07-三层技术-IP路由命令参考
01-IP路由基础命令
本章节下载 01-IP路由基础命令  (921.06 KB)
01-IP路由基础命令
  录
1 IP路由基础
1.1 IP路由基础配置命令
1.1.1 address-family ipv4
1.1.2 address-family ipv6
1.1.3 display ip routing-table
1.1.4 display ip routing-table acl
1.1.5 display ip routing-table ip-address
1.1.6 display ip routing-table prefix-list
1.1.7 display ip routing-table protocol
1.1.8 display ip routing-table record
1.1.9 display ip routing-table statistics
1.1.10 display ip routing-table summary
1.1.11 display ipv6 rib attribute
1.1.12 display ipv6 rib graceful-restart
1.1.13 display ipv6 rib nib
1.1.14 display ipv6 rib nib record
1.1.15 display ipv6 route-direct nib
1.1.16 display ipv6 routing-table
1.1.17 display ipv6 routing-table acl
1.1.18 display ipv6 routing-table ipv6-address
1.1.19 display ipv6 routing-table prefix-list
1.1.20 display ipv6 routing-table protocol
1.1.21 display ipv6 routing-table record
1.1.22 display ipv6 routing-table statistics
1.1.23 display ipv6 routing-table summary
1.1.24 display rib attribute
1.1.25 display rib graceful-restart
1.1.26 display rib nib
1.1.27 display rib nib record
1.1.28 display route-direct nib
1.1.29 fib lifetime
1.1.30 flush route-attribute
1.1.31 inter-protocol ecmp
1.1.32 inter-protocol fast-reroute
1.1.33 ipv6 route-direct track
1.1.34 maintenance-probe enable
1.1.35 nexthop recursive-lookup restrain
1.1.36 nexthop recursive-lookup restrain clear-interval
1.1.37 nexthop recursive-lookup restrain disable
1.1.38 primary-path-detect bfd
1.1.39 protocol lifetime
1.1.40 protocol nexthop recursive-lookup
1.1.41 record-limit
1.1.42 reset ip routing-table record
1.1.43 reset ip routing-table statistics protocol
1.1.44 reset ipv6 rib nib record
1.1.45 reset ipv6 routing-table record
1.1.46 reset ipv6 routing-table statistics protocol
1.1.47 reset rib nib record
1.1.48 rib
1.1.49 route-direct track
1.1.50 routing-table limit
1.1.51 snmp-agent trap enable ipv6 rib
1 IP路由基础
1.1  IP路由基础配置命令
address-family ipv4命令用来创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
undo address-family ipv4命令用来删除RIB IPv4地址族和RIB IPv4地址族视图下的所有配置。
address-family ipv4
不存在RIB IPv4地址族。
RIB视图
# 创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6命令用来创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
undo address-family命令用来删除RIB IPv6地址族和RIB IPv6地址族视图下的所有配置。
address-family ipv6
undo address-family ipv6
不存在RIB IPv6地址族。
RIB视图
# 创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
display ip routing-table命令用来显示路由表的信息。
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ priority { critical | high | low | medium } ] [ verbose ]
display ip routing-table all-routes
display ip routing-table [ vpn-instance vpn-instance-name ] fast-reroute
all-vpn-instance:显示所有VPN实例的路由表信息。
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
priority { critical | high | low | medium }:显示指定路由收敛优先级的路由信息。critical表示路由收敛优先级为关键,high表示路由收敛优先级为高,low表示路由收敛优先级为低,medium表示路由收敛优先级为中。如果未指定本参数,将显示所有级别的路由收敛优先级的路由信息。
all-routes:显示公网和所有VPN实例的路由表信息。
verbose:显示全部路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
fast-reroute:显示快速重路由的路由表信息。
如果不指定任何参数,将显示公网的路由表信息,不包含快速重路由的路由表信息。
# 显示公网中当前激活路由的概要信息。
<Sysname> display ip routing-table
Destinations : 8        Routes : 8
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
1.1.1.0/24          Static 60   0            192.168.47.4    XGE3/1/1
192.168.1.40/32     Direct 0    0            127.0.0.1       InLoop0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# 显示公网和所有VPN实例中当前激活路由的概要信息。
<Sysname> display ip routing-table all-routes
VPN instance: public instance
VPN instance: vpn1
Destinations : 5        Routes : 5
1.1.2.0/24          Static 60   0            2.2.1.1         XGE3/1/1
3.3.1.0/24          BGP    255  0            55.1.1.2        XGE3/1/2
# 显示所有VPN实例下的IPv4路由信息。
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
Destinations : 4        Routes : 4
1.1.3.0/24          Static 60   0            3.3.1.1         XGE3/1/1
表1-1 display ip routing-table命令显示信息描述表
VPN instance
路由表所属的公网或VPN实例信息,公网路由显示为public instance,私网路由显示为VPN实例名称
Destinations
目的地址个数
Routes
路由条数
Destination/Mask
目的地址/掩码长度
Proto
路由种类或发现该路由的路由协议类型:
·     Direct:直连路由
·     Static:静态路由
·     UNR:用户网络路由
·     RIP:RIP协议‌
·     O_INTRA:OSPF区域内路由
·     O_ASE2:OSPF第二类外部路由
·     IS_L1:Level-1的IS-IS IPv4路由
·     IS_L2:Level-2的IS-IS IPv4路由
·     BGP:BGP协议
·     EIGRP:EIGRP协议
·     LISP:LISP协议
Pre
路由的优先级
Cost
路由的度量值
NextHop
此路由的下一跳地址
出接口,即到该目的网段的数据包将从此接口发出
Summary count
路由数目
# 显示公网中所有路由的详细信息。
<Sysname> display ip routing-table verbose
 Destination: 0.0.0.0/32
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 08h34m37s
  FlushedAge: 15h28m49s
        Cost: 0                  Preference: 0
       IpPre: N/A                QosLocalID: N/A
         Tag: 0                       State: Active NoAdv
   OrigTblID: 0x0                   OrigVrf: default-vrf
     TableID: 0x2                    OrigAs: 0
       NibID: 0x10000000             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: 0.0.0.0
       Flags: 0x1000c           OrigNextHop: 127.0.0.1
       Label: NULL              RealNextHop: 127.0.0.1
     BkLabel: NULL                BkNextHop: N/A
     SRLabel: NULL                Interface: InLoopBack0
   BkSRLabel: NULL              BkInterface: N/A
   Tunnel ID: Invalid           IPInterface: InLoopBack0
 BkTunnel ID: Invalid         BkIPInterface: N/A
     InLabel: NULL           ColorInterface: N/A
    SIDIndex: NULL         BkColorInterface: N/A
    FtnIndex: 0x0           TunnelInterface: N/A
TrafficIndex: N/A         BkTunnelInterface: N/A
   Connector: N/A                    PathID: 0x0
      UserID: 0x0                SRTunnelID: Invalid
    SID Type: N/A                       NID: Invalid
    FlushNID: Invalid                 BkNID: Invalid
  BkFlushNID: Invalid             StatFlags: 0x0
         SID: N/A
       BkSID: N/A
CommBlockLen: 0                    Priority: Critical
  MemberPort: N/A
 Destination: 1.1.1.0/24
    Protocol: Static
  Process ID: 0
   SubProtID: 0x0                       Age: 04h20m37s
        Cost: 0                  Preference: 60
         Tag: 0                       State: Active Adv
       NibID: 0x10000003             LastAs: 0
      AttrID: 0xffffffff
       Flags: 0x1008c           OrigNextHop: 192.168.47.4
       Label: NULL              RealNextHop: 192.168.47.4
     SRLabel: NULL                Interface: Ten-GigabitEthernet3/1/1
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet3/1/1
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
    Protocol: Static
  Process ID: 0
         Tag: 0                       State: Active Adv Derived
      AttrID: 0xffffffff
       Label: NULL              RealNextHop: 125.2.1.1
     SRLabel: NULL                Interface: Ten-GigabitEthernet3/1/2
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet3/1/2
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
# 显示所有VPN实例内所有路由的详细信息。
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1        Routes : 1
    Protocol: Direct
  Process ID: 0
   OrigTblID: 0x0                   OrigVrf: vpn1
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
VPN instance: vpn2
    Protocol: Static
  Process ID: 0
   OrigTblID: 0x0                   OrigVrf: vpn2
      AttrID: 0xffffffff
    SIDIndex: NULL                  InLabel: NULL
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
表1-2 display ip routing-table verbose命令显示信息描述表
VPN instance
Destinations
目的地址个数
Routes
路由条数
Destination
目的地址/掩码
Protocol
发现该路由的路由协议类型
Process ID
进程号
SubProtID
路由子协议ID
Age
此路由在路由表中存在的时间
FlushedAge
此路由下刷FIB的时间
Cost
路由的度量值
Preference
路由的优先级
IpPre
IP优先级值
QosLocalID
QoS本地ID
Tag
路由标记
路由状态描述:
·     Active:有效的单播路由
·     Adv:允许对外发送的路由
·     Inactive:非激活路由标志
·     NoAdv:不允许发布的路由
·     Vrrp:VRRP产生的路由
·     Nat:NAT产生的路由
·     TunE:Tunnel隧道的标志
·     Derived:派生路由。路由迭代的出接口不唯一时,第一条迭代路由外的其他迭代路由为派生路由。携带此标记的路由不计入路由条数
·     Backup:备份路由的标志
OrigTblID
原始路由表ID
OrigVrf
路由所属的原始VPN,显示为default-vrf表示公网
TableID
路由所在路由表的ID
OrigAs
初始AS号
NibID
下一跳ID
LastAs
最后AS号
AttrID
路由属性ID号
BkAttrID
备份路由的属性ID号,仅支持显示BGP协议添加到IP路由表中的备份路由的属性ID号
Neighbor
路由协议的邻居地址
Flags
路由标志位
OrigNextHop
此路由的下一跳地址
Label
标签
RealNextHop
路由真实下一跳
BkLabel
备份标签
BkNexthop
备份下一跳地址
SRLabel
SR(Segment Routing)标签
BkSRLabel
SR(Segment Routing)备份标签
BkInterface
备份出接口
Tunnel ID
隧道ID
IPInterface
IP出接口
BkTunnel ID
备份隧道ID
BkIPInterface
备份IP出接口
InLabel
路由入标签
ColorInterface
Color出接口,即通过SR-MPLS TE Policy或SRv6 TE Policy迭代的出接口
SIDIndex
SID的相对值
BkColorInterface
备份Color出接口
FtnIndex
FTN表项索引
TunnelInterface
Tunnel出接口
TrafficIndex
流量统计索引值,取值范围为1~64,N/A表示无效值
BkTunnelInterface
备份Tunnel出接口
Connector
表示BGP为MD VPN特性所携带的Connector属性,具体取值为BGP对等体在交换VPN-IPv4路由时携带源PE的地址,N/A表示没有该属性
Summary count
路由数目
PathID
路径ID
UserID
接入用户ID
SRTunnelID
SR隧道ID
SID Type
(暂不支持)SID类型,N/A表示没有该属性
NID
路由协议下刷的NHLFE(Next Hop Label Forwarding Entry,下一跳标签转发项)表项索引
FlushNID
实际向FIB下刷的NHLFE表项索引
BkNID
路由协议下刷的备份NHLFE表项索引
BkFlushNID
实际向FIB下刷的备份NHLFE表项索引
StatFlags
SRv6流量统计标记
SID
主用SID(Segment Identifier,段标识),N/A表示没有该属性
BkSID
备用SID,N/A表示没有该属性
CommBlockLen
Locator中的公共前缀长度
Priority
路由的收敛优先级:
·     Critical:表示路由的收敛优先级为关键
·     High:表示路由的收敛优先级为高优先级
·     Medium:表示路由的收敛优先级为中优先级
·     Low:表示路由的收敛优先级为低优先级
MemberPort
聚合组成员端口编号,N/A表示没有该属性
display ip routing-table acl命令用来显示通过指定ACL过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
ipv4-acl-number:基本ACL的编号,取值范围为2000~2999。
verbose:显示通过指定ACL过滤的所有路由的详细信息。如果未指定本参数,将只显示通过指定ACL过滤的激活路由的概要信息。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则显示所有的路由信息。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 配置ACL 2000,并设置路由过滤规则。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# 显示通过ACL 2000过滤的激活路由的概要信息。
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24      Direct 0    0            192.168.1.111   XGE3/1/1
