14-网络管理和监控命令参考
02-NQA命令
本章节下载: 02-NQA命令  (1.25 MB)
02-NQA命令
1 NQA
1.1 NQA客户端配置命令
1.1.1 adjust-udp-checksum enable
1.1.2 adjust-udp-checksum global enable (TWAMP-light-client view)
1.1.3 advantage-factor
1.1.4 allowed-frame-loss
1.1.5 allowed-jitter
1.1.6 allowed-loss-ratio
1.1.7 allowed-transfer-delay
1.1.8 bandwidth
1.1.9 bind nqa-entry
1.1.10 cir-test enable
1.1.11 codec-type
1.1.12 color-aware-mode enable
1.1.13 community read
1.1.14 data-fill
1.1.15 data-size
1.1.16 description
1.1.17 destination host
1.1.18 destination ip
1.1.19 destination ipv6
1.1.20 destination mac
1.1.21 destination port
1.1.22 display nqa history
1.1.23 display nqa reaction counters
1.1.24 display nqa result
1.1.25 display nqa rfc2544 group
1.1.26 display nqa statistics
1.1.27 display nqa twamp-light client
1.1.28 display nqa twamp-light client statistics
1.1.29 display nqa twamp-light client test-session reaction counters
1.1.30 display nqa y1564 group
1.1.31 exchange-port enable
1.1.32 expect data
1.1.33 expect ip
1.1.34 expect ipv6
1.1.35 expect status
1.1.36 filename
1.1.37 frame-size
1.1.38 frequency
1.1.39 hex-data-fill
1.1.40 high-performance-mode
1.1.41 history-record enable
1.1.42 history-record keep-time
1.1.43 history-record number
1.1.44 icmp-jitter-mode
1.1.45 init-ttl
1.1.46 key
1.1.47 link-bundle-interface
1.1.48 lsr-path
1.1.49 mailbox
1.1.50 max-failure
1.1.51 mode
1.1.52 mpls-simulation enable
1.1.53 next-hop ip
1.1.54 next-hop ipv6
1.1.55 no-fragment enable
1.1.56 nqa
1.1.57 nqa agent enable
1.1.58 nqa report-ftp
1.1.59 nqa rfc2544 group
1.1.60 nqa schedule
1.1.61 nqa template
1.1.62 nqa twamp-light client
1.1.63 nqa twamp-light sender
1.1.64 nqa y1564 group
1.1.65 one-way delay-measure enable
1.1.66 one-way delay-measure global enable
1.1.67 operation (FTP operation view)
1.1.68 operation (HTTP/HTTPS operation view)
1.1.69 out interface
1.1.70 password
1.1.71 performance-test enable
1.1.72 pir-test enable
1.1.73 priority 8021p
1.1.74 probe count
1.1.75 probe duration
1.1.76 probe interval
1.1.77 probe packet-interval
1.1.78 probe packet-number
1.1.79 probe packet-timeout
1.1.80 probe timeout
1.1.81 raw-request
1.1.82 reaction checked-element { jitter-ds | jitter-sd }
1.1.83 reaction checked-element { owd-ds | owd-sd }
1.1.84 reaction checked-element icpif
1.1.85 reaction checked-element mos
1.1.86 reaction checked-element packet-loss
1.1.87 reaction checked-element probe-duration
1.1.88 reaction checked-element probe-fail (for trap)
1.1.89 reaction checked-element probe-fail (for trigger)
1.1.90 reaction checked-element rtt
1.1.91 reaction checked-element two-way-delay
1.1.92 reaction checked-element two-way-jitter
1.1.93 reaction checked-element two-way-loss
1.1.94 reaction trap
1.1.95 reaction trigger per-probe
1.1.96 reaction trigger probe-fail
1.1.97 reaction trigger probe-pass
1.1.98 reset nqa twamp-light statistics
1.1.99 resolve-target
1.1.100 resolve-type
1.1.101 route-option bypass-route
1.1.102 source interface (Frame-loss/Latency/Throughput/Y.1564 operation view and Client-session view)
1.1.103 source interface (ICMP-echo/UDP-tracert operation view)
1.1.104 source ip
1.1.105 source ipv6
1.1.106 source mac
1.1.107 source port
1.1.108 speed granularity
1.1.109 speed init
1.1.110 ssl-client-policy
1.1.111 start (Frame-loss/Latency/Throughput/Y.1564 operation view/Y.1564 group view/RFC2544 group view)
1.1.112 start (TWAMP-light-sender view)
1.1.113 statistics hold-time
1.1.114 statistics interval
1.1.115 statistics max-group
1.1.116 stop (Frame-loss/Latency/Throughput/Y.1564 operation view/Y.1564 group view/RFC2544 group view)
1.1.117 stop (TWAMP-light-sender view)
1.1.118 target-only
1.1.119 test-session (TWAMP-light-client view)
1.1.120 test-session bind interface
1.1.121 timestamp-format
1.1.122 tos
1.1.123 traffic-policing-test enable
1.1.124 ttl
1.1.125 type
1.1.126 url
1.1.127 username
1.1.128 version
1.1.129 vlan
1.1.130 vpn-instance
1.2 NQA服务器端命令
1.2.1 adjust-udp-checksum global enable (TWAMP-light-responder view)
1.2.2 display nqa reflector
1.2.3 display nqa server
1.2.4 display nqa twamp-light responder
1.2.5 nqa reflector
1.2.6 nqa server enable
1.2.7 nqa server icmp-server
1.2.8 nqa server tcp-connect
1.2.9 nqa server udp-echo
1.2.10 nqa twamp-light responder
1.2.11 test-session (TWAMP-light-responder view)
1.3 NQA TWAMP服务器端命令
1.3.1 client acl
1.3.2 control-session timeout
1.3.3 display nqa twamp server global-information
1.3.4 display nqa twamp server session
1.3.5 nqa twamp reflector
1.3.6 nqa twamp server
1.3.7 tcp port
1.3.8 test-session timeout
1 NQA
1.1  NQA客户端配置命令
adjust-udp-checksum enable命令用来开启测试报文中校验和字段调整功能。
undo adjust-udp-checksum enable命令用来关闭测试报文中校验和字段调整功能。
测试报文中校验和字段调整功能处于关闭状态。
TWAMP-light测试的Client-session视图
缺省情况下,TWAMP-light测试报文中校验和字段的值为0。配置本命令后,TWAMP-light会将实际计算的校验和值填入测试报文的校验和字段。不同TWAMP-light反射端对该字段取值的要求不同。如果设备连接的TWAMP-light反射端对该字段的取值有严格要求,请开启测试会话的校验和字段调整功能。
用户可以使用以下任意一种方式来开启测试会话的校验和字段调整功能:
·     全局开启该功能:该方式配置的测试报文校验和字段调整功能对TWAMP-light-client视图下所有未创建的会话生效,不会影响当前正在进行的测试会话。
·     测试会话视图下开启该功能:该方式配置的测试报文校验和字段调整功能仅对当前即将开始的会话生效。
本功能仅对IPv6测试报文生效,对于IPv4测试报文不生效。
# 开启测试报文中校验和字段调整功能。
[Sysname] nqa twamp-light client
[Sysname-nqa-twamp-light-client] test-session 1
[Sysname-nqa-twamp-light-client-session1] adjust-udp-checksum enable
·     adjust-udp-checksum global enable
adjust-udp-checksum global enable命令用来全局开启测试报文中校验和字段调整功能。
undo adjust-udp-checksum global enable命令用来全局关闭测试报文测试报文中校验和字段调整功能。
测试报文中校验和字段调整功能处于全局关闭状态。
# 开启全局调整测试报文校验和的值功能。
[Sysname-nqa-twamp-light-client] adjust-udp-checksum global enable
·     adjust-udp-checksum enable
advantage-factor命令用来配置用于计算MOS值和ICPIF值的补偿因子。
undo advantage-factor命令用来恢复缺省情况。
advantage-factor factor
补偿因子取值为0。
Voice测试类型视图
factor:用于计算MOS值和ICPIF值的补偿因子,取值范围为0~20。
用户对语音质量的评价具有一定的主观性,不同用户对语音质量的容忍程度不同,因此,衡量语音质量时,需要考虑用户的主观因素。对语音质量容忍程度较强的用户,可以通过advantage-factor命令配置补偿因子,在计算ICPIF值时将减去该补偿因子,修正ICPIF和MOS值,以便在比较语音质量时综合考虑客观和主观因素。
# 在Voice测试类型下配置计算MOS值和ICPIF值的补偿因子为10。
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] advantage-factor 10
allowed-frame-loss命令用来配置Y.1564测试可接受的丢包率上限。
undo allowed-frame-loss命令用来恢复缺省情况。
allowed-frame-loss count
未配置Y.1564测试可接受的丢包率上限。
Y.1564测试类型视图
count:每100000个包中设备可接受的丢包数,取值范围为0~100000。
若测试过程中报文丢包率超过配置的上限值,那么在测试完成后,NQA的测试结果显示为失败。
# 在Y.1564类型的NQA测试类型下配置Y.1564测试可接受的丢包率上限为1/1000,即100000个包中设备可接受的丢包数为100个。
[Sysname-nqa-admin-test] type y1564
[Sysname-nqa-admin-test-y1564] allowed-frame-loss 100
allowed-jitter命令用来配置可接受的时延抖动上限。
undo allowed-jitter命令用来恢复缺省情况。
allowed-jitter jitter
undo allowed-jitter
未配置可接受的时延抖动上限。
Y.1564测试类型视图
jitter:可接受的时延抖动上限,取值范围为1~10000000,单位为微秒。
若测试过程中报文的时延抖动超过配置的上限值,那么在测试完成后,NQA的测试结果显示为失败。
# 在Y.1564类型的NQA测试类型下配置可接受的时延抖动上限为10000微秒。
[Sysname-nqa-admin-test-y1564] allowed-jitter 10000
allowed-loss-ratio命令用来配置可接受的丢包率上限。
undo allowed-loss-ratio命令用来恢复缺省情况。
allowed-loss-ratio ratio
可接受的丢包率上限为1/10000。
Throughput测试类型视图
ratio:可接受的丢包率上限,取值为1/10000或1/1000000000。
# 在Throughput测试类型下配置可接受的丢包率上限为1/1000000000。
[Sysname-nqa-admin-test] type throughput
[Sysname-nqa-admin-test-throughput] allowed-loss-ratio 1/1000000000
allowed-transfer-delay命令用来配置可接受的时延上限。
undo allowed-transfer-delay命令用来恢复缺省情况。
allowed-transfer-delay delay
未配置可接受的时延上限。
Y.1564测试类型视图
delay:可接受的时延上限,取值范围为1~10000000,单位为微秒。
若测试过程中报文的时延超过配置的上限值,那么在测试完成后,NQA的测试结果显示为失败。
# 在Y.1564类型的NQA测试类型下配置可接受的时延上限为10000微秒。
[Sysname-nqa-admin-test-y1564] allowed-transfer-delay 10000
1.1.8  bandwidth
bandwidth命令用来配置测试时的承诺信息速率与峰值速率。
undo bandwidth命令用来恢复缺省情况。
bandwidth cir cir-value [ pir pir-value ]
undo bandwidth
未配置测试时的承诺信息速率与峰值速率。
Y.1564测试类型视图
cir-value:承诺信息速率(CIR:Committed Information Rate),单位为kbps。取值范围为8~32000000。
pir-value:峰值速率(PIR:Peak Information Rate),单位为kbps。取值范围为8~32000000。不配置该参数时,表示不测试峰值速率。
对于CIR测试,可能因测试步数和配置的探测报文长度的关系导致单位时间内发送探测报文的数量小于1,而导致系统无法启动测试,故配置的承诺信息速率、发包长度以及CIR测试的步数需要满足公式:(CIR*1000)/(Frame-size+20)/Step>1(CIR为承诺信息速率,Frame-size为frame-size配置探测报文的长度,Step为CIR测试的步数)。
# 在Y.1564类型的NQA测试类型下配置承诺信息速率为2000kbps,峰值速率为3000kbps。
[Sysname-nqa-admin-test-y1564] bandwidth cir 2000 pir 3000
bind nqa-entry命令用来将NQA操作组和测试组关联。
undo bind nqa-entry命令用来取消NQA操作组与测试组的关联。
bind nqa-entry admin-name operation-tag
undo bind nqa-entry admin-name operation-tag
NQA操作组下没有关联任何测试组。
Y.1564操作组视图
RFC2544操作组视图
admin-name:创建NQA测试组的管理员名称,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
operation-tag:测试操作的标签,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
如果NQA操作组中的测试正在进行,则不能建立或取消该NQA操作组与测试组的关联。
# 将一个管理员名为admin,测试操作标签为test的Y.1564测试组与名为test的NQA Y.1564操作组关联。
[Sysname] nqa y1564 group test
[Sysname-nqa-y1564group-test] bind nqa-entry admin test
·     nqa y1564 group
·     nqa rfc2544 group
cir-test enable命令用来开启CIR测试。
undo cir-test enable命令用来关闭CIR测试。
cir-test enable [ step-count count ] [ step-duration duration ]
CIR测试处于开启状态。
Y.1564测试类型视图
step-count count:CIR测试的执行步数。取值范围为1~1000,缺省值为1。
step-duration duration:CIR测试中一步测试的持续时间。取值范围为1~60,单位为秒,缺省值为3秒。
配置本命令后,进行Y.1564测试时将开启CIR测试,根据step-count参数配置的执行步数以及bandwidth命令配置的承诺信息速率开始测试。当执行步数为1步时,表示直接以承诺信息速率发送报文进行测试;当执行步数不为1步时,表示以每次递增一个平均速率(平均速率=承诺信息速率/执行步数)的方式发送报文,直到发送速率达到承诺信息速率。
对于CIR测试,可能因测试步数和配置的探测报文长度的关系导致单位时间内发送探测报文的数量小于1,而导致系统无法启动测试,故配置的承诺信息速率、CIR测试的步数以及发包长度需要满足公式:(CIR*1000)/(Frame-size+20)/Step>1(CIR为承诺信息速率,Frame-size为frame-size配置探测报文的长度,Step为CIR测试的步数)。
# 在Y.1564类型的NQA测试类型下开启CIR测试。
[Sysname-nqa-admin-test-y1564] cir-test enable
·     bandwidth
1.1.11  codec-type
codec-type命令用来配置语音测试的编码格式。
undo codec-type命令用来恢复缺省情况。
codec-type { g711a | g711u | g729a }
undo codec-type
语音编码格式为G.711 A律。
Voice测试类型视图
g711a:G.711 A律语音编码格式。
g711u:G.711 µ律语音编码格式。
g729a:G.729 A律语音编码格式。
# 在Voice测试类型下配置语音测试的编码格式为G.729 A律。
[Sysname-nqa-admin-test-voice] codec-type g729a
color-aware-mode enable命令用来开启颜色标记模式。
undo color-aware-mode enable命令用来关闭颜色标记模式。
color-aware-mode enable [ { 8021p | dscp } green value1 [ to value2 ] yellow value1 [ to value2 ] ]
颜色标记模式处于关闭状态。
Y.1564测试类型视图
8021p:表示根据帧的802.1p优先级进行着色。在二层组网环境中,必须指定802.1p优先级。
dscp:表示根据帧的DSCP优先级进行着色。在三层组网环境中,必须指定DSCP优先级。
green:表示将指定优先级的帧标识为绿色。
yellow:表示将指定优先级的帧标识为黄色。
value1 to value2:帧优先级。其中value表示帧优先级,802.1p优先级时取值范围为0~7;DSCP优先级时取值范围为0~63。to表示帧优先级的范围,value2的值要大于value1的值。如果是MPLS标签转发,设备会自动把802.1p优先级或DSCP优先级转换成EXP值,请确保802.1p优先级和DSCP优先级转在换成EXP值后不存在重叠。
为了测试在二层网络环境中、业务流量拥塞的情况下,带有颜色标记以及每种颜色不同优先级的业务流量在路径上可获得的服务质量,可通过本命令模拟构造指定颜色以及指定优先级的报文,来测试服务质量。
本命令仅对PIR和Traffic policing测试生效。关闭颜色标记模式状态下,设备以固定速率为PIR和Traffic policing测试发送探测报文。开启颜色标记模式后,设备将根据优先级以不同的发送速率为PIR和Traffic policing测试发送探测报文。
有关802.1p或DSCP优先级与带颜色报文的映射的详细介绍,请参见“ACL和QoS配置指导”中的“QoS”。
# 在Y.1564类型的NQA测试类型下开启颜色标记模式。
[Sysname-nqa-admin-test-y1564] color-aware-mode enable 8021p green 1 to 4 yellow 5
·     priority 8021p
community read命令用来配置用于SNMP测试使用的团体名。
undo community read命令用来恢复缺省情况。
community read { cipher | simple } community-name
undo community read
SNMP测试使用的团体名为public。
SNMP测试类型视图
SNMP类型的模板视图
cipher:以密文方式配置团体名。
simple:以明文方式配置团体名,该密码将以密文形式存储。
community-name:测试使用的团体名,区分大小写。当以明文形式配置时,团体名为1~32个字符的字符串;当以密文形式配置时,团体名为33~73个字符的字符串。
当被测试的SNMP Agent的版本为SNMPv1或者SNMPv2c时,若SNMP Agent配置了团体名,则SNMP测试组必须配置本命令,且配置的团体名必须与SNMP Agent上已配置的只读或读写权限团体名保持一致,才能通过SNMP Agent的认证,并进行探测。当SNMP Agent的版本为SNMPv3时,由于SNMPv3没有团体名概念,不需要配置团体名,直接进行探测。有关团体名及SNMP认证的具体介绍请参见“网络管理和监控”中的“SNMP”。
# 配置SNMP探测报文使用的团体名称为readaccess。
[Sysname-nqa-admin-test] type snmp
[Sysname-nqa-admin-test-snmp] community read simple readaccess
1.1.14  data-fill
data-fill命令用来配置探测报文的填充字符串。
undo data-fill命令用来恢复缺省情况。
data-fill string
undo data-fill
探测报文的填充内容为十六进制数值00010203040506070809。
ICMP-echo/UDP-echo测试类型视图
Path-jitter/UDP-jitter/Voice/ICMP-jitter测试类型视图
ICMP/TCP/UDP类型的NQA模板视图
string:探测报文的填充内容,为1~200个字符的字符串,区分大小写。
如果探测报文的数据段长度比配置的填充数据长度小,系统在报文封装时以报文的数据段长度为界截取该字符串的前一部分;
如果探测报文的数据段长度比配置的填充数据长度大,系统在报文封装时用该字符串进行循环填充,直到填满。
例如,配置填充数据为“abcd”,当探测报文数据段长度为3字节时,则取“abc”作为填充数据;当探测报文大小为6字节时,则使用“adcdab”作为填充数据。
对于不同的测试类型 ,填充字符串的情况有所不同:
·     在ICMP-echo测试中,配置的字符串用来填充ICMP Echo消息的数据字段。
·     在UDP-echo测试中,由于UDP报文数据字段的前5个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。
·     在UDP-jitter测试中,UDP报文数据字段的前68个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。
·     在Voice测试中,UDP报文数据字段的前16个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。
·     在Path-jitter测试中,由于ICMP探测阶段ICMP报文数据字段的前4个字节具有特定用途,所以只用所配置的字符串填充ICMP报文中剩余的字节。
·     在ICMP-jitter测试中,由于ICMP报文数据字段的前20个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。另外,ICMP-jitter测试的icmp-timestamp模式下不支持配置该命令。
本命令与hex-data-fill命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP-echo测试类型下配置探测报文的填充字符串为abcd。
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] data-fill abcd
# 在TCP类型的NQA模板视图下配置探测报文的填充字符串为abcd。
[Sysname] nqa template tcp tcptplt
[Sysname-nqatplt-tcp-tcptplt] data-fill abcd
·     hex-data-fill
1.1.15  data-size
data-size命令用来配置探测报文中的填充内容的大小。
undo data-size命令用来恢复缺省情况。
data-size size
undo data-size
缺省情况如表1-1所示。
表1-1 探测报文中的填充内容大小的缺省值
测试类型
编码类型
缺省值(字节)
ICMP-echo
100
ICMP-jitter
20
UDP-echo
100
UDP-jitter
100
UDP-tracert
100
Path-jitter
100
Voice
G.711 A律
172
Voice
G.711 µ律
172
Voice
G.729 A律
32
TWAMP-light
142
UDP-tracert测试类型视图
ICMP/UDP类型的NQA模板视图
·     NQA测试类型探测的目的地址为IPv4地址:
¡     ICMP-echo、ICMP-jitter、UDP-echo和UDP-tracert测试类型:20~65507。
¡     UDP-jitter和Path-jitter测试类型:68~65507。
¡     Voice测试类型:16~65507。
·     NQA测试类型探测的目的地址为IPv6地址:
¡     UDP-echo测试类型:20~65503。
¡     UDP-jitter测试类型:68~65503。
¡     ICMP-echo、ICMP-jitter和UDP-tracert测试类型:20~65487。
¡     Path-jitter测试类型:68~65487。
¡     Voice测试类型:16~65487。
·     NQA TWAMP-light测试:44~1518。
UDP-jitter和TWAMP-light测试的探测报文中填充内容的大小不能大于测试链路上所有接口的MTU值。
UDP-jitter高性能测试支持的IPv4探测报文的填充内容的大小为68~9500字节,IPv6探测报文的填充内容的大小为68~9000字节。
# 在ICMP-echo测试类型下配置探测报文中的填充内容的大小为80字节。
[Sysname-nqa-admin-test-icmp-echo] data-size 80
# 在ICMP类型的NQA模板视图下配置ICMP-echo探测报文中的填充内容的大小为80字节。
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] data-size 80
1.1.16  description
description命令用来配置测试组的描述信息,通常用于描述一个测试组的测试类型或测试目的。undo description命令用来恢复缺省情况。
未配置描述信息。
任意测试类型视图
任意类型的NQA模板视图
text:测试组的描述,为1~200个字符的字符串,区分大小写。
# 在ICMP-echo测试类型下配置测试组的描述信息为icmp-probe。
[Sysname-nqa-admin-test-icmp-echo] description icmp-probe
# 在ICMP类型的NQA模板视图下配置描述信息为icmp-probe。
[Sysname-nqatplt-icmp-icmptplt] description icmp-probe
destination host命令用来配置探测报文的目的主机名。
undo destination host命令用来恢复缺省情况。
destination host host-name
未配置探测报文的目的主机名。
UDP-tracert测试类型视图
host-name:探测报文的目的主机名,为1~254个字符的字符串,区分大小写,字符串中可以包含字母、数字、“-”、“_”和“.”,不能出现连续的“.”。如果目的主机名由“.”分隔成多个段,则每段不能超过63个字符。
如果要配置探测报文的目的IP地址,请使用destination ip或destination ipv6命令。
# 在UDP-Tracert测试类型下配置探测报文的目的主机名为www.test.com。
[Sysname-nqa-admin-test] type udp-tracert
[Sysname-nqa-admin-test-udp-tracert] destination host www.test.com
destination ip命令用来配置探测报文的目的IPv4地址。
undo destination ip命令用来恢复缺省情况。
Y.1564测试类型:
destination ip ipv4-address1 [ to ipv4-address2 ]
undo destination ip
其他测试类型:
undo destination ip
未配置探测报文的目的IPv4地址。
ICMP-echo/TCP/UDP-echo测试类型视图
DHCP/DLSw/DNS/SNMP测试类型视图
UDP-tracert测试类型视图
ICMP-jitter/Path-jitter/UDP-jitter/Voice测试类型视图
Frame-loss/Latency/Throughput/Y.1564测试类型视图
ARP/DNS/ICMP/IMAP/POP3/RADIUS/SMTP/SNMP/SSL/TCP/TCP Half Open/UDP类型的NQA模板视图
ipv4-address:探测报文的目的IPv4地址。
ipv4-address1 to ipv4-address2:指定探测报文的目的IPv4地址的范围。ipv4-address2的值要大于ipv4-address1的值,两个地址之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。
对于路径服务质量测和Y.1564探测类型,请按照以下要求配置源地址和目的地址,否则,会导致NQA测试启动失败:
·     二/三层以太网和二/三层VPN环境下必须配置源地址和目的地址。
·     其他组网环境下,源地址和目的地址要么均配置要么均不配置,如果配置,要求均为IPv4类型或者均为IPv6类型。
# 在ICMP-echo测试类型下配置探测报文的目的IPv4地址为10.1.1.2。
[Sysname-nqa-admin-test-icmp-echo] destination ip 10.1.1.2
# 在ICMP类型的NQA模板视图下配置探测报文的目的IPv4地址为10.1.1.2。
[Sysname-nqatplt-icmp-icmptplt] destination ip 10.1.1.2
# 在TWAMP-light测试的Client-session视图下配置探测报文的目的IPv4地址为10.1.1.2。
[Sysname-nqa-twamp-light-client-session1] destination ip 10.1.1.2
destination ipv6命令用来配置探测报文的目的IPv6地址。
undo destination ipv6命令用来恢复缺省情况。
Y.1564测试类型:
destination ipv6 ipv6-address1 [ to ipv6-address2 ]
其他测试类型:
未配置探测报文的目的IPv6地址。
UDP-jitter测试类型视图
ICMP-jitter/DLSw/DNS/SNMP/UDP-tracert/Path-jitter/Voice测试类型视图
ipv6-address:探测报文的目的IPv6地址,不支持IPv6链路本地地址。
ipv6-address1 to ipv6-address2:指定探测报文的目的IPv6地址的范围。ipv6-address2的值要大于ipv6-address1的值,两个地址之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。
UDP-jitter测试的MPLS模拟测试功能暂不支持使用IPv6地址作为探测报文的目的地址。
对于路径服务质量测试和Y.1564测试,请按照以下要求配置源地址和目的地址,否则,会导致NQA测试启动失败:
# 在ICMP类型的NQA模板视图下配置探测报文的目的IPv6地址为1::2。
[Sysname-nqatplt-icmp-icmptplt] destination ipv6 1::2
# 在TWAMP-light测试的Client-session视图下配置探测报文的目的IPv6地址为1::2。
[Sysname-nqa-twamp-light-client-session1] destination ipv6 1::2
destination mac命令配置探测报文的目的MAC地址。
undo destination mac命令用来恢复缺省情况。
Frame-loss/Latency/Throughput测试类型和TWAMP-light测试:
destination mac mac-address
Y.1564测试类型:
destination mac mac-address1 [ to mac-address2 ]
对于Frame-loss/Latency/Throughput/Y.1564测试类型,探测报文的目的MAC地址为0023-8900-0001。
对于TWAMP-light测试,未配置探测报文的目的MAC地址。
mac-address:探测报文的目的MAC地址,格式为H-H-H。在配置时,可以省去MAC地址中每段开头的“0”,例如:输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
mac-address1 to mac-address2:指定探测报文的目的MAC地址的范围。mac-address2的值要大于mac-address1的值。两个地址之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。
# 在Throughput测试类型视图下配置探测报文的目的MAC地址为0001-0001-0002。
[Sysname-nqa-admin-test-throughput] destination mac 1-1-2
# 在TWAMP-light测试的Client-session视图下配置探测报文的目的MAC地址为0001-0001-0002。
[Sysname-nqa-twamp-light-client-session1] destination mac 1-1-2
destination port命令用来配置探测报文的目的端口号。
undo destination port命令用来恢复缺省情况。
Y.1564测试类型:
destination port port-number1 [ to port-number2 ]
其他测试类型:
对于UDP-tracert测试,目的端口号缺省为33434;对于Frame-loss/Latency/Throughput测试,目的端口号缺省为7;对于SNMP测试,目的端口号缺省为161;对于其他类型测试,未配置测试操作的目的端口号。
对于NQA模板,缺省目的端口号分别为:DNS(53)、IMAP(143)、POP3(110)、RADIUS(1812)、SMTP(25)、SNMP(161)、其他类型模板未配置测试操作的目的端口号。
TCP/UDP-echo/SNMP测试类型视图
UDP-tracert测试类型视图
DNS/IMAP/POP3/RADIUS/SMTP/SNMP/SSL/TCP/UDP类型的NQA模板视图
port-number:探测报文的目的端口号,取值范围为1~65535。
port-number1 to port-number2:表示探测报文的目的端口号的范围。port-number2的值要大于port-number1的值,两个端口号之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。
# 在UDP-echo测试类型视图下配置测试操作的目的端口号为9000。
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] destination port 9000
# 在TCP类型的NQA模板视图下配置测试操作的目的端口号为9000。
[Sysname-nqatplt-tcp-tcptplt] destination port 9000
# 在TWAMP-light测试的Client-session视图下配置探测报文的目的端口号为9000。
[Sysname-nqa-twamp-light-client-session1] destination port 9000
display nqa history命令用来显示NQA测试组的历史记录。
display nqa history [ admin-name operation-tag ]
display nqa history命令的显示信息无法反映Frame-loss、ICMP-jitter、Latency、Path-jitter、Throughput、UDP-jitter和Voice测试的结果。如果想了解ICMP-jitter、Path-jitter、UDP-jitter和Voice测试的结果,建议通过display nqa result命令查看最近一次NQA测试的结果,或通过display nqa statistics命令查看NQA测试的统计信息;如果想了解Frame-loss、Latency和Throughput测试的结果,建议通过display nqa result命令查看最近一次NQA测试的结果。
不指定任何参数,则表示显示所有测试组的历史记录。
# 显示管理员名称为administrator、测试类型标签为tracert的UDP-tracert测试项的历史记录。
<Sysname> display nqa history administrator tracert
NQA entry (admin administrator, tag tracert) history records:
Index      TTL  Response  Hop IP          Status          Time
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:06.2
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:05.2
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:04.2
1          1    328       3.1.1.2         Succeeded       2013-09-09 14:46:03.2
1          1    328       3.1.1.1         Succeeded       2013-09-09 14:46:02.2
1          1    328       3.1.1.1         Succeeded       2013-09-09 14:46:01.2
# 查看管理员名称为administrator、测试操作标签为test的NQA测试组的历史记录。
<Sysname> display nqa history administrator test
NQA entry (admin administrator, tag test) history records:
  Index      Response     Status           Time
  10         329          Succeeded        2011-04-29 20:54:26.5
  9          344          Succeeded        2011-04-29 20:54:26.2
  8          328          Succeeded        2011-04-29 20:54:25.8
  7          328          Succeeded        2011-04-29 20:54:25.5
  6          328          Succeeded        2011-04-29 20:54:25.1
  5          328          Succeeded        2011-04-29 20:54:24.8
  4          328          Succeeded        2011-04-29 20:54:24.5
  3          328          Succeeded        2011-04-29 20:54:24.1
  2          328          Succeeded        2011-04-29 20:54:23.8
  1          328          Succeeded        2011-04-29 20:54:23.4
表1-2 display nqa history命令显示信息描述表
Index
历史记录的编号,一次UDP-tracert测试中的所有记录此编号一致
TTL
本次探测发送的探测报文的TTL值。如果设备配置了路由旁路功能,则TTL显示值与init-ttl命令配置相关,实际发送的TTL值固定为1
Response
测试成功时,为探测报文的往返时延;如果测试超时,则为超时时间;不能完成测试时,则为0。单位为毫秒
Hop IP
回复应答的节点IP地址
Status
测试结果的状态值,具体如下:
·     Succeeded:测试成功,接收到响应报文
·     Unknown error:未知错误导致NQA测试失败(如果配置了NQA与Track联动,则该状态会触发Track状态切换)
·     Internal error:内部错误导致NQA测试失败(如果配置了NQA与Track联动,则该状态不会触发Track状态切换)
·     Timeout:请求超时导致NQA测试失败(如果配置了NQA与Track联动,则该状态会触发Track状态切换)
Time
测试完成时间
display nqa reaction counters命令用来显示阈值告警组的当前监测结果。
display nqa reaction counters [ admin-name operation-tag [ item-number ] ]
item-number:显示指定阈值告警组的当前监测结果。如果不指定该参数,将显示所有阈值告警组的当前监测结果。item-number为阈值告警组的编号,取值范围为1~10。
如果NQA阈值告警组的阈值类型为平均值,或监测对象为Voice测试的ICPIF或MOS值,则显示的监测结果为无效值。
测试结束后,不会清除监测结果,即测试组启动后,监测结果会不断累加。
不指定任何参数,则表示显示所有测试组中所有阈值告警组的当前监测结果。
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ICMP-echo测试组的所有阈值告警组的当前监测结果。
<Sysname> display nqa reaction counters admin test
NQA entry (admin admin, tag test) reaction counters:
  Index  Checked Element  Threshold Type  Checked Num  Over-threshold Num
  1      probe-duration   accumulate      12           4
  2      probe-duration   average         -            -
  3      probe-duration   consecutive     160          56
  4      probe-fail       accumulate      12           0
  5      probe-fail       consecutive     162          2
表1-3 display nqa reaction counters命令显示信息描述
Index
阈值告警组的编号
Checked Element
监测的对象(不同的NQA测试类型支持的监测对象不同,具体请参见表1-4、表1-5)
Threshold Type
阈值类型
Checked Num
已监测的样本个数
Over-threshold Num
超出阈值的样本个数
表1-4 display nqa reaction counters命令显示字段取值描述(DHCP/DLSw/DNS/FTP/HTTP/ICMP-echo/SNMP/TCP/UDP-echo测试类型)
监测对象
阈值类型
监测的样本范围
Checked Num取值
Over-threshold Num取值
probe-duration
accumulate
启动NQA测试组后进行的探测
启动NQA测试组后已完成的探测次数
启动NQA测试组后累计的探测持续时间不在阈值范围内的探测次数
average
consecutive
启动NQA测试组后进行的探测
启动NQA测试组后已完成的探测次数
启动NQA测试组后连续的探测持续时间不在阈值范围内的探测次数
probe-fail
accumulate
启动NQA测试组后进行的探测
启动NQA测试组后已完成的探测次数
启动NQA测试组后累计的探测失败次数
consecutive
启动NQA测试组后进行的探测
启动NQA测试组后已完成的探测次数
启动NQA测试组后连续的探测失败次数
表1-5 display nqa reaction counters命令显示字段取值描述(ICMP-jitter/UDP-jitter/Voice测试类型)
监测对象
阈值类型
监测的样本范围
Checked Num取值
RTT
accumulate
启动NQA测试组后发送的报文
启动NQA测试组后已发送的报文个数
启动NQA测试组后累计的往返时间不在阈值范围内的报文个数
average
jitter-DS/jitter-SD
accumulate
启动NQA测试组后发送的报文
启动NQA测试组后已发送的报文个数
启动NQA测试组后累计的单向抖动时间不在阈值范围内的报文个数
average
OWD-DS/OWD-SD
启动NQA测试组后发送的报文
