12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R54xx)-6W10012-WLAN
11-HH3C-DOT11-QOS-MIB
11-HH3C-DOT11-QOS-MIB 106.39 KB
HH3C-DOT11-QOS-MIB
About this MIB
Use this MIB to configure and obtain WLAN QoS configuration information.
MIB file name
hh3c-dot11-qos.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11QoS(9)
Scalar objects
hh3cDot11WmmResetRadioByAP (1.3.6.1.4.1.25506.2.75.9.1.4.1)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Standard MIB values.
Clear WMM statistics for an AP or all radios. This object has the same meaning as hh3cDot11APElementIndex, which represents the index an AP. If this object is set to 0xFFFFFFFF, WMM statistics for all radios are cleared. For a GET operation, this object can only be 0.
As per the MIB.
hh3cDot11WmmResetStationByAP (1.3.6.1.4.1.25506.2.75.9.1.4.2)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Clear WMM statistics for an AP or all clients. This node has the same meaning as hh3cDot11APElementIndex, which represents the index an AP. If this object is set to 0xFFFFFFFF, WMM statistics for all clients are cleared. For a GET operation, this object can only be 0.
As per the MIB.
Tabular objects
hh3cDot11RadioWmmCfgTable
About this table
Use this table to define WMM basic parameters.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11WmmRadioIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11WmmRadioIndex (1.3.6.1.4.1.25506.2.75.9.1.1.1.1)
not-accessible
Hh3cDot11RadioElementIndex
Radio index.
As per the MIB.
hh3cDot11RadioWmmEnabled (1.3.6.1.4.1.25506.2.75.9.1.1.1.2)
read-write
TruthValue
true(1),
false(2)
WMM state.
As per the MIB.
hh3cDot11RadioSVPMapToAC (1.3.6.1.4.1.25506.2.75.9.1.1.1.3)
read-write
Hh3cDot11WMMSVPMapAC
acbk(1),
acbe(2),
acvi(3),
acvo(4),
disable(5)
AC queue assigned to SVP packets.
As per the MIB.
hh3cDot11RadioCacPolicy (1.3.6.1.4.1.25506.2.75.9.1.1.1.4)
read-write
Hh3cDot11WMMCACPolicy
channelUtilization(1),
userNumber(2)
CAC admission policy. CAC requires a client to obtain permission from an AP before it can use a high-priority AC for transmission. This guarantees bandwidth for the clients that have gained access. CAC controls real time traffic (AC-VO and AC-VI traffic) but not common data traffic (AC-BE and AC-BK traffic).
As per the MIB.
hh3cDot11RadioCacChlUtlValue (1.3.6.1.4.1.25506.2.75.9.1.1.1.5)
read-write
Integer32
Integer32(0..100)
Maximum channel usage. When hh3cDot11RadioCacPolicy is ChannelUtilization, this object can be set.
As per the MIB.
hh3cDot11RadioCacUserNum (1.3.6.1.4.1.25506.2.75.9.1.1.1.6)
read-write
Integer32
Integer32(0..124)
Maximum number of clients allowed to be connected. When hh3cDot11RadioCacPolicy is userNumber, this object can be set.
As per the MIB.
hh3cDot11RadioWmmEdcaCfgTable
About this table
Use this table to define EDCA basic parameters.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11WmmRadioIndex and hh3cDot11RadioWmmAC.
Object (OID)
Access
Value range
Implementation
hh3cDot11RadioWmmAC (1.3.6.1.4.1.25506.2.75.9.1.2.1.1)
not-accessible
Hh3cDot11QosAcType
acbk(1),
acbe(2),
acvi(3),
acvo(4)
AC queue.
As per the MIB.
hh3cDot11RadioWmmAifsn (1.3.6.1.4.1.25506.2.75.9.1.2.1.2)
read-write
Integer32
Integer32 (1..15)
Arbitration inter-frame spacing number (AIFSN). The value range of this object varies by chip capability.
As per the MIB.
hh3cDot11RadioWmmEcwMin (1.3.6.1.4.1.25506.2.75.9.1.2.1.3)
read-write
Integer32
Integer32(0..15)
Exponent form of CWmin (ECWmin). The value range of this object varies by chip capability. The value of ECWmin must be smaller than the value of ECWmax.
