07-三层技术-IP路由命令参考
11-OSPFv3命令
本章节下载: 11-OSPFv3命令  (1.27 MB)
11-OSPFv3命令
1 OSPFv3
1.1 OSPFv3配置命令
1.1.1 abr-summary
1.1.2 advertise application link-attributes te
1.1.3 advertise-definition enable
1.1.4 affinity exclude-any
1.1.5 affinity include-all
1.1.6 affinity include-any
1.1.7 affinity-map
1.1.8 area
1.1.9 asbr-summary
1.1.10 authentication-mode
1.1.11 bandwidth-reference
1.1.12 default tag
1.1.13 default-cost
1.1.14 default-route-advertise
1.1.15 display ospfv3
1.1.16 display ospfv3 abr-asbr
1.1.17 display ospfv3 abr-summary
1.1.18 display ospfv3 asbr-summary
1.1.19 display ospfv3 event-log
1.1.20 display ospfv3 flex-algo routing
1.1.21 display ospfv3 flex-algo spf-tree
1.1.22 display ospfv3 global-flex-algo
1.1.23 display ospfv3 global-statistics
1.1.24 display ospfv3 graceful-restart
1.1.25 display ospfv3 interface
1.1.26 display ospfv3 local-flex-algo
1.1.27 display ospfv3 lsdb
1.1.28 display ospfv3 nexthop
1.1.29 display ospfv3 non-stop-routing
1.1.30 display ospfv3 peer
1.1.31 display ospfv3 request-queue
1.1.32 display ospfv3 retrans-queue
1.1.33 display ospfv3 routing
1.1.34 display ospfv3 spf-tree
1.1.35 display ospfv3 statistics
1.1.36 display ospfv3 vlink
1.1.37 distibute bgp-ls
1.1.38 dscp
1.1.39 enable ipsec-profile
1.1.40 event-log
1.1.41 fast-reroute
1.1.42 fast-reroute enable
1.1.43 fast-reroute tiebreaker (OSPFv3 view)
1.1.44 fast-reroute tiebreaker (Flexible algorithm view)
1.1.45 fast-reroute ti-lfa enable
1.1.46 filter
1.1.47 filter-policy export
1.1.48 filter-policy import
1.1.49 flex-algo
1.1.50 graceful-restart enable
1.1.51 graceful-restart helper enable
1.1.52 graceful-restart helper strict-lsa-checking
1.1.53 graceful-restart interval
1.1.54 import-route
1.1.55 isolate enable
1.1.56 ispf enable
1.1.57 link-tag inherit enable
1.1.58 log-peer-change
1.1.59 lsa-arrival-interval
1.1.60 lsa-generation-interval
1.1.61 maximum load-balancing
1.1.62 metric-bandwidth advertisement enable
1.1.63 metric-bandwidth suppression
1.1.64 metric-delay advertisement enable
1.1.65 metric-delay suppression
1.1.66 metric-type
1.1.67 mpls te enable
1.1.68 nssa
1.1.69 ospfv3
1.1.70 ospfv3 affinity flex-algo
1.1.71 ospfv3 area
1.1.72 ospfv3 authentication-mode
1.1.73 ospfv3 bfd adjust-cost
1.1.74 ospfv3 bfd adjust-cost suppress-flapping
1.1.75 ospfv3 bfd enable
1.1.76 ospfv3 cost
1.1.77 ospfv3 cost-fallback
1.1.78 ospfv3 dr-priority
1.1.79 ospfv3 fast-reroute lfa-backup exclude
1.1.80 ospfv3 ipsec-profile
1.1.81 ospfv3 link-delay
1.1.82 ospfv3 link-quality adjust-cost
1.1.83 ospfv3 link-tag
1.1.84 ospfv3 mib-binding
1.1.85 ospfv3 mtu-ignore
1.1.86 ospfv3 network-type
1.1.87 ospfv3 peer
1.1.88 ospfv3 peer hold-max-cost duration
1.1.89 ospfv3 prefix-suppression
1.1.90 ospfv3 primary-path-detect bfd
1.1.91 ospfv3 silent
1.1.92 ospfv3 timer dead
1.1.93 ospfv3 timer hello
1.1.94 ospfv3 timer poll
1.1.95 ospfv3 timer retransmit
1.1.96 ospfv3 trans-delay
1.1.97 ospfv3 virtual-system
1.1.98 pic
1.1.99 preference
1.1.100 prefix-suppression
1.1.101 priority
1.1.102 reset ospfv3 event-log
1.1.103 reset ospfv3 process
1.1.104 reset ospfv3 redistribution
1.1.105 reset ospfv3 statistics
1.1.106 router-id
1.1.107 shutdown process
1.1.108 silent-interface
1.1.109 snmp context-name
1.1.110 snmp trap rate-limit
1.1.111 snmp-agent trap enable ospfv3
1.1.112 spf-schedule-interval
1.1.113 stub
1.1.114 stub-router
1.1.115 suppress intra-te link-attributes
1.1.116 te-router-id
1.1.117 transmit-pacing
1.1.118 virtual-system enable
1.1.119 vlink-peer
1 OSPFv3
1.1  OSPFv3配置命令
1.1.1  abr-summary
abr-summary命令用来配置ABR路由聚合。
undo abr-summary命令用来取消ABR对指定网段的路由聚合。
abr-summary ipv6-address prefix-length [ not-advertise ] [ cost cost-value ]
undo abr-summary ipv6-address prefix-length
ABR不对路由进行聚合。
OSPFv3区域视图
ipv6-address:聚合路由的目的IPv6地址。
prefix-length:聚合路由的目的IPv6地址前缀长度,取值范围为1~128。它指定地址中有多少连续的位组成IPv6网络前缀,即IPv6地址中的网络地址部分。
not-advertise:不通告聚合的IPv6路由。如果未指定本参数,则通告聚合的IPv6路由。
cost cost-value:聚合路由的开销值,取值范围为1~16777215,缺省值为所有被聚合的路由中最大的开销值。
本命令只适用于ABR,用来对当前区域进行路由聚合。对于落入该聚合网段的路由,ABR向其它区域只发送一条聚合后的路由。一个区域可配置多条聚合网段,这样OSPFv3可对多个网段进行聚合。
当配置了undo abr-summary命令后,原来被聚合的路由将重新被发布。
# 将OSPFv3区域1中两条路由2000:1:1:1::/64、2000:1:1:2::/64的路由聚合成一条前缀2000:1:1::/48向其它区域发送。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] abr-summary 2000:1:1:: 48
advertise application link-attributes te命令用来开启OSPFv3为特定应用发布链路TE属性、时延信息和带宽信息的功能。
undo advertise application link-attributes te命令用来关闭OSPFv3为特定应用发布链路TE Metric、时延信息和时延带宽信息的功能。
OSPFv3为特定应用发布链路TE Metric、时延信息和时延带宽信息的功能处于关闭状态。
OSPFv3视图
OSPFv3使用ASLA(Application-Specific Link Attributes,应用特定链路属性)sub-TLV来携带与特定应用(如Flex-Algo算法)关联的链路属性。配置本命令后,ASLA sub-TLV中将携带Link Attributes sub-sub-TLV,该sub-sub-TLV包括链路的TE开销、时延、带宽等信息。
目前仅支持为Flex-Algo算法发布链路属性信息。当Flex-Algo算法使用时延或TE开销作为度量类型时,需要配置本命令发布链路属性信息,以便进行Flex-Algo选路计算。
Flex-Algo算法使用时延作为度量类型时,需要保证节点的时延发布功能已经生效,Link Attributes sub-sub-TLV才能成功携带链路时延信息。
Flex-Algo算法使用TE开销作为度量类型时,为了让Link Attributes sub-sub-TLV能够成功携带链路属性信息,需要保证:
·     参与Flex-Algo算法的节点的MPLS TE能力处于开启状态。
·     参与Flex-Algo算法的接口的MPLS能力和MPLS TE能力处于开启状态。
·     OSPFv3区域的MPLS TE能力处于开启状态。
使用advertise application link-attributes te命令发布链路属性时,必须通过segment-routing ipv6 sid-sub-tlv-type命令修改SRv6 SID-Sub TLV的类型值,避免SRv6 SID-Sub TLV的类型值和ASLA Sub-TLV类型值冲突导致Flex-Algo功能异常。
# 配置OSPFv3进程1为特定的应用发布链路属性信息。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] advertise application link-attributes te
·     metric-delay advertisement enable
·     segment-routing ipv6 sid-sub-tlv-type(Segment Routing命令参考/SRv6)
advertise-definition enable命令用来开启本节点对Flex-Algo算法定义的通告功能。
undo advertise-definition enable命令用来关闭本节点对Flex-Algo算法定义的通告功能。
本节点对Flex-Algo算法定义的通告功能处于关闭状态。
Flex-Algo视图
配置本命令后,节点将通告自己对Flex-Algo算法的定义。需要保证Flex-Algo算法拓扑中至少有一个节点通告Flex-Algo算法的定义。
如果某个节点仅创建了Flex-Algo算法(如Flex-Algo算法128),但是未通告Flex-Algo算法128的定义,节点是否参与Flex-Algo算法128计算的机制如下:
·     节点收到邻居通告的Flex-Algo算法128的定义后,选择优先级最高的Flex-Algo算法128的定义。如果节点支持此算法定义中的度量类型,那么该节点将参与Flex-Algo算法128计算。否则,节点无法参与Flex-Algo算法128计算。
·     如果未接收到Flex-Algo算法128定义的通告,那么此节点将无法参与Flex-Algo算法128计算。
# 配置本节点通告对Flex-Algo算法128的定义。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] flex-algo 128
[Sysname-ospfv3-1-flex-algo-128] advertise-definition enable
·     display ospfv3 flex-algo routing
affinity exclude-any命令用来配置Flex-Algo算法拓扑排除具有任意一个指定亲和属性的链路。
undo affinity exclude-any命令用来恢复缺省情况。
affinity exclude-any affinity-name&<1-32>
参与Flex-Algo算法计算的所有节点的链路都会加入拓扑。
Flex-Algo视图
affinity-name&<1-32>:指定亲和属性名称。affinity-name表示亲和属性名称,为1~32个字符的字符串,区分大小写。&<1-32>表示前面的参数最多可以输入1~32次。
配置本命令后,只要链路有一个亲和属性和指定亲和属性名称映射的亲和属性相同,那么该链路就会被Flex-Algo算法从拓扑中排除。
# 配置Flex-Algo算法拓扑排除具有red映射的亲和属性的链路。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-flex-algo-128] affinity exclude-any red
·     affinity-map
affinity include-all命令用来配置Flex-Algo算法拓扑包含具有所有指定亲和属性的链路。
undo affinity include-all命令用来恢复缺省情况。
affinity include-all affinity-name&<1-32>
Flex-Algo视图
affinity-name&<1-32>:指定亲和属性名称。affinity-name表示亲和属性名称,取值为1~32个字符的字符串,区分大小写。&<1-32>表示前面的参数可以输入1~32次。
配置本命令后,只有链路具有所有指定的亲和属性名称映射的亲和属性时,链路才会被Flex-Algo算法加入拓扑。
# 配置Flex-Algo算法包含同时具有red和blue映射的亲和属性的链路。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-flex-algo-128] affinity include-all red blue
·     affinity-map
affinity include-any命令用来配置Flex-Algo算法拓扑包含具有任意一个指定亲和属性的链路。
undo affinity include-any命令用来恢复缺省情况。
affinity include-any affinity-name&<1-32>
Flex-Algo视图
配置本命令后,只要链路有一个亲和属性和指定的亲和属性名称映射的亲和属性相同,那么该链路就会被Flex-Algo算法加入拓扑。
# 配置Flex-Algo算法拓扑包含具有red映射的亲和属性的链路。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-flex-algo-128] affinity include-any red
·     affinity-map
1.1.7  affinity-map
affinity-map命令用来配置亲和属性名称和亲和属性比特位之间的映射关系。
undo affinity-map命令用来取消亲和属性名称和亲和属性比特位之间的映射关系。
affinity-map affinity-name bit-position bit
undo affinity-map affinity-name
未配置亲和属性名称和亲和属性比特位之间的映射关系。
OSPFv3视图
affinity-name:指定亲和属性名称,为1~32个字符的字符串,区分大小写。亲和属性名称只具有本地意义。
bit:指定亲和属性比特位的编号,取值范围为0~255。
OSPFv3支持256个亲和属性比特位(编号为0~255),使用本命令可以管理亲和属性名称和特定编号的亲和属性比特位之间的映射关系。例如affinity-map blue bit-position 3命令表示对于亲和属性blue,亲和属性比特位中的编号为3的比特位置位。
配置亲和属性名称和亲和属性比特位的映射关系后,OSPFv3可以方便地通过亲和属性名称来配置链路的亲和属性,或者定义Flex-Algo算法拓扑。
配置亲和属性名称和亲和属性比特位的映射关系时,需要注意不同的亲和属性名称不能包含相同的亲和属性比特位。
# 定义亲和属性映射关系,将亲和属性比特位1映射为亲和属性名称red。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] affinity-map red bit-position 1
1.1.8  area
area命令用来创建OSPFv3区域,并进入区域视图。
undo area命令用来删除指定的OSPFv3区域。
area area-id
undo area area-id
不存在OSPFv3区域。
OSPFv3视图
area-id:区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
# 进入OSPFv3区域0视图。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 0
[Sysname-ospfv3-1-area-0.0.0.0]
1.1.9  asbr-summary
asbr-summary命令用来配置ASBR路由聚合。
undo asbr-summary命令用来取消ASBR对指定网段的路由聚合。
asbr-summary ipv6-address prefix-length [ cost cost-value | not-advertise | nssa-only | tag tag ] *
undo asbr-summary ipv6-address prefix-length
ASBR不对引入的路由进行聚合。
OSPFv3视图
cost cost-value:聚合路由的开销,取值范围为1~16777214。如果未指定本参数,cost-value取所有被聚合的路由中最大的开销值作为聚合路由的开销;如果是Type-7 LSA转化成的Type-5 LSA描述的路由匹配聚合、且是Type2外部路由,则cost-value取所有被聚合的路由中最大的开销值加1作为聚合路由的开销。
not-advertise:不通告聚合路由。如果未指定本参数,将通告聚合路由。
nssa-only:设置Type-7 LSA的P比特位为不置位,即在对端路由器上不能转为Type-5 LSA。缺省时,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
tag tag:聚合路由的标记,取值范围为0~4294967295。
如果本地路由器是ASBR,对引入的聚合地址范围内的Type-5 LSA描述的路由进行聚合;当配置了NSSA区域时,对引入的聚合地址范围内的Type-7 LSA描述的路由进行聚合。
如果本地路由器同时是ASBR和ABR,并且是NSSA区域的转换路由器,则对由Type-7 LSA转化成的Type-5 LSA描述的路由进行聚合处理;如果不是NSSA区域的转换路由器,则不进行聚合处理。
配置asbr-summary命令后,对处于聚合地址范围内的外部路由,本地路由器只向邻居路由器发布一条聚合后的路由;配置undo asbr-summary命令后,原来被聚合的外部路由将重新被发布。
# 配置OSPFv3进程1对引入的路由进行聚合,聚合路由为2000::/16,开销值为100,标记为2。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] asbr-summary 2000:: 16 cost 100 tag 2
authentication-mode命令用来设置OSPFv3区域使用的验证模式。
undo authentication-mode命令用来恢复缺省情况。
HMAC-SHA-256/HMAC-SM3验证模式:
authentication-mode { hmac-sha-256 | hmac-sm3 } key-id { cipher | plain } string
keychain验证模式:
authentication-mode keychain keychain-name
未配置区域验证模式。
OSPFv3区域视图
hmac-sha-256:HMAC-SHA-256验证模式。
hmac-sm3:HMAC-SM3验证模式。
key-id:验证字标识符,取值范围为0~65535。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~255个字符的字符串;密文密钥为33~373个字符的字符串。
keychain:使用keychain验证模式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
一个区域中所有路由器的验证模式和验证密钥必须一致。同一时间只能使用一种验证模式,无法同时使用HMAC-SHA-256验证模式、HMAC-SM3验证模式和keychain验证模式中的两种或三种。
接口视图下配置的验证模式,其优先级高于OSPFv3区域视图下配置的验证模式。
在OSPFv3区域使用keychain验证模式时,本区域的OSPFv3报文验证过程如下:
·     OSPFv3在发送报文前,会先从keychain获取当前的有效发送key,然后发送报文。如果当前不存在有效发送key,或者该key的标识符大于65535,则OSPFv3不会发送报文。
·     OSPFv3在收到报文后,会根据报文携带的key的标识符从keychain中获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验,校验成功后再对报文进行下一步处理。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
对于keychain认证算法和key的标识符的范围,OSPFv3的支持情况如下:
·     OSPFv3仅支持HMAC-SHA-256和HMAC-SM3认证算法。
·     OSPFv3仅支持标识符取值范围为0~65535的key。
# 配置OSPFv3区域1使用keychain验证模式,keychain名为test。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] authentication-mode keychain test
bandwidth-reference命令用来配置计算链路开销时所依据的带宽参考值。
bandwidth-reference value
计算链路开销时所依据的带宽参考值为100Mbps。
OSPFv3视图
value:计算链路开销时所依据的带宽参考值,取值范围为1~4294967,单位为Mbps。
OSPFv3有两种方式来配置接口的开销值,第一种方法是在接口视图下直接配置开销值;第二种方法是配置接口的带宽参考值,OSPFv3根据带宽参考值自动计算接口的开销值,计算公式为:接口开销=带宽参考值÷接口带宽,当计算出来的开销值大于65535,开销取最大值65535;当计算出来的开销值小于1时,开销取最小值1。
如果没有在接口视图下显式的配置此接口的开销值,OSPFv3会根据该接口的带宽自动计算其开销值。
# 配置计算链路开销时所依据的带宽参考值为1000Mbps。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] bandwidth-reference 1000
1.1.12  default tag
default tag命令用来配置引入外部路由的全局标记。
undo default tag命令用来恢复缺省情况。
default tag tag
undo default tag
引入外部路由的全局标记为1。
OSPFv3视图
tag:外部路由的全局标记,取值范围为0~4294967295。
如果在配置default-route-advertise、import-route和route-tag命令时没有指定标记,则缺省使用本命令配置的全局标记。
# 配置OSPFv3引入外部路由的标记为2。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default tag 2
·     default-route-advertise
·     import-route
·     route-tag(MPLS命令参考/MPLS L3VPN)
1.1.13  default-cost
default-cost命令用来配置发送到Stub区域或NSSA区域的缺省路由的开销。
undo default-cost命令用来恢复缺省情况。
default-cost cost
undo default-cost
发送到Stub区域或NSSA区域的缺省路由的开销为1。
OSPFv3区域视图
cost:发送到Stub区域或NSSA区域的缺省路由的开销,取值范围为0~16777214。
该命令只有在Stub区域的ABR或NSSA区域的ABR/ASBR上配置才能生效。
# 将OSPFv3区域1设置为Stub区域,使发送到该Stub区域的缺省路由开销为60。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] stub
[Sysname-ospfv3-1-area-0.0.0.1] default-cost 60
·     nssa
·     stub
default-route-advertise命令用来将缺省路由引入到OSPFv3路由区域。
default-route-advertise [ [ always | permit-calculate-other ] | cost cost-value | route-policy route-policy-name | tag tag | type type ] *
未引入缺省路由。
OSPFv3视图
always:如果当前路由器的路由表中没有缺省路由,使用此参数可产生一个描述缺省路由的AS-external-LSA发布出去。如果没有指定该关键字,仅当本地路由器的路由表中存在缺省路由时,才可以产生一个描述缺省路由的AS-external-LSA发布出去。
permit-calculate-other:当路由器产生并发布了一个描述缺省路由的AS-external-LSA时,指定此参数的路由器仍然会计算来自于其他路由器的缺省路由,未指定此参数的路由器不再计算来自其他路由器的缺省路由。当路由器没有产生一个描述缺省路由的AS-external-LSA时,无论是否指定此参数,路由器都会计算来自其他路由器的缺省路由。
cost cost-value:该缺省路由的度量值,取值范围为0~16777214,缺省值为1。
route-policy route-policy-name:路由策略名,为1~63个字符的字符串,区分大小写。只有当前路由器的路由表中存在缺省路由,并且有路由匹配route-policy-name指定的路由策略,才可以产生一个描述缺省路由的AS-external-LSA发布出去,指定的路由策略会影响AS-external-LSA中的值。如果同时指定always参数,不论当前路由器的路由表中是否有缺省路由,只要有路由匹配指定的路由策略,就将产生一个描述缺省路由的AS-external-LSA发布出去,指定的路由策略会影响AS-external-LSA中的值。
tag tag:外部路由的标记,取值范围为0~4294967295。如果未指定本参数,将根据default tag命令的配置进行取值。
type type:该AS-external-LSA的类型,取值范围为1~2,缺省值为2。
使用import-route命令不能引入缺省路由,如果要引入缺省路由,必须使用本命令。当本地路由器的路由表中没有缺省路由时,要产生一个描述缺省路由的AS-external-LSA应使用always关键字。
# 将产生的缺省路由引入到OSPFv3自治系统中(本地路由器没有缺省路由)。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default-route-advertise always
·     import-route
display ospfv3命令用来显示OSPFv3的进程信息。
display ospfv3 [ process-id ] [ verbose ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的概要信息。
verbose:显示OSPFv3进程的详细信息。如果未指定本参数,将显示OSPFv3进程的概要信息。
# 显示所有OSPFv3进程的详细信息。
<Sysname> display ospfv3 verbose
               OSPFv3 Process 1 with Router ID 1.1.1.1
 RouterID: 1.1.1.1          Router type:  ABR  ASBR  NSSA
 IPv6 RouterID: 86::86
 Route tag: 0
 Route tag check: Disabled
 Multi-VPN-Instance: Disabled
 Type value of extended community attributes:
    Domain ID : 0x0005
    Route type: 0x0306
    Router ID : 0x0107
 Domain-id: 0.0.0.0
 DN-bit check: Enabled
 DN-bit set: Enabled
 Isolation: Enabled
 Originating router-LSAs with maximum metric
    Condition: On startup while BGP is converging for 600 seconds, State: Inactive
 Advertise summary-LSAs with metric 16711680
 Advertise external-LSAs with metric 16711680
 Advertise intra-area-prefix-LSAs with maximum metric
 ISPF: Enabled
 Link tag inheritance: Disabled
 SPF-schedule-interval: 5 50 200
 LSA generation interval: 5
 LSA arrival interval: 1000 500 500
 Default ASE parameters: Tag: 1
 Route preference: 10
 ASE route preference: 150
 FRR backup mode: LFA
 Node-Protecting Preference: 40
 Lowest-cost Preference: 20
 Microloop-avoidance: Disabled
 Microloop-avoidance RIB-update-delay: 5000 ms
 SPF calculation count: 0
 External LSA count: 0
 LSA originated count: 0
 LSA received count: 0
 SNMP trap rate limit interval: 10  Count: 7
 Area count: 2  Stub area count: 0  NSSA area count: 1
 ExChange/Loading neighbors: 0
 End.X SID deletion delay:
    State     : Disabled
    Delay time: 1800 sec
 Max equal cost paths: 32
 Up interfaces: 1
 Full neighbors: 1
 Normal areas with up interfaces: 1
 Calculation trigger type: Full
 Current calculation type: SPF calculation
 Current calculation phase: Calculation area topology
 Redistribute timer: Off
 Redistribute schedule type: RIB
 Redistribute route count: 0
 Process reset state: N/A
 Current reset type: N/A
 Next reset type: N/A
 Reset prepare message replied: -/-/-/-
 Reset process message replied: -/-/-/-
 Reset phase of module:
   M-N/A, P-N/A, S-N/A, C-N/A, R-N/A
 IPv6 segment routing: Enabled
   Fast-reroute TI-LFA: Disabled
   SR microloop-avoidance: Disabled
   SR microloop-avoidance RIB-update-delay: 5000 ms
   Metric-delay advertisement: Disabled
   Metric-bandwidth advertisement: Enabled
   Metric-bandwidth advertisement suppression: 100
 Area: 0.0.0.0          (MPLS TE not enabled)
 Area flag: Normal
 SPF scheduled count: 0
 LSA count: 0
 Up interfaces: 0
 MTU: 1440
 Default cost: 1
 Created by Vlink
 Area: 0.0.0.2          (MPLS TE not enabled)
 Area flag: Normal
 LSA count: 0
 IPsec profile name: Profile000
 Keychain authentication: Enabled (test)
 Up interfaces: 1
 MTU: 1500
 Default cost: 1
 Area: 0.0.0.3          (MPLS TE not enabled)
 Area flag: NSSA
 SPF Scheduled Count: 0
 LSA Count: 0
 Up interfaces: 0
 MTU: 1440
 Default cost: 1
 Process reset flag: N/A
表1-1 display ospfv3 verbose命令显示信息描述表
OSPFv3进程是1,Router ID是1.1.1.1
RouterID
本路由器的Router ID
IPv6 RouterID
本路由器的IPv6 Router ID
Router type
路由器类型,取值为:
·     ABR:表示区域边界路由器
·     ASBR:表示自治系统边界路由器
·     NSSA:表示支持NSSA区域
·     Lite:表示轻量级OSPFv3进程
为空表示非上面四种情况
Process state
OSPFv3进程的状态,显示为Admin-down表示通过shutdown process命令关闭了OSPFv3进程。如果未通过shutdown process命令关闭OSPFv3进程,则不显示该字段
Route tag
当前进程引入外部路由的缺省标记
Route tag check
当前进程是否使能检查OSPFv3 LSA的标记
Multi-VPN-Instance
当前进程对PE、多VPN实例的支持情况:
·     Multi-VPN-Instance:Disabled表示不支持多VPN实例
·     Multi-VPN-instance:Enabled表示支持多VPN实例
·     PE Router, Multi-VPN-Instance:Enabled表示为PE
OSPFv3扩展团体属性的类型编码
Domain-id
OSPFv3域标识符
DN-bit check
当前进程是否使能检查OSPFv3 LSA的DN位
DN-bit set
当前进程是否使能设置OSPFv3 LSA的DN位
Isolation
是否开启Isolate功能:
·     Disabled:表示关闭
·     Enabled:表示开启
Originating router-LSAs with maximum metric/Originating router-LSAs with R-bit clear
Router LSA中使用最大开销值发布/Router LSA中清除R-bit
Condition
Stub路由器的状态:
·     Always代表始终生效
·     On startup while BGP is converging for XXX seconds代表BGP收敛超时时间
·     On startup for XXX seconds代表重启后生效时间
Stub路由器是否生效:
·     Active表示生效
·     Inactive表示不生效
Summary LSA发布使用的开销值
外部LSA发布使用的开销值
Intra-area-prefix-LSA发布使用的开销值
ISPF
是否使能增量SPF计算功能:
·     Enabled:表示使能
·     Disabled:表示关闭
是否开启OSPFv3的链路标记继承功能:
·     Enabled:表示开启
·     Disabled:表示关闭
进行SPF计算的时间间隔,in milliseconds表示以固定的时间间隔进行SPF计算,单位为毫秒
LSA生成时间间隔
OSPFv3接收LSA的时间间隔
Transmit pacing
接口发送LSU报文的速率,其中:
·     Interval表示接口发送LSU报文的时间间隔
·     Count表示接口一次发送LSU报文的最大个数
引入外部路由的缺省参数值,其中Tag代表路由标记
Route preference
内部路由优先级
外部路由优先级
FRR backup mode
指定快速重路由的备份下一跳地址的方式:
·     LFA:为所有路由通过LFA(Loop Free Alternate)算法选取备份下一跳信息。如果显示为LFA ABR-only,则表示只有到ABR设备的路由才能够通过LFA算法被选取为备份路径。
·     route-policy route-policy-name:为通过策略的路由指定备份下一跳,route-policy-name为路由策略名
·     ECMP-shared:为包含等价路由在内的所有路由通过LFA算法选取备份下一跳信息
节点保护优选方案的优先级
最小开销路径优选方案的优先级
Microloop-avoidance
是否开启正切防微环功能:
·     Disabled:正切防微环功能处于关闭状态
·     Enabled:正切防微环功能处于开启状态
正切防微环收敛延时时间,单位为毫秒
OSPFv3进程的路由计算总数
External LSA count
外部LSA数目,其中:
·     Count:LSA数目
·     checksum Sum:校验和
产生的LSA数目
LSA received count
接收的LSA数目
OSPFv3在10内秒允许输出7条告警信息
Area count
区域总数目
Stub area count
Stub区域数目
NSSA area count
NSSA区域数目
处于ExChange/Loading状态的邻居数
动态End.X SID延迟删除功能相关信息
动态End.X SID延迟删除功能的状态:
·     Enabled:表示动态End.X SID延迟删除功能处于开启状态
·     Disabled:表示动态End.X SID延迟删除功能处于关闭状态
Delay time
动态End.X SID延迟删除的延迟时间,单位为秒
触发路由计算的类型,具体如下:
Full:触发全部路由计算
Area topology change:区域拓扑改变触发路由计算
Intra router change:增量的区域内路由器路由变化
ASBR change:增量的ASBR路由变化
Full IP prefix:触发全部IP前缀计算
Full intra AS:触发全部AS内部前缀计算
Inc intra AS:触发增量AS内部前缀计算
Full inter AS:触发全部AS外部前缀计算
Inc inter AS:触发增量AS外部前缀计算
Nexthop calculation:触发下一跳计算
N/A:未触发计算
当前路由计算的类型,具体如下:
SPF calculation:进行区域SPF计算