启动NQA测试组后已发送的报文个数
启动NQA测试组后单向时延不在阈值范围内的报文个数
packet-loss
accumulate
启动NQA测试组后发送的报文
启动NQA测试组后已发送的报文个数
启动NQA测试组后累计的丢包数
ICPIF/MOS(仅Voice测试支持)
display nqa result命令用来显示最近一次NQA测试的结果。
display nqa result [ admin-name operation-tag ]
operation-tag:为测试操作的标签,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
不指定任何参数,则表示显示所有测试组的最近一次测试的结果。
# 显示NQA测试组管理员名称为admin、测试操作标签为test的TCP测试的最近一次测试结果。
<Sysname> display nqa result admin test
NQA entry (admin admin, tag test) test results:
    Send operation times: 1              Receive response times: 1
    Min/Max/Average round trip time: 35/35/35
    Square-Sum of round trip time: 1225
    Last succeeded probe time: 2011-05-29 10:50:33.2
  Extended results:
    Packet loss ratio: 0%
    Failures due to timeout: 0
    Failures due to disconnect: 0
    Failures due to no connection: 0
    Failures due to internal error: 0
    Failures due to other errors: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ICMP-jitter测试的最近一次测试结果。
    Send operation times: 10             Receive response times: 10
    Min/Max/Average round trip time: 1/2/1
    Square-Sum of round trip time: 13
    Last packet received time: 2015-03-09 17:40:29.8
  Extended results:
    Packets out of sequence: 0
    Packets arrived late: 0
  ICMP-jitter results:
   RTT number: 10
    Min positive SD: 0                     Min positive DS: 0
    Max positive SD: 0                     Max positive DS: 0
    Positive SD number: 0                  Positive DS number: 0
    Positive SD sum: 0                     Positive DS sum: 0
    Positive SD average: 0                 Positive DS average: 0
    Positive SD square-sum: 0              Positive DS square-sum: 0
    Min negative SD: 1                     Min negative DS: 2
    Max negative SD: 1                     Max negative DS: 2
    Negative SD number: 1                  Negative DS number: 1
    Negative SD sum: 1                     Negative DS sum: 2
    Negative SD average: 1                 Negative DS average: 2
    Negative SD square-sum: 1              Negative DS square-sum: 4
    SD average: 1                          DS average: 2
  One way results:
    Max SD delay: 1                        Max DS delay: 2
    Min SD delay: 1                        Min DS delay: 2
    Number of SD delay: 1                  Number of DS delay: 1
    Sum of SD delay: 1                     Sum of DS delay: 2
    Square-Sum of SD delay: 1              Square-Sum of DS delay: 4
    Lost packets for unknown reason: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的UDP-jitter测试的最近一次测试结果。
    Min/Max/Average round trip time: 15/46/26
    Square-Sum of round trip time: 8103
    Last packet received time: 2011-05-29 10:56:38.7
  Extended results:
  UDP-jitter results:
   RTT number: 10
    Min positive SD: 8                     Min positive DS: 8
    Max positive SD: 18                    Max positive DS: 8
    Positive SD number: 5                  Positive DS number: 2
    Positive SD sum: 75                    Positive DS sum: 32
    Positive SD average: 15                Positive DS average: 16
    Positive SD square-sum: 1189           Positive DS square-sum: 640
    Min negative SD: 8                     Min negative DS: 1
    Max negative SD: 24                    Max negative DS: 30
    Negative SD number: 4                  Negative DS number: 7
    Negative SD sum: 56                    Negative DS sum: 99
    Negative SD average: 14                Negative DS average: 14
    Negative SD square-sum: 946            Negative DS square-sum: 1495
    SD average: 14                         DS average: 14
  One way results:
    Max SD delay: 22                       Max DS delay: 23
    Min SD delay: 7                        Min DS delay: 7
    Number of SD delay: 10                 Number of DS delay: 10
    Sum of SD delay: 125                   Sum of DS delay: 132
    Square-Sum of SD delay: 1805           Square-Sum of DS delay: 1988
    SD lost packets: 0                     DS lost packets: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Voice测试的最近一次测试结果。
    Send operation times: 1000           Receive response times: 0
    Min/Max/Average round trip time: 0/0/0
    Square-Sum of round trip time: 0
    Last packet received time: 0-00-00 00:00:00.0
  Extended results:
    Packet loss ratio: 100%
    Failures due to timeout: 1000
  Voice results:
   RTT number: 0
    Min negative SD: 0                     Min negative DS: 0
    Max negative SD: 0                     Max negative DS: 0
    Negative SD number: 0                  Negative DS number: 0
    Negative SD sum: 0                     Negative DS sum: 0
    Negative SD average: 0                 Negative DS average: 0
    Negative SD square-sum: 0              Negative DS square-sum: 0
    SD average: 0                          DS average: 0
  One way results:
    Max SD delay: 0                        Max DS delay: 0
    Min SD delay: 0                        Min DS delay: 0
    Number of SD delay: 0                  Number of DS delay: 0
    Sum of SD delay: 0                     Sum of DS delay: 0
    Square-Sum of SD delay: 0              Square-Sum of DS delay: 0
    Lost packets for unknown reason: 1000
  Voice scores:
    MOS value: 0.99                        ICPIF value: 87
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Path-jitter测试的最近一次测试结果。
  Hop IP 192.168.40.210
    Basic Results:
      Min/Max/Average round trip time: 1/1/1
      Square-Sum of round trip time: 10
    Extended Results:
    Path-Jitter Results:
      Jitter number: 9
        Min/Max/Average jitter: 0/0/0
      Positive jitter number: 0
        Min/Max/Average positive jitter: 0/0/0
        Sum/Square-Sum positive jitter: 0/0
      Negative jitter number: 0
        Min/Max/Average negative jitter: 0/0/0
        Sum/Square-Sum negative jitter: 0/0
  Hop IP 192.168.50.209
    Basic Results:
    Extended Results:
      Jitter number: 9
# 显示NQA测试组管理员名称为admin、测试操作标签为test的UDP-tracert测试的最近一次测试结果。
    Send operation times: 6              Receive response times: 6
    Last succeeded probe time: 2013-09-09 14:23:24.5
  Extended results:
  UDP-tracert results:
    TTL    Hop IP             Time
    1      3.1.1.1            2013-09-09 14:23:24.5
    2      4.1.1.1            2013-09-09 14:23:24.5
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Y.1564测试的最近一次测试结果。
  Status                : Succeeded
  Last test             : Service performance test
  Estimated total time  : 6
  Actual test time used : 6
  Detailed test results:
    CIR test (with the step of 1):
      Start time               : 2016-11-15 21:00:02.1
      End time                 : 2016-11-15 21:00:14.3
      Status                   : Succeeded
      Min/Max/Average IR(kbps) : 996/1003/1000
      Min/Max/Average FTD(us)  : 67/78/69
      Min/Max/Average FDV(us)  : 0/10/1
      FL count/FLR             : 0/0.000%
      Packets out of order     : 0
      Severely Err Secs/AVAIL  : 0/100.000%
    PIR test (color green):
      Start time               : 2016-11-15 21:00:22.3
      End time                 : 2016-11-15 21:00:34.5
      Status                   : Succeeded
      Min/Max/Average IR(kbps) : 997/1005/1000
      Min/Max/Average FTD(us)  : 68/69/68
      Min/Max/Average FDV (us)  : 35/39/37
      FL count/FLR              : 2/0.002%
    PIR test (color yellow):
      Start time               : 2016-11-15 21:00:22.5
      End time                 : 2016-11-15 21:00:34.7
      Status                   : --
      Min/Max/Average IR(kbps) : 496/503/499
      Min/Max/Average FTD(us)  : 67/69/68
      Min/Max/Average FDV (us)  : 40/45/42
    PIR test (total):
      Status                   : --
      Min/Max/Average IR(kbps) : 1493/1508/1499
      Min/Max/Average FDV (us)  : 35/45/40
      Severely Err Secs/AVAIL  : 0/--
    Traffic policing test (color green)
      Start time               : 2016-11-15 21:00:42.7
      End time                 : 2016-11-15 21:00:54.9
      Status                   : Succeeded
      Min/Max/Average FDV (us)  : 94/98/96
      FL count/FLR              : 4/0.004%
    Traffic policing test (color yellow):
      Start time               : 2016-11-15 21:00:42.1
      End time                 : 2016-11-15 21:00:54.3
      Status                   : --
      Min/Max/Average IR(kbps) : 622/627/624
      Min/Max/Average FDV (us)  : 58/62/60
      FL count/FLR              : 10/0.01%
    Traffic policing test (total):
      Start time               : 2016-11-15 21:00:42.5
      End time                 : 2016-11-15 21:00:54.7
      Status                   : --
      Min/Max/Average IR(kbps) : 1619/1632/1624
    Service performance test:
      Start time               : 2016-11-15 21:16:06.7
      End time                 : 2016-11-15 21:17:07.9
      Status                   : Succeeded
      Min/Max/Average IR(kbps) : 996/1003/999
      Min/Max/Average FDV (us)  : 47/51/49
# 显示Throughput类型的NQA测试组(管理员为admin,操作标签为test)的最近一次测试结果。
  Basic results     :
    Initial speed(Kbps)    : 100000
    Speed granularity(Kbps): 1000
    Probe duration(s)      : 60
    Probe interval(s)      : 4
    Allowed-loss-ratio     : 1/10000
  Throughput results:
    Frame size(Byte): 64
      Current speed(Kbps): -
      Frame-loss(Loss/Tx): -
      Status             : Failed
      Time               : 2022-01-01 07:20:40.8
    Frame size(Byte): 512
      Current speed(Kbps): 4000
      Frame-loss(Loss/Tx): 0/10000
      Status             : Succeeded
      Time               : 2022-01-01 07:21:40.8
    Frame size(Byte): 1024
      Current speed(Kbps): 8000
      Status             : Succeeded
      Time               : 2022-01-01 07:22:52.8
    Frame size(Byte): 1280
      Current speed(Kbps): 10000
      Status             : Succeeded
      Time               : 2022-01-01 07:23:45.8
    Frame size(Byte): 1518
      Status             : Succeeded
      Time               : 2022-01-01 07:24:45.8
表1-6 display nqa result命令显示信息描述
NQA(测试操作的标签,测试操作的标签)测试组的测试结果
Data collecting in progress
测试正在进行中
Path jitter result is not available
测试没有生成结果
发送的探测报文数
收到的响应报文数
最小/最大/平均往返时间,单位为毫秒
往返时间平方和
一次测试中最后一次成功探测的完成时间,如果一次测试中的探测均失败,则该时间显示为全0,UDP-jitter、Path-jitter和Voice测试中无此信息
一次探测中最后一次成功收到正确响应报文的时间,如果一次探测中没有收到过正确的响应报文,则该时间显示为全0,只在UDP-jitter和Voice测试中存在此信息
Extended results
扩展项的测试结果
Packet loss ratio
平均丢包率
测试过程中超时的次数
对方强制断开连接的次数
和对方建立连接失败的次数
因内部错误失败的次数
因其它错误失败的次数
报文失序的次数
ICMP-jitter results
ICMP-jitter测试的结果,只在ICMP-jitter测试中存在此信息
探测超时后,收到的响应报文个数
UDP-jitter results
UDP-jitter测试的结果,只在UDP-jitter测试中存在此信息
Voice results
Voice测试的结果,只在Voice测试中存在此信息
RTT number
收到的响应报文数
Min positive SD
源到目的方向正抖动时延的最小值,单位为毫秒
Min positive DS
目的到源方向正抖动时延的最小值,单位为毫秒
Max positive SD
源到目的方向正抖动时延的最大值,单位为毫秒
Max positive DS
目的到源方向正抖动时延的最大值,单位为毫秒
Positive SD number
源到目的方向正抖动时延的数目,单位为个
Positive DS number
目的到源方向正抖动时延的数目,单位为个
Positive SD sum
源到目的方向正抖动时延之和,单位为毫秒
Positive DS sum
目的到源方向正抖动时延之和,单位为毫秒
Positive SD average
源到目的方向正抖动时延的平均值,单位为毫秒
Positive DS average
目的到源方向正抖动时延的平均值,单位为毫秒
源到目的方向正抖动时延的平方和
目的到源方向正抖动时延的平方和
Min negative SD
源到目的方向负抖动时延的绝对值的最小值,单位为毫秒
Min negative DS
目的到源方向负抖动时延的绝对值的最小值,单位为毫秒
Max negative SD
源到目的方向负抖动时延的绝对值的最大值,单位为毫秒
Max negative DS
目的到源方向负抖动时延的绝对值的最大值,单位为毫秒
Negative SD number
源到目的方向负抖动时延的数目,单位为个
Negative DS number
目的到源方向负抖动时延的数目,单位为个
Negative SD sum
源到目的方向负抖动时延的绝对值之和,单位为毫秒
Negative DS sum
目的到源方向负抖动时延的绝对值之和,单位为毫秒
Negative SD average
源到目的方向负抖动时延的绝对值的平均值,单位为毫秒
Negative DS average
目的到源方向负抖动时延的绝对值的平均值,单位为毫秒
源到目的方向负抖动时延的平方和
目的到源方向负抖动时延的平方和
SD average
源到目的方向抖动时延的平均值,单位为毫秒
DS average
目的到源方向抖动时延的平均值,单位为毫秒
One way results
单向延迟测试结果,单位为毫秒。只有ICMP-jitter、UDP-Jitter和Voice类型测试有单向延迟测试结果
Max SD delay
源到目的的最大时延,单位为毫秒
Max DS delay
目的到源的最大时延,单位为毫秒
Min SD delay
源到目的的最小时延,单位为毫秒
Min DS delay
目的到源的最小时延,单位为毫秒
Number of SD delay
源到目的计算的时延数,单位为毫秒
Number of DS delay
目的到源计算的时延数,单位为毫秒
Sum of SD delay
源到目的的时延和,单位为毫秒
Sum of DS delay
目的到源的时延和,单位为毫秒
源到目的的时延的平方和
目的到源的时延的平方和
SD lost packets
源到目的方向丢失的报文个数
DS lost packets
目的到源方向丢失的报文个数
不能确定原因丢失的报文个数
Voice scores
语音参数,只在Voice类型测试有此信息
MOS value
为语音计算的MOS值
ICPIF value
为语音计算的ICPIF值
Hop IP
本跳IP地址,只在Path-jitter测试中存在此信息
Path-jitter results
Path-jitter测试的结果,只在Path-jitter测试中存在此信息
Jitter number
计算抖动次数,只在Path-jitter测试中存在此信息
最小/最大/平均抖动时延,单位为毫秒,只在Path-jitter测试中存在此信息
正抖动时延的数目,只在Path-jitter测试中存在此信息
最小/最大/平均正抖动时延,单位为毫秒,只在Path-jitter测试中存在此信息
正抖动时延之和/平方和,只在Path-jitter测试中存在此信息
负抖动时延的数目,只在Path-jitter测试中存在此信息
最小/最大/平均负抖动时延,单位为毫秒,只在Path-jitter测试中存在此信息
负抖动时延之和/平方和,只在Path-jitter测试中存在此信息
TTL
Hop IP
回复应答的节点IP地址
Time
收到应答报文的时间
Status
测试状态取值为:
·     Succeeded:测试成功
·     Failed:测试失败
·     In progress:测试正在进行
·     Aborted:测试终止,表示用户手动停止测试
·     Timeout:测试超时
·     --测试状态无意义。颜色标记模式下,color yellow和total字段显示状态无意义
Last test
当前完成的最后一步测试取值为:
·     CIR test:CIR测试
·     PIR test:PIR测试
·     Traffic policing test:流量监管测试
·     Service performance test:服务性能测试
测试估算全部时间,单位秒
测试实际使用时间,单位秒
测试开始结束时间以秒为单位,定时器精度为1秒,因此结果表中显示的实际测试时长(结束时间 - 开始时间)与用户配置时长存在1秒误差
CIR测试,执行步数为1
Start time
测试开始时间
End time
测试结束时间
最小/最大/平均速率,单位为kbps
最小/最大/平均传输时延,单位为微秒
最小/最大/平均时延抖动,单位为微秒
FL count/FLR
丢包个数/丢包率
乱序报文个数
SES(Severely Errored Second,严重错误秒):测试开始后,每一秒统计一次丢包率,若该秒内丢包率大于50%,记为严重错误秒。
·     不可用周期:连续10个SES发生时,进入不可用周期,直到连续10个非SES发生时结束。
·     可用周期:连续10个非SES发生时,进入可用周期,直到连续10个SES发生时结束。
·     Severely Err Secs:严重错误秒总数
·     AVAIL=可用周期/总时间。测试开始时,默认为可用周期
PIR测试,颜色标记为绿色
PIR测试,颜色标记为黄色
PIR test (total)
PIR测试,汇总
PIR test (color-blind)
PIR测试,非颜色标记模式
流量监管测试,颜色标记为绿色
流量监管测试,颜色标记为黄色
流量监管测试,汇总
Traffic policing test (color-blind)
流量监管测试,非颜色标记模式
服务性能测试
Basic results
基础测试结果
Throughput results
Throughput测试结果
Frame-loss results
Frame-loss测试结果
Latency results
Latency测试结果
Initial speed(Kbps)
发送探测报文的初始速率,单位为kbps
探测报文的速率调整精度,单位为kbps
Probe duration(s)
探测周期的时长,单位为秒
Probe interval(s)
探测的时间间隔,单位为秒
Allowed-loss-ratio
可接受的丢包率上限
Frame size(Byte)
探测报文的长度,单位为字节
Current speed(Kbps)
当前速率,单位为kbps
Frame-loss(Loss/Tx)
丢包率
Min-latency(us)
最小时延,单位为微秒
Max-latency(us)
最大时延,单位为微秒
Avg-latency(us)
平均时延,单位为微秒
Min-jitter(ns)
最小抖动时延,单位为纳秒
Max-jitter(ns)
最大抖动时延,单位为纳秒
Avg-jitter(ns)
平均抖动时延,单位为纳秒
Sent packets
发送报文数
Received packets
接收报文数
Status
探测结果:
·     Succeeded:成功
·     Failed:失败
Time
探测完成时间
display nqa rfc2544 group命令用来显示NQA路径服务质量操作组信息。
display nqa rfc2544 group [ brief | name group-name | result [ group-name ] ]
brief:显示NQA路径服务质量操作组的简要信息。
name group-name:显示指定NQA路径服务质量操作组的详细情况,group-name表示NQA路径服务质量操作组名称,为1~32个字符的字符串,不区分大小写。不指定该参数时,表示所有NQA路径服务质量操作组。
result:显示NQA路径服务质量操作组的探测结果信息。
不指定参数,则表示显示所有NQA路径服务质量测试操作组的详细信息。
# 显示NQA路径服务质量操作组的简要信息。
<Sysname> display nqa rfc2544 group brief
Group name                        Status
test1                             Active
test2                             Idle
# 显示名称为test的NQA路径服务质量操作组的详细信息。
<Sysname> display nqa rfc2544 group name test
Group name: test
Status: Idle
Bound NQA entry information:
  Admin-name                        Operation-tag
  admin                             1
  admin                             2
# 显示名称为test的NQA路径服务质量操作组的结果信息。
<Sysname> display nqa rfc2544 group result test
NQA entry (admin admin, tag 1) test results:
  Basic results     :
  Frame-loss results:
      Current speed(Kbps): 100000
      Frame-loss         : 0.0672002%
      Status             : Succeeded
      Time               : 2021-04-17 15:39:33.3
    Frame size(Byte): 96
      Frame-loss         : 0.0928005%
      Status             : Succeeded
      Time               : 2021-04-17 15:39:35.3
NQA entry (admin admin, tag 2) test results:
  Basic results  :
    Initial speed(Kbps): 100000
  Latency results:
    Frame size   : 64
      Min-latency(us)  : 146
      Max-latency(us)  : 150
      Avg-latency(us)  : 148
      Min-jitter(ns)   : 0
      Max-jitter(ns)   : 0
      Avg-jitter(ns)   : 0
      Sent packets     : 10000
      Received packets : 9998
      Status           : Succeeded
      Time             : 2021-04-17 15:39:37.3
    Frame size   : 128
      Min-latency(us)  : 82
      Max-latency(us)  : 86
      Avg-latency(us)  : 84
      Min-jitter(ns)   : 0
      Max-jitter(ns)   : 0
      Avg-jitter(ns)   : 0
      Status           : Succeeded
      Time             : 2021-04-17 15:39:39.3
NQA entry (admin admin, tag 3) test results:
  Basic results     :
  Throughput results:
      Status             : Failed
      Time               : 2021-04-17 15:41:12.4
表1-7 display nqa rfc2544 group命令显示信息描述表
Group name
NQA路径服务质量操作组的名称
Status
测试状态:
·     Idle:空闲
·     Active:正在测试中
NQA路径服务质量操作组绑定的测试组的信息
Admin-name
NQA测试组的管理员名称
Operation-tag
NQA测试操作的标签
Status
测试状态取值为:
·     Succeeded:测试成功
·     Failed:测试失败
·     Timeout:测试超时
·     --:表示测试状态无意义
display nqa statistics命令用来显示NQA测试的统计信息。
display nqa statistics [ admin-name operation-tag ]
admin-name :创建NQA测试组的管理员名称,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
测试开始后,如果第一次测试中的所有探测尚未完成,则无法生成统计信息。若此时通过该命令查看统计信息,则显示信息为全0。
如果配置了阈值告警组,将显示在statistics interval命令指定的统计周期内的监测结果。若阈值告警组的阈值类型为平均值,或监测对象为Voice测试的ICPIF或MOS值,则显示的监测结果为无效值。
Frame-loss、Latency、Throughput和UDP-tracert测试类型不支持用该命令显示统计信息。
不指定任何参数,则表示显示所有测试组的统计信息。
# 显示NQA测试组管理员名称为admin、测试操作标签为test的TCP测试的统计信息。
<Sysname> display nqa statistics admin test
NQA entry (admin admin, tag test) test statistics:
  NO. : 1
    Start time: 2007-01-01 09:30:20.0
    Life time: 2 seconds
    Min/Max/Average round trip time: 13/13/13
    Square-Sum of round trip time: 169
  Extended results:
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ICMP-jitter测试的统计信息。
  NO. : 1
    Start time: 2015-03-09 17:42:10.7
    Life time: 156 seconds
    Send operation times: 1560           Receive response times: 1560
    Square-Sum of round trip time: 1563
  Extended results:
   RTT number: 1560
    Min positive SD: 1                     Min positive DS: 1
    Max positive SD: 1                     Max positive DS: 2
    Positive SD number: 18                 Positive DS number: 46
    Positive SD sum: 18                    Positive DS sum: 49
    Positive SD average: 1                 Positive DS average: 1
    Positive SD square-sum: 18             Positive DS square-sum: 55
    Min negative SD: 1                     Min negative DS: 1
    Negative SD number: 24                 Negative DS number: 57
    Negative SD sum: 24                    Negative DS sum: 58
    Negative SD average: 1                 Negative DS average: 1
    Negative SD square-sum: 24             Negative DS square-sum: 60
    SD average: 1                          DS average: 1
  One way results:
    Min SD delay: 1                        Min DS delay: 1
    Number of SD delay: 4                  Number of DS delay: 4
    Sum of SD delay: 4                     Sum of DS delay: 5
    Square-Sum of SD delay: 4              Square-Sum of DS delay: 7
  Reaction statistics:
    1      jitter-DS        accumulate      1500         10
    2      jitter-SD        average         -            -
    3      OWD-DS           -               1560         2
    4      OWD-SD           -               1560         0
    5      packet-loss      accumulate      0            0
    6      RTT              accumulate      1560         0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的UDP-jitter测试的统计信息。
  NO. : 1
    Start time: 2007-01-01 09:33:22.3
    Life time: 23 seconds
    Send operation times: 100            Receive response times: 100
    Min/Max/Average round trip time: 1/11/5
    Square-Sum of round trip time: 24360
  Extended results:
  UDP-jitter results:
   RTT number: 550
    Max positive SD: 7                     Max positive DS: 1
    Positive SD number: 220                Positive DS number: 97
    Positive SD sum: 283                   Positive DS sum: 287
    Positive SD average: 1                 Positive DS average: 2
    Positive SD square-sum: 709            Positive DS square-sum: 1937
    Min negative SD: 2                     Min negative DS: 1
    Max negative SD: 10                    Max negative DS: 1
    Negative SD number: 81                 Negative DS number: 94
    Negative SD sum: 556                   Negative DS sum: 191
    Negative SD average: 6                 Negative DS average: 2
    Negative SD square-sum: 4292           Negative DS square-sum: 967
    SD average: 2                          DS average: 2
  One way results:
    Max SD delay: 5                        Max DS delay: 5
    Number of SD delay: 550                Number of DS delay: 550
    Sum of SD delay: 1475                  Sum of DS delay: 1201
    Square-Sum of SD delay: 5407           Square-Sum of DS delay: 3959
    1      jitter-DS        accumulate      90           25
    3      OWD-DS           -               100          24
    4      OWD-SD           -               100          13
    6      RTT              accumulate      100          52
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Voice测试的统计信息。
  NO. : 1
    Start time: 2007-01-01 09:33:45.3
    Life time: 120 seconds
    Min/Max/Average round trip time: 1/12/7
    Square-Sum of round trip time: 620
  Extended results:
  Voice results:
   RTT number: 10
    Min positive SD: 3                     Min positive DS: 1
    Max positive SD: 10                    Max positive DS: 1
    Positive SD number: 3                  Positive DS number: 2
    Positive SD sum: 18                    Positive DS sum: 2
    Positive SD average: 6                 Positive DS average: 1
    Positive SD square-sum: 134            Positive DS square-sum: 2
    Min negative SD: 3                     Min negative DS: 1
    Max negative SD: 9                     Max negative DS: 1
    Negative SD number: 4                  Negative DS number: 2
    Negative SD sum: 25                    Negative DS sum: 2
    Negative SD average: 6                 Negative DS average: 1
    Negative SD square-sum: 187            Negative DS square-sum: 2
    SD average: 6                          DS average: 1
  One way results:
  Voice scores:
    Max MOS value: 4.40                    Min MOS value: 4.40
    Max ICPIF value: 0                     Min ICPIF value: 0
    1      ICPIF            -               -            -
    2      MOS              -               -            -
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Path-jitter测试的统计信息。
  NO. : 1
  Path 1:
    Basic Results:
    Extended Results:
      Jitter number: 9
    Basic Results:
    Extended Results:
      Jitter number: 9
表1-8 display nqa statistics命令显示信息描述
No.
