0/2 changed back to UP.
20 2020-01-11 12:30:00 Protocol state of GigabitEthernet2/0/2 changed back to UP.
表1-3 display alarm active命令显示信息描述表
Seq |
告警序列号,告警发生时分配。 |
Level |
Time |
告警产生的时间 |
Info |
# 显示设备告警历史信息详细内容。
<Sysname> display alarm history verbose
Seq 24
Alarm name: CPUUsageMajor
Alarm source: Slot 1 cpu 0
Level: MAJOR
Occurred at: 2020-01-11 12:30:00
Info: CPU usage severe alarm occurred on state slot 1 cpu 0.
Cleared at: 2020-01-11 12:40:30
Info: CPU usage severe alarm cleared on slot 1 cpu 0.
Seq 23
Alarm name: MemoryUsageMajor
Level: MAJOR
Alarm source: Slot 1 CPU 0
Occurred at: 2020-01-11 12:35:00
Info: Memory usage severe alarm occurred on slot 1 cpu 0.
Cleared at: 2020-01-11 12:45:30
Info: Memory usage severe alarm cleared on slot 1 cpu 0.
表1-4 display alarm history verbose命令显示信息描述表
Seq |
告警序列号,告警发生时由系统自动分配 |
Alarm name |
告警的名称 |
AlarmPosition |
告警对象所在位置 |
Occurred at |
告警发生时间 |
Level |
Cleared at |
告警恢复时间 |
Info |
告警的详细信息 |
display cpu-usage命令用来显示CPU利用率的统计信息。
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
当最近5秒、最近1分钟、最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage summary
Slot CPU Last 5 sec Last 1 min Last 5 min
1 0 17% 29% 28%
表1-5 display cpu-usage命令显示信息描述表
1% in last 5 seconds |
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率 |
Last 5 sec |
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率。如果Last 5 sec的取值为“--”,则表示不支持统计该信息 |
1% in last 1 minute |
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率 |
Last 1 min |
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率。如果Last 1 min的取值为“--”,则表示不支持统计该信息 |
1% in last 5 minutes |
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率 |
Last 5 min |
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率。如果Last 5 min的取值为“--”,则表示不支持统计该信息 |
display cpu-usage configuration命令用来显示CPU监控功能的相关配置。
cpu cpu-number:表示CPU的编号。
# 显示CPU监控功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 79%.
表1-6 display cpu-usage configuration命令显示信息描述表
CPU usage monitor is enabled. |
CPU利用率历史记录功能处于开启状态 |
Current monitor interval is 60 seconds. |
CPU利用率历史记录的采样周期为60秒 |
Current severe alarm threshold is 99%. |
CPU利用率严重级别告警门限为99% |
Current minor alarm threshold is 79%. |
CPU利用率轻度级别告警门限为79% |
· monitor cpu-usage enable
· monitor cpu-usage interval
· monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理和监控命令参考”中的“系统维护与调试”。
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
· 纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
· 横坐标表示时间,时间越靠左表示距离当前时间越近。
· 用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备硬件信息。
display device [ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash:显示Flash的信息。
usb:显示USB接口的信息。
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息,且此时不会显示防火墙插卡的信息。
不指定cf-card、flash、harddisk、sd-card和usb参数时,显示成员设备的硬件信息。
# 显示设备硬件信息。
<Sysname> display device
Slot Subslot Type State Soft Ver Patch Ver
1 0 S12500R-48Y8C Master S12500R-48Y8C-5203P01 None
表1-7 display device命令显示信息描述表
Type |
设备类型 |
Soft Ver |
设备上运行的软件版本 |
Patch Ver |
当前设备上运行的、最新发布的热补丁版本。取值为None时表示没有安装热补丁 若同时安装了叠加补丁和非叠加补丁,则显示最新发布的叠加补丁。关于叠加补丁和非叠加补丁的介绍请参见“基础配置指导”中的“软件升级” |
display device manuinfo命令用来显示设备硬件的电子标签信息。
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
subslot subslot-number:显示指定子卡的电子标签信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
# 显示设备硬件的电子标签信息。
<Sysname> display device manuinfo
显示信息略……。
display device manuinfo fan命令用来显示风扇的电子标签信息。
display device manuinfo slot slot-number fan fan-id
fan-id:表示设备上风扇的ID编号。
# 显示指定风扇的电子标签信息。
<Sysname> display device manuinfo slot 1 fan 1
显示信息略……。
display device manuinfo power命令用来显示电源的电子标签信息。
display device manuinfo slot slot-number power power-id
power-id:表示设备上电源的ID编号。
# 显示指定电源的电子标签信息。
<Sysname> display device manuinfo slot 1 power 1
显示信息略……。
display environment命令用来显示设备上温度传感器的温度信息。
# 显示设备上所有温度传感器的温度信息。
<Sysname> display environment
System temperature information (degree centigrade):
Slot Sensor Temperature Lower Warning Alarm Shutdown
1 hotspot 1 26 0 75 90 95
1 hotspot 2 49 0 88 96 104
1 hotspot 3 49 0 75 90 95
1 hotspot 4 28 0 88 96 104
1 hotspot 5 31 0 75 90 95
1 hotspot 6 25 0 88 96 104
1 chip 0 38 0 60 60 90
1 cpu 1 21 0 102 102 NA
表1-8 display environment命令显示信息描述表
System Temperature information (degree centigrade) |
系统温度信息,单位为摄氏度 |
sensor |
温度传感器 · hotspot:表示热点温度传感器 · cpu:表示cpu温度传感器 · chip:表示芯片温度传感器 |
Slot |
当显示数字时表示指定slot上温度传感器的温度信息 |
Temperature |
当前温度 |
Lower |
低温告警门限。当显示为NA时,表示不支持该门限 |
Warning |
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限 |
Alarm |
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限 |
Shutdown |
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭。当显示为NA时,表示不支持该门限 |
display fan命令用来显示风扇的工作状态。
display fan [ slot slot-number [ fan-id ] ]
fan-id:表示设备内置风扇的编号。不指定该参数时,表示指定位置的所有风扇。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Fan-tray 1:
Status : Normal
Fan Type : FAN-40B-1-C
Fan number: 3
Fan mode : Auto
Airflow Direction: Fan-Panel-Exhaust
Fan Speed(rpm)
1 4615
2 4705
3 4589
Fan-tray 2:
Status : Normal
Fan number: 3
Fan mode : Auto
Fan Speed(rpm)
1 4749
2 4649
3 4560
---- More ----
表1-9 display fan命令显示信息描述表
Fan-tray |
风扇框编号 |
Status |
风扇框状态: · Absent:风扇不在位 · Normal:风扇正常工作 · Fault:风扇故障 |
Fan Type |
风扇框型号 |
Fan number |
风扇数量 |
Fan mode |
风扇框模式 |
Airflow Direction |
风扇模块的实际风道方向: · Fan-Panel-Exhaust:风扇面板侧出风 · Fan-Panel-Intake:风扇面板侧进风 |
Fan Speed(rpm) |
风扇转速 |
display fdisk-flash命令用来显示磁盘分区信息。
仅R5212P01及以上版本支持本命令。
display fdisk-flash slot slot-id
slot slot-id:表示盒式设备所在的槽位号。
# 显示磁盘分区信息。
<sysname> display fdisk-flash slot 0
New partition mode on slot 0 size 2GB
display hardware-resource acl-hash命令用来显示ACL哈希模式的状态
# 显示ACL哈希模式的状态。
<Sysname> display hardware-resource acl-hash
acl-hash mode(acl-hash), all supported modes:
disable Disable ACL hash mode with hash result calculated by the chip
enable Enable ACL hash mode with hash result caculated by the ACL
Default Current Next
disable disable disable
display hardware-resource mdb命令用来显示硬件资源的分配模式
display hardware-resource [ mdb ]
不指定mdb参数时,表示显示所有硬件资源的运行模式。
# 显示MAC地址表、ARP表、路由表硬件资源的分配模式。
<Sysname> display hardware-resource mdb
MDB resource(mdb), all supported modes:
normal The normal mode:MAC 506K, ARP 88K, route 1.5M
routing The routing mode:MAC 155K, ARP 98K, route 2.5M
routing routing routing
display hardware-resource bfd_enhance命令用来显示BFD优化功能的状态
display hardware-resource [ bfd_enhance ]
# 显示BFD优化功能的状态。
<Sysname> display hardware-resource bfd_enhance
bfd_enhance mode(bfd_enhance), all supported modes:
disable The disable bfd enhance
enable The enable bfd enhance
Default Current
enable enable
display hardware-resource opttask-delay命令用来显示MACsec设备端口识别延迟配置。
# 显示MACsec设备端口识别延迟配置。
<Sysname> display hardware-resource opttask-delay
opt task delay mode : enable
display hardware-resource port-speed命令用来显示设备的端口速率工作模式。
display hardware-resource [ port-speed ]
# 显示设备的端口速率工作模式。
<Sysname> display hardware-resource port-speed
Set card port speed module, all supported modes:
low low speed module
high high speed module
Slot Module
1 low
display hardware-resource smartman命令用来显示端口的licence生效状态
display hardware-resource [ smartman ]
# 显示端口的licence生效状态。
<Sysname> display hardware-resource smartman
smartman mode(smartman), all supported modes:
disable The disable smartman mode
enable The enable smartman mode
display hardware-resource telemetry-stream命令用来显示Telemetry Stream采集报文中的入接口索引类型。
仅R5212P06及以上版本支持本功能。
# 显示Telemetry Stream采集报文中的入接口索引类型。
<Sysname> display hardware-resource telemetry-stream
telemetry-stream, all supported modes:
link-aggregation-memberports The trunk members are mapped to the ifindex of th
e physical port in the telemetry stream.
