03-设备管理
03-HH3C-ENTITY-EXT-MIB
本章节下载 03-HH3C-ENTITY-EXT-MIB  (429.42 KB)
HH3C-ENTITY-EXT-MIB
功能介绍
该MIB用于描述实体扩展信息,用以实现对实体特定数据的监控功能,使得这些产品设备能够通过网管方式得到更好管理监控。
支持本MIB的产品必须首先支持ENTITY-MIB。
以下表格描述了实体扩展属性同设备实体的关联信息,需要产品确认规格。
entity
hh3cEntityExtAdminStatus (R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
Yes
stack
No
other
No
unknown
No
entity
hh3cEntityExtOperStatus (R)
chassis
No
backplane
No
container
No
power Supply
Yes
fan
Yes
sensor
No
module
Yes
port
Yes
stack
No
other
No
unknown
No
entity
hh3cEntityExtStandbyStatus (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
Yes
sensor
No
module
Yes
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtAlarmLight (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtCpuUsage (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes(Only support the Module Level1)
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtCpuUsageThreshold (R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtMemUsage (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtMemUsageThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtMemSize (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtUpTime (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtTemperature (R)
chassis
No
backplane
No
container
No
powerSupply
Yes
fan
Yes
sensor
Yes
module
Yes
port
No
stack
No
other
Yes
unknown
No
entity
hh3cEntityExtTemperatureThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
Yes
fan
Yes
sensor
Yes
module
Yes
port
No
stack
No
other
Yes
unknown
No
entity
hh3cEntityExtVoltage(R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtVoltageLowThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtVoltageHighThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtCriticalTemperatureThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
Yes
module
No
port
No
stack
No
other
No
unknown
No
entity
hh3cEntityExtMacAddress (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
Yes
other
No
unknown
No
entity
hh3cEntityExtErrorStatus (R)
chassis
No
backplane
Yes
container
Yes
powerSupply
Yes
fan
Yes
sensor
Yes
module
No
port
Yes
stack
No
other
Yes
unknown
Yes
entity
hh3cEntityExtManuSerialNum (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
No
cpu
No
entity
hh3cEntityExtManuBuildInfo (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
No
cpu
No
entity
hh3cEntityExtMacAddressCount (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
Yes
cpu
No
entity
hh3cEntityExtManuBOM (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
No
cpu
No
Entity
(R/W: 可读/读写)
POWERSUPPLY
FAN
CHASSIS
CONTAINER
MODULE
PORT
CPU
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
hh3cEntityExtTemperatureThreshold (R/W)
hh3cEntityExtVoltage (R)
hh3cEntityExtVoltageLowThreshold (R/W)
hh3cEntityExtVoltageHighThreshold (R/W)
Yes
说明:
1. “Yes”:表示该扩展属性已实现。
2. 如果读操作返回“no such name/instance”,那么说明该MIB节点在当前实体实例下是不支持的。
MIB文件名
hh3c-entity-ext.mib
告警信息
hh3cEntityExtTemperatureThresholdNotification
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.1
实体温度超过阈值
故障告警
重要
1.3.6.1.4.1.25506.2.6.2.0.22 (hh3cEntityExtTemperatureNormal)
开启
【触发原因】
在实体的温度超过上限阀值时,发送该告警。
【系统影响】
温度过高会影响系统正常工作。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
1.3.6.1.4.1.25506.2.6.1.1.1.1.1 (hh3cEntityExtPhysicalIndex)
实体索引
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.1.1.1.12 (hh3cEntityExtTemperature)
实体温度