统计组的组号
Start time
测试组启动时间
Life time
测试的持续时间,单位为秒
发送的探测报文数
收到的响应报文数
最小/最大/平均往返时间,单位为毫秒
往返时间平方和
Packet loss ratio
平均丢包率
测试过程中超时的次数
对方强制断开连接的次数
和对方建立连接失败的次数
因内部错误失败的次数
因其它错误失败的次数
报文失序的次数
迟到报文个数
ICMP-jitter results
UDP-jitter results
Voice results
RTT number
收到的响应报文数
Min positive SD
源到目的方向抖动时延为正值的最小值,单位为毫秒
Min positive DS
目的到源方向抖动时延为正值的最小值,单位为毫秒
Max positive SD
源到目的方向抖动时延为正值的最大值,单位为毫秒
Max positive DS
目的到源方向抖动时延为正值的最大值,单位为毫秒
Positive SD number
源到目的方向抖动时延为正值的数目,单位为个
Positive DS number
目的到源方向抖动时延为正值的数目,单位为个
Positive SD sum
源到目的方向抖动时延为正值的和,单位为毫秒
Positive DS sum
目的到源方向抖动时延为正值的和,单位为毫秒
Positive SD average
源到目的方向抖动时延为正值的平均值,单位为毫秒
Positive DS average
目的到源方向抖动时延为正值的平均值,单位为毫秒
源到目的方向抖动时延为正值的平方和
目的到源方向抖动时延为正值的平方和
Min negative SD
源到目的方向抖动时延为负值的最小绝对值,单位为毫秒
Min negative DS
目的到源方向抖动时延为负值的最小绝对值,单位为毫秒
Max negative SD
源到目的方向抖动时延为负值的最大绝对值,单位为毫秒
Max negative DS
目的到源方向抖动时延为负值的最大绝对值,单位为毫秒
Negative SD number
源到目的方向抖动时延为负值的数目,单位为个
Negative DS number
目的到源方向抖动时延为负值的数目,单位为个
Negative SD sum
源到目的方向抖动时延为负值的绝对值和,单位为毫秒
Negative DS sum
目的到源方向抖动时延为负值的绝对值和,单位为毫秒
Negative SD average
源到目的方向抖动时延为负值的绝对值的平均值,单位为毫秒
Negative DS average
目的到源方向抖动时延为负值的绝对值的平均值,单位为毫秒
源到目的方向抖动时延为负值的平方和
目的到源方向抖动时延为负值的平方和
SD average
DS average
One way results
Max SD delay
源到目的的最大时延,单位为毫秒
Max DS delay
目的到源的最大时延,单位为毫秒
Min SD delay
源到目的的最小时延,单位为毫秒
Min DS delay
目的到源的最小时延,单位为毫秒
Number of SD delay
源到目的计算的时延数,单位为个
Number of DS delay
目的到源计算的时延数,单位为个
Sum of SD delay
源到目的的时延和,单位为毫秒
Sum of DS delay
目的到源的时延和,单位为毫秒
源到目的的时延的平方和
目的到源的时延的平方和
SD lost packets
源到目的方向丢失的报文个数
DS lost packets
目的到源方向丢失的报文个数
不能确定原因丢失的报文个数
Voice scores
语音参数,只在voice类型测试有此信息
Max MOS value
最大MOS值
Min MOS value
最小MOS值
Max ICPIF value
最大ICPIF值
Min ICPIF value
最小ICPIF值
Reaction statistics
阈值告警组在统计周期内的监测结果
Index
阈值告警组的编号
Checked Element
监测对象
Threshold Type
阈值类型
Checked Num
已监测的样本个数
Over-threshold Num
超出阈值的样本个数
Path
Path-jitter测试结果的路径序号,只在Path-jitter测试中存在此信息
Hop IP
Path-jitter results
Jitter number
表1-9 display nqa statistics命令显示阈值告警功能相关字段取值描述(DHCP/DLSw/DNS/FTP/HTTP/ICMP-echo/SNMP/TCP/UDP-echo测试类型)
监测对象
阈值类型
监测的样本范围
Checked Num取值
probe-duration
accumulate
统计周期内,进行的探测
统计周期内,已完成的探测次数
统计周期内,累计的探测持续时间不在阈值范围内的探测次数
average
consecutive
统计周期内,进行的探测
统计周期内,已完成的探测次数
统计周期内,连续的探测持续时间不在阈值范围内的探测次数
probe-fail
accumulate
统计周期内,进行的探测
统计周期内,已完成的探测次数
统计周期内,累计的失败的探测次数
consecutive
统计周期内,进行的探测
统计周期内,已完成的探测次数
统计周期内,连续的失败的探测次数
表1-10 display nqa statistics命令显示阈值告警功能相关字段取值描述(ICMP-jitter/UDP-jitter/Voice测试类型)
监测对象
阈值类型
监测的样本范围
Checked Num取值
RTT
accumulate
统计周期内,发送的报文
统计周期内,已发送的报文个数
统计周期内,累计的往返时间不在阈值范围内的报文个数
average
jitter-DS/jitter-SD
accumulate
统计周期内,发送的报文
统计周期内,已发送的报文个数
统计周期内,累计的单向抖动时间不在阈值范围内的报文个数
average
OWD-DS/OWD-SD
统计周期内,发送的报文
统计周期内,已发送的报文个数
统计周期内,单向时延不在阈值范围内的报文个数
packet-loss
accumulate
统计周期内,发送的报文
统计周期内,已发送的报文个数
统计周期内累计的丢包数
·     statistics interval
display nqa twamp-light client命令用来查看TWAMP-light Client会话的信息。
display nqa twamp-light client [ link-bundle ] [ test-session session-id | verbose ]
link-bundle:显示捆绑链路接口的会话信息。当此显示命令未指定该参数时,显示全部会话的信息。
test-session session-id:显示指定会话的详细信息。session-id表示会话ID,取值范围为1~512。
verbose:表示显示所有会话的详细信息。
本命令未指定任何参数时,表示显示所有会话的简要信息。
# 查看所有会话的简要信息。
<Sysname> display nqa twamp-light client
Brief information about all test sessions:
Total sessions: 2
Active sessions: 1
ID    Status     Source IP/Port         Destination IP/Port
1     Active     10.1.1.1/10000         10.2.2.2/20000
2     Inactive   4.4.4.1/7777           4.4.4.2/8888
# 查看捆绑链路接口会话的简要信息。
<Sysname> display nqa twamp-light client link-bundle
Total sessions: 2
Active sessions: 2
ID   Status    Source IP/Port        Destination IP/Port  Link bundle interface
1    Active    1.1.1.1/2001          2.2.2.2/2010         Route-Aggregation1
2    Active    2001::1/2001          2001::2/2010         Route-Aggregation1
# 查看所有会话的详细信息。
<Sysname> display nqa twamp-light client verbose
Session ID                           : 1
  Status                             : Active
  Session type                       : Permanent
  Source interface                   : -
  Service instance                   : -
  Source IP                          : 10.1.1.1
  Source IPv6                        : -
  Destination IP                     : 10.2.2.2
  Destination IPv6                   : -
  Source port                        : 10000
  Destination port                   : 20000
  Source MAC                         : -
  Destination MAC                    : -
  VLAN ID                            : -
  Service VLAN ID                    : -
  Customer VLAN ID                   : -
  ToS                                : 0
  Padding length                     : 142
  Timestamp format                   : PTP
  VPN instance                       : -
  Priority 802.1p                    : 0
  Adjust-udp-checksum                : Disabled
  One-way delay-measure state        : Disabled
  Last start time                    : Never
  Last stop time                     : Never
  Packet sending interval(ms)        : 100
  Timeout(sec)                       : 5
  Duration(sec)                      : -
  Packets sent                       : -
  Statistics interval(ms)            : 10000
  Monitor time(ms)                   : 20000
  Delay monitor time(ms)             : 20000
  Jitter monitor time(ms)            : 20000
  Loss monitor time(ms)              : 20000
  Link bundle interface              : Route-Aggregation1
  Member interface                   : Ten-GigabitEthernet3/1/1
    Status                           : Active
    Last start time                  : 2021-11-29 23:05:33.7
Session ID                           : 2
  Status                             : Inactive
  Session type                       : -
  Source interface                   : Ten-GigabitEthernet3/1/2
  Source IP                          : 4.4.4.1
  Source IPv6                        : -
  Destination IP                     : 4.4.4.2
  Source port                        : 7777
  Destination port                   : 8888
  Source MAC                         : 0001-0001-0001
  Destination MAC                    : 0001-0001-0002
  VLAN ID                            : -
  Service VLAN ID                    : -
  ToS                                : 0
  VPN instance                       : -
  Priority 802.1p                    : 0
  Packet sending interval(ms)        : -
  Timeout(sec)                       : -
  Duration(sec)                      : -
  Packets sent                       : -
  Statistics interval(ms)            : -
  Monitor time(ms)                   : -
  Delay monitor time(ms)             : -
  Jitter monitor time(ms)            : -
  Loss monitor time(ms)              : -
  Link bundle interface              : -
表1-11 display nqa twamp-light client命令显示信息描述表
Total sessions
会话总数
Active sessions
正在运行的会话个数
Session ID
会话ID
Status
会话的状态:
·     Active:表示测试会话的测试功能处于激活状态
·     Inactive:表示测试会话的测试功能处于未激活状态
Session type
会话类型:
·     On-demand:按需统计
·     Permanent:连续统计
Source interface
测试会话的源AC口
Service instance
关联的以太网服务实例
Source IP
测试会话的源IP地址
Source IPv6
测试会话的源IPv6地址
Destination IP
测试会话的目的IP地址
Destination IPv6
测试会话的目的IPv6地址
Source port
测试会话的源端口号
Destination port
测试会话的目的端口号
Source MAC address
测试会话源MAC地址
Destination MAC address
测试会话目的MAC地址
VLAN ID
测试会话的VLAN ID
Service VLAN ID
测试会话的外层VLAN ID
Customer VLAN ID
测试会话的内层VLAN ID
ToS
测试会话的ToS(Type of Service,服务类型)信息
Padding length
测试会话的填充长度信息
Timestamp format
时间戳格式,取值包括:
·     NTP:NTP格式
·     PTP:PTP格式
VPN instance
MPLS L3VPN实例名称
Priority 802.1p
802.1p优先级
Adjust-udp-checksum
是否调整测试报文中校验和字段的值,取值为:
·     Enabled:调整为实际的校验和
·     Disabled:不调整,校验和字段取值为0
当未捆绑聚合链路时,取值为会话是否拥有调整测试报文中校验和字段的能力;当捆绑聚合链路时,聚合成员会话中只要有一个会话具有调整测试报文中校验和字段的能力,该字段便显示为Enabled
会话中单向时延统计功能的开启状态。取值为:
·     Enabled:表示开启
·     Disabled:表示关闭
当未捆绑聚合链路时,取值为会话是否拥有单向时延统计能力;当捆绑聚合链路时,聚合成员口会话中只要有一个会话拥有单向时延统计能力,该字段便显示为Enabled
Last start time
TWAMP-light测试最近一次测试的最新开始时间,格式为“年-月-日 时:分:秒.毫秒”
·     当未捆绑聚合链路时,如果取值为Never,表示测试未开始
·     当捆绑聚合链路时,取值恒为Never
Last stop time
TWAMP-light测试最近一次测试的停止时间,格式为“年-月-日 时:分:秒.毫秒”
·     当未捆绑聚合链路时,如果取值为Never,则表示测试未结束
TWAMP-light测试的发送报文周期,单位为毫秒
Timeout(sec)
TWAMP-light测试的统计周期内反射报文超时时间,单位为秒
Duration(sec)
TWAMP-light测试的持续时间,只有按需统计且配置了测试持续时间时会显示计数,单位为秒
Packets sent
TWAMP-light测试的发送报文个数,只有按需统计且配置了测试发送报文个数时会显示计数
TWAMP-light测试的统计周期,单位为毫秒
Monitor time(ms)
TWAMP-light测试的报文监控时间,单位为毫秒;仅显示用户通过start (TWAMP-light-sender view)命令配置的值
TWAMP-light测试的双向时延监控时间,单位为毫秒;当未启动测试时,显示为“-”
TWAMP-light测试的双向抖动监控时间,单位为毫秒;当未启动测试时,显示为“-”
TWAMP-light测试的双向丢包监控时间,单位为毫秒;当未启动测试时,显示为“-”
捆绑链路接口的名称,目前仅支持三层聚合接口和三层聚合子接口
取值为“-”时,表示当前接口为非捆绑链路接口
    Member interface             :
      Status                     :
      Last start time            :
      Last stop time             :
      One-waydelay-measure state          :
聚合成员口的TWAMP-light测试信息,包括:
·     聚合成员口的名称
·     聚合成员口的会话状态:
¡     Active:表示测试会话的测试功能处于激活状态
¡     Inactive:表示测试会话的测试功能处于未激活状态
·     聚合成员口TWAMP-light测试最近一次测试的最新开始时间,格式为“年-月-日 时:分:秒.毫秒”。取值为Never时,表示测试未开始
·     聚合成员口TWAMP-light测试最近一次测试的停止时间,格式为“年-月-日 时:分:秒.毫秒”。取值为Never时,表示测试未结束
·     聚合成员口是否拥有调整报文中校验和字段的能力,取值为:
¡     Enabled:调整为实际的校验和
¡     Disabled:不调整,校验和字段取值为0
·     聚合成员口是否拥有单向时延统计功能的能力,取值为:
¡     Enabled:表示开启
¡     Disabled:表示关闭
·     test-session
display nqa twamp-light client statistics命令用来查看TWAMP-light Client会话的统计信息,包括双向时延、双向抖动和双向丢包信息。
display nqa twamp-light client statistics { one-way-delay | two-way-delay | two-way-loss } test-session session-id [ link-bundle-member interface-type interface-number ]
one-way-delay:显示单向时延和抖动的统计信息。
two-way-delay:显示双向时延和抖动的统计信息。
two-way-loss:显示双向丢包的统计信息。
session-id:显示指定会话的统计信息;整数形式,取值范围为1~512。
link-bundle-member interface-type interface-number:显示捆绑链路中指定聚合成员口的统计信息。interface-type interface-number表示接口类型和接口编号。不指定该参数时,显示捆绑链路中所有聚合成员口的统计信息。
# 查看指定会话的单向时延和抖动的统计信息。
<Sysname> display nqa twamp-light client statistics one-way-delay test-session 1
Latest one-way-delay statistics(us):
    Index        SD-delay(Avg)DS-delay(Avg) SD-jitter(Avg)   DS-jitter(Avg)
    1            1869927531   0             1307             138
    2            1869921226   0             1691             186
    3            1869924535   0             1040             168
Average SD delay : 1869924431     Average DS delay : 0
Maximum SD delay : 1869927531     Maximum DS delay : 0
Minimum SD delay : 1869921226     Minimum DS delay : 0
Average SD jitter: 1346           Average DS jitter: 164
Maximum SD jitter: 40805          Maximum DS jitter: 13141
Minimum SD jitter: 1              Minimum DS jitter: 1
表1-12 display nqa twamp-light client statistic one-way-delay命令显示信息描述表
Link bundle member
捆绑链路接口的成员接口的相关统计信息
Latest one-way delay statistics(μs)
最近一次测试最新的单向时延统计信息,单位为微秒
Index
统计数据的序列号
SD-delay(avg)
源到目的方向平均时延值
DS-delay(avg)
目的到源方向平均时延值
SD-jitter(avg)
源到目的方向平均抖动值
DS-jitter(avg)
目的到源方向平均抖动值
Average SD delay
源到目的方向平均时延值
Average DS delay
目的到源方向平均时延值
Maximum SD delay
源到目的方向最大时延值
Maximum DS delay
目的到源方向最大时延值
Minimum SD delay
源到目的方向最小时延值
Minimum DS delay
目的到源方向最小时延值
Average SD jitter
源到目的方向平均抖动值
Average DS jitter
目的到源方向平均抖动值
Maximum SD jitter
源到目的方向最大抖动值
Maximum DS jitter
目的到源方向最大抖动值
Minimum SD jitter
源到目的方向最小抖动值
Minimum DS jitter
目的到源方向最小抖动值
# 查看指定会话的双向时延和抖动的统计信息。
<Sysname> display nqa twamp-light client statistics two-way-delay test-session 1
Latest two-way-delay statistics(us):
    Index        Delay(Avg)   Jitter(Avg)   SD-jitter(Avg)   DS-jitter(Avg)
    1            734          240           81               159
    2            658          24            12               12
    3            580          91            31               60
    4            667          40            42               2
    5            8346         15226         15293            67
    6            627          18            17               35
    7            659          10            4                14
    8            662          67            46               21
Average delay    : 1617           Average jitter   : 1965
Maximum delay    : 15959          Maximum jitter   : 15226
Minimum delay    : 534            Minimum jitter   : 10
Average SD jitter: 1941           Average DS jitter: 46
Maximum SD jitter: 15293          Maximum DS jitter: 159
Minimum SD jitter: 4              Minimum DS jitter: 2
# 查看指定会话的双向时延和抖动的统计信息。(假设当前只在三层聚合接口下进行测试,且该聚合口有两个成员接口执行本命令会分别显示两个聚合成员口下的统计信息)
<Sysname> display nqa twamp-light client statistics two-way-delay test-session 2
Link bundle member: Ten-GigabitEthernet3/1/1
    1            0            0                 0                 0
    2            0            0                 0                 0
    3            4            4                 4                 4
    4            1            1                 1                 1
Link bundle member: Ten-GigabitEthernet3/1/2
    1            0            0                 0                 0
    2            0            0                 0                 0
    3            4            4                 4                 4
    4            1            1                 1                 1
Average delay     :          1        Average jitter    :          1
Maximum delay     :          7        Maximum jitter    :          7
Minimum Delay     :          0        Minimum jitter    :          0
Average SD jitter :          1        Average DS jitter :          1
Maximum SD jitter :          7        Maximum DS jitter :          7
Minimum SD jitter :          0        Minimum DS jitter :          0
表1-13 display nqa twamp-light client statistic two-way-delay命令显示信息描述表
Link bundle member
捆绑链路接口的成员接口的相关统计信息
Latest two-way delay statistics(μs)
最近一次测试最新的双向时延统计信息,单位为微秒
Index
统计数据的序列号
Delay(avg)
平均时延值
Jitter(avg)
平均抖动值
SD jitter(avg)
源到目的方向平均抖动值
DS jitter(avg)
目的到源方向平均抖动值
Average delay
平均时延值
Average jitter
平均抖动值
Maximum delay
最大时延值
Maximum jitter
最大抖动值
Minimum delay
最小时延值
Minimum jitter
最小抖动值
Average SD jitter
源到目的方向平均抖动值
Average DS jitter
目的到源方向平均抖动值
Maximum SD jitter
源到目的方向最大抖动值
Maximum DS jitter
目的到源方向最大抖动值
Minimum SD jitter
源到目的方向最小抖动值
Minimum DS jitter
目的到源方向最小抖动值
# 查看指定会话的双向丢包统计信息。
<Sysname> display nqa twamp-light client statistics two-way-loss test-session 1
Latest two-way loss statistics:
    Index      Loss count      Loss ratio      Error count  Error ratio
    11006      5               50.0000%        0            0.0000%
    11007      3               30.0000%        0            0.0000%
    11008      4               40.0000%        0            0.0000%
    11009      8               80.0000%        0            0.0000%
    11010      10              100.0000%       0            0.0000%
    11011      1               10.0000%        0            0.0000%
    11012      10              100.0000%       0            0.0000%
    11013      2               20.0000%        0            0.0000%
    11014      10              100.0000%       0            0.0000%
    11015      9               90.0000%        0            0.0000%
    11016      6               60.0000%        0            0.0000%
    11017      2               20.0000%        0            0.0000%
    11018      8               80.0000%        0            0.0000%
    11019      2               20.0000%        0            0.0000%
    11020      8               80.0000%        0            0.0000%
    11021      2               20.0000%        0            0.0000%
    11022      2               20.0000%        0            0.0000%
    11023      7               70.0000%        0            0.0000%
    11024      4               40.0000%        0            0.0000%
    11025      4               40.0000%        0            0.0000%
    11026      7               70.0000%        0            0.0000%
    11027      7               70.0000%        0            0.0000%
    11028      8               80.0000%        0            0.0000%
    11029      1               10.0000%        0            0.0000%
    11030      2               20.0000%        0            0.0000%
    11031      8               80.0000%        0            0.0000%
    11032      7               70.0000%        0            0.0000%
    11033      7               70.0000%        0            0.0000%
    11034      8               80.0000%        0            0.0000%
    11035      4               40.0000%        0            0.0000%
Average loss count :          5      Average loss ratio :  55.3333%
Maximum loss count :          10     Maximum loss ratio : 100.0000%
Minimum loss count :          1      Minimum loss ratio :  10.0000%
Average error count:          0      Average error ratio:   0.0000%
Maximum error count:          0      Maximum error ratio:   0.0000%
Minimum error count:          0      Minimum error ratio:   0.0000%
# 查看会话2的双向丢包统计信息。(捆绑链路接口)
<Sysname> display nqa twamp-light client statistics two-way-loss test-session 2
    87            100           100.0000%     0              0.0000%
    88            100           100.0000%     0              0.0000%
    89            100           100.0000%     0              0.0000%
    90            100           100.0000%     0              0.0000%
    91            100           100.0000%     0              0.0000%
    92            100           100.0000%     0              0.0000%
    93            100           100.0000%     0              0.0000%
    94            100           100.0000%     0              0.0000%
    95            100           100.0000%     0              0.0000%
    96            100           100.0000%     0              0.0000%
    97            100           100.0000%     0              0.0000%
    98            100           100.0000%     0              0.0000%
    99            100           100.0000%     0              0.0000%
    100           100           100.0000%     0              0.0000%
    101           100           100.0000%     0              0.0000%
    102           100           100.0000%     0              0.0000%
    103           100           100.0000%     0              0.0000%
    104           100           100.0000%     0              0.0000%
    105           100           100.0000%     0              0.0000%
    106           100           100.0000%     0              0.0000%
    107           100           100.0000%     0              0.0000%
    108           100           100.0000%     0              0.0000%
    109           100           100.0000%     0              0.0000%
    110           100           100.0000%     0              0.0000%
    111           100           100.0000%     0              0.0000%
    112           100           100.0000%     0              0.0000%
    113           100           100.0000%     0              0.0000%
    114           100           100.0000%     0              0.0000%
    115           100           100.0000%     0              0.0000%
    116           100           100.0000%     0              0.0000%
Average loss count  : 100             Average loss ratio  : 100.0000%
Maximum loss count  : 100             Maximum loss ratio  : 100.0000%
Minimum loss count  : 100             Minimum loss ratio  : 100.0000%
Average error count : 0               Average error ratio : 0.0000%
Maximum error count : 0               Maximum error ratio : 0.0000%
Minimum error count : 0               Minimum error ratio : 0.0000%
表1-14 display nqa twamp-light client statistic two-way-loss命令显示信息描述表
Link bundle member
捆绑链路接口的成员接口的相关统计信息
双向丢包统计信息
Index
统计数据的序列号
Loss count
丢包个数
Loss ratio
丢包率
Error count
错包个数
Error ratio
错包率
Average loss count
平均丢包个数
Average loss ratio
平均丢包率
Maximum loss count
最大丢包个数
Maximum loss ratio
最大丢包率
Minimum loss count
最小丢包个数
Minimum loss ratio
最小丢包率
Average error count
平均错包个数
Average error ratio
平均错包率
Maximum error count
最大错包个数
Maximum error ratio
最大错包率
Minimum error count
最小错包个数
Minimum error ratio
最小错包率
·     reset nqa twamp-light statistics
·     test-session (TWAMP-light-client view)
display nqa twamp-light client test-session reaction counters命令用来显示TWAMP-light测试会话阈值告警组的监测结果。
display nqa twamp-light client test-session reaction counters [ session-id [ item-number ] ]
session-id:会话ID,取值范围为1~512。指定该参数时,可以显示该会话的所有统计信息。
不指定任何参数,则表示显示TWAMP-light所有测试会话中所有阈值告警组的当前监测结果。
# 显示TWAMP-light测试会话1阈值告警组的当前监测结果。
<Sysname> display nqa twamp-light client test-session reaction counters 1
Reaction counters for session 1:
Link bundle member interface Ten-GigabitEthernet3/1/1:
Index: 1
  Checked element: two-way-delay
  Lower-threshold: 5
  Upper-threshold: 50
  Action type: trap-only
  Check-objects: 0
  Threshold violations: 0
Reaction counters for session 2:
Index: 1
  Lower-threshold: 5
  Upper-threshold: 50
  Check-objects: 1
表1-15 display nqa twamp-light client test-session reaction counters命令显示信息描述表
捆绑链路接口的成员接口的相关信息
Index
阈值告警组的编号
Checked element
监测的对象
Lower threshold
阈值告警范围的最低阈值
Upper threshold
阈值告警范围的最高阈值
Action type
告警类型
Checked objects
已监测的样本个数
超出阈值的样本个数
·     reaction checked-element two-way-delay
·     reaction checked-element two-way-loss
·     reaction checked-element two-way-jitter
display nqa y1564 group命令用来显示NQA Y.1564操作组信息。
display nqa y1564 group [ brief | name group-name ]
brief:显示NQA Y.1564操作组的简要信息。
name group-name:显示NQA Y.1564操作组的详细信息,group-name表示NQA Y.1564操作组名称,为1~32个字符的字符串,不区分大小写。
不指定任何参数,则表示显示所有NQA Y.1564操作组的详细信息。
# 显示NQA Y.1564操作组的简要信息。
<Sysname> display nqa y1564 group brief
Group name                        Status
test1                             Active
test2                             Idle
# 显示名称为test的NQA Y.1564操作组的详细信息。
<Sysname> display nqa y1564 group name test
Group name: test
Status: Idle
  y1564                             1
  y1564                             2
表1-16 display nqa group命令显示信息描述表
Group name
NQA Y.1564操作组的名称
Status
测试状态:
·     Idle:空闲
·     Active:正在测试中
Admin-name
NQA测试组的管理员名称
Operation-tag
NQA测试操作的标签
·     nqa y1564 group
exchange-port enable命令用来开启源目的端口的交换功能。
undo exchange-port enable命令用来恢复缺省情况。
源目的端口的交换功能处于关闭状态。
缺省情况下,设备Frame-loss/Latency/Throughput/Y.1564测试类型发送的报文源目的端口在NQA服务器端会直接被反射回来,客户端可以直接解析。而开启了源目的端口的交换功能(nqa reflector命令的exchange-port开启)的NQA服务器,会将源目的端口互换之后再反射回客户端。配置本命令是为了使客户端能够解析被互换了源目的端口号的探测报文。
# 开启源目的端口的交换功能。
[Sysname-nqa-admin-test-throughput] exchange-port enable
1.1.32  expect data
expect data命令用来配置期望的应答内容。
undo expect data命令用来恢复缺省情况。
expect data expression [ offset number ]
undo expect data
未配置期望的应答内容。
HTTP/HTTPS/TCP/UDP类型的NQA模板视图
expression:期望收到的应答内容,为1~200个字符的字符串,区分大小写。
offset number:所期望的内容在返回报文中的偏移量,取值范围为0~1000,缺省值为0。如果不指定本参数,则设备直接从返回报文的第一个字节开始匹配。
NQA客户端对于返回报文中期望的应答内容匹配方式如下:
·     如果未配置offset参数,则设备直接从返回报文的第一个字节开始匹配,若不匹配,继续从第二个字节开始匹配,以此类推;
·     如果配置了offset参数,则设备从返回报文偏移量之后的第一个字节开始匹配,若匹配失败,则忽略该偏移量,从返回报文的第一个字节开始匹配,若不匹配,继续从第二个字节开始匹配,以此类推。
无论使用以上哪种匹配方式,只要返回报文中包含期望收到的应答内容,则表示当前NQA目的端设备合法;否则为非法设备。
对于HTTP/HTTPS类型的NQA模板,仅当回应报文中存在Content-Length头域时,进行期望应答内容的检查,否则不做检查。
对于TCP类型的NQA模板,仅当data-fill和expect data命令都配置时,进行期望应答内容的检查,否则不做检查。
对于UDP类型的NQA模板:
·     仅当data-fill和expect data命令都配置时,进行期望应答内容的检查,否则不做检查。
·     由于UDP报文数据字段的前5个字节具有特定用途。缺省情况下,配置expect data后从第6个字节开始进行偏移检查。
# 在HTTP类型的NQA模板视图下配置期望的应答内容为welcome!。
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] expect data welcome!