Intra router calculation:区域内路由器路由计算
ASBR calculation:区域间ASBR路由计算
Inc intra router:增量区域内路由器路由计算
Inc ASBR calculation:增量区域间ASBR路由计算
Full intra AS:进行全部AS内部前缀计算
Inc intra AS:进行增量AS内部前缀计算
Full inter AS:进行全部AS外部前缀计算
Inc inter AS:进行增量AS外部前缀计算
N/A:未触发计算
当前路由计算调度运行到的阶段,具体如下:
Calculation area topology:计算区域拓扑
Calculation router:计算路由器路由
Calculation intra AS:计算AS内部路由
Calculation ASBR:计算ASBR路由
Calculation inter AS:计算AS外部路由
Calculation end:计算收尾阶段
N/A:未触发计算
Redistribute timer
引入路由定时器,其中:
·     Off: 关闭
·     On:开启
引入路由调度类型,其中:
·     RIB: 触发遍历RIB表进行引入
·     Self: 触发遍历自身引入表进行引入
N/A:未触发引入
引入路由计数
Process reset state
进程重启状态标志,具体如下:
·     N/A:进程未重启
·     Under reset:进程正在重启
·     Under RIB smooth:进程正在同步RIB路由
Current reset type
当前进程重启类型,具体如下:
·     N/A:进程未重启
·     GR quit:GR异常退出进行普通重启
·     Delete:删除OSPFv3进程
·     Undo router-id:删除Router-id
·     Set router-id:设置Router-id
Next reset type
即将调度进程重启类型,具体如下:
·     N/A:进程未重启
·     Delete:删除OSPFv3进程
响应准备重启消息的模块,具体如下:
·     P代表邻居维护模块
·     S代表LSDB同步模块
·     C代表路由计算模块
·     R代表路由引入模块
响应进程重启消息的模块,具体如下:
·     P代表邻居维护模块
·     S代表LSDB同步模块
·     C代表路由计算模块
·     R代表路由引入模块
各模块所处重启阶段。其中M代表主控制模块,P代表邻居维护模块,S代表LSDB同步模块,其阶段有:
·     N/A:未重启
·     Delete ASE:删除所有ASE LSA
·     Delete area LSA:删除区域相关LSA
·     Delete area IF:删除区域下接口
·     C代表路由计算模块,其阶段有:
·     N/A:未重启
·     Delete topology:删除区域拓扑
·     Delete router:删除路由器路由
·     Delete intra AS:删除AS内部路由
·     Delete inter AS:删除AS外部路由
·     Delete ASBR:删除ASBR路由
·     R代表路由引入模块,其阶段有:
·     N/A:未重启
·     Delete import:删除引入路由
SRv6功能开启状态:
·     Disabled:表示SRv6处于关闭状态
·     Enabled:表示SRv6处于开启状态
Fast-reroute TI-LFA
是否使能TI-LFA快速重路由功能:
·     Disabled:表示未开启
·     Enabled:表示开启
SR防微环功能开启状态:
·     Disabled:表示未开启
·     Enabled:表示开启
SR防微环延迟时间,单位为毫秒
是否使能时延发布功能:
·     Disabled:表示未开启
·     Enabled:表示开启
是否使能带宽发布功能:
·     Disabled:表示未开启
·     Enabled:表示开启
Metric-delay advertisement suppression
时延发布抑制信息,包括:
·     Timer:时延发布抑制定时器,单位为秒
·     Percent threshold:时延变化率的抑制阈值,单位为百分比
·     Absolute threshold:时延变化绝对值的抑制阈值,单位为微秒
带宽发布抑制定时器,单位为秒
Area          (MPLS TE xxx)
区域信息,其中MPLS TE xxx表示是否开启OSPFv3区域的MPLS TE能力:
·     MPLS TE not enabled:表示关闭
·     MPLS TE enabled:表示开启
Area flag
区域类型
SPF scheduled count
OSPF区域的路由计算总数
LSA count
LSA数目,其中:
·     Count:LSA数目
·     checksum Sum:校验和
IPsec profile name
IPsec安全框架名
Cryptographic authentication: HMAC-SHA-256, key ID: xx
OSPFv3区域采用HMAC-SHA-256验证模式,key ID为xx
Cryptographic authentication: HMAC-SM3, key ID: xx
OSPFv3区域采用HMAC-SM3验证模式,key ID为xx
OSPFv3区域采用keychain验证模式,keychain名称为test
MTU
区域的MTU值
Default cost
路由的缺省开销值
Created by Vlink
区域由Vlink创建
Type-7 LSA转换为Type-5 LSA的转换者状态,取值为:
·     Enabled:表示本设备是通过命令指定的Type-7 LSA转换为Type-5 LSA的转换者
·     Elected:表示本设备是通过选举指定的Type-7 LSA转换为Type-5 LSA的转换者
·     Disabled:表示本设备不是Type-7 LSA转换为Type-5 LSA的转换者
Type-7 LSA转换为Type-5 LSA转换稳定定时器的超时时间间隔,单位为秒
display ospfv3 abr-asbr命令用来显示到OSPFv3的区域边界路由器和自治系统边界路由器的路由信息。
display ospfv3 [ process-id ] abr-asbr
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程下到区域边界路由器和自治系统边界路由器的路由信息。
# 显示所有OSPFv3进程的ABR和ASBR路由。
<Sysname> display ospfv3 abr-asbr
 Destination : 1.1.1.2                                   Rtr Type : ABR
 Area        : 0.0.0.0                                   Path Type: Intra
 Interface   : XGE3/1/2                                BkInterface: XGE3/1/1
 NextHop     : FE80:1:1::1
 BkNexthop   : FE80:1:2::2
 Cost        : 1
 TI-LFA      :
   PNode End SID : N/A
   QNode AdvId   : N/A
   LsIndex       : N/A
   Backup label stack(top->bottom): N/A
 Destination : 1.1.1.3                                   Rtr Type : ASBR
 Interface   : XGE3/1/3                                BkInterface: XGE3/1/4
 NextHop     : FE80:2:1::1
 BkNexthop   : FE80:1:2::4
 Cost        : 1
 TI-LFA      :
   PNode End SID : N/A
   QNode AdvId   : N/A
   LsIndex       : N/A
表1-2 display ospfv3 abr-asbr命令显示信息描述表
Destination
ABR或ASBR的路由器ID
Rtr Type
路由器类型,包括ABR和ASBR
Area
下一跳地址所在的区域ID
Path Type
到ABR或ASBR的路由类型,取值为:
·     Intra表示区域内路由
·     Inter表示区域间路由
路由出接口
BkInterface
备份出接口
NextHop
下一跳地址
BkNextHop
备份下一跳地址
Cost
从本路由器到达ABR或ASBR的开销
TI-LFA
TI-LFA路由计算信息:
·     PNode End SID:P节点的End SID
·     QNode AdvId:Q节点的发布源
·     LsIndex:TI-LFA标签栈索引
·     Backup label stack(top->bottom):TI-LFA标签栈信息,从栈顶标签到栈底标签依次排列,“N/A”表示标签栈不存在
LinkTag
链路标记值
display ospfv3 abr-summary命令用来显示OSPFv3的ABR聚合信息。
display ospfv3 [ process-id ] [ area area-id ] abr-summary [ ipv6-address prefix-length ] [ verbose ]
process-id:当前的聚合配置所在进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的ABR聚合信息。
area area-id:显示位于指定区域的ABR聚合信息。如果未指定本参数,将显示所有区域的ABR聚合信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
ipv6-address prefix-length:显示指定IPv6地址的ABR聚合信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为1~128。如果未指定本参数,将显示所有ABR聚合信息。
verbose:显示ABR聚合详细信息。如果未指定本参数,将显示ABR聚合的概要信息。
# 显示OSPFv3进程1的ABR聚合信息。
<Sysname> display ospfv3 1 abr-summary
             OSPFv3 Process 1 with Router ID 2.2.2.2
                     Area: 1.1.1.1
 Total summary addresses: 1
 Prefix      : 1000:4::/32
 Status      : Advertise
 NULL0       : Active
 Cost        : 1 (Configured)
 Routes count: 2
表1-3 display ospfv3 abr-summary命令显示信息描述表
Area
聚合路由所在的区域
聚合路由的路由数
Prefix
聚合路由的地址前缀
Status
聚合路由的状态:
·     Advertise:已发布
·     Not-advertise:未发布
NULL0
NULL0路由:
·     Active:激活
·     Inactive:未激活
Cost
聚合路由的开销
·     Configured:配置的聚合开销
·     Not Configured:未配置聚合开销
Routes count
被聚合的路由数
# 显示OSPFv3进程1的ABR聚合详细信息。
<Sysname> display ospfv3 1 abr-summary verbose
                        Area: 1.1.1.1
 Status      : Advertise
 NULL0       : Active
 Routes count: 2
   Destination                                        Metric
   1000:4:10:3::/96                                   1
   1000:4:11:3::/96                                   1
表1-4 display ospfv3 abr-summary verbose命令显示信息描述表
Destination
被聚合路由的目的地址
Metric
路由的开销值
display ospfv3 asbr-summary命令用来显示OSPFv3的ASBR聚合信息。
display ospfv3 [ process-id ] asbr-summary [ ipv6-address prefix-length ] [ verbose ]
process-id:当前的聚合配置所在进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的ASBR聚合信息。
ipv6-address prefix-length:显示指定IPv6地址的ASBR聚合信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为1~128。如果未指定本参数,将显示所有ASBR聚合信息。
verbose:显示ASBR聚合详细信息。如果未指定本参数,将显示ASBR聚合的概要信息。
# 显示OSPFv3进程1的ASBR聚合信息。
<Sysname> display ospfv3 1 asbr-summary
 Status      : Advertise
 NULL0       : Active
 Tag         : (Not configured)
 Nssa-only   : (Not configured)
 Routes count: 2
表1-5 display ospfv3 asbr-summary命令显示信息描述表
聚合路由的路由数
Prefix
聚合路由的地址前缀和前缀长度
Status
聚合路由的状态:
·     Advertise:已发布
·     Not-advertise:未发布
NULL0
NULL0路由:
·     Active:激活
·     Inactive:未激活
Cost
聚合路由的开销:
·     Not configured:未配置聚合开销
Tag
聚合路由的标记:
·     Configured:配置的聚合标记
·     Not configured:未配置聚合标记
Nssa-only
是否配置Nssa-only:
·     Configured:配置了Nssa-only
·     Not configured:未配置Nssa-only
Routes count
被聚合的路由数
# 显示OSPFv3进程1的ASBR聚合详细信息。
<Sysname> display ospfv3 1 asbr-summary verbose
 Status      : Advertise
 NULL0       : Active
 Routes count: 2
  Destination                                 Protocol Process Type Metric
  1000:4:10:3::/96                            Static   0       2    1
  1000:4:11:3::/96                            Static   0       2    1
表1-6 display ospfv3 asbr-summary verbose命令显示信息描述表
Destination
被聚合路由的前缀和前缀长度
Protocol
被聚合路由的协议类型
Process
被聚合路由的协议进程ID
被聚合路由的类型
Metric
被聚合路由的开销
display ospfv3 event-log命令用来显示OSPFv3的日志信息。
display ospfv3 [ process-id ] event-log { lsa-flush | peer | spf }
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的日志信息。
lsa-flush:LSA老化的日志信息。
peer:邻居的日志信息。
spf:路由计算的日志信息。
路由计算的日志信息是指更新到IPv6路由表的路由计数信息。
邻居的日志信息包括OSPFv3邻居状态倒退到DOWN,以及收到BadLSReq、SeqNumberMismatch和1-Way事件导致邻居状态倒退的信息。
# 显示OSPFv3进程1的LSA老化日志信息。
<Sysname>display ospfv3 1 event-log lsa-flush
               OSPFv3 Process 1 with Router ID 1.3.3.3
 2014-09-02 07:55:25 Received MaxAge LSA from 1.1.1.1
 Type: 3   LS ID: 0.0.0.2         AdvRtr: 1.1.1.1           Seq#: 80000001
 2014-09-02 07:55:22 Flushed MaxAge LSA by itself
 Type: 3   LS ID: 0.0.0.2         AdvRtr: 1.3.3.3           Seq#: 80000001
 2014-09-02 07:55:07 Flushed MaxAge LSA by itself
 Type: 3   LS ID: 0.0.0.40        AdvRtr: 1.3.3.3           Seq#: 80000001
 Type: 3   LS ID: 0.0.0.39        AdvRtr: 1.3.3.3           Seq#: 80000001
表1-7 display ospfv3 event-log lsa-flush命令显示信息描述表
Received MaxAge LSA from X.X.X.X
从Router ID为X.X.X.X的源收到MaxAge LSA
自身发起的老化,洪泛MaxAge LSA
LSA类型
LS ID
LSA链路状态ID
AdvRtr
发布LSA的路由器,用Router ID表示
Seq#
LSA序列号
# 显示OSPFv3进程1的路由计算的日志信息。
<Sysname>display ospfv3 1 event-log spf
 Date       Time     Duration   Intra   Inter   External Reason
 2020-03-02 07:55:30 0.258827   0       0       0        Intra-area LSA
 2020-03-02 07:55:30 0.679      0       0       0        Intra-area LSA
 2020-03-02 07:55:30 0.51576    0       0       0        Intra-area LSA
 2020-03-02 07:55:30 0.372      0       0       0        Intra-area LSA
 2020-03-02 07:55:25 4.948353   0       0       0        Intra-area LSA
 2020-03-02 07:55:25 0.5288     0       0       0        Area 0 full neighbor
 2020-03-02 07:55:21 1.66013    0       0       0        Intra-area LSA
 2020-03-02 07:55:20 0.450905   0       0       0        Intra-area LSA
 2020-03-02 07:55:15 0.253688   0       0       0        Interface state change
 2020-03-02 07:55:15 0.5693     0       0       0        Intra-area LSA
 2020-03-02 07:47:54 0.156      0       0       0        Intra-area SRv6 tunnel
表1-8 display ospfv3 event-log spf命令显示信息描述表
Date
路由计算开始的日期,单位为YYYY-MM-DD,其中YYYY为年,MM为月,DD为日
Time
路由计算开始的时间,单位为hh:mm:ss,其中hh为小时,mm为分钟,ss为秒
Duration
路由计算持续时间,单位为秒
Intra
区域内路由变化的个数
Inter
区域间路由变化的个数
External
外部路由变化的个数
Reason
路由计算的原因:
·     Intra-area LSA:区域内LSA变化
·     Inter-area LSA:区域间LSA变化
·     External LSA:外部LSA变化
·     Configuration:配置变化
·     Area 0 full neighbor:区域0 FULL邻居个数变化
·     Area 0 up interface:区域0 UP接口个数变化
·     AS number:AS号变化
·     ABR summarization:ABR聚合变化
·     GR end:GR结束
·     Routing policy:路由策略变化
·     Intra-area tunnel:区域内隧道变化
·     Intra-area SRv6 tunnel:区域内SRv6隧道变化
·     Others:除上述原因之外的其他原因
# 显示OSPFv3进程1的邻居的日志信息。
<Sysname> display ospfv3 1 event-log peer
 Date       Time     Router ID       Reason       InstID  Interface
 2014-09-02 16:39:13 1.3.3.3         IntPhyChange 0       XGE3/1/1
 2014-09-02 16:36:46 1.3.3.3         IntPhyChange 0       XGE3/1/1
 2014-09-02 16:34:49 1.3.3.3         BFDDown      0       XGE3/1/1
 2014-09-02 10:08:45 1.3.3.3         DeadExpired  0       XGE3/1/2
 2014-09-02 10:08:39 1.3.3.3         DeadExpired  0       VLINK1
 2014-09-02 10:08:08 1.3.3.3         BFDDown      0       XGE3/1/1
表1-9 display ospfv3 event-log peer命令显示信息描述表
Date
邻居状态变化的日期,单位为YYYY-MM-DD,其中YYYY为年,MM为月,DD为日
Time
邻居状态变化的时间,单位为hh:mm:ss,其中hh为小时,mm为分钟,ss为秒
Router ID
邻居的Router ID
Reason
邻居状态变化的原因:
·     ResetConnect:内存不足,邻居关系中断
·     IntChange:接口参数改变
·     ResetOspfv3:重启OSPFv3进程
·     UndoOspfv3:删除OSPFv3进程
·     UndoArea:删除OSPFv3区域
·     UndoInt:接口去使能
·     IntLogChange:接口逻辑属性变化
·     IntPhyChange:接口物理属性变化
·     DeadExpired:Dead Timer超时
·     Retrans:重传过多
·     BFDDown:BFD Down
·     SilentInt:配置抑制接口
·     ConfStubArea:配置Stub区域参数
·     ConfNssaArea:配置NSSA区域参数
·     VlinkDown:虚连接Down
·     ShamlinkDown:伪连接Down
·     BadLSReq:收到BadLSReq事件
·     SeqMismatch:收到SeqNumberMismatch事件
·     1-Way:收到1-Way事件
InstID
接口所属的实例ID
接口名称
display ospfv3 flex-algo routing命令用来显示Flex-Algo算法计算出来的路由信息。
display ospfv3 [ process-id ] flex-algo flex-algo-id routing [ ipv6-address prefix-length ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的路由表信息。
flex-algo flex-algo-id:显示指定Flex-Algo算法的OSPFv3路由表信息。flex-algo-id表示算法ID,取值范围为128~255。
ipv6-address prefix-length:显示指定IPv6地址前缀的OSPFv3路由表的信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为0~128。如果未指定本参数,将显示所有IPv6地址前缀的OSPFv3路由表的信息。
# 显示Flex-Algo算法128计算出来的路由信息。
<Sysname> display ospfv3 flex-algo 128 routing
               OSPFv3 Process 1 with Router ID 9.9.9.9
 I  - Intra area route,  E1 - Type 1 external route,  N1 - Type 1 NSSA route
 IA - Inter area route,  E2 - Type 2 external route,  N2 - Type 2 NSSA route
 *  - Selected route
 *Destination: 1::/64
  Type       : IA                        Area       : 0.0.0.1
  AdvRouter  : 2.2.2.2                   Preference : 10
  NibID      : 0x23000003                Cost       : 2
  Interface  : XGE3/1/1                  BkInterface: XGE3/1/2
  Nexthop    : FE80::6AC7:45FF:FE5C:206
  BkNexthop  : N/A
  Status     : Direct
 *Destination: 23::/64
  Type       : I                         Area       : 0.0.0.1
  AdvRouter  : 3.3.3.3                   Preference : 10
  NibID      : 0x23000001                Cost       : 1
  Nexthop    : ::
  BkNexthop  : N/A
  Status     : Direct
 *Destination: 8::/64
  Type       : E2                        Tag        : 1
  AdvRouter  : 1.1.1.1                   Preference : 150
  NibID      : 0x23000004                Cost       : 1
  BkNexthop  : N/A
  Status     : Normal
 Total: 3
 Intra area: 3         Inter area: 0         ASE: 0         NSSA: 0
表1-10 display ospfv3 flex-algo routing命令显示信息描述表
Destination
目的网络地址
路由类型
Tag
外部路由标记
·     1:表示第一类外部路由
·     2:表示第二类外部路由
Area
区域ID
AdvRouter
发布路由器的Router ID
Preference
路由优先级
NibID
路由下一跳信息的ID值
Cost
路由开销值
出接口的类型和编号
BkInterface
备份下一跳出接口
Nexthop
下一跳地址
BkNexthop
备份下一跳地址
Status
路由状态,具体如下:
·     Local:该条路由在本地,未发送给路由管理模块
·     Invalid:路由下一跳无效
·     Stale:该路由下一跳较旧
·     Normal:正常可用状态
·     Delete:处于删除状态
·     Direct:该条路由为直连路由
TI-LFA
TI-LFA信息
PNode End SID
P节点的End SID
QNode AdvId
Q节点的发布源Router ID
LsIndex
标签栈索引值
备份标签栈,从栈顶标签到栈底标签依次排列,“N/A”表示标签栈不存在
Total
路由总数目
Intra area
区域内路由数目
Inter area
区域间路由数目
ASE
5类外部路由数目
NSSA
7类外部路由数目
display ospfv3 flex-algo spf-tree命令用来显示OSPFv3区域的最短路径树信息。
display ospfv3 [ process-id ] [ area area-id ] flex-algo flex-algo-id spf-tree [ verbose ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程下区域的最短路径树信息。
area area-id:显示指定区域的最短路径树信息。如果未指定本参数,将显示所有区域的最短路径树信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
flex-algo flex-algo-id:显示指定算法ID的最短路径树信息。flex-algo-id表示算法ID,取值范围为128~255。
verbose:显示OSPFv3区域的最短路径树的详细信息。如果未指定本参数,将显示OSPFv3区域的最短路径树的概要信息。
# 显示OSPFv3进程1区域0下Flex-algo算法128的最短路径树的概要信息。
<Sysname> display ospfv3 1 area 0 flex-algo 128 spf-tree
 Flags: S-Node is on SPF tree       R-Node is directly reachable
        I-Node or Link is init      D-Node or Link is to be deleted
        P-Neighbor is parent        A-Node is in candidate list
        C-Neighbor is child         H-Nexthop changed
        N-Link is a new path        V-Link is involved
           Area: 0.0.0.0  Flex Algo Shortest Path Tree
 SPFNode          Type     Flag       SPFLink         Type   Cost  Flag
>2.2.2.2          Router   S
                                   -->2.2.2.2         RT2NET 1     P
>2.2.2.2          Network  S R
                                   -->2.2.2.2         NET2RT 0     C
                                   -->1.1.1.1         NET2RT 0     P
>1.1.1.1          Router   S
                                   -->2.2.2.2         RT2NET 1     C
表1-11 display ospfv3 flex-algo spf-tree命令显示信息描述表
SPFNode
SPF节点,以路由器ID作为标识
节点类型:
·     Network:表示网络节点
·     Router:表示路由器节点
Flag
节点标志:
·     I:节点处于初始化状态
·     A:节点在候选列表上
·     S:节点在SPF树上
·     R:该节点与根节点直连
·     D:该节点将被删除
SPFLink
SPF链路,以路由器ID作为标识
链路类型:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
Cost
链路开销
Flag
链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     V:目的节点删除或者是新增节点时,链路的目的节点不在SPF树上或处于删除状态
·     N:新增链路,并且源节点和目的节点都在SPF树上
·     L:链路在区域变化列表中
# 显示OSPFv3进程1下区域0的Flex-algo算法128的最短路径树详细信息。
<Sysname> display ospfv3 1 area 0 flex-algo 128 spf-tree verbose
           Area: 0.0.0.0  Shortest Path Tree
>SPFNode[0]
  AdvID        : 1.1.1.1                  LsID       : 0.0.0.0
  NodeType     : Router                   Distance   : 1
  NodeFlag     : S R
  Nexthop count: 1
 -->NbrID      : 1.1.1.1                  NbrIntID   : 21
    Interface  : XGE3/1/2                 NhFlag     : Valid
    BkInterface: XGE3/1/3                 RefCount    : 4
    Nexthop    : FE80::20C:29FF:FED7:F308
    BkNexthop  : FE80::4
  SPFLink count: 1
 -->AdvID      : 1.1.1.1                  LsID       : 0.0.0.0
    IntID      : 232                      NbrIntID   : 465
    NbrID      : 2.2.2.2                  LinkType   : RT2RT
    LinkCost   : 1                        LinkNewCost: 1
    LinkFlag   : C                        NexthopCnt : 0
  ParentLink count: 1
    IntID      : 215                      NbrIntID   : 466
    LinkFlag   : P                        NexthopCnt : 0
>SPFNode[2]
  AdvID        : 4.4.4.4                  LsID       : 0.0.0.0
  NodeType     : Router                   Distance   : 2
  NodeFlag     : S
  Nexthop count: 2
 -->NbrID      : 4.4.4.4                  NbrIntID   : 0
    Interface  : XGE3/1/1                 NhFlag     : Valid
    BkInterface: N/A                      RefCount   : 1
    Nexthop    : 4::44
    BkNexthop  : N/A
 -->NbrID      : 2.2.2.2                  NbrIntID   : 258
    BkInterface: N/A                      RefCount   : 5
    Nexthop    : FE80::362E:A7FF:FE29:616
    BkNexthop  : N/A
  SPFLink count: 0
  ParentLink count: 1
 -->AdvID      : 4.4.4.4                  LsID       : 0.0.0.0
    IntID      : 259                      NbrIntID   : 259
    NbrID      : 4.4.4.4                  LinkType   : RT2NET
表1-12 display ospfv3 flex-algo spf-tree verbose命令显示信息描述表
SPFNode
SPF节点
AdvID
通告路由器ID
LsID
链路状态ID
NodeType
节点类型:
·     Network:表示网络节点
·     Router:表示路由器节点
Distance
到根节点的开销
NodeFlag
节点标志:
·     I:节点处于初始化状态
·     A:节点在候选列表上
·     S:节点在SPF树上
·     R:该节点与根节点直连
·     D:该节点将被删除
Nexthop count
下一跳计数
NbrID
邻居路由器ID
NbrIntID
邻居的接口ID
出接口
NhFlag
下一跳标志:
·     Valid:有效
·     Invalid:无效
BkInterface
备份下一跳出接口
RefCount
下一跳的引用计数
Nexthop
下一跳地址
BkNexthop
备份下一跳地址
SPFLink count
SPF链路计数
IntID
接口ID
LinkType
链路类型:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
LinkCost
当前链路开销
LinkNewCost
新的链路开销
LinkFlag
链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     L:链路在区域变化列表中
NexthopCnt
下一跳个数
ParentLink count
父链路计数
display ospfv3 global-flex-algo命令用来显示本节点接收和发布的Flex-Algo算法的定义信息。
display ospfv3 [ process-id ] [ area area-id ] global-flex-algo [ algorithm-id flex-algo-id ]
process-id:显示指定OSPFv3进程下的Flex-Algo定义信息。process-id表示OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示本节点上所有OSPFv3进程接收和发布的Flex-Algo算法定义信息。
area area-id:显示指定OSPFv3区域下的Flex-Algo定义信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。如果未指定本参数,将显示所有区域的OSPFv3进行接收和发送的Flex-Algo算法定义信息。
algorithm-id flex-algo-id:显示指定算法ID的Flex-Algo算法定义信息。flex-algo-id表示算法ID,取值范围为128~255。如果未指定本参数,将显示本节点接收和发布的所有算法ID的Flex-Algo算法定义信息。
如果未指定任何参数,将显示本节点接收和发布的所有Flex-Algo算法的定义信息。
# 显示OSPFv3进程1在区域0接收和发布的Flex-Algo算法定义信息。
<Sysname> display ospfv3 1 area 0 global-flex-algo
Area: 0.0.0.0
    Algorithm: 130
        RouterID      : 2.2.2.2
        Priority      : 255
        MetricType    : IGP
        Status        : Active
        Exclude Any EAG: 0x00000000 0x00000000
                         0x00000004
        Include Any EAG: N/A
        Include All EAG: N/A
    SrcCount  : 2
     -->RouterID      : 1.1.1.1
        Priority      : 255
        MetricType    : IGP
                         0x00000004
