- 12-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-SAVI-MIB
- 15-HH3C-DOT11-WM2U-MIB
- 16-HH3C-DOT11-PROBE-MIB
- 17-HH3C-DOT11S-MESH-MIB
03-HH3C-DOT11-APMT-MIB | 786.55 KB |
hh3cDot11RadioAssocStatisTable
hh3cDot11RadioMngFrameStatisTable
hh3cDot11APAuthFailStatisTable
hh3cDot11APAssocFailStatisTable
hh3cDot11APUserAuthStatisTable
hh3cDot11APAssocFailStatis2Table
hh3cDot11RadioMngFrmStatisTable
hh3cDot11APPacketSizeStatisTable
hh3cDot11APPacketRateStatisTable
hh3cDot11APPacketMCSRateStatisTable
hh3cDot11APAssocFailStatis3Table
hh3cDot11APIfStatisByAPIDTable
hh3cDot11APUserSecAuthStatisTable
hh3cDot11APUserInfoStatisTable
hh3cDot11APReassocStatis2Table
hh3cDot11APUserSecAuthTypeStatisTable
hh3cDot11APPacketMCSRateStatis2Table
hh3cDot11APUserSecAuthStatisCMTable
hh3cDot11APUserInfoStatis2CMTable
hh3cDot11APMtRadioFailRecoverTrap
hh3cDot11DFSFreeCntBelowThrRecov
hh3cDot11APTrapUserCntExceedThre
hh3cDot11DetcAdjChlIntfAPClear
HH3C-DOT11-APMT-MIB
About this MIB
Use this MIB to obtain AP information.
MIB file name
hh3c-dot11-apmt.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11APMT(2)
Tabular objects
hh3cDot11APRadioTable
About this table
Use this table to obtain radio information about running APs.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID and hh3cDot11RadioID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11CurAPID (1.3.6.1.4.1.25506.2.75.2.1.3.1.1) |
read-only |
OCTET STRING |
OCTET STRING(0..64) |
ID of the running AP. |
As per the MIB. |
hh3cDot11RadioID (1.3.6.1.4.1.25506.2.75.2.1.3.1.2) |
read-only |
Integer32 |
Integer32(0..2147483647) |
Radio ID of the AP. |
As per the MIB. |
hh3cDot11AdminStatus (1.3.6.1.4.1.25506.2.75.2.1.3.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Management state of the radio. |
As per the MIB. |
hh3cDot11OperStatus (1.3.6.1.4.1.25506.2.75.2.1.3.1.4) |
read-only |
TruthValue |
true(1), false(2) |
Operating state of the radio. |
As per the MIB. |
hh3cDot11Channel (1.3.6.1.4.1.25506.2.75.2.1.3.1.5) |
read-only |
Hh3cDot11ChannelScopeType |
Integer32 Standard MIB values. |
Channel allocation information of the radio. |
As per the MIB. |
hh3cDot11TxPowerLevel (1.3.6.1.4.1.25506.2.75.2.1.3.1.6) |
read-only |
Hh3cDot11TxPwrLevelScopeType |
Transmit power level of the current AP's radio |
As per the MIB. |
hh3cDot11APRadioIfIndex (1.3.6.1.4.1.25506.2.75.2.1.3.1.7) |
read-only |
Integer32 |
Interface index of the current AP's radio frequency |
As per the MIB. |
hh3cDot11AntennaGain (1.3.6.1.4.1.25506.2.75.2.1.3.1.8) |
read-only |
Integer32 |
Antenna gain of the current AP's radio |
As per the MIB. |
hh3cDot11MaxBandwidth (1.3.6.1.4.1.25506.2.75.2.1.3.1.9) |
read-only |
Integer32 |
Maximum bandwidth of the current AP's radio |
As per the MIB. |
hh3cDot11ResourceUseRatio (1.3.6.1.4.1.25506.2.75.2.1.3.1.10) |
read-only |
Integer32 |
Usage of the current AP's radio resources |
As per the MIB. |
hh3cDot11RadioModeSupport (1.3.6.1.4.1.25506.2.75.2.1.3.1.11) |
read-only |
Unsigned32 |
dot11a(1), dot11b(2), dot11g(4), dot11gn(16), dot11an(32), dot11ac(64), dot11gac(128), dot11ax(256), dot11gax(512) |
Types of radios supported by the current AP |
As per the MIB. |
hh3cDot11TxPowerLevel2 (1.3.6.1.4.1.25506.2.75.2.1.3.1.12) |
read-only |
Integer32 |
Integer32(1..8) |
Current AP radio power for transmitting data |
As per the MIB. |
hh3cDot11PowerMgmtStatus (1.3.6.1.4.1.25506.2.75.2.1.3.1.13) |
read-only |
TruthValue |
true(1), false(2) |
Current AP radio power management state |
As per the MIB. |
hh3cDot11ChannelSwitchTimes (1.3.6.1.4.1.25506.2.75.2.1.3.1.14) |
read-only |
Counter32 |
Current AP radio channel switchover time |
As per the MIB. |
hh3cDot11AntennaType (1.3.6.1.4.1.25506.2.75.2.1.3.1.15) |
read-only |
OCTET STRING |
Current AP radio antenna type in use |
As per the MIB. |
hh3cDot11DiversitySelectionRx (1.3.6.1.4.1.25506.2.75.2.1.3.1.16) |
read-only |
TruthValue |
true(1), false(2) |
Current AP radio received diversity selection |
As per the MIB. |
hh3cDot11MaxTxPwrLvl (1.3.6.1.4.1.25506.2.75.2.1.3.1.17) |
read-only |
OCTET STRING |
Current AP radio maximum transmit power |
As per the MIB. |
hh3cDot11PwrAttRange (1.3.6.1.4.1.25506.2.75.2.1.3.1.18) |
read-only |
Integer32 |
Current AP radio power attenuation range |
As per the MIB. |
hh3cDot11AvgRxSignalStrength (1.3.6.1.4.1.25506.2.75.2.1.3.1.19) |
read-only |
Integer32 |
Current AP radio received average signal strength |
As per the MIB. |
hh3cDot11HighestRxSignalStrength (1.3.6.1.4.1.25506.2.75.2.1.3.1.20) |
read-only |
Integer32 |
Current AP radio received strongest signal strength |
As per the MIB. |
hh3cDot11LowestRxSignalStrength (1.3.6.1.4.1.25506.2.75.2.1.3.1.21) |
read-only |
Integer32 |
Current AP radio received weakest signal strength |
As per the MIB. |
hh3cDot11RadioIfUpdownTimes (1.3.6.1.4.1.25506.2.75.2.1.3.1.22) |
read-only |
Counter32 |
Current AP radio interface on/offs |
As per the MIB. |
hh3cDot11RadioIfLastChange (1.3.6.1.4.1.25506.2.75.2.1.3.1.23) |
read-only |
TimeTicks |
Current AP radio interface last change time |
As per the MIB. |
hh3cDot11RadioModeSupport2 (1.3.6.1.4.1.25506.2.75.2.1.3.1.24) |
read-only |
Unsigned32 |
dot11a(1), dot11b(2), dot11g(4), dot11an(8), dot11gn(16), dot11gac(32), dot11ac(64), dot11gax(128), dot11ax(256) |
Current AP radio supported radio types |
As per the MIB. |
hh3cDot11OperStatusCM (1.3.6.1.4.1.25506.2.75.2.1.3.1.25) |
read-only |
INTEGER |
up(1), down(2), testing(3), admindown(4) |
Current AP radio operating state |
As per the MIB. |
hh3cDot11AirPrimChnlBusy (1.3.6.1.4.1.25506.2.75.2.1.3.1.26) |
read-only |
Integer32 |
Integer32(0..100 | 255) |
Current AP radio air interface utilization on main channel |
As per the MIB. |
hh3cDot11RadioType (1.3.6.1.4.1.25506.2.75.2.1.3.1.30) |
read-only |
Integer32 |
Type of the AP radio. |
As per the MIB. |
hh3cDot11RadioOper (1.3.6.1.4.1.25506.2.75.2.1.3.1.31) |
read-write |
Integer32 |
Working status of the AP radio. |
As per the MIB. |
hh3cDot11BindSSID (1.3.6.1.4.1.25506.2.75.2.1.3.1.32) |
read-only |
OCTET STRING |
SSIDs bound to the AP radio. |
As per the MIB. |
hh3cDot11RadioAverageSignalStrength (1.3.6.1.4.1.25506.2.75.2.1.3.1.33) |
read-only |
Integer32 |
Average signal strength received by the AP radio. |
As per the MIB. |
hh3cDot11RadioMaxSignalStrength (1.3.6.1.4.1.25506.2.75.2.1.3.1.34) |
read-only |
Integer32 |
Maximum signal strength received by the AP radio. |
As per the MIB. |
hh3cDot11RadioMinSignalStrength (1.3.6.1.4.1.25506.2.75.2.1.3.1.35) |
read-only |
Integer32 |
Minimum signal strength received by the AP radio. |
As per the MIB. |
hh3cDot11APBSSTable
About this table
Use this table to obtain BSS-based AP and service policy information.
Edit/Modify:Not supported
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11WlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11WlanID (1.3.6.1.4.1.25506.2.75.2.1.4.1.1) |
not-accessible |
Integer32 |
Integer32 (0..2147483647) |
ID of the specified ESS |
As per the MIB. |
hh3cDot11BSSID (1.3.6.1.4.1.25506.2.75.2.1.4.1.2) |
read-only |
MacAddress |
MacAddress(6) |
In the same format as the MAC address and used to identify the BSS |
As per the MIB. |
hh3cDot11CurrSvcPolicyID (1.3.6.1.4.1.25506.2.75.2.1.4.1.3) |
read-only |
Hh3cDot11ServicePolicyIDType |
ID of each service policy used by the AP |
As per the MIB. |
hh3cDot11SSID (1.3.6.1.4.1.25506.2.75.2.1.4.1.4) |
read-only |
OCTET STRING |
SSID corresponding to the BSS |
As per the MIB. |
hh3cDot11CurrSSIDResourceUseRatio (1.3.6.1.4.1.25506.2.75.2.1.4.1.5) |
read-only |
Integer32 |
Resource usage of the current SSID |
As per the MIB. |
hh3cDot11APEssVlanId (1.3.6.1.4.1.25506.2.75.2.1.4.1.6) |
read-only |
Integer32 |
VLAN ID of the interface ESS corresponding to the BSS |
As per the MIB. |
hh3cDot11APModelTable
About this table
Use this table to define the capability information of a specific type of APs.
Read:Supported
Columns
The table index is hh3cDot11APModelAlias.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APModelAlias (1.3.6.1.4.1.25506.2.75.2.1.5.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING(0..127) |
Alias of the AP model name. |
As per the MIB. |
hh3cDot11APModelName (1.3.6.1.4.1.25506.2.75.2.1.5.1.2) |
read-only |
OCTET STRING |
AP model name. |
As per the MIB. |
hh3cDot11RadioNumSupport (1.3.6.1.4.1.25506.2.75.2.1.5.1.3) |
read-only |
Hh3cDot11RadioScopeType |
Number of radios supported by the AP model. |
As per the MIB. |
hh3cDot11StationNumSupport (1.3.6.1.4.1.25506.2.75.2.1.5.1.4) |
read-only |
Integer32 |
Number of clients that can be connected to the AP model |
As per the MIB. |
hh3cDot11MACModeSupport (1.3.6.1.4.1.25506.2.75.2.1.5.1.5) |
read-only |
Hh3cDot11MACModeType |
split(1), localtunnel(2), localbridge(3), fatAP(4) |
Supported AP model in CAPW MAC address of the AP mode |
As per the MIB. |
hh3cDot11APManufacturer (1.3.6.1.4.1.25506.2.75.2.1.5.1.6) |
read-only |
OCTET STRING |
Supplier of the AP model, so that NMS can know which supplier produces the AP through the "SMI network management private enterprise code" assigned by IANA |
As per the MIB. |
hh3cDot11APCPUType (1.3.6.1.4.1.25506.2.75.2.1.5.1.7) |
read-only |
OCTET STRING |
CPU type of the AP model |
As per the MIB. |
hh3cDot11APCPUClockSpeed (1.3.6.1.4.1.25506.2.75.2.1.5.1.8) |
read-only |
Unsigned32 |
CPU clock speed of the AP model |
As per the MIB. |
hh3cDot11APMemoryType (1.3.6.1.4.1.25506.2.75.2.1.5.1.9) |
read-only |
OCTET STRING |
Memory card type of the AP model |
As per the MIB. |
hh3cDot11APFlashType (1.3.6.1.4.1.25506.2.75.2.1.5.1.11) |
read-only |
OCTET STRING |
Flash memory card type of the AP model |
As per the MIB. |
hh3cDot11APFlashSize (1.3.6.1.4.1.25506.2.75.2.1.5.1.12) |
read-only |
Unsigned32 |
Flash memory card size of the AP model |
As per the MIB. |
hh3cDot11APMemSize (1.3.6.1.4.1.25506.2.75.2.1.5.1.13) |
read-only |
Gauge32 |
Memory card size of the AP model |
As per the MIB. |
hh3cDot11APFlashSizeInBytes (1.3.6.1.4.1.25506.2.75.2.1.5.1.14) |
read-only |
Unsigned32 |
Flash memory card size of the AP model (in bytes) |
As per the MIB. |
hh3cDot11WsmAPLicenseType (1.3.6.1.4.1.25506.2.75.2.1.5.1.15) |
read-only |
INTEGER |
normal(1), wtu(2), wt(3), iot(4), other(5) |
IMC WSM AP license type of the AP model |
As per the MIB. |
hh3cDot11APMemorySize (1.3.6.1.4.1.25506.2.75.2.1.5.1.20) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cDot11APIfTable
About this table
Use this table to obtain AP interface information.