1.1.33  expect ip
expect ip命令用来配置期望返回的IP地址。
undo expect ip命令用来恢复缺省情况。
expect ip ip-address
undo expect ip
未配置期望返回的IP地址。
DNS类型的NQA模板视图
ip-address:DNS探测期望返回的IP地址。
在DNS测试中,NQA客户端通过该命令配置的IP地址与DNS服务器通过域名解析出的IP地址进行比较,若相同,则证明目前测试的DNS服务器合法,否则为非法DNS服务器。
# 在DNS类型的NQA模板视图下配置期望返回的IP地址为1.1.1.1。
[Sysname] nqa template dns dnstplt
[Sysname-nqatplt-dns-dnstplt] expect ip 1.1.1.1
1.1.34  expect ipv6
expect ipv6命令用来配置期望返回的IPv6地址。
undo expect ipv6命令用来恢复缺省情况。
expect ipv6 ipv6-address
undo expect ipv6
未配置期望返回的IPv6地址。
DNS类型的NQA模板视图
ipv6-address:DNS探测期望返回的IPv6地址。
在DNS测试中,NQA客户端通过该命令配置的IPv6地址与DNS服务器通过域名解析出的IPv6地址进行比较,若相同,则证明目前测试的DNS服务器合法,否则为非法DNS服务器。
# 在DNS类型的NQA模板视图下配置期望返回的IPv6地址为1::1。
[Sysname-nqatplt-dns-dnstplt] expect ipv6 1::1
expect status命令用来配置期望的应答状态码。
undo expect status命令用来恢复缺省情况。
expect status status-list
undo expect status [ status-list ]
未配置期望的应答状态码。
HTTP/HTTPS类型的模板视图
status-list:状态码列表,即HTTP/HTTPS模板类型期望收到的状态码范围。表示方式为status-list = { status-num1 [ to status-num2 ] }&<1-10>,status-num取值范围为0~999,status-num2的值要大于或等于status-num1的值,&<1-10>表示前面的参数最多可以重复输入10次。
HTTP/HTTPS类型的NQA模板支持配置状态码。报文的状态码是由3位十进制数组成的字段,它包含服务器的状态信息,用户可以根据该状态码了解服务器的状态。状态码的第一位规定状态码的类型。
# 在HTTP类型的NQA模板视图下配置期望的应答状态码,允许状态码为200、300、400~500。
[Sysname-nqatplt-http-httptplt] expect status 200 300 400 to 500
1.1.36  filename
filename命令用来配置FTP服务器和客户端之间传送文件的文件名。
undo filename命令用来恢复缺省情况。
filename filename
undo filename
未配置FTP服务器和客户端之间传送文件的文件名。
FTP测试类型视图
FTP类型的NQA模板视图
filename:FTP服务器和客户端之间传送文件的文件名,为1~200个字符的字符串,字符串中不能包括“/”,不区分大小写。
# 在FTP测试类型下配置FTP服务器和客户端之间要传送文件的文件名为config.txt。
[Sysname-nqa-admin-test] type ftp
[Sysname-nqa-admin-test-ftp] filename config.txt
# 在FTP类型的NQA模板视图下配置FTP服务器和客户端之间要传送文件的文件名为config.txt。
[Sysname] nqa template ftp ftptplt
[Sysname-nqatplt-ftp-ftptplt] filename config.txt
1.1.37  frame-size
frame-size命令用来配置探测报文的长度。
undo frame-size命令用来恢复缺省情况。
frame-size size&<1-7>
undo frame-size [ size&<1-7> ]
对于Y.1564测试类型,探测报文的大小为512字节;对于Frame-loss/Latency/Throughput测试类型,探测报文的大小为1518字节。
size&<1-7>:报文长度列表。其中,size为探测报文长度的取值,取值范围为64~9600,单位为字节。&<1-7>表示前面的参数最多可以输入7次。
在Frame-loss、Latency和Throughput测试中,一次探测是在一个探测周期内使用一种探测报文连续发送,一次测试可以配置一种或多种长度的探测报文。当前一种探测报文结束探测后,另一种探测报文开始下一次探测。
在某些网络环境下,业务流量报文的最小长度可能比frame-size命令能配置的最小探测报文长度要大,可能导致无法发送探测报文,可以尝试配置更大的探测报文长度。
多次配置本命令时,最后一次的配置将覆盖之前的配置。
# 在Throughput测试类型下配置探测报文大小列表为64、512、1024、1280。
[Sysname-nqa-admin-test-throughput] frame-size 64 512 1024 1280
# 在Y.1564类型的NQA测试类型视图下配置探测报文的大小为1024字节。
[Sysname-nqa-admin-test-y1564] frame-size 1024
1.1.38  frequency
frequency命令用来配置测试组连续两次测试开始时间的时间间隔。
undo frequency命令用来恢复缺省情况。
frequency interval
undo frequency
在NQA测试类型视图下,Voice、Path-jitter测试中连续两次测试开始时间的时间间隔为60000毫秒;其他类型的测试中连续两次测试开始时间的时间间隔为0毫秒,即只进行一次测试。
在NQA模板视图下,测试中连续两次测试开始时间的时间间隔为5000毫秒。
DHCP/DLSw/DNS/FTP/HTTP/SNMP测试类型视图
UDP-tracert测试类型视图
任意类型的NQA模板视图
interval:连续两次测试开始时间的时间间隔,取值范围为0~604800000,单位为毫秒。时间间隔为0,表示两次测试的时间间隔为无穷,即只进行一次测试,此时不会生成统计结果。
通过nqa schedule命令启动NQA测试组后,每隔interval时间启动一次测试。
到达本命令指定的时间间隔时,将开始下一个间隔的计时,但如果此时测试尚未完成或者测试未超时,则不启动新一轮测试,直到测试完成或者测试超时,才开始新一轮测试。
# 在ICMP-echo测试类型下配置连续两次测试开始时间的时间间隔为1000毫秒。
[Sysname-nqa-admin-test-icmp-echo] frequency 1000
# 在DNS类型的NQA模板视图下配置连续两次测试开始时间的时间间隔为1000毫秒。
[Sysname-nqatplt-dns-dnstplt] frequency 1000
·     probe timeout
1.1.39  hex-data-fill
hex-data-fill命令用来配置探测报文十六进制的填充字符串。
undo hex-data-fill命令用来恢复缺省情况。
hex-data-fill hex
undo hex-data-fill
hex:探测报文的填充内容,为2~200个字符的十六进制字符串,字符串长度必须是偶数位,不区分大小写。
实际填充的字符与填充数据长度有关:
·     如果探测报文的数据段长度比配置的填充数据长度小,系统在报文封装时以报文的数据段长度为界截取该字符串的前一部分;
·     如果探测报文的数据段长度比配置的填充数据长度大,系统在报文封装时用该字符串进行循环填充,直到填满。
例如,配置填充数据为十六进制字符串“aa”,当探测报文数据段长度为1字节时,(两个十六进制数占一个字节),则取“aa”作为填充数据;当探测报文大小为6字节时,则使用“aaaaaaaaaaaa”作为填充数据。
本命令与data-fill命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在TWAMP-light测试的Client-session视图下配置探测报文十六进制的填充字符串为aa。
[Sysname-nqa-twamp-light-client-session1] hex-data-fill aa
·     data-fill
1.1.40  high-performance-mode
high-performance-mode enable命令用来开启UDP-jitter测试的高性能模式。
undo high-performance-mode enable命令用来关闭UDP-jitter测试的高性能模式。
UDP-jitter测试的高性能模式处于关闭状态。
UDP-jitter测试类型视图
配置本命令后,UDP-jitter测试将开启高性能模式,该模式下UDP-jitter测试的测试效率和测试结果的精确度将大大提升。
开启高性能模式后,命令route-option bypass-route、reaction checked-element { jitter-ds | jitter-sd } threshold-type accumulate、reaction checked-element rtt threshold-type accumulate将不再生效。
# 开启UDP-jitter测试的高性能模式。
[Sysname-nqa-admin-test] type udp-jitter
[Sysname-nqa-admin-test-udp-jitter] high-performance-mode enable
1.1.41  history-record enable
history-record enable命令用来开启NQA测试组的历史记录保存功能。
undo history-record enable命令用来关闭NQA测试组的历史记录保存功能。
UDP-tracert测试类型的历史记录保存功能处于开启状态,其他类型的NQA测试组的历史记录保存功能处于关闭状态。
UDP-tracert测试类型视图
如果开启NQA测试组的历史记录保存功能,则系统会记录该NQA测试组的历史信息,通过display nqa history命令可以查看该测试组的历史记录信息。
如果关闭NQA测试组的历史记录保存功能,则系统不会记录该测试组的历史信息,原有的历史记录信息也会被删除。
# 在ICMP-echo测试类型下开启NQA测试组的历史记录保存功能。
[Sysname-nqa-admin-test-icmp-echo] history-record enable
·     display nqa history
1.1.42  history-record keep-time
history-record keep-time命令用来配置NQA测试组中历史记录的保存时间。
undo history-record keep-time命令用来恢复缺省情况。
history-record keep-time keep-time
NQA测试组中历史记录的保存时间为120分钟。
UDP-tracert测试类型视图
keep-time:历史记录的保存时间,取值范围为1~1440,单位为分钟。
NQA测试结束后,开始计算该测试组中所有历史记录的保存时间。保存时间达到配置的值后,将删除这些记录。
# 在ICMP-echo测试类型下配置NQA测试组中历史记录的保存时间为100分钟。
[Sysname-nqa-admin-test-icmp-echo] history-record keep-time 100
1.1.43  history-record number
history-record number命令用来配置在一个测试组中能够保存的最大历史记录个数。
undo history-record number命令用来恢复缺省情况。
history-record number number
一个测试组中能够保存的最大历史记录个数为50。
UDP-tracert测试类型视图
number:在一个测试组中能够保存的最大历史记录个数,取值范围为0~50。
如果一个测试组中历史记录个数超过设定的最大数目,则最早的历史记录将会被删除。
# 在ICMP-echo测试类型下配置一个测试组中能够保存的最大历史记录数为10个。
[Sysname-nqa-admin-test-icmp-echo] history-record number 10
1.1.44  icmp-jitter-mode
icmp-jitter-mode命令用来指定ICMP-jitter测试使用的报文类型。
undo icmp-jitter-mode命令用来恢复缺省情况。
icmp-jitter-mode { icmp-echo | icmp-timestamp }
ICMP-jitter测试模式的类型为icmp-timestamp。
ICMP-jitter测试类型视图
icmp-echo:指定ICMP-jitter测试使用ICMP echo报文进行测试。
icmp-timestamp:指定ICMP-jitter测试使用ICMP timestamp报文进行测试。
本命令仅对未开始的测试生效,且多次配置本命令,最新配置生效。
只有在IPv4 ICMP jitter测试场景下才支持配置icmp-jitter-mode。
# 在ICMP-jitter测试类型下配置测试模式为icmp-echo。
[Sysname] nqa entry admin test1
[Sysname-nqa-admin-test1] type icmp-jitter
[Sysname-nqa-admin-test1-icmp-jitter] icmp-jitter-mode icmp-echo
1.1.45  init-ttl
init-ttl命令用来配置UDP-tracert探测报文的初始跳数。
undo init-ttl命令用来恢复缺省情况。
init-ttl value
undo init-ttl
UDP-tracert探测报文的初始跳数为1。
UDP-tracert测试类型视图
value:UDP-tracert探测报文的初始跳数,取值范围1~255。
# 在UDP-tracert测试类型下配置UDP-tracert探测报文的初始跳数为5跳。
[Sysname-nqa-admin-test-udp-tracert] init-ttl 5
1.1.46  key
key命令用来设置RADIUS认证使用的共享密钥。
undo key命令用来恢复缺省情况。
key { cipher | simple } string
undo key
未设置RADIUS认证使用的共享密钥。
RADIUS类型的NQA模板视图
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~64个字符的字符串,密文密钥为1~117个字符的字符串。
必须保证设备上设置的共享密钥与RADIUS服务器上的完全一致。
# 在RADIUS类型的NQA模板视图下设置RADIUS认证使用的共享密钥为明文abc。
[Sysname] nqa template radius radiustplt
[Sysname-nqatplt-radius-radiustplt] key simple abc
1.1.47  link-bundle-interface
link-bundle-interface命令用来开启聚合接口的所有成员口TWAMP-light测试功能。
undo link-bundle-interface命令用来关闭聚合接口的所有成员口TWAMP-light测试功能。
link-bundle-interface interface-type interface-number
聚合接口的所有成员口TWAMP-light测试功能处于关闭状态。
interface-type interface-number:接口类型和接口编号。目前仅支持三层聚合接口和三层聚合子接口。
本命令指定的接口必须处于UP状态,否则探测将会失败。
缺省情况下,如果TWAMP-light测试报文的出接口是个三层聚合接口或三层聚合子接口,则设备会自动选择聚合接口的一个成员口,在该成员口链路上进行测试,用该成员口链路的测试结果表示聚合口链路的质量。配置本命令后,设备会在聚合接口的所有成员口上进行TWAMP-light测试,测试结果为每个成员口链路的质量。
在TWAMP-light客户端和TWAMP-light服务端,聚合接口的所有成员口TWAMP-light测试功能的开启状态必须一致,否则,可能导致TWAMP-light测试失败或者测试数据不准确。
# 开启聚合接口Route-Aggregation 1的所有成员口TWAMP-light测试功能。
[Sysname] nqa twamp-light client
[Sysname-nqa-twamp-light-client] test-session 1
[Sysname-nqa-twamp-light-client-session1] link-bundle-interface route-aggregation 1
1.1.48  lsr-path
lsr-path命令用来配置松散路由。
undo lsr-path命令用来恢复缺省情况。
lsr-path ip-address&<1-8>
undo lsr-path
未配置松散路由。
Path-jitter测试类型视图
ip-address&<1-8>:松散路由IP地址,&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
通过本命令配置松散路由,用户只需给出NQA探测报文必须经过的一些“节点”,并不需要给出一条完备的路径,无直接连接的“节点”之间的路由需要路由器寻址功能补充。
Path-jitter测试中,NQA客户端通过tracert过程使用该命令配置的松散路由进行探路,并根据收到ICMP报文计算主要“节点”时延和抖动时间。
# 在Path-jitter测试类型下配置松散路由为10.1.1.20和10.1.2.10两跳。
[Sysname-nqa-admin-test] type path-jitter
[Sysname-nqa-admin-test- path-jitter] lsr-path 10.1.1.20 10.1.2.10
1.1.49  mailbox
mailbox命令用来配置IMAP测试操作的邮箱名称。
undo mailbox命令用来恢复缺省情况。
mailbox mailbox-name
undo mailbox
IMAP测试操作的邮箱名称为INBOX。
IMAP类型的NQA模板视图
mailbox-name:IMAP探测使用的邮箱名称,为1~64个字符的字符串,区分大小写。
# 在IMAP类型的NQA模板视图下配置邮箱名称为fortest1。
[Sysname] nqa template imap imaptplt
[Sysname-nqatplt-imap-imaptplt] mailbox fortest1
1.1.50  max-failure
max-failure命令用来配置一次UDP-tracert测试中连续探测失败的最大次数。
undo max-failure命令用来恢复缺省情况。
max-failure times
undo max-failure
一次UDP-tracert测试中连续探测失败的最大次数为5。
UDP-tracert测试类型视图
times:表示一次UDP-tracert测试中连续探测失败的最大次数,取值范围0~255。0和255意味着UDP-tracert探测不会因为连续探测失败而停止测试。
当UDP-tracert测试中连续探测失败的次数达到指定的最大值时,设备认为测试失败并停止探测。
# 在UDP-tracert测试类型下配置一次UDP-tracert测试中连续探测失败的最大次数为20次。
[Sysname-nqa-admin-test-udp-tracert] max-failure 20
1.1.51  mode
mode命令用来配置FTP测试的数据传输方式。
undo mode命令用来恢复缺省情况。
mode { active | passive }
undo mode
FTP测试的数据传输方式为主动方式。
FTP测试类型视图
FTP类型的NQA模板视图
active:设置FTP的数据传输方式为主动方式。表示在建立数据连接时由服务器主动发起连接请求。
passive:设置FTP的数据传输方式为被动方式。表示在建立数据连接时由客户端主动发起连接请求。
# 在FTP测试类型下配置FTP测试的数据传输方式为被动方式。
[Sysname-nqa-admin-test-ftp] mode passive
# 在FTP类型的NQA模板视图下配置数据传输方式为被动方式。
[Sysname-nqatplt-ftp-ftptplt] mode passive
1.1.52  mpls-simulation enable
mpls-simulation enable命令用来开启UDP-jitter测试的MPLS模拟测试功能。
undo mpls-simulation enable命令用来恢复缺省情况。
mpls-simulation enable [ exp exp-value ]
UDP-jitter测试的MPLS模拟测试功能处于关闭状态。
UDP-jitter测试类型视图
exp exp-value:UDP-jitter探测报文的MPLS EXP优先级,取值范围为0~7,缺省值为0。
配置本命令后,UDP-jitter测试将会模拟发送MPLS报文进行测试,用于测试链路对于MPLS流量的服务质量。
如需测试MPLS流量的服务质量,必须开启UDP-jitter测试的高性能模式,且只能测试直连链路上MPLS流量的服务质量。请在直连链路的两端配置NQA客户端和服务器,并使用mpls enable命令开启接口的MPLS功能。有关mpls enable命令的详细介绍,请参见“MPLS命令参考”的“MPLS基础”。
# 开启UDP-jitter测试的MPLS模拟测试功能。
[Sysname-nqa-admin-test-udp-jitter] mpls-simulation enable exp 5
1.1.53  next-hop ip
next-hop ip命令用来配置探测报文的下一跳IP地址。
undo next-hop ip命令用来恢复缺省情况。
next-hop ip ip-address
undo next-hop ip
未配置探测报文的下一跳IP地址。
ICMP-echo测试类型视图
ICMP/TCP Half Open类型的NQA模板视图
ip-address:探测报文的下一跳IP地址。
配置本命令之后,设备按照指定的下一跳地址发送探测报文;若未配置本命令,则按照路由表缺省的转发规则发送探测报文。
# 在ICMP-echo测试类型下配置探测报文的下一跳IP地址为10.1.1.1。
[Sysname-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.1
1.1.54  next-hop ipv6
next-hop ipv6命令用来配置探测报文的下一跳IPv6地址。
undo next-hop ipv6命令用来恢复缺省情况。
next-hop ipv6 ipv6-address
undo next-hop ipv6
未配置探测报文的下一跳IPv6地址。
ICMP-echo测试类型视图
ipv6-address:探测报文的下一跳IPv6地址,不支持IPv6链路本地地址。
# 在ICMP-echo测试类型下配置探测报文的下一跳IPv6地址为10::1。
[Sysname-nqa-admin-test-icmp-echo] next-hop ipv6 10::1
1.1.55  no-fragment enable
no-fragment enable命令用来开启UDP-tracert探测类型的禁止报文分片功能。
undo no-fragment enable命令用来关闭UDP-tracert探测类型的禁止报文分片功能。
no-fragment enable
UDP-tracert测试类型的禁止报文分片功能处于关闭状态。
UDP-tracert测试类型视图
开启此功能后,设备发送的IP报文头部的DF(don't fragment)字段会被置一,这样报文在转发过程中将无法被分片。通过配置这条命令可以对一条链路的路径MTU值进行测试。
# 在UDP-tracert测试类型下开启UDP-tracert探测类型的禁止报文分片功能。
[Sysname-nqa-admin-test-udp-tracert] no-fragment enable
1.1.56  nqa
nqa命令用来创建NQA测试组,并进入NQA测试组视图。如果指定的NQA测试组视图已经存在,则直接进入NQA测试组视图。
undo nqa命令用来删除指定的NQA测试组。
nqa entry admin-name operation-tag
undo nqa { all | entry admin-name operation-tag }
不存在NQA测试组。
admin-name:创建NQA测试组的管理员名称,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
operation-tag:测试操作的标签,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
all:所有NQA测试组、模板和NQA操作组。
创建NQA测试组之后需要指定NQA测试类型,一个测试组只能配置一个测试类型,对于已配置测试类型的测试组,本命令将直接进入测试类型视图。
如果测试组与NQA操作组关联,那么必须先解除关联后才能删除该测试组,all参数无此限制。
# 创建一个管理员名为admin,测试操作标签为test的NQA测试组,并进入NQA测试组视图。
1.1.57  nqa agent enable
nqa agent enable命令用来开启NQA客户端功能。
undo nqa agent enable命令用来关闭NQA客户端功能,并停止所有正在进行的测试。
nqa agent enable
NQA客户端功能处于开启状态。
# 开启NQA客户端功能。
[Sysname] nqa agent enable
·     nqa server enable
1.1.58  nqa report-ftp
nqa report-ftp命令用来配置测试结果上传的FTP服务器信息。
undo report-ftp命令用来恢复缺省情况。
nqa report-ftp url url [ username username ] [ password { cipher | simple } string ]
undo nqa report-ftp
未配置测试结果上传的FTP服务器信息。
url:探测操作访问的FTP服务器地址,为1~255个字符的字符串,区分大小写。字符串中可以包含字母、数字、“-”及“_”,不能出现连续“.”。url格式为ftp://host或ftp://host:port。其中,host为主机名,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符;port为端口号,取值范围为0~65535。
username username:测试使用的用户名,用于登录FTP服务器,为1~32个字符的字符串,区分大小写。若不指定该参数,则表示用户名为空。
password:FTP用户的密码。若不指定该参数,则表示用户密码为空。
cipher:以密文方式设置密码。
simple:以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串。
路径服务质量测试和Y.1564测试类型支持测试结果上传的FTP服务器功能。
# 配置将NQA测试结果上传FTP服务器ftp://19.23.1.25,用户名为test,密码为明文123456。
[Sysname] nqa report-ftp url ftp://19.23.1.25 username test password simple 123456
1.1.59  nqa rfc2544 group
nqa rfc2544 group命令用来创建NQA路径服务质量操作组,并进入路径服务质量操作组视图。如果指定的路径服务质量操作组已经存在,则直接进入该路径服务质量操作组。
undo nqa rfc2544 group命令用来删除路径服务质量操作组及该操作组视图下所有配置。
nqa rfc2544 group group-name
undo nqa rfc2544 group group-name
不存在NQA路径服务质量操作组。
group-name:NQA路径服务质量操作组名称,为1~32个字符的字符串,不区分大小写。
NQA路径服务质量操作组用于关联路径服务质量测试组,在NQA服务质量操作组视图下,可同时启动/停止所有关联的路径服务质量测试。
如果路径服务质量测试组与NQA路径服务质量操作组相关联,那么必须先解除关联后才能删除该路径服务质量测试组。
# 创建一个名为test的NQA路径服务质量操作组,并进入NQA路径服务质量操作组视图。
[Sysname] nqa rfc2544 group test
[Sysname-nqa-rfc2544group-test]
1.1.60  nqa schedule
nqa schedule命令用来配置测试组的启动时间和持续时间。
undo nqa schedule命令用来停止指定测试组的测试。
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd | mm/dd/yyyy ] | now } lifetime { lifetime | forever } [ recurring ]
undo nqa schedule admin-name operation-tag
未配置NQA调度功能。
start-time:指定测试组的启动时间和日期。
hh:mm:ss:测试组的启动时间,小时:分钟:秒。
yyyy/mm/dd:测试组的启动日期,年:月:日,缺省值为系统的当前日期,年的取值范围为2000~2035。
mm/dd/yyyy:测试组的启动日期,月:日:年,缺省值为系统的当前日期,年的取值范围为2000~2035。
now:测试组立即开始测试。
lifetime:指定测试的持续时间。
lifetime:测试的持续时间,取值范围为1~2147483647,单位为秒。
forever:测试组将一直进行测试。
recurring:指定测试组每天都被调度运行。每天启动测试的时间由start-time参数指定。若不指定该参数,则测试组只在当天的指定时间内调度运行一次。
测试组被调度后不允许进入测试类型视图。若需要重新进入测试类型视图,请使用undo nqa schedule命令停止指定测试组的测试。(路径服务质量测试无此限制)
系统时间在启动时间~启动时间+持续时间范围内时,测试组进行测试。执行nqa schedule命令时,如果系统时间尚未到达启动时间,则到达启动时间后,启动测试;如果系统时间在启动时间~启动时间+持续时间之间,则立即启动测试;如果系统时间已经超过启动时间+持续时间,则不会启动测试。通过display clock命令可以显示系统的当前时间。
配置lifetime时间请保证一次测试能够完成,否则无法完成正常的联动操作。
路径服务质量测试和Y.1564测试不能使用本命令调度测试。
# 启动管理员名称为admin,标签为test的测试组进行测试,测试组的启动时间为2008年8月8日以后(包含当天)的每天的08:08:08,测试持续时间为1000秒。
[Sysname] nqa schedule admin test start-time 08:08:08 2008/08/08 lifetime 1000 recurring
·     destination ip
·     display clock(基础配置命令参考/设备管理)
·     nqa entry
·     type
1.1.61  nqa template
nqa template命令用来创建指定类型NQA模板,并进入NQA模板视图。如果指定的NQA模板视图已经存在,则直接进入NQA模板视图。
undo nqa template命令用来删除指定类型的NQA模板。
nqa template { arp | dns | ftp | http | https | icmp | imap | pop3 | radius | smtp | snmp | ssl | tcp | tcphalfopen | udp } name
undo nqa template { arp | dns | ftp | http | https | icmp | imap | pop3 | radius | smtp | snmp | ssl | tcp | tcphalfopen | udp } name
不存在NQA模板。
arp:配置ARP模板类型。
dns:配置DNS模板类型。
ftp:配置FTP模板类型。
http:配置HTTP模板类型。
https:配置HTTPS模板类型。
icmp:配置ICMP模板类型。
imap:配置IMAP模板类型。
pop3:配置POP3模板类型。
radius:配置RADIUS模板类型。
smtp:配置SMTP模板类型。
snmp:配置SNMP模板类型。
ssl:配置SSL模板类型。
tcp:配置TCP模板类型。
tcphalfopen:配置TCP Half Open模板类型。
udp:配置UDP模板类型。
# 创建一个类型为ICMP、名称为icmptplt的模板,并进入NQA模板视图。
1.1.62  nqa twamp-light client
nqa twamp-light client命令用来创建TWAMP-light Client,并进入TWAMP-light-client视图。如果TWAMP-light Client已经存在,则直接进入TWAMP-light-client视图。
undo nqa twamp-light client命令用来删除TWAMP-light Client。
不存在TWAMP-light Client。
双向主动测量协议TWAMP满足对复杂、多样化组网场景性能测量的需求。当使用NQA TWAMP-light统计业务时,需要执行nqa twamp-light client命令进入client视图,在TWAMP-light-client视图下可以创建TWAMP-light Client测试会话(Test session),然后基于这些会话启动相关统计业务。
执行undo nqa twamp-light client命令时,系统会删除TWAMP-light Client及其所有的会话和统计信息。
# 创建TWAMP-light Client,并进入TWAMP-light-client视图。
1.1.63  nqa twamp-light sender
nqa twamp-light sender命令用来创建TWAMP-light Sender,并进入TWAMP-light-sender视图。如果TWAMP-light Sender已经存在,则直接进入TWAMP-light-sender视图。
undo nqa twamp-light sender命令用来删除TWAMP-light Sender。
不存在TWAMP-light Sender。
在TWAMP-light-sender视图下可以控制TWAMP-light测试的启动和停止。
# 创建TWAMP-light Sender,并进入TWAMP-light Sender。
[Sysname] nqa twamp-light sender
[Sysname-nqa-twamp-light-sender]
1.1.64  nqa y1564 group
nqa y1564 group命令用来创建NQA Y.1564操作组,并进入NQA Y.1564操作组视图。如果指定的Y.1564操作组已存在,则直接进入该Y.1564操作组视图。
undo nqa y1564 group 命令用来删除NQA Y.1564操作组及该操作组视图下所有配置。
nqa y1564 group group-name
undo nqa y1564 group group-name
不存在NQA Y.1564操作组。
group-name:NQA Y.1564操作组名称,为1~32个字符的字符串,不区分大小写。
NQA Y.1564操作组用于关联Y.1564测试组,在NQA Y.1564操作组视图下,可同时启动/停止所有关联的Y.1564测试。
如果Y.1564测试组与NQA Y.1564操作组关联,那么必须先解除关联后才能删除该Y.1564测试组。
# 创建一个名为test的NQA Y.1564操作组,并进入NQA Y.1564操作组视图。
[Sysname] nqa y1564 group test
[Sysname-nqa-y1564group-test]
·     bind nqa-entry
·     start
·     stop
1.1.65  one-way delay-measure enable
one-way delay-measure enable命令用来开启当前TWAMP-light会话的单向时延统计功能。