     -->RouterID      : 2.2.2.2
        Priority      : 255
        MetricType    : IGP
                         0x00000004
表1-13 display ospfv3 global-flex-algo命令显示信息描述表
OSPFv3进程号以及OSPFv3 Router ID
Area
OSPFv3区域
Algorithm xx
算法ID为xx的Flex-Algo路由信息
Router ID
Flex-Algo算法发布源的Router ID
Priority
Flex-Algo算法的优先级
Metric type
算法度量类型。当前仅支持IGP类型,即OSPFv3的链路开销
Status
Flex-Algo算法的定义信息的状态:
·     Active:生效
·     Inactive:失效
Exclude Any EAG
Flex-Algo算法排除的扩展管理组属性。显示为N/A表示Flex-Algo算法未定义排除的扩展管理组属性
Include Any EAG
Flex-Algo算法包含的扩展管理组属性。显示为N/A表示Flex-Algo算法未定义包含的扩展管理组属性
Include All EAG
Flex-Algo包含的所有扩展管理组属性。显示为N/A表示Flex-Algo算法未定义包含的所有扩展管理组属性
SrcCount
发布源个数
display ospfv3 global-statistics命令用来显示OSPFv3的全局统计信息。
display ospfv3 global-statistics [ public | vpn-instance vpn-instance-name ]
public:显示公网下OSPFv3的全局统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例下OSPFv3的全局统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
如果不指定任何参数,将显示公网和VPN实例下OSPFv3的全局统计信息。
# 显示OSPFv3的全局统计信息。
<Sysname> display ospfv3 global-statistics
  OSPFv3 global statistics
   Instance count   : 2
   Process count    : 2
   Interface information
    Down            : 1
    Up              : 1
   Neighbor information
    Down            : 0
    Init            : 0
    Attempt         : 0
    2-Way           : 0
    ExStart         : 0
    Exchange        : 0
    Loading         : 0
    Full            : 0
   Packets sent     : 0
   Packets received : 0
   LSA count        : 2
   Route count      : 1
表1-14 display ospfv3 global-statistics命令输出信息描述表
Instance count
公网和VPN实例下存在OSPFv3配置时,对公网和VPN实例总数的统计信息
Process count
进程数量
接口状态统计信息
Down
状态为Down的接口数目
Up
状态为Up的接口数目
邻居状态统计信息
Down
状态为Down的邻居路由器数目
Attempt
状态为Attempt的邻居路由器数目
Init
状态为Init的邻居路由器数目
2-Way
状态为2-Way的邻居路由器数目
ExStart
状态为ExStart的邻居路由器数目
Exchange
状态为Exchange的邻居路由器数目
Loading
状态为Loading的邻居路由器数目
Full
状态为Full的邻居路由器数目
Packets sent
发送协议报文的数目
Packets received
接收协议报文的数目
LSA count
链路状态数据库中所有LSA的数目
Route count
OSPFv3所有路由的数目
display ospfv3 graceful-restart命令用来显示OSPFv3进程的GR状态信息。
display ospfv3 [ process-id ] graceful-restart [ verbose ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的GR状态信息。
verbose:显示GR详细状态信息。如果未指定本参数,将显示OSPFv3进程的GR状态概要信息。
# 显示所有OSPFv3进程的GR状态信息(Restarter)。
<Sysname> display ospfv3 graceful-restart
               OSPFv3 Process 1 with Router ID 3.3.3.3
 Graceful-restart capability     : Enable
 Graceful-restart support        : Planned and unplanned, Partial
 Helper capability               : Enable
 Helper support                  : Planned and unplanned
 Current GR state                : Normal
 Graceful-restart period         : 120 seconds
 Number of neighbors under helper: 0
 Number of restarting neighbors  : 0
 Last exit reason:
   Restarter: None
   Helper   : None
表1-15 display ospfv3 graceful-restart命令显示信息描述表
OSPFv3进程是1,Router ID是3.3.3.3的GR状态信息
是否使能OSPFv3协议的GR能力
·     Enable:使能
·     Disable:未使能
进程GR支持模式(GR使能时才显示):
·     Planned and unplanned:支持计划和非计划GR
·     Planned only:只支持计划性GR
·     Partial:支持接口级GR
·     Global:不支持接口级GR,支持全局GR
Helper capability
是否使能OSPFv3协议的GR Helper能力
·     Enable:使能
·     Disable:未使能
Helper support
显示Helper的支持模式:
·     Strict LSA check:Helper端支持严格的LSA检查
·     Planned and unplanned:支持作为计划和非计划GR的Helper
·     Planned only:只支持作为计划GR的Helper
Current GR state
当前GR的状态,其状态有如下几种:
·     Normal:表示正处在非GR的正常状态
·     Under GR:表示正在GR过程中,自身作为Restarter
·     Under Helper:表示正在GR过程中,自身作为Helper
GR重启间隔时间
处于GR Helper模式的邻居个数
处于GR Restarter模式的邻居个数
Last exit reason
上次退出原因,其中:
·     Restarter:表示退出Restarter的原因
¡     None:无
¡     Completed:GR完成
¡     Interval timer is fired:GR定时器超时
¡     Interface state change:接口状态变化
¡     Received 1-way hello:收到邻居的1-way Hello报文
¡     Reset neighbor:邻居发生Reset操作
¡     DR or BDR change:DR或BDR发生变化
·     Helper:表示退出Helper的原因
¡     None:无
¡     Completed:GR完成
¡     Grace Period timer is fired:GR定时器超时
¡     Lsa check failed:LSA检查未通过
¡     Received MAXAGE gracelsa but neighbor is not full:收到到达老化时间的Grace LSA,但邻居状态未达到FULL状态
# 显示OSPFv3进程的GR详细状态信息(Restarter)。
<Sysname> display ospfv3 graceful-restart verbose
 Last exit reason:
   Restarter: None
   Helper   : None
 Area: 0.0.0.0
 Area flag: Normal
 Area up interface count: 1
 Virtual-link Neighbor-ID: 100.1.1.1, Neighbor-state: Full
 Restarter state: Normal   State: P-2-P    Type: Virtual
 Interface: 6696 (Ten-GigabitEthernet3/1/2), Instance-ID: 0
 Local  IPv6 address: 200:1:FFFF::1
 Remote IPv6 address: 201:FFFF::2
 Transit area: 0.0.0.1
 Last exit reason:
   Restarter: None
   Helper   : None
 Neighbor       GR state       Last helper exit reason
 100.1.1.1      Normal         None
 Area: 0.0.0.1
 Area flag: Transit
 Area up interface count: 3
 Interface: 5506 (Ten-GigabitEthernet3/1/3), Instance-ID: 0
 Restarter state: Normal   State: DR       Type: Broadcast
 Last exit reason:
   Restarter: None
   Helper   : None
 Neighbor count of this interface: 0
 Last exit reason:
   Restarter: None
   Helper   : None
 Neighbor count of this interface: 1
 Sham-link Neighbor-ID: 100.1.1.1, Neighbor-state: Full
 Restarter state: Normal   State: P-2-P    Type: Sham
 Interface-ID: 2147483649, Instance-ID: 0
 Source      : 8000:88::FFFF
 Destination : 7000:77::FFFF
 Last exit reason:
   Restarter: None
   Helper   : None
 Area: 0.0.0.5
 Area flag: NSSANoSummaryNoImportRoute
 Area up interface count: 0
表1-16 display ospfv3 graceful-restart命令显示信息描述表
Area
区域信息
Area flag
区域类型:
·     Normal:普通区域
·     Transit:传输区
·     Stub:Stub区域
·     StubNoSummary:完全Stub区域
·     NSSA:NSSA区域
·     NSSANoSummary:完全NSSA区域
·     NSSANoSummaryNoImportRoute:完全NSSA区域,配置了no-import-route参数
·     Enabled:表示通过命令指定Type-7 LSA转换为Type-5 LSA的转换者
·     Elected:表示通过选举指定Type-7 LSA转换为Type-5 LSA的转换者
·     Disabled:表示不是Type-7 LSA转换为Type-5 LSA的转换者
Type-7 LSA转换为Type-5 LSA转换稳定定时器的超时时间,单位为秒
区域下up的接口计数
区域内的普通接口,以及虚连接所属的出接口
Instance-ID
接口实例ID
Restarter state
作为Restarter的状态
接口状态
接口的网络类型
接口下的邻居个数
Neighbor
邻居Router ID
GR state
邻居的GR状态:
·     Normal:普通状态
·     Under GR:进程正在GR
·     Under Helper:进程正在作为GR Helper
上一次作为该邻居Helper退出的原因
虚连接的邻居Router ID
Neighbor-State
虚连接和邻居的状态,包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
Local  IPv6 address
本地IPv6地址
Remote IPv6 address
对端IPv6地址
Transit area
传输区域ID
Sham link的邻居Router ID
Source
Sham link源地址
Destination
Sham link目的地址
display ospfv3 interface命令用来显示OSPFv3的接口信息。
display ospfv3 [ process-id ] interface [ interface-type interface-number | verbose ]
interface-type interface-number:接口类型和接口编号。显示指定接口的详细信息。
verbose:显示所有接口的详细信息。
如果未指定OSPFv3进程号,将显示所有OSPFv3进程的接口概要信息。
如果未指定接口或参数verbose,将显示所有接口的概要信息。
# 显示运行OSPFv3的接口Ten-GigabitEthernet3/1/1的信息。
<Sysname> display ospfv3 interface ten-gigabitethernet 3/1/1
 Area: 0.0.0.0
 Ten-GigabitEthernet3/1/1 is up, line protocol is up
  Interface ID 3        Instance ID 0
  IPv6 prefixes
    FE80::200:12FF:FE34:1  (Link-Local address)
    2001::1
  Cost: 1       State: BDR       Type: Broadcast    MTU: 1500
  Cost source: Default
  Priority: 1
  Designated router: 2.2.2.2
  Backup designated router: 1.1.1.1
  Timers: Hello 10, Dead 40, Poll 40, Retransmit 5, Transmit delay 1
  FRR backup: Enabled
  FRR TI-LFA: Enabled
  Link tag: 100
  Neighbor count is 1, Adjacent neighbor count is 1
  Primary path detection mode: BFD echo
  IPsec profile name: profile001, inherited
  Keychain authentication: Enabled (test), inherited
  Exchanging/Loading neighbors: 0
  Wait timer: Off,  LsAck timer: Off
  Prefix-suppression is enabled
  Average delay: 100 us
  Min delay: 10 us
  Max delay: 200 us
  Delay variation: 0 us
  Link quality: GOOD, cost adjusted at low quality: Maximum
  BFD adjust cost: 1000
  BFD suppress flapping: Detect interval 30s
                         Threshold 2
                         Resume interval 10s
  Virtual system: Enabled
  Virtual Router ID: 3.3.3.3
表1-17 display ospfv3 interface命令显示信息描述表
Area
接口所属的区域ID
Interface ID
接口ID
Instance ID
实例ID
IPv6 prefixes
IPv6前缀
Cost
接口开销
根据OSPFv3接口状态机确定的当前接口状态,取值为:
·     Down:表示在接口上没有发送和接收任何路由协议的报文
·     Waiting:表示接口开始发送和接收Hello报文,并试图去识别网络上的DR和BDR
·     P-2-P:表示接口将每隔HelloInterval的时间间隔发送Hello报文,并尝试和接口链路另一端相连的路由器建立邻接关系
·     DR:表示路由器是所连网络的指定路由器
·     BDR:表示路由器是所连网络的备份指定路由器
·     DROther:表示路由器既不是所连网络的指定路由器,也不是所连网络的备份指定路由器
接口的网络类型,取值为:
·     PTP:表示网络类型为点对点
·     PTMP:表示网络类型为点对多点
·     Broadcast:表示网络类型为广播
·     NBMA:表示网络类型为NBMA
MTU
接口MTU的值
Cost source
接口当前的链路开销值来源,取值包括以下几种情况:
·     Default:缺省值
·     Manual:接口下配置的链路开销值
·     Fallback:三层聚合接口的带宽低于阈值时调整的链路开销值
·     LinkUp:Hold-max-cost生效期间,向邻居通告的最大链路开销值
·     BFD:BFD会话Down时的链路开销值
·     LOW:链路质量等级为LOW时调整的链路开销值
Priority
接口的DR优先级
Designated router
本链路上的DR
本链路上的BDR
Timers
配置的OSPFv3定时器,分别定义如下:
·     Hello:表示接口发送Hello报文的时间间隔,单位为秒
·     Dead:表示邻居的失效时间,单位为秒
·     Poll:表示NBMA网络上发送轮询Hello报文的时间间隔,单位为秒
·     Retransmit:表示接口重传LSA的时间间隔,单位为秒
Transmit Delay
接口对LSA的传输延迟时间,单位为秒
FRR backup
是否使能接口参与LFA(Loop Free Alternate)计算:
·     Enabled:使能
·     Disabled:关闭
Link tag
接口的链路标记值
FRR TI-LFA
接口参与TI-LFA计算状态:
·     Enabled:允许接口参与TI-LFA计算
·     Disabled:禁止接口参与TI-LFA计算
Neighbor count
接口的邻居数目
主链路检测方式:
·     BFD ctrl:BFD控制报文检测方式
·     BFD echo:BFD echo报文检测方式
接口的邻接数目
OSPFv3接口应用IPsec安全框架,IPsec安全框架名称为profile001,inherited表示接口继承的是其所属区域下配置的IPsec安全框架
Cryptographic authentication: HMAC-SM3, key ID: xx, inherited
OSPFv3接口采用HMAC-SM3验证模式,key ID为xx,inherited表示接口继承的是其所属区域下配置的HMAC-SM3验证模式
Cryptographic authentication: HMAC-SHA-256, key ID: xx, inherited
OSPFv3接口采用HMAC-SHA-256验证模式,key ID为xx,inherited表示接口继承的是其所属区域下配置的HMAC-SHA-256验证模式
OSPFv3接口采用keychain验证模式,keychain名称为test,inherited表示接口继承的是其所属区域下配置的keychain验证模式
处于Exchanging或Loading状态的邻居个数
Wait timer
等待定时器,其中:
·     Off:关闭
·     On:开启
LsAck timer
报文确认定时器,其中:
·     Off:关闭
·     On:开启
接口处于前缀抑制
Average delay
平均时延,单位为微秒
Max delay
最大时延,单位为微秒
Min delay
最小时延,单位为微秒
Delay variation
时延容差,单位为微秒
Link quality
接口的链路质量等级:
·     GOOD:链路质量优。误码率未达到高误码率门限或者误码率从大于等于高误码率门限回落到小于低误码率门限时,显示为GOOD
·     LOW:链路质量差。误码率达到高误码率门限时,链路质量显示为LOW
该信息仅在接口配置了ospfv3 link-quality adjust-cost命令时显示
当链路质量等级为LOW时接口开销值的调整值:
·     xx:表示调整值,即当链路质量等级为LOW时,接口的开销值=接口原本的开销值+xx
·     Maximum:表示调整为最大值,即当链路质量等级为LOW时,接口的开销值=最大值65535
BFD adjust cost
是否开启根据BFD会话状态调整接口开销值功能:
·     Disabled:表示关闭
·     1~65534:表示接口的开销调整值。调整后的接口开销值=接口的开销调整值+接口原本的开销值
·     Maximum:表示将接口的开销值调整为最大值65534
该信息仅在接口配置了ospfv3 bfd adjust-cost命令时显示
BFD会话震荡时抑制OSPFv3根据BFD会话状态调整接口开销值:
·     Detect interval:检测BFD会话状态变化的时间间隔,单位为秒
·     Threshold:BFD会话Down次数的阈值,单位为次。在Detect interval内检测到的BFD会话Down的次数小于阈值时,会通过BFD down times显示BFD会话Down的次数
·     Resume interval:延迟恢复接口开销值的时间间隔,单位为秒。remain表示定时器剩余时间
该信息仅在接口配置了ospfv3 bfd adjust-cost suppress-flapping命令时显示
Virtual system
接口是否开启OSPFv3共网段功能:
·     Enabled:开启
·     Disabled:关闭
Virtual Router ID
虚拟OSPFv3节点的Router ID
display ospfv3 local-flex-algo命令用来显示本节点对Flex-Algo算法的定义信息。
display ospfv3 [ process-id ] local-flex-algo [ algorithm-id flex-algo-id ]
process-id:显示指定OSPFv3进程的Flex-Algo算法定义信息。process-id为OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的OSPFv3 Flex-Algo算法定义信息。
algorithm-id flex-algo-id:显示指定算法ID的Flex-Algo算法定义信息。flex-algo-id表示算法ID,取值范围为128~255。如果未指定本参数,将显示本节点对所有Flex-Algo算法的定义信息。
# 显示本节点所有OSPFv3进程下,算法ID为255的Flex-Algo算法定义信息。
<Sysname> display ospfv3 local-flex-algo algorithm-id 255
Flex-Algo(255)
    Definition advertisement             : Enabled
    Priority                             : 255
    Metric type                          : IGP
    Fast reroute                         : Enabled
表1-18 display ospfv3 local-flex-algo命令显示信息描述表
Flex-Algo(xx)
Flex-Algo算法的定义信息,xx表示算法ID
本节点是否开启了Flex-Algo算法定义的通告功能:
·     Enabled:Flex-Algo算法定义通告功能处于开启状态
·     Disabled:Flex-Algo算法定义通告功能处于关闭状态
Priority
Flex-Algo算法的优先级
Metric type
Fast reroute
快速重路由功能的状态:
·     Enabled:快速重路由功能处于开启状态
·     Disabled:快速重路由功能处于关闭状态
display ospfv3 lsdb命令用来显示OSPFv3的链路状态数据库信息。
display ospfv3 [ process-id ] lsdb [ { e-inter-prefix | e-inter-router | e-router | external | grace | inter-prefix | inter-router | intra-prefix | intra-te | link | locator | network | nssa | router | router-information | unknown [ type ] } [ link-state-id ] [ originate-router router-id | self-originate ] | statistics | total | verbose ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的链路状态数据库信息。
e-inter-prefix:显示链路状态数据库中Type-35 LSA(E-Inter-Area-Prefix LSA)的信息。
e-inter-router:显示链路状态数据库中Type-36 LSA(E-Inter-Area-Router LSA)的信息。
e-rouer:显示链路状态数据库中Type-33 LSA(E-Router LSA)的信息。
external:显示链路状态数据库中Type-5 LSA(AS External LSA)的信息。
grace:显示链路状态数据库中Type-11 LSA(Grace LSA)的信息。
inter-prefix:显示链路状态数据库中Type-3 LSA(Inter-Area-Prefix LSA)的信息。
inter-router:显示链路状态数据库中Type-4 LSA(Inter-Area-Router LSA)的信息。
intra-prefix:显示链路状态数据库中Type-9 LSA(Intra-Area-Prefix LSA)的信息。
intra-te:显示链路状态数据库中Type-10 LSA(Intra-Area-TE LSA)的信息。
link:显示链路状态数据库中Type-8 LSA(Link LSA)的信息。
locator:显示链路状态数据库中Type-42 LSA(Locator LSA)的信息。
network:显示链路状态数据库中Type-2 LSA(Network LSA)的信息。
nssa:显示链路状态数据库中Type-7 LSA(NSSA LSA)的信息。
router:显示链路状态数据库中Type-1 LSA(Router LSA)的信息。
router-information:显示链路状态数据库中Type-12 LSA(Router-Information LSA)的信息。
unknown:显示链路状态数据库中未知类型LSA的信息。
type:LSA类型,取值范围为十六进制数0~ffff。如果未指定本参数,将显示所有未知类型LSA的信息。
link-state-id:链路状态ID,IPv4地址形式。
originate-router router-id:发布该LSA的路由器的Router ID。
self-originate:显示本地路由器自己产生的LSA的链路状态数据库信息。
statistics:显示链路状态数据库中LSA的统计信息。
total:显示链路状态数据库中各种LSA的总数。
# 显示OSPFv3的链路状态数据库信息。
<Sysname> display ospfv3 lsdb
                  Link-LSA (Interface Ten-GigabitEthernet3/1/1)
 Link state ID   Origin router    Age   SeqNumber  Checksum  Prefix
 0.15.0.8        2.2.2.2          0691  0x80000041 0x8315         1
 0.0.0.3         1.1.1.1          0623  0x80000001 0x0fee         1
                  Router-LSA (Area 0.0.0.1)
 Link state ID   Origin router    Age   SeqNumber  Checksum    Link
 0.0.0.0         1.1.1.1          0013  0x80000068 0x5d5f         2
 0.0.0.0         2.2.2.2          0024  0x800000ea 0x1e22         0
                  Network-LSA (Area 0.0.0.1)
 0.15.0.8        2.2.2.2          0019  0x80000007 0x599e
                  Intra-Area-Prefix-LSA (Area 0.0.0.1)
 Link state ID   Origin router    Age   SeqNumber  Checksum  Prefix  Reference
 0.0.0.2         2.2.2.2          3600  0x80000002 0x2eed         2  Network-LSA
 0.0.0.1         2.2.2.2          0018  0x80000001 0x1478         1  Network-LSA
                 Intra-Area-TE-LSA (Area 0.0.0.0)
 0.0.0.1         2.2.2.2          0114  0x80000001 0xb542
 0.0.0.0         2.2.2.2          0197  0x80000001 0xe79f
                  E-Router-LSA (Area 0.0.0.1)
 0.0.0.1         1.1.1.1          0009  0x80000001 0x1aa9         1
 0.0.0.0         1.1.1.1          0027  0x80000001 0x395e         1
                  E-Inter-Area-Prefix-LSA (Area 0.0.0.1)
 0.0.0.0         2.2.2.2          0019  0x80000007 0x599e
                  E-Inter-Area-Router-LSA (Area 0.0.0.1)
 0.0.0.0         2.2.2.2          0037  0x8000001d 0xeaf6
表1-19 display ospfv3 lsdb命令显示信息描述表
Link state ID
链路状态ID
Origin router
产生LSA的路由器
Age
LSA老化时间
SeqNumber
LSA序列号
Checksum
LSA校验和
Prefix
前缀数目
Link
链路数目
Reference
引用的LSA类型
# 显示OSPFv3链路状态数据库中Link-LSA的信息。
<Sysname> display ospfv3 lsdb link
  LS age            : 833
  LS type           : Link-LSA
  Link state ID     : 0.15.0.8
  Originating router: 2.2.2.2
  LS seq number     : 0x80000041
  Checksum          : 0x8315
  Length            : 56
  Priority          : 1
  Options           : 0x000013 (-|R|-|x|E|V6)
  Link-Local address: fe80::200:5eff:fe00:100
  Number of prefixes: 1
      Prefix        : 1001::/64
      Prefix options: 0 (-|R|-|x|E|V6)
表1-20 display ospfv3 lsdb link命令显示信息描述表
LS age
LSA老化时间
LS type
LSA类型
Link state ID
链路状态ID
Originating router
产生LSA的路由器
LS seq number
LSA序列号
Checksum
LSA校验和
Length
LSA长度
Priority
路由器优先级
Options
LSA选项,各选项含义如下:
·     DC:支持按需链路
·     R:活跃路由器
·     N:支持NSSA外部LSA
·     x:保留
·     E:拥有接收AS外部LSA的能力
·     V6:参与IPv6路由计算
Link-Local address
链路本地地址
Number of prefixes
前缀的数目
Prefix
地址前缀
Prefix options
前缀选项
# 显示OSPFv3链路状态数据库中E-Inter-Prefix LSA的信息。
<Sysname> display ospfv3 lsdb e-inter-prefix
                 E-Inter-Area-Prefix-LSA (Area 0.0.0.0)
  LS age                 : 195
  LS type                : E-Inter-Area-Prefix-LSA
  Link state ID          : 0.0.0.2
  Originating router     : 3.3.3.3
  LS seq number          : 0x8000001E
  Checksum               : 0xBD8E
  Length                 : 36
      Metric             : 1
      Prefix             : 777::/64
      Prefix options     : 0 (-|-|x|-|-)
      Link tag           : 2233
表1-21 display ospfv3 lsdb e-inter-prefix命令显示信息描述表
LS age
LSA老化时间
LS type
LSA类型
Link state ID
链路状态ID
Originating router
产生LSA的路由器
LS seq number
LSA序列号
Checksum
LSA校验和
Length
LSA长度,单位为字节
Metric
开销
Prefix
地址前缀
Prefix options
前缀选项
Link tag
接口的链路标记值
# 显示OSPFv3链路状态数据库中E-Inter-Router LSA的信息。
<Sysname> display ospfv3 lsdb e-inter-router
                 E-Inter-Area-Router-LSA (Area 0.0.0.0)
  LS age                 : 308
  LS type                : E-Inter-Area-Router-LSA
  Link state ID          : 0.0.0.0
  Checksum               : 0xE8F7
  Length                 : 32
      Metric               : 1
      Destination router ID: 4.4.4.4
      Link tag             : 2233
表1-22 display ospfv3 lsdb e-inter-router命令显示信息描述表
LS age
LSA老化时间
LS type
LSA类型
Link state ID
链路状态ID
Originating router
产生LSA的路由器
LS seq number
LSA序列号
Checksum
LSA校验和
Length
LSA长度,单位为字节
Metric
开销
目的Router ID
Link tag
接口的链路标记值
# 显示OSPFv3链路状态数据库中Intra-Area-TE LSA的信息。
<Sysname> display ospfv3 lsdb intra-te
  LS age                 : 191
  LS type                : Intra-Area-TE-LSA
  Link state ID          : 0.0.0.1
  Originating router     : 1.1.1.1
  LS seq number          : 0x80000001
  Checksum               : 0xB542
  Length                 : 64
  Link state information :
      Link type                : Broadcast
      Neighbor interface ID    : 1
      Neighbor router ID       : 2.2.2.2
      Local interface address  : 1001::1
      Remote interface address : 1001::2
      TE Metric                : 1
      Maximum Bandwidth        : 1250000 bytes/sec
      Maximum Reservable BW    : 625000 bytes/sec
      Administrative Group     : 0x0
      IGP Metric               : 1
      Unreserved Bandwidth for each TE Class:
        TE class  0 = 375000 bytes/sec
        TE class  1 = 375000 bytes/sec
        TE class  2 = 375000 bytes/sec
        TE class  3 = 375000 bytes/sec
        TE class  4 = 375000 bytes/sec
        TE class  5 = 375000 bytes/sec
        TE class  6 = 375000 bytes/sec
        TE class  7 = 375000 bytes/sec
        TE class  0 = 0 bytes/sec
        TE class  1 = 0 bytes/sec
        TE class  2 = 0 bytes/sec
        TE class  3 = 0 bytes/sec
        TE class  4 = 0 bytes/sec
        TE class  5 = 0 bytes/sec
        TE class  6 = 0 bytes/sec
        TE class  7 = 0 bytes/sec
      Bandwidth Constraint Model: Prestandard DS-TE RDM
      Bandwidth Constraints:
        BC [0] = 625000 bytes/sec
        BC [1] = 0 bytes/sec
      Flag: 0, Average delay: 20 us
      Flag: 0, Min delay: 20 us, Max delay: 40 us
      Delay variation: 30 us
      Remaining bandwidth: 10 bytes/sec
      Available bandwidth: 10 bytes/sec
      Utilized bandwidth: 10 bytes/sec
