12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R54xx)-6W10012-WLAN
14-HH3C-DOT11-SAVI-MIB
14-HH3C-DOT11-SAVI-MIB 87.49 KB
HH3C-DOT11-SAVI-MIB
About this MIB
Use this MIB to manage SAVI objects in WLAN scenarios.
MIB file name
hh3c-dot11-savi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11SAVI(20)
Tabular objects
hh3cDot11SAVIServiceTable
About this table
This table contains information about SAVI operating parameters for each service.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11SAVIServiceIPVersion and hh3cDot11SAVIServiceServiceName.
Object (OID)
Access
Value range
Implementation
hh3cDot11SAVIServiceIPVersion (1.3.6.1.4.1.25506.2.75.20.1.1.1.1)
not-accessible
InetVersion
unknown(0),
ipv4(1),
ipv6(2)
IP version.
As per the MIB.
hh3cDot11SAVIServiceServiceName (1.3.6.1.4.1.25506.2.75.20.1.1.1.2)
not-accessible
OCTET STRING
OCTET STRING(1..255)
Service name.
As per the MIB.
hh3cDot11SAVIServiceValidStatus (1.3.6.1.4.1.25506.2.75.20.1.1.1.3)
read-write
TruthValue
true(1),
false(2)
Whether to check the validity state of the source address.
If you set the attribute value to true,
the interface will verify the source addresses.
As per the MIB.
hh3cDot11SAVIFilteringTable
About this table
This table contains packet filtering information.
CreateNot supported.
Edit/ModifyNot supported.
DeleteNot supported.
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11SAVIFilteringIpType (1.3.6.1.4.1.25506.2.75.20.1.2.1.1)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Source IP address type.
As per the MIB.
hh3cDot11SAVIFilteringServName (1.3.6.1.4.1.25506.2.75.20.1.2.1.2)
not-accessible
OCTET STRING
Service name.
OCTET STRING
hh3cDot11SAVIFilteringIpAddress (1.3.6.1.4.1.25506.2.75.20.1.2.1.3)
not-accessible
InetAddress
InetAddress(0..255)
Source IP address.
As per the MIB.
hh3cDot11SAVIFilteringMacAddr (1.3.6.1.4.1.25506.2.75.20.1.2.1.4)
read-only
MacAddress
MacAddress(6)
Source MAC address.
As per the MIB.
hh3cDot11SAVICountTable
About this table
This table contains statistics on packets dropped due to SAVI check failures.
ReadSupported
Columns
The table indexes are hh3cDot11SAVICountIPVersion and hh3cDot11SAVICountServiceString.
Object (OID)
Access
Value range
Implementation
hh3cDot11SAVICountIPVersion (1.3.6.1.4.1.25506.2.75.20.1.3.1.1)
not-accessible
InetVersion
unknown(0),
ipv4(1),
ipv6(2)
IP version.
As per the MIB.
hh3cDot11SAVICountServiceString (1.3.6.1.4.1.25506.2.75.20.1.3.1.2)
not-accessible
OCTET STRING
Service name.
As per the MIB.
hh3cDot11SAVICountFilterPkts (1.3.6.1.4.1.25506.2.75.20.1.3.1.3)
read-only
Counter64
Standard MIB values.
Number of lost packets.
As per the MIB.
hh3cDot11SAVIStatisTable
About this table
This table contains SAVI statistics.
ReadSupported
Columns
The table indexes are hh3cDot11SAVIStatisAPID and hh3cDot11SAVIStatisRadioID.
Object (OID)
Access
Value range
Implementation
hh3cDot11SAVIStatisAPID (1.3.6.1.4.1.25506.2.75.20.1.4.1.1)
not-accessible
Hh3cDot11ObjectIDType
Hh3cDot11ObjectIDType(0..127)
Unique ID of an AP.
As per the MIB.
hh3cDot11SAVIStatisRadioID (1.3.6.1.4.1.25506.2.75.20.1.4.1.2)
not-accessible
Hh3cDot11RadioScopeType
Radio ID.
As per the MIB.
hh3cDot11SAVIStatisCount (1.3.6.1.4.1.25506.2.75.20.1.4.1.3)
read-only
Counter64
Number of data packets dropped due to SAVI check failures.
As per the MIB.
hh3cDot11SAVIStatisBytes (1.3.6.1.4.1.25506.2.75.20.1.4.1.4)
read-only
Counter64
Number of bytes dropped due to SAVI check failures.
As per the MIB.
hh3cDot11SAVIBindingCount (1.3.6.1.4.1.25506.2.75.20.1.4.1.5)
read-only
Counter64
Number of binding entries.
As per the MIB.