undo one-way delay-measure enable命令用来关闭当前TWAMP-light会话的单向时延统计功能。
当前TWAMP-light会话的单向时延统计功能处于关闭状态。
开启TWAMP-light会话的单向时延统计功能后,对于新启动的测试会话,TWAMP-light在测量网络双向路径时延、抖动及丢包率的同时,会单独统计并记录TWAMP-light Client到TWAMP-light服务器、TWAMP-light服务器到TWAMP-light Client两个方向的时延和时延抖动。
执行one-way delay-measure global enable或one-way delay-measure enable命令均可以开启TWAMP-light会话的单向时延统计功能,one-way delay-measure global enable命令对TWAMP-light-client视图下所有新启动的测试会话生效,one-way delay-measure enable命令仅对当前测试会话生效。
# 开启局部单向时延统计功能。
[Sysname-nqa-twamp-light-client-session1] one-way delay-measure enable
·     one-way delay-measure global enable
1.1.66  one-way delay-measure global enable
one-way delay-measure global enable命令用来开启TWAMP-light全局单向时延统计功能。
undo one-way delay-measure global enable命令用来关闭TWAMP-light全局单向时延统计功能。
TWAMP-light全局单向时延统计功能处于关闭状态。
# 开启TWAMP-light全局单向时延统计功能。
[Sysname-nqa-twamp-light-client] one-way delay-measure global enable
·     one-way delay-measure enable
1.1.67  operation (FTP operation view)
operation命令用来配置FTP测试的操作方式。
undo operation命令用来恢复缺省情况。
operation { get | put }
undo operation
FTP测试的操作方式为get操作。
FTP测试类型视图
FTP类型的模板视图
get:从FTP服务器获取文件。
put:向FTP服务器传送文件。
进行put操作时,若配置了filename,发送数据前判断filename指定的文件是否存在,如果存在则上传该文件,如果不存在则探测失败。
进行get操作时,如果FTP服务器上没有以url中所配置的文件名为名称的文件,则测试不会成功。进行get操作时,设备上不会保存从服务器获取的文件。
进行get、put操作时,请选用较小的文件进行测试,如果文件较大,可能会因为超时而导致测试失败,或由于占用较多的网络带宽而影响其他业务。
# 在FTP测试类型下配置FTP测试的操作方式为put操作。
[Sysname-nqa-admin-test-ftp] operation put
# 在FTP类型的NQA模板视图下配置测试的操作方式为put操作。
[Sysname-nqatplt-ftp-ftptplt] operation put
·     password
·     username
1.1.68  operation (HTTP/HTTPS operation view)
operation命令用来配置HTTP/HTTPS测试的操作方式。
operation { get | post | raw }
undo operation
HTTP/HTTPS测试的操作方式为get操作。
HTTP测试类型视图
HTTP/HTTPS类型的NQA模板视图
get:从HTTP/HTTPS服务器获取数据。
post:向HTTP/HTTPS服务器提交数据。
raw:向HTTP/HTTPS服务器发送RAW请求报文。
HTTP/HTTPS测试中以HTTP/HTTPS请求报文作为探测报文。
测试的操作方式为get或post时,请求报文内容从url中获取。
测试的操作方式为raw时,请求报文为raw-request子视图中配置的内容。在配置HTTP/HTTPS操作方式中的raw操作可以通过在raw-request子视图中配置get、post或其他服务器支持的请求类型的HTTP/HTTPS报文,以此直接作为探测报文。请确保raw-request子视图中所配置报文内容的正确性。
# 在HTTP测试类型下配置HTTP测试的操作方式为raw操作。
[Sysname-nqa-admin-test] type http
[Sysname-nqa-admin-test-http] operation raw
# 在HTTP类型的NQA模板视图下配置测试的操作方式为raw操作。
[Sysname-nqatplt-http-httptplt] operation raw
·     password
·     raw-request
·     username
1.1.69  out interface
out interface命令用来指定探测报文的出接口。
undo out interface命令用来恢复缺省情况。
out interface interface-type interface-number
undo out interface
未指定探测报文的出接口。
ICMP-echo测试类型视图
DHCP测试类型视图
UDP-tracert测试类型视图
UDP-jitter测试类型视图
Frame-loss/Latency/Throughput/ Y.1564测试类型视图
interface-type interface-number:探测报文出接口的接口类型和接口编号。
该命令指定的接口必须处于UP状态,否则NQA探测过程将会失败。
对于ICMP-echo测试类型,如果配置next-hop命令,此配置不生效。
# 在UDP-tracert测试类型下配置接口Ten-GigabitEthernet3/1/1作为UDP-tracert探测报文出接口。
[Sysname-nqa-admin-test] type udp-tracert
[Sysname-nqa-admin-test-udp-tracert] out interface ten-gigabitethernet 3/1/1
1.1.70  password
password命令用来配置测试服务器的用户登录密码。
undo password命令用来恢复缺省情况。
undo password
未配置测试服务器的用户登录密码。
FTP/HTTP测试类型视图
FTP/HTTP/HTTPS/IMAP/POP3/RADIUS类型的NQA模板视图
cipher:以密文方式设置密码。
string:密码字符串,区分大小写。对于FTP/HTTP/HTTPS,明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串;对于RADIUS,明文密码为1~64个字符的字符串,密文密码为1~117个字符的字符串;对于IMAP/POP3,明文密码为1~40个字符的字符串,密文密码为1~85个字符的字符串。
# 在FTP测试类型下配置FTP服务器的用户登录密码为ftpuser。
[Sysname-nqa-admin-test-ftp] password simple ftpuser
# 在FTP类型的NQA模板视图下配置FTP服务器的用户登录密码为ftpuser。
[Sysname-nqatplt-ftp-ftptplt] password simple ftpuser
·     operation
·     username
1.1.71  performance-test enable
performance-test enable命令用来开启服务性能测试。
undo performance-test enable命令用来关闭服务性能测试。
performance-test enable [ duration duration ]
服务性能测试处于开启状态。
Y.1564测试类型视图
duration duration:服务性能测试的持续时间,duration表示测试持续时间,取值范围为1~1440,单位为分钟,缺省值为15分钟。
配置本命令后,Y.1564测试时将开启服务性能(Service Performance)测试,根据duration参数指定的测试持续时间,以承诺信息速率发送报文进行测试。
# 在Y.1564类型的NQA测试类型下开启服务性能测试。
[Sysname-nqa-admin-test] type y1564
[Sysname-nqa-admin-test-y1564] performance-test enable
·     bandwidth
1.1.72  pir-test enable
pir-test enable命令用来开启PIR测试。
undo pir-test enable命令用来关闭PIR测试。
pir-test enable [ duration duration ]
PIR测试处于开启状态。
Y.1564测试类型视图
duration duration:PIR测试的持续时间。duration表示测试持续时间,取值范围为1~60,单位为秒,缺省值为3秒。
配置本命令后,Y.1564测试时将开启PIR测试,根据设备是否开启颜色标记模式分为两种情况:
·     开启颜色标记模式时,以承诺信息速率为绿色报文发送速率,以峰值速率为黄色报文发送速率,同时发送报文进行测试。
·     未开启颜色标记模式时,以“承诺信息速率+峰值速率”开始测试。
# 在Y.1564类型的NQA测试类型下开启PIR测试。
[Sysname-nqa-admin-test-y1564] pir-test enable
·     bandwidth
·     color-aware-mode enable
1.1.73  priority 8021p
priority 8021p命令用来配置探测报文的802.1p优先级。
undo priority 8021p命令用来恢复缺省情况。
priority 8021p value
undo priority 8021p
探测报文的802.1p优先级为0。
Frame-loss/Latency/Throughput/Y.1564测试类型视图
value:探测报文的802.1p优先级,取值范围为0~7。
为了测试在二层网络环境下,对于业务流量拥塞的情况下设备根据报文不同的优先级给予不同的优先转发策略时,路径上对于该类流量的服务质量。此时使用本命令指定测试流量的优先级。
有关802.1p优先级的详细介绍,请参见“ACL和QoS配置指导”中的“QoS”。
# 配置时延测试探测报文的802.1p优先级为1。
[Sysname-nqa-admin-test] type latency
[Sysname-nqa-admin-test-latency] priority 8021p 1
1.1.74  probe count
probe count命令用来配置一次NQA测试中探测的次数。
undo probe count命令用来恢复缺省情况。
probe count times
undo probe count
对于UDP-tracert测试类型,对于一个TTL值的节点发送的探测报文次数为3次;其他类型的NQA测试一次NQA测试中的探测次数为1次。
ICMP-echo/TCP/UDP-echo测试类型视图
UDP-tracert测试类型视图
ICMP-jitter/UDP-jitter测试类型视图
times:对于UDP-tracert测试类型,表示对于一个TTL值的节点发送的探测报文次数,取值范围为1~10;对于其他测试类型,表示一次NQA测试中进行探测的次数,取值范围为1~15。
不同测试类型中,探测的含义不同:
·     对于TCP和DLSw测试,一次探测操作是指建立一次连接。
·     对于ICMP-jitter和UDP-jitter测试,一次探测操作是指连续发送多个探测报文,发送探测报文的个数由probe packet-number命令指定。
·     对于FTP、HTTP、DHCP和DNS测试,一次探测操作是指完成一次相应的功能,例如上传或下载一个文件,获取一个Web页面,为接口申请一个IP地址,将一个域名解析为IP地址。
·     对于ICMP-echo和UDP-echo测试,一次探测操作是指发送一个探测报文。
·     对于SNMP测试,一次探测操作是指发送三个SNMP协议报文,分别对应SNMP v1、SNMP v2c和SNMP v3三个版本。
·     对于UDP-tracert测试,一次探测操作是指一个特定TTL值的节点发送一个探测报文的操作。
对于UDP-tracert测试,同一个TTL的节点,设备会发送数量为probe count命令配置的探测报文,系统在进行第一次探测之后,等待回应;对于其他类型的测试,如果配置的次数大于1,那么系统在进行第一次探测之后,等待回应。如果到达probe timeout命令指定的探测超时时间时,仍然没有收到回应,则发起第二次探测。如此反复,直到完成指定次数的探测。
Voice和Path-jitter测试不支持该命令,一次测试中只能进行一次探测。
# 在ICMP-echo测试类型下配置一次ICMP-echo测试中探测的次数为10次。
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] probe count 10
1.1.75  probe duration
probe duration命令用来配置探测周期的时长。
undo probe duration命令用来恢复缺省情况。
probe duration time
undo probe duration
探测周期的时长为60秒。
Frame-loss/Latency/Throughput测试类型视图
time:探测周期的时长,取值范围为10~172800,单位为秒。
# 在Throughput测试类型下配置测试的探测周期为90秒。
[Sysname-nqa-admin-test] type throughput
[Sysname-nqa-admin-test-throughput] probe duration 90
1.1.76  probe interval
probe interval命令用来配置探测的时间间隔。
undo probe interval命令用来恢复缺省情况。
probe interval interval
undo probe interval
探测时间间隔为4秒。
interval:配置探测的时间间隔,取值范围为1~60,单位为秒。
在Frame-loss、Latency和Throughput测试中,一次探测是指在一个探测周期内连续发送多个探测报文。前一次探测结束到下一次探测开始之间的时间间隔为探测时间间隔。
# 在Throughput测试类型下配置探测时间间隔为30秒。
[Sysname-nqa-admin-test-throughput] probe interval 30
1.1.77  probe packet-interval
probe packet-interval命令用来配置发送探测报文的时间间隔。
undo probe packet-interval命令用来恢复缺省情况。
probe packet-interval interval
发送探测报文的时间间隔为20毫秒。
ICMP-jitter/Path-jitter/UDP-jitter/Voice测试类型视图
interval:测试中发送探测报文的时间间隔,取值范围为10~60000,单位为毫秒。
# 在UDP-jitter测试类型下配置测试中发送探测报文的时间间隔为100毫秒。
[Sysname-nqa-admin-test-udp-jitter] probe packet-interval 100
1.1.78  probe packet-number
probe packet-number命令用来配置一次探测中发送探测报文的个数。
undo probe packet-number命令用恢复缺省情况。
probe packet-number number
一次ICMP-jitter、UDP-jitter或Path-jitter探测中发送10个探测报文;一次Voice探测中发送1000个探测报文。
number:一次探测中发送探测报文的个数,对于ICMP-jitter、UDP-jitter和Path-jitter测试,取值范围为10~1000;对于Voice测试,取值范围为10~60000。
# 在UDP-jitter测试类型下配置一次探测中发送100个探测报文。
[Sysname-nqa-admin-test-udp-jitter] probe packet-number 100
1.1.79  probe packet-timeout
probe packet-timeout命令用来配置一次探测中等待响应报文的超时时间。
undo probe packet-timeout命令用来恢复缺省情况。
probe packet-timeout timeout
ICMP-jitter、UDP-jitter和Path-jitter测试中等待响应报文的超时时间为3000毫秒;Voice测试中等待响应报文的超时时间为5000毫秒。
timeout:一次探测中等待响应报文的超时时间,取值范围为10~3600000,单位为毫秒。
# 在UDP-jitter测试类型下配置一次探测中等待响应报文的超时时间为100毫秒。
[Sysname-nqa-admin-test-udp-jitter] probe packet-timeout 100
1.1.80  probe timeout
probe timeout命令用来配置探测的超时时间。
undo probe timeout命令用来恢复缺省情况。
probe timeout timeout
undo probe timeout
探测的超时时间为3000毫秒。
UDP-tracert测试类型视图
任意类型的NQA模板视图
timeout:一次探测的超时时间,单位为毫秒。在FTP、HTTP探测中,取值范围为10~86400000;在DHCP、DLSw、DNS、ICMP-echo、SNMP、TCP、UDP-echo和UDP-tracert探测中,取值范围为10~3600000;在Frame-loss/Latency/Throughput/Y.1564测试中,取值范围为10~60000。对于NQA模板类型来说,FTP、HTTP和HTTPS模板的范围为10~86400000,其他模板范围为10~3600000。
如果NQA探测没有在probe timeout命令指定的时间内完成,则认为本次探测超时。
# 在DHCP测试类型下配置探测的超时时间为10000毫秒。
[Sysname-nqa-admin-test] type dhcp
[Sysname-nqa-admin-test-dhcp] probe timeout 10000
# 在HTTP类型的NQA模板视图下配置探测的超时时间为10000毫秒。
[Sysname-nqatplt-http-httptplt] probe timeout 10000
1.1.81  raw-request
raw-request命令用来进入raw-request子视图,并在该子视图下配置HTTP/HTTPS测试请求报文内容。
undo raw-request命令用来恢复缺省情况。
raw-request
undo raw-request
未配置HTTP/HTTPS测试请求报文的内容。
HTTP测试类型视图
每次使用raw-request命令进入raw-request子视图时,之前在该子视图下配置的HTTP测试请求报文内容会被清除。
HTTP/HTTPS测试的操作方式为raw时,必须配置该命令。raw-request子视图下支持配置TEXT命令。TEXT命令为HTTP/HTTPS测试报文的内容,即HTTP/HTTPS的请求报文。要求报文内容中不能包含alias命令配置的别名,请用户自行确保报文的正确性,否则探测将失败。有关alias命令的详细介绍请参见“基础配置命令参考”中的“CLI”。
# 进入raw-request子视图,并在该子视图下配置HTTP测试GET操作的请求报文的内容。
[Sysname-nqa-admin-test-http] raw-request
[Sysname-nqa-admin-test-http-raw-request] GET /sdn/ui/app/index HTTP/1.0\r\nHost: 172.0.0.2\r\n\r\n
# 在HTTP类型的NQA模板视图下,进入raw-request子视图,并在该子视图下配置HTTP测试POST操作的请求报文的内容。
[Sysname-nqatplt-http-httptplt] raw-request
[Sysname-nqatplt-http-httptplt-raw-request] POST /sdn/ui/app/index HTTP/1.0\r\nHost:
 172.0.0.2\r\nAuthorization: Basic cm9vdDoxMjM0NTY=\r\n\r\n
1.1.82  reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { jitter-ds | jitter-sd }命令用来创建监测单向抖动时间的阈值告警组。
undo reaction命令用来删除指定的阈值告警组。
reaction item-number checked-element { jitter-ds | jitter-sd } threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
undo reaction item-number
不存在监测单向抖动时间的阈值告警组。
ICMP-jitter/UDP-jitter/Voice测试类型视图
item-number:阈值告警组编号,取值范围为1~10。
jitter-ds:监测从目的到源的单向抖动时间。
jitter-sd:监测从源到目的的单向抖动时间。
threshold-type:指定阈值类型。
accumulate accumulate-occurrences:每次测试中,累计的单向抖动时间超出阈值的报文个数。对于ICMP-jitter与UDP-jitter测试,取值为1~14999;对于Voice测试,取值范围为1~59999。
average:每次测试中,单向抖动时间的平均值。
threshold-value:指定阈值范围。
upper-threshold:阈值上限,取值范围为0~3600000,单位为毫秒。
lower-threshold:阈值下限,取值范围为0~3600000,且必须小于等于阈值上限,单位为毫秒。
action-type:触发的动作类型,缺省动作类型为none。
none:只在显示信息中记录监测结果,不向网管发送Trap消息。
trap-only:条件满足时,在显示信息中记录监测结果的同时,向网管发送Trap消息。
阈值告警组创建后,不能再通过reaction命令修改该阈值告警组的内容。若要修改阈值告警组的内容,则需要先通过undo reaction命令用来删除阈值告警组,再利用新的参数创建阈值告警组。
监测的对象是探测成功的报文,探测失败的报文不参与计数。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测UDP-jitter探测报文的从目的到源的单向抖动时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的平均单向抖动时间,若超出阈值,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element jitter-ds threshold-type average threshold-value 50 5 action-type trap-only
# 在UDP-jitter测试类型下创建编号为2的阈值告警组,监测UDP-jitter探测报文的从目的到源的单向抖动时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的单向抖动时间超出阈值的报文个数,若达到或超过100个,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 2 checked-element jitter-ds threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
1.1.83  reaction checked-element { owd-ds | owd-sd }
reaction checked-element { owd-ds | owd-sd }命令用来创建监测单向时延的阈值告警组。
reaction item-number checked-element { owd-ds | owd-sd } threshold-value upper-threshold lower-threshold
不存在监测单向时延的阈值告警组。
owd-ds:监测每个探测报文的从目的到源的单向时延。
owd-sd:监测每个探测报文的从源到目的的单向时延。
lower-threshold:阈值下限,取值范围为0~3600000,单位为毫秒,且必须小于等于阈值上限。
监测单向时延的阈值告警组不支持触发动作,但可以通过相关显示命令display nqa reaction counters和display nqa statistics显示当前的监测结果。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测每个UDP-jitter探测报文的从目的到源的单向时延,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。收到探测报文的应答报文后,计算该探测报文从目的到源的单向时延,若超出阈值范围,阈值状态置为over-threshold;反之,置为below-threshold。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element owd-ds threshold-value 50 5
1.1.84  reaction checked-element icpif
reaction checked-element icpif命令用来创建监测Voice测试ICPIF值的阈值告警组。
reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测Voice测试ICPIF值的阈值告警组。
Voice测试类型视图
upper-threshold:阈值上限,取值范围为1~100。
lower-threshold:阈值下限,取值范围为1~100,且必须小于等于阈值上限。
# 在Voice测试类型下创建编号为1的阈值告警组,监测每次Voice测试的ICPIF值,阈值上限为50,下限为5。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的ICPIF值,若超出阈值范围,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] reaction 1 checked-element icpif threshold-value 50 5 action-type trap-only
1.1.85  reaction checked-element mos
reaction checked-element mos命令用来创建监测Voice测试MOS值的阈值告警组。
reaction item-number checked-element mos threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测Voice测试MOS值的阈值告警组。
Voice测试类型视图
item-number:阈值告警组的编号,取值范围为1~10。
upper-threshold:阈值上限,取值范围为1~500。
lower-threshold:阈值下限,取值范围为1~500,且必须小于等于阈值上限。
实际的阈值下限(或阈值上限)为输入的阈值下限/100(或阈值上限/100),即如果输入的阈值下限和阈值上限分别为100、200,则MOS值在1~2之间时,未超出阈值。
# 在Voice测试类型下创建编号为1的阈值告警组,监测每次Voice测试的MOS值,阈值上限为200,下限为100。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的MOS值,若超出阈值范围,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-voice] reaction 1 checked-element mos threshold-value 200 100 action-type trap-only
1.1.86  reaction checked-element packet-loss
reaction checked-element packet-loss命令用来创建监测每次测试中丢包数的阈值告警组。
reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences [ action-type { none | trap-only } ]
不存在监测每次测试中丢包数的阈值告警组。
accumulate accumulate-occurrences:每次测试中,累计的丢包数。对于ICMP-jitter与UDP-jitter测试,取值范围为1~15000;对于Voice测试,取值范围为1~60000。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测每次UDP-jitter测试的丢包数。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的丢包数,若达到或超过100个,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element packet-loss threshold-type accumulate 100 action-type trap-only
1.1.87  reaction checked-element probe-duration
reaction checked-element probe-duration命令用来创建监测探测持续时间的阈值告警组。
reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测探测持续时间的阈值告警组。
accumulate accumulate-occurrences:每次测试中,累计的探测持续时间超出阈值的探测次数。accumulate-occurrences取值范围为1~15。
average:每次测试中,探测持续时间的平均值。
consecutive consecutive-occurrences:测试组启动后,连续的探测持续时间超出阈值的探测次数。consecutive-occurrences取值范围为1~16。
trap-only:条件满足时,在显示信息中记录监测结果的同时,向网管发送Trap消息。DNS测试不支持发送Trap,DNS测试类型视图下无此参数。
监测的对象是成功的探测,失败的探测不参与计数。
# 在ICMP-echo测试类型下创建编号为1的阈值告警组,监测ICMP-echo探测的持续时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的平均探测持续时间,若超出阈值,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-duration threshold-type average threshold-value 50 5 action-type trap-only
# 在ICMP-echo测试类型下创建编号为2的阈值告警组,监测ICMP-echo探测的持续时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的持续时间超出阈值的探测次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-duration threshold-type accumulate 10 threshold-value 50 5 action-type trap-only
# 在ICMP-echo测试类型下创建编号为3的阈值告警组,监测ICMP-echo探测的持续时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次探测结束后,检查测试组启动以来连续的持续时间超出阈值的探测次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 3 checked-element probe-duration threshold-type consecutive 10 threshold-value 50 5 action-type trap-only
1.1.88  reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail命令用来创建监测探测失败次数的阈值告警组。
reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } [ action-type { none | trap-only } ]
不存在监测探测失败次数的阈值告警组。
accumulate accumulate-occurrences:一次测试中,累计的探测失败次数。accumulate-occurrences取值范围为1~15。
consecutive consecutive-occurrences:NQA测试组启动以来,连续的探测失败次数。consecutive-occurrences取值范围为1~16。
trap-only:条件满足时,在显示信息中记录监测结果的同时,向网管发送Trap消息。DNS测试不支持发送trap,DNS测试类型视图下无此参数。
# 在ICMP-echo测试类型下创建编号为1的阈值告警组,监测ICMP-echo探测的失败次数。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的探测失败次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type accumulate 10 action-type trap-only
# 在ICMP-echo测试类型下创建编号为2的阈值告警组,监测ICMP-echo探测的失败次数。NQA测试组启动前,初始的阈值状态为invalid。每次探测结束后,检查测试组启动以来连续的探测失败次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-fail threshold-type consecutive 10 action-type trap-only
1.1.89  reaction checked-element probe-fail (for trigger)
reaction checked-element probe-fail命令用来建立联动项,对当前所在测试组中的探测进行监测,当连续探测失败次数达到阈值时,就触发其他模块联动。
undo reaction命令用来删除指定的联动项。
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only
不存在联动项。
item-number:联动项序号,取值范围为1~10。
threshold-type:指定门限类型。
consecutive consecutive-occurrences:NQA测试组启动以来连续的探测失败次数,取值范围为1~16。
action-type:触发的动作类型。
trigger-only:条件满足时,触发其它模块联动。
联动项创建后,不能再通过reaction命令修改该联动项的内容。若要修改联动项的内容,则需要先通过undo reaction命令用来删除联动项,再利用新的参数创建联动项。
# 在TCP测试类型下建立序号为1的联动项,连续探测失败3次,触发其他模块联动。
[Sysname-nqa-admin-test] type tcp
[Sysname-nqa-admin-test-tcp] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
·     track(可靠性命令参考/Track)
1.1.90  reaction checked-element rtt
reaction checked-element rtt命令用来创建监测报文往返时延的阈值告警组。
reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测报文往返时延的阈值告警组。