Read:Supported
Columns
The table indexes are hh3cDot11APObjID and hh3cDot11APIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APIfIndex (1.3.6.1.4.1.25506.2.75.2.1.6.1.1) |
not-accessible |
Integer32 |
AP interface index. |
As per the MIB. |
hh3cDot11APIfDescr (1.3.6.1.4.1.25506.2.75.2.1.6.1.2) |
read-only |
OCTET STRING |
AP interface description. |
As per the MIB. |
hh3cDot11APIfType (1.3.6.1.4.1.25506.2.75.2.1.6.1.3) |
read-only |
Integer32 |
AP interface type. |
As per the MIB. |
hh3cDot11APIfMtu (1.3.6.1.4.1.25506.2.75.2.1.6.1.4) |
read-write |
Integer32 |
Maximum datagram size sent/received by this AP interface, specified in bytes |
As per the MIB. |
hh3cDot11APIfPHYAddress (1.3.6.1.4.1.25506.2.75.2.1.6.1.5) |
read-only |
OCTET STRING |
Physical address of the AP interface. |
As per the MIB. |
hh3cDot11APIfSpeed (1.3.6.1.4.1.25506.2.75.2.1.6.1.6) |
read-only |
Integer32 |
Maximum bandwidth of the AP interface. |
As per the MIB. |
hh3cDot11APIfInDataRate (1.3.6.1.4.1.25506.2.75.2.1.6.1.7) |
read-only |
Integer32 |
Average incoming data rate of the AP interface. |
As per the MIB. |
hh3cDot11APIfOutDataRate (1.3.6.1.4.1.25506.2.75.2.1.6.1.8) |
read-only |
Integer32 |
Average outgoing data rate of the AP interface. |
As per the MIB. |
hh3cDot11APIfSpeedKbps (1.3.6.1.4.1.25506.2.75.2.1.6.1.9) |
read-only |
Gauge32 |
As per the MIB. |
hh3cDot11APIfTypeCM (1.3.6.1.4.1.25506.2.75.2.1.6.1.10) |
read-only |
Gauge32 |
As per the MIB. |
hh3cDot11APSSIDObjectTable
About this table
Use this table to obtain SSID-based BSSID configuration information.
Read:Supported
Columns
The table index is hh3cDot11APConfigSPID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APConfigSPID (1.3.6.1.4.1.25506.2.75.2.1.7.1.1) |
not-accessible |
Service policy ID. |
As per the MIB. |
hh3cDot11APConfigSSIDName (1.3.6.1.4.1.25506.2.75.2.1.7.1.2) |
read-only |
Hh3cDot11SSIDStringType |
SSID name of this service policy |
As per the MIB. |
hh3cDot11APConfigBSSIDNum (1.3.6.1.4.1.25506.2.75.2.1.7.1.3) |
read-only |
Integer32 |
Number of BSSIDs configured for the current SSID |
As per the MIB. |
hh3cDot11APConfigPortalStaNum (1.3.6.1.4.1.25506.2.75.2.1.7.1.4) |
read-only |
Integer32 |
Total number of associated portal clients with the current SSID |
As per the MIB. |
hh3cDot11APAssocStaNum (1.3.6.1.4.1.25506.2.75.2.1.7.1.5) |
read-only |
Integer32 |
Total number of related clients with the current SSID |
As per the MIB. |
hh3cDot11APSysInfoTable
About this table
Use this table to obtain AP system information.
Read:Supported
Columns
The table index is hh3cDot11APElementIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APSysUpTime (1.3.6.1.4.1.25506.2.75.2.1.8.1.1) |
read-only |
TimeTicks |
AP uptime. |
As per the MIB. |
hh3cDot11APCPURTUsage (1.3.6.1.4.1.25506.2.75.2.1.8.1.2) |
read-only |
Integer32 |
Integer32(0..100) |
Real-time CPU usage of the AP. |
As per the MIB. |
hh3cDot11APCPUAvgUsage (1.3.6.1.4.1.25506.2.75.2.1.8.1.3) |
read-only |
Integer32 |
Integer32(0..100) |
Average usage rate of AP CPU during statistical time |
As per the MIB. |
hh3cDot11APMemRTUsage (1.3.6.1.4.1.25506.2.75.2.1.8.1.4) |
read-only |
Integer32 |
Integer32(0..100) |
Real-time memory usage of the AP. |
As per the MIB. |
hh3cDot11APMemAvgUsage (1.3.6.1.4.1.25506.2.75.2.1.8.1.5) |
read-only |
Integer32 |
Integer32(0..100) |
Average usage rate of AP memory during statistical time |
As per the MIB. |
hh3cDot11APIPAddressGateway (1.3.6.1.4.1.25506.2.75.2.1.8.1.6) |
read-only |
IpAddress |
AP gateway address. |
As per the MIB. |
hh3cDot11APACAssociateStatus (1.3.6.1.4.1.25506.2.75.2.1.8.1.7) |
read-only |
INTEGER |
associated(1) deassociated(2) downloadingImage(3) |
Association state between the AP and AC. |
As per the MIB. |
hh3cDot11APManuBuildInfo (1.3.6.1.4.1.25506.2.75.2.1.8.1.8) |
read-only |
OCTET STRING |
OCTET STRING(0..255) |
AP software information. |
As per the MIB. |
hh3cDot11APFlashFreeSize (1.3.6.1.4.1.25506.2.75.2.1.8.1.9) |
read-only |
Unsigned32 |
Remaining space of AP flash, in bytes |
As per the MIB. |
hh3cDot11APTemperature (1.3.6.1.4.1.25506.2.75.2.1.8.1.10) |
read-only |
Integer32 |
AP temperature information. |
As per the MIB. |
hh3cDot11APIdleListTable
About this table
Use this table to obtain information about available APs.
Read:Supported
Columns
The table index is hh3cDot11APIdleTemplateName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APIdleTemplateName (1.3.6.1.4.1.25506.2.75.2.1.9.1.1) |
not-accessible |
OCTET STRING |
Available AP template name. |
As per the MIB. |
hh3cDot11APIdleSerialID (1.3.6.1.4.1.25506.2.75.2.1.9.1.2) |
read-only |
OCTET STRING |
AP serial number. |
As per the MIB. |
hh3cDot11APSysInfoByAPIDTable
About this table
Read:Supported
Columns
The table index is hh3cDot11APObjID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APSysUpTime2 (1.3.6.1.4.1.25506.2.75.2.1.1.1.1) |
read-only |
TimeTicks |
AP uptime. |
As per the MIB. |
hh3cDot11APCPURTUsage2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.2) |
read-only |
Integer32 |
Integer32(0..100) |
As per the MIB. |
hh3cDot11APCPUAvgUsage2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.3) |
read-only |
Integer32 |
Integer32(0..100) |
As per the MIB. |
hh3cDot11APMemRTUsage2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.4) |
read-only |
Integer32 |
Integer32(0..100) |
As per the MIB. |
hh3cDot11APMemAvgUsage2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.5) |
read-only |
Integer32 |
Integer32(0..100) |
As per the MIB. |
hh3cDot11APIPAddressGateway2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.6) |
read-only |
IpAddress |
As per the MIB. |
hh3cDot11APACAssociateStatus2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.7) |
read-only |
INTEGER |
As per the MIB. |
hh3cDot11APManuBuildInfo2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.8) |
read-only |
OCTET STRING |
As per the MIB. |
hh3cDot11APFlashFreeSize2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.9) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cDot11APTemperature2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.10) |
read-only |
Integer32 |
As per the MIB. |
hh3cDot11APMacAddress2 (1.3.6.1.4.1.25506.2.75.2.1.10.1.11) |
read-only |
MacAddress |
OCTET STRING (6) |
MAC address of the AP. |
As per the MIB. |
hh3cDot11APACAssociateStatusCM (1.3.6.1.4.1.25506.2.75.2.1.10.1.12) |
read-only |
INTEGER |
deassociated(0) associated(1) |
As per the MIB. |
hh3cDot11WTUAPInfoTable
About this table
Use this table to obtain the relationship information between WTUs and WTs.
Read:Supported
Columns
The table indexes are hh3cDot11ContainerSerialID and hh3cDot11WTUAPSerialID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11ContainerSerialID (1.3.6.1.4.1.25506.2.75.2.1.11.1.1) |
not-accessible |
Hh3cDot11ObjectIDType |
Sequence number of the WT |
As per the MIB. |
hh3cDot11WTUAPSerialID (1.3.6.1.4.1.25506.2.75.2.1.11.1.2) |
not-accessible |
Sequence number of the WTU |
As per the MIB. |
hh3cDot11WTUAPSubSlotID (1.3.6.1.4.1.25506.2.75.2.1.11.1.3) |
read-only |
Unsigned32 |
Sub connection ID for WTU |
As per the MIB. |
hh3cDot11ApBriefInfoTable
About this table
Use this table to obtain AP information.