  LS age                 : 274
  Checksum               : 0xE79F
  Length                 : 40
  IPv6 Router ID         : 86::86
表1-23 display ospfv3 lsdb intra-te命令显示信息描述表
LS age
LSA老化时间
LS type
LSA类型
Link state ID
链路状态ID
Originating router
产生LSA的路由器
LS seq number
LSA序列号
Checksum
LSA校验和
Length
LSA长度
链路状态信息,用来描述一条链路:
·     Link type:链路类型
¡     Point To Point:点对点链路
¡     Broadcast:广播链路
¡     NBMA:非广播型多路访问链路
¡     Point To MultiPoint:点对多点链路
¡     Other type:其他链路
·     Neighbor interface ID:邻居接口ID
·     Neighbor router ID:邻居路由器Router ID
·     Local interface address:本地接口地址
·     Remote interface address:对端接口地址
·     TE metric:TE开销
·     Maximum bandwidth:用于转发MPLS TE流量的链路最大带宽
·     Maximum Reservable BW:最大可预留带宽
·     Administrative Group:链路管理组属性
·     IGP Metric:IGP开销
·     Unreserved Bandwidth for each TE Class:每个TE class的可预留带宽
·     Bandwidth Constraint Model:带宽约束模型,取值包括:
¡     Prestandard DS-TE RDM
¡     IETF DS-TE RDM
¡     IETF DS-TE MAM
·     Bandwidth Constraints:各个带宽约束值(Prestandard模式支持2个BC,IETF模式支持4个BC)
·     Flag:平均时延的测量值是否超过16777215微秒的标志位,0表示平均时延的测量值小于16777215微秒,说明此时链路较稳定;1表示平均时延的测量值大于或等于16777215微秒,说明此时链路不稳定
·     Average delay:链路平均时延,单位为微秒
·     Flag:最小/最大时延的测量值是否超过16777215微秒的标志位,0表示最小时延或最大时延的测量值小于16777215微秒,说明此时链路较稳定;1表示最小时延或最大时延的测量值大于或等于16777215微秒,说明此时链路不稳定
·     Min delay:链路最小时延,单位为微秒
·     Max delay:链路最大时延,单位为微秒
·     Delay variation:时延容差,单位为微秒
·     Remaining bandwidth:剩余带宽,单位为字节/秒
·     Available bandwidth:可用带宽,单位为字节/秒
·     Utilized bandwidth:已用带宽,单位为字节/秒
IPv6 Router ID
路由器IPv6 Router ID
# 显示OSPFv3链路状态数据库中Router-Information LSA的信息。
<Sysname> display ospfv3 lsdb router-information
                  Router-Information-LSA (Area 0.0.0.0)
  LS age                 : 315
  LS type                : Router-Information-LSA
  LS seq number          : 0x80000035
  Checksum               : 0x32EA
  Length                 : 56
  SRv6 capability        :
      Flags (O)          : 0
  SRv6 node MSD          :
      Segment Left       : 10
      End Pop MSD        : 10
      H.Encaps MSD       : 10
      End D MSD          : 10
  SRv6 algorithm         :
      Algorithm          : 0
      Algorithm          : 130
  Flex-Algo Definition   :
      Algorithm          : 130
      Metric-Type        : IGP
      Algo-Type          : SPF
      Priority           : 255
      Exclude Any EAG    : 0x00000000 0x00000000
                           0x00000004
表1-24 display ospfv3 lsdb router-information命令显示信息描述表
LS age
LSA老化时间
LS type
LSA类型
Link state ID
链路状态ID
Originating router
产生LSA的路由器
LS seq number
LSA序列号
Checksum
LSA校验和
Length
LSA长度
SRv6 capability
SRv6能力信息
Flags (O)
SRv6能力子TLV相关信息
·     O:SRH flag的O标志位,置位时,表示路由器支持OAM flag
SRv6 node MSD
SRv6节点MSD(Maximum SID Depths,最大SID深度)子TLV相关信息
Segment Left
SRH中Segment Left字段的值
End Pop MSD
支持PSP(Penultimate Segment Pop of the SRH,倒数第二跳弹出)或USP(Ultimate Segment Pop of the SRH,最后一跳弹出)的端点能够弹出的最大SID个数
H.Encaps MSD
SRv6 TE Policy能够封装到报文中的SID的最大个数
End D MSD
端点能够解封装的SID的最大个数
SRv6 algorithm
SRv6前缀关联的算法,取值为:
·     0:SPF算法
·     1:Strict SPF算法
·     128~255之间的某个数值:Flex-Algo算法
灵活算法定义信息
Algorithm
灵活算法ID
Metric-Type
灵活算法度量类型。当前仅支持IGP类型,即OSPFv3的链路开销
Algo-Type
灵活算法类型。当前仅支持SPF算法
Priority
灵活算法的优先级
Exclude Any EAG
排除具有任意一个Exclude Any扩展管理组中亲和属性的链路
Include All EAG
包含具有所有Include All扩展管理组中亲和属性的链路
Include Any EAG
包含具有任意一个Include Any扩展管理组中亲和属性的链路
# 显示OSPFv3链路状态数据库中Locator LSA的信息。
<Sysname> display ospfv3 lsdb locator
                 Locator-LSA (Area 0.0.0.0)
  LS age                 : 12
  LS type                : Locator-LSA
  Originating router     : 2.2.2.2
  LS seq number          : 0x80000002
  Checksum               : 0xED57
  Length                 : 72
  SRv6 locator           :
     Route type          : Intra-Area
     Locator             : 2001::/64
     Metric              : 0
     Flags (N/A)         : 1/0
     Algorithm           : 0
     SRv6 End SID        :
       SID               : 2001::1:0:0:0
       Function type     : End with PSP
表1-25 display ospfv3 lsdb locator命令显示信息描述表
LS age
LSA老化时间
LS type
LSA类型
Link state ID
链路状态ID
Originating router
产生LSA的路由器
LS seq number
LSA序列号
Checksum
LSA校验和
Length
LSA长度
SRv6 locator
SRv6 Locator TLV相关信息
Route type
路由类型,取值包括:
·     Intra-Area:区域内路由
·     Inter-Area:区域内路由
·     AS External:到AS外部的路由,通告到所有的区域(除了Stub区域和NSSA区域)
·     NSSA External:到AS外部的路由,仅在NSSA区域内传播
Locator
SID的节点路由段
Metric
开销
Flags (N/A)
标志位:
·     N:当Locator唯一标识一个节点时,该标志位置位
·     A:当Locator配置为任播时,该标志位置位
Algorithm
前缀关联的算法类型:
·     0:SPF算法
·     1:Strict SPF算法
SRv6 End SID
SRv6 End类型SID信息
SRv6 End.M SID
SRv6 End.M类型的SID信息
SID
End SID值
Function type
SID的function类型,取值如下:
·     End (NO-FLAVOR):End类型SID,且倒数第二跳不弹出、最后一跳不弹出
·     End with PSP:End类型SID,且倒数第二跳弹出
·     End with USP:End类型SID,且最后一跳弹出
·     End with PSP&USP:End类型SID,且倒数第二跳弹出或最后一跳弹出
·     End.X (NO-FLAVOR):End.X类型SID,且倒数第二跳不弹出、最后一跳不弹出
·     End.X with PSP:End.X类型SID,且倒数第二跳弹出
·     End.X with USP:End.X类型SID,且最后一跳弹出
·     End.X with PSP&USP:End.X类型SID,且倒数第二跳弹出或最后一跳弹出
·     End.T (no PSP, no USP):End.T类型SID,且倒数第二跳不弹出、最后一跳不弹出
·     End.T with PSP:End.T类型SID,且倒数第二跳弹出
·     End.T with USP:End.T类型SID,且最后一跳弹出
·     End.T with PSP&USP:End.T类型SID,且倒数第二跳弹出或最后一跳弹出
·     End.DT6:End.DT6类型SID
·     End.DX6:End.DX6类型SID
# 显示OSPFv3链路状态数据库中E-Router LSA的信息。
<Sysname> display ospfv3 lsdb e-router
                 E-Router-LSA (Area 0.0.0.0)
  LS age                 : 27
  LS type                : E-Router-LSA
  Originating router     : 9.9.9.9
  Checksum               : 0x4269
  Length                 : 108
      Link connected to    : a Transit Network
      Metric               : 1
      Interface ID         : 285
      Neighbor interface ID: 285
      Neighbor router ID   : 9.9.9.9
      Link tag             : 100
      SRv6 LAN End.X SID TLV:
          Neighbor router ID: 1.2.3.4
          SID               : 2001::2:0:0:0
          Algorithm         : 0
          Weight            : 0
          Flags (B/S/P)     : 0/0/0
          Neighbor router ID: 5.5.5.5
          SID               : 2001::1:0:0:0
          Algorithm         : 0
          Weight            : 0
      Application Specific Link Attributes :
          SA-Length          : 4
          UDA-Length         : 4
          SA-Value           : 0x10000000 Flex-Algo
          UDA-Value          : 0x10000000 Flex-Algo
          TE cost            : 1
          Flag: 0, Average delay: 100 us
          Flag: 0, Min delay: 10 us, Max delay: 1000 us
          Delay variation: 20 us
          Remaining bandwidth: 1 bytes/sec
          Available bandwidth: 2 bytes/sec
          Utilized bandwidth : 1 bytes/sec
      Local interface Address  : 10::1
      Remote interface Address : 10::2
表1-26 display ospfv3 lsdb e-router命令显示信息描述表
LS age
LSA老化时间
LS type
LSA类型
Link state ID
链路状态ID
Originating router
产生LSA的路由器
LS seq number
LSA序列号
Checksum
LSA校验和
Length
LSA长度
Options
LSA选项,各选项含义如下:
·     DC:支持按需链路
·     R:是否为活跃路由器
·     N:是否支持NSSA外部LSA
·     x:保留
·     E:AS外部LSA的接收能力
·     V6:是否参与IPv6路由计算
Link connected to
链路连接的网络类型:
·     another Router (Point To Point):点对点链路
·     a Transit Network:广播网络
·     a Virtual Link:虚连接
·     Unknown:未知网络
Metric
开销
Interface ID
接口ID
邻居接口ID
Neighbor router ID
邻居Router ID
Link tag
接口的链路标记值
SRv6 End.X SID TLV
P2P邻接链路的SRv6 End.X SID子TLV的相关信息
LAN邻接链路的SRv6 End.X SID子TLV的相关信息
SID
SRv6 SID
Function type
SID的Function类型,取值如下:
Algorithm
前缀关联的算法类型:
·     0:SPF算法
·     1:Strict SPF算法
Weight
权重
Flags
SRv6标志信息:
·     B:备份标志,置位时,表明可用于链路保护
·     S:集合标志,置位时,表明是一系列邻居设备的集合,表示该SID能分配给多个邻居
·     P:持久性标志,置位时,表明该SID永久分配给该邻居,即使邻居重建也不会改变分配给该邻居的SID
特定链路属性标识,表明该链路属性与Flex-Algo算法关联
SA-Length
Standard Application Identifier Bit Mask Length,标准的应用标识位掩码长度,单位为字节
UDA-Length
User Defined Application Identifier Bit Mask Length,用户自定义的应用标识位掩码长度,单位为字节
SA-Value
Standard Application Identifier Bit Mask,标准的应用标识位掩码位取值,不同的取值代表不同的特定应用。取值为0x10000000,表示Flex-Algo
UDA-Value
User Defined Application Identifier Bit Mask,用户自定义的应用标识位掩码位取值,不同的取值代表不同的特定应用。取值为0x10000000,表示Flex-Algo
TE cost
接口的MPLS TE开销值
Unidirectional link delay
单向链路时延信息
Average delay
平均时延,单位为微秒
Flag
平均时延的测量值是否超过16777215微秒的标志位,0表示平均时延的测量值小于16777215微秒,说明此时链路较稳定;1表示平均时延的测量值大于或等于16777215微秒,说明此时链路性能差
Minimum delay
最小时延,单位为微秒
Maximum delay
最大时延,单位为微秒
Flag
最小/最大时延的测量值是否超过16777215微秒的标志位,0表示最小时延或最大时延的测量值小于或等于16777215微秒,说明此时链路较稳定;1表示最小时延或最大时延的测量值大于16777215微秒,说明此时链路性能差
Delay variation
时延容差,单位为微秒
Remaining bandwidth
剩余带宽,单位为字节/秒
Available bandwidth
可用带宽,单位为字节/秒
Used bandwidth
已使用带宽,单位为字节/秒
本地全局单播地址
远端全局单播地址
# 显示OSPFv3链路状态数据库中LSA的统计信息。
<System> display ospfv3 lsdb statistics
 Area ID         Router Network IntePre InteRou IntraPre NSSA IntraTE
 0.0.0.0         2      1       0       0       1        0    0
 Total           2      1       0       0       1        0    0
 Area ID         ERouter Locator RtrInfo EInterPrefix EInterRouter
 0.0.0.0         1       0       0       0            0
 Total           1       0       0       0            0
                 Link   Grace   ASE
 Total           2      0       0
表1-27 display ospfv3 lsdb statistics命令显示信息描述表
Area ID
区域ID,显示该区域各类LSA的总数
Router
Type-1 LSA的数目
Network
Type-2 LSA的数目
IntePre
Type-3 LSA的数目
InteRou
Type-4 LSA的数目
IntraPre
Type-9 LSA的数目
IntraTE
Type-10 LSA的数目
NSSA
Type-7 LSA的数目
ERouter
Type-33 LSA的数目
Locator
Type-42 LSA的数目
RtrInfo
Type-12 LSA的数目
EInterPrefix
Type-35 LSA的数目
EInterRouter
Type-36 LSA的数目
Link
Type-8 LSA的数目
Grace
Type-11 LSA的数目
ASE
Type-5 LSA的数目
Total
不同区域相同类型LSA的总数
# 显示OSPFv3的链路状态数据库的各种LSA总数。
<Sysname> display ospfv3 lsdb total
 Type Of LSA              Number
 Router-LSA             : 2
 Network-LSA            : 1
 Inter-Area-Prefix-LSA  : 0
 Inter-Area-Router-LSA  : 0
 AS-external-LSA        : 0
 NSSA-LSA               : 0
 Link-LSA               : 2
 Intra-Area-Prefix-LSA  : 1
 Grace-LSA              : 0
 Intra-Area-TE-LSA      : 0
 E-Router-LSA           : 0
 Router-Information-LSA : 0
 Locator-LSA            : 0
 E-Inter-Area-Prefix-LSA: 0
 E-Inter-Area-Router-LSA: 0
 Unknown-LSA            : 0
 Total number of LSAs   : 6
表1-28 display ospfv3 lsdb total命令显示信息描述表
Type Of LSA
LSA类型
Number
LSA数目
Router-LSA
Type-1 LSA的数目
Network-LSA
Type-2 LSA的数目
Type-3 LSA的数目
Type-4 LSA的数目
AS-external-LSA
Type-5 LSA的数目
NSSA-LSA
Type-7 LSA的数目
Link-LSA
Type-8 LSA的数目
Type-9 LSA的数目
Grace-LSA
Type-11 LSA的数目
Intra-Area-TE-LSA
Type-10 LSA的数目
E-Router-LSA
Type-33 LSA的数目
Type-12 LSA的数目
Locator-LSA
Type-42 LSA的数目
Type-35 LSA的数目
Type-36 LSA的数目
Unknown-LSA
未知类型LSA的数目
各种LSA的总数
# 显示OSPFv3的链路状态数据库的详细信息。
<Sysname> display ospfv3 lsdb verbose
                 SendCnt: 0       RxmtCnt: 0       Status: Stale
                 Intra-Area-TE-LSA (Area 0.0.0.1)
 0.0.0.1         2.2.2.2          0066  0x80000001 0x2eed
 0.0.0.0         2.2.2.2          0066  0x80000001 0x1478
 0.0.0.1         1.1.1.1          0013  0x80000001 0x1aa9         1
 0.0.0.0         1.1.1.1          0024  0x80000001 0x395e         1
 0.0.0.0         2.2.2.2          0618  0x80000007 0x599e
                 SendCnt: 0       RxmtCnt: 0       Status: Normal
 0.0.0.0         2.2.2.2          0618  0x8000001d 0xeaf6
表1-29 display ospfv3 lsdb verbose命令显示信息描述表
SendCnt
待发送该LSA的接口数目
RxmtCnt
该LSA在重传列表中的数目
Status
LSA所处的状态:
·     Normal:正常状态
·     Delayed:延迟生成的LSA
·     Maxage routed:Maxage的LSA且已经经过拓扑前缀处理
·     Self originated:收到自己产生的LSA
·     Stale:GR过程中收到自己产生的LSA
1.1.28  display ospfv3 nexthop
display ospfv3 nexthop命令用来显示OSPFv3的路由下一跳信息。
display ospfv3 [ process-id ] nexthop
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的下一跳信息。
# 显示OSPFv3进程1的路由下一跳信息。
<Sysname> display ospfv3 1 nexthop
 Nexthop : FE80::20C:29FF:FED7:F308                Interface: XGE3/1/2
 RefCount: 4                                       Status   : Valid
 Nexthop : FE80::20C:29FF:FED7:F312                Interface: XGE3/1/3
 RefCount: 3                                       Status   : Valid
 NbrID   : 1.1.1.1                                 NbrIntID : 38
表1-30 display ospfv3 nexthop命令显示信息描述表
Nexthop
下一跳地址
出接口名
RefCount
下一跳引用计数
Status
该下一跳的状态:
·     Valid:有效
·     Invalid:无效
NbrID
邻居路由器ID
NbrIntID
邻居的接口ID
1.1.29  display ospfv3 non-stop-routing
display ospfv3 non-stop-routing命令用来显示OSPFv3进程的NSR状态信息。
display ospfv3 [ process-id ] non-stop-routing
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的NSR状态信息。
OSPFv3 NSR功能处于缺省开启状态,用户无法通过命令行对OSPFv3 NSR功能的开启/关闭进行控制。用户可通过display ospfv3 non-stop-routing命令查看OSPFv3 NSR功能的运行状态。
# 显示所有OSPFv3进程的NSR状态信息。
<Sysname> display ospfv3 non-stop-routing
 Nonstop Routing capability: Enabled
 Upgrade phase             : Normal
表1-31 display ospfv3 non-stop-routing命令显示信息描述表
是否使能OSPFv3协议的NSR能力
·     Enabled:使能
·     Disabled:未使能
Upgrade phase
NSR的各个阶段,有如下几种:
·     Normal:普通状态
·     Preparation:准备阶段
·     Smooth:数据平滑阶段
·     Precalculation:路由计算预处理阶段
·     Calculation:路由计算阶段
·     Redistribution:路由引入阶段
1.1.30  display ospfv3 peer
display ospfv3 peer命令用来显示OSPFv3的邻居信息。
display ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id | statistics ]
process-id:OSPFv3进程号,取值范围为1~65535。如果不指定本参数,则显示所有OSPFv3进程的邻居信息。
area area-id:显示位于指定区域的邻居信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。如果不指定本参数,则显示所有区域的邻居信息。
verbose:显示邻居的详细信息。
peer-router-id:显示指定邻居的信息。
statistics:显示OSPFv3邻居的统计信息。
如果接口参数、邻居Router ID参数都不输入,则显示所有接口的邻居信息。
# 显示OSPFv3进程1的邻居信息。
<Sysname> display ospfv3 1 peer
 Area: 0.0.0.1
 Router ID       Pri State             Dead-Time InstID Interface
 2.2.2.2         1   Full/DR           00:00:33  0      XGE3/1/1
 Sham link destination: 3::3
 100.1.1.1       1   Full/ -           00:00:39  0
表1-32 display ospfv3 peer命令显示信息描述表
Router ID
邻居ID
Pri
邻居路由器优先级
邻居状态
Dead-Time
邻居路由器的失效时间
InstID
实例ID
和邻居相连的接口
OSPFv3伪连接的目的IPv6地址
# 显示接口上的OSPFv3进程1的邻居详细信息。
<Sysname> display ospfv3 1 peer verbose
 Area 0.0.0.1 interface XGE3/1/2's neighbors
 Router ID: 2.2.2.2          Address: FE80::200:5EFF:FE00:100
   DR: 2.2.2.2  BDR: None   MTU: 1500
   Options is 0x000413 (AT|-|-|-|-|-|R|-|x|E|V6)
   Dead timer due in 00:00:38
   Neighbor is up for 00:19:07
   Authentication sequence: (high) 0, (low) 59755
   Neighbor state change count: 120
   Database Summary List 0
   Link State Request List 0
   Link State Retransmission List 3
   Neighbor interface ID: 8037
   GR state: Normal
   Grace period: 0           Grace period timer: Off
   DD Rxmt Timer: Off        LS Rxmt Timer: On
 Last Neighbor Down Event:
 Router ID: 1.1.1.1
 Local Interface Id: 1     InstId: 0
 Remote Interface Id: 1
 Time: Mar 27 10:04:29 2023
 Reason: Ospfv3 Interface Parameters Changed
 Sham link neighbor with address: 3::3
 Router ID: 100.1.1.1        Area: 0.0.0.1
   State: Full  Mode: Nbr is slave  Priority: 1
   DR: None   BDR: None   MTU: 0
   Options is 0x000013 (-|-|-|-|-|-|R|-|x|E|V6)
   Dead timer due in 00:00:36
   Neighbor is up for 00:13:55
   Authentication sequence: (high) 0, (low) 0
   Neighbor state change count: 5
   Link State Retransmission List 0
   Neighbor interface ID: 2147483649
   GR state: Normal
   DD Rxmt Timer: Off        LS Rxmt Timer: Off
表1-33 display ospfv3 peer verbose命令显示信息描述表
Router ID
邻居的Router ID
Address
接口链路本地地址
邻居状态
Mode
路由器在数据库同步阶段,路由器与邻居协商的主从关系,取值为:
·     Nbr is master:邻居路由器为主路由器
·     Nbr is slave:邻居路由器为从路由器
Priority
邻居路由器优先级
DR
接口所属网段的DR
BDR
接口所属网段的BDR
MTU
接口MTU的值
Options
邻居的LSA选项,各选项含义如下:
·     AT:报文是否带验证字段
·     DC:支持按需链路
·     R:是否为活跃路由器
·     N:是否支持NSSA外部LSA
·     x:保留
·     E:AS外部LSA的接收能力
·     V6:是否参与IPv6路由计算
Dead timer due in hh:mm:ss
Dead定时器距离超时的剩余时间,单位为hh:mm:ss,其中hh为小时,mm为分钟,ss为秒。Dead定时器超时后,认为该邻居已失效
Neighbor is up for hh:mm:ss
邻居关系建立的时长,单位为hh:mm:ss,其中hh为小时,mm为分钟,ss为秒
接收到的报文中的验证序列号,高32位的值为0,低32位的值为59755
邻居状态发生改变的次数
需要DD报文发送的LSA个数
链路状态请求列表中LSA个数
链路状态重传列表中LSA个数
邻居的接口ID
GR state
GR状态,取值为:
·     Normal:普通状态
·     Doing GR:正在作为GR Restarter
·     Complete GR:GR完成
·     Helper:正在作为GR Helper
Grace period
发送Grace LSA的间隔
Grace period timer
发送Grace LSA的间隔定时器,其中:
·     Off: 关闭
·     On:开启
DD Rxmt Timer
DD报文重传定时器,其中:
·     Off: 关闭
·     On:开启
LS Rxmt Timer
LSU报文重传定时器,其中:
·     Off: 关闭
·     On:开启
最后一次邻居down事件
Local Interface Id
本地的接口ID
InstId
OSPFv3实例ID
Remote Interface Id
对端的接口ID
Time
邻居down的时间,格式为MM DD,hh:mm:ss YYYY,其中MM为月,DD为日,hh为小时,mm为分钟,ss为秒,YYYY为年
Reason
邻居down的原因,取值包括:
·     Ospfv3_resetconnect:内存不足,邻居关系断开
·     Ospfv3 Interface Parameters Changed:OSPFv3接口参数的配置发生变化
·     Reset ospfv3 command was performed:执行了reset ospfv3 process命令
·     Undo ospfv3 command was performed:执行了undo ospfv3命令
·     Undo area command was performed:执行了undo area命令
·     Undo ospfv3 interface:接口上关闭OSPFv3功能
·     Ospfv3 iflchange:接口逻辑属性变化
·     Ospfv3 ifachange:接口物理属性变化
·     DeadInterval timer expired:Dead定时器超时
·     Too many retransmissions:重传过多
·     Bfd session down:OSPFv3联动的BFD会话down
·     Silent Interface:执行了silent interface命令
·     Configuring stub area:stub区域配置变化
·     Vlink down:虚连接接口down
·     Configuring NSSA area:NSSA区域配置变化
·     Sham-link down:伪连接接口down
·     1Way:收到1-Way事件
·     BadLsreq:收到BadLSReq事件
·     Dbfilter:指定接口对发送给邻居的LSA进行过滤的配置发生变化,或者该配置引用的ACL规则改变
OSPFv3伪连接的邻居IPv6地址
# 显示所有OSPFv3邻居的统计信息。
<Sysname> display ospfv3 peer statistics
 Area ID         Down Attempt Init 2-Way ExStart Exchange Loading Full Total
 0.0.0.0         0    0       0    0     0       0        0       1    1
 Total           0    0       0    0     0       0        0       1    1
 Sham links' neighbors(Total: 1):
 Down: 0,Init: 0,2-Way: 0,ExStart: 0,Exchange: 0,Loading: 0,Full: 1
表1-34 display ospfv3 peer statistics命令显示信息描述表
Area ID
区域标识
Down
该状态为OSPFv3建立邻居关系的初始化状态,表示OSPFv3路由器在一定时间之内没有收到从某一邻居路由器发送来的信息
Attempt
该状态仅对NBMA网络上的邻居有效,表示最近没有从邻居收到信息,但仍需作出进一步的尝试,用以与邻居联系
Init
此状态表示OSPFv3路由器已经接收到邻居路由器发送来的Hello数据包,但该Hello数据包内没有包含自己的Router ID,还没有建立起双方的双向通信
2-Way
此状态表示OSPFv3路由器与邻居路由器的双向通信已经建立。DR及BDR的选择是在这个状态(或更高的状态)完成的
ExStart
在此状态,路由器要确定邻居双方的主从关系并决定初始的DD报文的序列号
Exchange
在此状态,OSPFv3路由器向其邻居路由器发送DD报文来交换链路状态信息
Loading
在此状态,OSPFv3路由器向邻居路由器发送LSR报文,请求最新的链路状态信息
Full
在此状态,建立起邻居关系的路由器之间已经完成了数据库同步的工作,它们的链路状态数据库已经一致
Total
所有区域中处于相同状态的邻居数目的总和
Sham links' neighbors(Total: xx)
OSPFv3伪连接的邻居统计信息。Total表示伪连接的邻居总数
1.1.31  display ospfv3 request-queue
display ospfv3 request-queue命令用来显示OSPFv3请求列表的信息。
display ospfv3 [ process-id ] [ area area-id ] request-queue [ interface-type interface-number ] [ neighbor-id ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的请求列表信息。
area area-id:显示位于指定区域的信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。如果未指定本参数,将显示所有OSPFv3区域的请求列表信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的请求列表信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的请求列表信息。
# 显示OSPFv3请求列表的信息。
<Sysname> display ospfv3 request-queue
                   Area: 0.0.0.0
                   Nbr-ID 1.3.3.3 Request List
 Type    LinkState ID    AdvRouter       SeqNum       Age   CkSum
 0x4005  0.0.34.127      1.3.3.3         0x80000001   0027  0x274d
 0x4005  0.0.34.128      1.3.3.3         0x80000001   0027  0x2d45
 0x4005  0.0.34.129      1.3.3.3         0x80000001   0027  0x333d
 0x4005  0.0.34.130      1.3.3.3         0x80000001   0027  0x3935
表1-35 display ospfv3 request-queue命令显示信息描述表
Area
区域ID
接口类型和序号
Nbr-ID
邻居ID
Request List
请求列表信息
LSA类型