accumulate accumulate-occurrences:每次测试中,累计的RTT超出阈值的报文个数。对于ICMP-jitter与UDP-jitter测试,取值范围为1~15000;对于Voice测试,取值范围为1~60000。
average:每次测试中,报文往返时间的平均值。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测UDP-jitter探测报文的往返时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的平均报文往返时间,若超出阈值,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type average threshold-value 50 5 action-type trap-only
# 在UDP-jitter测试类型下创建编号为2的阈值告警组,监测每个UDP-jitter探测报文的往返时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的RTT超出阈值的报文个数,若达到或超过100个,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
1.1.91  reaction checked-element two-way-delay
reaction checked-element two-way-delay命令用来创建监测双向时延的阈值告警组。
reaction item-number checked-element two-way-delay threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测双向时延的阈值告警组。
Client-session视图
upper-threshold:上限阈值,取值范围是2~1000000,单位为微秒。
lower-threshold:下限阈值,取值范围是1~999999,且必须小于等于上限阈值,单位为微秒。
阈值告警组创建后,不能再通过reaction命令修改该阈值告警组的内容。若要修改阈值告警组的内容,则需要先通过undo reaction命令用来删除阈值告警组,再重新配置。
在监控时间内的测试结果均大于上限阈值或者从大于下限阈值恢复到小于下限阈值时,将触发告警。监控时间由start命令的monitor-time参数配置。
# 创建编号为1的阈值告警组,监测探测报文的从目的到源和从源到目的的双向时延,阈值上限为50毫秒,下限为5毫秒。
[Sysname-nqa-twamp-light-client-session1] reaction 1 checked-element two-way-delay threshold-value 50 5 action-type trap-only
·     start (TWAMP-light-sender view)
1.1.92  reaction checked-element two-way-jitter
reaction checked-element two-way-jitter命令用来创建监测双向抖动的阈值告警组。
reaction item-number checked-element two-way-jitter threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测双向抖动的阈值告警组。
Client-session视图
upper-threshold:上限阈值,取值范围2~1000000,单位为微秒。
lower-threshold:下限阈值,取值范围为1~999999,且必须小于等于上限阈值,单位为微秒。
# 创建编号为1的阈值告警组,监测探测报文的从目的到源和从源到目的的双向抖动时间,阈值上限为20毫秒,下限为3毫秒。
[Sysname-nqa-twamp-light-client-session1] reaction 1 checked-element two-way-jitter threshold-value 20 3 action-type trap-only
1.1.93  reaction checked-element two-way-loss
reaction checked-element two-way-loss命令用来创建监测双向丢包率的阈值告警组。
reaction item-number checked-element two-way-loss threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测双向丢包率的阈值告警组。
Client-session视图
upper-threshold:上限阈值,表示每1000000个包中设备可接受的丢包数,取值范围是2~1000000,单位为1/1000000。
lower-threshold:上限阈值,表示每1000000个包中设备可接受的丢包数,取值范围是1~999999,且必须小于等于上限阈值,单位为1/1000000。
# 创建编号为1的阈值告警组,监测探测报文的从目的到源和从源到目的的双向丢包率。阈值上限为1000,下限为500。
[Sysname-nqa-twamp-light-client-session1] reaction 1 checked-element two-way-loss threshold-value 1000 500 action-type trap-only
1.1.94  reaction trap
reaction trap命令用来配置在指定条件下向网管服务器发送Trap消息。
undo reaction trap命令用来恢复缺省情况。
reaction trap { path-change | probe-failure consecutive-probe-failures | test-complete | test-failure [ accumulate-probe-failures ] }
undo reaction trap { path-change | probe-failure | test-complete | test-failure }
不向网管服务器发送Trap消息。
UDP-tracert测试类型视图
path-change:当进行UDP-tracert类型测试时,在配置了frequency命令后进行连续测试后,如果检测到当前路径相对于上一次测试路径发生变化,则设备发送一次Trap消息。
probe-failure consecutive-probe-failures:每次探测结束后,计算本次NQA测试中探测连续失败的次数,如果连续失败次数大于或等于consecutive-probe-failures,则向网管服务器发送探测失败的Trap消息。一次测试中,可能发送多次Trap消息。consecutive-probe-failures为一次测试中连续探测失败的次数,取值范围为1~15。
test-complete:对于非UDP-tracert类型测试,当测试完成时发送测试完成的Trap消息。对于UDP-tracert类型测试,测试出到达目的设备的路径后,发送测试完成的Trap消息。
test-failure accumulate-probe-failures:对于非UDP-tracert类型测试,一次NQA测试结束后,计算本次NQA测试中探测失败的累计次数,如果累计失败次数大于或等于accumulate-probe-failures,则向网管服务器发送测试失败的Trap消息。accumulate-probe-failures为一次测试中累计探测失败的次数,为必须输入的参数,取值范围为1~15。对于UDP-tracert类型测试,只要未能测试出到达目的地的路径,就发送一次Trap消息。用户不能输入参数accumulate-probe-failures。
ICMP-jitter、UDP-jitter、Voice测试只支持reaction trap test-complete。
UDP-tracert测试不支持probe-failure和accumulate-probe-failures参数。
# 在ICMP-echo测试类型下配置测试中连续探测失败次数大于或等于5次时,发送探测失败的Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction trap probe-failure 5
1.1.95  reaction trigger per-probe
reaction trigger per-probe命令用来配置每次探测结果发送机制,即每次探测结束时都会将探测结果发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
undo reaction trigger per-probe命令用来恢复缺省情况。
连续探测成功或失败3次时,NQA客户端会把探测成功或失败的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
本命令与reaction trigger probe-fail命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
本命令与reaction trigger probe-pass命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP类型的NQA模板视图下配置每次探测结果发送机制,即每次探测结束时都会将探测结果发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] reaction trigger per-probe
·     reaction trigger probe-fail
·     reaction trigger probe-pass
1.1.96  reaction trigger probe-fail
reaction trigger probe-fail命令用来配置连续探测失败的次数。
undo reaction trigger probe-fail命令用来恢复缺省情况。
reaction trigger probe-fail count
连续探测失败3次时,NQA客户端会把探测失败的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
任意类型的NQA模板视图
count:连续探测失败的次数,取值范围为1~15。
当连续探测失败次数达到命令配置的数值时,NQA客户端会把探测失败的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
外部特性调用NQA模板后进行相应的NQA测试,使用此命令可以设定节点失效的连续测试失败次数。
本命令与reaction trigger per-probe命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在HTTP类型的NQA模板视图下配置确定节点失效需要连续探测失败5次。当连续探测失败的次数达到5次时,NQA客户端把探测失败的消息发送给外部特性,使外部特性能利用NQA测试的结果进行相应处理。
[Sysname-nqatplt-http-httptplt] reaction trigger probe-fail 5
·     reaction trigger per-probe
1.1.97  reaction trigger probe-pass
reaction trigger probe-pass命令用来配置连续探测成功次数。
undo reaction trigger probe-pass命令用来恢复缺省情况。
reaction trigger probe-pass count
连续探测成功3次时,NQA客户端会把探测成功的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
任意类型的NQA模板视图
count:连续探测成功的次数,取值范围为1~15。
当连续探测成功次数达到命令配置的数值时,NQA客户端会把探测成功的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
外部特性调用NQA模板后进行相应的NQA测试,使用此命令可以设定节点有效的连续探测成功次数。
# 在HTTP类型的NQA模板视图下配置确定节点有效需要连续探测成功5次。当连续探测成功的次数达到5次时,NQA客户端把探测成功的消息发送给外部特性,使外部特性能利用NQA测试的结果进行相应处理。
[Sysname-nqatplt-http-httptplt] reaction trigger probe-pass 5
1.1.98  reset nqa twamp-light statistics
reset nqa twamp-light statistics命令用来清除TWAMP-light测试会话的统计信息。
reset nqa twamp-light statistics { all | test-session session-id }
all:清除所有TWAMP-light测试会话的统计信息
test-session session-id:清除指定的TWAMP-light测试会话的统计信息。session-id表示测试会话的ID,取值范围为1~512。
TWAMP-light会话统计信息清除后将无法恢复。在执行reset twamp-light statistics命令前请确认是否进行清除。
# 清除所有TWAMP-light测试会话的统计信息。
<Sysname> reset nqa twamp-light statistics all
·     display nqa twamp-light client statistic
1.1.99  resolve-target
resolve-target命令用来配置要解析的域名。
undo resolve-target命令用来恢复缺省情况。
resolve-target domain-name
undo resolve-target
未配置要解析的域名。
DNS测试类型视图
DNS类型的NQA模板视图
domain-name:要解析的域名,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过255个字符,区分大小写。字符串中可以包含字母、数字、“-”及“_”,不能出现连续“.”。
# 在DNS测试类型下配置DNS测试要解析的域名为domain1。
[Sysname-nqa-admin-test] type dns
[Sysname-nqa-admin-test-dns] resolve-target domain1
# 在DNS类型的NQA模板视图下配置测试要解析的域名为domain1。
[Sysname-nqatplt-dns-dnstplt] resolve-target domain1
1.1.100  resolve-type
resolve-type命令用来配置域名解析类型。
undo resolve-type命令用来恢复缺省情况。
resolve-type { A | AAAA }
undo resolve-type
域名解析类型为A类型。
DNS测试类型视图
DNS类型的NQA模板视图
A:域名解析类型为A类型请求,即将域名解析为IPv4地址。
AAAA:域名解析类型为AAAA类型请求,即将域名解析为IPv6地址。
# 在DNS类型的NQA模板视图下,配置测试的域名解析类型为A。
[Sysname-nqa-admin-test-dns] resolve-type A
[Sysname-nqatplt-dns-dnstplt] resolve-type A
1.1.101  route-option bypass-route
route-option bypass-route命令用来开启路由表旁路功能,探测直连目的地的连通情况。
undo route-option bypass-route命令用来关闭路由表旁路功能。
路由表旁路功能处于关闭状态。
UDP-tracert测试类型视图
ICMP-jitte/UDP-jitter/Voice测试类型视图
开启该功能后,将不进行路由查找,而直接将报文发送到直连网络的目的地。
开启该功能后,设备转发探测报文可以经过的最大跳数为1,ttl命令设置的跳数不会生效。
测试目的端使用IPv6地址时,本命令配置无效。
# 在ICMP-echo测试类型下开启路由旁路功能。
[Sysname-nqa-admin-test-icmp-echo] route-option bypass-route
1.1.102  source interface (Frame-loss/Latency/Throughput/Y.1564 operation view and Client-session view)
source interface命令用来配置探测报文的源AC或源接口。
undo source interface命令用来恢复缺省情况。
source interface interface-type interface-number [ service-instance instance-id ]
未配置探测报文的源AC和源接口。
service-instance instance-id:以太网服务实例,二层以太网接口要通过以太网服务实例和源接口来获取源AC口。instance-id:以太网服务实例编号,取值范围为1~4096。有关以太网服务实例和AC口的详细介绍,请参见“MPLS配置指导”中的“VPLS”。
在二层VPN网络中进行的网络性能测试,执行本命令是通过将二层以太网接口和以太网服务实例相关联,生成在VPN网络中发送探测报文的源AC口。
在三层网络中进行测试时,执行本命令是将三层以太网接口作为探测报文的源接口。
执行本命令时,需要注意:
·     本命令指定的接口必须处于UP状态,否则探测将会失败。
·     本命令中指定的接口为二层接口时,必须通过service-instance instance-id参数指定以太网服务实例。
·     本命令中指定的接口为三层接口时:
¡     在MPLS L3VPN网络中,不需要配置service-instance参数。
¡     在MPLS L2VPN网络中,service-instance参数可选。该参数用于当指定的三层接口切换为二层接口时,不需要停止、修改、重启该测试,只需要修改MPLS L2VPN的相关配置即可,该测试即可继续运行。
# 在Throughput测试类型下指定探测报文的源AC口为Ten-GigabitEthernet3/1/1、以太网服务实例为1。
[Sysname-nqa-admin-test-throughput] source interface ten-gigabitethernet 3/1/1 service-instance 1
# 在TWAMP-light测试的Client-session视图下指定探测报文的源AC口为Ten-GigabitEthernet3/1/1、以太网服务实例为1。
[Sysname-nqa-twamp-light-client-session1] source interface ten-gigabitethernet 3/1/1 service-instance 1
·     source ip
1.1.103  source interface (ICMP-echo/UDP-tracert operation view)
source interface命令用来配置指定接口的IP地址作为探测报文的源IP地址。
以报文发送接口的主IP地址作为探测报文中的源IP地址。
ICMP-echo测试类型视图
UDP-tracert测试类型视图
ICMP类型的NQA模板视图
interface-type interface-number:探测报文源接口的接口类型和接口编号。
对于ICMP-echo测试类型及ICMP类型的NQA模板,本命令与source ip、source ipv6命令作用相同,多次执行这三条命令时,最后一次执行的命令生效;对于UDP-tracert测试类型,本命令与source ip命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP-echo测试类型下指定接口Ten-GigabitEthernet3/1/1的IP地址作为ICMP-echo探测报文的源IP地址。
[Sysname-nqa-admin-test-icmp-echo] source interface ten-gigabitethernet 3/1/1
# 在ICMP类型的NQA模板视图下指定接口Ten-GigabitEthernet3/1/1的IP地址作为ICMP-echo探测报文的源IP地址。
[Sysname-nqatplt-icmp-icmptplt] source interface ten-gigabitethernet 3/1/1
·     source ip
·     source ipv6
1.1.104  source ip
source ip命令用来配置探测报文的源IPv4地址。
undo source ip命令用来恢复缺省情况。
Y.1564测试类型:
source ip ipv4-address1 [ to ipv4-address2 ]
undo source ip
其他测试类型:
undo source ip
对于Frame-loss/Latency/Throughput/Y.1564测试类型和TWAMP-light测试,未配置测试操作中探测报文的源IPv4地址;对于其他测试类型,以报文发送接口的主IPv4地址作为探测报文中的源IPv4地址。
DHCP/DLSw/FTP/HTTP/SNMP测试类型视图
UDP-tracert测试类型视图
任意类型的NQA模板视图
ipv4-address:探测报文的源IPv4地址。
ipv4-address1 to ipv4-address2:指定探测报文的源IPv4地址范围。ipv4-address2的值要大于ipv4-address1的值。两个地址之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。
source ip命令配置的源IP地址必须是设备上接口的IPv4地址,且接口为UP状态,否则测试将会失败。对于Frame-loss/Latency/Throughput测试不存在这个限制。
对于NQA模板类型来说,当源地址类型和目的地址类型(IPv4或者IPv6)不一致时,以目的地址类型为准,进行该类型的报文探测,此时源地址的配置不生效。
对于ICMP-echo/UDP-tracert测试类型及ICMP类型的NQA模板,本命令和source interface命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
对于latency/frame-loss/throughput/y.1564探测类型,请按照以下要求配置源地址和目的地址,否则,会导致NQA测试启动失败:
·     二/三层以太网和二/三层VPN环境下必须配置源地址和目的地址。
·     其他组网环境下,源地址和目的地址要么均配置要么均不配置,如果配置,要求均为IPv4类型或者均为IPv6类型。
# 在ICMP-echo测试类型下配置ICMP-echo探测报文中的源IPv4地址为10.1.1.1。
[Sysname-nqa-admin-test-icmp-echo] source ip 10.1.1.1
# 在ICMP类型的NQA模板视图下配置探测报文中的源IPv4地址为10.1.1.1。
[Sysname-nqatplt-icmp-icmptplt] source ip 10.1.1.1
# 在TWAMP-light测试的Client-session视图下配置探测报文中的源IPv4地址为10.1.1.1。
[Sysname-nqa-twamp-light-client-session1] source ip 10.1.1.1
·     source interface
1.1.105  source ipv6
source ipv6命令用来配置探测报文的源IPv6地址。
undo source ipv6命令用来恢复缺省情况。
Y.1564测试类型:
source ipv6 ipv6-address1 [ to ipv6-address2 ]
undo source ipv6
其他测试类型:
undo source ipv6
对于Frame-loss/Latency/Throughput/Y.1564测试类型和TWAMP-light测试,未配置测试操作中探测报文的源IPv6地址;对于其他测试类型,以报文发送接口的IPv6地址作为探测报文中的源IPv6地址。
UDP-jitter测试类型视图
ICMP-jitter/DLSw/FTP/HTTP/SNMP/UDP-tracert/Path-jitter/Voice测试类型视图
DNS/FTP/HTTP/HTTPS/ICMP/IMAP/POP3/RADIUS/SMTP/SNMP/SSL/TCP/TCP Half Open/UDP类型的NQA模板视图
ipv6-address:探测报文的源IPv6地址,不支持IPv6链路本地地址。
ipv6-address1 to ipv6-address2:指定探测报文的源IPv6地址范围。ipv6-address2的值要大于ipv6-address1的值,两个地址之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。
source ipv6命令配置的源IPv6地址必须是设备上接口的IPv6地址,且接口为UP状态,否则测试将会失败。
对于NQA模板类型来说,当源地址类型和目的地址类型不一致时,以目的地址类型为准,进行该类型的报文探测,此时源地址的配置不生效。
对于ICMP-echo测试类型及ICMP类型的NQA模板,本命令和source interface命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP类型的NQA模板视图下配置探测报文中的源IPv6地址为1::1。
[Sysname-nqatplt-icmp-icmptplt] source ipv6 1::1
# 在TWAMP-light测试的Client-session视图下配置探测报文中的源IPv6地址为1::1。
[Sysname-nqa-twamp-light-client-session1] source ipv6 1::1
·     source interface
1.1.106  source mac
source mac命令用来配置探测报文的源MAC地址。
undo source mac命令用来恢复缺省情况。
source mac mac-address [ to mac-address1 ]
undo source mac
对于Frame-loss/Latency/Throughput/Y.1564测试类型,以报文发送接口的MAC地址作为探测报文的源MAC地址。
对于TWAMP-light测试,未配置探测报文的源MAC地址。
mac-address:探测报文的源MAC地址,格式为H-H-H。在配置时,可以省去MAC地址中每段开头的“0”,例如:输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
to mac-address1:指定探测报文的源MAC地址范围。mac-address1的值要大于mac-address的值。两个地址之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。仅Y.1564测试支持该参数。
# 在Y.1564类型的NQA测试类型下配置探测报文的源MAC地址为0001-0001-0001。
[Sysname-nqa-admin-test-y1564] source mac 1-1-1
# 在TWAMP-light测试的Client-session视图下配置探测报文的源MAC地址为0001-0001-0001。
[Sysname-nqa-twamp-light-client-session1] source mac 1-1-1
1.1.107  source port
source port命令用来配置探测报文的源端口号。
undo source port命令用来恢复缺省情况。
y.1564测试类型:
source port port-number1 [ to port-number2 ]
其他测试类型:
undo source port
对于Frame-loss/Latency/Throughput/Y.1564测试类型,探测报文的源端口号为49184;对于TWAMP-light测试类型,未配置源端口号;对于其它测试类型,系统自动选择设备当前空闲的端口号作为探测报文的源端口号。
UDP-echo测试类型视图
SNMP测试类型视图
UDP-tracert测试类型视图
DNS类型的NQA模板视图
port-number:探测报文的源端口号,取值范围为1~65535。
port-number1 to port-number2:指定探测报文的源端口号范围。port-number2的值要大于port-number1的值,两个端口号之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。
对于TWAMP-light测试类型,必须配置本命令;对于其它测试类型,建议使用缺省值即可。
如需配置本命令,要求指定的端口号不能是当前设备中其它服务正在使用的端口号,否则会导致探测失败。
·     通过display tcp和display udp命令显示信息中的Local Addr:port字段,可查看本端正在被使用的IPv4地址及端口号。
·     通过display ipv6 tcp和display ipv6 udp命令显示信息中的LAddr->port字段,可查看本端正在被使用的IPv6地址及端口号。
# 在UDP-echo测试类型下配置探测报文的源端口号为8000。
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] source port 8000
# 在DNS类型的NQA模板视图下配置探测报文的源端口号为8000。
[Sysname-nqatplt-dns-dnstplt] source port 8000
# 在TWAMP-light测试的Client-session视图下配置探测报文的源端口号为8000。
[Sysname-nqa-twamp-light-client-session1] source port 8000
·     display ipv6 tcp(三层技术-IP业务命令参考/IPv6基础)
·     display ipv6 udp(三层技术-IP业务命令参考/IPv6基础)
·     display tcp(三层技术-IP业务命令参考/IP性能优化)
·     display udp(三层技术-IP业务命令参考/IP性能优化)
1.1.108  speed granularity
speed granularity命令用来配置探测报文的速率调整精度。
undo speed granularity命令用来恢复缺省情况。
speed granularity value
速率调整精度为1000kbps。
Throughput测试类型视图
value:速率调整精度,取值范围为1~10000,单位为kbps。
当一个探测周期结束后,设备将以一定的精度调整发送速率,并以调整后的速率开始另一个探测周期。
# 在Throughput测试类型下配置发送速率调整精度为2000kbps。
[Sysname-nqa-admin-test-throughput] speed granularity 2000
1.1.109  speed init
speed init命令用来配置发送探测报文的初始速率。
undo speed init命令用来恢复缺省情况。
speed init init-speed
undo speed init
发送探测帧的初始速率100000kbps。
init-speed:初始发送速率,取值范围为1000~10000000,单位为kbps。
# 在Throughput测试类型下配置发送探测报文的初始速率为10000kbps。
[Sysname-nqa-admin-test-throughput] speed init 10000
1.1.110  ssl-client-policy
ssl-client-policy命令用来为HTTPS/SSL类型的NQA模板绑定SSL客户端策略。
undo ssl-client-policy命令用来恢复缺省情况。
ssl-client-policy policy-name
未绑定SSL客户端策略。
HTTPS/SSL类型的NQA模板视图
policy-name:SSL客户端策略名,为1~31个字符的字符串,不区分大小写。
通过绑定SSL客户端策略与服务器建立SSL连接,确认服务器业务的可用性。
# 在SSL类型的NQA模板视图下配置SSL客户端策略为policy。
[Sysname] nqa template ssl ssltplt
[Sysname-nqatplt-ssl-ssltplt] ssl-client-policy policy
1.1.111  start (Frame-loss/Latency/Throughput/Y.1564 operation view/Y.1564 group view/RFC2544 group view)
start命令用来启动丢包率、吞吐量、时延或Y.1564测试。
start
丢包率、吞吐量、时延和Y.1564测试未启动。
Y.1564操作组视图
RFC2544操作组视图
Frame-loss/Latency/Throughput/Y.1564测试进行时会占用测试的整个测试链路的带宽,为确保测试的准确性,请暂停该链路上的其他流量。
Frame-loss/Latency/Throughput/Y.1564测试与其他NQA测试互斥,并且一条链路上同时只能使用本命令开启一项Frame-loss/Latency/Throughput/Y.1564测试,开启之后将不能再使用本命令开启另一项Frame-loss/Latency/Throughput/Y.1564测试。对于Y.1564测试可以同时启动多个,但需要在关闭所有测试的前提下在Y.1564操作组视图启动。
# 在Throughput测试类型下启动Throughput测试。
[Sysname-nqa-admin-test-throughput] start
·     nqa y1564 group
·     stop (Frame-loss/Latency/Throughput/Y.1564 operation view/Y.1564 group view/RFC2544 group view)
1.1.112  start (TWAMP-light-sender view)
start命令用来启动TWAMP-light测试。
start test-session session-id { permanent | duration duration | packet-count count } [ tx-interval { 10 | 100 | 1000 | 10000 | 30000 } ] [ time-out timeout ] [ [ statistics-interval statistics-interval ] monitor-time time ]
TWAMP-light测试处于关闭状态。
test-session session-id:启动指定的TWAMP-light测试会话测试。session-id表示测试会话的ID,取值范围为1~512。
permanent:指定会话的TWAMP-light测试将一直进行测试。
duration duration:指定会话的TWAMP-light测试的持续时间,duration表示测试持续时间,取值范围为60~300,单位为秒。
packet-count count:指定会话的TWAMP-light测试的发送报文个数,count表示测试报文个数,取值范围100~30000。
tx-interval { 10 | 100 | 1000 | 10000 | 30000 }:指定报文发送周期,每个周期时间内发送一个报文。取值为10、100、1000、10000、30000,单位为ms,缺省值为100ms。
time-out timeout:指定统计周期内反射报文的超时时间,取值范围为1~10,单位为秒,缺省值为5。
statistics-interval interval:TWAMP-light测试的统计周期,每间隔周期时间统计一次报文收发的服务质量并上报统计结果。单位为毫秒,取值范围为1000~20000。统计周期必须是10ms的整数倍。本参数的缺省值与报文发送周期的取值有关,详情请参见表1-17。
monitor-time time:TWAMP-light测试的报文监控时间。取值范围为1000~86400000,单位为毫秒。监控时间必须是统计周期的整数倍。
TWAMP-light测试包括按需测试和连续测试两种方式。
·     按需测试是指有限的时间内为了诊断而由人工干预发起的性能检测,可以实现在诊断期间单次的性能检测。
会话在达到指定的时间间隔或者指定的发送报文数量后会自动停止统计。
·     连续测试是指连续、不间断发生的测试动作,直到使用stop (TWAMP-light-sender view)命令手工停止测试为止。
