12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R54xx)-6W10012-WLAN
15-HH3C-DOT11-WM2U-MIB
15-HH3C-DOT11-WM2U-MIB 120.98 KB
HH3C-DOT11-WM2U-MIB
About this MIB
Use this MIB to configure and obtain WLAN multicast optimization information.
MIB file name
hh3c-dot11-wm2u.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11WM2U(16)
Tabular objects
hh3cDot11WM2USrvTempStatesTable
About this table
Use this table to configure the WLAN multicast optimization state.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11WM2USrvTempName and hh3cDot11WM2USrvTempAddressType.
Object (OID)
Access
Value range
Implementation
hh3cDot11WM2USrvTempName (1.3.6.1.4.1.25506.2.75.16.1.1.1.1)
not-accessible
DisplayString
OCTET STRING (1..63)
Service template name.
As per the MIB.
hh3cDot11WM2USrvTempAddressType (1.3.6.1.4.1.25506.2.75.16.1.1.1.2)
not-accessible
InetAddressType
Standard MIB values.
Address type.
As per the MIB.
hh3cDot11WM2USrvTempState (1.3.6.1.4.1.25506.2.75.16.1.1.1.3)
read-write
INTEGER
enabled(1), disabled(2)
As per the MIB.
hh3cDot11WM2UAgingTimeTable
About this table
Use this table to set the aging time for multicast optimization entries.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11WM2UAgingAddressType.
Object (OID)
Access
Value range
Implementation
hh3cDot11WM2UAgingAddressType (1.3.6.1.4.1.25506.2.75.16.1.2.1.1)
not-accessible
InetAddressType
Address type.
As per the MIB.
hh3cDot11WM2UAgingTime (1.3.6.1.4.1.25506.2.75.16.1.2.1.2)
read-write
Unsigned32
Unsigned32 (60..3600)
Aging time in seconds.
As per the MIB.
hh3cDot11WM2UAgingTimeState (1.3.6.1.4.1.25506.2.75.16.1.2.1.3)
read-write
INTEGER
Aging time configuration state.
As per the MIB.
hh3cDot11WM2UClientEtyLmtTable
About this table
Use this table to set the limit for multicast optimization entries per client.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11WM2UClientEtyAddrType.
Object (OID)
Access
Value range
Implementation
hh3cDot11WM2UClientEtyAddrType (1.3.6.1.4.1.25506.2.75.16.1.3.1.1)
not-accessible
InetAddressType
Address type.
As per the MIB.
hh3cDot11WM2UClientValue (1.3.6.1.4.1.25506.2.75.16.1.3.1.2)
read-write
Unsigned32
Unsigned32 (8..1024)
Maximum number of multicast optimization entries per client.
As per the MIB.
hh3cDot11WM2UClientState (1.3.6.1.4.1.25506.2.75.16.1.3.1.3)
read-write
INTEGER
Limit configuration state.
As per the MIB.
hh3cDot11WM2UGlobalEtyLmtTable
About this table
Use this table to set the limit for multicast optimization entries.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11WM2UGlobalEtyAddrType.
Object (OID)
Access
Value range
Implementation
hh3cDot11WM2UGlobalEtyAddrType (1.3.6.1.4.1.25506.2.75.16.1.4.1.1)
not-accessible
InetAddressType
Address type.
As per the MIB.
hh3cDot11WM2UGlobalValue (1.3.6.1.4.1.25506.2.75.16.1.4.1.2)
read-write
Unsigned32
Unsigned32 (8..8192)
Maximum number of multicast optimization entries.
As per the MIB.
hh3cDot11WM2UGlobalState (1.3.6.1.4.1.25506.2.75.16.1.4.1.3)
read-write
INTEGER
As per the MIB.
hh3cDot11WM2UFwdClientLmtsTable
About this table
Use this table to configure a multicast optimization policy.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11WM2UFwdClientAddrType.
Object (OID)
Access
Value range
Implementation
hh3cDot11WM2UFwdClientAddrType (1.3.6.1.4.1.25506.2.75.16.1.5.1.1)
not-accessible
InetAddressType
Address type.
As per the MIB.
hh3cDot11WM2UFwdClientValue (1.3.6.1.4.1.25506.2.75.16.1.5.1.2)
read-write
Unsigned32
Maximum number of clients that WLAN multicast optimization supports.
As per the MIB.
hh3cDot11WM2UFwdClientAction (1.3.6.1.4.1.25506.2.75.16.1.5.1.3)
read-write
Unsigned32
drop(1),
unicast(2),
multicast(3)
Action to take when the maximum number of clients is reached.
As per the MIB.
hh3cDot11WM2UFwdClientState (1.3.6.1.4.1.25506.2.75.16.1.5.1.4)
Write Rate
INTEGER
As per the MIB.
hh3cDot11WM2URateLimitsTable
About this table
Use this table to set the maximum number of multicast protocol packets that can be received from clients within the specified period.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11WM2URateLmtsAddrType.
Object (OID)
Access
Value range
Implementation
hh3cDot11WM2URateLmtsAddrType (1.3.6.1.4.1.25506.2.75.16.1.6.1.1)
not-accessible
InetAddressType
Address type.
