- 12-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-SAVI-MIB
- 15-HH3C-DOT11-WM2U-MIB
- 16-HH3C-DOT11-PROBE-MIB
- 17-HH3C-DOT11S-MESH-MIB
17-HH3C-DOT11S-MESH-MIB | 154.92 KB |
hh3cDot11sMeshMkdID (1.3.6.1.4.1.25506.2.75.11.1.1.1)
hh3cDot11sMeshLinkBSSIDMAC (1.3.6.1.4.1.25506.2.75.11.4.1.1)
hh3cDot11sMeshLinkPeerMAC (1.3.6.1.4.1.25506.2.75.11.4.1.2)
About this MIB
This MIB provides WLAN mesh configuration information.
MIB file name
hh3c-dot11s-mesh.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cSystem(6)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sMeshMkdID (1.3.6.1.4.1.25506.2.75.11.1.1.1) |
read-write |
MacAddress |
Standard MIB values. |
Mesh key distributor identifier (MKD-ID) |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sMeshLinkBSSIDMAC (1.3.6.1.4.1.25506.2.75.11.4.1.1) |
accessible-for-notify |
MacAddress |
BSSID of the MP. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sMeshLinkPeerMAC (1.3.6.1.4.1.25506.2.75.11.4.1.2) |
MacAddress |
MAC address of the peer MP after mesh link switchover. |
As per the MIB. |
Tabular objects
hh3cDot11sMeshPflTable
About this table
Use this table to create a mesh profile and map the mesh profile to an MP to provide services for other MPs with the same mesh ID. After you enable the mesh profile, you cannot edit any objects in this table (except hh3cDot11sMeshPflEnable). The mesh profile cannot be deleted after it is bound to a radio.
Support for operations
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cDot11sMeshPflIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sMeshPflIndex (1.3.6.1.4.1.25506.2.75.11.1.2.1.1) |
not-accessible |
Integer32 |
Integer32 (1..32) |
Index of the mesh profile. |
As per the MIB. |
hh3cDot11sMeshPflMeshID (1.3.6.1.4.1.25506.2.75.11.1.2.1.2) |
read-create |
OCTET STRING |
OCTET STRING (0..32) |
Mesh ID of the mesh profile. |
As per the MIB. |
hh3cDot11sMeshPflBindIntNum (1.3.6.1.4.1.25506.2.75.11.1.2.1.3) |
read-create |
Integer32 |
Mesh number bound to the mesh profile. |
As per the MIB. |
hh3cDot11sMeshPflKeepAlive (1.3.6.1.4.1.25506.2.75.11.1.2.1.4) |
read-create |
Integer32 |
Integer32 (1..1800) |
Mesh link keepalive interval. |
As per the MIB. |
hh3cDot11sMeshPflBackhaulRate (1.3.6.1.4.1.25506.2.75.11.1.2.1.5) |
read-create |
Integer32 |
Mesh link backhaul rate. |
As per the MIB. |
hh3cDot11sMeshMkdServEnable (1.3.6.1.4.1.25506.2.75.11.1.2.1.6) |
read-create |
TruthValue |
true(1) false(2) |
Whether to enable the mesh key distributor (MKD) service of the mesh profile. |
As per the MIB. |
hh3cDot11sMeshPflEnable (1.3.6.1.4.1.25506.2.75.11.1.2.1.7) |
read-create |
TruthValue |
true(1) false(2) |
Whether to enable the mesh profile. |
As per the MIB. |
hh3cDot11sMeshPflRowStatus (1.3.6.1.4.1.25506.2.75.11.1.2.1.8) |
read-create |
RowStatus |
Active (1) notInService (2) notReady (3) createAndGo (4) createAndWait (5) Destroy (6) |
Table entry status. |
As per the MIB. |
hh3cDot11sMeshAKMMode (1.3.6.1.4.1.25506.2.75.11.1.2.1.9) |
read-create |
Hh3cDot11AKMType |
none(1), psk(2), dot1x(3), ext(4) |
Identity authentication and key management mode defined by 802.11. |
As per the MIB. |
hh3cDot11sMeshSimpleKey (1.3.6.1.4.1.25506.2.75.11.1.2.1.10) |
read-create |
OCTET STRING |
OCTET STRING (8..63) |
Simple key that is applicable to SAE. |
As per the MIB. |
hh3cDot11sMpPlcyTable
About this table
Use this table to configure mesh settings for the specified radio.