Read:Supported
Columns
The table index is hh3cDot11BrfAPName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11BrfAPName (1.3.6.1.4.1.25506.2.75.2.1.12.1.1) |
not-accessible |
OCTET STRING |
AP name |
As per the MIB. |
hh3cDot11BrfAPSerialID (1.3.6.1.4.1.25506.2.75.2.1.12.1.2) |
read-only |
OCTET STRING |
AP serial number. |
As per the MIB. |
hh3cDot11BrfAPModelName (1.3.6.1.4.1.25506.2.75.2.1.12.1.3) |
read-only |
OCTET STRING |
AP model |
As per the MIB. |
hh3cDot11BrfAPDescription (1.3.6.1.4.1.25506.2.75.2.1.12.1.4) |
read-only |
OCTET STRING |
AP description, including but not limited to location and owner |
As per the MIB. |
hh3cDot11BrfAPStatisInterv (1.3.6.1.4.1.25506.2.75.2.1.12.1.5) |
read-only |
Integer32 |
Radio frequency statistics interval |
As per the MIB. |
hh3cDot11BrfAPStaIdleInterv (1.3.6.1.4.1.25506.2.75.2.1.12.1.6) |
read-only |
Integer32 |
Maximum idle time allowed between AP and wireless client |
As per the MIB. |
hh3cDot11BrfAPStaKeepAliveInterv (1.3.6.1.4.1.25506.2.75.2.1.12.1.7) |
read-only |
Integer32 |
Wireless client keepalive time |
As per the MIB. |
hh3cDot11BrfAPCir (1.3.6.1.4.1.25506.2.75.2.1.12.1.8) |
read-only |
Integer32 |
Confirmation rate between AP and AC |
As per the MIB. |
hh3cDot11BrfAPCbs (1.3.6.1.4.1.25506.2.75.2.1.12.1.9) |
read-only |
Integer32 |
Congestion size between AP and AC |
As per the MIB. |
hh3cDot11BrfAPPriorityLevel (1.3.6.1.4.1.25506.2.75.2.1.12.1.10) |
read-only |
Integer32 |
AP connection precedence, if the precedence is 7, it means that the AC is the primary AC for the AP |
As per the MIB. |
hh3cDot11BrfAPElementID (1.3.6.1.4.1.25506.2.75.2.1.12.1.11) |
read-only |
Integer32 |
AP element ID |
As per the MIB. |
hh3cDot11BrfAPSupportRadioMode (1.3.6.1.4.1.25506.2.75.2.1.12.1.12) |
read-only |
Integer32 |
Supported radio modes of the AP. WLAN supports the following radio modes: dot11b(1), dot11a(2), dot11g(4), dot11gn(8), dot11an(16), dot11gac(32), dot11ac(64), dot11gax(128), dot11ax(256) An AP can simultaneously support multiple radio modes. |
As per the MIB. |
hh3cDot11BrfAPControlAddressState (1.3.6.1.4.1.25506.2.75.2.1.12.1.13) |
read-only |
INTEGER |
enable(1) disable(2) |
Secondary discovery support status: enable: Secondary discovery enabled disable: Secondary discovery disabled |
As per the MIB. |
hh3cDot11BrfAPControlAddressIPv4 (1.3.6.1.4.1.25506.2.75.2.1.12.1.14) |
read-only |
IpAddress |
Secondary discovery address |
As per the MIB. |
hh3cDot11BrfAPLocalACName (1.3.6.1.4.1.25506.2.75.2.1.12.1.15) |
read-only |
OCTET STRING |
Local AC name |
As per the MIB. |
hh3cDot11BrfAPIPAddress (1.3.6.1.4.1.25506.2.75.2.1.12.1.16) |
read-only |
IpAddress |
AP IP Address |
As per the MIB. |
hh3cDot11BrfAPMacAddress (1.3.6.1.4.1.25506.2.75.2.1.12.1.17) |
read-only |
OCTET STRING |
AP MAC |
As per the MIB. |
hh3cDot11BrfAPConnectType (1.3.6.1.4.1.25506.2.75.2.1.12.1.18) |
read-only |
INTEGER |
master(1) slave(2) notAvailable(3) |
Current connection type |
As per the MIB. |
hh3cDot11BrfAPIPv6Address (1.3.6.1.4.1.25506.2.75.2.1.12.1.19) |
read-only |
OCTET STRING |
AP IPv6 Address |
As per the MIB. |
hh3cDot11BrfAPACPortIndex (1.3.6.1.4.1.25506.2.75.2.1.12.1.20) |
read-only |
Integer32 |
Port index on the AC, AP traffic is transmitted through this port. The network management system may use this value as access information for MIB-2 |
As per the MIB. |
hh3cDot11BrfAPStaAssocCount (1.3.6.1.4.1.25506.2.75.2.1.12.1.21) |
read-only |
Integer32 |
Total number of clients associated with the AP |
As per the MIB. |
hh3cDot11BrfAPImageName (1.3.6.1.4.1.25506.2.75.2.1.12.1.22) |
read-only |
OCTET STRING |
AP image file name |
As per the MIB. |
hh3cDot11BrfAPSoftwareVersion (1.3.6.1.4.1.25506.2.75.2.1.12.1.23) |
read-only |
OCTET STRING |
AP software version number |
As per the MIB. |
hh3cDot11BrfAPIPNetMask (1.3.6.1.4.1.25506.2.75.2.1.12.1.24) |
read-only |
IpAddress |
AP subnet mask |
As per the MIB. |
hh3cDot11BrfAPOperationStatus (1.3.6.1.4.1.25506.2.75.2.1.12.1.25) |
read-only |
INTEGER |
run(1) idle(2) |
AP status: run: online idle: offline |
As per the MIB. |
hh3cDot11APRxStatisTable
About this table
Use this table to obtain radio statistics information.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RxFrameDupCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.1) |
read-only |
Counter32 |
Number of duplicate frames received by the radio |
As per the MIB. |
hh3cDot11RxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.2) |
read-only |
Counter32 |
Number of frames received by the radio |
As per the MIB. |
hh3cDot11RxUcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.3) |
read-only |
Counter32 |
Number of unicast frames received by the radio |
As per the MIB. |
hh3cDot11RxBcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.4) |
read-only |
Counter32 |
Number of broadcast frames received by the radio |
As per the MIB. |
hh3cDot11RxMcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.5) |
read-only |
Counter32 |
Number of multicast frames received by the radio |
As per the MIB. |
hh3cDot11RxDiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.6) |
read-only |
Counter32 |
Number of frames discarded by the radio |
As per the MIB. |
hh3cDot11RxFragCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.7) |
read-only |
Counter32 |
Number of frame fragments received by the radio |
As per the MIB. |
hh3cDot11RxFcsErrCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.8) |
read-only |
Counter32 |
Number of FCS error frames received by the radio |
As per the MIB. |
hh3cDot11RxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.9) |
read-only |
Counter32 |
Number of bytes received by the radio |
As per the MIB. |
hh3cDot11RxUcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.10) |
read-only |
Counter32 |
Number of bytes in the unicast frames received by the radio |
As per the MIB. |
hh3cDot11RxBcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.11) |
read-only |
Counter32 |
Number of bytes in the broadcast frames received by the radio |
As per the MIB. |
hh3cDot11RxMcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.12) |
read-only |
Counter32 |
Number of bytes in the multicast frames received by the radio |
As per the MIB. |
hh3cDot11RxDiscardFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.13) |
read-only |
Counter32 |
Number of bytes discarded by the radio |
As per the MIB. |
hh3cDot11RxMgmtFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.14) |
read-only |
Counter32 |
Number of management frames received by the radio |
As per the MIB. |
hh3cDot11RxCtrlFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.15) |
read-only |
Counter32 |
Number of control frames received by the radio |
As per the MIB. |
hh3cDot11RxDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.16) |
read-only |
Counter32 |
Number of data frames received by the radio |
As per the MIB. |
hh3cDot11RxDecryptErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.17) |
read-only |
Counter32 |
Number of decryption errors on the radio |
As per the MIB. |
hh3cDot11RxAuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.18) |
read-only |
Counter32 |
Number of authentication frames received by the radio |
As per the MIB. |
hh3cDot11RxAssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.19) |
read-only |
Counter32 |
Number of association frames received by the radio |
As per the MIB. |
hh3cDot11RxFrameErrorRatio (1.3.6.1.4.1.25506.2.75.2.2.1.1.20) |
read-only |
Integer32 |
Error frame ratio of the radio |
As per the MIB. |
hh3cDot11RxPhyErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.21) |
read-only |
Counter32 |
Number of physical receive errors on the radio |
As per the MIB. |
hh3cDot11RxMICErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.22) |
read-only |
Counter32 |
Number of MIC verification errors on the radio |
As per the MIB. |
hh3cDot11RxDataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.23) |
read-only |
Counter32 |
Number of bytes in the data frames received by the radio |
As per the MIB. |
hh3cDot11RadioRxAverSnr (1.3.6.1.4.1.25506.2.75.2.2.1.1.24) |
read-only |
Integer32 |
Average signal-to-noise ratio of the radio |
As per the MIB. |
hh3cDot11RxPayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.1.1.25) |
read-only |
Counter32 |
Payload bytes in data frames received by the radio |
As per the MIB. |
hh3cDot11RxTrafficSpeed (1.3.6.1.4.1.25506.2.75.2.2.1.1.26) |
read-only |
Integer32 |
Number of bytes received per second by the radio |
As per the MIB. |
hh3cDot11RxUcastDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.27) |
read-only |
Counter64 |
Number of unicast data frames received by the radio |
As per the MIB. |
hh3cDot11RxNUcastDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.28) |
read-only |
Counter64 |
Number of non-unicast data frames received by the radio |
As per the MIB. |
hh3cDot11RxTotalDiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.29) |
read-only |
Counter64 |
Ttal number of frames lost by the radio |
As per the MIB. |
hh3cDot11RxTotalIPCheckErrPacketCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.30) |
read-only |
Counter64 |
Total number of IP checksum error packets received by the radio |
As per the MIB. |
hh3cDot11RxSignalStrengthPacketCntCM (1.3.6.1.4.1.25506.2.75.2.2.1.1.31) |
read-only |
OCTET STRING |
Number of data packets received based on signal strength by the radio |
As per the MIB. |
hh3cDot11RxDataFrameCntCM (1.3.6.1.4.1.25506.2.75.2.2.1.1.32) |
read-only |
Counter32 |
Number of data frames received, excluding retransmitted frames, by the radio |
As per the MIB. |
hh3cDot11RxTotalFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.1.1.33) |
read-only |
Counter64 |
Total number of packets received by the radio |
As per the MIB. |
hh3cDot11APTxStatisTable
About this table
Use this table to obtain radio transmission statistics.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11TxFragCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.1) |
read-only |
Counter32 |
Number of segmented frames transmitted by the radio |
As per the MIB. |
hh3cDot11FailedCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.2) |
read-only |
Counter32 |
Number of failures in transmission by the radio |
As per the MIB. |
hh3cDot11RetryCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.3) |
read-only |
Counter32 |
Number of single retransmissions by the radio |
As per the MIB. |
hh3cDot11MultiRetryCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.4) |
read-only |
Counter32 |
Number of multiple retransmissions by the radio |
As per the MIB. |
hh3cDot11RtsSuccessCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.5) |
read-only |
Counter32 |
Number of successful RTS transmissions by the radio |
As per the MIB. |
hh3cDot11RtsFailCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.6) |
read-only |
Counter32 |
Number of failed RTS transmissions by the radio |
As per the MIB. |
hh3cDot11AckFailCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.7) |
read-only |
Counter32 |
Number of failed acknowledgment transmissions by the radio |
As per the MIB. |
hh3cDot11TxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.8) |
read-only |
Counter32 |
Total number of frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxUcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.9) |
read-only |
Counter32 |
Number of unicast frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxBcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.10) |
read-only |
Counter32 |
Number of broadcast frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxMcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.11) |
read-only |
Counter32 |
Number of multicast frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxDiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.12) |
read-only |
Counter32 |
Number of discarded frames by the radio |
As per the MIB. |
hh3cDot11TxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.13) |
read-only |
Counter32 |
Total bytes in the frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxUcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.14) |
read-only |
Counter32 |
Number of bytes in unicast frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxBcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.15) |
read-only |
Counter32 |
Number of bytes in broadcast frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxMcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.16) |
read-only |
Counter32 |
Number of bytes in multicast frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxDiscardFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.17) |
read-only |
Counter32 |
Number of bytes in discarded frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxAuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.18) |
read-only |
Counter32 |
Number of identity verification frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxAssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.19) |
read-only |
Counter32 |
Number of association frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxFrameRetryRatio (1.3.6.1.4.1.25506.2.75.2.2.2.1.20) |
read-only |
Integer32 |
Retransmission frame ratio of the radio |
As per the MIB. |
hh3cDot11TxDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.21) |
read-only |
Counter32 |
Number of data frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxDataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.22) |
read-only |
Counter32 |
Number of bytes in data frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.23) |
read-only |
Counter32 |
Number of MSDU transmitted by the radio |
As per the MIB. |
hh3cDot11TxDiscardMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.24) |
read-only |
Counter32 |
Number of discarded MSDU transmitted by the radio |
As per the MIB. |
hh3cDot11RetryMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.25) |
read-only |
Counter32 |
Number of retransmitted MSDU by the radio |
As per the MIB. |
hh3cDot11TxPayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.2.1.26) |
read-only |
Counter32 |
Payload bytes in data frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxTrafficSpeed (1.3.6.1.4.1.25506.2.75.2.2.2.1.27) |
read-only |
Integer32 |
Number of bytes in frames transmitted per second by the radio |
As per the MIB. |
hh3cDot11TxErrFrameRatio (1.3.6.1.4.1.25506.2.75.2.2.2.1.28) |
read-only |
Integer32 |
Error frame ratio of frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxFrameRate (1.3.6.1.4.1.25506.2.75.2.2.2.1.29) |
read-only |
Counter32 |
Number of frames transmitted per second by the radio |
As per the MIB. |
hh3cDot11TxMgtFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.30) |
read-only |
Counter32 |
Number of management frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxCtrlFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.31) |
read-only |
Counter32 |
Number of control frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxMACErrCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.32) |
read-only |
Counter32 |
Number of MAC error frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxErrFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.33) |
read-only |
Counter32 |
Number of error frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxUcastDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.34) |
read-only |
Counter64 |
Number of unicast data frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxNUcastDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.35) |
read-only |
Counter64 |
Number of non-unicast data frames transmitted by the radio |
As per the MIB. |
hh3cDot11TxTotalFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.2.1.36) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APAssocStatisTable
About this table
Use this table to obtain client statistics information about an AP.