As per the MIB.
hh3cDot11WM2UInterval (1.3.6.1.4.1.25506.2.75.16.1.6.1.2)
read-write
Unsigned32
Interval for calculating the incoming multicast protocol packet rate, in seconds.
As per the MIB.
hh3cDot11WM2UThreshold (1.3.6.1.4.1.25506.2.75.16.1.6.1.3)
read-write
INTEGER
Unsigned32 (1..100000)
Threshold on the number of incoming multicast protocol packets over the specified interval.
As per the MIB.
hh3cDot11WM2URateLmtsState (1.3.6.1.4.1.25506.2.75.16.1.6.1.4)
read-write
INTEGER
Packet rate configuration state.
As per the MIB.
hh3cDot11WM2UClientsTable
About this table
Use this table to obtain client information in WLAN multicast optimization entries.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11WM2UClientMacAddress.
Object (OID)
Access
Value range
Implementation
hh3cDot11WM2UClientMacAddress (1.3.6.1.4.1.25506.2.75.16.2.1.1.1)
not-accessible
MacAddress
OCTET STRING (6)
MAC address of a client.
As per the MIB.
hh3cDot11WM2UDuration (1.3.6.1.4.1.25506.2.75.16.2.1.1.2)
read-only
TimeTicks
Amount of time that has elapsed since the client was discovered.
As per the MIB.
hh3cDot11WM2UGroupNum4 (1.3.6.1.4.1.25506.2.75.16.2.1.1.3)
read-only
Unsigned32
Number of IGMP multicast groups that the client has joined.
As per the MIB.
hh3cDot11WM2UGroupNum6 (1.3.6.1.4.1.25506.2.75.16.2.1.1.4)
read-only
Unsigned32
Number of MLD multicast groups that the client has joined.
As per the MIB.
hh3cDot11WM2UGroupsTable
About this table
Use this table to obtain multicast group information in WLAN multicast optimization entries.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11WM2UGrpMacAddress, hh3cDot11WM2UGrpAddressType, and hh3cDot11WM2UAddress.
Object (OID)
Access
Value range
Implementation
hh3cDot11WM2UGrpMacAddress (1.3.6.1.4.1.25506.2.75.16.2.2.1.1)
not-accessible
MacAddress
OCTET STRING (6)
As per the MIB.
hh3cDot11WM2UGrpAddressType (1.3.6.1.4.1.25506.2.75.16.2.2.1.2)
not-accessible
InetAddressType
Address type.
As per the MIB.
hh3cDot11WM2UAddress (1.3.6.1.4.1.25506.2.75.16.2.2.1.3)
not-accessible
InetAddress
Multicast group address.
As per the MIB.
hh3cDot11WM2UVersion (1.3.6.1.4.1.25506.2.75.16.2.2.1.4)
read-only
INTEGER
igmpv1orv2(1),
igmpv3(2),
mldv1(3),
mldv2(4)
Version of the multicast group.
As per the MIB.
hh3cDot11WM2UMode (1.3.6.1.4.1.25506.2.75.16.2.2.1.5)
read-only
INTEGER
include(1),
exclude(2)
WLAN multicast optimization mode of the multicast group.
As per the MIB.
hh3cDot11WM2USourceNum (1.3.6.1.4.1.25506.2.75.16.2.2.1.6)
read-only
Unsigned32
Number of multicast sources.
As per the MIB.
hh3cDot11WM2UGrpDurLastRefTime (1.3.6.1.4.1.25506.2.75.16.2.2.1.7)
read-only
TimeTicks
Amount of time that has elapsed since the multicast optimization entry was created.
As per the MIB.
hh3cDot11WM2USourcesTable
About this table
Use this table to obtain multicast source information in WLAN multicast optimization entries.
CreateNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cDot11WM2USrcMacAddress, hh3cDot11WM2USrcMacAddress, hh3cDot11WM2UGroupAddress, and hh3cDot11WM2USourceAddress.
Object (OID)
Access
Value range
Implementation
hh3cDot11WM2USrcMacAddress (1.3.6.1.4.1.25506.2.75.16.2.3.1.1)
not-accessible
MacAddress
OCTET STRING (6)
As per the MIB.
hh3cDot11WM2USrcMacAddress (1.3.6.1.4.1.25506.2.75.16.2.3.1.2)
not-accessible
InetAddressType
Address type.
As per the MIB.
hh3cDot11WM2UGroupAddress (1.3.6.1.4.1.25506.2.75.16.2.3.1.3)
not-accessible
InetAddress
As per the MIB.
hh3cDot11WM2USourceAddress (1.3.6.1.4.1.25506.2.75.16.2.3.1.4)
not-accessible
InetAddress
Multicast source address.
As per the MIB.
hh3cDot11WM2USrcDurLastRefTime (1.3.6.1.4.1.25506.2.75.16.2.3.1.5)
read-only
TimeTicks
Amount of time that has elapsed since the multicast source address was added to the multicast optimization entry.
As per the MIB.