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.1.1.1.13 (hh3cEntityExtTemperatureThreshold)
实体温度阈值
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.1.1.1.2 (hh3cEntityExtAdminStatus)
实体管理状态
Hh3cAdminState
notSupported(1), locked(2), shuttingDown(3), unlocked(4)}
1.3.6.1.4.1.25506.2.6.1.1.1.1.5 (hh3cEntityExtAlarmLight)
实体告警状态
Hh3cAlarmStatus
BITS {, notSupported(0), underRepair(1), critical(2), major(3), minor(4), alarmOutstanding(5), warning(6), indeterminate(7), }
【处理建议】
现场查看环境温度,也可以通过display environment命令查看当前温度以及生效的阈值。
确认造成温度超过上限阀值的原因。
解决问题,确保温度恢复至正常范围。
如果问题无法解决,请联系H3C技术支持工程师。
hh3cEntityExtCpuUsageThresholdNotfication
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.4
实体CPU利用率超过阈值
故障告警
重要
1.3.6.1.4.1.25506.2.6.2.0.25 (hh3cEntityExtCpuUsageThresholdRecover)
开启
【触发原因】
在实体的CPU使用率超过阀值时,发送该告警。该告警每60秒发送一次,直至告警消除。
【系统影响】
系统业务处理能力会减弱。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.1.1.1.6 (hh3cEntityExtCpuUsage)
实体CPU利用率
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.7 (hh3cEntityExtCpuUsageThreshold)
实体CPU利用率阈值
Integer32
0..100
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
1.3.6.1.4.1.25506.2.6.1.1.1.1.31 (hh3cEntityExtCpuUsageRecoverThreshold)
实体CPU利用率恢复阈值
Integer32
0..100
1.3.6.1.4.1.25506.2.6.2.1.4 (hh3cEntityExtFirstTrapTime)
告警时间戳
TimeTicks
同MIB标准取值
【处理建议】
如果告警自动停止,无需处理。
如果告警无法自动停止,请联系H3C技术支持工程师。
hh3cEntityExtMemUsageThresholdNotification
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.5
实体内存利用率超过阈值
故障告警
重要
1.3.6.1.4.1.25506.2.6.2.0.26 (hh3cEntityExtMemUsageThresholdRecover)
开启
【触发原因】
实体内存总量小于4GB且实体内存使用率超过阈值时,发送该告警。该告警每60秒发送一次,直至告警消除。
内存利用率告警阈值节点为 hh3cEntityExtMemUsageThreshold;实体内存总量不小于(即大于等于)4GB时,超过阈值则发送hh3cEntityExtMemUsageThresholdOverTrap告警
【系统影响】
可用内存减少,可能会影响系统业务处理能力。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.1.1.1.8 (hh3cEntityExtMemUsage)
实体内存利用率
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.9 (hh3cEntityExtMemUsageThreshold)
实体内存利用率阈值
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.10 (hh3cEntityExtMemSize)
实体内存
Unsigned32
同MIB标准取值
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
告警时间戳
TimeTicks
同MIB标准取值
【处理建议】
请删除不需要的业务,减少内存消耗。
如果告警自动停止,无需处理。
hh3cEntityExtCriticalTemperatureThresholdNotification
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.8
实体温度超过临界阈值
故障告警
紧急
开启
【触发原因】
在实体的温度超过临界上限阈值时,发送该告警。该告警每80秒发送一次,直至告警消除。
【系统影响】
高温会影响系统正常工作。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体温度
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.1.1.1.17 (hh3cEntityExtCriticalTemperatureThreshold)
实体温度临界阈值
Integer32
同MIB标准取值
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
【处理建议】
现场查看环境温度。可以通过display environment命令查看当前温度以及生效的阈值。
确定造成温度超过临界上限阈值的原因。
解决问题,确保温度恢复至正常范围。
hh3cEntityInsert
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.12
实体插入
恢复告警
警告
开启
【触发原因】
在实体插入设备时,发送该告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
1.3.6.1.2.1.47.1.1.1.1.2 (entPhysicalDescr)
实体描述
entPhysicalIndex
SnmpAdminString
OCTET STRING (SIZE (0..255))
实体管理状态
Hh3cAdminState
1.3.6.1.4.1.25506.2.6.1.1.1.1.3 (hh3cEntityExtOperStatus)
实体操作状态
Hh3cOperState
notSupported(1), disabled(2), enabled(3), dangerous(4)
【处理建议】
正常运行信息,无需处理。
hh3cEntityRemove
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.13
实体拔出
故障告警
次要
1.3.6.1.4.1.25506.2.6.2.0.12 (hh3cEntityInsert)
开启
【触发原因】
在实体从设备上拔出时,发送该告警。
【系统影响】
视拔出实体而定。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体描述