Read:Supported
Columns
The table index is hh3cDot11CurAPID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11ApStationAssocSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.1) |
read-only |
Counter32 |
Total number of clients associated with this AP |
As per the MIB. |
hh3cDot11ApStationAssocFailSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.2) |
read-only |
Counter32 |
Total number of clients that failed to associate with this AP |
As per the MIB. |
hh3cDot11ApStationReassocSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.3) |
read-only |
Counter32 |
Total number of clients re-associated with this AP |
As per the MIB. |
hh3cDot11ApStationAssocRejectSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.4) |
read-only |
Counter32 |
Total number of client associations rejected due to resource limitations of this AP |
As per the MIB. |
hh3cDot11ApStationExDeAuthenSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.5) |
read-only |
Counter32 |
Total number of abnormal client identity verifications (not sent to AP for verification) for this AP |
As per the MIB. |
hh3cDot11ApStationCurAssocSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.6) |
read-only |
Integer32 |
Total number of clients currently associated with this AP |
As per the MIB. |
hh3cDot11ApStaCurAuthSuccSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.7) |
read-only |
Integer32 |
Number of successful client identity verifications for this AP |
As per the MIB. |
hh3cDot11AllStationUpSumTime (1.3.6.1.4.1.25506.2.75.2.2.3.1.8) |
read-only |
Counter32 |
Total duration of all clients associated with this AP |
As per the MIB. |
hh3cDot11ApStationAssocReqSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.9) |
read-only |
Counter32 |
Number of client association requests using this AP |
As per the MIB. |
hh3cDot11AllStationUpSumTimeTicks (1.3.6.1.4.1.25506.2.75.2.2.3.1.10) |
read-only |
TimeTicks |
As per the MIB. |
hh3cDot11ApStationReassocReqSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.11) |
read-only |
Counter32 |
Total number of client re-association requests using this AP |
As per the MIB. |
hh3cDot11ApStationReassocFailSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.12) |
read-only |
Counter32 |
Total number of client re-association failures for this AP |
As per the MIB. |
hh3cDot11ApStationAssocRespSum (1.3.6.1.4.1.25506.2.75.2.2.3.1.13) |
read-only |
Counter32 |
Response code for client association with this AP |
As per the MIB. |
hh3cDot11BSSRxStatisTable
About this table
Use this table to obtain Rx statistics for a specific BSS.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11BSSRxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.1) |
read-only |
Counter32 |
Number of frames received by the BSS. |
As per the MIB. |
hh3cDot11BSSRxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.4.1.2) |
read-only |
Counter32 |
Number of bytes received by the BSS. |
As per the MIB. |
hh3cDot11BSSRxDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.3) |
read-only |
Counter32 |
Number of data frames received by the BSS. |
As per the MIB. |
hh3cDot11BSSRxDataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.4.1.4) |
read-only |
Counter32 |
Number of bytes in the data frames received by the BSS. |
As per the MIB. |
hh3cDot11BSSRxAssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.5) |
read-only |
Counter32 |
Number of association frames received by the BSS. |
As per the MIB. |
hh3cDot11BSSRxFrameErrorRatio (1.3.6.1.4.1.25506.2.75.2.2.4.1.6) |
read-only |
Integer32 |
Ratio of error frames received by this BSS |
As per the MIB. |
hh3cDot11BSSRxPayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.4.1.7) |
read-only |
Counter32 |
Payload bytes of data frames received by this BSS |
As per the MIB. |
hh3cDot11BSSRxUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.8) |
read-only |
Counter32 |
Number of unicast frames received |
As per the MIB. |
hh3cDot11BSSRxNonUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.9) |
read-only |
Integer32 |
Number of non-unicast frames received |
As per the MIB. |
hh3cDot11BSSRxAuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.4.1.10) |
read-only |
Counter32 |
Number of authentication frames received |
As per the MIB. |
hh3cDot11BSSRxFrameErrCntCM (1.3.6.1.4.1.25506.2.75.2.2.4.1.11) |
read-only |
Counter32 |
Number of error authentication frames received |
As per the MIB. |
hh3cDot11BSSTxStatisTable
About this table
Use this table to obtain Tx statistics for a specific BSS.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11BSSTxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.1) |
read-only |
Counter32 |
Total number of frames transmitted by this BSS |
As per the MIB. |
hh3cDot11BSSTxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.5.1.2) |
read-only |
Counter32 |
Total bytes in frames transmitted by this BSS |
As per the MIB. |
hh3cDot11BSSTxDataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.3) |
read-only |
Counter32 |
Number of data frames transmitted by this BSS |
As per the MIB. |
hh3cDot11BSSTxDataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.5.1.4) |
read-only |
Counter32 |
Number of bytes in data frames transmitted using this BSS |
As per the MIB. |
hh3cDot11BSSTxAssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.5) |
read-only |
Counter32 |
Number of frames associated with the transmission of this BSS |
As per the MIB. |
hh3cDot11BSSTxPayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.5.1.6) |
read-only |
Counter32 |
Number of payload bytes transmitted using this BSS |
As per the MIB. |
hh3cDot11BSSTxRetryCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.7) |
read-only |
Counter32 |
Number of bytes in retransmitted data using this BSS |
As per the MIB. |
hh3cDot11BSSTxUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.8) |
read-only |
Counter32 |
Number of unicast frames transmitted using this BSS |
As per the MIB. |
hh3cDot11BSSTxNonUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.9) |
read-only |
Integer32 |
Number of non-unicast frames transmitted by this BSS |
As per the MIB. |
hh3cDot11BSSTxAuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.5.1.10) |
read-only |
Counter32 |
Number of authentication frames transmitted by this BSS |
As per the MIB. |
hh3cDot11BSSTxFrameErrCntCM (1.3.6.1.4.1.25506.2.75.2.2.5.1.11) |
read-only |
Counter32 |
Number of error authentication frames transmitted by this BSS |
As per the MIB. |
hh3cDot11BSSAssocStatisTable
About this table
Use this table to obtain client association statistics information.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11BSSStationAssocSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.1) |
read-only |
Counter32 |
Total number of clients associated with this BSS |
As per the MIB. |
hh3cDot11BSSStationAssocFailSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.2) |
read-only |
Counter32 |
Total number of clients associated with this BSS that failed |
As per the MIB. |
hh3cDot11BSSStationReassocSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.3) |
read-only |
Counter32 |
Total number of clients re-associated with this BSS |
As per the MIB. |
hh3cDot11BSSStationAssocRejectSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.4) |
read-only |
Counter32 |
Total number of client associations rejected due to resource constraints of this BSS |
As per the MIB. |
hh3cDot11BSSStationExDeAssocSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.5) |
read-only |
Counter32 |
Total number of abnormal client identity verifications (not sent to AP for verification) using this BSS |
As per the MIB. |
hh3cDot11BSSStationCurAssocSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.6) |
read-only |
Integer32 |
Total number of clients related to this BSS |
As per the MIB. |
hh3cDot11BSSStationAssocReqSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.7) |
read-only |
Counter32 |
Total number of client association requests using this BSS |
As per the MIB. |
hh3cDot11BSSStationCurAuthSum (1.3.6.1.4.1.25506.2.75.2.2.6.1.8) |
read-only |
Integer32 |
Number of associated clients that have passed portal or 1x identity verification through this BSS |
As per the MIB. |
hh3cDot11APLinkStatisTable
About this table
Use this table to obtain AP link statistics information.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11UpLinkUpDownTimes (1.3.6.1.4.1.25506.2.75.2.2.7.1.1) |
read-only |
Counter32 |
Number of times the uplink interface of this AP is opened/closed |
As per the MIB. |
hh3cDot11DownLinkUpDownTimes (1.3.6.1.4.1.25506.2.75.2.2.7.1.2) |
read-only |
Counter32 |
Number of times the downlink interface of this AP is opened/closed |
As per the MIB. |
hh3cDot11PrivateSrvRxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.3) |
read-only |
Counter64 |
Number of bytes received from private service by this AP |
As per the MIB. |
hh3cDot11PrivateSrvTxFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.4) |
read-only |
Counter64 |
Number of bytes sent to private service by this AP |
As per the MIB. |
hh3cDot11APInternetAllRxBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.5) |
read-only |
Counter64 |
Number of bytes in Internet traffic received from terminals by this AP |
As per the MIB. |
hh3cDot11APInternetAllTxBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.6) |
read-only |
Counter64 |
Number of bytes in Internet traffic sent to terminals by this AP |
As per the MIB. |
hh3cDot11APLocalAllRxBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.7) |
read-only |
Counter64 |
Number of bytes in local traffic received from terminals by this AP |
As per the MIB. |
hh3cDot11APLocalAllTxBytes (1.3.6.1.4.1.25506.2.75.2.2.7.1.8) |
read-only |
Counter64 |
Number of bytes in local traffic sent to terminals by this AP |
As per the MIB. |
About this table
Use this table to obtain client statistics information.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RadioStaAssocSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.1) |
read-only |
Counter32 |
Total number of clients associated with this radio |
As per the MIB. |
hh3cDot11RadioStaAssocFailSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.2) |
read-only |
Counter32 |
Total number of clients that failed to associate with this radio |
As per the MIB. |
hh3cDot11RadioStaReassocSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.3) |
read-only |
Counter32 |
Total number of clients re-associated with this radio |
As per the MIB. |
hh3cDot11RadioStaAssocRejectSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.4) |
read-only |
Counter32 |
Total number of client associations refused due to resource limitations of this radio |
As per the MIB. |
hh3cDot11RadioStaExDeAssocSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.5) |
read-only |
Counter32 |
Total number of exception clients using this radio that cancelled identity verification (not sent to AP) |
As per the MIB. |
hh3cDot11RadioStaCurAssocSum (1.3.6.1.4.1.25506.2.75.2.2.8.1.6) |
read-only |
Integer32 |
As per the MIB. |
About this table
Use this table to obtain radio management frame statistics.
Read:Supported
Columns
The table indexes are hh3cDot11RadioStatisIndex and hh3cDot11MngFrameType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RadioStatisIndex (1.3.6.1.4.1.25506.2.75.2.2.9.1.1) |
not-accessible |
Hh3cDot11RadioElementIndex |
Unsigned32 Standard MIB values |
Radio index, consisting of two parts: the lowest 8 bits represent the RF ID, the middle 8 represent the AP ID, and the highest 8 bits are reserved |
As per the MIB. |
hh3cDot11MngFrameType (1.3.6.1.4.1.25506.2.75.2.2.9.1.2) |
not-accessible |
INTEGER |
assocReq(1), assocResp(2), reassocReq(3), reassocResp(4), probeReq(5), probeResp(6), beacon(7), atim(8), disassociation(9), authentication(10), deauthentication(11), action(12) |
Frame type on the radio |
As per the MIB. |
hh3cDot11MngFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.9.1.3) |
read-only |
Counter32 |
Total number of management frames on the radio |
As per the MIB. |
About this table
Use this table to obtain statistics on failed identity verifications.
Read:Supported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APAuthFailStatisType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APAuthFailStatisType (1.3.6.1.4.1.25506.2.75.2.2.10.1.1) |
not-accessible |
INTEGER |
invalidation(1), overtime(2), rejected(3), other(4) |
Type of identity verification failure for this AP |
As per the MIB. |
hh3cDot11APAuthFailStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.10.1.2) |
read-only |
Counter32 |
Total number of each type of identity verification failure on this AP |
As per the MIB. |
About this table
Use this table to obtain association failure statistics for this AP.