LinkState ID
链路状态标示符
AdvRouter
通告路由器
SeqNum
LSA序列号
Age
LSA老化时间
CkSum
校验和
1.1.32  display ospfv3 retrans-queue
display ospfv3 retrans-queue命令用来显示OSPFv3重传列表的信息。
display ospfv3 [ process-id ] [ area area-id ] retrans-queue [ interface-type interface-number ] [ neighbor-id ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的重传列表信息。
area area-id:显示位于指定区域的信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。如果未指定本参数,将显示所有OSPFv3区域的重传列表信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的重传列表信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的重传列表信息。
# 显示OSPFv3重传列表的信息。
<Sysname> display ospfv3 retrans-queue
                   Area: 0.0.0.0
                   Nbr-ID 1.2.2.2 Retransmit List
 0x2009  0.0.0.0         1.3.3.3         0x80000001   3600  0x49fb
表1-36 display ospfv3 retrans-queue命令显示信息描述表
Area
区域ID
接口类型和序号
Nbr-ID
邻居ID
Retransmit List
重传列表信息
LSA类型
LinkState ID
链路状态标示符
AdvRouter
通告路由器
SeqNum
LSA序列号
Age
LSA老化时间
CkSum
校验和
1.1.33  display ospfv3 routing
display ospfv3 routing命令用来显示OSPFv3路由表的信息。
display ospfv3 [ process-id ] routing [ ipv6-address prefix-length ]
ipv6-address prefix-length:显示指定IPv6地址的OSPFv3路由表的信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为0~128。
# 显示OSPFv3路由表的信息。
<Sysname> display ospfv3 routing
 *  - Selected route
  NexthopFlag: -
  BkNexthop  : N/A
  Status     : Rely
  Delay Flag : N/A
  Nexthop    : ::
  NexthopFlag: -
  BkNexthop  : N/A
  Status     : Direct
  Delay Flag : N/A
  Type       : E2                        Tag        : 1
  NexthopFlag: -
  BkNexthop  : N/A
  Status     : Rely
  Delay Flag : N/A
 Total: 3
表1-37 display ospfv3 routing命令显示信息描述表
Destination
目的网段
路由类型。如果路由类型中携带了ECMP-back,表示等价路由的备份路由信息
Area
区域ID
AdvRouter
Preference
路由优先级
NibID
路由下一跳信息的ID值
Cost
路由开销值
出接口的类型和编号,或者SRv6 TE Policy的名称
BkInterface
备份下一跳出接口
Nexthop
下一跳地址
NexthopFlag
下一跳标志位,取值为D,表示发布源的直连下一跳
BkNexthop
备份下一跳地址
Status
路由状态,具体如下:
·     Invalid:路由下一跳无效
·     Stale:该路由下一跳较旧
·     Normal:正常可用状态
·     Delete:处于删除状态
·     Direct:该条路由为直连路由
·     Rely:该条路由为迭代路由
Delay Flag
防微环延迟标志位:
·     D:表示配置防微环功能后,路由处于延迟发送RIB的状态
·     N/A:未配置防微环功能或者达到防微环延迟时间时,路由处于正常发送RIB的状态
Mirror FRR
Mirror快速重路由信息
出接口
AdvRouter
发布路由器
Area
区域ID
Tag
外部路由标记
Preference
路由优先级
Total
路由总数目
Intra area
区域内路由数目
Inter area
区域间路由数目
ASE
5类外部路由数目
NSSA
7类外部路由数目
TI-LFA
TI-LFA备份信息
PNode End SID
P节点的End SID
QNode AdvID
Q节点的发布源
LsIndex
标签栈索引
Backup label stack (top->bottom)
备份路径标签栈,从栈顶标签到栈底标签依次排列,“N/A”表示标签栈不存在
SR microloop-avoidance label stack index
SR防微环标签栈索引
SR microloop label stack (top->bottom)
SR防微环路径标签栈,从栈顶标签到栈底标签依次排列
1.1.34  display ospfv3 spf-tree
display ospfv3 spf-tree命令用来显示OSPFv3区域的最短路径树信息。
display ospfv3 [ process-id ] [ area area-id ] spf-tree [ verbose ]
# 显示OSPFv3进程1下区域0的最短路径树信息。
<Sysname> display ospfv3 1 area 0 spf-tree
        T-Node is tunnel destination
        E-Node is SRv6-TE policy endpoint
>1.1.1.1         Router S R
                                  -->2.2.2.2         RT2RT  1     C
                                  -->2.2.2.2 RT2RT  1     P
>2.2.2.2         Router S T
                                  -->1.1.1.1         RT2RT  1     P
表1-38 display ospfv3 spf-tree命令显示信息描述表
SPFNode
SPF节点,以宣告路由器ID作为标识,其中,Type为节点类型:
·     Network:网络节点
·     Router:路由器节点
·     Flag为节点标志:
·     I:节点处于初始化状态
·     A:节点在候选列表上
·     S:节点在SPF树上
·     R:该节点与根节点直连
·     D:该节点将被删除
·     T:该节点是隧道目的端
·     E:该节点是SRv6 TE Policy的目的节点
SPFLink
SPF链路,以宣告路由器ID作为标识,其中,Type为链路类型:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
·     Cost为链路花费,Flag为链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     L:链路在区域变化列表中
# 显示OSPFv3进程1下区域0的最短路径树详细信息。
<Sysname> display ospfv3 1 area 0 spf-tree verbose
>SPFNode[0]
  NodeFlag     : S R                      TunDistance: 1
                                          SRPDistance: 1
  Tunnel count : 0
  Policy count : 0
  Nexthop count: 1
    BkNexthop  : FE80::4
    MADuration : N/A
    MALStack   : N/A
  SPFLink count: 1
  ParentLink count: 1
>SPFNode[2]
  NodeFlag     : S T                      TunDistance: 1
                                          SRPDistance: 1
  Tunnel count : 1
  Policy count : 0
  Nexthop count: 2
    Interface  : Tun1                     NhFlag     : Valid
    Nexthop    : 4::44
    BkNexthop  : N/A
    MADuration : N/A
    MALStack   : N/A
    BkNexthop  : N/A
    MADuration : N/A
    MALStack   : N/A
  SPFLink count: 0
  ParentLink count: 1
表1-39 display ospfv3 spf-tree verbose命令显示信息描述表
SPFNode
SPF节点
AdvID
通告路由器ID
LsID
链路状态ID
NodeType
节点类型
Distance
到根节点的开销
NodeFlag
节点标志
TunDistance
根节点到本节点的下一跳为隧道时的开销
Tunnel count
根节点到本节点的隧道条数
SRPDistance
根节点到本节点的下一跳为SRv6 TE Policy时的开销
Policy count
根节点到本节点的SRv6 TE Policy条数
PolicyName
SRv6 TE Policy名称
EndPoint
SRv6 TE Policy的目的节点
Color
SRv6 TE Policy的color值
Auto cost
SRv6 TE Policy配置的IGP开销值
Final cost
SRv6 TE Policy的最终生效开销值
Auto route
Autoroute类型,当前仅支持Shortcut
SRv6 TE Policy状态
Nexthop count
下一跳计数
NbrID
邻居路由器ID
NbrIntID
邻居的接口ID
出接口
NhFlag
下一跳标志:
Valid:有效
Invalid:无效
BkInterface
备份下一跳出接口
RefCount
下一跳的引用计数
Nexthop
下一跳地址
BkNexthop
备份下一跳地址
TI-LFA
TI-LFA信息
TiLfaNeighbor
节点TI-LFA的备份下一跳邻居节点Router ID
TiLfaInterface
节点TI-LFA的备份下一跳对应的出接口
TiLfaNexthop
节点TI-LFA的备份下一跳地址
PNode SrcID
P节点的Source ID
QNode SrcID
Q节点的Source ID
PNode EndSid
P节点的End SID,“N/A”表示目的节点在P空间,不显示SID
Protect
保护类型:
·     Node:节点保护
·     Link:链路保护
Label stack
标签栈,“N/A”表示标签栈不存在
SPFLink count
SPF链路计数
IntID
接口ID
LinkType
链路类型:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
LinkCost
当前链路花费
LinkNewCost
新的链路花费
LinkFlag
链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     L:链路在区域变化列表中
LinkTag
接口的链路标记值
NexthopCnt
下一跳个数
ParentLink count
父链路计数
MADuration
SR防微环持续时间,单位为毫秒
MALStack
SR防微环标签栈
TiLfaNeighbor
节点TI-LFA备份下一跳邻居节点ID
TiLfaInterface
节点TI-LFA备份下一跳对应的出接口
TiLfaNexthop
节点TI-LFA备份下一跳地址
PNode SrcID
P节点Source ID
QNode SrcID
Q节点Source ID
PNode prefix
P节点前缀,“N/A”表示目的节点在P空间不显示节点前缀
PNode SidIndex
P节点前缀SID相对值,“N/A”表示目的节点在P空间不显示SID
Protect
TI-LFA/Remote LFA的保护类型
·     Link:链路保护
·     Node:节点保护
Label stack
标签栈,“N/A”表示标签栈不存在
1.1.35  display ospfv3 statistics
display ospfv3 statistics命令用来显示OSPFv3的统计信息。
display ospfv3 [ process-id ] statistics [ error | packet [ interface-type interface-number ] ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的统计信息。
error:显示错误统计信息。如果未指定本参数,将显示OSPFv3进程的报文、LSA和路由的统计信息。
packet:显示OSPFv3的报文统计信息。
interface-type interface-number:接口类型和编号。显示指定接口的统计信息。如果未指定本参数,将显示所有接口的统计信息。
# 显示OSPFv3的统计信息。
<Sysname> display ospfv3 statistics
               OSPFv3 Process 1 with Router ID 1.1.1.1
                   Packet Statistics
 Type                         Recv                Send
 Hello                        1746                1284
 DB Description               505                 941
 Ls Req                       252                 136
 Ls Upd                       851                 1553
 Ls Ack                       416                 450
             Local Originated LSAs Statistics
 Type                                             Count
 Router-LSA                                       192
 Network-LSA                                      0
 Inter-Area-Prefix-LSA                            0
 Inter-Area-Router-LSA                            0
 AS-external-LSA                                  0
 NSSA-LSA                                         0
 Link-LSA                                         10
 Intra-Area-Prefix-LSA                            112
 Intra-Area-TE-LSA                                0
 E-Router-LSA                                     0
 Locator-LSA                                      0
 Router-Information-LSA                           0
 Grace-LSA                                        0
 E-Inter-Area-Prefix-LSA                          0
 E-Inter-Area-Router-LSA                          0
 Unknown-LSA                                      0
 Total                                            314
                   Routes Statistics
 Type                                             Count
 Intra Area                                       0
 Inter Area                                       0
 ASE                                              0
 NSSA                                             0
表1-40 display ospfv3 statistics命令显示信息描述表
Packet Statistics
收发报文统计
Hello
Hello报文
DB Description
数据库描述报文
Ls Req
链路状态请求报文
Ls Upd
链路状态更新报文
Ls Ack
链路状态确认报文
生成的LSA统计
Router-LSA
Type-1 LSA的数目
Network-LSA
Type-2 LSA的数目
Type-3 LSA的数目
Type-4 LSA的数目
AS-external-LSA
Type-5 LSA的数目
NSSA-LSA
Type-7 LSA的数目
Link-LSA
Type-8 LSA的数目
Type-9 LSA的数目
Intra-Area-TE-LSA
Type-10 LSA的数目
E-Router-LSA
Type-33 LSA的数目
Locator-LSA
Type-42 LSA的数目
Type-12 LSA的数目
Grace-LSA
Type-11 LSA的数目
Type-35 LSA的数目
Type-36LSA的数目
Unknown-LSA
Unknown-LSA数目
Total
总数目
Routes Statistics
路由计数
Intra Area
区域内路由
Inter Area
区域间路由
ASE
5类外部路由
NSSA
7类外部路由
# 显示OSPFv3进程的错误统计信息。
<sysname> display ospfv3 statistics error
 0         : Transmit error               0         : Neighbor state low
 0         : Packet too small             0         : Bad version
 0         : Bad checksum                 0         : Unknown neighbor
 0         : Bad area ID                  0         : Bad packet
 0         : Packet dest error            0         : Inactive area packet
 0         : Router ID confusion          0         : Bad virtual link
 0         : HELLO: Hello-time mismatch   0         : HELLO: Dead-time mismatch
 0         : HELLO: Ebit option mismatch  0         : DD: Ebit option mismatch
 0         : DD: Unknown LSA type         0         : DD: MTU option mismatch
 0         : REQ: Empty request           0         : REQ: Bad request
 0         : UPD: LSA checksum bad        0         : UPD: Unknown LSA type
 0         : UPD: Less recent LSA         0         : UPD: LSA length bad
 0         : UPD: LSA AdvRtr id bad       0         : ACK: Bad ack packet
 0         : ACK: Invalid ack             0         : Interface down
 0         : Multicast incapable          0         : Authentication failure
 0         : AuthSeqNumber error
表1-41 display ospfv3 statistics error命令显示信息描述表
Transmit error
发送出错的OSPFv3报文数
Neighbor state low
在低邻居状态收到的OSPFv3报文数
Packet too small
报文长度太小的OSPFv3报文数
Bad version
错误版本号的OSPFv3报文数
Bad checksum
校验和出错的OSPFv3报文数
Unknown neighbor
未知的邻居发来的OSPFv3报文数
Bad area ID
非法的区域ID的OSPFv3报文数
Bad packet
非法的OSPFv3报文数
Packet dest error
目的地址错误的OSPFv3报文数
非活动区域中接收到的报文数
Router ID confusion
含有重复路由器ID的OSPFv3报文数
Bad virtual link
错误的虚链路的OSPFv3报文数
Hello定时器不匹配的Hello报文数
Dead定时器不匹配的Hello报文数
Option字段E位不匹配的Hello报文数
Option字段E位不匹配的DD报文数
DD报文中含有未知类型LSA的数目
MTU不匹配的DD报文数
REQ: Empty request
不含有任何请求信息的LSR报文数
REQ: Bad request
请求错误LSA的LSR报文数
LSU报文中含有错误校验和LSA的数目
LSU报文中含有未知类型LSA的数目
LSU报文中含有不是最新LSA的数目
UPD: LSA length bad
LSU报文中含有错误长度LSA的数目
LSU报文中含有错误宣告路由器LSA的数目
ACK: Bad ack packet
对LSU报文错误确认的ack报文数
ACK: Invalid ack
LSAck报文中无效确认ack的数目
Interface down
接口down计数
Multicast incapable
加入组播组出错计数
接收到的报文验证失败
AuthSeqNumber error
接收到的报文验证序列号错误
# 显示OSPFv3进程和接口的报文统计信息。
<Sysname> display ospfv3 statistics packet
         Hello      DD         LSR        LSU        ACK        Total
 Input : 8727       128        28         1584       929        11396
 Output: 8757       159        86         987        1513       11502
 Area: 0.0.0.0
 Area: 0.0.0.1
 Interface: Ten-GigabitEthernet3/1/1
 Input : 16         0          45         7          68
 Output: 17         1          7          44         69
 Interface: Ten-GigabitEthernet3/1/2
 Input : 41         13         720        719        1493
 Output: 54         41         750        713        1558
表1-42 display ospfv3 statistics packet命令显示信息描述表
Hello
Hello报文
DD
数据库描述报文
LSR
链路状态请求报文
LSU
链路状态更新报文
ACK
链路状态确认报文
Total
报文总数
Input
接收报文数
Output
发送报文数
Area
区域ID
接口名称
1.1.36  display ospfv3 vlink
display ospfv3 vlink命令用来显示OSPFv3的虚连接信息。
display ospfv3 [ process-id ] vlink
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的虚连接信息。
# 显示OSPFv3的虚连接信息。
<Sysname> display ospfv3 vlink
 Virtual-link Neighbor-ID: 12.2.2.2, Neighbor-state: Full
 Interface: 2348 (Ten-GigabitEthernet3/1/2), Instance-ID: 0
 Local  IPv6 address: 3:3333::12
 Remote IPv6 address: 2:2222::12
 Cost: 1  State: P-2-P  Type: Virtual
 Timers: Hello 10, Dead 40, Retransmit 5, Transmit delay 1
表1-43 display ospfv3 vlink命令显示信息描述表
通过虚连接相连的邻居路由器的Router ID
Neighbor-state
邻居状态,包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
此虚连接的本端接口的端口号和名称
Instance-ID
实例ID
Local IPv6 address
本地IPv6地址
Remote IPv6 address
对端IPv6地址
Cost
接口的路由开销
接口状态
类型:虚连接
Transit area
传输区域ID(如果当前接口为虚连接,则显示)
Timers
OSPFv3定时器,分别定义如下:
·     Retransmit:表示接口重传LSA时间间隔,单位为秒
Transmit delay
接口对LSA的传输延迟时间,单位为秒
OSPFv3虚连接应用IPsec安全框架,IPsec安全框架名为profile001,inherited表示虚连接继承的是骨干区域下配置的IPsec安全框架
OSPFv3虚连接采用HMAC-SM3验证模式,key ID为xx,inherited表示虚连接继承的是骨干区域下配置的HMAC-SM3验证模式
OSPFv3虚连接采用HMAC-SHA-256验证模式,key ID为xx,inherited表示虚连接继承的是骨干区域下配置的HMAC-SHA-256验证模式
OSPFv3虚连接采用keychain验证模式,keychain名称为test,inherited表示虚连接继承的是骨干区域下配置的keychain验证模式
1.1.37  distibute bgp-ls
distribute bgp-ls命令用来配置允许设备将OSPFv3链路状态信息发布到BGP。
undo distribute bgp-ls命令用来恢复缺省情况。
distribute bgp-ls [ instance-id instance-id ]
不允许设备将OSPFv3链路状态信息发布到BGP。
OSPFv3视图
instance-id:OSPFv3实例ID,用于区分链路状态信息,取值范围为0~65535。如果未指定本参数,则表示实例0。
本功能允许设备将OSPFv3链路状态信息发布到BGP,由BGP通过BGP LS将收集到的链路状态信息发送给控制器,以便控制器构建全局链路状态信息数据库。关于BGP LS的详细介绍,请参见“三层技术-IP路由配置指导”中的“BGP扩展功能”。
如果OSPFv3进程位于VPN实例中,则无法配置本命令。
# 配置允许设备将OSPFv3进程1的链路状态信息发布到BGP。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] distribute bgp-ls
1.1.38  dscp
dscp命令用来配置OSPFv3发送协议报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
OSPFv3发送协议报文的DSCP优先级为48。
OSPFv3视图
dscp-value:DSCP优先级,取值范围为0~63。
# 配置OSPFv3进程1发送协议报文的DSCP优先级为63。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] dscp 63
1.1.39  enable ipsec-profile
enable ipsec-profile命令用来在OSPFv3区域应用IPsec安全框架。
undo enable ipsec-profile命令用来取消在OSPFv3区域应用的IPsec安全框架。
enable ipsec-profile profile-name
OSPFv3区域没有应用IPsec安全框架。
OSPFv3区域视图
profile-name:IPsec安全框架名称,为1~63个字符的字符串,不区分大小写。
本命令应结合IPsec安全框架使用,IPsec安全框架的具体情况请参见“安全配置指导”中的“IPsec”。
# 配置OSPFv3进程1区域0的安全框架为profile001。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 0
[Sysname-ospfv3-1-area-0.0.0.0] enable ipsec-profile profile001
1.1.40  event-log
event-log命令用来配置保存OSPFv3的日志信息的最大个数。
undo event-log命令用来取消保存OSPFv3的日志信息的最大个数的配置。
event-log { lsa-flush | peer | spf } size count
undo event-log { lsa-flush | peer | spf } size
保存的路由计算、邻居和LSA老化的日志信息个数均为10个。
OSPFv3视图
lsa-flush:LSA老化日志信息个数。
peer:邻居日志信息个数。
spf:SPF日志信息个数。
count:日志信息个数,取值范围为0~65535。
# 配置保存OSPFv3进程100的路由计算日志信息的最大个数为50。
[Sysname] ospfv3 100
[Sysname-ospfv3-100] event-log spf size 50
1.1.41  fast-reroute
fast-reroute命令用来配置OSPFv3快速重路由功能。
undo fast-reroute命令用来关闭OSPFv3快速重路由功能。
fast-reroute { lfa [ abr-only | ecmp-shared ] | route-policy route-policy-name }
undo fast-reroute
OSPFv3快速重路由功能处于关闭状态。
OSPFv3视图
lfa:为所有路由通过LFA(Loop Free Alternate)算法选取备份下一跳信息。
abr-only:仅选取到ABR设备的路由作为备份下一跳。
ecmp-shared:为包含等价路由的所有路由通过LFA算法选取备份下一跳信息,其中为等价路由选取的备份下一跳是共享下一跳,即多条等价的路由的备份下一跳是相同的。如果未指定本参数,则仅为非等价路由计算备份下一跳。
route-policy route-policy-name:为通过策略的路由指定备份下一跳,route-policy-name为路由策略名,为1~63个字符的字符串,区分大小写。
OSPFv3快速重路由功能(通过LFA算法选取备份下一跳信息)使能后,不能配置vlink-peer命令。
如需为去往同一目的地的等价路由计算共享备份下一跳,则需要指定ecmp-shared参数。指定本参数后,OSPFv3可以通过LFA算法选取备份下一跳,当链路或设备故障导致所有等价路由的下一跳均失效时,OSPFv3会使用事先获取的备份下一跳替换失效下一跳,通过备份下一跳来指导报文转发。计算出来的备份下一跳将以等价路由的形式下发给路由管理,可通过display ospfv3 routing命令查看路由信息,其中Type包含ECMP-back状态的路由即为等价路由的备份路由信息。
# 使能OSPFv3进程1的快速重路由功能,为所有路由通过LFA算法选取备份下一跳信息。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute lfa
·     display ospfv3 routing
1.1.42  fast-reroute enable
fast-reroute enable命令用来开启Flex-Algo算法的快速重路由功能。
undo fast-reroute enable命令用来关闭Flex-Algo算法的快速重路由功能。
fast-reroute enable
Flex-Algo算法的快速重路由功能处于开启状态。
Flex-Algo算法视图
缺省情况下,Flex-Algo算法使用LFA(Loop Free Alternate)计算到达某个SID的备份路径:
(1)     以可提供备份链路的邻居为根节点,利用SPF算法计算出到目的节点的最短路径树。
(2)     按照LFA计算出一条开销最小且无环的备份路径。
如果网络中不存在备份路径,可以使用本命令关闭Flex-Algo算法的快速重路由功能,节省设备资源。
# 关闭Flex-Algo算法128的快速重路由功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] flex-algo 128
[Sysname-ospfv3-1-flex-algo-128] undo fast-reroute enable
1.1.43  fast-reroute tiebreaker (OSPFv3 view)
fast-reroute tiebreaker命令用来配置快速重路由备份路径优选方案的优先级。
undo fast-reroute tiebreaker命令用来恢复缺省情况。
fast-reroute tiebreaker { lowest-cost | node-protecting } preference preference
undo fast-reroute tiebreaker { lowest-cost | node-protecting }
最小开销路径优选方案的优先级是20,节点保护优选方案的优先级是40。
OSPFv3视图
lowest-cost:指定最小开销路径优选方案的优先级。
node-protecting:指定节点保护优选方案的优先级。
preference preference:设置优选方案的优先级,取值范围为1~255,该数值越大表示优先级越高。
OSPFv3 FRR使用一定的计算规则计算备份路径。Tiebreaker使用优先级值来对计算规则进行排序,优先级的值越大,对应的计算规则的优先级越高。OSPFv3 FRR备份路径优选方案通过调整计算规则的优先级,能够影响OSPFv3 FRR计算出来的备份路径。不同的备份路径可为流量提供节点保护或链路保护,或者同时提供节点保护和链路保护。
OSPFv3 FRR支持如下类型的计算规则,不同的计算规则生成不同的用于计算备份路径的拓扑。
·     节点保护(node-protecting):OSPFv3 FRR排除主下一跳节点之后计算备份路径。
·     最低开销(lowest-cost):OSPFv3 FRR排除直连主链路之后计算备份路径。
当同一OSPFv3进程下存在多个FRR备份路径优选方案时,会优先选择优先级较高的优选方案计算备份路径。如果该方案不能计算出备份路径,则再从其他优选方案中选择优先级较高的优选方案计算备份路径。具体工作机制如下:
·     当node-protecting > lowest-cost时,如果使用node-protecting规则不能计算出备份路径,则再使用lowest-cost规则计算备份路径。如果仍不能计算备份路径,则主链路故障后无法保证可靠性。
·     当lowest-cost > node-protecting时,如果使用lowest-cost规则不能计算出备份路径,则不再使用node-protecting规则计算备份路径,主链路故障后无法保证可靠性。
多次执行本命令:
·     可以分别配置最小开销路径优选方案和节点保护优选方案的优先级。
·     对于同一优选方案,最后一次执行的命令生效。
# 配置OSPFv3进程1快速重路由备份路径计算时节点保护优选方案的优先级为100。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute tiebreaker node-protecting preference 100
·     fast-reroute
1.1.44  fast-reroute tiebreaker (Flexible algorithm view)
fast-reroute tiebreaker命令用来配置Flex-algo算法的快速重路由备份路径优选方案的优先级。
最小开销路径优选方案的优先级为20,节点保护优选方案的优先级为40。
Flex-algo视图
多次执行本命令:
·     可以分别配置最小开销路径优选方案、节点保护优选方案的优先级。
当同一视图下配置了两个优选方案时,会优先选择优先级较高的优选方案计算备份路径。如果该方案不能计算出备份路径,则采用另一个优选方案计算备份路径。如果两种优选方案均无法计算出备份路径,那么主链路故障后无法保证可靠性。
当通过最小开销路径方式计算备份路径时,如果不能计算出备份路径,则不会再通过节点保护方式计算备份路径,主链路故障后无法保证可靠性。
# 在OSPFv3进程1下配置Flex-Algo算法255计算快速重路由备份路径时,节点保护优选方案优先级为100。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] flex-algo 255
[Sysname-ospfv3-1-flex-algo-255] fast-reroute tiebreaker node-protecting preference 100
1.1.45  fast-reroute ti-lfa enable
fast-reroute ti-lfa enable命令用来开启Flex-algo算法的TI-LFA(Topology-Independent Loop-free Alternate,拓扑无关无环备份)快速重路由功能。
undo fast-refroute ti-lfa enable命令用来关闭Flex-algo算法的TI-LFA快速重路由功能。
fast-reroute ti-lfa enable [ per-prefix ]
undo fast-reroute ti-lfa enable
Flex-algo算法的TI-LFA快速重路由功能处于开启状态。
Flex-Algo视图
per-prefix:当路由由多源发布时,指定本参数可以为每条路由的每个发布源计算备份信息。如果未指定本参数,则设备为每条路由计算备份信息。
Flex-Algo算法的TI-LFA FRR功能基于FAD,在Flex-Algo拓扑中计算备份路径。Flex-algo算法的TI-LFA快速重路由功能能够提供链路及节点的保护。当某处链路或节点故障时,数据流量会快速切换到备份路径继续转发,从而最大程度上避免数据流量的丢失。
# 开启Flex-Algo算法255的TI-LFA快速重路由功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-flex-algo-255] fast-reroute ti-lfa enable
1.1.46  filter
filter命令用来配置对Inter-Area-Prefix-LSA进行过滤。
undo filter命令用来取消对Inter-Area-Prefix-LSA进行过滤。
filter { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
不对Inter-Area-Prefix-LSA进行过滤。
OSPFv3区域视图
ipv6-acl-number:指定的基本或高级IPv6 ACL编号,对进出本区域的Inter-Area-Prefix-LSA进行过滤,取值范围为2000~3999。
prefix-list-name:指定的IPv6地址前缀列表,对进出本区域的Inter-Area-Prefix-LSA进行过滤,为1~63个字符的字符串,区分大小写。
route-policy-name:指定的路由策略,对进出本区域的Inter-Area-Prefix-LSA进行过滤,为1~63个字符的字符串,区分大小写。
export:对ABR向其它区域发布的Inter-Area-Prefix-LSA进行过滤。