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cDot11sCfgRadioIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sCfgRadioIndex (1.3.6.1.4.1.25506.2.75.11.1.5.1.1) |
not-accessible |
Hh3cDot11RadioElementIndex |
AP ID and radio ID. |
As per the MIB. |
hh3cDot11sMeshPflMap (1.3.6.1.4.1.25506.2.75.11.1.5.1.2) |
read-write |
Integer32 |
Integer32 (0..32) |
Index of the mesh profile bound to a radio. |
As per the MIB. |
hh3cDot11sMpPlcyMap (1.3.6.1.4.1.25506.2.75.11.1.5.1.3) |
read-write |
Integer32 |
Integer32 (1.. 2147483647) |
Index of the MP policy bound to a radio. |
As per the MIB. |
hh3cDot11sBindInterface (1.3.6.1.4.1.25506.2.75.11.1.5.1.4) |
read-write |
Integer32 |
Integer32 (0..1023) |
Mesh interface bound to the specified radio. |
As per the MIB. |
hh3cDot11sAPCfgTable
About this table
Use this table to configure mesh settings for the specified AP.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cDot11APElementIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sPortalEnable (1.3.6.1.4.1.25506.2.75.11.1.6.1.1) |
read-write |
TruthValue |
true(1) false(2) |
Portal service status. |
As per the MIB. |
hh3cDot11sMlspExtCfgTable
About this table
Use this table to configure the MAC address for an MLSP proxy.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cDot11sMlspExtPolicyName, hh3cDot11sMlspExtProxyMac, and hh3cDot11sMlspExtProxyVlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sMlspExtPolicyName (1.3.6.1.4.1.25506.2.75.11.1.7.1.1) |
read-only |
OCTET STRING |
OCTET STRING (1..31) |
MP policy name. |
As per the MIB. |
hh3cDot11sMlspExtProxyMac (1.3.6.1.4.1.25506.2.75.11.1.7.1.2) |
read-only |
MacAddress |
MAC address of the MLSP proxy. |
As per the MIB. |
hh3cDot11sMlspExtProxyVlanID (1.3.6.1.4.1.25506.2.75.11.1.7.1.3) |
read-only |
Integer32 |
Integer32 (0..4096) |
VLAN ID of the MLSP proxy. |
As per the MIB. |
hh3cDot11sMlspExtProxyIP (1.3.6.1.4.1.25506.2.75.11.1.7.1.4) |
read-create |
IpAddress |
IP address of the MLSP proxy. |
As per the MIB. |
hh3cDot11sMlspExtRowStatus (1.3.6.1.4.1.25506.2.75.11.1.7.1.5) |
read-create |
RowStatus |
active (1) notInService (2) notReady (3) createAndGo (4) createAndWait (5) destroy (6) |
As per the MIB. |
hh3cDot11sWDSPeerMacTable
About this table
Use this table to configure the wireless distribution system (WDS). You cannot edit columns in this table.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cDot11sCfgRadioIndex and hh3cDot11sWDSPeerMacIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sWDSPeerMacIndex (1.3.6.1.4.1.25506.2.75.11.2.1.1.1) |
not-accessible |
Integer32 |
Index of the peer MAC address. |
As per the MIB. |
hh3cDot11sWDSPeerMacAddrss (1.3.6.1.4.1.25506.2.75.11.2.1.1.2) |
read-create |
MacAddress |
Peer MAC address. |
As per the MIB. |
hh3cDot11sWDSPeerMacRowStatus (1.3.6.1.4.1.25506.2.75.11.2.1.1.3) |
read-create |
RowStatus |
As per the MIB. |
hh3cDot11sMeshLinkStatusTable
About this table
Use this table to display the mesh link status.
