12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R54xx)-6W10012-WLAN
01-HH3C-DOT11-ROAM-MIB
01-HH3C-DOT11-ROAM-MIB 117.69 KB
HH3C-DOT11-ROAM-MIB
About this MIB
This MIB provides WLAN roaming configuration information.
MIB file name
hh3c-dot11-roam.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11ROAM(10)
Scalar objects
hh3cDot11IntraACRoamingSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.1)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Standard MIB values.
Number of successful intra-AC roamings for the client (the AC data type is Counter32).
As per the MIB.
hh3cDot11InterACRoamingSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.2)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of successful inter-AC roamings for the client (the AC data type is Counter32).
As per the MIB.
hh3cDot11InterACRoamOutSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.3)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of times the client has roamed out among successful inter-AC roamings (the AC data type is Counter32).
As per the MIB.
hh3cDot11InterACRoamInSuccCnt2 (1.3.6.1.4.1.25506.2.75.10.4.4)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of times the client has roamed to the current device among successful inter-AC roamings (the AC data type is Counter32).
As per the MIB.
Tabular objects
hh3cDot11MobGrpTable
About this table
This table defines mobility group configuration parameters.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11MobGrpName.
Object (OID)
Access
Value range
Implementation
hh3cDot11MobGrpName (1.3.6.1.4.1.25506.2.75.10.1.1.1.1)
not-accessible
OCTET STRING
OCTET STRING (1..15)
Name of the mobility group.
As per the MIB.
hh3cdot11MobGrpTunnelType (1.3.6.1.4.1.25506.2.75.10.1.1.1.2)
read-create
Hh3cDot11RoamMobileTunnelType
ipv4(1),
ipv6(2)
Protocol type of the tunnel.
As per the MIB.
hh3cDot11MobGrpSrcIPAddr (1.3.6.1.4.1.25506.2.75.10.1.1.1.3)
read-create
InetAddress
InetAddress(0..255)
Source IP address of the tunnel. The IP type must be the same as that for the hh3cdot11MobGrpTunnelType node. The default value is 0.
As per the MIB.
hh3cDot11MobGrpAuthMode (1.3.6.1.4.1.25506.2.75.10.1.1.1.4)
read-create
Hh3cDot11RoamAuthMode
none(1),
md5(2)
Authentication mode for the IADTP tunnel. This node is used to verify the integrity of IADTP control messages.
As per the MIB.
hh3cDot11MobGrpAuthKey (1.3.6.1.4.1.25506.2.75.10.1.1.1.5)
read-create
OCTET STRING
OCTET STRING(0..16)
Authentication key for the IADTP tunnel. The authentication key is used together with the specified authentication mode. When the value for the hh3cDot11MobGrpAuthMode node is none, you cannot edit this node.
As per the MIB.
hh3cDot11MobGrpEnable (1.3.6.1.4.1.25506.2.75.10.1.1.1.6)
read-create
TruthValue
true(1),
false(2)
Mobility group status.
As per the MIB.
hh3cDot11MobGrpRowStatus (1.3.6.1.4.1.25506.2.75.10.1.1.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Mobility group entry status.
As per the MIB.
hh3cDot11MobGrpMemberTable
About this table
This table defines mobility group member configuration parameters.
CreateSupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11MobGrpName and hh3cDot11MobGrpMemberIpAddr.
Object (OID)
Access
Value range
Implementation
hh3cDot11MobGrpMemberIpAddr (1.3.6.1.4.1.25506.2.75.10.1.2.1.1)
not-accessible
InetAddress
InetAddress(0..255)
IP address of the mobility group member. The value cannot be the same as the source IP address of the mobility group. The address type must be the same as that for the hh3cdot11MobGrpTunnelType node.
As per the MIB.
hh3cDot11MobGrpMemberStatus (1.3.6.1.4.1.25506.2.75.10.1.2.1.2)
read-only
Hh3cDot11RoamIACTPStatus
init(1),
idle(2),
joinRequestWait(3),
joinResponseWait(4),
joinConfirmWait(5),
joinError(6),
run(7)
Mobility group member status.
As per the MIB.
hh3cDot11MobGrpMemberIf (1.3.6.1.4.1.25506.2.75.10.1.2.1.3)
read-only
OCTET STRING
Tunnel interface name of the mobility group member.