link-aggregation The trunk members are mapped to the ifindex of th
e trunk in the telemetry stream.
Default Current
link-aggregation link-aggregation
display memory命令用来显示内存使用情况。
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
cpu cpu-number:表示CPU编号。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。
<Sysname> display memory
Memory statistics are measured in KB:
Slot 0:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 16335164 4145632 12189532 0 8596 2472508 77.5%
-/+ Buffers/Cache: 1664528 14670636
Swap: 0 0 0
Container memory statistics are measured in KB:
Slot 0:
Total Used Free UsageRatio
Mem: 16335164 2357588 12189532 14.4%
# 显示设备的内存使用情况的简要信息。
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
0 0 16335164 4144720 12190444 8596 2472508 77.5%
Slot CPU Total Used Free UsageRatio
0 0 16335164 2358048 12190444 14.4%
表1-10 display memory命令显示信息描述表
Memory statistics are measured in KB: |
物理设备中内存使用情况,以下统计信息均以KB为单位 |
Mem |
内存使用信息 |
Total |
系统可分配的物理内存的大小 设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小 |
Used |
整个系统已用的物理内存大小 |
Free |
整个系统可用的物理内存大小 |
Shared |
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值 |
Buffers |
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值 |
Cached |
高速缓冲寄存器已使用的内存大小。取值为“--”时,表示不支持统计该参数的值 |
Caches |
高速缓冲寄存器已使用的内存大小 |
FreeRatio |
整个系统物理内存的空闲率 |
-/+ buffers/cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小 -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小 |
Swap |
交换分区的使用信息 |
LowMem |
低端内存使用信息 |
HighMem |
高端内存使用信息 |
Container memory statistics are measured in KB |
Comware容器对内存的使用情况,包括: · Total:Comware容器总共可分配的物理内存的大小,单位为KB · Used:Comware容器已使用的物理内存的大小,单位为KB · Free:Comware容器可用的物理内存的大小,单位为KB · UsageRatio:Comware容器对物理内存的使用率 |
display memory dma命令用来显示DMA内存的使用情况。
display memory dma [ slot slot-number [ cpu cpu-number ] ]
仅R5212及以上版本支持本命令。
# 显示slot1的DMA内存使用相关信息。
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total Used Free FreeRatio
16384 6140 10244 63%
表1-11 display memory dma 命令显示信息描述表
DMA memory statistics measured in KB |
系统使用DMA内存情况,单位为KB |
Total |
内存分片的总个数,为Free和Used之和 |
Used |
系统已使用的DMA内存大小 |
Free |
系统可使用的DMA内存大小 |
FreeRatio |
Free与Total的比率,可以反映系统DMA内存的空闲率 |
display memory-threshold命令用来显示内存告警门限相关信息。
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
Minor: 1024M
Severe: 768M
Critical: 512M
Normal: 1280M
Early-warning: 0M
Secure: 0M
Current memory state: Normal
Event statistics:
[Back to normal state]
First notification: 0.0
Latest notification: 0.0
Total number of notifications sent: 0
[Enter minor low-memory state]
First notification at: 0.0
Latest notification at: 0.0
[Back to minor low-memory state]
[Enter severe low-memory state]
[Back to severe low-memory state]
[Enter critical low-memory state]
表1-12 display memory-threshold命令显示信息描述表
Memory usage threshold |
内存利用率阈值 |
Free-memory thresholds Minor Severe Critical Normal Early-warning Secure |
剩余内存门限阈值: · Minor:一级告警门限,单位为MB · Severe:二级告警门限,单位为MB · Critical:三级告警门限,单位为MB · Normal:恢复到正常状态的阈值,单位为MB · Early-warning:预警门限,单位为MB · Secure:恢复预警门限状态的阈值,单位为MB |
Current free-memory state |
系统当前内存使用状态: · Normal:正常状态 · Minor:一级告警门限状态 · Severe:二级告警门限状态 · Critical:三级告警门限状态 · Normal (early-warning):预告警状态 · Normal (secure):安全状态 |
Free-memory event statistics: |
门限事件统计信息,事件分为: · Back to secure state:恢复到预警前的状态 · Entered early-warning state:进入预告警门限状态 · Back to normal state:内存恢复到正常状态 · Entered minor alarm state:进入一级告警门限状态 · Back to minor alarm state:恢复到一级告警前的状态 · Entered severe alarm state:进入二级告警门限状态 · Back to severe alarm state:恢复到二级告警前的状态 · Entered critical alarm state:进入三级告警门限状态 |
First notification at |
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification at |
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notification send |
事件发生的总次数 |
display memory-threshold dma命令用来显示DMA内存告警相关信息。
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
仅R5212及以上版本支持本命令。
# 显示DMA内存告警相关信息。
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
Critical: 2048KB
Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
[Entered to critcal state]
表1-13 display memory-threshold dma 命令显示信息描述表
Free DMA memory thresholds: Critical: Normal: |
DMA内存告警阈值(单位为KB): · Critical:告警阈值 · Normal:告警恢复阈值 |
Current DMA memory state |
DMA内存的当前状态: · Critical:告警状态 · Normal:正常状态 |
Free memory event statistics: |
告警事件统计信息,事件分为: · Back to normal state:内存恢复到正常状态 · Entered to critcal state:进入告警状态 |
First notification |
告警事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification |
告警事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notifications sent |
告警事件发生的总次数 |
display power命令用来显示设备电源的信息。
display power [ slot slot-number [ power-id ] ]
power-id:表示电源模块的编号。不指定该参数时,表示指定位置的所有电源。