import:对ABR向本区域发布的Inter-Area-Prefix-LSA进行过滤。
此命令只在ABR路由器上有效,对区域内部路由器无效。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示ABR不会对Inter-Area-Prefix-LSA进行过滤。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则会拒绝所有Inter-Area-Prefix-LSA通过过滤。
当配置的是高级ACL(3000~3999)时,其使用规则如下:
·     使用命令rule [ rule-id ] { deny | permit } ipv6 source sour-addr sour-prefix来过滤携带指定地址前缀的Inter-Area-Prefix-LSA。
·     使用命令rule [ rule-id ] { deny | permit } ipv6 source sour-addr sour-prefix destination dest-addr dest-prefix来过滤携带指定地址前缀和前缀长度的Inter-Area-Prefix-LSA。
其中,source用来过滤Inter-Area-Prefix-LSA携带的地址前缀,destination用来过滤Inter-Area-Prefix-LSA携带的地址前缀的前缀长度,配置的前缀长度应该是连续的(当配置的前缀不连续时该过滤LAS的条件不生效)。
# 根据IPv6地址前缀列表my-prefix-list和编号为2000的IPv6基本ACL分别对进出OSPFv3区域1的Inter-Area-Prefix-LSA进行过滤。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] filter prefix-list my-prefix-list import
[Sysname-ospfv3-1-area-0.0.0.1] filter 2000 export
1.1.47  filter-policy export
filter-policy export命令用来配置对引入的路由信息进行过滤。
undo filter-policy export命令用来取消对引入的路由信息进行过滤。
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } export [ bgp4+ | direct | { isisv6 | ospfv3 | ripng } [ process-id ] | static | unr ]
undo filter-policy export [ bgp4+ | direct | { isisv6 | ospfv3 | ripng } [ process-id ] | static | unr ]
不对引入的路由信息进行过滤。
OSPFv3视图
ipv6-acl-number:用于过滤路由信息目的地址的基本或高级IPv6 ACL编号,取值范围为2000~3999。
prefix-list-name:用于过滤路由信息目的地址的IPv6地址前缀列表的名称,为1~63个字符的字符串,区分大小写。
bgp4+:对引入的IPv6 BGP路由进行过滤。
direct:对引入的直连路由进行过滤。
isisv6:对引入的IPv6 IS-IS路由进行过滤。
ospfv3:对引入的OSPFv3路由进行过滤。
ripng:对引入的RIPng路由进行过滤。
process-id:路由协议进程号,取值范围为1~65535,缺省值为1。
static:对引入的IPv6静态路由进行过滤。
unr:对引入的UNR(User Network Route,用户网络路由)路由进行过滤。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示OSPFv3不会对引入的路由信息进行过滤。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则会拒绝所有引入的路由信息通过过滤。
·     使用命令rule [ rule-id ] { deny | permit } ipv6 source sour-addr sour-prefix来过滤指定目的地址的路由。
·     使用命令rule [ rule-id ] { deny | permit } ipv6 source sour-addr sour-prefix destination dest-addr dest-prefix来过滤指定目的地址和掩码的路由。
其中,source用来过滤路由目的地址,destination用来过滤路由前缀,配置的前缀应该是连续的(当配置的前缀不连续时该过滤前缀的条件不生效)。
filter-policy export命令只对本设备使用import-route引入的路由起作用。如果没有配置import-route命令来引入其它外部路由(包括不同进程的OSPFv3路由),则filter-policy export命令无效。
如果没有指定路由协议,将对引入的任何一个协议产生的路由都要进行过滤。
# 根据IPv6地址前缀列表abc对引入的路由信息进行过滤。
[Sysname] ipv6 prefix-list abc permit 2002:1:: 64
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy prefix-list abc export
# 使用编号为3000的IPv6高级ACL对引入的路由进行过滤,只允许2001::1/128通过。
[Sysname-acl-ipv6-adv-3000] rule 10 permit ipv6 source 2001::1 128 destination ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff 128
[Sysname-acl-ipv6-adv-3000] rule 100 deny ipv6
[Sysname-acl-ipv6-adv-3000] quit
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 3000 export
1.1.48  filter-policy import
filter-policy import命令用来过滤通过接收到的LSA计算出来的路由信息。
filter-policy { ipv6-acl-number [ gateway prefix-list-name ] | prefix-list prefix-list-name [ gateway prefix-list-name ] | gateway prefix-list-name | route-policy route-policy-name } import
不对通过接收到的LSA计算出来的路由信息进行过滤。
OSPFv3视图
gateway prefix-list-name:指定的IPv6地址前缀列表,基于要加入到路由表的路由信息的下一跳进行过滤。prefix-list-name为1~63个字符的字符串,区分大小写。如果未指定本参数,则不会基于要加入到路由表的路由信息的下一跳进行过滤。
prefix-list prefix-list-name:指定的地址前缀列表,基于目的地址对接收的路由信息进行过滤。prefix-list-name为1~63个字符的字符串,区分大小写。
route-policy route-policy-name:指定路由策略名,基于路由策略对接收的路由信息进行过滤。route-policy-name为1~63个字符的字符串,区分大小写。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示OSPFv3不会对计算出来的路由信息进行过滤。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则会拒绝所有计算出来的路由信息通过过滤。
当配置的是高级ACL(3000~3999)或者指定的路由策略中配置的是高级ACL时,其使用规则如下:
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-prefix来过滤指定目的地址的路由。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-prefix destination dest-addr dest-prefix来过滤指定目的地址和前缀的路由。
filter-policy import命令只对OSPFv3计算出来的路由进行过滤,没有通过过滤的路由将不被加入路由表中,从而不能指导报文转发。
# 根据IPv6地址前缀列表abc对接收的路由信息进行过滤。
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy prefix-list abc import
# 使用编号为3000的IPv6高级ACL对接收的路由进行过滤,只允许2001::1/128通过。
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 3000 import
1.1.49  flex-algo
flex-algo命令用来创建Flex-Algo算法,并进入Flex-Algo视图。如果指定的Flex-Algo算法已经存在,则直接进入Flex-Algo算法视图。
undo flex-algo命令用来删除指定的Flex-Algo算法。
undo flex-algo flex-algo-id
不存在Flex-Algo算法。
OSPFv3视图
flex-algo-id:Flex-Algo的算法标识符,取值范围为128~255。同一个OSPFv3进程下可以创建多个Flex-Algo算法。
OSPFv3通告的SID中包含算法字段,该字段共8位,用0~255之间的数字表示不同的算法:
·     算法0表示基于IGP链路度量的SPF算法。
·     算法128~255可以自由定义,称为Flex-Algo(Flexible Algorithm,灵活算法)。表示基于特定度量类型和约束条件的SPF算法。
Flex-Algo算法包含三个要素:算法类型、优化目标和约束条件。
·     算法类型:计算路径使用的算法。当前仅支持SPF算法。
·     优化目标:使用Flex-Algo算法基于特定度量类型计算到达目的地的最小开销路径。当前仅支持使用OSPFv3的链路开销作为度量类型。
·     约束条件:Flex-Algo算法生成算法拓扑时遵循的规则,即包含或排除具有特定亲和属性的链路。
生成特定算法标识符的Flex-Algo算法拓扑的机制如下:
(1)     删除所有不参与该Flex-Algo算法计算的节点。
(2)     删除约束条件中避免使用的链路。
(3)     删除不具备算法所使用的度量的链路。
生成Flex-Algo算法拓扑后,各节点根据计算类型和优化目标进行路径计算。
# 创建算法标识符为128的Flex-Algo,并进入Flex-Algo算法视图。
[Sysname] ospfv3 1
1.1.50  graceful-restart enable
graceful-restart enable命令用来使能OSPFv3协议的GR能力。
undo graceful-restart enable命令用来关闭OSPFv3协议的GR能力。
graceful-restart enable [ global | planned-only ] *
OSPFv3的GR能力处于关闭状态。
OSPFv3视图
global:全局GR,必须保证所有的GR Helper都存在,整个GR才会完成,如果有一个GR Helper失效(比如,接口down),则整个GR失败。如果未指定本参数,表示支持接口级GR,即只要有一个GR Helper存在,则整个GR会完成。
planned-only:表示只支持计划重启。如果未指定本参数,表示计划重启和非计划重启都支持。
GR包括计划重启和非计划重启:
·     计划重启指的是手动通过命令执行重启或主备倒换,在进行重启或主备倒换前GR Restarter会先发送Grace-LSA。
·     非计划GR指的是由于设备故障等原因进行重启或主备倒换,在进行重启或主备倒换前GR Restarter不会事先发送Grace-LSA。
支持OSPFv3的GR Restarter能力的设备主备倒换后,为了实现设备转发业务的不中断,它必须完成下列两项任务:
·     重启过程GR Restarter转发表项保持稳定;
·     重启流程结束后重建所有邻居关系,重新获取完整的网络拓扑信息。
# 使能OSPFv3进程1的GR能力。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart enable
·     graceful-restart helper enable
1.1.51  graceful-restart helper enable
graceful-restart helper enable命令用来使能OSPFv3的GR Helper能力。
undo graceful-restart helper enable命令用来关闭OSPFv3的GR Helper能力。
OSPFv3的GR Helper能力处于开启状态。
OSPFv3视图
planned-only:表示只支持计划重启。如果未指定本参数,表示计划重启和非计划重启(即异常重启)都支持。
收到Grace-LSA后,如果支持GR Helper能力则进入Helper模式(此时该邻居称为GR Helper)。在GR Restarter重新建立邻居的时候,GR Helper帮助GR Restarter进行LSDB的同步。
# 使能OSPFv3进程1的GR Helper能力。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart helper enable
·     graceful-restart enable
1.1.52  graceful-restart helper strict-lsa-checking
graceful-restart helper strict-lsa-checking命令用来使能GR Helper严格LSA检查能力。
undo graceful-restart helper strict-lsa-checking命令用来关闭GR Helper严格LSA检查能力。
GR Helper严格LSA检查能力处于关闭状态。
OSPFv3视图
使能GR Helper严格LSA检查能力,当检查到GR Helper设备的LSA发生变化时候,Helper设备退出GR Helper模式。
# 使能OSPFv3进程1的GR Helper严格LSA检查能力。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart helper strict-lsa-checking
1.1.53  graceful-restart interval
graceful-restart interval命令用来配置OSPFv3协议的GR重启间隔时间。
OSPFv3协议的GR重启间隔时间为120秒。
OSPFv3视图
interval:指定OSPFv3协议的GR重启间隔时间(期望重启时间),取值范围为40~1800,单位为秒。
配置此命令的用户需要确保配置的GR重启间隔不小于OSPFv3所有接口的邻居失效时间的最大值,否则可能造成GR重启失败。
# 配置OSPFv3进程1的GR重启间隔时间为100秒。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart interval 100
·     ospfv3 timer dead
1.1.54  import-route
import-route命令用来配置引入外部路由信息。
undo import-route命令用来取消引入外部路由信息。
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { direct | static | unr } [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { isisv6 | ospfv3 | ripng } [ process-id | all-processes ] [ allow-direct | [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
undo import-route { bgp4+ | direct | { isisv6 | ospfv3 | ripng } [ process-id | all-processes ] | static | unr }
不引入外部路由信息。
OSPFv3视图
bgp4+:引入IPv6 BGP协议的路由。
as-number:引入指定AS内的路由。as-number为AS号,取值范围为1~4294967295。如果没有指定本参数,则引入所有的IPv6 EBGP路由。建议配置时指定AS号,否则引入的IPv6 EBGP路由数量过多时,会引发设备内存资源紧张等问题。
direct:引入直连路由。
static:引入IPv6静态路由。
unr:引入UNR(User Network Route,用户网络路由)路由。UNR路由是接入设备为上线用户生成的路由。
isisv6:引入IPv6 IS-IS协议的路由。
ospfv3:引入OSPFv3协议的路由。
ripng:引入RIPng协议的路由。
process-id:IPv6 IS-IS、OSPFv3或RIPng路由协议进程号,取值范围为1~65535,缺省值为1。
all-processes:引入IPv6 IS-IS、OSPFv3或RIPng路由协议所有进程的路由。
allow-ibgp:允许引入IBGP路由。import-route bgp4+表示只引入EBGP路由;import-route bgp4+ allow-ibgp表示将IBGP路由也引入,容易引起路由环路,请慎用。
allow-direct:在引入的路由中包含使能了该协议的接口网段路由。如果未指定本参数,在引入协议路由时不会包含使能了该协议的接口网段路由。当allow-direct与route-policy route-policy-name参数一起使用时,需要注意路由策略中配置的匹配规则不要与接口路由信息存在冲突,否则会导致allow-direct配置失效。例如,当配置allow-direct参数引入OSPFv3直连时,在路由策略中不要配置if-match route-type匹配条件,否则,allow-direct参数失效。
cost cost-value:路由开销值,取值范围为0~16777214。
inherit-cost:指定引入外部路由时使用路由的原有开销值。
nssa-only:设置Type-7 LSA的P比特位不置位,即在对端路由器上不能转为Type-5 LSA。如果未指定本参数,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
route-policy route-policy-name:配置只能引入符合指定路由策略的路由。route-policy-name为路由策略名称,为1~63个字符的字符串,区分大小写。
tag tag:外部LSA中的标记,取值范围为0~4294967295。如果未指定本参数,将根据default tag命令的配置进行取值。
type type:度量值类型,取值范围为1~2,缺省值为2。
外部路由是指到达自治系统外部的路由,有两类:
·     第一类外部路由(Type1 External):这类路由的可信程度较高,并且和OSPFv3自身路由的开销具有可比性,所以到第一类外部路由的开销等于本路由器到相应的ASBR的开销与ASBR到该路由目的地址的开销之和。
·     第二类外部路由(Type2 External):这类路由的可信度比较低,所以OSPFv3协议认为从ASBR到自治系统之外的开销远远大于在自治系统之内到达ASBR的开销。所以计算路由开销时将主要考虑前者,即到第二类外部路由的开销等于ASBR到该路由目的地址的开销。如果计算出开销值相等的两条路由,再考虑本路由器到相应的ASBR的开销。
该命令不能引入缺省路由。
如果未指定cost和inherit-cost参数,则引入的外部路由的开销值为1。
import-route nssa-only命令配置后,引入的路由只在NSSA区域产生Type-7 LSA,不会在非NSSA区域产生Type-5 LSA。
# 指定引入进程号为10的RIPng路由为第二类路由,路由开销值为50。
[Sysname] ospfv3
[Sysname-ospfv3-1] import-route ripng 10 type 2 cost 50
# OSPFv3进程100引入OSPFv3进程160发现的路由。
[Sysname-ospfv3-100] import-route ospfv3 160
·     default-route-advertise
1.1.55  isolate enable
isolate enable命令用来开启OSPFv3协议的隔离功能。
undo isolate enable命令用来关闭OSPFv3协议的隔离功能。
isolate enable
undo isolate enable
OSPFv3协议的隔离功能处于关闭状态。
OSPFv3视图
Isolate是一种对网络设备进行软件或硬件维护的方式。Isolate使用网络中的冗余路径,平滑移除需要维护的设备。当完成设备维护后,该设备可以重新投入使用。
当用户需要对网络中某台设备的OSPFv3协议进行升级时,为了不对当前网络中通过该设备发布的OSPFv3路由指导转发的流量产生影响,可以使用OSPFv3 isolate功能把该设备上的OSPFv3协议从当前网络中隔离出来,具体工作机制如下:
(1)     开启OSPFv3 isolate功能后,OSPFv3将链路度量值调大,以便邻居重新进行路径优选。OSPFv3调整链路度量值的机制如下:
¡     发布的Type-1 LSA中,OSPFv3将链路度量值调整为最大值65535。
¡     发布的Type-3 LSA和Type-4 LSA中,OSPFv3将链路度量值调整为16711680。
¡     发布的外部LSA中,OSPFv3将链路度量值调整为16711680。
(2)     邻居收到LSA完成路由计算后,将选择更优的路径转发流量,不再将流量发往OSPFv3 isolate设备。此时,设备的OSPFv3协议完全从当前组网中隔离出来,可以对该设备上的OSPFv3协议进行升级处理。
(3)     对OSPFv3协议的维护结束后,使用undo isolate enable命令将链路度量值恢复为调整前的值,从而让该设备的OSPFv3协议重新加入网络。
单独配置isolate enable命令的效果与单独配置stub-router max-metric external-lsa 16711680 summary-lsa 16711680 include-stub命令的效果相同。
同时配置OSPFv3 isolate功能和OSPFv3 stub路由器功能时,需要注意:
·     如果stub-router max-metric命令中指定了include-stub参数,那么Router-LSA中链路类型为3的Stub链路度量值由OSPFv3 stub路由器功能调整;Router-LSA中链路类型为1、2、4的链路度量值由OSPFv3 isolate功能调整。
·     如果stub-router max-metric命令中指定了external-lsa和summary-lsa参数,OSPFv3选择Isolate功能和Stub路由器功能中同类LSA链路度量值的较大值作为对应类型LSA的链路度量值。
·     如果stub-router max-metric命令中指定了on-startup参数,在Stub路由器功能未生效期间,仅Isolate功能会影响流量转发路径。当Stub路由器功能生效时,Isolate功能和Stub路由器功能都会影响流量转发路径。
·     如果stub-router max-metric命令未指定任何参数,那么仅Isolate功能会影响流量转发路径。
# 在OSPFv3进程100下,把设备的OSPFv3协议从当前网络中隔离出来。
[Sysname-ospfv3-100] isolate enable
·     stub-router
1.1.56  ispf enable
ispf enable命令用来开启OSPFv3 ISPF功能,即增量SPF计算功能。
undo ispf enable命令用来关闭OSPFv3 ISPF计算功能。
ispf enable
undo ispf enable
OSPFv3 ISPF功能处于开启状态。
OSPFv3视图
使能增量SPF计算功能后,当网络的拓扑结构发生变化影响到最短路径树的结构时,只将受影响的部分节点进行修正,而不重建整棵最短路径树。
# 关闭OSPFv3进程1的增量SPF计算功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] undo ispf enable
1.1.57  link-tag inherit enable
link-tag inherit enable命令用来开启OSPFv3的链路标记继承功能。
undo link-tag inherit enable命令用来关闭OSPFv3链路标记继承功能。
OSPFv3链路标记继承功能处于关闭状态。
OSPFv3进程视图
配置本命令后,当设备收到携带链路标记的链路状态信息时,设备将提取并继承链路标记中的链路标记值。如果设备提取到了多个链路标记值(假设为tag 1、tag 2、tag n),设备将根据一定的规则选取其中一个(假设为tag 1)进行继承。后续设备计算出来的到达某个目的地的路径包含携带链路标记的链路时,将该路由的路由标记设置为tag 1,借助路由标记可以实现路由筛选。
上述机制可应用于域内SAVA(Source Address Validation Architecture,源地址验证架构)场景。一个局域网存在多个网关设备时,网关需要将自己本地生成的IPv6 SAVA表项同步给其他的网关。可以借助OSPFv3的链路标记功能实现IPv6 SAVA表项同步,具体机制如下:
(1)     需要发布IPv6 SAVA表项的网关设备上,在靠近用户侧接口上开启接口链路标记功能。
(2)     在接收IPv6 SAVA表项的网关设备上开启链路标记继承功能。当该设备计算出来的OSPFv3路由条目的路由标记与自身通过ipv6 sava import remote-route-tag命令为远端路由指定的路由标记相同时,设备将使用OSPFv3路由的目的前缀生成IPv6 SAVA表项,从而实现IPv6 SAVA表项的同步。
关于SAVA功能以及IPv6 SAVA表项的详细介绍,请参见“安全配置指导”中的“SAVA”。
# 在OSPFv3进程1下,开启链路标记继承功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] link-tag inherit enable
·     ipv6 sava import remote-route-tag(安全命令参考/SAVA)
·     ospfv3 link-tag
1.1.58  log-peer-change
log-peer-change命令用来打开邻居状态变化的输出开关。
undo log-peer-change命令用来关闭邻居状态变化的输出开关。
log-peer-change
邻居状态变化的输出开关处于打开状态。
OSPFv3视图
打开邻居状态输出开关后,OSPFv3邻居状态变化时会生成日志信息发送到设备的信息中心,通过设置信息中心的参数,最终决定日志信息的输出规则(即是否允许输出以及输出方向)。(有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。)
# 关闭OSPFv3进程100的邻居状态变化的输出开关。
[Sysname-ospfv3-100] undo log-peer-change
1.1.59  lsa-arrival-interval
lsa-arrival-interval命令用来配置OSPFv3接收LSA的时间间隔。
undo lsa-arrival-interval命令用来恢复缺省情况。
lsa-arrival-interval maximum-interval [ minimum-interval [ incremental-interval ] ]
OSPFv3接收LSA的最大时间间隔为1000毫秒,最小时间间隔为500毫秒,时间间隔惩罚增量为500毫秒。
OSPFv3视图
maximum-interval:OSPFv3接收LSA的最大时间间隔,取值范围为0~10000,单位为毫秒。
minimum-interval:OSPFv3接收LSA的最小时间间隔,取值范围为0~1000,单位为毫秒。如果未指定本参数,则OSPFv3接收LSA的最小时间间隔为0。
incremental-interval:OSPFv3接收LSA的时间间隔惩罚增量,取值范围为1~5000,单位为毫秒。如果未指定本参数,则OSPFv3接收LSA的时间间隔惩罚增量为0。
LSA类型、LSA ID、生成路由器ID均相同的多个LSA为重复LSA,对于在接收LSA的时间间隔内收到的重复LSA,设备将直接丢弃,避免处理大量重复LSA导致设备资源被过多占用的问题。具体机制如下:
·     配置lsa-arrival-interval maximum-interval命令后,设备接收LSA的时间间隔为maximum-interval。对于在接收时间间隔内收到的重复LSA,设备将直接丢弃。
·     配置lsa-arrival-interval maximum-interval minimum-interval命令后,设备首次接收LSA的时间间隔为minimum-interval,后续接收LSA的时间间隔为maximum-interval。对于在接收时间间隔内收到的重复LSA,设备将直接丢弃。
·     配置lsa-arrival-interval maximum-interval minimum-interval incremental-interval命令后,设备首次接收LSA的时间间隔为minimum-interval;第n(n≥2)次接收LSA的时间间隔为minimum-interval+incremental-interval×2n-2,最大不超过maximum-interval。对于在接收时间间隔内收到的重复LSA,设备将直接丢弃。
在网络相对稳定且对路由收敛速度要求较高的组网环境中,可以将接收LSA的时间间隔配置为0,使得拓扑或者路由的变化可以立即被感知到,从而加快路由的收敛。
minimum-interval和incremental-interval配置值不允许大于maximum-interval配置值。
# 配置OSPFv3接收LSA的最大时间间隔为2000毫秒,最小时间间隔为100毫秒,惩罚增量为300毫秒。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] lsa-arrival-interval 2000 100 300
1.1.60  lsa-generation-interval
lsa-generation-interval命令用来配置OSPFv3 LSA重新生成的时间间隔。
undo lsa-generation-interval命令用来恢复缺省情况。
OSPFv3 LSA重新生成的最大时间间隔为5秒,最小时间间隔为0毫秒,时间间隔惩罚增量为0毫秒。
OSPFv3视图
maximum-interval:OSPFv3 LSA重新生成的最大时间间隔,取值范围为1~60,单位为秒。
minimum-interval:OSPFv3 LSA重新生成的最小时间间隔,取值范围为10~60000,单位为毫秒。取值为0毫秒时表示不对OSPFv3 LSA重新生成的最小时间间隔进行限制。
incremental-interval:OSPFv3 LSA重新生成的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
通过调节LSA重新生成的时间间隔,可以抑制网络频繁变化可能导致的带宽资源和路由器资源被过多占用的问题。在网络变化不频繁的情况下,将LSA重新生成时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可以进行相应惩罚,将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval。
# 设置LSA重新生成的最大时间间隔为2秒,最小时间间隔为100毫秒,惩罚增量为100毫秒。
[Sysname-ospfv3-100] lsa-generation-interval 2 100 100
1.1.61  maximum load-balancing
maximum load-balancing命令用来配置OSPFv3支持的等价路由的最大条数。
maximum load-balancing number
OSPFv3支持的等价路由的最大条数为64。
OSPFv3视图
number:等价路由的最大条数,当number取值为1时,相当于不进行负载分担。当number不大于64时,支持的等价路由条数为1~number;当number大于64时,支持的等价路由条数为1~64。
# 配置OSPFv3支持的等价路由的最大条数为2。
[Sysname-ospfv3-100] maximum load-balancing 2
1.1.62  metric-bandwidth advertisement enable
metric-bandwidth advertisement enable命令用来开启带宽发布功能。
undo metric-bandwidth advertisement enable命令用来关闭带宽发布功能。
带宽发布功能处于关闭状态。
OSPFv3视图
开启本功能后,OSPFv3发布的LSA中将携带链路带宽信息。
在使用BGP-LS将链路状态上报给控制器进行路径计算的场景中,可以配置本功能由OSPFv3收集和扩散域内链路带宽信息,并通过BGP-LS上报给控制器,由控制器基于带宽计算路径信息,从而满足最优路径带宽最大的需求。
# 开启OSPFv3进程1的带宽发布功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] metric-bandwidth advertisement enable
·     distribute bgp-ls
1.1.63  metric-bandwidth suppression
metric-bandwidth suppression命令用来开启OSPFv3的带宽发布抑制功能,并设置抑制参数。
undo metric-bandwidth suppression命令用来关闭OSPFv3带宽发布抑制功能。
metric-bandwidth suppression timer time-value
OSPFv3的带宽发布抑制功能处于开启状态,抑制定时器为120秒。
OSPFv3视图
timer time-value:设置带宽发布抑制定时器,time-value表示带宽发布抑制定时器的值,取值范围为0~600,单位为秒。0表示不启动带宽发布抑制定时器。
带宽频繁变化时,OSPFv3会频繁地处理接口上报的带宽信息,并通过BGP-LS向控制器频繁上报链路信息,导致设备资源被过多占用。带宽发布抑制功能可以用来解决上述问题。
带宽发布抑制功能的工作机制为:
(1)     开启带宽发布抑制功能后,接口按照与OSPFv3协商的周期向OSPFv3上报带宽信息,不再频繁上报带宽信息。
(2)     OSPFv3按照带宽发布抑制定时器设置的时间间隔通过BGP-LS发布接口上报的带宽信息。即OSPFv3在定时器超时前不能发布带宽信息。
只有通过metric-bandwidth advertisement enable命令开启带宽发布抑制功能之后,本命令才能生效。
建议配置的带宽发布抑制定时器的值要大于或等于以太网接口带宽测量的时间间隔。关于以太网接口的详细介绍,请参见“接口管理配置指导”中的“以太网接口”。
# 开启OSPFv3进程1的带宽发布抑制功能,配置带宽发布抑制定时器为100秒。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] metric-bandwidth suppression timer 100
·     metric-bandwidth advertisement enable
1.1.64  metric-delay advertisement enable
metric-delay advertisement enable命令用来开启时延发布功能。
undo metric-delay advertisement enable命令用来关闭时延发布功能。
时延发布功能处于关闭状态。
OSPFv3视图
开启本功能后,OSPFv3发布的LSA中将携带链路时延信息。
在使用BGP-LS将链路状态上报给控制器进行路径计算的场景中,可以配置本功能由OSPFv3收集和扩散域内链路时延信息,并通过BGP-LS上报给控制器,由控制器基于时延计算路径,从而满足最优路径时延最小的需求。
# 开启OSPFv3进程1的时延发布功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] metric-delay advertisement enable
·     distribute bgp-ls
1.1.65  metric-delay suppression
metric-delay suppression命令用来开启OSPFv3的时延发布抑制功能,并设置抑制参数。
undo metric-delay suppression命令用来关闭OSPFv3时延发布抑制功能。
metric-delay suppression timer time-value percent-threshold percent-value absolute-threshold absolute-value
OSPFv3的时延发布抑制功能处于开启状态,时延发布抑制定时器为120秒,时延变化率的抑制阈值为10%,时延变化绝对值的抑制阈值为1000微秒。
OSPFv3视图
timer time-value:设置时延发布抑制定时器,time-value表示时延发布抑制定时器的值,取值范围为0~600,单位为秒。0表示不启动时延发布抑制定时器。
percent-value:时延变化率的抑制阈值,取值范围为0~100,单位为百分比。将percent-value设置为0表示不关注时延变化率。
absolute-value:时延变化绝对值的抑制阈值,取值范围为0~10000,单位为微秒。将absolute-value设置为0表示不关注时延变化的绝对值。
时延频繁抖动时,OSPFv3会频繁地处理接口上报的时延信息,并通过BGP-LS向控制器频繁上报链路信息,导致设备资源被过多占用。时延发布抑制功能可以用来解决上述问题。
时延发布抑制功能的工作机制为:
(1)     开启时延发布抑制功能后,接口按照与OSPFv3协商的周期向OSPFv3上报时延信息,不再频繁上报时延信息。
(2)     OSPFv3按照时延发布抑制定时器设置的时间间隔通过BGP-LS发布接口上报的时延信息。即OSPFv3在定时器超时前不能发布时延信息,以下两种情况除外:
¡     OSPFv3收到接口上报的前后两次最小时延的变化率大于或等于时延变化率抑制阈值。
¡     OSPFv3收到接口上报的前后两次最小时延差值的绝对值大于或等于时延变化绝对值抑制阈值。
只有通过metric-delay advertisement enable命令开启时延发布功能之后,本命令才能生效。
建议将时延发布抑制定时器的值配置为大于或等于NQA时延测量的时间间隔。关于NQA的详细介绍,请参见“网络管理和监控配置指导”中的“NQA”。
# 开启OSPFv3进程1的时延发布抑制功能,配置时延发布抑制定时器为100秒、时延变化率的抑制阈值为50%、时延变化绝对值的抑制阈值为200微秒。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] metric-delay suppression timer 100 percent-threshold 50 absolute-threshold 200
·     metric-delay advertisement enable
1.1.66  metric-type
metric-type命令用来配置Flex-Algo算法使用的度量类型。
undo metric-type命令用来恢复缺省情况。
metric-type { delay | te-cost }
undo metric-type
Flex-Algo算法使用OSPFv3的链路开销作为度量类型。
Flex-Algo算法视图
delay:配置Flex-Algo算法使用链路时延作为度量类型。
te-cost:配置Flex-Algo算法使用MPLS TE度量值作为度量类型。
缺省情况下,OSPFv3使用链路开销作为度量类型来计算到达目的地的最优路径。但是,对于某些类型的流量,这种方式计算出来的路径可能并不总是最好的路径。
Flex-Algo算法支持如下三种度量类型,用户可以根据业务需求选取合适的度量类型。
·     OSPFv3的链路开销。
·     链路时延。
·     MPLS TE度量值。
使用链路时延(delay)作为度量类型时,需要保证参与Flex-Algo算法的接口的时延发布功能处于生效状态。
使用MPLS TE度量值(te-cost)作为度量类型时,需要执行如下操作:
·     在参与Flex-Algo算法的节点上开启MPLS TE能力。
·     在参与Flex-Algo算法的接口上开启MPLS能力。
·     在参与Flex-Algo算法的接口上开启MPLS TE能力。
·     开启OSPFv3区域的MPLS TE能力。
# 配置Flex-Algo使用TE度量作为度量类型。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-flex-algo-128] metric-type te-cost
·     mpls enable(MPLS命令参考/MPLS基础)
·     mpls te enable (interface view)(MPLS命令参考/MPLS TE)
·     mpls te(MPLS命令参考/MPLS TE)
·     ospfv3 link-delay
1.1.67  mpls te enable
mpls te enable命令用来开启OSPFv3区域的MPLS TE能力。
undo mpls te enable命令用来关闭OSPFv3区域的MPLS TE能力。