测试启动后,系统将持续监控探测结果,一旦出现不符合阈值的结果出现便启动监控时间计时,当在监控时间段内探测结果始终不符合阈值时,则打印日志并发送告警。不符合阈值的情况如下:
·     在监控时间段内的探测结果始终大于上限阈值。
·     探测结果从大于下限阈值恢复到小于下限阈值则开始计时,在监控时间段内的探测结果始终小于下限阈值。
其中监控时间与monitor-time参数的配置有关:
·     配置monitor-time参数时,会同时将丢包、时延和抖动监控时间配置为相同值。
·     不配置monitor-time参数时,丢包、时延和抖动的监控时间使用缺省值,缺省值与报文发送周期的取值有关,详情请参见表1-17。
阈值告警的上下限阈值由NQA TWAMP-light阈值告警功能配置。
如果同时启动多个TWAMP-light测试,那么每个测试会话指定的源IP、源端口、目的IP和目的端口四个参数不能均相同,否则多个测试匹配同一条流将影响测试结果。
如果配置了data-fill命令,则报文发送周期不允许配置为10ms和100ms。
如果配置了timestamp-format ntp命令,则报文发送周期不允许配置为10ms和100ms。
统计周期建议配置为大于等于报文发送周期,否则将出现上报的统计信息为空的情况。
统计周期和监控时间的缺省值和测试报文发送周期的取值有关,关系如表1-17所示:
表1-17 统计周期和监控时间缺省情况描述表
报文发送周期
统计周期缺省值
双向丢包监控时间缺省值
双向时延和双向抖动监控时间缺省值
10ms
2s
60s
2s
100ms
20s
60s
20s
1s
200s
200s
200s
10s
400s
400s
400s
30s
600s
600s
600s
# 启动TWAMP-light测试,并指定发送报文数量为3000个。
[Sysname-nqa-twamp-light-sender] start test-session 1 packet-count 3000
·     data-fill
·     stop (TWAMP-light-sender view)
1.1.113  statistics hold-time
statistics hold-time命令用来配置统计组的保留时间。
undo statistics hold-time命令用来恢复缺省情况。
statistics hold-time hold-time
统计组的保留时间为120分钟。
hold-time:统计组的保留时间,取值范围为1~1440,单位为分钟。
统计组具有老化功能。统计组保存一定时间后将被删除,以便记录新的统计组信息。
# 在ICMP-echo测试类型下配置统计组的保留时间为3分钟。
[Sysname-nqa-admin-test-icmp-echo] statistics hold-time 3
1.1.114  statistics interval
statistics interval命令用来配置对测试结果进行统计的时间间隔。
undo statistics interval命令用来恢复缺省情况。
statistics interval interval
对测试结果进行统计的时间间隔为60分钟。
interval:对测试结果进行统计的时间间隔,取值范围为1~35791394,单位为分钟。
NQA将统计时间间隔内完成的NQA测试归为一组,计算该组测试结果的统计值,这些统计值构成一个统计组。通过display nqa statistics命令可以显示该统计组的信息。
# 在ICMP-echo测试类型下配置对测试结果进行统计的时间间隔为2分钟。
[Sysname-nqa-admin-test-icmp-echo] statistics interval 2
1.1.115  statistics max-group
statistics max-group命令用来配置能够保留的最大统计组个数。
undo statistics max-group命令用来恢复缺省情况。
statistics max-group number
能够保留的最大统计组个数为2。
number:能够保留的最大统计组个数,取值范围为0~100。
当保留的统计组数目达到最大值时,如果形成新的统计组,保存时间最久的统计组将被删除。
能够保留的最大统计组个数为0时,不进行统计。
# 在ICMP-echo测试类型下配置能够保留的最大统计组个数为5。
[Sysname-nqa-admin-test-icmp-echo] statistics max-group 5
1.1.116  stop (Frame-loss/Latency/Throughput/Y.1564 operation view/Y.1564 group view/RFC2544 group view)
stop命令用来停止丢包率、吞吐量、时延或Y.1564测试。
stop
Y.1564操作组视图
RFC2544操作组视图
对于操作组内还未开始执行的探测,可以在测试组视图下执行本命令来停止该探测。对于操作组内正在执行的探测,不能在测试组视图下执行本命令来停止该探测,但是可以在操作组视图下执行本命令来停止执行操作组内所有的探测。
# 在Throughput测试类型下停止Throughput测试。
[Sysname-nqa-admin-test-throughput] stop
·     nqa y1564 group
·     start (Frame-loss/Latency/Throughput/Y.1564 operation view/Y.1564 group view/RFC2544 group view)
1.1.117  stop (TWAMP-light-sender view)
stop命令用来停止TWAMP-light测试。
stop { all | test-session session-id }
all:停止所有TWAMP-light测试会话的测试。
test-session session-id:停止TWAMP-light测试会话。session-id表示测试会话的编号,取值范围为1~512。
# 停止TWAMP-light测试会话1的测试。
[Sysname-nqa-twamp-light-sender] stop test-session 1
1.1.118  target-only
target-only命令用来配置Path-jitter测试中仅针对到达目的地址的完整路径进行探测,不逐跳进行探测。
undo target-only命令用来恢复缺省情况。
target-only
undo target-only
Path-jitter测试中会逐跳进行探测。
Path-jitter测试类型视图
# 在Path-jitter测试类型下配置仅针对到达目的地址的完整路径进行探测。
[Sysname-nqa-admin-test-path-jitter] target-only
1.1.119  test-session (TWAMP-light-client view)
test-session命令用来创建TWAMP-light Client端的测试会话,并进入Client-session视图。如果TWAMP-light Client端的测试会话已经存在,则直接进入Client-session视图。
undo test-session命令用来删除TWAMP-light Client端的测试会话。
undo test-session session-id
不存在TWAMP-light Client端的测试会话。
session-id:表示测试会话的ID。取值范围为1~512。
请创建TWAMP-light Client端的测试会话并完成会话相关参数的配置后,再通过nqa twamp-light sender命令进入TWAMP-light-sender视图启动TWAMP-light测试。
# 创建TWAMP-light Client端的测试会话1,并进入Client-session1视图。
1.1.120  test-session bind interface
test-session bind interface命令用来配置TWAMP-light测试会话的绑定出接口。
undo test-session bind interface命令用来取消TWAMP-light测试会话绑定出接口配置。
test-session session-id bind interface interface-type interface-number
undo test-session session-id bind interface [ interface-type interface-number ]
未配置TWAMP-light测试会话的绑定出接口。
interface-type interface-number:绑定出接口的接口类型和接口编号。不指定该参数时,表示所有接口。
配置本命令后,设备会将绑定出接口作为TWAMP-light测试报文的出接口,发送测试报文。所以,请将该接口配置为到达TWAMP-light服务器的路由出接口。
配置本命令会同时开启TWAMP-light模块和业务模块的联动功能:当TWAMP-light测量到有效统计数据时,会将时延信息(包括远端IP、最大时延、最小时延、平均时延)发布给其他业务模块(例如ISIS),配合其他业务模块完成相关功能。
只有当TWAMP-light配置连续探测,并且统计到有效的时延数据时,TWAMP-light才会将数据发布给其他业务模块。
一个TWAMP-light测试会话只能绑定一个接口。多次配置本命令,最新配置生效。
# 配置TWAMP-light测试会话的绑定出接口为Ten-GigabitEthernet3/1/1。
[Sysname-nqa-twamp-light-client] test-session 1 bind interface ten-gigabitethernet 3/1/1
1.1.121  timestamp-format
timestamp-format命令用来配置TWAMP-light测试探测报文的时间戳格式。
undo timestamp-format命令用来恢复缺省情况。
timestamp-format { ntp | ptp }
TWAMP-light测试的时间戳格式为PTP。
ntp:配置探测报文的时间戳格式为NTP。
ptp:配置探测报文的时间戳格式为PTP。
TWAMP-light测试的探测报文会携带时间戳,本命令用来配置测试时报文携带的时间戳封装格式。相比NTP时间戳格式,PTP时间戳格式可携带更高精度的时间,可使TWAMP-light测试结果更精确。
使用本命令时,如果设备未达到NTP或者PTP时间同步,或者TWAMP-light Sender端和Responder端使用的时间戳格式不同,设备都可以进行TWAMP-light测试,只是测试结果的精确度会有差异。
# 配置TWAMP-light测试的时间戳格式为NTP。
[Sysname-nqa-twamp-light-client-session1] timestamp-format ntp
1.1.122  tos
tos命令用来配置NQA探测报文IP报文头中服务类型域的值。
undo tos命令用来恢复缺省情况。
tos value
undo tos
NQA探测报文IP报文头中服务类型域的值为0。
任意测试类型视图
value:探测报文IP报文头中服务类型域的值,取值范围为0~255。
# 在ICMP-echo测试类型下配置探测报文IP报文头中服务类型域的值为1。
[Sysname-nqa-admin-test-icmp-echo] tos 1
# 在ICMP类型的NQA模板视图下配置探测报文IP报文头中服务类型域的值为1。
[Sysname-nqatplt-icmp-icmptplt] tos 1
1.1.123  traffic-policing-test enable
traffic-policing-test enable命令用来开启流量监管测试。
undo traffic-policing-test enable命令用来关闭流量监管测试。
traffic-policing-test enable [ duration duration ]
Traffic policing测试处于关闭状态。
Y.1564测试类型视图
duration duration:表示流量监管测试的持续时间,取值范围为1~60,单位为秒,缺省值为3秒。
配置本命令后,Y.1564测试时将开启流量监管(Traffic policing)测试,根据设备是否开启颜色标记模式分为两种情况:
·     开启颜色标记模式时,以承诺信息速率为绿色报文发送速率,以125%的峰值速率为黄色报文发送速率(若配置的PIR<20%*CIR,则黄色报文发送速率=25%*CIR+PIR),同时发送报文进行测试。
·     未开启颜色标记模式时,以CIR+125%*PIR作为报文发送速率(若配置的PIR<20%*CIR,则发送报文速率=125%*CIR+PIR),发送报文进行测试。
# 在Y.1564类型的NQA测试类型视图下使能流量监管测试。
[Sysname-nqa-admin-test-y1564] traffic-policing-test enable
·     bandwidth
1.1.124  ttl
ttl命令用来配置探测报文在网络中可以经过的最大跳数。
undo ttl命令用来恢复缺省情况。
ttl value
undo ttl
UDP-tracert类型探测报文在网络中可以经过的最大跳数是30跳。其它测试类型下探测报文在网络中可以经过的最大跳数为20跳。
UDP-tracert测试类型视图
value:对于UDP-tracert测试类型,表示允许探测报文填充的最大跳数值;对于其它测试类型,表示探测报文在网络中可以经过的最大跳数。取值范围为1~255。
配置route-option bypass-route命令后,探测报文在网络中可以经过的最大跳数为1,ttl命令不会生效。
配置UDP-tracert类型测试时,如果使用init-ttl命令配置的初始跳数值大于此值,测试将无法启动。
# 在ICMP-echo测试类型下配置探测报文在网络中可以经过的最大跳数为16跳。
[Sysname-nqa-admin-test-icmp-echo] ttl 16
# 在ICMP类型的NQA模板视图下配置探测报文在网络中可以经过的最大跳数为16跳。
[Sysname-nqatplt-icmp-icmptplt] ttl 16
1.1.125  type
type命令用来配置当前测试组的测试类型,并进入测试组测试类型视图。
type { dhcp | dlsw | dns | frame-loss | ftp | http | icmp-echo | icmp-jitter | latency | path-jitter | snmp | tcp | throughput | udp-echo | udp-jitter | udp-tracert | voice | y1564 }
未配置当前测试组的测试类型。
NQA测试组视图
dhcp:测试类型为DHCP。
dlsw:测试类型为DLSw。
dns:测试类型为DNS。
frame-loss:测试类型为Frame-loss。
ftp:测试类型为FTP。
http:测试类型为HTTP。
icmp-echo:测试类型为ICMP-echo。
icmp-jitter:测试类型为ICMP-jitter。
latency:测试类型为Latency。
path-jitter:测试类型为Path-jitter。
snmp:测试类型为SNMP。
tcp:测试类型为TCP。
throughput:测试类型为Throughput。
udp-echo:测试类型为UDP-echo。
udp-jitter:测试类型为UDP-jitter。
udp-tracert:测试类型为UDP-tracert。
voice:测试类型为Voice。
y1564:测试类型为Y.1564。
一个NQA测试组对应一个NQA测试类型。当进入NQA测试组视图后,需要指定测试类型并配置测试类型相应的属性。当NQA测试组指定了一个测试类型后,测试组将与测试类型绑定,若需要重新指定测试类型,请在系统视图下删除测试组之后重新创建测试组并指定测试类型。
# 配置测试组的测试类型为FTP测试,并进入测试组测试类型视图。
[Sysname-nqa-admin-test] type ftp
1.1.126  url
url命令用来配置测试访问的网址。
undo url命令用来恢复缺省情况。
url url
undo url
未配置测试访问的网址。
FTP/HTTP测试类型视图
FTP/HTTP/HTTPS类型的NQA模板视图
url:测试操作访问的目标资源地址,为1~255个字符的字符串,区分大小写。url中的主机名部分,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符,区分大小写;字符串中可以包含字母、数字、“-”及“_”,不能出现连续“.”。
filename取值范围的详细介绍,请参见“基础配置指导”中的“文件系统管理”。
HTTP测试类型时,url格式为http://host/resource或http://host:port/resource。如果host参数取值为一个IPv6地址,则IPv6地址外面需要添加[ ],例如http://[2001::1]/test。
HTTPS测试类型时,url格式为https://host/resource或https://host:port/resource。如果host参数取值为一个IPv6地址,则IPv6地址外面需要添加[ ],例如https://[2001::1]/test。
FTP测试类型时,url格式为ftp://host/filename或ftp://host:port/filename。如果host参数取值为一个IPv6地址,则IPv6地址外面需要添加[ ],例如ftp://[2001::1]/test。
# 在HTTP测试类型下配置HTTP测试访问的网址为http://www.company.com/index.html。
[Sysname-nqa-admin-test-http] url http://www.company.com/index.html
# 在HTTP类型的NQA模板视图下配置测试访问的网址为http://www.company.com/index.html。
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] url http://www.company.com/index.html
1.1.127  username
username命令用来配置登录用户名。
undo username命令用来恢复缺省情况。
username username
undo username
未配置登录用户名。
FTP/HTTP测试类型视图
username:测试使用的登录用户名,区分大小写。FTP、HTTP或HTTPS登录用户名,为1~32个字符的字符串;POP3或IMAP登录用户名,为1~40个字符的字符串,形如user1@test.com;RADIUS用户名,为1~253个字符的字符串。
# 在FTP测试类型下配置FTP登录用户名为administrator。
[Sysname-nqa-admin-test-ftp] username administrator
# 在FTP类型的NQA模板视图下配置FTP登录用户名为administrator。
[Sysname] nqa template ftp ftptplt
[Sysname-nqatplt-ftp-ftptplt] username administrator
·     operation
·     password
1.1.128  version
version命令用来配置HTTP/HTTPS测试所使用的版本。
undo version命令用来恢复缺省情况。
version { v1.0 | v1.1 }
undo version
HTTP/HTTPS测试所使用的版本为1.0。
HTTP测试类型视图
v1.0:测试使用的版本为1.0。
v1.1:测试使用的版本为1.1。
# 在HTTP测试类型下配置HTTP测试使用的版本为1.1。
[Sysname-nqa-admin-test-http] version v1.1
1.1.129  vlan
vlan命令用来配置探测报文的VLAN标签。
undo vlan命令用来恢复缺省情况。
Frame-loss/Latency/Throughput测试类型和TWAMP-light测试:
vlan { vlan-id | s-vid vlan-id c-vid vlan-id }
undo vlan
Y.1564测试类型:
vlan { vlan-id1 [ to vlan-id2 ] | s-vid vlan-id1 [ to vlan-id2 ] c-vid vlan-id1 [ to vlan-id2 ] }
undo vlan
未配置探测报文的VLAN标签。
vlan-id:探测报文所属的VLAN,取值范围为1~4094。
vlan-id1 to vlan-id2:探测报文所属的VLAN。其中vlan-id表示探测报文所属的VLAN,取值范围为1~4094。to表示指定VLAN的编号范围,vlan-id2的值要大于vlan-id1的值,且二者的差值不能超过127。
s-vid:匹配外层VLAN标签(Service VLAN ID)。
c-vid:匹配内层VLAN标签(Customer VLAN ID)。
配置该命令后探测报文将在指定的VLAN内发送。
当需要使用封装内外层VLAN标签的报文进行测试时,用户可根据需求来配置探测报文的内外层VLAN。
# 在Throughput测试类型下配置探测报文的所属的VLAN为VLAN 3。
[Sysname-nqa-admin-test-throughput] vlan 3
# 在TWAMP-light测试的Client-session视图下配置探测报文的所属VLAN为VLAN 3。
[Sysname-nqa-twamp-light-client-session1] vlan 3
1.1.130  vpn-instance
vpn-instance命令用来指定测试操作所属的VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
未指定测试操作所属的VPN,表示在公网中进行NQA测试。
DHCP/DLSw/DNS/FTP/HTTP/SNMP测试类型视图
UDP-tracert测试类型视图
任意类型的NQA模板视图
vpn-instance-name:表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
配置本命令后,NQA将在指定的VPN中进行测试。
# 在ICMP-echo测试类型下指定测试操作所属的VPN实例为vpn1。
[Sysname-nqa-admin-test-icmp-echo] vpn-instance vpn1
# 在FTP类型的NQA模板视图下指定测试操作所属的VPN实例为vpn1。
[Sysname-nqatplt-ftp-ftptplt] vpn-instance vpn1
1.2  NQA服务器端命令
只有在测试类型为UDP-jitter、TCP、UDP-echo和Voice时,才需要配置NQA服务器。
1.2.1  adjust-udp-checksum global enable (TWAMP-light-responder view)
adjust-udp-checksum global enable命令用来全局开启测试报文中校验和字段调整功能。
undo adjust-udp-checksum global enable命令用来全局关闭测试报文测试报文中校验和字段调整功能。
测试报文中校验和字段调整功能处于全局关闭状态。
TWAMP-light-responder视图
缺省情况下,TWAMP-light测试报文中校验和字段的值为0。配置本命令后,TWAMP-light会将实际计算的校验和值填入测试报文的校验和字段。不同TWAMP-light反射端对该字段取值的要求不同。如果设备连接的TWAMP-light反射端对该字段的取值有严格要求,请开启测试会话的校验和字段调整功能。
用户可以使用以下任意一种方式来开启测试会话的校验和字段调整功能:
·     全局开启该功能:该方式配置的测试报文校验和字段调整功能对TWAMP-light-responder视图下所有未创建的会话生效,不会影响当前正在进行的测试会话。
·     test-session (TWAMP-light-responder view)命令中开启该功能:该方式配置的测试报文校验和字段调整功能仅对当前即将开始的会话生效。
本功能仅对IPv6测试报文生效,对于IPv4测试报文不生效。
# 开启全局调整测试报文校验和的值功能。
[Sysname] nqa twamp-light responder
[Sysname-nqa-twamp-light-responder] adjust-udp-checksum global enable
1.2.2  display nqa reflector
display nqa reflector命令用来查看路径服务质量测试和Y.1564测试反射端的会话信息。
display nqa reflector [ reflector-id ]
reflector-id:反射端ID。取值范围为1~544。未指定本参数时,表示显示所有反射端的会话信息。
# 查看指定反射端的会话信息。
<Sysname> display nqa reflector 1
NQA server status:Enabled
Reflector ID                     : 1
  Status                         : Active
  Interface                      : XGE3/1/1
  Service instance               : -
  Destination IP                 : 1.1.1.2
  Destination IPv6               : -
  Source IP                      : 1.1.1.1
  Source IPv6                    : -
  Destination port               : 2010
  Source port                    : 2001
  Destination MAC                : -
  Source MAC                     : -
  VLAN ID                        : -
  Service VLAN ID                : -
  Customer VLAN ID               : -
  VPN instance                   : -
  Switch src/dst ports           : Enabled
表1-18 display nqa reflector命令显示信息描述表
NQA server status
NQA服务器状态,取值为:
·     Disabled:NQA服务器功能处于关闭状态
·     Enabled:NQA服务器功能处于开启状态
Reflector ID
反射端ID
Status
测试的工作状态,取值为:
·     Active:激活状态,表示NQA服务器的反射功能已开启
·     Inactive:未激活状态,表示NQA服务器的反射功能处于关闭状态
反射端口
Service instance
关联的以太网服务实例
Destination IP
待反射的报文的目的IPv4地址或IPv4地址范围
Destination IPv6
待反射的报文的目的IPv6地址或IPv6地址范围
Source IP
待反射的报文的源IPv4地址IPv4地址范围
Source IPv6
待反射的报文的源IPv6地址或IPv6地址范围
Destination port
待反射报文的UDP目的端口号或端口号范围
Source port
待反射报文的UDP源端口号或端口号范围
Destination MAC
待反射报文目的MAC地址或MAC地址范围
Source MAC
待反射报文源MAC地址或MAC地址范围
VLAN ID
‌待反射报文的VLAN ID或VLAN ID范围
Service VLAN ID
‌待反射报文的外层VLAN ID或VLAN ID范围
Customer VLAN ID
‌待反射报文的内层VLAN ID或VLAN ID范围
VPN instance
‌VPN实例名称
源目的端口交换功能的激活状态,取值为:
·     Enabled:源目的端口交换功能处于激活状态
·     Disabled:源目的端口交换功能处于未激活状态
1.2.3  display nqa server
display nqa server命令用来显示NQA服务器的状态信息。
display nqa server
# 显示NQA服务器的状态信息。
<Sysname> display nqa server
NQA server status: Enabled
TCP connect:
  IP address:2.2.2.2
  Port:2000
  ToS:200
  VPN instance:-
UDP echo:
  IP address:3.3.3.3
  Port:3000
  ToS:255
  VPN instance:-
  High performance mode: Enabled
表1-19 display nqa server命令输出信息描述
描述命令
NQA server status
NQA服务器状态,包括的取值如下:
TCP connect
NQA TCP测试中服务器的状态信息
UDP echo
NQA UDP测试中服务器的状态信息
IP address
NQA服务器TCP/UDP监听服务监听的IP地址
Port
NQA服务器TCP/UDP监听服务监听的端口号
ToS
NQA服务器TCP/UDP监听服务的回应报文携带的ToS值。未配置ToS参数时,本字段显示为-,但:
·     对于TCP监听服务,回应报文中实际携带的ToS值为0
·     对于UDP监听服务,回应报文中实际携带的ToS值为从客户端发送的请求报文中获取到的ToD值
VPN instance
NQA服务器监听的IP地址所属的VPN实例名称。如果NQA服务器监听的是公网IP地址,则显示为-
NQA服务器的高性能模式,包括的取值如下:
·     Disabled:未开启NQA服务器高性能模式
·     Enabled:开启了NQA服务器高性能模式
1.2.4  display nqa twamp-light responder
display nqa twamp-light responder命令用来显示TWAMP-light Responder端的会话信息。
display nqa twamp-light responder [ test-session session-id ]
test-session session-id:显示指定会话的信息。session-id表示会话ID,取值范围为1~512。未指定本参数时,表示显示所有会话的信息。
# 显示所有TWAMP-light Responder端的会话信息。
<Sysname> display nqa twamp-light responder
TWAMP-light:
Session ID                       : 1
  Status                         : Active
  Interface                      : -
  Destination IP                 : 1.1.1.1
  Source IP                      : 2.2.2.2
  Source IPv6                    : -
  Destination port               : 2001
  Source port                    : 2010
  VPN instance                   : -
  Destination MAC                : 0001-0001-0002
  Source MAC                     : 0001-0001-0001
  VLAN ID                        : -
  Service VLAN ID                : -
  Timestamp format               : PTP
  Description                    : -
  Adjust-udp-checksum            : Enabled
  Extended-packet                : Enabled
  Link bundle interface          : -
Session ID                       : 2
  Status                         : Active
  Interface                      : -
  Source IP                      : 3.3.3.3
  Source IPv6                    : -
  Source port                    : 2020
  VPN instance                   : -
  VLAN ID                        : -
  Service VLAN ID                : -
  Timestamp format               : NTP
  Description                    : -
  Adjust-udp-checksum            : Disabled
  Extended-packet                : Disabled
  Link bundle interface          : Route-Aggregation 1
    Member interface             : Ten-GigabitEthernet3/1/1
      Status                     : Active
    Member interface             : Ten-GigabitEthernet3/1/2
      Status                     : Active
表1-20 display nqa twamp-light responder命令显示信息描述表
NQA server status
NQA服务器状态,包括的取值如下:
TWAMP-light
NQA服务器上TWAMP-light功能的相关信息
Session ID
会话ID
Status
测试会话的工作状态,取值为:
·     Active:激活状态,表示测试会话的NQA服务器的TWAMP-light Responder的反射功能已被激活
·     Inactive:未激活状态,表示测试会话的NQA服务器的TWAMP-light Responder的反射功能未被激活
反射端口
Service instance
关联的以太网服务实例
Destination IP
待反射报文的目的IP地址
Destination IPv6
待反射报文的目的IPv6地址
Source IP
待反射报文的源IP地址
Source IPv6
待反射报文的源IPv6地址
Destination port
待反射报文的目的端口号
Source port
待反射报文的源端口号
VPN instance
MPLS L3VPN实例名称
Destination MAC
待反射报文的目的MAC地址
Source MAC
待反射报文的源MAC地址
VLAN ID
待反射报文的VLAN ID
Service VLAN ID
待反射报文的外层VLAN ID
Customer VLAN ID
待反射报文的内层VLAN ID
Timestamp format
时间戳格式,取值为:
·     AUTO:表示由TWAMP-light Responder自动决定使用的时间戳格式。如果用户未通过test-session命令指定时间戳格式,则使用AUTO格式
·     NTP:NTP格式
·     PTP:PTP格式
测试会话的描述信息
Adjust-udp-checksum
是否调整测试报文中校验和字段的值,取值为:
·     Enabled:调整为实际的校验和
·     Disabled:不调整,校验和字段取值为0
Extended-packet
是否扩展反射报文的报文头,取值为:
·     Enabled:当设备收到测试报文的长度(data-size)小于41字节时,设备会将反射报文的TWAMP报文头扩充成标准头长度