Read:Supported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APAssocFailStatisType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APAssocFailStatisType (1.3.6.1.4.1.25506.2.75.2.2.11.1.1) |
not-accessible |
INTEGER |
Type of association failure with this AP |
As per the MIB. |
hh3cDot11APAssocFailStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.11.1.2) |
read-only |
Counter32 |
Total number of association failures of each type on this AP |
As per the MIB. |
hh3cDot11APReassocStatisTable
About this table
Use this table to obtain reassociation statistics for this AP.
Read:Supported
Columns
The table index is hh3cDot11RadioID, hh3cDot11APReassocStatisType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APReassocStatisType (1.3.6.1.4.1.25506.2.75.2.2.12.1.1) |
not-accessible |
INTEGER |
total(1), success(2), invalidation(3), overtime(4), rejected(5), other(6) |
Type of reassociation with this AP |
As per the MIB. |
hh3cDot11APReassocStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.12.1.2) |
read-only |
Counter32 |
Total number of each type of reassociation with this AP |
As per the MIB. |
About this table
Use this table to obtain user authentication statistics for this AP.
Read:Supported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11UserAuthStatisType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11UserAuthStatisType (1.3.6.1.4.1.25506.2.75.2.2.13.1.1) |
not-accessible |
INTEGER |
total(1), success(2), keyError(3), invalidation(4), overtime(5), rejected(6), other(7) |
Type of user identity verification using this AP |
As per the MIB. |
hh3cDot11UserAuthStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.13.1.2) |
read-only |
Counter32 |
Total number of each type of user identity verification using this AP |
As per the MIB. |
hh3cDot11APDeauthStatisTable
About this table
Use this table to obtain deauthentication statistics for this AP.
Read:Supported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APDeauthStatisType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APDeauthStatisType (1.3.6.1.4.1.25506.2.75.2.2.14.1.1) |
not-accessible |
INTEGER |
total(1), clientLeaving(2), shortResource(3), exception(4), other(5) |
Deauthentication type of this AP |
As per the MIB. |
hh3cDot11APDeauthStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.14.1.2) |
read-only |
Counter32 |
Total number of each type that uses this AP for cancellation of identity verification |
As per the MIB. |
hh3cDot11APDeassocStatisTable
About this table
Use this table to obtain disassociation statistics for this AP.
Read:Supported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APDeassocStatisType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APDeassocStatisType (1.3.6.1.4.1.25506.2.75.2.2.15.1.1) |
not-accessible |
INTEGER |
Type of disassociation with this AP |
As per the MIB. |
hh3cDot11APDeassocStatisCnt (1.3.6.1.4.1.25506.2.75.2.2.15.1.2) |
read-only |
Counter32 |
Total number of each type of disassociation with this AP |
As per the MIB. |
About this table
Use this table to obtain statistics information on each AP association failure.
Read:Supported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APAssocFailStatis2Type.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APAssocFailStatis2Type (1.3.6.1.4.1.25506.2.75.2.2.16.1.1) |
not-accessible |
INTEGER |
shortResource(1), notSupportRateSet(2), unknownReasonCode(3), other(4), rssiLowness(5) |
Association type of this AP failure |
As per the MIB. |
hh3cDot11APAssocFailStatis2Cnt (1.3.6.1.4.1.25506.2.75.2.2.16.1.2) |
read-only |
Counter32 |
Total number of association failures for this AP |
As per the MIB. |
hh3cDot11APIfStatisTable
About this table
Use this table to obtain AP interface statistics information.
Read:Supported
Columns
The table indexes are hh3cDot11APElementIndex and hh3cDot11APIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APIfInPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.1) |
read-only |
Counter32 |
Total number of data packets received by the interface. |
As per the MIB. |
hh3cDot11APIfInNormalPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.2) |
read-only |
Counter32 |
Total number of valid data packets received by the interface. |
As per the MIB. |
hh3cDot11APIfInErrorPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.3) |
read-only |
Counter32 |
Total number of error data packets received by the interface. |
As per the MIB. |
hh3cDot11APIfOutPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.4) |
read-only |
Counter32 |
Total number of data packets sent by the interface. |
As per the MIB. |
hh3cDot11APIfInOctets (1.3.6.1.4.1.25506.2.75.2.2.17.1.5) |
read-only |
Counter32 |
Total number of eight-bit bytes received on this interface |
As per the MIB. |
hh3cDot11APIfOutOctets (1.3.6.1.4.1.25506.2.75.2.2.17.1.6) |
read-only |
Counter32 |
Total number of eight-bit bytes sent on this interface |
As per the MIB. |
hh3cDot11APIfFlowOut (1.3.6.1.4.1.25506.2.75.2.2.17.1.7) |
read-only |
Unsigned32 |
Traffic rate on the uplink interface of this interface during the sampling period (bytes/second) |
As per the MIB. |
hh3cDot11APIfFlowIN (1.3.6.1.4.1.25506.2.75.2.2.17.1.8) |
read-only |
Unsigned32 |
Traffic rate on the downlink interface of this interface during the sampling period (bytes/second) |
As per the MIB. |
hh3cDot11APIfInUcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.9) |
read-only |
Counter32 |
Total number of unicast data packets received by the interface. |
As per the MIB. |
hh3cDot11APIfInNUcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.10) |
read-only |
Counter32 |
Number of non-unicast data packets received on this wired interface |
As per the MIB. |
hh3cDot11APIfInDiscardPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.11) |
read-only |
Counter32 |
Total number of unicast data packets discarded on this interface |
As per the MIB. |
hh3cDot11APIfOutUcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.12) |
read-only |
Counter32 |
Number of unicast data packets sent on this interface |
As per the MIB. |
hh3cDot11APIfOutNUcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.13) |
read-only |
Counter32 |
Number of non-unicast data packets sent on this interface |
As per the MIB. |
hh3cDot11APIfOutDiscardPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.14) |
read-only |
Counter32 |
Number of discarded data packets sent on this interface |
As per the MIB. |
hh3cDot11APIfOutErrorPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.15) |
read-only |
Counter32 |
Number of error data packets sent on this interface |
As per the MIB. |
hh3cDot11APIfUpdownTimes (1.3.6.1.4.1.25506.2.75.2.2.17.1.16) |
read-only |
Counter32 |
Number of times this interface was opened/closed |
As per the MIB. |
hh3cDot11APIfStatusKeepTime (1.3.6.1.4.1.25506.2.75.2.2.17.1.17) |
read-only |
TimeTicks |
Time of the last state change on this interface |
As per the MIB. |
hh3cDot11APIfOperStatus (1.3.6.1.4.1.25506.2.75.2.2.17.1.18) |
read-only |
INTEGER |
up(1), down(2), testing(3), unknown(4), dormant(5), notPresent(6), lowerLayerDown(7) |
Operating status of this interface |
As per the MIB. |
hh3cDot11APIfInBrdcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.19) |
read-only |
Counter64 |
Ttal number of broadcast data packets received on this interface |
As per the MIB. |
hh3cDot11APIfOutBrdcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.20) |
read-only |
Counter64 |
Total number of broadcast data packets sent on this interface |
As per the MIB. |
hh3cDot11APIfInMulcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.21) |
read-only |
Counter64 |
Total number of multicast data packets received on this interface |
As per the MIB. |
hh3cDot11APIfOutMulcastPkts (1.3.6.1.4.1.25506.2.75.2.2.17.1.22) |
read-only |
Counter64 |
Total number of multicast data packets sent on this interface |
As per the MIB. |
hh3cDot11APIfInPayloadOctets (1.3.6.1.4.1.25506.2.75.2.2.17.1.23) |
read-only |
Counter64 |
Actual eight-bit bytes received on this interface |
As per the MIB. |
hh3cDot11APIfOutPayloadOctets (1.3.6.1.4.1.25506.2.75.2.2.17.1.24) |
read-only |
Counter64 |
Actual eight-bit bytes sent on this interface |
As per the MIB. |
About this table
Use this table to obtain the management frame statistics of a radio.
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11MngFrmType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11MngFrmType (1.3.6.1.4.1.25506.2.75.2.2.18.1.1) |
not-accessible |
INTEGER |
Type of management frames on the radio |
As per the MIB. |
hh3cDot11MngFrmCnt (1.3.6.1.4.1.25506.2.75.2.2.18.1.2) |
read-only |
Counter32 |
Total number of management frames of all types on the radio |
As per the MIB. |
About this table
Use this table to obtain size-based data packet statistics of a radio.
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11APPacketSize.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APPacketSize (1.3.6.1.4.1.25506.2.75.2.2.19.1.1) |
not-accessible |
INTEGER |
sizeLevel1(1), sizeLevel2(2), sizeLevel3(3), sizeLevel4(4) |
Data packet size sizeLevel1(1): size <= 128 sizeLevel2(2): 128 < size <= 512 sizeLevel3(3): 512 < size <= 1024 sizeLevel4(4): size > 1024 |
As per the MIB. |
hh3cDot11APRXPacketSizeCount (1.3.6.1.4.1.25506.2.75.2.2.19.1.2) |
read-only |
Counter64 |
Number of received data packets based on frame size |
As per the MIB. |
hh3cDot11APTXPacketSizeCount (1.3.6.1.4.1.25506.2.75.2.2.19.1.3) |
read-only |
Counter64 |
Number of transmitted data packets based on frame size |
As per the MIB. |
About this table
Use this table to obtain rate-based data packet statistics of a radio.
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11APPacketRate.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APPacketRate (1.3.6.1.4.1.25506.2.75.2.2.20.1.1) |
not-accessible |
Integer32 |
Data rate (twice the actual rate) |
As per the MIB. |
hh3cDot11APRXPacketRateCount (1.3.6.1.4.1.25506.2.75.2.2.20.1.2) |
read-only |
Counter64 |
Number of received data packets based on data rate |
As per the MIB. |
hh3cDot11APTXPacketRateCount (1.3.6.1.4.1.25506.2.75.2.2.20.1.3) |
read-only |
Counter64 |
Number of sent data packets based on data rate |
As per the MIB. |
About this table
Use this table to obtain MCS rate-based data packet statistics of a radio.