192.168.1.0/32      Direct 0    0            192.168.1.111   XGE3/1/1
192.168.1.111/32    Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.111   XGE3/1/1
以上显示信息解释请参见表1-1
# 显示通过ACL 2000过滤的所有路由的详细信息。
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
 Destination: 192.168.1.0/24
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x1                       Age: 04h20m37s
      AttrID: 0xffffffff
       Flags: 0x10080           OrigNextHop: 192.168.1.111
       Label: NULL              RealNextHop: 192.168.1.111
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
 Destination: 192.168.1.0/32
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
       Flags: 0x1008c           OrigNextHop: 192.168.1.111
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
 Destination: 192.168.1.111/32
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
       Flags: 0x10004           OrigNextHop: 127.0.0.1
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
 Destination: 192.168.1.255/32
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
以上显示信息解释请参见表1-2
display ip routing-table ip-address命令用来显示指定目的地址的路由信息。
display ip routing-table ip-address1 to ip-address2命令用来显示指定目的地址范围内的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] fast-reroute ip-address [ mask-length | mask ]
ip-address:目的IP地址,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
longer-match:显示与指定目的网络匹配的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ip-address1 to ip-address2:IP地址范围。ip-address1ip-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
使用不同的可选参数,命令的输出也不相同,以下是对该命令不同形式的输出说明:
·     display ip routing-table ip-address
显示满足如下条件的所有激活路由:
¡     用户输入的目的IP地址同路由表中各条路由的子网掩码值进行与运算;
¡     路由表中各条路由的目的IP地址同其自身子网掩码值进行与运算;
¡     两次运算结果相同的路由条目将被显示出来。
·     display ip routing-table ip-address mask
显示满足如下条件的所有激活路由:
¡     用户输入的目的IP地址同用户输入的子网掩码值进行与运算;
¡     路由表中各条路由的目的IP地址同用户输入的子网掩码值进行与运算;
¡     两次运算结果相同,并且掩码小于等于用户输入的子网掩码的路由条目将被显示出来。
·     display ip routing-table ip-address longer-match
显示满足如下条件的所有激活路由:
¡     用户输入的目的IP地址同子网掩码值进行与运算,有以下三种情况:
-     用户输入的目的IP地址得出其所对应的自然网段,取该自然网段对应的子网掩码默认值(A、B、C类IP地址对应的子网掩码默认值分别为255.0.0.0、255.255.0.0和255.255.255.0),再将用户输入的目的IP地址与对应的子网掩码默认值进行与运算。
-     如果用户输入的目的IP地址是0.0.0.0,将使用掩码0.0.0.0与其进行与运算。
-     除上述两种情况外(如组播地址、环回地址),将使用掩码255.255.255.255与用户输入的目的IP地址进行与运算。
¡     路由表中各条路由的目的IP地址同上一步得到的子网掩码值进行与运算;
¡     两次运算结果相同的所有路由条目将被显示出来。
·     display ip routing-table ip-address mask longer-match
显示满足如下条件的所有激活路由:
·     display ip routing-table ip-address1 to ip-address2
显示ip-address1/32到ip-address2/32之间的激活路由,目的地址与掩码(32位)同时在指定范围内才会显示。
# 显示目的地址为11.0.0.1的路由信息。
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# 显示目的地址/掩码为11.0.0.1/20的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# 显示目的地址为11.0.0.1并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
# 显示目的地址/掩码为11.0.0.1/20并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# 显示目的地址从1.1.1.0到5.5.5.0范围内的路由信息。
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 5
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
3.3.3.0/24          Direct 0    0            3.3.3.1         XGE3/1/2
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1         XGE3/1/1
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
以上显示信息的解释请参见表1-1
# 显示到达目的网络3.3.3.3/32的快速重路由信息。
<Sysname> display ip routing-table fast-reroute 3.3.3.3 32
Summary count : 1
3.3.3.3/32         Static  60  0           1.1.1.2         XGE3/1/1
                                           2.1.1.2         XGE3/1/2
以上显示信息的解释请参见表1-1
# 显示目的地址为1.2.3.4的路由的详细信息。
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
 Destination: 1.2.3.4/32
    Protocol: BGP instance test
  Process ID: 0
   SubProtID: 0x1                       Age: 00h00m37s
        Cost: 0                  Preference: 255
     TableID: 0x2                    OrigAs: 200
       NibID: 0x15000000             LastAs: 200
      AttrID: 0x0
    BkAttrID: 0x0                  Neighbor: 192.168.47.2
       Flags: 0x10060           OrigNextHop: 192.168.47.2
       Label: NULL              RealNextHop: 192.168.47.2
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
以上显示信息的解释请参见表1-2
display ip routing-table prefix-list命令用来显示通过指定前缀列表过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:前缀列表名称,为1~63个字符的字符串,区分大小写。
verbose:当使用该参数时,显示通过过滤规则的所有路由的详细信息。如果未指定本参数,将只显示通过过滤规则的激活路由的概要信息。
如果指定的前缀列表不存在,将显示所有的路由信息。
# 配置地址前缀列表test允许前缀为1.1.1.0,掩码长度为24的路由通过。
[Sysname] ip prefix-list test permit 1.1.1.0 24
# 显示通过前缀列表test过滤的激活路由的概要信息。
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24          Direct 0    0            1.1.1.2         XGE3/1/2
以上显示信息的解释请参见表1-1
# 显示通过前缀列表test过滤的所有路由的详细信息。
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
       Flags: 0x1008c           OrigNextHop: 1.1.1.2
       Label: NULL              RealNextHop: 1.1.1.2
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
以上显示信息的解释请参见表1-2
display ip routing-table protocol命令用来显示指定协议生成或发现的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ fast-reroute | inactive | verbose ]
protocol:显示指定路由协议的信息。
inactive:显示未激活路由的信息。如果未指定本参数,则显示激活路由和未激活路由的信息。
verbose:当使用该参数时,显示路由的详细信息。如果未指定本参数,将显示路由的概要信息。
fast-reroute:显示指定路由协议快速重路由的路由信息。
# 显示公网中所有直连路由的概要信息。
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
192.168.80.0/24     Direct 0    0            192.168.80.10   XGE3/1/1
192.168.80.0/32     Direct 0    0            192.168.80.10   XGE3/1/1
192.168.80.10/32    Direct 0    0            127.0.0.1       InLoop0
192.168.80.255/32   Direct 0    0            192.168.80.10   XGE3/1/1
Direct Routing table status : <Inactive>
Summary count : 0
以上显示信息的解释请参见表1-1
# 显示公网中静态路由的路由信息。
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
3.0.0.0/8           Static 60   0            2.2.2.2        XGE3/1/1
以上显示信息的解释请参见表1-1
# 显示公网中静态路由的快速重路由信息。
<Sysname> display ip routing-table protocol static fast-reroute
Destinations : 2        Routes : 2
                                           2.1.1.2         XGE3/1/2
4.4.4.4/32         Static  60  0           1.1.1.2         XGE3/1/1
                                           2.1.1.2         XGE3/1/2
以上显示信息的解释请参见表1-1
# 显示公网中BGP协议所有路由的详细信息。
<Sysname> display ip routing-table protocol bgp verbose
Summary count : 1
 Destination: 1.1.1.2/32
    Protocol: BGP instance default
  Process ID: 0
   SubProtID: 0x6                       Age: 00h03m54s
       NibID: 0x16000000             LastAs: 200
      AttrID: 0x0
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
以上显示信息的解释请参见表1-2
display ip routing-table record命令用来显示路由表项的记录信息。
display ip routing-table record flush [ delete | update ] [ verbose ]
display ip routing-table record notify [ delete | update ] [ verbose ]
display ip routing-table record receive [ add | delete | update ] [ verbose ]
flush:显示RIB向FIB下发路由表项的记录信息。
notify:显示RIB向路由协议上报路由表项的记录信息。
receive:显示RIB从路由协议收到路由表项的记录信息。
add:显示新增路由表项的记录信息。
delete:显示删除路由表项的记录信息。
update:显示更新路由表项的记录信息。如果指定了flushnotify参数,则新增路由表项的记录信息也会被认为是更新路由表项的记录信息。
verbose:显示路由表项的详细记录信息。如果不指定本参数,则显示路由表项的简要记录信息。
如果adddeleteupdate参数均未指定,则显示新增、删除和更新路由表项的记录信息。
当系统进入一级内存门限告警状态后,会停止记录新的路由表项信息;当系统进入三级内存门限告警状态后,会清除已记录的路由表项信息;当系统退出一级内存门限告警状态后,会恢复记录新的路由表项信息。
# 显示RIB向FIB下发路由表项的简要记录信息。
<Sysname> display ip routing-table record flush
Total number of records: 2
Date   Time         Action Destination/Mask/VNID/Vrf
210907 15:38:50:961 update 200.0.0.0/24/0x111000000/default-vrf
210907 15:40:13:331 delete 200.0.0.0/24/0x0/default-vrf
表1-3 display ip routing-table record flush命令显示信息描述表
路由表项记录信息的个数
Date
记录信息产生的日期
Time
记录信息产生的时间
Action
路由表项记录信息的类型,取值包括:
·     update:表示更新路由
·     delete:表示删除路由
Destination
目的地址
Mask
掩码长度
VNID
VN表项ID
Vrf
路由所属的VPN实例,显示为default-vrf表示公网
# 显示RIB向FIB下发的更新路由表项的详细记录信息。
<Sysname> display ip routing-table record flush update verbose
Total number of records: 1
Limit of records: 1000
        Time: 210907 15:38:50:961    Action: update
 Destination: 200.0.0.0/24
    VrfIndex: 0                     VrfName: default-vrf
 SrcVrfIndex: 0                    PriNibID: 0x0
      OrigAs: 0                      LastAs: 0
        VNID: 0x111000000            AttrId: 0xffffffff
       Flags: 0x10020000           ExtFlags: 0x0
       Label: 0xffffffff            BkLabel: 0xffffffff
   LabelType: None               InstanceId: 0
IpPrecedence: 65535              QosLocalId: 65535
TrafficIndex: 65535                  UserID: 0x0
表1-4 display ip routing-table record flush verbose命令显示信息描述表
路由表项记录信息的个数
Limit of records
路由表项记录信息的最大个数
Time
记录信息产生的日期和时间
Action
路由表项记录信息的类型,取值包括:
·     update:表示更新路由
·     delete:表示删除路由
Destination
目的地址和掩码长度
VrfIndex
VPN实例索引
VrfName
路由所属的VPN实例名称,显示为default-vrf表示公网
SrcVrfIndex
复制路由的源VPN实例索引
PriNibID
SRv6转发表项索引
OrigAs
初始AS号
LastAs
最后AS号
VNID
VN表项ID
AttrId
路由属性ID号
Flags
路由标志位
ExtFlags
扩展路由标志位
Label
标签
BkLabel
备份标签
LabelType
生成标签的协议类型,取值包括:
·     None:没有标签
·     BGP:BGP协议
·     LDP:LDP协议
·     SLSP:SLSP协议
·     OSPF:OSPF协议
·     ISIS:IS-IS协议
·     UNR:用户网络路由
·     Unknown:未知的协议类型
InstanceId
多实例进程标识号
IpPre
IP优先级值
QosLocalID
QoS本地ID
TrafficIndex
流量索引值,N/A表示无效值
UserID
接入用户ID
SID Type
SID类型
VsiIndex
EVPN SRv6 SID所属的VSI索引
LinkId
L2VPN DX2类型SID对应的Link ID
ArgLen
Arguments字段长度
# 显示RIB向路由协议上报路由表项的简要记录信息。
<Sysname> display ip routing-table record notify
Total number of records: 3
Date   Time         Action Destination/Mask/NibID/Vrf
210907 15:38:50:961 update 200.0.0.0/24/0x11000000/default-vrf
210907 15:39:46:496 update 200.0.0.0/24/0x11000000/default-vrf
210907 15:39:51:825 update 200.0.0.0/24/0x11000000/default-vrf
表1-5 display ip routing-table record notify命令显示信息描述表
路由表项记录信息的个数
Date
记录信息产生的日期
Time
记录信息产生的时间
Action
路由表项记录信息的类型,取值包括:
·     update:表示更新路由
·     delete:表示删除路由
Destination
目的地址
Mask
掩码长度
NibID
路由下一跳信息的ID值
Vrf
# 显示RIB向路由协议上报的删除路由表项的详细记录信息。
<Sysname> display ip routing-table record notify delete verbose