Read:Supported
Columns
The table index is hh3cDot11sMeshLinkIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sMeshLinkIfIndex (1.3.6.1.4.1.25506.2.75.11.3.1.1.1) |
not-accessible |
Unsigned32 |
Mesh link index. |
As per the MIB. |
hh3cDot11sMeshLinkName (1.3.6.1.4.1.25506.2.75.11.3.1.1.2) |
read-only |
OCTET STRING |
Mesh link name. |
As per the MIB. |
hh3cDot11sMeshLinkBSSID (1.3.6.1.4.1.25506.2.75.11.3.1.1.3) |
read-only |
MacAddress |
Mesh link BSSID. |
As per the MIB. |
hh3cDot11sMeshLinkPeerMac (1.3.6.1.4.1.25506.2.75.11.3.1.1.4) |
read-only |
MacAddress |
Peer MAC address of the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkExistDuration (1.3.6.1.4.1.25506.2.75.11.3.1.1.5) |
read-only |
Integer32 |
Duration that that mesh link has been established. |
As per the MIB. |
hh3cDot11sMeshLinkType (1.3.6.1.4.1.25506.2.75.11.3.1.1.6) |
read-only |
INTEGER |
active(1) dormant(2) |
Link type. |
As per the MIB. |
hh3cDot11sMeshLinkSNR (1.3.6.1.4.1.25506.2.75.11.3.1.1.7) |
read-only |
Integer32 |
Signal to noise ratio (SNR) of the link. |
As per the MIB. |
hh3cDot11sMeshLinkNoise (1.3.6.1.4.1.25506.2.75.11.3.1.1.8) |
read-only |
Integer32 |
Noise of the link. |
As per the MIB. |
hh3cDot11sMeshLinkPeerSNR (1.3.6.1.4.1.25506.2.75.11.3.1.1.9) |
read-only |
Integer32 |
Mesh link peer SNR. |
As per the MIB. |
hh3cDot11sMeshLinkPeerNoise (1.3.6.1.4.1.25506.2.75.11.3.1.1.10) |
read-only |
Integer32 |
Mesh link peer noise. |
As per the MIB. |
hh3cDot11sMeshLinkPeerIPAddress (1.3.6.1.4.1.25506.2.75.11.3.1.1.11) |
read-only |
IpAddress |
Peer IP address of the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkPeerSystemName (1.3.6.1.4.1.25506.2.75.11.3.1.1.12) |
read-only |
OCTET STRING |
Peer system name of the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkStatisTable
About this table
Use this table to display mesh link statistics information.
Read:Supported
Columns
The table indexes are hh3cDot11APElementIndex and hh3cDot11sMeshLinkStat.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sMeshLinkStatIfIndex (1.3.6.1.4.1.25506.2.75.11.3.2.1.1) |
not-accessible |
Unsigned32 |
Mesh link interface index. |
As per the MIB. |
hh3cDot11sMeshLinkNbrIndex (1.3.6.1.4.1.25506.2.75.11.3.2.1.2) |
read-only |
Unsigned32 |
Peer interface index of the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkRxTotByte (1.3.6.1.4.1.25506.2.75.11.3.2.1.3) |
read-only |
Counter32 |
Number of received bytes on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkRxTotPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.4) |
read-only |
Counter32 |
Number of received packets on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkRxUniPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.5) |
read-only |
Counter32 |
Number of received unicast packets on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkRxBrocPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.6) |
read-only |
Counter32 |
Number of received broadcast packets on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkRxMuticPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.7) |
read-only |
Counter32 |
Number of received multicast packets on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkRxDiscPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.8) |
read-only |
Counter32 |
Number of discarded packets on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkTxTotByte (1.3.6.1.4.1.25506.2.75.11.3.2.1.9) |
read-only |
Counter32 |
Total number of bytes transmitted on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkTxTotPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.10) |
read-only |
Counter32 |
Total number of packets transmitted on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkTxUniPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.11) |
read-only |
Counter32 |
Number of unicast packets transmitted on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkTxBrocPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.12) |
read-only |
Counter32 |
Number of broadcast packets transmitted on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkTxMuticPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.13) |
read-only |
Counter32 |
Number of multicast packets transmitted on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkTxDiscPkt (1.3.6.1.4.1.25506.2.75.11.3.2.1.14) |
read-only |
Counter32 |
Number of discarded packets during transmission on the mesh link. |
As per the MIB. |
hh3cDot11sMeshLinkIFName (1.3.6.1.4.1.25506.2.75.11.3.2.1.15) |
read-only |
OCTET STRING |
Mesh link interface name. |
As per the MIB. |
hh3cDot11sMeshNbrStatusTable
About this table
Use this table to display MP peer state information.