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11APPacketMCSRate.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APPacketMCSRate (1.3.6.1.4.1.25506.2.75.2.2.21.1.1) |
not-accessible |
Integer32 |
Data rate for transmitted data (twice the actual rate) |
As per the MIB. |
hh3cDot11APRXPacketMCSRateCount (1.3.6.1.4.1.25506.2.75.2.2.21.1.2) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APTXPacketMCSRateCount (1.3.6.1.4.1.25506.2.75.2.2.21.1.3) |
read-only |
Counter64 |
Number of transmitted data packets based on data rate |
As per the MIB. |
About this table
Use this table to obtain association failure statistics of each AP.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APAssocFailStatis3SRCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.1) |
read-only |
Counter32 |
Number of association failures due to insufficient resources |
As per the MIB. |
hh3cDot11APAssocFailStatis3NSRCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.2) |
read-only |
Counter32 |
Number of association failures due to unsupported rate settings |
As per the MIB. |
hh3cDot11APAssocFailStatis3URCCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.3) |
read-only |
Counter32 |
Number of association failures due to unknown reason codes |
As per the MIB. |
hh3cDot11APAssocFailStatis3RFCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.4) |
read-only |
Counter32 |
Number of association failures due to reassociation failures |
As per the MIB. |
hh3cDot11APAssocFailStatis3OtherCnt (1.3.6.1.4.1.25506.2.75.2.2.22.1.5) |
read-only |
Counter32 |
Number of association failures due to reasons other than the 802.11 protocol |
As per the MIB. |
hh3cDot11APAssocFailStatis3RSSILowCntCM (1.3.6.1.4.1.25506.2.75.2.2.22.1.6) |
read-only |
Counter32 |
Number of association failures due to low RSSI |
As per the MIB. |
About this table
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID and hh3cDot11APIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APIfInPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.1) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfInNormalPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.2) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfInErrorPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.3) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfOutPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.4) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfInOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.5) |
read-only |
Counter64 |
Total bytes received on this interface |
As per the MIB. |
hh3cDot11APIfOutOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.6) |
read-only |
Counter64 |
Total bytes sent on this interface |
As per the MIB. |
hh3cDot11APIfFlowOut2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.7) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cDot11APIfFlowIN2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.8) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cDot11APIfInUcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.9) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfInNUcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.10) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfInDiscardPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.11) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfOutUcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.12) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfOutNUcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.13) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfOutDiscardPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.14) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfOutErrorPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.15) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfUpdownTimes2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.16) |
read-only |
Counter32 |
Number of times this interface has been opened/closed |
As per the MIB. |
hh3cDot11APIfStatusKeepTime2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.17) |
read-only |
TimeTicks |
Time of the last status change on this interface |
As per the MIB. |
hh3cDot11APIfOperStatus2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.18) |
read-only |
INTEGER |
Operating state of this interface |
As per the MIB. |
hh3cDot11APIfInBrdcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.19) |
read-only |
Counter64 |
Total number of broadcast data packets received on this interface |
As per the MIB. |
hh3cDot11APIfOutBrdcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.20) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfInMulcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.21) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfOutMulcastPkts2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.22) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfInPayloadOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.23) |
read-only |
Counter64 |
Actual bytes received on this interface |
As per the MIB. |
hh3cDot11APIfOutPayloadOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.24) |
read-only |
Counter64 |
Actual bytes sent on this interface |
As per the MIB. |
hh3cDot11APIfInDataOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.25) |
read-only |
Counter64 |
Actual data bytes received on this interface |
As per the MIB. |
hh3cDot11APIfOutDataOctets2 (1.3.6.1.4.1.25506.2.75.2.2.23.1.26) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APIfAdminStatus (1.3.6.1.4.1.25506.2.75.2.2.23.1.27) |
read-write |
INTEGER |
up(1) down(2) testing(3) |
Expected state of this interface. In the testing state, the interface does not forward any operand packets. When the management system is initialized, all interfaces start with hh3cDot1APIfAdminStatus and are in the down state. As a result of explicit management operations or as a result of each profile reserved by the management system, hh3cDot1APIfAdminStatus is then changed to the up state or testing state, or remains in the down state |
As per the MIB. |
hh3cDot11APIfOperStatusCM (1.3.6.1.4.1.25506.2.75.2.2.23.1.28) |
read-only |
INTEGER |
up(1) down(2) testing(3) admindown(4) |
As per the MIB. |
hh3cDot11APUserSecAuthStatisTable
About this table
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APUserAuthCurNumber (1.3.6.1.4.1.25506.2.75.2.2.24.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Current number of users using this AP for identity verification |
As per the MIB. |
hh3cDot11APUserConnFailCnt (1.3.6.1.4.1.25506.2.75.2.2.24.1.2) |
read-only |
Counter32 |
Total number of users disconnected from this AP |
As per the MIB. |
hh3cDot11APUserAuthReqCnt (1.3.6.1.4.1.25506.2.75.2.2.24.1.3) |
read-only |
Counter32 |
Total number of user identity verification requests using this AP |
As per the MIB. |
hh3cDot11APUserAuthSuccCnt (1.3.6.1.4.1.25506.2.75.2.2.24.1.4) |
read-only |
Counter32 |
Total number of users successfully verified through this AP |
As per the MIB. |
hh3cDot11APUserAuthFailCnt (1.3.6.1.4.1.25506.2.75.2.2.24.1.5) |
read-only |
Counter32 |
Total number of user identity verification failures for this AP |
As per the MIB. |
hh3cDot11AllUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.24.1.6) |
read-only |
TimeTicks |
Uptime of all users successfully verified through this AP |
As per the MIB. |
hh3cDot11APUserInfoStatisTable
About this table
Use this table to obtain user information for this AP.
Read:Supported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APUserMacAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APUserMacAddr (1.3.6.1.4.1.25506.2.75.2.2.25.1.1) |
not-accessible |
MacAddress |
MacAddress(6) |
MAC address of the user logging into this AP |
As per the MIB. |
hh3cDot11APUserIpAddr (1.3.6.1.4.1.25506.2.75.2.2.25.1.2) |
read-only |
IpAddress |
IP address of the user logging into this AP |
As per the MIB. |
hh3cDot11APUserLoginName (1.3.6.1.4.1.25506.2.75.2.2.25.1.3) |
read-only |
OCTET STRING |
Login name of the user logging into this AP |
As per the MIB. |
hh3cDot11APUserLoginTime (1.3.6.1.4.1.25506.2.75.2.2.25.1.4) |
read-only |
OCTET STRING |
Login time of the user using this AP |
As per the MIB. |
hh3cDot11APUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.25.1.5) |
read-only |
TimeTicks |
Uptime of the user of this AP |
As per the MIB. |
hh3cDot11APUserLoginNameCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.6) |
read-only |
OCTET STRING |
As per the MIB. |
hh3cDot11APUserAuthTypeCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.7) |
read-only |
INTEGER |
authFree(1), associateAuth(2), portalAuth(3), autoAuth(4) |
Authentication type of the user with this AP |
As per the MIB. |
hh3cDot11APUserTxPacketCntCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.8) |
read-only |
Counter32 |
Total number of packets sent to online users |
As per the MIB. |
hh3cDot11APUserTxBytesCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.9) |
read-only |
Counter64 |
Total bytes sent to online users |
As per the MIB. |
hh3cDot11APUserRxPacketCntCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.10) |
read-only |
Counter32 |
Total number of packets received from online users |
As per the MIB. |
hh3cDot11APUserRxBytesCM (1.3.6.1.4.1.25506.2.75.2.2.25.1.11) |
read-only |
Counter64 |
Total bytes received from online users |
As per the MIB. |
hh3cDot11APReassocStatis2Table
About this table
Use this table to obtain reassociation statistics for each AP.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APReassocFailStatis2Cnt (1.3.6.1.4.1.25506.2.75.2.2.26.1.1) |
read-only |
Counter32 |
Number of times re-association failed due to insufficient resources |
As per the MIB. |
hh3cDot11TrafficTable
About this table
Use this table to obtain SSID-based user traffic information.
Read:Supported
Columns
The table index is hh3cDot11SSIDIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11SSIDIndex (1.3.6.1.4.1.25506.2.75.2.2.27.1.1) |
not-accessible |
OCTET STRING |
SSID |
As per the MIB. |
hh3cDot11UpPacketNumber (1.3.6.1.4.1.25506.2.75.2.2.27.1.2) |
read-only |
Counter64 |
Packets of the uplink |
As per the MIB. |
hh3cDot11UpByteNumber (1.3.6.1.4.1.25506.2.75.2.2.27.1.3) |
read-only |
Counter64 |
Bytes of the uplink |
As per the MIB. |
hh3cDot11DownPacketNumber (1.3.6.1.4.1.25506.2.75.2.2.27.1.4) |
read-only |
Counter64 |
Data packets of the downlink |
As per the MIB. |
hh3cDot11DownByteNumber (1.3.6.1.4.1.25506.2.75.2.2.27.1.5) |
read-only |
Counter64 |
Bytes of the downlink |
As per the MIB. |
hh3cDot11APEchoStatisTable
About this table
Use this table to obtain AP response statistics information.
Edit/Modify:Not supported
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APEchoAvgDelay (1.3.6.1.4.1.25506.2.75.2.2.28.1.1) |
read-only |
Integer32 |
Average delay time of AP heartbeat messages, in milliseconds |
As per the MIB. |
hh3cDot11APEchoRequestCnt (1.3.6.1.4.1.25506.2.75.2.2.28.1.2) |
read-only |
Counter64 |
Number of AP heartbeat request messages |
As per the MIB. |
hh3cDot11APEchoRespLossCnt (1.3.6.1.4.1.25506.2.75.2.2.28.1.3) |
read-only |
Counter64 |
Number of dropped AP heartbeat response messages |
As per the MIB. |
hh3cDot11APUserSecAuthTypeStatisTable
About this table
Use this table to obtain statistics information on user authentication types for this AP.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APPortalOnlineUserNum (1.3.6.1.4.1.25506.2.75.2.2.29.1.1) |
read-only |
Integer32 |
Number of online users of the AP portal, including MAC-trigger and IMSIAuth users |
As per the MIB. |
hh3cDot11APAuthFreeOnlineUserNum (1.3.6.1.4.1.25506.2.75.2.2.29.1.2) |
read-only |
read-only |
Number of free users online through this AP for identity verification |
As per the MIB. |
hh3cDot11APAssocAuthOnlineUserNum (1.3.6.1.4.1.25506.2.75.2.2.29.1.3) |
read-only |
Integer32 |
Number of online users authenticated through association authentication with this AP, excluding automatic authentication users |
As per the MIB. |
hh3cDot11APMacAuthOnlineUserNum (1.3.6.1.4.1.25506.2.75.2.2.29.1.4) |
read-only |
Integer32 |
Number of MAC address online users authenticated by this AP |
As per the MIB. |
hh3cDot11APAllPortalUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.29.1.5) |
read-only |
TimeTicks |
Uptime of all user portals using this AP for identity verification |
As per the MIB. |
hh3cDot11APAllAuthFreeUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.29.1.6) |
read-only |
TimeTicks |
Uptime of all users authenticated through this AP |
As per the MIB. |
hh3cDot11APAllAssocAuthUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.29.1.7) |
read-only |
TimeTicks |
Uptime of all authenticated users associated with this AP |
As per the MIB. |
hh3cDot11APAllMacAuthUserOnlineTime (1.3.6.1.4.1.25506.2.75.2.2.29.1.8) |
read-only |
TimeTicks |
Uptime of all users' MAC addresses authenticated by this AP |
As per the MIB. |
hh3cDot11APPortalUserLostCnntCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.9) |
read-only |
Counter32 |
Disconnections of user portals using this AP for identity verification |
As per the MIB. |
hh3cDot11APAuthFreeUserLostCnntCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.10) |
read-only |
Counter32 |
Disconnections of idle users authenticated with this AP |
As per the MIB. |
hh3cDot11APAssocAuthUserLostCnntCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.11) |
read-only |
Counter32 |
Disconnections associated with users authenticated with this AP |
As per the MIB. |
hh3cDot11APMacAuthUserLostCnntCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.12) |
read-only |
Counter32 |
Disconnections of user MAC addresses authenticated with this AP |
As per the MIB. |
hh3cDot11APPortalAuthReqCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.13) |
read-only |
Counter32 |
Requests of user portals using this AP for identity verification |
As per the MIB. |
hh3cDot11APAssocAuthReqCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.14) |
read-only |
Counter32 |
Requests associated with users authenticated with this AP |
As per the MIB. |
hh3cDot11APMacAuthReqCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.15) |
read-only |
Counter32 |
Requests of user MAC addresses authenticated through this AP |
As per the MIB. |
hh3cDot11APPortalAuthSucCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.16) |
read-only |
Counter32 |
Number of user portals successfully authenticated through this AP |
As per the MIB. |
hh3cDot11APAssocAuthSucCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.17) |
read-only |
Counter32 |
Number of users successfully authenticated through this AP |
As per the MIB. |
hh3cDot11APMacAuthSucCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.18) |
read-only |
Counter32 |
Number of user MAC addresses successfully authenticated through this AP |
As per the MIB. |
hh3cDot11APPortalAuthReqFailCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.19) |
read-only |
Counter32 |
Number of user portals failed to authenticate through this AP |
As per the MIB. |
hh3cDot11APAssocAuthReqFailCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.20) |
read-only |
Counter32 |
Number of users failed to authenticate through this AP |
As per the MIB. |
hh3cDot11APMacAuthReqFailCnt (1.3.6.1.4.1.25506.2.75.2.2.29.1.21) |
read-only |
Counter32 |
Number of user MAC addresses failed to authenticate through this AP |
As per the MIB. |
hh3cDot11APAutoAuthOnlineUserNumCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.22) |
read-only |
Integer32 |
Number of online users for automatic authentication using this AP |
As per the MIB. |
hh3cDot11APAllAutoAuthUserOnlineTimeCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.23) |
read-only |
TimeTicks |
Uptime of users for automatic authentication using this AP |
As per the MIB. |
hh3cDot11APAutoAuthUserLostCnntCntCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.24) |
read-only |
Counter32 |
Disconnections of automatic authentication users |
As per the MIB. |
hh3cDot11APAutoAuthReqCntCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.25) |
read-only |
Counter32 |
Requests of automatic authentication requests using this AP |
As per the MIB. |
hh3cDot11APAutoAuthSucCntCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.26) |
read-only |
Counter32 |
Number of successful automatic identity verifications using this AP |
As per the MIB. |
hh3cDot11APAutoAuthReqFailCntCM (1.3.6.1.4.1.25506.2.75.2.2.29.1.27) |
read-only |
Counter32 |
Number of failed automatic authentication requests using this AP |
As per the MIB. |
hh3cDot11RadioRxStatis64Table
About this table
Use this table to obtain the Rx statistics about each radio on the specified AP.