        Time: 210908 09:22:11:460    Action: delete
 Destination: 200.0.0.0/8
     TableID: 0x2                     NibID: 0x0
      ActCnt: 0                  InactNibID: 0x0
 OldProtocol: STATIC            NewProtocol: UnSpec
       Flags: 0xc00                ExtFlags: 0x22
表1-6 display ip routing-table record notify verbose命令显示信息描述表
路由表项记录信息的个数
Limit of records
路由表项记录信息的最大个数
Time
记录信息产生的日期和时间
Action
路由表项记录信息的类型,取值包括:
·     add:表示添加路由
·     update:表示更新路由
·     delete:表示删除路由
Destination
目的地址和掩码长度
TableID
路由所在路由表的ID
NibID
下一跳ID
ActCnt
该路由前缀的激活路由条数
InactNibID
上报给MPLS协议的非激活路由下一跳ID
VrfIndex
VPN实例索引
VrfName
OldProtocol
该路由上一次上报的路由协议类型
NewProtocol
该路由本次上报的路由协议类型
Flags
路由标志位
ExtFlags
扩展路由标志位
# 显示RIB从路由协议收到路由表项的简要记录信息。
<Sysname> display ip routing-table record receive
Date   Time         Action Proto      Destination/Mask/NibID/Vrf
210907 15:38:50:957 add    STATIC     200.0.0.0/24/0x11000000/default-vrf
210907 15:39:51:825 update STATIC     200.0.0.0/24/0x11000000/default-vrf
210907 15:40:13:329 delete STATIC     200.0.0.0/24/0x11000000/default-vrf
表1-7 display ip routing-table record receive命令显示信息描述表
路由表项记录信息的个数
Date
记录信息产生的日期
Time
记录信息产生的时间
Action
路由表项记录信息的类型,取值包括:
·     add:表示添加路由
·     update:表示更新路由
·     delete:表示删除路由
Protocol
发现该路由的路由协议类型
Destination
目的地址
Mask
掩码长度
PrefixLength
IPv6地址前缀长度
NibID
路由下一跳信息的ID值
Vrf
# 显示RIB从路由协议收到的添加路由表项的详细记录信息。
<Sysname> display ip routing-table record receive add verbose
        Time: 210907 15:38:50:957    Action: add
     TableID: 0x2                 ProcessID: 0
    Protocol: STATIC              SubProtID: 0x1
       NibID: 0x11000000           NewNibID: N/A
      AttrID: 0xffffffff           BkAttrID: 0xffffffff
       Flags: 0x60                 ExtFlags: 0x0
  ResetFlags: 0x0                  ModFlags: 0x0
     SRLabel: 0xffffffff          BkSRLabel: 0xffffffff
     InLabel: 0xffffffff           SIDIndex: 0xffffffff
      CommID: 0x8000000                 Tag: 0
      UserID: 0x0                  SID Type: N/A
         SID: N/A
       BkSID: N/A
表1-8 display ip routing-table record receive verbose命令显示信息描述表
路由表项记录信息的个数
Limit of records
路由表项记录信息的最大个数
Time
记录信息产生的日期和时间
Action
路由表项记录信息的类型,取值包括:
·     add:表示添加路由
·     update:表示更新路由
·     delete:表示删除路由
Destination
目的地址和掩码长度
TableID
路由所在路由表的ID
ProcessID
进程号
VrfIndex
VPN实例索引
VrfName
Protocol
发现该路由的路由协议类型
SubProtID
路由子协议ID
NibID
下一跳ID
NewNibID
更新后的下一跳ID,N/A表示没有该属性
AttrID
路由属性ID号
BkAttrID
Flags
路由标志位
ExtFlags
扩展路由标志位
ResetFlags
路由更新时,Flags字段更新信息的标志位。如果Flags中的某一位发生变化,则ResetFlags对应位的值为1
ModFlags
路由更新字段的标志位
Label
标签
BkLabel
备份标签
SRLabel
BkSRLabel
SR备份标签
InLabel
路由入标签
SIDIndex
SID的相对值
CommID
路由的公共信息表项ID
Tag
路由标记
Cost
路由的度量值
Preference
路由的优先级
IpPre
IP优先级值
QosLocalID
QoS本地ID
Connector
BGP Connector属性,N/A表示没有该属性。该字段的取值为:在组播VPN的B类跨AS的MDT模式MVPN组网中,BGP对等体在交换VPN-IPv4路由时携带的源PE地址。有关BGP Connector的详细介绍,请参见“IP组播配置指导”中的“组播VPN”
PathID
路径ID
UserID
接入用户ID
SID Type
SID类型,N/A表示没有该属性
SID
主用SID,N/A表示没有该属性
BkSID
备用SID,N/A表示没有该属性
display ip routing-table statistics命令用来显示路由表中路由或前缀的统计信息。
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
all-routes:显示公网和所有VPN实例的信息。
all-vpn-instance:显示所有VPN实例的信息。
prefix:显示前缀的统计信息。如果不指定本参数,则显示路由的统计信息。
如果不指定任何参数,将显示公网的信息。
# 显示公网路由表中的路由统计信息。
<Sysname> display ip routing-table statistics
Total prefixes: 15        Active prefixes: 15
Proto      Routes      Active      Added       Deleted
DIRECT     12          12          30          18
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      15          15          35          20
# 显示公网和所有VPN实例路由表中的路由统计信息。
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11        Active prefixes: 11
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# 显示指定VPN实例路由表中的综合路由统计信息。
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# 显示所有VPN实例路由表中的路由统计信息。
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIP        0           0           0           0
UNR        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# 显示公网的前缀统计信息。
<Sysname> display ip routing-table prefix statistics
Proto      Prefixes    Active      Added       Deleted
DIRECT     7           7           7           0
STATIC     0           0           0           0
UNR        0           0           0           0
RIP        1           0           1           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      8           7           8           0
表1-9 display ip routing-table statistics命令显示信息描述表
Total prefixes
总的前缀数目
Active prefixes
总的激活前缀数目
Proto
路由协议
Routes
路由数目
Prefixes
前缀数目
Active
活跃的、正在使用的路由或前缀数目
Added
路由器启动后或在上一次清除路由表后,路由表中添加的路由或前缀数目
Deleted
标记为删除的路由或前缀数目(此类路由在等待一段时间后会被释放)
Total
各种类型路由或前缀数目的总和
display ip routing-table summary命令用来显示路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ip routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
# 显示实例vpn1的路由表概要信息。
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 32
Remain Active Route: 262134
Threshold value percentage of max active routes: 100%
表1-10 display ip routing-table summary命令显示信息描述表
Max ECMP
最大等价路由数
Max Active Route
最多支持激活路由前缀数
Remain Active Route
剩余可激活路由前缀数
Threshold value xxx
显示最多支持激活路由前缀数的告警门限:
·     如果在VPN实例中配置了命令routing-table limit number simply-alert,则显示信息字段为Threshold value of active routes alert,取值表示产生告警的门限值。当VPN实例的激活路由前缀数超过该取值时,可以继续激活新的路由前缀,但会产生Trap告警和日志信息
·     若在VPN实例中配置了命令routing-table limit number warn-threshold,则显示信息字段为Threshold value percentage of max active routes,取值表示当(VPN实例中的激活路由前缀数/最多支持激活路由前缀数×100)达到warn-threshold时,产生Trap告警和日志信息,但仍然允许增加激活路由前缀。当VPN实例中的激活路由前缀由数达到最多支持激活路由前缀数目时,不再激活新的路由前缀
display ipv6 rib attribute命令用来显示IPv6 RIB的路由属性信息。
attribute-id:路由属性ID值,取值范围为十六进制数0~ffffffff。
# 显示IPv6 RIB的路由属性信息。
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
                  Flag: 0x0
              Protocol: BGP4+ instance default
        Address family: IPv6
       Reference count: 0
      Local preference: 0
Ext-communities number: 0
 Ext-communities value: N/A
  Ext-comm-ipv6 number: 1
   Ext-comm-ipv6 value: <RT Import: 303::3:9>
    Communities number: 0
     Communities value: N/A
        AS-path number: 0
         AS-path value: N/A
以上显示信息的解释请参见表1-14
display ipv6 rib graceful-restart命令用来显示IPv6 RIB的GR状态信息。
# 显示IPv6 RIB的GR状态信息。
<Sysname> display ipv6 rib graceful-restart
RIB GR state     : Phase2-calculation end
RCOM GR state    : Flush end
Protocol GR state:
 No.  Protocol   Lifetime FD   State    Start/End
 1    DIRECT     900      29   End      No/No
 2    STATIC     900      32   End      No/No
 3    ISISV6     900      30   End      No/No
 4    BGP4+ instance default
                 900      31   End      No/No
 5    BGP4+ instance ebcdefg
                 900      32   End      No/No
以上显示信息的解释请参见表1-15
display ipv6 rib nib命令用来显示IPv6 RIB的下一跳信息。
display ipv6 rib nib [ sub-nib nib-id ] [ verbose ]
display ipv6 rib nib protocol protocol [ fast-reroute ] [ verbose ]
self-originated:路由管理自己生成的下一跳。
sub-nib:根据子下一跳查找组合下一跳信息。
nib-id:路由下一跳ID值,取值范围为十六进制数0~ffffffff。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议的下一跳信息。
fast-reroute:显示协议的快速重路由的下一跳信息。
# 显示IPv6 RIB的下一跳信息。
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
      NibID: 0x20000000        Sequence: 0
       Type: 0x1                Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: ::
    IFIndex: 0x111            LocalAddr: ::
 MemberPort: 0x0
   TopoNthp: Invalid            ExtType: 0x0
      Color: 0                   COFlag: 0x0
   SIDIndex: 0x0                SRPName:
 OriNexthop: ::
      NibID: 0x20000001        Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: ::1
    IFIndex: 0x112            LocalAddr: ::1
 MemberPort: 0x0
 OriNexthop: ::
# 显示IPv6 RIB下一跳的详细信息。
<Sysname> display ipv6 rib nib verbose
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: ::
     RefCnt: 4              FlushRefCnt: 1
       Flag: 0x84               Version: 1
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::
  RelyDepth: 0              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0                    Flags: 0x0
SRPolicyNID: 4294967295     SRInterface:
ColorWeight: 0                  Locator: N/A
 MemberPort: N/A
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: ::
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::1
  RelyDepth: 0              RealNexthop: ::1
  Interface: InLoop0          LocalAddr: ::1
 MemberPort: N/A
以上显示信息的解释请参见表1-16表1-17
display ipv6 rib nib record命令用来显示IPv6 RIB下一跳的记录信息。
display ipv6 rib nib record flush [ delete | update ] [ verbose ]
display ipv6 rib nib record receive [ add | delete | update ] [ verbose ]
flush:显示IPv6 RIB向FIB下发下一跳的记录信息。
receive:显示IPv6 RIB从路由协议收到下一跳的记录信息。
add:显示新增下一跳的记录信息。
delete:显示删除下一跳的记录信息。
update:显示更新下一跳的记录信息。如果指定了flush参数,则新增下一跳的记录信息也会被认为是更新下一跳的记录信息。
verbose:显示下一跳的详细记录信息。如果不指定本参数,则显示下一跳的简要记录信息。
如果adddeleteupdate参数均未指定,则显示新增、删除和更新下一跳的记录信息。
当系统进入一级内存门限告警状态后,会停止记录新的下一跳信息;当系统进入三级内存门限告警状态后,会清除已记录的下一跳信息;当系统退出一级内存门限告警状态后,会恢复记录新的下一跳信息。
# 显示IPv6 RIB向FIB下发下一跳的简要记录信息。
<Sysname> display ipv6 rib nib record flush
Date   Time         Action VNID
210908 15:31:55:364 update 0x20000000
210908 15:31:55:364 update 0x120000001
以上显示信息解释请参见表1-18
# 显示IPv6 RIB向FIB下发的更新下一跳的详细记录信息。
<Sysname> display ipv6 rib nib record flush update verbose
        Time: 210908 15:31:55:364    Action: update
       NibID: 0x20000000               VNID: 0x20000000
    Sequence: 0                     Version: 1
       Flags: 0x80                 ExtFlags: 0x0
        Type: 0xd
    VrfIndex: 0                     Nexthop: ::
     IfIndex: 1410                LocalAddr: ::
     ExtType: 0x0               NibInstance: IFM
    UserKey0: 0x0                  UserKey1: 0x0
      NewUK0: 0x0                    NewUK1: 0x0
      NewUK2: 0x0                    NewUK3: 0x0
