12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R54xx)-6W10012-WLAN
05-HH3C-DOT11-CFGEXT-MIB
05-HH3C-DOT11-CFGEXT-MIB 91.72 KB
About this MIB
This MIB provides extended WLAN configuration information, defining the MIB nodes for advanced WLAN settings, such as load balancing. HH3C-DOT11-CFG-MIB defines the MIB nodes for basic WLAN settings.
MIB file name
hh3c-dot11-cfgext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11CFGEXT(6)
Scalar objects
hh3cDot11LoadBalanceTrafficEnable (1.3.6.1.4.1.25506.2.75.6.1.1.1)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Whether to enable traffic-based load balancing.
As per the MIB.
hh3cDot11LoadBalanceTrafficThres (1.3.6.1.4.1.25506.2.75.6.1.1.2)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Standard MIB values.
Traffic threshold that triggers traffic-based load balancing.
As per the MIB.
hh3cDot11LoadBalanceSessionEnable (1.3.6.1.4.1.25506.2.75.6.1.1.3)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Whether to enable session-based load balancing.
As per the MIB.
hh3cDot11LoadBalanceSessionThres (1.3.6.1.4.1.25506.2.75.6.1.1.4)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Session threshold that triggers session-based load balancing.
As per the MIB.
hh3cDot11LoadBalanceTrafficGap (1.3.6.1.4.1.25506.2.75.6.1.1.5)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Integer32(10..40)
Traffic gap threshold that triggers traffic-based WLAN load balancing. The AC performs traffic-based WLAN load balancing when both the traffic threshold and the traffic gap threshold are exceeded.
As per the MIB.
hh3cDot11LoadBalanceSessionGap (1.3.6.1.4.1.25506.2.75.6.1.1.6)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Integer32(1..12)
Session gap threshold that triggers session-based load balancing. The AC performs session-based WLAN radio load balancing when both the session threshold and the session gap threshold are exceeded.
As per the MIB.
hh3cDot11LBTrafficThresKbps (1.3.6.1.4.1.25506.2.75.6.1.1.7)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
As per the MIB.
hh3cDot11LBTrafficGapKbps (1.3.6.1.4.1.25506.2.75.6.1.1.8)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Traffic gap threshold that triggers traffic-based WLAN radio load balancing. The AC performs traffic-based WLAN radio load balancing when the traffic gap threshold is exceeded.
As per the MIB.
Tabular objects
hh3cDot11LBRadioGroupId
About this table
Load balancing group ID.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11LBRadioGroupId.
Object (OID)
Access
Value range
Implementation
hh3cDot11LBRadioGroupId (1.3.6.1.4.1.25506.2.75.6.1.2.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cDot11LBRadioGroupDesc (1.3.6.1.4.1.25506.2.75.6.1.2.1.2)
read-create
OCTET STRING
Load balancing group description.
As per the MIB.
hh3cDot11LBRadioGroupRowStatus (1.3.6.1.4.1.25506.2.75.6.1.2.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status of the entry.
As per the MIB.