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID and hh3cDot11RadioID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11Rx64FrameDupCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.1) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64FrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.2) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64UcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.3) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64BcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.4) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64McastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.5) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64DiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.6) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64FragCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.7) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64FcsErrCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.8) |
read-only |
Counter64 |
Number of FCS errored frames received by the radio |
As per the MIB. |
hh3cDot11Rx64FrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.9) |
read-only |
Counter64 |
Bytes of frames received by the radio |
As per the MIB. |
hh3cDot11Rx64UcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.10) |
read-only |
Counter64 |
Bytes of unicast frames received by the radio |
As per the MIB. |
hh3cDot11Rx64BcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.11) |
read-only |
Counter64 |
Bytes of broadcast frames received by the radio |
As per the MIB. |
hh3cDot11Rx64McastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.12) |
read-only |
Counter64 |
Bytes of multicast frames received by the radio |
As per the MIB. |
hh3cDot11Rx64DiscardFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.13) |
read-only |
Counter64 |
Bytes of frames discarded by the radio |
As per the MIB. |
hh3cDot11Rx64MgmtFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.14) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64CtrlFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.15) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64DataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.16) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64DecryptErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.17) |
read-only |
Counter64 |
Number of decryption errors by the radio |
As per the MIB. |
hh3cDot11Rx64AuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.18) |
read-only |
Counter64 |
Number of identity verification frames received by the radio |
As per the MIB. |
hh3cDot11Rx64AssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.19) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Rx64PhyErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.20) |
read-only |
Counter64 |
Number of physical receive errors by the radio |
As per the MIB. |
hh3cDot11Rx64MICErrorCnt (1.3.6.1.4.1.25506.2.75.2.2.30.1.21) |
read-only |
Counter64 |
Number of MIC verification errors by the radio |
As per the MIB. |
hh3cDot11Rx64DataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.22) |
read-only |
Counter64 |
Bytes of data frames received by the radio |
As per the MIB. |
hh3cDot11Rx64PayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.30.1.23) |
read-only |
Counter64 |
Payload bytes of data frames received by the radio |
As per the MIB. |
hh3cDot11Rx64DataFrameBytesCM (1.3.6.1.4.1.25506.2.75.2.2.30.1.24) |
read-only |
Counter64 |
Number of data frames received by the radio (excluding retransmitted frames) |
As per the MIB. |
hh3cDot11RadioTxStatis64Table
About this table
Use this table to obtain the Tx statistics data for each radio of the specified AP.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11Tx64FragCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.1) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64FailedCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.2) |
read-only |
Counter64 |
Number of transmission failures by the radio |
As per the MIB. |
hh3cDot11Tx64RetryCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.3) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64MultiRetryCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.4) |
read-only |
Counter64 |
Number of multiple retransmissions needed by the radio |
As per the MIB. |
hh3cDot11Tx64RtsSuccessCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.5) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64RtsFailCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.6) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64AckFailCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.7) |
read-only |
Counter64 |
Number of acknowledgment failures by the radio |
As per the MIB. |
hh3cDot11Tx64TxFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.8) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64UcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.9) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64BcastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.10) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64McastFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.11) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64DiscardFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.12) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64FrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.13) |
read-only |
Counter64 |
Total bytes of frames transmitted by the radio |
As per the MIB. |
hh3cDot11Tx64UcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.14) |
read-only |
Counter64 |
Bytes of unicast frames transmitted by the radio |
As per the MIB. |
hh3cDot11Tx64BcastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.15) |
read-only |
Counter64 |
Bytes of broadcast frames transmitted by the radio |
As per the MIB. |
hh3cDot11Tx64McastFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.16) |
read-only |
Counter64 |
Bytes of multicast frames transmitted by the radio |
As per the MIB. |
hh3cDot11Tx64DiscardFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.17) |
read-only |
Counter64 |
Bytes of discarded frames transmitted by the radio |
As per the MIB. |
hh3cDot11Tx64AuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.18) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64AssociateFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.19) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64DataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.20) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64DataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.21) |
read-only |
Counter64 |
Bytes of data frames transmitted by the radio |
As per the MIB. |
hh3cDot11Tx64MSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.22) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64DiscardMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.23) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64RetryMSDUCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.24) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64PayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.31.1.25) |
read-only |
Counter64 |
Payload bytes of data frames transmitted by the radio |
As per the MIB. |
hh3cDot11Tx64MgtFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.36) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64CtrlFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.37) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11Tx64MACErrCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.38) |
read-only |
Counter64 |
Number of MAC errored frames transmitted by the radio |
As per the MIB. |
hh3cDot11Tx64ErrFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.31.1.39) |
read-only |
Counter64 |
Number of transmission errored frames by the radio |
As per the MIB. |
hh3cDot11BSSRxStatis64Table
About this table
Use this table to obtain Rx statistics for a specific BSS on the radio.
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11WlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11BSSRx64FrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.1) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11BSSRx64FrameBytes (1.3.6.1.4.1.25506.2.75.2.2.32.1.2) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11BSSRx64DataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.3) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11BSSRx64DataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.32.1.4) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11BSSRx64AssocFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.5) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11BSSRx64PayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.32.1.6) |
read-only |
Counter64 |
Number of payload bytes of data frames received by this BSS |
As per the MIB. |
hh3cDot11BSSRx64UniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.7) |
read-only |
Counter64 |
Number of unicast frames received by the BSS. |
As per the MIB. |
hh3cDot11BSSRx64NonUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.8) |
read-only |
Counter64 |
Number of non-unicast frames received by the BSS. |
As per the MIB. |
hh3cDot11BSSRx64AuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.32.1.9) |
read-only |
Counter64 |
Number of authentication frames received by the BSS. |
As per the MIB. |
hh3cDot11BSSTxStatis64Table
About this table
Use this table to obtain Tx statistics for a specific BSS on the radio.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11BSSTx64FrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.1) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11BSSTx64FrameBytes (1.3.6.1.4.1.25506.2.75.2.2.33.1.2) |
read-only |
Counter64 |
Total bytes of frames transmitted by this BSS |
As per the MIB. |
hh3cDot11BSSTx64DataFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.3) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11BSSTx64DataFrameBytes (1.3.6.1.4.1.25506.2.75.2.2.33.1.4) |
read-only |
Counter64 |
Bytes of data frames transmitted using this BSS |
As per the MIB. |
hh3cDot11BSSTx64AssocFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.5) |
read-only |
Counter64 |
Number of frame transmissions associated with this BSS |
As per the MIB. |
hh3cDot11BSSTx64PayloadBytes (1.3.6.1.4.1.25506.2.75.2.2.33.1.6) |
read-only |
Counter64 |
Bytes of payload bytes transmitted using this BSS |
As per the MIB. |
hh3cDot11BSSTx64RetryCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.7) |
read-only |
Counter64 |
Bytes of retransmissions using this BSS |
As per the MIB. |
hh3cDot11BSSTx64UniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.8) |
read-only |
Counter64 |
Number of unicast frames transmitted by this BSS |
As per the MIB. |
hh3cDot11BSSTx64NonUniFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.9) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11BSSTx64AuthenFrameCnt (1.3.6.1.4.1.25506.2.75.2.2.33.1.10) |
read-only |
Counter64 |
As per the MIB. |
hh3cDot11APPacketMCSRateStatis2Table
About this table
Read:Supported
Columns
The table indexes are hh3cDot11CurAPID, hh3cDot11RadioID, and hh3cDot11APPacketMCS2Rate.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APPacketMCS2Rate (1.3.6.1.4.1.25506.2.75.2.2.34.1.1) |
not-accessible |
Integer32 |
Integer32(1.. 2000000000) |
Data rate for transmission (actual rate for tenfold) |
As per the MIB. |
hh3cDot11APRXPacketRate2Count (1.3.6.1.4.1.25506.2.75.2.2.34.1.2) |
read-only |
Counter64 |
Number of received data packets based on data rate for transmission |
As per the MIB. |
hh3cDot11APTXPacketRate2Count (1.3.6.1.4.1.25506.2.75.2.2.34.1.3) |
read-only |
Counter64 |
Number of sent data packets based on data rate for transmission |
As per the MIB. |
hh3cDot11APUserSecAuthStatisCMTable
About this table
Use this table to obtain user authentication statistics.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APUserConnFailCntCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.1) |
read-only |
Counter32 |
Number of failed connections by users using this AP |
As per the MIB. |
hh3cDot11APUserAuthReqCntCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.2) |
read-only |
Counter32 |
Total number of identity verification requests by users using this AP |
As per the MIB. |
hh3cDot11APUserAuthSuccCntCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.3) |
read-only |
Counter32 |
Total number of successful user identity verifications using this AP |
As per the MIB. |
hh3cDot11APUserAuthFailCntCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.4) |
read-only |
Counter32 |
Total number of failed user identity verifications by this AP |
As per the MIB. |
hh3cDot11AllUserOnlineTimeCM (1.3.6.1.4.1.25506.2.75.2.2.35.1.5) |
read-only |
TimeTicks |
Total uptime of all users using this AP |
As per the MIB. |
hh3cDot11APUserInfoStatis2CMTable
About this table
Use this table to obtain statistics information on authenticated users of this AP.
Read:Supported
Columns
The table index is hh3cDot11CurAPID, hh3cDot11APUserMacAddr2CM.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APUserMacAddr2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.1) |
not-accessible |
MacAddress |
MacAddress(6) |
MAC address of the authenticated user logged into this AP. |
As per the MIB. |
hh3cDot11APUserIpAddr2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.2) |
read-only |
IpAddress |
IP address of the authenticated user logged into this AP. |
As per the MIB. |
hh3cDot11APUserLoginName2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.3) |
read-only |
OCTET STRING |
Login name of the authenticated user logged into this AP. |
As per the MIB. |
hh3cDot11APUserLoginTime2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.4) |
read-only |
OCTET STRING |
Login time of the authenticated user for this AP. |
As per the MIB. |
hh3cDot11APUserOnlineTime2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.5) |
read-only |
TimeTicks |
Uptime of the authenticated user. |
As per the MIB. |
hh3cDot11APUserAuthType2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.6) |
read-only |
INTEGER |
Authentication type of the user with this AP. |
As per the MIB. |
hh3cDot11APUserTxPacketCnt2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.7) |
read-only |
Counter32 |
Reflects the total number of packets sent to online users. |
As per the MIB. |
hh3cDot11APUserTxBytes2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.8) |
read-only |
Counter64 |
Total bytes sent to online users. |
As per the MIB. |
hh3cDot11APUserRxPacketCnt2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.9) |
read-only |
Counter32 |
Total number of packets received from online users. |
As per the MIB. |
hh3cDot11APUserRxBytes2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.10) |
read-only |
Counter64 |
Total bytes received from online users. |
As per the MIB. |
hh3cDot11APUserIPv6Addr2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.11) |
read-only |
OCTET STRING |
IPv6 address of the online user. |
As per the MIB. |
hh3cDot11APUserMac2CM (1.3.6.1.4.1.25506.2.75.2.2.36.1.12) |
read-only |
MacAddress |
MacAddress(6) |
As per the MIB. |
hh3cDot11APUserInCirValueCM (1.3.6.1.4.1.25506.2.75.2.2.36.1.13) |
read-only |
Counter32 |
CIR for the inbound direction of this user. |
As per the MIB. |
hh3cDot11APUserOutCirValueCM (1.3.6.1.4.1.25506.2.75.2.2.36.1.14) |
read-only |
Counter32 |
CIR for the outbound direction of this user. |
As per the MIB. |
hh3cDot11APElementTable
About this table
Use this table to obtain AP template information.