      NewUK4: 0x0                    NewUK5: 0x0
      NewUK6: 0x0                    NewUK7: 0x0
    SIDIndex: 0x0              SrPolicyName:
       Color: 0                  OriNexthop: ::
      COFlag: 0x0                   Locator: N/A
 1 nexthop(s):
   Interface: 258                 LocalAddr: ::
    VrfIndex: 0                    Topology:
      Weight: 0                       Flags: 0x800
 SRPolicyNID: 4294967295        SRInterface: 0
  MemberPort: 0               SRL2Interface: 0
       NibID: 0x20000001               VNID: 0x120000001
    Sequence: 1                     Version: 1
        Type: 0x1
    VrfIndex: 0                     Nexthop: ::1
     IfIndex: 1410                LocalAddr: ::1
 1 nexthop(s):
以上显示信息解释请参见表1-19
# 显示IPv6 RIB从路由协议收到下一跳的简要记录信息。
<Sysname> display ipv6 rib nib record receive
Date   Time         Action NibID      NibInstance
210908 10:45:35:211 add    0x21000000 USR
210908 10:45:35:215 update 0x21000000 USR
210908 10:49:47:785 delete 0x21000000 USR
以上显示信息解释请参见表1-20
# 显示IPv6 RIB从路由协议收到的添加下一跳的详细记录信息。
<Sysname> display ipv6 rib nib record receive add verbose
        Time: 210928 14:39:14:147    Action: add
 NibInstance: IFM                   Version: 1
       Flags: 0x0                   UsrData: 0xffffffffffffffff
        Type: 0x1                   ExtType: 0x0
  InstanceId: 0                     Nexthop: ::1
   BandWidth: 0                      Weight: 0
   ProtNibID: 0xffffffff           NibFlags: 0x0
 1 nexthop(s):
   Interface: 1410                LocalAddr: ::1
以上显示信息解释请参见表1-21
display ipv6 route-direct nib命令用来显示IPv6直连路由下一跳信息。
nib-id:路由邻居ID值,取值范围为十六进制数0~ffffffff。
# 显示IPv6直连路由下一跳信息。
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: ::
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: ::
# 显示IPv6直连路由下一跳详细信息。
<Sysname> display ipv6 route-direct nib verbose
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: ::
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x2                Version: 1
    ExtFlag: 0x0
 1 nexthop(s):
 MemberPort: N/A
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: ::
    ExtFlag: 0x0
 1 nexthop(s):
 MemberPort: N/A
以上显示信息的解释请参见表1-22表1-23
display ipv6 routing-table命令用来显示IPv6路由表的信息。
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ priority { critical | high | low | medium } ] [ verbose ]
display ipv6 routing-table all-routes
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] fast-reroute
all-vpn-instance:显示所有VPN实例的路由信息。
verbose:显示IPv6路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
# 显示公网中所有路由的概要信息。
<Sysname> display ipv6 routing-table
Destinations : 3 Routes : 3
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 5000::1:0:1/128                             Protocol  : SRv6
NextHop    : ::1                                         Preference: 4
Interface  : policy1                                     Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
<Sysname> display ipv6 routing-table all-routes
VPN instance: vpn1
Destination: 1:2::3:4/128                                Protocol  : Static
NextHop    : ::                                          Preference: 60
Interface  : NULL0                                       Cost      : 0
# 显示所有VPN实例下的IPv6路由信息。
<Sysname> display ipv6 routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
# 显示公网中IPv6快速重路由的概要信息。
<Sysname> display ipv6 routing-table fast-reroute
Destination: 3::/64                                      Protocol  : Static
NextHop    : 11::2                                       Preference: 60
Interface  : XGE3/1/1                                     Cost      : 0
NextHop    : 12::2                                       Preference:
Interface  : XGE3/1/2                                     Cost      :
表1-11 display ipv6 routing-table命令显示信息描述表
VPN instance
Destinations
目的地址个数
Routes
路由条数
Destination
目的网络/主机的IPv6地址和前缀
NextHop
下一跳地址
Preference
路由优先级
出接口,即到该目的地址的数据包将从此接口发出(当Protocol为SRv6并且转发隧道是SRv6 TE Policy时,出接口显示该policy的名称)
Protocol
发现该路由的路由协议类型
Cost
路由的开销值
Summary count
路由数目
# 显示公网中所有路由的详细信息。
<Sysname> display ipv6 routing-table verbose
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 19h23m02s
     TableID: 0xa                    OrigAs: 0
       NibID: 0x20000000             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: ::
       Flags: 0x10004           OrigNextHop: ::1
       Label: NULL              RealNextHop: ::1
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
 Destination: 12::/96
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 00h01m47s
       NibID: 0x20000003             LastAs: 0
      AttrID: 0xffffffff
       Flags: 0x10080           OrigNextHop: ::
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
    Protocol: SRv6
  Process ID: 0
        Cost: 0                  Preference: 4
       NibID: 0x20000002             LastAs: 0
      AttrID: 0xffffffff
       Flags: 0x10000           OrigNextHop: ::1
     SRLabel: NULL                Interface: policy1
   Tunnel ID: Invalid           IPInterface: NULL0
    SID Type: End                       NID: 0x80300001
    FlushNID: 0x80300001              BkNID: Invalid
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
<Sysname> display ipv6 routing-table all-vpn-instance verbose
VPN instance: vpn1
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
 Destination: 12::1/128
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 00h01m45s
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
    Protocol: SRv6
  Process ID: 0
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
表1-12 display ipv6 routing-table verbose命令显示信息描述表
VPN instance
路由表所属的公网或VPN实例信息,公网路由显示为public instance实例名称,私网路由显示为VPN实例名称
Destination
目的网络/主机的IPv6地址和前缀
Protocol
发现该路由的路由协议类型
Process ID
进程号
SubProtID
路由子协议ID
Age
此路由在路由表中存在的时间
FlushedAge
此路由下刷FIB的时间
Cost
路由的度量值
Preference
路由的优先级
IpPre
IP优先级值
QosLocalID
QoS本地ID
Tag
路由标记
路由状态描述:
·     Active:有效的单播路由
·     Adv:允许对外发送的路由
·     Inactive:非激活路由标志
·     NoAdv:不允许发布的路由
·     Vrrp:VRRP产生的路由
·     Nat:NAT产生的路由
·     TunE:Tunnel隧道的标志
OrigTblID
原始路由表ID
OrigVrf
TableID
路由所在路由表的ID
OrigAs
初始AS号
NibID
下一跳ID
LastAs
最后AS号
AttrID
路由属性ID号
BkAttrID
Neighbor
路由协议的邻居地址
Flags
路由标志位
OrigNextHop
此路由的下一跳地址
Label
标签
RealNextHop
路由真实下一跳
BkLabel
备份标签
BkNexthop
备份下一跳地址
SRLabel
出接口,即到该目的网段的数据包将从此接口发出(当Protocol为SRv6并且转发隧道是SRv6 TE Policy时,出接口显示该policy的名称)
BkSRLabel
SR(Segment Routing))备份标签
BkInterface
备份出接口(当Protocol为SRv6并且转发隧道是SRv6 TE Policy时,备份出接口显示该policy的名称)
Tunnel ID
隧道ID
IPInterface
IP出接口,即到该目的网段的数据包将从此接口发出
BkTunnel ID
备份隧道ID
BkInterface
备份IP出接口
InLabel
路由入标签
ColorInterface
SIDIndex
SID的相对值
BkColorInterface
备份Color出接口
FtnIndex
FTN表项索引
TunnelInterface
Tunnel出接口
TrafficIndex
BkTunnelInterface
备份Tunnel出接口
Connector
PathID
路径ID
Summary count
路由数目
UserID
接入用户ID
SRTunnelID
SR隧道ID
SID Type
SID类型,N/A表示没有该属性
NID
FlushNID
实际向FIB下刷的NHLFE表项索引
BkNID
路由协议下刷的备份NHLFE表项索引
BkFlushNID
StatFlags
SRv6流量统计标记
SID
BkSID
备用SID,N/A表示没有该属性
CommBlockLen
Locator中的公共前缀长度
Priority
路由的收敛优先级:
MemberPort
display ipv6 routing-table acl命令用来显示通过指定IPv6 ACL过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number:基本IPv6 ACL编号,取值范围为2000~2999。
verbose:显示通过指定IPv6 ACL过滤的所有路由的详细信息。如果未指定本参数,只显示通过IPv6 ACL过滤的激活路由的概要信息。
引用IPv6 ACL时,需要注意的是:
·     若引用的IPv6 ACL不存在,或者引用的IPv6 ACL中没有配置规则,则显示所有的IPv6路由信息。
·     在引用的IPv6 ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 显示通过IPv6 ACL 2000过滤的激活路由的概要信息。
<Sysname> display ipv6 routing-table acl 2000
Summary count : 5
Destination : ::1/128                                    Protocol  : Direct
Destination: 12::/96                                     Protocol  : Direct
Interface  : XGE3/1/2                                    Cost      : 0
Destination: 12::1/128                                   Protocol  : Direct
Destination: FF::11/128                                  Protocol  : BGP4+
NextHop    : 12::2                                       Preference: 255
以上显示信息的解释请参见表1-11
# 显示通过IPv6 ACL 2000过滤的所有路由的详细信息。
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 5
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 19h29m12s
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 00h07m57s
      AttrID: 0xffffffff
 BkTunnel ID: Invalid         IPBkInterface: N/A
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 00h07m55s
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
  Process ID: 0
   SubProtID: 0x6                       Age: 00h06m43s
     TableID: 0xa                    OrigAs: 200
       NibID: 0x26000000             LastAs: 200
      AttrID: 0x1
    BkAttrID: 0x1                  Neighbor: 12::2
       Flags: 0x10060           OrigNextHop: 12::2
       Label: NULL              RealNextHop: 12::2
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
       Flags: 0x10084           OrigNextHop: ::
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
以上显示信息的解释请参见表1-12
display ipv6 routing-table ipv6-address命令用来显示指定目的地址的IPv6路由信息。
display ipv6 routing-table ipv6-address1 to ipv6-address2命令用来显示指定目的地址范围内的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] fast-reroute ipv6-address [ prefix-length ]
ipv6-address:IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
longer-match:显示满足匹配条件的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ipv6-address1 to ipv6-address2:IPv6地址范围。ipv6-address1ipv6-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示激活路由的概要信息。
·     display ipv6 routing-table ipv6-address
显示满足如下条件的所有激活路由:
¡     用户输入的目的IPv6地址同路由表中各条路由的前缀长度值进行与运算;
¡     路由表中各条路由的目的IPv6地址同其自身前缀长度值进行与运算;
·     display ipv6 routing-table ipv6-address prefix-length
显示满足如下条件的所有激活路由:
¡     用户输入的目的IPv6地址同用户输入的前缀长度值进行与运算;
¡     路由表中各条路由的目的IPv6地址同用户输入的前缀长度值进行与运算;
¡     两次运算结果相同,并且路由表中前缀长度小于等于用户输入的前缀长度的路由条目将被显示出来。
·     display ipv6 routing-table ipv6-address longer-match