# 显示设备电源的简要信息。
<Sysname> display power
Slot 1:
Input Power: 99(W)
PowerID State Mode Current(A) Voltage(V) Power(W) FanDirection
1 Normal AC 5.40 12.35 66 PowerToPort
2 Normal AC 2.85 10.00 33 PortToPower
表1-14 display power命令显示信息描述表
Input Power |
设备的额定功率 |
PowerID |
设备上的电源模块编号 |
State |
电源模块的状态 · Absent:电源不在位 · Normal:电源正常工作 · Fault:电源故障 |
Mode |
电源模块的类型,取值为: · AC:表示交流电源 · DC:表示直流电源 |
Current(A) |
电源输出电流,单位为安,显示为“--”表示设备暂不支持统计该信息 |
Voltage(V) |
电源输出电压,单位为伏,显示为“--”表示设备暂不支持统计该信息 |
Power(W) |
电源输出功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息 |
FanDirection |
电源模块内风扇的吹风方向,取值为: · PowerToPort:电源侧进风、端口侧出风 · PortToPower:端口侧进风、电源侧出风 |
display resource-monitor命令用来显示资源监控功能的相关信息。
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name:需要监测的资源的名称。参数的取值请参见表1-25。
cpu cpu-number:显示指定CPU的资源告警事件通知功能的相关信息。cpu-number表示需要检测的资源所在CPU的编号。
# 显示ARP资源监控的相关信息。
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource Minor Severe Free/Total
(%) (%) (absolute)
arp 50 20 90095/90098
表1-15 display resource-monitor命令显示信息描述表
Minor alarms resending |
周期发送低级别资源告警通知功能的开启状态: · Enabled:表示该功能已开启 · Disabled:表示该功能未开启 |
Resource |
监控资源的名称 |
Minor (%) |
低级别告警门限,单位为百分比 |
Severe (%) |
高级别门限,单位为百分比 |
Free/Total (absolute) |
剩余资源的数量/该资源的总数,用绝对值形式表示 |
· resource-monitor minor resend enable
· resource-monitor resource
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-16 SFP/SFP+的display transceiver alarm命令输出信息描述表
RX loss of signal |
接收信号丢失 |
RX power high |
接收光功率高 |
RX power low |
接收光功率低 |
TX fault |
发送错误 |
TX bias high |
偏置电流高 |
TX bias low |
偏置电流低 |
TX power high |
发送光功率高 |
TX power low |
发送光功率低 |
Temp high |
温度高 |
Temp low |
温度低 |
Voltage high |
电压高 |
Voltage low |
电压低 |
Transceiver info I/O error |
模块信息读写错误 |
Transceiver info checksum error |
模块信息校验和错误 |
Transceiver type and port configuration mismatch |
模块类型和端口配置不匹配 |
Transceiver type not supported by port hardware |
端口不支持该模块类型 |
TEC fault |
TEC(Thermoelectric Cooler,热点冷却器)错误。仅SFP-XG-LH80-Tunable光模块支持显示该信息 |
Wavelength unlocked |
光信号波长失锁。仅SFP-XG-LH80-Tunable光模块支持显示该信息 |
Tx is not ready due to tuning |
光信号波长改变时发射端处于准备过程状态告警。仅SFP-XG-LH80-Tunable光模块支持显示该信息 |
表1-17 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high |
温度高 |
Temp low |
温度低 |
Voltage high |
电压高 |
Voltage low |
电压低 |
RX signal loss in channel x |
通道x接收到的信号丢失 |
TX fault in channel x |
通道x发送报文时出错 |
TX signal loss in channel x |
通道x发送的信号丢失 |
RX power high in channel x |
通道x接收到的光的功率太高 |
RX power low in channel x |
通道x接收到的光的功率太低 |
TX bias high in channel x |
通道x的偏置电流高 |
TX bias low in channel x |
通道x的偏置电流低 |
模块读写错误 |
模块信息校验和错误 |
Transceiver type and port configuration mismatched |
模块类型和端口配置不匹配 |
Transceiver type not supported |
端口不支持该类型的模块 |
表1-18 QSFP-DD光模块的display transceiver alarm命令输出信息描述表
Data path firmware fault |
数据通道固件错误 |
Module firmware fault |
模块固件错误 |
Module state changed |
模块状态改变 |
Data path state changed in channel x |
通道x的数据路径状态改变 |
TX loss in channel x |
通道x的发送信号丢失 |
TX CDR LOL in channel x |
通道x的TX 时钟和数据恢复失锁 |
TX input eq fault in channel x |
通道x的TX输入均衡错误 |
RX CDR LOL in channel x |
通道x的RX 时钟和数据恢复失锁 |
Loss of reference clock |
基准时钟丢失 |
L-host pattern generator LOL in channel x |
通道x的主机端码型发生器失锁 |
L-media pattern generator LOL in channel x |
通道x的介质端模式发生器失锁 |
L-host pattern checker LOL in channel x |
通道x的主机端码型检查器失锁 |
L-media pattern checker LOL in channel x |
通道x的介质端模式检查器失锁 |
TEC Current high |
制冷器工作电流/制冷器的额定电流高告警 |
TEC Current low |
制冷器工作电流/制冷器的额定电流低告警 |
Laser Temperature high |
激光器温度高告警 |
Laser Temperature low |
激光器温度低告警 |
Temp high warning |
模块温度高预警 |
Temp low warning |
模块温度低预警 |
Voltage high warning |
模块电压高预警 |
Voltage low warning |
模块电压低预警 |
RX power high warning(channel x) |
通道x的接收功率高预警 |
RX power low warning(channel x) |
通道x的接收功率低预警 |
TX power high warning(channel x) |
通道x的发送功率高预警 |
TX power low warning(channel x) |
通道x的发送功率低预警 |
TX bias high warning(channel x) |
通道x的发送电流高预警 |
TX bias low warning(channel x) |
通道x的发送电流低预警 |
TEC Current high warning |
制冷器工作电流/制冷器的额定电流高预警 |
TEC Current low warning |
制冷器工作电流/制冷器的额定电流低预警 |
Laser Temperature high warning |
激光器温度高预警 |
Laser Temperature low warning |
激光器温度低预警 |
VDM: Laser temperature high alarm |
VDM(Versatile diagnostics monitoring,多功能诊断监控)中的激光器温度高告警 |
VDM: Laser temperature low alarm |
VDM中的激光器温度低告警 |
VDM: Host current pre-FEC BER high alarm(channel x) |
VDM中通道x主机侧前向纠错误码率高告警 |
VDM: Host current pre-FEC BER low alarm(channel x) |
VDM中通道x主机侧前向纠错误码率低告警 |
VDM: Media current pre-FEC BER high alarm(channel x) |
VDM中通道x介质侧前向纠错误码率高告警 |
VDM: Media current pre-FEC BER low alarm(channel x) |
VDM中通道x介质侧前向纠错误码率低告警 |
VDM: Media current pre-FEC BER high warning(channel x) |
VDM中通道x介质侧前向纠错误码率高预警 |