Read:Supported
Columns
The table indexes are hh3cDot11APElementIndex and hh3cDot11sMeshNbrIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11sMeshNbrIndex (1.3.6.1.4.1.25506.2.75.11.3.3.1.1) |
not-accessible |
Unsigned32 |
Peer index. |
As per the MIB. |
hh3cDot11sMeshNbrRadioID (1.3.6.1.4.1.25506.2.75.11.3.3.1.2) |
read-only |
Unsigned32 |
Radio ID of the peer. |
As per the MIB. |
hh3cDot11sMeshLocalMeshID (1.3.6.1.4.1.25506.2.75.11.3.3.1.3) |
read-only |
OCTET STRING |
Local mesh ID. |
As per the MIB. |
hh3cDot11sMeshNbrMeshID (1.3.6.1.4.1.25506.2.75.11.3.3.1.4) |
read-only |
OCTET STRING |
Peer mesh ID. |
As per the MIB. |
hh3cDot11sMeshNbrBSSID (1.3.6.1.4.1.25506.2.75.11.3.3.1.5) |
read-only |
MacAddress |
Peer BSSID. |
As per the MIB. |
hh3cDot11sMeshNbrPeerMac (1.3.6.1.4.1.25506.2.75.11.3.3.1.6) |
read-only |
MacAddress |
Peer MAC address. |
As per the MIB. |
hh3cDot11sMeshLinkInMp (1.3.6.1.4.1.25506.2.75.11.3.3.1.7) |
read-only |
Unsigned32 |
Interface index of mesh link connected to the peer. |
As per the MIB. |
hh3cDot11sMeshMPLinkStatus (1.3.6.1.4.1.25506.2.75.11.3.3.1.8) |
read-only |
INTEGER |
processing(1) up(2) down(3) |
State of mesh link connected to the peer. |
As per the MIB. |
hh3cDot11sMeshNbrChannel (1.3.6.1.4.1.25506.2.75.11.3.3.1.9) |
read-only |
Unsigned32 |
Channel number used by the peer. |
As per the MIB. |
hh3cDot11sMeshNbrLinkDuration (1.3.6.1.4.1.25506.2.75.11.3.3.1.10) |
read-only |
Integer32 |
Duration of the mesh link connected to the peer. |
As per the MIB. |
hh3cDot11sMeshNbrRSSI (1.3.6.1.4.1.25506.2.75.11.3.3.1.11) |
read-only |
Integer32 |
RSSI of mesh link connected to the peer. |
As per the MIB. |
hh3cDot11sMeshNbrSNR (1.3.6.1.4.1.25506.2.75.11.3.3.1.12) |
read-only |
Integer32 |
SNR of mesh link connected to the peer. |
As per the MIB. |
Notifications
h3cDot11sMeshLinkSwitchTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.75.11.4.0.1 |
Mesh link switchover event. |
Informational |
Informational |
1.3.6.1.4.1.25506.2.46.5.0.4 (hh3cUserIPLowerLimitWarningResume) |
OFF |
Notification triggers
This notification is generated when the IP address usage in the domain reaches or falls below the lower threshold for the first time.
System impact
No negative impact on services.
Status control
N/A
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.11.4.1.1 (hh3cDot11sMeshLinkBSSIDMAC) |
Local BSSID. |
N/A |
MacAddress |
OCTET STRING (SIZE (6)) |
1.3.6.1.4.1.25506.2.75.11.4.1.2 (hh3cDot11sMeshLinkPeerMAC) |
Peer MAC address. |
N/A |
MacAddress |
Recommended action
No action is required.