用户未指定前缀长度时,显示结果与display ipv6 routing-table命令的显示结果相同。
·     display ipv6 routing-table ipv6-address prefix-length longer-match
显示满足如下条件的所有激活路由:
·     display ipv6 routing-table ipv6-address1 to ipv6-address2
显示ipv6-address1/128到ipv6-address2/128之间的路由,目的IPv6地址与前缀长度(128位)同时在指定范围内才会显示。
# 显示目的IPv6地址/前缀为10::1/127的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64                                     Protocol  : Static
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# 显示目的IPv6地址/前缀为10::1/127并且满足匹配条件的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# 显示目的IPv6地址从100::到300::范围内的IPv6路由信息。
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
# 显示目的IPv6地址/前缀为3::/32的IPv6快速重路由概要信息。
<Sysname> display ipv6 routing-table fast-reroute 3:: 32
Summary count : 1
Destination: 3::/32                                      Protocol  : Static
# 显示目的IPv6地址/前缀为1:2::3:4/128的IPv6路由的详细信息。
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
    Protocol: BGP4+ instance abc
  Process ID: 0
   SubProtID: 0x1                       Age: 00h01m14s
     TableID: 0x1                    OrigAs: 200
      AttrID: 0x0
    BkAttrID: 0x0                  Neighbor: 2:2::3:4
       Flags: 0x10060           OrigNextHop: 2:2::3:4
       Label: NULL              RealNextHop: 2:2::3:4
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
以上显示信息的解释请参见表1-12
display ipv6 routing-table prefix-list命令用来显示通过指定前缀列表过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:IPv6前缀列表的名称,为1~63个字符的字符串,区分大小写。
verbose:显示所有路由的详细信息。如果未指定本参数,只显示激活路由的概要信息。
# 配置地址前缀列表test允许前缀为::1,前缀长度为128的IPv6路由通过。
[Sysname] ipv6 prefix-list test permit ::1 128
# 显示通过前缀列表test过滤的IPv6激活路由的概要信息。
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
以上显示信息的解释请参见表1-11
# 显示通过前缀列表test过滤的所有IPv6路由的详细信息。
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 08h57m19s
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
以上显示信息的解释请参见表1-12
display ipv6 routing-table protocol命令用来显示指定协议生成或发现的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ fast-reroute | inactive | verbose ]
inactive:如果配置了该参数,此命令只显示未激活路由信息。如果未指定本参数,将显示所有激活和未激活路由信息。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示公网中所有IPv6直连路由的概要信息。
<Sysname> display ipv6 routing-table protocol direct
Summary count : 2
Summary count : 2
Summary count : 0
# 显示公网中IPv6静态路由的路由信息。
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128                                    Protocol  : Static
NextHop    : fe80::2                                     Preference: 60
NextHop    : fe80::3                                     Preference: 60
Destination: 3::3/128                                    Protocol  : Static
NextHop    : 2::2                                        Preference: 60
Summary count : 0
# 显示公网中IPv6静态路由的快速重路由信息。
NextHop    : 12::2                                       Preference: 60
# 显示公网中BGP4+协议所有路由的详细信息。
<Sysname> display ipv6 routing-table protocol bgp4+ verbose
Summary count : 1
 Destination: 22::22/128
  Process ID: 0
   SubProtID: 0x6                       Age: 00h04m15s
       NibID: 0x25000001             LastAs: 200
      AttrID: 0x3
    BkAttrID: 0x3                  Neighbor: 121::2
       Flags: 0x10060           OrigNextHop: 121::2
       Label: NULL              RealNextHop: 121::2
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
以上显示信息的解释请参见表1-12
display ipv6 routing-table record命令用来显示IPv6路由表项的记录信息。
display ipv6 routing-table record flush [ delete | update ] [ verbose ]
display ipv6 routing-table record notify [ delete | update ] [ verbose ]
display ipv6 routing-table record receive [ add | delete | update ] [ verbose ]
flush:显示IPv6 RIB向FIB下发路由表项的记录信息。
notify:显示IPv6 RIB向路由协议上报路由表项的记录信息。
receive:显示IPv6 RIB从路由协议收到路由表项的记录信息。
add:显示新增路由表项的记录信息。
# 显示IPv6 RIB向FIB下发路由表项的简要记录信息。
<Sysname> display ipv6 routing-table record flush
Date   Time         Action Destination/PrefixLength/VNID/Vrf
210908 09:33:21:996 update 1001::/64/0x520000004/default-vrf
210908 09:33:23:386 update 1001::1/128/0x120000001/default-vrf
以上显示信息解释请参见表1-3
# 显示IPv6 RIB向FIB下发的更新路由表项的详细记录信息。
<Sysname> display ipv6 routing-table record flush update verbose
        Time: 210908 09:33:21:996    Action: update
 Destination: 1001::/64
      OrigAs: 0                      LastAs: 0
        VNID: 0x520000004
       Flags: 0x10040000           ExtFlags: 0x0
   FlowIndex: 65535                  UserID: 0x0
    SID Type: 0                    VsiIndex: 0xffffffff
      LinkId: 0xffffffff             ArgLen: 0
        Time: 210908 09:33:23:386    Action: update
 Destination: 1001::1/128
      OrigAs: 0                      LastAs: 0
        VNID: 0x120000001
以上显示信息解释请参见表1-4
#显示IPv6 RIB向路由协议上报路由表项的简要记录信息。
<Sysname> display ipv6 routing-table record notify
Date   Time         Action Destination/PrefixLength/NibID/Vrf
210908 10:47:03:698 update 2000::/64/0x21000000/default-vrf
以上显示信息解释请参见表1-5
#显示IPv6 RIB向路由协议上报的删除路由表项的详细记录信息。
<Sysname> display ipv6 routing-table record notify delete verbose
        Time: 210908 10:49:47:787    Action: delete
 Destination: 2000::/64
     TableID: 0xa                     NibID: 0x0
     RtFlags: 0xc00              ExtRtFlags: 0x22
以上显示信息解释请参见表1-6
# 显示IPv6 RIB从路由协议收到路由表项的简要记录信息
<Sysname> display ipv6 routing-table record receive
Date   Time         Action Proto      Destination/PrefixLength/NibID/Vrf
210908 09:33:23:385 add    DIRECT     1001::1/128/0x20000001/default-vrf
以上显示信息解释请参见表1-7
# 显示IPv6 RIB从路由协议收到的添加路由表项的详细记录信息。
<Sysname> display ipv6 routing-table record receive add verbose
        Time: 210908 09:33:23:385    Action: add
     TableID: 0xa                 ProcessID: 0
    Protocol: DIRECT              SubProtID: 0x0
       NibID: 0x20000001           NewNibID: N/A
       Flags: 0x4                  ExtFlags: 0x0
      CommID: 0x5000001                 Tag: 0
         SID: N/A
       BkSID: N/A
以上显示信息解释请参见表1-8
display ipv6 routing-table statistics命令用来显示IPv6路由表中路由或前缀的统计信息。
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
如果不指定任何参数时,则显示公网的信息。
# 显示路由统计信息。
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8        Active prefixes: 8
DIRECT     5           5           5           0
STATIC     3           3           3           0
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
Total      8           8           8           0
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6        Active prefixes: 6
DIRECT     3           3           3           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
Total      6           6           8           2
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
Total      11          11          13          2
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
Total      11          11          13          2
# 显示公网的IPv6前缀统计信息。
<Sysname> display ipv6 routing-table prefix statistics
DIRECT     5             5           5           0
STATIC     1             1           1           0
UNR        0           0           0           0
RIPng      0             0           0           0
OSPFv3     0             0           0           0
IS-ISv6    0             0           0           0
LISP       0             0           0           0
SRv6       0             0           0           0
BGP4+      0             0           0           0
Total      6             6           6           0
表1-13 display ipv6 routing-table statistics命令显示信息描述表
Total prefixes
总的前缀数目
Active prefixes
总的激活前缀数目
Proto
路由协议
Routes
路由数目
Prefixes
前缀数目
Active
激活的、正在使用的路由或前缀数目
Added
Deleted
Total
各种类型路由或前缀数目的总和
display ipv6 routing-table summary命令用来显示IPv6路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
以上显示信息的解释请参见表1-10
# 显示vpn1实例的路由表概要信息。
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
Threshold value of active routes alert: 65100
以上显示信息的解释请参见表1-10
display rib attribute命令用来显示RIB的路由属性信息。
# 显示RIB的路由属性信息。
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
                  Flag: 0x0
        Address family: IPv4
       Reference count: 0
Act-RT reference count: 0
            Flush flag: 0
      Local preference: 0
Ext-communities number: 26
 Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
                        > <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
                        : 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
                         <RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
                        13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
        AS-path number: 0
         AS-path value: N/A
  SFlow AS-path length: 0
   SFlow AS-path value: N/A
Detailed information of attribute 0x1:
                  Flag: 0x0
              Protocol: BGP
       Reference count: 0
            Flush flag: 0
       Local prefrence: 0
Ext-communities number: 1
 Ext-communities value: <RT: 1.1.1.1:2>
        AS-path number: 0
         AS-path value: N/A
表1-14 display rib attribute命令显示信息描述表
attribute的总个数
Flag
标志位
Protocol
产生该属性的协议
Address family
地址簇类型
Reference count
引用计数
被激活路由引用次数
Flush flag
下刷FIB标记,0表示属性没有下刷FIB,1表示属性已经下刷FIB
Local prefrence
本地优先级
IPv4类型的扩展团体属性个数
IPv4类型的扩展团体属性值(个数为0显示N/A,最多显示20个,超出部分用…表示)
IPv6类型的扩展团体属性个数
Ext-comm-ipv6 value
IPv6类型的团体属性值(个数为0显示N/A,最多显示20个,超出部分用…表示)
Communities number
团体属性个数
Communities value
AS-path number
AS-path个数(AS-path个数为所有AS号之和)
AS-path value
AS-path值(AS-path值不区分AS-set、AS-sequence、联盟AS-set、联盟AS-sequence;个数为0显示N/A,最多显示20个,超出部分用…表示)
(暂不支持)sFlow AS-path属性长度
SFlow AS-path value
(暂不支持)sFlow AS-path值(长度为0显示N/A,最多显示20个,超出部分用…表示)
display rib graceful-restart命令用来显示RIB的GR状态信息。
# 显示RIB的GR状态信息。
<Sysname> display rib graceful-restart
Protocol GR state:
 1    DIRECT     900      30   End      No/No
 2    STATIC     900      34   End      No/No
 3    OSPF       900      36   End      No/No