VDM: Media current pre-FEC BER low warning(channel x) |
VDM中通道x介质侧前向纠错误码率低预警 |
VDM: RX Total Power high alarm(channel 1) |
VDM中通道1接收总功率高告警 |
VDM: RX Total Power low alarm(channel 1) |
VDM中通道1接收总功率低告警 |
VDM: RX Total Power high warning(channel 1) |
VDM中通道1接收总功率高预警 |
VDM: RX Total Power low warning(channel 1) |
VDM中通道1接收总功率低预警 |
Media-side Rx Loss of Frame |
介质侧接收丢失的帧数 |
Media-side Rx Loss of Multi-Frame |
介质侧接收丢失的多帧数 |
VDM: CFO high alarm |
VDM中CFO(Carrier Frequency Offset载波频率偏移)高告警 |
VDM: CFO low alarm |
VDM中CFO低告警 |
# 显示接口HundredGigE1/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver current alarm information:
RX loss of signal
RX power low
表1-19 display transceiver alarm显示信息描述表
transceiver current alarm information |
接口光模块当前故障告警信息 |
RX loss of signal |
接收信号丢失 |
RX power low |
接收光功率低告警 |
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口HundredGigE1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver diagnostic information:
Temp(C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
Temp(C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
<Sysname> display transceiver diagnosis interface hundredgige 1/0/1:1
HundredGigE1/0/1:1 transceiver diagnostic information:
[module] Temp.(C) Voltage(V)
43 3.30
[channel] Bias(mA) RX power(dBm) TX power(dBm)
1 7.39 -36.96 1.13
2 7.39 -36.96 0.99
3 7.39 -36.96 1.08
4 7.39 -36.96 1.11
Alarm thresholds:
Temp.(C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
High 85 3.64 15.00 3.40 5.40
Low -15 2.97 3.00 -14.00 -12.10
# 显示接口FourHundredGigE1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver diagnostic information:
[Module] Temp(C) Voltage(V) TEC Current(%) Laser Temp(C)
40 3.34 38 53
[Channel] Bias(mA) RX power(dBm) TX power(dBm)
1 1.13 -20.43 -1.0
2 1.13 -20.43 -1.0
3 1.13 -20.43 -1.0
4 1.13 -20.43 -1.0
5 1.13 -20.43 -1.0
6 1.13 -20.43 -1.0
7 1.13 -20.43 -1.0
8 1.13 -20.43 -1.0
Alarm thresholds:
High 80 3.64 15.00 5.00 5.50
Low -10 2.97 4.50 -12.00 -3.50
TEC Curr(%) Laser Temp(C)
High N/A N/A
Low N/A N/A
Warning thresholds:
High 70 3.47 10.00 4.00 4.00
Low 0 3.13 0.00 -9.50 -6.50
High N/A N/A
Low N/A N/A
Alarm thresholds:
Media performance monitoring:
Rx bits : 12345678901234567890
Rx FEC corrected bits : 12345678901234567890
Rx frames : 12345678901234567890
Rx uncorrectable frames : 12345678901234567890
Host performance monitoring:
Tx bits : 12345678901234567890
Tx FEC corrected bits : 12345678901234567890
Tx frames : 12345678901234567890
Tx uncorrectable frames : 12345678901234567890
表1-20 display transceiver diagnosis显示信息描述表
transceiver diagnostic information |
接口插入的光模块的数字诊断信息 |
Current diagnostic parameters |
当前的诊断参数 |
Wave.er(nm) |
波长偏移,单位为nm,精确到0.001nm。仅SFP-XG-LH80-Tunable光模块支持显示该字段 |
Freq.er(GHz) |
频率偏移,单位为GHZ,精确到0.1GHZ。仅SFP-XG-LH80-Tunable光模块支持显示该字段 |
[Module] |
整个光模块的参数信息 |
Temp.(C) |
数字诊断参数——温度,单位为°C,精确到1°C |
Voltage(V) |
数字诊断参数——电压,单位为V,精确到0.01V |
TEC Current(%) |
数字诊断参数——制冷器工作电流/制冷器的额定电流,单位为%,精确到0.01% |
Laser Temp(C) |
数字诊断参数——激光器温度,单位为°C,精确到0.01°C |
[Channel] |
光通道的编号,也称为lane |
Bias(mA) |
数字诊断参数——偏置电流,单位为mA,精确到0.01mA |
RX power(dBm) |
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm |
TX power(dBm) |
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm |
Alarm thresholds |
告警门限 |
High |
高告警门限 |
Low |
低告警门限 |
TEC Curr. (%) |
数字诊断参数——制冷器工作电流,单位为%,精确到0.01% |
Laser Temp. (C) |
表1-21 display transceiver diagnosis显示信息中光学参数统计信息描述表(本表中的显示信息仅CMIS 4.0光模块支持)
Media performance monitoring |
介质侧性能监控 |
Host performance monitoring |
主机侧性能监控 |
Rx bits |
接收比特数 |
Rx FEC corrected bits |
FEC纠正的接收比特数 |
Rx frames |
接收帧数 |
Rx uncorrectable frames |
FEC无法纠正的接收帧数 |
Tx bits |
发送比特数 |
Tx FEC corrected bits |
FEC纠正的发送比特数 |
Tx frames |
发送帧数 |
Tx uncorrectable frames |
FEC无法纠正的发送帧数 |
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口HundredGigE1/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver information:
Transceiver type : 400G_BASE_SR8_QSFPDD
Connector type : MPO
Wavelength (nm) : 850
Transfer distance (m) : 70(OM3),100(OM4)
Max power(W) : 12
Digital diagnostic monitoring : Yes
Vendor name : H3C
表1-22 display transceiver interface命令显示信息描述表
transceiver information |
可插拔接口模块信息 |
Transceiver Type |
可插拔接口模块的物理型号 |
Connector Type |
可插拔接口模块的连接器类型,其中: · 光纤连接器包括SC(SC Connector,NTT公司推出的拔插锁紧式光纤连接器)、LC(LC Connector,Lucent公司推出的1.25mm/RJ45锁紧式光纤连接器)两种类型 · 其他连接器包括RJ-45、CX4等类型 |
Wavelength(nm) |
· 光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块(例如10GBASE-LX4模块),各个波长值之间用逗号分隔 · 电模块:显示为“N/A” |
Transfer Distance(xx) |
传输距离,对于单模模块,xx显示为km,其他模块xx显示为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称: · 9um:表示9/125um单模光纤 · 50um:表示50/125um OM2多模光纤 · 62.5um:表示62.5/125um OM1多模光纤 · CX4:表示CX4电缆 · OM3:表示50um OM3多模光纤 · OM4:表示50um OM4多模光纤 · OM5:表示50um OM5多模光纤 · STACK:表示堆叠线 · TP:表示双绞线 |