entPhysicalIndex
SnmpAdminString
实体管理状态
Hh3cAdminState
实体操作状态
Hh3cOperState
【处理建议】
如果实体被拔出,无需处理。
如果实体没有被拔出,确认实体安装正确。
hh3cEntityExtFaultAlarmOn
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.16
实体故障告警
故障告警
重要
1.3.6.1.4.1.25506.2.6.2.0.17 (hh3cEntityExtFaultAlarmOff)
开启
【触发原因】
在实体发生故障时,发送该告警。
【系统影响】
视故障实体而定。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
1.3.6.1.2.1.47.1.1.1.1.7 (entPhysicalName)
实体名称
entPhysicalIndex
SnmpAdminString
1.3.6.1.4.1.25506.2.6.1.1.1.1.19 (hh3cEntityExtErrorStatus)
实体错误状态
INTEGER
notSupported(1), normal(2), postFailure(3), entityAbsent(4), poeError(11), stackError(21), stackPortBlocked(22), stackPortFailed(23), sfpRecvError(31), sfpSendError(32), sfpBothError(33), sfpRecvExceedUpperLimit(34),, sfpRecvBelowLowerLimit(35),, sfpSendExceedUpperLimit(36),, sfpSendBelowLowerLimit(37),, fanError(41), psuError(51), rpsError(61), moduleFaulty(71), sensorError(81), hardwareFaulty(91)
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
【处理建议】
确认实体安装正确。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
实体故障撤销
恢复告警
警告
开启
【触发原因】
在实体从故障状态中恢复时,发送该告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体名称
entPhysicalIndex
SnmpAdminString
实体错误状态
INTEGER
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
【处理建议】
正常运行信息,无需处理。
hh3cEntityExtTemperatureLower
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.20
实体温度低于下限阈值
故障告警
重要
开启
【触发原因】
在实体的温度低于下限阀值时,发送该告警。
【系统影响】
低温会影响系统正常工作。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体名称
entPhysicalIndex
SnmpAdminString
实体温度
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.1.1.1.21 (hh3cEntityExtLowerTemperatureThreshold)
实体温度Lower阈值
Integer32
同MIB标准取值
实体管理状态
Hh3cAdminState
【处理建议】
确定造成温度低于下限阀值的原因。
解决问题,确保温度恢复至正常范围。
hh3cEntityExtTemperatureTooUp
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.21
实体温度超过停止阈值
故障告警
紧急
开启
【触发原因】
在实体的温度超过停止阀值时,发送该告警。该告警每80秒发送一次,直至告警消除。
【系统影响】
温度过高,系统随时会关机。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体名称
entPhysicalIndex
SnmpAdminString
实体温度
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.1.1.1.22 (hh3cEntityExtShutdownTemperatureThreshold)
实体温度Shutdown阈值
Integer32
同MIB标准取值
实体管理状态
Hh3cAdminState
【处理建议】
确定造成温度超过停止阀值的原因。
解决问题,确保温度恢复至正常范围。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
实体温度恢复正常
恢复告警
警告
开启
【触发原因】
在实体的温度从异常状态中恢复时,发送该告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体名称
entPhysicalIndex
SnmpAdminString
实体温度
Integer32
同MIB标准取值
实体温度Lower阈值
Integer32
同MIB标准取值
实体温度阈值
Integer32
同MIB标准取值
实体管理状态
Hh3cAdminState
【处理建议】
正常运行信息,无需处理。
hh3cEntityExternalAlarmOccur
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.23
实体扩展故障
故障告警
重要
1.3.6.1.4.1.25506.2.6.2.0.24 (hh3cEntityExternalAlarmRecover)
开启
【触发原因】
在实体发生故障时,发送该告警。
【系统影响】
视故障实体而定。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体名称
entPhysicalIndex
SnmpAdminString
【处理建议】
确认实体安装正确。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
实体扩展故障恢复
恢复告警
警告
开启
【触发原因】
在实体从故障状态中恢复时,发送该告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体名称
entPhysicalIndex
SnmpAdminString
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
实体CPU利用率从告警阈值恢复
恢复告警
警告
开启
【触发原因】
在实体的CPU使用率从异常状态中恢复时,发送该告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体CPU利用率
Integer32
0..100
实体CPU利用率阈值
Integer32
0..100
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
实体CPU利用率恢复阈值
Integer32
0..100
告警时间戳
TimeTicks
同MIB标准取值
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