 4    ISIS       900      32   End      No/No
 5    BGP instance abc
                 900      22   End      No/No
 6    BGP instance default
                 900      25   End      No/No
 7    LDP        900      35   End      No/No
 8    SLSP       900      29   End      No/No
 9    UNR instance UCM
                 900      33   End      No/No
表1-15 display rib graceful-restart命令显示信息描述表
RIB GR state
RIB GR状态:
·     Start:协议GR开始
·     IGP end:所有IGP协议GR结束
·     VPN-triggering end:VPN路由触发优选结束
·     VPN-calculation end:VPN路由优选结束
·     Routing protocol end:所有路由协议GR结束
·     NSR-calculation unfinished:NSR优选未完成状态
·     Triggering start:所有路由触发优选开始
·     Triggering end:所有路由触发优选结束
·     Phase1-calculation end:第一阶段优选结束
·     All end:所有协议GR结束
·     Phase2-calculation end:第二阶段优选结束
RCOM GR state
RCOM GR状态:
·     Start:协议GR开始
·     VPN-notification end:VPN路由上报结束
·     Notification end:所有路由上报结束
·     Flush start:开始下刷FIB
·     Flush end:下刷FIB结束
Protocol GR state
协议GR状态
No.
编号
Protocol
协议名称
Lifetime
倒换过程中协议的路由信息/标签信息在RIB中的存活时间,单位为秒
FD
协议进程与RIB连接的句柄
协议GR状态:
·     Init:协议GR初始化状态
·     Listen:协议GR监听状态
·     Idle:协议GR空闲状态
·     Active:协议GR激活状态
·     Start:协议GR开始状态
·     End:协议GR结束状态
Start/End
·     No:表示该消息未发送
·     Yes:表示该消息已发送
display rib nib命令用来显示RIB的下一跳信息。
display rib nib [ sub-nib nib-id ] [ verbose ]
display rib nib protocol protocol [ fast-reroute ] [ verbose ]
self-originated:路由管理自己生成的下一跳信息。
nib-id:路由下一跳信息的ID值,取值范围为十六进制数0~ffffffff。
protocol protocol:显示指定路由协议生成的下一跳信息。
如果不指定任何参数,将显示RIB中所有下一跳的概要信息。
# 显示RIB的下一跳信息。
<Sysname> display rib nib
Total number of nexthop(s): 176
      NibID: 0x10000000        Sequence: 0
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 0.0.0.0
    IFIndex: 0x111            LocalAddr: 0.0.0.0
 MemberPort: 0x0
   TopoNthp: 0                  ExtType: 0x0
 OriNexthop: 0.0.0.0
      NibID: 0x10000001        Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 127.0.0.1
    IFIndex: 0x112            LocalAddr: 127.0.0.1
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
      NibID: 0x10000002        Sequence: 2
       Type: 0x5                Flushed: Yes
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
      NibID: 0x16000000        Sequence: 3
       Type: 0x21               Flushed: No
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 12.1.1.2
    IFIndex: 0x0              LocalAddr: 0.0.0.0
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
   Instance: abc
表1-16 display rib nib命令显示信息描述表
总的下一跳个数
NibID
下一跳ID
Sequence
下一跳序列号
下一跳类型
Flushed
是否下刷
Age
下一跳信息最近一次更新的时间
UserKey0
第一个协议保留数据
UserKey1
第二个协议保留数据
VrfNthp
下一跳所在VPN索引,显示为0表示公网
Nexthop
下一跳地址
IFIndex
接口索引
LocalAddr
本地接口地址
MemberPort
聚合组成员端口的索引值
NewUK0
第一个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK1
第二个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK2
第三个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK3
第四个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK4
第五个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK5
第六个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK6
第七个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK7
第八个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK8
第九个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK9
第十个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK10
第十一个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK11
第十二个新的协议保留数据,如果没有此属性,则不显示该字段
NewUK12
第十三个新的协议保留数据,如果没有此属性,则不显示该字段
TopoNthp
(暂不支持子拓扑)‌下一跳所在拓扑索引,显示为0表示公网拓扑(目前IPv6不支持子拓扑,显示为Invalid)
ExtType
下一跳扩展类型
Color
Color扩展团体属性
COFlag
Color属性的标志位
SIDIndex
SID的索引值
SRPName
SR-MPLS TE Policy的名称
OriNexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
Instance
BGP实例名称
SubNibID
子下一跳的ID
SubSeq
子下一跳的序列号
NthpCnt
子下一跳的下一跳计数
Samed
子下一跳中相同下一跳计数
NthpType
子下一跳类型:
·     IP:下一跳是IP转发类型
·     MPLS:下一跳是MPLS转发类型
# 显示RIB下一跳详细信息。
<Sysname> display rib nib verbose
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 6              FlushRefCnt: 2
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 0.0.0.0
  RelyDepth: 0              RealNexthop: 0.0.0.0
  Interface: NULL0            LocalAddr: 0.0.0.0
   TunnelID: N/A               Topology: base
 MemberPort: N/A
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 13             FlushRefCnt: 5
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 127.0.0.1
  RelyDepth: 0              RealNexthop: 127.0.0.1
  Interface: InLoop0          LocalAddr: 127.0.0.1
 MemberPort: N/A
      NibID: 0x15000003        Sequence: 3
       Type: 0x43               Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x100010000        VrfNthp: 0
   UserKey1: 0x0                Nexthop: 22.22.22.22
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
   Instance: default
     RefCnt: 9              FlushRefCnt: 3
    ExtFlag: 0x0
     Policy: tnl-policy1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 22.22.22.22
  RelyDepth: 1              RealNexthop: 13.1.1.2
  Interface: XGE3/1/1         LocalAddr: 13.1.1.1
  TunnelCnt: 1                      Vrf: default-vrf
   TunnelID: 1025              Topology: base
 MemberPort: N/A
表1-17 display rib nib verbose命令显示信息描述表
总的下一跳个数
NibID
下一跳ID
Sequence
下一跳序列号
下一跳类型
Flushed
是否下刷
Age
下一跳信息最近一次更新的时间
UserKey0
第一个协议保留数据
VrfNthp
下一跳所在VPN索引,显示为0表示公网
UserKey1
第二个协议保留数据
Nexthop
下一跳地址
IFIndex
接口索引
LocalAddr
本地接口地址
MemberPort
聚合组成员端口的索引值
NewUK0
NewUK1
NewUK2
NewUK3
NewUK4
NewUK5
NewUK6
NewUK7
NewUK8
NewUK9
NewUK10
NewUK11
NewUK12
TopoNthp
(暂不支持子拓扑)下一跳所在拓扑索引,显示为0表示公网拓扑(目前IPv6不支持子拓扑,显示为Invalid)
ExtType
下一跳扩展类型
Color
Color扩展团体属性
COFlag
Color属性的标志位
SIDIndex
SID的索引值
SRPName
OriNexthop
Instance
BGP实例名称
RefCnt
下一跳信息的引用计数
FlushRefCnt
下一跳信息的下刷引用计数
Flag
下一跳信息的标志位
Version
下一跳信息的版本号
ExtFlag
下一跳信息的扩展标志位
Policy
隧道策略名
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
OrigNexthop
原始下一跳
RelyDepth
迭代深度
RealNexthop
真实下一跳
出接口
LocalAddr
本地接口地址
TunnelCnt
迭代到隧道的个数
Vrf
VPN实例名,显示为default-vrf表示公网
TunnelID
迭代到隧道的ID
Topology
(暂不支持子拓扑)拓扑名称,显示为base表示公网拓扑(目前IPv6不支持子拓扑,显示为空)
Weight
等价路由各路由的权重,取值为0表示不是等价路由
Flags
当前下一跳的标志位
SRPolicyNID
SR-MPLS TE Policy迭代路由的下一跳ID
SRInterface
SR-MPLS TE Policy迭代路由的出接口
ColorWeight
SR-MPLS TE Policy中Color属性的权重值
Locator
SID所属Locator段的IPv6前缀,N/A表示没有该属性
MemberPort
display rib nib record命令用来显示RIB下一跳的记录信息。
display rib nib record flush [ delete | update ] [ verbose ]
display rib nib record receive [ add | delete | update ] [ verbose ]
flush:显示RIB向FIB下发下一跳的记录信息。
receive:显示RIB从路由协议收到下一跳的记录信息。
add:显示新增下一跳的记录信息。
# 显示RIB向FIB下发下一跳的简要记录信息。
<Sysname> display rib nib record flush
210908 15:31:58:753 update 0x10000000
210908 15:31:58:755 update 0x110000001
表1-18 display rib nib record flush命令显示信息描述表
下一跳记录信息的个数
Date
记录信息产生的日期
Time
记录信息产生的时间
Action
下一跳记录信息的类型,取值包括:
·     add:表示添加下一跳
·     update:表示更新下一跳
·     delete:表示删除下一跳
VNID
VN表项ID
# 显示RIB向FIB下发的更新下一跳的详细记录信息。
<Sysname> display rib nib record flush update verbose
        Time: 210928 14:39:14:162    Action: update
       NibID: 0x10000000               VNID: 0x10000000
        Flag: 0x80                 ExtFlags: 0x0
      RefCnt: 5                 FlushRefCnt: 1
        Type: 0x1
    VrfIndex: 0x0                   Nexthop: 127.0.0.1
     IfIndex: 1410                LocalAddr: 127.0.0.1
       Color: 0                  OriNexthop: 0.0.0.0
 1 nexthop(s):
   Interface: 1410                LocalAddr: 127.0.0.1
    VrfIndex: 0                    Topology: base
表1-19 display rib nib record flush verbose命令显示信息描述表
下一跳记录信息的个数
Limit of records
下一跳记录信息的最大个数
Time
记录信息产生的日期和时间
Action
下一跳记录信息的类型,取值包括:
·     update:表示更新下一跳
·     delete:表示删除路下一跳
NibID
下一跳ID
VNID
VN表项ID
Sequence
下一跳序列号
Version
下一跳信息的版本号
Flag
下一跳信息的标志位
ExtFlags
扩展下一跳信息的标志位
RefCnt
下一跳实例内引用计数
FlushRefCnt
表项下刷引用计数
下一跳类型
VrfIndex
VPN实例索引
Nexthop
下一跳地址
IfIndex
出接口索引
LocalAddr
本地接口地址
ExtType
下一跳扩展类型
NibInstance
生成下一跳信息的实例名称,取值包括:
·     IFM:接口管理实例
·     USR:静态路由协议
·     RIP:RIP或RIBng协议
·     OSPF:OSPF或OSPFv3协议
·     ISIS:IS-IS或IPv6 IS-IS协议
·     LISP:LISP协议
·     BGP:BGP或BGP4+协议
·     RIB:IP路由表实例
·     EVPN:EVPN实例
·     EIGRP:EIGRP或EIGRPv6协议
·     UNR:用户网络路由实例
·     SRV6:SRv6协议
·     None:未知或非法实例
UserKey0
第一个协议保留数据
UserKey1
第二个协议保留数据
NewUK0
第一个新的协议保留数据
NewUK1
第二个新的协议保留数据
NewUK2
第三个新的协议保留数据
NewUK3
第四个新的协议保留数据
NewUK4
第五个新的协议保留数据
NewUK5
第六个新的协议保留数据
NewUK6
第七个新的协议保留数据
NewUK7
第八个新的协议保留数据
SIDIndex
SID的索引值
SrPolicyName
Color
Color扩展团体属性
OriNexthop
COFlag
Color属性的标志位
Locator
SubType
组合下一跳子类型
SubNibID
子下一跳的ID
SubSeq
子下一跳的序列号
NthpCnt
子下一跳的下一跳计数
Samed
子下一跳中相同下一跳计数
NthpType
子下一跳类型,取值包括:
·     IP:表示下一跳是IP转发类型
·     MPLS:表示下一跳是MPLS转发类型
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
OrigNexthop
原始下一跳
RelyDepth
迭代深度
RealNexthop
真实下一跳
出接口
Topology
Weight
本路由在等价路由中的权重,取值为0表示不是等价路由
Flags
当前下一跳的标志位
SRPolicyNID
SRInterface
ColorWeight
Locator
MemberPort
聚合组成员端口的索引值,0表示没有该属性
SRL2Interface
聚合组成员端口编号,0表示没有该属性
# 显示RIB从路由协议收到的下一跳的简要记录信息。
<Sysname> display rib nib record receive
210907 14:42:09:471 add    0x10000003 IFM
210907 15:35:45:190 delete 0x10000003 IFM
表1-20 display rib nib record receive命令显示信息描述表
下一跳记录信息的个数
Date
记录信息产生的日期
Time
记录信息产生的时间
Action
下一跳记录信息的类型,取值包括:
·     add:表示添加下一跳
·     update:表示更新下一跳
·     delete:表示删除下一跳
NibID
路由下一跳信息的ID值
NibInstance
生成下一跳信息的实例类型,取值包括:
·     IFM:接口管理实例
·     USR:静态路由协议
·     RIP:RIP或RIBng协议
·     LISP:LISP协议
·     BGP:BGP或BGP4+协议
·     RIB:IP路由表实例
·     EVPN:EVPN实例
·     UNR:用户网络路由实例
·     SRV6:SRv6协议
·     None:未知或非法实例
# 显示RIB从路由协议收到的添加下一跳的详细记录信息。
<Sysname> display rib nib record receive add verbose
        Time: 210928 14:39:14:148    Action: add
        Flag: 0x0                   UsrData: 0xffffffffffffffff
  InstanceId: 0                     Nexthop: 127.0.0.1
 1 nexthop(s):
表1-21 display rib nib record receive verbose命令显示信息描述表
下一跳记录信息的个数
Limit of records
下一跳记录信息的最大个数
Time
记录信息产生的日期和时间
Action