Max power(W) |
光模块的最大功耗 |
Digital Diagnostic Monitoring |
对数字诊断功能的支持情况,其中: · YES:表示支持数字诊断 · NO:表示不支持数字诊断 |
Vendor Name |
模块生产或定制厂商名称 |
Ordering Name |
可插拔接口模块的对外型号 |
display transceiver itu-channel命令用来显示光模块的ITU通道信息。
display transceiver itu-channel interface [ interface-type interface-number [ supported-channel ] ]
interface:显示接口上插入的光模块当前使用的ITU通道的信息。
interface-type interface-number:显示指定光模块当前使用的ITU通道的信息。interface-type interface-number表示接口类型和接口编号。不指定该参数时,表示所有接口上光模块当前使用的ITU通道的信息。
supported-channel:仅显示接口支持配置的ITU通道的信息。不指定该参数时,仅显示光模块当前使用的ITU通道的信息。
本命令仅SFP-XG-LH80-Tunable光模块支持。
# 显示GigabitEthernet1/0/1上插入的光模块当前使用的ITU通道的信息。
<Sysname> display transceiver itu-channel interface gigabitethernet 1/0/1
Interface Channel WaveLength(nm) Frequency(THz)
GE1/0/1 1 1566.72 191.35
# 显示GigabitEthernet1/0/1上插入的光模块支持配置的ITU通道的信息。
<Sysname> display transceiver itu-channel interface gigabitethernet 1/0/1 supported-channel
ITU channel settings supported on GigabitEthernet1/0/1 :
1 1566.72 191.35
2 1566.31 191.40
3 1565.90 191.45
4 1565.50 191.50
5 1565.09 191.55
6 1564.68 191.60
7 1564.27 191.65
8 1563.86 191.70
其它显示信息略……。
表1-23 display transceiver itu-channel interface命令显示信息描述表
光模块所在接口的简称 |
Channel |
ITU通道编号 |
WaveLength(nm) |
通道编号对应的波长,单位为nm,精确到0.01nm。取值为“-”时,表示对应接口显示ITU通道信息失败,失败原因有: · 该接口上未插入光模块 · 该接口上光模块不支持配置ITU通道编号 · 光模块获取ITU通道信息失败 · 设备不支持光模块上当前存储的ITU通道编号 |
Frequency(THz) |
通道编号对应的频率,单位为THZ,精确到0.01THZ。取值为“-”时,表示对应接口显示ITU通道信息失败,失败原因有: · 该接口上未插入光模块 · 该接口上光模块不支持配置ITU通道编号 · 光模块获取ITU通道信息失败 · 设备不支持光模块上当前存储的ITU通道编号 |
· itu-channel
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口HundredGigE1/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver manufacture information:
Manu. Serial Number : 213410A0000054000251
Manufacturing Date : 2019-09-01
Vendor Name : H3C
表1-24 display transceiver manuinfo命令显示信息描述表
Manu. Serial Number |
在调测(调试、测试)过程中生成的序列号 |
Manufacturing Date |
调测日期,取值为调测平台计算机的系统日期 |
Vendor Name |
定制厂商名称,即H3C |
hardware-failure-detection命令用来配置当系统检测到硬件故障时自动采取的修复操作。
undo hardware-failure-detection命令用来恢复缺省情况。
hardware-failure-detection { board | chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
当系统检测到器件、设备和转发的硬件故障时,修复操作均为reset。
board:对设备故障进行在线检测,包括控制通道检测和设备状态快速检测。
chip:对器件故障进行在线检测,包括设备上各种器件(比如芯片、电容、电阻等)的检测。
forwarding:对转发层面的故障进行在线检测,包括业务自动检测和其他转发相关的检测。
isolate:检测到故障时,设备会自动关闭端口、隔离设备、禁止设备加载或给设备下电,从而尽量减小故障的影响。
off:检测到故障时,设备不进行任何操作。
reset:检测到故障时,设备会自动重启器件/设备以尝试修复故障。
warning:检测到故障时,设备发送Trap信息,不会修复故障。
设备启动后,系统会持续自动检测器件、设备和转发的硬件故障。
# 配置系统检测到器件故障时自动告警。
[Sysname] hardware-failure-detection chip warning
fdisk-flash slot命令用来给磁盘进行分区。
undo fdisk-flash slot命令用来回收磁盘分区。
fdisk-flash slot slot-id [ size size-value ]
undo fdisk-flash slot slot-id
缺省情况下,未对磁盘进行分区。
分区操作前,请做好如下准备:
· 请务必做好文件备份,分区操作会清除磁盘中的所有数据。
· 请确认分区过程中,无其他用户访问该磁盘。
· 对磁盘介质分区前,请确保没有对磁盘设置写保护。
仅C3000 CPU系列的式设备支持磁盘分区功能。
对磁盘分区完后需要重启设备且在BTW下格式化才能生效。
size size-value:取值范围为1~4,指定分区的大小,单位GB。如果未指定size,默认为2GB。
# 对磁盘进行分区
<sysname> system-view
[Sysname] fdisk-flash slot 0
Please back up important files, if you do not back up, the data may be lost.
Whether to continue to divide [Y/N]:Y
New partition mode set successfully on slot 0!
Whether to restart immediately [Y/N]:Y
Now rebooting, please wait...
hardware-resource acl-hash命令用来使能或者去使能ACL哈希模式。
hardware-resource acl-hash { disable | enable }
未使能ACL哈希模式。
disable:去使能ACL哈希模式,哈希结果由芯片计算。芯片计算哈希结果时不能区分五元组中的源IP地址和目的IP地址,例如hash option选择了源IP地址,则目的IP地址变化也会影响到哈希。
enable:使能ACL哈希模式,哈希结果由ACL计算。
本命令仅适用于普通IPv4报文,不适用于封装报文与IPv6报文。配置成功后需要重启设备才能生效。
# 使能ACL哈希模式。
[Sysname] hardware-resource acl-hash enable
Do you want to change the specified hardware resource working mode? [Y/N]: y
The hardware resource working mode is changed, please save the configuration and reboot the system to make it effective.
hardware-resource mdb命令用来配置mdb资源运行的分配模式
hardware-resource mdb { normal | routing }
mdb资源运行的分配模式为路由模式。
normal:正常模式。该模式下MAC地址表、ARP表、路由表的规格分别为506K / 88K / 1.5M。
routing:路由模式。该模式下MAC地址表、ARP表、路由表的规格分别为155K / 98K / 2.5M。
本命令配置成功后需要重启设备才能生效。
# 配置mdb资源运行的分配模式为正常模式。
[Sysname] hardware-resource mdb normal
Do you want to change the specified hardware resource working mode? [Y/N]:Y
hardware-resource opttask-delay命令用来配置MACsec设备端口模块识别延迟功能。
hardware-resource opttask-delay { enable | disable } [ slot slot-number ]
MACsec设备端口模块识别延迟功能处于开启状态。
enable:开启MACsec设备端口模块识别延迟功能。
disable:关闭MACsec设备端口模块识别延迟功能。
本命令仅对S12500R-48C6D设备生效。
修改MACsec设备端口模块识别延迟功能,必须重启设备,配置才能生效。
# 开启MACsec设备端口模块识别延迟功能。
[Sysname] hardware-resource opttask-delay enable slot 1
The port speed mode is changed, to make it effective please reboot the slot.