·     Disabled:当设备收到测试报文的长度(data-size)小于41字节时,设备直接根据收到的测试报文构建反射报文,不扩充TWAMP报文头,此时,可能会导致反射报文头部中缺少必要的参数,测试结果不准确
捆绑链路接口的名称,目前仅支持三层聚合接口和三层聚合子接口
取值为“-”时,表示当前接口为非捆绑链路接口
Member interface             :
  Status                     :
·     聚合成员口的名称
·     会话的状态:
¡     Active:表示测试会话的测试功能处于激活状态
¡     Inactive:表示测试会话的测试功能处于未激活状态
·     nqa reflector
1.2.5  nqa reflector
nqa reflector命令用来配置路径服务质量和Y.1564测试的反射参数。
undo nqa reflector命令用来删除路径服务质量和Y.1564测试的反射参数。
nqa reflector reflector-id interface interface-type interface-number [ service-instance instance-id ] [ { ip | ipv6 } { destination address1 [ to address2 ] | source address1 [ to address2 ] } * | destination-port port-number1 [ to port-number2 ] | source-port port-number1 [ to port-number2 ] | destination-mac mac-address1 [ to mac-address2 ] | source-mac mac-address1 [ to mac-address2 ] | vlan { vlan-id1 [ to vlan-id2 ] | s-vid vlan-id1 [ to vlan-id2 ] c-vid vlan-id1 [ to vlan-id2 ] } | exchange-port | vpn-instance vpn-instance-name ] *
undo nqa reflector { all | reflector-id [ { ip | ipv6 } { destination | source } | destination-port | source-port | destination-mac | source-mac | vlan | exchange-port | vpn-instance ] * }
未配置路径服务质量和Y.1564测试的反射参数。
reflector-id:反射会话ID,必须本地唯一。取值范围为1~544。
interface:反射报文的接口。
interface-type interface-number:反射报文的接口类型和接口编号。
service-instance instance-id:关联的以太网服务实例。instance-id为以太网实例编号,取值范围为1~4096。有关以太网服务实例的详细介绍,请参见“MPLS配置指导”中的“MPLS L2VPN”。
ip:表示后续将指定的IP地址为IPv4类型地址。
ipv6:表示后续将指定的IP地址为IPv6类型地址。
destination:待反射报文的目的地址。
source:待反射报文的源地址。
address1:指定IP地址。
to address2:指定IP地址的范围。address2的值要大于address1的值,两个地址之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。
destination-port:待反射报文的UDP目的端口号,缺省值为7。
source-port:待反射报文的UDP源端口号,缺省值为49185。
port-number1:指端口号,取值范围为1~65535。
to port-number2:指端口号的范围,取值范围为1~65535。port-number2的值要大于port-number1的值,并且范围起始值和结束值的差不能超过127。
destination-mac:待反射报文的目的MAC地址。若不指定本参数,则使用interface-type interface-number指定的接口MAC地址。不支持广播、组播和全0的MAC地址。
source-mac:待反射报文的源MAC地址。不支持广播、组播和全0的MAC地址。
mac-address1:指定MAC地址。
to mac-address2:指定MAC地址的范围。mac-address2的值要大于mac-address1的值。两个地址之间只能有一个字节存在差异,其余字节必须相同,并且范围起始值和结束值的差不能超过127。
vlan:待反射报文的VLAN或内外层VLAN标签。
vlan-id1:指定VLAN的编号,取值范围为1~4094。
to vlan-id2:指定VLAN的编号范围。vlan-id2为VLAN的编号,取值范围为1~4094。vlan-id2的值要大于vlan-id1的值,并且范围起始值和结束值的差不能超过127。
s-vid:外层VLAN标签(Service VLAN ID)。
c-vid:内层VLAN标签(Customer VLAN ID)。
exchange-port:将待反射报文的源和目的端口号交换并反射。配置本参数后客户端需要配置exchange-port enable命令开启源目的端口的交换功能。
vpn-instance vpn-instance-name:表示在指定VPN中进行测试。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定该参数时,表示在公网中进行测试。
all:关闭路径服务质量和Y.1564测试的所有反射功能。
路径服务质量和Y.1564测试必须在NQA服务器端配置本命令。配置该命令后,设备会根据配置的信息匹配对应接收到的探测报文并将其直接反射回客户端,节省了节点的处理时间。
配置该命令时,源IP地址、目的IP地址、源MAC地址、目的MAC地址、源端口、目的端口和内外层VLAN标签VLAN不能同时配置范围,最多只允许其中一个参数配范围值。其中路径服务质量测试不支持配置任何范围值。
一个反射会话ID只能指定一个反射接口和一个以太网服务实例,如需修改,必须通过undo nqa reflector命令删除该会话后重新指定。
不同反射会话可以指定同一个反射接口和以太网服务实例。
对于一个反射会话除反射接口和以太网服务实例外,其他参数均可以修改或删除,如果删除时不指定可选参数,则会直接删除这个会话。
本命令和l2vpn reflector命令在功能上相互影响,请不要同时配置,否则可能导致两个功能都无法正常运行。有关l2vpn reflector命令的详细介绍请参见“MPLS命令参考”的“MPLS L2VPN”。
# 在NQA服务器端配置路径服务质量和Y.1564测试的反射参数。
[Sysname] nqa reflector 1 interface ten-gigabitethernet 3/1/1 ip destination 2.2.2.2 source 1.1.1.1
1.2.6  nqa server enable
nqa server enable命令用来开启NQA服务器功能。
undo nqa server enable命令用来关闭NQA服务器功能。
nqa server enable
NQA服务器功能处于关闭状态。
# 开启NQA服务器功能。
[Sysname] nqa server enable
1.2.7  nqa server icmp-server
nqa server icmp-server命令用来在NQA服务器上配置ICMP反射参数。
undo nqa server icmp-server命令用来恢复缺省情况。
nqa server icmp-server { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ tos tos ]
undo nqa server icmp-server { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
NQA服务器上未配置ICMP反射参数。
ipv4-address:NQA服务器ICMP反射服务反射的IPv4地址。
ipv6-address:NQA服务器ICMP反射服务反射的IPv6地址。
vpn-instance vpn-instance-name:NQA服务器监听的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示ICMP反射的是公网IP地址。
tos tos:NQA服务器应答报文中的ToS域的值。取值范围为0~255,缺省值为0。
当需要使用ICMP echo报文进行ICMP-jitter测试前,配置本命令,可以使得配置结果更准确。其它测试场景,本命令不生效。
本命令指定的IP地址及VPN实例必须与NQA客户端配置的目的IP地址以及VPN实例一致,且本命令配置的IP地址必须是本设备上某个接口的IP地址,否则配置无效。
如果多次配置本命令且指定的IP地址或者VPN参数不同,则多条配置都生效,直到达到设备允许配置的ICMP反射参数条目的最大值。
# 创建IP地址为10.1.1.2的ICMP反射服务。
[Sysname] nqa server icmp-server 10.1.1.2
·     destination ip
·     vpn-instance
1.2.8  nqa server tcp-connect
nqa server tcp-connect命令用来在NQA服务器上创建TCP监听服务。
undo nqa server tcp-connect命令用来删除指定的TCP监听服务。
nqa server tcp-connect { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] [ tos tos ]
undo nqa server tcp-connect { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ]
不存在TCP监听服务。
ipv4-address:NQA服务器TCP监听服务监听的IPv4地址。
ipv6-address:NQA服务器TCP监听服务监听的IPv6地址。
port-number:NQA服务器TCP监听服务监听的端口号,取值范围为1~65535。
vpn-instance vpn-instance-name:NQA服务器监听的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示TCP监听的是公网IP地址。
tos tos:NQA服务器应答报文中的ToS域的值。取值范围为0~255。不指定本参数时,取值为0。
仅TCP和DLSw测试类型下必须配置本命令,且对于DLSw测试类型,port-number值必须为2065。否则,测试失败。
所配置的IP地址、端口号及VPN实例必须与NQA客户端的配置一致,且不能与已有的监听服务冲突。
所配置的IP地址必须是作为服务器的设备上的接口的IP地址,否则配置无效。
建议不要配置知名端口,否则可能导致NQA测试失败或该知名端口对应的服务不可用。
# 创建IP地址为169.254.10.2,端口号为9000的TCP监听服务。
[Sysname] nqa server tcp-connect 169.254.10.2 9000
·     destination ip
·     destination port
·     vpn-instance
1.2.9  nqa server udp-echo
nqa server udp-echo命令用来在NQA服务器上创建UDP监听服务。
undo nqa server udp-echo命令用来删除指定的UDP监听服务。
nqa server udp-echo { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] [ high-performance-mode ] [ tos tos ]
undo nqa server udp-echo { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ]
不存在UDP监听服务。
ipv4-address:NQA服务器UDP监听服务监听的IPv4地址。
ipv6-address:NQA服务器UDP监听服务监听的IPv6地址。
port-number:NQA服务器UDP监听服务监听的端口号,取值范围为1~65535。
vpn-instance vpn-instance-name:NQA服务器监听的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示UDP监听的是公网IP地址。
high-performance-mode:开启NQA服务器端对于UDP-jitter测试的高性能模式。不指定本参数则NQA服务器对于UDP-jitter测试的高性能模式处于关闭状态。
tos tos:NQA服务器应答报文中的ToS域的值。取值范围为0~255。不指定本参数时,取值从客户端发送的请求报文中获取。
只有在测试类型为UDP-jitter、UDP-echo或Voice时,才需在NQA服务器上配置此命令。
# 创建IP地址为169.254.10.2、端口号为9000的UDP监听服务。
[Sysname] nqa server udp-echo 169.254.10.2 9000
·     destination ip
·     destination ipv6
·     destination port
·     vpn-instance
1.2.10  nqa twamp-light responder
nqa twamp-light responder命令用来创建TWAMP-light Responder,并进入TWAMP-light-responder视图。如果TWAMP-light Responder已经存在,则直接进入TWAMP-light-responder视图。
undo nqa twamp-light responder命令用来删除TWAMP-light Responder。
不存在TWAMP-light Responder。
在TWAMP-light-responder视图下创建与TWAMP-light Client测试会话相对应的测试会话,从而与TWAMP-light Client测试会话进行交互。
执行undo nqa twamp-light responder命令时,系统会删除Responder以及所有的会话信息。
# 创建TWAMP-light Responder,并进入TWAMP-light-responder视图。
1.2.11  test-session (TWAMP-light-responder view)
test-session命令用来配置TWAMP-light Responder端的测试会话。
undo test-session命令用来删除TWAMP-light Responder端的测试会话。
test-session session-id [ interface interface-type interface-number [ service-instance instance-id ] ] [ link-bundle-interface interface-type interface-number ] { destination-mac mac-address source-mac mac-address | { ip | ipv6 } destination address source address destination-port port-number source-port port-number [ vpn-instance vpn-instance-name ] } * [ adjust-udp-checksum | description text | extended-packet | timestamp-format { ntp | ptp } | vlan { vlan-id | s-vid vlan-id c-vid vlan-id } ] *
未配置TWAMP-light Responder端的测试会话。
interface interface-type interface-number:测试会话中反射报文的接口。interface-type interface-number表示接口类型和接口编号。
service-instance instance-id:测试会话关联的以太网服务实例,instance-id为以太网服务实例编号,取值范围为1~4096。
link-bundle-interface interface-type interface-number:测试会话反射报文绑定的聚合成员口作为出接口。
destination-mac:测试会话待反射报文的目的MAC地址。
source-mac:测试会话待反射报文的源MAC地址。
mac-address:MAC地址。格式为H-H-H。在配置时,可以省去MAC地址中每段开头的“0”,例如:输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
ip:待反射报文的IPv4地址。
ipv6:待反射报文的IPv6地址。
destination:待反射报文的目的地址。指定ip参数时表示IPv4地址,指定ipv6参数时表示IPv6地址。
source:待反射报文的源地址。指定ip参数时表示IPv4地址,指定ipv6参数时表示IPv6地址。
address:IP地址。
destination-port port-number:测试会话待反射报文的目的UDP端口号,port-number表示UDP端口号,取值范围为1~65535。
source-port port-number:测试会话待反射报文的源UDP端口号。port-number表示UDP端口号,取值范围为1~65535。
adjust-udp-checksum:配置本参数后,TWAMP-light会调整测试报文中校验和字段的值。
description text:测试会话的描述信息。text表示描述信息,为1~200个字符的字符串,区分大小写。使用本参数可为测试会话增加描述信息,方便用户查看和管理测试会话。
extended-paket:配置该参数后,当设备收到测试报文的长度(data-size)小于41字节时,设备会将反射报文的TWAMP-light报文头扩充成标准头长度。不指定该参数时,设备直接根据收到的测试报文构建反射报文,不扩充TWAMP-light报文头,此时,可能会导致反射报文头部中缺少必要的参数,测试结果不准确。
timestamp-format:TWAMP-light Responder端的时间戳格式。缺省值为AUTO,AUTO表示由TWAMP-light Responder端自动选择使用的时间戳格式。
·     ntp:NTP时间戳格式。
·     ptp:PTP时间戳格式。
vlan:测试会话待反射报文的VLAN或内外层VLAN标签。
·     vlan-id:VLAN的编号,取值范围为1~4094。
·     s-vid:外层VLAN标签(Service VLAN ID)。
·     c-vid:内层VLAN标签(Customer VLAN ID)。
TWAMP-light Responder端的测试会话是与TWAMP-light Client测试会话相对应的测试会话,用于和TWAMP-light Client测试会话进行交互。
本命令指定的发送端IP地址、反射端IP地址、发送端UDP端口号、反射端UDP端口号以及VPN实例名组成的五元组信息需要和TWAMP-light Client测试会话的信息相互对应。
当创建的会话ID不存在,则创建一个新的会话;如果指定的会话ID已存在,则对会话信息进行修改。
一个会话ID只能指定一个反射接口和以太网服务实例,但多个会话ID可以指定同一个反射接口和以太网服务实例;一旦指定了反射接口和以太网服务实例则无法更改,只能通过undo test-session命令删除对应的会话后重新指定;已配置的会话相关参数除反射接口和以太网服务实例外,均可以修改或删除,但若删除掉所有配置,那么该测试会话也会一同删除。
缺省情况下,TWAMP-light测试报文中校验和字段的值为0。配置本命令并指定adjust-udp-checksum后,TWAMP-light会将实际计算的校验和值填入测试报文的校验和字段。不同TWAMP-light反射端对该字段取值的要求不同。如果设备连接的TWAMP-light客户端对该字段的取值有严格要求,请配置该字段。如果TWAMP-light客户端是H3C设备,则不需要配置该字段。用户可以使用以下任意一种方式来开启测试会话的校验和字段调整功能:
·     本命令中开启该功能:该方式配置的测试报文校验和字段调整功能仅对当前即将开始的会话生效。
校验和字段调整功能仅对IPv6测试报文生效,对于IPv4测试报文不生效。
# 创建TWAMP-light Responder端的测试会话1,并指定源IPv4地址为1.1.1.1.,目的IPv4地址为2.2.2.2,源端口为3000,目的端口为3001,VPN实例名称为vpn1。
[Sysname-nqa-twamp-light-responder] test-session 1 ip destination 2.2.2.2 source 1.1.1.1 destination-port 3001 source-port 3000 vpn-instance vpn1
·     adjust-udp-checksum global enable (TWAMP-light-responder view)
1.3  NQA TWAMP服务器端命令
1.3.1  client acl
client acl命令用来配置TWAMP Server关联的ACL。
undo client acl命令用来恢复缺省情况。
client acl { acl-number | name acl-name }
undo client acl
未使用ACL对可访问设备的TWAMP Client进行限制。
IPv4 TWAMP Server视图
IPv6 TWAMP Server视图
acl-number:ACL的匹配规则编号,取值范围为2000~3999。其中:
·     基本ACL,acl-number取值范围为2000~2999;
·     高级ACL,acl-number取值范围为3000~3999。
name acl-name:ACL的匹配规则名称。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。本命令仅支持关联基本ACL和高级ACL。
配置本命令后,只有符合ACL permit规则的客户端才能与TWAMP Server建立链接。
当关联的ACL不存在,或者关联的ACL中规则为空时,与不配置本命令效果相同。
IPv4 TWAMP Server视图下关联的ACL,只有IPv4 ACL生效;IPv6 TWAMP Server视图下关联的ACL,只有IPv6 ACL生效。在同一TWAMP Server视图下多次执行本命令,最新配置生效。
# 配置IPv4 TWAMP Server关联ACL 3000。
[Sysname] nqa twamp server
[Sysname-twamp-server] client acl 3000
1.3.2  control-session timeout
control-session timeout命令用来配置TWAMP Server的控制会话的会话老化时间。
undo control-session timeout命令用来恢复缺省情况。
control-session timeout timeout
TWAMP Server的控制会话的会话老化时间为900秒。
IPv4 TWAMP Server视图
IPv6 TWAMP Server视图
timeout:表示控制会话的老化时间,取值范围是1~6000,单位为秒。
一个TWAMP测试涉及两个会话:TWAMP控制会话和TWAMP测量会话。一个TWAMP测试对应一个TWAMP测量会话,多个TWAMP测量会话可以共用一个TWAMP控制会话。TWAMP控制会话是基于TCP协议建立的,它用于协商TWAMP测量会话参数。
如果控制会话在指定的时间内一直处于非活跃状态,则该控制会话将被删除,以免空闲的控制会话长时间占用系统资源。
# 配置控制会话的老化时间为600秒。
[Sysname-twamp-server] control-session timeout 600
1.3.3  display nqa twamp server global-information
display nqa twamp server global-information命令用来显示TWAMP Server的全局信息。
display nqa twamp [ ipv6 ] server global-information
ipv6:显示IPv6 TWAMP Server的全局信息。不指定该参数时,显示IPv4 TWAMP Server的全局信息。
# 显示TWAMP Server的全局信息。
<Sysname> display nqa twamp server global-information
Start time                      : 2020-10-27 17:43:24.111
Server address                  : 0.0.0.0
Server port                     : 862
Server timeout time             : 900
Reflector timeout time          : --
Reflector status               : Enabled
Control sessions               : 10
Test sessions                  : 10
Completed test sessions        : 10
Aborted test sessions          : 0
Sent probe packets             : 100
Received probe packets         : 100
表1-21 display nqa twamp server global-information命令显示信息描述表
Start time
TWAMP启动时间
Server address
TWAMP监听服务的IP地址
Server port
TWAMP Server监听端口
Server timeout time
控制会话的老化时间
测量会话的老化时间
Reflector status
TWAMP测量会话的状态,取值为:
·     Enabled:测量会话处于使能状态
·     Disabled:测量会话处于未使能状态
Control sessions
控制会话个数
Test sessions
测量会话个数
完成的测量会话个数
异常中断的测量会话个数
Sent probe packets
发送Test报文个数
接收Test报文个数
1.3.4  display nqa twamp server session
display nqa twamp server session命令用来显示TWAMP Server的会话信息。
display nqa twamp [ ipv6 ] server session [ source source-ip [ vpn-instance vpn-instance-name ] ]
ipv6:显示IPv6 TWAMP Server的会话信息。不指定该参数时,显示IPv4 TWAMP Server的会话信息。
source source-ip:指定源IP地址。
vpn-instance vpn-instance-name:源地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示公网。
# 显示TWAMP Server的会话信息。
<Sysname> display nqa twamp server session
Controle session 1:
  Client address       : 192.168.29.2
  Client port          : 51637
  Server address       : 192.168.29.1
  Server port          : 5001
  VPN instance         : --
  Mode                 : No Authentication
  Created at           : 2012-08-05 16:47:55
  Connection state     : Active
  Test session 1:
    Sender address       : 192.168.29.2
    Sender port          : 11001
    Reflector address    : 192.168.29.1
    Reflector port       : 12001
    DSCP                 : 0
    Padding length       : 128
    Session ID           : 192.168.29.1:3596890923-1139789831:dca28147
    Received probe packets: 100
    Session state        : Active
  Test session 2:
    Sender port          : 11001
    DSCP                 : 0
Controle session 2:
  Client port          : 51637
  Server port          : 5001
  VPN instance         : --
  Created time         : 2012-08-05 16:47:55
  Test session 1:
    Sender port          : 11001
    DSCP                 : 0
表1-22 display nqa twamp session命令显示信息描述
Connection session
控制连接
Client address
客户端IP地址
Client port
客户端端口号
Server address
服务端IP地址
Server port
服务端端口号
VPN instance
服务端所属的VPN实例
Mode
探测模式,取值为:
·     No Authentication:表示TWAMP测量会话处于非认证模式
·     Invalid Mode:表示TWAMP控制会话处于初始化模式
Created time
控制会话的创建时间
Connection state
控制连接的状态,取值为:
·     Initial:控制会话处于初始化状态
·     Connecting:控制会话处于连接状态,处于参数协商阶段
·     Establish:控制会话建立完成,但没有建立测量会话
·     Inactive:控制会话建立完成,且已建立测量会话,但测量会话处于未启动阶段
·     Active:控制会话建立完成,且已建立测量会话,测量会话处于启动阶段
Test session
测量会话表项的信息
Sender address
发送方IP地址
Sender port
发送方端口号
Reflector address
接收方IP地址
Reflector port
接收方端口号
DSCP
测量会话报文DSCP优先级
Padding length
测量会话报文填充长度
Created at
测量会话的创建时间
Session ID
测量会话ID,由设备自动生成
Sent probe packets
本设备发送的测量报文的数目
本设备接收的测量报文的数目
Session state
测量会话的状态,取值为
·     Active:活跃
·     Inactive:非活跃
1.3.5  nqa twamp reflector
nqa twamp reflector命令用来开启TWAMP Reflector功能,并进入TWAMP Reflector视图。
undo nqa twamp reflector命令用来关闭TWAMP Reflector功能。
nqa twamp reflector
TWAMP Reflector功能处于关闭状态。
TWAMP采用客户端-服务器通信模式,涉及Server和Client两个角色。同时,Server上需要支持逻辑角色Reflector,Client上需要支持逻辑角色Sender。Server和Client之间建立TWAMP控制会话,用于协商和管理TWAMP测量会话;Reflector和Sender之间建立TWAMP测量会话,交互探测报文。
配置本命令后,设备即可作为Reflector,应答Sender发送的探测报文,进行TWAMP测试。
# 开启TWAMP Reflector功能。
[Sysname] nqa twamp reflector
[Sysname-nqa-twamp-reflector]
1.3.6  nqa twamp server
nqa twamp server命令用来开启TWAMP Server功能,并进入TWAMP Server视图。
undo nqa twamp server命令用来关闭TWAMP Server功能。
undo nqa twamp [ ipv6 ] server
TWAMP Server和IPv6 TWAMP Server功能处于关闭状态。
ipv6:开启IPv6 TWAMP Server功能,并进入IPv6 TWAMP Server视图。不指定该参数时,表示开启IPv4 TWAMP Server功能,并进入IPv4 TWAMP Server视图。
配置本命令后,设备即可作为TWAMP Server,应答TWAMP Client发送的连接请求报文。
执行undo nqa twamp [ ipv6 ] server命令会删除TWAMP Server相关的所有配置。
# 开启IPv4 TWAMP Server功能。
[Sysname-nqa-twamp-server]
# 开启IPv6 TWAMP Server功能。
[Sysname] nqa twamp ipv6 server
[Sysname-nqa-twamp-ipv6-server]
1.3.7  tcp port
tcp port命令用来配置TWAMP Server的TCP侦听端口号。
undo tcp port命令用来恢复缺省情况。
tcp port port-number [ all | vpn-instance vpn-instance-name ]
undo tcp port
TWAMP Server的TCP侦听端口号为862。
IPv4 TWAMP Server视图
IPv6 TWAMP Server视图
port-number:指定TCP侦听端口号,取值范围为1~65535。
all:表示侦听公网和所有VPN实例。
vpn-instance vpn-instance-name:TWAMP Server监听的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示公网。
如果缺省端口被别的服务占用,或者TWAMP Client发送的测试报文的目的端口号不是862时,可使用本命令修改TWAMP Server的TCP侦听端口号。
TWAMP Server的TCP侦听端口号必须和TWAMP Client发送的测试报文的目的端口号一致。
# 配置TWAMP Server的TCP侦听端口号为65530。
[Sysname]nqa twamp server
[Sysname-nqa-twamp-server]tcp port 65530
1.3.8  test-session timeout
test-session timeout命令用来配置TWAMP Reflector的测量会话的老化时间。
undo test-session timeout命令用来恢复缺省情况。
test-session timeout timeout
TWAMP Reflector的测量会话的老化时间为900秒。
TWAMP-Reflector视图
timeout:表示TWAMP Reflector的测量会话的老化时间,取值范围是1~604800,单位为秒。
一个TWAMP测试涉及两个会话:TWAMP控制会话和TWAMP测量会话。一个TWAMP测试对应一个TWAMP测量会话,多个TWAMP测量会话可以共用一个TWAMP控制会话。TWAMP测量会话是基于UDP协议建立的,它用于进行TWAMP探测功能。
如果测量会话在指定的老化时间内一直处于非活跃状态,该测量会话将被删除,防止占用系统资源。
# 配置TWAMP Reflector的测量会话的老化时间为600秒。
[Sysname-nqa-twamp-reflctor] test-session timeout 600