下一跳记录信息的类型,取值包括:
·     add:表示添加下一跳
·     update:表示更新下一跳
·     delete:表示删除路下一跳
NibID
下一跳ID
Sequence
下一跳序列号
NibInstance
生成下一跳信息的实例名称
·     IFM:接口管理实例
·     USR:静态路由协议
·     RIP:RIP或RIBng协议
·     ISIS:IS-IS或IS-ISv6
·     LISP:LISP协议
·     BGP:BGP或BGP4+协议
·     RIB:IP路由表实例
·     EVPN:EVPN实例
·     UNR:用户网络路由实例
·     SRV6:SRv6协议
·     None:未知或非法实例
Version
下一跳信息的版本号
Flag
下一跳信息的标志位
UsrData
协议私有数据
VrfIndex
VPN实例索引
VrfName
下一跳类型
Nexthop
下一跳地址
ExtType
下一跳扩展类型
LocalAddr
本地接口地址
InstanceId
多实例进程标识号
IfIndex
接口索引
UserKey0
第一个协议保留数据
UserKey1
第二个协议保留数据
NewUK0
第一个新的协议保留数据
NewUK1
第二个新的协议保留数据
NewUK2
第三个新的协议保留数据
NewUK3
第四个新的协议保留数据
NewUK4
第五个新的协议保留数据
NewUK5
第六个新的协议保留数据
NewUK6
第七个新的协议保留数据
NewUK7
第八个新的协议保留数据
Color
Color扩展团体属性
COFlag
Color属性的标志位
BandWidth
下一跳所在链路的带宽
Weight
ProtNibID
协议携带的下一跳ID
NibFlags
当前下一跳的标志位
SIDIndex
SID的索引值
SrPolicyName
SubType
组合下一跳子类型
SubNibID
子下一跳的ID
SubSeq
子下一跳的序列号
NthpCnt
子下一跳的下一跳计数
Samed
子下一跳中相同下一跳计数
NthpType
子下一跳类型,取值包括:
·     IP:表示下一跳是IP转发类型
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
OrigNexthop
原始下一跳
RelyDepth
迭代深度
RealNexthop
真实下一跳
出接口
Topology
Flags
当前下一跳的标志位
SRPolicyNID
SRInterface
ColorWeight
Locator
MemberPort
SRL2Interface
聚合组成员端口编号,0表示没有该属性
display route-direct nib命令用来显示直连路由下一跳信息。
# 显示直连路由下一跳信息。
<Sysname> display route-direct nib
Total number of nexthop(s): 116
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
表1-22 display route-direct nib命令显示信息描述表
总的下一跳个数
NibID
NIB ID号
Sequence
NIB序列号
NIB类型
Flushed
是否下刷FIB
Age
下一跳信息最近一次更新的时间
UserKey0
NIB协议保留数据1
UserKey1
NIB协议保留数据2
VrfNthp
下一跳所在VPN索引,显示为0表示公网
Nexthop
下一跳信息
IFIndex
接口索引
LocalAddr
本地接口地址
MemberPort
聚合组成员端口的索引值
NewUK0
NewUK1
NewUK2
NewUK3
NewUK4
NewUK5
NewUK6
NewUK7
NewUK8
NewUK9
NewUK10
NewUK11
NewUK12
TopoNthp
ExtType
下一跳扩展类型
Color
Color扩展团体属性
COFlag
Color属性的标志位
SIDIndex
SID的索引值
SRPName
OriNexthop
# 显示直连路由下一跳详细信息。
<Sysname> display route-direct nib verbose
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 2              FlushRefCnt: 0
    ExtFlag: 0x0
 1 nexthop(s):
 MemberPort: N/A
        Age: 00h01m50s
 MemberPort: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 5              FlushRefCnt: 0
    ExtFlag: 0x0
 1 nexthop(s):
 MemberPort: N/A
表1-23 display route-direct nib verbose命令显示信息描述表
总的下一跳个数
NibID
下一跳ID
Sequence
下一跳序列号
下一跳类型
Flushed
是否下刷
Age
下一跳信息最近一次更新的时间
UserKey0
第一个协议保留数据
VrfNthp
下一跳所在VPN索引,显示为0表示公网
UserKey1
第二个协议保留数据
Nexthop
下一跳地址
IFIndex
接口索引
LocalAddr
本地接口地址
MemberPort
聚合组成员端口的索引值
NewUK0
NewUK1
NewUK2
NewUK3
NewUK4
NewUK5
NewUK6
NewUK7
NewUK8
NewUK9
NewUK10
NewUK11
NewUK12
TopoNthp
ExtType
下一跳扩展类型
Color
Color扩展团体属性
COFlag
Color属性的标志位
SIDIndex
SID的索引值
SRPName
OriNexthop
RefCnt
RefCnt
FlushRefCnt
下一跳信息的下刷引用计数
Flag
下一跳信息的标志位
Version
下一跳信息的版本号
ExtFlag
下一跳信息的扩展标志位
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
OrigNexthop
原始下一跳
RelyDepth
迭代深度
RealNexthop
真实下一跳
出接口
LocalAddr
本地接口地址
TunnelCnt
迭代到隧道的个数
Vrf
TunnelID
迭代到隧道的ID
Topology
Weight
Flags
当前下一跳的标志位
SRPolicyNID
SRInterface
ColorWeight
Locator
MemberPort
1.1.29  fib lifetime
fib lifetime命令用来配置IPv4/IPv6路由在FIB中的最大存活时间。
undo fib lifetime命令用来恢复缺省情况。
fib lifetime seconds
undo fib lifetime
IPv4/IPv6路由在FIB中的最大存活时间为600秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
seconds:路由在FIB中的最大存活时间,取值范围为0~6000,单位为秒。取值为0时表示,协议或RIB进程倒换并重新恢复后,会立即通知FIB老化表项。
配置本命令后,协议在未配置GR的情况下,协议或RIB倒换重新恢复后,会延迟配置的seconds,再通知FIB老化表项。
# 配置IPv4路由在FIB中的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute命令用来配置RIB向FIB下发路由时会携带属性消息。
undo flush route-attribute命令用来取消该配置。
flush route-attribute protocol
undo flush route-attribute protocol
RIB向FIB下发路由时不携带属性消息。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议,目前只支持BGP。
# 配置RIB向FIB下发BGP路由时会携带属性消息。
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
inter-protocol ecmp命令用来配置RIB IPv4/IPv6地址族不同协议的路由可以形成等价路由。
undo inter-protocol ecmp命令用来恢复缺省情况。
inter-protocol ecmp [ ignore-preference ] [ vpn-instance vpn-instance-name ]
undo inter-protocol ecmp [ vpn-instance vpn-instance-name ]
不同协议的路由不能形成等价路由。
RIB IPv4地址族视图
RIB IPv6地址族视图
ignore-preference:配置不同优先级的路由也可以形成等价路由。如果未指定本参数,则只有相同优先级的路由才可以形成等价路由。
vpn-instance vpn-instance-name:配置指定VPN实例中不同协议的路由可以形成等价路由。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则配置公网中不同协议的路由可以形成等价路由。
缺省情况下,不同协议的路由优先级不相同,开销值的计算方法也不同,因此不能形成等价路由。配置本命令后,设备在形成等价路由时会忽略路由的开销值。
对于到达同一目的地址的多条不同协议的路由:
·     在配置本命令时如果未指定ignore-preference参数,则优先级最高的多条路由会形成等价路由。将不同协议的路由修改为相同的优先级,即可形成等价路由。
·     在配置本命令时如果指定了ignore-preference参数,则多条路由都会形成等价路由。
如果同时配置了本命令和inter-protocol fast-reroute命令,则仅本命令生效。
# 开启RIB IPv4地址族中公网的不同协议的路由可以形成等价路由。
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol ecmp
inter-protocol fast-reroute命令用来开启RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
undo inter-protocol fast-reroute命令用来关闭RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
inter-protocol fast-reroute [ ecmp-shared ] [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
不同协议间快速重路由功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
ecmp-shared:为包含等价路由的所有路由选取备份下一跳信息,其中为等价路由选取的备份下一跳是共享下一跳,即多条等价的路由的备份下一跳是相同的。如果未指定本参数,则仅为非等价路由计算备份下一跳。
vpn-instance vpn-instance-name:开启指定VPN实例的不同协议间快速重路由功能。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则开启RIB IPv4/IPv6地址族中公网的不同协议间快速重路由功能。
通过配置不同协议间快速重路由功能,可将不同协议的下一跳作为备份下一跳。当路由器检测到网络故障时,将使用备份下一跳替换失效下一跳,通过备份下一跳来指导报文的转发,从而大大缩短了流量中断的时间。
如果RIB表中去往同一目的地的不同路由的下一跳和出接口均相同,使用该命令不会生成备份下一跳。
使用不同协议间的快速重路由功能生成备份下一跳时可能会造成环路。
去往同一目的地址的多条路由形成等价路由时,指定ecmp-shared参数可以为等价路由计算一个共享的备份下一跳,该备份下一跳为等价路由之外的、其他协议的路由。当链路或设备故障导致所有等价路由的下一跳均失效时,RIB会使用该备份下一跳替换失效的下一跳,通过备份下一跳来指导报文转发。备份下一跳将以等价路由的形式下发给FIB,可通过display ip routing-table命令查看路由的详细信息,其中State包含Backup状态的路由即为等价路由的备份路由信息。如果备份下一跳和某个等价路由的下一跳相同,则RIB不会将备份下一跳发给FIB,备份下一跳实际上不生效。
如果同时配置了本命令和inter-protocol ecmp命令,则本命令不生效。
# 开启RIB IPv4地址族中公网的不同协议间快速重路由功能。
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
1.1.33  ipv6 route-direct track
ipv6 route-direct track命令用来配置IPv6直连路由与Track项关联。
undo ipv6 route-direct track命令用来恢复缺省情况。
ipv6 route-direct track track-entry-number degrade-cost cost-value
未配置IPv6直连路由与Track项关联。
track-entry-number:指定Track项序号,取值范围为1~1024。
degrade-cost cost-value:当Track项状态变为Negative后直连路由的开销值,取值范围为1~4294967295。
在采用VRRP备份组作为用户网关的场景中,由于上行流量的路径取决于VRRP状态,而下行流量的路径一般由动态路由协议通过选路决定,因此可能出现上下行流量路径不一致的情况。当需要在主机上设置防火墙以提高安全性时,上下行路径不一致会导致流量被防火墙阻止;另外,在进行流量监控、流量统计等管理工作时,上下行流量路径不一致会增加不必要的难度和成本。为了解决该问题,可以通过Track项在IPv6 VRRP备份组和IPv6直连路由之间建立关联,使设备根据IPv6 VRRP状态来调整IPv6直连路由的开销值,然后配置动态路由协议引入IPv6直连路由,从而使VRRP状态影响动态路由协议的选路结果。具体的工作机制如下:
·     如果IPv6直连路由关联的Track项不存在,或者关联的Track项的状态为NotReady或Positive时,接口的IPv6直连路由的开销值为0,该路由被优选。
·     如果IPv6直连路由关联的Track项的状态为Negative时,该接口的IPv6直连路由的开销值为用户通过本功能设置的值,以便路由协议重新进行路由优选。
Track项的状态与IPv6 VRRP备份组中设备状态的对应关系如下:
·     当设备为Master状态时,关联的Track项为Positive状态。
·     当设备为Backup或Initialize状态时,关联的Track项为Negative状态;当设备为Inactive状态或IPv6 VRRP备份组不存在时,对应的Track项为NotReady状态。
关于IPv6 VRRP备份组关联Track项的详细介绍,请参见“可靠性配置指导”中的“Track”。
不能通过重复执行本命令修改IPv6直连路由关联的Track项。如需修改IPv6直连路由关联的Track项,请先通过undo ipv6 route-direct track命令取消IPv6直连路由关联的Track项,再执行ipv6 route-direct track命令。
# 在接口Ten-GigabitEthernet3/1/1上配置IPv6直连路由与序号为1的Track项关联,并设置Track项状态变为Negative后直连路由的开销值为200。
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] ipv6 route-direct track 1 degrade-cost 200
·     track vrrp ipv6(可靠性命令参考/Track)
1.1.34  maintenance-probe enable
maintenance-probe enable命令用来开启MTP(Maintain Probe,维护探测器)功能。
undo maintenance-probe enable命令用来关闭MTP功能。
MTP功能处于关闭状态。
开启MTP功能后,当与邻居间的路由协议报文超时时,设备会向超时的邻居发起Ping操作和Tracert操作并记录结果。相关信息可以通过display ospf troubleshooting等路由协议模块的显示命令查看,也可以通过display logbuffer命令查看MTP的详细信息。
# 开启MTP功能。
[Sysname] maintenance-probe enable
·     display bgp troubleshooting(三层技术-IP路由命令参考/BGP)
·     display logbuffer(网络管理和监控命令参考/信息中心)
·     display ospf troubleshooting(三层技术-IP路由命令参考/OSPF)
1.1.35  nexthop recursive-lookup restrain
nexthop recursive-lookup restrain命令用来配置路由迭代抑制功能。
undo nexthop recursive-lookup restrain命令用来恢复缺省情况。
nexthop recursive-lookup restrain { maximum-interval [ minimum-interval [ incremental-interval ] ] | millisecond interval }
不对路由迭代进行抑制。
RIB IPv4地址族视图
RIB IPv6地址族视图
maximum-interval:路由迭代的最大抑制时间,取值范围为1~60,单位为秒。
minimum-interval:路由迭代的最小抑制时间,取值范围为10~60000,单位为毫秒,缺省值为50。
incremental-interval:路由迭代的抑制时间惩罚增量,取值范围为10~60000,单位为毫秒,缺省值为200。
millisecond interval:路由迭代的抑制时间为固定值,取值范围为10~10000,单位为毫秒。
当路由的下一跳迭代到的依赖路由或者隧道发生变化时,会触发该路由重新进行迭代。当网络频繁变化时,路由可能会反复迭代,导致系统CPU占用率居高不下。为了解决上述问题,可以配置本命令,使得路由在进行迭代时,RIB等待一段时间再得到迭代的结果,从而降低路由迭代的频率,减轻设备CPU的运行压力。但本功能会导致路由迭代的效率降低、路由收敛速度变慢,请根据网络的实际情况判断是否需要配置本命令,以及确定合适的参数。
路由开始迭代后,RIB需要经过一段时间才能得到迭代的结果,这段时间就是抑制时间。在抑制时间内,不管路由迭代的结果是否发生变化,RIB都会继续等待至抑制时间结束后才能得到最新的路由迭代结果。
在配置本命令时,如果指定了最大抑制时间,则表明RIB采用动态的方式对路由迭代进行抑制。在该方式中,如果路由迭代的结果持续变化,则RIB对路由迭代的抑制时间会越来越长,直到抑制时间达到最大抑制时间;如果路由迭代的结果不再变化,则抑制时间会减少。
采用动态方式时,抑制时间T的计算方式如下:
·     路由开始第一次(即路由迭代的次数N=1)迭代时,抑制时间T为minimum-interval
·     路由在开始第N次(N不小于2)迭代时,抑制时间T=minimum-intervalincremental-interval×[2^(N-2)]。T的最大值为maximum-interval的值。
·     如果连续三次路由迭代的抑制时间都为maximum-interval,则下一次该路由进行迭代时,抑制时间为minimum-interval,并且路由迭代的次数N恢复为1。
·     如果在两倍的maximum-interval时间内路由的迭代结果都没有变化,则下一次该路由进行迭代时,抑制时间为minimum-interval,并且路由迭代的次数N恢复为1。
参数minimum-intervalincremental-interval的值不允许大于参数maximum-interval的值。
执行本命令后,配置的抑制时间不会立即生效,而是等待路由开始下一次迭代时才生效。
多次执行本命令,最后一次执行的命令生效。
如果同时配置了本命令和如下一条或多条命令,则当RIB路由的下一跳迭代到BGP路由时,抑制时间为本命令与如下命令配置的抑制时间之和:
·     BGP实例视图/BGP-VPN实例视图下的nexthop recursive-lookup restrain命令。
·     BGP地址族视图下的nexthop recursive-lookup delay命令。
# 配置IPv4路由迭代的最大抑制时间为60秒,最小抑制时间为500毫秒,抑制时间惩罚增量为1000毫秒。
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4] nexthop recursive-lookup restrain 60 500 1000
# 配置IPv6路由迭代的固定抑制时间为1000毫秒。
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6] nexthop recursive-lookup restrain millisecond 1000
·     nexthop recursive-lookup delay(三层技术-IP路由命令参考/BGP)
·     nexthop recursive-lookup restrain(三层技术-IP路由命令参考/BGP)