hardware-resource port-speed命令用来配置设备的端口速率工作模式。
hardware-resource port-speed { high | low } [ slot slot-number ]
设备的端口以低速率模式工作。
high:设置设备端口以高速率模式工作。
low:设置设备端口以低速率模式工作
修改设备的端口速率工作模式后,必须重启设备,配置才能生效。
# 将端口设置为高速率工作模式。
[Sysname] hardware-resource port-speed high slot 1
hardware-resource smartman命令用来配置端口的licence生效状态。
hardware-resource smartman { enable | disable }
端口的licence不能正常生效。
enable:端口的license正常生效。
disable:端口的licence不能正常生效。
若要执行license的相关功能时,必须首先为设备安装相应的license,本命令仅用来配置已安装的license是否能够正常生效。
修改生效状态后,必须重启设备,配置才能生效。
# 配置端口的licence正常生效。
[Sysname] hardware-resource smartman enable
hardware-resource telemetry-stream用来配置Telemetry Stream采集报文中的入接口索引类型。
hardware-resource telemetry-stream { link-aggregation | link-aggregation-memberports }
在聚合成员接口、三层聚合接口或三层聚合子接口上配置Telemetry Stream动作时,Telemetry Stream采集到的报文入接口索引值是聚合接口的索引值。
link-aggregation:配置Telemetry Stream采集聚合接口的索引值。
link-aggregation-memberports:配置Telemetry Stream采集聚合成员接口的索引值。
本命令配置后立即生效,无需重启设备。
# 配置Telemetry Stream采集到的报文入接口索引值是聚合接口的索引值。
[Sysname] hardware-resource telemetry-stream link-aggregation
Do you want to change the type of interface index to be collected? [Y/N]:Y
itu-channel命令用来配置光模块的ITU通道编号。
undo itu-channel命令用来恢复缺省情况。
itu-channel channel-number
undo itu-channel
光模块的ITU通道编号为1。
以太网接口视图
channel-number:表示光模块的ITU通道编号。
配置该命令后,设备会将ITU通道编号保存在光模块内部的寄存器中,不会保存到配置文件中。
# 将GigabitEthernet1/0/1上插入的光模块的ITU通道编号配置为2。
[Sysname-GigabitEthernet1/0/1] itu-channel 2
Changing the channel number causes the service to be down for a while. Continue? [Y/N]:Y
· display transceiver itu-channel
locator blink blink-time命令用来定位设备的位置。
locator blink stop命令用来停止定位。
locator [ slot slot-number ] blink blink-time
locator [ slot slot-number ] blink stop
blink-time:闪烁的持续时间,取值范围为5~120,单位为秒。
stop:停止闪烁。
配置locator blink blink-time命令后,指定设备上用于定位的LED灯会以间隔快闪的方式闪烁,并持续指定的时间。用户可根据LED灯的指示来定位设备所在的位置。
blink-time时间到或者执行locator blink stop命令,则定位闪烁的LED灯会恢复正常点亮状态。
# 开始定位。
<Sysname> locator blink 30
# 结束定位。
<Sysname> locator blink stop
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
一级告警门限为1024MB,二级和三级告警门限均为768MB,系统恢复到正常的内存门限为1280MB,预告警门限和预告警恢复门限均为1152MB。
ratio:表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
severe severe-value:二级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
critical critical-value:三级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小。输入该参数的值时可通过输入?,来获取该参数的取值范围。
early-warning early-warning-value:预告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
secure secure-value:预告警恢复门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
系统实时监控剩余空闲内存大小,当条件达到一级、二级、三级告警门限或者恢复正常状态门限时,就产生相应的告警/告警解除通知,通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
除了一级、二级、三级告警,设备还支持预告警功能。预告警门限用于内存使用率尚处于正常范围内,但需要提醒用户提前关注内存的情况。预告警恢复门限用于解除预告警。
缺省情况下,本系列设备二级门限和三级门限相同,可以手工配置使二级门限和三级门限不同。
二、三级门限值相同时,二级门限满足以下条件,设备会重启。
· 产生二级告警后,剩余空闲内存值持续小于二级告警门限,其时长到达30秒,则系统会重启设备。
· 如果连续产生两次二级告警的时间间隔小于30秒,则系统会重启设备。
· 如果3分钟内产生二次二级告警,则系统会重启设备。
· 产生二级告警后,系统将会周期采样,预测剩余空闲内存是否会在30秒之内耗尽,如果预测结果为会在30秒之内耗尽,则系统会重启设备。
二、三级门限值不同时,设备达到二级门限则不会重启,三级门限满足以下条件,设备才会重启。
· 产生三级告警后,剩余空闲内存值持续小于三级告警门限,其时长到达30秒,则系统会重启设备。
· 如果连续产生两次三级告警的时间间隔小于30秒,则系统会重启设备。
· 如果3分钟内产生二次三级告警,则系统会重启设备。
· 产生三级告警后,系统将会周期采样,预测剩余空闲内存是否会在30秒之内耗尽,如果预测结果为会在30秒之内耗尽,则系统会重启设备。
关于告警门限的详细介绍请参见“设备管理配置指导”中的“硬件资源管理配置”。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# 配置一级、二级、三级告警门限分别为设备总内存的3%、2%、1%,当剩余空闲内存大于设备总内存的5%时,恢复到正常状态。
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
· display memory-threshold
memory-threshold dma命令用来配置DMA(Direct Memory Access,直接内存存取)内存告警阈值。
undo memory-threshold dma命令用来恢复缺省情况。
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
缺省情况下,告警阈值为2048KB,告警恢复阈值为4096KB。
ratio:以百分比配置阈值。
critical critical-value:告警阈值。当指定ratio参数时,critical-value为百分比,取值范围为0~100;当不指定ratio参数时,critical-value单位为KB,取值范围为0~4177920。
normal normal-value:告警恢复阈值。当指定ratio参数时,normal-value为百分比;当不指定ratio参数时,normal-value单位为KB。设备会根据critical-value的配置值自动调整normal-value的取值范围,请以设备的实际情况为准。
部分业务的运行需要使用DMA内存,如果DMA内存不足,会导致业务模块功能异常。系统周期监控DMA空闲内存大小,当DMA空闲内存小于或等于告警阈值,产生告警事件并重启设备。
仅R5212及以上版本支持本命令。
# 配置Slot 1的DMA内存告警的阈值为32KB,告警恢复阈值为96KB。
[Sysname] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
monitor chipblock reset命令用来启用芯片复位功能。
undo monitor chipblock命令用来关闭芯片复位功能。
monitor chipblock reset [ logging ]
芯片复位功能处于开启状态。
logging:指定该参数时,芯片复位的同时将记录日志信息。
芯片发生故障时,系统会打印告警信息。通过配置本命令,可实现系统告警时复位芯片。
# 开启芯片复位功能。
[Sysname] monitor chipblock reset
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
· display cpu-usage configuration
· display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
undo monitor cpu-usage interval命令用来恢复缺省情况。
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
monitor cpu-usage threshold severe-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
CPU利用率高级别告警门限为99%,低级别告警门限为79%,未配置恢复门限。
severe-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。不指定该参数时,该参数的取值为severe-threshold*0.8。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。不指定该参数时,该参数的取值为severe-threshold*0.7。
系统每隔1分钟会对CPU以及CPU核的利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为利用率过高,设备会进行相应的处理。
# 配置CPU利用率告警门限为90%。
[Sysname] monitor cpu-usage threshold 90
monitor resend cpu-usage命令用来配置发送CPU告警事件的间隔。
undo monitor resend cpu-usage命令用来取消CPU告警事件发送间隔的配置。
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU高级别告警事件。
minor-interval minor-interval:CPU低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,CPU将进入该级别告警状态并生成相应的告警事件。
CPU处于低级别告警状态时,会周期发送CPU低级别告警事件,直到CPU进入高级别告警状态或者低级别告警状态解除。CPU处于高级别告警状态时,会周期发送CPU高级别告警事件,直到高级别告警状态解除。使用本命令可以修改CPU告警事件的发送周期。