实体内存利用率从告警阈值恢复
恢复告警
警告
开启
【触发原因】
在实体的内存使用率从异常状态中恢复时,发送该告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体内存利用率
Integer32
0..100
实体内存利用率阈值
Integer32
0..100
实体内存
Unsigned32
同MIB标准取值
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
告警时间戳
TimeTicks
同MIB标准取值
【处理建议】
正常运行信息,无需处理。
hh3cEntityExtVoltageNormal
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.37
实体电压从告警阈值恢复
恢复告警
警告
开启
【触发原因】
在实体的电压从异常状态中恢复时,发送该告警
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.5.1.1.1 (hh3cEntityExtCurrentVoltage)
实体电压
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.5.1.1.2 (hh3cEntityExtNominalVoltage)
实体标称电压
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.5.1.1.4 (hh3cEntityExtVoltageMajorLowThreshold)
实体电压低门限阈值
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.5.1.1.6 (hh3cEntityExtVoltageMajorHighThreshold)
实体电压高门限阈值
Integer32
同MIB标准取值
【处理建议】
正常运行信息,无需处理。
hh3cEntityExtVoltageLower
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.38
实体电压低于阈值
故障告警
重要
1.3.6.1.4.1.25506.2.6.2.0.37 (hh3cEntityExtVoltageNormal)
开启
【触发原因】
在实体的电压低于下限阈值时,发送该告警。
【系统影响】
系统业务处理能力可能受影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体电压
Integer32
同MIB标准取值
实体标称电压
Integer32
同MIB标准取值
实体电压低门限阈值
Integer32
同MIB标准取值
【处理建议】
检查设备的电源系统。
hh3cEntityExtVoltageTooLow
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.39
实体电压低于临界阈值
故障告警
紧急
开启
【触发原因】
在实体的电压低于临界下限阈值时,发送该告警。该告警每80秒发送一次,直至告警消除。
【系统影响】
系统业务处理能力可能受影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体电压
Integer32
同MIB标准取值
实体标称电压
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.5.1.1.5 (hh3cEntityExtVoltageFatalLowThreshold)
实体电压过低门限阈值
Integer32
同MIB标准取值
【处理建议】
检查设备的电源系统。
hh3cEntityExtVoltageHigher
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.40
实体电压高于阈值
故障告警
重要
开启
【触发原因】
在实体的电压高于上限阈值时,发送该告警。
【系统影响】
系统业务处理能力可能受影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体电压
Integer32
同MIB标准取值
实体标称电压
Integer32
同MIB标准取值
实体电压高门限阈值
Integer32
同MIB标准取值
【处理建议】
检查设备的电源系统。
hh3cEntityExtVoltageTooHigh
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.41
实体电压高于临界阈值
故障告警
紧急
开启
【触发原因】
在实体的电压高于临界上限阈值时,发送该告警。该告警每80秒发送一次,直至告警消除。
【系统影响】
系统业务处理能力可能受影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体电压
Integer32
同MIB标准取值
实体标称电压
Integer32
同MIB标准取值
1.3.6.1.4.1.25506.2.6.1.5.1.1.7 (hh3cEntityExtVoltageFatalHighThreshold)
实体电压过高门限阈值
Integer32
同MIB标准取值
【处理建议】
检查设备的电源系统。
hh3cEntityExtSFPAlarmOnEx
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.42
实体光模块故障告警
故障告警
重要
1.3.6.1.4.1.25506.2.6.2.0.43 (hh3cEntityExtSFPAlarmOffEx)
开启
【触发原因】
在光模块发生故障时,发送该告警。
【系统影响】
告警光模块不可用。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体名称
entPhysicalIndex
SnmpAdminString
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
实体错误状态
Integer32
同MIB标准取值
【处理建议】
检查光模块状态。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
实体光模块故障撤销
恢复告警
警告
开启
【触发原因】
在光模块恢复正常时,发送该告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体名称
entPhysicalIndex
SnmpAdminString
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
实体错误状态
Integer32
同MIB标准取值
【处理建议】
正常运行信息,无需处理。
h3cEntityExtSFPPhony
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.6.2.0.11
伪光模块告警
故障告警
重要
开启
【触发原因】
在识别到伪光模块时,发送该告警。
【系统影响】
使用伪光模块可能会导致无法正常通信。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
实体索引
Integer32
同MIB标准取值
实体名称
entPhysicalIndex
SnmpAdminString
实体管理状态
Hh3cAdminState
实体告警状态
Hh3cAlarmStatus
【处理建议】
请更换为H3C提供的光模块。