1.1.36  nexthop recursive-lookup restrain clear-interval
nexthop recursive-lookup restrain clear-interval命令用来配置清除下一跳循环迭代惩罚计数的时间间隔。
undo nexthop recursive-lookup restrain clear-interval命令用来恢复缺省情况。
nexthop recursive-lookup restrain clear-interval interval
清除下一跳循环迭代惩罚计数的时间间隔为600秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
clear-interval interval:清除下一跳循环迭代惩罚计数的时间间隔。interval表示时间间隔,取值范围1~65535,单位为秒。
下一跳循环迭代惩罚计数达到20次后,设备将启动抑制,即停止根据下一跳信息查找直连出接口的操作。interval时间后,设备将停止对下一跳循环迭代进行抑制,并将下一跳循环迭代惩罚计数清零。
# 配置清除下一跳循环迭代计数的时间间隔为100秒。
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain clear-interval 100
1.1.37  nexthop recursive-lookup restrain disable
nexthop recursive-lookup restrain disable命令用来关闭下一跳循环迭代抑制功能。
undo nexthop recursive-lookup restrain disable命令用来开启下一跳循环迭代抑制功能。
下一跳循环迭代抑制功能处于开启状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
在路由迭代过程中,若迭代路径包含该路由本身,则认为发生循环迭代。循环迭代将导致本次迭代失败并触发继续查找其他依赖路由。当大量路由的下一跳相同,且该下一跳因不断进行循环迭代导致路由频繁震荡时,系统会频繁处理大量的路由变化,这样会占用大量系统资源,导致CPU占用率升高,影响设备性能。
不断进行循环迭代时,迭代失败次数(下一跳循环迭代惩罚计数)会累计一次,当惩罚计数达到一定数量时,将不再进行路由迭代,从而解决上述问题。
用户不关心循环迭代造成的CPU占用率升高时,可以关闭下一跳循环迭代抑制功能。
# 关闭下一跳循环迭代抑制功能。
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain disable
1.1.38  primary-path-detect bfd
primary-path-detect bfd命令用来配置协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达。
undo primary-path-detect bfd命令用来取消协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达的配置。
primary-path-detect bfd { ctrl | echo } [ inter-protocol-frr | protocol-ecmp protocol ]
undo primary-path-detect bfd [ inter-protocol-frr | protocol-ecmp protocol ]
未配置协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达。
RIB IPv4地址族视图
RIB IPv6地址族视图
ctrl:配置通过控制报文方式的BFD会话检测主路由的下一跳是否可达。
echo:配置通过echo报文方式的BFD会话检测主路由的下一跳是否可达。
inter-protocol-frr:配置不同协议间快速重路由通过BFD会话检测主路由的下一跳是否可达。
protocol-ecmp protocol:配置指定路由协议的等价路由通过BFD会话检测主路由的下一跳是否可达。在RIB IPv4地址族视图中,该参数的取值包括bgpisisospfstatic。在RIB IPv6地址族视图中,对于控制报文方式的BFD会话,该参数的取值包括bgp4+isisv6ospfv3static;对于echo报文方式的BFD会话,该参数的取值包括bgp4+static
配置本命令后,设备会自动创建一个协议类型为IPFRR的BFD会话,通过该BFD会话对主路由的下一跳进行检测,以提高主路由下一跳失效时流量切换到备路由下一跳上的收敛速度:
·     对于不同协议间的快速重路由,主路由指的是去往同一目的地的多条路由中优先级最高的路由。
·     对于指定路由协议的等价路由,主路由指的是形成等价路由的每一条路由。如果在配置路由协议的快速重路由功能时指定了ecmp-shared参数,设备会为包含等价路由的所有路由通过LFA算法选取备份下一跳信息。自动计算的备份下一跳也作为等价路由添加到路由表中,状态为backup,该路由不是主路由,BFD不会检测这种等价路由。
只有存在已经生成了备份下一跳的主路由时,本命令才会生效并自动创建BFD会话。
通过重复执行本命令,可以修改BFD会话的工作方式(echo报文方式或控制报文方式)。
执行本命令时,如果没有指定inter-protocol-frrprotocol-ecmp参数,表示同时配置或取消配置不同协议间快速重路由和指定路由协议的所有等价路由通过BFD会话检测主路由的下一跳是否可达的功能。以此种方式进行的配置,优先级高于通过指定inter-protocol-frrprotocol-ecmp参数进行的配置。例如,当执行了primary-path-detect bfd ctrl命令后,仅可通过primary-path-detect bfd echo 命令修改配置,或通过undo primary-path-detect bfd命令取消配置。
通过控制报文方式的BFD会话检测主路由的下一跳是否可达时,由于控制报文方式的BFD会话需要两端进行协商才能成功建立,用户需要在下一跳设备上手工创建一个静态BFD会话。该BFD会话为控制报文方式的单跳BFD会话,并且会话源IP地址为本端自动创建的BFD会话的目的IP地址、会话目的IP地址为本端自动创建的BFD会话的源IP地址、远端标识符为本端自动创建的BFD会话的本地标识符。主路由下一跳设备上创建满足上述要求的静态BFD会话后,本端设备才能使用控制报文方式的BFD会话来检测主路由的下一跳。有关创建静态BFD会话的详细介绍,请参见“可靠性配置指导”中的“BFD”。
其他业务模块在通过BFD会话检测主路由的下一跳是否可达时,也会自动创建BFD会话(如BGP、OSPF、IS-IS等)。如果其他协议创建的自动BFD会话检测的路由下一跳与RIB主路由的下一跳相同,则设备不会重复自动创建同类型的BFD会话,而是复用其他协议的BFD会话。
# 配置通过控制报文方式的BFD会话检测IS-IS协议所有等价路由的下一跳是否可达。
[Sysname] rib
[Sysname-rib-ipv4] primary-path-detect bfd ctrl protocol-ecmp isis
·     fast-reroute(三层技术-IP路由命令参考/IS-IS)
·     inter-protocol fast-reroute
1.1.39  protocol lifetime
protocol lifetime命令用来配置IPv4/IPv6路由和标签在RIB中的最大存活时间。
undo protocol lifetime命令用来恢复缺省情况。
undo protocol protocol [ instance instance-name ] lifetime
IPv4/IPv6路由和标签在RIB中的最大存活时间为900秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议。
instance instance-name:BGP实例名称,instance-name为1~31个字符的字符串,区分大小写。如果未指定本参数,将配置所有BGP实例的最大存活时间。只有当protocolbgp时该参数可选。
seconds:最大存活时间,取值范围为1~6000,单位为秒。
如果配置了该命令,且协议配置GR的情况下,需要注意该时间不要与GR时间冲突,即必须要保证协议能够在该时间内完成GR并将全部表项下发RIB,否则会导致GR失败并断流。
# 配置RIB中RIP路由和标签的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] protocol rip lifetime 60
1.1.40  protocol nexthop recursive-lookup
protocol nexthop recursive-lookup命令用来配置按照路由策略进行迭代下一跳查找。
undo protocol nexthop recursive-lookup命令用来取消该配置。
protocol protocol nexthop recursive-lookup route-policy route-policy-name
undo protocol protocol nexthop recursive-lookup route-policy
没有配置按路由策略进行下一跳迭代查找。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议,RIB IPv4地址族视图下支持bgpstatic,RIB IPv6地址族视图下支持bgp4+
route-policy-name:指定路由策略名,为1~63个字符的字符串,区分大小写。
通过配置按路由策略迭代下一跳,可以对路由迭代的结果进行控制。例如:当路由发生变化时,路由管理需要对非直连的下一跳重新进行迭代。如果不对迭代的结果路由进行任何限制,则路由管理可能会将下一跳迭代到一个错误的转发路径上,从而造成流量丢失。此时,可以通过配置本功能,将错误的依赖路由过滤掉,使路由迭代到通过路由策略过滤的指定依赖路由上。
配置路由策略时,如果配置了apply子句,apply子句不会生效。
配置路由策略时,请确保至少有一个正确的依赖路由能够通过该策略的过滤,否则可能导致相关路由不可达,无法正确指导转发。
从BGP直连邻居收到的路由不受下一跳迭代路由策略的限制。
# 配置BGP路由按照路由策略policy1进行下一跳迭代查找。
[Sysname] rib
[Sysname-rib-ipv4] protocol bgp nexthop recursive-lookup route-policy policy1
1.1.41  record-limit
record-limit命令用来配置RIB下一跳或路由表项记录信息的最大数目。
undo record-limit命令用来恢复缺省情况。
record-limit limit [ rib nib [ flush [ delete | update ] | receive [ add | delete | update ] ] ]
undo record-limit [ rib nib [ flush [ delete | update ] | receive [ add | delete | update ] ] ]
record-limit limit [ routing-table [ flush [ delete | update ] | notify [ delete | update ] | receive [ add | delete | update ] ] ]
undo record-limit [ routing-table [ flush [ delete | update ] | notify [ delete | update ] | receive [ add | delete | update ] ] ]
RIB下一跳和路由表项记录信息的最大数目均为1000。
RIB IPv4地址族视图
RIB IPv6地址族视图
limit:指定RIB下一跳或路由表项记录信息的最大数目,取值范围为0~10000。取值为0时,表示不记录RIB下一跳或路由表项信息。当记录信息到达最大数目时,可以继续记录新的信息,但新的信息会覆盖最早的信息。
rib nib:配置RIB下一跳记录信息的最大数目。
routing-table:配置路由表项记录信息的最大数目。
flush:配置RIB向FIB下发记录信息的最大数目。
notify:配置RIB向路由协议上报记录信息的最大数目。
receive:配置RIB从路由协议收到记录信息的最大数目。
add:配置记录新增信息的最大数目。
update:配置记录更新信息的最大数目。如果指定了flushnotify参数,则新增信息也会被认为是更新信息。
delete:配置记录删除信息的最大数目。
多次执行本命令,可以为RIB下一跳或路由表项的不同记录信息分别配置最大数目。
如果rib nibrouting-table参数均未指定,则表示同时配置RIB下一跳和路由表项所有记录信息的最大数目。
如果adddeleteupdate参数均未指定,则表示同时配置新增、删除和更新记录信息的最大数目。
# 配置IPv4 RIB下一跳和路由表项记录信息的最大数目为100。
[Sysname] rib
[Sysname-rib-ipv4] record-limit 100
# 配置IPv4路由表项记录信息的最大数目为200。
[Sysname] rib
[Sysname-rib-ipv4] record-limit 200 routing-table
# 配置IPv4 RIB从路由协议收到的新增下一跳记录信息的最大数目为300。
[Sysname] rib
[Sysname-rib-ipv4] record-limit 300 rib nib receive
# 配置IPv6 RIB向路由协议上报的更新路由表项记录信息的最大数目为400。
[Sysname] rib
[Sysname-rib-ipv6] record-limit 400 routing-table notify update
# 配置IPv6 RIB向FIB下发的删除下一跳记录信息的最大数目为500。
[Sysname] rib
[Sysname-rib-ipv6] record-limit 500 rib nib flush delete
1.1.42  reset ip routing-table record
reset ip routing-table record命令用来清除路由表项的记录信息。
# 清除IPv4路由表项的记录信息。
<Sysname> reset ip routing-table record
1.1.43  reset ip routing-table statistics protocol
reset ip routing-table statistics protocol命令用来清除路由表中的路由统计信息。
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name:清除指定VPN的路由统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
all-routes:清除公网和所有VPN实例的路由统计信息。
all-vpn-instance:清除所有VPN实例的路由统计信息。
protocol:清除IPv4路由表中指定路由协议的统计信息。
all:清除IPv4路由表中所有路由协议的统计信息。
如果没有指定all-routesvpn-instanceall-vpn-instance参数,则清除公网的路由统计信息。
# 清除路由表中的路由统计信息。
<Sysname> reset ip routing-table statistics protocol all
1.1.44  reset ipv6 rib nib record
reset ipv6 rib nib record命令用来清除IPv6 RIB下一跳的记录信息。
# 清除IPv6 RIB下一跳的记录信息。
<Sysname> reset ipv6 rib nib record
1.1.45  reset ipv6 routing-table record
reset ipv6 routing-table record命令用来清除IPv6路由表项的记录信息。
# 清除IPv6路由表项的记录信息。
<Sysname> reset ipv6 routing-table record
1.1.46  reset ipv6 routing-table statistics protocol
reset ipv6 routing-table statistics protocol命令用来清除IPv6路由表中的综合路由统计信息。
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
protocol:清除IPv6路由表中指定路由协议的统计信息。
all:清除IPv6路由表中所有路由协议的统计信息。
# 清除IPv6路由表中所有路由协议的综合路由统计信息。
<Sysname> reset ipv6 routing-table statistics protocol all
1.1.47  reset rib nib record
reset rib nib record命令用来清除IPv4 RIB下一跳的记录信息。
# 清除IPv4 RIB下一跳的记录信息。
<Sysname> reset rib nib record
1.1.48  rib
rib命令用来进入RIB视图。
undo rib命令用来删除RIB视图下的所有配置。
rib
undo rib
# 进入RIB视图。
[Sysname] rib
[Sysname-rib]
1.1.49  route-direct track
route-direct track命令用来配置直连路由与Track项关联。
undo route-direct track命令用来恢复缺省情况。
未配置直连路由与Track项关联。
在采用VRRP备份组作为用户网关的场景中,由于上行流量的路径取决于VRRP状态,而下行流量的路径一般由动态路由协议通过选路决定,因此可能出现上下行流量路径不一致的情况。当需要在主机上设置防火墙以提高安全性时,上下行路径不一致会导致流量被防火墙阻止;另外,在进行流量监控、流量统计等管理工作时,上下行流量路径不一致会增加不必要的难度和成本。为了解决该问题,可以通过Track项在VRRP备份组和直连路由之间建立关联,使设备根据VRRP状态来调整直连路由的开销值,然后配置动态路由协议引入直连路由,从而使VRRP状态影响动态路由协议的选路结果。具体的工作机制如下:
·     如果直连路由关联的Track项不存在,或者关联的Track项的状态为NotReady或Positive时,接口的直连路由的开销值为0,该路由被优选。
·     如果直连路由关联的Track项的状态为Negative时,该接口的直连路由的开销值为用户通过本功能设置的值,该路由不会被优选。
Track项的状态与VRRP备份组中设备状态的对应关系如下:
·     当设备为Backup或Initialize状态时,关联的Track项为Negative状态;当设备为Inactive状态或VRRP备份组不存在时,对应的Track项为NotReady状态。
不能通过重复执行本命令修改直连路由关联的Track项。如需修改直连路由关联的Track项,请先通过undo route-direct track命令取消直连路由关联的Track项,再执行route-direct track命令。
# 在接口Ten-GigabitEthernet3/1/1上配置直连路由与序号为1的Track项关联,并设置Track项状态变为Negative后直连路由的开销值为200。
[Sysname-Ten-GigabitEthernet3/1/1] route-direct track 1 degrade-cost 200
·     track vrrp(可靠性命令参考/Track)
1.1.50  routing-table limit
routing-table limit命令用来配置设备支持的最大IPv4/IPv6激活路由前缀数。
undo routing-table limit命令用来恢复缺省情况。
不限制设备支持的最大IPv4/IPv6激活路由前缀数。
RIB IPv4地址族视图
RIB IPv6地址族视图
number:设备支持的最大IPv4/IPv6激活路由前缀数目,取值范围为1~4294967295。
simply-alert:当设备的IPv4/IPv6激活路由前缀数超过最大支持的激活路由前缀数目时,可以继续激活新的路由前缀,但会产生一条日志信息。
RIB IPv4地址族视图下的配置用于控制公网和所有VPN实例内IPv4激活路由的总数。
RIB IPv6地址族视图下的配置用于控制公网和所有VPN实例内IPv6激活路由的总数。
# 配置当前设备上的RIB IPv4地址族视图下公网和所有VPN实例内IPv4激活路由的总数超过1000时,可以继续激活新的路由前缀,但是会产生一条日志信息。
[Sysname] rib
[Sysname-rib-ipv4] routing-table limit 1000 simply-alert
1.1.51  snmp-agent trap enable ipv6 rib
snmp-agent trap enable ipv6 rib命令用来开启IPv6 RIB的告警功能。
undo snmp-agent trap enable ipv6 rib命令用来关闭IPv6 RIB模块的告警功能。
IPv6 RIB的告警功能处于开启状态。
开启IPv6 RIB的告警功能后,IPv6 RIB会生成告警信息,用以报告本模块的重要事件。生成的告警信息将发送到SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 关闭IPv6 RIB的告警功能。
[Sysname] undo snmp-agent trap enable ipv6 rib