执行undo monitor resend cpu-usage命令不指定minor-interval和severe-interval参数时,表示将这两个参数恢复到缺省情况。当指定某一个参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0低级别告警事件的发送周期为60秒。
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend cpu-usage core-interval命令用来配置发送CPU核告警事件的间隔。
undo monitor resend cpu-usage core-interval命令用来取消CPU核告警事件发送间隔的配置。
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
发送CPU核低级别事件告警间隔时间为300秒,发送CPU核高级别事件告警间隔时间为60秒。
minor-interval minor-interval:CPU核低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU核高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU核使用率进行统计,并将统计值与告警门限进行比较。当统计值从小于或等于变成大于告警门限时,CPU核将进入该告警状态并生成告警事件。
CPU核处于告警状态时,会周期发送CPU核告警事件,直到CPU核告警状态解除。使用本命令可以修改CPU核告警事件的发送周期。
# 配置设备上所有CPU核发送告警事件的间隔:低级别告警为100秒、高级别告警为60秒。
[Sysname] monitor resend cpu-usage core-interval minor-interval 100 severe-interval 60
monitor resend memory-threshold dma命令用来配置发送DMA内存告警事件的间隔。
undo monitor resend memory-threshold dma命令用来恢复缺省情况。
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
缺省情况下,DMA内存告警事件周期发送的间隔为300秒。
critical-interval:DMA内存告警事件周期发送的间隔,取值范围为10~3600,单位为秒。
设备定期对DMA内存使用率进行统计,并将统计值与告警门限进行比较。当统计值从小于或等于变成大于告警门限时,DMA内存将进入该告警状态并生成告警事件。
仅R5212及以上版本支持本命令。
# 配置发送DMA内存告警事件的间隔为100秒。
[Sysname] monitor resend memory-threshold dma critical-interval 100
parity-error consistency-check log enable命令用来开启软硬件表项一致性检查日志信息功能。
undo parity-error consistency-check log enable命令用来关闭软硬件表项一致性检查日志信息功能。
软硬件表项一致性检查日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项和软件表项进行一致性检查。配置本命令后,在采样周期内,如果检查软硬件表项的不一致次数达到通过parity-error consistency-check threshold命令配置的错误次数阈值,则生成软硬件表项一致性检查日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“设备管理配置指导”中的“信息中心”。
# 开启软硬件表项一致性检查日志信息功能。
[Sysname] parity-error consistency-check log enable
· parity-error consistency-check threshold
parity-error consistency-check threshold命令用来配置软硬件表项一致性检查的错误次数阈值。
undo parity-error consistency-check threshold命令用来恢复缺省情况。
parity-error consistency-check threshold value
软硬件表项一致性检查的错误次数阈值为10次。
value:表示软硬件表项一致性检查的错误次数阈值,取值范围为1~2147483647,单位为次数。
在开启软硬件表项一致性检查日志信息功能后,配置本命令后,设备在软硬件表项一致性检查错误次数的采样周期内,当检查到软硬件表项不一致的错误次数达到配置的阈值时,会生成软硬件表项一致性检查日志信息。
# 配置软硬件表项一致性检查的错误次数阈值为20次。
[Sysname] parity-error consistency-check threshold 20
parity-error monitor log enable命令用来开启硬件表项奇偶校验和ECC校验日志信息功能。
undo parity-error monitor log enable命令用来关闭硬件表项奇偶校验和ECC校验日志信息功能。
对于R2719P02之前的版本,硬件表项奇偶校验和ECC校验日志信息功能处于关闭状态;
对于R2719P02及之后的版本,硬件表项奇偶校验和ECC校验日志信息功能处于开启状态。
设备在运行过程中,会自动对转发芯片中硬件表项进行奇偶校验和ECC校验,并记录错误次数。配置本命令后,在通过parity-error monitor period命令配置的采样周期内,如果硬件表项的奇偶校验和ECC校验的错误次数达到通过parity-error monitor threshold命令配置的错误次数阈值,则生成硬件表项奇偶校验和ECC校验日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“设备管理配置指导”中的“信息中心”。
# 开启硬件表项奇偶校验和ECC校验日志信息功能。
[Sysname] parity-error monitor log enable
· parity-error monitor period
· parity-error monitor threshold
parity-error monitor period命令用来配置硬件表项奇偶校验和ECC校验错误次数的采样周期。
undo parity-error monitor period命令用来恢复缺省情况。
parity-error monitor period period
硬件表项奇偶校验和ECC校验错误次数的采样周期为60秒。
period:表示硬件表项奇偶校验和ECC校验错误次数的采样周期,取值范围为1~86400,单位为秒。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在配置的硬件表项内,当硬件表项奇偶校验和ECC校验的错误次数达到阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置奇偶校验和ECC校验错误次数的采样周期为120秒。
[Sysname] parity-error monitor period 120
· parity-error monitor log enable
parity-error monitor threshold命令用来配置硬件表项奇偶校验和ECC校验的错误次数阈值。
undo parity-error monitor threshold命令用来恢复缺省情况。
parity-error monitor threshold value
对于R2719P02之前的版本,硬件表项奇偶校验和ECC校验的错误次数阈值为5000次;
对于R2719P02及之后的版本,硬件表项奇偶校验和ECC校验的错误次数阈值为20000次。
value:表示硬件表项奇偶校验和ECC校验的错误次数阈值,取值范围为1~1000000,单位为次数。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在硬件表项奇偶校验和ECC校验错误次数的采样周期内,当校验错误次数达到配置的阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置硬件表项奇偶校验和ECC校验的错误次数阈值为8000次。
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable命令用来开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
undo parity-error unrecoverable log enable命令用来关闭关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项进行奇偶校验和ECC校验。在硬件表项奇偶校验和ECC校验发现错误时,会尝试恢复这些错误。配置本命令后,当一些关键硬件表项的校验错误不可恢复时,在通过parity-error unrecoverable period命令配置的采样周期内,如果关键硬件表项的校验错误不可恢复的次数达到通过parity-error unrecoverable threshold命令配置的不可恢复次数阈值,则会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“设备管理配置指导”中的“信息中心”。
# 开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
[Sysname] parity-error unrecoverable log enable
· parity-error unrecoverable period
· parity-error unrecoverable reboot
· parity-error unrecoverable threshold
parity-error unrecoverable period命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期。
undo parity-error unrecoverable period命令用来恢复缺省情况。
parity-error unrecoverable period period
关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为60秒。
period:表示关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期,取值范围为1~86400,单位为秒。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在配置的采样周期内,当关键硬件表项奇偶校验和ECC校验错误的不可恢复次数达到阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为120秒。
[Sysname] parity-error unrecoverable period 120
· parity-error unrecoverable log enable
parity-error unrecoverable reboot命令用来开启生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启功能。
undo parity-error unrecoverable reboot命令用来关闭生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启功能。
生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启。
如果设备转发芯片上关键硬件表项发生奇偶校验和ECC校验错误,且不可恢复时,可能会影响业务正常进行,则需要配置本命令,使设备通过重启来恢复关键硬件表项。
配置本命令后,当设备生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后,将自动重启。
# 开启生成关键硬件表项不可恢复日志信息后设备的自动重启功能。
[Sysname] parity-error unrecoverable reboot