mpls te enable
undo mpls te enable
OSPFv3区域的MPLS TE能力处于关闭状态。
OSPFv3区域视图
OSPFv3通过Intra-Area-TE LSA携带链路的TE属性信息,Intra-Area-TE LSA中的TE属性信息目前只用于BGP-LS收集拓扑TE信息,暂不支持完整的TE能力。
必须开启本节点的MPLS TE能力,否则本功能无法生效。
# 开启OSPFv3进程1区域1的MPLS TE能力。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] mpls te enable
1.1.68  nssa
nssa命令用来配置一个区域为NSSA区域。
undo nssa命令用来恢复缺省情况。
nssa [ default-route-advertise [ cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] * | no-import-route | no-summary | [ translate-always | translate-never ] | suppress-fa | translator-stability-interval value ] *
undo nssa
没有区域被配置为NSSA区域。
OSPFv3区域视图
default-route-advertise:该参数只用于NSSA区域的ABR或ASBR,配置后,对于ABR,不论本地是否存在缺省路由,都将生成一条Type-7 LSA向区域内发布缺省路由;对于ASBR,只有当本地存在缺省路由时,才产生Type-7 LSA向区域内发布缺省路由。
cost cost-value:该缺省路由的度量值,取值范围为0~16777214。如果未指定本参数,缺省路由的度量值将取default-cost命令配置的值。
nssa-only:设置Type-7 LSA的P比特位不置位,即在对端路由器上不能转为Type-5 LSA,对端路由器不能引入Type-7 LSA产生的外部路由。如果未指定本参数,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA,对端路由器可以引入Type-7 LSA产生的外部路由(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
route-policy route-policy-name:路由策略名,为1~63个字符的字符串,区分大小写。只有route-policy-name指定的路由策略匹配时,才可以产生一个描述缺省路由的Type-7 LSA发布出去,指定的路由策略会影响Type-7 LSA中的属性。
tag tag:缺省路由的标识,取值范围为0~4294967295。
type type:该NSSA LSA的类型,取值范围为1~2,缺省类型为2。
no-import-route:该参数用于禁止将AS外部路由以Type-7 LSA的形式引入到NSSA区域中,这个参数通常只用在既是NSSA区域的ABR,也是OSPFv3自治系统的ASBR的路由器上,以保证所有外部路由信息能正确地进入OSPFv3路由域。
no-summary:该参数只用于NSSA区域的ABR,配置后,NSSA ABR只通过Type-3 LSA向区域内发布一条缺省路由,不再向区域内发布任何其它Type-3 LSA(这种区域又称为Totally NSSA区域)。
translate-always:指定ABR为NSSA区域的Type-7 LSA转换为Type-5 LSA的转换路由器。
translate-never:指定ABR不能将NSSA区域的Type-7 LSA转换为Type-5 LSA。
suppress-fa:指定当Type-7 LSA转换为Type-5 LSA时,生成的Type-5 LSA不携带Forwarding Address。
translator-stability-interval value:当有新的设备成为NSSA区域的Type-7 LSA转换为Type-5 LSA的转换路由器后,原Type-7 LSA转换为Type-5 LSA的转换路由器保持转换能力的时间。value为保持时间,取值范围为0~900,单位为秒,缺省值为0,即不保持。
如果要将一个区域配置成NSSA区域,则该区域中的所有路由器都必须配置本命令。
# 将区域1配置成NSSA区域。
[Sysname] ospfv3 120
[Sysname-ospfv3-120] area 1
[Sysname-ospfv3-120-area-0.0.0.1] nssa
·     default-cost
1.1.69  ospfv3
ospfv3命令用来启动OSPFv3进程,并进入OSPFv3视图。
undo ospfv3命令用来关闭指定的OSPFv3进程。
ospfv3 [ process-id ] [ lite | vpn-instance vpn-instance-name ] *
undo ospfv3 [ process-id ]
系统没有运行OSPFv3进程。
process-id:OSPFv3进程号,取值范围为1~65535,缺省值为1。
lite:轻量级OSPFv3进程。如果未指定本参数,表示传统OSPFv3进程。
vpn-instance vpn-instance-name:指定OSPFv3进程所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示OSPFv3位于公网中。
只有在OSPFv3视图下配置了Router ID,OSPFv3进程才能正常运行,否则只能看到该进程,但无法生成LSA。
在用户需要启动大量OSPFv3进程的场景中,为了避免设备内存资源紧张,可以在创建OSPFv3进程时指定lite参数,以减少OSPFv3进程对内存的占用。轻量级OSPFv3进程虽然减少了内存占用,但在邻居数量、路由条目较多时会出现性能下降的情况。请根据设备的资源的使用情况合理规划启动轻量级OSPFv3进程的数量。
不能通过重复执行本命令将传统OSPFv3进程修改为轻量级进程。如需修改,请先通过undo ospfv3命令关闭OSPFv3进程,再执行ospfv3命令。对于已存在的轻量级进程,在进入进程视图时,可以不指定lite参数。
# 启动进程号为120的OSPFv3进程并配置路由器的Router ID为1.1.1.1。
[Sysname-ospfv3-120] router-id 1.1.1.1
·     router-id
1.1.70  ospfv3 affinity flex-algo
ospfv3 affinity flex-algo命令用来配置OSPFv3接口链路的亲和属性。
undo ospfv3 affinity flex-algo命令用来恢复缺省情况。
ospfv3 affinity flex-algo { affinity-name }&<1-32> [ instance instance-id ]
undo ospfv3 affinity flex-algo [ instance instance-id ]
OSPFv3接口链路不具有任何亲和属性。
affinity-name&<1-32>:OSPFv3接口链路的亲和属性。affinity-name表示亲和属性名称,为1~32个字符的字符串,区分大小写。&<1-32>表示前面的参数最多可以输入32次。
instance instance-id:OSPFv3实例ID,用于区分链路状态信息,取值范围为0~65535。如果未指定本参数,则表示实例0。
配置本命令后,接口去往邻接节点的链路将具有指定亲和属性名称映射的亲和属性。如果指定了多个亲和属性名称,那么接口链路将具有指定的所有亲和属性名称映射的亲和属性。
接口所在节点参与Flex-Algo算法计算时,如果Flex-Algo算法定义了约束条件,那么Flex-Algo算法会根据约束条件将具有特定亲和属性的链路加入Flex-Algo算法拓扑,或从Flex-Algo算法拓扑中排除。
# 配置接口Ten-GigabitEthernet3/1/1的链路的亲和属性为red映射的亲和属性。
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 affinity flex-algo red
·     affinity-map
1.1.71  ospfv3 area
ospfv3 area命令用来在接口上使能OSPFv3功能,并指定其所属区域。
undo ospfv3 area命令用来在指定接口上关闭OSPFv3功能。
ospfv3 process-id area area-id [ instance instance-id ]
undo ospfv3 process-id area area-id [ instance instance-id ]
接口上的OSPFv3功能处于关闭状态。
area-id:区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
instance-id:接口所属的实例ID,取值范围为0~255,缺省值为0。
# 在接口Ten-GigabitEthernet3/1/1上启动OSPFv3实例1的运行,并使能到Area 1中。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 1 area 1 instance 1
1.1.72  ospfv3 authentication-mode
ospfv3 authentication-mode命令用来设置接口上的OSPFv3报文的验证模式。
undo ospfv3 authentication-mode命令用来取消接口上的OSPFv3报文的验证模式的配置。
HMAC-SHA-256/HMAC-SM3验证模式:
ospfv3 authentication-mode { hmac-sha-256 | hmac-sm3 } key-id { cipher | plain } string [ instance instance-id ]
undo ospfv3 authentication-mode [ instance instance-id ]
keychain验证模式:
ospfv3 authentication-mode keychain keychain-name [ instance instance-id ]
接口不对OSPFv3报文进行验证。
hmac-sha-256:HMAC-SHA-256验证模式。
hmac-sm3:HMAC-SM3验证模式。
key-id:验证字标识符,取值范围为0~65535。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~255个字符的字符串;密文密钥为33~373个字符的字符串。
keychain:使用keychain验证模式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
instance instance-id:接口所属的实例ID,取值范围为0~255,缺省值为0。
不同设备上,属于同一网段的所有接口需要配置相同的验证模式和验证密钥。同一时间只能使用一种验证模式,无法同时使用HMAC-SHA-256验证模式、HMAC-SM3验证模式和keychain验证模式中的两种或三种。
接口视图下配置的验证模式,其优先级高于OSPFv3区域视图下配置的验证模式。
在使能了OSPFv3的接口上使用keychain验证模式时,报文的收、发过程如下:
·     OSPFv3在发送报文前,会先从keychain获取当前的有效发送key,然后发送报文。如果当前不存在有效发送key,或者该key的标识符大于65535,则OSPFv3不会发送报文。
·     OSPFv3在收到报文后,会根据报文携带的key的标识符从keychain中获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验,校验成功后再对报文进行下一步处理。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
对于keychain认证算法和key的标识符的范围,OSPFv3的支持情况如下:
·     OSPFv3仅支持HMAC-SHA-256和HMAC-SM3认证算法。
·     OSPFv3仅支持标识符取值范围为0~65535的key。
# 配置接口Ten-GigabitEthernet3/1/1上OSPFv3使用keychain验证模式,keychain名为test。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 authentication-mode keychain test
1.1.73  ospfv3 bfd adjust-cost
ospfv3 bfd adjust-cost命令用来配置OSPFv3根据BFD会话状态调整接口开销值。
undo ospfv3 bfd adjust-cost命令用来恢复缺省情况。
ospfv3 bfd adjust-cost { cost-offset | max } [ instance instance-id ]
undo ospfv3 bfd adjust-cost [ instance instance-id ]
OSPFv3不会根据BFD会话状态调整接口开销值。
cost-offset:指定接口开销调整值的大小,取值范围为1~65534。指定本参数后,当BFD会话Down时,接口的开销值=接口原本的开销值+cost-value。最大不超过接口开销的最大值65535。
max:将接口的开销值调整为最大值65535。
使用BFD检测OSPFv3邻居之间的链路,当BFD检测到故障但故障又很快恢复时,会导致OSPFv3邻居关系震荡,在OSPFv3重新建立邻居的过程中,已从故障恢复正常的链路不可用于OSPFv3报文转发。为了解决上述问题,可以在OSPFv3接口视图下配置本命令。
配置本命令后,在使用BFD检测OSPFv3邻居之间的链路的场景中,邻居关系不再受BFD会话的影响,而是通过改变接口的开销值来响应链路故障及故障恢复,具体机制如下:
·     当OSPFv3接口感知到BFD会话Down时,OSPFv3将该接口的开销值调大。
·     当OSPFv3接口感知到BFD会话Up时,OSPFv3将该接口的开销值恢复为调整前的值。
# 在接口Ten-GigabitEthernet3/1/1下配置OSPFv3根据BFD会话状态调整接口开销值,并设置开销调整值为200。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 bfd enable
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 bfd adjust-cost 100
【【相关命令】
·     display ospfv3 interface
·     ospfv3 bfd enable
1.1.74  ospfv3 bfd adjust-cost suppress-flapping
ospfv3 bfd adjust-cost suppress-flapping命令用来配置BFD会话震荡时抑制OSPFv3根据BFD会话状态调整接口开销值。
undo ospfv3 bfd adjust-cost suppress-flapping命令用来恢复缺省情况。
ospfv3 bfd adjust-cost suppress-flapping { detect-interval detect-interval | resume-interval resume-interval | threshold threshold } *
undo ospfv3 bfd adjust-cost suppress-flapping [ detect-interval | resume-interval | threshold ] *
BFD会话震荡时,不会抑制OSPFv3根据BFD会话状态调整接口开销值。
detect-interval detect-interval:设置检测BFD会话状态变化的时间间隔,取值范围为1~600,单位为秒,缺省值为60。
resume-interval resume-interval:设置延迟恢复接口开销值的时长,取值范围为0~600,单位为秒,缺省值为0。
threshold threshold:设置BFD会话Down次数的阈值,取值范围为1~100,单位为次,缺省值为1。
OSPFv3根据BFD会话状态调整接口开销值的场景中,如果BFD会话频繁震荡,可能会出现如下问题:
·     OSPFv3接口的开销值频繁变化,触发设备不断进行路由计算,导致设备资源被过多占用。
·     当BFD会话由Down变为Up后,OSPFv3立即将接口开销值恢复为该接口的原始开销值,如果链路短时间内再次由可用变为不可用,路由收敛前,通过包含该链路的路径转发的报文会被丢弃。
使用本功能可以解决上述问题。配置本功能后,当BFD会话状态变化时,OSPFv3不会立刻调整接口开销值。具体机制如下:
·     BFD会话由Up变为Down时,触发OSPFv3启动检测BFD会话状态变化定时器,OSPFv3记录BFD会话Down次数为1。在detect-interval时间内,只有BFD会话由Up变为Down的次数累计达到threshold参数的配置值时,OSPFv3才会根据ospfv3 bfd adjust-cost命令设置的值调整接口开销值。否则,OSPFv3不会调整接口开销值。
·     OSPFv3根据ospfv3 bfd adjust-cost命令设置的值调整接口开销值后,当BFD会话由Down变为Up后,启动resume-interval定时器:
¡     如果resume-interval定时器超时前,BFD会话一直处于Up状态,那么resume-interval定时器超时后,OSPFv3将接口开销值恢复为该接口的原始开销值。
¡     如果resume-interval定时器超时前,BFD会话由Up变为Down,则删除resume-interval定时器,OSPFv3不会将接口开销值恢复为该接口的原始开销值。
配置本命令时,需要注意:
·     只有通过ospfv3 bfd adjust-cost命令配置根据BFD会话状态调整接口开销值后,本命令才能生效。
·     可以通过重复执行本命令修改detect-interval、threshold、resume-interval参数的配置值。修改参数的配置值后,detect-interval、resume-interval定时器将重新开始计时,threshold计数器将重新开始计数。
# 配置BFD会话震荡时抑制OSPFv3根据BFD会话状态调整接口Ten-GigabitEthernet3/1/1的开销值,其中检测BFD会话状态变化的时间间隔为60秒、BFD会话Down次数的阈值为10次、延迟恢复接口开销值的时间间隔为10秒。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 bfd adjust-cost suppress-flapping detect-interval 60 threshold 10 resume-interval 10
·     ospfv3 bfd adjust-cost
·     ospfv3 bfd enable
1.1.75  ospfv3 bfd enable
ospfv3 bfd enable命令用来在运行OSPFv3的接口下使能BFD功能。
undo ospfv3 bfd enable命令用来在运行OSPFv3的接口下关闭BFD功能。
ospfv3 bfd enable [ instance instance-id ]
undo ospfv3 bfd enable [ instance instance-id ]
运行OSPFv3的接口的BFD功能处于关闭状态。
BFD(Bidirectional Forwarding Detection,双向转发检测)能够为OSPFv3邻居之间的链路提供快速检测功能。当邻居之间的链路出现故障时,加快OSPFv3协议的收敛速度。
OSPFv3通过BFD控制报文实现BFD功能。
# 使能接口Ten-GigabitEthernet3/1/1的OSPFv3实例1的BFD功能。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 bfd enable instance 1
1.1.76  ospfv3 cost
ospfv3 cost命令用来配置运行不同OSPFv3实例的接口的开销值。
undo ospfv3 cost命令用来取消运行不同OSPFv3实例的接口的开销值的配置。
ospfv3 cost cost-value [ instance instance-id ]
undo ospfv3 cost [ instance instance-id ]
路由器接口按照带宽自动计算运行OSPFv3协议所需的开销;对于VLAN接口,缺省值为1;对于Loopback接口,缺省值为0。
cost-value:接口运行OSPFv3协议的路由开销,Loopback接口的取值范围为0~65535,其他接口的取值范围为1~65535。
# 指定运行OSPFv3实例1的接口Ten-GigabitEthernet3/1/1的开销为33。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 cost 33 instance 1
1.1.77  ospfv3 cost-fallback
ospfv3 cost-fallback命令用来配置在聚合接口的带宽低于阈值时改变接口的链路开销值。
undo ospfv3 cost-fallback命令用来取消聚合接口的带宽低于阈值时改变接口的链路开销值的配置。
ospfv3 cost-fallback cost-value threshold bandwidth-value [ instance instance-id ]
undo ospfv3 cost-fallback [ instance instance-id ]
聚合接口使用原始链路开销值。
三层聚合接口视图
三层聚合子接口视图
cost-value:链路开销值,取值范围为1~65535。建议设置的cost-value大于聚合接口原始链路开销值。
threshold bandwidth-value:设置带宽阈值。bandwidth-value表示带宽阈值,取值范围为1~4294967295,单位为Mbps。
三层聚合组的某个成员端口状态为Down时,剩余带宽可能无法满足用户需求,导致用户业务受损。为了解决上述问题,可以配置本功能,根据三层聚合接口的带宽调整该聚合接口的链路开销值。具体工作机制如下:
·     当三层聚合接口的带宽小于带宽阈值时,设备将该聚合接口的链路开销值设置为cost-value,OSPFv3将选择更优的路径转发流量。
·     当三层聚合接口的带宽大于或等于带宽阈值时,该聚合接口使用原始的链路开销值。
# 在聚合接口Route-Aggregation 1的带宽低于带宽阈值300Mbps时,将Route-Aggregation 1的链路开销值设置为100。
[Sysname] interface Route-Aggregation 1
[Sysname-Route-Aggregation1] ospfv3 cost-fallback 100 threshold 300
【【相关命令】
1.1.78  ospfv3 dr-priority
ospfv3 dr-priority命令用来配置运行不同OSPFv3实例的接口的DR优先级。
undo ospfv3 dr-priority命令用来取消运行不同OSPFv3实例的接口的DR优先级的配置。
ospfv3 dr-priority priority [ instance instance-id ]
undo ospfv3 dr-priority [ instance instance-id ]
接口的DR优先级为1。
priority:接口的DR优先级,取值范围为0~255。
接口的DR优先级决定了该接口在选举DR/BDR时所具有的资格,优先级高的在选举时被首先考虑。
# 设置运行OSPFv3实例1的接口Ten-GigabitEthernet3/1/1在选举DR/BDR时的优先级为8。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 dr-priority 8 instance 1
1.1.79  ospfv3 fast-reroute lfa-backup exclude
ospfv3 fast-reroute lfa-backup exclude命令用来禁止接口参与LFA(Loop Free Alternate)计算。
undo ospfv3 fast-reroute lfa-backup exclude命令用来取消禁止接口参与LFA计算配置的配置。
ospfv3 fast-reroute lfa-backup exclude [ instance instance-id ]
undo ospfv3 fast-reroute lfa-backup exclude [ instance instance-id ]
接口参与LFA计算。
接口缺省参与LFA计算,有资格成为备份接口。配置本功能后,接口不会被选为备份接口。
# 禁止接口Ten-GigabitEthernet3/1/1参与LFA计算。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 fast-reroute lfa-backup exclude
1.1.80  ospfv3 ipsec-profile
ospfv3 ipsec-profile命令用来在OSPFv3接口上应用IPsec安全框架。
undo ospfv3 ipsec-profile命令用来取消OSPFv3接口上应用的IPsec安全框架。
ospfv3 ipsec-profile profile-name [ instance instance-id ]
undo ospfv3 ipsec-profile [ instance instance-id ]
OSPFv3接口没有应用IPsec安全框架。
# 配置OSPFv3接口Ten-GigabitEthernet3/1/1上应用的IPsec安全框架为profile001。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 ipsec-profile profile001
1.1.81  ospfv3 link-delay
ospfv3 link-delay命令用来配置OSPFv3接口的时延参数。
undo ospfv3 link-delay命令用来取消接口时延参数的配置。
ospfv3 link-delay { average average-delay-value | min min-delay-value max max-delay-value | variation variation-value } * [ instance instance-id ]
undo ospfv3 link-delay { average | min | variation } [ instance instance-id ]
未配置OSPFv3接口时延信息。
average average-delay-value:设置接口的平均时延。average-delay-value表示接口的平均时延,取值范围为1~16777215,单位为微秒。平均时延是指本端发往直连OSPFv3邻居的所有IP数据包的平均时延。如果未指定本参数,OSPFv3将使用接口上报的平均时延作为OSPFv3接口的平均时延。
min min-delay-value:设置接口的最小时延,min-delay-value表示接口时延的最小值,取值范围为1~16777215,单位为微秒。接口的最小时延是指本端发往直连OSPFv3邻居的全部IP数据包的最小时延。如果未指定本参数,OSPFv3将使用接口上报的最小时延作为OSPFv3接口的最小时延。
max max-delay-value:设置接口的最大传送时延,max-delay-value表示时延最大值,取值范围为1~16777215,单位为微秒。最大传送时延指的是从本端发往直连OSPFv3邻居的全部IP数据包的最大时延。如果未指定本参数,OSPFv3将使用接口上报的最大时延作为OSPFv3接口的最大时延。
variation variation-value:设置接口的时延容差,variation-value表示时延容差值,取值范围为1~16777215,单位为微秒。时延容差是指平均时延的变化。如果未指定本参数,OSPFv3将使用接口上报的时延容差作为OSPFv3接口的时延容差。
OSPFv3接口时延信息可通过如下两种方式获取:
·     使用本命令静态配置接口时延。
·     使用test-session bind interface命令将TWAMP-light测试与接口绑定,由TWAMP-light将统计后的时延信息发布给绑定接口,绑定接口向OSPFv3上报时延信息。关于TWAMP的详细介绍,请参见“网络管理和监控配置指导”中的“NQA TWAMP-light”。
如果同时通过两种方式获取到了某个时延参数,则以本命令配置的为准。
配置的min-delay必须小于max-delay。
# 配置接口Ten-GigabitEthernet3/1/1的平均时延为100微秒,最小时延为10微秒,最大时延为1000微秒,时延容差为20微秒。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 link-delay average 100 min 10 max 1000 variation 20
·     test-session bind interface(网络管理和监控命令参考/NQA服务器端命令)
1.1.82  ospfv3 link-quality adjust-cost
ospfv3 link-quality adjust-cost命令用来配置OSPFv3根据链路质量等级调整接口开销值。
undo ospfv3 link-quality adjust-cost命令用来恢复缺省情况。
ospfv3 link-quality adjust-cost { max | cost-offset } [ instance instance-id ]
undo ospfv3 link-quality adjust-cost [ instance instance-id ]
OSPFv3不会根据链路质量等级调整接口开销值。
cost-offset:接口开销调整值,取值范围为1~65534。指定本参数后,当链路的质量等级由GOOD变为LOW时,接口的开销值=接口原本的开销值+cost-offset。最大不超过接口开销的最大值65535。
max:指定将接口的开销值调整为最大值65535。
instance instance-id:指定接口所属的实例ID,取值范围为0~255,缺省值为0。
误码是指通信设备接收到的信号与源信号之间存在比特差错。由于不可避免的线路老化、光路抖动等原因,误码是不能从根本上避免的。当误码积累到一定程度可能导致服务等级降低,甚至停止服务。为了尽可能减少误码对OSPFv3网络的影响,可在OSPFv3接口视图下配置本命令。
配置本命令后,OSPFv3将根据链路质量等级来调整接口开销值,具体机制如下:
·     当链路质量检测模块检测到误码率大于或等于高误码率门限时,链路的质量等级由GOOD变为LOW。链路质量检测模块向OSPFv3上报高误码事件,OSPFv3将接口开销值调大。
·     当链路质量检测模块检测到误码率小于低误码率门限时,链路的质量等级由LOW变为GOOD。链路质量检测模块向OSPFv3上报高误码解除事件,OSPFv3将接口开销值恢复为调整前的值。
上述机制可以使OSPFv3选择误码率较小的链路转发流量,从而尽可能减少误码对OSPFv3网络的影响。关于链路质量检测的详细介绍,请参见“可靠性配置指导”中的“误码检测”。
# 在接口Ten-GigabitEthernet3/1/1下配置OSPFv3根据链路质量等级调整接口开销值,并设置开销调整值为200。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 link-quality adjust-cost 200
1.1.83  ospfv3 link-tag
ospfv3 link-tag命令用来配置接口的链路标记。
undo ospfv3 link-tag命令用来恢复缺省情况。
ospfv3 link-tag tag [ instance instance-id ]
undo ospfv3 link-tag [ instance instance-id ]
未配置接口的链路标记。
tag:链路标记值,取值范围为1~4294967295。
instance instance-id:接口所属的实例。instance-id表示实例ID,取值范围为0~255,缺省值为0。
配置本命令后,设备将发布E-Router-LSA(Type-33),该类LSA中会携带链路标记。配置了本命令的设备与配置了link-tag inherit enable命令的设备相互配合,可以实现路由筛选。
在同一个接口上多次执行本命令,最后一次执行的命令生效。
# 配置接口Ten-GigabitEthernet3/1/1的链路标记值为222333。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 link-tag 222333
·     link-tag inherit enable
1.1.84  ospfv3 mib-binding
ospfv3 mib-binding命令用来配置OSPFv3进程绑定MIB。
undo ospfv3 mib-binding命令用来恢复缺省情况。
ospfv3 mib-binding process-id
MIB绑定在进程号最小的OSPFv3进程上。
如果指定的process-id不存在,配置OSPFv3进程绑定命令时将会提示OSPFv3进程不存在,无法完成配置。
如果配置了OSPFv3进程绑定MIB,若删除process-id对应的OSPFv3进程,则同时删除OSPFv3进程绑定MIB配置,MIB绑定到进程号最小的OSPFv3进程上。
# 配置OSPFv3进程100绑定MIB。
[Sysname] ospfv3 mib-binding 100
1.1.85  ospfv3 mtu-ignore
ospfv3 mtu-ignore命令用来配置接口在进行DD报文交换时忽略MTU检查。
undo ospfv3 mtu-ignore命令用来取消接口在进行DD报文交换时忽略MTU检查的配置。
ospfv3 mtu-ignore [ instance instance-id ]
undo ospfv3 mtu-ignore [ instance instance-id ]
接口在进行DD报文交换时执行MTU检查。
双方的接口MTU必须相同才能建立邻居关系。
# 配置运行OSPFv3实例1的接口Ten-GigabitEthernet3/1/1在进行DD报文交换时忽略MTU检查。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 mtu-ignore instance 1
1.1.86  ospfv3 network-type
ospfv3 network-type命令用来配置OSPFv3接口的网络类型。
undo ospfv3 network-type命令用来取消OSPFv3接口的网络类型的配置。
ospfv3 network-type { broadcast | nbma | p2mp [ unicast ] | p2p } [ instance instance-id ]
undo ospfv3 network-type [ instance instance-id ]
当接口封装的链路层协议不同时,OSPFv3接口网络类型的缺省值也不同:
·     当接口封装的链路层协议是Ethernet、FDDI时,OSPFv3接口网络类型的缺省值为广播类型;
·     当接口封装的链路层协议是ATM或X.25时,OSPFv3接口网络类型的缺省值为NBMA;
·     当接口封装的链路层协议是PPP、LAPB、HDLC或POS时,OSPFv3接口网络类型的缺省值为P2P。
broadcast:配置接口的网络类型为广播类型。
nbma:配置接口的网络类型为NBMA类型。
p2mp:配置接口的网络类型为点到多点类型。
unicast:P2MP类型支持单播发送报文,缺省情况下是组播方式发送报文。
p2p:配置接口的网络类型为点到点类型。
如果在广播网络上有不支持组播地址的路由器,可以将接口的网络类型改为NBMA。
在NBMA网络中,如果任意两台路由器之间都有一条虚电路直接可达,或者说,这个网络是全连通的,那么可以把OSPFv3接口的网路类型配置为NBMA;否则,需要把OSPFv3接口的网络类型配置为点到多点,这样,两台不能直接可达的路由器之间可以通过一台与两者都直接可达的路由器来交换路由信息。
接口的网络类型为NBMA或P2MP(unicast)时,必须使用peer命令来配置邻接点。
接口的网络类型为P2MP(unicast)时,OSPFv3协议在该接口上发送的报文均为单播报文。
# 设置运行OSPFv3的接口Ten-GigabitEthernet3/1/1网络类型为NBMA。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 network-type nbma
·     ospfv3 dr-priority
1.1.87  ospfv3 peer
ospfv3 peer命令用来指定邻居接口的链路本地地址,并指定该邻居是否有选举权。
undo ospfv3 peer命令用来取消指定邻居接口的链路本地地址的配置。
ospfv3 peer ipv6-address [ cost cost-value | dr-priority priority ] [ instance instance-id ]
undo ospfv3 peer ipv6-address [ instance instance-id ]
未指定邻居接口的链路本地地址。
ipv6-address:邻居的链路本地地址。
cost cost-value:表示网络邻居的开销,取值范围为1~65535。
dr-priority priority:表示网络邻居的优先级,取值范围为0~255,缺省值为1。
当路由器的接口类型为如下网络类型时,需要为其指定相邻路由器IP地址:
·     NBMA网络
·     P2MP网络(仅当接口选择单播形式发送报文时,需要此配置)
由于无法通过广播Hello报文的形式发现相邻路由器,必须手工指定相邻路由器的本地链路地址。对于NBMA网络,可以指定该相邻路由器是否有选举权等。
# 在运行OSPFv3协议的接口Ten-GigabitEthernet3/1/1上指定邻居的链路本地地址为FE80::1111。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 peer fe80::1111
1.1.88  ospfv3 peer hold-max-cost duration
ospfv3 peer hold-max-cost duration命令用来配置OSPFv3通告给邻居的链路开销值保持最大值的持续时间。
undo ospfv3 peer hold-max-cost duration命令用来恢复缺省情况。
ospfv3 peer hold-max-cost duration timer [ instance instance-id ]
undo ospfv3 peer hold-max-cost duration [ instance instance-id ]
未配置OSPFv3邻居保持最大开销值的时间。
timer:OSPFv3通告给邻居的链路开销值保持最大值的持续时间,取值范围为100~1000000,单位为毫秒。
OSPFv3网络中,链路发生故障并从故障中恢复,或接口状态变化时,OSPFv3会重新建立邻接关系,路由会重新进行收敛。在路由重新收敛的过程中,由于各个节点的路由收敛速度不一致,可能会形成环路,造成流量丢失。为了在路由收敛过程中保持转发路径不变,可以配置本命令使OSPFv3在time时间内向邻居通告最大链路开销,time超时后OSPFv3向邻居通告的链路开销从最大值恢复为原始开销值,OSPFv3重新进行路由优选。
当OSPF邻居状态变为Full时,time开始计时。在此期间,OSPF向邻居通告的链路开销为65535。
# 在接口Ten-GigabitEthernet3/1/1上配置OSPv3F通告给邻居的链路开销值保持最大值的持续时间为1000毫秒。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 peer hold-max-cost duration 1000
·     display ospfv3 interface verbose
1.1.89  ospfv3 prefix-suppression
ospfv3 prefix-suppression命令用来抑制接口进行前缀发布。
undo ospfv3 prefix-suppression命令用来取消抑制接口进行前缀发布的配置。
ospfv3 prefix-suppression [ disable ] [ instance instance-id ]
undo ospfv3 prefix-suppression [ instance instance-id ]
不抑制接口进行前缀发布。
disable:不抑制接口进行前缀发布。
如果OSPFv3进程配置了抑制前缀发布,但某个接口不想进行抑制,此时可以配置本命令并指定disable参数。
# 抑制接口Ten-GigabitEthernet3/1/1进行前缀发布。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 prefix-suppression
·     prefix-suppression
1.1.90  ospfv3 primary-path-detect bfd
ospfv3 primary-path-detect bfd命令用来使能OSPFv3协议中主用链路的BFD检测功能。
undo ospfv3 primary-path-detect bfd命令用来关闭OSPFv3协议中主用链路的BFD检测功能。
ospfv3 primary-path-detect bfd { ctrl | echo } [ instance instance-id ]
undo ospfv3 primary-path-detect bfd [ instance instance-id ]
OSPFv3协议中主用链路的BFD检测功能处于关闭状态。
ctrl:配置通过工作于控制报文方式的BFD会话对主用链路进行检测。
echo:配置通过工作于echo报文方式的BFD会话对主用链路进行检测。