Read:Supported
Columns
The table index is hh3cDot11APElementIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APElementIndex (1.3.6.1.4.1.25506.2.75.12.1.1.1.1) |
not-accessible |
Integer32 |
Index of this AP element |
As per the MIB. |
hh3cDot11APElementTemplateName (1.3.6.1.4.1.25506.2.75.12.1.1.1.2) |
read-only |
OCTET STRING |
Template name of this AP element |
As per the MIB. |
hh3cDot11APElementSerialID (1.3.6.1.4.1.25506.2.75.12.1.1.1.3) |
read-only |
OCTET STRING |
Serial ID of this AP element |
As per the MIB. |
hh3cDot11APElementModelAlias (1.3.6.1.4.1.25506.2.75.2.2.34.1.3) |
read-only |
OCTET STRING |
Alias of the model name of this AP element |
As per the MIB. |
Notifications
hh3cDot11APMtCfgErrorTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.2 |
AP configuration error |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This notification is generated when an error occurs during AP configuration on the AC.
System impact
Configuration deployment fails.
Status control
ON
CLI: snmp-agent trap enable wlan ap
OFF
CLI: undo snmp-agent trap enable wlan ap
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.2.1.1.1.1 (hh3cDot11APID) |
Serial number of the AP |
N/A |
Hh3cDot11ObjectIDType |
OCTET STRING (0..127) |
1.3.6.1.4.1.25506.2.75.2.1.3.1.2 (hh3cDot11RadioID) |
Radio ID |
N/A |
Integer32 |
Integer32(0..2147483647) |
1.3.6.1.4.1.25506.2.75.2.3.1.1 (hh3cDot11APMtTrapCfgErrReason) |
Reason |
N/A |
Hh3cDot11NotifyReasonType |
OCTET STRING(0..255) |
Recommended action
No action is required.
hh3cDot11APMtRadioFailTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.3 |
AP radio down |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.4 (hh3cDot11APMtRadioFailRecoverTrap) |
OFF |
When the AC receives the update configuration response message, if the configuration update fails, and the reason is the failure to set the channel, failure to set the RD status, failure to set the hardware retrys, failure to set the beacon interval, failure to set the RD operating mode, or failure to set the preamble, it sends this trap.
System impact
Radio is unavailable.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING(0..127) |
Radio ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.2 (hh3cDot11APMtTrapRadioFailReason) |
Reason for the down event |
N/A |
INTEGER |
config(1) , hh3cerror(2) , swerror(3) , radar(4) , unknown(8) |
Recommended action
Redeploy the configuration.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.4 |
AP radio up |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when a radio comes up.
System impact
Radio is available.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Radio ID |
N/A |
Integer32 |
N/A |
INTEGER |
Recommended action
hh3cDot11APMtRdoChanlChgTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.5 |
Radio channel change |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the channel of a radio changes.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Radio ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.5 (hh3cDot11APChannelChgMode) |
Channel type change |
N/A |
Hh3cDot11RFModeType |
manual(1),, auto(2) |
1.3.6.1.4.1.25506.2.75.2.3.1.3 (hh3cDot11APMtTrapOldChannel) |
Previous channel number |
N/A |
Hh3cDot11ChannelScopeType |
Integer32, Standard MIB values. |
1.3.6.1.4.1.25506.2.75.2.3.1.4 (hh3cDot11APMtTrapNewChannel) |
New channel number |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.16 (hh3cDot11APMtChanlChgCount) |
Number of changes |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.24 (hh3cDot11APMtTrapAPMacAddress) |
Corresponding MAC |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
hh3cDot11APMtTimeSynFail
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.6 |
AP clock synchronization failed |
Informational |
Warning |
N/A (N/A) |
OFF |
AC will regularly send clock synchronization requests to all successfully registered APs. If no corresponding response is received, the system will send a "clock synchronization alarm." Only when the AC sends update config to the AP will it carry a timestamp. If the AP response times out, this alarm will be triggered. In other cases, the AP will not respond to this timestamp.
Possible causes include:
If the master AC sends an update config message at master/backup AC switchover, this notification is sent.
When setting echo-interval, the AC will send an update config to the AP, at which point the AP will respond, thus not meeting the alarm sending condition; If the AP is disconnected and then echo-interval is set again, the AP response will inevitably time out, triggering the alarm.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Recommended action
hh3cDot11APMtChlIntfDetected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.7 |
Channel interference detected |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the AP detects interference.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan rrm command.
OFF
CLI: Use the undo snmp-agent trap enable wlan rrm command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.2.1.3.1.5 (hh3cDot11Channel) |
Channel |
N/A |
Integer32 |
Recommended action
hh3cDot11APMtIntfAPDetected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.8 |
AP detected |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.16 (hh3cDot11APInterfClearTrap) |
OFF |
This notification is generated when the system detects the presence of wireless APs.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Channel |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.7 (hh3cDot11APIntfDevMACAddress) |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
hh3cDot11APFlashWriteFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.11 |
AP flash write-in failed |
Informational |
Major |
N/A (N/A) |
OFF |
This alarm is generated if the AP fails to write data into the flash.
System impact
Failed to update the AP version.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.17 (hh3cDot11APMtFormerApVersion) |
Original version number |
N/A |
OCTET STRING |
OCTET STRING |
MAC address of the AP |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
Identify whether the issue is caused by insufficient memory or insufficient flash.
hh3cDot11APMtAvailChlTooLow
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.13 |
Low number of available channels |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.27 (hh3cDot11DFSFreeCntBelowThrRecov) |
OFF |
When an AP performs auto channel selection and all detected channels are in a bad condition, this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Radio ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.18 (hh3cDot11APMtAPID) |
AP Identifier |
N/A |
OCTET STRING(1..127) |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
hh3cDot11APImgDwldSuccess
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.14 |
AP image downloading succeeded |
Informational |
Warning |
N/A (N/A) |
OFF |
If the versions of AP and AC do not match, the AP will automatically download the version. When the version download is complete, the AC will send this alarm.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.2.1.2.1.8 (hh3cDot11CurrAPName) |
AP Name |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.2.1.2.1.2 (hh3cDot11CurrAPIPAddress) |
AP IP Address |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.75.2.1.2.1.11 (hh3cDot11CurrAPSoftwareVersion) |
Current version number of AP |
N/A |
OCTET STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.16 |
Co-channel interference from adjacent APs removed |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the AP no longer detects any co-channel AP or when the signal strength of all co-channel APs is less than hh3cDot11IntfTrapThreshold (default value -60dBm).
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Channel |
N/A |
Integer32 |
As stipulated in the 802.11x protocol |
AP Identifier |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.19 (hh3cDot11APMtRadioID) |
Radio ID |
N/A |
Hh3cDot11RadioScopeType |
1.3.6.1.4.1.25506.2.75.2.3.1.21 (hh3cDot11APMtInterfMacAdd) |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
1.3.6.1.4.1.25506.2.75.2.3.1.23 (hh3cDot11APMtFirstTrapTime) |
Timestamp. |
N/A |
Timeticks |
Neighbor MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
hh3cDot11APRadioDownTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.23 |
Wireless link terminated |
Informational |
Major |
1.3.6.1.4.1.25506.2.75.2.3.0.24 (hh3cDot11APRadioDownRecovTrap) |
OFF |
When the radio changes from UP to Down, it will trigger this alarm.
Possible reasons for this alarm include:
AP offline when tunnel is down.
When the radio interface is down, for example, radio disable. (Note: When the radio status changes, such as enabling or disabling the radio, and when the CAPWAP tunnel is disconnected, an alarm will be triggered. Removing the last service template for the radio to delete the AP, but not disabling the radio status, will not trigger this alarm.)
When hwSysTrapCollectionPeriod times out, and the time interval since the last trap transmission exceeds hwSysTrapResendPeriod, this alarm will be sent repeatedly.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Radio ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.12 (hh3cDot11APRadioDownReason) |
N/A |
INTEGER |
phyicalUnusable(1) , configDisable(2) operatinUnusable(3) , apTunnelDown(4) |
N/A |
First occurrence time |
N/A |
TimeTicks |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.24 |
Wireless link recovered |
Informational |
Major |
N/A (N/A) |
OFF |
When the Radio of Ap changes from Down to UP, this alarm will be triggered. After a "wireless link disruption" occurs, if the following conditions happen, the system detects that the air interface can provide wireless service, then sends a "link recovery" alarm:
When the radio interface changes from down to up, for example, radio enable. (Note: This trap is sent when the radio status changes, i.e., enabling a previously disabled radio. However, this alarm is not triggered if the radio is enabled for the first time after the AP comes online.)
System impact
The radio is not available.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Radio ID |
N/A |
Integer32 |
N/A |
INTEGER |
N/A |
N/A |
TimeTicks |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
hh3cDot11APStaFullTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.25 |
Client quantity upper limit reached |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.26 (hh3cDot11APStaFullRecoverTrap) |
OFF |
When the number of clients is about to exceed the maximum value allowed by the AP, this alarm will be triggered.
System impact
Status control
ON
CLI: snmp-agent trap enable wlan client
OFF
CLI: undo snmp-agent trap enable wlan client
Object
OID (object name) |
Index |
Type |
Value range |
APID |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.11 (hh3cDot11StaLimitNumber) |
Maximum number of clients on the AP. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.10 (hh3cDot11StaFullReason) |
Reasons for the number of clients reaching the upper limit |
N/A |
INTEGER |
ap(1), bss(2), radio(3), radioConcur(4), radiopolicy(5), ac(6), acConcur(7), aid(8) |
First alarm time |
N/A |
TimeTicks |
MAC address of the AP. |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
Check the configuration or add more APs.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.26 |
Upper limit-reaching alarm removed for associated client quantity |
Informational |
Warning |
N/A (N/A) |
OFF |
The number of clients dropped below the maximum allowed number. .
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
APID |
N/A |
N/A |
Integer32 |
Reason |
N/A |
INTEGER |
First alarm time |
N/A |
TimeTicks |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.27 |
Alarm removed for low number of available channels |
Informational |
Warning |
N/A (N/A) |
OFF |
If the available channel condition recovers, this alarm will be generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Radio ID |
N/A |
Integer32 |
AP Identifier |
N/A |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
hh3cDot11APTrapUserCntExceedThre
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.32 |
Number of associated clients exceeded the upper limit |
Informational |
Warning |
N/A (N/A) |
OFF |
When the number of terminals on an AP exceeds the set threshold (hh3cDot11APUserThreshold), the system will generate this alarm.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
APID |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.14 (hh3cDot11APTrapUserCnt) |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.15 (hh3cDot11APTrapUserThreshold) |
Threshold for online users of AP |
N/A |
Integer32 |
Recommended action
hh3cDot11APMtDetectedIntfAP
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.33 |
Co-channel interference from adjacent APs |
Informational |
Warning |
OFF |
When the AP detects that the signal strength of the neighboring AP on the same channel is greater than hh3cDot11IntfTrapThreshold (default value is -60dbm), this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
AP Identifier |
N/A |
RADIO |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.20 (hh3cDot11APMtChannel) |
Channel |
N/A |
Integer32 |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Timestamp. |
N/A |
Timeticks |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.36 |
Adjacent-channel interference from adjacent APs |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.37 (hh3cDot11DetcAdjChlIntfAPClear) |
OFF |
The AP detects that there are adjacent frequency channels AP and the signal strength of the adjacent AP is greater than hh3cDot11AdjIntfTrapThreshold (default value is -60dbm), then this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
AP ID |
N/A |
Radio ID |
N/A |
Channel |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.22 (hh3cDot11APMtAdjChannel) |
Neighbor channel |
N/A |
Integer32 |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Timestamp. |
N/A |
Timeticks |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.37 |
Neighbor AP co-channel interference cleared |
Informational |
Warning |
N/A (N/A) |
OFF |
When the AP no longer detects any AP on the same channel or when the signal strength of all APs on the same channel is less than hh3cDot11IntfTrapThreshold (default value is -60dbm), this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
AP Identifier |
N/A |
Radio ID |
N/A |
Channel |
N/A |
Integer32 |
Neighbor channel |
N/A |
Integer32 |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Timestamp. |
N/A |
Timeticks |
Recommended action
