- 12-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-SAVI-MIB
- 15-HH3C-DOT11-WM2U-MIB
- 16-HH3C-DOT11-PROBE-MIB
- 17-HH3C-DOT11S-MESH-MIB
08-HH3C-DOT11-WLANEXT-MIB | 80.74 KB |
About this MIB
Use this MIB to provide extended WLAN information.
MIB file name
hh3c-dot11-wlanext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11WLANEXT(7)
Tabular objects
hh3cDot11RFSignalStatisTable
About this table
This table provides signal strength statistics for each radio frequency of the specified AP.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cDot11RFAPID and hh3cDot11RFRadioID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RFAPID (1.3.6.1.4.1.25506.2.75.7.1.1.1.1) |
not-accessible |
Hh3cDot11ObjectIDType |
OCTET STRING(0..127) |
Unique ID of the running AP. |
As per the MIB. |
hh3cDot11RFRadioID (1.3.6.1.4.1.25506.2.75.7.1.1.1.2) |
not-accessible |
Hh3cDot11RadioScopeType |
Standard MIB values. |
Unique ID of the running AP radio frequency. |
As per the MIB. |
hh3cDot11RFSignalStatisInterv (1.3.6.1.4.1.25506.2.75.7.1.1.1.3) |
read-only |
Integer32 |
Statistics collection interval for the AP radio frequency. |
As per the MIB. |
hh3cDot11RFAverageSignalStrength (1.3.6.1.4.1.25506.2.75.7.1.1.1.4) |
read-only |
Integer32 |
Average signal strength of the AP radio frequency. |
As per the MIB. |
hh3cDot11RFMaxSignalStrength (1.3.6.1.4.1.25506.2.75.7.1.1.1.5) |
read-only |
Integer32 |
Maximum signal strength of the AP radio frequency. |
As per the MIB. |
hh3cDot11RFMinSignalStrength (1.3.6.1.4.1.25506.2.75.7.1.1.1.6) |
read-only |
Integer32 |
Minimum signal strength of the AP radio frequency. |
As per the MIB. |
hh3cDot11QosStatisTable
About this table
This table defines the radio QoS settings.
Read:Supported
Columns
The table indexes are hh3cDot11QosAPID and hh3cDot11QosRadioID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11QosAPID (1.3.6.1.4.1.25506.2.75.7.2.1.1.1) |
not-accessible |
OCTET STRING (0..127) |
As per the MIB. |
hh3cDot11QosRadioID (1.3.6.1.4.1.25506.2.75.7.2.1.1.2) |
not-accessible |
Radio ID. |
As per the MIB. |
hh3cDot11QosAverageQueLen (1.3.6.1.4.1.25506.2.75.7.2.1.1.3) |
read-only |
Integer32 |
Average number of frames transmitted to the queue. |
As per the MIB. |
hh3cDot11QosDropFrameRatio (1.3.6.1.4.1.25506.2.75.7.2.1.1.4) |
read-only |
Integer32 |
Ratio of frames dropped per minute after the queue was filled. |
As per the MIB. |
hh3cDot11QosAverageDataRate (1.3.6.1.4.1.25506.2.75.7.2.1.1.5) |
read-only |
Integer32 |
Average data transmission rate. |
As per the MIB. |
hh3cDot11QosAcStatisTable
About this table
This table defines the access-type QoS settings.
Read:Supported
Columns
The table indexes are hh3cDot11QosAPID, hh3cDot11QosRadioID, and hh3cDot11QosAcType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11QosAcType (1.3.6.1.4.1.25506.2.75.7.2.2.1.1) |
not-accessible |
Hh3cDot11QosAcType |
acbk(1), acbe(2), acvi(3), acvo(4) |
Access type. |
As per the MIB. |
hh3cDot11AcDropFrameCnt (1.3.6.1.4.1.25506.2.75.7.2.2.1.2) |
read-only |
Counter32 |
Number of frames dropped per minute after the queue was filled. |
As per the MIB. |