配置本功能后,OSPFv3协议的快速重路由特性中的主用链路将使用BFD进行检测。
接口使用echo报文方式的BFD会话对主用链路进行检测时,需要保证该接口拥有IPv6全球单播地址,否则BFD功能无法正常运行。关于IPv6全球单播地址的详细介绍,请参见“三层技术-IP业务配置指导”中的“IPv6基础”。
# 在接口Ten-GigabitEthernet3/1/1上配置OSPFv3协议快速重路由特性中主用链路使能BFD(Echo方式)检测功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] quit
[Sysname] bfd echo-source-ipv6 1::1
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 primary-path-detect bfd echo
1.1.91  ospfv3 silent
ospfv3 silent命令用来禁止接口收发OSPF报文。
undo ospfv3 silent命令用来恢复缺省情况。
ospfv3 silent [ instance instance-id ]
undo ospfv3 silent [ instance instance-id ]
允许接口收发OSPFv3报文。
如果本地设备不希望通过某个接口接收网络中其他设备发布的路由更新信息,也不希望通过该接口向网络中的其他设备发布路由更新信息,可以使用本命令禁止该接口收发OSPFv3报文。
配置本命令后,相应的OSPFv3接口将执行如下操作:
·     向邻居发送1-way Hello报文。邻居收到1-way Hello报文后,断开与发送该报文的接口的邻居关系。
·     接口不再建立邻居关系。
silent-interface命令和ospfv3 silent命令的作用相同。对于同一个接口,执行其中任意一条命令,或者同时执行这两条命令,均可以禁止接口收发OSPFv3报文。用户可以根据实际使用场景,选择合适的命令禁止接口收发OSPFv3报文。
# 禁止接口Ten-GigabitEthernet3/1/1收发OSPF报文。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 silent
·     silent-interface
1.1.92  ospfv3 timer dead
ospfv3 timer dead命令用来配置OSPFv3的邻居失效时间。
undo ospfv3 timer dead命令用来取消OSPFv3的邻居失效时间的配置。
ospfv3 timer dead seconds [ instance instance-id ]
undo ospfv3 timer dead [ instance instance-id ]
P2P、Broadcast类型接口的OSPFv3邻居失效的时间为40秒;P2MP、NBMA类型接口的OSPFv3邻居失效的时间为120秒。
seconds:OSPFv3邻居失效的时间,取值范围为1~65535,单位为秒。
OSPFv3邻居的失效时间是指:在该时间间隔内,若未收到邻居的Hello报文,就认为该邻居已失效。dead seconds值至少应为hello seconds值的4倍,同一网段上的接口的dead seconds也必须相同。
# 配置接口Ten-GigabitEthernet3/1/1上的邻居失效时间为60秒。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 timer dead 60
·     ospfv3 timer hello
1.1.93  ospfv3 timer hello
ospfv3 timer hello命令用来配置接口发送Hello报文的时间间隔。
undo ospfv3 timer hello命令用来取消接口发送Hello报文的时间间隔的配置。
ospfv3 timer hello seconds [ instance instance-id ]
undo ospfv3 timer hello [ instance instance-id ]
P2P、Broadcast类型接口发送Hello报文的时间间隔为10秒;P2MP、NBMA类型接口发送Hello报文的时间间隔为30秒。
seconds的值越小,发现网络拓扑改变的速度越快,对系统资源的开销也就越大。同一网段上的接口的seconds必须相同。
# 配置接口Ten-GigabitEthernet3/1/1发送Hello报文的时间间隔为20秒。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 timer hello 20
·     ospfv3 timer dead
1.1.94  ospfv3 timer poll
ospfv3 timer poll命令用来配置在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔。
undo ospfv3 timer poll命令用来取消在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔的配置。
ospfv3 timer poll seconds [ instance instance-id ]
undo ospfv3 timer poll [ instance instance-id ]
在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔为120秒。
seconds:向状态为down的邻居路由器发送轮询Hello报文的时间间隔,取值范围为1~65535,单位为秒。
在NBMA的网络上,当邻居失效后,将按轮询时间间隔定期地发送Hello报文。用户可配置轮询时间间隔以指定该接口在与相邻路由器构成邻居关系之前发送Hello报文的时间间隔。
发送轮询Hello报文的时间间隔至少应为发送Hello报文时间间隔的4倍。
# 配置接口Ten-GigabitEthernet3/1/1发送轮询Hello报文的时间间隔为120秒。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 timer poll 120
1.1.95  ospfv3 timer retransmit
ospfv3 timer retransmit命令用来配置接口重传LSA的时间间隔。
undo ospfv3 timer retransmit命令用来取消接口重传LSA的时间间隔的配置。
ospfv3 timer retransmit seconds [ instance instance-id ]
undo ospfv3 timer retransmit [ instance instance-id ]
接口重传LSA的时间间隔为5秒。
seconds:接口重传LSA的时间间隔,取值范围为1~3600,单位为秒。
相邻路由器重传LSA时间间隔的值不要设置得太小,否则将会引起不必要的重传。
# 指定运行OSPFv3实例1的接口Ten-GigabitEthernet3/1/1重传LSA的时间间隔为12秒。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 timer retransmit 12 instance 1
1.1.96  ospfv3 trans-delay
ospfv3 trans-delay命令用来配置接口对LSA的传输延迟时间。
undo ospfv3 trans-delay命令用来取消接口对LSA的传输延迟时间的配置。
ospfv3 trans-delay seconds [ instance instance-id ]
undo ospfv3 trans-delay [ instance instance-id ]
接口对LSA的传输延迟时间为1秒。
LSA在本路由器的LSDB中会随时间老化(LSA的老化时间每秒钟加1),但在网络的传输过程中却不会,所以有必要在发送之前在LSA的老化时间上增加一定的延迟时间。此配置对低速率的网络尤其重要。
# 指定运行OSPFv3实例1的接口Ten-GigabitEthernet3/1/1洪泛LSA的时延值为3秒。
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 trans-delay 3 instance 1
1.1.97  ospfv3 virtual-system
ospfv3 virtual-system命令用来在指定接口上开启OSPFv3共网段功能。
undo ospfv3 virtual-system命令用来在指定接口上取消OSPFv3共网段功能。
ospfv3 virtual-system router-id router-id [ instance instance-id ]
undo ospfv3 virtual-system [ instance instance-id ]
OSPFv3接口上的共网段功能处于关闭状态。
instance instance-id:接口所属的OSPFv3实例。instance-id表示OSPFv3实例ID,取值范围为0~65535。如果未指定本参数,则表示实例0。
执行virtual-system enable命令全局开启OSPFv3进程的共网段功能后,需要通过ospfv3 virtual-system命令打开接口下的OSPFv3共网段功能,才能开启该进程下指定OSPFv3接口的共网段功能。
通过ospfv3 virtual-system命令指定虚拟OSPFv3节点的Router ID时,需要注意:
·     指定的Router ID必须和其他虚拟OSPFv3节点的Router ID不同,否则配置失败。
·     指定的Router ID必须和本虚拟OSPFv3节点所属OSPFv3进程的Router ID不同,否则配置失败。
# 接口下使能OSPFv3共网段功能。
[Sysname] ospfv3
[Sysname-ospfv3-1] virtual-system enable
[Sysname-ospfv3-1] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] ospfv3 virtual-system router-id 1.1.1.1
·     virtual-system enable
1.1.98  pic
pic命令用来使能前缀无关收敛功能。
undo pic命令用来关闭前缀无关收敛功能。
undo pic
前缀无关收敛功能处于关闭状态。
OSPFv3视图
additional-path-always:支持非直连的次优路由作为备份。
PIC(Prefix Independent Convergence,前缀无关收敛),即收敛时间与前缀数量无关,加快收敛速度。传统的路由计算快速收敛都与前缀数量相关,收敛时间与前缀数量成正比。OSPFv3只实现区域间路由以及外部路由的前缀无关收敛。
OSPFv3快速重路由功能和PIC同时配置时,OSPFv3快速重路由功能生效。
# 使能OSPFv3协议的PIC支持非直连次优路由做备份功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] pic additional-path-always
1.1.99  preference
preference命令用来配置OSPFv3协议的路由优先级。
undo preference命令用来取消OSPFv3协议的路由优先级的配置。
undo preference [ ase ]
对于自治系统内部路由,OSPFv3协议的路由优先级为10;对于自治系统外部路由,OSPFv3协议的路由优先级为150。
OSPFv3视图
ase:配置OSPFv3协议对自治系统外部路由的优先级。如果未指定该参数,则配置的是OSPFv3协议对自治系统内部路由的优先级。
preference:OSPFv3路由的优先级,取值范围为1~255。优先级的值越小,其实际的优先程度越高。
route-policy route-policy-name:应用路由策略,对特定的路由设置优先级。route-policy-name是路由策略名称,为1~63个字符的字符串,区分大小写。
由于路由器上可能同时运行多个动态路由协议,就存在各个路由协议之间路由信息共享和选择的问题,所以为每一种路由协议指定了一个缺省的优先级。在不同的路由协议发现去往同一目的地的多条路由时,优先级高的协议发现的路由将被选中以转发IPv6报文。
# 配置OSPFv3协议路由的优先级为150。
[Sysname] ospfv3
[Sysname-ospfv3-1] preference 150
1.1.100  prefix-suppression
prefix-suppression命令用来抑制OSPFv3进程进行前缀发布。
undo prefix-suppression命令用来恢复缺省情况。
prefix-suppression
不抑制OSPFv3进程进行前缀发布。
OSPFv3视图
接口使能OSPFv3后,会将接口下的所有网段路由都通过LSA发布,但有时候网段路由是不希望被发布的。通过前缀抑制配置,可以减少LSA中携带不需要的前缀,即不发布某些网段路由,从而提高网络安全性,加快路由收敛。
全局配置前缀抑制不能抑制LoopBack接口和处于silent-interface状态接口对应的前缀。如果想对Loopback接口或处于silent-interface状态接口进行抑制,可以通过接口下配置前缀抑制(ospfv3 prefix-suppression命令)来实现。
当使能前缀抑制时,具体处理如下:
·     Type-8 LSA中不发布处于抑制的接口前缀信息。
·     对于广播网/NBMA网络,DR在生成Type-9 LSA引用Type-2 LSA时,不发布处于抑制的接口前缀信息。
·     对于P2P/P2MP网络,生成Type-9 LSA引用Type-1 LSA时,不发布处于抑制的接口前缀信息。
# 抑制OSPFv3进程100的前缀发布。
[Sysname-ospfv3-100] prefix-suppression
1.1.101  priority
priority命令用来配置Flex-Algo算法的优先级。
undo priority命令用来恢复缺省情况。
priority priority-value
undo priority
Flex-Algo算法的优先级为128。
Flex-Algo算法视图
priority-id:指定Flex-Algo算法的优先级值,取值范围为0~255,该值越大优先级越高。
每个参与Flex-Algo算法计算的节点都可以定义Flex-Algo算法。为了避免环路,在Flex-Algo算法标识符通告范围(OSPFv3区域)内,使用相同Flex-Algo算法ID的节点必须对Flex-Algo算法的定义达成一致。
为了保证Flex-Algo算法定义的一致性,每个参与特定Flex-Algo算法计算的节点都遵从以下规则选择Flex-Algo算法定义:
(1)     从本区域的Flex-Algo算法定义通告中(包括本地产生和接收到的通告),选择具有最高优先级的Flex-Algo算法定义。如果本地未通告Flex-Algo算法定义,则从接收到的通告中选择具有最高优先级的Flex-Algo算法定义。
(2)     如果存在多个具有相同最高优先级的Flex-Algo算法定义,则选择Router ID最大的设备通告的Flex-Algo算法定义。
# 配置Flex-Algo算法128的优先级为200。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-flex-algo-128] priority 200
·     advertise-definition
1.1.102  reset ospfv3 event-log
reset ospfv3 event-log命令用于清除OSPFv3的日志信息。
reset ospfv3 [ process-id ] event-log [ lsa-flush | peer | spf ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,则清除所有OSPFv3进程的日志信息。
lsa-flush:清除LSA老化日志信息。
peer:清除邻居的日志信息。
spf:清除路由计算的日志信息。
如果未指定日志类型,则所有日志信息都被清除。
# 清除所有OSPFv3进程路由计算的日志信息。
<Sysname> reset ospfv3 event-log spf
·     display ospfv3 event-log
1.1.103  reset ospfv3 process
reset ospfv3 process命令用来重启OSPFv3进程。
reset ospfv3 [ process-id ] process [ graceful-restart ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,则重启所有OSPFv3进程。
graceful-restart:以GR方式重启OSPFv3进程。
使用reset ospfv3 process命令重启OSPFv3,可以获得如下结果:
·     可以立即清除无效的LSA,而不必等到LSA超时。
·     方便重新选举DR、BDR。
·     重启前的OSPFv3配置不会丢失。
执行该命令后,系统提示用户确认是否重启OSPFv3协议。
# 重启所有OSPFv3进程。
<Sysname> reset ospfv3 process
Reset OSPFv3 process? [Y/N]:y
1.1.104  reset ospfv3 redistribution
reset ospfv3 redistribution命令用来重新向OSPFv3引入外部路由。
reset ospfv3 [ process-id ] redistribution
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,所有OSPFv3进程都将重新引入外部路由。
# 重新向OSPFv3引入外部路由。
<Sysname> reset ospfv3 redistribution
1.1.105  reset ospfv3 statistics
reset ospfv3 statistics命令用来清除OSPFv3的统计信息。
reset ospfv3 [ process-id ] statistics
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,则清除所有OSPFv3进程的统计信息。
# 清除所有OSPFv3进程的统计信息。
<Sysname> reset ospfv3 statistics
1.1.106  router-id
router-id命令用来配置运行OSPFv3协议的路由器的Router ID。
undo router-id命令用来恢复缺省情况。
router-id router-id
undo router-id
运行OSPFv3协议的路由器没有Router ID。
OSPFv3视图
router-id:路由器标识符,IPv4地址格式。
Router ID是一台运行OSPFv3协议的路由器在自治系统中的唯一标识。如果用户没有指定路由器的Router ID,则OSPFv3进程无法运行。
同一台设备上以及同一自治系统中不同的OSPFv3进程,必须为其指定不同的Router ID。
# 设置OSPFv3进程1的Router ID为10.1.1.3。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] router-id 10.1.1.3
·     ospfv3
1.1.107  shutdown process
shutdown process命令用来关闭OSPFv3进程。
undo shutdown process命令用来开启OSPFv3进程。
shutdown process
OSPFv3进程处于开启状态。
OSPFv3视图
使用本功能或Isolate功能均可以对OSPFv3进程进行维护。
配置shutdown process命令后,相应的OSPFv3进程将执行如下操作:
·     通知邻居与自己断开邻居关系。
邻居收到1-way Hello报文后,断开与发送该报文的设备的邻居关系。
·     停止收发OSPFv3协议报文,清除邻居信息、LSDB(包括自己产生的LSP和接收到的LSP)以及OSPFv3路由等信息。
当完成对网络设备的维护后,执行undo shutdown process命令,重新开启OSPFv3进程,以便OSPFv3重新建立邻居关系。
# 关闭进程号为100的OSPFv3进程。
[Sysname-ospfv3-100] shutdown process
·     isolate enable
1.1.108  silent-interface
silent-interface命令用来禁止接口收发OSPFv3报文。
undo silent-interface命令用来取消禁止接口收发OSPFv3报文的配置。
允许接口收发OSPFv3报文。
OSPFv3视图
interface-type interface-number:接口类型和接口号,禁止指定OSPFv3接口收发OSPFv3报文。
all:禁止所有OSPFv3接口收发OSPFv3报文。
·     接口不再建立邻居关系。
不同的进程可以对同一接口禁止收发OSPFv3报文,但silent-interface命令只对本进程已经使能的OSPFv3接口起作用,对其它进程的接口不起作用。
# 禁止接口Ten-GigabitEthernet3/1/1在OSPFv3进程100和200中收发OSPFv3报文。
[Sysname-ospfv3-100] router-id 10.100.1.9
[Sysname-ospfv3-100] silent-interface ten-gigabitethernet 3/1/1
[Sysname-ospfv3-100] quit
[Sysname] ospfv3 200
[Sysname-ospfv3-200] router-id 20.100.1.9
[Sysname-ospfv3-200] silent-interface ten-gigabitethernet 3/1/1
·     ospfv3 silent
1.1.109  snmp context-name
snmp context-name命令用来创建一个管理OSPFv3的SNMP实体所使用的上下文名称。
不存在管理OSPFv3的SNMP实体所使用的上下文名称。
OSPFv3视图
context-name:管理OSPFv3的SNMP实体所使用的上下文名称,为1~32个字符的字符串,区分大小写。
OSPFv3使用MIB(Management Information Base,管理信息库)为NMS(Network Management System,网络管理系统)提供对OSPFv3实例的管理,但标准OSPFv3 MIB中定义的MIB为单实例管理对象,无法对多个OSPFv3实例进行管理。因此,参考RFC 4750中对OSPF多实例的管理方法,为管理OSPFv3的SNMP实体定义一个上下文名称,以此来区分不同的OSPFv3实例,实现对多个OSPFv3实例进行管理。由于上下文名称只是SNMPv3独有的概念,对于SNMPv1/v2c,会将团体名映射为上下文名称以对不同协议进行区分。
# 配置管理OSPFv3进程1的SNMP实体所使用的上下文名称为mib。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] snmp context-name mib
1.1.110  snmp trap rate-limit
snmp trap rate-limit命令用来配置OSPFv3在指定时间间隔内允许输出的告警信息条数。
undo snmp trap rate-limit命令用来恢复缺省情况。
OSPFv3在10秒内允许输出7条告警信息。
OSPFv3视图
interval trap-interval:指定时间间隔,取值范围为2~60,单位为秒。
count trap-number:在指定时间间隔内允许输出的告警信息条数,取值范围为0~300,为0时表示不输出告警信息。
# 配置OSPFv3在5秒内允许输出10条告警信息。
[Sysname-ospfv3-100] snmp trap rate-limit interval 5 count 10
1.1.111  snmp-agent trap enable ospfv3
snmp-agent trap enable ospfv3命令用来开启OSPFv3的告警功能。
undo snmp-agent trap enable ospfv3命令用来关闭OSPFv3的告警功能。
snmp-agent trap enable ospfv3 [ grhelper-status-change | grrestarter-status-change | if-bad-pkt | if-cfg-error | if-state-change | last-auth-key-expiry | neighbor-state-change | nssatranslator-status-change | virtgrhelper-status-change | virtif-bad-pkt | virtif-cfg-error | virtif-state-change | virtneighbor-state-change ] *
undo snmp-agent trap enable ospfv3 [ grhelper-status-change | grrestarter-status-change | if-bad-pkt | if-cfg-error | if-state-change | last-auth-key-expiry | neighbor-state-change | nssatranslator-status-change | virtgrhelper-status-change | virtif-bad-pkt | virtif-cfg-error | virtif-state-change | virtneighbor-state-change ] *
OSPFv3的告警功能处于开启状态。
grhelper-status-change:邻居GR Helper状态变化。
grrestarter-status-change:GR Restarter状态变化。
if-bad-pkt:接口接收了错误报文。
if-cfg-error:接口配置错误。
if-state-change:接口状态变化。
last-auth-key-expiry:OSPFv3所用的keychain中最后一个有效发送key的生命周期结束。
neighbor-state-change:邻居状态变化。
nssatranslator-status-change:NSSA转换路由器状态变化。
virtgrhelper-status-change:虚接口邻居GR Helper状态变化。
virtif-bad-pkt:虚接口接收错误报文。
virt-cfg-error:虚接口配置错误。
virtif-state-change:虚接口状态变化。
virtneighbor-state-change:虚接口邻居状态变化。
# 关闭OSPFv3的告警功能。
[Sysname] undo snmp-agent trap enable ospfv3
1.1.112  spf-schedule-interval
spf-schedule-interval命令用来配置OSPFv3路由计算的时间间隔。
undo spf-schedule-interval命令用来恢复缺省情况。
spf-schedule-interval { maximum-interval [ minimum-interval [ incremental-interval [ conservative ] ] ] | millisecond interval }
OSPFv3路由计算的最大时间间隔为5秒,最小时间间隔为50毫秒,时间间隔惩罚增量为200毫秒。
OSPFv3视图
maximum-interval:OSPFv3路由计算的最大时间间隔,取值范围为1~60,单位为秒。
minimum-interval:OSPFv3路由计算的最小时间间隔,取值范围为10~60000,单位为毫秒。
incremental-interval:OSPFv3路由计算的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
conservative:OSPFv3路由震荡时,持续按照最大时间间隔进行路由计算。如果未指定本参数,连续三次按最大时间间隔进行路由计算后,将按照最小时间间隔进行路由计算。
millisecond interval:OSPFv3路由计算采用固定的时间间隔,取值范围为0~10000,单位为毫秒。
根据本地维护的LSDB,运行OSPFv3协议的路由器通过SPF算法计算出以自己为根的最短路径树,并根据这一最短路径树决定到目的网络的下一跳。通过调节SPF的计算间隔,可以抑制网络频繁变化可能导致的带宽资源和路由器资源被过多占用的问题。
maximum-interval、minimum-interval和incremental-interval的工作机制如下:
(1)     初次进行路由计算的时间间隔为minimum-interval。
(2)     如果在incremental-interval时间内收到了触发路由计算的事件,那么需要等待incremental-interval×2n-2(n为连续触发路由计算的次数,n大于或等于2)后才能进行路由计算。
(3)     当incremental-interval×2n-2达到maximum-interval时,OSPFv3连续三次按照maximum-interval进行路由计算。之后,再次返回步骤(1)。
如果指定了conservative参数,OSPFv3初次路由计算以及后续路由计算的时间间隔均为最大时间间隔。
在某些特定的组网环境下(例如对路由收敛速度要求较高的环境),可以使用spf-schedule-interval millisecond interval命令指定以毫秒为单位的时间间隔,用来加快路由计算的频率,从而加速路由收敛。
# 设置OSPFv3路由计算最大时间间隔为10秒,最小时间间隔为500毫秒,惩罚增量为300毫秒。
[Sysname-ospfv3-100] spf-schedule-interval 10 500 300
1.1.113  stub
stub命令用来配置一个区域为Stub区域。
undo stub命令用来恢复缺省情况。
undo stub
没有区域被设置为Stub区域。
OSPFv3区域视图
default-route-advertise-always:该参数用于设置总是通告默认路由。
no-summary:该参数只用于Stub区域的ABR,配置后ABR只向区域内发布一条缺省路由的Inter-Area-Prefix-LSA。这种既没有AS-external-LSA,也没有其它Inter-Area-Prefix-LSA、Inter-Area-Router-LSA的Stub区域,又称为Totally Stub区域。
如果需要在ABR上取消配置no-summary参数,可以通过重新执行stub命令覆盖之前配置即可。
# 将OSPFv3区域1设置为Stub区域。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] stub
·     default-cost
1.1.114  stub-router
stub-router命令用来配置当前路由器为Stub路由器。
undo stub-router命令用来恢复缺省情况。
stub-router r-bit [ include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } ] *
stub-router max-metric [ external-lsa [ max-metric-value ] | summary-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } ] *
undo stub-router
当前路由器没有被配置为Stub路由器。
OSPFv3视图
r-bit:路由器发布的Type-1 LSA中,options域的R-bit将清除。
max-metric:路由器发布的Type-1 LSA的链路度量值将设置为最大值65535。
external-lsa max-metric-value:路由器发布的外部LSA链路度量值。max-metric-value表示链路度量值,取值范围为1~16777215,缺省值为16711680。
summary-lsa max-metric-value:路由器发布的Type-3 LSA和Type-4 LSA链路度量值。max-metric-value表示链路度量值,取值范围为1~16777215,缺省值为16711680。
include-stub:路由器发布的引用Type-1 LSA的Type-9 LSA中,链路度量值将设置为最大值65535。
on-startup seconds:在路由器重启期间,路由器作为Stub路由器。seconds表示超时时间,取值范围为5~86400,单位为秒。
wait-for-bgp seconds:在路由器重启后,等待BGP路由收敛期间,路由器作为Stub路由器。seconds表示超时时间,取值范围为5~86400,单位为秒,缺省值为600秒。
将当前路由器配置为Stub路由器的功能,可通过R-bit和max-metric两种模式来实现:
·     R-bit模式:通过清除该路由器发布Type-1 LSA中options域的R-bit,使其他路由器不通过该路由器来转发数据。
·     max-metric模式:该路由器发布的Type-1 LSA的链路度量值将设为最大值65535,这样其邻居计算出这条路由的开销就会很大,如果邻居上有到这个目的地址开销更小的路由,则数据不会通过这个Stub路由器转发。
# 配置当前路由器为Stub路由器。
[Sysname] ospfv3 100
[Sysname-ospfv3-100] stub-router r-bit
1.1.115  suppress intra-te link-attributes
suppress intra-te link-attributes命令用来抑制Intra-Area-TE LSA通告链路属性信息。
undo suppress intra-telink-attributes命令用来取消对Intra-Area-TE LSA通告链路属性信息的抑制。
undo suppress intra-te link-attributes
不会抑制Intra-Area-TE LSA通告链路属性信息。
OSPFv3视图
OSPFv3 SRv6应用Flex-Algo算法进行路径计算的场景中,使用MPLS TE度量值或链路时延作为度量类型时,OSPFv3将生成E-Router LSA和Intra-Area-TE LSA。E-Router LSA和Intra-Area-TE LSA分别通过ASLA sub-TLV、Link-TLV携带链路属性信息。E-Router LSA中的链路属性信息仅用于Flex-Algo进行路径计算;Intra-Area-TE LSA中的链路属性信息仅用于MPLS TE进行路径计算。如果上述场景中仅使用Flex-Algo进行路径计算,为了减小LSDB规模,请配置suppress intra-te link-attributes命令,抑制Intra-Area-TE LSA通告链路TE属性信息和链路时延信息。
# 抑制OSPFv3进程1通过Intra-Area-TE LSA通告链路TE属性信息。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] suppress intra-te link-attributes
1.1.116  te-router-id
te-router-id命令用来配置OSPFv3设备的IPv6 Router ID。
undo te-router-id命令用来恢复缺省情况。
te-router-id ipv6-address
undo te-router-id
未配置OSPFv3设备的IPv6 Router ID。
OSPFv3视图
ipv6-address:指定IPv6地址,只能为IPv6单播地址。
配置本命令后,OPSFv3设备将生成Intra-Area-TE LSA,Intra-Area-TE LSA中的IPv6 Router ID和邻居ID、本地接口IPv6地址、邻居接口IPv6地址等信息用于BGP生成BGP LS。
# 配置OSPFv3设备的IPv6 Router ID为2001::1。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] te-router-id 2001::1
1.1.117  transmit-pacing
transmit-pacing用来配置接口发送LSU报文的时间间隔和一次发送LSU报文的最大个数。
undo transmit-pacing命令用来恢复缺省情况。
接口发送LSU报文的时间间隔为20毫秒,一次最多发送3个LSU报文。
OSPFv3视图
interval interval:接口发送LSU报文的时间间隔,interval的取值范围为10~1000,单位为毫秒。当路由器上使能OSPFv3功能的接口数比较多时,建议增大该值,以控制路由器每秒钟发送LSU报文的总数。
count count:接口一次发送LSU报文的最大个数,count的取值范围为1~200。当路由器上使能OSPFv3功能的接口数比较多时,建议减小该值,以控制路由器每秒钟发送LSU报文的总数。
# 配置OSPFv3进程1的所有接口发送LSU报文的时间间隔为30毫秒,一次最多发送10个LSU报文。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] transmit-pacing interval 30 count 10
1.1.118  virtual-system enable
virtual-system enable命令用来全局开启OSPFv3共网段功能。
undo virtual-system enable命令用来全局关闭OSPFv3共网段功能。
OSPFv3共网段功能处于关闭状态。
OSPFv3视图
Router ID用来在一个自治系统中唯一地标识一个OSPFv3节点。每个OSPFv3节点可以管理多个OSPFv3接口。对于同一个OSPFv3节点的不同OSPFv3接口,这些OSPFv3接口的IPv6地址不能属于同一网段。
# 全局开启OSPFv3共网段功能。
[Sysname] ospfv3
[Sysname-opsfv3-1] virtual-system enable
·     ospfv3 virtual-system
1.1.119  vlink-peer
vlink-peer命令用来创建并配置一条虚连接。
undo vlink-peer命令用来删除一条已有的虚连接。
vlink-peer router-id [ dead seconds | hello seconds | instance instance-id | ipsec-profile profile-name | [ { hmac-sha-256 | hmac-sm3 } key-id { cipher | plain } string | keychain keychain-name ] | retransmit seconds | trans-delay seconds ] *
undo vlink-peer router-id [ dead | hello | ipsec-profile | { hmac-sha-256 | hmac-sm3 | keychain } | retransmit | trans-delay ] *
不存在虚连接。
OSPFv3区域视图
router-id:虚连接邻居的路由器ID。
dead seconds:失效时间间隔,取值范围为1~32768,单位为秒,缺省值为40秒。该值必须和与其建立虚连接路由器的dead seconds值相等,并至少为hello seconds值的4倍。
hello seconds:接口发送Hello报文的时间间隔,取值范围为1~8192,单位为秒,缺省值为10秒。该值必须和与其建立虚连接路由器上的hello seconds值相等。
instance instance-id:设置虚连接的实例ID,取值范围为0~255,缺省值为0。
ipsec-profile profile-name:应用IPsec安全框架。profile-name为IPsec安全框架名称,为1~63个字符的字符串,不区分大小写。IPsec安全框架的具体情况请参见“安全配置指导”中的“IPsec”。
cipher:以密文方式设置密钥。
retransmit seconds:接口重传LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为5。
trans-delay seconds:接口延迟发送LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为1。
对于没有和骨干区域直接相连的非骨干区域,或者不连续的骨干区域来说,可以使用vlink-peer命令建立逻辑上的连通性。在某种程度上,可以将虚连接看作一个普通的使能了OSPFv3的接口,因为在其上配置的hello、dead、retransmit和trans-delay等参数的原理是类似的。
虚连接的两端必须是ABR,vlink-peer命令必须在两端同时配置才可生效。
各参数取值规则如下:
·     hello值越小,发现网络变化的速度越快,消耗的网络资源也就越多。
·     不能将retransmit值设置的太小,否则将会引起不必要的重传。网络速度相对较慢的时候应把该值设的更大一些。
·     设置trans-delay值时必须考虑接口的发送延迟。
在OSPFv3虚连接下配置的验证模式,其优先级高于在骨干区域下配置的验证模式。只有在OSPFv3虚连接下未配置验证模式时,骨干区域下配置的验证模式才会对该虚连接生效。对于同一条虚连接,同一时间只能使用一种验证模式,无法同时使用HMAC-SHA-256验证模式、HMAC-SM3验证模式和keychain验证模式中的两种或三种。
在OSPFv3虚连接使用keychain验证模式时,报文的收、发过程如下:
·     OSPFv3仅支持HMAC-SHA-256认证算法。
# 创建一条到10.10.0.3的虚连接。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] vlink-peer 10.10.0.3
·     display ospfv3 vlink