parity-error unrecoverable threshold命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值。
undo parity-error unrecoverable threshold命令用来恢复缺省情况。
parity-error unrecoverable threshold value
关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为1。
value:表示关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值,取值范围为1~1000000,单位为次数。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期内,当校验错误不可恢复次数达到配置的阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为10。
[Sysname] parity-error unrecoverable log threshold 10
power-exception-monitor命令用来配置电源模块的监控模式。
power-exception-monitor { normal | enhanced }
电源模块的监控模式为normal模式。
normal:电源模块故障后,打印状态告警信息。
enhanced:持续对电源模块进行监控,一旦监控到温度、电压或电流等异常情况,即打印状态告警信息。
配置电源模块的监控模式为enhanced时,将会占用一定系统的资源。
# 配置电源模块的监控模式为normal模式。
[Sysname] power-exception-monitor normal
power-supply surplus-power enable命令用来开启电源睡眠功能。
undo power-supply surplus-power enable命令用来关闭电源睡眠功能。
仅适配PSR2400-54A、PSR2400-54D或PSR3000-54A电源模块的交换机支持开启电源睡眠功能。
只有使用power-supply policy enable命令开启电源管理功能后,开启电源睡眠功能的配置才能生效。
处于睡眠状态的电源模块无法提供冗余备份功能,若正常工作的电源模块突然故障或被拔出,可能会影响设备正常运行。用户可通过display power命令查看电源模块的工作状态。
开启电源睡眠功能后,系统会根据设备当前的实际功耗,智能控制电源模块进入或者退出睡眠状态,降低能耗:
· 当系统剩余功率大于单个电源模块输入功率时,将其设置为睡眠模式并关断输出。
· 当系统剩余功率不足时,唤醒睡眠中的电源模块。
# 开启电源睡眠功能
[Sysname] power-supply surplus-power enable
· power-supply policy enable
resource-monitor minor resend enable命令用来开启周期发送低级别资源告警通知功能。
undo resource-monitor minor resend enable命令用来关闭周期发送低级别资源告警通知功能。
周期发送低级别资源告警通知功能处于开启状态。
如果剩余的资源小于或等于低级别告警门限且大于高级别告警门限,则资源进入低级别告警状态,并生成低级别告警通知。
当资源一直处于低级别告警状态时:
· 开启周期发送低级别资源告警通知功能后,第一次达到低级别告警状态时,会生成低级别告警通知,后续还会周期生成低级别告警通知。当剩余资源达到更高级别告警门限时,将会生成更高级别的告警通知,暂时抑制低级别的告警通知。直到高级别的告警状态解除,再周期输出低级别的告警通知。
· 关闭周期发送低级别资源告警通知功能后,只有第一次达到低级别告警状态时,才生成低级别告警通知,不会连续生成低级别告警通知。
高级别告警通知重发功能一直处于开启状态,不能通过命令行配置。
高级别告警通知的重发周期是24小时,低级别告警通知的重发周期是7x24小时,不能配置。
# 开启周期发送低级别资源告警通知功能。
[Sysname] resource-monitor minor resend enable
· display resource-monitor
· resource-monitor output
resource-monitor output命令用来配置资源告警通知的输出方向。
undo resource-monitor output命令用来关闭资源告警通知的输出方向。
undo resource-monitor output [ netconf-event | snmp-notification | syslog ]*
资源告警通知会同时向NETCONF、SNMP、信息中心三个方向输出。
netconf-event:将资源告警通知输出到NETCONF模块。
syslog:将资源告警通知输出到信息中心模块。
snmp-notification:将资源告警通知输出到SNMP模块。
设备会实时监控一些重要资源的是使用情况,当达到指定门限时,设备会生成对应的资源告警通知,这些通知可以输出到以下三个方向:
· NETCONF模块。通过配置NETCONF模块的参数,可以将资源告警通知以NETCONF事件的形式发送给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
· 信息中心模块。通过配置信息中心模块的参数,可以将资源告警通知以系统日志的形式发送给用户。关于信息中心的详细介绍请参见“设备管理配置指导”中的“信息中心”。
· SNMP模块。通过配置SNMP模块的参数,可以将资源告警通知以Trap或者Inform消息的形式发送给用户。关于SNMP的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
执行undo resource-monitor output命令,并且不指定可选参数时,表示资源告警通知不会向NETCONF、SNMP、信息中心三个方向输出。
# 将资源告警通知输出到信息中心模块。
[Sysname] resource-monitor output syslog
resource-monitor resource命令用来配置生成资源告警通知的门限。
undo resource-monitor resource命令用来取消资源告警通知的门限配置。
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
不同类型资源的缺省情况不同,请使用display resource-monitor命令查看。
resource-name:需要监测的资源的名称,不区分大小写,需要完整输入参数的值。参数的取值请参见表1-25。
取值 |
含义 |
ac |
VXLAN服务实例资源 |
agg_group |
聚合组资源 |
arp |
ARP表项资源 |
ecmp_fec_1 |
一级ECMP FEC资源 |
ecmp_fec_2 |
二级ECMP FEC资源 |
ecmp_fec_3 |
三级ECMP FEC资源 |
local_ecmp |
本地等价路由组资源 |
local_fec_1 |
一级本地转发等价类资源 |
local_fec_2 |
二级本地转发等价类资源 |
local_fec_3 |
三级本地转发等价类资源 |
mac |
MAC地址表项资源 |
mc |
二层和三层组播资源 |
mqcin |
入方向MQC资源 |
mqcout |
出方向MQC资源 |
nd |
ND表项资源 |
openflow |
OpenFlow资源 |
pbr |
PBR资源 |
pfilterin |
入方向包过滤资源 |
pfilterout |
出方向包过滤资源 |
route |
路由表项资源 |
rport |
三层以太网接口资源 |
subrport |
三层以太网子接口资源 |
vlan |
VLAN资源 |
vlaninterface |
VLAN接口资源 |
vrf |
VPN实例资源 |
vsiintf |
VSI接口资源 |
cpu cpu-number:表示监测指定CPU上的资源。cpu-number表示在CPU的编号。
by-percent:以百分比的方式配置告警门限。
minor-threshold minor-threshold:低级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
severe-threshold severe-threshold:高级别门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
配置本命令后,设备会监测资源的剩余情况,周期采样监测对象的值,并和配置的告警门限进行比较。当达到条件时,设备会生成告警通知。
# 配置slot 1上ARP资源的低级别门限为30%,高级别门限为10%。
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动检测端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。在协议自动关闭端口的同时,系统会启动一个检测端口状态的定时器。如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
· 若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
· 若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
temperature-limit slot slot-number { hotspot } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
sensor-number:温度传感器的编号,输入该参数的值时可通过输入?,来获取该参数的取值范围。
lowlimit:低温告警门限,单位为摄氏度。不同温度传感器的低温告警门限取值范围不同,输入该参数的值时可通过输入?,来获取该参数的取值范围。
warninglimit:一般级高温告警门限,单位为摄氏度,必须大于低温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
alarmlimit:严重级高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
# 配置指定slot上热点1号温度传感器,低温门限为-10摄氏度,一般级高温门限为50摄氏度,严重级高温门限为60摄氏度。
[sysname] temperature-limit slot 1 hotspot 1 -10 50 60
· display environment
transceiver monitor enable命令用来开启光模块监控功能。
undo transceiver monitor enable命令用来关闭光模块监控功能。
transceiver monitor enable [ grey | tunable ]
光模块监控功能处于关闭状态。
grey:表示仅开启对灰光类型光模块的监控功能。
tunable:表示仅开启对彩光类型光模块的监控功能。
开启光模块监控功能后,设备会按周期检查光模块的参数(例如光模块的输出功率、输入功率等),当参数的采样值达到软件设定的阈值时,会生成相应的日志提醒用户。
配置本命令时,如果选择grey参数,则表示仅开启对灰光类型光模块的监控功能;如果选择tunable参数,则表示仅开启对彩光类型光模块的监控功能;如果不指定grey和tunable参数,则表示开启对所有类型光模块的监控功能。
# 开启光模块监控功能。
[Sysname] transceiver monitor enable
· transceiver monitor interval
transceiver monitor interval命令用来配置光模块的监控周期。
undo transceiver monitor interval命令用来恢复缺省情况。
transceiver monitor interval interval
光模块的监控周期是600秒。
interval:表示光模块的监控周期,取值范围为30~3600,单位为秒。
开启光模块监控功能后,本命令才生效。
# 配置光模块监控周期为500秒。
[Sysname] transceiver monitor interval 500
· transceiver monitor enable