As per the MIB.
hh3cDot11RadioWmmEcwMax (1.3.6.1.4.1.25506.2.75.9.1.2.1.4)
read-write
Integer32
Integer32(0..15)
Exponent form of CWmax (ECWmax). The value range of this object varies by chip capability. The value of ECWmax must be greater than the value of ECWmin.
As per the MIB.
hh3cDot11RadioWmmTxoplimit (1.3.6.1.4.1.25506.2.75.9.1.2.1.5)
read-write
Integer32
Integer32(0..65535)
Transmission opportunity limit (TXOP Limit).
As per the MIB.
hh3cDot11RadioWmmNoAck (1.3.6.1.4.1.25506.2.75.9.1.2.1.6)
read-write
TruthValue
true(1),
false(2)
ACK policy for the AC queue.
As per the MIB.
hh3cDot11StationWmmEdcaTable
About this table
Use this table to define EDCA basic parameters for clients.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11WmmRadioIndex and hh3cDot11StationWmmAC.
Object (OID)
Access
Value range
Implementation
hh3cDot11StationWmmAC (1.3.6.1.4.1.25506.2.75.9.1.3.1.1)
not-accessible
Hh3cDot11QosAcType
acbk(1),
acbe(2),
acvi(3),
acvo(4)
AC queue.
As per the MIB.
hh3cDot11StationWmmAifsn (1.3.6.1.4.1.25506.2.75.9.1.3.1.2)
read-write
Integer32
Integer32(2..15)
As per the MIB.
hh3cDot11StationWmmEcwMin (1.3.6.1.4.1.25506.2.75.9.1.3.1.3)
read-write
Integer32
Integer32(0..15)
As per the MIB.
hh3cDot11StationWmmEcwMax (1.3.6.1.4.1.25506.2.75.9.1.3.1.4)
read-write
Integer32
Integer32(0..15)
As per the MIB.
hh3cDot11StationWmmTxoplimit (1.3.6.1.4.1.25506.2.75.9.1.3.1.5)
read-write
Integer32
Integer32(0..65535)
Transmission opportunity limit (TXOP Limit), in units of 32 microseconds. If the value is 0, a client can send only one packet each time it holds the channel.
As per the MIB.
hh3cDot11StationWmmCacEnabled (1.3.6.1.4.1.25506.2.75.9.1.3.1.6)
read-write
TruthValue
true(1),
false(2)
As per the MIB.
hh3cDot11RadioWmmEdcaCfg2Table
About this table
Use this table to define EDCA basic parameters for a radio.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11WMMAPSerialID, hh3cDot11WMMRdId, and hh3cDot11RdWmmAC.
Object (OID)
Access
Value range
Implementation
hh3cDot11WMMAPSerialID (1.3.6.1.4.1.25506.2.75.9.1.5.1.1)
not-accessible
Hh3cDot11ObjectIDType
Hh3cDot11ObjectIDType(0..127)
Serial ID of an AP.
As per the MIB.
hh3cDot11WMMRdId (1.3.6.1.4.1.25506.2.75.9.1.5.1.2)
not-accessible
Hh3cDot11RadioScopeType
Radio ID.
As per the MIB.
hh3cDot11RdWmmAC (1.3.6.1.4.1.25506.2.75.9.1.5.1.3)
not-accessible
Hh3cDot11QosAcType
acbk(1),
acbe(2),
acvi(3),
acvo(4)
AC queue.
As per the MIB.
hh3cDot11RdWmmAifsn (1.3.6.1.4.1.25506.2.75.9.1.5.1.4)
read-write
Integer32
Integer32(1..15)
Arbitration inter-frame spacing number. The value range of this object varies by chip capability.
As per the MIB.
hh3cDot11RdWmmEcwMin (1.3.6.1.4.1.25506.2.75.9.1.5.1.5)
read-write
Integer32
Integer32(0..15)
Exponent form of CWmin. The value range of this object varies by chip capability. The value of ECWmin must be smaller than the value of ECWmax.
As per the MIB.
hh3cDot11RdWmmEcwMax (1.3.6.1.4.1.25506.2.75.9.1.5.1.6)
read-write
Integer32
Integer32(0..15)
Exponent form of CWmax. The value range of this object varies by chip capability. The value of ECWmax must be greater than the value of ECWmin.
As per the MIB.
hh3cDot11RdWmmTxoplimit (1.3.6.1.4.1.25506.2.75.9.1.5.1.7)
read-write
Integer32
Integer32 (0..65535)
As per the MIB.