As per the MIB.
hh3cDot11MobGrpMemberUpTime (1.3.6.1.4.1.25506.2.75.10.1.2.1.4)
read-only
Integer32
Uptime of the mobility group member after tunnel establishment. If the tunnel is closed, the MemberUpTime value is 0.
As per the MIB.
hh3cDot11MobGrpMemberRowStatus (1.3.6.1.4.1.25506.2.75.10.1.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
As per the MIB.
hh3cDot11RoamInInfoTable
About this table
This table displays information about the client that has roamed from another device.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11RoamClientMAC.
Object (OID)
Access
Value range
Implementation
hh3cDot11RoamClientMAC (1.3.6.1.4.1.25506.2.75.10.2.1.1.1)
not-accessible
MacAddress
MacAddress(6)
MAC address of the client that has roamed to the current device.
As per the MIB.
hh3cDot11RoamInClientBSSID (1.3.6.1.4.1.25506.2.75.10.2.1.1.2)
read-only
MacAddress
MacAddress(6)
BSSID of the AP to which the client is connected.
As per the MIB.
hh3cDot11RoamInClientVlanID (1.3.6.1.4.1.25506.2.75.10.2.1.1.3)
read-only
Integer32
VLAN ID of the client that has roamed to the current device.
As per the MIB.
hh3cDot11RoamInHomeACIPType (1.3.6.1.4.1.25506.2.75.10.2.1.1.4)
read-only
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Address type of the HA.
As per the MIB.
hh3cDot11RoamInHomeACIPAddr (1.3.6.1.4.1.25506.2.75.10.2.1.1.5)
read-only
InetAddress
InetAddress(0..255)
IP address of the HA.
As per the MIB.
hh3cDot11RoamOutInfoTable
About this table
This table displays information about the client that has roamed to another device.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11RoamOutClientBSSID (1.3.6.1.4.1.25506.2.75.10.2.2.1.1)
read-only
MacAddress
MacAddress(6)
As per the MIB.
hh3cDot11RoamOutClientVlanID (1.3.6.1.4.1.25506.2.75.10.2.2.1.2)
read-only
Integer32
VLAN ID of the client that has roamed to another device.
As per the MIB.
hh3cDot11RoamOutForeignACIPType (1.3.6.1.4.1.25506.2.75.10.2.2.1.3)
read-only
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Address type of the FA.
As per the MIB.
hh3cDot11RoamOutForeignACIPAddr (1.3.6.1.4.1.25506.2.75.10.2.2.1.4)
read-only
InetAddress
InetAddress(0..255)
IP address of the FA.
As per the MIB.
hh3cDot11RoamOutClientUpTime (1.3.6.1.4.1.25506.2.75.10.2.2.1.5)
read-only
Integer32
Duration that the roam-out client has been connected with the FA.
As per the MIB.
hh3cDot11RoamTrackTable
About this table
This table contains the specified client information on the HA of the client.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11RoamTrackIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11RoamTrackIndex (1.3.6.1.4.1.25506.2.75.10.2.3.1.1)
not-accessible
Integer32
Index of this entry.
As per the MIB.
hh3cDot11RoamTrackClientMAC (1.3.6.1.4.1.25506.2.75.10.2.3.1.2)
read-only
MacAddress
MacAddress(6)
MAC address of the client that has roamed to another device.
As per the MIB.
hh3cDot11RoamTrackBSSID (1.3.6.1.4.1.25506.2.75.10.2.3.1.3)
read-only
MacAddress
MacAddress(6)
As per the MIB.
hh3cDot11RoamTrackUpTime (1.3.6.1.4.1.25506.2.75.10.2.3.1.4)
read-only
Integer32
Association duration or online duration of the client that has roamed to another device.
As per the MIB.
hh3cDot11RoamTrackACIPType (1.3.6.1.4.1.25506.2.75.10.2.3.1.5)
read-only
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
As per the MIB.
hh3cDot11RoamTrackACIPAddr (1.3.6.1.4.1.25506.2.75.10.2.3.1.6)
read-only
InetAddress
InetAddress(0..255)
As per the MIB.
